[petsc-users] DMGlobalToLocal acting weird
Manuel Valera mvalera-w at sdsu.edu
Mon Jul 2 17:42:05 CDT 2018
On Mon, Jul 2, 2018 at 3:04 PM, Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
>    First make sure that getCenterInfo(daScalars,  xstart, ystart, zstart,
> xend, yend, zend) returns what it should.
It does, i am also working in one processor only for now.
>    remove the 99 business and print out the arrtemp() and TO() values. Are
> they correct?
They are not, i'm using maximum and minimum as probes to print into, but
the minimum of T0 is 1 and is 0 for arrtemp,
   What is DimTemperature? Shouldn't it be LocTempature?
Yes, sorry about that,
>    Print out the values in tdim().
Yes, the same as with arrtemp/T0
Sorry i didn't mention i was debugging by printing the extremas of the
arrays,
>From your answer you seem to think the problem is in my code's side and it
may very well be, but from the DMGlobalToLocalBegin there is a warning
saying INSERT_VALUES doesn't work with DMDAs, is this still an issue or
have been fixed? i understand it looks like these are two different
problems in my code,
>    Barry
> > On Jul 2, 2018, at 2:58 PM, Manuel Valera <mvalera-w at sdsu.edu> wrote:
> > Hi guys,
> > I've noticed a bug in my code that seems to happen right after a call to
> DMGlobalToLocalBegin/End and i can't seem to find a reason, it goes like
> this:
> > I create the DMDA (daScalars) with the following:
> >  bx = DM_BOUNDARY_GHOSTED
> >  by = DM_BOUNDARY_PERIODIC
> >  bz = DM_BOUNDARY_GHOSTED
> >  dof = 1
> >  stw = 3
> > call DMDACreate3d(PETSC_COMM_WORLD,bx,by,bz,DMDA_STENCIL_BOX,
> gridx,gridy,gridz,PETSC_DECIDE,PETSC_DECIDE,PETSC_DECIDE, &
>                   dof,stw,PETSC_NULL_INTEGER,
> PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,daScalars,ierr)
> > call DMSetFromOptions(daScalars,ierr)
> > call DMSetUp(daScalars,ierr)
> > Then i read from a file the temperature and salinity fields of my
> problems, those two are giving the trouble, i do it with this template:
> > call DMCreateGlobalVector(daScalars,gTemperature,ierr)
> > call DMDAVecGetArrayF90(daScalars,gTemperature,arrtemp,ierr)
> >    arrtemp = 99.0d0      !no idea why this fixes the problem -mv 62518
> > call getCenterInfo(daScalars,  xstart, ystart, zstart, xend, yend, zend)
> >             do k=zstart,zend-1
> >                 do j=ystart,yend-1
> >                     do i=xstart,xend-1
> >                         arrtemp(i,j,k) = T0(i+1,j+1,k+1)
> >                     enddo
> >                 enddo
> >             enddo
> > call DMDAVecRestoreArrayF90(daScalars,gTemperature,arrtemp,ierr)
> > call DMCreateLocalVector(daScalars,LocTemperature,ierr)
> > call DMGlobalToLocalBegin(daScalars,gTemperature,INSERT_
> VALUES,LocTemperature,ierr)
> > call DMGlobalToLocalEnd(daScalars,gTemperature,INSERT_VALUES,
> > Now here is the first weirdness, if i assign a number to my array it
> does behave as it should for the global quantity, but it must be a greater
> number than the maximum of the field for this to happen, so i assign 99.0
> arbitrarily, otherwise it doesn't read the array correctly, but it does as
> of now,
> > Next, the last two lines communicate the array to the local
> counterparts, but when i read LocTemperature with:
> >     call DMDAVecGetArrayReadF90(daScalars,DimTemperature,tdim,ierr)
> >     print*,'Copied MinT0: ', minval(tdim)
> >     call DMDAVecRestoreArrayReadF90(daScalars,DimTemperature,tdim,ierr)
> > That array minimum doesn't coincide with the global minimum, it should
> be 1.000 but it is just 0.000, the same happens with the Salinity following
> an identical approach,
> > Any ideas on where to start looking? i have last month's PETSc build,
> > I'm running in 1 processor for now,
> > Thanks,
> > Manuel
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180702/099a341c/attachment.html>
