[petsc-users] Error when use DMPlexGetVertexNumbering
Danyang Su danyang.su at gmail.com
Fri Feb 16 12:45:39 CST 2018
Hi Matt,
I try to get the global vertex index and cell index from local mesh and
run into problem. What I need is local to global index (the original
index used in DMPlexCreateFromCellList is best, as user know exactly
where the node/cell is) for vertices and cells, which will be used to
assign material properties and some parameters to the specified
cell/vertex. I can use coordinates to select vertex/cell which has
already included, but still want to keep this feature. This is pretty
straightforward when using structured grid. For the unstructured grid, I
just got compiling error saying "You need a ISO C conforming compiler to
use the glibc headers"
Would you please let me know if I need to change the configuration of
PETSc or is there any alternative ways to avoid using
DMPlexGetVertexNumbering and DMPlexGetCellNumbering but get local to
global index?
The error information during compilation is shown below, followed by
PETSc configuration.
  -o ../../solver/solver_ddmethod.o ../../solver/solver_ddmethod.F90
In file included from /usr/include/features.h:375:0,
                  from /usr/include/stdio.h:28,
                  from
/home/dsu/Soft/PETSc/petsc-3.7.5/include/petscsys.h:161,
                  from /home/dsu/Soft/PETSc/petsc-3.7.5/include/petscis.h:8,
                  from
/home/dsu/Soft/PETSc/petsc-3.7.5/include/petscvec.h:10,
                  from
/home/dsu/Soft/PETSc/petsc-3.7.5/include/petscmat.h:7,
                  from
/home/dsu/Soft/PETSc/petsc-3.7.5/include/petsc/private/dmpleximpl.h:5,
                  from ../../solver/solver_ddmethod.F90:4122:
/usr/include/x86_64-linux-gnu/sys/cdefs.h:30:3: error: #error "You need
a ISO C conforming compiler to us\
  # error "You need a ISO C conforming compiler to use the glibc headers"
In file included from /usr/include/features.h:399:0,
                  from
                  from
                  from
                  from
/usr/include/x86_64-linux-gnu/gnu/stubs.h:7:0: fatal error:
gnu/stubs-32.h: No such file or directory
  # include <gnu/stubs-32.h>
compilation terminated.
make: [../../solver/solver_ddmethod.o] Error 1 (ignored)
PETSc configuration
--with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-mumps
--download-scalapack --download-parmetis --download-metis
--download-ptscotch --download-fblaslapack --download-mpich
--download-hypre --download-superlu_dist --download-hdf5=yes
--with-debugging=0 COPTFLAGS="-O3 -march=native -mtune=native"
CXXOPTFLAGS="-O3 -march=native -mtune=native" FOPTFLAGS="-O3
Thanks and regards,
Danyang
