[petsc-users] MAT_NEW_NONZERO_LOCATIONS working?
Jean-Yves LExcellent
Jean-Yves.L.Excellent at ens-lyon.fr
Mon Jun 4 07:03:48 CDT 2018
Thanks for the details of your needs.
For the first application, the sparse RHS feature with distributed
solution should effectively be fine.
For the second one, a future distributed RHS feature (not currently
available in MUMPS) might help if the centralized sparse RHS is too
memory consuming, depending on the size of B1.
Jean-Yves, for the MUMPS developers
> I want to invert a rather large sparse matrix for this using a
> sparse rhs with centralized input would be ok as long as the solution
> is distributed.
> and the second application I have in mind is solving a system of the
> from AX=B where A and B are sparse and B is given by a block matrix of
> the form B=[B1 0, 0 0] where B1 is dense but the dimension is (much)
> smaller than that of the whole matrix B.
> Marius:
> Current PETSc interface supports sequential sparse multiple right-hand
> side, but not distributed.
> It turns out that mumps does not support distributed sparse multiple
> right-hand sides at
> the moment (see attached email).
> Jean-Yves invites you to communicate with him directly.
> Let me know what we can help on this matter,
> e.g., add support for parallel implementation of sparse multiple
> right-hand side with
> centralized rhs input?
> Hong
> Jean-Yves LExcellent<Jean-Yves.L.Excellent at ens-lyon.fr
> <mailto:Jean-Yves.L.Excellent at ens-lyon.fr>>
> 5:14 AM (3 hours ago)
> toHong,mumps-dev
> Hello,
> We do not support distributed sparse multiple right-hand sides at
> the moment. From the feedback we have from applications, the
> right-hand sides are often very sparse, and having them distributed
> did not seem critical.
> Since we are specifying a distributed right-hand sides feature at the
> moment, could you let us know in more detail the need regarding
> distributed sparse right-hand side (e.g., do all columns have the same
> nonzero structure in that case) or put us in contact with the user who
> needs this?
> Thanks,
> Jean-Yves and Patrick
> Thanks a lot guys, very helpful.
> I see MUMPS http://mumps.enseeiht.fr/
> Sparse multiple right-hand side, distributed solution;
> Exploitation of sparsity in the right-hand sidesPETSc interface
> computes mumps distributed solution as default (this is not new)
> (ICNTL(21) = 1)
> I will add support for Sparse multiple right-hand side.
> Hong
> On Thu, May 31, 2018 at 11:25 AM, Smith, Barry F.
> <bsmith at mcs.anl.gov
> <mailto:bsmith at mcs.anl.gov>[mailto:bsmith at mcs.anl.gov
> <mailto:bsmith at mcs.anl.gov>]> wrote:
> Hong,
> Can you see about adding support for distributed right hand side?
> Thanks
> Barry
> > On May 31, 2018, at 2:37 AM, Marius Buerkle <mbuerkle at web.de
> <mailto:mbuerkle at web.de>[mailto:mbuerkle at web.de
> <mailto:mbuerkle at web.de>]> wrote:
> > The fix for MAT_NEW_NONZERO_LOCATIONS, thanks again.
> > I have yet another question, sorry. The recent version of MUMPS
> supports distributed and sparse RHS is there any chance that this
> will be supported in PETSc in the near future?
> >> On May 30, 2018, at 6:55 PM, Marius Buerkle <mbuerkle at web.de
> >> Thanks for the quick fix, I will test it and report back.
> >> I have another maybe related question, if
> MAT_NEW_NONZERO_LOCATIONS is true and let's say 1 new nonzero
> position is created it does not allocated 1 but several new
> nonzeros but only use 1.
> > Correct
> >> I think that is normal, right?
> > Yes
> >> But, at least as far as I understand the manual, a subsequent
> call of mat assemble with
> >> MAT_FINAL_ASSEMBLY should compress out the unused allocations
> and release the memory, is this correct?
