[petsc-users] Parallel Matrix Causes a Deadlock
Ali Berk Kahraman aliberkkahraman at yahoo.com
Sun Jan 28 13:15:13 CST 2018
Hello All,
My apologies, I have closed this e-mail window and the first thing I
read on the manual is "ALL processes that share a matrix MUST call
MatAssemblyBegin
<http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatAssemblyBegin.html#MatAssemblyBegin>()
and MatAssemblyEnd
<http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatAssemblyEnd.html#MatAssemblyEnd>()
the SAME NUMBER of times". So I understand that petsc simply does not
support unequal number of assembly calls.
My question evolves then. I have a problem at hand where I do not know
how many calls each process will make to MatAssembly routines. Any
suggestions to make this work?
On 28-01-2018 22:09, Ali Berk Kahraman wrote:
> Hello All,
> The code takes a parallel matrix and calls a function using that
> matrix. That function fills the specified row of that matrix with the
> id of the process that part of the matrix belongs in. You can see the
> short code in the attachment, it is about 80 lines.
> The problem is that the code gets into a deadlock at some point,
> usually at the last row  of each process except for the last process
> (greatest pid). I use petsc with configure options "--with-cc=gcc
> --with-cxx=g++ --with-fc=gfortran --download-mpich
> --download-fblaslapack".
> I am a beginner with MPI, so I do not know what may be causing this.
> My apologies in advance if this is a very trivial problem.
> Best Regards to All,
> Ali Berk Kahraman
> M.Sc. Student, Mechanical Eng.
> Bogazici Uni., Istanbul, Turkey
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180128/602450ba/attachment.html>
