[petsc-users] I have a question for PETSc example
Matthew Knepley
knepley at gmail.com
Thu Jan 18 10:09:02 CST 2018
On Thu, Jan 18, 2018 at 6:10 AM, 서승진 (기계항공및원자력공학부) <mistloin at unist.ac.kr>
wrote:
> Dear petsc-user.
> Hi. I am trying several parts of example code, (SNES ex12.c : Poisson
> Problem in 2d and 3d with simplicial finite element)
> and I have several problems to understand.
> I appologize to sent a long and boring email to you...
> *1) About setting of geometry*
> I referred the "DMPlexCreateBoxMesh" function to make simplicial box mesh.
> I found that lower[] and upper[] are factors to set the size of the box
> mesh. Is it right?
> Actually, I want to make a rectangular geometry with size of 3m x 1m, and
> four boundary (two dirichlet and two neumann condition).
> If I wrong, please give me some tip to make a good geometry.
Yes, you can use DMPlexCreateBoxMesh() to make that.
> *2) About application boundary condition*
> I reffered the example "SNES ex69.c" to set a label and condition for the
> four boundarys.
> First part of code is about label of boundary condition,
This is wrong. You should not have DMPlexMarkBoundaryFaces() in there. What
did you want it to do?
> and second part is about setting of boundary condition.
> However, due to second part, error occurs.
Always, always, always send the full error message. Otherwise, I am just
guessing.
> Is there any wrong argument?
If they are homogeneous Neumann conditions, there is no need to mark them.
If they are inhomogeneous, you
must specify a part of the weak form, as is done in SNES ex12 and ex77.
Second, for the Dirichlet conditions, are you sure you only want to
constrain the components that I am in ex69?
What would help is to fully specify your problem, so that we know what you
want to do.
> Please give me some tip to applied four boundary conditions on the mesh.
> *3) About input parameters of DSSetJacobian()*
> In DSSetJacobian (prob, f, g, g0, g1, g2, g3), I have a problem to
> understand g0~g3
> g0 : integrand for test function and basis function
> g1 : integrand for test function gradient and basis function
> g2 : integrand for test function and basis function gradient
> g3 : integrand for test function gradient and basis function gradient
> I have studied the FEM before one month, but I am very confused by above
> four terms.
There is a short explanation here:
http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/DT/PetscDSSetJacobian.html
and here you can see the four terms which are being integrated to arrive at
the element matrix:
http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/DT/PetscFEIntegrateJacobian.html
> I should study this in my self, but I need to some tip or internet address
> which include a helpful description about above terms.
> (I think this issue is not good at this email, but I have been really
> suffered by above term...)
> *4) About useful tool to visualize the result and geometry *
> I also have searched the tool which can express the visualized result and
> geometry.
I use Paraview from KitWare, which is free. I output HDF5, using the
generic PETSc Viewer options detailed in the manual,
-dm_view hdf5:lap.h5 -vec_view hdf5:lap.h5::append
and then I automatically create an XDMF file lap.xmf, describing the HDF5,
which can be read by Paraview,
$PETSC_DIR/bin/petsc_gen_xdmf.py lap.h5
Matt
> Could you give me a tip to select the visualizing tool for better analysis?
> Thanks you for reading my email.
> Best regards,
> Seungjin Seo
> *보낸 사람:* Matthew Knepley <knepley at gmail.com>
> *보낸 날짜:* 2018년 1월 16일 화요일 오후 8:48:16
> *받는 사람:* 서승진 (기계항공및원자력공학부)
> *참조:* Smith, Barry F.; petsc-users at mcs.anl.gov
> *제목:* Re: [petsc-users] I have a question for PETSc example
> On Mon, Jan 15, 2018 at 8:28 PM, 서승진 (기계항공및원자력공학부) <mistloin at unist.ac.kr>
> wrote:
> sorry, I mean that
> *My geometry is a rectangle*.
> That means, geometry is just rectangle box shape with four boundary.
