[petsc-users] Novice: How to implement the petsc Gmres libraries in my CFD code
Stephen Wornom stephen.wornom at inria.fr
Fri Jan 26 03:39:14 CST 2018
I am disparate to implement the petsc library gmres in an CFD code and need a little help to get going.
23 years ago, gmres was implemented/written in the code by Y. Saad, modified by A. Malevsky, version February 1, 1995.
petsc, most likely started with the same version, added new solvers, ...etc and maintained and corrected bugs reported by users
and I would like to use the latest petsc version of gmres
Why?
Normally we have no convergence problems using gmres.
However sometimes gmres diverges instantaneously, no warning, just a negative density.
Our code is parallel mpi, unstructured, uses a low Mach preconditioner, FV Roe scheme.
Thus I would like to add an petsc option.
Would someone outline, in detail, the steps that I need to follow?
I need all the encourage that I can get to add the option in the code.
petsc is installed on our computers
Thanks in advance,
Stephen
IF ( petsc .EQ. 1 ) THEN
c petsc CALL MatAssembleBegin
c petsc CALL MatAssembleEnd
... add steps
ELSE
CALL GMRESASR ! from our code
ENDIF
This is from our code which may be useful information
c-----------------------------------------------------------------------
c flexible GMRES routine. This is a version of GMRES which allows a
c a variable preconditioner. Implemented with a reverse communication
c protocole for flexibility -
c DISTRIBUTED VERSION (USES DISTDOT FOR DDOT)
c explicit (exact) residual norms for restarts
c written by Y. Saad, modified by A. Malevsky, version February 1, 1995
c This Is A Reverse Communication Implementation.
c USAGE: (see also comments for icode below). CGMRES
c should be put in a loop and the loop should be active for as
c long as icode is not equal to 0. On RETURN fgmres will
c 1) either be requesting the new preconditioned vector applied
c to wk1 in case icode.eq.1 (result should be put in wk2)
c 2) or be requesting the product of A applied to the vector wk1
c in case icode.eq.2 (result should be put in wk2)
c 3) or be terminated in case icode .eq. 0.
c on entry always set icode = 0. So icode should be set back to zero
c upon convergence.
c Here is a typical way of running fgmres:
c
c icode = 0
c 1 continue
c CALL fgmres (n,im,rhs,sol,i,vv,w,wk1, wk2,eps,maxits,iout,icode)
c
c if (icode .eq. 1) then
c CALL precon(n, wk1, wk2) <--- user's variable preconditioning
c goto 1
c else if (icode .ge. 2) then
c CALL matvec (n,wk1, wk2) <--- user's matrix vector product.
c goto 1
c else
c ----- done ----
c .........
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180126/e32a8c62/attachment.html>