> > It "compresses it out" (by shifting all the nonzero entries to
> the beginning of the internal i, j, and a arrays), but does NOT
> release any memory. Since the values are stored in one big
> contiguous array (obtained with a single malloc) it cannot just
> free part of the array, so the extra locations just sit harmlessly
> at the end if the array unused.
> >> If so, this did not work for me, even after doing
> >> MAT_FINAL_ASSEMBLY the unused nonzero allocations remain. Is
> this normal?
> > Yes,
> > Barry
> >>> Fixed in the branch barry/fix-mat-new-nonzero-locations/maint
> >>> Once this passes testing it will go into the maint branch and
> then the next patch release but you can use it now in the branch
> >>> Thanks for the report and reproducible example
> >>> Barry
> >>>> On May 29, 2018, at 7:51 PM, Marius Buerkle <mbuerkle at web.de
> >>>> Sure, I made a small reproducer, it is Fortran though I hope
> that is ok. If MAT_NEW_NONZERO_LOCATIONS is set to false I get an
> error, if it is set to true the new nonzero element is inserted,
> if MAT_NEW_NONZERO_LOCATIONS is false and either
> MAT_NEW_NONZERO_LOCATION_ERR or MAT_NEW_NONZERO_ALLOCATION_ERR is
> set to false afterwards then the new nonzero is also created
> without an error, but if MAT_NEW_NONZERO_LOCATIONS is set to false
> after MAT_NEW_NONZERO_LOCATION_ERR/MAT_NEW_NONZERO_ALLOCATION_ERR
> have been set to false I get an error again.
> >>>> program newnonzero
> >>>> #include <petsc/finclude/petscmat.h>
> >>>> use petscmat
> >>>> implicit none
> >>>> Mat :: A
> >>>> PetscInt :: dnnz,onnz,n,m,idxm(1),idxn(1),nl1,nl2
> >>>> PetscScalar :: v(1)
> >>>> PetscReal :: info(MAT_INFO_SIZE)
> >>>> PetscErrorCode :: ierr
> >>>> integer :: nproc,iproc,i
> >>>> call PetscInitialize(PETSC_NULL_CHARACTER,ierr)
> >>>> call MPI_COMM_SIZE(PETSC_COMM_WORLD, nproc,ierr)
> >>>> call MPI_Comm_rank( PETSC_COMM_WORLD, iproc, ierr )
> >>>> n=3
> >>>> m=n
> >>>> call
> MatCreateAIJ(PETSC_COMM_WORLD,PETSC_DECIDE,PETSC_DECIDE,n,m,1,PETSC_NULL_INTEGER,0,PETSC_NULL_INTEGER,A,ierr)
> >>>> call MatGetOwnershipRange(A,nl1,nl2,ierr)
> >>>> do i=nl1,nl2-1
> >>>> idxn(1)=i
> >>>> idxm(1)=i
> >>>> v(1)=1d0
> >>>> call MatSetValues(A,1,idxn,1,idxm, v,INSERT_VALUES,ierr)
> >>>> end do
> >>>> call MatAssemblyBegin(A,MAT_FINAL_ASSEMBLY,ierr)
> >>>> call MatAssemblyEnd(A,MAT_FINAL_ASSEMBLY,ierr)
> >>>> call MatSetOption(A,MAT_NEW_NONZERO_LOCATIONS,PETSC_FALSE,ierr)
> >>>> !~ call
> MatSetOption(A,MAT_NEW_NONZERO_LOCATION_ERR,PETSC_FALSE,ierr)
> >>>> !~ call MatSetOption(A,MAT_NEW_NONZERO_ALLOCATION_ERR
> ,PETSC_FALSE,ierr)
> >>>> !~ call
> >>>> idxn(1)=0
> >>>> idxm(1)=n-1
> >>>> if ((idxn(1).ge.nl1).and.(idxn(1).le.nl2-1)) then
> >>>> v(1)=2d0
> >>>> end if
> >>>> v(1)=2d0
> >>>> call MatGetValues(A,1,idxn,1,idxm, v,ierr)
> >>>> write(6,*) v
> >>>> end if
> >>>> call PetscFinalize(ierr)
> >>>> end program newnonzero
> >>>> $ mpiexec.hydra -n 3 ./a.out
> >>>> [0]PETSC ERROR: --------------------- Error Message
> >>>> [0]PETSC ERROR: Argument out of range
> >>>> [0]PETSC ERROR: Inserting a new nonzero at global row/column
> (0, 2) into matrix
> >>>> [0]PETSC ERROR: See
> http://www.mcs.anl.gov/petsc/documentation/faq.html[http://www.mcs.anl.gov/petsc/documentation/faq.html]
> for trouble shooting.
