[petsc-users] Recommendations of possible preconditioner/ksp solver/snes solver for three phase flow reservoir simulator
Chukwudi Chukwudozie
chdozie at gmail.com
Sun Dec 16 21:00:59 CST 2018
Barry,
Thanks for the reply. I have attached two files with the information.
On Sat, Dec 15, 2018 at 8:58 PM Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
> Chuks,
> 1) Please run a successful case with -snes_view and send the output so
> we can see the exact solver options being used.
> 2) Run a less successful case with -snes_monitor
> -ksp_monitor_true_residual -ksp_converged_reason
> -fieldsplit_ksp_monitor_true_residual -fieldsplit_ksp_converged reason so
> we can see how the linear solver (and the sub linear solves) are (not)
> converging.
> Barry
> > On Dec 15, 2018, at 7:54 PM, Chukwudi Chukwudozie via petsc-users <
> petsc-users at mcs.anl.gov> wrote:
> > Hi,
> > I am developing a fully implicit control volume finite element black oil
> reservoir simulator using petscdmplex and snes. So far, for 2 phase flow
> problems (3 by 3 block for pressure, saturation and bottomhole pressure),
> my simulator runs fine for small time step sizes in the order of less than
> 5 days. However, increasing the time step size, it doesn't converge with -3
> (-5 sometimes) diverge reason. Considering that this is a fully implicit
> but nonlinear problem, I expect unconditional stability for reasonable time
> step sizes.
> > The background DM for the 3 block problem is a composite one with the
> first two being DMPLES's (bag->plexScalNode for pressure and saturation)
> and the last one, bag->WellRedun, a redundant DM for the wellbore
> pressures. See below.
> > ierr =
> DMRedundantCreate(PETSC_COMM_WORLD,0,bag->numWells,&bag->WellRedun);CHKERRQ(ierr);
> > ierr =
> DMCompositeCreate(PETSC_COMM_WORLD,&bag->MultiPhasePacker);CHKERRQ(ierr);
> > ierr =
> DMCompositeAddDM(bag->MultiPhasePacker,bag->plexScalNode);CHKERRQ(ierr);
> > ierr =
> > ierr =
> DMCompositeAddDM(bag->MultiPhasePacker,bag->WellRedun);CHKERRQ(ierr);
> > I have used nested matrices as shown below. In addition, I used the
> fieldsplit (composite multiplicative) preconditioner with FGRES and least
> square for newton solver. See below.
> > ierr =
> MatCreateNest(PETSC_COMM_WORLD,Msize,is,Msize,is,&bK[0],K);CHKERRQ(ierr);
> > ierr = SNESGetKSP(bag->snesP,&kspP);CHKERRQ(ierr);
> > ierr =
> KSPSetTolerances(kspP,1.e-8,1.e-8,PETSC_DEFAULT,PETSC_DEFAULT);CHKERRQ(ierr);
> > ierr = KSPSetType(kspP,KSPFGMRES);CHKERRQ(ierr);
> > ierr = KSPSetFromOptions(kspP);CHKERRQ(ierr);
> > ierr = KSPGetPC(kspP,&pcP);CHKERRQ(ierr);
> > ierr = PCSetType(pcP, PCFIELDSPLIT);CHKERRQ(ierr);
> > ierr =
> DMCompositeGetGlobalISs(bag->MultiPhasePacker,&is);CHKERRQ(ierr);
> > for(i = 0; i < Msize; i++) ierr =
> PCFieldSplitSetIS(pcP,NULL,is[i]);CHKERRQ(ierr);
> > ierr =
> PCFieldSplitSetType(pcP,PC_COMPOSITE_MULTIPLICATIVE);CHKERRQ(ierr);
> > Any ideas on possible precoditioner options/solver options/combinations
> to improve stability will be appreciated.
> > Chuks
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181216/27c4696e/attachment-0001.html>
FracD:
Numerical implementation of multiphysics models.
(c) 2016-2017 Chukwudi Chukwudozie chdozie at gmail.com
Well object "well":
top: 3.000000e+03 3.000000e+03
bottom: 3.000000e+03 3.000000e+03
wellnodes: 1.500000e+03 1.500000e+03
well water rate: 1.000000e+02
well oil rate: 0.000000e+00
well gas rate: 0.000000e+00
total well rate: 0.000000e+00
well bottomhole pressure: 5.000000e+03
well height/production interval: 3.000000e+01
well radius: 2.920000e-01
well block equivalent radius: 0.000000e+00
well skin: 0.000000e+00
Well Type: "INJECTORWATER" well under "WATERRATE" condition
Well object "well":
wellnodes: 4.500000e+03 4.500000e+03
well water rate: -0.000000e+00
well oil rate: -5.000000e+02
well gas rate: -0.000000e+00
total well rate: -0.000000e+00
well bottomhole pressure: 2.000000e+03
Well Type: "PRODUCER" well under "PRESSURE" condition
Option table:
#PETSc Option Table entries:
-Cr 4e-6
-PcowInrelPermData
-RsBubblepointfilename solutiongas.txt
-bubblepointfilename bubblepoint2phase.txt
-dim 2
-elementtype QUADRILATERAL
-fluid OILWATER
-initialSw 0.2
-initialpressure 4000
-maxtimestep 10
-meshfilename 2phasemesh_quad.msh
-nw 2
-oil_FVFmodel INTERPOLATION
-oil_PVTfilename oil_pvt_1.txt
-oil_compress 1e-5
-oil_denscoeff 0.
-oil_densmodel INTERPOLATION
-oil_prefdens 0.
-oil_preffvf -3000
-oil_prefvisc -3000
-oil_refFVF 1.11
-oil_refdens 1.0
-oil_refvisc 1.2
-oil_visccoeff 4e-6
-oil_viscmodel INTERPOLATION
-oilwaterrelpermfilename owrelperm1.txt
-p_snes_view
-perm 300,300
-phi 0.3
-pref_phi 4000
-refpressure 4000
-timevalue 5
-units FIELDUNITS
-verbose
-w0_Pbh 5000
-w0_Qws 100
-w0_bottom 3000,3000
-w0_constraint waterrate
-w0_coords 1500,1500
-w0_h 30
-w0_rw 0.292
-w0_top 3000,3000
-w0_type injectorwater
-w1_Pbh 2000
-w1_Qos 500
-w1_bottom 3000,3000
-w1_constraint pressure
-w1_coords 4500,4500
-w1_h 30
-w1_rw 0.292
-w1_top 3000,3000
-w1_type producer
-w2_Pbh 2000
-w2_Qos 500
-w2_bottom 3000,3000
-w2_constraint pressure
-w2_coords 2250,3750
-w2_h 30
-w2_rw 0.292
-w2_top 3000,3000
-w2_type producer
-w3_Pbh 2000
-w3_Qos 500
-w3_bottom 3000,3000
-w3_constraint pressure
-w3_coords 3750,2250
-w3_h 30
-w3_rw 0.292
-w3_top 3000,3000
-w3_type producer
-w4_Pbh 2000
-w4_Qos 500
-w4_bottom 3000,3000
-w4_constraint pressure
-w4_coords 3750,3750
-w4_h 30
-w4_rw 0.292
-w4_top 3000,3000
-w4_type producer
-water_FVFmodel ANALYTICAL
-water_compress 3e-6
-water_denscoeff 0.
-water_densmodel ANALYTICAL
-water_prefdens 0.
-water_preffvf 14.7
-water_prefvisc 14.7
-water_refFVF 1.0142
-water_refdens 1.0
-water_refvisc 0.96
-water_visccoeff 0.
-water_viscmodel ANALYTICAL
#End of PETSc Option Table entries
SNES Object: (P_) 1 MPI processes
type: newtonls
maximum iterations=50, maximum function evaluations=10000
tolerances: relative=1e-08, absolute=1e-08, solution=1e-08
total number of linear solver iterations=4583
total number of function evaluations=8
norm schedule ALWAYS
SNESLineSearch Object: (P_) 1 MPI processes
type: bt
interpolation: cubic
alpha=1.000000e-04
maxstep=1.000000e+08, minlambda=1.000000e-12
tolerances: relative=1.000000e-08, absolute=1.000000e-15, lambda=1.000000e-08
maximum iterations=40
KSP Object: (P_) 1 MPI processes
type: fgmres
restart=30, using Classical (unmodified) Gram-Schmidt Orthogonalization with no iterative refinement
happy breakdown tolerance 1e-30
maximum iterations=10000, initial guess is zero
tolerances: relative=1e-08, absolute=1e-08, divergence=10000.
right preconditioning
using UNPRECONDITIONED norm type for convergence test
PC Object: (P_) 1 MPI processes
type: fieldsplit
FieldSplit with MULTIPLICATIVE composition: total splits = 3
Solver info for each split is in the following KSP objects:
Split number 0 Defined by IS
KSP Object: (P_fieldsplit_0_) 1 MPI processes
type: preonly
tolerances: relative=1e-05, absolute=1e-50, divergence=10000.
left preconditioning
using NONE norm type for convergence test
PC Object: (P_fieldsplit_0_) 1 MPI processes
type: ilu
out-of-place factorization
0 levels of fill
tolerance for zero pivot 2.22045e-14
matrix ordering: natural
factor fill ratio given 1., needed 1.
Factored matrix follows:
Mat Object: 1 MPI processes
type: seqaij
rows=2500, cols=2500
package used to perform factorization: petsc
total: nonzeros=21904, allocated nonzeros=21904
total number of mallocs used during MatSetValues calls =0
not using I-node routines
linear system matrix = precond matrix:
Mat Object: (P_fieldsplit_0_) 1 MPI processes
type: seqaij
Split number 1 Defined by IS
KSP Object: (P_fieldsplit_1_) 1 MPI processes
type: preonly
PC Object: (P_fieldsplit_1_) 1 MPI processes
type: ilu
0 levels of fill
type: seqaij
Mat Object: (P_fieldsplit_1_) 1 MPI processes
type: seqaij
Split number 2 Defined by IS
KSP Object: (P_fieldsplit_2_) 1 MPI processes
type: preonly
PC Object: (P_fieldsplit_2_) 1 MPI processes
type: ilu
0 levels of fill
type: seqaij
rows=2, cols=2
total: nonzeros=4, allocated nonzeros=4
using I-node routines: found 1 nodes, limit used is 5
Mat Object: (P_fieldsplit_2_) 1 MPI processes
type: seqaij
rows=2, cols=2
linear system matrix followed by preconditioner matrix:
type: nest
rows=5002, cols=5002
Matrix object:
type=nest, rows=3, cols=3
MatNest structure:
(0,0) : prefix="P_fieldsplit_0_", type=seqaij, rows=2500, cols=2500
(0,1) : type=seqaij, rows=2500, cols=2500
(0,2) : type=seqaij, rows=2500, cols=2
(1,0) : type=seqaij, rows=2500, cols=2500
(1,1) : prefix="P_fieldsplit_1_", type=seqaij, rows=2500, cols=2500
(1,2) : type=seqaij, rows=2500, cols=2
(2,0) : type=seqaij, rows=2, cols=2500
(2,1) : type=seqaij, rows=2, cols=2500
(2,2) : prefix="P_fieldsplit_2_", type=seqaij, rows=2, cols=2
type: nest
Matrix object:
MatNest structure:
snesP converged in 7 iterations 3.
Checking 0
Time Step: 0
type: newtonls
total number of linear solver iterations=16048
total number of function evaluations=24
type: bt
alpha=1.000000e-04
type: fgmres
type: fieldsplit
type: preonly
type: ilu
0 levels of fill
type: seqaij
type: seqaij
type: preonly
type: ilu
0 levels of fill
type: seqaij
type: seqaij
type: preonly
type: ilu
0 levels of fill
type: seqaij
rows=2, cols=2
type: seqaij
rows=2, cols=2
type: nest
Matrix object:
MatNest structure:
type: nest
Matrix object:
MatNest structure:
snesP converged in 17 iterations 4.
Checking 1
Time Step: 1
type: newtonls
total number of linear solver iterations=15778
total number of function evaluations=27
type: bt
alpha=1.000000e-04
type: fgmres
type: fieldsplit
type: preonly
type: ilu
0 levels of fill
type: seqaij
type: seqaij
type: preonly
type: ilu
0 levels of fill
type: seqaij
type: seqaij
type: preonly
type: ilu
0 levels of fill
type: seqaij
rows=2, cols=2
type: seqaij
rows=2, cols=2
type: nest
Matrix object:
MatNest structure:
type: nest
Matrix object:
MatNest structure:
snesP converged in 18 iterations 4.
Checking 2
Time Step: 2
type: newtonls
total number of linear solver iterations=18413
total number of function evaluations=32
type: bt
alpha=1.000000e-04
type: fgmres
type: fieldsplit
type: preonly
type: ilu
0 levels of fill
type: seqaij
type: seqaij
type: preonly
type: ilu
0 levels of fill
type: seqaij
type: seqaij
type: preonly
type: ilu
0 levels of fill
type: seqaij
rows=2, cols=2
type: seqaij
rows=2, cols=2
type: nest
Matrix object:
MatNest structure:
type: nest
Matrix object:
MatNest structure:
snesP converged in 20 iterations 4.
Checking 3
Time Step: 3
type: newtonls
total number of linear solver iterations=21146
total number of function evaluations=29
type: bt
alpha=1.000000e-04
type: fgmres
type: fieldsplit
type: preonly
type: ilu
0 levels of fill
type: seqaij
type: seqaij
type: preonly
type: ilu
0 levels of fill
type: seqaij
type: seqaij
type: preonly
type: ilu
0 levels of fill
type: seqaij
rows=2, cols=2
type: seqaij
rows=2, cols=2
type: nest
Matrix object:
MatNest structure:
type: nest
Matrix object:
MatNest structure:
snesP converged in 22 iterations 4.
Checking 4
Time Step: 4
type: newtonls
total number of linear solver iterations=44142
total number of function evaluations=54
type: bt
alpha=1.000000e-04
type: fgmres
type: fieldsplit
type: preonly
type: ilu
0 levels of fill
type: seqaij
type: seqaij
type: preonly
type: ilu
0 levels of fill
type: seqaij
type: seqaij
type: preonly
type: ilu
0 levels of fill
type: seqaij
rows=2, cols=2
type: seqaij
rows=2, cols=2
type: nest
Matrix object:
MatNest structure:
type: nest
Matrix object:
MatNest structure:
[ERROR] snesP diverged with reason -5
Checking 5
Time Step: 5
type: newtonls
total number of linear solver iterations=16223
total number of function evaluations=23
type: bt
alpha=1.000000e-04
type: fgmres
type: fieldsplit
type: preonly
type: ilu
0 levels of fill
type: seqaij
type: seqaij
type: preonly
type: ilu
0 levels of fill
type: seqaij
type: seqaij
type: preonly
type: ilu
0 levels of fill
type: seqaij
rows=2, cols=2
type: seqaij
rows=2, cols=2
type: nest
Matrix object:
MatNest structure:
type: nest
Matrix object:
MatNest structure:
Checking 6
Time Step: 6
type: newtonls
total number of linear solver iterations=46100
total number of function evaluations=52
type: bt
alpha=1.000000e-04
type: fgmres
type: fieldsplit
type: preonly
type: ilu
0 levels of fill
type: seqaij
type: seqaij
type: preonly
type: ilu
0 levels of fill
type: seqaij
type: seqaij
type: preonly
type: ilu
0 levels of fill
type: seqaij
rows=2, cols=2
type: seqaij
rows=2, cols=2
type: nest
Matrix object:
MatNest structure:
type: nest
Matrix object:
MatNest structure:
Checking 7
Time Step: 7
type: newtonls
total number of linear solver iterations=27735
total number of function evaluations=34
type: bt
alpha=1.000000e-04
type: fgmres
type: fieldsplit
type: preonly
type: ilu
0 levels of fill
type: seqaij
type: seqaij
type: preonly
type: ilu
0 levels of fill
type: seqaij
type: seqaij
type: preonly
type: ilu
0 levels of fill
type: seqaij
rows=2, cols=2
type: seqaij
rows=2, cols=2
type: nest
Matrix object:
MatNest structure:
type: nest
Matrix object:
MatNest structure:
snesP converged in 33 iterations 4.
Checking 8
Time Step: 8
type: newtonls
total number of linear solver iterations=33027
total number of function evaluations=37
type: bt
alpha=1.000000e-04
type: fgmres
type: fieldsplit
type: preonly
type: ilu
0 levels of fill
type: seqaij
type: seqaij
type: preonly
type: ilu
0 levels of fill
type: seqaij
type: seqaij
type: preonly
type: ilu
0 levels of fill
type: seqaij
rows=2, cols=2
type: seqaij
rows=2, cols=2
type: nest
Matrix object:
MatNest structure:
type: nest
Matrix object:
MatNest structure:
snesP converged in 36 iterations 4.
Checking 9
Time Step: 9
rank: 0/1 NEW TIME STEP
FracD:
Well object "well":
Well object "well":
Option table:
-Cr 4e-6
-PcowInrelPermData
-dim 2
-fluid OILWATER
-initialSw 0.2
-maxtimestep 10
-nw 2
-oil_compress 1e-5
-oil_denscoeff 0.
-oil_prefdens 0.
-oil_preffvf -3000
-oil_prefvisc -3000
-oil_refFVF 1.11
-oil_refdens 1.0
-oil_refvisc 1.2
-oil_visccoeff 4e-6
-p_fieldsplit_ksp_converged
-p_fieldsplit_ksp_monitor_true_residual
-p_ksp_converged_reason
-p_ksp_monitor_true_residual
-perm 300,300
-phi 0.3
-pref_phi 4000
-refpressure 4000
-timevalue 60
-units FIELDUNITS
-verbose
-w0_Pbh 5000
-w0_Qws 100
-w0_h 30
-w0_rw 0.292
-w0_top 3000,3000
-w1_Pbh 2000
-w1_Qos 500
-w1_h 30
-w1_rw 0.292
-w1_top 3000,3000
-w1_type producer
-w2_Pbh 2000
-w2_Qos 500
-w2_h 30
-w2_rw 0.292
-w2_top 3000,3000
-w2_type producer
-w3_Pbh 2000
-w3_Qos 500
-w3_h 30
-w3_rw 0.292
-w3_top 3000,3000
-w3_type producer
-w4_Pbh 2000
-w4_Qos 500
-w4_h 30
-w4_rw 0.292
-w4_top 3000,3000
-w4_type producer
-water_denscoeff 0.
-water_prefdens 0.
-water_preffvf 14.7
-water_refdens 1.0
-water_refvisc 0.96
-water_visccoeff 0.
Residual norms for P_ solve.
0 KSP unpreconditioned resid norm 4.185437006342e+04 true resid norm 4.185437006342e+04 ||r(i)||/||b|| 1.000000000000e+00
1 KSP unpreconditioned resid norm 4.184640887695e+04 true resid norm 4.184640887695e+04 ||r(i)||/||b|| 9.998097884056e-01
2 KSP unpreconditioned resid norm 4.171213485177e+04 true resid norm 4.171213485177e+04 ||r(i)||/||b|| 9.966016640215e-01
3 KSP unpreconditioned resid norm 4.093622417125e+04 true resid norm 4.093622417127e+04 ||r(i)||/||b|| 9.780633207295e-01
4 KSP unpreconditioned resid norm 3.840582270678e+04 true resid norm 3.840582270683e+04 ||r(i)||/||b|| 9.176060384768e-01
5 KSP unpreconditioned resid norm 3.322460159635e+04 true resid norm 3.322460159653e+04 ||r(i)||/||b|| 7.938143985010e-01
6 KSP unpreconditioned resid norm 2.634213498990e+04 true resid norm 2.634213499031e+04 ||r(i)||/||b|| 6.293759755648e-01
7 KSP unpreconditioned resid norm 1.980381737493e+04 true resid norm 1.980381737555e+04 ||r(i)||/||b|| 4.731600868809e-01
8 KSP unpreconditioned resid norm 1.467692800940e+04 true resid norm 1.467692800998e+04 ||r(i)||/||b|| 3.506665609288e-01
9 KSP unpreconditioned resid norm 1.096469054164e+04 true resid norm 1.096469054172e+04 ||r(i)||/||b|| 2.619724182949e-01
10 KSP unpreconditioned resid norm 8.328970656537e+03 true resid norm 8.328970656600e+03 ||r(i)||/||b|| 1.989988296080e-01
11 KSP unpreconditioned resid norm 6.445663747163e+03 true resid norm 6.445663747246e+03 ||r(i)||/||b|| 1.540021684111e-01
12 KSP unpreconditioned resid norm 5.078356973787e+03 true resid norm 5.078356973862e+03 ||r(i)||/||b|| 1.213339722033e-01
13 KSP unpreconditioned resid norm 4.154673390757e+03 true resid norm 4.154673390890e+03 ||r(i)||/||b|| 9.926498438741e-02
14 KSP unpreconditioned resid norm 3.356737749834e+03 true resid norm 3.356737749909e+03 ||r(i)||/||b|| 8.020041264085e-02
15 KSP unpreconditioned resid norm 2.681812457336e+03 true resid norm 2.681812457321e+03 ||r(i)||/||b|| 6.407484937074e-02
16 KSP unpreconditioned resid norm 2.149016260026e+03 true resid norm 2.149016260045e+03 ||r(i)||/||b|| 5.134508670873e-02
17 KSP unpreconditioned resid norm 1.748364269419e+03 true resid norm 1.748364269532e+03 ||r(i)||/||b|| 4.177256202598e-02
18 KSP unpreconditioned resid norm 1.459185573394e+03 true resid norm 1.459185573427e+03 ||r(i)||/||b|| 3.486339828352e-02
19 KSP unpreconditioned resid norm 1.225194416364e+03 true resid norm 1.225194416368e+03 ||r(i)||/||b|| 2.927279551722e-02
20 KSP unpreconditioned resid norm 1.031914188646e+03 true resid norm 1.031914188695e+03 ||r(i)||/||b|| 2.465487324577e-02
21 KSP unpreconditioned resid norm 8.735852793236e+02 true resid norm 8.735852793422e+02 ||r(i)||/||b|| 2.087202072373e-02
22 KSP unpreconditioned resid norm 7.443917521568e+02 true resid norm 7.443917521724e+02 ||r(i)||/||b|| 1.778528146630e-02
23 KSP unpreconditioned resid norm 6.387343091504e+02 true resid norm 6.387343091529e+02 ||r(i)||/||b|| 1.526087498594e-02
24 KSP unpreconditioned resid norm 5.501010666818e+02 true resid norm 5.501010666948e+02 ||r(i)||/||b|| 1.314321696543e-02
25 KSP unpreconditioned resid norm 4.783227223974e+02 true resid norm 4.783227223986e+02 ||r(i)||/||b|| 1.142826236959e-02
26 KSP unpreconditioned resid norm 4.219894039272e+02 true resid norm 4.219894039439e+02 ||r(i)||/||b|| 1.008232601051e-02
27 KSP unpreconditioned resid norm 3.772321733981e+02 true resid norm 3.772321733970e+02 ||r(i)||/||b|| 9.012969800417e-03
28 KSP unpreconditioned resid norm 3.408912515859e+02 true resid norm 3.408912515975e+02 ||r(i)||/||b|| 8.144699133711e-03
29 KSP unpreconditioned resid norm 3.104197243561e+02 true resid norm 3.104197243723e+02 ||r(i)||/||b|| 7.416662200434e-03
30 KSP unpreconditioned resid norm 2.844309566432e+02 true resid norm 2.844309566432e+02 ||r(i)||/||b|| 6.795729005412e-03
31 KSP unpreconditioned resid norm 2.725558244331e+02 true resid norm 2.725558244331e+02 ||r(i)||/||b|| 6.512003979994e-03
32 KSP unpreconditioned resid norm 2.606960762248e+02 true resid norm 2.606960762248e+02 ||r(i)||/||b|| 6.228646514804e-03
33 KSP unpreconditioned resid norm 2.488650158858e+02 true resid norm 2.488650158858e+02 ||r(i)||/||b|| 5.945974470735e-03
34 KSP unpreconditioned resid norm 2.368499267478e+02 true resid norm 2.368499267478e+02 ||r(i)||/||b|| 5.658905542932e-03
35 KSP unpreconditioned resid norm 2.247395208302e+02 true resid norm 2.247395208302e+02 ||r(i)||/||b|| 5.369559271582e-03
36 KSP unpreconditioned resid norm 2.125548513132e+02 true resid norm 2.125548513132e+02 ||r(i)||/||b|| 5.078438667005e-03
37 KSP unpreconditioned resid norm 2.018421848568e+02 true resid norm 2.018421848568e+02 ||r(i)||/||b|| 4.822487700830e-03
38 KSP unpreconditioned resid norm 1.929964456490e+02 true resid norm 1.929964456490e+02 ||r(i)||/||b|| 4.611142046973e-03
39 KSP unpreconditioned resid norm 1.854409542298e+02 true resid norm 1.854409542298e+02 ||r(i)||/||b|| 4.430623467724e-03
40 KSP unpreconditioned resid norm 1.781632871563e+02 true resid norm 1.781632871563e+02 ||r(i)||/||b|| 4.256742769902e-03
41 KSP unpreconditioned resid norm 1.705795476338e+02 true resid norm 1.705795476338e+02 ||r(i)||/||b|| 4.075549276583e-03
42 KSP unpreconditioned resid norm 1.630804077040e+02 true resid norm 1.630804077040e+02 ||r(i)||/||b|| 3.896377067841e-03
43 KSP unpreconditioned resid norm 1.553067395054e+02 true resid norm 1.553067395054e+02 ||r(i)||/||b|| 3.710645728752e-03
44 KSP unpreconditioned resid norm 1.463195822591e+02 true resid norm 1.463195822591e+02 ||r(i)||/||b|| 3.495921263117e-03
45 KSP unpreconditioned resid norm 1.363957299914e+02 true resid norm 1.363957299914e+02 ||r(i)||/||b|| 3.258816935597e-03
46 KSP unpreconditioned resid norm 1.260988883702e+02 true resid norm 1.260988883702e+02 ||r(i)||/||b|| 3.012801009289e-03
47 KSP unpreconditioned resid norm 1.158371057308e+02 true resid norm 1.158371057308e+02 ||r(i)||/||b|| 2.767622725065e-03
48 KSP unpreconditioned resid norm 1.053575736103e+02 true resid norm 1.053575736103e+02 ||r(i)||/||b|| 2.517241890169e-03
49 KSP unpreconditioned resid norm 9.533891433288e+01 true resid norm 9.533891433288e+01 ||r(i)||/||b|| 2.277872398711e-03
50 KSP unpreconditioned resid norm 8.705465269949e+01 true resid norm 8.705465269949e+01 ||r(i)||/||b|| 2.079941773526e-03
51 KSP unpreconditioned resid norm 8.068525173658e+01 true resid norm 8.068525173658e+01 ||r(i)||/||b|| 1.927761703601e-03
52 KSP unpreconditioned resid norm 7.566535127065e+01 true resid norm 7.566535127065e+01 ||r(i)||/||b|| 1.807824395780e-03
53 KSP unpreconditioned resid norm 7.099640454939e+01 true resid norm 7.099640454939e+01 ||r(i)||/||b|| 1.696272203878e-03
54 KSP unpreconditioned resid norm 6.668259985170e+01 true resid norm 6.668259985170e+01 ||r(i)||/||b|| 1.593205195793e-03
55 KSP unpreconditioned resid norm 6.260036654607e+01 true resid norm 6.260036654607e+01 ||r(i)||/||b|| 1.495670976560e-03
56 KSP unpreconditioned resid norm 5.883817898871e+01 true resid norm 5.883817898871e+01 ||r(i)||/||b|| 1.405783408030e-03
57 KSP unpreconditioned resid norm 5.562235607642e+01 true resid norm 5.562235607643e+01 ||r(i)||/||b|| 1.328949784506e-03
58 KSP unpreconditioned resid norm 5.297079658586e+01 true resid norm 5.297079658588e+01 ||r(i)||/||b|| 1.265597750142e-03
59 KSP unpreconditioned resid norm 5.079442717111e+01 true resid norm 5.079442717113e+01 ||r(i)||/||b|| 1.213599131803e-03
60 KSP unpreconditioned resid norm 4.907222818727e+01 true resid norm 4.907222818727e+01 ||r(i)||/||b|| 1.172451720404e-03
61 KSP unpreconditioned resid norm 4.855863018352e+01 true resid norm 4.855863018353e+01 ||r(i)||/||b|| 1.160180648041e-03
62 KSP unpreconditioned resid norm 4.818688995047e+01 true resid norm 4.818688995047e+01 ||r(i)||/||b|| 1.151298893699e-03
63 KSP unpreconditioned resid norm 4.777104756076e+01 true resid norm 4.777104756076e+01 ||r(i)||/||b|| 1.141363434413e-03
64 KSP unpreconditioned resid norm 4.732776721320e+01 true resid norm 4.732776721321e+01 ||r(i)||/||b|| 1.130772417349e-03
65 KSP unpreconditioned resid norm 4.680987352819e+01 true resid norm 4.680987352819e+01 ||r(i)||/||b|| 1.118398710989e-03
66 KSP unpreconditioned resid norm 4.609652595419e+01 true resid norm 4.609652595419e+01 ||r(i)||/||b|| 1.101355148443e-03
67 KSP unpreconditioned resid norm 4.510019040066e+01 true resid norm 4.510019040067e+01 ||r(i)||/||b|| 1.077550333032e-03
68 KSP unpreconditioned resid norm 4.377295459951e+01 true resid norm 4.377295459952e+01 ||r(i)||/||b|| 1.045839527227e-03
69 KSP unpreconditioned resid norm 4.208504090348e+01 true resid norm 4.208504090349e+01 ||r(i)||/||b|| 1.005511272532e-03
70 KSP unpreconditioned resid norm 3.980380090965e+01 true resid norm 3.980380090967e+01 ||r(i)||/||b|| 9.510070477555e-04
71 KSP unpreconditioned resid norm 3.708086284362e+01 true resid norm 3.708086284366e+01 ||r(i)||/||b|| 8.859496102194e-04
72 KSP unpreconditioned resid norm 3.459727873751e+01 true resid norm 3.459727873766e+01 ||r(i)||/||b|| 8.266109055097e-04
73 KSP unpreconditioned resid norm 3.180719255347e+01 true resid norm 3.180719255351e+01 ||r(i)||/||b|| 7.599491404438e-04
74 KSP unpreconditioned resid norm 2.918185526651e+01 true resid norm 2.918185526660e+01 ||r(i)||/||b|| 6.972236166111e-04
75 KSP unpreconditioned resid norm 2.678651110970e+01 true resid norm 2.678651110961e+01 ||r(i)||/||b|| 6.399931732105e-04
76 KSP unpreconditioned resid norm 2.484906333827e+01 true resid norm 2.484906333836e+01 ||r(i)||/||b|| 5.937029586328e-04
77 KSP unpreconditioned resid norm 2.330913573053e+01 true resid norm 2.330913573043e+01 ||r(i)||/||b|| 5.569104419710e-04
78 KSP unpreconditioned resid norm 2.216435682431e+01 true resid norm 2.216435682436e+01 ||r(i)||/||b|| 5.295589633956e-04
79 KSP unpreconditioned resid norm 2.123395613535e+01 true resid norm 2.123395613537e+01 ||r(i)||/||b|| 5.073294880127e-04
80 KSP unpreconditioned resid norm 2.043084268153e+01 true resid norm 2.043084268164e+01 ||r(i)||/||b|| 4.881412060600e-04
81 KSP unpreconditioned resid norm 1.965586415234e+01 true resid norm 1.965586415254e+01 ||r(i)||/||b|| 4.696251340723e-04
82 KSP unpreconditioned resid norm 1.881622901102e+01 true resid norm 1.881622901121e+01 ||r(i)||/||b|| 4.495642625298e-04
83 KSP unpreconditioned resid norm 1.789380993135e+01 true resid norm 1.789380993180e+01 ||r(i)||/||b|| 4.275254866981e-04
84 KSP unpreconditioned resid norm 1.688449457197e+01 true resid norm 1.688449457201e+01 ||r(i)||/||b|| 4.034105529823e-04
85 KSP unpreconditioned resid norm 1.593222827658e+01 true resid norm 1.593222827682e+01 ||r(i)||/||b|| 3.806586564960e-04
86 KSP unpreconditioned resid norm 1.515471799214e+01 true resid norm 1.515471799254e+01 ||r(i)||/||b|| 3.620820948823e-04
87 KSP unpreconditioned resid norm 1.446999386874e+01 true resid norm 1.446999386898e+01 ||r(i)||/||b|| 3.457224143393e-04
88 KSP unpreconditioned resid norm 1.383334025997e+01 true resid norm 1.383334026043e+01 ||r(i)||/||b|| 3.305112522174e-04
89 KSP unpreconditioned resid norm 1.317043989288e+01 true resid norm 1.317043989271e+01 ||r(i)||/||b|| 3.146729928739e-04
90 KSP unpreconditioned resid norm 1.239101125736e+01 true resid norm 1.239101125736e+01 ||r(i)||/||b|| 2.960505973112e-04
91 KSP unpreconditioned resid norm 1.186324262364e+01 true resid norm 1.186324262364e+01 ||r(i)||/||b|| 2.834409550464e-04
92 KSP unpreconditioned resid norm 1.150464677494e+01 true resid norm 1.150464677494e+01 ||r(i)||/||b|| 2.748732511685e-04
93 KSP unpreconditioned resid norm 1.113300288814e+01 true resid norm 1.113300288813e+01 ||r(i)||/||b|| 2.659937987662e-04
94 KSP unpreconditioned resid norm 1.070172922664e+01 true resid norm 1.070172922664e+01 ||r(i)||/||b|| 2.556896498604e-04
95 KSP unpreconditioned resid norm 1.031469163099e+01 true resid norm 1.031469163098e+01 ||r(i)||/||b|| 2.464424053055e-04
96 KSP unpreconditioned resid norm 9.961561506781e+00 true resid norm 9.961561506789e+00 ||r(i)||/||b|| 2.380052905275e-04
97 KSP unpreconditioned resid norm 9.727599193659e+00 true resid norm 9.727599193657e+00 ||r(i)||/||b|| 2.324153769109e-04
98 KSP unpreconditioned resid norm 9.599540307022e+00 true resid norm 9.599540307025e+00 ||r(i)||/||b|| 2.293557469024e-04
99 KSP unpreconditioned resid norm 9.509470398964e+00 true resid norm 9.509470398968e+00 ||r(i)||/||b|| 2.272037635391e-04
100 KSP unpreconditioned resid norm 9.466509947556e+00 true resid norm 9.466509947555e+00 ||r(i)||/||b|| 2.261773366368e-04
101 KSP unpreconditioned resid norm 9.455222327075e+00 true resid norm 9.455222327062e+00 ||r(i)||/||b|| 2.259076486574e-04
102 KSP unpreconditioned resid norm 9.453955291155e+00 true resid norm 9.453955291154e+00 ||r(i)||/||b|| 2.258773761696e-04
103 KSP unpreconditioned resid norm 9.453901238683e+00 true resid norm 9.453901238680e+00 ||r(i)||/||b|| 2.258760847280e-04
104 KSP unpreconditioned resid norm 9.453537983245e+00 true resid norm 9.453537983238e+00 ||r(i)||/||b|| 2.258674056954e-04
105 KSP unpreconditioned resid norm 9.453508666674e+00 true resid norm 9.453508666665e+00 ||r(i)||/||b|| 2.258667052530e-04
106 KSP unpreconditioned resid norm 9.453292702551e+00 true resid norm 9.453292702541e+00 ||r(i)||/||b|| 2.258615453588e-04
107 KSP unpreconditioned resid norm 9.453181837192e+00 true resid norm 9.453181837176e+00 ||r(i)||/||b|| 2.258588965227e-04
108 KSP unpreconditioned resid norm 9.452682673607e+00 true resid norm 9.452682673598e+00 ||r(i)||/||b|| 2.258469703230e-04
109 KSP unpreconditioned resid norm 9.447895229458e+00 true resid norm 9.447895229465e+00 ||r(i)||/||b|| 2.257325869473e-04
110 KSP unpreconditioned resid norm 9.447238405614e+00 true resid norm 9.447238405615e+00 ||r(i)||/||b|| 2.257168938704e-04
111 KSP unpreconditioned resid norm 9.446910264057e+00 true resid norm 9.446910264054e+00 ||r(i)||/||b|| 2.257090537915e-04
112 KSP unpreconditioned resid norm 9.446735687192e+00 true resid norm 9.446735687190e+00 ||r(i)||/||b|| 2.257048827369e-04
113 KSP unpreconditioned resid norm 9.439830631922e+00 true resid norm 9.439830631909e+00 ||r(i)||/||b|| 2.255399046170e-04
114 KSP unpreconditioned resid norm 9.417912808091e+00 true resid norm 9.417912808088e+00 ||r(i)||/||b|| 2.250162359108e-04
115 KSP unpreconditioned resid norm 9.387566046376e+00 true resid norm 9.387566046378e+00 ||r(i)||/||b|| 2.242911799211e-04
116 KSP unpreconditioned resid norm 9.358214264326e+00 true resid norm 9.358214264320e+00 ||r(i)||/||b|| 2.235898963511e-04
117 KSP unpreconditioned resid norm 9.329543016274e+00 true resid norm 9.329543016269e+00 ||r(i)||/||b|| 2.229048723498e-04
118 KSP unpreconditioned resid norm 9.283697902212e+00 true resid norm 9.283697902208e+00 ||r(i)||/||b|| 2.218095240268e-04
119 KSP unpreconditioned resid norm 9.230603560626e+00 true resid norm 9.230603560623e+00 ||r(i)||/||b|| 2.205409744941e-04
120 KSP unpreconditioned resid norm 9.176644987087e+00 true resid norm 9.176644987087e+00 ||r(i)||/||b|| 2.192517764139e-04
121 KSP unpreconditioned resid norm 9.143991177863e+00 true resid norm 9.143991177861e+00 ||r(i)||/||b|| 2.184715995966e-04
122 KSP unpreconditioned resid norm 9.129366561991e+00 true resid norm 9.129366561990e+00 ||r(i)||/||b|| 2.181221828965e-04
123 KSP unpreconditioned resid norm 9.117830710266e+00 true resid norm 9.117830710263e+00 ||r(i)||/||b|| 2.178465640851e-04
124 KSP unpreconditioned resid norm 9.114456287974e+00 true resid norm 9.114456287976e+00 ||r(i)||/||b|| 2.177659411470e-04
125 KSP unpreconditioned resid norm 9.114265447956e+00 true resid norm 9.114265447950e+00 ||r(i)||/||b|| 2.177613815270e-04
126 KSP unpreconditioned resid norm 9.113358612539e+00 true resid norm 9.113358612544e+00 ||r(i)||/||b|| 2.177397150820e-04
127 KSP unpreconditioned resid norm 9.109681304148e+00 true resid norm 9.109681304142e+00 ||r(i)||/||b|| 2.176518554775e-04
128 KSP unpreconditioned resid norm 9.108178258871e+00 true resid norm 9.108178258865e+00 ||r(i)||/||b|| 2.176159441670e-04
129 KSP unpreconditioned resid norm 9.108045214257e+00 true resid norm 9.108045214258e+00 ||r(i)||/||b|| 2.176127654163e-04
130 KSP unpreconditioned resid norm 9.107947148704e+00 true resid norm 9.107947148702e+00 ||r(i)||/||b|| 2.176104223980e-04
131 KSP unpreconditioned resid norm 9.107582780259e+00 true resid norm 9.107582780261e+00 ||r(i)||/||b|| 2.176017167732e-04
132 KSP unpreconditioned resid norm 9.102727327550e+00 true resid norm 9.102727327557e+00 ||r(i)||/||b|| 2.174857085118e-04
133 KSP unpreconditioned resid norm 9.100831330692e+00 true resid norm 9.100831330683e+00 ||r(i)||/||b|| 2.174404086573e-04
134 KSP unpreconditioned resid norm 9.099043254524e+00 true resid norm 9.099043254522e+00 ||r(i)||/||b|| 2.173976872842e-04
135 KSP unpreconditioned resid norm 9.098356626208e+00 true resid norm 9.098356626206e+00 ||r(i)||/||b|| 2.173812821079e-04
136 KSP unpreconditioned resid norm 9.097355464612e+00 true resid norm 9.097355464602e+00 ||r(i)||/||b|| 2.173573619868e-04
137 KSP unpreconditioned resid norm 9.089186105397e+00 true resid norm 9.089186105393e+00 ||r(i)||/||b|| 2.171621766526e-04
138 KSP unpreconditioned resid norm 9.072508753871e+00 true resid norm 9.072508753870e+00 ||r(i)||/||b|| 2.167637152375e-04
139 KSP unpreconditioned resid norm 9.045555446429e+00 true resid norm 9.045555446427e+00 ||r(i)||/||b|| 2.161197369049e-04
140 KSP unpreconditioned resid norm 8.998721136797e+00 true resid norm 8.998721136781e+00 ||r(i)||/||b|| 2.150007543572e-04
141 KSP unpreconditioned resid norm 8.957999948441e+00 true resid norm 8.957999948446e+00 ||r(i)||/||b|| 2.140278287518e-04
142 KSP unpreconditioned resid norm 8.914720920393e+00 true resid norm 8.914720920379e+00 ||r(i)||/||b|| 2.129937902989e-04
143 KSP unpreconditioned resid norm 8.861276524407e+00 true resid norm 8.861276524386e+00 ||r(i)||/||b|| 2.117168771375e-04
144 KSP unpreconditioned resid norm 8.828215689678e+00 true resid norm 8.828215689670e+00 ||r(i)||/||b|| 2.109269755176e-04
145 KSP unpreconditioned resid norm 8.814871762477e+00 true resid norm 8.814871762457e+00 ||r(i)||/||b|| 2.106081575019e-04
146 KSP unpreconditioned resid norm 8.812208435271e+00 true resid norm 8.812208435264e+00 ||r(i)||/||b|| 2.105445243092e-04
147 KSP unpreconditioned resid norm 8.811828184692e+00 true resid norm 8.811828184665e+00 ||r(i)||/||b|| 2.105354392221e-04
148 KSP unpreconditioned resid norm 8.810270839057e+00 true resid norm 8.810270839056e+00 ||r(i)||/||b|| 2.104982305481e-04
149 KSP unpreconditioned resid norm 8.809360836498e+00 true resid norm 8.809360836477e+00 ||r(i)||/||b|| 2.104764884319e-04
150 KSP unpreconditioned resid norm 8.809228450273e+00 true resid norm 8.809228450273e+00 ||r(i)||/||b|| 2.104733254120e-04
151 KSP unpreconditioned resid norm 8.809217648496e+00 true resid norm 8.809217648490e+00 ||r(i)||/||b|| 2.104730673319e-04
152 KSP unpreconditioned resid norm 8.809143040459e+00 true resid norm 8.809143040463e+00 ||r(i)||/||b|| 2.104712847694e-04
153 KSP unpreconditioned resid norm 8.809115621054e+00 true resid norm 8.809115621055e+00 ||r(i)||/||b|| 2.104706296549e-04
154 KSP unpreconditioned resid norm 8.808990540067e+00 true resid norm 8.808990540063e+00 ||r(i)||/||b|| 2.104676411738e-04
155 KSP unpreconditioned resid norm 8.808875174679e+00 true resid norm 8.808875174687e+00 ||r(i)||/||b|| 2.104648848218e-04
156 KSP unpreconditioned resid norm 8.808536626453e+00 true resid norm 8.808536626456e+00 ||r(i)||/||b|| 2.104567961030e-04
157 KSP unpreconditioned resid norm 8.808160785477e+00 true resid norm 8.808160785485e+00 ||r(i)||/||b|| 2.104478163723e-04
158 KSP unpreconditioned resid norm 8.808132992547e+00 true resid norm 8.808132992551e+00 ||r(i)||/||b|| 2.104471523333e-04
159 KSP unpreconditioned resid norm 8.808122181749e+00 true resid norm 8.808122181753e+00 ||r(i)||/||b|| 2.104468940378e-04
160 KSP unpreconditioned resid norm 8.807956020806e+00 true resid norm 8.807956020805e+00 ||r(i)||/||b|| 2.104429240593e-04
161 KSP unpreconditioned resid norm 8.806829391882e+00 true resid norm 8.806829391878e+00 ||r(i)||/||b|| 2.104160062267e-04
162 KSP unpreconditioned resid norm 8.806319018453e+00 true resid norm 8.806319018453e+00 ||r(i)||/||b|| 2.104038121972e-04
163 KSP unpreconditioned resid norm 8.806294482453e+00 true resid norm 8.806294482454e+00 ||r(i)||/||b|| 2.104032259740e-04
164 KSP unpreconditioned resid norm 8.806294365652e+00 true resid norm 8.806294365660e+00 ||r(i)||/||b|| 2.104032231836e-04
165 KSP unpreconditioned resid norm 8.806291697672e+00 true resid norm 8.806291697675e+00 ||r(i)||/||b|| 2.104031594391e-04
166 KSP unpreconditioned resid norm 8.805745258243e+00 true resid norm 8.805745258237e+00 ||r(i)||/||b|| 2.103901037071e-04
167 KSP unpreconditioned resid norm 8.805235547061e+00 true resid norm 8.805235547060e+00 ||r(i)||/||b|| 2.103779255002e-04
168 KSP unpreconditioned resid norm 8.805103805113e+00 true resid norm 8.805103805114e+00 ||r(i)||/||b|| 2.103747778732e-04
169 KSP unpreconditioned resid norm 8.805014161928e+00 true resid norm 8.805014161924e+00 ||r(i)||/||b|| 2.103726360852e-04
170 KSP unpreconditioned resid norm 8.804202103754e+00 true resid norm 8.804202103744e+00 ||r(i)||/||b|| 2.103532340925e-04
171 KSP unpreconditioned resid norm 8.797040981002e+00 true resid norm 8.797040981004e+00 ||r(i)||/||b|| 2.101821379148e-04
172 KSP unpreconditioned resid norm 8.792835377869e+00 true resid norm 8.792835377873e+00 ||r(i)||/||b|| 2.100816560983e-04
173 KSP unpreconditioned resid norm 8.792684168267e+00 true resid norm 8.792684168266e+00 ||r(i)||/||b|| 2.100780433428e-04
174 KSP unpreconditioned resid norm 8.792562059260e+00 true resid norm 8.792562059262e+00 ||r(i)||/||b|| 2.100751258695e-04
175 KSP unpreconditioned resid norm 8.791859939389e+00 true resid norm 8.791859939386e+00 ||r(i)||/||b|| 2.100583505633e-04
176 KSP unpreconditioned resid norm 8.789112601337e+00 true resid norm 8.789112601343e+00 ||r(i)||/||b|| 2.099927101525e-04
177 KSP unpreconditioned resid norm 8.784752787756e+00 true resid norm 8.784752787762e+00 ||r(i)||/||b|| 2.098885438833e-04
178 KSP unpreconditioned resid norm 8.781725079298e+00 true resid norm 8.781725079292e+00 ||r(i)||/||b|| 2.098162047592e-04
179 KSP unpreconditioned resid norm 8.781356495123e+00 true resid norm 8.781356495128e+00 ||r(i)||/||b|| 2.098073984108e-04
180 KSP unpreconditioned resid norm 8.780959440563e+00 true resid norm 8.780959440563e+00 ||r(i)||/||b|| 2.097979118371e-04
181 KSP unpreconditioned resid norm 8.780949304990e+00 true resid norm 8.780949304991e+00 ||r(i)||/||b|| 2.097976696743e-04
182 KSP unpreconditioned resid norm 8.780949101503e+00 true resid norm 8.780949101511e+00 ||r(i)||/||b|| 2.097976648127e-04
183 KSP unpreconditioned resid norm 8.780874815148e+00 true resid norm 8.780874815142e+00 ||r(i)||/||b|| 2.097958899354e-04
184 KSP unpreconditioned resid norm 8.780852129532e+00 true resid norm 8.780852129536e+00 ||r(i)||/||b|| 2.097953479226e-04
185 KSP unpreconditioned resid norm 8.780770254915e+00 true resid norm 8.780770254911e+00 ||r(i)||/||b|| 2.097933917440e-04
186 KSP unpreconditioned resid norm 8.780755189593e+00 true resid norm 8.780755189589e+00 ||r(i)||/||b|| 2.097930317977e-04
187 KSP unpreconditioned resid norm 8.780751549738e+00 true resid norm 8.780751549745e+00 ||r(i)||/||b|| 2.097929448333e-04
188 KSP unpreconditioned resid norm 8.780683751128e+00 true resid norm 8.780683751126e+00 ||r(i)||/||b|| 2.097913249637e-04
189 KSP unpreconditioned resid norm 8.780522987845e+00 true resid norm 8.780522987849e+00 ||r(i)||/||b|| 2.097874839484e-04
190 KSP unpreconditioned resid norm 8.780278742096e+00 true resid norm 8.780278742107e+00 ||r(i)||/||b|| 2.097816483393e-04
191 KSP unpreconditioned resid norm 8.780267035067e+00 true resid norm 8.780267035064e+00 ||r(i)||/||b|| 2.097813686303e-04
192 KSP unpreconditioned resid norm 8.780216625442e+00 true resid norm 8.780216625446e+00 ||r(i)||/||b|| 2.097801642252e-04
193 KSP unpreconditioned resid norm 8.779863419269e+00 true resid norm 8.779863419283e+00 ||r(i)||/||b|| 2.097717252937e-04
194 KSP unpreconditioned resid norm 8.778848410057e+00 true resid norm 8.778848410054e+00 ||r(i)||/||b|| 2.097474743200e-04
195 KSP unpreconditioned resid norm 8.777401446116e+00 true resid norm 8.777401446119e+00 ||r(i)||/||b|| 2.097129029256e-04
196 KSP unpreconditioned resid norm 8.776565851009e+00 true resid norm 8.776565851011e+00 ||r(i)||/||b|| 2.096929385800e-04
197 KSP unpreconditioned resid norm 8.776554097188e+00 true resid norm 8.776554097188e+00 ||r(i)||/||b|| 2.096926577533e-04
198 KSP unpreconditioned resid norm 8.776069995876e+00 true resid norm 8.776069995872e+00 ||r(i)||/||b|| 2.096810914267e-04
199 KSP unpreconditioned resid norm 8.775307222507e+00 true resid norm 8.775307222510e+00 ||r(i)||/||b|| 2.096628669650e-04
200 KSP unpreconditioned resid norm 8.774369998639e+00 true resid norm 8.774369998640e+00 ||r(i)||/||b|| 2.096404744677e-04
201 KSP unpreconditioned resid norm 8.772456346984e+00 true resid norm 8.772456346996e+00 ||r(i)||/||b|| 2.095947527989e-04
202 KSP unpreconditioned resid norm 8.771578449583e+00 true resid norm 8.771578449587e+00 ||r(i)||/||b|| 2.095737777512e-04
203 KSP unpreconditioned resid norm 8.771577600114e+00 true resid norm 8.771577600112e+00 ||r(i)||/||b|| 2.095737574552e-04
204 KSP unpreconditioned resid norm 8.769947395455e+00 true resid norm 8.769947395447e+00 ||r(i)||/||b|| 2.095348080059e-04
205 KSP unpreconditioned resid norm 8.765625569759e+00 true resid norm 8.765625569766e+00 ||r(i)||/||b|| 2.094315493576e-04
206 KSP unpreconditioned resid norm 8.762920016340e+00 true resid norm 8.762920016349e+00 ||r(i)||/||b|| 2.093669072805e-04
207 KSP unpreconditioned resid norm 8.762030877593e+00 true resid norm 8.762030877583e+00 ||r(i)||/||b|| 2.093456636501e-04
208 KSP unpreconditioned resid norm 8.762025443448e+00 true resid norm 8.762025443453e+00 ||r(i)||/||b|| 2.093455338159e-04
209 KSP unpreconditioned resid norm 8.759118158195e+00 true resid norm 8.759118158210e+00 ||r(i)||/||b|| 2.092760718878e-04
210 KSP unpreconditioned resid norm 8.757626170280e+00 true resid norm 8.757626170280e+00 ||r(i)||/||b|| 2.092404247636e-04
211 KSP unpreconditioned resid norm 8.757586002492e+00 true resid norm 8.757586002498e+00 ||r(i)||/||b|| 2.092394650601e-04
212 KSP unpreconditioned resid norm 8.757586002150e+00 true resid norm 8.757586002141e+00 ||r(i)||/||b|| 2.092394650516e-04
213 KSP unpreconditioned resid norm 8.757565964562e+00 true resid norm 8.757565964558e+00 ||r(i)||/||b|| 2.092389863063e-04
214 KSP unpreconditioned resid norm 8.757565930019e+00 true resid norm 8.757565930026e+00 ||r(i)||/||b|| 2.092389854812e-04
215 KSP unpreconditioned resid norm 8.757562287652e+00 true resid norm 8.757562287652e+00 ||r(i)||/||b|| 2.092388984563e-04
216 KSP unpreconditioned resid norm 8.757562261294e+00 true resid norm 8.757562261303e+00 ||r(i)||/||b|| 2.092388978268e-04
217 KSP unpreconditioned resid norm 8.757551783601e+00 true resid norm 8.757551783609e+00 ||r(i)||/||b|| 2.092386474899e-04
218 KSP unpreconditioned resid norm 8.757525988303e+00 true resid norm 8.757525988300e+00 ||r(i)||/||b|| 2.092380311789e-04
219 KSP unpreconditioned resid norm 8.757446263195e+00 true resid norm 8.757446263193e+00 ||r(i)||/||b|| 2.092361263573e-04
220 KSP unpreconditioned resid norm 8.757445081631e+00 true resid norm 8.757445081633e+00 ||r(i)||/||b|| 2.092360981270e-04
221 KSP unpreconditioned resid norm 8.757155678610e+00 true resid norm 8.757155678605e+00 ||r(i)||/||b|| 2.092291836034e-04
222 KSP unpreconditioned resid norm 8.757038866468e+00 true resid norm 8.757038866463e+00 ||r(i)||/||b|| 2.092263926848e-04
223 KSP unpreconditioned resid norm 8.756997899453e+00 true resid norm 8.756997899453e+00 ||r(i)||/||b|| 2.092254138859e-04
224 KSP unpreconditioned resid norm 8.756889734530e+00 true resid norm 8.756889734533e+00 ||r(i)||/||b|| 2.092228295699e-04
225 KSP unpreconditioned resid norm 8.756239703827e+00 true resid norm 8.756239703827e+00 ||r(i)||/||b|| 2.092072987972e-04
226 KSP unpreconditioned resid norm 8.755468069592e+00 true resid norm 8.755468069589e+00 ||r(i)||/||b|| 2.091888626283e-04
227 KSP unpreconditioned resid norm 8.755445934609e+00 true resid norm 8.755445934609e+00 ||r(i)||/||b|| 2.091883337712e-04
228 KSP unpreconditioned resid norm 8.754918105730e+00 true resid norm 8.754918105736e+00 ||r(i)||/||b|| 2.091757226897e-04
229 KSP unpreconditioned resid norm 8.754027449030e+00 true resid norm 8.754027449026e+00 ||r(i)||/||b|| 2.091544427921e-04
230 KSP unpreconditioned resid norm 8.753580266945e+00 true resid norm 8.753580266946e+00 ||r(i)||/||b|| 2.091437585534e-04
231 KSP unpreconditioned resid norm 8.753445273497e+00 true resid norm 8.753445273503e+00 ||r(i)||/||b|| 2.091405332404e-04
232 KSP unpreconditioned resid norm 8.753125264343e+00 true resid norm 8.753125264342e+00 ||r(i)||/||b|| 2.091328874638e-04
233 KSP unpreconditioned resid norm 8.753122592440e+00 true resid norm 8.753122592424e+00 ||r(i)||/||b|| 2.091328236254e-04
234 KSP unpreconditioned resid norm 8.751108125980e+00 true resid norm 8.751108125975e+00 ||r(i)||/||b|| 2.090846932522e-04
235 KSP unpreconditioned resid norm 8.747204043868e+00 true resid norm 8.747204043868e+00 ||r(i)||/||b|| 2.089914154870e-04
236 KSP unpreconditioned resid norm 8.739424804688e+00 true resid norm 8.739424804689e+00 ||r(i)||/||b|| 2.088055510440e-04
237 KSP unpreconditioned resid norm 8.735970046643e+00 true resid norm 8.735970046639e+00 ||r(i)||/||b|| 2.087230086943e-04
238 KSP unpreconditioned resid norm 8.735325320962e+00 true resid norm 8.735325320970e+00 ||r(i)||/||b|| 2.087076046715e-04
239 KSP unpreconditioned resid norm 8.731311370642e+00 true resid norm 8.731311370644e+00 ||r(i)||/||b|| 2.086117018943e-04
240 KSP unpreconditioned resid norm 8.726727857325e+00 true resid norm 8.726727857325e+00 ||r(i)||/||b|| 2.085021909087e-04
241 KSP unpreconditioned resid norm 8.726280522474e+00 true resid norm 8.726280522469e+00 ||r(i)||/||b|| 2.084915030198e-04
242 KSP unpreconditioned resid norm 8.726255525655e+00 true resid norm 8.726255525642e+00 ||r(i)||/||b|| 2.084909057864e-04
243 KSP unpreconditioned resid norm 8.726216348352e+00 true resid norm 8.726216348345e+00 ||r(i)||/||b|| 2.084899697481e-04
244 KSP unpreconditioned resid norm 8.725795928070e+00 true resid norm 8.725795928062e+00 ||r(i)||/||b|| 2.084799249120e-04
245 KSP unpreconditioned resid norm 8.725765353744e+00 true resid norm 8.725765353739e+00 ||r(i)||/||b|| 2.084791944191e-04
246 KSP unpreconditioned resid norm 8.725733691045e+00 true resid norm 8.725733691033e+00 ||r(i)||/||b|| 2.084784379221e-04
247 KSP unpreconditioned resid norm 8.725627225598e+00 true resid norm 8.725627225588e+00 ||r(i)||/||b|| 2.084758942105e-04
248 KSP unpreconditioned resid norm 8.724527925127e+00 true resid norm 8.724527925119e+00 ||r(i)||/||b|| 2.084496293195e-04
249 KSP unpreconditioned resid norm 8.723377732966e+00 true resid norm 8.723377732962e+00 ||r(i)||/||b|| 2.084221485055e-04
250 KSP unpreconditioned resid norm 8.723197023098e+00 true resid norm 8.723197023086e+00 ||r(i)||/||b|| 2.084178309187e-04
251 KSP unpreconditioned resid norm 8.722768328753e+00 true resid norm 8.722768328745e+00 ||r(i)||/||b|| 2.084075883959e-04
252 KSP unpreconditioned resid norm 8.721740187465e+00 true resid norm 8.721740187470e+00 ||r(i)||/||b|| 2.083830236665e-04
253 KSP unpreconditioned resid norm 8.721702728270e+00 true resid norm 8.721702728255e+00 ||r(i)||/||b|| 2.083821286771e-04
254 KSP unpreconditioned resid norm 8.721655068435e+00 true resid norm 8.721655068431e+00 ||r(i)||/||b|| 2.083809899711e-04
255 KSP unpreconditioned resid norm 8.721611187245e+00 true resid norm 8.721611187241e+00 ||r(i)||/||b|| 2.083799415456e-04
256 KSP unpreconditioned resid norm 8.721574655632e+00 true resid norm 8.721574655623e+00 ||r(i)||/||b|| 2.083790687187e-04
257 KSP unpreconditioned resid norm 8.721540381065e+00 true resid norm 8.721540381068e+00 ||r(i)||/||b|| 2.083782498184e-04
258 KSP unpreconditioned resid norm 8.721475929279e+00 true resid norm 8.721475929270e+00 ||r(i)||/||b|| 2.083767099124e-04
259 KSP unpreconditioned resid norm 8.721465096813e+00 true resid norm 8.721465096799e+00 ||r(i)||/||b|| 2.083764510990e-04
260 KSP unpreconditioned resid norm 8.721465019120e+00 true resid norm 8.721465019107e+00 ||r(i)||/||b|| 2.083764492428e-04
261 KSP unpreconditioned resid norm 8.721384031374e+00 true resid norm 8.721384031368e+00 ||r(i)||/||b|| 2.083745142539e-04
262 KSP unpreconditioned resid norm 8.721383529209e+00 true resid norm 8.721383529209e+00 ||r(i)||/||b|| 2.083745022561e-04
263 KSP unpreconditioned resid norm 8.721224081770e+00 true resid norm 8.721224081754e+00 ||r(i)||/||b|| 2.083706926789e-04
264 KSP unpreconditioned resid norm 8.720726769939e+00 true resid norm 8.720726769931e+00 ||r(i)||/||b|| 2.083588107220e-04
265 KSP unpreconditioned resid norm 8.720597987351e+00 true resid norm 8.720597987348e+00 ||r(i)||/||b|| 2.083557338012e-04
266 KSP unpreconditioned resid norm 8.719955804547e+00 true resid norm 8.719955804544e+00 ||r(i)||/||b|| 2.083403905335e-04
267 KSP unpreconditioned resid norm 8.718989506411e+00 true resid norm 8.718989506405e+00 ||r(i)||/||b|| 2.083173033830e-04
268 KSP unpreconditioned resid norm 8.718497997075e+00 true resid norm 8.718497997066e+00 ||r(i)||/||b|| 2.083055600611e-04
269 KSP unpreconditioned resid norm 8.717860759677e+00 true resid norm 8.717860759673e+00 ||r(i)||/||b|| 2.082903349510e-04
270 KSP unpreconditioned resid norm 8.717860526462e+00 true resid norm 8.717860526462e+00 ||r(i)||/||b|| 2.082903293791e-04
271 KSP unpreconditioned resid norm 8.717860524178e+00 true resid norm 8.717860524178e+00 ||r(i)||/||b|| 2.082903293245e-04
272 KSP unpreconditioned resid norm 8.717857081592e+00 true resid norm 8.717857081582e+00 ||r(i)||/||b|| 2.082902470727e-04
273 KSP unpreconditioned resid norm 8.717856493353e+00 true resid norm 8.717856493351e+00 ||r(i)||/||b|| 2.082902330185e-04
274 KSP unpreconditioned resid norm 8.717854425359e+00 true resid norm 8.717854425360e+00 ||r(i)||/||b|| 2.082901836093e-04
275 KSP unpreconditioned resid norm 8.717854130915e+00 true resid norm 8.717854130914e+00 ||r(i)||/||b|| 2.082901765743e-04
276 KSP unpreconditioned resid norm 8.717847329843e+00 true resid norm 8.717847329843e+00 ||r(i)||/||b|| 2.082900140806e-04
277 KSP unpreconditioned resid norm 8.717847300683e+00 true resid norm 8.717847300674e+00 ||r(i)||/||b|| 2.082900133837e-04
278 KSP unpreconditioned resid norm 8.717831899187e+00 true resid norm 8.717831899184e+00 ||r(i)||/||b|| 2.082896454056e-04
279 KSP unpreconditioned resid norm 8.717781277780e+00 true resid norm 8.717781277772e+00 ||r(i)||/||b|| 2.082884359402e-04
280 KSP unpreconditioned resid norm 8.717775160312e+00 true resid norm 8.717775160320e+00 ||r(i)||/||b|| 2.082882897798e-04
281 KSP unpreconditioned resid norm 8.717735983767e+00 true resid norm 8.717735983764e+00 ||r(i)||/||b|| 2.082873537591e-04
282 KSP unpreconditioned resid norm 8.717735948913e+00 true resid norm 8.717735948907e+00 ||r(i)||/||b|| 2.082873529263e-04
283 KSP unpreconditioned resid norm 8.717735939544e+00 true resid norm 8.717735939538e+00 ||r(i)||/||b|| 2.082873527025e-04
284 KSP unpreconditioned resid norm 8.717709924004e+00 true resid norm 8.717709923998e+00 ||r(i)||/||b|| 2.082867311296e-04
285 KSP unpreconditioned resid norm 8.717707763936e+00 true resid norm 8.717707763935e+00 ||r(i)||/||b|| 2.082866795206e-04
286 KSP unpreconditioned resid norm 8.717659689139e+00 true resid norm 8.717659689121e+00 ||r(i)||/||b|| 2.082855308995e-04
287 KSP unpreconditioned resid norm 8.717583508790e+00 true resid norm 8.717583508785e+00 ||r(i)||/||b|| 2.082837107709e-04
288 KSP unpreconditioned resid norm 8.717552811681e+00 true resid norm 8.717552811671e+00 ||r(i)||/||b|| 2.082829773441e-04
289 KSP unpreconditioned resid norm 8.717549445547e+00 true resid norm 8.717549445540e+00 ||r(i)||/||b|| 2.082828969193e-04
290 KSP unpreconditioned resid norm 8.717524666846e+00 true resid norm 8.717524666849e+00 ||r(i)||/||b|| 2.082823048977e-04
291 KSP unpreconditioned resid norm 8.717312269535e+00 true resid norm 8.717312269535e+00 ||r(i)||/||b|| 2.082772302230e-04
292 KSP unpreconditioned resid norm 8.717312122044e+00 true resid norm 8.717312122031e+00 ||r(i)||/||b|| 2.082772266987e-04
293 KSP unpreconditioned resid norm 8.717178077010e+00 true resid norm 8.717178077002e+00 ||r(i)||/||b|| 2.082740240456e-04
294 KSP unpreconditioned resid norm 8.716918901925e+00 true resid norm 8.716918901917e+00 ||r(i)||/||b|| 2.082678317392e-04
295 KSP unpreconditioned resid norm 8.716865809745e+00 true resid norm 8.716865809726e+00 ||r(i)||/||b|| 2.082665632410e-04
296 KSP unpreconditioned resid norm 8.716865464389e+00 true resid norm 8.716865464387e+00 ||r(i)||/||b|| 2.082665549901e-04
297 KSP unpreconditioned resid norm 8.716288976735e+00 true resid norm 8.716288976726e+00 ||r(i)||/||b|| 2.082527813349e-04
298 KSP unpreconditioned resid norm 8.715944271533e+00 true resid norm 8.715944271528e+00 ||r(i)||/||b|| 2.082445455115e-04
299 KSP unpreconditioned resid norm 8.715942917902e+00 true resid norm 8.715942917897e+00 ||r(i)||/||b|| 2.082445131701e-04
300 KSP unpreconditioned resid norm 8.715855687508e+00 true resid norm 8.715855687508e+00 ||r(i)||/||b|| 2.082424290296e-04
301 KSP unpreconditioned resid norm 8.715855679545e+00 true resid norm 8.715855679548e+00 ||r(i)||/||b|| 2.082424288394e-04
302 KSP unpreconditioned resid norm 8.715855562642e+00 true resid norm 8.715855562642e+00 ||r(i)||/||b|| 2.082424260462e-04
303 KSP unpreconditioned resid norm 8.715855196578e+00 true resid norm 8.715855196569e+00 ||r(i)||/||b|| 2.082424172999e-04
304 KSP unpreconditioned resid norm 8.715855171901e+00 true resid norm 8.715855171895e+00 ||r(i)||/||b|| 2.082424167103e-04
305 KSP unpreconditioned resid norm 8.715854660888e+00 true resid norm 8.715854660882e+00 ||r(i)||/||b|| 2.082424045010e-04
306 KSP unpreconditioned resid norm 8.715854351998e+00 true resid norm 8.715854352001e+00 ||r(i)||/||b|| 2.082423971211e-04
307 KSP unpreconditioned resid norm 8.715851775216e+00 true resid norm 8.715851775215e+00 ||r(i)||/||b|| 2.082423355556e-04
308 KSP unpreconditioned resid norm 8.715850858847e+00 true resid norm 8.715850858849e+00 ||r(i)||/||b|| 2.082423136615e-04
309 KSP unpreconditioned resid norm 8.715850704804e+00 true resid norm 8.715850704798e+00 ||r(i)||/||b|| 2.082423099808e-04
310 KSP unpreconditioned resid norm 8.715846850617e+00 true resid norm 8.715846850603e+00 ||r(i)||/||b|| 2.082422178950e-04
