[petsc-users] Weak scaling test with geometric multigrid
Buesing, Henrik
hbuesing at eonerc.rwth-aachen.de
Wed Jan 10 05:25:11 CST 2018
Dear all,
I am doing a weak scaling test using geometric multigrid. With increasing the number of cells, and the number of processes, I also increase the number of multigrid levels. With 64 cores, 12288 cells in x-direction and 11 multigrid levels, I see error message [1].
Could you help me understand what is happening here?
The characteristics of the weak scaling test are summarized in table [2]. Refinement level 7-9 went through fine.
Thank you!
Henrik
[1]
[0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[0]PETSC ERROR: Argument out of range
[0]PETSC ERROR: Partition in x direction is too fine! 12 16
[0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[0]PETSC ERROR: Petsc Development GIT revision: v3.8.2-48-g851ec02 GIT Date: 2017-12-05 09:52:17 -0600
[0]PETSC ERROR: shem_fw64gnu_const.x on a gnu_openmpi named linuxihfc033.rz.RWTH-Aachen.DE by hb111949 Wed Jan 10 11:48:09 2018
[0]PETSC ERROR: Configure options --download-fblaslapack --with-cc=mpicc -with-fc=mpif90 --with-cxx=mpicxx --download-hypre --download-superlu_dist --download-suitesparse --download-scalapack --download-blacs --download-hdf5 --download-parmetis --download-metis --with-debugging=0 --download-mumps
[0]PETSC ERROR: #1 DMSetUp_DA_3D() line 299 in /rwthfs/rz/cluster/work/hb111949/Code/petsc/src/dm/impls/da/da3.c
[0]PETSC ERROR: #2 DMSetUp_DA() line 25 in /rwthfs/rz/cluster/work/hb111949/Code/petsc/src/dm/impls/da/dareg.c
[0]PETSC ERROR: #3 DMSetUp() line 720 in /rwthfs/rz/cluster/work/hb111949/Code/petsc/src/dm/interface/dm.c
[0]PETSC ERROR: #4 DMCoarsen_DA() line 1203 in /rwthfs/rz/cluster/work/hb111949/Code/petsc/src/dm/impls/da/da.c
[0]PETSC ERROR: #5 DMCoarsen() line 2427 in /rwthfs/rz/cluster/work/hb111949/Code/petsc/src/dm/interface/dm.c
[0]PETSC ERROR: #6 PCSetUp_MG() line 618 in /rwthfs/rz/cluster/work/hb111949/Code/petsc/src/ksp/pc/impls/mg/mg.c
[0]PETSC ERROR: #7 PCSetUp() line 924 in /rwthfs/rz/cluster/work/hb111949/Code/petsc/src/ksp/pc/interface/precon.c
[0]PETSC ERROR: #8 KSPSetUp() line 381 in /rwthfs/rz/cluster/work/hb111949/Code/petsc/src/ksp/ksp/interface/itfunc.c
[0]PETSC ERROR: #9 KSPSolve() line 612 in /rwthfs/rz/cluster/work/hb111949/Code/petsc/src/ksp/ksp/interface/itfunc.c
[0]PETSC ERROR: #10 SNESSolve_NEWTONLS() line 224 in /rwthfs/rz/cluster/work/hb111949/Code/petsc/src/snes/impls/ls/ls.c
[0]PETSC ERROR: #11 SNESSolve() line 4179 in /rwthfs/rz/cluster/work/hb111949/Code/petsc/src/snes/interface/snes.c
[2]
# refinement level
# cores
# cells in x
# cells in y
# cells in z
# mg levels
7
1
1536
1
256
8
8
4
3072
1
512
9
9
16
6144
1
1024
10
10
64
12288
1
2048
11
Dipl.-Math. Henrik Büsing
Institute for Applied Geophysics and Geothermal Energy
E.ON Energy Research Center
RWTH Aachen University
Mathieustr. 10 | Tel +49 (0)241 80 49907
52074 Aachen, Germany | Fax +49 (0)241 80 49889
http://www.eonerc.rwth-aachen.de/GGE
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180110/84d42724/attachment.html>
