[petsc-users] Compiling problem after upgrading to PETSc 3.8.3
Smith, Barry F.
bsmith at mcs.anl.gov
Tue Feb 20 21:44:36 CST 2018
Did you follow the directions in the changes file for 3.8?
<li>Replace calls to DMDACreateXd() with DMDACreateXd(), [DMSetFromOptions()] DMSetUp()</li>
<li>DMDACreateXd() no longer can take negative values for dimensons, instead pass positive values and call DMSetFromOptions() immediately after</li>
I suspect you are not calling DMSetUp() and this is causing the problem.
Barry
> On Feb 20, 2018, at 7:35 PM, TAY wee-beng <zonexo at gmail.com> wrote:
> On 21/2/2018 10:47 AM, Smith, Barry F. wrote:
>> Try setting
>> u_global = tVec(1)
>> immediately before the call to DMCreateGlobalVector()
> Hi,
> I added the line in but still got the same error below. Btw, my code is organised as:
> module global_data
> #include "petsc/finclude/petsc.h"
> use petsc
> use kdtree2_module
> implicit none
> save
> Vec u_local,u_global ...
> contains
> subroutine allo_var
> u_global = tVec(1)
> call DMCreateGlobalVector(da_u,u_global,ierr)
> [0]PETSC ERROR: --------------------- Error Message ----------------------------
> [0]PETSC ERROR: Null argument, when expecting valid pointer
> [0]PETSC ERROR: Null Object: Parameter # 2
> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trou
> ble shooting.
> [0]PETSC ERROR: Petsc Release Version 3.8.3, Dec, 09, 2017
> [0]PETSC ERROR: C:\Obj_tmp\ibm3d_IIB_mpi\Debug\ibm3d_IIB_mpi.exe on a petsc-3.8.
> 3_win64_msmpi_vs2008 named 1C3YYY1-PC by tsltaywb Wed Feb 21 11:18:20 2018
> [0]PETSC ERROR: Configure options --with-cc="win32fe icl" --with-fc="win32fe ifo
> rt" --with-cxx="win32fe icl" --download-fblaslapack --with-mpi-include="[/cygdri
> ve/c/Program Files (x86)/Microsoft SDKs/MPI/Include,/cygdrive/c/Program Files (x
> 86)/Microsoft SDKs/MPI/Include/x64]" --with-mpi-mpiexec="/cygdrive/c/Program Fil
> es/Microsoft MPI/Bin/mpiexec.exe" --with-debugging=1 --with-file-create-pause=1
> --prefix=/cygdrive/c/wtay/Lib/petsc-3.8.3_win64_msmpi_vs2008 --with-mpi-lib="[/c
> ygdrive/c/Program Files (x86)/Microsoft SDKs/MPI/Lib/x64/msmpifec.lib,/cygdrive/
> c/Program Files (x86)/Microsoft SDKs/MPI/Lib/x64/msmpi.lib]" --with-shared-libra
> ries=0
> [0]PETSC ERROR: #1 VecSetLocalToGlobalMapping() line 78 in C:\Source\PETSC-~2.3\
> src\vec\vec\INTERF~1\vector.c
> [0]PETSC ERROR: #2 DMCreateGlobalVector_DA() line 41 in C:\Source\PETSC-~2.3\src
> \dm\impls\da\dadist.c
> [0]PETSC ERROR: #3 DMCreateGlobalVector() line 844 in C:\Source\PETSC-~2.3\src\d
> m\INTERF~1\dm.c
> Thanks.
>>> On Feb 20, 2018, at 6:40 PM, TAY wee-beng <zonexo at gmail.com> wrote:
>>> Hi,
>>> Indeed, replacing tvec with t_vec solves the problem. Now I'm trying to debug step by step. I got into problem when calling:
>>> The error is:
>>> ble shooting.
>>> 3_win64_msmpi_vs2008 named 1C3YYY1-PC by tsltaywb Wed Feb 21 10:20:20 2018
>>> ve/c/Program Files (x86)/Microsoft SDKs/MPI/Include,/cygdrive/c/Program Files (x....
>>> But all I changed is from:
>>> module global_data
>>> use petsc
>>> use kdtree2_module
>>> implicit none
>>> save
>>> !grid variables
>>> integer :: size_x,s....
>>> to
>>> module global_data
>>> use kdtree2_module
>>> implicit none
>>> save
>>> #include "petsc/finclude/petsc.h90"
>>> !grid variables
>>> da_u, u_global were declared thru:
>>> DM da_u,da_v,...
>>> DM da_cu_types ...
>>> Vec u_local,u_global,v_local...
>>> So what could be the problem?
>>> Thank you very much.
>>> Yours sincerely,
>>> TAY Wee-Beng (Zheng Weiming) 郑伟明
>>> Personal research webpage: http://tayweebeng.wixsite.com/website
>>> Youtube research showcase: https://www.youtube.com/channel/UC72ZHtvQNMpNs2uRTSToiLA
>>> linkedin: www.linkedin.com/in/tay-weebeng
>>> On 20/2/2018 10:46 PM, Jose E. Roman wrote:
>>>> Probably the first error is produced by using a variable (mpi_comm) with the same name as an MPI type.
