[petsc-users] Parallel Matrix Causes a Deadlock
Ali Berk Kahraman aliberkkahraman at yahoo.com
Sun Jan 28 13:09:30 CST 2018
Hello All,
The code takes a parallel matrix and calls a function using that matrix.
That function fills the specified row of that matrix with the id of the
process that part of the matrix belongs in. You can see the short code
in the attachment, it is about 80 lines.
The problem is that the code gets into a deadlock at some point, usually
at the last row  of each process except for the last process (greatest
pid). I use petsc with configure options "--with-cc=gcc --with-cxx=g++
--with-fc=gfortran --download-mpich --download-fblaslapack".
I am a beginner with MPI, so I do not know what may be causing this. My
apologies in advance if this is a very trivial problem.
Best Regards to All,
Ali Berk Kahraman
M.Sc. Student, Mechanical Eng.
Bogazici Uni., Istanbul, Turkey
Type: text/x-csrc
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180128/a626477d/attachment.bin>
