[petsc-users] interpolate HDF5 mesh
Matthew Knepley
knepley at gmail.com
Thu Dec 20 12:05:28 CST 2018
On Thu, Dec 20, 2018 at 12:56 PM Yann JOBIC <yann.jobic at univ-amu.fr> wrote:
> Le 20/12/2018 à 16:40, Matthew Knepley a écrit :
> On Thu, Dec 20, 2018 at 9:33 AM Yann JOBIC via petsc-users <
> petsc-users at mcs.anl.gov> wrote:
>> Dear Petsc Users,
>> When i'm using DMPlexCreateBoxMesh, my code works fine. However, when i
>> load the "exact" same mesh from an HDF5 file, it's not working anymore
>> (Nonlinear solve did not converge due to DIVERGED_FNORM_NAN iterations 0).
>> The mesh view when i use DMPlexCreateBoxMesh looks like (i labeled my
>> boudary nodes):
>> /* generated with DMPlexCreateBoxMesh */
>> DM Object: Mesh 1 MPI processes
>> type: plex
>> Mesh in 3 dimensions:
>> 0-cells: 216
>> 1-cells: 540
>> 2-cells: 450
>> 3-cells: 125
>> Labels:
>> Faces: 6 strata with value/size (2 (121), 4 (121), 3 (121), 6 (121),
>> 5 (121), 7 (121))
>> boundary: 1 strata with value/size (1 (602))
>> depth: 4 strata with value/size (0 (216), 1 (540), 2 (450), 3 (125))
>> Face Sets: 6 strata with value/size (6 (25), 5 (25), 3 (25), 4 (25),
>> 1 (25), 2 (25))
>> marker: 1 strata with value/size (1 (450))
>> And when i use DMPlexCreateFromFile, or DMLoad, i have :
>> /* generated with H5 file */
>> fin label DM
>> type: plex
>> 0-cells: 216
>> 1-cells: 540
>> 2-cells: 450
>> 3-cells: 125
>> Labels:
>> Faces: 6 strata with value/size (2 (121), 4 (121), 6 (121), 7 (121),
>> 5 (121), 3 (121))
>> It looks like my DM is not interpolated. Am i wrong ?
> Its interpolated (you have 4 kinds of k-cells, instead of 2). However, you
> are missing your
> Face Sets marker, which probably means boundary conditions are not getting
> applied.
> My Face marker is label to 1, with the label "boundary" (i used
> DMPlexMarkBoundaryFaces)
> After that, i create a new label, "Faces", with the number associated to
> the boundary condition.
> Faces = 0 -> ouest
> Faces = 1 -> est
> But you're right, I'm missing "Face Sets".
You are also missing "marker". Both of these are added by the mesh creation
function. Do you know
which one you are using (setting in a boundary condition)?
Matt
> I couldn't find the function which adds this label.
> Is there one ? or do i have to do as in DMPlexCreateCubeMesh_Internal?
> Thanks,
> Yann
> Thanks,
> Matt
>> It's strange, because when i use DMPlexCreateFromFile, i put PETSC_TRUE
>> for interpolation.
>> Even after loading the mesh, i used DMPlexInterpolate, which return a
>> new DM (not null).
>> Do you know what's happening here ?
>> Maybe my DIVERGED_FNORM_NAN comes from another part of the code ?
>> (however only the mesh is changing)
>> Thanks,
>> Yann
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181220/f40ac83d/attachment.html>
