[petsc-users] How to generate manul.pdf from source files
    Kong, Fande
    fande.kong at inl.gov
    Fri Jan 26 18:00:11 CST 2018
I guess we install sowing automatically when we are on petsc/master
> cat configure.log  | grep "sowing"
*        Bfort not found. Installing sowing for FortranStubsTEST
checkDependencies from
config.packages.sowing(/Users/kongf/projects/petsc/config/BuildSystem/config/package.py:719)TESTING:
config.packages.sowing(config/BuildSystem/config/package.py:719)TEST
configureLibrary from
config.packages.sowing(/Users/kongf/projects/petsc/config/BuildSystem/config/package.py:744)TESTING:
config.packages.sowing(config/BuildSystem/config/package.py:744)
Checking for a functional sowing                      Looking for SOWING at
git.sowing, hg.sowing or a directory starting with
['petsc-pkg-sowing']                      Found a copy of SOWING in
git.sowingRemoving sowing.petscconfTEST checkSharedLibrary from
config.packages.sowing(/Users/kongf/projects/petsc/config/BuildSystem/config/package.py:792)TESTING:
config.packages.sowing(config/BuildSystem/config/package.py:792)sowing:*
Thanks
Fande
On Fri, Jan 26, 2018 at 4:56 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Sat, Jan 27, 2018 at 10:53 AM, Kong, Fande <fande.kong at inl.gov> wrote:
>> Hi,
>> I want to generate manul.pdf from source files on my own desktop.
>> In directory:  ./src/docs/tex/manual
>> make ALL  LOC=/Users/kongf/projects/petsc
>> * make: *** No rule to make target
>> `/Users/kongf/projects/petsc/docs/manualpages/htmlmap', needed by
>> `listing_kspex1tmp.tex'.  Stop.*
>> What else I need to install?
> Do you have sowing?
>   Matt
>> Fande
> experiments lead.
> -- Norbert Wiener
> <https://urldefense.proofpoint.com/v2/url?u=http-3A__www.caam.rice.edu_-7Emk51_&d=DwMFaQ&c=54IZrppPQZKX9mLzcGdPfFD1hxrcB__aEkJFOKJFd00&r=DUUt3SRGI0_JgtNaS3udV68GRkgV4ts7XKfj2opmiCY&m=zXfxecLju5hawg2DhuHqya7s2fzzkAwImvAOj3UvoqE&s=rKKqNp27QtRzVTHE03_mMvZmF70ig8PdWRiRXNhmPzA&e=>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180126/c887e003/attachment-0001.html>
