[petsc-users] Efficient way to access and use entries of an MPI vector with ghost values
    Smith, Barry F.
    bsmith at mcs.anl.gov
    Tue Dec 18 12:06:38 CST 2018
> On Dec 18, 2018, at 9:36 AM, Marco Tiberga via petsc-users <petsc-users at mcs.anl.gov> wrote:
> Dear all,
> We are using PETSc in our (Fortran) CFD code, which we have recently parallelized.
> We need to access the values stored in the solution vector to assemble the matrix of the linear system. In particular, we need to access the values on the local elements, plus the ones on the first neighbors, which might be handled by other processes.
> Hence, we defined our solution vector as MPI Vec with ghost values.
> At the moment, to access all the required values, at each time step we update the ghost values, then call ‘VecGhostGetLocalForm’ and finally ‘VecGetArrayReadF90’.
> Since all these procedures are collective, we store the gotten values in a local Fortran array (of length n_local + n_ghosts) and then proceed with the parallel matrix assembly.
   Why do you need to copy the values from the VecGetArrayReadF90() vector to a local Fortran array? Why can't you just access them directly with the pointer obtained from VecGetArrayReadF90() as needed.
> The code works perfectly, so I believe we are doing things in the right way.
> However, I was wondering whether there is a more efficient way to access the local values of a ghosted vector; something not collective, so that we could access the values on-demand while assembling the matrix.
> In this way, we could avoid storing the values in Fortran array, thus saving memory.
> Less important issue, but it puzzles me: Why is VecGetArrayReadF90 collective while its C counterpart VecGetArrayRead is not? (same thing for VecRestoreArrayReadF90 and VecRestoreArrayRead).
   Hmm, the Read versions of these routines are not collective; can you point to where in the documentation it says they are collective so we can fix the documentation.  Note: the VecGetArray() (non-read only versions) are collective.
    Thanks
      Barry
> Thanks a lot for your time and help.
> Best regards,
> Marco Tiberga
> PhD candidate
> Delft University of Technology
> Faculty of Applied Sciences
> Radiation Science & Technology Department
> Mekelweg 15, 2629 JB Delft, The Netherlands
> E-Mail: m.tiberga at tudelft.nl
> Website: http://www.nera.rst.tudelft.nl/
