[petsc-users] call to PetscViewerAsciiOpen
Randall Mackie
rlmackie862 at gmail.com
Fri Dec 21 13:07:16 CST 2018
The attached simple test program (when compiled in debug mode with gfortran and mpich) throws a lot of valgrind errors on the call to PetscViewerAsciiOpen, as well as the call to MPI_Comm_split.
I can’t figure out if it is a problem in the code, or a bug somewhere else.
Any advice is appreciated.
Thanks
Randy M.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181221/6c33160c/attachment.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181221/6c33160c/attachment-0001.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181221/6c33160c/attachment-0002.obj>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181221/6c33160c/attachment.txt>
