[petsc-users] Issue with KSPSolve when the number of CPUs are larger than four
Matthew Knepley
knepley at gmail.com
Wed Jan 10 18:04:23 CST 2018
On Wed, Jan 10, 2018 at 4:41 PM, Mohammad R. Gohardoust <
gohardoust at email.arizona.edu> wrote:
> Hi,
> I hope you are doing well. I am Mohammad, a PhD student of environmental
> sciences at the University of Arizona.
> I do appreciate any help that can shed some light on the issue I have:
> recently I have added a feature to an existing parallel code called
> 'parswms' which solves water and solute transport in soils. The code uses
> MPI and parmetis for the parallelization purposes and petsc package
> (KSPSolve) for solving linear systems. I have it installed on the UofA
> HPC : the issue is that it works well if the number of CPUs are up to 4!
> but when I add to this number the numerical linear solver (here it is
> 'KSPCGS') stops with the error of 'KSP_DIVERGED_NANORINF'.
> Would you mind please giving me some hints, suggestions or resources in
> this regard?
It sounds like you might have a problem in matrix assembly. However, first
use -pc_type gmres instead since
it has nicer numerical behavior (I believe).
Matt
> Best Regards,
> Mohammad
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180110/ea07fead/attachment.html>
