[petsc-users] petsc4py, cython
Jaroslaw Piwonski (CAU) jpi at informatik.uni-kiel.de
Fri Jan 12 08:38:43 CST 2018
Dear PETSc users,
I would like to use petsc4py to create (say) PETSc vectors and
then pass them to a routine from a module written in Cython,
which in turn passes them to a routine written in C:
main.py ========================================================
from petsc4py import PETSc
import m3d4py
if __name__ == "__main__":
    v = PETSc.Vec()
    v.create()
    v.setType("standard")
    v.setSizes(3)
    v.set(0.3)
    v.assemble()
    m3d4py.sub_pyx(v)
m3d4py.pyx ========================================================
cimport petsc4py.PETSc as PETSc
cdef extern from "sub.c":
    int sub_c(Vec)
def sub_pyx(PETSc.Vec vec):
    vec.view()
    sub_c(vec.vec)
sub.c ========================================================
#include "petsc.h"
extern PetscErrorCode sub_c(Vec);
PetscErrorCode sub_c(Vec vec) {
    PetscFunctionBegin;
    VecView(vec, PETSC_VIEWER_STDOUT_WORLD);
    PetscFunctionReturn(0);
I used (ana/mini)conda to install petsc4py and cython. When I try to
compile the cython file I get the following error:
$> cython -f m3d4py.pyx -I /Users/jpicau/miniconda3/lib/python3.6/site-packages/petsc4py/include/
Error compiling Cython file:
    int sub_c(Vec)
    vec.view()
    sub_c(vec.vec)
m3d4py.pyx:8:13: Cannot convert 'PetscVec' to Python object
make: *** [all] Error 1
I somehow realize that this is not correct. But comparing this to the petsc4py implementation ...
petscvec.pxi:
	int VecView(PetscVec,PetscViewer)
Vec.pyx:
    def view(self, Viewer viewer=None):
        cdef PetscViewer vwr = NULL
        if viewer is not None: vwr = viewer.vwr
        CHKERR( VecView(self.vec, vwr) )
… I do not understand why.
Can some explain this to me or just give me a hint where I can dig further, please?
And just out of pure curiosity, why isn’t the return value of VecView() in petscvec.pxi defined as PetscErrorCode?
The type seems to be defined:
libpetsc4py.pyx:
    ctypedef int PetscErrorCode
Thanks in advance,
Jaroslaw
Dr. Jaroslaw Piwonski
Christian-Albrechts-Universität zu Kiel
Institut für Informatik
Algorithmische Optimale Steuerung — CO2-Aufnahme des Meeres
Christian-Albrechts-Platz 4
24118 Kiel
Telefon: +49 431 880-7452
Telefax: +49 431 880-7618
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180112/0596490a/attachment.html>
