[petsc-users] Petsc messing with OpenMP
Timothée Nicolas
timothee.nicolas at gmail.com
Tue Jan 30 12:00:54 CST 2018
Thank you very much Barry, it works indeed to build petsc with the qopenmp
flags!
Best
Timothee
2018-01-30 18:46 GMT+01:00 Satish Balay <balay at mcs.anl.gov>:
> Try building PETSc with -qopenmp flag and see if this makes a difference.
> i.e use CFLAGS=-qopenmp FFLAGS=-qopenmp CXXFLAGS=-qopenmp
> Potential explanation:
> Compilers do different things internally [for ex - link to different
> libraries] when different compile flags are used.
> When -qopenmp is used - its possible some openmp library gets linked
> in. And when -qopenmp is not used - some equivalnet stub library might
> get linked in. Only one lib is supporsed to be used at anytime. With
> the way petsc gets built - both might get used - causing some
> conflict.
> You can verify with:
> <compare logs from>
> mpicc -v -qopenmp dummy.c
> mpicc -v dummy.c
> And 'ldd libpetsc.so'
> Satish
> On Tue, 30 Jan 2018, Timothée Nicolas wrote:
> > Thank you for your answer,
> > I am not responsible for the choices in this code to begin with, but in
> any
> > case, as you can see in the example, I am not using any petsc call. Also
> in
> > our code, even though openmp is used, this is never in interaction with
> > petsc, the latter being used only at a specific (but crucial) place in
> the
> > code, and without openMP. In that sense, the model we are using is NOT
> some
> > 'Petsc with threads model', as described in the page you sent me.
> > Nevertheless, it appears that just linking petsc is enough to perturb the
> > behavior of openMP. I believe it may require further investigation. On
> top
> > of the bug I report in my first message, I have noticed very weird openMP
> > behavior lately, the kind of bugs that 'don't make sense' at first sight
> > (would be too long/boring to give details at this stage). I am starting
> to
> > realize that it may have something to do with petsc.
> > Again, the webpage you have sent me seems to adopt the point of view that
> > hybrid MPI/openMP is useless from the performance point of view, and/or
> > that Petsc routines should not be threaded. It does not, however, explain
> > why the behaviour of openMP may be changed by merely linking a program
> with
> > petsc, without a single petsc call in the program.
> > Best
> > 2018-01-30 18:02 GMT+01:00 Smith, Barry F. <bsmith at mcs.anl.gov>:
> > > I don't know what you are trying to do with OpenMP and PETSc, nor do
> I
> > > understand why anyone would use OpenMP, but you cannot call virtually
> any
> > > PETSc function or operation while you are using threads.
> > > Best to use PETSc as intended, with one MPI process per core or
> hardware
> > > thread and not use OpenMP at all. http://www.mcs.anl.gov/petsc/
> > > miscellaneous/petscthreads.html
> > > Barry
> > > > On Jan 30, 2018, at 10:57 AM, Timothée Nicolas <
> > > timothee.nicolas at gmail.com> wrote:
> > > > Dear petsc team,
> > > > For a while, I have been wondering why I have never managed to print
> > > what threads are doing in an openMP region in my FORTRAN programs. Some
> > > people told me it was normal because threads will get confused all
> trying
> > > to write at the same time. However I realised today that the problem
> seems
> > > to be related to petsc. I have a super simple "hello world" example
> that
> > > reproduces the problem :
> > > > program hello
> > > > !$ use omp_lib
> > > > implicit none
> > > > integer nthreads, tid
> > > > !$omp parallel private(nthreads, tid)
> > > > tid = omp_get_thread_num()
> > > > print *, 'hello world from thread = ', tid
> > > > if (tid .eq. 0) then
> > > > nthreads = omp_get_num_threads()
> > > > print *, 'number of threads = ', nthreads
> > > > end if
> > > > !$omp end parallel
> > > > end program hello
> > > > If I compile it with
> > > > mpif90 -qopenmp -o omp main.f90
> > > > Then I get no problem. But if I link petsc library (as is the case
> in my
> > > code) :
> > > > mpif90 -qopenmp -o omp main.f90 -L/home/timotheenicolas/petsc-
> 3.7.3/arch-linux2-c-debug/lib
> > > -lpetsc
> > > > Then I get the following error after execution of export
> > > OMP_NUM_THREADS=2;./omp
> > > > hello world from thread = 0
> > > > number of threads = 2
> > > > forrtl: severe (40): recursive I/O operation, unit -1, file unknown
> > > > Image PC Routine Line
> > > Source
> > > > omp 0000000000403BC8 Unknown Unknown
> > > Unknown
> > > > omp 0000000000403572 Unknown Unknown
> > > Unknown
> > > > libiomp5.so 00002AAAAD3146A3 Unknown Unknown
> > > Unknown
> > > > libiomp5.so 00002AAAAD2E3007 Unknown Unknown
> > > Unknown
> > > > libiomp5.so 00002AAAAD2E26F5 Unknown Unknown
> > > Unknown
> > > > libiomp5.so 00002AAAAD3149C3 Unknown Unknown
> > > Unknown
> > > > libpthread.so.0 00002AAAAD5BADC5 Unknown Unknown
> > > Unknown
> > > > libc.so.6 00002AAAAD8C5CED Unknown Unknown
> > > Unknown
> > > > This means that in my programs using petsc, I can't use prints to see
> > > exactly what the threads are doing, which is a pain when debug is
> required
> > > (that is to say, all the time). Is this issue expected ?
> > > > Thx in advance
> > > > Timothee NICOLAS
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180130/e44df301/attachment.html>