311 KSP unpreconditioned resid norm 8.715845332660e+00 true resid norm 8.715845332654e+00 ||r(i)||/||b|| 2.082421816276e-04
312 KSP unpreconditioned resid norm 8.715833913706e+00 true resid norm 8.715833913712e+00 ||r(i)||/||b|| 2.082419088020e-04
313 KSP unpreconditioned resid norm 8.715798925519e+00 true resid norm 8.715798925516e+00 ||r(i)||/||b|| 2.082410728512e-04
314 KSP unpreconditioned resid norm 8.715794362305e+00 true resid norm 8.715794362297e+00 ||r(i)||/||b|| 2.082409638251e-04
315 KSP unpreconditioned resid norm 8.715787838635e+00 true resid norm 8.715787838633e+00 ||r(i)||/||b|| 2.082408079593e-04
316 KSP unpreconditioned resid norm 8.715786233708e+00 true resid norm 8.715786233710e+00 ||r(i)||/||b|| 2.082407696139e-04
317 KSP unpreconditioned resid norm 8.715783459228e+00 true resid norm 8.715783459223e+00 ||r(i)||/||b|| 2.082407033248e-04
318 KSP unpreconditioned resid norm 8.715743962908e+00 true resid norm 8.715743962913e+00 ||r(i)||/||b|| 2.082397596645e-04
319 KSP unpreconditioned resid norm 8.715742474102e+00 true resid norm 8.715742474093e+00 ||r(i)||/||b|| 2.082397240930e-04
320 KSP unpreconditioned resid norm 8.715679403183e+00 true resid norm 8.715679403183e+00 ||r(i)||/||b|| 2.082382171796e-04
321 KSP unpreconditioned resid norm 8.715675934766e+00 true resid norm 8.715675934770e+00 ||r(i)||/||b|| 2.082381343111e-04
322 KSP unpreconditioned resid norm 8.715675589879e+00 true resid norm 8.715675589878e+00 ||r(i)||/||b|| 2.082381260708e-04
323 KSP unpreconditioned resid norm 8.715639208596e+00 true resid norm 8.715639208599e+00 ||r(i)||/||b|| 2.082372568359e-04
324 KSP unpreconditioned resid norm 8.715630416150e+00 true resid norm 8.715630416152e+00 ||r(i)||/||b|| 2.082370467635e-04
325 KSP unpreconditioned resid norm 8.715593228875e+00 true resid norm 8.715593228865e+00 ||r(i)||/||b|| 2.082361582712e-04
326 KSP unpreconditioned resid norm 8.715592540217e+00 true resid norm 8.715592540222e+00 ||r(i)||/||b|| 2.082361418178e-04
327 KSP unpreconditioned resid norm 8.715581797348e+00 true resid norm 8.715581797340e+00 ||r(i)||/||b|| 2.082358851450e-04
328 KSP unpreconditioned resid norm 8.715572447451e+00 true resid norm 8.715572447452e+00 ||r(i)||/||b|| 2.082356617540e-04
329 KSP unpreconditioned resid norm 8.715572431207e+00 true resid norm 8.715572431204e+00 ||r(i)||/||b|| 2.082356613658e-04
330 KSP unpreconditioned resid norm 8.715496797564e+00 true resid norm 8.715496797564e+00 ||r(i)||/||b|| 2.082338542991e-04
331 KSP unpreconditioned resid norm 8.715496769357e+00 true resid norm 8.715496769369e+00 ||r(i)||/||b|| 2.082338536254e-04
332 KSP unpreconditioned resid norm 8.715496589864e+00 true resid norm 8.715496589865e+00 ||r(i)||/||b|| 2.082338493366e-04
333 KSP unpreconditioned resid norm 8.715496072559e+00 true resid norm 8.715496072573e+00 ||r(i)||/||b|| 2.082338369773e-04
334 KSP unpreconditioned resid norm 8.715495964245e+00 true resid norm 8.715495964256e+00 ||r(i)||/||b|| 2.082338343893e-04
335 KSP unpreconditioned resid norm 8.715495580817e+00 true resid norm 8.715495580819e+00 ||r(i)||/||b|| 2.082338252281e-04
336 KSP unpreconditioned resid norm 8.715495522314e+00 true resid norm 8.715495522323e+00 ||r(i)||/||b|| 2.082338238305e-04
337 KSP unpreconditioned resid norm 8.715495335767e+00 true resid norm 8.715495335762e+00 ||r(i)||/||b|| 2.082338193731e-04
338 KSP unpreconditioned resid norm 8.715495317019e+00 true resid norm 8.715495317033e+00 ||r(i)||/||b|| 2.082338189257e-04
339 KSP unpreconditioned resid norm 8.715494238458e+00 true resid norm 8.715494238463e+00 ||r(i)||/||b|| 2.082337931561e-04
340 KSP unpreconditioned resid norm 8.715493847607e+00 true resid norm 8.715493847612e+00 ||r(i)||/||b|| 2.082337838177e-04
341 KSP unpreconditioned resid norm 8.715490918535e+00 true resid norm 8.715490918540e+00 ||r(i)||/||b|| 2.082337138353e-04
342 KSP unpreconditioned resid norm 8.715484900680e+00 true resid norm 8.715484900683e+00 ||r(i)||/||b|| 2.082335700544e-04
343 KSP unpreconditioned resid norm 8.715483403749e+00 true resid norm 8.715483403756e+00 ||r(i)||/||b|| 2.082335342893e-04
344 KSP unpreconditioned resid norm 8.715482678264e+00 true resid norm 8.715482678270e+00 ||r(i)||/||b|| 2.082335169557e-04
345 KSP unpreconditioned resid norm 8.715479172594e+00 true resid norm 8.715479172594e+00 ||r(i)||/||b|| 2.082334331968e-04
346 KSP unpreconditioned resid norm 8.715479083055e+00 true resid norm 8.715479083052e+00 ||r(i)||/||b|| 2.082334310574e-04
347 KSP unpreconditioned resid norm 8.715475638791e+00 true resid norm 8.715475638797e+00 ||r(i)||/||b|| 2.082333487660e-04
348 KSP unpreconditioned resid norm 8.715468928434e+00 true resid norm 8.715468928433e+00 ||r(i)||/||b|| 2.082331884395e-04
349 KSP unpreconditioned resid norm 8.715468571741e+00 true resid norm 8.715468571748e+00 ||r(i)||/||b|| 2.082331799175e-04
350 KSP unpreconditioned resid norm 8.715467609263e+00 true resid norm 8.715467609260e+00 ||r(i)||/||b|| 2.082331569214e-04
351 KSP unpreconditioned resid norm 8.715444037384e+00 true resid norm 8.715444037381e+00 ||r(i)||/||b|| 2.082325937334e-04
352 KSP unpreconditioned resid norm 8.715439910362e+00 true resid norm 8.715439910364e+00 ||r(i)||/||b|| 2.082324951292e-04
353 KSP unpreconditioned resid norm 8.715438567006e+00 true resid norm 8.715438567008e+00 ||r(i)||/||b|| 2.082324630332e-04
354 KSP unpreconditioned resid norm 8.715386508172e+00 true resid norm 8.715386508163e+00 ||r(i)||/||b|| 2.082312192241e-04
355 KSP unpreconditioned resid norm 8.715386039058e+00 true resid norm 8.715386039064e+00 ||r(i)||/||b|| 2.082312080162e-04
356 KSP unpreconditioned resid norm 8.715383056708e+00 true resid norm 8.715383056715e+00 ||r(i)||/||b|| 2.082311367609e-04
357 KSP unpreconditioned resid norm 8.715379362504e+00 true resid norm 8.715379362511e+00 ||r(i)||/||b|| 2.082310484976e-04
358 KSP unpreconditioned resid norm 8.715357301200e+00 true resid norm 8.715357301209e+00 ||r(i)||/||b|| 2.082305214008e-04
359 KSP unpreconditioned resid norm 8.715352121331e+00 true resid norm 8.715352121341e+00 ||r(i)||/||b|| 2.082303976415e-04
360 KSP unpreconditioned resid norm 8.715307128105e+00 true resid norm 8.715307128105e+00 ||r(i)||/||b|| 2.082293226466e-04
361 KSP unpreconditioned resid norm 8.715307119221e+00 true resid norm 8.715307119211e+00 ||r(i)||/||b|| 2.082293224341e-04
362 KSP unpreconditioned resid norm 8.715306968079e+00 true resid norm 8.715306968075e+00 ||r(i)||/||b|| 2.082293188231e-04
363 KSP unpreconditioned resid norm 8.715306020766e+00 true resid norm 8.715306020766e+00 ||r(i)||/||b|| 2.082292961896e-04
364 KSP unpreconditioned resid norm 8.715305347036e+00 true resid norm 8.715305347041e+00 ||r(i)||/||b|| 2.082292800928e-04
365 KSP unpreconditioned resid norm 8.715305297487e+00 true resid norm 8.715305297484e+00 ||r(i)||/||b|| 2.082292789087e-04
366 KSP unpreconditioned resid norm 8.715305268857e+00 true resid norm 8.715305268855e+00 ||r(i)||/||b|| 2.082292782247e-04
367 KSP unpreconditioned resid norm 8.715304760080e+00 true resid norm 8.715304760081e+00 ||r(i)||/||b|| 2.082292660689e-04
368 KSP unpreconditioned resid norm 8.715304577208e+00 true resid norm 8.715304577201e+00 ||r(i)||/||b|| 2.082292616995e-04
369 KSP unpreconditioned resid norm 8.715304551191e+00 true resid norm 8.715304551183e+00 ||r(i)||/||b|| 2.082292610778e-04
370 KSP unpreconditioned resid norm 8.715301827851e+00 true resid norm 8.715301827849e+00 ||r(i)||/||b|| 2.082291960109e-04
371 KSP unpreconditioned resid norm 8.715301721255e+00 true resid norm 8.715301721244e+00 ||r(i)||/||b|| 2.082291934639e-04
372 KSP unpreconditioned resid norm 8.715295756875e+00 true resid norm 8.715295756872e+00 ||r(i)||/||b|| 2.082290509609e-04
373 KSP unpreconditioned resid norm 8.715292049258e+00 true resid norm 8.715292049248e+00 ||r(i)||/||b|| 2.082289623770e-04
374 KSP unpreconditioned resid norm 8.715290821544e+00 true resid norm 8.715290821548e+00 ||r(i)||/||b|| 2.082289330443e-04
375 KSP unpreconditioned resid norm 8.715290664158e+00 true resid norm 8.715290664151e+00 ||r(i)||/||b|| 2.082289292838e-04
376 KSP unpreconditioned resid norm 8.715289995744e+00 true resid norm 8.715289995731e+00 ||r(i)||/||b|| 2.082289133136e-04
377 KSP unpreconditioned resid norm 8.715288560951e+00 true resid norm 8.715288560946e+00 ||r(i)||/||b|| 2.082288790332e-04
378 KSP unpreconditioned resid norm 8.715280213801e+00 true resid norm 8.715280213791e+00 ||r(i)||/||b|| 2.082286795999e-04
379 KSP unpreconditioned resid norm 8.715275517946e+00 true resid norm 8.715275517942e+00 ||r(i)||/||b|| 2.082285674050e-04
380 KSP unpreconditioned resid norm 8.715248139111e+00 true resid norm 8.715248139103e+00 ||r(i)||/||b|| 2.082279132597e-04
381 KSP unpreconditioned resid norm 8.715247766175e+00 true resid norm 8.715247766164e+00 ||r(i)||/||b|| 2.082279043493e-04
382 KSP unpreconditioned resid norm 8.715246414670e+00 true resid norm 8.715246414664e+00 ||r(i)||/||b|| 2.082278720588e-04
383 KSP unpreconditioned resid norm 8.715228242318e+00 true resid norm 8.715228242309e+00 ||r(i)||/||b|| 2.082274378782e-04
384 KSP unpreconditioned resid norm 8.715226313126e+00 true resid norm 8.715226313130e+00 ||r(i)||/||b|| 2.082273917855e-04
385 KSP unpreconditioned resid norm 8.715192789055e+00 true resid norm 8.715192789045e+00 ||r(i)||/||b|| 2.082265908157e-04
386 KSP unpreconditioned resid norm 8.715192785426e+00 true resid norm 8.715192785422e+00 ||r(i)||/||b|| 2.082265907292e-04
387 KSP unpreconditioned resid norm 8.715022319800e+00 true resid norm 8.715022319792e+00 ||r(i)||/||b|| 2.082225179016e-04
388 KSP unpreconditioned resid norm 8.715013024677e+00 true resid norm 8.715013024673e+00 ||r(i)||/||b|| 2.082222958193e-04
389 KSP unpreconditioned resid norm 8.715000295403e+00 true resid norm 8.715000295394e+00 ||r(i)||/||b|| 2.082219916866e-04
390 KSP unpreconditioned resid norm 8.714993298025e+00 true resid norm 8.714993298025e+00 ||r(i)||/||b|| 2.082218245029e-04
391 KSP unpreconditioned resid norm 8.714993256884e+00 true resid norm 8.714993256889e+00 ||r(i)||/||b|| 2.082218235201e-04
392 KSP unpreconditioned resid norm 8.714993208878e+00 true resid norm 8.714993208876e+00 ||r(i)||/||b|| 2.082218223730e-04
393 KSP unpreconditioned resid norm 8.714993203913e+00 true resid norm 8.714993203925e+00 ||r(i)||/||b|| 2.082218222547e-04
394 KSP unpreconditioned resid norm 8.714993107241e+00 true resid norm 8.714993107240e+00 ||r(i)||/||b|| 2.082218199446e-04
395 KSP unpreconditioned resid norm 8.714992513095e+00 true resid norm 8.714992513105e+00 ||r(i)||/||b|| 2.082218057493e-04
396 KSP unpreconditioned resid norm 8.714992076297e+00 true resid norm 8.714992076295e+00 ||r(i)||/||b|| 2.082217953129e-04
397 KSP unpreconditioned resid norm 8.714991904091e+00 true resid norm 8.714991904086e+00 ||r(i)||/||b|| 2.082217911984e-04
398 KSP unpreconditioned resid norm 8.714991526119e+00 true resid norm 8.714991526118e+00 ||r(i)||/||b|| 2.082217821679e-04
399 KSP unpreconditioned resid norm 8.714991333320e+00 true resid norm 8.714991333314e+00 ||r(i)||/||b|| 2.082217775613e-04
400 KSP unpreconditioned resid norm 8.714991057569e+00 true resid norm 8.714991057569e+00 ||r(i)||/||b|| 2.082217709731e-04
401 KSP unpreconditioned resid norm 8.714991027971e+00 true resid norm 8.714991027971e+00 ||r(i)||/||b|| 2.082217702660e-04
402 KSP unpreconditioned resid norm 8.714987121921e+00 true resid norm 8.714987121937e+00 ||r(i)||/||b|| 2.082216769416e-04
403 KSP unpreconditioned resid norm 8.714984075295e+00 true resid norm 8.714984075311e+00 ||r(i)||/||b|| 2.082216041504e-04
404 KSP unpreconditioned resid norm 8.714978100044e+00 true resid norm 8.714978100050e+00 ||r(i)||/||b|| 2.082214613873e-04
405 KSP unpreconditioned resid norm 8.714976277644e+00 true resid norm 8.714976277651e+00 ||r(i)||/||b|| 2.082214178459e-04
406 KSP unpreconditioned resid norm 8.714976178777e+00 true resid norm 8.714976178784e+00 ||r(i)||/||b|| 2.082214154837e-04
407 KSP unpreconditioned resid norm 8.714974190439e+00 true resid norm 8.714974190436e+00 ||r(i)||/||b|| 2.082213679774e-04
408 KSP unpreconditioned resid norm 8.714971493927e+00 true resid norm 8.714971493925e+00 ||r(i)||/||b|| 2.082213035514e-04
409 KSP unpreconditioned resid norm 8.714966686517e+00 true resid norm 8.714966686517e+00 ||r(i)||/||b|| 2.082211886910e-04
410 KSP unpreconditioned resid norm 8.714966673134e+00 true resid norm 8.714966673137e+00 ||r(i)||/||b|| 2.082211883713e-04
411 KSP unpreconditioned resid norm 8.714931601060e+00 true resid norm 8.714931601050e+00 ||r(i)||/||b|| 2.082203504161e-04
412 KSP unpreconditioned resid norm 8.714929853758e+00 true resid norm 8.714929853765e+00 ||r(i)||/||b|| 2.082203086693e-04
413 KSP unpreconditioned resid norm 8.714911505489e+00 true resid norm 8.714911505480e+00 ||r(i)||/||b|| 2.082198702854e-04
414 KSP unpreconditioned resid norm 8.714851686120e+00 true resid norm 8.714851686132e+00 ||r(i)||/||b|| 2.082184410595e-04
415 KSP unpreconditioned resid norm 8.714851670474e+00 true resid norm 8.714851670482e+00 ||r(i)||/||b|| 2.082184406856e-04
416 KSP unpreconditioned resid norm 8.714846601215e+00 true resid norm 8.714846601218e+00 ||r(i)||/||b|| 2.082183195689e-04
417 KSP unpreconditioned resid norm 8.714834014168e+00 true resid norm 8.714834014172e+00 ||r(i)||/||b|| 2.082180188345e-04
418 KSP unpreconditioned resid norm 8.714815093662e+00 true resid norm 8.714815093660e+00 ||r(i)||/||b|| 2.082175667787e-04
419 KSP unpreconditioned resid norm 8.714800460823e+00 true resid norm 8.714800460830e+00 ||r(i)||/||b|| 2.082172171658e-04
420 KSP unpreconditioned resid norm 8.714725005871e+00 true resid norm 8.714725005871e+00 ||r(i)||/||b|| 2.082154143681e-04
421 KSP unpreconditioned resid norm 8.714723986397e+00 true resid norm 8.714723986395e+00 ||r(i)||/||b|| 2.082153900104e-04
422 KSP unpreconditioned resid norm 8.714718946688e+00 true resid norm 8.714718946673e+00 ||r(i)||/||b|| 2.082152695995e-04
423 KSP unpreconditioned resid norm 8.714713071323e+00 true resid norm 8.714713071318e+00 ||r(i)||/||b|| 2.082151292234e-04
424 KSP unpreconditioned resid norm 8.714712053749e+00 true resid norm 8.714712053738e+00 ||r(i)||/||b|| 2.082151049110e-04
425 KSP unpreconditioned resid norm 8.714710421205e+00 true resid norm 8.714710421207e+00 ||r(i)||/||b|| 2.082150659060e-04
426 KSP unpreconditioned resid norm 8.714708686691e+00 true resid norm 8.714708686683e+00 ||r(i)||/||b|| 2.082150244641e-04
427 KSP unpreconditioned resid norm 8.714708099075e+00 true resid norm 8.714708099084e+00 ||r(i)||/||b|| 2.082150104250e-04
428 KSP unpreconditioned resid norm 8.714707078998e+00 true resid norm 8.714707079002e+00 ||r(i)||/||b|| 2.082149860528e-04
429 KSP unpreconditioned resid norm 8.714702226116e+00 true resid norm 8.714702226121e+00 ||r(i)||/||b|| 2.082148701060e-04
430 KSP unpreconditioned resid norm 8.714694253736e+00 true resid norm 8.714694253741e+00 ||r(i)||/||b|| 2.082146796269e-04
431 KSP unpreconditioned resid norm 8.714687649500e+00 true resid norm 8.714687649509e+00 ||r(i)||/||b|| 2.082145218362e-04
432 KSP unpreconditioned resid norm 8.714678601103e+00 true resid norm 8.714678601098e+00 ||r(i)||/||b|| 2.082143056482e-04
433 KSP unpreconditioned resid norm 8.714677059861e+00 true resid norm 8.714677059863e+00 ||r(i)||/||b|| 2.082142688245e-04
434 KSP unpreconditioned resid norm 8.714671700527e+00 true resid norm 8.714671700519e+00 ||r(i)||/||b|| 2.082141407771e-04
435 KSP unpreconditioned resid norm 8.714668710897e+00 true resid norm 8.714668710897e+00 ||r(i)||/||b|| 2.082140693479e-04
436 KSP unpreconditioned resid norm 8.714666474687e+00 true resid norm 8.714666474677e+00 ||r(i)||/||b|| 2.082140159193e-04
437 KSP unpreconditioned resid norm 8.714665998901e+00 true resid norm 8.714665998899e+00 ||r(i)||/||b|| 2.082140045519e-04
438 KSP unpreconditioned resid norm 8.714647091575e+00 true resid norm 8.714647091581e+00 ||r(i)||/||b|| 2.082135528112e-04
439 KSP unpreconditioned resid norm 8.714646452397e+00 true resid norm 8.714646452398e+00 ||r(i)||/||b|| 2.082135375397e-04
440 KSP unpreconditioned resid norm 8.714638240750e+00 true resid norm 8.714638240754e+00 ||r(i)||/||b|| 2.082133413440e-04
441 KSP unpreconditioned resid norm 8.714635480127e+00 true resid norm 8.714635480134e+00 ||r(i)||/||b|| 2.082132753863e-04
442 KSP unpreconditioned resid norm 8.714634630131e+00 true resid norm 8.714634630121e+00 ||r(i)||/||b|| 2.082132550775e-04
443 KSP unpreconditioned resid norm 8.714624324054e+00 true resid norm 8.714624324048e+00 ||r(i)||/||b|| 2.082130088410e-04
444 KSP unpreconditioned resid norm 8.714599358709e+00 true resid norm 8.714599358713e+00 ||r(i)||/||b|| 2.082124123600e-04
445 KSP unpreconditioned resid norm 8.714578314445e+00 true resid norm 8.714578314443e+00 ||r(i)||/||b|| 2.082119095626e-04
446 KSP unpreconditioned resid norm 8.714558492429e+00 true resid norm 8.714558492430e+00 ||r(i)||/||b|| 2.082114359678e-04
447 KSP unpreconditioned resid norm 8.714558085664e+00 true resid norm 8.714558085660e+00 ||r(i)||/||b|| 2.082114262491e-04
448 KSP unpreconditioned resid norm 8.714558011301e+00 true resid norm 8.714558011296e+00 ||r(i)||/||b|| 2.082114244723e-04
449 KSP unpreconditioned resid norm 8.714554079652e+00 true resid norm 8.714554079646e+00 ||r(i)||/||b|| 2.082113305359e-04
450 KSP unpreconditioned resid norm 8.714533931468e+00 true resid norm 8.714533931468e+00 ||r(i)||/||b|| 2.082108491482e-04
451 KSP unpreconditioned resid norm 8.714533768431e+00 true resid norm 8.714533768436e+00 ||r(i)||/||b|| 2.082108452530e-04
452 KSP unpreconditioned resid norm 8.714532877423e+00 true resid norm 8.714532877427e+00 ||r(i)||/||b|| 2.082108239647e-04
453 KSP unpreconditioned resid norm 8.714531400744e+00 true resid norm 8.714531400745e+00 ||r(i)||/||b|| 2.082107886833e-04
454 KSP unpreconditioned resid norm 8.714530886431e+00 true resid norm 8.714530886432e+00 ||r(i)||/||b|| 2.082107763951e-04
455 KSP unpreconditioned resid norm 8.714530746452e+00 true resid norm 8.714530746458e+00 ||r(i)||/||b|| 2.082107730508e-04
456 KSP unpreconditioned resid norm 8.714530644273e+00 true resid norm 8.714530644281e+00 ||r(i)||/||b|| 2.082107706095e-04
457 KSP unpreconditioned resid norm 8.714530502145e+00 true resid norm 8.714530502154e+00 ||r(i)||/||b|| 2.082107672138e-04
458 KSP unpreconditioned resid norm 8.714530132192e+00 true resid norm 8.714530132191e+00 ||r(i)||/||b|| 2.082107583745e-04
459 KSP unpreconditioned resid norm 8.714529822398e+00 true resid norm 8.714529822402e+00 ||r(i)||/||b|| 2.082107509729e-04
460 KSP unpreconditioned resid norm 8.714527883658e+00 true resid norm 8.714527883663e+00 ||r(i)||/||b|| 2.082107046519e-04
461 KSP unpreconditioned resid norm 8.714527639692e+00 true resid norm 8.714527639698e+00 ||r(i)||/||b|| 2.082106988230e-04
462 KSP unpreconditioned resid norm 8.714525996448e+00 true resid norm 8.714525996456e+00 ||r(i)||/||b|| 2.082106595620e-04
463 KSP unpreconditioned resid norm 8.714525927792e+00 true resid norm 8.714525927808e+00 ||r(i)||/||b|| 2.082106579218e-04
464 KSP unpreconditioned resid norm 8.714525542088e+00 true resid norm 8.714525542095e+00 ||r(i)||/||b|| 2.082106487062e-04
465 KSP unpreconditioned resid norm 8.714519167084e+00 true resid norm 8.714519167089e+00 ||r(i)||/||b|| 2.082104963923e-04
466 KSP unpreconditioned resid norm 8.714519166867e+00 true resid norm 8.714519166874e+00 ||r(i)||/||b|| 2.082104963871e-04
467 KSP unpreconditioned resid norm 8.714516326737e+00 true resid norm 8.714516326743e+00 ||r(i)||/||b|| 2.082104285297e-04
468 KSP unpreconditioned resid norm 8.714512766368e+00 true resid norm 8.714512766370e+00 ||r(i)||/||b|| 2.082103434639e-04
469 KSP unpreconditioned resid norm 8.714507313158e+00 true resid norm 8.714507313161e+00 ||r(i)||/||b|| 2.082102131738e-04
470 KSP unpreconditioned resid norm 8.714504721906e+00 true resid norm 8.714504721917e+00 ||r(i)||/||b|| 2.082101512629e-04
471 KSP unpreconditioned resid norm 8.714494108323e+00 true resid norm 8.714494108317e+00 ||r(i)||/||b|| 2.082098976789e-04
472 KSP unpreconditioned resid norm 8.714493327064e+00 true resid norm 8.714493327067e+00 ||r(i)||/||b|| 2.082098790129e-04
473 KSP unpreconditioned resid norm 8.714484449636e+00 true resid norm 8.714484449642e+00 ||r(i)||/||b|| 2.082096669103e-04
474 KSP unpreconditioned resid norm 8.714478729702e+00 true resid norm 8.714478729704e+00 ||r(i)||/||b|| 2.082095302474e-04
475 KSP unpreconditioned resid norm 8.714455769443e+00 true resid norm 8.714455769440e+00 ||r(i)||/||b|| 2.082089816723e-04
476 KSP unpreconditioned resid norm 8.714451897646e+00 true resid norm 8.714451897657e+00 ||r(i)||/||b|| 2.082088891663e-04
477 KSP unpreconditioned resid norm 8.714415532265e+00 true resid norm 8.714415532286e+00 ||r(i)||/||b|| 2.082080203114e-04
478 KSP unpreconditioned resid norm 8.714414702398e+00 true resid norm 8.714414702402e+00 ||r(i)||/||b|| 2.082080004835e-04
479 KSP unpreconditioned resid norm 8.714373893880e+00 true resid norm 8.714373893882e+00 ||r(i)||/||b|| 2.082070254714e-04
480 KSP unpreconditioned resid norm 8.714328889876e+00 true resid norm 8.714328889876e+00 ||r(i)||/||b|| 2.082059502191e-04
481 KSP unpreconditioned resid norm 8.714328518179e+00 true resid norm 8.714328518182e+00 ||r(i)||/||b|| 2.082059413385e-04
482 KSP unpreconditioned resid norm 8.714325140041e+00 true resid norm 8.714325140038e+00 ||r(i)||/||b|| 2.082058606266e-04
483 KSP unpreconditioned resid norm 8.714316876355e+00 true resid norm 8.714316876351e+00 ||r(i)||/||b|| 2.082056631876e-04
484 KSP unpreconditioned resid norm 8.714315353515e+00 true resid norm 8.714315353515e+00 ||r(i)||/||b|| 2.082056268034e-04
485 KSP unpreconditioned resid norm 8.714312054804e+00 true resid norm 8.714312054795e+00 ||r(i)||/||b|| 2.082055479892e-04
486 KSP unpreconditioned resid norm 8.714310656575e+00 true resid norm 8.714310656577e+00 ||r(i)||/||b|| 2.082055145824e-04
487 KSP unpreconditioned resid norm 8.714309076660e+00 true resid norm 8.714309076651e+00 ||r(i)||/||b|| 2.082054768343e-04
488 KSP unpreconditioned resid norm 8.714305995216e+00 true resid norm 8.714305995216e+00 ||r(i)||/||b|| 2.082054032115e-04
489 KSP unpreconditioned resid norm 8.714301832987e+00 true resid norm 8.714301832981e+00 ||r(i)||/||b|| 2.082053037658e-04
490 KSP unpreconditioned resid norm 8.714284818443e+00 true resid norm 8.714284818443e+00 ||r(i)||/||b|| 2.082048972482e-04
491 KSP unpreconditioned resid norm 8.714283308037e+00 true resid norm 8.714283308030e+00 ||r(i)||/||b|| 2.082048611609e-04
492 KSP unpreconditioned resid norm 8.714262434717e+00 true resid norm 8.714262434709e+00 ||r(i)||/||b|| 2.082043624478e-04
493 KSP unpreconditioned resid norm 8.714261564657e+00 true resid norm 8.714261564649e+00 ||r(i)||/||b|| 2.082043416600e-04
494 KSP unpreconditioned resid norm 8.714250839520e+00 true resid norm 8.714250839510e+00 ||r(i)||/||b|| 2.082040854111e-04
495 KSP unpreconditioned resid norm 8.714249406599e+00 true resid norm 8.714249406597e+00 ||r(i)||/||b|| 2.082040511754e-04
496 KSP unpreconditioned resid norm 8.714246249735e+00 true resid norm 8.714246249733e+00 ||r(i)||/||b|| 2.082039757504e-04
497 KSP unpreconditioned resid norm 8.714245768234e+00 true resid norm 8.714245768235e+00 ||r(i)||/||b|| 2.082039642463e-04
498 KSP unpreconditioned resid norm 8.714237614333e+00 true resid norm 8.714237614331e+00 ||r(i)||/||b|| 2.082037694302e-04
499 KSP unpreconditioned resid norm 8.714223832895e+00 true resid norm 8.714223832887e+00 ||r(i)||/||b|| 2.082034401589e-04
500 KSP unpreconditioned resid norm 8.714215373965e+00 true resid norm 8.714215373949e+00 ||r(i)||/||b|| 2.082032380549e-04
501 KSP unpreconditioned resid norm 8.714198979908e+00 true resid norm 8.714198979908e+00 ||r(i)||/||b|| 2.082028463624e-04
502 KSP unpreconditioned resid norm 8.714192880623e+00 true resid norm 8.714192880613e+00 ||r(i)||/||b|| 2.082027006358e-04
503 KSP unpreconditioned resid norm 8.714177003695e+00 true resid norm 8.714177003684e+00 ||r(i)||/||b|| 2.082023212984e-04
504 KSP unpreconditioned resid norm 8.714144020896e+00 true resid norm 8.714144020900e+00 ||r(i)||/||b|| 2.082015332616e-04
505 KSP unpreconditioned resid norm 8.714121931679e+00 true resid norm 8.714121931677e+00 ||r(i)||/||b|| 2.082010054977e-04
506 KSP unpreconditioned resid norm 8.714114483113e+00 true resid norm 8.714114483115e+00 ||r(i)||/||b|| 2.082008275339e-04
507 KSP unpreconditioned resid norm 8.714113967805e+00 true resid norm 8.714113967801e+00 ||r(i)||/||b|| 2.082008152219e-04
508 KSP unpreconditioned resid norm 8.714111639264e+00 true resid norm 8.714111639261e+00 ||r(i)||/||b|| 2.082007595875e-04
509 KSP unpreconditioned resid norm 8.714107997688e+00 true resid norm 8.714107997685e+00 ||r(i)||/||b|| 2.082006725817e-04
510 KSP unpreconditioned resid norm 8.714105654152e+00 true resid norm 8.714105654152e+00 ||r(i)||/||b|| 2.082006165891e-04
511 KSP unpreconditioned resid norm 8.714105635957e+00 true resid norm 8.714105635954e+00 ||r(i)||/||b|| 2.082006161543e-04
512 KSP unpreconditioned resid norm 8.714105461577e+00 true resid norm 8.714105461580e+00 ||r(i)||/||b|| 2.082006119881e-04
513 KSP unpreconditioned resid norm 8.714104934823e+00 true resid norm 8.714104934812e+00 ||r(i)||/||b|| 2.082005994024e-04
514 KSP unpreconditioned resid norm 8.714104613527e+00 true resid norm 8.714104613527e+00 ||r(i)||/||b|| 2.082005917261e-04
515 KSP unpreconditioned resid norm 8.714104603407e+00 true resid norm 8.714104603400e+00 ||r(i)||/||b|| 2.082005914842e-04
516 KSP unpreconditioned resid norm 8.714104583732e+00 true resid norm 8.714104583725e+00 ||r(i)||/||b|| 2.082005910141e-04
517 KSP unpreconditioned resid norm 8.714104001501e+00 true resid norm 8.714104001496e+00 ||r(i)||/||b|| 2.082005771033e-04
518 KSP unpreconditioned resid norm 8.714102384963e+00 true resid norm 8.714102384957e+00 ||r(i)||/||b|| 2.082005384803e-04
519 KSP unpreconditioned resid norm 8.714102354101e+00 true resid norm 8.714102354096e+00 ||r(i)||/||b|| 2.082005377430e-04
520 KSP unpreconditioned resid norm 8.714101450086e+00 true resid norm 8.714101450089e+00 ||r(i)||/||b|| 2.082005161441e-04
521 KSP unpreconditioned resid norm 8.714101392044e+00 true resid norm 8.714101392049e+00 ||r(i)||/||b|| 2.082005147574e-04
522 KSP unpreconditioned resid norm 8.714100912477e+00 true resid norm 8.714100912472e+00 ||r(i)||/||b|| 2.082005032992e-04
523 KSP unpreconditioned resid norm 8.714100871064e+00 true resid norm 8.714100871054e+00 ||r(i)||/||b|| 2.082005023096e-04
524 KSP unpreconditioned resid norm 8.714098225079e+00 true resid norm 8.714098225066e+00 ||r(i)||/||b|| 2.082004390907e-04
525 KSP unpreconditioned resid norm 8.714090740558e+00 true resid norm 8.714090740544e+00 ||r(i)||/||b|| 2.082002602677e-04
526 KSP unpreconditioned resid norm 8.714090691572e+00 true resid norm 8.714090691578e+00 ||r(i)||/||b|| 2.082002590978e-04
527 KSP unpreconditioned resid norm 8.714088532793e+00 true resid norm 8.714088532793e+00 ||r(i)||/||b|| 2.082002075193e-04
528 KSP unpreconditioned resid norm 8.714088312896e+00 true resid norm 8.714088312900e+00 ||r(i)||/||b|| 2.082002022656e-04
529 KSP unpreconditioned resid norm 8.714086319492e+00 true resid norm 8.714086319483e+00 ||r(i)||/||b|| 2.082001546381e-04
530 KSP unpreconditioned resid norm 8.714079009034e+00 true resid norm 8.714079009019e+00 ||r(i)||/||b|| 2.081999799738e-04
531 KSP unpreconditioned resid norm 8.714062546574e+00 true resid norm 8.714062546560e+00 ||r(i)||/||b|| 2.081995866467e-04
532 KSP unpreconditioned resid norm 8.714062466422e+00 true resid norm 8.714062466423e+00 ||r(i)||/||b|| 2.081995847320e-04
533 KSP unpreconditioned resid norm 8.714042504664e+00 true resid norm 8.714042504668e+00 ||r(i)||/||b|| 2.081991077984e-04
534 KSP unpreconditioned resid norm 8.714041234257e+00 true resid norm 8.714041234254e+00 ||r(i)||/||b|| 2.081990774452e-04
535 KSP unpreconditioned resid norm 8.714027851635e+00 true resid norm 8.714027851633e+00 ||r(i)||/||b|| 2.081987577027e-04
536 KSP unpreconditioned resid norm 8.714018782479e+00 true resid norm 8.714018782476e+00 ||r(i)||/||b|| 2.081985410191e-04
537 KSP unpreconditioned resid norm 8.713980165675e+00 true resid norm 8.713980165667e+00 ||r(i)||/||b|| 2.081976183721e-04
538 KSP unpreconditioned resid norm 8.713980109349e+00 true resid norm 8.713980109356e+00 ||r(i)||/||b|| 2.081976170267e-04
539 KSP unpreconditioned resid norm 8.713926586165e+00 true resid norm 8.713926586159e+00 ||r(i)||/||b|| 2.081963382308e-04
540 KSP unpreconditioned resid norm 8.713883118512e+00 true resid norm 8.713883118512e+00 ||r(i)||/||b|| 2.081952996858e-04
541 KSP unpreconditioned resid norm 8.713882712622e+00 true resid norm 8.713882712616e+00 ||r(i)||/||b|| 2.081952899880e-04
542 KSP unpreconditioned resid norm 8.713878343365e+00 true resid norm 8.713878343361e+00 ||r(i)||/||b|| 2.081951855961e-04
543 KSP unpreconditioned resid norm 8.713867453877e+00 true resid norm 8.713867453877e+00 ||r(i)||/||b|| 2.081949254206e-04
544 KSP unpreconditioned resid norm 8.713865726728e+00 true resid norm 8.713865726734e+00 ||r(i)||/||b|| 2.081948841550e-04
545 KSP unpreconditioned resid norm 8.713861777227e+00 true resid norm 8.713861777224e+00 ||r(i)||/||b|| 2.081947897919e-04
546 KSP unpreconditioned resid norm 8.713860164837e+00 true resid norm 8.713860164836e+00 ||r(i)||/||b|| 2.081947512681e-04
547 KSP unpreconditioned resid norm 8.713859225552e+00 true resid norm 8.713859225551e+00 ||r(i)||/||b|| 2.081947288264e-04
548 KSP unpreconditioned resid norm 8.713859033981e+00 true resid norm 8.713859033982e+00 ||r(i)||/||b|| 2.081947242493e-04
549 KSP unpreconditioned resid norm 8.713845977070e+00 true resid norm 8.713845977069e+00 ||r(i)||/||b|| 2.081944122888e-04
550 KSP unpreconditioned resid norm 8.713816253850e+00 true resid norm 8.713816253854e+00 ||r(i)||/||b|| 2.081937021308e-04
551 KSP unpreconditioned resid norm 8.713816229048e+00 true resid norm 8.713816229037e+00 ||r(i)||/||b|| 2.081937015378e-04
552 KSP unpreconditioned resid norm 8.713796904003e+00 true resid norm 8.713796904000e+00 ||r(i)||/||b|| 2.081932398169e-04
553 KSP unpreconditioned resid norm 8.713794974800e+00 true resid norm 8.713794974797e+00 ||r(i)||/||b|| 2.081931937237e-04
554 KSP unpreconditioned resid norm 8.713794955937e+00 true resid norm 8.713794955939e+00 ||r(i)||/||b|| 2.081931932732e-04
555 KSP unpreconditioned resid norm 8.713788163455e+00 true resid norm 8.713788163448e+00 ||r(i)||/||b|| 2.081930309845e-04
556 KSP unpreconditioned resid norm 8.713777273605e+00 true resid norm 8.713777273596e+00 ||r(i)||/||b|| 2.081927708001e-04
557 KSP unpreconditioned resid norm 8.713777272988e+00 true resid norm 8.713777272984e+00 ||r(i)||/||b|| 2.081927707855e-04
558 KSP unpreconditioned resid norm 8.713752892988e+00 true resid norm 8.713752892990e+00 ||r(i)||/||b|| 2.081921882897e-04
559 KSP unpreconditioned resid norm 8.713627218799e+00 true resid norm 8.713627218800e+00 ||r(i)||/||b|| 2.081891856358e-04
560 KSP unpreconditioned resid norm 8.713605454970e+00 true resid norm 8.713605454969e+00 ||r(i)||/||b|| 2.081886656463e-04
561 KSP unpreconditioned resid norm 8.713605284457e+00 true resid norm 8.713605284454e+00 ||r(i)||/||b|| 2.081886615723e-04
562 KSP unpreconditioned resid norm 8.713604428656e+00 true resid norm 8.713604428651e+00 ||r(i)||/||b|| 2.081886411251e-04
563 KSP unpreconditioned resid norm 8.713598699060e+00 true resid norm 8.713598699056e+00 ||r(i)||/||b|| 2.081885042315e-04
564 KSP unpreconditioned resid norm 8.713415240704e+00 true resid norm 8.713415240701e+00 ||r(i)||/||b|| 2.081841209771e-04
565 KSP unpreconditioned resid norm 8.713219643026e+00 true resid norm 8.713219643022e+00 ||r(i)||/||b|| 2.081794476854e-04
566 KSP unpreconditioned resid norm 8.713194229893e+00 true resid norm 8.713194229893e+00 ||r(i)||/||b|| 2.081788405056e-04
567 KSP unpreconditioned resid norm 8.713191300178e+00 true resid norm 8.713191300169e+00 ||r(i)||/||b|| 2.081787705075e-04
568 KSP unpreconditioned resid norm 8.713189738697e+00 true resid norm 8.713189738685e+00 ||r(i)||/||b|| 2.081787332000e-04
569 KSP unpreconditioned resid norm 8.713189032082e+00 true resid norm 8.713189032084e+00 ||r(i)||/||b|| 2.081787163176e-04
570 KSP unpreconditioned resid norm 8.713169109390e+00 true resid norm 8.713169109390e+00 ||r(i)||/||b|| 2.081782403173e-04
571 KSP unpreconditioned resid norm 8.713169033099e+00 true resid norm 8.713169033100e+00 ||r(i)||/||b|| 2.081782384945e-04
572 KSP unpreconditioned resid norm 8.713168654964e+00 true resid norm 8.713168654956e+00 ||r(i)||/||b|| 2.081782294598e-04
573 KSP unpreconditioned resid norm 8.713168376639e+00 true resid norm 8.713168376631e+00 ||r(i)||/||b|| 2.081782228099e-04
574 KSP unpreconditioned resid norm 8.713168278489e+00 true resid norm 8.713168278484e+00 ||r(i)||/||b|| 2.081782204650e-04
575 KSP unpreconditioned resid norm 8.713167058143e+00 true resid norm 8.713167058144e+00 ||r(i)||/||b|| 2.081781913082e-04
576 KSP unpreconditioned resid norm 8.713166342360e+00 true resid norm 8.713166342356e+00 ||r(i)||/||b|| 2.081781742063e-04
577 KSP unpreconditioned resid norm 8.713164013230e+00 true resid norm 8.713164013226e+00 ||r(i)||/||b|| 2.081781185578e-04
578 KSP unpreconditioned resid norm 8.713156397717e+00 true resid norm 8.713156397707e+00 ||r(i)||/||b|| 2.081779366051e-04
579 KSP unpreconditioned resid norm 8.713149141248e+00 true resid norm 8.713149141235e+00 ||r(i)||/||b|| 2.081777632308e-04
580 KSP unpreconditioned resid norm 8.713146901991e+00 true resid norm 8.713146901991e+00 ||r(i)||/||b|| 2.081777097299e-04
581 KSP unpreconditioned resid norm 8.713146737649e+00 true resid norm 8.713146737653e+00 ||r(i)||/||b|| 2.081777058035e-04
582 KSP unpreconditioned resid norm 8.713146617582e+00 true resid norm 8.713146617572e+00 ||r(i)||/||b|| 2.081777029345e-04
583 KSP unpreconditioned resid norm 8.713139085179e+00 true resid norm 8.713139085180e+00 ||r(i)||/||b|| 2.081775229678e-04
584 KSP unpreconditioned resid norm 8.713113087858e+00 true resid norm 8.713113087854e+00 ||r(i)||/||b|| 2.081769018301e-04
585 KSP unpreconditioned resid norm 8.713086776808e+00 true resid norm 8.713086776807e+00 ||r(i)||/||b|| 2.081762731969e-04
586 KSP unpreconditioned resid norm 8.713083311860e+00 true resid norm 8.713083311856e+00 ||r(i)||/||b|| 2.081761904111e-04
587 KSP unpreconditioned resid norm 8.713083302981e+00 true resid norm 8.713083302972e+00 ||r(i)||/||b|| 2.081761901988e-04
588 KSP unpreconditioned resid norm 8.713082785884e+00 true resid norm 8.713082785888e+00 ||r(i)||/||b|| 2.081761778444e-04
589 KSP unpreconditioned resid norm 8.713080098347e+00 true resid norm 8.713080098346e+00 ||r(i)||/||b|| 2.081761136327e-04
590 KSP unpreconditioned resid norm 8.713069258492e+00 true resid norm 8.713069258494e+00 ||r(i)||/||b|| 2.081758546429e-04
591 KSP unpreconditioned resid norm 8.713053389553e+00 true resid norm 8.713053389556e+00 ||r(i)||/||b|| 2.081754754965e-04
592 KSP unpreconditioned resid norm 8.713052789167e+00 true resid norm 8.713052789168e+00 ||r(i)||/||b|| 2.081754611518e-04
593 KSP unpreconditioned resid norm 8.713051817378e+00 true resid norm 8.713051817380e+00 ||r(i)||/||b|| 2.081754379334e-04
594 KSP unpreconditioned resid norm 8.713033024560e+00 true resid norm 8.713033024558e+00 ||r(i)||/||b|| 2.081749889284e-04
595 KSP unpreconditioned resid norm 8.713015636538e+00 true resid norm 8.713015636538e+00 ||r(i)||/||b|| 2.081745734875e-04
596 KSP unpreconditioned resid norm 8.713012180068e+00 true resid norm 8.713012180060e+00 ||r(i)||/||b|| 2.081744909040e-04
597 KSP unpreconditioned resid norm 8.713006786686e+00 true resid norm 8.713006786676e+00 ||r(i)||/||b|| 2.081743620433e-04
598 KSP unpreconditioned resid norm 8.713006727609e+00 true resid norm 8.713006727604e+00 ||r(i)||/||b|| 2.081743606319e-04
599 KSP unpreconditioned resid norm 8.712988569399e+00 true resid norm 8.712988569388e+00 ||r(i)||/||b|| 2.081739267892e-04
600 KSP unpreconditioned resid norm 8.712982123790e+00 true resid norm 8.712982123790e+00 ||r(i)||/||b|| 2.081737727886e-04
601 KSP unpreconditioned resid norm 8.712982083276e+00 true resid norm 8.712982083271e+00 ||r(i)||/||b|| 2.081737718205e-04
602 KSP unpreconditioned resid norm 8.712981662760e+00 true resid norm 8.712981662765e+00 ||r(i)||/||b|| 2.081737617736e-04
603 KSP unpreconditioned resid norm 8.712980892664e+00 true resid norm 8.712980892652e+00 ||r(i)||/||b|| 2.081737433738e-04
604 KSP unpreconditioned resid norm 8.712980882455e+00 true resid norm 8.712980882455e+00 ||r(i)||/||b|| 2.081737431301e-04
605 KSP unpreconditioned resid norm 8.712980311498e+00 true resid norm 8.712980311497e+00 ||r(i)||/||b|| 2.081737294886e-04
606 KSP unpreconditioned resid norm 8.712980310327e+00 true resid norm 8.712980310325e+00 ||r(i)||/||b|| 2.081737294606e-04
607 KSP unpreconditioned resid norm 8.712978420712e+00 true resid norm 8.712978420709e+00 ||r(i)||/||b|| 2.081736843132e-04
608 KSP unpreconditioned resid norm 8.712976777701e+00 true resid norm 8.712976777700e+00 ||r(i)||/||b|| 2.081736450578e-04
609 KSP unpreconditioned resid norm 8.712976663079e+00 true resid norm 8.712976663065e+00 ||r(i)||/||b|| 2.081736423189e-04
610 KSP unpreconditioned resid norm 8.712974689472e+00 true resid norm 8.712974689461e+00 ||r(i)||/||b|| 2.081735951648e-04
611 KSP unpreconditioned resid norm 8.712974392078e+00 true resid norm 8.712974392072e+00 ||r(i)||/||b|| 2.081735880595e-04
612 KSP unpreconditioned resid norm 8.712971415589e+00 true resid norm 8.712971415590e+00 ||r(i)||/||b|| 2.081735169443e-04
613 KSP unpreconditioned resid norm 8.712971360286e+00 true resid norm 8.712971360285e+00 ||r(i)||/||b|| 2.081735156229e-04
614 KSP unpreconditioned resid norm 8.712969392690e+00 true resid norm 8.712969392689e+00 ||r(i)||/||b|| 2.081734686124e-04
615 KSP unpreconditioned resid norm 8.712967281063e+00 true resid norm 8.712967281057e+00 ||r(i)||/||b|| 2.081734181605e-04
616 KSP unpreconditioned resid norm 8.712967204422e+00 true resid norm 8.712967204425e+00 ||r(i)||/||b|| 2.081734163296e-04
617 KSP unpreconditioned resid norm 8.712967202735e+00 true resid norm 8.712967202719e+00 ||r(i)||/||b|| 2.081734162889e-04
618 KSP unpreconditioned resid norm 8.712964460308e+00 true resid norm 8.712964460303e+00 ||r(i)||/||b|| 2.081733507660e-04
619 KSP unpreconditioned resid norm 8.712961490057e+00 true resid norm 8.712961490058e+00 ||r(i)||/||b|| 2.081732797999e-04
620 KSP unpreconditioned resid norm 8.712958224193e+00 true resid norm 8.712958224192e+00 ||r(i)||/||b|| 2.081732017706e-04
621 KSP unpreconditioned resid norm 8.712953065367e+00 true resid norm 8.712953065366e+00 ||r(i)||/||b|| 2.081730785140e-04
622 KSP unpreconditioned resid norm 8.712952626972e+00 true resid norm 8.712952626972e+00 ||r(i)||/||b|| 2.081730680397e-04
623 KSP unpreconditioned resid norm 8.712949768851e+00 true resid norm 8.712949768859e+00 ||r(i)||/||b|| 2.081729997527e-04
624 KSP unpreconditioned resid norm 8.712905570429e+00 true resid norm 8.712905570419e+00 ||r(i)||/||b|| 2.081719437473e-04
625 KSP unpreconditioned resid norm 8.712845083561e+00 true resid norm 8.712845083563e+00 ||r(i)||/||b|| 2.081704985731e-04
626 KSP unpreconditioned resid norm 8.712841173781e+00 true resid norm 8.712841173788e+00 ||r(i)||/||b|| 2.081704051593e-04
627 KSP unpreconditioned resid norm 8.712840373974e+00 true resid norm 8.712840373972e+00 ||r(i)||/||b|| 2.081703860498e-04
628 KSP unpreconditioned resid norm 8.712840072221e+00 true resid norm 8.712840072219e+00 ||r(i)||/||b|| 2.081703788402e-04
629 KSP unpreconditioned resid norm 8.712834817030e+00 true resid norm 8.712834817027e+00 ||r(i)||/||b|| 2.081702532812e-04
630 KSP unpreconditioned resid norm 8.712806333552e+00 true resid norm 8.712806333552e+00 ||r(i)||/||b|| 2.081695727436e-04
631 KSP unpreconditioned resid norm 8.712806236239e+00 true resid norm 8.712806236239e+00 ||r(i)||/||b|| 2.081695704185e-04
632 KSP unpreconditioned resid norm 8.712805743772e+00 true resid norm 8.712805743763e+00 ||r(i)||/||b|| 2.081695586521e-04
633 KSP unpreconditioned resid norm 8.712805342546e+00 true resid norm 8.712805342535e+00 ||r(i)||/||b|| 2.081695490658e-04
634 KSP unpreconditioned resid norm 8.712805338244e+00 true resid norm 8.712805338233e+00 ||r(i)||/||b|| 2.081695489630e-04
635 KSP unpreconditioned resid norm 8.712805068721e+00 true resid norm 8.712805068704e+00 ||r(i)||/||b|| 2.081695425234e-04
636 KSP unpreconditioned resid norm 8.712805068533e+00 true resid norm 8.712805068527e+00 ||r(i)||/||b|| 2.081695425191e-04
637 KSP unpreconditioned resid norm 8.712805019831e+00 true resid norm 8.712805019830e+00 ||r(i)||/||b|| 2.081695413556e-04
638 KSP unpreconditioned resid norm 8.712803440444e+00 true resid norm 8.712803440439e+00 ||r(i)||/||b|| 2.081695036202e-04
639 KSP unpreconditioned resid norm 8.712799561558e+00 true resid norm 8.712799561570e+00 ||r(i)||/||b|| 2.081694109449e-04
640 KSP unpreconditioned resid norm 8.712796734182e+00 true resid norm 8.712796734186e+00 ||r(i)||/||b|| 2.081693433920e-04
641 KSP unpreconditioned resid norm 8.712796167243e+00 true resid norm 8.712796167233e+00 ||r(i)||/||b|| 2.081693298461e-04
642 KSP unpreconditioned resid norm 8.712796055195e+00 true resid norm 8.712796055192e+00 ||r(i)||/||b|| 2.081693271692e-04
643 KSP unpreconditioned resid norm 8.712795658897e+00 true resid norm 8.712795658897e+00 ||r(i)||/||b|| 2.081693177008e-04
644 KSP unpreconditioned resid norm 8.712787091779e+00 true resid norm 8.712787091771e+00 ||r(i)||/||b|| 2.081691130118e-04
645 KSP unpreconditioned resid norm 8.712778429819e+00 true resid norm 8.712778429818e+00 ||r(i)||/||b|| 2.081689060573e-04
646 KSP unpreconditioned resid norm 8.712776305798e+00 true resid norm 8.712776305797e+00 ||r(i)||/||b|| 2.081688553094e-04
647 KSP unpreconditioned resid norm 8.712773988222e+00 true resid norm 8.712773988213e+00 ||r(i)||/||b|| 2.081687999368e-04
648 KSP unpreconditioned resid norm 8.712773916060e+00 true resid norm 8.712773916052e+00 ||r(i)||/||b|| 2.081687982127e-04
649 KSP unpreconditioned resid norm 8.712773710051e+00 true resid norm 8.712773710044e+00 ||r(i)||/||b|| 2.081687932907e-04
650 KSP unpreconditioned resid norm 8.712771861033e+00 true resid norm 8.712771861022e+00 ||r(i)||/||b|| 2.081687491132e-04
651 KSP unpreconditioned resid norm 8.712758684029e+00 true resid norm 8.712758684031e+00 ||r(i)||/||b|| 2.081684342837e-04
652 KSP unpreconditioned resid norm 8.712750664046e+00 true resid norm 8.712750664035e+00 ||r(i)||/||b|| 2.081682426670e-04
653 KSP unpreconditioned resid norm 8.712735633125e+00 true resid norm 8.712735633112e+00 ||r(i)||/||b|| 2.081678835427e-04
654 KSP unpreconditioned resid norm 8.712680868954e+00 true resid norm 8.712680868947e+00 ||r(i)||/||b|| 2.081665750971e-04
655 KSP unpreconditioned resid norm 8.712664583222e+00 true resid norm 8.712664583221e+00 ||r(i)||/||b|| 2.081661859925e-04
656 KSP unpreconditioned resid norm 8.712664510350e+00 true resid norm 8.712664510352e+00 ||r(i)||/||b|| 2.081661842515e-04
657 KSP unpreconditioned resid norm 8.712664496472e+00 true resid norm 8.712664496466e+00 ||r(i)||/||b|| 2.081661839197e-04
658 KSP unpreconditioned resid norm 8.712656312822e+00 true resid norm 8.712656312813e+00 ||r(i)||/||b|| 2.081659883929e-04
659 KSP unpreconditioned resid norm 8.712656115778e+00 true resid norm 8.712656115767e+00 ||r(i)||/||b|| 2.081659836850e-04
660 KSP unpreconditioned resid norm 8.712655364451e+00 true resid norm 8.712655364451e+00 ||r(i)||/||b|| 2.081659657343e-04
661 KSP unpreconditioned resid norm 8.712655360900e+00 true resid norm 8.712655360910e+00 ||r(i)||/||b|| 2.081659656497e-04
662 KSP unpreconditioned resid norm 8.712655353580e+00 true resid norm 8.712655353592e+00 ||r(i)||/||b|| 2.081659654748e-04
663 KSP unpreconditioned resid norm 8.712655338619e+00 true resid norm 8.712655338625e+00 ||r(i)||/||b|| 2.081659651172e-04
664 KSP unpreconditioned resid norm 8.712655161301e+00 true resid norm 8.712655161307e+00 ||r(i)||/||b|| 2.081659608807e-04
665 KSP unpreconditioned resid norm 8.712654969327e+00 true resid norm 8.712654969331e+00 ||r(i)||/||b|| 2.081659562939e-04
666 KSP unpreconditioned resid norm 8.712654951185e+00 true resid norm 8.712654951198e+00 ||r(i)||/||b|| 2.081659558607e-04
667 KSP unpreconditioned resid norm 8.712654218782e+00 true resid norm 8.712654218787e+00 ||r(i)||/||b|| 2.081659383617e-04
668 KSP unpreconditioned resid norm 8.712653254592e+00 true resid norm 8.712653254606e+00 ||r(i)||/||b|| 2.081659153251e-04
669 KSP unpreconditioned resid norm 8.712653083943e+00 true resid norm 8.712653083947e+00 ||r(i)||/||b|| 2.081659112476e-04
670 KSP unpreconditioned resid norm 8.712653076519e+00 true resid norm 8.712653076520e+00 ||r(i)||/||b|| 2.081659110702e-04
671 KSP unpreconditioned resid norm 8.712652841453e+00 true resid norm 8.712652841463e+00 ||r(i)||/||b|| 2.081659054541e-04
672 KSP unpreconditioned resid norm 8.712652771568e+00 true resid norm 8.712652771575e+00 ||r(i)||/||b|| 2.081659037843e-04
673 KSP unpreconditioned resid norm 8.712652265710e+00 true resid norm 8.712652265715e+00 ||r(i)||/||b|| 2.081658916981e-04
674 KSP unpreconditioned resid norm 8.712651257705e+00 true resid norm 8.712651257712e+00 ||r(i)||/||b|| 2.081658676146e-04
675 KSP unpreconditioned resid norm 8.712647351247e+00 true resid norm 8.712647351261e+00 ||r(i)||/||b|| 2.081657742802e-04
676 KSP unpreconditioned resid norm 8.712646407407e+00 true resid norm 8.712646407415e+00 ||r(i)||/||b|| 2.081657517295e-04
677 KSP unpreconditioned resid norm 8.712646273895e+00 true resid norm 8.712646273905e+00 ||r(i)||/||b|| 2.081657485396e-04
678 KSP unpreconditioned resid norm 8.712646085656e+00 true resid norm 8.712646085663e+00 ||r(i)||/||b|| 2.081657440421e-04
679 KSP unpreconditioned resid norm 8.712645399874e+00 true resid norm 8.712645399884e+00 ||r(i)||/||b|| 2.081657276572e-04
680 KSP unpreconditioned resid norm 8.712642084766e+00 true resid norm 8.712642084775e+00 ||r(i)||/||b|| 2.081656484514e-04
681 KSP unpreconditioned resid norm 8.712640636255e+00 true resid norm 8.712640636253e+00 ||r(i)||/||b|| 2.081656138428e-04
682 KSP unpreconditioned resid norm 8.712637627645e+00 true resid norm 8.712637627646e+00 ||r(i)||/||b|| 2.081655419600e-04
683 KSP unpreconditioned resid norm 8.712630096339e+00 true resid norm 8.712630096345e+00 ||r(i)||/||b|| 2.081653620194e-04
684 KSP unpreconditioned resid norm 8.712616915211e+00 true resid norm 8.712616915214e+00 ||r(i)||/||b|| 2.081650470910e-04
685 KSP unpreconditioned resid norm 8.712589842440e+00 true resid norm 8.712589842438e+00 ||r(i)||/||b|| 2.081644002583e-04
686 KSP unpreconditioned resid norm 8.712586622272e+00 true resid norm 8.712586622280e+00 ||r(i)||/||b|| 2.081643233211e-04
687 KSP unpreconditioned resid norm 8.712581730315e+00 true resid norm 8.712581730329e+00 ||r(i)||/||b|| 2.081642064408e-04
688 KSP unpreconditioned resid norm 8.712578181191e+00 true resid norm 8.712578181200e+00 ||r(i)||/||b|| 2.081641216437e-04
689 KSP unpreconditioned resid norm 8.712568644896e+00 true resid norm 8.712568644905e+00 ||r(i)||/||b|| 2.081638937990e-04
690 KSP unpreconditioned resid norm 8.712548921691e+00 true resid norm 8.712548921691e+00 ||r(i)||/||b|| 2.081634225647e-04
691 KSP unpreconditioned resid norm 8.712548855072e+00 true resid norm 8.712548855072e+00 ||r(i)||/||b|| 2.081634209730e-04
692 KSP unpreconditioned resid norm 8.712548556584e+00 true resid norm 8.712548556577e+00 ||r(i)||/||b|| 2.081634138413e-04
693 KSP unpreconditioned resid norm 8.712548298993e+00 true resid norm 8.712548298995e+00 ||r(i)||/||b|| 2.081634076870e-04
694 KSP unpreconditioned resid norm 8.712548255613e+00 true resid norm 8.712548255608e+00 ||r(i)||/||b|| 2.081634066504e-04
695 KSP unpreconditioned resid norm 8.712548255612e+00 true resid norm 8.712548255601e+00 ||r(i)||/||b|| 2.081634066503e-04
696 KSP unpreconditioned resid norm 8.712548233163e+00 true resid norm 8.712548233154e+00 ||r(i)||/||b|| 2.081634061139e-04
697 KSP unpreconditioned resid norm 8.712548206581e+00 true resid norm 8.712548206570e+00 ||r(i)||/||b|| 2.081634054788e-04
698 KSP unpreconditioned resid norm 8.712548195457e+00 true resid norm 8.712548195457e+00 ||r(i)||/||b|| 2.081634052133e-04
699 KSP unpreconditioned resid norm 8.712547507730e+00 true resid norm 8.712547507736e+00 ||r(i)||/||b|| 2.081633887820e-04
700 KSP unpreconditioned resid norm 8.712546690313e+00 true resid norm 8.712546690306e+00 ||r(i)||/||b|| 2.081633692516e-04
701 KSP unpreconditioned resid norm 8.712546587927e+00 true resid norm 8.712546587921e+00 ||r(i)||/||b|| 2.081633668054e-04
702 KSP unpreconditioned resid norm 8.712546325832e+00 true resid norm 8.712546325832e+00 ||r(i)||/||b|| 2.081633605435e-04
703 KSP unpreconditioned resid norm 8.712546168392e+00 true resid norm 8.712546168390e+00 ||r(i)||/||b|| 2.081633567818e-04
704 KSP unpreconditioned resid norm 8.712545473742e+00 true resid norm 8.712545473735e+00 ||r(i)||/||b|| 2.081633401849e-04
705 KSP unpreconditioned resid norm 8.712545388944e+00 true resid norm 8.712545388941e+00 ||r(i)||/||b|| 2.081633381590e-04
706 KSP unpreconditioned resid norm 8.712545236022e+00 true resid norm 8.712545236016e+00 ||r(i)||/||b|| 2.081633345052e-04
707 KSP unpreconditioned resid norm 8.712543578602e+00 true resid norm 8.712543578596e+00 ||r(i)||/||b|| 2.081632949055e-04
708 KSP unpreconditioned resid norm 8.712543555328e+00 true resid norm 8.712543555327e+00 ||r(i)||/||b|| 2.081632943496e-04
709 KSP unpreconditioned resid norm 8.712542192367e+00 true resid norm 8.712542192361e+00 ||r(i)||/||b|| 2.081632617851e-04
710 KSP unpreconditioned resid norm 8.712542188750e+00 true resid norm 8.712542188750e+00 ||r(i)||/||b|| 2.081632616988e-04
711 KSP unpreconditioned resid norm 8.712539094786e+00 true resid norm 8.712539094785e+00 ||r(i)||/||b|| 2.081631877767e-04
712 KSP unpreconditioned resid norm 8.712537689608e+00 true resid norm 8.712537689600e+00 ||r(i)||/||b|| 2.081631542035e-04
713 KSP unpreconditioned resid norm 8.712533191052e+00 true resid norm 8.712533191049e+00 ||r(i)||/||b|| 2.081630467224e-04
714 KSP unpreconditioned resid norm 8.712519693884e+00 true resid norm 8.712519693877e+00 ||r(i)||/||b|| 2.081627242430e-04
715 KSP unpreconditioned resid norm 8.712519057404e+00 true resid norm 8.712519057408e+00 ||r(i)||/||b|| 2.081627090363e-04
716 KSP unpreconditioned resid norm 8.712518959222e+00 true resid norm 8.712518959217e+00 ||r(i)||/||b|| 2.081627066903e-04
717 KSP unpreconditioned resid norm 8.712518884219e+00 true resid norm 8.712518884223e+00 ||r(i)||/||b|| 2.081627048985e-04
718 KSP unpreconditioned resid norm 8.712516786850e+00 true resid norm 8.712516786847e+00 ||r(i)||/||b|| 2.081626547872e-04
719 KSP unpreconditioned resid norm 8.712516685839e+00 true resid norm 8.712516685854e+00 ||r(i)||/||b|| 2.081626523743e-04
720 KSP unpreconditioned resid norm 8.712514084547e+00 true resid norm 8.712514084547e+00 ||r(i)||/||b|| 2.081625902229e-04
721 KSP unpreconditioned resid norm 8.712514077083e+00 true resid norm 8.712514077092e+00 ||r(i)||/||b|| 2.081625900447e-04
722 KSP unpreconditioned resid norm 8.712514056132e+00 true resid norm 8.712514056125e+00 ||r(i)||/||b|| 2.081625895438e-04
723 KSP unpreconditioned resid norm 8.712514055987e+00 true resid norm 8.712514055990e+00 ||r(i)||/||b|| 2.081625895406e-04
724 KSP unpreconditioned resid norm 8.712514027768e+00 true resid norm 8.712514027775e+00 ||r(i)||/||b|| 2.081625888665e-04
725 KSP unpreconditioned resid norm 8.712513997451e+00 true resid norm 8.712513997446e+00 ||r(i)||/||b|| 2.081625881418e-04
726 KSP unpreconditioned resid norm 8.712513974383e+00 true resid norm 8.712513974390e+00 ||r(i)||/||b|| 2.081625875909e-04
727 KSP unpreconditioned resid norm 8.712513712758e+00 true resid norm 8.712513712763e+00 ||r(i)||/||b|| 2.081625813401e-04
728 KSP unpreconditioned resid norm 8.712513534349e+00 true resid norm 8.712513534351e+00 ||r(i)||/||b|| 2.081625770774e-04
729 KSP unpreconditioned resid norm 8.712513515363e+00 true resid norm 8.712513515373e+00 ||r(i)||/||b|| 2.081625766240e-04
730 KSP unpreconditioned resid norm 8.712513392294e+00 true resid norm 8.712513392307e+00 ||r(i)||/||b|| 2.081625736836e-04
731 KSP unpreconditioned resid norm 8.712513353823e+00 true resid norm 8.712513353831e+00 ||r(i)||/||b|| 2.081625727643e-04
732 KSP unpreconditioned resid norm 8.712513308797e+00 true resid norm 8.712513308797e+00 ||r(i)||/||b|| 2.081625716884e-04
733 KSP unpreconditioned resid norm 8.712513270513e+00 true resid norm 8.712513270514e+00 ||r(i)||/||b|| 2.081625707737e-04
734 KSP unpreconditioned resid norm 8.712513131206e+00 true resid norm 8.712513131207e+00 ||r(i)||/||b|| 2.081625674453e-04
735 KSP unpreconditioned resid norm 8.712512953483e+00 true resid norm 8.712512953487e+00 ||r(i)||/||b|| 2.081625631992e-04
736 KSP unpreconditioned resid norm 8.712512877820e+00 true resid norm 8.712512877816e+00 ||r(i)||/||b|| 2.081625613912e-04
737 KSP unpreconditioned resid norm 8.712512877786e+00 true resid norm 8.712512877798e+00 ||r(i)||/||b|| 2.081625613908e-04
738 KSP unpreconditioned resid norm 8.712511745866e+00 true resid norm 8.712511745869e+00 ||r(i)||/||b|| 2.081625343463e-04
739 KSP unpreconditioned resid norm 8.712511648284e+00 true resid norm 8.712511648280e+00 ||r(i)||/||b|| 2.081625320147e-04
