[petsc-users] Fortran interface of MatNullSpaceCreate
Smith, Barry F. bsmith at mcs.anl.gov
Mon Feb 26 18:07:46 CST 2018
> On Feb 26, 2018, at 5:38 PM, Sanjay Govindjee <s_g at berkeley.edu> wrote:
> If PETSc is expecting an integer, I presume it is fine to pass PETSC_NULL_INTEGER(1)?
  Not if the function has an interface definition. Fortran interfaces distinguish between   passing an integer a and an integer a(1) so you can
only use PETSC_NULL_INTEGER if it expects an array.
> On 2/26/18 11:53 PM, Smith, Barry F. wrote:
>> PETSC_NULL_INTEGER is actually declared as an array of size 1 (this is why you get the confusing message about no specific subroutine that matches). PETSC_NULL_INTEGER  can only be passed where PETSc expects and integer array, not an integer scalar.
>>   Barry
> Sanjay Govindjee, PhD, PE
> Horace, Dorothy, and Katherine Johnson Professor in Engineering
> 779 Davis Hall
> University of California
> Berkeley, CA 94720-1710
> Voice:  +1 510 642 6060
> FAX:    +1 510 643 5264
> s_g at berkeley.edu
> http://faculty.ce.berkeley.edu/sanjay
> Books:
> Engineering Mechanics of Deformable
> Solids: A Presentation with Exercises
> http://ukcatalogue.oup.com/product/9780199651641.do
> http://amzn.com/0199651647
> Engineering Mechanics 3 (Dynamics) 2nd Edition
> http://www.springer.com/978-3-642-53711-0
> http://amzn.com/3642537111
> Engineering Mechanics 3, Supplementary Problems: Dynamics
> http://www.amzn.com/B00SOXN8JU
