[petsc-users] MAT_NEW_NONZERO_LOCATIONS working?
    Hong
    hzhang at mcs.anl.gov
    Mon Jun  4 09:54:28 CDT 2018
On Mon, Jun 4, 2018 at 1:03 PM, Jean-Yves LExcellent <
Jean-Yves.L.Excellent at ens-lyon.fr> wrote:
> Thanks for the details of your needs.
> For the first application, the sparse RHS feature with distributed
> solution should effectively be fine.
I'll add parallel support of this feature in petsc after I'm back the ANL
after June 14th.
Hong
> For the second one, a future distributed RHS feature (not currently
> available in MUMPS) might help if the centralized sparse RHS is too
> memory consuming, depending on the size of B1.
> Regards,
> Jean-Yves, for the MUMPS developers
>  I want to  invert a rather large sparse matrix for this using a sparse
> rhs with centralized input would be ok as long as the solution is
> distributed.
> and the second application I have in mind is solving a system of the from
> AX=B where A and B are sparse and B is given by a block matrix of the form
> B=[B1 0, 0 0] where B1 is dense but the dimension is (much) smaller than
> that of the whole matrix B.
> Marius:
> Current PETSc interface supports sequential sparse multiple right-hand
> side, but not distributed.
> It turns out that mumps does not support distributed sparse multiple
> right-hand sides at
> the moment (see attached email).
> Jean-Yves invites you to communicate with him directly.
> Let me know what we can help on this matter,
> e.g., add support for parallel implementation of sparse multiple
> right-hand side with
> centralized rhs input?
> Hong
> Jean-Yves LExcellent <Jean-Yves.L.Excellent at ens-lyon.fr>
> 5:14 AM (3 hours ago)
> to Hong, mumps-dev
> Hello,
> We do not support distributed sparse multiple right-hand sides at
> the moment. From the feedback we have from applications, the
> right-hand sides are often very sparse, and having them distributed
> did not seem critical.
> Since we are specifying a distributed right-hand sides feature at the
> moment, could you let us know in more detail the need regarding
> distributed sparse right-hand side (e.g., do all columns have the same
> nonzero structure in that case) or put us in contact with the user who
> needs this?
> Thanks,
> Jean-Yves and Patrick
>> Thanks a lot guys, very helpful.
>> I see MUMPS http://mumps.enseeiht.fr/
>> Sparse multiple right-hand side, distributed solution; Exploitation of
>> sparsity in the right-hand sidesPETSc interface computes mumps distributed
>> solution as default (this is not new) (ICNTL(21) = 1)
>> I will add support for Sparse multiple right-hand side.
>> Hong
>> On Thu, May 31, 2018 at 11:25 AM, Smith, Barry F. <bsmith at mcs.anl.gov
>> [mailto:bsmith at mcs.anl.gov]> wrote:
>>   Hong,
>>     Can you see about adding support for distributed right hand side?
>>     Thanks
>>       Barry
>> > On May 31, 2018, at 2:37 AM, Marius Buerkle <mbuerkle at web.de[mailto:
>> mbuerkle at web.de]> wrote:
>> > The fix for MAT_NEW_NONZERO_LOCATIONS, thanks again.
>> > I have yet another question, sorry. The recent version of MUMPS
>> supports distributed and sparse RHS is there any chance that this will be
>> supported in PETSc in the near future?
>> >> On May 30, 2018, at 6:55 PM, Marius Buerkle <mbuerkle at web.de[mailto:
>> >> Thanks for the quick fix, I will test it and report back.
>> >> I have another maybe related question, if MAT_NEW_NONZERO_LOCATIONS is
>> true and let's say 1 new nonzero position is created it does not allocated
>> 1 but several new nonzeros but only use 1.
>> > Correct
>> >> I think that is normal, right?
>> > Yes
>> >> But, at least as far as I understand the manual, a subsequent call of
>> mat assemble with
>> >> MAT_FINAL_ASSEMBLY should compress out the unused allocations and
>> release the memory, is this correct?
