[petsc-users] How to efficiently represent a diagonal matrix?
Matthew Knepley
knepley at gmail.com
Wed Feb 14 18:18:15 CST 2018
On Wed, Feb 14, 2018 at 7:11 PM, Fande Kong <fdkong.jd at gmail.com> wrote:
> On Wed, Feb 14, 2018 at 4:35 PM, Smith, Barry F. <bsmith at mcs.anl.gov>
> wrote:
>> What are you doing with the matrix?
> We are doing an explicit method. PDEs are discretized using a finite
> element method, so there is a mass matrix. The mass matrix will be lumped,
> and it becomes diagonal. We want to compute the inverse of the lumped
> matrix, and also do a few of matrix-vector multiplications using the
> lumped matrix or its inverse.
> The specific implementation won't make this more efficient?
I am doing this for Pylith. I think you should just do Vec operations, and
pull the inverse mass matrix to the rhs.
Matt
> Fande,
>> We don't have a diagonal matrix but it would be easy to add such a
>> beast if it was performance critical, which it probably isn't.
>> Barry
>> > On Feb 14, 2018, at 3:57 PM, Fande Kong <fdkong.jd at gmail.com> wrote:
>> > Hi All,
>> > If a matrix is always diagonal, what a good way to represent the
>> matrix? Still MPIAIJ, MPIBAIJ? Can we have a specific implementation for
>> this?
>> > Fande,
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180214/f6dba37a/attachment.html>
