[petsc-users] PC_SUBPC_ERROR with -pc_factor_zeropivot
Matthew Overholt
overholt at capesim.com
Mon Jul 9 11:13:16 CDT 2018
Great idea, thanks again!
Matt...
On Mon, Jul 9, 2018 at 11:08 AM, Matthew Knepley <knepley at gmail.com> wrote:
> On Mon, Jul 9, 2018 at 11:05 AM Matthew Overholt <overholt at capesim.com>
> wrote:
>> The -sub_pc_factor_zeropivot <value> option works, but since this is for
>> a commercial code I don't want users to have to type that every time.
>> Is there an equivalent call to
>> PCFactorSetZeroPivot()
>> for the block Jacobi method (like PCSubFactorSetZeroPivot())? I can't
>> find it.
>> Instead, does one need to call
>> PCBjacobiGetSubKSP()
>> and then loop over every block, calling
>> KSPGetPC()
>> on each block? That seems a little tedious, but if that is the correct
>> approach I'll do it
> Yes, that is the API approach. As you can see, for composed solvers its
> not a great option. How about
> putting
> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/
> PetscOptionsSetValue.html
> in the code?
> Thanks,
> Matt
>> Thanks,
>> Matt Overholt
>> On Mon, Jul 9, 2018 at 10:17 AM, Matthew Overholt <overholt at capesim.com>
>> wrote:
>>> Thanks, Matt, that option works perfectly, and explains the -ksp_view
>>> output.
>>> Much appreciated!
>>> Matt...
>>> On Fri, Jul 6, 2018 at 6:25 PM, Matthew Knepley <knepley at gmail.com>
>>> wrote:
>>>> Default Case (zeropivot is 2.22045E-14):
>>>>> mpiexec -n 1 ...
>>>>> ==> ksp fails due to pcReason = PC_FACTOR_NUMERIC_ZEROPIVOT
>>>>> Reduced pivot case, n = 1:
>>>>> mpiexec -n 1 ... -pc_factor_zeropivot 1E-15
>>>>> ==> runs successfully
>>>>> Reduced pivot case, n > 1:
>>>>> mpiexec -n 2 .. -pc_factor_zeropivot 1E-15
>>>>> ==> ksp fails due to pcReason = PC_SUBPC_ERROR
>>>> Okay, what is likely happening is that your preconditioner is actually
>>>> Block-Jacobi/LU
>>>> instead of parallel LU. Thus you would need
>>>> -sub_pc_factor_zeropivot 1e-15
> experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180709/f872d01e/attachment.html>
