[petsc-users] Compiling problem after upgrading to PETSc 3.8.3
    TAY wee-beng
    zonexo at gmail.com
    Tue Feb 20 20:40:08 CST 2018
Indeed, replacing tvec with t_vec solves the problem. Now I'm trying to
debug step by step. I got into problem when calling:
call DMCreateGlobalVector(da_u,u_global,ierr)
The error is:
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Null argument, when expecting valid pointer
[0]PETSC ERROR: Null Object: Parameter # 2
[0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
for trou
ble shooting.
[0]PETSC ERROR: Petsc Release Version 3.8.3, Dec, 09, 2017
[0]PETSC ERROR: C:\Obj_tmp\ibm3d_IIB_mpi\Debug\ibm3d_IIB_mpi.exe on a
petsc-3.8.
3_win64_msmpi_vs2008 named 1C3YYY1-PC by tsltaywb Wed Feb 21 10:20:20 2018
[0]PETSC ERROR: Configure options --with-cc="win32fe icl"
--with-fc="win32fe ifo
rt" --with-cxx="win32fe icl" --download-fblaslapack
--with-mpi-include="[/cygdri
ve/c/Program Files (x86)/Microsoft SDKs/MPI/Include,/cygdrive/c/Program
Files (x....
But all I changed is from:
module global_data
#include "petsc/finclude/petsc.h"
use petsc
use kdtree2_module
implicit none
save
!grid variables
integer :: size_x,s....
to
module global_data
use kdtree2_module
implicit none
save
#include "petsc/finclude/petsc.h90"
!grid variables
da_u, u_global were declared thru:
DM  da_u,da_v,...
DM  da_cu_types ...
Vec u_local,u_global,v_local...
So what could be the problem?
Thank you very much.
Yours sincerely,
TAY Wee-Beng (Zheng Weiming) 郑伟明
Personal research webpage: http://tayweebeng.wixsite.com/website
Youtube research showcase: https://www.youtube.com/channel/UC72ZHtvQNMpNs2uRTSToiLA
linkedin: www.linkedin.com/in/tay-weebeng
On 20/2/2018 10:46 PM, Jose E. Roman wrote:
> Probably the first error is produced by using a variable (mpi_comm) with the same name as an MPI type.
> The second error I guess is due to variable tvec, since a Fortran type tVec is now being defined in src/vec/f90-mod/petscvec.h
> Jose
>> El 20 feb 2018, a las 15:35, Smith, Barry F. <bsmith at mcs.anl.gov> escribió:
>>    Please run a clean compile of everything and cut and paste all the output. This will make it much easier to debug than trying to understand your snippets of what is going wrong.
>>> On Feb 20, 2018, at 1:56 AM, TAY Wee Beng <tsltaywb at nus.edu.sg> wrote:
>>> Hi,
>>> I was previously using PETSc 3.7.6 on different clusters with both Intel
>>> Fortran and GNU Fortran. After upgrading, I met some problems when
>>> trying to compile:
>>> On Intel Fortran:
>>> Previously, I was using:
>>> in *.F90 when requires the use of PETSc
>>> I read in the change log that h90 is no longer there and so I replaced
>>> with #include "petsc/finclude/petsc.h"
>>> It worked. But I also have some *.F90 which do not use PETSc. However,
>>> they use some modules which uses PETSc.
>>> Now I can't compile them. The error is :
>>> math_routine.f90(3): error #7002: Error in opening the compiled module
>>> file.  Check INCLUDE paths.   [PETSC]
>>> use mpi_subroutines
>>> mpi_subroutines is a module which uses PETSc, and it compiled w/o problem.
>>> The solution is that I have to compile e.g.  math_routine.F90 as if they
>>> use PETSc, by including PETSc include and lib files.
>>> May I know why this is so? It was not necessary before.
>>> Anyway, it managed to compile until it reached hypre.F90.
>>> Previously, due to some bugs, I have to compile hypre with the -r8
>>> option. Also, I have to use:
>>> integer(8) mpi_comm
>>> mpi_comm = MPI_COMM_WORLD
>>> to make my codes work with HYPRE.
>>> But now, compiling gives the error:
>>> hypre.F90(11): error #6401: The attributes of this name conflict with
>>> those made accessible by a USE statement.   [MPI_COMM]
>>> integer(8) mpi_comm
>>> hypre.F90(84): error #6478: A type-name must not be used as a
>>> variable.   [MPI_COMM]
>>> hypre.F90(84): error #6303: The assignment operation or the binary
>>> expression operation is invalid for the data types of the two
>>> operands.   [1140850688]
>>> hypre.F90(100): error #6478: A type-name must not be used as a
>>>        call HYPRE_StructGridCreate(mpi_comm, 3, grid_hypre, ierr)
>>> What's actually happening? Why can't I compile now?
>>> On GNU gfortran:
>>> I tried to use similar tactics as above here. However, when compiling
>>> math_routine.F90, I got the error:
>>> math_routine.F90:1333:21:
>>> call subb(orig,vert1,tvec)
>>>                     1
>>> Error: Invalid procedure argument at (1)
>>> math_routine.F90:1339:18:
>>> qvec = cross_pdt2(tvec,edge1)
>>>                  1
>>> math_routine.F90:1345:21:
>>>     uu = dot_product(tvec,pvec)
>>>                     1
>>> Error: ‘vector_a’ argument of ‘dot_product’ intrinsic at (1) must be
>>> numeric or LOGICAL
>>> math_routine.F90:1371:21:
>>> These errors were not present before. My variables are mostly vectors:
>>> real(8), intent(in) ::
>>> orig(3),infinity(3),vert1(3),vert2(3),vert3(3),normal(3)
>>> real(8) :: uu,vv,dir(3)
>>> real(8) :: edge1(3),edge2(3),tvec(3),pvec(3),qvec(3),det,inv_det,epsilon,d,t
>>> I wonder what happened?
>>> Please advice.
>>> Yours sincerely,
>>> TAY Wee-Beng 郑伟明
>>> Research Scientist
>>> Experimental AeroScience Group
>>> Temasek Laboratories
>>> National University of Singapore
>>> T-Lab Building
>>> 5A, Engineering Drive 1, #02-02
>>> Singapore 117411
>>> Phone: +65 65167330
>>> E-mail: tsltaywb at nus.edu.sg
>>> http://www.temasek-labs.nus.edu.sg/program/program_aeroexperimental_tsltaywb.php
>>> ________________________________
>>> Important: This email is confidential and may be privileged. If you are not the intended recipient, please delete it and notify us immediately; you should not copy or use it for any purpose, nor disclose its contents to any other person. Thank you.