> >>>> [0]PETSC ERROR: Petsc Release Version 3.9.2, May, 20, 2018
> >>>> [0]PETSC ERROR: ./a.out on a named tono-hpc1 by marius Wed
> May 30 09:42:40 2018
> >>>> [0]PETSC ERROR: Configure options
> --prefix=/home/marius/prog/petsc/3.9.2 --download-elemental=yes
> --download-metis=yes --download-parmetis=yes --download-mumps=yes
> --with-scalapack-lib="/home/marius/intel/compilers_and_libraries_2018.2.199/linux/mkl/lib/intel64/libmkl_scalapack_lp64.a
> -Wl,--start-group
> /home/marius/intel/compilers_and_libraries_2018.2.199/linux/mkl/lib/intel64/libmkl_intel_lp64.a
> /home/marius/intel/compilers_and_libraries_2018.2.199/linux/mkl/lib/intel64/libmkl_sequential.a
> /home/marius/intel/compilers_and_libraries_2018.2.199/linux/mkl/lib/intel64/libmkl_core.a
> /home/marius/intel/compilers_and_libraries_2018.2.199/linux/mkl/lib/intel64/libmkl_blacs_intelmpi_lp64.a
> -Wl,--end-group -lpthread -lm -ldl" --FC=mpiifort --CC=mpicc
> --CXX=mpicxx --with-scalar-type=complex --with-mpi-dir=
> --with-blaslapack-lib="/home/marius/intel/compilers_and_libraries_2018.2.199/linux/mkl/lib/intel64/libmkl_scalapack_lp64.a
> -Wl,--start-group
> -Wl,--end-group -lpthread -lm -ldl" --with-cxx-dialect=C++11
> --download-superlu_dist=yes --download-ptscotch=yes --with-x
> --with-debugging=1 --download-superlu=yes --with-mkl_cpardiso=1
> --with-mkl_pardiso=1 --with-scalapack=1
> >>>> [0]PETSC ERROR: #1 MatSetValues_MPIAIJ() line 607 in
> /home/marius/prog/petsc/petsc-3.9.2/src/mat/impls/aij/mpi/mpiaij.c
> >>>> [0]PETSC ERROR: #2 MatSetValues() line 1312 in
> /home/marius/prog/petsc/petsc-3.9.2/src/mat/interface/matrix.c
> >>>> (0.000000000000000E+000,0.000000000000000E+000)
> >>>> Please send complete error message; type of matrix used etc.
> Ideally code that demonstrates the problem.
> >>>> Barry
> >>>>> On May 29, 2018, at 3:31 AM, Marius Buerkle <mbuerkle at web.de
> >>>>> Hi,
> >>>>> I tried to set MAT_NEW_NONZERO_LOCATIONS to false, as far as
> I understood MatSetValues should simply ignore entries which would
> give rise to new nonzero values not creating a new entry and not
> cause an error, but I get "[1]PETSC ERROR: Inserting a new nonzero
> at global row/column". Is this option supposed to work or not?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180604/dbc3db50/attachment-0001.html>
