[petsc-users] with-openmp error with hypre
Bakytzhan Kallemov bkallemov at lbl.gov
Tue Feb 13 12:44:45 CST 2018
I am not sure about 64 flat run,
unfortunately I did not save logs since it's easy to run,  but for 16 -
here is the plot I got for different number of threads for KSPSolve time
Baky
On 02/13/2018 10:28 AM, Matthew Knepley wrote:
> On Tue, Feb 13, 2018 at 11:30 AM, Smith, Barry F. <bsmith at mcs.anl.gov
> <mailto:bsmith at mcs.anl.gov>> wrote:
>     > On Feb 13, 2018, at 10:12 AM, Mark Adams <mfadams at lbl.gov
>     <mailto:mfadams at lbl.gov>> wrote:
>     > FYI, we were able to get hypre with threads working on KNL on
>     Cori by going down to -O1 optimization. We are getting about 2x
>     speedup with 4 threads and 16 MPI processes per socket. Not bad.
>       In other works using 16 MPI processes with 4 threads per process
>     is twice as fast as running with 64 mpi processes?  Could you send
>     the -log_view output for these two cases?
> Is that what you mean? I took it to mean
>   We ran 16MPI processes and got time T.
>   We ran 16MPI processes with 4 threads each and got time T/2.
> I would likely eat my shirt if 16x4 was 2x faster than 64.
>   Matt
>     > There error, flatlined or slightly diverging hypre solves,
>     occurred even in flat MPI runs with openmp=1.
>       But the answers are wrong as soon as you turn on OpenMP?
>        Thanks
>         Barry
>     > We are going to test the Haswell nodes next.
>     > On Thu, Jan 25, 2018 at 4:16 PM, Mark Adams <mfadams at lbl.gov
>     > Baky (cc'ed) is getting a strange error on Cori/KNL at NERSC.
>     Using maint it runs fine with -with-openmp=0, it runs fine with
>     -with-openmp=1 and gamg, but with hypre and -with-openmp=1, even
>     running with flat MPI, the solver seems flatline (see attached and
>     notice that the residual starts to creep after a few time steps).
>     > Maybe you can suggest a hypre test that I can run?
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/%7Emk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180213/709ab971/attachment-0001.html>
Type: image/x-eps
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180213/709ab971/attachment-0001.bin>
