[petsc-users] DMGlobalToLocal acting weird
Manuel Valera mvalera-w at sdsu.edu
Mon Jul 2 19:07:48 CDT 2018
Yes, LocTemperature is the one with the problem, right after calling
GlobalToLocalBegin/End() that array is different from the gTemperature it
comes from,
I cannot tell exactly where right now, i would need to create a much
smaller experiment to print all of the entries, i'll try doing that
tomorrow,
On Mon, Jul 2, 2018 at 4:52 PM, Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
> > On Jul 2, 2018, at 6:48 PM, Manuel Valera <mvalera-w at sdsu.edu> wrote:
> > On Mon, Jul 2, 2018 at 4:23 PM, Smith, Barry F. <bsmith at mcs.anl.gov>
> wrote:
> > > On Jul 2, 2018, at 6:13 PM, Manuel Valera <mvalera-w at sdsu.edu> wrote:
> > > Ok so i fixed the '99 business' by making sure the whole DMDA array
> was filled, there was row at the end that wasn't and hence that problem,
> > > The local vector problem persists, though,
> >   Exactly what error? When you print the entire local vector it doesn't
> match the global vector? Or something else.
> > So, still debugging with extremas, if i do:
> >     call DMGlobalToLocalBegin(daScalars,gTemperature,INSERT_
> VALUES,LocTemperature,ierr)
> >     call DMGlobalToLocalEnd(daScalars,gTemperature,INSERT_VALUES,
>    What about LocTempature? Is that correct or not?
>    using min() helps you determine there is a problem but doesn't help
> much in determine exactly where the problem is. Print all of the entries in
> LocTempature and in DimTempature to see which ones are bad, or are they all
> bad?
> >     call DMCreateLocalVector(daScalars,DimTemperature,ierr)
> >     call VecCopy(LocTemperature,DimTemperature,ierr)
> >   I get a wrong minimum, zero instead of the actual value,
> > If instead i do:
> >     call DMCreateGlobalVector(daScalars,DimTemperature,ierr)
> >     call VecCopy(gTemperature,DimTemperature,ierr)
> > I get the right extreme values,
> >   DMGlobalToLocalBegin/End() are used in dozens of tests in PETSc; very
> unlikely there is a bug that is causing you a problem especially on one
> process where it just copies the values from the global vector to the local
> vector.
> > Yes, this is baffling for me also, but the parallelization of my code is
> based on this paradigm of local vectors so i need to be sure is working
> properly, and it wasn't until these changes,
> > Thanks,
> > > i solved it for now using a global vector instead of a local one, is
> this because of the warning on globaltolocalbegin/end?
> > > Thanks,
> > > On Mon, Jul 2, 2018 at 3:42 PM, Manuel Valera <mvalera-w at sdsu.edu>
> wrote:
> > > On Mon, Jul 2, 2018 at 3:04 PM, Smith, Barry F. <bsmith at mcs.anl.gov>
> wrote:
> > >    First make sure that getCenterInfo(daScalars,  xstart, ystart,
> zstart, xend, yend, zend) returns what it should.
> > > It does, i am also working in one processor only for now.
> > >    remove the 99 business and print out the arrtemp() and TO() values.
> Are they correct?
> > > They are not, i'm using maximum and minimum as probes to print into,
> but the minimum of T0 is 1 and is 0 for arrtemp,
> > >    What is DimTemperature? Shouldn't it be LocTempature?
> > > Yes, sorry about that,
> > >    Print out the values in tdim().
> > > Yes, the same as with arrtemp/T0
> > > Sorry i didn't mention i was debugging by printing the extremas of the
> arrays,
> > > From your answer you seem to think the problem is in my code's side
> and it may very well be, but from the DMGlobalToLocalBegin there is a
> warning saying INSERT_VALUES doesn't work with DMDAs, is this still an
> issue or have been fixed? i understand it looks like these are two
> different problems in my code,
> > > Thanks,
> > >    Barry
> > > > On Jul 2, 2018, at 2:58 PM, Manuel Valera <mvalera-w at sdsu.edu>
> wrote:
> > > > Hi guys,
> > > > I've noticed a bug in my code that seems to happen right after a
> call to DMGlobalToLocalBegin/End and i can't seem to find a reason, it goes
> like this:
> > > > I create the DMDA (daScalars) with the following:
> > > >  bx = DM_BOUNDARY_GHOSTED
> > > >  by = DM_BOUNDARY_PERIODIC
> > > >  bz = DM_BOUNDARY_GHOSTED
> > > >  dof = 1
> > > >  stw = 3
> > > > call DMDACreate3d(PETSC_COMM_WORLD,bx,by,bz,DMDA_STENCIL_BOX,
> gridx,gridy,gridz,PETSC_DECIDE,PETSC_DECIDE,PETSC_DECIDE, &
>                   dof,stw,PETSC_NULL_INTEGER,
> PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,daScalars,ierr)
> > > > call DMSetFromOptions(daScalars,ierr)
> > > > call DMSetUp(daScalars,ierr)
> > > > Then i read from a file the temperature and salinity fields of my
> problems, those two are giving the trouble, i do it with this template:
> > > > call DMCreateGlobalVector(daScalars,gTemperature,ierr)
> > > > call DMDAVecGetArrayF90(daScalars,gTemperature,arrtemp,ierr)
> > > >    arrtemp = 99.0d0      !no idea why this fixes the problem -mv
> 62518
> > > > call getCenterInfo(daScalars,  xstart, ystart, zstart, xend, yend,
> zend)
> > > >             do k=zstart,zend-1
> > > >                 do j=ystart,yend-1
> > > >                     do i=xstart,xend-1
> > > >                         arrtemp(i,j,k) = T0(i+1,j+1,k+1)
> > > >                     enddo
> > > >                 enddo
> > > >             enddo
> > > > call DMDAVecRestoreArrayF90(daScalars,gTemperature,arrtemp,ierr)
> > > > call DMCreateLocalVector(daScalars,LocTemperature,ierr)
> > > > Now here is the first weirdness, if i assign a number to my array it
> does behave as it should for the global quantity, but it must be a greater
> number than the maximum of the field for this to happen, so i assign 99.0
> arbitrarily, otherwise it doesn't read the array correctly, but it does as
> of now,
> > > > Next, the last two lines communicate the array to the local
> counterparts, but when i read LocTemperature with:
> > > >     call DMDAVecGetArrayReadF90(daScalars,DimTemperature,tdim,ierr)
> > > >     print*,'Copied MinT0: ', minval(tdim)
> > > >     call DMDAVecRestoreArrayReadF90(daScalars,DimTemperature,tdim,
> ierr)
> > > > That array minimum doesn't coincide with the global minimum, it
> should be 1.000 but it is just 0.000, the same happens with the Salinity
> following an identical approach,
> > > > Any ideas on where to start looking? i have last month's PETSc build,
> > > > I'm running in 1 processor for now,
> > > > Thanks,
> > > > Manuel
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180702/2f2706a4/attachment-0001.html>
