[petsc-users] matrix preallocation for unstructured finite element
    saturday luis
    luis.saturday at gmail.com
    Thu Jan 18 22:49:47 CST 2018
Hi PETSc team:
Is there a way to make precise matrix preallocation for an unstructured
grid (I am not using the DMPlex object). Or do you have any example code
for estimating the dnz & onz data?
On top of my head, I can do a two-phase calculation. I can first give a
rough estimate and do one finite element assembly, then I will call
MatGetRow to locate the column indices for nonzero entries. Then in the
second step, I will destroy the Mat and create a new Mat with this obtained
sparsity pattern.
Do you have any suggestions?
Thanks!
Luis
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180118/bc07300a/attachment.html>
