[petsc-users] with-openmp error with hypre
Kong, Fande
fande.kong at inl.gov
Tue Feb 13 13:02:50 CST 2018
Curious about the comparison of 16x4 VS 64.
Fande,
On Tue, Feb 13, 2018 at 11:44 AM, Bakytzhan Kallemov <bkallemov at lbl.gov>
wrote:
> Hi,
> I am not sure about 64 flat run,
> unfortunately I did not save logs since it's easy to run, but for 16 -
> here is the plot I got for different number of threads for KSPSolve time
> Baky
> On 02/13/2018 10:28 AM, Matthew Knepley wrote:
> On Tue, Feb 13, 2018 at 11:30 AM, Smith, Barry F. <bsmith at mcs.anl.gov>
> wrote:
>> > On Feb 13, 2018, at 10:12 AM, Mark Adams <mfadams at lbl.gov> wrote:
>> > FYI, we were able to get hypre with threads working on KNL on Cori by
>> going down to -O1 optimization. We are getting about 2x speedup with 4
>> threads and 16 MPI processes per socket. Not bad.
>> In other works using 16 MPI processes with 4 threads per process is
>> twice as fast as running with 64 mpi processes? Could you send the
>> -log_view output for these two cases?
> Is that what you mean? I took it to mean
> We ran 16MPI processes and got time T.
> We ran 16MPI processes with 4 threads each and got time T/2.
> I would likely eat my shirt if 16x4 was 2x faster than 64.
> Matt
>> > There error, flatlined or slightly diverging hypre solves, occurred
>> even in flat MPI runs with openmp=1.
>> But the answers are wrong as soon as you turn on OpenMP?
>> Thanks
>> Barry
>> > We are going to test the Haswell nodes next.
>> > On Thu, Jan 25, 2018 at 4:16 PM, Mark Adams <mfadams at lbl.gov> wrote:
>> > Baky (cc'ed) is getting a strange error on Cori/KNL at NERSC. Using
>> maint it runs fine with -with-openmp=0, it runs fine with -with-openmp=1
>> and gamg, but with hypre and -with-openmp=1, even running with flat MPI,
>> the solver seems flatline (see attached and notice that the residual starts
>> to creep after a few time steps).
>> > Maybe you can suggest a hypre test that I can run?
> experiments lead.
> -- Norbert Wiener
> <https://urldefense.proofpoint.com/v2/url?u=http-3A__www.caam.rice.edu_-257Emk51_&d=DwMDaQ&c=54IZrppPQZKX9mLzcGdPfFD1hxrcB__aEkJFOKJFd00&r=DUUt3SRGI0_JgtNaS3udV68GRkgV4ts7XKfj2opmiCY&m=ZS-L-0QdKGNAOTdfVWHmsv4U3pZmyEvneNWi1bnUBUc&s=Mo_G_7aeedH4UA8ZyO0DCM5xoWvnNhyUcFeSSgPnrBE&e=>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180213/1ec9be4d/attachment.html>