>> > It "compresses it out" (by shifting all the nonzero entries to the
>> beginning of the internal i, j, and a arrays), but does NOT release any
>> memory. Since the values are stored in one big contiguous array (obtained
>> with a single malloc) it cannot just free part of the array, so the extra
>> locations just sit harmlessly at the end if the array unused.
>> >> If so, this did not work for me, even after doing
>> >> MAT_FINAL_ASSEMBLY the unused nonzero allocations remain. Is this
>> normal?
>> > Yes,
>> > Barry
>> >>> Fixed in the branch barry/fix-mat-new-nonzero-locations/maint
>> >>> Once this passes testing it will go into the maint branch and then
>> the next patch release but you can use it now in the branch
>> >>> Thanks for the report and reproducible example
>> >>> Barry
>> >>>> On May 29, 2018, at 7:51 PM, Marius Buerkle <mbuerkle at web.de[mailto:
>> >>>> Sure, I made a small reproducer, it is Fortran though I hope that is
>> ok. If MAT_NEW_NONZERO_LOCATIONS is set to false I get an error, if it is
>> set to true the new nonzero element is inserted, if
>> MAT_NEW_NONZERO_LOCATIONS is false and either MAT_NEW_NONZERO_LOCATION_ERR
>> or MAT_NEW_NONZERO_ALLOCATION_ERR is set to false afterwards then the new
>> nonzero is also created without an error, but if MAT_NEW_NONZERO_LOCATIONS
>> is set to false after MAT_NEW_NONZERO_LOCATION_ERR/MAT_NEW_NONZERO_ALLOCATION_ERR
>> have been set to false I get an error again.
>> >>>> program newnonzero
>> >>>> #include <petsc/finclude/petscmat.h>
>> >>>> use petscmat
>> >>>> implicit none
>> >>>> Mat :: A
>> >>>> PetscInt :: dnnz,onnz,n,m,idxm(1),idxn(1),nl1,nl2
>> >>>> PetscScalar :: v(1)
>> >>>> PetscReal :: info(MAT_INFO_SIZE)
>> >>>> PetscErrorCode :: ierr
>> >>>> integer :: nproc,iproc,i
>> >>>> call PetscInitialize(PETSC_NULL_CHARACTER,ierr)
>> >>>> call MPI_COMM_SIZE(PETSC_COMM_WORLD, nproc,ierr)
>> >>>> call MPI_Comm_rank( PETSC_COMM_WORLD, iproc, ierr )
>> >>>> n=3
>> >>>> m=n
>> >>>> call MatCreateAIJ(PETSC_COMM_WORLD,PETSC_DECIDE,PETSC_DECIDE,n,m,
>> 1,PETSC_NULL_INTEGER,0,PETSC_NULL_INTEGER,A,ierr)
>> >>>> call MatGetOwnershipRange(A,nl1,nl2,ierr)
>> >>>> do i=nl1,nl2-1
>> >>>> idxn(1)=i
>> >>>> idxm(1)=i
>> >>>> v(1)=1d0
>> >>>> call MatSetValues(A,1,idxn,1,idxm, v,INSERT_VALUES,ierr)
>> >>>> end do
>> >>>> call MatAssemblyBegin(A,MAT_FINAL_ASSEMBLY,ierr)
>> >>>> call MatAssemblyEnd(A,MAT_FINAL_ASSEMBLY,ierr)
>> >>>> call MatSetOption(A,MAT_NEW_NONZERO_LOCATIONS,PETSC_FALSE,ierr)
>> >>>> !~ call MatSetOption(A,MAT_NEW_NONZERO_LOCATION_ERR,PETSC_
>> FALSE,ierr)
>> >>>> !~ call MatSetOption(A,MAT_NEW_NONZERO_ALLOCATION_ERR
>> ,PETSC_FALSE,ierr)
>> >>>> !~ call MatSetOption(A,MAT_NEW_NONZERO_LOCATIONS,PETSC_FALSE,ierr)
>> >>>> idxn(1)=0
>> >>>> idxm(1)=n-1
>> >>>> if ((idxn(1).ge.nl1).and.(idxn(1).le.nl2-1)) then
>> >>>> v(1)=2d0
>> >>>> end if
>> >>>> v(1)=2d0
>> >>>> call MatGetValues(A,1,idxn,1,idxm, v,ierr)
>> >>>> write(6,*) v
>> >>>> end if
>> >>>> call PetscFinalize(ierr)
>> >>>> end program newnonzero
>> >>>> $ mpiexec.hydra -n 3 ./a.out
>> >>>> [0]PETSC ERROR: --------------------- Error Message
>> >>>> [0]PETSC ERROR: Argument out of range
>> >>>> [0]PETSC ERROR: Inserting a new nonzero at global row/column (0, 2)
>> into matrix
>> >>>> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/
>> documentation/faq.html[http://www.mcs.anl.gov/petsc/
>> documentation/faq.html] for trouble shooting.
