[petsc-users] Efficient way to access and use entries of an MPI vector with ghost values
Matthew Knepley
knepley at gmail.com
Tue Dec 18 10:22:20 CST 2018
On Tue, Dec 18, 2018 at 10:37 AM Marco Tiberga via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Dear all,
> We are using PETSc in our (Fortran) CFD code, which we have recently
> parallelized.
> We need to access the values stored in the solution vector to assemble the
> matrix of the linear system. In particular, we need to access the values on
> the local elements, plus the ones on the first neighbors, which might be
> handled by other processes.
> Hence, we defined our solution vector as MPI Vec with ghost values.
> At the moment, to access all the required values, at each time step we
> update the ghost values, then call ‘VecGhostGetLocalForm’ and finally
> ‘VecGetArrayReadF90’.
> Since all these procedures are collective, we store the gotten values in a
> local Fortran array (of length n_local + n_ghosts) and then proceed with
> the parallel matrix assembly.
> The code works perfectly, so I believe we are doing things in the right
> way.
> However, I was wondering whether there is a more efficient way to access
> the local values of a ghosted vector; something not collective,
These are just "Logically Collective" so there is no communication.
> so that we could access the values on-demand while assembling the matrix.
You can.
> In this way, we could avoid storing the values in Fortran array, thus
> saving memory.
The array is not being copied. It is just an F90 view into the actual
storage.
> Less important issue, but it puzzles me: Why is VecGetArrayReadF90
> collective while its C counterpart VecGetArrayRead is not?
It is also Logically Collective. The current webpage has this correct.
Matt
> (same thing for VecRestoreArrayReadF90 and VecRestoreArrayRead).
> Thanks a lot for your time and help.
> Best regards,
> Marco Tiberga
> PhD candidate
> Delft University of Technology
> Faculty of Applied Sciences
> Radiation Science & Technology Department
> Mekelweg 15, 2629 JB Delft, The Netherlands
> E-Mail: m.tiberga at tudelft.nl
> Website: http://www.nera.rst.tudelft.nl/
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181218/bf108ec0/attachment.html>
