[petsc-users] valgrind errors on vecscattercreatetoAll
Smith, Barry F.
bsmith at mcs.anl.gov
Thu Jan 18 17:08:17 CST 2018
Sorry this is actually in master already
> On Jan 18, 2018, at 5:00 PM, Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
> This is a known issue without a perfect solution.
> The problem is that by default PETSc fortran types, like type(tKSP) are not initialized but we want to check if they are a special null character, for example PETSC_NULL_KSP. So we could initialize them but then they cannot be used in common blocks (since default initialized Fortran90 types cannot be used in common blocks; some strange feature of Fortran 90)
> In next you can configure with the option -with-fortran-type-initialize=1 and the valgrind errors will go away, but then there cannot be Fortran datatypes into common blocks.
> Barry
> It may be we should make -with-fortran-type-initialize=1 the default but this will break some PETSc Fortran examples that use common blocks. We should rewrite those examples not to use common blocks but who volunteers?
>> On Jan 18, 2018, at 4:11 PM, Randall Mackie <rlmackie862 at gmail.com> wrote:
>> The very simple attached program throws lots of valgrind errors.
>> I am using pets 3.8.3, compiled with the following options:
>> ./configure \
>> --with-debugging=1 \
>> --with-fortran=1 \
>> --download-mpich=../mpich-3.3a2.tar.gz \
>> The makefile, run file, and valgrind output are also attached.
>> Randy M.
>> <cmd_test><makefile><test.F90><valgrind.txt>
