[petsc-users] interpolate HDF5 mesh
Yann JOBIC
yann.jobic at univ-amu.fr
Thu Dec 20 13:35:30 CST 2018
Le 20/12/2018 à 19:05, Matthew Knepley a écrit :
> On Thu, Dec 20, 2018 at 12:56 PM Yann JOBIC <yann.jobic at univ-amu.fr
> <mailto:yann.jobic at univ-amu.fr>> wrote:
> Le 20/12/2018 à 16:40, Matthew Knepley a écrit :
>> On Thu, Dec 20, 2018 at 9:33 AM Yann JOBIC via petsc-users
>> <petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov>> wrote:
>> Dear Petsc Users,
>> When i'm using DMPlexCreateBoxMesh, my code works fine.
>> However, when i
>> load the "exact" same mesh from an HDF5 file, it's not
>> working anymore
>> (Nonlinear solve did not converge due to DIVERGED_FNORM_NAN
>> iterations 0).
>> The mesh view when i use DMPlexCreateBoxMesh looks like (i
>> labeled my
>> boudary nodes):
>> /* generated with DMPlexCreateBoxMesh */
>> DM Object: Mesh 1 MPI processes
>> type: plex
>> Mesh in 3 dimensions:
>> 0-cells: 216
>> 1-cells: 540
>> 2-cells: 450
>> 3-cells: 125
>> Labels:
>> Faces: 6 strata with value/size (2 (121), 4 (121), 3
>> (121), 6 (121),
>> 5 (121), 7 (121))
>> boundary: 1 strata with value/size (1 (602))
>> depth: 4 strata with value/size (0 (216), 1 (540), 2
>> (450), 3 (125))
>> Face Sets: 6 strata with value/size (6 (25), 5 (25), 3
>> (25), 4 (25),
>> 1 (25), 2 (25))
>> marker: 1 strata with value/size (1 (450))
>> And when i use DMPlexCreateFromFile, or DMLoad, i have :
>> /* generated with H5 file */
>> fin label DM
>> type: plex
>> 0-cells: 216
>> 1-cells: 540
>> 2-cells: 450
>> 3-cells: 125
>> Labels:
>> Faces: 6 strata with value/size (2 (121), 4 (121), 6
>> (121), 7 (121),
>> 5 (121), 3 (121))
>> (450), 3 (125))
>> It looks like my DM is not interpolated. Am i wrong ?
>> Its interpolated (you have 4 kinds of k-cells, instead of 2).
>> However, you are missing your
>> Face Sets marker, which probably means boundary conditions are
>> not getting applied.
> My Face marker is label to 1, with the label "boundary" (i used
> DMPlexMarkBoundaryFaces)
> After that, i create a new label, "Faces", with the number
> associated to the boundary condition.
> Faces = 0 -> ouest
> Faces = 1 -> est
> But you're right, I'm missing "Face Sets".
> You are also missing "marker". Both of these are added by the mesh
> creation function. Do you know
> which one you are using (setting in a boundary condition)?
I'm using DMPlexLoad_HDF5_Internal, which doesn't add those markers.
I'm using the label "Faces", that i create, with has a different value
defining the physical location of the boundary.
Next, my using this label in order to define my boundary condition, as :
ierr = PetscDSAddBoundary(prob, DM_BC_ESSENTIAL, "wall", "Faces", 0,
Ncomp, components, (void (*)(void)) zero, NInd, nord, NULL);CHKERRQ(ierr);
Ncomp, components, (void (*)(void)) zero, NInd, sud, NULL);CHKERRQ(ierr);
Ncomp, components, (void (*)(void)) zero, NInd, Back, NULL);CHKERRQ(ierr);
Ncomp, components, (void (*)(void)) zero, NInd, Top, NULL);CHKERRQ(ierr);
ierr = PetscDSAddBoundary(prob, DM_BC_ESSENTIAL, "in", "Faces", 0,
Ncomp, components, (void (*)(void)) uIn, NInd, west, NULL);CHKERRQ(ierr);
With:
const PetscInt Ncomp = 3; /* dim = 3 */
const PetscInt components[] = {0,1,2};
const PetscInt NInd = 1;
const PetscInt west[] = {2}; /* (x=0) */
const PetscInt est[] = {3}; /* (x=L_x) */
const PetscInt sud[] = {4}; /* (y=0) */
const PetscInt nord[] = {5}; /* (y=L_y) */
const PetscInt Back[] = {6}; /* (z=0) */
const PetscInt Top[] = {7}; /* (z=L_z) */
Is it the right way to do it ?
Should i have a different label for each boundary condition ? I thought
that the value was enough.
Yann
> Thanks,
> Matt
> I couldn't find the function which adds this label.
> Is there one ? or do i have to do as in DMPlexCreateCubeMesh_Internal?
> Thanks,
> Yann
>> Thanks,
>> Matt
>> It's strange, because when i use DMPlexCreateFromFile, i put
>> PETSC_TRUE
>> for interpolation.
>> Even after loading the mesh, i used DMPlexInterpolate, which
>> return a
>> new DM (not null).
>> Do you know what's happening here ?
>> Maybe my DIVERGED_FNORM_NAN comes from another part of the
>> code ?
>> (however only the mesh is changing)
>> Thanks,
>> Yann
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181220/88d49d44/attachment-0001.html>
