[petsc-users] Preconditioned residuals for FGMRES
Jed Brown jed at jedbrown.org
Fri Jun 22 16:02:13 CDT 2018
Matthew Knepley <knepley at gmail.com> writes:
> On Fri, Jun 22, 2018 at 1:47 PM Boyce Griffith <griffith at cims.nyu.edu>
> wrote:
>> Can you set up the preconditioner so that you can just use GMRES?
> So I think what Boyce is saying is, can't you fix the number of iterates in
> the inner Krylov solvers so that it becomes a linear
> operator and you can use GMRES?
A fixed number of Krylov iterations is not a linear operation.
A fixed number of Chebyshev iterations (or other method that applies a
constant polynomial) is linear.