740 KSP unpreconditioned resid norm 8.712511467310e+00 true resid norm 8.712511467307e+00 ||r(i)||/||b|| 2.081625276908e-04
741 KSP unpreconditioned resid norm 8.712511466610e+00 true resid norm 8.712511466625e+00 ||r(i)||/||b|| 2.081625276745e-04
742 KSP unpreconditioned resid norm 8.712510803074e+00 true resid norm 8.712510803072e+00 ||r(i)||/||b|| 2.081625118207e-04
743 KSP unpreconditioned resid norm 8.712509576822e+00 true resid norm 8.712509576829e+00 ||r(i)||/||b|| 2.081624825228e-04
744 KSP unpreconditioned resid norm 8.712509188031e+00 true resid norm 8.712509188030e+00 ||r(i)||/||b|| 2.081624732335e-04
745 KSP unpreconditioned resid norm 8.712506436486e+00 true resid norm 8.712506436487e+00 ||r(i)||/||b|| 2.081624074926e-04
746 KSP unpreconditioned resid norm 8.712506346917e+00 true resid norm 8.712506346911e+00 ||r(i)||/||b|| 2.081624053524e-04
747 KSP unpreconditioned resid norm 8.712505531069e+00 true resid norm 8.712505531073e+00 ||r(i)||/||b|| 2.081623858601e-04
748 KSP unpreconditioned resid norm 8.712505156642e+00 true resid norm 8.712505156635e+00 ||r(i)||/||b|| 2.081623769139e-04
749 KSP unpreconditioned resid norm 8.712505120874e+00 true resid norm 8.712505120871e+00 ||r(i)||/||b|| 2.081623760594e-04
750 KSP unpreconditioned resid norm 8.712504873465e+00 true resid norm 8.712504873465e+00 ||r(i)||/||b|| 2.081623701483e-04
751 KSP unpreconditioned resid norm 8.712504872475e+00 true resid norm 8.712504872461e+00 ||r(i)||/||b|| 2.081623701243e-04
752 KSP unpreconditioned resid norm 8.712504869354e+00 true resid norm 8.712504869357e+00 ||r(i)||/||b|| 2.081623700502e-04
753 KSP unpreconditioned resid norm 8.712504865955e+00 true resid norm 8.712504865951e+00 ||r(i)||/||b|| 2.081623699688e-04
754 KSP unpreconditioned resid norm 8.712504865953e+00 true resid norm 8.712504865958e+00 ||r(i)||/||b|| 2.081623699690e-04
755 KSP unpreconditioned resid norm 8.712504863596e+00 true resid norm 8.712504863594e+00 ||r(i)||/||b|| 2.081623699125e-04
756 KSP unpreconditioned resid norm 8.712504850634e+00 true resid norm 8.712504850625e+00 ||r(i)||/||b|| 2.081623696026e-04
757 KSP unpreconditioned resid norm 8.712504804832e+00 true resid norm 8.712504804826e+00 ||r(i)||/||b|| 2.081623685084e-04
758 KSP unpreconditioned resid norm 8.712504743934e+00 true resid norm 8.712504743942e+00 ||r(i)||/||b|| 2.081623670537e-04
759 KSP unpreconditioned resid norm 8.712504738709e+00 true resid norm 8.712504738701e+00 ||r(i)||/||b|| 2.081623669285e-04
760 KSP unpreconditioned resid norm 8.712504738561e+00 true resid norm 8.712504738564e+00 ||r(i)||/||b|| 2.081623669252e-04
761 KSP unpreconditioned resid norm 8.712504738549e+00 true resid norm 8.712504738555e+00 ||r(i)||/||b|| 2.081623669250e-04
762 KSP unpreconditioned resid norm 8.712504719611e+00 true resid norm 8.712504719599e+00 ||r(i)||/||b|| 2.081623664721e-04
763 KSP unpreconditioned resid norm 8.712504717393e+00 true resid norm 8.712504717392e+00 ||r(i)||/||b|| 2.081623664193e-04
764 KSP unpreconditioned resid norm 8.712504667898e+00 true resid norm 8.712504667899e+00 ||r(i)||/||b|| 2.081623652369e-04
765 KSP unpreconditioned resid norm 8.712504622101e+00 true resid norm 8.712504622085e+00 ||r(i)||/||b|| 2.081623641422e-04
766 KSP unpreconditioned resid norm 8.712504614869e+00 true resid norm 8.712504614865e+00 ||r(i)||/||b|| 2.081623639698e-04
767 KSP unpreconditioned resid norm 8.712504485400e+00 true resid norm 8.712504485394e+00 ||r(i)||/||b|| 2.081623608764e-04
768 KSP unpreconditioned resid norm 8.712504472481e+00 true resid norm 8.712504472479e+00 ||r(i)||/||b|| 2.081623605678e-04
769 KSP unpreconditioned resid norm 8.712504426071e+00 true resid norm 8.712504426065e+00 ||r(i)||/||b|| 2.081623594589e-04
770 KSP unpreconditioned resid norm 8.712504403005e+00 true resid norm 8.712504403001e+00 ||r(i)||/||b|| 2.081623589078e-04
771 KSP unpreconditioned resid norm 8.712504162953e+00 true resid norm 8.712504162947e+00 ||r(i)||/||b|| 2.081623531724e-04
772 KSP unpreconditioned resid norm 8.712504145417e+00 true resid norm 8.712504145418e+00 ||r(i)||/||b|| 2.081623527535e-04
773 KSP unpreconditioned resid norm 8.712504075441e+00 true resid norm 8.712504075438e+00 ||r(i)||/||b|| 2.081623510816e-04
774 KSP unpreconditioned resid norm 8.712502686363e+00 true resid norm 8.712502686358e+00 ||r(i)||/||b|| 2.081623178932e-04
775 KSP unpreconditioned resid norm 8.712502682763e+00 true resid norm 8.712502682758e+00 ||r(i)||/||b|| 2.081623178071e-04
776 KSP unpreconditioned resid norm 8.712502640506e+00 true resid norm 8.712502640505e+00 ||r(i)||/||b|| 2.081623167976e-04
777 KSP unpreconditioned resid norm 8.712502233697e+00 true resid norm 8.712502233693e+00 ||r(i)||/||b|| 2.081623070779e-04
778 KSP unpreconditioned resid norm 8.712502233444e+00 true resid norm 8.712502233446e+00 ||r(i)||/||b|| 2.081623070720e-04
779 KSP unpreconditioned resid norm 8.712501744985e+00 true resid norm 8.712501744980e+00 ||r(i)||/||b|| 2.081622954014e-04
780 KSP unpreconditioned resid norm 8.712500817476e+00 true resid norm 8.712500817476e+00 ||r(i)||/||b|| 2.081622732411e-04
781 KSP unpreconditioned resid norm 8.712500813892e+00 true resid norm 8.712500813892e+00 ||r(i)||/||b|| 2.081622731555e-04
782 KSP unpreconditioned resid norm 8.712500799725e+00 true resid norm 8.712500799722e+00 ||r(i)||/||b|| 2.081622728169e-04
783 KSP unpreconditioned resid norm 8.712500792416e+00 true resid norm 8.712500792421e+00 ||r(i)||/||b|| 2.081622726425e-04
784 KSP unpreconditioned resid norm 8.712500792067e+00 true resid norm 8.712500792065e+00 ||r(i)||/||b|| 2.081622726340e-04
785 KSP unpreconditioned resid norm 8.712500791819e+00 true resid norm 8.712500791821e+00 ||r(i)||/||b|| 2.081622726282e-04
786 KSP unpreconditioned resid norm 8.712500779525e+00 true resid norm 8.712500779527e+00 ||r(i)||/||b|| 2.081622723344e-04
787 KSP unpreconditioned resid norm 8.712500713738e+00 true resid norm 8.712500713729e+00 ||r(i)||/||b|| 2.081622707624e-04
788 KSP unpreconditioned resid norm 8.712500656579e+00 true resid norm 8.712500656579e+00 ||r(i)||/||b|| 2.081622693969e-04
789 KSP unpreconditioned resid norm 8.712500656575e+00 true resid norm 8.712500656570e+00 ||r(i)||/||b|| 2.081622693967e-04
790 KSP unpreconditioned resid norm 8.712500650534e+00 true resid norm 8.712500650541e+00 ||r(i)||/||b|| 2.081622692526e-04
791 KSP unpreconditioned resid norm 8.712500635692e+00 true resid norm 8.712500635680e+00 ||r(i)||/||b|| 2.081622688976e-04
792 KSP unpreconditioned resid norm 8.712500635329e+00 true resid norm 8.712500635333e+00 ||r(i)||/||b|| 2.081622688893e-04
793 KSP unpreconditioned resid norm 8.712500623226e+00 true resid norm 8.712500623235e+00 ||r(i)||/||b|| 2.081622686002e-04
794 KSP unpreconditioned resid norm 8.712500623045e+00 true resid norm 8.712500623047e+00 ||r(i)||/||b|| 2.081622685958e-04
795 KSP unpreconditioned resid norm 8.712500519553e+00 true resid norm 8.712500519551e+00 ||r(i)||/||b|| 2.081622661230e-04
796 KSP unpreconditioned resid norm 8.712500482677e+00 true resid norm 8.712500482677e+00 ||r(i)||/||b|| 2.081622652420e-04
797 KSP unpreconditioned resid norm 8.712500482217e+00 true resid norm 8.712500482209e+00 ||r(i)||/||b|| 2.081622652308e-04
798 KSP unpreconditioned resid norm 8.712500281497e+00 true resid norm 8.712500281503e+00 ||r(i)||/||b|| 2.081622604355e-04
799 KSP unpreconditioned resid norm 8.712500277569e+00 true resid norm 8.712500277566e+00 ||r(i)||/||b|| 2.081622603414e-04
800 KSP unpreconditioned resid norm 8.712500260637e+00 true resid norm 8.712500260638e+00 ||r(i)||/||b|| 2.081622599369e-04
801 KSP unpreconditioned resid norm 8.712500245240e+00 true resid norm 8.712500245244e+00 ||r(i)||/||b|| 2.081622595692e-04
802 KSP unpreconditioned resid norm 8.712500143816e+00 true resid norm 8.712500143808e+00 ||r(i)||/||b|| 2.081622571456e-04
803 KSP unpreconditioned resid norm 8.712499926226e+00 true resid norm 8.712499926234e+00 ||r(i)||/||b|| 2.081622519472e-04
804 KSP unpreconditioned resid norm 8.712499888931e+00 true resid norm 8.712499888930e+00 ||r(i)||/||b|| 2.081622510560e-04
805 KSP unpreconditioned resid norm 8.712499222503e+00 true resid norm 8.712499222503e+00 ||r(i)||/||b|| 2.081622351334e-04
806 KSP unpreconditioned resid norm 8.712499117868e+00 true resid norm 8.712499117866e+00 ||r(i)||/||b|| 2.081622326334e-04
807 KSP unpreconditioned resid norm 8.712499117853e+00 true resid norm 8.712499117852e+00 ||r(i)||/||b|| 2.081622326331e-04
808 KSP unpreconditioned resid norm 8.712498556445e+00 true resid norm 8.712498556453e+00 ||r(i)||/||b|| 2.081622192199e-04
809 KSP unpreconditioned resid norm 8.712498437690e+00 true resid norm 8.712498437690e+00 ||r(i)||/||b|| 2.081622163824e-04
810 KSP unpreconditioned resid norm 8.712498324520e+00 true resid norm 8.712498324520e+00 ||r(i)||/||b|| 2.081622136785e-04
811 KSP unpreconditioned resid norm 8.712498324058e+00 true resid norm 8.712498324059e+00 ||r(i)||/||b|| 2.081622136675e-04
812 KSP unpreconditioned resid norm 8.712498321955e+00 true resid norm 8.712498321941e+00 ||r(i)||/||b|| 2.081622136169e-04
813 KSP unpreconditioned resid norm 8.712498317103e+00 true resid norm 8.712498317103e+00 ||r(i)||/||b|| 2.081622135013e-04
814 KSP unpreconditioned resid norm 8.712498311860e+00 true resid norm 8.712498311850e+00 ||r(i)||/||b|| 2.081622133758e-04
815 KSP unpreconditioned resid norm 8.712498308082e+00 true resid norm 8.712498308095e+00 ||r(i)||/||b|| 2.081622132861e-04
816 KSP unpreconditioned resid norm 8.712498299868e+00 true resid norm 8.712498299859e+00 ||r(i)||/||b|| 2.081622130893e-04
817 KSP unpreconditioned resid norm 8.712498289324e+00 true resid norm 8.712498289320e+00 ||r(i)||/||b|| 2.081622128375e-04
818 KSP unpreconditioned resid norm 8.712498274201e+00 true resid norm 8.712498274199e+00 ||r(i)||/||b|| 2.081622124762e-04
819 KSP unpreconditioned resid norm 8.712498269161e+00 true resid norm 8.712498269165e+00 ||r(i)||/||b|| 2.081622123559e-04
820 KSP unpreconditioned resid norm 8.712498265438e+00 true resid norm 8.712498265441e+00 ||r(i)||/||b|| 2.081622122670e-04
821 KSP unpreconditioned resid norm 8.712498264148e+00 true resid norm 8.712498264135e+00 ||r(i)||/||b|| 2.081622122358e-04
822 KSP unpreconditioned resid norm 8.712498262965e+00 true resid norm 8.712498262954e+00 ||r(i)||/||b|| 2.081622122076e-04
823 KSP unpreconditioned resid norm 8.712498259970e+00 true resid norm 8.712498259959e+00 ||r(i)||/||b|| 2.081622121360e-04
824 KSP unpreconditioned resid norm 8.712498229869e+00 true resid norm 8.712498229869e+00 ||r(i)||/||b|| 2.081622114171e-04
825 KSP unpreconditioned resid norm 8.712498197465e+00 true resid norm 8.712498197462e+00 ||r(i)||/||b|| 2.081622106428e-04
826 KSP unpreconditioned resid norm 8.712498189106e+00 true resid norm 8.712498189105e+00 ||r(i)||/||b|| 2.081622104431e-04
827 KSP unpreconditioned resid norm 8.712498149578e+00 true resid norm 8.712498149581e+00 ||r(i)||/||b|| 2.081622094988e-04
828 KSP unpreconditioned resid norm 8.712498142287e+00 true resid norm 8.712498142285e+00 ||r(i)||/||b|| 2.081622093245e-04
829 KSP unpreconditioned resid norm 8.712498129588e+00 true resid norm 8.712498129584e+00 ||r(i)||/||b|| 2.081622090210e-04
830 KSP unpreconditioned resid norm 8.712498111323e+00 true resid norm 8.712498111315e+00 ||r(i)||/||b|| 2.081622085845e-04
831 KSP unpreconditioned resid norm 8.712498074947e+00 true resid norm 8.712498074942e+00 ||r(i)||/||b|| 2.081622077155e-04
832 KSP unpreconditioned resid norm 8.712498065589e+00 true resid norm 8.712498065582e+00 ||r(i)||/||b|| 2.081622074919e-04
833 KSP unpreconditioned resid norm 8.712498027887e+00 true resid norm 8.712498027882e+00 ||r(i)||/||b|| 2.081622065911e-04
834 KSP unpreconditioned resid norm 8.712497635699e+00 true resid norm 8.712497635699e+00 ||r(i)||/||b|| 2.081621972209e-04
835 KSP unpreconditioned resid norm 8.712497624101e+00 true resid norm 8.712497624098e+00 ||r(i)||/||b|| 2.081621969438e-04
836 KSP unpreconditioned resid norm 8.712497537136e+00 true resid norm 8.712497537128e+00 ||r(i)||/||b|| 2.081621948658e-04
837 KSP unpreconditioned resid norm 8.712497226627e+00 true resid norm 8.712497226621e+00 ||r(i)||/||b|| 2.081621874471e-04
838 KSP unpreconditioned resid norm 8.712497114443e+00 true resid norm 8.712497114437e+00 ||r(i)||/||b|| 2.081621847668e-04
839 KSP unpreconditioned resid norm 8.712496800150e+00 true resid norm 8.712496800146e+00 ||r(i)||/||b|| 2.081621772576e-04
840 KSP unpreconditioned resid norm 8.712496570930e+00 true resid norm 8.712496570930e+00 ||r(i)||/||b|| 2.081621717811e-04
841 KSP unpreconditioned resid norm 8.712496569990e+00 true resid norm 8.712496569987e+00 ||r(i)||/||b|| 2.081621717585e-04
842 KSP unpreconditioned resid norm 8.712496565308e+00 true resid norm 8.712496565303e+00 ||r(i)||/||b|| 2.081621716466e-04
843 KSP unpreconditioned resid norm 8.712496560011e+00 true resid norm 8.712496560008e+00 ||r(i)||/||b|| 2.081621715201e-04
844 KSP unpreconditioned resid norm 8.712496555855e+00 true resid norm 8.712496555866e+00 ||r(i)||/||b|| 2.081621714212e-04
845 KSP unpreconditioned resid norm 8.712496550699e+00 true resid norm 8.712496550687e+00 ||r(i)||/||b|| 2.081621712974e-04
846 KSP unpreconditioned resid norm 8.712496544463e+00 true resid norm 8.712496544459e+00 ||r(i)||/||b|| 2.081621711486e-04
847 KSP unpreconditioned resid norm 8.712496527899e+00 true resid norm 8.712496527906e+00 ||r(i)||/||b|| 2.081621707531e-04
848 KSP unpreconditioned resid norm 8.712496510377e+00 true resid norm 8.712496510380e+00 ||r(i)||/||b|| 2.081621703344e-04
849 KSP unpreconditioned resid norm 8.712496507975e+00 true resid norm 8.712496507973e+00 ||r(i)||/||b|| 2.081621702769e-04
850 KSP unpreconditioned resid norm 8.712496507548e+00 true resid norm 8.712496507545e+00 ||r(i)||/||b|| 2.081621702667e-04
851 KSP unpreconditioned resid norm 8.712496500713e+00 true resid norm 8.712496500707e+00 ||r(i)||/||b|| 2.081621701033e-04
852 KSP unpreconditioned resid norm 8.712496500621e+00 true resid norm 8.712496500626e+00 ||r(i)||/||b|| 2.081621701014e-04
853 KSP unpreconditioned resid norm 8.712496487559e+00 true resid norm 8.712496487568e+00 ||r(i)||/||b|| 2.081621697894e-04
854 KSP unpreconditioned resid norm 8.712496483842e+00 true resid norm 8.712496483846e+00 ||r(i)||/||b|| 2.081621697004e-04
855 KSP unpreconditioned resid norm 8.712496436665e+00 true resid norm 8.712496436666e+00 ||r(i)||/||b|| 2.081621685732e-04
856 KSP unpreconditioned resid norm 8.712496414602e+00 true resid norm 8.712496414600e+00 ||r(i)||/||b|| 2.081621680460e-04
857 KSP unpreconditioned resid norm 8.712496412804e+00 true resid norm 8.712496412803e+00 ||r(i)||/||b|| 2.081621680031e-04
858 KSP unpreconditioned resid norm 8.712496350507e+00 true resid norm 8.712496350512e+00 ||r(i)||/||b|| 2.081621665148e-04
859 KSP unpreconditioned resid norm 8.712496346853e+00 true resid norm 8.712496346840e+00 ||r(i)||/||b|| 2.081621664271e-04
860 KSP unpreconditioned resid norm 8.712496345529e+00 true resid norm 8.712496345527e+00 ||r(i)||/||b|| 2.081621663957e-04
861 KSP unpreconditioned resid norm 8.712496340990e+00 true resid norm 8.712496340989e+00 ||r(i)||/||b|| 2.081621662873e-04
862 KSP unpreconditioned resid norm 8.712496300285e+00 true resid norm 8.712496300283e+00 ||r(i)||/||b|| 2.081621653147e-04
863 KSP unpreconditioned resid norm 8.712496181849e+00 true resid norm 8.712496181850e+00 ||r(i)||/||b|| 2.081621624850e-04
864 KSP unpreconditioned resid norm 8.712496139558e+00 true resid norm 8.712496139553e+00 ||r(i)||/||b|| 2.081621614745e-04
865 KSP unpreconditioned resid norm 8.712495885375e+00 true resid norm 8.712495885378e+00 ||r(i)||/||b|| 2.081621554016e-04
866 KSP unpreconditioned resid norm 8.712495790657e+00 true resid norm 8.712495790656e+00 ||r(i)||/||b|| 2.081621531385e-04
867 KSP unpreconditioned resid norm 8.712495745372e+00 true resid norm 8.712495745371e+00 ||r(i)||/||b|| 2.081621520565e-04
868 KSP unpreconditioned resid norm 8.712495334054e+00 true resid norm 8.712495334052e+00 ||r(i)||/||b|| 2.081621422291e-04
869 KSP unpreconditioned resid norm 8.712495220355e+00 true resid norm 8.712495220360e+00 ||r(i)||/||b|| 2.081621395128e-04
870 KSP unpreconditioned resid norm 8.712495183884e+00 true resid norm 8.712495183884e+00 ||r(i)||/||b|| 2.081621386413e-04
871 KSP unpreconditioned resid norm 8.712495183732e+00 true resid norm 8.712495183724e+00 ||r(i)||/||b|| 2.081621386375e-04
872 KSP unpreconditioned resid norm 8.712495182737e+00 true resid norm 8.712495182733e+00 ||r(i)||/||b|| 2.081621386138e-04
873 KSP unpreconditioned resid norm 8.712495179188e+00 true resid norm 8.712495179186e+00 ||r(i)||/||b|| 2.081621385290e-04
874 KSP unpreconditioned resid norm 8.712495172789e+00 true resid norm 8.712495172792e+00 ||r(i)||/||b|| 2.081621383763e-04
875 KSP unpreconditioned resid norm 8.712495166116e+00 true resid norm 8.712495166105e+00 ||r(i)||/||b|| 2.081621382165e-04
876 KSP unpreconditioned resid norm 8.712495161476e+00 true resid norm 8.712495161476e+00 ||r(i)||/||b|| 2.081621381059e-04
877 KSP unpreconditioned resid norm 8.712495157960e+00 true resid norm 8.712495157950e+00 ||r(i)||/||b|| 2.081621380216e-04
878 KSP unpreconditioned resid norm 8.712495151185e+00 true resid norm 8.712495151182e+00 ||r(i)||/||b|| 2.081621378599e-04
879 KSP unpreconditioned resid norm 8.712495144761e+00 true resid norm 8.712495144754e+00 ||r(i)||/||b|| 2.081621377064e-04
880 KSP unpreconditioned resid norm 8.712495138630e+00 true resid norm 8.712495138628e+00 ||r(i)||/||b|| 2.081621375600e-04
881 KSP unpreconditioned resid norm 8.712495137036e+00 true resid norm 8.712495137033e+00 ||r(i)||/||b|| 2.081621375219e-04
882 KSP unpreconditioned resid norm 8.712495137025e+00 true resid norm 8.712495137016e+00 ||r(i)||/||b|| 2.081621375215e-04
883 KSP unpreconditioned resid norm 8.712495131512e+00 true resid norm 8.712495131505e+00 ||r(i)||/||b|| 2.081621373898e-04
884 KSP unpreconditioned resid norm 8.712495112182e+00 true resid norm 8.712495112173e+00 ||r(i)||/||b|| 2.081621369279e-04
885 KSP unpreconditioned resid norm 8.712495090221e+00 true resid norm 8.712495090211e+00 ||r(i)||/||b|| 2.081621364032e-04
886 KSP unpreconditioned resid norm 8.712495081252e+00 true resid norm 8.712495081247e+00 ||r(i)||/||b|| 2.081621361890e-04
887 KSP unpreconditioned resid norm 8.712495060402e+00 true resid norm 8.712495060396e+00 ||r(i)||/||b|| 2.081621356909e-04
888 KSP unpreconditioned resid norm 8.712495053558e+00 true resid norm 8.712495053558e+00 ||r(i)||/||b|| 2.081621355275e-04
889 KSP unpreconditioned resid norm 8.712495044833e+00 true resid norm 8.712495044826e+00 ||r(i)||/||b|| 2.081621353189e-04
890 KSP unpreconditioned resid norm 8.712495037341e+00 true resid norm 8.712495037340e+00 ||r(i)||/||b|| 2.081621351400e-04
891 KSP unpreconditioned resid norm 8.712495027694e+00 true resid norm 8.712495027685e+00 ||r(i)||/||b|| 2.081621349093e-04
892 KSP unpreconditioned resid norm 8.712495018081e+00 true resid norm 8.712495018079e+00 ||r(i)||/||b|| 2.081621346798e-04
893 KSP unpreconditioned resid norm 8.712494974811e+00 true resid norm 8.712494974807e+00 ||r(i)||/||b|| 2.081621336459e-04
894 KSP unpreconditioned resid norm 8.712494800300e+00 true resid norm 8.712494800296e+00 ||r(i)||/||b|| 2.081621294765e-04
895 KSP unpreconditioned resid norm 8.712494777028e+00 true resid norm 8.712494777011e+00 ||r(i)||/||b|| 2.081621289201e-04
896 KSP unpreconditioned resid norm 8.712494698117e+00 true resid norm 8.712494698109e+00 ||r(i)||/||b|| 2.081621270350e-04
897 KSP unpreconditioned resid norm 8.712494500911e+00 true resid norm 8.712494500906e+00 ||r(i)||/||b|| 2.081621223233e-04
898 KSP unpreconditioned resid norm 8.712494325439e+00 true resid norm 8.712494325423e+00 ||r(i)||/||b|| 2.081621181306e-04
899 KSP unpreconditioned resid norm 8.712494118510e+00 true resid norm 8.712494118513e+00 ||r(i)||/||b|| 2.081621131870e-04
900 KSP unpreconditioned resid norm 8.712494046966e+00 true resid norm 8.712494046966e+00 ||r(i)||/||b|| 2.081621114776e-04
901 KSP unpreconditioned resid norm 8.712494046666e+00 true resid norm 8.712494046664e+00 ||r(i)||/||b|| 2.081621114704e-04
902 KSP unpreconditioned resid norm 8.712494044741e+00 true resid norm 8.712494044742e+00 ||r(i)||/||b|| 2.081621114245e-04
903 KSP unpreconditioned resid norm 8.712494040963e+00 true resid norm 8.712494040963e+00 ||r(i)||/||b|| 2.081621113342e-04
904 KSP unpreconditioned resid norm 8.712494035678e+00 true resid norm 8.712494035675e+00 ||r(i)||/||b|| 2.081621112078e-04
905 KSP unpreconditioned resid norm 8.712494029109e+00 true resid norm 8.712494029118e+00 ||r(i)||/||b|| 2.081621110512e-04
906 KSP unpreconditioned resid norm 8.712494025419e+00 true resid norm 8.712494025422e+00 ||r(i)||/||b|| 2.081621109629e-04
907 KSP unpreconditioned resid norm 8.712494019812e+00 true resid norm 8.712494019815e+00 ||r(i)||/||b|| 2.081621108289e-04
908 KSP unpreconditioned resid norm 8.712494011772e+00 true resid norm 8.712494011770e+00 ||r(i)||/||b|| 2.081621106367e-04
909 KSP unpreconditioned resid norm 8.712494007363e+00 true resid norm 8.712494007354e+00 ||r(i)||/||b|| 2.081621105312e-04
910 KSP unpreconditioned resid norm 8.712494004621e+00 true resid norm 8.712494004624e+00 ||r(i)||/||b|| 2.081621104660e-04
911 KSP unpreconditioned resid norm 8.712494001142e+00 true resid norm 8.712494001132e+00 ||r(i)||/||b|| 2.081621103825e-04
912 KSP unpreconditioned resid norm 8.712494000947e+00 true resid norm 8.712494000953e+00 ||r(i)||/||b|| 2.081621103782e-04
913 KSP unpreconditioned resid norm 8.712493991173e+00 true resid norm 8.712493991180e+00 ||r(i)||/||b|| 2.081621101448e-04
914 KSP unpreconditioned resid norm 8.712493984347e+00 true resid norm 8.712493984343e+00 ||r(i)||/||b|| 2.081621099814e-04
915 KSP unpreconditioned resid norm 8.712493957381e+00 true resid norm 8.712493957383e+00 ||r(i)||/||b|| 2.081621093373e-04
916 KSP unpreconditioned resid norm 8.712493942750e+00 true resid norm 8.712493942745e+00 ||r(i)||/||b|| 2.081621089875e-04
917 KSP unpreconditioned resid norm 8.712493938265e+00 true resid norm 8.712493938273e+00 ||r(i)||/||b|| 2.081621088807e-04
918 KSP unpreconditioned resid norm 8.712493912052e+00 true resid norm 8.712493912048e+00 ||r(i)||/||b|| 2.081621082541e-04
919 KSP unpreconditioned resid norm 8.712493907379e+00 true resid norm 8.712493907379e+00 ||r(i)||/||b|| 2.081621081426e-04
920 KSP unpreconditioned resid norm 8.712493907348e+00 true resid norm 8.712493907349e+00 ||r(i)||/||b|| 2.081621081418e-04
921 KSP unpreconditioned resid norm 8.712493906905e+00 true resid norm 8.712493906900e+00 ||r(i)||/||b|| 2.081621081311e-04
922 KSP unpreconditioned resid norm 8.712493885542e+00 true resid norm 8.712493885531e+00 ||r(i)||/||b|| 2.081621076206e-04
923 KSP unpreconditioned resid norm 8.712493807049e+00 true resid norm 8.712493807043e+00 ||r(i)||/||b|| 2.081621057453e-04
924 KSP unpreconditioned resid norm 8.712493758120e+00 true resid norm 8.712493758111e+00 ||r(i)||/||b|| 2.081621045762e-04
925 KSP unpreconditioned resid norm 8.712493633750e+00 true resid norm 8.712493633752e+00 ||r(i)||/||b|| 2.081621016050e-04
926 KSP unpreconditioned resid norm 8.712493557071e+00 true resid norm 8.712493557074e+00 ||r(i)||/||b|| 2.081620997729e-04
927 KSP unpreconditioned resid norm 8.712493487076e+00 true resid norm 8.712493487078e+00 ||r(i)||/||b|| 2.081620981006e-04
928 KSP unpreconditioned resid norm 8.712493187387e+00 true resid norm 8.712493187382e+00 ||r(i)||/||b|| 2.081620909401e-04
929 KSP unpreconditioned resid norm 8.712493082077e+00 true resid norm 8.712493082073e+00 ||r(i)||/||b|| 2.081620884240e-04
930 KSP unpreconditioned resid norm 8.712493066853e+00 true resid norm 8.712493066853e+00 ||r(i)||/||b|| 2.081620880604e-04
931 KSP unpreconditioned resid norm 8.712493066790e+00 true resid norm 8.712493066790e+00 ||r(i)||/||b|| 2.081620880589e-04
932 KSP unpreconditioned resid norm 8.712493066188e+00 true resid norm 8.712493066192e+00 ||r(i)||/||b|| 2.081620880446e-04
933 KSP unpreconditioned resid norm 8.712493063462e+00 true resid norm 8.712493063465e+00 ||r(i)||/||b|| 2.081620879795e-04
934 KSP unpreconditioned resid norm 8.712493057659e+00 true resid norm 8.712493057656e+00 ||r(i)||/||b|| 2.081620878407e-04
935 KSP unpreconditioned resid norm 8.712493050995e+00 true resid norm 8.712493050999e+00 ||r(i)||/||b|| 2.081620876816e-04
936 KSP unpreconditioned resid norm 8.712493048050e+00 true resid norm 8.712493048053e+00 ||r(i)||/||b|| 2.081620876112e-04
937 KSP unpreconditioned resid norm 8.712493046356e+00 true resid norm 8.712493046353e+00 ||r(i)||/||b|| 2.081620875706e-04
938 KSP unpreconditioned resid norm 8.712493042193e+00 true resid norm 8.712493042188e+00 ||r(i)||/||b|| 2.081620874711e-04
939 KSP unpreconditioned resid norm 8.712493035967e+00 true resid norm 8.712493035967e+00 ||r(i)||/||b|| 2.081620873225e-04
940 KSP unpreconditioned resid norm 8.712493030021e+00 true resid norm 8.712493030010e+00 ||r(i)||/||b|| 2.081620871801e-04
941 KSP unpreconditioned resid norm 8.712493028629e+00 true resid norm 8.712493028641e+00 ||r(i)||/||b|| 2.081620871474e-04
942 KSP unpreconditioned resid norm 8.712493028595e+00 true resid norm 8.712493028591e+00 ||r(i)||/||b|| 2.081620871462e-04
943 KSP unpreconditioned resid norm 8.712493023018e+00 true resid norm 8.712493023017e+00 ||r(i)||/||b|| 2.081620870130e-04
944 KSP unpreconditioned resid norm 8.712493009535e+00 true resid norm 8.712493009524e+00 ||r(i)||/||b|| 2.081620866907e-04
945 KSP unpreconditioned resid norm 8.712492993401e+00 true resid norm 8.712492993399e+00 ||r(i)||/||b|| 2.081620863054e-04
946 KSP unpreconditioned resid norm 8.712492985174e+00 true resid norm 8.712492985177e+00 ||r(i)||/||b|| 2.081620861090e-04
947 KSP unpreconditioned resid norm 8.712492972383e+00 true resid norm 8.712492972392e+00 ||r(i)||/||b|| 2.081620858035e-04
948 KSP unpreconditioned resid norm 8.712492966024e+00 true resid norm 8.712492966026e+00 ||r(i)||/||b|| 2.081620856514e-04
949 KSP unpreconditioned resid norm 8.712492958740e+00 true resid norm 8.712492958740e+00 ||r(i)||/||b|| 2.081620854773e-04
950 KSP unpreconditioned resid norm 8.712492955875e+00 true resid norm 8.712492955882e+00 ||r(i)||/||b|| 2.081620854090e-04
951 KSP unpreconditioned resid norm 8.712492952191e+00 true resid norm 8.712492952197e+00 ||r(i)||/||b|| 2.081620853210e-04
952 KSP unpreconditioned resid norm 8.712492943910e+00 true resid norm 8.712492943906e+00 ||r(i)||/||b|| 2.081620851229e-04
953 KSP unpreconditioned resid norm 8.712492903124e+00 true resid norm 8.712492903117e+00 ||r(i)||/||b|| 2.081620841483e-04
954 KSP unpreconditioned resid norm 8.712492804292e+00 true resid norm 8.712492804298e+00 ||r(i)||/||b|| 2.081620817873e-04
955 KSP unpreconditioned resid norm 8.712492775404e+00 true resid norm 8.712492775401e+00 ||r(i)||/||b|| 2.081620810969e-04
956 KSP unpreconditioned resid norm 8.712492712509e+00 true resid norm 8.712492712510e+00 ||r(i)||/||b|| 2.081620795943e-04
957 KSP unpreconditioned resid norm 8.712492581750e+00 true resid norm 8.712492581748e+00 ||r(i)||/||b|| 2.081620764701e-04
958 KSP unpreconditioned resid norm 8.712492399849e+00 true resid norm 8.712492399848e+00 ||r(i)||/||b|| 2.081620721241e-04
959 KSP unpreconditioned resid norm 8.712492251929e+00 true resid norm 8.712492251931e+00 ||r(i)||/||b|| 2.081620685900e-04
960 KSP unpreconditioned resid norm 8.712492222509e+00 true resid norm 8.712492222509e+00 ||r(i)||/||b|| 2.081620678870e-04
961 KSP unpreconditioned resid norm 8.712492222385e+00 true resid norm 8.712492222389e+00 ||r(i)||/||b|| 2.081620678842e-04
962 KSP unpreconditioned resid norm 8.712492221376e+00 true resid norm 8.712492221382e+00 ||r(i)||/||b|| 2.081620678601e-04
963 KSP unpreconditioned resid norm 8.712492218534e+00 true resid norm 8.712492218546e+00 ||r(i)||/||b|| 2.081620677923e-04
964 KSP unpreconditioned resid norm 8.712492213547e+00 true resid norm 8.712492213549e+00 ||r(i)||/||b|| 2.081620676729e-04
965 KSP unpreconditioned resid norm 8.712492207459e+00 true resid norm 8.712492207467e+00 ||r(i)||/||b|| 2.081620675276e-04
966 KSP unpreconditioned resid norm 8.712492204976e+00 true resid norm 8.712492204979e+00 ||r(i)||/||b|| 2.081620674682e-04
967 KSP unpreconditioned resid norm 8.712492202466e+00 true resid norm 8.712492202464e+00 ||r(i)||/||b|| 2.081620674081e-04
968 KSP unpreconditioned resid norm 8.712492197728e+00 true resid norm 8.712492197732e+00 ||r(i)||/||b|| 2.081620672950e-04
969 KSP unpreconditioned resid norm 8.712492193016e+00 true resid norm 8.712492193021e+00 ||r(i)||/||b|| 2.081620671825e-04
970 KSP unpreconditioned resid norm 8.712492189440e+00 true resid norm 8.712492189437e+00 ||r(i)||/||b|| 2.081620670969e-04
971 KSP unpreconditioned resid norm 8.712492187398e+00 true resid norm 8.712492187401e+00 ||r(i)||/||b|| 2.081620670482e-04
972 KSP unpreconditioned resid norm 8.712492187226e+00 true resid norm 8.712492187224e+00 ||r(i)||/||b|| 2.081620670440e-04
973 KSP unpreconditioned resid norm 8.712492180084e+00 true resid norm 8.712492180088e+00 ||r(i)||/||b|| 2.081620668735e-04
974 KSP unpreconditioned resid norm 8.712492172678e+00 true resid norm 8.712492172677e+00 ||r(i)||/||b|| 2.081620666964e-04
975 KSP unpreconditioned resid norm 8.712492154686e+00 true resid norm 8.712492154695e+00 ||r(i)||/||b|| 2.081620662668e-04
976 KSP unpreconditioned resid norm 8.712492144360e+00 true resid norm 8.712492144362e+00 ||r(i)||/||b|| 2.081620660199e-04
977 KSP unpreconditioned resid norm 8.712492139182e+00 true resid norm 8.712492139184e+00 ||r(i)||/||b|| 2.081620658962e-04
978 KSP unpreconditioned resid norm 8.712492125353e+00 true resid norm 8.712492125356e+00 ||r(i)||/||b|| 2.081620655658e-04
979 KSP unpreconditioned resid norm 8.712492120471e+00 true resid norm 8.712492120470e+00 ||r(i)||/||b|| 2.081620654491e-04
980 KSP unpreconditioned resid norm 8.712492120441e+00 true resid norm 8.712492120439e+00 ||r(i)||/||b|| 2.081620654483e-04
981 KSP unpreconditioned resid norm 8.712492120429e+00 true resid norm 8.712492120441e+00 ||r(i)||/||b|| 2.081620654484e-04
982 KSP unpreconditioned resid norm 8.712492107534e+00 true resid norm 8.712492107546e+00 ||r(i)||/||b|| 2.081620651403e-04
983 KSP unpreconditioned resid norm 8.712492052538e+00 true resid norm 8.712492052540e+00 ||r(i)||/||b|| 2.081620638261e-04
984 KSP unpreconditioned resid norm 8.712492004683e+00 true resid norm 8.712492004691e+00 ||r(i)||/||b|| 2.081620626828e-04
985 KSP unpreconditioned resid norm 8.712491931805e+00 true resid norm 8.712491931810e+00 ||r(i)||/||b|| 2.081620609415e-04
986 KSP unpreconditioned resid norm 8.712491871575e+00 true resid norm 8.712491871568e+00 ||r(i)||/||b|| 2.081620595022e-04
987 KSP unpreconditioned resid norm 8.712491801186e+00 true resid norm 8.712491801195e+00 ||r(i)||/||b|| 2.081620578208e-04
988 KSP unpreconditioned resid norm 8.712491577043e+00 true resid norm 8.712491577039e+00 ||r(i)||/||b|| 2.081620524652e-04
989 KSP unpreconditioned resid norm 8.712491484590e+00 true resid norm 8.712491484586e+00 ||r(i)||/||b|| 2.081620502563e-04
990 KSP unpreconditioned resid norm 8.712491476263e+00 true resid norm 8.712491476263e+00 ||r(i)||/||b|| 2.081620500574e-04
991 KSP unpreconditioned resid norm 8.712491476229e+00 true resid norm 8.712491476236e+00 ||r(i)||/||b|| 2.081620500568e-04
992 KSP unpreconditioned resid norm 8.712491475804e+00 true resid norm 8.712491475807e+00 ||r(i)||/||b|| 2.081620500465e-04
993 KSP unpreconditioned resid norm 8.712491473658e+00 true resid norm 8.712491473657e+00 ||r(i)||/||b|| 2.081620499952e-04
994 KSP unpreconditioned resid norm 8.712491468823e+00 true resid norm 8.712491468825e+00 ||r(i)||/||b|| 2.081620498797e-04
995 KSP unpreconditioned resid norm 8.712491463076e+00 true resid norm 8.712491463070e+00 ||r(i)||/||b|| 2.081620497422e-04
996 KSP unpreconditioned resid norm 8.712491461028e+00 true resid norm 8.712491461035e+00 ||r(i)||/||b|| 2.081620496936e-04
997 KSP unpreconditioned resid norm 8.712491459987e+00 true resid norm 8.712491459991e+00 ||r(i)||/||b|| 2.081620496687e-04
998 KSP unpreconditioned resid norm 8.712491457038e+00 true resid norm 8.712491457042e+00 ||r(i)||/||b|| 2.081620495982e-04
999 KSP unpreconditioned resid norm 8.712491451696e+00 true resid norm 8.712491451692e+00 ||r(i)||/||b|| 2.081620494704e-04
1000 KSP unpreconditioned resid norm 8.712491446715e+00 true resid norm 8.712491446706e+00 ||r(i)||/||b|| 2.081620493513e-04
1001 KSP unpreconditioned resid norm 8.712491445574e+00 true resid norm 8.712491445568e+00 ||r(i)||/||b|| 2.081620493241e-04
1002 KSP unpreconditioned resid norm 8.712491445507e+00 true resid norm 8.712491445511e+00 ||r(i)||/||b|| 2.081620493227e-04
1003 KSP unpreconditioned resid norm 8.712491440655e+00 true resid norm 8.712491440656e+00 ||r(i)||/||b|| 2.081620492067e-04
1004 KSP unpreconditioned resid norm 8.712491430753e+00 true resid norm 8.712491430741e+00 ||r(i)||/||b|| 2.081620489698e-04
1005 KSP unpreconditioned resid norm 8.712491418366e+00 true resid norm 8.712491418369e+00 ||r(i)||/||b|| 2.081620486742e-04
1006 KSP unpreconditioned resid norm 8.712491411400e+00 true resid norm 8.712491411406e+00 ||r(i)||/||b|| 2.081620485078e-04
1007 KSP unpreconditioned resid norm 8.712491402851e+00 true resid norm 8.712491402849e+00 ||r(i)||/||b|| 2.081620483034e-04
1008 KSP unpreconditioned resid norm 8.712491397262e+00 true resid norm 8.712491397250e+00 ||r(i)||/||b|| 2.081620481696e-04
1009 KSP unpreconditioned resid norm 8.712491391193e+00 true resid norm 8.712491391191e+00 ||r(i)||/||b|| 2.081620480249e-04
1010 KSP unpreconditioned resid norm 8.712491389994e+00 true resid norm 8.712491389999e+00 ||r(i)||/||b|| 2.081620479964e-04
1011 KSP unpreconditioned resid norm 8.712491388168e+00 true resid norm 8.712491388174e+00 ||r(i)||/||b|| 2.081620479528e-04
1012 KSP unpreconditioned resid norm 8.712491381447e+00 true resid norm 8.712491381454e+00 ||r(i)||/||b|| 2.081620477922e-04
1013 KSP unpreconditioned resid norm 8.712491346713e+00 true resid norm 8.712491346717e+00 ||r(i)||/||b|| 2.081620469623e-04
1014 KSP unpreconditioned resid norm 8.712491282127e+00 true resid norm 8.712491282130e+00 ||r(i)||/||b|| 2.081620454191e-04
1015 KSP unpreconditioned resid norm 8.712491253310e+00 true resid norm 8.712491253312e+00 ||r(i)||/||b|| 2.081620447306e-04
1016 KSP unpreconditioned resid norm 8.712491204315e+00 true resid norm 8.712491204323e+00 ||r(i)||/||b|| 2.081620435601e-04
1017 KSP unpreconditioned resid norm 8.712491112378e+00 true resid norm 8.712491112374e+00 ||r(i)||/||b|| 2.081620413633e-04
1018 KSP unpreconditioned resid norm 8.712490949380e+00 true resid norm 8.712490949378e+00 ||r(i)||/||b|| 2.081620374689e-04
1019 KSP unpreconditioned resid norm 8.712490838883e+00 true resid norm 8.712490838881e+00 ||r(i)||/||b|| 2.081620348289e-04
1020 KSP unpreconditioned resid norm 8.712490823669e+00 true resid norm 8.712490823669e+00 ||r(i)||/||b|| 2.081620344654e-04
1021 KSP unpreconditioned resid norm 8.712490823605e+00 true resid norm 8.712490823602e+00 ||r(i)||/||b|| 2.081620344638e-04
1022 KSP unpreconditioned resid norm 8.712490822980e+00 true resid norm 8.712490822978e+00 ||r(i)||/||b|| 2.081620344489e-04
1023 KSP unpreconditioned resid norm 8.712490820794e+00 true resid norm 8.712490820788e+00 ||r(i)||/||b|| 2.081620343966e-04
1024 KSP unpreconditioned resid norm 8.712490816546e+00 true resid norm 8.712490816540e+00 ||r(i)||/||b|| 2.081620342951e-04
1025 KSP unpreconditioned resid norm 8.712490811432e+00 true resid norm 8.712490811441e+00 ||r(i)||/||b|| 2.081620341733e-04
1026 KSP unpreconditioned resid norm 8.712490809639e+00 true resid norm 8.712490809633e+00 ||r(i)||/||b|| 2.081620341301e-04
1027 KSP unpreconditioned resid norm 8.712490808249e+00 true resid norm 8.712490808249e+00 ||r(i)||/||b|| 2.081620340970e-04
1028 KSP unpreconditioned resid norm 8.712490805055e+00 true resid norm 8.712490805054e+00 ||r(i)||/||b|| 2.081620340207e-04
1029 KSP unpreconditioned resid norm 8.712490800821e+00 true resid norm 8.712490800826e+00 ||r(i)||/||b|| 2.081620339196e-04
1030 KSP unpreconditioned resid norm 8.712490797390e+00 true resid norm 8.712490797403e+00 ||r(i)||/||b|| 2.081620338379e-04
1031 KSP unpreconditioned resid norm 8.712490796045e+00 true resid norm 8.712490796032e+00 ||r(i)||/||b|| 2.081620338051e-04
1032 KSP unpreconditioned resid norm 8.712490795914e+00 true resid norm 8.712490795904e+00 ||r(i)||/||b|| 2.081620338020e-04
1033 KSP unpreconditioned resid norm 8.712490790610e+00 true resid norm 8.712490790603e+00 ||r(i)||/||b|| 2.081620336754e-04
1034 KSP unpreconditioned resid norm 8.712490783855e+00 true resid norm 8.712490783850e+00 ||r(i)||/||b|| 2.081620335140e-04
1035 KSP unpreconditioned resid norm 8.712490770870e+00 true resid norm 8.712490770868e+00 ||r(i)||/||b|| 2.081620332039e-04
1036 KSP unpreconditioned resid norm 8.712490763287e+00 true resid norm 8.712490763279e+00 ||r(i)||/||b|| 2.081620330226e-04
1037 KSP unpreconditioned resid norm 8.712490758483e+00 true resid norm 8.712490758480e+00 ||r(i)||/||b|| 2.081620329079e-04
1038 KSP unpreconditioned resid norm 8.712490749938e+00 true resid norm 8.712490749935e+00 ||r(i)||/||b|| 2.081620327037e-04
1039 KSP unpreconditioned resid norm 8.712490745473e+00 true resid norm 8.712490745471e+00 ||r(i)||/||b|| 2.081620325971e-04
1040 KSP unpreconditioned resid norm 8.712490745385e+00 true resid norm 8.712490745376e+00 ||r(i)||/||b|| 2.081620325948e-04
1041 KSP unpreconditioned resid norm 8.712490745173e+00 true resid norm 8.712490745177e+00 ||r(i)||/||b|| 2.081620325901e-04
1042 KSP unpreconditioned resid norm 8.712490736579e+00 true resid norm 8.712490736572e+00 ||r(i)||/||b|| 2.081620323845e-04
1043 KSP unpreconditioned resid norm 8.712490696569e+00 true resid norm 8.712490696558e+00 ||r(i)||/||b|| 2.081620314284e-04
1044 KSP unpreconditioned resid norm 8.712490654327e+00 true resid norm 8.712490654324e+00 ||r(i)||/||b|| 2.081620304194e-04
1045 KSP unpreconditioned resid norm 8.712490606279e+00 true resid norm 8.712490606266e+00 ||r(i)||/||b|| 2.081620292711e-04
1046 KSP unpreconditioned resid norm 8.712490559352e+00 true resid norm 8.712490559356e+00 ||r(i)||/||b|| 2.081620281504e-04
1047 KSP unpreconditioned resid norm 8.712490497533e+00 true resid norm 8.712490497540e+00 ||r(i)||/||b|| 2.081620266734e-04
1048 KSP unpreconditioned resid norm 8.712490326551e+00 true resid norm 8.712490326545e+00 ||r(i)||/||b|| 2.081620225880e-04
1049 KSP unpreconditioned resid norm 8.712490248790e+00 true resid norm 8.712490248791e+00 ||r(i)||/||b|| 2.081620207302e-04
1050 KSP unpreconditioned resid norm 8.712490243279e+00 true resid norm 8.712490243279e+00 ||r(i)||/||b|| 2.081620205985e-04
1051 KSP unpreconditioned resid norm 8.712490243256e+00 true resid norm 8.712490243261e+00 ||r(i)||/||b|| 2.081620205981e-04
1052 KSP unpreconditioned resid norm 8.712490242933e+00 true resid norm 8.712490242926e+00 ||r(i)||/||b|| 2.081620205901e-04
1053 KSP unpreconditioned resid norm 8.712490241234e+00 true resid norm 8.712490241237e+00 ||r(i)||/||b|| 2.081620205497e-04
1054 KSP unpreconditioned resid norm 8.712490237337e+00 true resid norm 8.712490237340e+00 ||r(i)||/||b|| 2.081620204566e-04
1055 KSP unpreconditioned resid norm 8.712490232644e+00 true resid norm 8.712490232644e+00 ||r(i)||/||b|| 2.081620203444e-04
1056 KSP unpreconditioned resid norm 8.712490231140e+00 true resid norm 8.712490231134e+00 ||r(i)||/||b|| 2.081620203084e-04
1057 KSP unpreconditioned resid norm 8.712490230412e+00 true resid norm 8.712490230413e+00 ||r(i)||/||b|| 2.081620202911e-04
1058 KSP unpreconditioned resid norm 8.712490228192e+00 true resid norm 8.712490228192e+00 ||r(i)||/||b|| 2.081620202381e-04
1059 KSP unpreconditioned resid norm 8.712490223841e+00 true resid norm 8.712490223837e+00 ||r(i)||/||b|| 2.081620201340e-04
1060 KSP unpreconditioned resid norm 8.712490219863e+00 true resid norm 8.712490219860e+00 ||r(i)||/||b|| 2.081620200390e-04
1061 KSP unpreconditioned resid norm 8.712490218947e+00 true resid norm 8.712490218947e+00 ||r(i)||/||b|| 2.081620200172e-04
1062 KSP unpreconditioned resid norm 8.712490218876e+00 true resid norm 8.712490218884e+00 ||r(i)||/||b|| 2.081620200157e-04
1063 KSP unpreconditioned resid norm 8.712490214885e+00 true resid norm 8.712490214877e+00 ||r(i)||/||b|| 2.081620199199e-04
1064 KSP unpreconditioned resid norm 8.712490207411e+00 true resid norm 8.712490207407e+00 ||r(i)||/||b|| 2.081620197415e-04
1065 KSP unpreconditioned resid norm 8.712490197740e+00 true resid norm 8.712490197728e+00 ||r(i)||/||b|| 2.081620195102e-04
1066 KSP unpreconditioned resid norm 8.712490192065e+00 true resid norm 8.712490192058e+00 ||r(i)||/||b|| 2.081620193747e-04
1067 KSP unpreconditioned resid norm 8.712490185999e+00 true resid norm 8.712490185998e+00 ||r(i)||/||b|| 2.081620192300e-04
1068 KSP unpreconditioned resid norm 8.712490181291e+00 true resid norm 8.712490181293e+00 ||r(i)||/||b|| 2.081620191175e-04
1069 KSP unpreconditioned resid norm 8.712490176364e+00 true resid norm 8.712490176371e+00 ||r(i)||/||b|| 2.081620189999e-04
1070 KSP unpreconditioned resid norm 8.712490175783e+00 true resid norm 8.712490175782e+00 ||r(i)||/||b|| 2.081620189859e-04
1071 KSP unpreconditioned resid norm 8.712490174702e+00 true resid norm 8.712490174691e+00 ||r(i)||/||b|| 2.081620189598e-04
1072 KSP unpreconditioned resid norm 8.712490169338e+00 true resid norm 8.712490169334e+00 ||r(i)||/||b|| 2.081620188318e-04
1073 KSP unpreconditioned resid norm 8.712490141010e+00 true resid norm 8.712490141008e+00 ||r(i)||/||b|| 2.081620181550e-04
1074 KSP unpreconditioned resid norm 8.712490095212e+00 true resid norm 8.712490095218e+00 ||r(i)||/||b|| 2.081620170610e-04
1075 KSP unpreconditioned resid norm 8.712490069468e+00 true resid norm 8.712490069463e+00 ||r(i)||/||b|| 2.081620164456e-04
1076 KSP unpreconditioned resid norm 8.712490031325e+00 true resid norm 8.712490031319e+00 ||r(i)||/||b|| 2.081620155343e-04
1077 KSP unpreconditioned resid norm 8.712489963804e+00 true resid norm 8.712489963802e+00 ||r(i)||/||b|| 2.081620139212e-04
1078 KSP unpreconditioned resid norm 8.712489827012e+00 true resid norm 8.712489827007e+00 ||r(i)||/||b|| 2.081620106528e-04
1079 KSP unpreconditioned resid norm 8.712489742627e+00 true resid norm 8.712489742623e+00 ||r(i)||/||b|| 2.081620086367e-04
1080 KSP unpreconditioned resid norm 8.712489733341e+00 true resid norm 8.712489733341e+00 ||r(i)||/||b|| 2.081620084149e-04
1081 KSP unpreconditioned resid norm 8.712489733301e+00 true resid norm 8.712489733292e+00 ||r(i)||/||b|| 2.081620084137e-04
1082 KSP unpreconditioned resid norm 8.712489732873e+00 true resid norm 8.712489732872e+00 ||r(i)||/||b|| 2.081620084037e-04
1083 KSP unpreconditioned resid norm 8.712489731177e+00 true resid norm 8.712489731178e+00 ||r(i)||/||b|| 2.081620083632e-04
1084 KSP unpreconditioned resid norm 8.712489727714e+00 true resid norm 8.712489727716e+00 ||r(i)||/||b|| 2.081620082805e-04
1085 KSP unpreconditioned resid norm 8.712489723582e+00 true resid norm 8.712489723583e+00 ||r(i)||/||b|| 2.081620081818e-04
1086 KSP unpreconditioned resid norm 8.712489722238e+00 true resid norm 8.712489722232e+00 ||r(i)||/||b|| 2.081620081495e-04
1087 KSP unpreconditioned resid norm 8.712489721352e+00 true resid norm 8.712489721354e+00 ||r(i)||/||b|| 2.081620081285e-04
1088 KSP unpreconditioned resid norm 8.712489719044e+00 true resid norm 8.712489719036e+00 ||r(i)||/||b|| 2.081620080731e-04
1089 KSP unpreconditioned resid norm 8.712489715501e+00 true resid norm 8.712489715499e+00 ||r(i)||/||b|| 2.081620079886e-04
1090 KSP unpreconditioned resid norm 8.712489712548e+00 true resid norm 8.712489712542e+00 ||r(i)||/||b|| 2.081620079180e-04
1091 KSP unpreconditioned resid norm 8.712489711593e+00 true resid norm 8.712489711583e+00 ||r(i)||/||b|| 2.081620078951e-04
1092 KSP unpreconditioned resid norm 8.712489711495e+00 true resid norm 8.712489711502e+00 ||r(i)||/||b|| 2.081620078931e-04
1093 KSP unpreconditioned resid norm 8.712489707484e+00 true resid norm 8.712489707489e+00 ||r(i)||/||b|| 2.081620077972e-04
1094 KSP unpreconditioned resid norm 8.712489701776e+00 true resid norm 8.712489701777e+00 ||r(i)||/||b|| 2.081620076608e-04
1095 KSP unpreconditioned resid norm 8.712489692040e+00 true resid norm 8.712489692037e+00 ||r(i)||/||b|| 2.081620074280e-04
1096 KSP unpreconditioned resid norm 8.712489686330e+00 true resid norm 8.712489686329e+00 ||r(i)||/||b|| 2.081620072917e-04
1097 KSP unpreconditioned resid norm 8.712489682245e+00 true resid norm 8.712489682246e+00 ||r(i)||/||b|| 2.081620071941e-04
1098 KSP unpreconditioned resid norm 8.712489676406e+00 true resid norm 8.712489676401e+00 ||r(i)||/||b|| 2.081620070545e-04
1099 KSP unpreconditioned resid norm 8.712489672608e+00 true resid norm 8.712489672613e+00 ||r(i)||/||b|| 2.081620069640e-04
1100 KSP unpreconditioned resid norm 8.712489672498e+00 true resid norm 8.712489672500e+00 ||r(i)||/||b|| 2.081620069613e-04
1101 KSP unpreconditioned resid norm 8.712489672154e+00 true resid norm 8.712489672160e+00 ||r(i)||/||b|| 2.081620069531e-04
1102 KSP unpreconditioned resid norm 8.712489666039e+00 true resid norm 8.712489666028e+00 ||r(i)||/||b|| 2.081620068066e-04
1103 KSP unpreconditioned resid norm 8.712489636146e+00 true resid norm 8.712489636144e+00 ||r(i)||/||b|| 2.081620060926e-04
1104 KSP unpreconditioned resid norm 8.712489600917e+00 true resid norm 8.712489600916e+00 ||r(i)||/||b|| 2.081620052510e-04
1105 KSP unpreconditioned resid norm 8.712489566911e+00 true resid norm 8.712489566916e+00 ||r(i)||/||b|| 2.081620044386e-04
1106 KSP unpreconditioned resid norm 8.712489530407e+00 true resid norm 8.712489530399e+00 ||r(i)||/||b|| 2.081620035661e-04
1107 KSP unpreconditioned resid norm 8.712489479112e+00 true resid norm 8.712489479106e+00 ||r(i)||/||b|| 2.081620023406e-04
1108 KSP unpreconditioned resid norm 8.712489347084e+00 true resid norm 8.712489347087e+00 ||r(i)||/||b|| 2.081619991864e-04
1109 KSP unpreconditioned resid norm 8.712489283438e+00 true resid norm 8.712489283439e+00 ||r(i)||/||b|| 2.081619976657e-04
1110 KSP unpreconditioned resid norm 8.712489279381e+00 true resid norm 8.712489279381e+00 ||r(i)||/||b|| 2.081619975687e-04
1111 KSP unpreconditioned resid norm 8.712489279364e+00 true resid norm 8.712489279362e+00 ||r(i)||/||b|| 2.081619975683e-04
1112 KSP unpreconditioned resid norm 8.712489279110e+00 true resid norm 8.712489279103e+00 ||r(i)||/||b|| 2.081619975621e-04
1113 KSP unpreconditioned resid norm 8.712489277765e+00 true resid norm 8.712489277768e+00 ||r(i)||/||b|| 2.081619975302e-04
1114 KSP unpreconditioned resid norm 8.712489274670e+00 true resid norm 8.712489274661e+00 ||r(i)||/||b|| 2.081619974559e-04
1115 KSP unpreconditioned resid norm 8.712489270926e+00 true resid norm 8.712489270923e+00 ||r(i)||/||b|| 2.081619973666e-04
1116 KSP unpreconditioned resid norm 8.712489269788e+00 true resid norm 8.712489269785e+00 ||r(i)||/||b|| 2.081619973395e-04
1117 KSP unpreconditioned resid norm 8.712489269244e+00 true resid norm 8.712489269230e+00 ||r(i)||/||b|| 2.081619973262e-04
1118 KSP unpreconditioned resid norm 8.712489267530e+00 true resid norm 8.712489267518e+00 ||r(i)||/||b|| 2.081619972853e-04
1119 KSP unpreconditioned resid norm 8.712489264069e+00 true resid norm 8.712489264076e+00 ||r(i)||/||b|| 2.081619972031e-04
1120 KSP unpreconditioned resid norm 8.712489260945e+00 true resid norm 8.712489260934e+00 ||r(i)||/||b|| 2.081619971280e-04
1121 KSP unpreconditioned resid norm 8.712489260214e+00 true resid norm 8.712489260209e+00 ||r(i)||/||b|| 2.081619971107e-04
1122 KSP unpreconditioned resid norm 8.712489260152e+00 true resid norm 8.712489260143e+00 ||r(i)||/||b|| 2.081619971091e-04
1123 KSP unpreconditioned resid norm 8.712489256948e+00 true resid norm 8.712489256932e+00 ||r(i)||/||b|| 2.081619970324e-04
1124 KSP unpreconditioned resid norm 8.712489251224e+00 true resid norm 8.712489251226e+00 ||r(i)||/||b|| 2.081619968960e-04
1125 KSP unpreconditioned resid norm 8.712489243632e+00 true resid norm 8.712489243626e+00 ||r(i)||/||b|| 2.081619967144e-04
1126 KSP unpreconditioned resid norm 8.712489239095e+00 true resid norm 8.712489239085e+00 ||r(i)||/||b|| 2.081619966060e-04
1127 KSP unpreconditioned resid norm 8.712489234622e+00 true resid norm 8.712489234622e+00 ||r(i)||/||b|| 2.081619964993e-04
1128 KSP unpreconditioned resid norm 8.712489230764e+00 true resid norm 8.712489230757e+00 ||r(i)||/||b|| 2.081619964070e-04
1129 KSP unpreconditioned resid norm 8.712489226840e+00 true resid norm 8.712489226833e+00 ||r(i)||/||b|| 2.081619963132e-04
1130 KSP unpreconditioned resid norm 8.712489226512e+00 true resid norm 8.712489226517e+00 ||r(i)||/||b|| 2.081619963057e-04
1131 KSP unpreconditioned resid norm 8.712489225797e+00 true resid norm 8.712489225794e+00 ||r(i)||/||b|| 2.081619962884e-04
1132 KSP unpreconditioned resid norm 8.712489221540e+00 true resid norm 8.712489221535e+00 ||r(i)||/||b|| 2.081619961867e-04
1133 KSP unpreconditioned resid norm 8.712489198880e+00 true resid norm 8.712489198876e+00 ||r(i)||/||b|| 2.081619956453e-04
1134 KSP unpreconditioned resid norm 8.712489164903e+00 true resid norm 8.712489164893e+00 ||r(i)||/||b|| 2.081619948333e-04
1135 KSP unpreconditioned resid norm 8.712489143209e+00 true resid norm 8.712489143207e+00 ||r(i)||/||b|| 2.081619943152e-04
1136 KSP unpreconditioned resid norm 8.712489113424e+00 true resid norm 8.712489113409e+00 ||r(i)||/||b|| 2.081619936033e-04
1137 KSP unpreconditioned resid norm 8.712489062448e+00 true resid norm 8.712489062446e+00 ||r(i)||/||b|| 2.081619923856e-04
1138 KSP unpreconditioned resid norm 8.712488951318e+00 true resid norm 8.712488951300e+00 ||r(i)||/||b|| 2.081619897301e-04
1139 KSP unpreconditioned resid norm 8.712488886149e+00 true resid norm 8.712488886130e+00 ||r(i)||/||b|| 2.081619881730e-04
1140 KSP unpreconditioned resid norm 8.712488879862e+00 true resid norm 8.712488879862e+00 ||r(i)||/||b|| 2.081619880233e-04
1141 KSP unpreconditioned resid norm 8.712488879836e+00 true resid norm 8.712488879834e+00 ||r(i)||/||b|| 2.081619880226e-04
1142 KSP unpreconditioned resid norm 8.712488879525e+00 true resid norm 8.712488879520e+00 ||r(i)||/||b|| 2.081619880151e-04
1143 KSP unpreconditioned resid norm 8.712488878204e+00 true resid norm 8.712488878202e+00 ||r(i)||/||b|| 2.081619879836e-04
1144 KSP unpreconditioned resid norm 8.712488875439e+00 true resid norm 8.712488875438e+00 ||r(i)||/||b|| 2.081619879176e-04
1145 KSP unpreconditioned resid norm 8.712488872157e+00 true resid norm 8.712488872149e+00 ||r(i)||/||b|| 2.081619878390e-04
1146 KSP unpreconditioned resid norm 8.712488871130e+00 true resid norm 8.712488871130e+00 ||r(i)||/||b|| 2.081619878146e-04
1147 KSP unpreconditioned resid norm 8.712488870514e+00 true resid norm 8.712488870501e+00 ||r(i)||/||b|| 2.081619877996e-04
1148 KSP unpreconditioned resid norm 8.712488868785e+00 true resid norm 8.712488868778e+00 ||r(i)||/||b|| 2.081619877584e-04
1149 KSP unpreconditioned resid norm 8.712488865918e+00 true resid norm 8.712488865915e+00 ||r(i)||/||b|| 2.081619876900e-04
1150 KSP unpreconditioned resid norm 8.712488863492e+00 true resid norm 8.712488863478e+00 ||r(i)||/||b|| 2.081619876318e-04
1151 KSP unpreconditioned resid norm 8.712488862782e+00 true resid norm 8.712488862782e+00 ||r(i)||/||b|| 2.081619876152e-04
1152 KSP unpreconditioned resid norm 8.712488862709e+00 true resid norm 8.712488862700e+00 ||r(i)||/||b|| 2.081619876132e-04
1153 KSP unpreconditioned resid norm 8.712488859635e+00 true resid norm 8.712488859625e+00 ||r(i)||/||b|| 2.081619875398e-04
1154 KSP unpreconditioned resid norm 8.712488854989e+00 true resid norm 8.712488854988e+00 ||r(i)||/||b|| 2.081619874290e-04
1155 KSP unpreconditioned resid norm 8.712488847552e+00 true resid norm 8.712488847540e+00 ||r(i)||/||b|| 2.081619872510e-04
1156 KSP unpreconditioned resid norm 8.712488843186e+00 true resid norm 8.712488843176e+00 ||r(i)||/||b|| 2.081619871468e-04
1157 KSP unpreconditioned resid norm 8.712488839847e+00 true resid norm 8.712488839829e+00 ||r(i)||/||b|| 2.081619870668e-04
1158 KSP unpreconditioned resid norm 8.712488835614e+00 true resid norm 8.712488835609e+00 ||r(i)||/||b|| 2.081619869660e-04
1159 KSP unpreconditioned resid norm 8.712488832504e+00 true resid norm 8.712488832494e+00 ||r(i)||/||b|| 2.081619868915e-04
1160 KSP unpreconditioned resid norm 8.712488832396e+00 true resid norm 8.712488832394e+00 ||r(i)||/||b|| 2.081619868891e-04
1161 KSP unpreconditioned resid norm 8.712488832028e+00 true resid norm 8.712488832027e+00 ||r(i)||/||b|| 2.081619868804e-04
1162 KSP unpreconditioned resid norm 8.712488827502e+00 true resid norm 8.712488827485e+00 ||r(i)||/||b|| 2.081619867719e-04
1163 KSP unpreconditioned resid norm 8.712488804778e+00 true resid norm 8.712488804768e+00 ||r(i)||/||b|| 2.081619862291e-04
1164 KSP unpreconditioned resid norm 8.712488776297e+00 true resid norm 8.712488776296e+00 ||r(i)||/||b|| 2.081619855488e-04
1165 KSP unpreconditioned resid norm 8.712488751221e+00 true resid norm 8.712488751221e+00 ||r(i)||/||b|| 2.081619849497e-04
1166 KSP unpreconditioned resid norm 8.712488722819e+00 true resid norm 8.712488722820e+00 ||r(i)||/||b|| 2.081619842712e-04
1167 KSP unpreconditioned resid norm 8.712488681399e+00 true resid norm 8.712488681389e+00 ||r(i)||/||b|| 2.081619832813e-04