> My question is that, how can I set the four boundary condition
> individually in example 12 of SNES?
> You put a different marker on each side. The easiest way to do it is to
> give the
> -dm_plex_separate_marker
> option. This is done in SNES ex69.
> Thanks,
> Matt
> (I think that the boundary condition should be added in right side of the
> weak form, where load vector f and test function term is included. However,
> in example of petsc, boundary condition is applied as general form.)
> Seungjin Seo
> *보낸 사람:* Smith, Barry F. <bsmith at mcs.anl.gov>
> *보낸 날짜:* 2018년 1월 15일 월요일 오후 11:06:18
> The term "rectangular mesh" usually refers to a "structured grid mesh"
> so it is not clear if you truly need an unstructured grid. Take a look at
> src/snes/examples/tutorials/ex19.c
> Barry
> > On Jan 15, 2018, at 1:03 AM, 서승진 (기계항공및원자력공학부) <mistloin at unist.ac.kr>
> wrote:
> > Dear PETSc-user
> > I am Seungjin Seo, researcher of Korean Advanced Institute of Science
> and Technology, South Korea.
> > I am tring to understand the ex12.c in SNES examples, and I have a
> problem...
> > Could you give me some advise? Is there any good description or
> materials for PetscFE and DMPlex?
> > I will make a code with unstructured grid with PetscFE and SNES. My
> geometry is a rectangle mesh (the size is not fixed so I think this is
> unstructured grid).
> > The equation is
> > I will set boundry conditions as follow;
> > 1. (Top-side boundary) Neumann boundary
> > 2. (Bottom-side boundary) Neumann boundary
> > 3. (Left-side boundary) Dirichlet boundary
> > 4. (Right-side boundary) Dirichlet boundary
> > In example ex12.c in SNES, load vector f is defiend as f_0, and neumann
> boundary condition is defined as f_bd_0. f_1 means the test function
> gradient term. The example set general type of neumann boundary condition
> on f_bd_0, but I want to set each boundary condition individually. Could
> > Thansk for reading my email.
> > Best regard,
> > Seungjin Seo
> > 보낸 사람: Smith, Barry F. <bsmith at mcs.anl.gov>
> > 보낸 날짜: 2017년 12월 21일 목요일 오후 3:46:42
> > 받는 사람: 서승진 (기계항공및원자력공학부)
> > 참조: petsc-users at mcs.anl.gov
> > 제목: Re: [petsc-users] I have a question for PETSc example
> > In deed you can, yes many PETSc examples only feature a single field
> for simplicity, but multiple fields are fine. You simple provide your
> FormFunction and FormJacobian to handle both degrees of freedom per
> cell/node at the same time. You use SNES or TS depending on if your problem
> is time dependent and then use -pc_type lu to start. Once you have the
> physics correct come back and ask us about optimizing the linear solver
> with preconditioners; but until you have the physics correct it is absurd
> to waste time worrying about making the linear solver efficient. What you
> want to do, many people do and is not a big deal.
> > Barry
> > > On Dec 21, 2017, at 12:27 AM, 서승진 (기계항공및원자력공학부) <mistloin at unist.ac.kr>
> wrote:
> > > Dear PETSc-user
> > > I am trying to solve thermal and fluid equations within a porous
> structure.
> > > The thermal equation includes a non-linear term of pressure and the
> fluid equation has a boundary condition using temperature gradient.
> > > Is there any way I can solve these two equations at the same time,
> instead of solving temperature first with previous pressure distribution
> and then pressure and update temperature?
> > > Many examples solve only one PDF instead of coupling several physics.
> > > Please recommend me which solver is appropriate for my case?
> > > Best regards,
> > > Seungjin Seo
> experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180118/9cc0adbd/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180118/9cc0adbd/attachment-0006.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180118/9cc0adbd/attachment-0007.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180118/9cc0adbd/attachment-0008.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180118/9cc0adbd/attachment-0009.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180118/9cc0adbd/attachment-0010.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180118/9cc0adbd/attachment-0011.png>
