[petsc-users] local/global Vec for SNES function/jacobian
Matteo Semplice matteo.semplice at unito.it
Tue Jan 9 00:53:58 CST 2018
Dear all,
     I could not find info on the manual but from the examples and my
own trying I guess that the vectors involved in the SNESfunction should
be global ones and that, if one needs ghosts values to compute the
function and/or the jacobian, should do a GlobalToLocal communication
inside the function. Correct? (I get errors of inconsistent dimensions
between Vecs and Mats if I call SNESSolve(snes,b, localU)...)
     Since I need the ghost values both in the function and in the
jacobian evaluation, would it be safe (and worthwhile) to do define a
local vector in the ctx, perform the communication in the function and
using the vec in the ctx in the jacobian evaluation (without performing
again the communication in the SNESJacobianFunction?)... Put in other
words, is it guaranteed that each call to the jacobian function is
preceded by a call to the function with the same x argument?
     Matteo Semplice
