[petsc-users] DMGlobalToLocal acting weird
Manuel Valera mvalera-w at sdsu.edu
Mon Jul 2 18:13:31 CDT 2018
Ok so i fixed the '99 business' by making sure the whole DMDA array was
filled, there was row at the end that wasn't and hence that problem,
The local vector problem persists, though, i solved it for now using a
global vector instead of a local one, is this because of the warning on
globaltolocalbegin/end?
On Mon, Jul 2, 2018 at 3:42 PM, Manuel Valera <mvalera-w at sdsu.edu> wrote:
> On Mon, Jul 2, 2018 at 3:04 PM, Smith, Barry F. <bsmith at mcs.anl.gov>
> wrote:
>>    First make sure that getCenterInfo(daScalars,  xstart, ystart, zstart,
>> xend, yend, zend) returns what it should.
> It does, i am also working in one processor only for now.
>>    remove the 99 business and print out the arrtemp() and TO() values.
>> Are they correct?
> They are not, i'm using maximum and minimum as probes to print into, but
> the minimum of T0 is 1 and is 0 for arrtemp,
>    What is DimTemperature? Shouldn't it be LocTempature?
> Yes, sorry about that,
>>    Print out the values in tdim().
> Yes, the same as with arrtemp/T0
> Sorry i didn't mention i was debugging by printing the extremas of the
> arrays,
> From your answer you seem to think the problem is in my code's side and it
> may very well be, but from the DMGlobalToLocalBegin there is a warning
> saying INSERT_VALUES doesn't work with DMDAs, is this still an issue or
> have been fixed? i understand it looks like these are two different
> problems in my code,
> Thanks,
>>    Barry
>> > On Jul 2, 2018, at 2:58 PM, Manuel Valera <mvalera-w at sdsu.edu> wrote:
>> > Hi guys,
>> > I've noticed a bug in my code that seems to happen right after a call
>> to DMGlobalToLocalBegin/End and i can't seem to find a reason, it goes like
>> this:
>> > I create the DMDA (daScalars) with the following:
>> >  bx = DM_BOUNDARY_GHOSTED
>> >  by = DM_BOUNDARY_PERIODIC
>> >  bz = DM_BOUNDARY_GHOSTED
>> >  dof = 1
>> >  stw = 3
>> > call DMDACreate3d(PETSC_COMM_WORLD,bx,by,bz,DMDA_STENCIL_BOX,grid
>> x,gridy,gridz,PETSC_DECIDE,PETSC_DECIDE,PETSC_DECIDE, &
>>               dof,stw,PETSC_NULL_INTEGER,PET
>> SC_NULL_INTEGER,PETSC_NULL_INTEGER,daScalars,ierr)
>> > call DMSetFromOptions(daScalars,ierr)
>> > call DMSetUp(daScalars,ierr)
>> > Then i read from a file the temperature and salinity fields of my
>> problems, those two are giving the trouble, i do it with this template:
>> > call DMCreateGlobalVector(daScalars,gTemperature,ierr)
>> > call DMDAVecGetArrayF90(daScalars,gTemperature,arrtemp,ierr)
>> >    arrtemp = 99.0d0      !no idea why this fixes the problem -mv 62518
>> > call getCenterInfo(daScalars,  xstart, ystart, zstart, xend, yend, zend)
>> >             do k=zstart,zend-1
>> >                 do j=ystart,yend-1
>> >                     do i=xstart,xend-1
>> >                         arrtemp(i,j,k) = T0(i+1,j+1,k+1)
>> >                     enddo
>> >                 enddo
>> >             enddo
>> > call DMDAVecRestoreArrayF90(daScalars,gTemperature,arrtemp,ierr)
>> > call DMCreateLocalVector(daScalars,LocTemperature,ierr)
>> > call DMGlobalToLocalBegin(daScalars,gTemperature,INSERT_VALUES,
>> > call DMGlobalToLocalEnd(daScalars,gTemperature,INSERT_VALUES,LocT
>> emperature,ierr)
>> > Now here is the first weirdness, if i assign a number to my array it
>> does behave as it should for the global quantity, but it must be a greater
>> number than the maximum of the field for this to happen, so i assign 99.0
>> arbitrarily, otherwise it doesn't read the array correctly, but it does as
>> of now,
>> > Next, the last two lines communicate the array to the local
>> counterparts, but when i read LocTemperature with:
>> >     call DMDAVecGetArrayReadF90(daScalars,DimTemperature,tdim,ierr)
>> >     print*,'Copied MinT0: ', minval(tdim)
>> >     call DMDAVecRestoreArrayReadF90(daScalars,DimTemperature,tdim,ierr)
>> > That array minimum doesn't coincide with the global minimum, it should
>> be 1.000 but it is just 0.000, the same happens with the Salinity following
>> an identical approach,
>> > Any ideas on where to start looking? i have last month's PETSc build,
>> > I'm running in 1 processor for now,
>> > Thanks,
>> > Manuel
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180702/33ee8ee2/attachment-0001.html>
