[petsc-users] Compiling problem after upgrading to PETSc 3.8.3
    Jose E. Roman
    jroman at dsic.upv.es
    Tue Feb 20 08:46:48 CST 2018
Probably the first error is produced by using a variable (mpi_comm) with the same name as an MPI type.
The second error I guess is due to variable tvec, since a Fortran type tVec is now being defined in src/vec/f90-mod/petscvec.h
Jose
> El 20 feb 2018, a las 15:35, Smith, Barry F. <bsmith at mcs.anl.gov> escribió:
>   Please run a clean compile of everything and cut and paste all the output. This will make it much easier to debug than trying to understand your snippets of what is going wrong.
>> On Feb 20, 2018, at 1:56 AM, TAY Wee Beng <tsltaywb at nus.edu.sg> wrote:
>> Hi,
>> I was previously using PETSc 3.7.6 on different clusters with both Intel
>> Fortran and GNU Fortran. After upgrading, I met some problems when
>> trying to compile:
>> On Intel Fortran:
>> Previously, I was using:
>> #include "petsc/finclude/petsc.h90"
>> in *.F90 when requires the use of PETSc
>> I read in the change log that h90 is no longer there and so I replaced
>> with #include "petsc/finclude/petsc.h"
>> It worked. But I also have some *.F90 which do not use PETSc. However,
>> they use some modules which uses PETSc.
>> Now I can't compile them. The error is :
>> math_routine.f90(3): error #7002: Error in opening the compiled module
>> file.  Check INCLUDE paths.   [PETSC]
>> use mpi_subroutines
>> mpi_subroutines is a module which uses PETSc, and it compiled w/o problem.
>> The solution is that I have to compile e.g.  math_routine.F90 as if they
>> use PETSc, by including PETSc include and lib files.
>> May I know why this is so? It was not necessary before.
>> Anyway, it managed to compile until it reached hypre.F90.
>> Previously, due to some bugs, I have to compile hypre with the -r8
>> option. Also, I have to use:
>> integer(8) mpi_comm
>> mpi_comm = MPI_COMM_WORLD
>> to make my codes work with HYPRE.
>> But now, compiling gives the error:
>> hypre.F90(11): error #6401: The attributes of this name conflict with
>> those made accessible by a USE statement.   [MPI_COMM]
>> integer(8) mpi_comm
>> hypre.F90(84): error #6478: A type-name must not be used as a
>> variable.   [MPI_COMM]
>> hypre.F90(84): error #6303: The assignment operation or the binary
>> expression operation is invalid for the data types of the two
>> operands.   [1140850688]
>> hypre.F90(100): error #6478: A type-name must not be used as a
>>       call HYPRE_StructGridCreate(mpi_comm, 3, grid_hypre, ierr)
>> What's actually happening? Why can't I compile now?
>> On GNU gfortran:
>> I tried to use similar tactics as above here. However, when compiling
>> math_routine.F90, I got the error:
>> math_routine.F90:1333:21:
>> call subb(orig,vert1,tvec)
>>                    1
>> Error: Invalid procedure argument at (1)
>> math_routine.F90:1339:18:
>> qvec = cross_pdt2(tvec,edge1)
>>                 1
>> math_routine.F90:1345:21:
>>    uu = dot_product(tvec,pvec)
>>                    1
>> Error: ‘vector_a’ argument of ‘dot_product’ intrinsic at (1) must be
>> numeric or LOGICAL
>> math_routine.F90:1371:21:
>> These errors were not present before. My variables are mostly vectors:
>> real(8), intent(in) ::
>> orig(3),infinity(3),vert1(3),vert2(3),vert3(3),normal(3)
>> real(8) :: uu,vv,dir(3)
>> real(8) :: edge1(3),edge2(3),tvec(3),pvec(3),qvec(3),det,inv_det,epsilon,d,t
>> I wonder what happened?
>> Please advice.
>> Thank you very much.
>> Yours sincerely,
>> TAY Wee-Beng 郑伟明
>> Research Scientist
>> Experimental AeroScience Group
>> Temasek Laboratories
>> National University of Singapore
>> T-Lab Building
>> 5A, Engineering Drive 1, #02-02
>> Singapore 117411
>> Phone: +65 65167330
>> E-mail: tsltaywb at nus.edu.sg
>> http://www.temasek-labs.nus.edu.sg/program/program_aeroexperimental_tsltaywb.php
>> Personal research webpage: http://tayweebeng.wixsite.com/website
>> Youtube research showcase: https://www.youtube.com/channel/UC72ZHtvQNMpNs2uRTSToiLA
>> linkedin: www.linkedin.com/in/tay-weebeng
>> ________________________________
>> Important: This email is confidential and may be privileged. If you are not the intended recipient, please delete it and notify us immediately; you should not copy or use it for any purpose, nor disclose its contents to any other person. Thank you.
