[petsc-users] Poor weak scaling when solving successive linearsystems
Michael Becker michael.becker at physik.uni-giessen.de
Fri Jun 15 02:26:57 CDT 2018
Hello,
thanks again for your efforts.
> Boundary processors have less nonzeros than interior processors.
Doesn't that mean that boundary processors have less work to do than the
others? Or does this affect the size of the coarse grids?
I know that defining the outermost nodes as boundary is not the most
efficient way in this particular case (using Dirichlet boundary
conditions on a smaller grid would do the same), but I need the solver
to be able to handle arbitrarily shaped boundaries inside the domain,
e.g. to calculate the potential inside a spherical capacitor (constant
potential on the boundaries, charge distribution inside). Is there a
better way to do that?
Michael
Am 12.06.2018 um 22:07 schrieb Junchao Zhang:
> Hello, Michael,
>   Sorry for the delay. I am actively doing experiments with your
> example code. I tested it on a cluster with 36 cores/node. To
> distribute MPI ranks evenly among nodes, I used 216  and 1728 ranks
> instead of 125, 1000.  So far I have these findings:
>  1) It is not a strict weak scaling test since with 1728 ranks it
> needs more KPS iterations, and more calls to MatSOR etc functions.
>  2) If I use half cores per node but double the nodes (keep MPI ranks
> the same), the performance is 60~70% better. It implies memory
> bandwidth plays an important role in performance.
>  3) I find you define the outermost two layers of nodes of the grid as
> boundary. Boundary processors have less nonzeros than interior
> processors. It is a source of load imbalance. At coarser grids, it
> gets worse. But I need to confirm this caused the poor scaling and big
> vecscatter delays in the experiment.
>  Thanks.
> --Junchao Zhang
> On Tue, Jun 12, 2018 at 12:42 AM, Michael Becker
> <michael.becker at physik.uni-giessen.de
> <mailto:michael.becker at physik.uni-giessen.de>> wrote:
>     Hello,
>     any new insights yet?
>     Michael
>     Am 04.06.2018 um 21:56 schrieb Junchao Zhang:
>>     Miachael,  I can compile and run you test.  I am now profiling
>>     it. Thanks.
>>     --Junchao Zhang
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180615/6faa0ea8/attachment.html>