1168 KSP unpreconditioned resid norm 8.712488578739e+00 true resid norm 8.712488578734e+00 ||r(i)||/||b|| 2.081619808286e-04
1169 KSP unpreconditioned resid norm 8.712488527491e+00 true resid norm 8.712488527484e+00 ||r(i)||/||b|| 2.081619796041e-04
1170 KSP unpreconditioned resid norm 8.712488524324e+00 true resid norm 8.712488524324e+00 ||r(i)||/||b|| 2.081619795286e-04
1171 KSP unpreconditioned resid norm 8.712488524311e+00 true resid norm 8.712488524315e+00 ||r(i)||/||b|| 2.081619795284e-04
1172 KSP unpreconditioned resid norm 8.712488524110e+00 true resid norm 8.712488524109e+00 ||r(i)||/||b|| 2.081619795235e-04
1173 KSP unpreconditioned resid norm 8.712488523047e+00 true resid norm 8.712488523062e+00 ||r(i)||/||b|| 2.081619794985e-04
1174 KSP unpreconditioned resid norm 8.712488520605e+00 true resid norm 8.712488520612e+00 ||r(i)||/||b|| 2.081619794399e-04
1175 KSP unpreconditioned resid norm 8.712488517650e+00 true resid norm 8.712488517652e+00 ||r(i)||/||b|| 2.081619793692e-04
1176 KSP unpreconditioned resid norm 8.712488516775e+00 true resid norm 8.712488516767e+00 ||r(i)||/||b|| 2.081619793481e-04
1177 KSP unpreconditioned resid norm 8.712488516358e+00 true resid norm 8.712488516372e+00 ||r(i)||/||b|| 2.081619793386e-04
1178 KSP unpreconditioned resid norm 8.712488515020e+00 true resid norm 8.712488515027e+00 ||r(i)||/||b|| 2.081619793065e-04
1179 KSP unpreconditioned resid norm 8.712488512295e+00 true resid norm 8.712488512304e+00 ||r(i)||/||b|| 2.081619792414e-04
1180 KSP unpreconditioned resid norm 8.712488509855e+00 true resid norm 8.712488509859e+00 ||r(i)||/||b|| 2.081619791830e-04
1181 KSP unpreconditioned resid norm 8.712488509277e+00 true resid norm 8.712488509291e+00 ||r(i)||/||b|| 2.081619791695e-04
1182 KSP unpreconditioned resid norm 8.712488509226e+00 true resid norm 8.712488509225e+00 ||r(i)||/||b|| 2.081619791679e-04
1183 KSP unpreconditioned resid norm 8.712488506684e+00 true resid norm 8.712488506694e+00 ||r(i)||/||b|| 2.081619791074e-04
1184 KSP unpreconditioned resid norm 8.712488502263e+00 true resid norm 8.712488502255e+00 ||r(i)||/||b|| 2.081619790013e-04
1185 KSP unpreconditioned resid norm 8.712488496296e+00 true resid norm 8.712488496305e+00 ||r(i)||/||b|| 2.081619788592e-04
1186 KSP unpreconditioned resid norm 8.712488492704e+00 true resid norm 8.712488492709e+00 ||r(i)||/||b|| 2.081619787733e-04
1187 KSP unpreconditioned resid norm 8.712488489325e+00 true resid norm 8.712488489335e+00 ||r(i)||/||b|| 2.081619786926e-04
1188 KSP unpreconditioned resid norm 8.712488486218e+00 true resid norm 8.712488486234e+00 ||r(i)||/||b|| 2.081619786186e-04
1189 KSP unpreconditioned resid norm 8.712488483127e+00 true resid norm 8.712488483123e+00 ||r(i)||/||b|| 2.081619785442e-04
1190 KSP unpreconditioned resid norm 8.712488482919e+00 true resid norm 8.712488482922e+00 ||r(i)||/||b|| 2.081619785394e-04
1191 KSP unpreconditioned resid norm 8.712488482412e+00 true resid norm 8.712488482416e+00 ||r(i)||/||b|| 2.081619785273e-04
1192 KSP unpreconditioned resid norm 8.712488479044e+00 true resid norm 8.712488479048e+00 ||r(i)||/||b|| 2.081619784469e-04
1193 KSP unpreconditioned resid norm 8.712488461088e+00 true resid norm 8.712488461098e+00 ||r(i)||/||b|| 2.081619780180e-04
1194 KSP unpreconditioned resid norm 8.712488435250e+00 true resid norm 8.712488435244e+00 ||r(i)||/||b|| 2.081619774003e-04
1195 KSP unpreconditioned resid norm 8.712488417536e+00 true resid norm 8.712488417544e+00 ||r(i)||/||b|| 2.081619769774e-04
1196 KSP unpreconditioned resid norm 8.712488394223e+00 true resid norm 8.712488394233e+00 ||r(i)||/||b|| 2.081619764204e-04
1197 KSP unpreconditioned resid norm 8.712488355109e+00 true resid norm 8.712488355118e+00 ||r(i)||/||b|| 2.081619754859e-04
1198 KSP unpreconditioned resid norm 8.712488266342e+00 true resid norm 8.712488266347e+00 ||r(i)||/||b|| 2.081619733649e-04
1199 KSP unpreconditioned resid norm 8.712488215725e+00 true resid norm 8.712488215732e+00 ||r(i)||/||b|| 2.081619721556e-04
1200 KSP unpreconditioned resid norm 8.712488211219e+00 true resid norm 8.712488211219e+00 ||r(i)||/||b|| 2.081619720478e-04
1201 KSP unpreconditioned resid norm 8.712488211200e+00 true resid norm 8.712488211188e+00 ||r(i)||/||b|| 2.081619720471e-04
1202 KSP unpreconditioned resid norm 8.712488210966e+00 true resid norm 8.712488210957e+00 ||r(i)||/||b|| 2.081619720415e-04
1203 KSP unpreconditioned resid norm 8.712488209937e+00 true resid norm 8.712488209937e+00 ||r(i)||/||b|| 2.081619720172e-04
1204 KSP unpreconditioned resid norm 8.712488207752e+00 true resid norm 8.712488207737e+00 ||r(i)||/||b|| 2.081619719646e-04
1205 KSP unpreconditioned resid norm 8.712488205164e+00 true resid norm 8.712488205157e+00 ||r(i)||/||b|| 2.081619719030e-04
1206 KSP unpreconditioned resid norm 8.712488204372e+00 true resid norm 8.712488204370e+00 ||r(i)||/||b|| 2.081619718842e-04
1207 KSP unpreconditioned resid norm 8.712488203922e+00 true resid norm 8.712488203908e+00 ||r(i)||/||b|| 2.081619718731e-04
1208 KSP unpreconditioned resid norm 8.712488202603e+00 true resid norm 8.712488202594e+00 ||r(i)||/||b|| 2.081619718417e-04
1209 KSP unpreconditioned resid norm 8.712488200319e+00 true resid norm 8.712488200321e+00 ||r(i)||/||b|| 2.081619717874e-04
1210 KSP unpreconditioned resid norm 8.712488198369e+00 true resid norm 8.712488198356e+00 ||r(i)||/||b|| 2.081619717405e-04
1211 KSP unpreconditioned resid norm 8.712488197829e+00 true resid norm 8.712488197831e+00 ||r(i)||/||b|| 2.081619717279e-04
1212 KSP unpreconditioned resid norm 8.712488197774e+00 true resid norm 8.712488197770e+00 ||r(i)||/||b|| 2.081619717265e-04
1213 KSP unpreconditioned resid norm 8.712488195399e+00 true resid norm 8.712488195394e+00 ||r(i)||/||b|| 2.081619716697e-04
1214 KSP unpreconditioned resid norm 8.712488191688e+00 true resid norm 8.712488191670e+00 ||r(i)||/||b|| 2.081619715807e-04
1215 KSP unpreconditioned resid norm 8.712488185952e+00 true resid norm 8.712488185950e+00 ||r(i)||/||b|| 2.081619714441e-04
1216 KSP unpreconditioned resid norm 8.712488182584e+00 true resid norm 8.712488182573e+00 ||r(i)||/||b|| 2.081619713634e-04
1217 KSP unpreconditioned resid norm 8.712488179909e+00 true resid norm 8.712488179893e+00 ||r(i)||/||b|| 2.081619712993e-04
1218 KSP unpreconditioned resid norm 8.712488176735e+00 true resid norm 8.712488176724e+00 ||r(i)||/||b|| 2.081619712236e-04
1219 KSP unpreconditioned resid norm 8.712488174240e+00 true resid norm 8.712488174240e+00 ||r(i)||/||b|| 2.081619711643e-04
1220 KSP unpreconditioned resid norm 8.712488174145e+00 true resid norm 8.712488174134e+00 ||r(i)||/||b|| 2.081619711618e-04
1221 KSP unpreconditioned resid norm 8.712488173810e+00 true resid norm 8.712488173799e+00 ||r(i)||/||b|| 2.081619711538e-04
1222 KSP unpreconditioned resid norm 8.712488170383e+00 true resid norm 8.712488170379e+00 ||r(i)||/||b|| 2.081619710720e-04
1223 KSP unpreconditioned resid norm 8.712488152925e+00 true resid norm 8.712488152915e+00 ||r(i)||/||b|| 2.081619706548e-04
1224 KSP unpreconditioned resid norm 8.712488130282e+00 true resid norm 8.712488130271e+00 ||r(i)||/||b|| 2.081619701138e-04
1225 KSP unpreconditioned resid norm 8.712488111355e+00 true resid norm 8.712488111360e+00 ||r(i)||/||b|| 2.081619696619e-04
1226 KSP unpreconditioned resid norm 8.712488089244e+00 true resid norm 8.712488089238e+00 ||r(i)||/||b|| 2.081619691334e-04
1227 KSP unpreconditioned resid norm 8.712488056262e+00 true resid norm 8.712488056259e+00 ||r(i)||/||b|| 2.081619683454e-04
1228 KSP unpreconditioned resid norm 8.712487976139e+00 true resid norm 8.712487976131e+00 ||r(i)||/||b|| 2.081619664310e-04
1229 KSP unpreconditioned resid norm 8.712487935275e+00 true resid norm 8.712487935258e+00 ||r(i)||/||b|| 2.081619654544e-04
1230 KSP unpreconditioned resid norm 8.712487932760e+00 true resid norm 8.712487932760e+00 ||r(i)||/||b|| 2.081619653948e-04
1231 KSP unpreconditioned resid norm 8.712487932749e+00 true resid norm 8.712487932743e+00 ||r(i)||/||b|| 2.081619653944e-04
1232 KSP unpreconditioned resid norm 8.712487932589e+00 true resid norm 8.712487932595e+00 ||r(i)||/||b|| 2.081619653908e-04
1233 KSP unpreconditioned resid norm 8.712487931750e+00 true resid norm 8.712487931753e+00 ||r(i)||/||b|| 2.081619653707e-04
1234 KSP unpreconditioned resid norm 8.712487929831e+00 true resid norm 8.712487929831e+00 ||r(i)||/||b|| 2.081619653248e-04
1235 KSP unpreconditioned resid norm 8.712487927510e+00 true resid norm 8.712487927508e+00 ||r(i)||/||b|| 2.081619652693e-04
1236 KSP unpreconditioned resid norm 8.712487926832e+00 true resid norm 8.712487926829e+00 ||r(i)||/||b|| 2.081619652531e-04
1237 KSP unpreconditioned resid norm 8.712487926507e+00 true resid norm 8.712487926505e+00 ||r(i)||/||b|| 2.081619652453e-04
1238 KSP unpreconditioned resid norm 8.712487925459e+00 true resid norm 8.712487925456e+00 ||r(i)||/||b|| 2.081619652202e-04
1239 KSP unpreconditioned resid norm 8.712487923324e+00 true resid norm 8.712487923322e+00 ||r(i)||/||b|| 2.081619651693e-04
1240 KSP unpreconditioned resid norm 8.712487921422e+00 true resid norm 8.712487921418e+00 ||r(i)||/||b|| 2.081619651238e-04
1241 KSP unpreconditioned resid norm 8.712487920966e+00 true resid norm 8.712487920960e+00 ||r(i)||/||b|| 2.081619651128e-04
1242 KSP unpreconditioned resid norm 8.712487920924e+00 true resid norm 8.712487920925e+00 ||r(i)||/||b|| 2.081619651120e-04
1243 KSP unpreconditioned resid norm 8.712487918920e+00 true resid norm 8.712487918923e+00 ||r(i)||/||b|| 2.081619650642e-04
1244 KSP unpreconditioned resid norm 8.712487915489e+00 true resid norm 8.712487915484e+00 ||r(i)||/||b|| 2.081619649820e-04
1245 KSP unpreconditioned resid norm 8.712487910800e+00 true resid norm 8.712487910802e+00 ||r(i)||/||b|| 2.081619648701e-04
1246 KSP unpreconditioned resid norm 8.712487907971e+00 true resid norm 8.712487907969e+00 ||r(i)||/||b|| 2.081619648024e-04
1247 KSP unpreconditioned resid norm 8.712487905382e+00 true resid norm 8.712487905380e+00 ||r(i)||/||b|| 2.081619647406e-04
1248 KSP unpreconditioned resid norm 8.712487902907e+00 true resid norm 8.712487902906e+00 ||r(i)||/||b|| 2.081619646815e-04
1249 KSP unpreconditioned resid norm 8.712487900486e+00 true resid norm 8.712487900484e+00 ||r(i)||/||b|| 2.081619646236e-04
1250 KSP unpreconditioned resid norm 8.712487900343e+00 true resid norm 8.712487900353e+00 ||r(i)||/||b|| 2.081619646205e-04
1251 KSP unpreconditioned resid norm 8.712487899968e+00 true resid norm 8.712487899961e+00 ||r(i)||/||b|| 2.081619646111e-04
1252 KSP unpreconditioned resid norm 8.712487897310e+00 true resid norm 8.712487897308e+00 ||r(i)||/||b|| 2.081619645477e-04
1253 KSP unpreconditioned resid norm 8.712487883149e+00 true resid norm 8.712487883153e+00 ||r(i)||/||b|| 2.081619642095e-04
1254 KSP unpreconditioned resid norm 8.712487863234e+00 true resid norm 8.712487863240e+00 ||r(i)||/||b|| 2.081619637338e-04
1255 KSP unpreconditioned resid norm 8.712487849021e+00 true resid norm 8.712487849027e+00 ||r(i)||/||b|| 2.081619633942e-04
1256 KSP unpreconditioned resid norm 8.712487830747e+00 true resid norm 8.712487830732e+00 ||r(i)||/||b|| 2.081619629571e-04
1257 KSP unpreconditioned resid norm 8.712487800462e+00 true resid norm 8.712487800450e+00 ||r(i)||/||b|| 2.081619622335e-04
1258 KSP unpreconditioned resid norm 8.712487730199e+00 true resid norm 8.712487730199e+00 ||r(i)||/||b|| 2.081619605551e-04
1259 KSP unpreconditioned resid norm 8.712487690771e+00 true resid norm 8.712487690765e+00 ||r(i)||/||b|| 2.081619596129e-04
1260 KSP unpreconditioned resid norm 8.712487687400e+00 true resid norm 8.712487687400e+00 ||r(i)||/||b|| 2.081619595325e-04
1261 KSP unpreconditioned resid norm 8.712487687386e+00 true resid norm 8.712487687388e+00 ||r(i)||/||b|| 2.081619595322e-04
1262 KSP unpreconditioned resid norm 8.712487687208e+00 true resid norm 8.712487687210e+00 ||r(i)||/||b|| 2.081619595280e-04
1263 KSP unpreconditioned resid norm 8.712487686405e+00 true resid norm 8.712487686401e+00 ||r(i)||/||b|| 2.081619595086e-04
1264 KSP unpreconditioned resid norm 8.712487684687e+00 true resid norm 8.712487684686e+00 ||r(i)||/||b|| 2.081619594677e-04
1265 KSP unpreconditioned resid norm 8.712487682655e+00 true resid norm 8.712487682655e+00 ||r(i)||/||b|| 2.081619594191e-04
1266 KSP unpreconditioned resid norm 8.712487682041e+00 true resid norm 8.712487682049e+00 ||r(i)||/||b|| 2.081619594047e-04
1267 KSP unpreconditioned resid norm 8.712487681703e+00 true resid norm 8.712487681708e+00 ||r(i)||/||b|| 2.081619593965e-04
1268 KSP unpreconditioned resid norm 8.712487680687e+00 true resid norm 8.712487680681e+00 ||r(i)||/||b|| 2.081619593720e-04
1269 KSP unpreconditioned resid norm 8.712487678882e+00 true resid norm 8.712487678891e+00 ||r(i)||/||b|| 2.081619593292e-04
1270 KSP unpreconditioned resid norm 8.712487677333e+00 true resid norm 8.712487677338e+00 ||r(i)||/||b|| 2.081619592921e-04
1271 KSP unpreconditioned resid norm 8.712487676915e+00 true resid norm 8.712487676915e+00 ||r(i)||/||b|| 2.081619592820e-04
1272 KSP unpreconditioned resid norm 8.712487676873e+00 true resid norm 8.712487676874e+00 ||r(i)||/||b|| 2.081619592810e-04
1273 KSP unpreconditioned resid norm 8.712487675030e+00 true resid norm 8.712487675035e+00 ||r(i)||/||b|| 2.081619592371e-04
1274 KSP unpreconditioned resid norm 8.712487672095e+00 true resid norm 8.712487672105e+00 ||r(i)||/||b|| 2.081619591671e-04
1275 KSP unpreconditioned resid norm 8.712487667649e+00 true resid norm 8.712487667652e+00 ||r(i)||/||b|| 2.081619590607e-04
1276 KSP unpreconditioned resid norm 8.712487665036e+00 true resid norm 8.712487665049e+00 ||r(i)||/||b|| 2.081619589985e-04
1277 KSP unpreconditioned resid norm 8.712487662916e+00 true resid norm 8.712487662915e+00 ||r(i)||/||b|| 2.081619589475e-04
1278 KSP unpreconditioned resid norm 8.712487660492e+00 true resid norm 8.712487660508e+00 ||r(i)||/||b|| 2.081619588900e-04
1279 KSP unpreconditioned resid norm 8.712487658511e+00 true resid norm 8.712487658517e+00 ||r(i)||/||b|| 2.081619588424e-04
1280 KSP unpreconditioned resid norm 8.712487658431e+00 true resid norm 8.712487658435e+00 ||r(i)||/||b|| 2.081619588405e-04
1281 KSP unpreconditioned resid norm 8.712487658148e+00 true resid norm 8.712487658163e+00 ||r(i)||/||b|| 2.081619588340e-04
1282 KSP unpreconditioned resid norm 8.712487655520e+00 true resid norm 8.712487655517e+00 ||r(i)||/||b|| 2.081619587708e-04
1283 KSP unpreconditioned resid norm 8.712487642024e+00 true resid norm 8.712487642026e+00 ||r(i)||/||b|| 2.081619584484e-04
1284 KSP unpreconditioned resid norm 8.712487624184e+00 true resid norm 8.712487624191e+00 ||r(i)||/||b|| 2.081619580223e-04
1285 KSP unpreconditioned resid norm 8.712487609706e+00 true resid norm 8.712487609716e+00 ||r(i)||/||b|| 2.081619576765e-04
1286 KSP unpreconditioned resid norm 8.712487592482e+00 true resid norm 8.712487592484e+00 ||r(i)||/||b|| 2.081619572647e-04
1287 KSP unpreconditioned resid norm 8.712487566418e+00 true resid norm 8.712487566419e+00 ||r(i)||/||b|| 2.081619566420e-04
1288 KSP unpreconditioned resid norm 8.712487503765e+00 true resid norm 8.712487503769e+00 ||r(i)||/||b|| 2.081619551451e-04
1289 KSP unpreconditioned resid norm 8.712487471373e+00 true resid norm 8.712487471366e+00 ||r(i)||/||b|| 2.081619543709e-04
1290 KSP unpreconditioned resid norm 8.712487469365e+00 true resid norm 8.712487469365e+00 ||r(i)||/||b|| 2.081619543232e-04
1291 KSP unpreconditioned resid norm 8.712487469357e+00 true resid norm 8.712487469354e+00 ||r(i)||/||b|| 2.081619543229e-04
1292 KSP unpreconditioned resid norm 8.712487469229e+00 true resid norm 8.712487469222e+00 ||r(i)||/||b|| 2.081619543197e-04
1293 KSP unpreconditioned resid norm 8.712487468568e+00 true resid norm 8.712487468553e+00 ||r(i)||/||b|| 2.081619543037e-04
1294 KSP unpreconditioned resid norm 8.712487467062e+00 true resid norm 8.712487467058e+00 ||r(i)||/||b|| 2.081619542680e-04
1295 KSP unpreconditioned resid norm 8.712487465244e+00 true resid norm 8.712487465231e+00 ||r(i)||/||b|| 2.081619542244e-04
1296 KSP unpreconditioned resid norm 8.712487464716e+00 true resid norm 8.712487464713e+00 ||r(i)||/||b|| 2.081619542120e-04
1297 KSP unpreconditioned resid norm 8.712487464462e+00 true resid norm 8.712487464451e+00 ||r(i)||/||b|| 2.081619542058e-04
1298 KSP unpreconditioned resid norm 8.712487463639e+00 true resid norm 8.712487463630e+00 ||r(i)||/||b|| 2.081619541861e-04
1299 KSP unpreconditioned resid norm 8.712487461970e+00 true resid norm 8.712487461966e+00 ||r(i)||/||b|| 2.081619541464e-04
1300 KSP unpreconditioned resid norm 8.712487460488e+00 true resid norm 8.712487460486e+00 ||r(i)||/||b|| 2.081619541110e-04
1301 KSP unpreconditioned resid norm 8.712487460129e+00 true resid norm 8.712487460127e+00 ||r(i)||/||b|| 2.081619541024e-04
1302 KSP unpreconditioned resid norm 8.712487460096e+00 true resid norm 8.712487460096e+00 ||r(i)||/||b|| 2.081619541017e-04
1303 KSP unpreconditioned resid norm 8.712487458521e+00 true resid norm 8.712487458509e+00 ||r(i)||/||b|| 2.081619540638e-04
1304 KSP unpreconditioned resid norm 8.712487455850e+00 true resid norm 8.712487455846e+00 ||r(i)||/||b|| 2.081619540002e-04
1305 KSP unpreconditioned resid norm 8.712487452168e+00 true resid norm 8.712487452170e+00 ||r(i)||/||b|| 2.081619539123e-04
1306 KSP unpreconditioned resid norm 8.712487449946e+00 true resid norm 8.712487449940e+00 ||r(i)||/||b|| 2.081619538590e-04
1307 KSP unpreconditioned resid norm 8.712487447947e+00 true resid norm 8.712487447936e+00 ||r(i)||/||b|| 2.081619538112e-04
1308 KSP unpreconditioned resid norm 8.712487445986e+00 true resid norm 8.712487445982e+00 ||r(i)||/||b|| 2.081619537645e-04
1309 KSP unpreconditioned resid norm 8.712487444096e+00 true resid norm 8.712487444093e+00 ||r(i)||/||b|| 2.081619537193e-04
1310 KSP unpreconditioned resid norm 8.712487443992e+00 true resid norm 8.712487443997e+00 ||r(i)||/||b|| 2.081619537171e-04
1311 KSP unpreconditioned resid norm 8.712487443708e+00 true resid norm 8.712487443691e+00 ||r(i)||/||b|| 2.081619537097e-04
1312 KSP unpreconditioned resid norm 8.712487441613e+00 true resid norm 8.712487441606e+00 ||r(i)||/||b|| 2.081619536599e-04
1313 KSP unpreconditioned resid norm 8.712487430476e+00 true resid norm 8.712487430469e+00 ||r(i)||/||b|| 2.081619533938e-04
1314 KSP unpreconditioned resid norm 8.712487415014e+00 true resid norm 8.712487415004e+00 ||r(i)||/||b|| 2.081619530243e-04
1315 KSP unpreconditioned resid norm 8.712487403719e+00 true resid norm 8.712487403708e+00 ||r(i)||/||b|| 2.081619527545e-04
1316 KSP unpreconditioned resid norm 8.712487389387e+00 true resid norm 8.712487389382e+00 ||r(i)||/||b|| 2.081619524122e-04
1317 KSP unpreconditioned resid norm 8.712487365821e+00 true resid norm 8.712487365817e+00 ||r(i)||/||b|| 2.081619518492e-04
1318 KSP unpreconditioned resid norm 8.712487310484e+00 true resid norm 8.712487310479e+00 ||r(i)||/||b|| 2.081619505270e-04
1319 KSP unpreconditioned resid norm 8.712487279726e+00 true resid norm 8.712487279717e+00 ||r(i)||/||b|| 2.081619497920e-04
1320 KSP unpreconditioned resid norm 8.712487277171e+00 true resid norm 8.712487277171e+00 ||r(i)||/||b|| 2.081619497312e-04
1321 KSP unpreconditioned resid norm 8.712487277160e+00 true resid norm 8.712487277164e+00 ||r(i)||/||b|| 2.081619497310e-04
1322 KSP unpreconditioned resid norm 8.712487277024e+00 true resid norm 8.712487277021e+00 ||r(i)||/||b|| 2.081619497276e-04
1323 KSP unpreconditioned resid norm 8.712487276397e+00 true resid norm 8.712487276395e+00 ||r(i)||/||b|| 2.081619497126e-04
1324 KSP unpreconditioned resid norm 8.712487275050e+00 true resid norm 8.712487275057e+00 ||r(i)||/||b|| 2.081619496807e-04
1325 KSP unpreconditioned resid norm 8.712487273457e+00 true resid norm 8.712487273456e+00 ||r(i)||/||b|| 2.081619496424e-04
1326 KSP unpreconditioned resid norm 8.712487272979e+00 true resid norm 8.712487272966e+00 ||r(i)||/||b|| 2.081619496307e-04
1327 KSP unpreconditioned resid norm 8.712487272722e+00 true resid norm 8.712487272724e+00 ||r(i)||/||b|| 2.081619496249e-04
1328 KSP unpreconditioned resid norm 8.712487271935e+00 true resid norm 8.712487271933e+00 ||r(i)||/||b|| 2.081619496060e-04
1329 KSP unpreconditioned resid norm 8.712487270514e+00 true resid norm 8.712487270515e+00 ||r(i)||/||b|| 2.081619495721e-04
1330 KSP unpreconditioned resid norm 8.712487269291e+00 true resid norm 8.712487269283e+00 ||r(i)||/||b|| 2.081619495427e-04
1331 KSP unpreconditioned resid norm 8.712487268966e+00 true resid norm 8.712487268967e+00 ||r(i)||/||b|| 2.081619495352e-04
1332 KSP unpreconditioned resid norm 8.712487268934e+00 true resid norm 8.712487268938e+00 ||r(i)||/||b|| 2.081619495345e-04
1333 KSP unpreconditioned resid norm 8.712487267499e+00 true resid norm 8.712487267497e+00 ||r(i)||/||b|| 2.081619495000e-04
1334 KSP unpreconditioned resid norm 8.712487265190e+00 true resid norm 8.712487265187e+00 ||r(i)||/||b|| 2.081619494449e-04
1335 KSP unpreconditioned resid norm 8.712487261734e+00 true resid norm 8.712487261727e+00 ||r(i)||/||b|| 2.081619493622e-04
1336 KSP unpreconditioned resid norm 8.712487259702e+00 true resid norm 8.712487259690e+00 ||r(i)||/||b|| 2.081619493135e-04
1337 KSP unpreconditioned resid norm 8.712487258030e+00 true resid norm 8.712487258017e+00 ||r(i)||/||b|| 2.081619492735e-04
1338 KSP unpreconditioned resid norm 8.712487256160e+00 true resid norm 8.712487256153e+00 ||r(i)||/||b|| 2.081619492290e-04
1339 KSP unpreconditioned resid norm 8.712487254597e+00 true resid norm 8.712487254599e+00 ||r(i)||/||b|| 2.081619491919e-04
1340 KSP unpreconditioned resid norm 8.712487254531e+00 true resid norm 8.712487254530e+00 ||r(i)||/||b|| 2.081619491902e-04
1341 KSP unpreconditioned resid norm 8.712487254301e+00 true resid norm 8.712487254292e+00 ||r(i)||/||b|| 2.081619491845e-04
1342 KSP unpreconditioned resid norm 8.712487252271e+00 true resid norm 8.712487252267e+00 ||r(i)||/||b|| 2.081619491362e-04
1343 KSP unpreconditioned resid norm 8.712487241798e+00 true resid norm 8.712487241792e+00 ||r(i)||/||b|| 2.081619488859e-04
1344 KSP unpreconditioned resid norm 8.712487227808e+00 true resid norm 8.712487227802e+00 ||r(i)||/||b|| 2.081619485516e-04
1345 KSP unpreconditioned resid norm 8.712487216650e+00 true resid norm 8.712487216641e+00 ||r(i)||/||b|| 2.081619482850e-04
1346 KSP unpreconditioned resid norm 8.712487203226e+00 true resid norm 8.712487203225e+00 ||r(i)||/||b|| 2.081619479644e-04
1347 KSP unpreconditioned resid norm 8.712487182714e+00 true resid norm 8.712487182709e+00 ||r(i)||/||b|| 2.081619474743e-04
1348 KSP unpreconditioned resid norm 8.712487133680e+00 true resid norm 8.712487133683e+00 ||r(i)||/||b|| 2.081619463029e-04
1349 KSP unpreconditioned resid norm 8.712487108099e+00 true resid norm 8.712487108097e+00 ||r(i)||/||b|| 2.081619456916e-04
1350 KSP unpreconditioned resid norm 8.712487106485e+00 true resid norm 8.712487106485e+00 ||r(i)||/||b|| 2.081619456531e-04
1351 KSP unpreconditioned resid norm 8.712487106479e+00 true resid norm 8.712487106480e+00 ||r(i)||/||b|| 2.081619456530e-04
1352 KSP unpreconditioned resid norm 8.712487106377e+00 true resid norm 8.712487106383e+00 ||r(i)||/||b|| 2.081619456507e-04
1353 KSP unpreconditioned resid norm 8.712487105857e+00 true resid norm 8.712487105852e+00 ||r(i)||/||b|| 2.081619456380e-04
1354 KSP unpreconditioned resid norm 8.712487104677e+00 true resid norm 8.712487104678e+00 ||r(i)||/||b|| 2.081619456099e-04
1355 KSP unpreconditioned resid norm 8.712487103254e+00 true resid norm 8.712487103245e+00 ||r(i)||/||b|| 2.081619455757e-04
1356 KSP unpreconditioned resid norm 8.712487102842e+00 true resid norm 8.712487102845e+00 ||r(i)||/||b|| 2.081619455661e-04
1357 KSP unpreconditioned resid norm 8.712487102642e+00 true resid norm 8.712487102634e+00 ||r(i)||/||b|| 2.081619455611e-04
1358 KSP unpreconditioned resid norm 8.712487101996e+00 true resid norm 8.712487101991e+00 ||r(i)||/||b|| 2.081619455457e-04
1359 KSP unpreconditioned resid norm 8.712487100693e+00 true resid norm 8.712487100694e+00 ||r(i)||/||b|| 2.081619455147e-04
1360 KSP unpreconditioned resid norm 8.712487099538e+00 true resid norm 8.712487099525e+00 ||r(i)||/||b|| 2.081619454868e-04
1361 KSP unpreconditioned resid norm 8.712487099256e+00 true resid norm 8.712487099249e+00 ||r(i)||/||b|| 2.081619454802e-04
1362 KSP unpreconditioned resid norm 8.712487099230e+00 true resid norm 8.712487099226e+00 ||r(i)||/||b|| 2.081619454797e-04
1363 KSP unpreconditioned resid norm 8.712487097994e+00 true resid norm 8.712487097985e+00 ||r(i)||/||b|| 2.081619454500e-04
1364 KSP unpreconditioned resid norm 8.712487095912e+00 true resid norm 8.712487095911e+00 ||r(i)||/||b|| 2.081619454004e-04
1365 KSP unpreconditioned resid norm 8.712487093021e+00 true resid norm 8.712487093008e+00 ||r(i)||/||b|| 2.081619453311e-04
1366 KSP unpreconditioned resid norm 8.712487091278e+00 true resid norm 8.712487091288e+00 ||r(i)||/||b|| 2.081619452900e-04
1367 KSP unpreconditioned resid norm 8.712487089727e+00 true resid norm 8.712487089729e+00 ||r(i)||/||b|| 2.081619452528e-04
1368 KSP unpreconditioned resid norm 8.712487088181e+00 true resid norm 8.712487088180e+00 ||r(i)||/||b|| 2.081619452157e-04
1369 KSP unpreconditioned resid norm 8.712487086706e+00 true resid norm 8.712487086704e+00 ||r(i)||/||b|| 2.081619451805e-04
1370 KSP unpreconditioned resid norm 8.712487086629e+00 true resid norm 8.712487086627e+00 ||r(i)||/||b|| 2.081619451786e-04
1371 KSP unpreconditioned resid norm 8.712487086411e+00 true resid norm 8.712487086401e+00 ||r(i)||/||b|| 2.081619451732e-04
1372 KSP unpreconditioned resid norm 8.712487084763e+00 true resid norm 8.712487084761e+00 ||r(i)||/||b|| 2.081619451340e-04
1373 KSP unpreconditioned resid norm 8.712487076017e+00 true resid norm 8.712487076012e+00 ||r(i)||/||b|| 2.081619449250e-04
1374 KSP unpreconditioned resid norm 8.712487063965e+00 true resid norm 8.712487063965e+00 ||r(i)||/||b|| 2.081619446372e-04
1375 KSP unpreconditioned resid norm 8.712487055038e+00 true resid norm 8.712487055043e+00 ||r(i)||/||b|| 2.081619444240e-04
1376 KSP unpreconditioned resid norm 8.712487043796e+00 true resid norm 8.712487043799e+00 ||r(i)||/||b|| 2.081619441554e-04
1377 KSP unpreconditioned resid norm 8.712487025410e+00 true resid norm 8.712487025418e+00 ||r(i)||/||b|| 2.081619437162e-04
1378 KSP unpreconditioned resid norm 8.712486981951e+00 true resid norm 8.712486981949e+00 ||r(i)||/||b|| 2.081619426776e-04
1379 KSP unpreconditioned resid norm 8.712486957939e+00 true resid norm 8.712486957943e+00 ||r(i)||/||b|| 2.081619421041e-04
1380 KSP unpreconditioned resid norm 8.712486955984e+00 true resid norm 8.712486955984e+00 ||r(i)||/||b|| 2.081619420573e-04
1381 KSP unpreconditioned resid norm 8.712486955976e+00 true resid norm 8.712486955982e+00 ||r(i)||/||b|| 2.081619420572e-04
1382 KSP unpreconditioned resid norm 8.712486955870e+00 true resid norm 8.712486955864e+00 ||r(i)||/||b|| 2.081619420544e-04
1383 KSP unpreconditioned resid norm 8.712486955381e+00 true resid norm 8.712486955380e+00 ||r(i)||/||b|| 2.081619420428e-04
1384 KSP unpreconditioned resid norm 8.712486954326e+00 true resid norm 8.712486954319e+00 ||r(i)||/||b|| 2.081619420175e-04
1385 KSP unpreconditioned resid norm 8.712486953079e+00 true resid norm 8.712486953085e+00 ||r(i)||/||b|| 2.081619419880e-04
1386 KSP unpreconditioned resid norm 8.712486952707e+00 true resid norm 8.712486952711e+00 ||r(i)||/||b|| 2.081619419791e-04
1387 KSP unpreconditioned resid norm 8.712486952509e+00 true resid norm 8.712486952516e+00 ||r(i)||/||b|| 2.081619419744e-04
1388 KSP unpreconditioned resid norm 8.712486951897e+00 true resid norm 8.712486951891e+00 ||r(i)||/||b|| 2.081619419595e-04
1389 KSP unpreconditioned resid norm 8.712486950782e+00 true resid norm 8.712486950795e+00 ||r(i)||/||b|| 2.081619419333e-04
1390 KSP unpreconditioned resid norm 8.712486949819e+00 true resid norm 8.712486949822e+00 ||r(i)||/||b|| 2.081619419100e-04
1391 KSP unpreconditioned resid norm 8.712486949566e+00 true resid norm 8.712486949571e+00 ||r(i)||/||b|| 2.081619419040e-04
1392 KSP unpreconditioned resid norm 8.712486949541e+00 true resid norm 8.712486949545e+00 ||r(i)||/||b|| 2.081619419034e-04
1393 KSP unpreconditioned resid norm 8.712486948422e+00 true resid norm 8.712486948423e+00 ||r(i)||/||b|| 2.081619418766e-04
1394 KSP unpreconditioned resid norm 8.712486946610e+00 true resid norm 8.712486946609e+00 ||r(i)||/||b|| 2.081619418333e-04
1395 KSP unpreconditioned resid norm 8.712486943919e+00 true resid norm 8.712486943913e+00 ||r(i)||/||b|| 2.081619417689e-04
1396 KSP unpreconditioned resid norm 8.712486942336e+00 true resid norm 8.712486942340e+00 ||r(i)||/||b|| 2.081619417313e-04
1397 KSP unpreconditioned resid norm 8.712486941022e+00 true resid norm 8.712486941013e+00 ||r(i)||/||b|| 2.081619416996e-04
1398 KSP unpreconditioned resid norm 8.712486939572e+00 true resid norm 8.712486939577e+00 ||r(i)||/||b|| 2.081619416653e-04
1399 KSP unpreconditioned resid norm 8.712486938341e+00 true resid norm 8.712486938349e+00 ||r(i)||/||b|| 2.081619416359e-04
1400 KSP unpreconditioned resid norm 8.712486938288e+00 true resid norm 8.712486938282e+00 ||r(i)||/||b|| 2.081619416343e-04
1401 KSP unpreconditioned resid norm 8.712486938105e+00 true resid norm 8.712486938104e+00 ||r(i)||/||b|| 2.081619416301e-04
1402 KSP unpreconditioned resid norm 8.712486936530e+00 true resid norm 8.712486936532e+00 ||r(i)||/||b|| 2.081619415925e-04
1403 KSP unpreconditioned resid norm 8.712486928386e+00 true resid norm 8.712486928388e+00 ||r(i)||/||b|| 2.081619413979e-04
1404 KSP unpreconditioned resid norm 8.712486917441e+00 true resid norm 8.712486917432e+00 ||r(i)||/||b|| 2.081619411362e-04
1405 KSP unpreconditioned resid norm 8.712486908802e+00 true resid norm 8.712486908801e+00 ||r(i)||/||b|| 2.081619409300e-04
1406 KSP unpreconditioned resid norm 8.712486898336e+00 true resid norm 8.712486898350e+00 ||r(i)||/||b|| 2.081619406802e-04
1407 KSP unpreconditioned resid norm 8.712486882233e+00 true resid norm 8.712486882228e+00 ||r(i)||/||b|| 2.081619402951e-04
1408 KSP unpreconditioned resid norm 8.712486843844e+00 true resid norm 8.712486843853e+00 ||r(i)||/||b|| 2.081619393782e-04
1409 KSP unpreconditioned resid norm 8.712486823690e+00 true resid norm 8.712486823687e+00 ||r(i)||/||b|| 2.081619388964e-04
1410 KSP unpreconditioned resid norm 8.712486822389e+00 true resid norm 8.712486822389e+00 ||r(i)||/||b|| 2.081619388654e-04
1411 KSP unpreconditioned resid norm 8.712486822383e+00 true resid norm 8.712486822387e+00 ||r(i)||/||b|| 2.081619388653e-04
1412 KSP unpreconditioned resid norm 8.712486822303e+00 true resid norm 8.712486822305e+00 ||r(i)||/||b|| 2.081619388633e-04
1413 KSP unpreconditioned resid norm 8.712486821894e+00 true resid norm 8.712486821903e+00 ||r(i)||/||b|| 2.081619388538e-04
1414 KSP unpreconditioned resid norm 8.712486820969e+00 true resid norm 8.712486820969e+00 ||r(i)||/||b|| 2.081619388314e-04
1415 KSP unpreconditioned resid norm 8.712486819857e+00 true resid norm 8.712486819861e+00 ||r(i)||/||b|| 2.081619388050e-04
1416 KSP unpreconditioned resid norm 8.712486819535e+00 true resid norm 8.712486819537e+00 ||r(i)||/||b|| 2.081619387972e-04
1417 KSP unpreconditioned resid norm 8.712486819378e+00 true resid norm 8.712486819374e+00 ||r(i)||/||b|| 2.081619387933e-04
1418 KSP unpreconditioned resid norm 8.712486818871e+00 true resid norm 8.712486818887e+00 ||r(i)||/||b|| 2.081619387817e-04
1419 KSP unpreconditioned resid norm 8.712486817853e+00 true resid norm 8.712486817854e+00 ||r(i)||/||b|| 2.081619387570e-04
1420 KSP unpreconditioned resid norm 8.712486816953e+00 true resid norm 8.712486816957e+00 ||r(i)||/||b|| 2.081619387356e-04
1421 KSP unpreconditioned resid norm 8.712486816731e+00 true resid norm 8.712486816741e+00 ||r(i)||/||b|| 2.081619387304e-04
1422 KSP unpreconditioned resid norm 8.712486816711e+00 true resid norm 8.712486816728e+00 ||r(i)||/||b|| 2.081619387301e-04
1423 KSP unpreconditioned resid norm 8.712486815742e+00 true resid norm 8.712486815741e+00 ||r(i)||/||b|| 2.081619387065e-04
1424 KSP unpreconditioned resid norm 8.712486814118e+00 true resid norm 8.712486814124e+00 ||r(i)||/||b|| 2.081619386679e-04
1425 KSP unpreconditioned resid norm 8.712486811850e+00 true resid norm 8.712486811849e+00 ||r(i)||/||b|| 2.081619386135e-04
1426 KSP unpreconditioned resid norm 8.712486810484e+00 true resid norm 8.712486810493e+00 ||r(i)||/||b|| 2.081619385811e-04
1427 KSP unpreconditioned resid norm 8.712486809277e+00 true resid norm 8.712486809282e+00 ||r(i)||/||b|| 2.081619385522e-04
1428 KSP unpreconditioned resid norm 8.712486808061e+00 true resid norm 8.712486808069e+00 ||r(i)||/||b|| 2.081619385232e-04
1429 KSP unpreconditioned resid norm 8.712486806911e+00 true resid norm 8.712486806922e+00 ||r(i)||/||b|| 2.081619384958e-04
1430 KSP unpreconditioned resid norm 8.712486806852e+00 true resid norm 8.712486806862e+00 ||r(i)||/||b|| 2.081619384944e-04
1431 KSP unpreconditioned resid norm 8.712486806683e+00 true resid norm 8.712486806691e+00 ||r(i)||/||b|| 2.081619384903e-04
1432 KSP unpreconditioned resid norm 8.712486805388e+00 true resid norm 8.712486805398e+00 ||r(i)||/||b|| 2.081619384594e-04
1433 KSP unpreconditioned resid norm 8.712486798526e+00 true resid norm 8.712486798525e+00 ||r(i)||/||b|| 2.081619382952e-04
1434 KSP unpreconditioned resid norm 8.712486789112e+00 true resid norm 8.712486789121e+00 ||r(i)||/||b|| 2.081619380705e-04
1435 KSP unpreconditioned resid norm 8.712486782080e+00 true resid norm 8.712486782084e+00 ||r(i)||/||b|| 2.081619379024e-04
1436 KSP unpreconditioned resid norm 8.712486773262e+00 true resid norm 8.712486773264e+00 ||r(i)||/||b|| 2.081619376917e-04
1437 KSP unpreconditioned resid norm 8.712486758899e+00 true resid norm 8.712486758888e+00 ||r(i)||/||b|| 2.081619373482e-04
1438 KSP unpreconditioned resid norm 8.712486724823e+00 true resid norm 8.712486724826e+00 ||r(i)||/||b|| 2.081619365344e-04
1439 KSP unpreconditioned resid norm 8.712486706071e+00 true resid norm 8.712486706061e+00 ||r(i)||/||b|| 2.081619360860e-04
1440 KSP unpreconditioned resid norm 8.712486704580e+00 true resid norm 8.712486704580e+00 ||r(i)||/||b|| 2.081619360506e-04
1441 KSP unpreconditioned resid norm 8.712486704573e+00 true resid norm 8.712486704569e+00 ||r(i)||/||b|| 2.081619360504e-04
1442 KSP unpreconditioned resid norm 8.712486704491e+00 true resid norm 8.712486704478e+00 ||r(i)||/||b|| 2.081619360482e-04
1443 KSP unpreconditioned resid norm 8.712486704110e+00 true resid norm 8.712486704108e+00 ||r(i)||/||b|| 2.081619360394e-04
1444 KSP unpreconditioned resid norm 8.712486703284e+00 true resid norm 8.712486703280e+00 ||r(i)||/||b|| 2.081619360196e-04
1445 KSP unpreconditioned resid norm 8.712486702308e+00 true resid norm 8.712486702299e+00 ||r(i)||/||b|| 2.081619359961e-04
1446 KSP unpreconditioned resid norm 8.712486702018e+00 true resid norm 8.712486702009e+00 ||r(i)||/||b|| 2.081619359892e-04
1447 KSP unpreconditioned resid norm 8.712486701865e+00 true resid norm 8.712486701861e+00 ||r(i)||/||b|| 2.081619359857e-04
1448 KSP unpreconditioned resid norm 8.712486701389e+00 true resid norm 8.712486701379e+00 ||r(i)||/||b|| 2.081619359742e-04
1449 KSP unpreconditioned resid norm 8.712486700514e+00 true resid norm 8.712486700515e+00 ||r(i)||/||b|| 2.081619359535e-04
1450 KSP unpreconditioned resid norm 8.712486699757e+00 true resid norm 8.712486699750e+00 ||r(i)||/||b|| 2.081619359352e-04
1451 KSP unpreconditioned resid norm 8.712486699560e+00 true resid norm 8.712486699552e+00 ||r(i)||/||b|| 2.081619359305e-04
1452 KSP unpreconditioned resid norm 8.712486699540e+00 true resid norm 8.712486699538e+00 ||r(i)||/||b|| 2.081619359302e-04
1453 KSP unpreconditioned resid norm 8.712486698667e+00 true resid norm 8.712486698665e+00 ||r(i)||/||b|| 2.081619359093e-04
1454 KSP unpreconditioned resid norm 8.712486697248e+00 true resid norm 8.712486697238e+00 ||r(i)||/||b|| 2.081619358752e-04
1455 KSP unpreconditioned resid norm 8.712486695150e+00 true resid norm 8.712486695136e+00 ||r(i)||/||b|| 2.081619358250e-04
1456 KSP unpreconditioned resid norm 8.712486693915e+00 true resid norm 8.712486693910e+00 ||r(i)||/||b|| 2.081619357957e-04
1457 KSP unpreconditioned resid norm 8.712486692884e+00 true resid norm 8.712486692879e+00 ||r(i)||/||b|| 2.081619357711e-04
1458 KSP unpreconditioned resid norm 8.712486691756e+00 true resid norm 8.712486691752e+00 ||r(i)||/||b|| 2.081619357441e-04
1459 KSP unpreconditioned resid norm 8.712486690789e+00 true resid norm 8.712486690781e+00 ||r(i)||/||b|| 2.081619357209e-04
1460 KSP unpreconditioned resid norm 8.712486690747e+00 true resid norm 8.712486690739e+00 ||r(i)||/||b|| 2.081619357199e-04
1461 KSP unpreconditioned resid norm 8.712486690602e+00 true resid norm 8.712486690586e+00 ||r(i)||/||b|| 2.081619357163e-04
1462 KSP unpreconditioned resid norm 8.712486689378e+00 true resid norm 8.712486689375e+00 ||r(i)||/||b|| 2.081619356873e-04
1463 KSP unpreconditioned resid norm 8.712486683035e+00 true resid norm 8.712486683035e+00 ||r(i)||/||b|| 2.081619355359e-04
1464 KSP unpreconditioned resid norm 8.712486674483e+00 true resid norm 8.712486674479e+00 ||r(i)||/||b|| 2.081619353314e-04
1465 KSP unpreconditioned resid norm 8.712486667776e+00 true resid norm 8.712486667775e+00 ||r(i)||/||b|| 2.081619351713e-04
1466 KSP unpreconditioned resid norm 8.712486659614e+00 true resid norm 8.712486659599e+00 ||r(i)||/||b|| 2.081619349759e-04
1467 KSP unpreconditioned resid norm 8.712486646989e+00 true resid norm 8.712486646980e+00 ||r(i)||/||b|| 2.081619346744e-04
1468 KSP unpreconditioned resid norm 8.712486616933e+00 true resid norm 8.712486616931e+00 ||r(i)||/||b|| 2.081619339565e-04
1469 KSP unpreconditioned resid norm 8.712486601081e+00 true resid norm 8.712486601069e+00 ||r(i)||/||b|| 2.081619335775e-04
1470 KSP unpreconditioned resid norm 8.712486600032e+00 true resid norm 8.712486600032e+00 ||r(i)||/||b|| 2.081619335527e-04
1471 KSP unpreconditioned resid norm 8.712486600028e+00 true resid norm 8.712486600032e+00 ||r(i)||/||b|| 2.081619335527e-04
1472 KSP unpreconditioned resid norm 8.712486599965e+00 true resid norm 8.712486599972e+00 ||r(i)||/||b|| 2.081619335513e-04
1473 KSP unpreconditioned resid norm 8.712486599643e+00 true resid norm 8.712486599653e+00 ||r(i)||/||b|| 2.081619335437e-04
1474 KSP unpreconditioned resid norm 8.712486598919e+00 true resid norm 8.712486598923e+00 ||r(i)||/||b|| 2.081619335262e-04
1475 KSP unpreconditioned resid norm 8.712486598049e+00 true resid norm 8.712486598055e+00 ||r(i)||/||b|| 2.081619335055e-04
1476 KSP unpreconditioned resid norm 8.712486597797e+00 true resid norm 8.712486597794e+00 ||r(i)||/||b|| 2.081619334993e-04
1477 KSP unpreconditioned resid norm 8.712486597674e+00 true resid norm 8.712486597678e+00 ||r(i)||/||b|| 2.081619334965e-04
1478 KSP unpreconditioned resid norm 8.712486597276e+00 true resid norm 8.712486597285e+00 ||r(i)||/||b|| 2.081619334871e-04
1479 KSP unpreconditioned resid norm 8.712486596482e+00 true resid norm 8.712486596487e+00 ||r(i)||/||b|| 2.081619334680e-04
1480 KSP unpreconditioned resid norm 8.712486595780e+00 true resid norm 8.712486595789e+00 ||r(i)||/||b|| 2.081619334513e-04
1481 KSP unpreconditioned resid norm 8.712486595606e+00 true resid norm 8.712486595612e+00 ||r(i)||/||b|| 2.081619334471e-04
1482 KSP unpreconditioned resid norm 8.712486595590e+00 true resid norm 8.712486595600e+00 ||r(i)||/||b|| 2.081619334468e-04
1483 KSP unpreconditioned resid norm 8.712486594831e+00 true resid norm 8.712486594841e+00 ||r(i)||/||b|| 2.081619334287e-04
1484 KSP unpreconditioned resid norm 8.712486593563e+00 true resid norm 8.712486593565e+00 ||r(i)||/||b|| 2.081619333982e-04
1485 KSP unpreconditioned resid norm 8.712486591784e+00 true resid norm 8.712486591780e+00 ||r(i)||/||b|| 2.081619333556e-04
1486 KSP unpreconditioned resid norm 8.712486590714e+00 true resid norm 8.712486590716e+00 ||r(i)||/||b|| 2.081619333301e-04
1487 KSP unpreconditioned resid norm 8.712486589774e+00 true resid norm 8.712486589778e+00 ||r(i)||/||b|| 2.081619333077e-04
1488 KSP unpreconditioned resid norm 8.712486588818e+00 true resid norm 8.712486588807e+00 ||r(i)||/||b|| 2.081619332845e-04
1489 KSP unpreconditioned resid norm 8.712486587922e+00 true resid norm 8.712486587929e+00 ||r(i)||/||b|| 2.081619332636e-04
1490 KSP unpreconditioned resid norm 8.712486587876e+00 true resid norm 8.712486587884e+00 ||r(i)||/||b|| 2.081619332625e-04
1491 KSP unpreconditioned resid norm 8.712486587745e+00 true resid norm 8.712486587750e+00 ||r(i)||/||b|| 2.081619332593e-04
1492 KSP unpreconditioned resid norm 8.712486586728e+00 true resid norm 8.712486586732e+00 ||r(i)||/||b|| 2.081619332350e-04
1493 KSP unpreconditioned resid norm 8.712486581348e+00 true resid norm 8.712486581351e+00 ||r(i)||/||b|| 2.081619331064e-04
1494 KSP unpreconditioned resid norm 8.712486573987e+00 true resid norm 8.712486573985e+00 ||r(i)||/||b|| 2.081619329304e-04
1495 KSP unpreconditioned resid norm 8.712486568457e+00 true resid norm 8.712486568465e+00 ||r(i)||/||b|| 2.081619327985e-04
1496 KSP unpreconditioned resid norm 8.712486561543e+00 true resid norm 8.712486561539e+00 ||r(i)||/||b|| 2.081619326330e-04
1497 KSP unpreconditioned resid norm 8.712486550314e+00 true resid norm 8.712486550313e+00 ||r(i)||/||b|| 2.081619323648e-04
1498 KSP unpreconditioned resid norm 8.712486523621e+00 true resid norm 8.712486523621e+00 ||r(i)||/||b|| 2.081619317271e-04
1499 KSP unpreconditioned resid norm 8.712486508974e+00 true resid norm 8.712486508974e+00 ||r(i)||/||b|| 2.081619313771e-04
1500 KSP unpreconditioned resid norm 8.712486507813e+00 true resid norm 8.712486507813e+00 ||r(i)||/||b|| 2.081619313494e-04
1501 KSP unpreconditioned resid norm 8.712486507808e+00 true resid norm 8.712486507810e+00 ||r(i)||/||b|| 2.081619313493e-04
1502 KSP unpreconditioned resid norm 8.712486507744e+00 true resid norm 8.712486507740e+00 ||r(i)||/||b|| 2.081619313476e-04
1503 KSP unpreconditioned resid norm 8.712486507447e+00 true resid norm 8.712486507447e+00 ||r(i)||/||b|| 2.081619313406e-04
1504 KSP unpreconditioned resid norm 8.712486506800e+00 true resid norm 8.712486506811e+00 ||r(i)||/||b|| 2.081619313255e-04
1505 KSP unpreconditioned resid norm 8.712486506037e+00 true resid norm 8.712486506035e+00 ||r(i)||/||b|| 2.081619313069e-04
1506 KSP unpreconditioned resid norm 8.712486505810e+00 true resid norm 8.712486505804e+00 ||r(i)||/||b|| 2.081619313014e-04
1507 KSP unpreconditioned resid norm 8.712486505692e+00 true resid norm 8.712486505686e+00 ||r(i)||/||b|| 2.081619312986e-04
1508 KSP unpreconditioned resid norm 8.712486505321e+00 true resid norm 8.712486505327e+00 ||r(i)||/||b|| 2.081619312900e-04
1509 KSP unpreconditioned resid norm 8.712486504636e+00 true resid norm 8.712486504635e+00 ||r(i)||/||b|| 2.081619312735e-04
1510 KSP unpreconditioned resid norm 8.712486504042e+00 true resid norm 8.712486504046e+00 ||r(i)||/||b|| 2.081619312594e-04
1511 KSP unpreconditioned resid norm 8.712486503887e+00 true resid norm 8.712486503893e+00 ||r(i)||/||b|| 2.081619312557e-04
1512 KSP unpreconditioned resid norm 8.712486503872e+00 true resid norm 8.712486503878e+00 ||r(i)||/||b|| 2.081619312554e-04
1513 KSP unpreconditioned resid norm 8.712486503190e+00 true resid norm 8.712486503195e+00 ||r(i)||/||b|| 2.081619312391e-04
1514 KSP unpreconditioned resid norm 8.712486502079e+00 true resid norm 8.712486502082e+00 ||r(i)||/||b|| 2.081619312125e-04
1515 KSP unpreconditioned resid norm 8.712486500443e+00 true resid norm 8.712486500452e+00 ||r(i)||/||b|| 2.081619311735e-04
1516 KSP unpreconditioned resid norm 8.712486499479e+00 true resid norm 8.712486499480e+00 ||r(i)||/||b|| 2.081619311503e-04
1517 KSP unpreconditioned resid norm 8.712486498671e+00 true resid norm 8.712486498679e+00 ||r(i)||/||b|| 2.081619311312e-04
1518 KSP unpreconditioned resid norm 8.712486497792e+00 true resid norm 8.712486497795e+00 ||r(i)||/||b|| 2.081619311100e-04
1519 KSP unpreconditioned resid norm 8.712486497033e+00 true resid norm 8.712486497036e+00 ||r(i)||/||b|| 2.081619310919e-04
1520 KSP unpreconditioned resid norm 8.712486496999e+00 true resid norm 8.712486497007e+00 ||r(i)||/||b|| 2.081619310912e-04
1521 KSP unpreconditioned resid norm 8.712486496885e+00 true resid norm 8.712486496888e+00 ||r(i)||/||b|| 2.081619310884e-04
1522 KSP unpreconditioned resid norm 8.712486495932e+00 true resid norm 8.712486495937e+00 ||r(i)||/||b|| 2.081619310657e-04
1523 KSP unpreconditioned resid norm 8.712486490989e+00 true resid norm 8.712486490985e+00 ||r(i)||/||b|| 2.081619309473e-04
1524 KSP unpreconditioned resid norm 8.712486484309e+00 true resid norm 8.712486484303e+00 ||r(i)||/||b|| 2.081619307877e-04
1525 KSP unpreconditioned resid norm 8.712486479093e+00 true resid norm 8.712486479095e+00 ||r(i)||/||b|| 2.081619306632e-04
1526 KSP unpreconditioned resid norm 8.712486472726e+00 true resid norm 8.712486472725e+00 ||r(i)||/||b|| 2.081619305111e-04
1527 KSP unpreconditioned resid norm 8.712486462836e+00 true resid norm 8.712486462844e+00 ||r(i)||/||b|| 2.081619302750e-04
1528 KSP unpreconditioned resid norm 8.712486439306e+00 true resid norm 8.712486439302e+00 ||r(i)||/||b|| 2.081619297125e-04
1529 KSP unpreconditioned resid norm 8.712486426852e+00 true resid norm 8.712486426857e+00 ||r(i)||/||b|| 2.081619294152e-04
1530 KSP unpreconditioned resid norm 8.712486426034e+00 true resid norm 8.712486426034e+00 ||r(i)||/||b|| 2.081619293955e-04
1531 KSP unpreconditioned resid norm 8.712486426031e+00 true resid norm 8.712486426032e+00 ||r(i)||/||b|| 2.081619293955e-04
1532 KSP unpreconditioned resid norm 8.712486425981e+00 true resid norm 8.712486425986e+00 ||r(i)||/||b|| 2.081619293944e-04
1533 KSP unpreconditioned resid norm 8.712486425729e+00 true resid norm 8.712486425723e+00 ||r(i)||/||b|| 2.081619293881e-04
1534 KSP unpreconditioned resid norm 8.712486425162e+00 true resid norm 8.712486425168e+00 ||r(i)||/||b|| 2.081619293748e-04
1535 KSP unpreconditioned resid norm 8.712486424482e+00 true resid norm 8.712486424487e+00 ||r(i)||/||b|| 2.081619293585e-04
1536 KSP unpreconditioned resid norm 8.712486424285e+00 true resid norm 8.712486424274e+00 ||r(i)||/||b|| 2.081619293535e-04
1537 KSP unpreconditioned resid norm 8.712486424188e+00 true resid norm 8.712486424180e+00 ||r(i)||/||b|| 2.081619293512e-04
1538 KSP unpreconditioned resid norm 8.712486423876e+00 true resid norm 8.712486423875e+00 ||r(i)||/||b|| 2.081619293439e-04
1539 KSP unpreconditioned resid norm 8.712486423255e+00 true resid norm 8.712486423257e+00 ||r(i)||/||b|| 2.081619293291e-04
1540 KSP unpreconditioned resid norm 8.712486422708e+00 true resid norm 8.712486422703e+00 ||r(i)||/||b|| 2.081619293159e-04
1541 KSP unpreconditioned resid norm 8.712486422572e+00 true resid norm 8.712486422575e+00 ||r(i)||/||b|| 2.081619293129e-04
1542 KSP unpreconditioned resid norm 8.712486422559e+00 true resid norm 8.712486422556e+00 ||r(i)||/||b|| 2.081619293124e-04
1543 KSP unpreconditioned resid norm 8.712486421965e+00 true resid norm 8.712486421966e+00 ||r(i)||/||b|| 2.081619292983e-04
1544 KSP unpreconditioned resid norm 8.712486420974e+00 true resid norm 8.712486420978e+00 ||r(i)||/||b|| 2.081619292747e-04
1545 KSP unpreconditioned resid norm 8.712486419580e+00 true resid norm 8.712486419575e+00 ||r(i)||/||b|| 2.081619292412e-04
1546 KSP unpreconditioned resid norm 8.712486418742e+00 true resid norm 8.712486418738e+00 ||r(i)||/||b|| 2.081619292212e-04
1547 KSP unpreconditioned resid norm 8.712486418009e+00 true resid norm 8.712486418006e+00 ||r(i)||/||b|| 2.081619292037e-04
1548 KSP unpreconditioned resid norm 8.712486417259e+00 true resid norm 8.712486417265e+00 ||r(i)||/||b|| 2.081619291860e-04
1549 KSP unpreconditioned resid norm 8.712486416559e+00 true resid norm 8.712486416549e+00 ||r(i)||/||b|| 2.081619291689e-04
1550 KSP unpreconditioned resid norm 8.712486416524e+00 true resid norm 8.712486416521e+00 ||r(i)||/||b|| 2.081619291682e-04
1551 KSP unpreconditioned resid norm 8.712486416422e+00 true resid norm 8.712486416423e+00 ||r(i)||/||b|| 2.081619291659e-04
1552 KSP unpreconditioned resid norm 8.712486415624e+00 true resid norm 8.712486415625e+00 ||r(i)||/||b|| 2.081619291468e-04
1553 KSP unpreconditioned resid norm 8.712486411407e+00 true resid norm 8.712486411404e+00 ||r(i)||/||b|| 2.081619290460e-04
1554 KSP unpreconditioned resid norm 8.712486405648e+00 true resid norm 8.712486405639e+00 ||r(i)||/||b|| 2.081619289082e-04
1555 KSP unpreconditioned resid norm 8.712486401305e+00 true resid norm 8.712486401307e+00 ||r(i)||/||b|| 2.081619288047e-04
1556 KSP unpreconditioned resid norm 8.712486395884e+00 true resid norm 8.712486395885e+00 ||r(i)||/||b|| 2.081619286752e-04
1557 KSP unpreconditioned resid norm 8.712486387103e+00 true resid norm 8.712486387101e+00 ||r(i)||/||b|| 2.081619284653e-04
1558 KSP unpreconditioned resid norm 8.712486366206e+00 true resid norm 8.712486366202e+00 ||r(i)||/||b|| 2.081619279660e-04
1559 KSP unpreconditioned resid norm 8.712486354764e+00 true resid norm 8.712486354758e+00 ||r(i)||/||b|| 2.081619276926e-04
1560 KSP unpreconditioned resid norm 8.712486353863e+00 true resid norm 8.712486353863e+00 ||r(i)||/||b|| 2.081619276712e-04
1561 KSP unpreconditioned resid norm 8.712486353860e+00 true resid norm 8.712486353861e+00 ||r(i)||/||b|| 2.081619276711e-04
1562 KSP unpreconditioned resid norm 8.712486353810e+00 true resid norm 8.712486353808e+00 ||r(i)||/||b|| 2.081619276698e-04
1563 KSP unpreconditioned resid norm 8.712486353578e+00 true resid norm 8.712486353576e+00 ||r(i)||/||b|| 2.081619276643e-04
1564 KSP unpreconditioned resid norm 8.712486353072e+00 true resid norm 8.712486353069e+00 ||r(i)||/||b|| 2.081619276522e-04
1565 KSP unpreconditioned resid norm 8.712486352475e+00 true resid norm 8.712486352470e+00 ||r(i)||/||b|| 2.081619276379e-04
1566 KSP unpreconditioned resid norm 8.712486352298e+00 true resid norm 8.712486352305e+00 ||r(i)||/||b|| 2.081619276339e-04
1567 KSP unpreconditioned resid norm 8.712486352206e+00 true resid norm 8.712486352207e+00 ||r(i)||/||b|| 2.081619276316e-04
1568 KSP unpreconditioned resid norm 8.712486351917e+00 true resid norm 8.712486351911e+00 ||r(i)||/||b|| 2.081619276245e-04
1569 KSP unpreconditioned resid norm 8.712486351380e+00 true resid norm 8.712486351376e+00 ||r(i)||/||b|| 2.081619276117e-04
1570 KSP unpreconditioned resid norm 8.712486350914e+00 true resid norm 8.712486350912e+00 ||r(i)||/||b|| 2.081619276007e-04
1571 KSP unpreconditioned resid norm 8.712486350793e+00 true resid norm 8.712486350786e+00 ||r(i)||/||b|| 2.081619275977e-04
1572 KSP unpreconditioned resid norm 8.712486350781e+00 true resid norm 8.712486350778e+00 ||r(i)||/||b|| 2.081619275975e-04
1573 KSP unpreconditioned resid norm 8.712486350249e+00 true resid norm 8.712486350253e+00 ||r(i)||/||b|| 2.081619275849e-04
1574 KSP unpreconditioned resid norm 8.712486349379e+00 true resid norm 8.712486349370e+00 ||r(i)||/||b|| 2.081619275638e-04
1575 KSP unpreconditioned resid norm 8.712486348103e+00 true resid norm 8.712486348108e+00 ||r(i)||/||b|| 2.081619275337e-04
1576 KSP unpreconditioned resid norm 8.712486347350e+00 true resid norm 8.712486347347e+00 ||r(i)||/||b|| 2.081619275155e-04
1577 KSP unpreconditioned resid norm 8.712486346717e+00 true resid norm 8.712486346712e+00 ||r(i)||/||b|| 2.081619275003e-04
1578 KSP unpreconditioned resid norm 8.712486346031e+00 true resid norm 8.712486346027e+00 ||r(i)||/||b|| 2.081619274839e-04
1579 KSP unpreconditioned resid norm 8.712486345436e+00 true resid norm 8.712486345443e+00 ||r(i)||/||b|| 2.081619274700e-04
1580 KSP unpreconditioned resid norm 8.712486345410e+00 true resid norm 8.712486345405e+00 ||r(i)||/||b|| 2.081619274691e-04
1581 KSP unpreconditioned resid norm 8.712486345320e+00 true resid norm 8.712486345324e+00 ||r(i)||/||b|| 2.081619274672e-04
1582 KSP unpreconditioned resid norm 8.712486344578e+00 true resid norm 8.712486344576e+00 ||r(i)||/||b|| 2.081619274493e-04
1583 KSP unpreconditioned resid norm 8.712486340722e+00 true resid norm 8.712486340726e+00 ||r(i)||/||b|| 2.081619273573e-04
1584 KSP unpreconditioned resid norm 8.712486335506e+00 true resid norm 8.712486335501e+00 ||r(i)||/||b|| 2.081619272325e-04
1585 KSP unpreconditioned resid norm 8.712486331445e+00 true resid norm 8.712486331443e+00 ||r(i)||/||b|| 2.081619271355e-04
1586 KSP unpreconditioned resid norm 8.712486326476e+00 true resid norm 8.712486326472e+00 ||r(i)||/||b|| 2.081619270167e-04
1587 KSP unpreconditioned resid norm 8.712486318733e+00 true resid norm 8.712486318735e+00 ||r(i)||/||b|| 2.081619268319e-04
1588 KSP unpreconditioned resid norm 8.712486300314e+00 true resid norm 8.712486300312e+00 ||r(i)||/||b|| 2.081619263917e-04
1589 KSP unpreconditioned resid norm 8.712486290538e+00 true resid norm 8.712486290532e+00 ||r(i)||/||b|| 2.081619261581e-04
1590 KSP unpreconditioned resid norm 8.712486289883e+00 true resid norm 8.712486289883e+00 ||r(i)||/||b|| 2.081619261425e-04
1591 KSP unpreconditioned resid norm 8.712486289880e+00 true resid norm 8.712486289883e+00 ||r(i)||/||b|| 2.081619261425e-04
1592 KSP unpreconditioned resid norm 8.712486289840e+00 true resid norm 8.712486289845e+00 ||r(i)||/||b|| 2.081619261416e-04
1593 KSP unpreconditioned resid norm 8.712486289642e+00 true resid norm 8.712486289648e+00 ||r(i)||/||b|| 2.081619261369e-04
