[petsc-users] Error during PETSc build on Edison
Amneet Bhalla
mail2amneet at gmail.com
Mon Jan 29 22:05:00 CST 2018
I am trying to build PETSc (v3.7.7) locally in my home directory on NERSC
(Edison).
However, I am getting the following error during the configuration stage.
TESTING: checkFortranNameMangling from
config.compilers(config/BuildSystem/config/compilers.py:653)
UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log for
details):
Unknown Fortran name mangling: Are you sure the C and Fortran compilers are
compatible?
Perhaps one is 64 bit and one is 32 bit?
compatible?
File "./config/configure.py", line 405, in petsc_configure
framework.configure(out = sys.stdout)
File
"/global/u2/a/apbhalla/softwares/PETSc-BitBucket/PETSc/config/BuildSystem/config/framework.py",
line 1091, in configure
self.processChildren()
File
line 1080, in processChildren
self.serialEvaluation(self.childGraph)
File
line 1061, in serialEvaluation
child.configure()
File
"/global/u2/a/apbhalla/softwares/PETSc-BitBucket/PETSc/config/BuildSystem/config/compilers.py",
line 1458, in configure
self.executeTest(self.checkFortranNameMangling)
File
"/global/u2/a/apbhalla/softwares/PETSc-BitBucket/PETSc/config/BuildSystem/config/base.py",
line 126, in executeTest
ret = test(*args,**kargs)
File
line 675, in checkFortranNameMangling
raise RuntimeError('Unknown Fortran name mangling: Are you sure the C
and Fortran compilers are compatible?\n Perhaps one is 64 bit and one is
32 bit?\n'+mess)
I using the following configure options
./config/configure.py --CC=cc --CXX=CC --FC=ftn --with-default-arch=0
--PETSC_ARCH=linux-opt --with-debugging=0 --with-c++-support=1
--with-hypre=1 --download-hypre=1 --COPTFLAGS="-O3" --CXXOPTFLAGS="-O3"
--FOPTFLAGS="-O3" --with-x=0
I have swapped the Prgn-Env-intel with Prgn-Env-gnu.
The compiler commands return the following:
% cc --version
gcc (GCC) 7.1.0 20170502 (Cray Inc.)
Copyright (C) 2017 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
% which cc
/opt/cray/pe/craype/2.5.12/bin/cc
% CC --version
g++ (GCC) 7.1.0 20170502 (Cray Inc.)
% which CC
/opt/cray/pe/craype/2.5.12/bin/CC
% ftn --version
GNU Fortran (GCC) 7.1.0 20170502 (Cray Inc.)
% which ftn
/opt/cray/pe/craype/2.5.12/bin/ftn
Any suggestions?
--Amneet
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180129/153d73fb/attachment.html>
