[petsc-users] Can I use TAO for embarrassingly parallel problems with multiple threads?
    Matthew Knepley
    knepley at gmail.com
    Thu Dec 20 09:35:07 CST 2018
On Thu, Dec 20, 2018 at 10:30 AM Krzysztof Kamieniecki via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Hello All,
> I have an embarrassingly parallel problem that I would like to use TAO on,
> is there some way to do this with threads as opposed to multiple processes?
You should be able to run COMPLETELY independent object on different
threads. However, notice that
there is absolutely no advantage to doing this. Why do you want to run
independent instances on multiple
threads?
     Matt
>  I compiled PETSc with the following flags
> ./configure \
> --prefix=${DEP_INSTALL_DIR} \
> --with-threadsafety --with-log=0 --download-concurrencykit \
> --with-openblas=1 \
> --with-openblas-dir=${DEP_INSTALL_DIR} \
> --with-mpi=0 \
> --with-shared=0 \
> --with-debugging=0 COPTFLAGS='-O3' CXXOPTFLAGS='-O3' FOPTFLAGS='-O3'
> When I run TAO in multiple threads I get the error "Called VecxxxEnd() in
> a different order or with a different vector than VecxxxBegin()"
> Thanks,
> Krys
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181220/a3f5df32/attachment.html>