1594 KSP unpreconditioned resid norm 8.712486289199e+00 true resid norm 8.712486289203e+00 ||r(i)||/||b|| 2.081619261263e-04
1595 KSP unpreconditioned resid norm 8.712486288667e+00 true resid norm 8.712486288668e+00 ||r(i)||/||b|| 2.081619261135e-04
1596 KSP unpreconditioned resid norm 8.712486288513e+00 true resid norm 8.712486288509e+00 ||r(i)||/||b|| 2.081619261097e-04
1597 KSP unpreconditioned resid norm 8.712486288437e+00 true resid norm 8.712486288440e+00 ||r(i)||/||b|| 2.081619261081e-04
1598 KSP unpreconditioned resid norm 8.712486288192e+00 true resid norm 8.712486288197e+00 ||r(i)||/||b|| 2.081619261023e-04
1599 KSP unpreconditioned resid norm 8.712486287708e+00 true resid norm 8.712486287707e+00 ||r(i)||/||b|| 2.081619260905e-04
1600 KSP unpreconditioned resid norm 8.712486287281e+00 true resid norm 8.712486287283e+00 ||r(i)||/||b|| 2.081619260804e-04
1601 KSP unpreconditioned resid norm 8.712486287174e+00 true resid norm 8.712486287173e+00 ||r(i)||/||b|| 2.081619260778e-04
1602 KSP unpreconditioned resid norm 8.712486287164e+00 true resid norm 8.712486287162e+00 ||r(i)||/||b|| 2.081619260775e-04
1603 KSP unpreconditioned resid norm 8.712486286699e+00 true resid norm 8.712486286694e+00 ||r(i)||/||b|| 2.081619260663e-04
1604 KSP unpreconditioned resid norm 8.712486285925e+00 true resid norm 8.712486285924e+00 ||r(i)||/||b|| 2.081619260480e-04
1605 KSP unpreconditioned resid norm 8.712486284832e+00 true resid norm 8.712486284840e+00 ||r(i)||/||b|| 2.081619260221e-04
1606 KSP unpreconditioned resid norm 8.712486284176e+00 true resid norm 8.712486284176e+00 ||r(i)||/||b|| 2.081619260062e-04
1607 KSP unpreconditioned resid norm 8.712486283604e+00 true resid norm 8.712486283608e+00 ||r(i)||/||b|| 2.081619259926e-04
1608 KSP unpreconditioned resid norm 8.712486283016e+00 true resid norm 8.712486283005e+00 ||r(i)||/||b|| 2.081619259782e-04
1609 KSP unpreconditioned resid norm 8.712486282470e+00 true resid norm 8.712486282471e+00 ||r(i)||/||b|| 2.081619259655e-04
1610 KSP unpreconditioned resid norm 8.712486282443e+00 true resid norm 8.712486282430e+00 ||r(i)||/||b|| 2.081619259645e-04
1611 KSP unpreconditioned resid norm 8.712486282363e+00 true resid norm 8.712486282367e+00 ||r(i)||/||b|| 2.081619259630e-04
1612 KSP unpreconditioned resid norm 8.712486281737e+00 true resid norm 8.712486281739e+00 ||r(i)||/||b|| 2.081619259479e-04
1613 KSP unpreconditioned resid norm 8.712486278433e+00 true resid norm 8.712486278442e+00 ||r(i)||/||b|| 2.081619258692e-04
1614 KSP unpreconditioned resid norm 8.712486273926e+00 true resid norm 8.712486273925e+00 ||r(i)||/||b|| 2.081619257613e-04
1615 KSP unpreconditioned resid norm 8.712486270518e+00 true resid norm 8.712486270516e+00 ||r(i)||/||b|| 2.081619256798e-04
1616 KSP unpreconditioned resid norm 8.712486266270e+00 true resid norm 8.712486266277e+00 ||r(i)||/||b|| 2.081619255785e-04
1617 KSP unpreconditioned resid norm 8.712486259402e+00 true resid norm 8.712486259405e+00 ||r(i)||/||b|| 2.081619254143e-04
1618 KSP unpreconditioned resid norm 8.712486243048e+00 true resid norm 8.712486243047e+00 ||r(i)||/||b|| 2.081619250235e-04
1619 KSP unpreconditioned resid norm 8.712486234109e+00 true resid norm 8.712486234112e+00 ||r(i)||/||b|| 2.081619248100e-04
1620 KSP unpreconditioned resid norm 8.712486233418e+00 true resid norm 8.712486233418e+00 ||r(i)||/||b|| 2.081619247935e-04
1621 KSP unpreconditioned resid norm 8.712486233415e+00 true resid norm 8.712486233412e+00 ||r(i)||/||b|| 2.081619247933e-04
1622 KSP unpreconditioned resid norm 8.712486233377e+00 true resid norm 8.712486233378e+00 ||r(i)||/||b|| 2.081619247925e-04
1623 KSP unpreconditioned resid norm 8.712486233195e+00 true resid norm 8.712486233189e+00 ||r(i)||/||b|| 2.081619247880e-04
1624 KSP unpreconditioned resid norm 8.712486232800e+00 true resid norm 8.712486232806e+00 ||r(i)||/||b|| 2.081619247788e-04
1625 KSP unpreconditioned resid norm 8.712486232332e+00 true resid norm 8.712486232329e+00 ||r(i)||/||b|| 2.081619247674e-04
1626 KSP unpreconditioned resid norm 8.712486232194e+00 true resid norm 8.712486232192e+00 ||r(i)||/||b|| 2.081619247642e-04
1627 KSP unpreconditioned resid norm 8.712486232123e+00 true resid norm 8.712486232129e+00 ||r(i)||/||b|| 2.081619247626e-04
1628 KSP unpreconditioned resid norm 8.712486231897e+00 true resid norm 8.712486231898e+00 ||r(i)||/||b|| 2.081619247571e-04
1629 KSP unpreconditioned resid norm 8.712486231477e+00 true resid norm 8.712486231475e+00 ||r(i)||/||b|| 2.081619247470e-04
1630 KSP unpreconditioned resid norm 8.712486231112e+00 true resid norm 8.712486231108e+00 ||r(i)||/||b|| 2.081619247383e-04
1631 KSP unpreconditioned resid norm 8.712486231017e+00 true resid norm 8.712486231017e+00 ||r(i)||/||b|| 2.081619247361e-04
1632 KSP unpreconditioned resid norm 8.712486231008e+00 true resid norm 8.712486231002e+00 ||r(i)||/||b|| 2.081619247357e-04
1633 KSP unpreconditioned resid norm 8.712486230592e+00 true resid norm 8.712486230584e+00 ||r(i)||/||b|| 2.081619247257e-04
1634 KSP unpreconditioned resid norm 8.712486229911e+00 true resid norm 8.712486229907e+00 ||r(i)||/||b|| 2.081619247096e-04
1635 KSP unpreconditioned resid norm 8.712486228915e+00 true resid norm 8.712486228911e+00 ||r(i)||/||b|| 2.081619246858e-04
1636 KSP unpreconditioned resid norm 8.712486228327e+00 true resid norm 8.712486228318e+00 ||r(i)||/||b|| 2.081619246716e-04
1637 KSP unpreconditioned resid norm 8.712486227832e+00 true resid norm 8.712486227833e+00 ||r(i)||/||b|| 2.081619246600e-04
1638 KSP unpreconditioned resid norm 8.712486227296e+00 true resid norm 8.712486227305e+00 ||r(i)||/||b|| 2.081619246474e-04
1639 KSP unpreconditioned resid norm 8.712486226830e+00 true resid norm 8.712486226822e+00 ||r(i)||/||b|| 2.081619246359e-04
1640 KSP unpreconditioned resid norm 8.712486226809e+00 true resid norm 8.712486226811e+00 ||r(i)||/||b|| 2.081619246356e-04
1641 KSP unpreconditioned resid norm 8.712486226739e+00 true resid norm 8.712486226752e+00 ||r(i)||/||b|| 2.081619246342e-04
1642 KSP unpreconditioned resid norm 8.712486226160e+00 true resid norm 8.712486226156e+00 ||r(i)||/||b|| 2.081619246200e-04
1643 KSP unpreconditioned resid norm 8.712486223151e+00 true resid norm 8.712486223154e+00 ||r(i)||/||b|| 2.081619245482e-04
1644 KSP unpreconditioned resid norm 8.712486219078e+00 true resid norm 8.712486219081e+00 ||r(i)||/||b|| 2.081619244509e-04
1645 KSP unpreconditioned resid norm 8.712486215914e+00 true resid norm 8.712486215906e+00 ||r(i)||/||b|| 2.081619243750e-04
1646 KSP unpreconditioned resid norm 8.712486212036e+00 true resid norm 8.712486212033e+00 ||r(i)||/||b|| 2.081619242825e-04
1647 KSP unpreconditioned resid norm 8.712486205975e+00 true resid norm 8.712486205979e+00 ||r(i)||/||b|| 2.081619241379e-04
1648 KSP unpreconditioned resid norm 8.712486191559e+00 true resid norm 8.712486191555e+00 ||r(i)||/||b|| 2.081619237933e-04
1649 KSP unpreconditioned resid norm 8.712486183891e+00 true resid norm 8.712486183890e+00 ||r(i)||/||b|| 2.081619236101e-04
1650 KSP unpreconditioned resid norm 8.712486183382e+00 true resid norm 8.712486183382e+00 ||r(i)||/||b|| 2.081619235980e-04
1651 KSP unpreconditioned resid norm 8.712486183380e+00 true resid norm 8.712486183382e+00 ||r(i)||/||b|| 2.081619235980e-04
1652 KSP unpreconditioned resid norm 8.712486183349e+00 true resid norm 8.712486183359e+00 ||r(i)||/||b|| 2.081619235974e-04
1653 KSP unpreconditioned resid norm 8.712486183194e+00 true resid norm 8.712486183176e+00 ||r(i)||/||b|| 2.081619235931e-04
1654 KSP unpreconditioned resid norm 8.712486182846e+00 true resid norm 8.712486182837e+00 ||r(i)||/||b|| 2.081619235850e-04
1655 KSP unpreconditioned resid norm 8.712486182431e+00 true resid norm 8.712486182430e+00 ||r(i)||/||b|| 2.081619235752e-04
1656 KSP unpreconditioned resid norm 8.712486182310e+00 true resid norm 8.712486182307e+00 ||r(i)||/||b|| 2.081619235723e-04
1657 KSP unpreconditioned resid norm 8.712486182251e+00 true resid norm 8.712486182244e+00 ||r(i)||/||b|| 2.081619235708e-04
1658 KSP unpreconditioned resid norm 8.712486182059e+00 true resid norm 8.712486182045e+00 ||r(i)||/||b|| 2.081619235660e-04
1659 KSP unpreconditioned resid norm 8.712486181680e+00 true resid norm 8.712486181676e+00 ||r(i)||/||b|| 2.081619235572e-04
1660 KSP unpreconditioned resid norm 8.712486181347e+00 true resid norm 8.712486181334e+00 ||r(i)||/||b|| 2.081619235490e-04
1661 KSP unpreconditioned resid norm 8.712486181263e+00 true resid norm 8.712486181269e+00 ||r(i)||/||b|| 2.081619235475e-04
1662 KSP unpreconditioned resid norm 8.712486181255e+00 true resid norm 8.712486181249e+00 ||r(i)||/||b|| 2.081619235470e-04
1663 KSP unpreconditioned resid norm 8.712486180891e+00 true resid norm 8.712486180885e+00 ||r(i)||/||b|| 2.081619235383e-04
1664 KSP unpreconditioned resid norm 8.712486180286e+00 true resid norm 8.712486180286e+00 ||r(i)||/||b|| 2.081619235240e-04
1665 KSP unpreconditioned resid norm 8.712486179430e+00 true resid norm 8.712486179422e+00 ||r(i)||/||b|| 2.081619235034e-04
1666 KSP unpreconditioned resid norm 8.712486178917e+00 true resid norm 8.712486178913e+00 ||r(i)||/||b|| 2.081619234912e-04
1667 KSP unpreconditioned resid norm 8.712486178470e+00 true resid norm 8.712486178464e+00 ||r(i)||/||b|| 2.081619234805e-04
1668 KSP unpreconditioned resid norm 8.712486178009e+00 true resid norm 8.712486178009e+00 ||r(i)||/||b|| 2.081619234696e-04
1669 KSP unpreconditioned resid norm 8.712486177583e+00 true resid norm 8.712486177568e+00 ||r(i)||/||b|| 2.081619234591e-04
1670 KSP unpreconditioned resid norm 8.712486177562e+00 true resid norm 8.712486177562e+00 ||r(i)||/||b|| 2.081619234589e-04
1671 KSP unpreconditioned resid norm 8.712486177500e+00 true resid norm 8.712486177488e+00 ||r(i)||/||b|| 2.081619234571e-04
1672 KSP unpreconditioned resid norm 8.712486177009e+00 true resid norm 8.712486176997e+00 ||r(i)||/||b|| 2.081619234454e-04
1673 KSP unpreconditioned resid norm 8.712486174421e+00 true resid norm 8.712486174407e+00 ||r(i)||/||b|| 2.081619233835e-04
1674 KSP unpreconditioned resid norm 8.712486170893e+00 true resid norm 8.712486170883e+00 ||r(i)||/||b|| 2.081619232993e-04
1675 KSP unpreconditioned resid norm 8.712486168220e+00 true resid norm 8.712486168207e+00 ||r(i)||/||b|| 2.081619232354e-04
1676 KSP unpreconditioned resid norm 8.712486164892e+00 true resid norm 8.712486164880e+00 ||r(i)||/||b|| 2.081619231559e-04
1677 KSP unpreconditioned resid norm 8.712486159520e+00 true resid norm 8.712486159506e+00 ||r(i)||/||b|| 2.081619230275e-04
1678 KSP unpreconditioned resid norm 8.712486146724e+00 true resid norm 8.712486146716e+00 ||r(i)||/||b|| 2.081619227219e-04
1679 KSP unpreconditioned resid norm 8.712486139741e+00 true resid norm 8.712486139738e+00 ||r(i)||/||b|| 2.081619225552e-04
1680 KSP unpreconditioned resid norm 8.712486139195e+00 true resid norm 8.712486139195e+00 ||r(i)||/||b|| 2.081619225422e-04
1681 KSP unpreconditioned resid norm 8.712486139192e+00 true resid norm 8.712486139193e+00 ||r(i)||/||b|| 2.081619225422e-04
1682 KSP unpreconditioned resid norm 8.712486139162e+00 true resid norm 8.712486139160e+00 ||r(i)||/||b|| 2.081619225414e-04
1683 KSP unpreconditioned resid norm 8.712486139021e+00 true resid norm 8.712486139017e+00 ||r(i)||/||b|| 2.081619225380e-04
1684 KSP unpreconditioned resid norm 8.712486138712e+00 true resid norm 8.712486138713e+00 ||r(i)||/||b|| 2.081619225307e-04
1685 KSP unpreconditioned resid norm 8.712486138346e+00 true resid norm 8.712486138335e+00 ||r(i)||/||b|| 2.081619225217e-04
1686 KSP unpreconditioned resid norm 8.712486138238e+00 true resid norm 8.712486138234e+00 ||r(i)||/||b|| 2.081619225193e-04
1687 KSP unpreconditioned resid norm 8.712486138182e+00 true resid norm 8.712486138180e+00 ||r(i)||/||b|| 2.081619225180e-04
1688 KSP unpreconditioned resid norm 8.712486138006e+00 true resid norm 8.712486137996e+00 ||r(i)||/||b|| 2.081619225136e-04
1689 KSP unpreconditioned resid norm 8.712486137677e+00 true resid norm 8.712486137670e+00 ||r(i)||/||b|| 2.081619225058e-04
1690 KSP unpreconditioned resid norm 8.712486137391e+00 true resid norm 8.712486137392e+00 ||r(i)||/||b|| 2.081619224992e-04
1691 KSP unpreconditioned resid norm 8.712486137317e+00 true resid norm 8.712486137311e+00 ||r(i)||/||b|| 2.081619224972e-04
1692 KSP unpreconditioned resid norm 8.712486137310e+00 true resid norm 8.712486137312e+00 ||r(i)||/||b|| 2.081619224972e-04
1693 KSP unpreconditioned resid norm 8.712486136985e+00 true resid norm 8.712486136975e+00 ||r(i)||/||b|| 2.081619224892e-04
1694 KSP unpreconditioned resid norm 8.712486136453e+00 true resid norm 8.712486136458e+00 ||r(i)||/||b|| 2.081619224768e-04
1695 KSP unpreconditioned resid norm 8.712486135675e+00 true resid norm 8.712486135675e+00 ||r(i)||/||b|| 2.081619224582e-04
1696 KSP unpreconditioned resid norm 8.712486135216e+00 true resid norm 8.712486135217e+00 ||r(i)||/||b|| 2.081619224472e-04
1697 KSP unpreconditioned resid norm 8.712486134827e+00 true resid norm 8.712486134830e+00 ||r(i)||/||b|| 2.081619224380e-04
1698 KSP unpreconditioned resid norm 8.712486134409e+00 true resid norm 8.712486134402e+00 ||r(i)||/||b|| 2.081619224277e-04
1699 KSP unpreconditioned resid norm 8.712486134044e+00 true resid norm 8.712486134049e+00 ||r(i)||/||b|| 2.081619224193e-04
1700 KSP unpreconditioned resid norm 8.712486134027e+00 true resid norm 8.712486134021e+00 ||r(i)||/||b|| 2.081619224186e-04
1701 KSP unpreconditioned resid norm 8.712486133973e+00 true resid norm 8.712486133972e+00 ||r(i)||/||b|| 2.081619224175e-04
1702 KSP unpreconditioned resid norm 8.712486133521e+00 true resid norm 8.712486133518e+00 ||r(i)||/||b|| 2.081619224066e-04
1703 KSP unpreconditioned resid norm 8.712486131172e+00 true resid norm 8.712486131173e+00 ||r(i)||/||b|| 2.081619223506e-04
1704 KSP unpreconditioned resid norm 8.712486127992e+00 true resid norm 8.712486127986e+00 ||r(i)||/||b|| 2.081619222744e-04
1705 KSP unpreconditioned resid norm 8.712486125525e+00 true resid norm 8.712486125524e+00 ||r(i)||/||b|| 2.081619222156e-04
1706 KSP unpreconditioned resid norm 8.712486122497e+00 true resid norm 8.712486122498e+00 ||r(i)||/||b|| 2.081619221433e-04
1707 KSP unpreconditioned resid norm 8.712486117755e+00 true resid norm 8.712486117756e+00 ||r(i)||/||b|| 2.081619220300e-04
1708 KSP unpreconditioned resid norm 8.712486106473e+00 true resid norm 8.712486106475e+00 ||r(i)||/||b|| 2.081619217605e-04
1709 KSP unpreconditioned resid norm 8.712486100461e+00 true resid norm 8.712486100465e+00 ||r(i)||/||b|| 2.081619216169e-04
1710 KSP unpreconditioned resid norm 8.712486100055e+00 true resid norm 8.712486100055e+00 ||r(i)||/||b|| 2.081619216071e-04
1711 KSP unpreconditioned resid norm 8.712486100054e+00 true resid norm 8.712486100047e+00 ||r(i)||/||b|| 2.081619216069e-04
1712 KSP unpreconditioned resid norm 8.712486100029e+00 true resid norm 8.712486100020e+00 ||r(i)||/||b|| 2.081619216063e-04
1713 KSP unpreconditioned resid norm 8.712486099907e+00 true resid norm 8.712486099901e+00 ||r(i)||/||b|| 2.081619216034e-04
1714 KSP unpreconditioned resid norm 8.712486099636e+00 true resid norm 8.712486099631e+00 ||r(i)||/||b|| 2.081619215970e-04
1715 KSP unpreconditioned resid norm 8.712486099311e+00 true resid norm 8.712486099302e+00 ||r(i)||/||b|| 2.081619215891e-04
1716 KSP unpreconditioned resid norm 8.712486099216e+00 true resid norm 8.712486099204e+00 ||r(i)||/||b|| 2.081619215868e-04
1717 KSP unpreconditioned resid norm 8.712486099170e+00 true resid norm 8.712486099164e+00 ||r(i)||/||b|| 2.081619215858e-04
1718 KSP unpreconditioned resid norm 8.712486099019e+00 true resid norm 8.712486099021e+00 ||r(i)||/||b|| 2.081619215824e-04
1719 KSP unpreconditioned resid norm 8.712486098724e+00 true resid norm 8.712486098724e+00 ||r(i)||/||b|| 2.081619215753e-04
1720 KSP unpreconditioned resid norm 8.712486098463e+00 true resid norm 8.712486098468e+00 ||r(i)||/||b|| 2.081619215692e-04
1721 KSP unpreconditioned resid norm 8.712486098398e+00 true resid norm 8.712486098387e+00 ||r(i)||/||b|| 2.081619215672e-04
1722 KSP unpreconditioned resid norm 8.712486098392e+00 true resid norm 8.712486098386e+00 ||r(i)||/||b|| 2.081619215672e-04
1723 KSP unpreconditioned resid norm 8.712486098107e+00 true resid norm 8.712486098095e+00 ||r(i)||/||b|| 2.081619215603e-04
1724 KSP unpreconditioned resid norm 8.712486097634e+00 true resid norm 8.712486097629e+00 ||r(i)||/||b|| 2.081619215491e-04
1725 KSP unpreconditioned resid norm 8.712486096963e+00 true resid norm 8.712486096949e+00 ||r(i)||/||b|| 2.081619215329e-04
1726 KSP unpreconditioned resid norm 8.712486096562e+00 true resid norm 8.712486096552e+00 ||r(i)||/||b|| 2.081619215234e-04
1727 KSP unpreconditioned resid norm 8.712486096213e+00 true resid norm 8.712486096214e+00 ||r(i)||/||b|| 2.081619215153e-04
1728 KSP unpreconditioned resid norm 8.712486095852e+00 true resid norm 8.712486095847e+00 ||r(i)||/||b|| 2.081619215065e-04
1729 KSP unpreconditioned resid norm 8.712486095519e+00 true resid norm 8.712486095519e+00 ||r(i)||/||b|| 2.081619214987e-04
1730 KSP unpreconditioned resid norm 8.712486095503e+00 true resid norm 8.712486095494e+00 ||r(i)||/||b|| 2.081619214981e-04
1731 KSP unpreconditioned resid norm 8.712486095454e+00 true resid norm 8.712486095455e+00 ||r(i)||/||b|| 2.081619214972e-04
1732 KSP unpreconditioned resid norm 8.712486095069e+00 true resid norm 8.712486095063e+00 ||r(i)||/||b|| 2.081619214878e-04
1733 KSP unpreconditioned resid norm 8.712486093043e+00 true resid norm 8.712486093038e+00 ||r(i)||/||b|| 2.081619214394e-04
1734 KSP unpreconditioned resid norm 8.712486090282e+00 true resid norm 8.712486090283e+00 ||r(i)||/||b|| 2.081619213736e-04
1735 KSP unpreconditioned resid norm 8.712486088186e+00 true resid norm 8.712486088185e+00 ||r(i)||/||b|| 2.081619213235e-04
1736 KSP unpreconditioned resid norm 8.712486085578e+00 true resid norm 8.712486085572e+00 ||r(i)||/||b|| 2.081619212611e-04
1737 KSP unpreconditioned resid norm 8.712486081377e+00 true resid norm 8.712486081374e+00 ||r(i)||/||b|| 2.081619211608e-04
1738 KSP unpreconditioned resid norm 8.712486071367e+00 true resid norm 8.712486071359e+00 ||r(i)||/||b|| 2.081619209215e-04
1739 KSP unpreconditioned resid norm 8.712486065911e+00 true resid norm 8.712486065915e+00 ||r(i)||/||b|| 2.081619207914e-04
1740 KSP unpreconditioned resid norm 8.712486065485e+00 true resid norm 8.712486065485e+00 ||r(i)||/||b|| 2.081619207811e-04
1741 KSP unpreconditioned resid norm 8.712486065483e+00 true resid norm 8.712486065479e+00 ||r(i)||/||b|| 2.081619207810e-04
1742 KSP unpreconditioned resid norm 8.712486065459e+00 true resid norm 8.712486065465e+00 ||r(i)||/||b|| 2.081619207807e-04
1743 KSP unpreconditioned resid norm 8.712486065349e+00 true resid norm 8.712486065345e+00 ||r(i)||/||b|| 2.081619207778e-04
1744 KSP unpreconditioned resid norm 8.712486065107e+00 true resid norm 8.712486065112e+00 ||r(i)||/||b|| 2.081619207722e-04
1745 KSP unpreconditioned resid norm 8.712486064821e+00 true resid norm 8.712486064817e+00 ||r(i)||/||b|| 2.081619207652e-04
1746 KSP unpreconditioned resid norm 8.712486064737e+00 true resid norm 8.712486064731e+00 ||r(i)||/||b|| 2.081619207631e-04
1747 KSP unpreconditioned resid norm 8.712486064693e+00 true resid norm 8.712486064697e+00 ||r(i)||/||b|| 2.081619207623e-04
1748 KSP unpreconditioned resid norm 8.712486064556e+00 true resid norm 8.712486064549e+00 ||r(i)||/||b|| 2.081619207588e-04
1749 KSP unpreconditioned resid norm 8.712486064299e+00 true resid norm 8.712486064295e+00 ||r(i)||/||b|| 2.081619207527e-04
1750 KSP unpreconditioned resid norm 8.712486064074e+00 true resid norm 8.712486064067e+00 ||r(i)||/||b|| 2.081619207473e-04
1751 KSP unpreconditioned resid norm 8.712486064016e+00 true resid norm 8.712486064012e+00 ||r(i)||/||b|| 2.081619207459e-04
1752 KSP unpreconditioned resid norm 8.712486064011e+00 true resid norm 8.712486064003e+00 ||r(i)||/||b|| 2.081619207457e-04
1753 KSP unpreconditioned resid norm 8.712486063757e+00 true resid norm 8.712486063752e+00 ||r(i)||/||b|| 2.081619207397e-04
1754 KSP unpreconditioned resid norm 8.712486063340e+00 true resid norm 8.712486063339e+00 ||r(i)||/||b|| 2.081619207299e-04
1755 KSP unpreconditioned resid norm 8.712486062733e+00 true resid norm 8.712486062733e+00 ||r(i)||/||b|| 2.081619207154e-04
1756 KSP unpreconditioned resid norm 8.712486062374e+00 true resid norm 8.712486062379e+00 ||r(i)||/||b|| 2.081619207069e-04
1757 KSP unpreconditioned resid norm 8.712486062070e+00 true resid norm 8.712486062059e+00 ||r(i)||/||b|| 2.081619206993e-04
1758 KSP unpreconditioned resid norm 8.712486061744e+00 true resid norm 8.712486061743e+00 ||r(i)||/||b|| 2.081619206917e-04
1759 KSP unpreconditioned resid norm 8.712486061458e+00 true resid norm 8.712486061454e+00 ||r(i)||/||b|| 2.081619206848e-04
1760 KSP unpreconditioned resid norm 8.712486061445e+00 true resid norm 8.712486061446e+00 ||r(i)||/||b|| 2.081619206846e-04
1761 KSP unpreconditioned resid norm 8.712486061402e+00 true resid norm 8.712486061395e+00 ||r(i)||/||b|| 2.081619206834e-04
1762 KSP unpreconditioned resid norm 8.712486061049e+00 true resid norm 8.712486061047e+00 ||r(i)||/||b|| 2.081619206751e-04
1763 KSP unpreconditioned resid norm 8.712486059216e+00 true resid norm 8.712486059214e+00 ||r(i)||/||b|| 2.081619206313e-04
1764 KSP unpreconditioned resid norm 8.712486056731e+00 true resid norm 8.712486056725e+00 ||r(i)||/||b|| 2.081619205718e-04
1765 KSP unpreconditioned resid norm 8.712486054807e+00 true resid norm 8.712486054797e+00 ||r(i)||/||b|| 2.081619205258e-04
1766 KSP unpreconditioned resid norm 8.712486052443e+00 true resid norm 8.712486052437e+00 ||r(i)||/||b|| 2.081619204694e-04
1767 KSP unpreconditioned resid norm 8.712486048733e+00 true resid norm 8.712486048739e+00 ||r(i)||/||b|| 2.081619203810e-04
1768 KSP unpreconditioned resid norm 8.712486039905e+00 true resid norm 8.712486039893e+00 ||r(i)||/||b|| 2.081619201697e-04
1769 KSP unpreconditioned resid norm 8.712486035193e+00 true resid norm 8.712486035182e+00 ||r(i)||/||b|| 2.081619200571e-04
1770 KSP unpreconditioned resid norm 8.712486034860e+00 true resid norm 8.712486034860e+00 ||r(i)||/||b|| 2.081619200494e-04
1771 KSP unpreconditioned resid norm 8.712486034858e+00 true resid norm 8.712486034860e+00 ||r(i)||/||b|| 2.081619200494e-04
1772 KSP unpreconditioned resid norm 8.712486034839e+00 true resid norm 8.712486034846e+00 ||r(i)||/||b|| 2.081619200491e-04
1773 KSP unpreconditioned resid norm 8.712486034743e+00 true resid norm 8.712486034754e+00 ||r(i)||/||b|| 2.081619200469e-04
1774 KSP unpreconditioned resid norm 8.712486034531e+00 true resid norm 8.712486034539e+00 ||r(i)||/||b|| 2.081619200418e-04
1775 KSP unpreconditioned resid norm 8.712486034277e+00 true resid norm 8.712486034284e+00 ||r(i)||/||b|| 2.081619200357e-04
1776 KSP unpreconditioned resid norm 8.712486034203e+00 true resid norm 8.712486034213e+00 ||r(i)||/||b|| 2.081619200340e-04
1777 KSP unpreconditioned resid norm 8.712486034166e+00 true resid norm 8.712486034169e+00 ||r(i)||/||b|| 2.081619200329e-04
1778 KSP unpreconditioned resid norm 8.712486034049e+00 true resid norm 8.712486034055e+00 ||r(i)||/||b|| 2.081619200302e-04
1779 KSP unpreconditioned resid norm 8.712486033818e+00 true resid norm 8.712486033830e+00 ||r(i)||/||b|| 2.081619200248e-04
1780 KSP unpreconditioned resid norm 8.712486033614e+00 true resid norm 8.712486033616e+00 ||r(i)||/||b|| 2.081619200197e-04
1781 KSP unpreconditioned resid norm 8.712486033563e+00 true resid norm 8.712486033572e+00 ||r(i)||/||b|| 2.081619200186e-04
1782 KSP unpreconditioned resid norm 8.712486033558e+00 true resid norm 8.712486033555e+00 ||r(i)||/||b|| 2.081619200182e-04
1783 KSP unpreconditioned resid norm 8.712486033336e+00 true resid norm 8.712486033343e+00 ||r(i)||/||b|| 2.081619200132e-04
1784 KSP unpreconditioned resid norm 8.712486032966e+00 true resid norm 8.712486032968e+00 ||r(i)||/||b|| 2.081619200042e-04
1785 KSP unpreconditioned resid norm 8.712486032441e+00 true resid norm 8.712486032453e+00 ||r(i)||/||b|| 2.081619199919e-04
1786 KSP unpreconditioned resid norm 8.712486032126e+00 true resid norm 8.712486032130e+00 ||r(i)||/||b|| 2.081619199842e-04
1787 KSP unpreconditioned resid norm 8.712486031854e+00 true resid norm 8.712486031858e+00 ||r(i)||/||b|| 2.081619199777e-04
1788 KSP unpreconditioned resid norm 8.712486031571e+00 true resid norm 8.712486031575e+00 ||r(i)||/||b|| 2.081619199709e-04
1789 KSP unpreconditioned resid norm 8.712486031311e+00 true resid norm 8.712486031311e+00 ||r(i)||/||b|| 2.081619199646e-04
1790 KSP unpreconditioned resid norm 8.712486031299e+00 true resid norm 8.712486031306e+00 ||r(i)||/||b|| 2.081619199645e-04
1791 KSP unpreconditioned resid norm 8.712486031261e+00 true resid norm 8.712486031256e+00 ||r(i)||/||b|| 2.081619199633e-04
1792 KSP unpreconditioned resid norm 8.712486030959e+00 true resid norm 8.712486030969e+00 ||r(i)||/||b|| 2.081619199565e-04
1793 KSP unpreconditioned resid norm 8.712486029372e+00 true resid norm 8.712486029373e+00 ||r(i)||/||b|| 2.081619199183e-04
1794 KSP unpreconditioned resid norm 8.712486027211e+00 true resid norm 8.712486027216e+00 ||r(i)||/||b|| 2.081619198668e-04
1795 KSP unpreconditioned resid norm 8.712486025569e+00 true resid norm 8.712486025569e+00 ||r(i)||/||b|| 2.081619198275e-04
1796 KSP unpreconditioned resid norm 8.712486023526e+00 true resid norm 8.712486023528e+00 ||r(i)||/||b|| 2.081619197787e-04
1797 KSP unpreconditioned resid norm 8.712486020240e+00 true resid norm 8.712486020256e+00 ||r(i)||/||b|| 2.081619197005e-04
1798 KSP unpreconditioned resid norm 8.712486012411e+00 true resid norm 8.712486012418e+00 ||r(i)||/||b|| 2.081619195132e-04
1799 KSP unpreconditioned resid norm 8.712486008148e+00 true resid norm 8.712486008143e+00 ||r(i)||/||b|| 2.081619194111e-04
1800 KSP unpreconditioned resid norm 8.712486007828e+00 true resid norm 8.712486007828e+00 ||r(i)||/||b|| 2.081619194036e-04
1801 KSP unpreconditioned resid norm 8.712486007826e+00 true resid norm 8.712486007824e+00 ||r(i)||/||b|| 2.081619194035e-04
1802 KSP unpreconditioned resid norm 8.712486007808e+00 true resid norm 8.712486007810e+00 ||r(i)||/||b|| 2.081619194031e-04
1803 KSP unpreconditioned resid norm 8.712486007722e+00 true resid norm 8.712486007722e+00 ||r(i)||/||b|| 2.081619194010e-04
1804 KSP unpreconditioned resid norm 8.712486007533e+00 true resid norm 8.712486007523e+00 ||r(i)||/||b|| 2.081619193963e-04
1805 KSP unpreconditioned resid norm 8.712486007309e+00 true resid norm 8.712486007309e+00 ||r(i)||/||b|| 2.081619193912e-04
1806 KSP unpreconditioned resid norm 8.712486007243e+00 true resid norm 8.712486007242e+00 ||r(i)||/||b|| 2.081619193896e-04
1807 KSP unpreconditioned resid norm 8.712486007209e+00 true resid norm 8.712486007207e+00 ||r(i)||/||b|| 2.081619193887e-04
1808 KSP unpreconditioned resid norm 8.712486007102e+00 true resid norm 8.712486007099e+00 ||r(i)||/||b|| 2.081619193861e-04
1809 KSP unpreconditioned resid norm 8.712486006901e+00 true resid norm 8.712486006890e+00 ||r(i)||/||b|| 2.081619193812e-04
1810 KSP unpreconditioned resid norm 8.712486006725e+00 true resid norm 8.712486006713e+00 ||r(i)||/||b|| 2.081619193769e-04
1811 KSP unpreconditioned resid norm 8.712486006680e+00 true resid norm 8.712486006680e+00 ||r(i)||/||b|| 2.081619193761e-04
1812 KSP unpreconditioned resid norm 8.712486006675e+00 true resid norm 8.712486006662e+00 ||r(i)||/||b|| 2.081619193757e-04
1813 KSP unpreconditioned resid norm 8.712486006477e+00 true resid norm 8.712486006473e+00 ||r(i)||/||b|| 2.081619193712e-04
1814 KSP unpreconditioned resid norm 8.712486006151e+00 true resid norm 8.712486006138e+00 ||r(i)||/||b|| 2.081619193632e-04
1815 KSP unpreconditioned resid norm 8.712486005677e+00 true resid norm 8.712486005668e+00 ||r(i)||/||b|| 2.081619193520e-04
1816 KSP unpreconditioned resid norm 8.712486005396e+00 true resid norm 8.712486005392e+00 ||r(i)||/||b|| 2.081619193454e-04
1817 KSP unpreconditioned resid norm 8.712486005158e+00 true resid norm 8.712486005144e+00 ||r(i)||/||b|| 2.081619193394e-04
1818 KSP unpreconditioned resid norm 8.712486004903e+00 true resid norm 8.712486004896e+00 ||r(i)||/||b|| 2.081619193335e-04
1819 KSP unpreconditioned resid norm 8.712486004679e+00 true resid norm 8.712486004667e+00 ||r(i)||/||b|| 2.081619193280e-04
1820 KSP unpreconditioned resid norm 8.712486004669e+00 true resid norm 8.712486004660e+00 ||r(i)||/||b|| 2.081619193279e-04
1821 KSP unpreconditioned resid norm 8.712486004635e+00 true resid norm 8.712486004636e+00 ||r(i)||/||b|| 2.081619193273e-04
1822 KSP unpreconditioned resid norm 8.712486004360e+00 true resid norm 8.712486004361e+00 ||r(i)||/||b|| 2.081619193207e-04
1823 KSP unpreconditioned resid norm 8.712486002928e+00 true resid norm 8.712486002930e+00 ||r(i)||/||b|| 2.081619192865e-04
1824 KSP unpreconditioned resid norm 8.712486000988e+00 true resid norm 8.712486000983e+00 ||r(i)||/||b|| 2.081619192400e-04
1825 KSP unpreconditioned resid norm 8.712485999486e+00 true resid norm 8.712485999489e+00 ||r(i)||/||b|| 2.081619192043e-04
1826 KSP unpreconditioned resid norm 8.712485997640e+00 true resid norm 8.712485997635e+00 ||r(i)||/||b|| 2.081619191600e-04
1827 KSP unpreconditioned resid norm 8.712485994737e+00 true resid norm 8.712485994737e+00 ||r(i)||/||b|| 2.081619190908e-04
1828 KSP unpreconditioned resid norm 8.712485987831e+00 true resid norm 8.712485987828e+00 ||r(i)||/||b|| 2.081619189257e-04
1829 KSP unpreconditioned resid norm 8.712485984139e+00 true resid norm 8.712485984125e+00 ||r(i)||/||b|| 2.081619188372e-04
1830 KSP unpreconditioned resid norm 8.712485983876e+00 true resid norm 8.712485983876e+00 ||r(i)||/||b|| 2.081619188313e-04
1831 KSP unpreconditioned resid norm 8.712485983875e+00 true resid norm 8.712485983877e+00 ||r(i)||/||b|| 2.081619188313e-04
1832 KSP unpreconditioned resid norm 8.712485983859e+00 true resid norm 8.712485983854e+00 ||r(i)||/||b|| 2.081619188308e-04
1833 KSP unpreconditioned resid norm 8.712485983785e+00 true resid norm 8.712485983789e+00 ||r(i)||/||b|| 2.081619188292e-04
1834 KSP unpreconditioned resid norm 8.712485983618e+00 true resid norm 8.712485983623e+00 ||r(i)||/||b|| 2.081619188253e-04
1835 KSP unpreconditioned resid norm 8.712485983420e+00 true resid norm 8.712485983416e+00 ||r(i)||/||b|| 2.081619188203e-04
1836 KSP unpreconditioned resid norm 8.712485983362e+00 true resid norm 8.712485983359e+00 ||r(i)||/||b|| 2.081619188190e-04
1837 KSP unpreconditioned resid norm 8.712485983333e+00 true resid norm 8.712485983335e+00 ||r(i)||/||b|| 2.081619188184e-04
1838 KSP unpreconditioned resid norm 8.712485983241e+00 true resid norm 8.712485983251e+00 ||r(i)||/||b|| 2.081619188164e-04
1839 KSP unpreconditioned resid norm 8.712485983060e+00 true resid norm 8.712485983061e+00 ||r(i)||/||b|| 2.081619188118e-04
1840 KSP unpreconditioned resid norm 8.712485982902e+00 true resid norm 8.712485982887e+00 ||r(i)||/||b|| 2.081619188077e-04
1841 KSP unpreconditioned resid norm 8.712485982862e+00 true resid norm 8.712485982854e+00 ||r(i)||/||b|| 2.081619188069e-04
1842 KSP unpreconditioned resid norm 8.712485982858e+00 true resid norm 8.712485982858e+00 ||r(i)||/||b|| 2.081619188070e-04
1843 KSP unpreconditioned resid norm 8.712485982684e+00 true resid norm 8.712485982679e+00 ||r(i)||/||b|| 2.081619188027e-04
1844 KSP unpreconditioned resid norm 8.712485982395e+00 true resid norm 8.712485982391e+00 ||r(i)||/||b|| 2.081619187958e-04
1845 KSP unpreconditioned resid norm 8.712485981983e+00 true resid norm 8.712485981983e+00 ||r(i)||/||b|| 2.081619187861e-04
1846 KSP unpreconditioned resid norm 8.712485981737e+00 true resid norm 8.712485981746e+00 ||r(i)||/||b|| 2.081619187804e-04
1847 KSP unpreconditioned resid norm 8.712485981524e+00 true resid norm 8.712485981522e+00 ||r(i)||/||b|| 2.081619187751e-04
1848 KSP unpreconditioned resid norm 8.712485981303e+00 true resid norm 8.712485981296e+00 ||r(i)||/||b|| 2.081619187697e-04
1849 KSP unpreconditioned resid norm 8.712485981100e+00 true resid norm 8.712485981097e+00 ||r(i)||/||b|| 2.081619187649e-04
1850 KSP unpreconditioned resid norm 8.712485981090e+00 true resid norm 8.712485981096e+00 ||r(i)||/||b|| 2.081619187649e-04
1851 KSP unpreconditioned resid norm 8.712485981061e+00 true resid norm 8.712485981069e+00 ||r(i)||/||b|| 2.081619187642e-04
1852 KSP unpreconditioned resid norm 8.712485980824e+00 true resid norm 8.712485980814e+00 ||r(i)||/||b|| 2.081619187582e-04
1853 KSP unpreconditioned resid norm 8.712485979582e+00 true resid norm 8.712485979578e+00 ||r(i)||/||b|| 2.081619187286e-04
1854 KSP unpreconditioned resid norm 8.712485977891e+00 true resid norm 8.712485977887e+00 ||r(i)||/||b|| 2.081619186882e-04
1855 KSP unpreconditioned resid norm 8.712485976604e+00 true resid norm 8.712485976606e+00 ||r(i)||/||b|| 2.081619186576e-04
1856 KSP unpreconditioned resid norm 8.712485975004e+00 true resid norm 8.712485975005e+00 ||r(i)||/||b|| 2.081619186194e-04
1857 KSP unpreconditioned resid norm 8.712485972434e+00 true resid norm 8.712485972438e+00 ||r(i)||/||b|| 2.081619185580e-04
1858 KSP unpreconditioned resid norm 8.712485966310e+00 true resid norm 8.712485966317e+00 ||r(i)||/||b|| 2.081619184118e-04
1859 KSP unpreconditioned resid norm 8.712485962980e+00 true resid norm 8.712485962981e+00 ||r(i)||/||b|| 2.081619183321e-04
1860 KSP unpreconditioned resid norm 8.712485962713e+00 true resid norm 8.712485962713e+00 ||r(i)||/||b|| 2.081619183257e-04
1861 KSP unpreconditioned resid norm 8.712485962712e+00 true resid norm 8.712485962716e+00 ||r(i)||/||b|| 2.081619183257e-04
1862 KSP unpreconditioned resid norm 8.712485962698e+00 true resid norm 8.712485962717e+00 ||r(i)||/||b|| 2.081619183258e-04
1863 KSP unpreconditioned resid norm 8.712485962630e+00 true resid norm 8.712485962646e+00 ||r(i)||/||b|| 2.081619183241e-04
1864 KSP unpreconditioned resid norm 8.712485962483e+00 true resid norm 8.712485962496e+00 ||r(i)||/||b|| 2.081619183205e-04
1865 KSP unpreconditioned resid norm 8.712485962308e+00 true resid norm 8.712485962309e+00 ||r(i)||/||b|| 2.081619183160e-04
1866 KSP unpreconditioned resid norm 8.712485962256e+00 true resid norm 8.712485962267e+00 ||r(i)||/||b|| 2.081619183150e-04
1867 KSP unpreconditioned resid norm 8.712485962230e+00 true resid norm 8.712485962238e+00 ||r(i)||/||b|| 2.081619183143e-04
1868 KSP unpreconditioned resid norm 8.712485962146e+00 true resid norm 8.712485962152e+00 ||r(i)||/||b|| 2.081619183123e-04
1869 KSP unpreconditioned resid norm 8.712485961988e+00 true resid norm 8.712485962004e+00 ||r(i)||/||b|| 2.081619183087e-04
1870 KSP unpreconditioned resid norm 8.712485961851e+00 true resid norm 8.712485961874e+00 ||r(i)||/||b|| 2.081619183056e-04
1871 KSP unpreconditioned resid norm 8.712485961815e+00 true resid norm 8.712485961825e+00 ||r(i)||/||b|| 2.081619183045e-04
1872 KSP unpreconditioned resid norm 8.712485961812e+00 true resid norm 8.712485961828e+00 ||r(i)||/||b|| 2.081619183045e-04
1873 KSP unpreconditioned resid norm 8.712485961657e+00 true resid norm 8.712485961664e+00 ||r(i)||/||b|| 2.081619183006e-04
1874 KSP unpreconditioned resid norm 8.712485961402e+00 true resid norm 8.712485961416e+00 ||r(i)||/||b|| 2.081619182947e-04
1875 KSP unpreconditioned resid norm 8.712485961032e+00 true resid norm 8.712485961040e+00 ||r(i)||/||b|| 2.081619182857e-04
1876 KSP unpreconditioned resid norm 8.712485960812e+00 true resid norm 8.712485960822e+00 ||r(i)||/||b|| 2.081619182805e-04
1877 KSP unpreconditioned resid norm 8.712485960626e+00 true resid norm 8.712485960626e+00 ||r(i)||/||b|| 2.081619182758e-04
1878 KSP unpreconditioned resid norm 8.712485960427e+00 true resid norm 8.712485960437e+00 ||r(i)||/||b|| 2.081619182713e-04
1879 KSP unpreconditioned resid norm 8.712485960251e+00 true resid norm 8.712485960272e+00 ||r(i)||/||b|| 2.081619182673e-04
1880 KSP unpreconditioned resid norm 8.712485960243e+00 true resid norm 8.712485960251e+00 ||r(i)||/||b|| 2.081619182668e-04
1881 KSP unpreconditioned resid norm 8.712485960217e+00 true resid norm 8.712485960222e+00 ||r(i)||/||b|| 2.081619182662e-04
1882 KSP unpreconditioned resid norm 8.712485960002e+00 true resid norm 8.712485960014e+00 ||r(i)||/||b|| 2.081619182612e-04
1883 KSP unpreconditioned resid norm 8.712485958884e+00 true resid norm 8.712485958892e+00 ||r(i)||/||b|| 2.081619182344e-04
1884 KSP unpreconditioned resid norm 8.712485957368e+00 true resid norm 8.712485957375e+00 ||r(i)||/||b|| 2.081619181981e-04
1885 KSP unpreconditioned resid norm 8.712485956196e+00 true resid norm 8.712485956203e+00 ||r(i)||/||b|| 2.081619181701e-04
1886 KSP unpreconditioned resid norm 8.712485954754e+00 true resid norm 8.712485954765e+00 ||r(i)||/||b|| 2.081619181358e-04
1887 KSP unpreconditioned resid norm 8.712485952483e+00 true resid norm 8.712485952482e+00 ||r(i)||/||b|| 2.081619180812e-04
1888 KSP unpreconditioned resid norm 8.712485947080e+00 true resid norm 8.712485947092e+00 ||r(i)||/||b|| 2.081619179524e-04
1889 KSP unpreconditioned resid norm 8.712485944188e+00 true resid norm 8.712485944193e+00 ||r(i)||/||b|| 2.081619178832e-04
1890 KSP unpreconditioned resid norm 8.712485943997e+00 true resid norm 8.712485943997e+00 ||r(i)||/||b|| 2.081619178785e-04
1891 KSP unpreconditioned resid norm 8.712485943996e+00 true resid norm 8.712485943992e+00 ||r(i)||/||b|| 2.081619178784e-04
1892 KSP unpreconditioned resid norm 8.712485943984e+00 true resid norm 8.712485943975e+00 ||r(i)||/||b|| 2.081619178780e-04
1893 KSP unpreconditioned resid norm 8.712485943926e+00 true resid norm 8.712485943923e+00 ||r(i)||/||b|| 2.081619178767e-04
1894 KSP unpreconditioned resid norm 8.712485943796e+00 true resid norm 8.712485943795e+00 ||r(i)||/||b|| 2.081619178737e-04
1895 KSP unpreconditioned resid norm 8.712485943640e+00 true resid norm 8.712485943644e+00 ||r(i)||/||b|| 2.081619178701e-04
1896 KSP unpreconditioned resid norm 8.712485943595e+00 true resid norm 8.712485943591e+00 ||r(i)||/||b|| 2.081619178688e-04
1897 KSP unpreconditioned resid norm 8.712485943573e+00 true resid norm 8.712485943571e+00 ||r(i)||/||b|| 2.081619178683e-04
1898 KSP unpreconditioned resid norm 8.712485943500e+00 true resid norm 8.712485943497e+00 ||r(i)||/||b|| 2.081619178666e-04
1899 KSP unpreconditioned resid norm 8.712485943359e+00 true resid norm 8.712485943357e+00 ||r(i)||/||b|| 2.081619178632e-04
1900 KSP unpreconditioned resid norm 8.712485943235e+00 true resid norm 8.712485943229e+00 ||r(i)||/||b|| 2.081619178601e-04
1901 KSP unpreconditioned resid norm 8.712485943204e+00 true resid norm 8.712485943200e+00 ||r(i)||/||b|| 2.081619178595e-04
1902 KSP unpreconditioned resid norm 8.712485943201e+00 true resid norm 8.712485943192e+00 ||r(i)||/||b|| 2.081619178593e-04
1903 KSP unpreconditioned resid norm 8.712485943065e+00 true resid norm 8.712485943046e+00 ||r(i)||/||b|| 2.081619178558e-04
1904 KSP unpreconditioned resid norm 8.712485942839e+00 true resid norm 8.712485942830e+00 ||r(i)||/||b|| 2.081619178506e-04
1905 KSP unpreconditioned resid norm 8.712485942517e+00 true resid norm 8.712485942511e+00 ||r(i)||/||b|| 2.081619178430e-04
1906 KSP unpreconditioned resid norm 8.712485942324e+00 true resid norm 8.712485942325e+00 ||r(i)||/||b|| 2.081619178386e-04
1907 KSP unpreconditioned resid norm 8.712485942158e+00 true resid norm 8.712485942149e+00 ||r(i)||/||b|| 2.081619178343e-04
1908 KSP unpreconditioned resid norm 8.712485941984e+00 true resid norm 8.712485941971e+00 ||r(i)||/||b|| 2.081619178301e-04
1909 KSP unpreconditioned resid norm 8.712485941826e+00 true resid norm 8.712485941824e+00 ||r(i)||/||b|| 2.081619178266e-04
1910 KSP unpreconditioned resid norm 8.712485941819e+00 true resid norm 8.712485941820e+00 ||r(i)||/||b|| 2.081619178265e-04
1911 KSP unpreconditioned resid norm 8.712485941795e+00 true resid norm 8.712485941787e+00 ||r(i)||/||b|| 2.081619178257e-04
1912 KSP unpreconditioned resid norm 8.712485941610e+00 true resid norm 8.712485941609e+00 ||r(i)||/||b|| 2.081619178214e-04
1913 KSP unpreconditioned resid norm 8.712485940638e+00 true resid norm 8.712485940633e+00 ||r(i)||/||b|| 2.081619177981e-04
1914 KSP unpreconditioned resid norm 8.712485939314e+00 true resid norm 8.712485939313e+00 ||r(i)||/||b|| 2.081619177666e-04
1915 KSP unpreconditioned resid norm 8.712485938306e+00 true resid norm 8.712485938299e+00 ||r(i)||/||b|| 2.081619177424e-04
1916 KSP unpreconditioned resid norm 8.712485937054e+00 true resid norm 8.712485937045e+00 ||r(i)||/||b|| 2.081619177124e-04
1917 KSP unpreconditioned resid norm 8.712485935044e+00 true resid norm 8.712485935035e+00 ||r(i)||/||b|| 2.081619176644e-04
1918 KSP unpreconditioned resid norm 8.712485930254e+00 true resid norm 8.712485930244e+00 ||r(i)||/||b|| 2.081619175499e-04
1919 KSP unpreconditioned resid norm 8.712485927651e+00 true resid norm 8.712485927647e+00 ||r(i)||/||b|| 2.081619174879e-04
1920 KSP unpreconditioned resid norm 8.712485927438e+00 true resid norm 8.712485927438e+00 ||r(i)||/||b|| 2.081619174829e-04
1921 KSP unpreconditioned resid norm 8.712485927437e+00 true resid norm 8.712485927441e+00 ||r(i)||/||b|| 2.081619174829e-04
1922 KSP unpreconditioned resid norm 8.712485927426e+00 true resid norm 8.712485927431e+00 ||r(i)||/||b|| 2.081619174827e-04
1923 KSP unpreconditioned resid norm 8.712485927374e+00 true resid norm 8.712485927373e+00 ||r(i)||/||b|| 2.081619174813e-04
1924 KSP unpreconditioned resid norm 8.712485927258e+00 true resid norm 8.712485927256e+00 ||r(i)||/||b|| 2.081619174785e-04
1925 KSP unpreconditioned resid norm 8.712485927121e+00 true resid norm 8.712485927130e+00 ||r(i)||/||b|| 2.081619174755e-04
1926 KSP unpreconditioned resid norm 8.712485927081e+00 true resid norm 8.712485927085e+00 ||r(i)||/||b|| 2.081619174744e-04
1927 KSP unpreconditioned resid norm 8.712485927060e+00 true resid norm 8.712485927056e+00 ||r(i)||/||b|| 2.081619174737e-04
1928 KSP unpreconditioned resid norm 8.712485926995e+00 true resid norm 8.712485926999e+00 ||r(i)||/||b|| 2.081619174724e-04
1929 KSP unpreconditioned resid norm 8.712485926872e+00 true resid norm 8.712485926878e+00 ||r(i)||/||b|| 2.081619174695e-04
1930 KSP unpreconditioned resid norm 8.712485926764e+00 true resid norm 8.712485926762e+00 ||r(i)||/||b|| 2.081619174667e-04
1931 KSP unpreconditioned resid norm 8.712485926736e+00 true resid norm 8.712485926741e+00 ||r(i)||/||b|| 2.081619174662e-04
1932 KSP unpreconditioned resid norm 8.712485926734e+00 true resid norm 8.712485926747e+00 ||r(i)||/||b|| 2.081619174664e-04
1933 KSP unpreconditioned resid norm 8.712485926612e+00 true resid norm 8.712485926609e+00 ||r(i)||/||b|| 2.081619174631e-04
1934 KSP unpreconditioned resid norm 8.712485926413e+00 true resid norm 8.712485926417e+00 ||r(i)||/||b|| 2.081619174585e-04
1935 KSP unpreconditioned resid norm 8.712485926124e+00 true resid norm 8.712485926132e+00 ||r(i)||/||b|| 2.081619174517e-04
1936 KSP unpreconditioned resid norm 8.712485925952e+00 true resid norm 8.712485925949e+00 ||r(i)||/||b|| 2.081619174473e-04
1937 KSP unpreconditioned resid norm 8.712485925807e+00 true resid norm 8.712485925809e+00 ||r(i)||/||b|| 2.081619174439e-04
1938 KSP unpreconditioned resid norm 8.712485925651e+00 true resid norm 8.712485925655e+00 ||r(i)||/||b|| 2.081619174403e-04
1939 KSP unpreconditioned resid norm 8.712485925514e+00 true resid norm 8.712485925526e+00 ||r(i)||/||b|| 2.081619174372e-04
1940 KSP unpreconditioned resid norm 8.712485925507e+00 true resid norm 8.712485925514e+00 ||r(i)||/||b|| 2.081619174369e-04
1941 KSP unpreconditioned resid norm 8.712485925487e+00 true resid norm 8.712485925498e+00 ||r(i)||/||b|| 2.081619174365e-04
1942 KSP unpreconditioned resid norm 8.712485925319e+00 true resid norm 8.712485925335e+00 ||r(i)||/||b|| 2.081619174326e-04
1943 KSP unpreconditioned resid norm 8.712485924445e+00 true resid norm 8.712485924461e+00 ||r(i)||/||b|| 2.081619174117e-04
1944 KSP unpreconditioned resid norm 8.712485923260e+00 true resid norm 8.712485923263e+00 ||r(i)||/||b|| 2.081619173831e-04
1945 KSP unpreconditioned resid norm 8.712485922346e+00 true resid norm 8.712485922345e+00 ||r(i)||/||b|| 2.081619173612e-04
1946 KSP unpreconditioned resid norm 8.712485921219e+00 true resid norm 8.712485921220e+00 ||r(i)||/||b|| 2.081619173343e-04
1947 KSP unpreconditioned resid norm 8.712485919443e+00 true resid norm 8.712485919453e+00 ||r(i)||/||b|| 2.081619172921e-04
1948 KSP unpreconditioned resid norm 8.712485915216e+00 true resid norm 8.712485915219e+00 ||r(i)||/||b|| 2.081619171909e-04
1949 KSP unpreconditioned resid norm 8.712485912952e+00 true resid norm 8.712485912952e+00 ||r(i)||/||b|| 2.081619171368e-04
1950 KSP unpreconditioned resid norm 8.712485912801e+00 true resid norm 8.712485912801e+00 ||r(i)||/||b|| 2.081619171331e-04
1951 KSP unpreconditioned resid norm 8.712485912800e+00 true resid norm 8.712485912806e+00 ||r(i)||/||b|| 2.081619171333e-04
1952 KSP unpreconditioned resid norm 8.712485912791e+00 true resid norm 8.712485912797e+00 ||r(i)||/||b|| 2.081619171331e-04
1953 KSP unpreconditioned resid norm 8.712485912745e+00 true resid norm 8.712485912742e+00 ||r(i)||/||b|| 2.081619171317e-04
1954 KSP unpreconditioned resid norm 8.712485912643e+00 true resid norm 8.712485912642e+00 ||r(i)||/||b|| 2.081619171294e-04
1955 KSP unpreconditioned resid norm 8.712485912522e+00 true resid norm 8.712485912522e+00 ||r(i)||/||b|| 2.081619171265e-04
1956 KSP unpreconditioned resid norm 8.712485912486e+00 true resid norm 8.712485912476e+00 ||r(i)||/||b|| 2.081619171254e-04
1957 KSP unpreconditioned resid norm 8.712485912469e+00 true resid norm 8.712485912465e+00 ||r(i)||/||b|| 2.081619171251e-04
1958 KSP unpreconditioned resid norm 8.712485912412e+00 true resid norm 8.712485912409e+00 ||r(i)||/||b|| 2.081619171238e-04
1959 KSP unpreconditioned resid norm 8.712485912302e+00 true resid norm 8.712485912302e+00 ||r(i)||/||b|| 2.081619171212e-04
1960 KSP unpreconditioned resid norm 8.712485912205e+00 true resid norm 8.712485912198e+00 ||r(i)||/||b|| 2.081619171187e-04
1961 KSP unpreconditioned resid norm 8.712485912181e+00 true resid norm 8.712485912176e+00 ||r(i)||/||b|| 2.081619171182e-04
1962 KSP unpreconditioned resid norm 8.712485912178e+00 true resid norm 8.712485912177e+00 ||r(i)||/||b|| 2.081619171182e-04
1963 KSP unpreconditioned resid norm 8.712485912072e+00 true resid norm 8.712485912070e+00 ||r(i)||/||b|| 2.081619171157e-04
1964 KSP unpreconditioned resid norm 8.712485911895e+00 true resid norm 8.712485911880e+00 ||r(i)||/||b|| 2.081619171111e-04
1965 KSP unpreconditioned resid norm 8.712485911643e+00 true resid norm 8.712485911646e+00 ||r(i)||/||b|| 2.081619171056e-04
1966 KSP unpreconditioned resid norm 8.712485911492e+00 true resid norm 8.712485911492e+00 ||r(i)||/||b|| 2.081619171019e-04
1967 KSP unpreconditioned resid norm 8.712485911362e+00 true resid norm 8.712485911353e+00 ||r(i)||/||b|| 2.081619170986e-04
1968 KSP unpreconditioned resid norm 8.712485911227e+00 true resid norm 8.712485911225e+00 ||r(i)||/||b|| 2.081619170955e-04
1969 KSP unpreconditioned resid norm 8.712485911103e+00 true resid norm 8.712485911100e+00 ||r(i)||/||b|| 2.081619170925e-04
1970 KSP unpreconditioned resid norm 8.712485911097e+00 true resid norm 8.712485911098e+00 ||r(i)||/||b|| 2.081619170925e-04
1971 KSP unpreconditioned resid norm 8.712485911079e+00 true resid norm 8.712485911077e+00 ||r(i)||/||b|| 2.081619170920e-04
1972 KSP unpreconditioned resid norm 8.712485910934e+00 true resid norm 8.712485910931e+00 ||r(i)||/||b|| 2.081619170885e-04
1973 KSP unpreconditioned resid norm 8.712485910173e+00 true resid norm 8.712485910178e+00 ||r(i)||/||b|| 2.081619170705e-04
1974 KSP unpreconditioned resid norm 8.712485909137e+00 true resid norm 8.712485909137e+00 ||r(i)||/||b|| 2.081619170456e-04
1975 KSP unpreconditioned resid norm 8.712485908347e+00 true resid norm 8.712485908346e+00 ||r(i)||/||b|| 2.081619170267e-04
1976 KSP unpreconditioned resid norm 8.712485907367e+00 true resid norm 8.712485907351e+00 ||r(i)||/||b|| 2.081619170029e-04
1977 KSP unpreconditioned resid norm 8.712485905795e+00 true resid norm 8.712485905800e+00 ||r(i)||/||b|| 2.081619169659e-04
1978 KSP unpreconditioned resid norm 8.712485902049e+00 true resid norm 8.712485902041e+00 ||r(i)||/||b|| 2.081619168761e-04
1979 KSP unpreconditioned resid norm 8.712485900015e+00 true resid norm 8.712485900009e+00 ||r(i)||/||b|| 2.081619168275e-04
1980 KSP unpreconditioned resid norm 8.712485899862e+00 true resid norm 8.712485899862e+00 ||r(i)||/||b|| 2.081619168240e-04
1981 KSP unpreconditioned resid norm 8.712485899861e+00 true resid norm 8.712485899842e+00 ||r(i)||/||b|| 2.081619168235e-04
1982 KSP unpreconditioned resid norm 8.712485899852e+00 true resid norm 8.712485899846e+00 ||r(i)||/||b|| 2.081619168236e-04
1983 KSP unpreconditioned resid norm 8.712485899811e+00 true resid norm 8.712485899812e+00 ||r(i)||/||b|| 2.081619168228e-04
1984 KSP unpreconditioned resid norm 8.712485899721e+00 true resid norm 8.712485899723e+00 ||r(i)||/||b|| 2.081619168207e-04
1985 KSP unpreconditioned resid norm 8.712485899614e+00 true resid norm 8.712485899613e+00 ||r(i)||/||b|| 2.081619168181e-04
1986 KSP unpreconditioned resid norm 8.712485899582e+00 true resid norm 8.712485899571e+00 ||r(i)||/||b|| 2.081619168171e-04
1987 KSP unpreconditioned resid norm 8.712485899566e+00 true resid norm 8.712485899561e+00 ||r(i)||/||b|| 2.081619168168e-04
1988 KSP unpreconditioned resid norm 8.712485899515e+00 true resid norm 8.712485899512e+00 ||r(i)||/||b|| 2.081619168156e-04
1989 KSP unpreconditioned resid norm 8.712485899419e+00 true resid norm 8.712485899408e+00 ||r(i)||/||b|| 2.081619168132e-04
1990 KSP unpreconditioned resid norm 8.712485899334e+00 true resid norm 8.712485899328e+00 ||r(i)||/||b|| 2.081619168113e-04
1991 KSP unpreconditioned resid norm 8.712485899313e+00 true resid norm 8.712485899303e+00 ||r(i)||/||b|| 2.081619168107e-04
1992 KSP unpreconditioned resid norm 8.712485899311e+00 true resid norm 8.712485899310e+00 ||r(i)||/||b|| 2.081619168108e-04
1993 KSP unpreconditioned resid norm 8.712485899216e+00 true resid norm 8.712485899210e+00 ||r(i)||/||b|| 2.081619168084e-04
1994 KSP unpreconditioned resid norm 8.712485899060e+00 true resid norm 8.712485899052e+00 ||r(i)||/||b|| 2.081619168047e-04
1995 KSP unpreconditioned resid norm 8.712485898834e+00 true resid norm 8.712485898826e+00 ||r(i)||/||b|| 2.081619167993e-04
1996 KSP unpreconditioned resid norm 8.712485898700e+00 true resid norm 8.712485898693e+00 ||r(i)||/||b|| 2.081619167961e-04
1997 KSP unpreconditioned resid norm 8.712485898586e+00 true resid norm 8.712485898585e+00 ||r(i)||/||b|| 2.081619167935e-04
1998 KSP unpreconditioned resid norm 8.712485898464e+00 true resid norm 8.712485898467e+00 ||r(i)||/||b|| 2.081619167907e-04
1999 KSP unpreconditioned resid norm 8.712485898357e+00 true resid norm 8.712485898350e+00 ||r(i)||/||b|| 2.081619167879e-04
2000 KSP unpreconditioned resid norm 8.712485898352e+00 true resid norm 8.712485898344e+00 ||r(i)||/||b|| 2.081619167877e-04
2001 KSP unpreconditioned resid norm 8.712485898336e+00 true resid norm 8.712485898334e+00 ||r(i)||/||b|| 2.081619167875e-04
2002 KSP unpreconditioned resid norm 8.712485898205e+00 true resid norm 8.712485898192e+00 ||r(i)||/||b|| 2.081619167841e-04
2003 KSP unpreconditioned resid norm 8.712485897522e+00 true resid norm 8.712485897512e+00 ||r(i)||/||b|| 2.081619167679e-04
2004 KSP unpreconditioned resid norm 8.712485896596e+00 true resid norm 8.712485896592e+00 ||r(i)||/||b|| 2.081619167459e-04
2005 KSP unpreconditioned resid norm 8.712485895882e+00 true resid norm 8.712485895877e+00 ||r(i)||/||b|| 2.081619167288e-04
2006 KSP unpreconditioned resid norm 8.712485895002e+00 true resid norm 8.712485894995e+00 ||r(i)||/||b|| 2.081619167077e-04
2007 KSP unpreconditioned resid norm 8.712485893613e+00 true resid norm 8.712485893605e+00 ||r(i)||/||b|| 2.081619166745e-04
2008 KSP unpreconditioned resid norm 8.712485890306e+00 true resid norm 8.712485890301e+00 ||r(i)||/||b|| 2.081619165956e-04
2009 KSP unpreconditioned resid norm 8.712485888533e+00 true resid norm 8.712485888533e+00 ||r(i)||/||b|| 2.081619165533e-04
2010 KSP unpreconditioned resid norm 8.712485888401e+00 true resid norm 8.712485888401e+00 ||r(i)||/||b|| 2.081619165502e-04
2011 KSP unpreconditioned resid norm 8.712485888400e+00 true resid norm 8.712485888397e+00 ||r(i)||/||b|| 2.081619165501e-04
2012 KSP unpreconditioned resid norm 8.712485888393e+00 true resid norm 8.712485888391e+00 ||r(i)||/||b|| 2.081619165499e-04
2013 KSP unpreconditioned resid norm 8.712485888357e+00 true resid norm 8.712485888351e+00 ||r(i)||/||b|| 2.081619165490e-04
2014 KSP unpreconditioned resid norm 8.712485888278e+00 true resid norm 8.712485888278e+00 ||r(i)||/||b|| 2.081619165472e-04
2015 KSP unpreconditioned resid norm 8.712485888183e+00 true resid norm 8.712485888179e+00 ||r(i)||/||b|| 2.081619165449e-04
2016 KSP unpreconditioned resid norm 8.712485888155e+00 true resid norm 8.712485888152e+00 ||r(i)||/||b|| 2.081619165442e-04
2017 KSP unpreconditioned resid norm 8.712485888141e+00 true resid norm 8.712485888148e+00 ||r(i)||/||b|| 2.081619165441e-04
2018 KSP unpreconditioned resid norm 8.712485888097e+00 true resid norm 8.712485888101e+00 ||r(i)||/||b|| 2.081619165430e-04
2019 KSP unpreconditioned resid norm 8.712485888011e+00 true resid norm 8.712485888009e+00 ||r(i)||/||b|| 2.081619165408e-04
