[petsc-users] multiply a mpibaij matrix by its block diagonal inverse
Jed Brown
jed at jedbrown.org
Wed Feb 14 09:27:57 CST 2018
"Smith, Barry F." <bsmith at mcs.anl.gov> writes:
> Hmm, I never had this idea presented to me, I have no way to know if
> it is particularly good or bad. So essentially you transform the
> matrix "decoupling the physics alone the diagonal" and then do
> PCFIELDSPLIT instead of using PCFIELDSPLIT directly on the original
> equations.
We talked about this several years ago, e.g., in the context of a
low-Mach preconditioner (acting in the pressure space) when using
conservative variables.
