[petsc-users] call to PetscViewerAsciiOpen
Matthew Knepley
knepley at gmail.com
Fri Dec 21 13:21:24 CST 2018
On Fri, Dec 21, 2018 at 2:08 PM Randall Mackie via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> The attached simple test program (when compiled in debug mode with
> gfortran and mpich) throws a lot of valgrind errors on the call to
> PetscViewerAsciiOpen, as well as the call to MPI_Comm_split.
> I can’t figure out if it is a problem in the code, or a bug somewhere else.
Those are all just memory leaks. I believe most will go away if you call
PetscViewDestroy().
Matt
> Any advice is appreciated.
> Thanks
> Randy M.
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181221/d3f08ef8/attachment.html>