2020 KSP unpreconditioned resid norm 8.712485887935e+00 true resid norm 8.712485887933e+00 ||r(i)||/||b|| 2.081619165390e-04
2021 KSP unpreconditioned resid norm 8.712485887916e+00 true resid norm 8.712485887913e+00 ||r(i)||/||b|| 2.081619165385e-04
2022 KSP unpreconditioned resid norm 8.712485887914e+00 true resid norm 8.712485887922e+00 ||r(i)||/||b|| 2.081619165387e-04
2023 KSP unpreconditioned resid norm 8.712485887831e+00 true resid norm 8.712485887833e+00 ||r(i)||/||b|| 2.081619165366e-04
2024 KSP unpreconditioned resid norm 8.712485887692e+00 true resid norm 8.712485887695e+00 ||r(i)||/||b|| 2.081619165333e-04
2025 KSP unpreconditioned resid norm 8.712485887495e+00 true resid norm 8.712485887487e+00 ||r(i)||/||b|| 2.081619165283e-04
2026 KSP unpreconditioned resid norm 8.712485887377e+00 true resid norm 8.712485887385e+00 ||r(i)||/||b|| 2.081619165259e-04
2027 KSP unpreconditioned resid norm 8.712485887276e+00 true resid norm 8.712485887276e+00 ||r(i)||/||b|| 2.081619165233e-04
2028 KSP unpreconditioned resid norm 8.712485887169e+00 true resid norm 8.712485887173e+00 ||r(i)||/||b|| 2.081619165208e-04
2029 KSP unpreconditioned resid norm 8.712485887073e+00 true resid norm 8.712485887076e+00 ||r(i)||/||b|| 2.081619165185e-04
2030 KSP unpreconditioned resid norm 8.712485887068e+00 true resid norm 8.712485887069e+00 ||r(i)||/||b|| 2.081619165184e-04
2031 KSP unpreconditioned resid norm 8.712485887054e+00 true resid norm 8.712485887055e+00 ||r(i)||/||b|| 2.081619165180e-04
2032 KSP unpreconditioned resid norm 8.712485886940e+00 true resid norm 8.712485886943e+00 ||r(i)||/||b|| 2.081619165153e-04
2033 KSP unpreconditioned resid norm 8.712485886345e+00 true resid norm 8.712485886346e+00 ||r(i)||/||b|| 2.081619165011e-04
2034 KSP unpreconditioned resid norm 8.712485885534e+00 true resid norm 8.712485885533e+00 ||r(i)||/||b|| 2.081619164816e-04
2035 KSP unpreconditioned resid norm 8.712485884916e+00 true resid norm 8.712485884914e+00 ||r(i)||/||b|| 2.081619164669e-04
2036 KSP unpreconditioned resid norm 8.712485884149e+00 true resid norm 8.712485884155e+00 ||r(i)||/||b|| 2.081619164487e-04
2037 KSP unpreconditioned resid norm 8.712485882919e+00 true resid norm 8.712485882930e+00 ||r(i)||/||b|| 2.081619164195e-04
2038 KSP unpreconditioned resid norm 8.712485879990e+00 true resid norm 8.712485879990e+00 ||r(i)||/||b|| 2.081619163492e-04
2039 KSP unpreconditioned resid norm 8.712485878400e+00 true resid norm 8.712485878393e+00 ||r(i)||/||b|| 2.081619163111e-04
2040 KSP unpreconditioned resid norm 8.712485878278e+00 true resid norm 8.712485878278e+00 ||r(i)||/||b|| 2.081619163083e-04
2041 KSP unpreconditioned resid norm 8.712485878278e+00 true resid norm 8.712485878279e+00 ||r(i)||/||b|| 2.081619163084e-04
2042 KSP unpreconditioned resid norm 8.712485878271e+00 true resid norm 8.712485878265e+00 ||r(i)||/||b|| 2.081619163080e-04
2043 KSP unpreconditioned resid norm 8.712485878239e+00 true resid norm 8.712485878248e+00 ||r(i)||/||b|| 2.081619163076e-04
2044 KSP unpreconditioned resid norm 8.712485878168e+00 true resid norm 8.712485878168e+00 ||r(i)||/||b|| 2.081619163057e-04
2045 KSP unpreconditioned resid norm 8.712485878084e+00 true resid norm 8.712485878088e+00 ||r(i)||/||b|| 2.081619163038e-04
2046 KSP unpreconditioned resid norm 8.712485878060e+00 true resid norm 8.712485878080e+00 ||r(i)||/||b|| 2.081619163036e-04
2047 KSP unpreconditioned resid norm 8.712485878047e+00 true resid norm 8.712485878064e+00 ||r(i)||/||b|| 2.081619163032e-04
2048 KSP unpreconditioned resid norm 8.712485878007e+00 true resid norm 8.712485878007e+00 ||r(i)||/||b|| 2.081619163018e-04
2049 KSP unpreconditioned resid norm 8.712485877932e+00 true resid norm 8.712485877944e+00 ||r(i)||/||b|| 2.081619163003e-04
2050 KSP unpreconditioned resid norm 8.712485877866e+00 true resid norm 8.712485877869e+00 ||r(i)||/||b|| 2.081619162985e-04
2051 KSP unpreconditioned resid norm 8.712485877849e+00 true resid norm 8.712485877858e+00 ||r(i)||/||b|| 2.081619162983e-04
2052 KSP unpreconditioned resid norm 8.712485877847e+00 true resid norm 8.712485877854e+00 ||r(i)||/||b|| 2.081619162982e-04
2053 KSP unpreconditioned resid norm 8.712485877773e+00 true resid norm 8.712485877777e+00 ||r(i)||/||b|| 2.081619162964e-04
2054 KSP unpreconditioned resid norm 8.712485877651e+00 true resid norm 8.712485877664e+00 ||r(i)||/||b|| 2.081619162936e-04
2055 KSP unpreconditioned resid norm 8.712485877474e+00 true resid norm 8.712485877482e+00 ||r(i)||/||b|| 2.081619162893e-04
2056 KSP unpreconditioned resid norm 8.712485877370e+00 true resid norm 8.712485877375e+00 ||r(i)||/||b|| 2.081619162867e-04
2057 KSP unpreconditioned resid norm 8.712485877280e+00 true resid norm 8.712485877287e+00 ||r(i)||/||b|| 2.081619162846e-04
2058 KSP unpreconditioned resid norm 8.712485877185e+00 true resid norm 8.712485877193e+00 ||r(i)||/||b|| 2.081619162824e-04
2059 KSP unpreconditioned resid norm 8.712485877101e+00 true resid norm 8.712485877109e+00 ||r(i)||/||b|| 2.081619162804e-04
2060 KSP unpreconditioned resid norm 8.712485877097e+00 true resid norm 8.712485877097e+00 ||r(i)||/||b|| 2.081619162801e-04
2061 KSP unpreconditioned resid norm 8.712485877085e+00 true resid norm 8.712485877095e+00 ||r(i)||/||b|| 2.081619162801e-04
2062 KSP unpreconditioned resid norm 8.712485876982e+00 true resid norm 8.712485876981e+00 ||r(i)||/||b|| 2.081619162773e-04
2063 KSP unpreconditioned resid norm 8.712485876449e+00 true resid norm 8.712485876451e+00 ||r(i)||/||b|| 2.081619162647e-04
2064 KSP unpreconditioned resid norm 8.712485875725e+00 true resid norm 8.712485875738e+00 ||r(i)||/||b|| 2.081619162476e-04
2065 KSP unpreconditioned resid norm 8.712485875168e+00 true resid norm 8.712485875182e+00 ||r(i)||/||b|| 2.081619162343e-04
2066 KSP unpreconditioned resid norm 8.712485874480e+00 true resid norm 8.712485874482e+00 ||r(i)||/||b|| 2.081619162176e-04
2067 KSP unpreconditioned resid norm 8.712485873393e+00 true resid norm 8.712485873397e+00 ||r(i)||/||b|| 2.081619161917e-04
2068 KSP unpreconditioned resid norm 8.712485870807e+00 true resid norm 8.712485870815e+00 ||r(i)||/||b|| 2.081619161300e-04
2069 KSP unpreconditioned resid norm 8.712485869419e+00 true resid norm 8.712485869424e+00 ||r(i)||/||b|| 2.081619160968e-04
2070 KSP unpreconditioned resid norm 8.712485869321e+00 true resid norm 8.712485869321e+00 ||r(i)||/||b|| 2.081619160943e-04
2071 KSP unpreconditioned resid norm 8.712485869320e+00 true resid norm 8.712485869337e+00 ||r(i)||/||b|| 2.081619160947e-04
2072 KSP unpreconditioned resid norm 8.712485869315e+00 true resid norm 8.712485869323e+00 ||r(i)||/||b|| 2.081619160944e-04
2073 KSP unpreconditioned resid norm 8.712485869287e+00 true resid norm 8.712485869294e+00 ||r(i)||/||b|| 2.081619160937e-04
2074 KSP unpreconditioned resid norm 8.712485869224e+00 true resid norm 8.712485869227e+00 ||r(i)||/||b|| 2.081619160921e-04
2075 KSP unpreconditioned resid norm 8.712485869150e+00 true resid norm 8.712485869161e+00 ||r(i)||/||b|| 2.081619160905e-04
2076 KSP unpreconditioned resid norm 8.712485869128e+00 true resid norm 8.712485869138e+00 ||r(i)||/||b|| 2.081619160899e-04
2077 KSP unpreconditioned resid norm 8.712485869118e+00 true resid norm 8.712485869125e+00 ||r(i)||/||b|| 2.081619160896e-04
2078 KSP unpreconditioned resid norm 8.712485869083e+00 true resid norm 8.712485869092e+00 ||r(i)||/||b|| 2.081619160888e-04
2079 KSP unpreconditioned resid norm 8.712485869016e+00 true resid norm 8.712485869019e+00 ||r(i)||/||b|| 2.081619160871e-04
2080 KSP unpreconditioned resid norm 8.712485868956e+00 true resid norm 8.712485868970e+00 ||r(i)||/||b|| 2.081619160859e-04
2081 KSP unpreconditioned resid norm 8.712485868941e+00 true resid norm 8.712485868956e+00 ||r(i)||/||b|| 2.081619160856e-04
2082 KSP unpreconditioned resid norm 8.712485868940e+00 true resid norm 8.712485868943e+00 ||r(i)||/||b|| 2.081619160853e-04
2083 KSP unpreconditioned resid norm 8.712485868875e+00 true resid norm 8.712485868886e+00 ||r(i)||/||b|| 2.081619160839e-04
2084 KSP unpreconditioned resid norm 8.712485868767e+00 true resid norm 8.712485868771e+00 ||r(i)||/||b|| 2.081619160812e-04
2085 KSP unpreconditioned resid norm 8.712485868612e+00 true resid norm 8.712485868617e+00 ||r(i)||/||b|| 2.081619160775e-04
2086 KSP unpreconditioned resid norm 8.712485868520e+00 true resid norm 8.712485868529e+00 ||r(i)||/||b|| 2.081619160754e-04
2087 KSP unpreconditioned resid norm 8.712485868441e+00 true resid norm 8.712485868461e+00 ||r(i)||/||b|| 2.081619160738e-04
2088 KSP unpreconditioned resid norm 8.712485868358e+00 true resid norm 8.712485868368e+00 ||r(i)||/||b|| 2.081619160715e-04
2089 KSP unpreconditioned resid norm 8.712485868282e+00 true resid norm 8.712485868288e+00 ||r(i)||/||b|| 2.081619160696e-04
2090 KSP unpreconditioned resid norm 8.712485868279e+00 true resid norm 8.712485868287e+00 ||r(i)||/||b|| 2.081619160696e-04
2091 KSP unpreconditioned resid norm 8.712485868267e+00 true resid norm 8.712485868279e+00 ||r(i)||/||b|| 2.081619160694e-04
2092 KSP unpreconditioned resid norm 8.712485868179e+00 true resid norm 8.712485868183e+00 ||r(i)||/||b|| 2.081619160671e-04
2093 KSP unpreconditioned resid norm 8.712485867712e+00 true resid norm 8.712485867718e+00 ||r(i)||/||b|| 2.081619160560e-04
2094 KSP unpreconditioned resid norm 8.712485867078e+00 true resid norm 8.712485867089e+00 ||r(i)||/||b|| 2.081619160410e-04
2095 KSP unpreconditioned resid norm 8.712485866594e+00 true resid norm 8.712485866597e+00 ||r(i)||/||b|| 2.081619160292e-04
2096 KSP unpreconditioned resid norm 8.712485865994e+00 true resid norm 8.712485866000e+00 ||r(i)||/||b|| 2.081619160150e-04
2097 KSP unpreconditioned resid norm 8.712485865032e+00 true resid norm 8.712485865044e+00 ||r(i)||/||b|| 2.081619159921e-04
2098 KSP unpreconditioned resid norm 8.712485862741e+00 true resid norm 8.712485862746e+00 ||r(i)||/||b|| 2.081619159372e-04
2099 KSP unpreconditioned resid norm 8.712485861499e+00 true resid norm 8.712485861514e+00 ||r(i)||/||b|| 2.081619159078e-04
2100 KSP unpreconditioned resid norm 8.712485861404e+00 true resid norm 8.712485861404e+00 ||r(i)||/||b|| 2.081619159052e-04
2101 KSP unpreconditioned resid norm 8.712485861404e+00 true resid norm 8.712485861409e+00 ||r(i)||/||b|| 2.081619159053e-04
2102 KSP unpreconditioned resid norm 8.712485861398e+00 true resid norm 8.712485861412e+00 ||r(i)||/||b|| 2.081619159054e-04
2103 KSP unpreconditioned resid norm 8.712485861373e+00 true resid norm 8.712485861375e+00 ||r(i)||/||b|| 2.081619159045e-04
2104 KSP unpreconditioned resid norm 8.712485861318e+00 true resid norm 8.712485861318e+00 ||r(i)||/||b|| 2.081619159031e-04
2105 KSP unpreconditioned resid norm 8.712485861252e+00 true resid norm 8.712485861268e+00 ||r(i)||/||b|| 2.081619159019e-04
2106 KSP unpreconditioned resid norm 8.712485861233e+00 true resid norm 8.712485861244e+00 ||r(i)||/||b|| 2.081619159013e-04
2107 KSP unpreconditioned resid norm 8.712485861223e+00 true resid norm 8.712485861224e+00 ||r(i)||/||b|| 2.081619159009e-04
2108 KSP unpreconditioned resid norm 8.712485861192e+00 true resid norm 8.712485861200e+00 ||r(i)||/||b|| 2.081619159003e-04
2109 KSP unpreconditioned resid norm 8.712485861133e+00 true resid norm 8.712485861134e+00 ||r(i)||/||b|| 2.081619158987e-04
2110 KSP unpreconditioned resid norm 8.712485861081e+00 true resid norm 8.712485861091e+00 ||r(i)||/||b|| 2.081619158977e-04
2111 KSP unpreconditioned resid norm 8.712485861068e+00 true resid norm 8.712485861070e+00 ||r(i)||/||b|| 2.081619158972e-04
2112 KSP unpreconditioned resid norm 8.712485861067e+00 true resid norm 8.712485861079e+00 ||r(i)||/||b|| 2.081619158974e-04
2113 KSP unpreconditioned resid norm 8.712485861009e+00 true resid norm 8.712485861016e+00 ||r(i)||/||b|| 2.081619158959e-04
2114 KSP unpreconditioned resid norm 8.712485860914e+00 true resid norm 8.712485860912e+00 ||r(i)||/||b|| 2.081619158934e-04
2115 KSP unpreconditioned resid norm 8.712485860776e+00 true resid norm 8.712485860776e+00 ||r(i)||/||b|| 2.081619158902e-04
2116 KSP unpreconditioned resid norm 8.712485860694e+00 true resid norm 8.712485860714e+00 ||r(i)||/||b|| 2.081619158887e-04
2117 KSP unpreconditioned resid norm 8.712485860624e+00 true resid norm 8.712485860623e+00 ||r(i)||/||b|| 2.081619158865e-04
2118 KSP unpreconditioned resid norm 8.712485860550e+00 true resid norm 8.712485860554e+00 ||r(i)||/||b|| 2.081619158849e-04
2119 KSP unpreconditioned resid norm 8.712485860484e+00 true resid norm 8.712485860494e+00 ||r(i)||/||b|| 2.081619158834e-04
2120 KSP unpreconditioned resid norm 8.712485860481e+00 true resid norm 8.712485860489e+00 ||r(i)||/||b|| 2.081619158833e-04
2121 KSP unpreconditioned resid norm 8.712485860471e+00 true resid norm 8.712485860478e+00 ||r(i)||/||b|| 2.081619158830e-04
2122 KSP unpreconditioned resid norm 8.712485860391e+00 true resid norm 8.712485860394e+00 ||r(i)||/||b|| 2.081619158810e-04
2123 KSP unpreconditioned resid norm 8.712485859974e+00 true resid norm 8.712485859970e+00 ||r(i)||/||b|| 2.081619158709e-04
2124 KSP unpreconditioned resid norm 8.712485859409e+00 true resid norm 8.712485859409e+00 ||r(i)||/||b|| 2.081619158575e-04
2125 KSP unpreconditioned resid norm 8.712485858973e+00 true resid norm 8.712485858975e+00 ||r(i)||/||b|| 2.081619158471e-04
2126 KSP unpreconditioned resid norm 8.712485858435e+00 true resid norm 8.712485858437e+00 ||r(i)||/||b|| 2.081619158343e-04
2127 KSP unpreconditioned resid norm 8.712485857586e+00 true resid norm 8.712485857594e+00 ||r(i)||/||b|| 2.081619158141e-04
2128 KSP unpreconditioned resid norm 8.712485855563e+00 true resid norm 8.712485855572e+00 ||r(i)||/||b|| 2.081619157658e-04
2129 KSP unpreconditioned resid norm 8.712485854476e+00 true resid norm 8.712485854484e+00 ||r(i)||/||b|| 2.081619157398e-04
2130 KSP unpreconditioned resid norm 8.712485854407e+00 true resid norm 8.712485854407e+00 ||r(i)||/||b|| 2.081619157380e-04
2131 KSP unpreconditioned resid norm 8.712485854406e+00 true resid norm 8.712485854406e+00 ||r(i)||/||b|| 2.081619157380e-04
2132 KSP unpreconditioned resid norm 8.712485854402e+00 true resid norm 8.712485854406e+00 ||r(i)||/||b|| 2.081619157380e-04
2133 KSP unpreconditioned resid norm 8.712485854380e+00 true resid norm 8.712485854382e+00 ||r(i)||/||b|| 2.081619157374e-04
2134 KSP unpreconditioned resid norm 8.712485854331e+00 true resid norm 8.712485854332e+00 ||r(i)||/||b|| 2.081619157362e-04
2135 KSP unpreconditioned resid norm 8.712485854273e+00 true resid norm 8.712485854286e+00 ||r(i)||/||b|| 2.081619157351e-04
2136 KSP unpreconditioned resid norm 8.712485854256e+00 true resid norm 8.712485854271e+00 ||r(i)||/||b|| 2.081619157347e-04
2137 KSP unpreconditioned resid norm 8.712485854248e+00 true resid norm 8.712485854248e+00 ||r(i)||/||b|| 2.081619157342e-04
2138 KSP unpreconditioned resid norm 8.712485854221e+00 true resid norm 8.712485854228e+00 ||r(i)||/||b|| 2.081619157337e-04
2139 KSP unpreconditioned resid norm 8.712485854168e+00 true resid norm 8.712485854165e+00 ||r(i)||/||b|| 2.081619157322e-04
2140 KSP unpreconditioned resid norm 8.712485854122e+00 true resid norm 8.712485854126e+00 ||r(i)||/||b|| 2.081619157313e-04
2141 KSP unpreconditioned resid norm 8.712485854110e+00 true resid norm 8.712485854114e+00 ||r(i)||/||b|| 2.081619157310e-04
2142 KSP unpreconditioned resid norm 8.712485854109e+00 true resid norm 8.712485854109e+00 ||r(i)||/||b|| 2.081619157309e-04
2143 KSP unpreconditioned resid norm 8.712485854058e+00 true resid norm 8.712485854057e+00 ||r(i)||/||b|| 2.081619157296e-04
2144 KSP unpreconditioned resid norm 8.712485853973e+00 true resid norm 8.712485853976e+00 ||r(i)||/||b|| 2.081619157277e-04
2145 KSP unpreconditioned resid norm 8.712485853853e+00 true resid norm 8.712485853859e+00 ||r(i)||/||b|| 2.081619157249e-04
2146 KSP unpreconditioned resid norm 8.712485853781e+00 true resid norm 8.712485853789e+00 ||r(i)||/||b|| 2.081619157232e-04
2147 KSP unpreconditioned resid norm 8.712485853718e+00 true resid norm 8.712485853715e+00 ||r(i)||/||b|| 2.081619157215e-04
2148 KSP unpreconditioned resid norm 8.712485853653e+00 true resid norm 8.712485853655e+00 ||r(i)||/||b|| 2.081619157200e-04
2149 KSP unpreconditioned resid norm 8.712485853594e+00 true resid norm 8.712485853591e+00 ||r(i)||/||b|| 2.081619157185e-04
2150 KSP unpreconditioned resid norm 8.712485853592e+00 true resid norm 8.712485853597e+00 ||r(i)||/||b|| 2.081619157186e-04
2151 KSP unpreconditioned resid norm 8.712485853583e+00 true resid norm 8.712485853592e+00 ||r(i)||/||b|| 2.081619157185e-04
2152 KSP unpreconditioned resid norm 8.712485853513e+00 true resid norm 8.712485853514e+00 ||r(i)||/||b|| 2.081619157166e-04
2153 KSP unpreconditioned resid norm 8.712485853148e+00 true resid norm 8.712485853145e+00 ||r(i)||/||b|| 2.081619157078e-04
2154 KSP unpreconditioned resid norm 8.712485852652e+00 true resid norm 8.712485852659e+00 ||r(i)||/||b|| 2.081619156962e-04
2155 KSP unpreconditioned resid norm 8.712485852273e+00 true resid norm 8.712485852284e+00 ||r(i)||/||b|| 2.081619156873e-04
2156 KSP unpreconditioned resid norm 8.712485851803e+00 true resid norm 8.712485851810e+00 ||r(i)||/||b|| 2.081619156759e-04
2157 KSP unpreconditioned resid norm 8.712485851051e+00 true resid norm 8.712485851056e+00 ||r(i)||/||b|| 2.081619156579e-04
2158 KSP unpreconditioned resid norm 8.712485849260e+00 true resid norm 8.712485849269e+00 ||r(i)||/||b|| 2.081619156152e-04
2159 KSP unpreconditioned resid norm 8.712485848289e+00 true resid norm 8.712485848289e+00 ||r(i)||/||b|| 2.081619155918e-04
2160 KSP unpreconditioned resid norm 8.712485848225e+00 true resid norm 8.712485848225e+00 ||r(i)||/||b|| 2.081619155903e-04
2161 KSP unpreconditioned resid norm 8.712485848224e+00 true resid norm 8.712485848217e+00 ||r(i)||/||b|| 2.081619155901e-04
2162 KSP unpreconditioned resid norm 8.712485848220e+00 true resid norm 8.712485848212e+00 ||r(i)||/||b|| 2.081619155900e-04
2163 KSP unpreconditioned resid norm 8.712485848200e+00 true resid norm 8.712485848200e+00 ||r(i)||/||b|| 2.081619155897e-04
2164 KSP unpreconditioned resid norm 8.712485848157e+00 true resid norm 8.712485848156e+00 ||r(i)||/||b|| 2.081619155886e-04
2165 KSP unpreconditioned resid norm 8.712485848106e+00 true resid norm 8.712485848101e+00 ||r(i)||/||b|| 2.081619155873e-04
2166 KSP unpreconditioned resid norm 8.712485848091e+00 true resid norm 8.712485848088e+00 ||r(i)||/||b|| 2.081619155870e-04
2167 KSP unpreconditioned resid norm 8.712485848083e+00 true resid norm 8.712485848082e+00 ||r(i)||/||b|| 2.081619155869e-04
2168 KSP unpreconditioned resid norm 8.712485848059e+00 true resid norm 8.712485848063e+00 ||r(i)||/||b|| 2.081619155864e-04
2169 KSP unpreconditioned resid norm 8.712485848013e+00 true resid norm 8.712485848015e+00 ||r(i)||/||b|| 2.081619155853e-04
2170 KSP unpreconditioned resid norm 8.712485847972e+00 true resid norm 8.712485847965e+00 ||r(i)||/||b|| 2.081619155841e-04
2171 KSP unpreconditioned resid norm 8.712485847962e+00 true resid norm 8.712485847957e+00 ||r(i)||/||b|| 2.081619155839e-04
2172 KSP unpreconditioned resid norm 8.712485847961e+00 true resid norm 8.712485847961e+00 ||r(i)||/||b|| 2.081619155840e-04
2173 KSP unpreconditioned resid norm 8.712485847916e+00 true resid norm 8.712485847917e+00 ||r(i)||/||b|| 2.081619155829e-04
2174 KSP unpreconditioned resid norm 8.712485847841e+00 true resid norm 8.712485847833e+00 ||r(i)||/||b|| 2.081619155809e-04
2175 KSP unpreconditioned resid norm 8.712485847733e+00 true resid norm 8.712485847730e+00 ||r(i)||/||b|| 2.081619155785e-04
2176 KSP unpreconditioned resid norm 8.712485847669e+00 true resid norm 8.712485847675e+00 ||r(i)||/||b|| 2.081619155771e-04
2177 KSP unpreconditioned resid norm 8.712485847615e+00 true resid norm 8.712485847607e+00 ||r(i)||/||b|| 2.081619155755e-04
2178 KSP unpreconditioned resid norm 8.712485847557e+00 true resid norm 8.712485847554e+00 ||r(i)||/||b|| 2.081619155742e-04
2179 KSP unpreconditioned resid norm 8.712485847505e+00 true resid norm 8.712485847504e+00 ||r(i)||/||b|| 2.081619155731e-04
2180 KSP unpreconditioned resid norm 8.712485847503e+00 true resid norm 8.712485847500e+00 ||r(i)||/||b|| 2.081619155730e-04
2181 KSP unpreconditioned resid norm 8.712485847495e+00 true resid norm 8.712485847505e+00 ||r(i)||/||b|| 2.081619155731e-04
2182 KSP unpreconditioned resid norm 8.712485847432e+00 true resid norm 8.712485847433e+00 ||r(i)||/||b|| 2.081619155714e-04
2183 KSP unpreconditioned resid norm 8.712485847107e+00 true resid norm 8.712485847100e+00 ||r(i)||/||b|| 2.081619155634e-04
2184 KSP unpreconditioned resid norm 8.712485846665e+00 true resid norm 8.712485846654e+00 ||r(i)||/||b|| 2.081619155528e-04
2185 KSP unpreconditioned resid norm 8.712485846324e+00 true resid norm 8.712485846323e+00 ||r(i)||/||b|| 2.081619155448e-04
2186 KSP unpreconditioned resid norm 8.712485845904e+00 true resid norm 8.712485845908e+00 ||r(i)||/||b|| 2.081619155349e-04
2187 KSP unpreconditioned resid norm 8.712485845240e+00 true resid norm 8.712485845226e+00 ||r(i)||/||b|| 2.081619155186e-04
2188 KSP unpreconditioned resid norm 8.712485843657e+00 true resid norm 8.712485843652e+00 ||r(i)||/||b|| 2.081619154810e-04
2189 KSP unpreconditioned resid norm 8.712485842807e+00 true resid norm 8.712485842805e+00 ||r(i)||/||b|| 2.081619154608e-04
2190 KSP unpreconditioned resid norm 8.712485842738e+00 true resid norm 8.712485842738e+00 ||r(i)||/||b|| 2.081619154592e-04
2191 KSP unpreconditioned resid norm 8.712485842737e+00 true resid norm 8.712485842743e+00 ||r(i)||/||b|| 2.081619154593e-04
2192 KSP unpreconditioned resid norm 8.712485842734e+00 true resid norm 8.712485842745e+00 ||r(i)||/||b|| 2.081619154593e-04
2193 KSP unpreconditioned resid norm 8.712485842717e+00 true resid norm 8.712485842716e+00 ||r(i)||/||b|| 2.081619154587e-04
2194 KSP unpreconditioned resid norm 8.712485842679e+00 true resid norm 8.712485842696e+00 ||r(i)||/||b|| 2.081619154582e-04
2195 KSP unpreconditioned resid norm 8.712485842633e+00 true resid norm 8.712485842645e+00 ||r(i)||/||b|| 2.081619154570e-04
2196 KSP unpreconditioned resid norm 8.712485842620e+00 true resid norm 8.712485842630e+00 ||r(i)||/||b|| 2.081619154566e-04
2197 KSP unpreconditioned resid norm 8.712485842613e+00 true resid norm 8.712485842617e+00 ||r(i)||/||b|| 2.081619154563e-04
2198 KSP unpreconditioned resid norm 8.712485842592e+00 true resid norm 8.712485842601e+00 ||r(i)||/||b|| 2.081619154559e-04
2199 KSP unpreconditioned resid norm 8.712485842551e+00 true resid norm 8.712485842553e+00 ||r(i)||/||b|| 2.081619154548e-04
2200 KSP unpreconditioned resid norm 8.712485842515e+00 true resid norm 8.712485842522e+00 ||r(i)||/||b|| 2.081619154540e-04
2201 KSP unpreconditioned resid norm 8.712485842506e+00 true resid norm 8.712485842509e+00 ||r(i)||/||b|| 2.081619154537e-04
2202 KSP unpreconditioned resid norm 8.712485842505e+00 true resid norm 8.712485842507e+00 ||r(i)||/||b|| 2.081619154537e-04
2203 KSP unpreconditioned resid norm 8.712485842465e+00 true resid norm 8.712485842472e+00 ||r(i)||/||b|| 2.081619154528e-04
2204 KSP unpreconditioned resid norm 8.712485842399e+00 true resid norm 8.712485842415e+00 ||r(i)||/||b|| 2.081619154515e-04
2205 KSP unpreconditioned resid norm 8.712485842304e+00 true resid norm 8.712485842304e+00 ||r(i)||/||b|| 2.081619154488e-04
2206 KSP unpreconditioned resid norm 8.712485842248e+00 true resid norm 8.712485842255e+00 ||r(i)||/||b|| 2.081619154476e-04
2207 KSP unpreconditioned resid norm 8.712485842199e+00 true resid norm 8.712485842213e+00 ||r(i)||/||b|| 2.081619154466e-04
2208 KSP unpreconditioned resid norm 8.712485842148e+00 true resid norm 8.712485842149e+00 ||r(i)||/||b|| 2.081619154451e-04
2209 KSP unpreconditioned resid norm 8.712485842102e+00 true resid norm 8.712485842104e+00 ||r(i)||/||b|| 2.081619154440e-04
2210 KSP unpreconditioned resid norm 8.712485842100e+00 true resid norm 8.712485842106e+00 ||r(i)||/||b|| 2.081619154441e-04
2211 KSP unpreconditioned resid norm 8.712485842093e+00 true resid norm 8.712485842101e+00 ||r(i)||/||b|| 2.081619154440e-04
2212 KSP unpreconditioned resid norm 8.712485842039e+00 true resid norm 8.712485842051e+00 ||r(i)||/||b|| 2.081619154428e-04
2213 KSP unpreconditioned resid norm 8.712485841753e+00 true resid norm 8.712485841765e+00 ||r(i)||/||b|| 2.081619154359e-04
2214 KSP unpreconditioned resid norm 8.712485841365e+00 true resid norm 8.712485841371e+00 ||r(i)||/||b|| 2.081619154265e-04
2215 KSP unpreconditioned resid norm 8.712485841069e+00 true resid norm 8.712485841066e+00 ||r(i)||/||b|| 2.081619154192e-04
2216 KSP unpreconditioned resid norm 8.712485840701e+00 true resid norm 8.712485840714e+00 ||r(i)||/||b|| 2.081619154108e-04
2217 KSP unpreconditioned resid norm 8.712485840113e+00 true resid norm 8.712485840123e+00 ||r(i)||/||b|| 2.081619153967e-04
2218 KSP unpreconditioned resid norm 8.712485838712e+00 true resid norm 8.712485838719e+00 ||r(i)||/||b|| 2.081619153632e-04
2219 KSP unpreconditioned resid norm 8.712485837953e+00 true resid norm 8.712485837963e+00 ||r(i)||/||b|| 2.081619153451e-04
2220 KSP unpreconditioned resid norm 8.712485837904e+00 true resid norm 8.712485837904e+00 ||r(i)||/||b|| 2.081619153437e-04
2221 KSP unpreconditioned resid norm 8.712485837903e+00 true resid norm 8.712485837908e+00 ||r(i)||/||b|| 2.081619153438e-04
2222 KSP unpreconditioned resid norm 8.712485837900e+00 true resid norm 8.712485837902e+00 ||r(i)||/||b|| 2.081619153436e-04
2223 KSP unpreconditioned resid norm 8.712485837885e+00 true resid norm 8.712485837880e+00 ||r(i)||/||b|| 2.081619153431e-04
2224 KSP unpreconditioned resid norm 8.712485837851e+00 true resid norm 8.712485837849e+00 ||r(i)||/||b|| 2.081619153424e-04
2225 KSP unpreconditioned resid norm 8.712485837811e+00 true resid norm 8.712485837810e+00 ||r(i)||/||b|| 2.081619153414e-04
2226 KSP unpreconditioned resid norm 8.712485837799e+00 true resid norm 8.712485837803e+00 ||r(i)||/||b|| 2.081619153413e-04
2227 KSP unpreconditioned resid norm 8.712485837793e+00 true resid norm 8.712485837791e+00 ||r(i)||/||b|| 2.081619153410e-04
2228 KSP unpreconditioned resid norm 8.712485837774e+00 true resid norm 8.712485837779e+00 ||r(i)||/||b|| 2.081619153407e-04
2229 KSP unpreconditioned resid norm 8.712485837738e+00 true resid norm 8.712485837739e+00 ||r(i)||/||b|| 2.081619153397e-04
2230 KSP unpreconditioned resid norm 8.712485837706e+00 true resid norm 8.712485837701e+00 ||r(i)||/||b|| 2.081619153388e-04
2231 KSP unpreconditioned resid norm 8.712485837698e+00 true resid norm 8.712485837702e+00 ||r(i)||/||b|| 2.081619153389e-04
2232 KSP unpreconditioned resid norm 8.712485837697e+00 true resid norm 8.712485837699e+00 ||r(i)||/||b|| 2.081619153388e-04
2233 KSP unpreconditioned resid norm 8.712485837662e+00 true resid norm 8.712485837669e+00 ||r(i)||/||b|| 2.081619153381e-04
2234 KSP unpreconditioned resid norm 8.712485837604e+00 true resid norm 8.712485837608e+00 ||r(i)||/||b|| 2.081619153366e-04
2235 KSP unpreconditioned resid norm 8.712485837519e+00 true resid norm 8.712485837510e+00 ||r(i)||/||b|| 2.081619153343e-04
2236 KSP unpreconditioned resid norm 8.712485837469e+00 true resid norm 8.712485837470e+00 ||r(i)||/||b|| 2.081619153333e-04
2237 KSP unpreconditioned resid norm 8.712485837427e+00 true resid norm 8.712485837423e+00 ||r(i)||/||b|| 2.081619153322e-04
2238 KSP unpreconditioned resid norm 8.712485837381e+00 true resid norm 8.712485837370e+00 ||r(i)||/||b|| 2.081619153309e-04
2239 KSP unpreconditioned resid norm 8.712485837341e+00 true resid norm 8.712485837333e+00 ||r(i)||/||b|| 2.081619153301e-04
2240 KSP unpreconditioned resid norm 8.712485837339e+00 true resid norm 8.712485837345e+00 ||r(i)||/||b|| 2.081619153303e-04
2241 KSP unpreconditioned resid norm 8.712485837333e+00 true resid norm 8.712485837330e+00 ||r(i)||/||b|| 2.081619153300e-04
2242 KSP unpreconditioned resid norm 8.712485837284e+00 true resid norm 8.712485837273e+00 ||r(i)||/||b|| 2.081619153286e-04
2243 KSP unpreconditioned resid norm 8.712485837030e+00 true resid norm 8.712485837028e+00 ||r(i)||/||b|| 2.081619153228e-04
2244 KSP unpreconditioned resid norm 8.712485836684e+00 true resid norm 8.712485836687e+00 ||r(i)||/||b|| 2.081619153146e-04
2245 KSP unpreconditioned resid norm 8.712485836418e+00 true resid norm 8.712485836415e+00 ||r(i)||/||b|| 2.081619153081e-04
2246 KSP unpreconditioned resid norm 8.712485836090e+00 true resid norm 8.712485836082e+00 ||r(i)||/||b|| 2.081619153001e-04
2247 KSP unpreconditioned resid norm 8.712485835570e+00 true resid norm 8.712485835567e+00 ||r(i)||/||b|| 2.081619152878e-04
2248 KSP unpreconditioned resid norm 8.712485834333e+00 true resid norm 8.712485834336e+00 ||r(i)||/||b|| 2.081619152584e-04
2249 KSP unpreconditioned resid norm 8.712485833667e+00 true resid norm 8.712485833671e+00 ||r(i)||/||b|| 2.081619152425e-04
2250 KSP unpreconditioned resid norm 8.712485833619e+00 true resid norm 8.712485833619e+00 ||r(i)||/||b|| 2.081619152413e-04
2251 KSP unpreconditioned resid norm 8.712485833619e+00 true resid norm 8.712485833624e+00 ||r(i)||/||b|| 2.081619152414e-04
2252 KSP unpreconditioned resid norm 8.712485833616e+00 true resid norm 8.712485833609e+00 ||r(i)||/||b|| 2.081619152411e-04
2253 KSP unpreconditioned resid norm 8.712485833603e+00 true resid norm 8.712485833608e+00 ||r(i)||/||b|| 2.081619152410e-04
2254 KSP unpreconditioned resid norm 8.712485833573e+00 true resid norm 8.712485833569e+00 ||r(i)||/||b|| 2.081619152401e-04
2255 KSP unpreconditioned resid norm 8.712485833538e+00 true resid norm 8.712485833549e+00 ||r(i)||/||b|| 2.081619152396e-04
2256 KSP unpreconditioned resid norm 8.712485833527e+00 true resid norm 8.712485833529e+00 ||r(i)||/||b|| 2.081619152392e-04
2257 KSP unpreconditioned resid norm 8.712485833522e+00 true resid norm 8.712485833522e+00 ||r(i)||/||b|| 2.081619152390e-04
2258 KSP unpreconditioned resid norm 8.712485833505e+00 true resid norm 8.712485833514e+00 ||r(i)||/||b|| 2.081619152388e-04
2259 KSP unpreconditioned resid norm 8.712485833473e+00 true resid norm 8.712485833478e+00 ||r(i)||/||b|| 2.081619152379e-04
2260 KSP unpreconditioned resid norm 8.712485833445e+00 true resid norm 8.712485833446e+00 ||r(i)||/||b|| 2.081619152372e-04
2261 KSP unpreconditioned resid norm 8.712485833438e+00 true resid norm 8.712485833440e+00 ||r(i)||/||b|| 2.081619152370e-04
2262 KSP unpreconditioned resid norm 8.712485833437e+00 true resid norm 8.712485833441e+00 ||r(i)||/||b|| 2.081619152371e-04
2263 KSP unpreconditioned resid norm 8.712485833406e+00 true resid norm 8.712485833414e+00 ||r(i)||/||b|| 2.081619152364e-04
2264 KSP unpreconditioned resid norm 8.712485833354e+00 true resid norm 8.712485833362e+00 ||r(i)||/||b|| 2.081619152352e-04
2265 KSP unpreconditioned resid norm 8.712485833280e+00 true resid norm 8.712485833286e+00 ||r(i)||/||b|| 2.081619152334e-04
2266 KSP unpreconditioned resid norm 8.712485833236e+00 true resid norm 8.712485833232e+00 ||r(i)||/||b|| 2.081619152321e-04
2267 KSP unpreconditioned resid norm 8.712485833198e+00 true resid norm 8.712485833209e+00 ||r(i)||/||b|| 2.081619152315e-04
2268 KSP unpreconditioned resid norm 8.712485833158e+00 true resid norm 8.712485833147e+00 ||r(i)||/||b|| 2.081619152300e-04
2269 KSP unpreconditioned resid norm 8.712485833122e+00 true resid norm 8.712485833124e+00 ||r(i)||/||b|| 2.081619152295e-04
2270 KSP unpreconditioned resid norm 8.712485833121e+00 true resid norm 8.712485833127e+00 ||r(i)||/||b|| 2.081619152295e-04
2271 KSP unpreconditioned resid norm 8.712485833115e+00 true resid norm 8.712485833114e+00 ||r(i)||/||b|| 2.081619152292e-04
2272 KSP unpreconditioned resid norm 8.712485833073e+00 true resid norm 8.712485833077e+00 ||r(i)||/||b|| 2.081619152284e-04
2273 KSP unpreconditioned resid norm 8.712485832849e+00 true resid norm 8.712485832849e+00 ||r(i)||/||b|| 2.081619152229e-04
2274 KSP unpreconditioned resid norm 8.712485832546e+00 true resid norm 8.712485832550e+00 ||r(i)||/||b|| 2.081619152158e-04
2275 KSP unpreconditioned resid norm 8.712485832314e+00 true resid norm 8.712485832316e+00 ||r(i)||/||b|| 2.081619152102e-04
2276 KSP unpreconditioned resid norm 8.712485832026e+00 true resid norm 8.712485832038e+00 ||r(i)||/||b|| 2.081619152035e-04
2277 KSP unpreconditioned resid norm 8.712485831566e+00 true resid norm 8.712485831557e+00 ||r(i)||/||b|| 2.081619151921e-04
2278 KSP unpreconditioned resid norm 8.712485830470e+00 true resid norm 8.712485830479e+00 ||r(i)||/||b|| 2.081619151663e-04
2279 KSP unpreconditioned resid norm 8.712485829877e+00 true resid norm 8.712485829885e+00 ||r(i)||/||b|| 2.081619151521e-04
2280 KSP unpreconditioned resid norm 8.712485829834e+00 true resid norm 8.712485829834e+00 ||r(i)||/||b|| 2.081619151509e-04
2281 KSP unpreconditioned resid norm 8.712485829834e+00 true resid norm 8.712485829839e+00 ||r(i)||/||b|| 2.081619151510e-04
2282 KSP unpreconditioned resid norm 8.712485829832e+00 true resid norm 8.712485829821e+00 ||r(i)||/||b|| 2.081619151506e-04
2283 KSP unpreconditioned resid norm 8.712485829820e+00 true resid norm 8.712485829813e+00 ||r(i)||/||b|| 2.081619151504e-04
2284 KSP unpreconditioned resid norm 8.712485829793e+00 true resid norm 8.712485829788e+00 ||r(i)||/||b|| 2.081619151498e-04
2285 KSP unpreconditioned resid norm 8.712485829762e+00 true resid norm 8.712485829758e+00 ||r(i)||/||b|| 2.081619151491e-04
2286 KSP unpreconditioned resid norm 8.712485829753e+00 true resid norm 8.712485829751e+00 ||r(i)||/||b|| 2.081619151489e-04
2287 KSP unpreconditioned resid norm 8.712485829748e+00 true resid norm 8.712485829739e+00 ||r(i)||/||b|| 2.081619151486e-04
2288 KSP unpreconditioned resid norm 8.712485829733e+00 true resid norm 8.712485829735e+00 ||r(i)||/||b|| 2.081619151485e-04
2289 KSP unpreconditioned resid norm 8.712485829705e+00 true resid norm 8.712485829702e+00 ||r(i)||/||b|| 2.081619151477e-04
2290 KSP unpreconditioned resid norm 8.712485829680e+00 true resid norm 8.712485829675e+00 ||r(i)||/||b|| 2.081619151471e-04
2291 KSP unpreconditioned resid norm 8.712485829674e+00 true resid norm 8.712485829669e+00 ||r(i)||/||b|| 2.081619151469e-04
2292 KSP unpreconditioned resid norm 8.712485829673e+00 true resid norm 8.712485829670e+00 ||r(i)||/||b|| 2.081619151470e-04
2293 KSP unpreconditioned resid norm 8.712485829645e+00 true resid norm 8.712485829636e+00 ||r(i)||/||b|| 2.081619151461e-04
2294 KSP unpreconditioned resid norm 8.712485829600e+00 true resid norm 8.712485829594e+00 ||r(i)||/||b|| 2.081619151451e-04
2295 KSP unpreconditioned resid norm 8.712485829534e+00 true resid norm 8.712485829529e+00 ||r(i)||/||b|| 2.081619151436e-04
2296 KSP unpreconditioned resid norm 8.712485829495e+00 true resid norm 8.712485829487e+00 ||r(i)||/||b|| 2.081619151426e-04
2297 KSP unpreconditioned resid norm 8.712485829461e+00 true resid norm 8.712485829463e+00 ||r(i)||/||b|| 2.081619151420e-04
2298 KSP unpreconditioned resid norm 8.712485829426e+00 true resid norm 8.712485829426e+00 ||r(i)||/||b|| 2.081619151411e-04
2299 KSP unpreconditioned resid norm 8.712485829394e+00 true resid norm 8.712485829382e+00 ||r(i)||/||b|| 2.081619151401e-04
2300 KSP unpreconditioned resid norm 8.712485829393e+00 true resid norm 8.712485829397e+00 ||r(i)||/||b|| 2.081619151404e-04
2301 KSP unpreconditioned resid norm 8.712485829388e+00 true resid norm 8.712485829380e+00 ||r(i)||/||b|| 2.081619151400e-04
2302 KSP unpreconditioned resid norm 8.712485829350e+00 true resid norm 8.712485829342e+00 ||r(i)||/||b|| 2.081619151391e-04
2303 KSP unpreconditioned resid norm 8.712485829151e+00 true resid norm 8.712485829144e+00 ||r(i)||/||b|| 2.081619151344e-04
2304 KSP unpreconditioned resid norm 8.712485828881e+00 true resid norm 8.712485828882e+00 ||r(i)||/||b|| 2.081619151281e-04
2305 KSP unpreconditioned resid norm 8.712485828673e+00 true resid norm 8.712485828661e+00 ||r(i)||/||b|| 2.081619151228e-04
2306 KSP unpreconditioned resid norm 8.712485828416e+00 true resid norm 8.712485828412e+00 ||r(i)||/||b|| 2.081619151169e-04
2307 KSP unpreconditioned resid norm 8.712485828010e+00 true resid norm 8.712485828009e+00 ||r(i)||/||b|| 2.081619151073e-04
2308 KSP unpreconditioned resid norm 8.712485827042e+00 true resid norm 8.712485827042e+00 ||r(i)||/||b|| 2.081619150842e-04
2309 KSP unpreconditioned resid norm 8.712485826521e+00 true resid norm 8.712485826508e+00 ||r(i)||/||b|| 2.081619150714e-04
2310 KSP unpreconditioned resid norm 8.712485826481e+00 true resid norm 8.712485826481e+00 ||r(i)||/||b|| 2.081619150708e-04
2311 KSP unpreconditioned resid norm 8.712485826481e+00 true resid norm 8.712485826480e+00 ||r(i)||/||b|| 2.081619150707e-04
2312 KSP unpreconditioned resid norm 8.712485826479e+00 true resid norm 8.712485826480e+00 ||r(i)||/||b|| 2.081619150707e-04
2313 KSP unpreconditioned resid norm 8.712485826468e+00 true resid norm 8.712485826465e+00 ||r(i)||/||b|| 2.081619150704e-04
2314 KSP unpreconditioned resid norm 8.712485826445e+00 true resid norm 8.712485826440e+00 ||r(i)||/||b|| 2.081619150698e-04
2315 KSP unpreconditioned resid norm 8.712485826417e+00 true resid norm 8.712485826413e+00 ||r(i)||/||b|| 2.081619150691e-04
2316 KSP unpreconditioned resid norm 8.712485826409e+00 true resid norm 8.712485826405e+00 ||r(i)||/||b|| 2.081619150689e-04
2317 KSP unpreconditioned resid norm 8.712485826405e+00 true resid norm 8.712485826396e+00 ||r(i)||/||b|| 2.081619150687e-04
2318 KSP unpreconditioned resid norm 8.712485826392e+00 true resid norm 8.712485826398e+00 ||r(i)||/||b|| 2.081619150688e-04
2319 KSP unpreconditioned resid norm 8.712485826367e+00 true resid norm 8.712485826365e+00 ||r(i)||/||b|| 2.081619150680e-04
2320 KSP unpreconditioned resid norm 8.712485826345e+00 true resid norm 8.712485826347e+00 ||r(i)||/||b|| 2.081619150676e-04
2321 KSP unpreconditioned resid norm 8.712485826339e+00 true resid norm 8.712485826337e+00 ||r(i)||/||b|| 2.081619150673e-04
2322 KSP unpreconditioned resid norm 8.712485826339e+00 true resid norm 8.712485826339e+00 ||r(i)||/||b|| 2.081619150674e-04
2323 KSP unpreconditioned resid norm 8.712485826314e+00 true resid norm 8.712485826319e+00 ||r(i)||/||b|| 2.081619150669e-04
2324 KSP unpreconditioned resid norm 8.712485826274e+00 true resid norm 8.712485826277e+00 ||r(i)||/||b|| 2.081619150659e-04
2325 KSP unpreconditioned resid norm 8.712485826216e+00 true resid norm 8.712485826220e+00 ||r(i)||/||b|| 2.081619150645e-04
2326 KSP unpreconditioned resid norm 8.712485826182e+00 true resid norm 8.712485826176e+00 ||r(i)||/||b|| 2.081619150635e-04
2327 KSP unpreconditioned resid norm 8.712485826152e+00 true resid norm 8.712485826152e+00 ||r(i)||/||b|| 2.081619150629e-04
2328 KSP unpreconditioned resid norm 8.712485826121e+00 true resid norm 8.712485826127e+00 ||r(i)||/||b|| 2.081619150623e-04
2329 KSP unpreconditioned resid norm 8.712485826093e+00 true resid norm 8.712485826092e+00 ||r(i)||/||b|| 2.081619150615e-04
2330 KSP unpreconditioned resid norm 8.712485826091e+00 true resid norm 8.712485826090e+00 ||r(i)||/||b|| 2.081619150614e-04
2331 KSP unpreconditioned resid norm 8.712485826087e+00 true resid norm 8.712485826089e+00 ||r(i)||/||b|| 2.081619150614e-04
2332 KSP unpreconditioned resid norm 8.712485826054e+00 true resid norm 8.712485826063e+00 ||r(i)||/||b|| 2.081619150608e-04
2333 KSP unpreconditioned resid norm 8.712485825879e+00 true resid norm 8.712485825874e+00 ||r(i)||/||b|| 2.081619150563e-04
2334 KSP unpreconditioned resid norm 8.712485825641e+00 true resid norm 8.712485825649e+00 ||r(i)||/||b|| 2.081619150509e-04
2335 KSP unpreconditioned resid norm 8.712485825460e+00 true resid norm 8.712485825453e+00 ||r(i)||/||b|| 2.081619150462e-04
2336 KSP unpreconditioned resid norm 8.712485825235e+00 true resid norm 8.712485825240e+00 ||r(i)||/||b|| 2.081619150411e-04
2337 KSP unpreconditioned resid norm 8.712485824875e+00 true resid norm 8.712485824886e+00 ||r(i)||/||b|| 2.081619150327e-04
2338 KSP unpreconditioned resid norm 8.712485824018e+00 true resid norm 8.712485824018e+00 ||r(i)||/||b|| 2.081619150119e-04
2339 KSP unpreconditioned resid norm 8.712485823554e+00 true resid norm 8.712485823559e+00 ||r(i)||/||b|| 2.081619150010e-04
2340 KSP unpreconditioned resid norm 8.712485823510e+00 true resid norm 8.712485823510e+00 ||r(i)||/||b|| 2.081619149998e-04
2341 KSP unpreconditioned resid norm 8.712485823509e+00 true resid norm 8.712485823516e+00 ||r(i)||/||b|| 2.081619149999e-04
2342 KSP unpreconditioned resid norm 8.712485823507e+00 true resid norm 8.712485823511e+00 ||r(i)||/||b|| 2.081619149998e-04
2343 KSP unpreconditioned resid norm 8.712485823498e+00 true resid norm 8.712485823498e+00 ||r(i)||/||b|| 2.081619149995e-04
2344 KSP unpreconditioned resid norm 8.712485823477e+00 true resid norm 8.712485823478e+00 ||r(i)||/||b|| 2.081619149990e-04
2345 KSP unpreconditioned resid norm 8.712485823453e+00 true resid norm 8.712485823449e+00 ||r(i)||/||b|| 2.081619149983e-04
2346 KSP unpreconditioned resid norm 8.712485823446e+00 true resid norm 8.712485823442e+00 ||r(i)||/||b|| 2.081619149982e-04
2347 KSP unpreconditioned resid norm 8.712485823442e+00 true resid norm 8.712485823450e+00 ||r(i)||/||b|| 2.081619149984e-04
2348 KSP unpreconditioned resid norm 8.712485823430e+00 true resid norm 8.712485823439e+00 ||r(i)||/||b|| 2.081619149981e-04
2349 KSP unpreconditioned resid norm 8.712485823408e+00 true resid norm 8.712485823405e+00 ||r(i)||/||b|| 2.081619149973e-04
2350 KSP unpreconditioned resid norm 8.712485823389e+00 true resid norm 8.712485823402e+00 ||r(i)||/||b|| 2.081619149972e-04
2351 KSP unpreconditioned resid norm 8.712485823384e+00 true resid norm 8.712485823384e+00 ||r(i)||/||b|| 2.081619149968e-04
2352 KSP unpreconditioned resid norm 8.712485823384e+00 true resid norm 8.712485823381e+00 ||r(i)||/||b|| 2.081619149967e-04
2353 KSP unpreconditioned resid norm 8.712485823362e+00 true resid norm 8.712485823365e+00 ||r(i)||/||b|| 2.081619149963e-04
2354 KSP unpreconditioned resid norm 8.712485823326e+00 true resid norm 8.712485823322e+00 ||r(i)||/||b|| 2.081619149953e-04
2355 KSP unpreconditioned resid norm 8.712485823275e+00 true resid norm 8.712485823283e+00 ||r(i)||/||b|| 2.081619149943e-04
2356 KSP unpreconditioned resid norm 8.712485823244e+00 true resid norm 8.712485823252e+00 ||r(i)||/||b|| 2.081619149936e-04
2357 KSP unpreconditioned resid norm 8.712485823218e+00 true resid norm 8.712485823216e+00 ||r(i)||/||b|| 2.081619149928e-04
2358 KSP unpreconditioned resid norm 8.712485823190e+00 true resid norm 8.712485823198e+00 ||r(i)||/||b|| 2.081619149923e-04
2359 KSP unpreconditioned resid norm 8.712485823166e+00 true resid norm 8.712485823176e+00 ||r(i)||/||b|| 2.081619149918e-04
2360 KSP unpreconditioned resid norm 8.712485823164e+00 true resid norm 8.712485823163e+00 ||r(i)||/||b|| 2.081619149915e-04
2361 KSP unpreconditioned resid norm 8.712485823161e+00 true resid norm 8.712485823164e+00 ||r(i)||/||b|| 2.081619149915e-04
2362 KSP unpreconditioned resid norm 8.712485823131e+00 true resid norm 8.712485823138e+00 ||r(i)||/||b|| 2.081619149909e-04
2363 KSP unpreconditioned resid norm 8.712485822975e+00 true resid norm 8.712485822976e+00 ||r(i)||/||b|| 2.081619149870e-04
2364 KSP unpreconditioned resid norm 8.712485822764e+00 true resid norm 8.712485822767e+00 ||r(i)||/||b|| 2.081619149820e-04
2365 KSP unpreconditioned resid norm 8.712485822602e+00 true resid norm 8.712485822604e+00 ||r(i)||/||b|| 2.081619149781e-04
2366 KSP unpreconditioned resid norm 8.712485822401e+00 true resid norm 8.712485822403e+00 ||r(i)||/||b|| 2.081619149733e-04
2367 KSP unpreconditioned resid norm 8.712485822083e+00 true resid norm 8.712485822087e+00 ||r(i)||/||b|| 2.081619149658e-04
2368 KSP unpreconditioned resid norm 8.712485821326e+00 true resid norm 8.712485821329e+00 ||r(i)||/||b|| 2.081619149477e-04
2369 KSP unpreconditioned resid norm 8.712485820919e+00 true resid norm 8.712485820928e+00 ||r(i)||/||b|| 2.081619149381e-04
2370 KSP unpreconditioned resid norm 8.712485820892e+00 true resid norm 8.712485820892e+00 ||r(i)||/||b|| 2.081619149372e-04
2371 KSP unpreconditioned resid norm 8.712485820892e+00 true resid norm 8.712485820895e+00 ||r(i)||/||b|| 2.081619149373e-04
2372 KSP unpreconditioned resid norm 8.712485820890e+00 true resid norm 8.712485820885e+00 ||r(i)||/||b|| 2.081619149371e-04
2373 KSP unpreconditioned resid norm 8.712485820882e+00 true resid norm 8.712485820880e+00 ||r(i)||/||b|| 2.081619149369e-04
2374 KSP unpreconditioned resid norm 8.712485820864e+00 true resid norm 8.712485820864e+00 ||r(i)||/||b|| 2.081619149366e-04
2375 KSP unpreconditioned resid norm 8.712485820842e+00 true resid norm 8.712485820837e+00 ||r(i)||/||b|| 2.081619149359e-04
2376 KSP unpreconditioned resid norm 8.712485820836e+00 true resid norm 8.712485820837e+00 ||r(i)||/||b|| 2.081619149359e-04
2377 KSP unpreconditioned resid norm 8.712485820833e+00 true resid norm 8.712485820834e+00 ||r(i)||/||b|| 2.081619149358e-04
2378 KSP unpreconditioned resid norm 8.712485820822e+00 true resid norm 8.712485820826e+00 ||r(i)||/||b|| 2.081619149357e-04
2379 KSP unpreconditioned resid norm 8.712485820803e+00 true resid norm 8.712485820804e+00 ||r(i)||/||b|| 2.081619149351e-04
2380 KSP unpreconditioned resid norm 8.712485820785e+00 true resid norm 8.712485820788e+00 ||r(i)||/||b|| 2.081619149347e-04
2381 KSP unpreconditioned resid norm 8.712485820781e+00 true resid norm 8.712485820779e+00 ||r(i)||/||b|| 2.081619149345e-04
2382 KSP unpreconditioned resid norm 8.712485820781e+00 true resid norm 8.712485820790e+00 ||r(i)||/||b|| 2.081619149348e-04
2383 KSP unpreconditioned resid norm 8.712485820762e+00 true resid norm 8.712485820769e+00 ||r(i)||/||b|| 2.081619149343e-04
2384 KSP unpreconditioned resid norm 8.712485820730e+00 true resid norm 8.712485820735e+00 ||r(i)||/||b|| 2.081619149335e-04
2385 KSP unpreconditioned resid norm 8.712485820685e+00 true resid norm 8.712485820688e+00 ||r(i)||/||b|| 2.081619149324e-04
2386 KSP unpreconditioned resid norm 8.712485820658e+00 true resid norm 8.712485820663e+00 ||r(i)||/||b|| 2.081619149317e-04
2387 KSP unpreconditioned resid norm 8.712485820635e+00 true resid norm 8.712485820642e+00 ||r(i)||/||b|| 2.081619149313e-04
2388 KSP unpreconditioned resid norm 8.712485820610e+00 true resid norm 8.712485820608e+00 ||r(i)||/||b|| 2.081619149305e-04
2389 KSP unpreconditioned resid norm 8.712485820588e+00 true resid norm 8.712485820594e+00 ||r(i)||/||b|| 2.081619149301e-04
2390 KSP unpreconditioned resid norm 8.712485820587e+00 true resid norm 8.712485820587e+00 ||r(i)||/||b|| 2.081619149299e-04
2391 KSP unpreconditioned resid norm 8.712485820584e+00 true resid norm 8.712485820584e+00 ||r(i)||/||b|| 2.081619149299e-04
2392 KSP unpreconditioned resid norm 8.712485820558e+00 true resid norm 8.712485820557e+00 ||r(i)||/||b|| 2.081619149292e-04
2393 KSP unpreconditioned resid norm 8.712485820421e+00 true resid norm 8.712485820423e+00 ||r(i)||/||b|| 2.081619149260e-04
2394 KSP unpreconditioned resid norm 8.712485820235e+00 true resid norm 8.712485820235e+00 ||r(i)||/||b|| 2.081619149215e-04
2395 KSP unpreconditioned resid norm 8.712485820093e+00 true resid norm 8.712485820089e+00 ||r(i)||/||b|| 2.081619149180e-04
2396 KSP unpreconditioned resid norm 8.712485819917e+00 true resid norm 8.712485819922e+00 ||r(i)||/||b|| 2.081619149141e-04
2397 KSP unpreconditioned resid norm 8.712485819636e+00 true resid norm 8.712485819641e+00 ||r(i)||/||b|| 2.081619149073e-04
2398 KSP unpreconditioned resid norm 8.712485818966e+00 true resid norm 8.712485818968e+00 ||r(i)||/||b|| 2.081619148913e-04
2399 KSP unpreconditioned resid norm 8.712485818603e+00 true resid norm 8.712485818608e+00 ||r(i)||/||b|| 2.081619148827e-04
2400 KSP unpreconditioned resid norm 8.712485818571e+00 true resid norm 8.712485818571e+00 ||r(i)||/||b|| 2.081619148818e-04
2401 KSP unpreconditioned resid norm 8.712485818570e+00 true resid norm 8.712485818579e+00 ||r(i)||/||b|| 2.081619148820e-04
2402 KSP unpreconditioned resid norm 8.712485818569e+00 true resid norm 8.712485818578e+00 ||r(i)||/||b|| 2.081619148820e-04
2403 KSP unpreconditioned resid norm 8.712485818562e+00 true resid norm 8.712485818575e+00 ||r(i)||/||b|| 2.081619148819e-04
2404 KSP unpreconditioned resid norm 8.712485818545e+00 true resid norm 8.712485818560e+00 ||r(i)||/||b|| 2.081619148815e-04
2405 KSP unpreconditioned resid norm 8.712485818526e+00 true resid norm 8.712485818536e+00 ||r(i)||/||b|| 2.081619148809e-04
2406 KSP unpreconditioned resid norm 8.712485818521e+00 true resid norm 8.712485818522e+00 ||r(i)||/||b|| 2.081619148806e-04
2407 KSP unpreconditioned resid norm 8.712485818518e+00 true resid norm 8.712485818524e+00 ||r(i)||/||b|| 2.081619148807e-04
2408 KSP unpreconditioned resid norm 8.712485818509e+00 true resid norm 8.712485818524e+00 ||r(i)||/||b|| 2.081619148807e-04
2409 KSP unpreconditioned resid norm 8.712485818491e+00 true resid norm 8.712485818511e+00 ||r(i)||/||b|| 2.081619148803e-04
2410 KSP unpreconditioned resid norm 8.712485818476e+00 true resid norm 8.712485818484e+00 ||r(i)||/||b|| 2.081619148797e-04
2411 KSP unpreconditioned resid norm 8.712485818472e+00 true resid norm 8.712485818474e+00 ||r(i)||/||b|| 2.081619148795e-04
2412 KSP unpreconditioned resid norm 8.712485818472e+00 true resid norm 8.712485818487e+00 ||r(i)||/||b|| 2.081619148798e-04
2413 KSP unpreconditioned resid norm 8.712485818455e+00 true resid norm 8.712485818473e+00 ||r(i)||/||b|| 2.081619148794e-04
2414 KSP unpreconditioned resid norm 8.712485818427e+00 true resid norm 8.712485818431e+00 ||r(i)||/||b|| 2.081619148784e-04
2415 KSP unpreconditioned resid norm 8.712485818387e+00 true resid norm 8.712485818401e+00 ||r(i)||/||b|| 2.081619148777e-04
2416 KSP unpreconditioned resid norm 8.712485818363e+00 true resid norm 8.712485818363e+00 ||r(i)||/||b|| 2.081619148768e-04
2417 KSP unpreconditioned resid norm 8.712485818343e+00 true resid norm 8.712485818356e+00 ||r(i)||/||b|| 2.081619148766e-04
2418 KSP unpreconditioned resid norm 8.712485818321e+00 true resid norm 8.712485818324e+00 ||r(i)||/||b|| 2.081619148759e-04
2419 KSP unpreconditioned resid norm 8.712485818302e+00 true resid norm 8.712485818310e+00 ||r(i)||/||b|| 2.081619148755e-04
2420 KSP unpreconditioned resid norm 8.712485818301e+00 true resid norm 8.712485818313e+00 ||r(i)||/||b|| 2.081619148756e-04
2421 KSP unpreconditioned resid norm 8.712485818298e+00 true resid norm 8.712485818309e+00 ||r(i)||/||b|| 2.081619148755e-04
2422 KSP unpreconditioned resid norm 8.712485818274e+00 true resid norm 8.712485818277e+00 ||r(i)||/||b|| 2.081619148747e-04
2423 KSP unpreconditioned resid norm 8.712485818153e+00 true resid norm 8.712485818153e+00 ||r(i)||/||b|| 2.081619148718e-04
2424 KSP unpreconditioned resid norm 8.712485817988e+00 true resid norm 8.712485817999e+00 ||r(i)||/||b|| 2.081619148681e-04
2425 KSP unpreconditioned resid norm 8.712485817861e+00 true resid norm 8.712485817859e+00 ||r(i)||/||b|| 2.081619148648e-04
2426 KSP unpreconditioned resid norm 8.712485817704e+00 true resid norm 8.712485817714e+00 ||r(i)||/||b|| 2.081619148613e-04
2427 KSP unpreconditioned resid norm 8.712485817455e+00 true resid norm 8.712485817459e+00 ||r(i)||/||b|| 2.081619148552e-04
2428 KSP unpreconditioned resid norm 8.712485816863e+00 true resid norm 8.712485816878e+00 ||r(i)||/||b|| 2.081619148413e-04
2429 KSP unpreconditioned resid norm 8.712485816545e+00 true resid norm 8.712485816545e+00 ||r(i)||/||b|| 2.081619148334e-04
2430 KSP unpreconditioned resid norm 8.712485816538e+00 true resid norm 8.712485816538e+00 ||r(i)||/||b|| 2.081619148332e-04
2431 KSP unpreconditioned resid norm 8.712485816538e+00 true resid norm 8.712485816526e+00 ||r(i)||/||b|| 2.081619148329e-04
2432 KSP unpreconditioned resid norm 8.712485816537e+00 true resid norm 8.712485816528e+00 ||r(i)||/||b|| 2.081619148330e-04
2433 KSP unpreconditioned resid norm 8.712485816530e+00 true resid norm 8.712485816524e+00 ||r(i)||/||b|| 2.081619148329e-04
2434 KSP unpreconditioned resid norm 8.712485816516e+00 true resid norm 8.712485816509e+00 ||r(i)||/||b|| 2.081619148325e-04
2435 KSP unpreconditioned resid norm 8.712485816499e+00 true resid norm 8.712485816493e+00 ||r(i)||/||b|| 2.081619148321e-04
2436 KSP unpreconditioned resid norm 8.712485816494e+00 true resid norm 8.712485816488e+00 ||r(i)||/||b|| 2.081619148320e-04
2437 KSP unpreconditioned resid norm 8.712485816491e+00 true resid norm 8.712485816486e+00 ||r(i)||/||b|| 2.081619148320e-04
2438 KSP unpreconditioned resid norm 8.712485816484e+00 true resid norm 8.712485816476e+00 ||r(i)||/||b|| 2.081619148317e-04
2439 KSP unpreconditioned resid norm 8.712485816468e+00 true resid norm 8.712485816463e+00 ||r(i)||/||b|| 2.081619148314e-04
2440 KSP unpreconditioned resid norm 8.712485816455e+00 true resid norm 8.712485816443e+00 ||r(i)||/||b|| 2.081619148309e-04
2441 KSP unpreconditioned resid norm 8.712485816451e+00 true resid norm 8.712485816448e+00 ||r(i)||/||b|| 2.081619148310e-04
2442 KSP unpreconditioned resid norm 8.712485816451e+00 true resid norm 8.712485816440e+00 ||r(i)||/||b|| 2.081619148309e-04
2443 KSP unpreconditioned resid norm 8.712485816436e+00 true resid norm 8.712485816436e+00 ||r(i)||/||b|| 2.081619148308e-04
2444 KSP unpreconditioned resid norm 8.712485816411e+00 true resid norm 8.712485816408e+00 ||r(i)||/||b|| 2.081619148301e-04
2445 KSP unpreconditioned resid norm 8.712485816376e+00 true resid norm 8.712485816373e+00 ||r(i)||/||b|| 2.081619148293e-04