>> >>>> [0]PETSC ERROR: Petsc Release Version 3.9.2, May, 20, 2018
>> >>>> [0]PETSC ERROR: ./a.out on a named tono-hpc1 by marius Wed May 30
>> 09:42:40 2018
>> >>>> [0]PETSC ERROR: Configure options --prefix=/home/marius/prog/petsc/3.9.2
>> --download-elemental=yes --download-metis=yes --download-parmetis=yes
>> --download-mumps=yes --with-scalapack-lib="/home/
>> marius/intel/compilers_and_libraries_2018.2.199/linux/
>> mkl/lib/intel64/libmkl_scalapack_lp64.a -Wl,--start-group
>> /home/marius/intel/compilers_and_libraries_2018.2.199/
>> linux/mkl/lib/intel64/libmkl_intel_lp64.a /home/marius/intel/compilers_
>> and_libraries_2018.2.199/linux/mkl/lib/intel64/libmkl_sequential.a
>> linux/mkl/lib/intel64/libmkl_core.a /home/marius/intel/compilers_
>> and_libraries_2018.2.199/linux/mkl/lib/intel64/libmkl_blacs_intelmpi_lp64.a
>> -Wl,--end-group -lpthread -lm -ldl" --FC=mpiifort --CC=mpicc --CXX=mpicxx
>> --with-scalar-type=complex --with-mpi-dir= --with-blaslapack-lib="/home/
>> -Wl,--end-group -lpthread -lm -ldl" --with-cxx-dialect=C++11
>> --download-superlu_dist=yes --download-ptscotch=yes --with-x
>> --with-debugging=1 --download-superlu=yes --with-mkl_cpardiso=1
>> --with-mkl_pardiso=1 --with-scalapack=1
>> >>>> [0]PETSC ERROR: #1 MatSetValues_MPIAIJ() line 607 in
>> /home/marius/prog/petsc/petsc-3.9.2/src/mat/impls/aij/mpi/mpiaij.c
>> >>>> [0]PETSC ERROR: #2 MatSetValues() line 1312 in
>> /home/marius/prog/petsc/petsc-3.9.2/src/mat/interface/matrix.c
>> >>>> (0.000000000000000E+000,0.000000000000000E+000)
>> >>>> Please send complete error message; type of matrix used etc. Ideally
>> code that demonstrates the problem.
>> >>>> Barry
>> >>>>> On May 29, 2018, at 3:31 AM, Marius Buerkle <mbuerkle at web.de
>> [mailto:mbuerkle at web.de]> wrote:
>> >>>>> Hi,
>> >>>>> I tried to set MAT_NEW_NONZERO_LOCATIONS to false, as far as I
>> understood MatSetValues should simply ignore entries which would give rise
>> to new nonzero values not creating a new entry and not cause an error, but
>> I get "[1]PETSC ERROR: Inserting a new nonzero at global row/column". Is
>> this option supposed to work or not?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180604/510fa83a/attachment-0001.html>
