[petsc-users] PC_SUBPC_ERROR with -pc_factor_zeropivot
Matthew Overholt
overholt at capesim.com
Mon Jul 9 09:17:10 CDT 2018
Thanks, Matt, that option works perfectly, and explains the -ksp_view
output.
Much appreciated!
Matt...
On Fri, Jul 6, 2018 at 6:25 PM, Matthew Knepley <knepley at gmail.com> wrote:
> Default Case (zeropivot is 2.22045E-14):
>> mpiexec -n 1 ...
>> ==> ksp fails due to pcReason = PC_FACTOR_NUMERIC_ZEROPIVOT
>> Reduced pivot case, n = 1:
>> mpiexec -n 1 ... -pc_factor_zeropivot 1E-15
>> ==> runs successfully
>> Reduced pivot case, n > 1:
>> mpiexec -n 2 .. -pc_factor_zeropivot 1E-15
>> ==> ksp fails due to pcReason = PC_SUBPC_ERROR
> Okay, what is likely happening is that your preconditioner is actually
> Block-Jacobi/LU
> instead of parallel LU. Thus you would need
> -sub_pc_factor_zeropivot 1e-15
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180709/7350f844/attachment.html>