2446 KSP unpreconditioned resid norm 8.712485816355e+00 true resid norm 8.712485816346e+00 ||r(i)||/||b|| 2.081619148286e-04
2447 KSP unpreconditioned resid norm 8.712485816337e+00 true resid norm 8.712485816331e+00 ||r(i)||/||b|| 2.081619148283e-04
2448 KSP unpreconditioned resid norm 8.712485816318e+00 true resid norm 8.712485816315e+00 ||r(i)||/||b|| 2.081619148279e-04
2449 KSP unpreconditioned resid norm 8.712485816300e+00 true resid norm 8.712485816294e+00 ||r(i)||/||b|| 2.081619148274e-04
2450 KSP unpreconditioned resid norm 8.712485816299e+00 true resid norm 8.712485816293e+00 ||r(i)||/||b|| 2.081619148273e-04
2451 KSP unpreconditioned resid norm 8.712485816297e+00 true resid norm 8.712485816295e+00 ||r(i)||/||b|| 2.081619148274e-04
2452 KSP unpreconditioned resid norm 8.712485816277e+00 true resid norm 8.712485816271e+00 ||r(i)||/||b|| 2.081619148268e-04
2453 KSP unpreconditioned resid norm 8.712485816170e+00 true resid norm 8.712485816167e+00 ||r(i)||/||b|| 2.081619148243e-04
2454 KSP unpreconditioned resid norm 8.712485816024e+00 true resid norm 8.712485816013e+00 ||r(i)||/||b|| 2.081619148207e-04
2455 KSP unpreconditioned resid norm 8.712485815913e+00 true resid norm 8.712485815909e+00 ||r(i)||/||b|| 2.081619148182e-04
2456 KSP unpreconditioned resid norm 8.712485815775e+00 true resid norm 8.712485815764e+00 ||r(i)||/||b|| 2.081619148147e-04
2457 KSP unpreconditioned resid norm 8.712485815555e+00 true resid norm 8.712485815541e+00 ||r(i)||/||b|| 2.081619148094e-04
2458 KSP unpreconditioned resid norm 8.712485815031e+00 true resid norm 8.712485815020e+00 ||r(i)||/||b|| 2.081619147969e-04
2459 KSP unpreconditioned resid norm 8.712485814748e+00 true resid norm 8.712485814730e+00 ||r(i)||/||b|| 2.081619147900e-04
2460 KSP unpreconditioned resid norm 8.712485814719e+00 true resid norm 8.712485814719e+00 ||r(i)||/||b|| 2.081619147897e-04
2461 KSP unpreconditioned resid norm 8.712485814719e+00 true resid norm 8.712485814717e+00 ||r(i)||/||b|| 2.081619147897e-04
2462 KSP unpreconditioned resid norm 8.712485814717e+00 true resid norm 8.712485814711e+00 ||r(i)||/||b|| 2.081619147895e-04
2463 KSP unpreconditioned resid norm 8.712485814712e+00 true resid norm 8.712485814708e+00 ||r(i)||/||b|| 2.081619147895e-04
2464 KSP unpreconditioned resid norm 8.712485814699e+00 true resid norm 8.712485814691e+00 ||r(i)||/||b|| 2.081619147891e-04
2465 KSP unpreconditioned resid norm 8.712485814684e+00 true resid norm 8.712485814682e+00 ||r(i)||/||b|| 2.081619147889e-04
2466 KSP unpreconditioned resid norm 8.712485814680e+00 true resid norm 8.712485814679e+00 ||r(i)||/||b|| 2.081619147888e-04
2467 KSP unpreconditioned resid norm 8.712485814677e+00 true resid norm 8.712485814680e+00 ||r(i)||/||b|| 2.081619147888e-04
2468 KSP unpreconditioned resid norm 8.712485814670e+00 true resid norm 8.712485814665e+00 ||r(i)||/||b|| 2.081619147885e-04
2469 KSP unpreconditioned resid norm 8.712485814657e+00 true resid norm 8.712485814651e+00 ||r(i)||/||b|| 2.081619147881e-04
2470 KSP unpreconditioned resid norm 8.712485814645e+00 true resid norm 8.712485814650e+00 ||r(i)||/||b|| 2.081619147881e-04
2471 KSP unpreconditioned resid norm 8.712485814642e+00 true resid norm 8.712485814645e+00 ||r(i)||/||b|| 2.081619147880e-04
2472 KSP unpreconditioned resid norm 8.712485814642e+00 true resid norm 8.712485814630e+00 ||r(i)||/||b|| 2.081619147876e-04
2473 KSP unpreconditioned resid norm 8.712485814628e+00 true resid norm 8.712485814639e+00 ||r(i)||/||b|| 2.081619147878e-04
2474 KSP unpreconditioned resid norm 8.712485814607e+00 true resid norm 8.712485814613e+00 ||r(i)||/||b|| 2.081619147872e-04
2475 KSP unpreconditioned resid norm 8.712485814575e+00 true resid norm 8.712485814572e+00 ||r(i)||/||b|| 2.081619147862e-04
2476 KSP unpreconditioned resid norm 8.712485814556e+00 true resid norm 8.712485814552e+00 ||r(i)||/||b|| 2.081619147858e-04
2477 KSP unpreconditioned resid norm 8.712485814540e+00 true resid norm 8.712485814547e+00 ||r(i)||/||b|| 2.081619147856e-04
2478 KSP unpreconditioned resid norm 8.712485814523e+00 true resid norm 8.712485814525e+00 ||r(i)||/||b|| 2.081619147851e-04
2479 KSP unpreconditioned resid norm 8.712485814508e+00 true resid norm 8.712485814515e+00 ||r(i)||/||b|| 2.081619147849e-04
2480 KSP unpreconditioned resid norm 8.712485814508e+00 true resid norm 8.712485814508e+00 ||r(i)||/||b|| 2.081619147847e-04
2481 KSP unpreconditioned resid norm 8.712485814505e+00 true resid norm 8.712485814508e+00 ||r(i)||/||b|| 2.081619147847e-04
2482 KSP unpreconditioned resid norm 8.712485814487e+00 true resid norm 8.712485814479e+00 ||r(i)||/||b|| 2.081619147840e-04
2483 KSP unpreconditioned resid norm 8.712485814392e+00 true resid norm 8.712485814401e+00 ||r(i)||/||b|| 2.081619147821e-04
2484 KSP unpreconditioned resid norm 8.712485814263e+00 true resid norm 8.712485814271e+00 ||r(i)||/||b|| 2.081619147790e-04
2485 KSP unpreconditioned resid norm 8.712485814164e+00 true resid norm 8.712485814158e+00 ||r(i)||/||b|| 2.081619147763e-04
2486 KSP unpreconditioned resid norm 8.712485814041e+00 true resid norm 8.712485814034e+00 ||r(i)||/||b|| 2.081619147734e-04
2487 KSP unpreconditioned resid norm 8.712485813847e+00 true resid norm 8.712485813852e+00 ||r(i)||/||b|| 2.081619147690e-04
2488 KSP unpreconditioned resid norm 8.712485813384e+00 true resid norm 8.712485813379e+00 ||r(i)||/||b|| 2.081619147577e-04
2489 KSP unpreconditioned resid norm 8.712485813134e+00 true resid norm 8.712485813127e+00 ||r(i)||/||b|| 2.081619147517e-04
2490 KSP unpreconditioned resid norm 8.712485813119e+00 true resid norm 8.712485813119e+00 ||r(i)||/||b|| 2.081619147515e-04
2491 KSP unpreconditioned resid norm 8.712485813119e+00 true resid norm 8.712485813122e+00 ||r(i)||/||b|| 2.081619147516e-04
2492 KSP unpreconditioned resid norm 8.712485813117e+00 true resid norm 8.712485813108e+00 ||r(i)||/||b|| 2.081619147512e-04
2493 KSP unpreconditioned resid norm 8.712485813112e+00 true resid norm 8.712485813102e+00 ||r(i)||/||b|| 2.081619147511e-04
2494 KSP unpreconditioned resid norm 8.712485813101e+00 true resid norm 8.712485813091e+00 ||r(i)||/||b|| 2.081619147508e-04
2495 KSP unpreconditioned resid norm 8.712485813088e+00 true resid norm 8.712485813076e+00 ||r(i)||/||b|| 2.081619147505e-04
2496 KSP unpreconditioned resid norm 8.712485813084e+00 true resid norm 8.712485813070e+00 ||r(i)||/||b|| 2.081619147503e-04
2497 KSP unpreconditioned resid norm 8.712485813082e+00 true resid norm 8.712485813084e+00 ||r(i)||/||b|| 2.081619147507e-04
2498 KSP unpreconditioned resid norm 8.712485813076e+00 true resid norm 8.712485813073e+00 ||r(i)||/||b|| 2.081619147504e-04
2499 KSP unpreconditioned resid norm 8.712485813064e+00 true resid norm 8.712485813069e+00 ||r(i)||/||b|| 2.081619147503e-04
2500 KSP unpreconditioned resid norm 8.712485813053e+00 true resid norm 8.712485813051e+00 ||r(i)||/||b|| 2.081619147499e-04
2501 KSP unpreconditioned resid norm 8.712485813051e+00 true resid norm 8.712485813045e+00 ||r(i)||/||b|| 2.081619147497e-04
2502 KSP unpreconditioned resid norm 8.712485813050e+00 true resid norm 8.712485813041e+00 ||r(i)||/||b|| 2.081619147496e-04
2503 KSP unpreconditioned resid norm 8.712485813039e+00 true resid norm 8.712485813035e+00 ||r(i)||/||b|| 2.081619147495e-04
2504 KSP unpreconditioned resid norm 8.712485813019e+00 true resid norm 8.712485813007e+00 ||r(i)||/||b|| 2.081619147488e-04
2505 KSP unpreconditioned resid norm 8.712485812992e+00 true resid norm 8.712485812984e+00 ||r(i)||/||b|| 2.081619147483e-04
2506 KSP unpreconditioned resid norm 8.712485812975e+00 true resid norm 8.712485812963e+00 ||r(i)||/||b|| 2.081619147478e-04
2507 KSP unpreconditioned resid norm 8.712485812961e+00 true resid norm 8.712485812958e+00 ||r(i)||/||b|| 2.081619147477e-04
2508 KSP unpreconditioned resid norm 8.712485812946e+00 true resid norm 8.712485812940e+00 ||r(i)||/||b|| 2.081619147472e-04
2509 KSP unpreconditioned resid norm 8.712485812933e+00 true resid norm 8.712485812932e+00 ||r(i)||/||b|| 2.081619147471e-04
2510 KSP unpreconditioned resid norm 8.712485812932e+00 true resid norm 8.712485812933e+00 ||r(i)||/||b|| 2.081619147471e-04
2511 KSP unpreconditioned resid norm 8.712485812930e+00 true resid norm 8.712485812919e+00 ||r(i)||/||b|| 2.081619147467e-04
2512 KSP unpreconditioned resid norm 8.712485812914e+00 true resid norm 8.712485812907e+00 ||r(i)||/||b|| 2.081619147464e-04
2513 KSP unpreconditioned resid norm 8.712485812830e+00 true resid norm 8.712485812827e+00 ||r(i)||/||b|| 2.081619147445e-04
2514 KSP unpreconditioned resid norm 8.712485812717e+00 true resid norm 8.712485812709e+00 ||r(i)||/||b|| 2.081619147417e-04
2515 KSP unpreconditioned resid norm 8.712485812630e+00 true resid norm 8.712485812628e+00 ||r(i)||/||b|| 2.081619147398e-04
2516 KSP unpreconditioned resid norm 8.712485812522e+00 true resid norm 8.712485812518e+00 ||r(i)||/||b|| 2.081619147371e-04
2517 KSP unpreconditioned resid norm 8.712485812350e+00 true resid norm 8.712485812349e+00 ||r(i)||/||b|| 2.081619147331e-04
2518 KSP unpreconditioned resid norm 8.712485811940e+00 true resid norm 8.712485811935e+00 ||r(i)||/||b|| 2.081619147232e-04
2519 KSP unpreconditioned resid norm 8.712485811719e+00 true resid norm 8.712485811718e+00 ||r(i)||/||b|| 2.081619147180e-04
2520 KSP unpreconditioned resid norm 8.712485811714e+00 true resid norm 8.712485811714e+00 ||r(i)||/||b|| 2.081619147179e-04
2521 KSP unpreconditioned resid norm 8.712485811713e+00 true resid norm 8.712485811715e+00 ||r(i)||/||b|| 2.081619147180e-04
2522 KSP unpreconditioned resid norm 8.712485811713e+00 true resid norm 8.712485811712e+00 ||r(i)||/||b|| 2.081619147179e-04
2523 KSP unpreconditioned resid norm 8.712485811708e+00 true resid norm 8.712485811699e+00 ||r(i)||/||b|| 2.081619147176e-04
2524 KSP unpreconditioned resid norm 8.712485811698e+00 true resid norm 8.712485811690e+00 ||r(i)||/||b|| 2.081619147174e-04
2525 KSP unpreconditioned resid norm 8.712485811686e+00 true resid norm 8.712485811672e+00 ||r(i)||/||b|| 2.081619147169e-04
2526 KSP unpreconditioned resid norm 8.712485811683e+00 true resid norm 8.712485811671e+00 ||r(i)||/||b|| 2.081619147169e-04
2527 KSP unpreconditioned resid norm 8.712485811681e+00 true resid norm 8.712485811673e+00 ||r(i)||/||b|| 2.081619147170e-04
2528 KSP unpreconditioned resid norm 8.712485811676e+00 true resid norm 8.712485811667e+00 ||r(i)||/||b|| 2.081619147168e-04
2529 KSP unpreconditioned resid norm 8.712485811665e+00 true resid norm 8.712485811660e+00 ||r(i)||/||b|| 2.081619147167e-04
2530 KSP unpreconditioned resid norm 8.712485811656e+00 true resid norm 8.712485811642e+00 ||r(i)||/||b|| 2.081619147162e-04
2531 KSP unpreconditioned resid norm 8.712485811653e+00 true resid norm 8.712485811649e+00 ||r(i)||/||b|| 2.081619147164e-04
2532 KSP unpreconditioned resid norm 8.712485811653e+00 true resid norm 8.712485811644e+00 ||r(i)||/||b|| 2.081619147163e-04
2533 KSP unpreconditioned resid norm 8.712485811643e+00 true resid norm 8.712485811634e+00 ||r(i)||/||b|| 2.081619147160e-04
2534 KSP unpreconditioned resid norm 8.712485811626e+00 true resid norm 8.712485811613e+00 ||r(i)||/||b|| 2.081619147155e-04
2535 KSP unpreconditioned resid norm 8.712485811601e+00 true resid norm 8.712485811597e+00 ||r(i)||/||b|| 2.081619147151e-04
2536 KSP unpreconditioned resid norm 8.712485811587e+00 true resid norm 8.712485811580e+00 ||r(i)||/||b|| 2.081619147147e-04
2537 KSP unpreconditioned resid norm 8.712485811574e+00 true resid norm 8.712485811578e+00 ||r(i)||/||b|| 2.081619147147e-04
2538 KSP unpreconditioned resid norm 8.712485811561e+00 true resid norm 8.712485811553e+00 ||r(i)||/||b|| 2.081619147141e-04
2539 KSP unpreconditioned resid norm 8.712485811549e+00 true resid norm 8.712485811531e+00 ||r(i)||/||b|| 2.081619147136e-04
2540 KSP unpreconditioned resid norm 8.712485811548e+00 true resid norm 8.712485811539e+00 ||r(i)||/||b|| 2.081619147138e-04
2541 KSP unpreconditioned resid norm 8.712485811547e+00 true resid norm 8.712485811533e+00 ||r(i)||/||b|| 2.081619147136e-04
2542 KSP unpreconditioned resid norm 8.712485811532e+00 true resid norm 8.712485811524e+00 ||r(i)||/||b|| 2.081619147134e-04
2543 KSP unpreconditioned resid norm 8.712485811458e+00 true resid norm 8.712485811441e+00 ||r(i)||/||b|| 2.081619147114e-04
2544 KSP unpreconditioned resid norm 8.712485811357e+00 true resid norm 8.712485811345e+00 ||r(i)||/||b|| 2.081619147091e-04
2545 KSP unpreconditioned resid norm 8.712485811280e+00 true resid norm 8.712485811267e+00 ||r(i)||/||b|| 2.081619147073e-04
2546 KSP unpreconditioned resid norm 8.712485811184e+00 true resid norm 8.712485811168e+00 ||r(i)||/||b|| 2.081619147049e-04
2547 KSP unpreconditioned resid norm 8.712485811032e+00 true resid norm 8.712485811024e+00 ||r(i)||/||b|| 2.081619147015e-04
2548 KSP unpreconditioned resid norm 8.712485810670e+00 true resid norm 8.712485810656e+00 ||r(i)||/||b|| 2.081619146927e-04
2549 KSP unpreconditioned resid norm 8.712485810475e+00 true resid norm 8.712485810465e+00 ||r(i)||/||b|| 2.081619146881e-04
2550 KSP unpreconditioned resid norm 8.712485810458e+00 true resid norm 8.712485810458e+00 ||r(i)||/||b|| 2.081619146879e-04
2551 KSP unpreconditioned resid norm 8.712485810458e+00 true resid norm 8.712485810452e+00 ||r(i)||/||b|| 2.081619146878e-04
2552 KSP unpreconditioned resid norm 8.712485810457e+00 true resid norm 8.712485810454e+00 ||r(i)||/||b|| 2.081619146878e-04
2553 KSP unpreconditioned resid norm 8.712485810453e+00 true resid norm 8.712485810450e+00 ||r(i)||/||b|| 2.081619146878e-04
2554 KSP unpreconditioned resid norm 8.712485810444e+00 true resid norm 8.712485810445e+00 ||r(i)||/||b|| 2.081619146876e-04
2555 KSP unpreconditioned resid norm 8.712485810434e+00 true resid norm 8.712485810430e+00 ||r(i)||/||b|| 2.081619146873e-04
2556 KSP unpreconditioned resid norm 8.712485810431e+00 true resid norm 8.712485810425e+00 ||r(i)||/||b|| 2.081619146871e-04
2557 KSP unpreconditioned resid norm 8.712485810429e+00 true resid norm 8.712485810428e+00 ||r(i)||/||b|| 2.081619146872e-04
2558 KSP unpreconditioned resid norm 8.712485810424e+00 true resid norm 8.712485810414e+00 ||r(i)||/||b|| 2.081619146869e-04
2559 KSP unpreconditioned resid norm 8.712485810415e+00 true resid norm 8.712485810400e+00 ||r(i)||/||b|| 2.081619146866e-04
2560 KSP unpreconditioned resid norm 8.712485810407e+00 true resid norm 8.712485810407e+00 ||r(i)||/||b|| 2.081619146867e-04
2561 KSP unpreconditioned resid norm 8.712485810404e+00 true resid norm 8.712485810413e+00 ||r(i)||/||b|| 2.081619146869e-04
2562 KSP unpreconditioned resid norm 8.712485810404e+00 true resid norm 8.712485810409e+00 ||r(i)||/||b|| 2.081619146868e-04
2563 KSP unpreconditioned resid norm 8.712485810395e+00 true resid norm 8.712485810394e+00 ||r(i)||/||b|| 2.081619146864e-04
2564 KSP unpreconditioned resid norm 8.712485810380e+00 true resid norm 8.712485810376e+00 ||r(i)||/||b|| 2.081619146860e-04
2565 KSP unpreconditioned resid norm 8.712485810358e+00 true resid norm 8.712485810361e+00 ||r(i)||/||b|| 2.081619146856e-04
2566 KSP unpreconditioned resid norm 8.712485810345e+00 true resid norm 8.712485810344e+00 ||r(i)||/||b|| 2.081619146852e-04
2567 KSP unpreconditioned resid norm 8.712485810334e+00 true resid norm 8.712485810335e+00 ||r(i)||/||b|| 2.081619146850e-04
2568 KSP unpreconditioned resid norm 8.712485810323e+00 true resid norm 8.712485810321e+00 ||r(i)||/||b|| 2.081619146847e-04
2569 KSP unpreconditioned resid norm 8.712485810312e+00 true resid norm 8.712485810316e+00 ||r(i)||/||b|| 2.081619146845e-04
2570 KSP unpreconditioned resid norm 8.712485810312e+00 true resid norm 8.712485810305e+00 ||r(i)||/||b|| 2.081619146843e-04
2571 KSP unpreconditioned resid norm 8.712485810310e+00 true resid norm 8.712485810297e+00 ||r(i)||/||b|| 2.081619146841e-04
2572 KSP unpreconditioned resid norm 8.712485810298e+00 true resid norm 8.712485810302e+00 ||r(i)||/||b|| 2.081619146842e-04
2573 KSP unpreconditioned resid norm 8.712485810232e+00 true resid norm 8.712485810230e+00 ||r(i)||/||b|| 2.081619146825e-04
2574 KSP unpreconditioned resid norm 8.712485810143e+00 true resid norm 8.712485810147e+00 ||r(i)||/||b|| 2.081619146805e-04
2575 KSP unpreconditioned resid norm 8.712485810075e+00 true resid norm 8.712485810069e+00 ||r(i)||/||b|| 2.081619146786e-04
2576 KSP unpreconditioned resid norm 8.712485809991e+00 true resid norm 8.712485809990e+00 ||r(i)||/||b|| 2.081619146767e-04
2577 KSP unpreconditioned resid norm 8.712485809856e+00 true resid norm 8.712485809851e+00 ||r(i)||/||b|| 2.081619146734e-04
2578 KSP unpreconditioned resid norm 8.712485809536e+00 true resid norm 8.712485809533e+00 ||r(i)||/||b|| 2.081619146658e-04
2579 KSP unpreconditioned resid norm 8.712485809363e+00 true resid norm 8.712485809358e+00 ||r(i)||/||b|| 2.081619146616e-04
2580 KSP unpreconditioned resid norm 8.712485809348e+00 true resid norm 8.712485809348e+00 ||r(i)||/||b|| 2.081619146614e-04
2581 KSP unpreconditioned resid norm 8.712485809348e+00 true resid norm 8.712485809334e+00 ||r(i)||/||b|| 2.081619146611e-04
2582 KSP unpreconditioned resid norm 8.712485809347e+00 true resid norm 8.712485809339e+00 ||r(i)||/||b|| 2.081619146612e-04
2583 KSP unpreconditioned resid norm 8.712485809344e+00 true resid norm 8.712485809340e+00 ||r(i)||/||b|| 2.081619146612e-04
2584 KSP unpreconditioned resid norm 8.712485809336e+00 true resid norm 8.712485809336e+00 ||r(i)||/||b|| 2.081619146611e-04
2585 KSP unpreconditioned resid norm 8.712485809327e+00 true resid norm 8.712485809321e+00 ||r(i)||/||b|| 2.081619146608e-04
2586 KSP unpreconditioned resid norm 8.712485809324e+00 true resid norm 8.712485809320e+00 ||r(i)||/||b|| 2.081619146607e-04
2587 KSP unpreconditioned resid norm 8.712485809323e+00 true resid norm 8.712485809312e+00 ||r(i)||/||b|| 2.081619146606e-04
2588 KSP unpreconditioned resid norm 8.712485809319e+00 true resid norm 8.712485809305e+00 ||r(i)||/||b|| 2.081619146604e-04
2589 KSP unpreconditioned resid norm 8.712485809310e+00 true resid norm 8.712485809309e+00 ||r(i)||/||b|| 2.081619146605e-04
2590 KSP unpreconditioned resid norm 8.712485809303e+00 true resid norm 8.712485809311e+00 ||r(i)||/||b|| 2.081619146605e-04
2591 KSP unpreconditioned resid norm 8.712485809301e+00 true resid norm 8.712485809294e+00 ||r(i)||/||b|| 2.081619146601e-04
2592 KSP unpreconditioned resid norm 8.712485809301e+00 true resid norm 8.712485809301e+00 ||r(i)||/||b|| 2.081619146603e-04
2593 KSP unpreconditioned resid norm 8.712485809293e+00 true resid norm 8.712485809282e+00 ||r(i)||/||b|| 2.081619146598e-04
2594 KSP unpreconditioned resid norm 8.712485809280e+00 true resid norm 8.712485809275e+00 ||r(i)||/||b|| 2.081619146597e-04
2595 KSP unpreconditioned resid norm 8.712485809260e+00 true resid norm 8.712485809253e+00 ||r(i)||/||b|| 2.081619146591e-04
2596 KSP unpreconditioned resid norm 8.712485809249e+00 true resid norm 8.712485809247e+00 ||r(i)||/||b|| 2.081619146590e-04
2597 KSP unpreconditioned resid norm 8.712485809239e+00 true resid norm 8.712485809240e+00 ||r(i)||/||b|| 2.081619146588e-04
2598 KSP unpreconditioned resid norm 8.712485809229e+00 true resid norm 8.712485809225e+00 ||r(i)||/||b|| 2.081619146585e-04
2599 KSP unpreconditioned resid norm 8.712485809219e+00 true resid norm 8.712485809217e+00 ||r(i)||/||b|| 2.081619146583e-04
2600 KSP unpreconditioned resid norm 8.712485809219e+00 true resid norm 8.712485809216e+00 ||r(i)||/||b|| 2.081619146583e-04
2601 KSP unpreconditioned resid norm 8.712485809218e+00 true resid norm 8.712485809210e+00 ||r(i)||/||b|| 2.081619146581e-04
2602 KSP unpreconditioned resid norm 8.712485809206e+00 true resid norm 8.712485809203e+00 ||r(i)||/||b|| 2.081619146579e-04
2603 KSP unpreconditioned resid norm 8.712485809148e+00 true resid norm 8.712485809142e+00 ||r(i)||/||b|| 2.081619146565e-04
2604 KSP unpreconditioned resid norm 8.712485809069e+00 true resid norm 8.712485809070e+00 ||r(i)||/||b|| 2.081619146548e-04
2605 KSP unpreconditioned resid norm 8.712485809009e+00 true resid norm 8.712485809000e+00 ||r(i)||/||b|| 2.081619146531e-04
2606 KSP unpreconditioned resid norm 8.712485808934e+00 true resid norm 8.712485808921e+00 ||r(i)||/||b|| 2.081619146512e-04
2607 KSP unpreconditioned resid norm 8.712485808815e+00 true resid norm 8.712485808815e+00 ||r(i)||/||b|| 2.081619146487e-04
2608 KSP unpreconditioned resid norm 8.712485808532e+00 true resid norm 8.712485808525e+00 ||r(i)||/||b|| 2.081619146417e-04
2609 KSP unpreconditioned resid norm 8.712485808379e+00 true resid norm 8.712485808380e+00 ||r(i)||/||b|| 2.081619146383e-04
2610 KSP unpreconditioned resid norm 8.712485808363e+00 true resid norm 8.712485808363e+00 ||r(i)||/||b|| 2.081619146379e-04
2611 KSP unpreconditioned resid norm 8.712485808363e+00 true resid norm 8.712485808361e+00 ||r(i)||/||b|| 2.081619146378e-04
2612 KSP unpreconditioned resid norm 8.712485808363e+00 true resid norm 8.712485808363e+00 ||r(i)||/||b|| 2.081619146379e-04
2613 KSP unpreconditioned resid norm 8.712485808360e+00 true resid norm 8.712485808362e+00 ||r(i)||/||b|| 2.081619146379e-04
2614 KSP unpreconditioned resid norm 8.712485808353e+00 true resid norm 8.712485808354e+00 ||r(i)||/||b|| 2.081619146377e-04
2615 KSP unpreconditioned resid norm 8.712485808345e+00 true resid norm 8.712485808340e+00 ||r(i)||/||b|| 2.081619146373e-04
2616 KSP unpreconditioned resid norm 8.712485808342e+00 true resid norm 8.712485808336e+00 ||r(i)||/||b|| 2.081619146372e-04
2617 KSP unpreconditioned resid norm 8.712485808341e+00 true resid norm 8.712485808341e+00 ||r(i)||/||b|| 2.081619146373e-04
2618 KSP unpreconditioned resid norm 8.712485808337e+00 true resid norm 8.712485808325e+00 ||r(i)||/||b|| 2.081619146370e-04
2619 KSP unpreconditioned resid norm 8.712485808330e+00 true resid norm 8.712485808330e+00 ||r(i)||/||b|| 2.081619146371e-04
2620 KSP unpreconditioned resid norm 8.712485808323e+00 true resid norm 8.712485808329e+00 ||r(i)||/||b|| 2.081619146371e-04
2621 KSP unpreconditioned resid norm 8.712485808322e+00 true resid norm 8.712485808313e+00 ||r(i)||/||b|| 2.081619146367e-04
2622 KSP unpreconditioned resid norm 8.712485808322e+00 true resid norm 8.712485808326e+00 ||r(i)||/||b|| 2.081619146370e-04
2623 KSP unpreconditioned resid norm 8.712485808315e+00 true resid norm 8.712485808314e+00 ||r(i)||/||b|| 2.081619146367e-04
2624 KSP unpreconditioned resid norm 8.712485808303e+00 true resid norm 8.712485808302e+00 ||r(i)||/||b|| 2.081619146364e-04
2625 KSP unpreconditioned resid norm 8.712485808286e+00 true resid norm 8.712485808280e+00 ||r(i)||/||b|| 2.081619146359e-04
2626 KSP unpreconditioned resid norm 8.712485808276e+00 true resid norm 8.712485808271e+00 ||r(i)||/||b|| 2.081619146357e-04
2627 KSP unpreconditioned resid norm 8.712485808267e+00 true resid norm 8.712485808264e+00 ||r(i)||/||b|| 2.081619146355e-04
2628 KSP unpreconditioned resid norm 8.712485808258e+00 true resid norm 8.712485808254e+00 ||r(i)||/||b|| 2.081619146353e-04
2629 KSP unpreconditioned resid norm 8.712485808250e+00 true resid norm 8.712485808253e+00 ||r(i)||/||b|| 2.081619146353e-04
2630 KSP unpreconditioned resid norm 8.712485808249e+00 true resid norm 8.712485808249e+00 ||r(i)||/||b|| 2.081619146352e-04
2631 KSP unpreconditioned resid norm 8.712485808248e+00 true resid norm 8.712485808242e+00 ||r(i)||/||b|| 2.081619146350e-04
2632 KSP unpreconditioned resid norm 8.712485808238e+00 true resid norm 8.712485808234e+00 ||r(i)||/||b|| 2.081619146348e-04
2633 KSP unpreconditioned resid norm 8.712485808187e+00 true resid norm 8.712485808184e+00 ||r(i)||/||b|| 2.081619146336e-04
2634 KSP unpreconditioned resid norm 8.712485808118e+00 true resid norm 8.712485808120e+00 ||r(i)||/||b|| 2.081619146321e-04
2635 KSP unpreconditioned resid norm 8.712485808064e+00 true resid norm 8.712485808064e+00 ||r(i)||/||b|| 2.081619146307e-04
2636 KSP unpreconditioned resid norm 8.712485807998e+00 true resid norm 8.712485808004e+00 ||r(i)||/||b|| 2.081619146293e-04
2637 KSP unpreconditioned resid norm 8.712485807893e+00 true resid norm 8.712485807892e+00 ||r(i)||/||b|| 2.081619146266e-04
2638 KSP unpreconditioned resid norm 8.712485807643e+00 true resid norm 8.712485807639e+00 ||r(i)||/||b|| 2.081619146206e-04
2639 KSP unpreconditioned resid norm 8.712485807507e+00 true resid norm 8.712485807514e+00 ||r(i)||/||b|| 2.081619146176e-04
2640 KSP unpreconditioned resid norm 8.712485807503e+00 true resid norm 8.712485807503e+00 ||r(i)||/||b|| 2.081619146173e-04
2641 KSP unpreconditioned resid norm 8.712485807503e+00 true resid norm 8.712485807498e+00 ||r(i)||/||b|| 2.081619146172e-04
2642 KSP unpreconditioned resid norm 8.712485807502e+00 true resid norm 8.712485807495e+00 ||r(i)||/||b|| 2.081619146172e-04
2643 KSP unpreconditioned resid norm 8.712485807499e+00 true resid norm 8.712485807506e+00 ||r(i)||/||b|| 2.081619146174e-04
2644 KSP unpreconditioned resid norm 8.712485807493e+00 true resid norm 8.712485807489e+00 ||r(i)||/||b|| 2.081619146170e-04
2645 KSP unpreconditioned resid norm 8.712485807486e+00 true resid norm 8.712485807466e+00 ||r(i)||/||b|| 2.081619146164e-04
2646 KSP unpreconditioned resid norm 8.712485807484e+00 true resid norm 8.712485807466e+00 ||r(i)||/||b|| 2.081619146165e-04
2647 KSP unpreconditioned resid norm 8.712485807483e+00 true resid norm 8.712485807479e+00 ||r(i)||/||b|| 2.081619146168e-04
2648 KSP unpreconditioned resid norm 8.712485807479e+00 true resid norm 8.712485807476e+00 ||r(i)||/||b|| 2.081619146167e-04
2649 KSP unpreconditioned resid norm 8.712485807473e+00 true resid norm 8.712485807466e+00 ||r(i)||/||b|| 2.081619146164e-04
2650 KSP unpreconditioned resid norm 8.712485807467e+00 true resid norm 8.712485807462e+00 ||r(i)||/||b|| 2.081619146164e-04
2651 KSP unpreconditioned resid norm 8.712485807466e+00 true resid norm 8.712485807452e+00 ||r(i)||/||b|| 2.081619146161e-04
2652 KSP unpreconditioned resid norm 8.712485807466e+00 true resid norm 8.712485807462e+00 ||r(i)||/||b|| 2.081619146164e-04
2653 KSP unpreconditioned resid norm 8.712485807459e+00 true resid norm 8.712485807449e+00 ||r(i)||/||b|| 2.081619146161e-04
2654 KSP unpreconditioned resid norm 8.712485807449e+00 true resid norm 8.712485807440e+00 ||r(i)||/||b|| 2.081619146158e-04
2655 KSP unpreconditioned resid norm 8.712485807434e+00 true resid norm 8.712485807437e+00 ||r(i)||/||b|| 2.081619146158e-04
2656 KSP unpreconditioned resid norm 8.712485807425e+00 true resid norm 8.712485807413e+00 ||r(i)||/||b|| 2.081619146152e-04
2657 KSP unpreconditioned resid norm 8.712485807417e+00 true resid norm 8.712485807417e+00 ||r(i)||/||b|| 2.081619146153e-04
2658 KSP unpreconditioned resid norm 8.712485807409e+00 true resid norm 8.712485807399e+00 ||r(i)||/||b|| 2.081619146149e-04
2659 KSP unpreconditioned resid norm 8.712485807402e+00 true resid norm 8.712485807395e+00 ||r(i)||/||b|| 2.081619146147e-04
2660 KSP unpreconditioned resid norm 8.712485807402e+00 true resid norm 8.712485807391e+00 ||r(i)||/||b|| 2.081619146147e-04
2661 KSP unpreconditioned resid norm 8.712485807401e+00 true resid norm 8.712485807390e+00 ||r(i)||/||b|| 2.081619146146e-04
2662 KSP unpreconditioned resid norm 8.712485807392e+00 true resid norm 8.712485807384e+00 ||r(i)||/||b|| 2.081619146145e-04
2663 KSP unpreconditioned resid norm 8.712485807346e+00 true resid norm 8.712485807346e+00 ||r(i)||/||b|| 2.081619146136e-04
2664 KSP unpreconditioned resid norm 8.712485807285e+00 true resid norm 8.712485807290e+00 ||r(i)||/||b|| 2.081619146123e-04
2665 KSP unpreconditioned resid norm 8.712485807237e+00 true resid norm 8.712485807233e+00 ||r(i)||/||b|| 2.081619146109e-04
2666 KSP unpreconditioned resid norm 8.712485807179e+00 true resid norm 8.712485807173e+00 ||r(i)||/||b|| 2.081619146095e-04
2667 KSP unpreconditioned resid norm 8.712485807086e+00 true resid norm 8.712485807075e+00 ||r(i)||/||b|| 2.081619146071e-04
2668 KSP unpreconditioned resid norm 8.712485806864e+00 true resid norm 8.712485806852e+00 ||r(i)||/||b|| 2.081619146018e-04
2669 KSP unpreconditioned resid norm 8.712485806745e+00 true resid norm 8.712485806746e+00 ||r(i)||/||b|| 2.081619145992e-04
2670 KSP unpreconditioned resid norm 8.712485806739e+00 true resid norm 8.712485806739e+00 ||r(i)||/||b|| 2.081619145991e-04
2671 KSP unpreconditioned resid norm 8.712485806739e+00 true resid norm 8.712485806727e+00 ||r(i)||/||b|| 2.081619145988e-04
2672 KSP unpreconditioned resid norm 8.712485806739e+00 true resid norm 8.712485806738e+00 ||r(i)||/||b|| 2.081619145990e-04
2673 KSP unpreconditioned resid norm 8.712485806736e+00 true resid norm 8.712485806727e+00 ||r(i)||/||b|| 2.081619145988e-04
2674 KSP unpreconditioned resid norm 8.712485806731e+00 true resid norm 8.712485806710e+00 ||r(i)||/||b|| 2.081619145984e-04
2675 KSP unpreconditioned resid norm 8.712485806725e+00 true resid norm 8.712485806718e+00 ||r(i)||/||b|| 2.081619145986e-04
2676 KSP unpreconditioned resid norm 8.712485806723e+00 true resid norm 8.712485806715e+00 ||r(i)||/||b|| 2.081619145985e-04
2677 KSP unpreconditioned resid norm 8.712485806722e+00 true resid norm 8.712485806718e+00 ||r(i)||/||b|| 2.081619145986e-04
2678 KSP unpreconditioned resid norm 8.712485806719e+00 true resid norm 8.712485806714e+00 ||r(i)||/||b|| 2.081619145985e-04
2679 KSP unpreconditioned resid norm 8.712485806713e+00 true resid norm 8.712485806706e+00 ||r(i)||/||b|| 2.081619145983e-04
2680 KSP unpreconditioned resid norm 8.712485806708e+00 true resid norm 8.712485806707e+00 ||r(i)||/||b|| 2.081619145983e-04
2681 KSP unpreconditioned resid norm 8.712485806707e+00 true resid norm 8.712485806698e+00 ||r(i)||/||b|| 2.081619145981e-04
2682 KSP unpreconditioned resid norm 8.712485806707e+00 true resid norm 8.712485806696e+00 ||r(i)||/||b|| 2.081619145981e-04
2683 KSP unpreconditioned resid norm 8.712485806701e+00 true resid norm 8.712485806681e+00 ||r(i)||/||b|| 2.081619145977e-04
2684 KSP unpreconditioned resid norm 8.712485806692e+00 true resid norm 8.712485806686e+00 ||r(i)||/||b|| 2.081619145978e-04
2685 KSP unpreconditioned resid norm 8.712485806678e+00 true resid norm 8.712485806674e+00 ||r(i)||/||b|| 2.081619145975e-04
2686 KSP unpreconditioned resid norm 8.712485806671e+00 true resid norm 8.712485806669e+00 ||r(i)||/||b|| 2.081619145974e-04
2687 KSP unpreconditioned resid norm 8.712485806664e+00 true resid norm 8.712485806656e+00 ||r(i)||/||b|| 2.081619145971e-04
2688 KSP unpreconditioned resid norm 8.712485806657e+00 true resid norm 8.712485806637e+00 ||r(i)||/||b|| 2.081619145967e-04
2689 KSP unpreconditioned resid norm 8.712485806650e+00 true resid norm 8.712485806644e+00 ||r(i)||/||b|| 2.081619145968e-04
2690 KSP unpreconditioned resid norm 8.712485806650e+00 true resid norm 8.712485806640e+00 ||r(i)||/||b|| 2.081619145967e-04
2691 KSP unpreconditioned resid norm 8.712485806649e+00 true resid norm 8.712485806641e+00 ||r(i)||/||b|| 2.081619145967e-04
2692 KSP unpreconditioned resid norm 8.712485806641e+00 true resid norm 8.712485806632e+00 ||r(i)||/||b|| 2.081619145965e-04
2693 KSP unpreconditioned resid norm 8.712485806601e+00 true resid norm 8.712485806582e+00 ||r(i)||/||b|| 2.081619145953e-04
2694 KSP unpreconditioned resid norm 8.712485806547e+00 true resid norm 8.712485806549e+00 ||r(i)||/||b|| 2.081619145945e-04
2695 KSP unpreconditioned resid norm 8.712485806505e+00 true resid norm 8.712485806494e+00 ||r(i)||/||b|| 2.081619145932e-04
2696 KSP unpreconditioned resid norm 8.712485806454e+00 true resid norm 8.712485806439e+00 ||r(i)||/||b|| 2.081619145919e-04
2697 KSP unpreconditioned resid norm 8.712485806371e+00 true resid norm 8.712485806360e+00 ||r(i)||/||b|| 2.081619145900e-04
2698 KSP unpreconditioned resid norm 8.712485806175e+00 true resid norm 8.712485806167e+00 ||r(i)||/||b|| 2.081619145854e-04
2699 KSP unpreconditioned resid norm 8.712485806069e+00 true resid norm 8.712485806064e+00 ||r(i)||/||b|| 2.081619145830e-04
2700 KSP unpreconditioned resid norm 8.712485806054e+00 true resid norm 8.712485806054e+00 ||r(i)||/||b|| 2.081619145827e-04
2701 KSP unpreconditioned resid norm 8.712485806054e+00 true resid norm 8.712485806065e+00 ||r(i)||/||b|| 2.081619145830e-04
2702 KSP unpreconditioned resid norm 8.712485806053e+00 true resid norm 8.712485806059e+00 ||r(i)||/||b|| 2.081619145828e-04
2703 KSP unpreconditioned resid norm 8.712485806051e+00 true resid norm 8.712485806058e+00 ||r(i)||/||b|| 2.081619145828e-04
2704 KSP unpreconditioned resid norm 8.712485806046e+00 true resid norm 8.712485806048e+00 ||r(i)||/||b|| 2.081619145826e-04
2705 KSP unpreconditioned resid norm 8.712485806041e+00 true resid norm 8.712485806044e+00 ||r(i)||/||b|| 2.081619145825e-04
2706 KSP unpreconditioned resid norm 8.712485806039e+00 true resid norm 8.712485806046e+00 ||r(i)||/||b|| 2.081619145825e-04
2707 KSP unpreconditioned resid norm 8.712485806038e+00 true resid norm 8.712485806038e+00 ||r(i)||/||b|| 2.081619145823e-04
2708 KSP unpreconditioned resid norm 8.712485806036e+00 true resid norm 8.712485806044e+00 ||r(i)||/||b|| 2.081619145825e-04
2709 KSP unpreconditioned resid norm 8.712485806030e+00 true resid norm 8.712485806035e+00 ||r(i)||/||b|| 2.081619145823e-04
2710 KSP unpreconditioned resid norm 8.712485806026e+00 true resid norm 8.712485806030e+00 ||r(i)||/||b|| 2.081619145822e-04
2711 KSP unpreconditioned resid norm 8.712485806025e+00 true resid norm 8.712485806023e+00 ||r(i)||/||b|| 2.081619145820e-04
2712 KSP unpreconditioned resid norm 8.712485806025e+00 true resid norm 8.712485806038e+00 ||r(i)||/||b|| 2.081619145823e-04
2713 KSP unpreconditioned resid norm 8.712485806020e+00 true resid norm 8.712485806030e+00 ||r(i)||/||b|| 2.081619145822e-04
2714 KSP unpreconditioned resid norm 8.712485806012e+00 true resid norm 8.712485806013e+00 ||r(i)||/||b|| 2.081619145817e-04
2715 KSP unpreconditioned resid norm 8.712485806000e+00 true resid norm 8.712485806002e+00 ||r(i)||/||b|| 2.081619145815e-04
2716 KSP unpreconditioned resid norm 8.712485805993e+00 true resid norm 8.712485805993e+00 ||r(i)||/||b|| 2.081619145813e-04
2717 KSP unpreconditioned resid norm 8.712485805987e+00 true resid norm 8.712485805987e+00 ||r(i)||/||b|| 2.081619145811e-04
2718 KSP unpreconditioned resid norm 8.712485805981e+00 true resid norm 8.712485805994e+00 ||r(i)||/||b|| 2.081619145813e-04
2719 KSP unpreconditioned resid norm 8.712485805975e+00 true resid norm 8.712485805980e+00 ||r(i)||/||b|| 2.081619145809e-04
2720 KSP unpreconditioned resid norm 8.712485805975e+00 true resid norm 8.712485805978e+00 ||r(i)||/||b|| 2.081619145809e-04
2721 KSP unpreconditioned resid norm 8.712485805974e+00 true resid norm 8.712485805975e+00 ||r(i)||/||b|| 2.081619145808e-04
2722 KSP unpreconditioned resid norm 8.712485805967e+00 true resid norm 8.712485805964e+00 ||r(i)||/||b|| 2.081619145806e-04
2723 KSP unpreconditioned resid norm 8.712485805931e+00 true resid norm 8.712485805939e+00 ||r(i)||/||b|| 2.081619145800e-04
2724 KSP unpreconditioned resid norm 8.712485805883e+00 true resid norm 8.712485805895e+00 ||r(i)||/||b|| 2.081619145789e-04
2725 KSP unpreconditioned resid norm 8.712485805846e+00 true resid norm 8.712485805840e+00 ||r(i)||/||b|| 2.081619145776e-04
2726 KSP unpreconditioned resid norm 8.712485805800e+00 true resid norm 8.712485805806e+00 ||r(i)||/||b|| 2.081619145768e-04
2727 KSP unpreconditioned resid norm 8.712485805728e+00 true resid norm 8.712485805734e+00 ||r(i)||/||b|| 2.081619145751e-04
2728 KSP unpreconditioned resid norm 8.712485805554e+00 true resid norm 8.712485805558e+00 ||r(i)||/||b|| 2.081619145709e-04
2729 KSP unpreconditioned resid norm 8.712485805461e+00 true resid norm 8.712485805459e+00 ||r(i)||/||b|| 2.081619145685e-04
2730 KSP unpreconditioned resid norm 8.712485805462e+00 true resid norm 8.712485805462e+00 ||r(i)||/||b|| 2.081619145686e-04
2731 KSP unpreconditioned resid norm 8.712485805462e+00 true resid norm 8.712485805458e+00 ||r(i)||/||b|| 2.081619145685e-04
2732 KSP unpreconditioned resid norm 8.712485805462e+00 true resid norm 8.712485805468e+00 ||r(i)||/||b|| 2.081619145687e-04
2733 KSP unpreconditioned resid norm 8.712485805460e+00 true resid norm 8.712485805454e+00 ||r(i)||/||b|| 2.081619145684e-04
2734 KSP unpreconditioned resid norm 8.712485805456e+00 true resid norm 8.712485805455e+00 ||r(i)||/||b|| 2.081619145684e-04
2735 KSP unpreconditioned resid norm 8.712485805451e+00 true resid norm 8.712485805442e+00 ||r(i)||/||b|| 2.081619145681e-04
2736 KSP unpreconditioned resid norm 8.712485805450e+00 true resid norm 8.712485805442e+00 ||r(i)||/||b|| 2.081619145681e-04
2737 KSP unpreconditioned resid norm 8.712485805449e+00 true resid norm 8.712485805441e+00 ||r(i)||/||b|| 2.081619145681e-04
2738 KSP unpreconditioned resid norm 8.712485805447e+00 true resid norm 8.712485805440e+00 ||r(i)||/||b|| 2.081619145681e-04
2739 KSP unpreconditioned resid norm 8.712485805442e+00 true resid norm 8.712485805436e+00 ||r(i)||/||b|| 2.081619145679e-04
2740 KSP unpreconditioned resid norm 8.712485805438e+00 true resid norm 8.712485805431e+00 ||r(i)||/||b|| 2.081619145678e-04
2741 KSP unpreconditioned resid norm 8.712485805437e+00 true resid norm 8.712485805435e+00 ||r(i)||/||b|| 2.081619145679e-04
2742 KSP unpreconditioned resid norm 8.712485805437e+00 true resid norm 8.712485805427e+00 ||r(i)||/||b|| 2.081619145677e-04
2743 KSP unpreconditioned resid norm 8.712485805433e+00 true resid norm 8.712485805431e+00 ||r(i)||/||b|| 2.081619145678e-04
2744 KSP unpreconditioned resid norm 8.712485805425e+00 true resid norm 8.712485805429e+00 ||r(i)||/||b|| 2.081619145678e-04
2745 KSP unpreconditioned resid norm 8.712485805415e+00 true resid norm 8.712485805411e+00 ||r(i)||/||b|| 2.081619145674e-04
2746 KSP unpreconditioned resid norm 8.712485805409e+00 true resid norm 8.712485805403e+00 ||r(i)||/||b|| 2.081619145672e-04
2747 KSP unpreconditioned resid norm 8.712485805404e+00 true resid norm 8.712485805399e+00 ||r(i)||/||b|| 2.081619145671e-04
2748 KSP unpreconditioned resid norm 8.712485805398e+00 true resid norm 8.712485805394e+00 ||r(i)||/||b|| 2.081619145670e-04
2749 KSP unpreconditioned resid norm 8.712485805393e+00 true resid norm 8.712485805394e+00 ||r(i)||/||b|| 2.081619145670e-04
2750 KSP unpreconditioned resid norm 8.712485805393e+00 true resid norm 8.712485805382e+00 ||r(i)||/||b|| 2.081619145667e-04
2751 KSP unpreconditioned resid norm 8.712485805392e+00 true resid norm 8.712485805382e+00 ||r(i)||/||b|| 2.081619145667e-04
2752 KSP unpreconditioned resid norm 8.712485805386e+00 true resid norm 8.712485805385e+00 ||r(i)||/||b|| 2.081619145667e-04
2753 KSP unpreconditioned resid norm 8.712485805355e+00 true resid norm 8.712485805348e+00 ||r(i)||/||b|| 2.081619145658e-04
2754 KSP unpreconditioned resid norm 8.712485805312e+00 true resid norm 8.712485805311e+00 ||r(i)||/||b|| 2.081619145650e-04
2755 KSP unpreconditioned resid norm 8.712485805279e+00 true resid norm 8.712485805271e+00 ||r(i)||/||b|| 2.081619145640e-04
2756 KSP unpreconditioned resid norm 8.712485805239e+00 true resid norm 8.712485805234e+00 ||r(i)||/||b|| 2.081619145631e-04
2757 KSP unpreconditioned resid norm 8.712485805175e+00 true resid norm 8.712485805178e+00 ||r(i)||/||b|| 2.081619145618e-04
2758 KSP unpreconditioned resid norm 8.712485805022e+00 true resid norm 8.712485805021e+00 ||r(i)||/||b|| 2.081619145580e-04
2759 KSP unpreconditioned resid norm 8.712485804939e+00 true resid norm 8.712485804942e+00 ||r(i)||/||b|| 2.081619145562e-04
2760 KSP unpreconditioned resid norm 8.712485804931e+00 true resid norm 8.712485804931e+00 ||r(i)||/||b|| 2.081619145559e-04
2761 KSP unpreconditioned resid norm 8.712485804931e+00 true resid norm 8.712485804935e+00 ||r(i)||/||b|| 2.081619145560e-04
2762 KSP unpreconditioned resid norm 8.712485804931e+00 true resid norm 8.712485804936e+00 ||r(i)||/||b|| 2.081619145560e-04
2763 KSP unpreconditioned resid norm 8.712485804929e+00 true resid norm 8.712485804936e+00 ||r(i)||/||b|| 2.081619145560e-04
2764 KSP unpreconditioned resid norm 8.712485804925e+00 true resid norm 8.712485804930e+00 ||r(i)||/||b|| 2.081619145559e-04
2765 KSP unpreconditioned resid norm 8.712485804921e+00 true resid norm 8.712485804924e+00 ||r(i)||/||b|| 2.081619145557e-04
2766 KSP unpreconditioned resid norm 8.712485804920e+00 true resid norm 8.712485804931e+00 ||r(i)||/||b|| 2.081619145559e-04
2767 KSP unpreconditioned resid norm 8.712485804919e+00 true resid norm 8.712485804925e+00 ||r(i)||/||b|| 2.081619145557e-04
2768 KSP unpreconditioned resid norm 8.712485804917e+00 true resid norm 8.712485804911e+00 ||r(i)||/||b|| 2.081619145554e-04
2769 KSP unpreconditioned resid norm 8.712485804913e+00 true resid norm 8.712485804906e+00 ||r(i)||/||b|| 2.081619145553e-04
2770 KSP unpreconditioned resid norm 8.712485804909e+00 true resid norm 8.712485804913e+00 ||r(i)||/||b|| 2.081619145554e-04
2771 KSP unpreconditioned resid norm 8.712485804909e+00 true resid norm 8.712485804914e+00 ||r(i)||/||b|| 2.081619145555e-04
2772 KSP unpreconditioned resid norm 8.712485804909e+00 true resid norm 8.712485804910e+00 ||r(i)||/||b|| 2.081619145554e-04
2773 KSP unpreconditioned resid norm 8.712485804905e+00 true resid norm 8.712485804905e+00 ||r(i)||/||b|| 2.081619145553e-04
2774 KSP unpreconditioned resid norm 8.712485804898e+00 true resid norm 8.712485804907e+00 ||r(i)||/||b|| 2.081619145553e-04
2775 KSP unpreconditioned resid norm 8.712485804889e+00 true resid norm 8.712485804894e+00 ||r(i)||/||b|| 2.081619145550e-04
2776 KSP unpreconditioned resid norm 8.712485804884e+00 true resid norm 8.712485804903e+00 ||r(i)||/||b|| 2.081619145552e-04
2777 KSP unpreconditioned resid norm 8.712485804879e+00 true resid norm 8.712485804890e+00 ||r(i)||/||b|| 2.081619145549e-04
2778 KSP unpreconditioned resid norm 8.712485804874e+00 true resid norm 8.712485804875e+00 ||r(i)||/||b|| 2.081619145546e-04
2779 KSP unpreconditioned resid norm 8.712485804870e+00 true resid norm 8.712485804869e+00 ||r(i)||/||b|| 2.081619145544e-04
2780 KSP unpreconditioned resid norm 8.712485804869e+00 true resid norm 8.712485804874e+00 ||r(i)||/||b|| 2.081619145545e-04
2781 KSP unpreconditioned resid norm 8.712485804869e+00 true resid norm 8.712485804871e+00 ||r(i)||/||b|| 2.081619145545e-04
2782 KSP unpreconditioned resid norm 8.712485804863e+00 true resid norm 8.712485804872e+00 ||r(i)||/||b|| 2.081619145545e-04
2783 KSP unpreconditioned resid norm 8.712485804836e+00 true resid norm 8.712485804847e+00 ||r(i)||/||b|| 2.081619145539e-04
2784 KSP unpreconditioned resid norm 8.712485804798e+00 true resid norm 8.712485804802e+00 ||r(i)||/||b|| 2.081619145528e-04
2785 KSP unpreconditioned resid norm 8.712485804769e+00 true resid norm 8.712485804774e+00 ||r(i)||/||b|| 2.081619145521e-04
2786 KSP unpreconditioned resid norm 8.712485804733e+00 true resid norm 8.712485804740e+00 ||r(i)||/||b|| 2.081619145513e-04
2787 KSP unpreconditioned resid norm 8.712485804676e+00 true resid norm 8.712485804669e+00 ||r(i)||/||b|| 2.081619145496e-04
2788 KSP unpreconditioned resid norm 8.712485804541e+00 true resid norm 8.712485804534e+00 ||r(i)||/||b|| 2.081619145464e-04
2789 KSP unpreconditioned resid norm 8.712485804468e+00 true resid norm 8.712485804466e+00 ||r(i)||/||b|| 2.081619145448e-04
2790 KSP unpreconditioned resid norm 8.712485804468e+00 true resid norm 8.712485804468e+00 ||r(i)||/||b|| 2.081619145448e-04
2791 KSP unpreconditioned resid norm 8.712485804468e+00 true resid norm 8.712485804461e+00 ||r(i)||/||b|| 2.081619145446e-04
2792 KSP unpreconditioned resid norm 8.712485804468e+00 true resid norm 8.712485804469e+00 ||r(i)||/||b|| 2.081619145449e-04
2793 KSP unpreconditioned resid norm 8.712485804467e+00 true resid norm 8.712485804472e+00 ||r(i)||/||b|| 2.081619145449e-04
2794 KSP unpreconditioned resid norm 8.712485804463e+00 true resid norm 8.712485804458e+00 ||r(i)||/||b|| 2.081619145446e-04
2795 KSP unpreconditioned resid norm 8.712485804460e+00 true resid norm 8.712485804448e+00 ||r(i)||/||b|| 2.081619145444e-04
2796 KSP unpreconditioned resid norm 8.712485804458e+00 true resid norm 8.712485804449e+00 ||r(i)||/||b|| 2.081619145444e-04
2797 KSP unpreconditioned resid norm 8.712485804458e+00 true resid norm 8.712485804455e+00 ||r(i)||/||b|| 2.081619145445e-04
2798 KSP unpreconditioned resid norm 8.712485804456e+00 true resid norm 8.712485804444e+00 ||r(i)||/||b|| 2.081619145443e-04
2799 KSP unpreconditioned resid norm 8.712485804452e+00 true resid norm 8.712485804443e+00 ||r(i)||/||b|| 2.081619145442e-04
2800 KSP unpreconditioned resid norm 8.712485804449e+00 true resid norm 8.712485804446e+00 ||r(i)||/||b|| 2.081619145443e-04
2801 KSP unpreconditioned resid norm 8.712485804449e+00 true resid norm 8.712485804446e+00 ||r(i)||/||b|| 2.081619145443e-04
2802 KSP unpreconditioned resid norm 8.712485804449e+00 true resid norm 8.712485804443e+00 ||r(i)||/||b|| 2.081619145442e-04
2803 KSP unpreconditioned resid norm 8.712485804445e+00 true resid norm 8.712485804429e+00 ||r(i)||/||b|| 2.081619145439e-04
2804 KSP unpreconditioned resid norm 8.712485804439e+00 true resid norm 8.712485804422e+00 ||r(i)||/||b|| 2.081619145437e-04
2805 KSP unpreconditioned resid norm 8.712485804431e+00 true resid norm 8.712485804424e+00 ||r(i)||/||b|| 2.081619145438e-04
2806 KSP unpreconditioned resid norm 8.712485804427e+00 true resid norm 8.712485804425e+00 ||r(i)||/||b|| 2.081619145438e-04
2807 KSP unpreconditioned resid norm 8.712485804422e+00 true resid norm 8.712485804417e+00 ||r(i)||/||b|| 2.081619145436e-04
2808 KSP unpreconditioned resid norm 8.712485804418e+00 true resid norm 8.712485804412e+00 ||r(i)||/||b|| 2.081619145435e-04
2809 KSP unpreconditioned resid norm 8.712485804414e+00 true resid norm 8.712485804401e+00 ||r(i)||/||b|| 2.081619145432e-04
2810 KSP unpreconditioned resid norm 8.712485804414e+00 true resid norm 8.712485804410e+00 ||r(i)||/||b|| 2.081619145434e-04
2811 KSP unpreconditioned resid norm 8.712485804413e+00 true resid norm 8.712485804412e+00 ||r(i)||/||b|| 2.081619145435e-04
2812 KSP unpreconditioned resid norm 8.712485804409e+00 true resid norm 8.712485804397e+00 ||r(i)||/||b|| 2.081619145431e-04
2813 KSP unpreconditioned resid norm 8.712485804384e+00 true resid norm 8.712485804389e+00 ||r(i)||/||b|| 2.081619145429e-04
2814 KSP unpreconditioned resid norm 8.712485804351e+00 true resid norm 8.712485804346e+00 ||r(i)||/||b|| 2.081619145419e-04
2815 KSP unpreconditioned resid norm 8.712485804325e+00 true resid norm 8.712485804320e+00 ||r(i)||/||b|| 2.081619145413e-04
2816 KSP unpreconditioned resid norm 8.712485804294e+00 true resid norm 8.712485804277e+00 ||r(i)||/||b|| 2.081619145403e-04
2817 KSP unpreconditioned resid norm 8.712485804243e+00 true resid norm 8.712485804239e+00 ||r(i)||/||b|| 2.081619145393e-04
2818 KSP unpreconditioned resid norm 8.712485804124e+00 true resid norm 8.712485804116e+00 ||r(i)||/||b|| 2.081619145364e-04
2819 KSP unpreconditioned resid norm 8.712485804059e+00 true resid norm 8.712485804052e+00 ||r(i)||/||b|| 2.081619145349e-04
2820 KSP unpreconditioned resid norm 8.712485804043e+00 true resid norm 8.712485804043e+00 ||r(i)||/||b|| 2.081619145347e-04
2821 KSP unpreconditioned resid norm 8.712485804043e+00 true resid norm 8.712485804039e+00 ||r(i)||/||b|| 2.081619145346e-04
2822 KSP unpreconditioned resid norm 8.712485804043e+00 true resid norm 8.712485804034e+00 ||r(i)||/||b|| 2.081619145345e-04
2823 KSP unpreconditioned resid norm 8.712485804041e+00 true resid norm 8.712485804044e+00 ||r(i)||/||b|| 2.081619145347e-04
2824 KSP unpreconditioned resid norm 8.712485804039e+00 true resid norm 8.712485804039e+00 ||r(i)||/||b|| 2.081619145346e-04
2825 KSP unpreconditioned resid norm 8.712485804035e+00 true resid norm 8.712485804044e+00 ||r(i)||/||b|| 2.081619145347e-04
2826 KSP unpreconditioned resid norm 8.712485804034e+00 true resid norm 8.712485804036e+00 ||r(i)||/||b|| 2.081619145345e-04
2827 KSP unpreconditioned resid norm 8.712485804034e+00 true resid norm 8.712485804030e+00 ||r(i)||/||b|| 2.081619145344e-04
2828 KSP unpreconditioned resid norm 8.712485804032e+00 true resid norm 8.712485804022e+00 ||r(i)||/||b|| 2.081619145342e-04
2829 KSP unpreconditioned resid norm 8.712485804029e+00 true resid norm 8.712485804038e+00 ||r(i)||/||b|| 2.081619145345e-04
2830 KSP unpreconditioned resid norm 8.712485804026e+00 true resid norm 8.712485804047e+00 ||r(i)||/||b|| 2.081619145348e-04
2831 KSP unpreconditioned resid norm 8.712485804025e+00 true resid norm 8.712485804020e+00 ||r(i)||/||b|| 2.081619145341e-04
2832 KSP unpreconditioned resid norm 8.712485804025e+00 true resid norm 8.712485804030e+00 ||r(i)||/||b|| 2.081619145343e-04
2833 KSP unpreconditioned resid norm 8.712485804022e+00 true resid norm 8.712485804023e+00 ||r(i)||/||b|| 2.081619145342e-04
2834 KSP unpreconditioned resid norm 8.712485804017e+00 true resid norm 8.712485804021e+00 ||r(i)||/||b|| 2.081619145341e-04
2835 KSP unpreconditioned resid norm 8.712485804010e+00 true resid norm 8.712485804016e+00 ||r(i)||/||b|| 2.081619145340e-04
2836 KSP unpreconditioned resid norm 8.712485804006e+00 true resid norm 8.712485804013e+00 ||r(i)||/||b|| 2.081619145339e-04
2837 KSP unpreconditioned resid norm 8.712485804002e+00 true resid norm 8.712485804005e+00 ||r(i)||/||b|| 2.081619145338e-04
2838 KSP unpreconditioned resid norm 8.712485803998e+00 true resid norm 8.712485803998e+00 ||r(i)||/||b|| 2.081619145336e-04
2839 KSP unpreconditioned resid norm 8.712485803995e+00 true resid norm 8.712485803994e+00 ||r(i)||/||b|| 2.081619145335e-04
2840 KSP unpreconditioned resid norm 8.712485803995e+00 true resid norm 8.712485803993e+00 ||r(i)||/||b|| 2.081619145335e-04
2841 KSP unpreconditioned resid norm 8.712485803994e+00 true resid norm 8.712485803991e+00 ||r(i)||/||b|| 2.081619145334e-04
2842 KSP unpreconditioned resid norm 8.712485803990e+00 true resid norm 8.712485803999e+00 ||r(i)||/||b|| 2.081619145336e-04
2843 KSP unpreconditioned resid norm 8.712485803968e+00 true resid norm 8.712485803969e+00 ||r(i)||/||b|| 2.081619145329e-04
2844 KSP unpreconditioned resid norm 8.712485803939e+00 true resid norm 8.712485803954e+00 ||r(i)||/||b|| 2.081619145325e-04
2845 KSP unpreconditioned resid norm 8.712485803916e+00 true resid norm 8.712485803914e+00 ||r(i)||/||b|| 2.081619145316e-04
2846 KSP unpreconditioned resid norm 8.712485803888e+00 true resid norm 8.712485803900e+00 ||r(i)||/||b|| 2.081619145312e-04
2847 KSP unpreconditioned resid norm 8.712485803844e+00 true resid norm 8.712485803852e+00 ||r(i)||/||b|| 2.081619145301e-04
2848 KSP unpreconditioned resid norm 8.712485803738e+00 true resid norm 8.712485803744e+00 ||r(i)||/||b|| 2.081619145275e-04
2849 KSP unpreconditioned resid norm 8.712485803681e+00 true resid norm 8.712485803679e+00 ||r(i)||/||b|| 2.081619145260e-04
2850 KSP unpreconditioned resid norm 8.712485803673e+00 true resid norm 8.712485803673e+00 ||r(i)||/||b|| 2.081619145258e-04
2851 KSP unpreconditioned resid norm 8.712485803673e+00 true resid norm 8.712485803678e+00 ||r(i)||/||b|| 2.081619145259e-04
2852 KSP unpreconditioned resid norm 8.712485803673e+00 true resid norm 8.712485803664e+00 ||r(i)||/||b|| 2.081619145256e-04
2853 KSP unpreconditioned resid norm 8.712485803671e+00 true resid norm 8.712485803673e+00 ||r(i)||/||b|| 2.081619145258e-04
2854 KSP unpreconditioned resid norm 8.712485803669e+00 true resid norm 8.712485803663e+00 ||r(i)||/||b|| 2.081619145256e-04
2855 KSP unpreconditioned resid norm 8.712485803666e+00 true resid norm 8.712485803659e+00 ||r(i)||/||b|| 2.081619145255e-04
2856 KSP unpreconditioned resid norm 8.712485803665e+00 true resid norm 8.712485803667e+00 ||r(i)||/||b|| 2.081619145257e-04
2857 KSP unpreconditioned resid norm 8.712485803665e+00 true resid norm 8.712485803664e+00 ||r(i)||/||b|| 2.081619145256e-04
2858 KSP unpreconditioned resid norm 8.712485803663e+00 true resid norm 8.712485803670e+00 ||r(i)||/||b|| 2.081619145258e-04
2859 KSP unpreconditioned resid norm 8.712485803660e+00 true resid norm 8.712485803661e+00 ||r(i)||/||b|| 2.081619145255e-04
2860 KSP unpreconditioned resid norm 8.712485803658e+00 true resid norm 8.712485803668e+00 ||r(i)||/||b|| 2.081619145257e-04
2861 KSP unpreconditioned resid norm 8.712485803657e+00 true resid norm 8.712485803647e+00 ||r(i)||/||b|| 2.081619145252e-04
2862 KSP unpreconditioned resid norm 8.712485803657e+00 true resid norm 8.712485803660e+00 ||r(i)||/||b|| 2.081619145255e-04
2863 KSP unpreconditioned resid norm 8.712485803655e+00 true resid norm 8.712485803647e+00 ||r(i)||/||b|| 2.081619145252e-04
2864 KSP unpreconditioned resid norm 8.712485803650e+00 true resid norm 8.712485803652e+00 ||r(i)||/||b|| 2.081619145253e-04
2865 KSP unpreconditioned resid norm 8.712485803644e+00 true resid norm 8.712485803639e+00 ||r(i)||/||b|| 2.081619145250e-04
2866 KSP unpreconditioned resid norm 8.712485803640e+00 true resid norm 8.712485803637e+00 ||r(i)||/||b|| 2.081619145250e-04
2867 KSP unpreconditioned resid norm 8.712485803637e+00 true resid norm 8.712485803638e+00 ||r(i)||/||b|| 2.081619145250e-04
2868 KSP unpreconditioned resid norm 8.712485803633e+00 true resid norm 8.712485803645e+00 ||r(i)||/||b|| 2.081619145252e-04
2869 KSP unpreconditioned resid norm 8.712485803630e+00 true resid norm 8.712485803630e+00 ||r(i)||/||b|| 2.081619145248e-04
2870 KSP unpreconditioned resid norm 8.712485803630e+00 true resid norm 8.712485803633e+00 ||r(i)||/||b|| 2.081619145249e-04
