[petsc-users] Install Petsc from repository "--download-fblaslapack libraries cannot be used"
John Haase
jhaase1 at nd.edu
Thu Jan 25 17:53:53 CST 2018
Hello all,
I am trying to install an bleeding edge version of Petsc (
https://bitbucket.org/petsc/petsc/pull-requests/843/added-api-snesgetforceiteration/diff).
However, when I try to install with the command
./configure --prefix=$PETSC_DIR/../installed --download-hypre=1
--with-ssl=0 --with-debugging=no --with-pic=1 --with-shared-libraries=1
--with-cc=mpicc --with-cxx=mpicxx --with-fc=mpif90 --download-fblaslapack=1
--download-metis=1 --download-parmetis=1 --download-superlu_dist=1
--download-scalapack=1 --download-mumps=1 CC=mpicc CXX=mpicxx FC=mpif90
F77=mpif77 F90=mpif90 CFLAGS='-fPIC -fopenmp' CXXFLAGS='-fPIC -fopenmp'
FFLAGS='-fPIC -fopenmp' FCFLAGS='-fPIC -fopenmp' F90FLAGS='-fPIC -fopenmp'
F77FLAGS='-fPIC -fopenmp' PETSC_DIR=`pwd`
I get the error "--download-fblaslapack libraries cannot be used". Any
suggestions?
I've attached configure.log in case I'm not reporting something important.
Thank you for your help
John
John R. Haase
jhaase1 at nd.edu
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180125/ee7cba28/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180125/ee7cba28/attachment-0001.obj>