>>>> The second error I guess is due to variable tvec, since a Fortran type tVec is now being defined in src/vec/f90-mod/petscvec.h
>>>> Jose
>>>>> El 20 feb 2018, a las 15:35, Smith, Barry F. <bsmith at mcs.anl.gov> escribió:
>>>>> Please run a clean compile of everything and cut and paste all the output. This will make it much easier to debug than trying to understand your snippets of what is going wrong.
>>>>>> On Feb 20, 2018, at 1:56 AM, TAY Wee Beng <tsltaywb at nus.edu.sg> wrote:
>>>>>> Hi,
>>>>>> I was previously using PETSc 3.7.6 on different clusters with both Intel
>>>>>> Fortran and GNU Fortran. After upgrading, I met some problems when
>>>>>> trying to compile:
>>>>>> On Intel Fortran:
>>>>>> Previously, I was using:
>>>>>> in *.F90 when requires the use of PETSc
>>>>>> I read in the change log that h90 is no longer there and so I replaced
>>>>>> with #include "petsc/finclude/petsc.h"
>>>>>> It worked. But I also have some *.F90 which do not use PETSc. However,
>>>>>> they use some modules which uses PETSc.
>>>>>> Now I can't compile them. The error is :
>>>>>> math_routine.f90(3): error #7002: Error in opening the compiled module
>>>>>> file. Check INCLUDE paths. [PETSC]
>>>>>> use mpi_subroutines
>>>>>> mpi_subroutines is a module which uses PETSc, and it compiled w/o problem.
>>>>>> The solution is that I have to compile e.g. math_routine.F90 as if they
>>>>>> use PETSc, by including PETSc include and lib files.
>>>>>> May I know why this is so? It was not necessary before.
>>>>>> Anyway, it managed to compile until it reached hypre.F90.
>>>>>> Previously, due to some bugs, I have to compile hypre with the -r8
>>>>>> option. Also, I have to use:
>>>>>> integer(8) mpi_comm
>>>>>> mpi_comm = MPI_COMM_WORLD
>>>>>> to make my codes work with HYPRE.
>>>>>> But now, compiling gives the error:
>>>>>> hypre.F90(11): error #6401: The attributes of this name conflict with
>>>>>> those made accessible by a USE statement. [MPI_COMM]
>>>>>> integer(8) mpi_comm
>>>>>> hypre.F90(84): error #6478: A type-name must not be used as a
>>>>>> variable. [MPI_COMM]
>>>>>> hypre.F90(84): error #6303: The assignment operation or the binary
>>>>>> expression operation is invalid for the data types of the two
>>>>>> operands. [1140850688]
>>>>>> hypre.F90(100): error #6478: A type-name must not be used as a
>>>>>> call HYPRE_StructGridCreate(mpi_comm, 3, grid_hypre, ierr)
>>>>>> What's actually happening? Why can't I compile now?
>>>>>> On GNU gfortran:
>>>>>> I tried to use similar tactics as above here. However, when compiling
>>>>>> math_routine.F90, I got the error:
>>>>>> math_routine.F90:1333:21:
>>>>>> call subb(orig,vert1,tvec)
>>>>>> 1
>>>>>> Error: Invalid procedure argument at (1)
>>>>>> math_routine.F90:1339:18:
>>>>>> qvec = cross_pdt2(tvec,edge1)
>>>>>> 1
>>>>>> math_routine.F90:1345:21:
>>>>>> uu = dot_product(tvec,pvec)
>>>>>> 1
>>>>>> Error: ‘vector_a’ argument of ‘dot_product’ intrinsic at (1) must be
>>>>>> numeric or LOGICAL
>>>>>> math_routine.F90:1371:21:
>>>>>> These errors were not present before. My variables are mostly vectors:
>>>>>> real(8), intent(in) ::
>>>>>> orig(3),infinity(3),vert1(3),vert2(3),vert3(3),normal(3)
>>>>>> real(8) :: uu,vv,dir(3)
>>>>>> real(8) :: edge1(3),edge2(3),tvec(3),pvec(3),qvec(3),det,inv_det,epsilon,d,t
>>>>>> I wonder what happened?
>>>>>> Please advice.
>>>>>> Yours sincerely,
>>>>>> TAY Wee-Beng 郑伟明
>>>>>> Research Scientist
>>>>>> Experimental AeroScience Group
>>>>>> Temasek Laboratories
>>>>>> National University of Singapore
>>>>>> T-Lab Building
>>>>>> 5A, Engineering Drive 1, #02-02
>>>>>> Singapore 117411
>>>>>> Phone: +65 65167330
>>>>>> E-mail: tsltaywb at nus.edu.sg
>>>>>> http://www.temasek-labs.nus.edu.sg/program/program_aeroexperimental_tsltaywb.php
>>>>>> ________________________________
>>>>>> Important: This email is confidential and may be privileged. If you are not the intended recipient, please delete it and notify us immediately; you should not copy or use it for any purpose, nor disclose its contents to any other person. Thank you.
