[petsc-users] Compiling problem after upgrading to PETSc 3.8.3
    TAY wee-beng
    zonexo at gmail.com
    Tue Feb 20 21:35:14 CST 2018
On 21/2/2018 10:47 AM, Smith, Barry F. wrote:
>    Try setting
>    u_global = tVec(1)
>    immediately before the call to DMCreateGlobalVector()
I added the line in but still got the same error below. Btw, my code is
organised as:
module global_data
#include "petsc/finclude/petsc.h"
use petsc
use kdtree2_module
implicit none
save
Vec u_local,u_global ...
contains
subroutine allo_var
u_global = tVec(1)
call DMCreateGlobalVector(da_u,u_global,ierr)
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Null argument, when expecting valid pointer
[0]PETSC ERROR: Null Object: Parameter # 2
[0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
for trou
ble shooting.
[0]PETSC ERROR: Petsc Release Version 3.8.3, Dec, 09, 2017
[0]PETSC ERROR: C:\Obj_tmp\ibm3d_IIB_mpi\Debug\ibm3d_IIB_mpi.exe on a
petsc-3.8.
3_win64_msmpi_vs2008 named 1C3YYY1-PC by tsltaywb Wed Feb 21 11:18:20 2018
[0]PETSC ERROR: Configure options --with-cc="win32fe icl"
--with-fc="win32fe ifo
rt" --with-cxx="win32fe icl" --download-fblaslapack
--with-mpi-include="[/cygdri
ve/c/Program Files (x86)/Microsoft SDKs/MPI/Include,/cygdrive/c/Program
Files (x
86)/Microsoft SDKs/MPI/Include/x64]"
--with-mpi-mpiexec="/cygdrive/c/Program Fil
es/Microsoft MPI/Bin/mpiexec.exe" --with-debugging=1
--with-file-create-pause=1
--prefix=/cygdrive/c/wtay/Lib/petsc-3.8.3_win64_msmpi_vs2008
--with-mpi-lib="[/c
ygdrive/c/Program Files (x86)/Microsoft
SDKs/MPI/Lib/x64/msmpifec.lib,/cygdrive/
c/Program Files (x86)/Microsoft SDKs/MPI/Lib/x64/msmpi.lib]"
--with-shared-libra
ries=0
[0]PETSC ERROR: #1 VecSetLocalToGlobalMapping() line 78 in
C:\Source\PETSC-~2.3\
src\vec\vec\INTERF~1\vector.c
[0]PETSC ERROR: #2 DMCreateGlobalVector_DA() line 41 in
C:\Source\PETSC-~2.3\src
\dm\impls\da\dadist.c
[0]PETSC ERROR: #3 DMCreateGlobalVector() line 844 in
C:\Source\PETSC-~2.3\src\d
m\INTERF~1\dm.c
Thanks.
>> On Feb 20, 2018, at 6:40 PM, TAY wee-beng <zonexo at gmail.com> wrote:
>> Hi,
>> Indeed, replacing tvec with t_vec solves the problem. Now I'm trying to debug step by step. I got into problem when calling:
>> The error is:
>> [0]PETSC ERROR: --------------------- Error Message ----------------------------
>> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trou
>> ble shooting.
>> [0]PETSC ERROR: C:\Obj_tmp\ibm3d_IIB_mpi\Debug\ibm3d_IIB_mpi.exe on a petsc-3.8.
>> 3_win64_msmpi_vs2008 named 1C3YYY1-PC by tsltaywb Wed Feb 21 10:20:20 2018
>> [0]PETSC ERROR: Configure options --with-cc="win32fe icl" --with-fc="win32fe ifo
>> rt" --with-cxx="win32fe icl" --download-fblaslapack --with-mpi-include="[/cygdri
>> ve/c/Program Files (x86)/Microsoft SDKs/MPI/Include,/cygdrive/c/Program Files (x....
>> But all I changed is from:
>> module global_data
>> use petsc
>> use kdtree2_module
>> implicit none
>> save
>> !grid variables
>> integer :: size_x,s....
>> to
>> module global_data
>> use kdtree2_module
>> implicit none
>> save
>> #include "petsc/finclude/petsc.h90"
>> !grid variables
>> da_u, u_global were declared thru:
>> DM  da_u,da_v,...
>> DM  da_cu_types ...
>> Vec u_local,u_global,v_local...
>> So what could be the problem?
>> Thank you very much.
>> Yours sincerely,
>> TAY Wee-Beng (Zheng Weiming) 郑伟明
>> Personal research webpage: http://tayweebeng.wixsite.com/website
>> Youtube research showcase: https://www.youtube.com/channel/UC72ZHtvQNMpNs2uRTSToiLA
>> linkedin: www.linkedin.com/in/tay-weebeng
>> On 20/2/2018 10:46 PM, Jose E. Roman wrote:
>>> Probably the first error is produced by using a variable (mpi_comm) with the same name as an MPI type.
