[petsc-users] Petsc messing with OpenMP
Timothée Nicolas
timothee.nicolas at gmail.com
Tue Jan 30 10:57:30 CST 2018
Dear petsc team,
For a while, I have been wondering why I have never managed to print what
threads are doing in an openMP region in my FORTRAN programs. Some people
told me it was normal because threads will get confused all trying to write
at the same time. However I realised today that the problem seems to be
related to petsc. I have a super simple "hello world" example that
reproduces the problem :
program hello
!$ use omp_lib
implicit none
integer nthreads, tid
!$omp parallel private(nthreads, tid)
tid = omp_get_thread_num()
print *, 'hello world from thread = ', tid
if (tid .eq. 0) then
nthreads = omp_get_num_threads()
print *, 'number of threads = ', nthreads
end if
!$omp end parallel
end program hello
If I compile it with
mpif90 -qopenmp -o omp main.f90
Then I get no problem. But if I link petsc library (as is the case in my
code) :
-L/home/timotheenicolas/petsc-3.7.3/arch-linux2-c-debug/lib -lpetsc
Then I get the following error after execution of export
OMP_NUM_THREADS=2;./omp
hello world from thread = 0
number of threads = 2
forrtl: severe (40): recursive I/O operation, unit -1, file unknown
Image PC Routine Line Source
omp 0000000000403BC8 Unknown Unknown Unknown
omp 0000000000403572 Unknown Unknown Unknown
libiomp5.so 00002AAAAD3146A3 Unknown Unknown Unknown
libiomp5.so 00002AAAAD2E3007 Unknown Unknown Unknown
libiomp5.so 00002AAAAD2E26F5 Unknown Unknown Unknown
libiomp5.so 00002AAAAD3149C3 Unknown Unknown Unknown
libpthread.so.0 00002AAAAD5BADC5 Unknown Unknown Unknown
libc.so.6 00002AAAAD8C5CED Unknown Unknown Unknown
This means that in my programs using petsc, I can't use prints to see
exactly what the threads are doing, which is a pain when debug is required
(that is to say, all the time). Is this issue expected ?
Thx in advance
Timothee NICOLAS
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180130/06b34489/attachment.html>
