[petsc-users] PC_SUBPC_ERROR with -pc_factor_zeropivot
Matthew Knepley
knepley at gmail.com
Fri Jul 6 17:25:03 CDT 2018
On Fri, Jul 6, 2018 at 3:16 PM Matthew Overholt <overholt at capesim.com>
wrote:
> I am working on handling very small pivot values for a very small
> percentage of my matrix (linear Ax = b solution), and I am getting an error
> that I don't understand when I run the KSPCG solver in parallel.
> KSPCreate(comm, &ksp)
> KSPSetTolerances(ksp, rtol, ...)
> KSPSetType(ksp, KSPCG)
> KSPSetInitialGuessNonzero(ksp, PETSC_TRUE)
> KSPSetFromOptions(ksp)
> KSPSetOperators(ksp, V, V)
> KSPSolve(ksp,...)
> KSPGetConvergedReason(ksp, &kspReason)
> if ( kspReason == KSP_DIVERGED_PCSETUP_FAILED )
> PCGetSetUpFailedReason(pc, &pcReason)
> Default Case (zeropivot is 2.22045E-14):
> mpiexec -n 1 ...
> ==> ksp fails due to pcReason = PC_FACTOR_NUMERIC_ZEROPIVOT
> Reduced pivot case, n = 1:
> mpiexec -n 1 ... -pc_factor_zeropivot 1E-15
> ==> runs successfully
> Reduced pivot case, n > 1:
> mpiexec -n 2 ... -pc_factor_zeropivot 1E-15
> ==> ksp fails due to pcReason = PC_SUBPC_ERROR
Okay, what is likely happening is that your preconditioner is actually
Block-Jacobi/LU
instead of parallel LU. Thus you would need
-sub_pc_factor_zeropivot 1e-15
if this is indeed the PC that you want.
> What does this mean?
> If I use the MUMPS solver and either Cholesky or LU preconditioning
> instead, it runs fine with any number of MPI ranks,
Yes, since MUMPS (or SuperLU_dist) is parallel LU.
> but I'd like to be able to run the CG solver in parallel too.
You can use MUMPS as the preconditioner for CG, but that would not make
much sense.
Matt
> Thanks in advance,
> Matt Overholt
> CapeSym, Inc.
> (508) 653-7100 x204
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180706/03891880/attachment.html>