>>> The second error I guess is due to variable tvec, since a Fortran type tVec is now being defined in src/vec/f90-mod/petscvec.h
>>> Jose
>>>> El 20 feb 2018, a las 15:35, Smith, Barry F. <bsmith at mcs.anl.gov> escribió:
>>>>    Please run a clean compile of everything and cut and paste all the output. This will make it much easier to debug than trying to understand your snippets of what is going wrong.
>>>>> On Feb 20, 2018, at 1:56 AM, TAY Wee Beng <tsltaywb at nus.edu.sg> wrote:
>>>>> Hi,
>>>>> I was previously using PETSc 3.7.6 on different clusters with both Intel
>>>>> Fortran and GNU Fortran. After upgrading, I met some problems when
>>>>> trying to compile:
>>>>> On Intel Fortran:
>>>>> Previously, I was using:
>>>>> in *.F90 when requires the use of PETSc
>>>>> I read in the change log that h90 is no longer there and so I replaced
>>>>> with #include "petsc/finclude/petsc.h"
>>>>> It worked. But I also have some *.F90 which do not use PETSc. However,
>>>>> they use some modules which uses PETSc.
>>>>> Now I can't compile them. The error is :
>>>>> math_routine.f90(3): error #7002: Error in opening the compiled module
>>>>> file.  Check INCLUDE paths.   [PETSC]
>>>>> use mpi_subroutines
>>>>> mpi_subroutines is a module which uses PETSc, and it compiled w/o problem.
>>>>> The solution is that I have to compile e.g.  math_routine.F90 as if they
>>>>> use PETSc, by including PETSc include and lib files.
>>>>> May I know why this is so? It was not necessary before.
>>>>> Anyway, it managed to compile until it reached hypre.F90.
>>>>> Previously, due to some bugs, I have to compile hypre with the -r8
>>>>> option. Also, I have to use:
>>>>> integer(8) mpi_comm
>>>>> mpi_comm = MPI_COMM_WORLD
>>>>> to make my codes work with HYPRE.
>>>>> But now, compiling gives the error:
>>>>> hypre.F90(11): error #6401: The attributes of this name conflict with
>>>>> those made accessible by a USE statement.   [MPI_COMM]
>>>>> integer(8) mpi_comm
>>>>> hypre.F90(84): error #6478: A type-name must not be used as a
>>>>> variable.   [MPI_COMM]
>>>>> hypre.F90(84): error #6303: The assignment operation or the binary
>>>>> expression operation is invalid for the data types of the two
>>>>> operands.   [1140850688]
>>>>> hypre.F90(100): error #6478: A type-name must not be used as a
>>>>>        call HYPRE_StructGridCreate(mpi_comm, 3, grid_hypre, ierr)
>>>>> What's actually happening? Why can't I compile now?
>>>>> On GNU gfortran:
>>>>> I tried to use similar tactics as above here. However, when compiling
>>>>> math_routine.F90, I got the error:
>>>>> math_routine.F90:1333:21:
>>>>> call subb(orig,vert1,tvec)
>>>>>                     1
>>>>> Error: Invalid procedure argument at (1)
>>>>> math_routine.F90:1339:18:
>>>>> qvec = cross_pdt2(tvec,edge1)
>>>>>                  1
>>>>> math_routine.F90:1345:21:
>>>>>     uu = dot_product(tvec,pvec)
>>>>>                     1
>>>>> Error: ‘vector_a’ argument of ‘dot_product’ intrinsic at (1) must be
>>>>> numeric or LOGICAL
>>>>> math_routine.F90:1371:21:
>>>>> These errors were not present before. My variables are mostly vectors:
>>>>> real(8), intent(in) ::
>>>>> orig(3),infinity(3),vert1(3),vert2(3),vert3(3),normal(3)
>>>>> real(8) :: uu,vv,dir(3)
>>>>> real(8) :: edge1(3),edge2(3),tvec(3),pvec(3),qvec(3),det,inv_det,epsilon,d,t
>>>>> I wonder what happened?
>>>>> Please advice.
>>>>> Yours sincerely,
>>>>> TAY Wee-Beng 郑伟明
>>>>> Research Scientist
>>>>> Experimental AeroScience Group
>>>>> Temasek Laboratories
>>>>> National University of Singapore
>>>>> T-Lab Building
>>>>> 5A, Engineering Drive 1, #02-02
>>>>> Singapore 117411
>>>>> Phone: +65 65167330
>>>>> E-mail: tsltaywb at nus.edu.sg
>>>>> http://www.temasek-labs.nus.edu.sg/program/program_aeroexperimental_tsltaywb.php
>>>>> ________________________________
>>>>> Important: This email is confidential and may be privileged. If you are not the intended recipient, please delete it and notify us immediately; you should not copy or use it for any purpose, nor disclose its contents to any other person. Thank you.
