[petsc-users] Add unstructured grid capability to existing structured grid code
Danyang Su
danyang.su at gmail.com
Wed Feb 14 12:47:14 CST 2018
Dear All,
I have a reactive transport code that was first developed using
structured grid and parallelized using PETSc. Both sequential version
(with or without PETSc) and parallel version work fine. Recently I have
finished the unstructured grid capability for the sequential version.
Next step work is to modify the necessary part to make the code
parallelized using unstructured grid.
For the structured grid code, it follows the following steps.
!domain decomposition
DMDACreate3D()
DMDAGetInfo()
DMDAGetCorners()
!timeloop begins
!calculate matrix entry and rhs
Solve Ax=b using PETSc
DMGlobalToLocalBegin()
DMGlobalToLocalEnd()
!end of timeloop
So far as I know, the domain decomposition part need to be modified. I
plan to use PETSc DMPlex class to do this job. Is this the best way to
port the code?
DMPlexCreateFromFile()
DMPlexDistribute()
!timeloop begins
!end of timeloop
Danyang