2871 KSP unpreconditioned resid norm 8.712485803630e+00 true resid norm 8.712485803625e+00 ||r(i)||/||b|| 2.081619145247e-04
2872 KSP unpreconditioned resid norm 8.712485803626e+00 true resid norm 8.712485803632e+00 ||r(i)||/||b|| 2.081619145248e-04
2873 KSP unpreconditioned resid norm 8.712485803607e+00 true resid norm 8.712485803604e+00 ||r(i)||/||b|| 2.081619145242e-04
2874 KSP unpreconditioned resid norm 8.712485803581e+00 true resid norm 8.712485803593e+00 ||r(i)||/||b|| 2.081619145239e-04
2875 KSP unpreconditioned resid norm 8.712485803561e+00 true resid norm 8.712485803560e+00 ||r(i)||/||b|| 2.081619145231e-04
2876 KSP unpreconditioned resid norm 8.712485803536e+00 true resid norm 8.712485803539e+00 ||r(i)||/||b|| 2.081619145226e-04
2877 KSP unpreconditioned resid norm 8.712485803497e+00 true resid norm 8.712485803494e+00 ||r(i)||/||b|| 2.081619145216e-04
2878 KSP unpreconditioned resid norm 8.712485803403e+00 true resid norm 8.712485803399e+00 ||r(i)||/||b|| 2.081619145193e-04
2879 KSP unpreconditioned resid norm 8.712485803353e+00 true resid norm 8.712485803347e+00 ||r(i)||/||b|| 2.081619145180e-04
2880 KSP unpreconditioned resid norm 8.712485803354e+00 true resid norm 8.712485803354e+00 ||r(i)||/||b|| 2.081619145182e-04
2881 KSP unpreconditioned resid norm 8.712485803354e+00 true resid norm 8.712485803348e+00 ||r(i)||/||b|| 2.081619145181e-04
2882 KSP unpreconditioned resid norm 8.712485803354e+00 true resid norm 8.712485803348e+00 ||r(i)||/||b|| 2.081619145181e-04
2883 KSP unpreconditioned resid norm 8.712485803353e+00 true resid norm 8.712485803348e+00 ||r(i)||/||b|| 2.081619145181e-04
2884 KSP unpreconditioned resid norm 8.712485803351e+00 true resid norm 8.712485803337e+00 ||r(i)||/||b|| 2.081619145178e-04
2885 KSP unpreconditioned resid norm 8.712485803348e+00 true resid norm 8.712485803337e+00 ||r(i)||/||b|| 2.081619145178e-04
2886 KSP unpreconditioned resid norm 8.712485803347e+00 true resid norm 8.712485803348e+00 ||r(i)||/||b|| 2.081619145181e-04
2887 KSP unpreconditioned resid norm 8.712485803347e+00 true resid norm 8.712485803335e+00 ||r(i)||/||b|| 2.081619145177e-04
2888 KSP unpreconditioned resid norm 8.712485803346e+00 true resid norm 8.712485803344e+00 ||r(i)||/||b|| 2.081619145180e-04
2889 KSP unpreconditioned resid norm 8.712485803343e+00 true resid norm 8.712485803333e+00 ||r(i)||/||b|| 2.081619145177e-04
2890 KSP unpreconditioned resid norm 8.712485803341e+00 true resid norm 8.712485803334e+00 ||r(i)||/||b|| 2.081619145177e-04
2891 KSP unpreconditioned resid norm 8.712485803341e+00 true resid norm 8.712485803343e+00 ||r(i)||/||b|| 2.081619145179e-04
2892 KSP unpreconditioned resid norm 8.712485803341e+00 true resid norm 8.712485803331e+00 ||r(i)||/||b|| 2.081619145177e-04
2893 KSP unpreconditioned resid norm 8.712485803338e+00 true resid norm 8.712485803333e+00 ||r(i)||/||b|| 2.081619145177e-04
2894 KSP unpreconditioned resid norm 8.712485803334e+00 true resid norm 8.712485803321e+00 ||r(i)||/||b|| 2.081619145174e-04
2895 KSP unpreconditioned resid norm 8.712485803329e+00 true resid norm 8.712485803316e+00 ||r(i)||/||b|| 2.081619145173e-04
2896 KSP unpreconditioned resid norm 8.712485803325e+00 true resid norm 8.712485803317e+00 ||r(i)||/||b|| 2.081619145173e-04
2897 KSP unpreconditioned resid norm 8.712485803323e+00 true resid norm 8.712485803315e+00 ||r(i)||/||b|| 2.081619145173e-04
2898 KSP unpreconditioned resid norm 8.712485803320e+00 true resid norm 8.712485803304e+00 ||r(i)||/||b|| 2.081619145170e-04
2899 KSP unpreconditioned resid norm 8.712485803317e+00 true resid norm 8.712485803312e+00 ||r(i)||/||b|| 2.081619145172e-04
2900 KSP unpreconditioned resid norm 8.712485803317e+00 true resid norm 8.712485803319e+00 ||r(i)||/||b|| 2.081619145174e-04
2901 KSP unpreconditioned resid norm 8.712485803316e+00 true resid norm 8.712485803313e+00 ||r(i)||/||b|| 2.081619145172e-04
2902 KSP unpreconditioned resid norm 8.712485803313e+00 true resid norm 8.712485803311e+00 ||r(i)||/||b|| 2.081619145172e-04
2903 KSP unpreconditioned resid norm 8.712485803296e+00 true resid norm 8.712485803288e+00 ||r(i)||/||b|| 2.081619145166e-04
2904 KSP unpreconditioned resid norm 8.712485803273e+00 true resid norm 8.712485803273e+00 ||r(i)||/||b|| 2.081619145163e-04
2905 KSP unpreconditioned resid norm 8.712485803255e+00 true resid norm 8.712485803249e+00 ||r(i)||/||b|| 2.081619145157e-04
2906 KSP unpreconditioned resid norm 8.712485803233e+00 true resid norm 8.712485803224e+00 ||r(i)||/||b|| 2.081619145151e-04
2907 KSP unpreconditioned resid norm 8.712485803199e+00 true resid norm 8.712485803186e+00 ||r(i)||/||b|| 2.081619145142e-04
2908 KSP unpreconditioned resid norm 8.712485803116e+00 true resid norm 8.712485803114e+00 ||r(i)||/||b|| 2.081619145125e-04
2909 KSP unpreconditioned resid norm 8.712485803071e+00 true resid norm 8.712485803062e+00 ||r(i)||/||b|| 2.081619145112e-04
2910 KSP unpreconditioned resid norm 8.712485803076e+00 true resid norm 8.712485803076e+00 ||r(i)||/||b|| 2.081619145116e-04
2911 KSP unpreconditioned resid norm 8.712485803076e+00 true resid norm 8.712485803065e+00 ||r(i)||/||b|| 2.081619145113e-04
2912 KSP unpreconditioned resid norm 8.712485803076e+00 true resid norm 8.712485803065e+00 ||r(i)||/||b|| 2.081619145113e-04
2913 KSP unpreconditioned resid norm 8.712485803075e+00 true resid norm 8.712485803065e+00 ||r(i)||/||b|| 2.081619145113e-04
2914 KSP unpreconditioned resid norm 8.712485803073e+00 true resid norm 8.712485803059e+00 ||r(i)||/||b|| 2.081619145112e-04
2915 KSP unpreconditioned resid norm 8.712485803071e+00 true resid norm 8.712485803063e+00 ||r(i)||/||b|| 2.081619145112e-04
2916 KSP unpreconditioned resid norm 8.712485803070e+00 true resid norm 8.712485803061e+00 ||r(i)||/||b|| 2.081619145112e-04
2917 KSP unpreconditioned resid norm 8.712485803069e+00 true resid norm 8.712485803058e+00 ||r(i)||/||b|| 2.081619145111e-04
2918 KSP unpreconditioned resid norm 8.712485803068e+00 true resid norm 8.712485803065e+00 ||r(i)||/||b|| 2.081619145113e-04
2919 KSP unpreconditioned resid norm 8.712485803066e+00 true resid norm 8.712485803052e+00 ||r(i)||/||b|| 2.081619145110e-04
2920 KSP unpreconditioned resid norm 8.712485803064e+00 true resid norm 8.712485803057e+00 ||r(i)||/||b|| 2.081619145111e-04
2921 KSP unpreconditioned resid norm 8.712485803064e+00 true resid norm 8.712485803069e+00 ||r(i)||/||b|| 2.081619145114e-04
2922 KSP unpreconditioned resid norm 8.712485803064e+00 true resid norm 8.712485803062e+00 ||r(i)||/||b|| 2.081619145112e-04
2923 KSP unpreconditioned resid norm 8.712485803062e+00 true resid norm 8.712485803051e+00 ||r(i)||/||b|| 2.081619145110e-04
2924 KSP unpreconditioned resid norm 8.712485803058e+00 true resid norm 8.712485803051e+00 ||r(i)||/||b|| 2.081619145110e-04
2925 KSP unpreconditioned resid norm 8.712485803053e+00 true resid norm 8.712485803041e+00 ||r(i)||/||b|| 2.081619145107e-04
2926 KSP unpreconditioned resid norm 8.712485803050e+00 true resid norm 8.712485803060e+00 ||r(i)||/||b|| 2.081619145112e-04
2927 KSP unpreconditioned resid norm 8.712485803048e+00 true resid norm 8.712485803049e+00 ||r(i)||/||b|| 2.081619145109e-04
2928 KSP unpreconditioned resid norm 8.712485803045e+00 true resid norm 8.712485803046e+00 ||r(i)||/||b|| 2.081619145109e-04
2929 KSP unpreconditioned resid norm 8.712485803043e+00 true resid norm 8.712485803037e+00 ||r(i)||/||b|| 2.081619145106e-04
2930 KSP unpreconditioned resid norm 8.712485803043e+00 true resid norm 8.712485803036e+00 ||r(i)||/||b|| 2.081619145106e-04
2931 KSP unpreconditioned resid norm 8.712485803042e+00 true resid norm 8.712485803041e+00 ||r(i)||/||b|| 2.081619145107e-04
2932 KSP unpreconditioned resid norm 8.712485803039e+00 true resid norm 8.712485803030e+00 ||r(i)||/||b|| 2.081619145105e-04
2933 KSP unpreconditioned resid norm 8.712485803024e+00 true resid norm 8.712485803017e+00 ||r(i)||/||b|| 2.081619145102e-04
2934 KSP unpreconditioned resid norm 8.712485803004e+00 true resid norm 8.712485802993e+00 ||r(i)||/||b|| 2.081619145096e-04
2935 KSP unpreconditioned resid norm 8.712485802988e+00 true resid norm 8.712485802978e+00 ||r(i)||/||b|| 2.081619145092e-04
2936 KSP unpreconditioned resid norm 8.712485802969e+00 true resid norm 8.712485802957e+00 ||r(i)||/||b|| 2.081619145087e-04
2937 KSP unpreconditioned resid norm 8.712485802938e+00 true resid norm 8.712485802946e+00 ||r(i)||/||b|| 2.081619145084e-04
2938 KSP unpreconditioned resid norm 8.712485802865e+00 true resid norm 8.712485802864e+00 ||r(i)||/||b|| 2.081619145065e-04
2939 KSP unpreconditioned resid norm 8.712485802825e+00 true resid norm 8.712485802816e+00 ||r(i)||/||b|| 2.081619145054e-04
2940 KSP unpreconditioned resid norm 8.712485802811e+00 true resid norm 8.712485802811e+00 ||r(i)||/||b|| 2.081619145052e-04
2941 KSP unpreconditioned resid norm 8.712485802811e+00 true resid norm 8.712485802809e+00 ||r(i)||/||b|| 2.081619145052e-04
2942 KSP unpreconditioned resid norm 8.712485802810e+00 true resid norm 8.712485802812e+00 ||r(i)||/||b|| 2.081619145053e-04
2943 KSP unpreconditioned resid norm 8.712485802810e+00 true resid norm 8.712485802811e+00 ||r(i)||/||b|| 2.081619145052e-04
2944 KSP unpreconditioned resid norm 8.712485802808e+00 true resid norm 8.712485802806e+00 ||r(i)||/||b|| 2.081619145051e-04
2945 KSP unpreconditioned resid norm 8.712485802806e+00 true resid norm 8.712485802809e+00 ||r(i)||/||b|| 2.081619145052e-04
2946 KSP unpreconditioned resid norm 8.712485802805e+00 true resid norm 8.712485802809e+00 ||r(i)||/||b|| 2.081619145052e-04
2947 KSP unpreconditioned resid norm 8.712485802805e+00 true resid norm 8.712485802804e+00 ||r(i)||/||b|| 2.081619145051e-04
2948 KSP unpreconditioned resid norm 8.712485802804e+00 true resid norm 8.712485802804e+00 ||r(i)||/||b|| 2.081619145051e-04
2949 KSP unpreconditioned resid norm 8.712485802802e+00 true resid norm 8.712485802805e+00 ||r(i)||/||b|| 2.081619145051e-04
2950 KSP unpreconditioned resid norm 8.712485802800e+00 true resid norm 8.712485802803e+00 ||r(i)||/||b|| 2.081619145050e-04
2951 KSP unpreconditioned resid norm 8.712485802800e+00 true resid norm 8.712485802805e+00 ||r(i)||/||b|| 2.081619145051e-04
2952 KSP unpreconditioned resid norm 8.712485802800e+00 true resid norm 8.712485802802e+00 ||r(i)||/||b|| 2.081619145050e-04
2953 KSP unpreconditioned resid norm 8.712485802798e+00 true resid norm 8.712485802805e+00 ||r(i)||/||b|| 2.081619145051e-04
2954 KSP unpreconditioned resid norm 8.712485802795e+00 true resid norm 8.712485802788e+00 ||r(i)||/||b|| 2.081619145047e-04
2955 KSP unpreconditioned resid norm 8.712485802791e+00 true resid norm 8.712485802795e+00 ||r(i)||/||b|| 2.081619145048e-04
2956 KSP unpreconditioned resid norm 8.712485802788e+00 true resid norm 8.712485802787e+00 ||r(i)||/||b|| 2.081619145047e-04
2957 KSP unpreconditioned resid norm 8.712485802786e+00 true resid norm 8.712485802793e+00 ||r(i)||/||b|| 2.081619145048e-04
2958 KSP unpreconditioned resid norm 8.712485802783e+00 true resid norm 8.712485802798e+00 ||r(i)||/||b|| 2.081619145049e-04
2959 KSP unpreconditioned resid norm 8.712485802781e+00 true resid norm 8.712485802791e+00 ||r(i)||/||b|| 2.081619145048e-04
2960 KSP unpreconditioned resid norm 8.712485802781e+00 true resid norm 8.712485802792e+00 ||r(i)||/||b|| 2.081619145048e-04
2961 KSP unpreconditioned resid norm 8.712485802781e+00 true resid norm 8.712485802782e+00 ||r(i)||/||b|| 2.081619145045e-04
2962 KSP unpreconditioned resid norm 8.712485802778e+00 true resid norm 8.712485802782e+00 ||r(i)||/||b|| 2.081619145045e-04
2963 KSP unpreconditioned resid norm 8.712485802765e+00 true resid norm 8.712485802767e+00 ||r(i)||/||b|| 2.081619145042e-04
2964 KSP unpreconditioned resid norm 8.712485802747e+00 true resid norm 8.712485802744e+00 ||r(i)||/||b|| 2.081619145036e-04
2965 KSP unpreconditioned resid norm 8.712485802733e+00 true resid norm 8.712485802743e+00 ||r(i)||/||b|| 2.081619145036e-04
2966 KSP unpreconditioned resid norm 8.712485802716e+00 true resid norm 8.712485802722e+00 ||r(i)||/||b|| 2.081619145031e-04
2967 KSP unpreconditioned resid norm 8.712485802689e+00 true resid norm 8.712485802681e+00 ||r(i)||/||b|| 2.081619145021e-04
2968 KSP unpreconditioned resid norm 8.712485802624e+00 true resid norm 8.712485802624e+00 ||r(i)||/||b|| 2.081619145008e-04
2969 KSP unpreconditioned resid norm 8.712485802589e+00 true resid norm 8.712485802589e+00 ||r(i)||/||b|| 2.081619144999e-04
2970 KSP unpreconditioned resid norm 8.712485802593e+00 true resid norm 8.712485802593e+00 ||r(i)||/||b|| 2.081619145000e-04
2971 KSP unpreconditioned resid norm 8.712485802593e+00 true resid norm 8.712485802589e+00 ||r(i)||/||b|| 2.081619144999e-04
2972 KSP unpreconditioned resid norm 8.712485802592e+00 true resid norm 8.712485802593e+00 ||r(i)||/||b|| 2.081619145000e-04
2973 KSP unpreconditioned resid norm 8.712485802592e+00 true resid norm 8.712485802599e+00 ||r(i)||/||b|| 2.081619145002e-04
2974 KSP unpreconditioned resid norm 8.712485802590e+00 true resid norm 8.712485802590e+00 ||r(i)||/||b|| 2.081619145000e-04
2975 KSP unpreconditioned resid norm 8.712485802588e+00 true resid norm 8.712485802582e+00 ||r(i)||/||b|| 2.081619144998e-04
2976 KSP unpreconditioned resid norm 8.712485802588e+00 true resid norm 8.712485802601e+00 ||r(i)||/||b|| 2.081619145002e-04
2977 KSP unpreconditioned resid norm 8.712485802587e+00 true resid norm 8.712485802582e+00 ||r(i)||/||b|| 2.081619144998e-04
2978 KSP unpreconditioned resid norm 8.712485802587e+00 true resid norm 8.712485802590e+00 ||r(i)||/||b|| 2.081619145000e-04
2979 KSP unpreconditioned resid norm 8.712485802585e+00 true resid norm 8.712485802583e+00 ||r(i)||/||b|| 2.081619144998e-04
2980 KSP unpreconditioned resid norm 8.712485802583e+00 true resid norm 8.712485802581e+00 ||r(i)||/||b|| 2.081619144997e-04
2981 KSP unpreconditioned resid norm 8.712485802583e+00 true resid norm 8.712485802575e+00 ||r(i)||/||b|| 2.081619144996e-04
2982 KSP unpreconditioned resid norm 8.712485802583e+00 true resid norm 8.712485802587e+00 ||r(i)||/||b|| 2.081619144999e-04
2983 KSP unpreconditioned resid norm 8.712485802581e+00 true resid norm 8.712485802580e+00 ||r(i)||/||b|| 2.081619144997e-04
2984 KSP unpreconditioned resid norm 8.712485802579e+00 true resid norm 8.712485802574e+00 ||r(i)||/||b|| 2.081619144996e-04
2985 KSP unpreconditioned resid norm 8.712485802575e+00 true resid norm 8.712485802566e+00 ||r(i)||/||b|| 2.081619144994e-04
2986 KSP unpreconditioned resid norm 8.712485802573e+00 true resid norm 8.712485802575e+00 ||r(i)||/||b|| 2.081619144996e-04
2987 KSP unpreconditioned resid norm 8.712485802571e+00 true resid norm 8.712485802579e+00 ||r(i)||/||b|| 2.081619144997e-04
2988 KSP unpreconditioned resid norm 8.712485802568e+00 true resid norm 8.712485802580e+00 ||r(i)||/||b|| 2.081619144997e-04
2989 KSP unpreconditioned resid norm 8.712485802567e+00 true resid norm 8.712485802566e+00 ||r(i)||/||b|| 2.081619144994e-04
2990 KSP unpreconditioned resid norm 8.712485802566e+00 true resid norm 8.712485802576e+00 ||r(i)||/||b|| 2.081619144996e-04
2991 KSP unpreconditioned resid norm 8.712485802566e+00 true resid norm 8.712485802564e+00 ||r(i)||/||b|| 2.081619144993e-04
2992 KSP unpreconditioned resid norm 8.712485802564e+00 true resid norm 8.712485802560e+00 ||r(i)||/||b|| 2.081619144992e-04
2993 KSP unpreconditioned resid norm 8.712485802552e+00 true resid norm 8.712485802554e+00 ||r(i)||/||b|| 2.081619144991e-04
2994 KSP unpreconditioned resid norm 8.712485802536e+00 true resid norm 8.712485802543e+00 ||r(i)||/||b|| 2.081619144988e-04
2995 KSP unpreconditioned resid norm 8.712485802524e+00 true resid norm 8.712485802515e+00 ||r(i)||/||b|| 2.081619144982e-04
2996 KSP unpreconditioned resid norm 8.712485802509e+00 true resid norm 8.712485802505e+00 ||r(i)||/||b|| 2.081619144979e-04
2997 KSP unpreconditioned resid norm 8.712485802485e+00 true resid norm 8.712485802484e+00 ||r(i)||/||b|| 2.081619144974e-04
2998 KSP unpreconditioned resid norm 8.712485802428e+00 true resid norm 8.712485802425e+00 ||r(i)||/||b|| 2.081619144960e-04
2999 KSP unpreconditioned resid norm 8.712485802397e+00 true resid norm 8.712485802387e+00 ||r(i)||/||b|| 2.081619144951e-04
3000 KSP unpreconditioned resid norm 8.712485802396e+00 true resid norm 8.712485802396e+00 ||r(i)||/||b|| 2.081619144953e-04
3001 KSP unpreconditioned resid norm 8.712485802396e+00 true resid norm 8.712485802405e+00 ||r(i)||/||b|| 2.081619144955e-04
3002 KSP unpreconditioned resid norm 8.712485802396e+00 true resid norm 8.712485802387e+00 ||r(i)||/||b|| 2.081619144951e-04
3003 KSP unpreconditioned resid norm 8.712485802396e+00 true resid norm 8.712485802399e+00 ||r(i)||/||b|| 2.081619144954e-04
3004 KSP unpreconditioned resid norm 8.712485802394e+00 true resid norm 8.712485802395e+00 ||r(i)||/||b|| 2.081619144953e-04
3005 KSP unpreconditioned resid norm 8.712485802393e+00 true resid norm 8.712485802390e+00 ||r(i)||/||b|| 2.081619144952e-04
3006 KSP unpreconditioned resid norm 8.712485802392e+00 true resid norm 8.712485802397e+00 ||r(i)||/||b|| 2.081619144953e-04
3007 KSP unpreconditioned resid norm 8.712485802392e+00 true resid norm 8.712485802392e+00 ||r(i)||/||b|| 2.081619144952e-04
3008 KSP unpreconditioned resid norm 8.712485802391e+00 true resid norm 8.712485802388e+00 ||r(i)||/||b|| 2.081619144951e-04
3009 KSP unpreconditioned resid norm 8.712485802390e+00 true resid norm 8.712485802390e+00 ||r(i)||/||b|| 2.081619144952e-04
3010 KSP unpreconditioned resid norm 8.712485802388e+00 true resid norm 8.712485802379e+00 ||r(i)||/||b|| 2.081619144949e-04
3011 KSP unpreconditioned resid norm 8.712485802388e+00 true resid norm 8.712485802383e+00 ||r(i)||/||b|| 2.081619144950e-04
3012 KSP unpreconditioned resid norm 8.712485802388e+00 true resid norm 8.712485802398e+00 ||r(i)||/||b|| 2.081619144954e-04
3013 KSP unpreconditioned resid norm 8.712485802386e+00 true resid norm 8.712485802388e+00 ||r(i)||/||b|| 2.081619144951e-04
3014 KSP unpreconditioned resid norm 8.712485802384e+00 true resid norm 8.712485802382e+00 ||r(i)||/||b|| 2.081619144950e-04
3015 KSP unpreconditioned resid norm 8.712485802381e+00 true resid norm 8.712485802373e+00 ||r(i)||/||b|| 2.081619144948e-04
3016 KSP unpreconditioned resid norm 8.712485802379e+00 true resid norm 8.712485802376e+00 ||r(i)||/||b|| 2.081619144948e-04
3017 KSP unpreconditioned resid norm 8.712485802377e+00 true resid norm 8.712485802369e+00 ||r(i)||/||b|| 2.081619144947e-04
3018 KSP unpreconditioned resid norm 8.712485802375e+00 true resid norm 8.712485802376e+00 ||r(i)||/||b|| 2.081619144948e-04
3019 KSP unpreconditioned resid norm 8.712485802373e+00 true resid norm 8.712485802383e+00 ||r(i)||/||b|| 2.081619144950e-04
3020 KSP unpreconditioned resid norm 8.712485802373e+00 true resid norm 8.712485802368e+00 ||r(i)||/||b|| 2.081619144946e-04
3021 KSP unpreconditioned resid norm 8.712485802373e+00 true resid norm 8.712485802366e+00 ||r(i)||/||b|| 2.081619144946e-04
3022 KSP unpreconditioned resid norm 8.712485802371e+00 true resid norm 8.712485802373e+00 ||r(i)||/||b|| 2.081619144948e-04
3023 KSP unpreconditioned resid norm 8.712485802361e+00 true resid norm 8.712485802360e+00 ||r(i)||/||b|| 2.081619144945e-04
3024 KSP unpreconditioned resid norm 8.712485802347e+00 true resid norm 8.712485802338e+00 ||r(i)||/||b|| 2.081619144939e-04
3025 KSP unpreconditioned resid norm 8.712485802336e+00 true resid norm 8.712485802337e+00 ||r(i)||/||b|| 2.081619144939e-04
3026 KSP unpreconditioned resid norm 8.712485802322e+00 true resid norm 8.712485802316e+00 ||r(i)||/||b|| 2.081619144934e-04
3027 KSP unpreconditioned resid norm 8.712485802301e+00 true resid norm 8.712485802298e+00 ||r(i)||/||b|| 2.081619144930e-04
3028 KSP unpreconditioned resid norm 8.712485802250e+00 true resid norm 8.712485802248e+00 ||r(i)||/||b|| 2.081619144918e-04
3029 KSP unpreconditioned resid norm 8.712485802223e+00 true resid norm 8.712485802217e+00 ||r(i)||/||b|| 2.081619144910e-04
3030 KSP unpreconditioned resid norm 8.712485802225e+00 true resid norm 8.712485802225e+00 ||r(i)||/||b|| 2.081619144912e-04
3031 KSP unpreconditioned resid norm 8.712485802225e+00 true resid norm 8.712485802210e+00 ||r(i)||/||b|| 2.081619144909e-04
3032 KSP unpreconditioned resid norm 8.712485802225e+00 true resid norm 8.712485802214e+00 ||r(i)||/||b|| 2.081619144910e-04
3033 KSP unpreconditioned resid norm 8.712485802224e+00 true resid norm 8.712485802222e+00 ||r(i)||/||b|| 2.081619144911e-04
3034 KSP unpreconditioned resid norm 8.712485802223e+00 true resid norm 8.712485802210e+00 ||r(i)||/||b|| 2.081619144909e-04
3035 KSP unpreconditioned resid norm 8.712485802222e+00 true resid norm 8.712485802213e+00 ||r(i)||/||b|| 2.081619144910e-04
3036 KSP unpreconditioned resid norm 8.712485802221e+00 true resid norm 8.712485802210e+00 ||r(i)||/||b|| 2.081619144909e-04
3037 KSP unpreconditioned resid norm 8.712485802221e+00 true resid norm 8.712485802208e+00 ||r(i)||/||b|| 2.081619144908e-04
3038 KSP unpreconditioned resid norm 8.712485802220e+00 true resid norm 8.712485802218e+00 ||r(i)||/||b|| 2.081619144911e-04
3039 KSP unpreconditioned resid norm 8.712485802219e+00 true resid norm 8.712485802206e+00 ||r(i)||/||b|| 2.081619144908e-04
3040 KSP unpreconditioned resid norm 8.712485802218e+00 true resid norm 8.712485802209e+00 ||r(i)||/||b|| 2.081619144909e-04
3041 KSP unpreconditioned resid norm 8.712485802218e+00 true resid norm 8.712485802206e+00 ||r(i)||/||b|| 2.081619144908e-04
3042 KSP unpreconditioned resid norm 8.712485802218e+00 true resid norm 8.712485802207e+00 ||r(i)||/||b|| 2.081619144908e-04
3043 KSP unpreconditioned resid norm 8.712485802216e+00 true resid norm 8.712485802209e+00 ||r(i)||/||b|| 2.081619144909e-04
3044 KSP unpreconditioned resid norm 8.712485802214e+00 true resid norm 8.712485802214e+00 ||r(i)||/||b|| 2.081619144910e-04
3045 KSP unpreconditioned resid norm 8.712485802211e+00 true resid norm 8.712485802199e+00 ||r(i)||/||b|| 2.081619144906e-04
3046 KSP unpreconditioned resid norm 8.712485802209e+00 true resid norm 8.712485802205e+00 ||r(i)||/||b|| 2.081619144908e-04
3047 KSP unpreconditioned resid norm 8.712485802208e+00 true resid norm 8.712485802203e+00 ||r(i)||/||b|| 2.081619144907e-04
3048 KSP unpreconditioned resid norm 8.712485802206e+00 true resid norm 8.712485802187e+00 ||r(i)||/||b|| 2.081619144903e-04
3049 KSP unpreconditioned resid norm 8.712485802205e+00 true resid norm 8.712485802200e+00 ||r(i)||/||b|| 2.081619144906e-04
3050 KSP unpreconditioned resid norm 8.712485802205e+00 true resid norm 8.712485802194e+00 ||r(i)||/||b|| 2.081619144905e-04
3051 KSP unpreconditioned resid norm 8.712485802204e+00 true resid norm 8.712485802190e+00 ||r(i)||/||b|| 2.081619144904e-04
3052 KSP unpreconditioned resid norm 8.712485802203e+00 true resid norm 8.712485802198e+00 ||r(i)||/||b|| 2.081619144906e-04
3053 KSP unpreconditioned resid norm 8.712485802193e+00 true resid norm 8.712485802191e+00 ||r(i)||/||b|| 2.081619144904e-04
3054 KSP unpreconditioned resid norm 8.712485802181e+00 true resid norm 8.712485802177e+00 ||r(i)||/||b|| 2.081619144901e-04
3055 KSP unpreconditioned resid norm 8.712485802171e+00 true resid norm 8.712485802159e+00 ||r(i)||/||b|| 2.081619144897e-04
3056 KSP unpreconditioned resid norm 8.712485802160e+00 true resid norm 8.712485802136e+00 ||r(i)||/||b|| 2.081619144891e-04
3057 KSP unpreconditioned resid norm 8.712485802141e+00 true resid norm 8.712485802129e+00 ||r(i)||/||b|| 2.081619144889e-04
3058 KSP unpreconditioned resid norm 8.712485802096e+00 true resid norm 8.712485802093e+00 ||r(i)||/||b|| 2.081619144881e-04
3059 KSP unpreconditioned resid norm 8.712485802072e+00 true resid norm 8.712485802065e+00 ||r(i)||/||b|| 2.081619144874e-04
3060 KSP unpreconditioned resid norm 8.712485802051e+00 true resid norm 8.712485802051e+00 ||r(i)||/||b|| 2.081619144871e-04
3061 KSP unpreconditioned resid norm 8.712485802051e+00 true resid norm 8.712485802059e+00 ||r(i)||/||b|| 2.081619144873e-04
3062 KSP unpreconditioned resid norm 8.712485802050e+00 true resid norm 8.712485802071e+00 ||r(i)||/||b|| 2.081619144875e-04
3063 KSP unpreconditioned resid norm 8.712485802050e+00 true resid norm 8.712485802064e+00 ||r(i)||/||b|| 2.081619144874e-04
3064 KSP unpreconditioned resid norm 8.712485802049e+00 true resid norm 8.712485802055e+00 ||r(i)||/||b|| 2.081619144872e-04
3065 KSP unpreconditioned resid norm 8.712485802048e+00 true resid norm 8.712485802061e+00 ||r(i)||/||b|| 2.081619144873e-04
3066 KSP unpreconditioned resid norm 8.712485802047e+00 true resid norm 8.712485802052e+00 ||r(i)||/||b|| 2.081619144871e-04
3067 KSP unpreconditioned resid norm 8.712485802047e+00 true resid norm 8.712485802061e+00 ||r(i)||/||b|| 2.081619144873e-04
3068 KSP unpreconditioned resid norm 8.712485802046e+00 true resid norm 8.712485802048e+00 ||r(i)||/||b|| 2.081619144870e-04
3069 KSP unpreconditioned resid norm 8.712485802045e+00 true resid norm 8.712485802059e+00 ||r(i)||/||b|| 2.081619144873e-04
3070 KSP unpreconditioned resid norm 8.712485802044e+00 true resid norm 8.712485802051e+00 ||r(i)||/||b|| 2.081619144871e-04
3071 KSP unpreconditioned resid norm 8.712485802044e+00 true resid norm 8.712485802054e+00 ||r(i)||/||b|| 2.081619144871e-04
3072 KSP unpreconditioned resid norm 8.712485802044e+00 true resid norm 8.712485802050e+00 ||r(i)||/||b|| 2.081619144870e-04
3073 KSP unpreconditioned resid norm 8.712485802043e+00 true resid norm 8.712485802060e+00 ||r(i)||/||b|| 2.081619144873e-04
3074 KSP unpreconditioned resid norm 8.712485802041e+00 true resid norm 8.712485802061e+00 ||r(i)||/||b|| 2.081619144873e-04
3075 KSP unpreconditioned resid norm 8.712485802038e+00 true resid norm 8.712485802055e+00 ||r(i)||/||b|| 2.081619144872e-04
3076 KSP unpreconditioned resid norm 8.712485802037e+00 true resid norm 8.712485802035e+00 ||r(i)||/||b|| 2.081619144867e-04
3077 KSP unpreconditioned resid norm 8.712485802035e+00 true resid norm 8.712485802039e+00 ||r(i)||/||b|| 2.081619144868e-04
3078 KSP unpreconditioned resid norm 8.712485802034e+00 true resid norm 8.712485802048e+00 ||r(i)||/||b|| 2.081619144870e-04
3079 KSP unpreconditioned resid norm 8.712485802033e+00 true resid norm 8.712485802044e+00 ||r(i)||/||b|| 2.081619144869e-04
3080 KSP unpreconditioned resid norm 8.712485802032e+00 true resid norm 8.712485802040e+00 ||r(i)||/||b|| 2.081619144868e-04
3081 KSP unpreconditioned resid norm 8.712485802032e+00 true resid norm 8.712485802044e+00 ||r(i)||/||b|| 2.081619144869e-04
3082 KSP unpreconditioned resid norm 8.712485802031e+00 true resid norm 8.712485802042e+00 ||r(i)||/||b|| 2.081619144869e-04
3083 KSP unpreconditioned resid norm 8.712485802023e+00 true resid norm 8.712485802036e+00 ||r(i)||/||b|| 2.081619144867e-04
3084 KSP unpreconditioned resid norm 8.712485802012e+00 true resid norm 8.712485802012e+00 ||r(i)||/||b|| 2.081619144861e-04
3085 KSP unpreconditioned resid norm 8.712485802003e+00 true resid norm 8.712485802007e+00 ||r(i)||/||b|| 2.081619144860e-04
3086 KSP unpreconditioned resid norm 8.712485801993e+00 true resid norm 8.712485801995e+00 ||r(i)||/||b|| 2.081619144857e-04
3087 KSP unpreconditioned resid norm 8.712485801976e+00 true resid norm 8.712485801984e+00 ||r(i)||/||b|| 2.081619144855e-04
3088 KSP unpreconditioned resid norm 8.712485801936e+00 true resid norm 8.712485801943e+00 ||r(i)||/||b|| 2.081619144845e-04
3089 KSP unpreconditioned resid norm 8.712485801915e+00 true resid norm 8.712485801928e+00 ||r(i)||/||b|| 2.081619144841e-04
3090 KSP unpreconditioned resid norm 8.712485801932e+00 true resid norm 8.712485801932e+00 ||r(i)||/||b|| 2.081619144842e-04
3091 KSP unpreconditioned resid norm 8.712485801932e+00 true resid norm 8.712485801931e+00 ||r(i)||/||b|| 2.081619144842e-04
3092 KSP unpreconditioned resid norm 8.712485801932e+00 true resid norm 8.712485801927e+00 ||r(i)||/||b|| 2.081619144841e-04
3093 KSP unpreconditioned resid norm 8.712485801932e+00 true resid norm 8.712485801930e+00 ||r(i)||/||b|| 2.081619144842e-04
3094 KSP unpreconditioned resid norm 8.712485801931e+00 true resid norm 8.712485801920e+00 ||r(i)||/||b|| 2.081619144839e-04
3095 KSP unpreconditioned resid norm 8.712485801930e+00 true resid norm 8.712485801928e+00 ||r(i)||/||b|| 2.081619144841e-04
3096 KSP unpreconditioned resid norm 8.712485801930e+00 true resid norm 8.712485801931e+00 ||r(i)||/||b|| 2.081619144842e-04
3097 KSP unpreconditioned resid norm 8.712485801929e+00 true resid norm 8.712485801919e+00 ||r(i)||/||b|| 2.081619144839e-04
3098 KSP unpreconditioned resid norm 8.712485801929e+00 true resid norm 8.712485801923e+00 ||r(i)||/||b|| 2.081619144840e-04
3099 KSP unpreconditioned resid norm 8.712485801928e+00 true resid norm 8.712485801928e+00 ||r(i)||/||b|| 2.081619144841e-04
3100 KSP unpreconditioned resid norm 8.712485801927e+00 true resid norm 8.712485801922e+00 ||r(i)||/||b|| 2.081619144840e-04
3101 KSP unpreconditioned resid norm 8.712485801927e+00 true resid norm 8.712485801923e+00 ||r(i)||/||b|| 2.081619144840e-04
3102 KSP unpreconditioned resid norm 8.712485801927e+00 true resid norm 8.712485801925e+00 ||r(i)||/||b|| 2.081619144841e-04
3103 KSP unpreconditioned resid norm 8.712485801926e+00 true resid norm 8.712485801923e+00 ||r(i)||/||b|| 2.081619144840e-04
3104 KSP unpreconditioned resid norm 8.712485801924e+00 true resid norm 8.712485801918e+00 ||r(i)||/||b|| 2.081619144839e-04
3105 KSP unpreconditioned resid norm 8.712485801922e+00 true resid norm 8.712485801922e+00 ||r(i)||/||b|| 2.081619144840e-04
3106 KSP unpreconditioned resid norm 8.712485801920e+00 true resid norm 8.712485801925e+00 ||r(i)||/||b|| 2.081619144841e-04
3107 KSP unpreconditioned resid norm 8.712485801919e+00 true resid norm 8.712485801923e+00 ||r(i)||/||b|| 2.081619144840e-04
3108 KSP unpreconditioned resid norm 8.712485801918e+00 true resid norm 8.712485801914e+00 ||r(i)||/||b|| 2.081619144838e-04
3109 KSP unpreconditioned resid norm 8.712485801917e+00 true resid norm 8.712485801905e+00 ||r(i)||/||b|| 2.081619144836e-04
3110 KSP unpreconditioned resid norm 8.712485801917e+00 true resid norm 8.712485801906e+00 ||r(i)||/||b|| 2.081619144836e-04
3111 KSP unpreconditioned resid norm 8.712485801916e+00 true resid norm 8.712485801917e+00 ||r(i)||/||b|| 2.081619144839e-04
3112 KSP unpreconditioned resid norm 8.712485801915e+00 true resid norm 8.712485801916e+00 ||r(i)||/||b|| 2.081619144838e-04
3113 KSP unpreconditioned resid norm 8.712485801908e+00 true resid norm 8.712485801905e+00 ||r(i)||/||b|| 2.081619144836e-04
3114 KSP unpreconditioned resid norm 8.712485801898e+00 true resid norm 8.712485801890e+00 ||r(i)||/||b|| 2.081619144832e-04
3115 KSP unpreconditioned resid norm 8.712485801891e+00 true resid norm 8.712485801888e+00 ||r(i)||/||b|| 2.081619144832e-04
3116 KSP unpreconditioned resid norm 8.712485801881e+00 true resid norm 8.712485801877e+00 ||r(i)||/||b|| 2.081619144829e-04
3117 KSP unpreconditioned resid norm 8.712485801867e+00 true resid norm 8.712485801850e+00 ||r(i)||/||b|| 2.081619144823e-04
3118 KSP unpreconditioned resid norm 8.712485801832e+00 true resid norm 8.712485801815e+00 ||r(i)||/||b|| 2.081619144814e-04
3119 KSP unpreconditioned resid norm 8.712485801813e+00 true resid norm 8.712485801807e+00 ||r(i)||/||b|| 2.081619144812e-04
3120 KSP unpreconditioned resid norm 8.712485801813e+00 true resid norm 8.712485801813e+00 ||r(i)||/||b|| 2.081619144814e-04
3121 KSP unpreconditioned resid norm 8.712485801813e+00 true resid norm 8.712485801808e+00 ||r(i)||/||b|| 2.081619144813e-04
3122 KSP unpreconditioned resid norm 8.712485801813e+00 true resid norm 8.712485801820e+00 ||r(i)||/||b|| 2.081619144816e-04
3123 KSP unpreconditioned resid norm 8.712485801813e+00 true resid norm 8.712485801815e+00 ||r(i)||/||b|| 2.081619144814e-04
3124 KSP unpreconditioned resid norm 8.712485801812e+00 true resid norm 8.712485801815e+00 ||r(i)||/||b|| 2.081619144814e-04
3125 KSP unpreconditioned resid norm 8.712485801811e+00 true resid norm 8.712485801813e+00 ||r(i)||/||b|| 2.081619144814e-04
3126 KSP unpreconditioned resid norm 8.712485801811e+00 true resid norm 8.712485801814e+00 ||r(i)||/||b|| 2.081619144814e-04
3127 KSP unpreconditioned resid norm 8.712485801810e+00 true resid norm 8.712485801804e+00 ||r(i)||/||b|| 2.081619144812e-04
3128 KSP unpreconditioned resid norm 8.712485801810e+00 true resid norm 8.712485801805e+00 ||r(i)||/||b|| 2.081619144812e-04
3129 KSP unpreconditioned resid norm 8.712485801809e+00 true resid norm 8.712485801806e+00 ||r(i)||/||b|| 2.081619144812e-04
3130 KSP unpreconditioned resid norm 8.712485801808e+00 true resid norm 8.712485801816e+00 ||r(i)||/||b|| 2.081619144815e-04
3131 KSP unpreconditioned resid norm 8.712485801808e+00 true resid norm 8.712485801798e+00 ||r(i)||/||b|| 2.081619144810e-04
3132 KSP unpreconditioned resid norm 8.712485801808e+00 true resid norm 8.712485801811e+00 ||r(i)||/||b|| 2.081619144813e-04
3133 KSP unpreconditioned resid norm 8.712485801807e+00 true resid norm 8.712485801799e+00 ||r(i)||/||b|| 2.081619144811e-04
3134 KSP unpreconditioned resid norm 8.712485801806e+00 true resid norm 8.712485801809e+00 ||r(i)||/||b|| 2.081619144813e-04
3135 KSP unpreconditioned resid norm 8.712485801804e+00 true resid norm 8.712485801800e+00 ||r(i)||/||b|| 2.081619144811e-04
3136 KSP unpreconditioned resid norm 8.712485801802e+00 true resid norm 8.712485801799e+00 ||r(i)||/||b|| 2.081619144810e-04
3137 KSP unpreconditioned resid norm 8.712485801801e+00 true resid norm 8.712485801793e+00 ||r(i)||/||b|| 2.081619144809e-04
3138 KSP unpreconditioned resid norm 8.712485801800e+00 true resid norm 8.712485801799e+00 ||r(i)||/||b|| 2.081619144811e-04
3139 KSP unpreconditioned resid norm 8.712485801799e+00 true resid norm 8.712485801791e+00 ||r(i)||/||b|| 2.081619144809e-04
3140 KSP unpreconditioned resid norm 8.712485801799e+00 true resid norm 8.712485801795e+00 ||r(i)||/||b|| 2.081619144809e-04
3141 KSP unpreconditioned resid norm 8.712485801799e+00 true resid norm 8.712485801809e+00 ||r(i)||/||b|| 2.081619144813e-04
3142 KSP unpreconditioned resid norm 8.712485801798e+00 true resid norm 8.712485801782e+00 ||r(i)||/||b|| 2.081619144806e-04
3143 KSP unpreconditioned resid norm 8.712485801791e+00 true resid norm 8.712485801785e+00 ||r(i)||/||b|| 2.081619144807e-04
3144 KSP unpreconditioned resid norm 8.712485801783e+00 true resid norm 8.712485801781e+00 ||r(i)||/||b|| 2.081619144806e-04
3145 KSP unpreconditioned resid norm 8.712485801776e+00 true resid norm 8.712485801774e+00 ||r(i)||/||b|| 2.081619144805e-04
3146 KSP unpreconditioned resid norm 8.712485801768e+00 true resid norm 8.712485801771e+00 ||r(i)||/||b|| 2.081619144804e-04
3147 KSP unpreconditioned resid norm 8.712485801755e+00 true resid norm 8.712485801761e+00 ||r(i)||/||b|| 2.081619144801e-04
3148 KSP unpreconditioned resid norm 8.712485801724e+00 true resid norm 8.712485801719e+00 ||r(i)||/||b|| 2.081619144791e-04
3149 KSP unpreconditioned resid norm 8.712485801707e+00 true resid norm 8.712485801710e+00 ||r(i)||/||b|| 2.081619144789e-04
3150 KSP unpreconditioned resid norm 8.712485801708e+00 true resid norm 8.712485801708e+00 ||r(i)||/||b|| 2.081619144789e-04
3151 KSP unpreconditioned resid norm 8.712485801708e+00 true resid norm 8.712485801701e+00 ||r(i)||/||b|| 2.081619144787e-04
3152 KSP unpreconditioned resid norm 8.712485801708e+00 true resid norm 8.712485801710e+00 ||r(i)||/||b|| 2.081619144789e-04
3153 KSP unpreconditioned resid norm 8.712485801708e+00 true resid norm 8.712485801717e+00 ||r(i)||/||b|| 2.081619144791e-04
3154 KSP unpreconditioned resid norm 8.712485801707e+00 true resid norm 8.712485801700e+00 ||r(i)||/||b|| 2.081619144787e-04
3155 KSP unpreconditioned resid norm 8.712485801706e+00 true resid norm 8.712485801702e+00 ||r(i)||/||b|| 2.081619144787e-04
3156 KSP unpreconditioned resid norm 8.712485801706e+00 true resid norm 8.712485801698e+00 ||r(i)||/||b|| 2.081619144786e-04
3157 KSP unpreconditioned resid norm 8.712485801706e+00 true resid norm 8.712485801710e+00 ||r(i)||/||b|| 2.081619144789e-04
3158 KSP unpreconditioned resid norm 8.712485801705e+00 true resid norm 8.712485801696e+00 ||r(i)||/||b|| 2.081619144786e-04
3159 KSP unpreconditioned resid norm 8.712485801704e+00 true resid norm 8.712485801701e+00 ||r(i)||/||b|| 2.081619144787e-04
3160 KSP unpreconditioned resid norm 8.712485801704e+00 true resid norm 8.712485801705e+00 ||r(i)||/||b|| 2.081619144788e-04
3161 KSP unpreconditioned resid norm 8.712485801704e+00 true resid norm 8.712485801691e+00 ||r(i)||/||b|| 2.081619144785e-04
3162 KSP unpreconditioned resid norm 8.712485801704e+00 true resid norm 8.712485801697e+00 ||r(i)||/||b|| 2.081619144786e-04
3163 KSP unpreconditioned resid norm 8.712485801703e+00 true resid norm 8.712485801697e+00 ||r(i)||/||b|| 2.081619144786e-04
3164 KSP unpreconditioned resid norm 8.712485801701e+00 true resid norm 8.712485801693e+00 ||r(i)||/||b|| 2.081619144785e-04
3165 KSP unpreconditioned resid norm 8.712485801700e+00 true resid norm 8.712485801694e+00 ||r(i)||/||b|| 2.081619144785e-04
3166 KSP unpreconditioned resid norm 8.712485801699e+00 true resid norm 8.712485801692e+00 ||r(i)||/||b|| 2.081619144785e-04
3167 KSP unpreconditioned resid norm 8.712485801698e+00 true resid norm 8.712485801691e+00 ||r(i)||/||b|| 2.081619144785e-04
3168 KSP unpreconditioned resid norm 8.712485801697e+00 true resid norm 8.712485801694e+00 ||r(i)||/||b|| 2.081619144786e-04
3169 KSP unpreconditioned resid norm 8.712485801696e+00 true resid norm 8.712485801687e+00 ||r(i)||/||b|| 2.081619144784e-04
3170 KSP unpreconditioned resid norm 8.712485801696e+00 true resid norm 8.712485801691e+00 ||r(i)||/||b|| 2.081619144785e-04
3171 KSP unpreconditioned resid norm 8.712485801695e+00 true resid norm 8.712485801697e+00 ||r(i)||/||b|| 2.081619144786e-04
3172 KSP unpreconditioned resid norm 8.712485801694e+00 true resid norm 8.712485801695e+00 ||r(i)||/||b|| 2.081619144786e-04
3173 KSP unpreconditioned resid norm 8.712485801689e+00 true resid norm 8.712485801696e+00 ||r(i)||/||b|| 2.081619144786e-04
3174 KSP unpreconditioned resid norm 8.712485801681e+00 true resid norm 8.712485801669e+00 ||r(i)||/||b|| 2.081619144780e-04
3175 KSP unpreconditioned resid norm 8.712485801675e+00 true resid norm 8.712485801669e+00 ||r(i)||/||b|| 2.081619144779e-04
3176 KSP unpreconditioned resid norm 8.712485801668e+00 true resid norm 8.712485801667e+00 ||r(i)||/||b|| 2.081619144779e-04
3177 KSP unpreconditioned resid norm 8.712485801657e+00 true resid norm 8.712485801650e+00 ||r(i)||/||b|| 2.081619144775e-04
3178 KSP unpreconditioned resid norm 8.712485801629e+00 true resid norm 8.712485801631e+00 ||r(i)||/||b|| 2.081619144770e-04
3179 KSP unpreconditioned resid norm 8.712485801614e+00 true resid norm 8.712485801611e+00 ||r(i)||/||b|| 2.081619144765e-04
3180 KSP unpreconditioned resid norm 8.712485801608e+00 true resid norm 8.712485801608e+00 ||r(i)||/||b|| 2.081619144765e-04
3181 KSP unpreconditioned resid norm 8.712485801608e+00 true resid norm 8.712485801615e+00 ||r(i)||/||b|| 2.081619144767e-04
3182 KSP unpreconditioned resid norm 8.712485801608e+00 true resid norm 8.712485801614e+00 ||r(i)||/||b|| 2.081619144766e-04
3183 KSP unpreconditioned resid norm 8.712485801608e+00 true resid norm 8.712485801618e+00 ||r(i)||/||b|| 2.081619144767e-04
3184 KSP unpreconditioned resid norm 8.712485801607e+00 true resid norm 8.712485801611e+00 ||r(i)||/||b|| 2.081619144766e-04
3185 KSP unpreconditioned resid norm 8.712485801606e+00 true resid norm 8.712485801612e+00 ||r(i)||/||b|| 2.081619144766e-04
3186 KSP unpreconditioned resid norm 8.712485801606e+00 true resid norm 8.712485801619e+00 ||r(i)||/||b|| 2.081619144768e-04
3187 KSP unpreconditioned resid norm 8.712485801606e+00 true resid norm 8.712485801610e+00 ||r(i)||/||b|| 2.081619144765e-04
3188 KSP unpreconditioned resid norm 8.712485801606e+00 true resid norm 8.712485801616e+00 ||r(i)||/||b|| 2.081619144767e-04
3189 KSP unpreconditioned resid norm 8.712485801605e+00 true resid norm 8.712485801609e+00 ||r(i)||/||b|| 2.081619144765e-04
3190 KSP unpreconditioned resid norm 8.712485801604e+00 true resid norm 8.712485801606e+00 ||r(i)||/||b|| 2.081619144764e-04
3191 KSP unpreconditioned resid norm 8.712485801604e+00 true resid norm 8.712485801610e+00 ||r(i)||/||b|| 2.081619144765e-04
3192 KSP unpreconditioned resid norm 8.712485801604e+00 true resid norm 8.712485801625e+00 ||r(i)||/||b|| 2.081619144769e-04
3193 KSP unpreconditioned resid norm 8.712485801604e+00 true resid norm 8.712485801604e+00 ||r(i)||/||b|| 2.081619144764e-04
3194 KSP unpreconditioned resid norm 8.712485801602e+00 true resid norm 8.712485801604e+00 ||r(i)||/||b|| 2.081619144764e-04
3195 KSP unpreconditioned resid norm 8.712485801601e+00 true resid norm 8.712485801608e+00 ||r(i)||/||b|| 2.081619144765e-04
3196 KSP unpreconditioned resid norm 8.712485801600e+00 true resid norm 8.712485801603e+00 ||r(i)||/||b|| 2.081619144764e-04
3197 KSP unpreconditioned resid norm 8.712485801599e+00 true resid norm 8.712485801613e+00 ||r(i)||/||b|| 2.081619144766e-04
3198 KSP unpreconditioned resid norm 8.712485801598e+00 true resid norm 8.712485801615e+00 ||r(i)||/||b|| 2.081619144767e-04
3199 KSP unpreconditioned resid norm 8.712485801597e+00 true resid norm 8.712485801598e+00 ||r(i)||/||b|| 2.081619144762e-04
3200 KSP unpreconditioned resid norm 8.712485801597e+00 true resid norm 8.712485801616e+00 ||r(i)||/||b|| 2.081619144767e-04
3201 KSP unpreconditioned resid norm 8.712485801597e+00 true resid norm 8.712485801609e+00 ||r(i)||/||b|| 2.081619144765e-04
3202 KSP unpreconditioned resid norm 8.712485801596e+00 true resid norm 8.712485801608e+00 ||r(i)||/||b|| 2.081619144765e-04
3203 KSP unpreconditioned resid norm 8.712485801591e+00 true resid norm 8.712485801598e+00 ||r(i)||/||b|| 2.081619144762e-04
3204 KSP unpreconditioned resid norm 8.712485801584e+00 true resid norm 8.712485801593e+00 ||r(i)||/||b|| 2.081619144761e-04
3205 KSP unpreconditioned resid norm 8.712485801579e+00 true resid norm 8.712485801586e+00 ||r(i)||/||b|| 2.081619144760e-04
3206 KSP unpreconditioned resid norm 8.712485801573e+00 true resid norm 8.712485801582e+00 ||r(i)||/||b|| 2.081619144759e-04
3207 KSP unpreconditioned resid norm 8.712485801563e+00 true resid norm 8.712485801568e+00 ||r(i)||/||b|| 2.081619144755e-04
3208 KSP unpreconditioned resid norm 8.712485801538e+00 true resid norm 8.712485801553e+00 ||r(i)||/||b|| 2.081619144752e-04
3209 KSP unpreconditioned resid norm 8.712485801525e+00 true resid norm 8.712485801542e+00 ||r(i)||/||b|| 2.081619144749e-04
3210 KSP unpreconditioned resid norm 8.712485801533e+00 true resid norm 8.712485801533e+00 ||r(i)||/||b|| 2.081619144747e-04
3211 KSP unpreconditioned resid norm 8.712485801533e+00 true resid norm 8.712485801522e+00 ||r(i)||/||b|| 2.081619144744e-04
3212 KSP unpreconditioned resid norm 8.712485801533e+00 true resid norm 8.712485801531e+00 ||r(i)||/||b|| 2.081619144746e-04
3213 KSP unpreconditioned resid norm 8.712485801533e+00 true resid norm 8.712485801529e+00 ||r(i)||/||b|| 2.081619144746e-04
3214 KSP unpreconditioned resid norm 8.712485801532e+00 true resid norm 8.712485801532e+00 ||r(i)||/||b|| 2.081619144747e-04
3215 KSP unpreconditioned resid norm 8.712485801532e+00 true resid norm 8.712485801535e+00 ||r(i)||/||b|| 2.081619144747e-04
3216 KSP unpreconditioned resid norm 8.712485801532e+00 true resid norm 8.712485801527e+00 ||r(i)||/||b|| 2.081619144745e-04
3217 KSP unpreconditioned resid norm 8.712485801531e+00 true resid norm 8.712485801530e+00 ||r(i)||/||b|| 2.081619144746e-04
3218 KSP unpreconditioned resid norm 8.712485801531e+00 true resid norm 8.712485801526e+00 ||r(i)||/||b|| 2.081619144745e-04
3219 KSP unpreconditioned resid norm 8.712485801530e+00 true resid norm 8.712485801518e+00 ||r(i)||/||b|| 2.081619144743e-04
3220 KSP unpreconditioned resid norm 8.712485801530e+00 true resid norm 8.712485801527e+00 ||r(i)||/||b|| 2.081619144745e-04
3221 KSP unpreconditioned resid norm 8.712485801530e+00 true resid norm 8.712485801526e+00 ||r(i)||/||b|| 2.081619144745e-04
3222 KSP unpreconditioned resid norm 8.712485801530e+00 true resid norm 8.712485801525e+00 ||r(i)||/||b|| 2.081619144745e-04
3223 KSP unpreconditioned resid norm 8.712485801529e+00 true resid norm 8.712485801529e+00 ||r(i)||/||b|| 2.081619144746e-04
3224 KSP unpreconditioned resid norm 8.712485801528e+00 true resid norm 8.712485801526e+00 ||r(i)||/||b|| 2.081619144745e-04
3225 KSP unpreconditioned resid norm 8.712485801527e+00 true resid norm 8.712485801518e+00 ||r(i)||/||b|| 2.081619144743e-04
3226 KSP unpreconditioned resid norm 8.712485801526e+00 true resid norm 8.712485801531e+00 ||r(i)||/||b|| 2.081619144746e-04
3227 KSP unpreconditioned resid norm 8.712485801525e+00 true resid norm 8.712485801523e+00 ||r(i)||/||b|| 2.081619144745e-04
3228 KSP unpreconditioned resid norm 8.712485801524e+00 true resid norm 8.712485801527e+00 ||r(i)||/||b|| 2.081619144746e-04
3229 KSP unpreconditioned resid norm 8.712485801524e+00 true resid norm 8.712485801520e+00 ||r(i)||/||b|| 2.081619144744e-04
3230 KSP unpreconditioned resid norm 8.712485801524e+00 true resid norm 8.712485801526e+00 ||r(i)||/||b|| 2.081619144745e-04
3231 KSP unpreconditioned resid norm 8.712485801523e+00 true resid norm 8.712485801523e+00 ||r(i)||/||b|| 2.081619144744e-04
3232 KSP unpreconditioned resid norm 8.712485801523e+00 true resid norm 8.712485801522e+00 ||r(i)||/||b|| 2.081619144744e-04
3233 KSP unpreconditioned resid norm 8.712485801518e+00 true resid norm 8.712485801515e+00 ||r(i)||/||b|| 2.081619144743e-04
3234 KSP unpreconditioned resid norm 8.712485801512e+00 true resid norm 8.712485801513e+00 ||r(i)||/||b|| 2.081619144742e-04
3235 KSP unpreconditioned resid norm 8.712485801508e+00 true resid norm 8.712485801507e+00 ||r(i)||/||b|| 2.081619144741e-04
3236 KSP unpreconditioned resid norm 8.712485801502e+00 true resid norm 8.712485801493e+00 ||r(i)||/||b|| 2.081619144737e-04
3237 KSP unpreconditioned resid norm 8.712485801493e+00 true resid norm 8.712485801490e+00 ||r(i)||/||b|| 2.081619144737e-04
3238 KSP unpreconditioned resid norm 8.712485801472e+00 true resid norm 8.712485801465e+00 ||r(i)||/||b|| 2.081619144731e-04
3239 KSP unpreconditioned resid norm 8.712485801460e+00 true resid norm 8.712485801458e+00 ||r(i)||/||b|| 2.081619144729e-04
3240 KSP unpreconditioned resid norm 8.712485801454e+00 true resid norm 8.712485801454e+00 ||r(i)||/||b|| 2.081619144728e-04
3241 KSP unpreconditioned resid norm 8.712485801454e+00 true resid norm 8.712485801460e+00 ||r(i)||/||b|| 2.081619144729e-04
3242 KSP unpreconditioned resid norm 8.712485801454e+00 true resid norm 8.712485801464e+00 ||r(i)||/||b|| 2.081619144731e-04
3243 KSP unpreconditioned resid norm 8.712485801453e+00 true resid norm 8.712485801459e+00 ||r(i)||/||b|| 2.081619144729e-04
3244 KSP unpreconditioned resid norm 8.712485801453e+00 true resid norm 8.712485801467e+00 ||r(i)||/||b|| 2.081619144731e-04
3245 KSP unpreconditioned resid norm 8.712485801452e+00 true resid norm 8.712485801452e+00 ||r(i)||/||b|| 2.081619144728e-04
3246 KSP unpreconditioned resid norm 8.712485801452e+00 true resid norm 8.712485801467e+00 ||r(i)||/||b|| 2.081619144731e-04
3247 KSP unpreconditioned resid norm 8.712485801452e+00 true resid norm 8.712485801456e+00 ||r(i)||/||b|| 2.081619144728e-04
3248 KSP unpreconditioned resid norm 8.712485801452e+00 true resid norm 8.712485801456e+00 ||r(i)||/||b|| 2.081619144729e-04
3249 KSP unpreconditioned resid norm 8.712485801451e+00 true resid norm 8.712485801453e+00 ||r(i)||/||b|| 2.081619144728e-04
3250 KSP unpreconditioned resid norm 8.712485801451e+00 true resid norm 8.712485801455e+00 ||r(i)||/||b|| 2.081619144728e-04
3251 KSP unpreconditioned resid norm 8.712485801451e+00 true resid norm 8.712485801448e+00 ||r(i)||/||b|| 2.081619144727e-04
3252 KSP unpreconditioned resid norm 8.712485801451e+00 true resid norm 8.712485801459e+00 ||r(i)||/||b|| 2.081619144729e-04
3253 KSP unpreconditioned resid norm 8.712485801450e+00 true resid norm 8.712485801455e+00 ||r(i)||/||b|| 2.081619144728e-04
3254 KSP unpreconditioned resid norm 8.712485801449e+00 true resid norm 8.712485801453e+00 ||r(i)||/||b|| 2.081619144728e-04
3255 KSP unpreconditioned resid norm 8.712485801448e+00 true resid norm 8.712485801456e+00 ||r(i)||/||b|| 2.081619144729e-04
3256 KSP unpreconditioned resid norm 8.712485801447e+00 true resid norm 8.712485801453e+00 ||r(i)||/||b|| 2.081619144728e-04
3257 KSP unpreconditioned resid norm 8.712485801446e+00 true resid norm 8.712485801448e+00 ||r(i)||/||b|| 2.081619144727e-04
3258 KSP unpreconditioned resid norm 8.712485801446e+00 true resid norm 8.712485801448e+00 ||r(i)||/||b|| 2.081619144727e-04
3259 KSP unpreconditioned resid norm 8.712485801445e+00 true resid norm 8.712485801446e+00 ||r(i)||/||b|| 2.081619144726e-04
3260 KSP unpreconditioned resid norm 8.712485801445e+00 true resid norm 8.712485801457e+00 ||r(i)||/||b|| 2.081619144729e-04
3261 KSP unpreconditioned resid norm 8.712485801445e+00 true resid norm 8.712485801460e+00 ||r(i)||/||b|| 2.081619144730e-04
3262 KSP unpreconditioned resid norm 8.712485801444e+00 true resid norm 8.712485801444e+00 ||r(i)||/||b|| 2.081619144726e-04
3263 KSP unpreconditioned resid norm 8.712485801440e+00 true resid norm 8.712485801442e+00 ||r(i)||/||b|| 2.081619144725e-04
3264 KSP unpreconditioned resid norm 8.712485801435e+00 true resid norm 8.712485801440e+00 ||r(i)||/||b|| 2.081619144725e-04
3265 KSP unpreconditioned resid norm 8.712485801431e+00 true resid norm 8.712485801429e+00 ||r(i)||/||b|| 2.081619144722e-04
3266 KSP unpreconditioned resid norm 8.712485801426e+00 true resid norm 8.712485801429e+00 ||r(i)||/||b|| 2.081619144722e-04
3267 KSP unpreconditioned resid norm 8.712485801418e+00 true resid norm 8.712485801422e+00 ||r(i)||/||b|| 2.081619144721e-04
3268 KSP unpreconditioned resid norm 8.712485801399e+00 true resid norm 8.712485801394e+00 ||r(i)||/||b|| 2.081619144714e-04
3269 KSP unpreconditioned resid norm 8.712485801389e+00 true resid norm 8.712485801395e+00 ||r(i)||/||b|| 2.081619144714e-04
3270 KSP unpreconditioned resid norm 8.712485801391e+00 true resid norm 8.712485801391e+00 ||r(i)||/||b|| 2.081619144713e-04
3271 KSP unpreconditioned resid norm 8.712485801391e+00 true resid norm 8.712485801391e+00 ||r(i)||/||b|| 2.081619144713e-04
3272 KSP unpreconditioned resid norm 8.712485801391e+00 true resid norm 8.712485801397e+00 ||r(i)||/||b|| 2.081619144714e-04
3273 KSP unpreconditioned resid norm 8.712485801390e+00 true resid norm 8.712485801389e+00 ||r(i)||/||b|| 2.081619144713e-04
3274 KSP unpreconditioned resid norm 8.712485801390e+00 true resid norm 8.712485801393e+00 ||r(i)||/||b|| 2.081619144713e-04
3275 KSP unpreconditioned resid norm 8.712485801389e+00 true resid norm 8.712485801392e+00 ||r(i)||/||b|| 2.081619144713e-04
3276 KSP unpreconditioned resid norm 8.712485801389e+00 true resid norm 8.712485801389e+00 ||r(i)||/||b|| 2.081619144713e-04
3277 KSP unpreconditioned resid norm 8.712485801389e+00 true resid norm 8.712485801389e+00 ||r(i)||/||b|| 2.081619144713e-04
3278 KSP unpreconditioned resid norm 8.712485801389e+00 true resid norm 8.712485801392e+00 ||r(i)||/||b|| 2.081619144713e-04
3279 KSP unpreconditioned resid norm 8.712485801388e+00 true resid norm 8.712485801389e+00 ||r(i)||/||b|| 2.081619144713e-04
3280 KSP unpreconditioned resid norm 8.712485801388e+00 true resid norm 8.712485801389e+00 ||r(i)||/||b|| 2.081619144713e-04
3281 KSP unpreconditioned resid norm 8.712485801388e+00 true resid norm 8.712485801392e+00 ||r(i)||/||b|| 2.081619144713e-04
3282 KSP unpreconditioned resid norm 8.712485801388e+00 true resid norm 8.712485801395e+00 ||r(i)||/||b|| 2.081619144714e-04
3283 KSP unpreconditioned resid norm 8.712485801387e+00 true resid norm 8.712485801390e+00 ||r(i)||/||b|| 2.081619144713e-04
3284 KSP unpreconditioned resid norm 8.712485801387e+00 true resid norm 8.712485801387e+00 ||r(i)||/||b|| 2.081619144712e-04
3285 KSP unpreconditioned resid norm 8.712485801386e+00 true resid norm 8.712485801390e+00 ||r(i)||/||b|| 2.081619144713e-04
3286 KSP unpreconditioned resid norm 8.712485801385e+00 true resid norm 8.712485801392e+00 ||r(i)||/||b|| 2.081619144713e-04
3287 KSP unpreconditioned resid norm 8.712485801384e+00 true resid norm 8.712485801389e+00 ||r(i)||/||b|| 2.081619144713e-04
3288 KSP unpreconditioned resid norm 8.712485801384e+00 true resid norm 8.712485801378e+00 ||r(i)||/||b|| 2.081619144710e-04
3289 KSP unpreconditioned resid norm 8.712485801383e+00 true resid norm 8.712485801387e+00 ||r(i)||/||b|| 2.081619144712e-04
3290 KSP unpreconditioned resid norm 8.712485801383e+00 true resid norm 8.712485801387e+00 ||r(i)||/||b|| 2.081619144712e-04
3291 KSP unpreconditioned resid norm 8.712485801383e+00 true resid norm 8.712485801389e+00 ||r(i)||/||b|| 2.081619144713e-04
3292 KSP unpreconditioned resid norm 8.712485801382e+00 true resid norm 8.712485801379e+00 ||r(i)||/||b|| 2.081619144710e-04
3293 KSP unpreconditioned resid norm 8.712485801379e+00 true resid norm 8.712485801378e+00 ||r(i)||/||b|| 2.081619144710e-04
3294 KSP unpreconditioned resid norm 8.712485801374e+00 true resid norm 8.712485801372e+00 ||r(i)||/||b|| 2.081619144709e-04
3295 KSP unpreconditioned resid norm 8.712485801371e+00 true resid norm 8.712485801375e+00 ||r(i)||/||b|| 2.081619144709e-04
3296 KSP unpreconditioned resid norm 8.712485801366e+00 true resid norm 8.712485801372e+00 ||r(i)||/||b|| 2.081619144709e-04
3297 KSP unpreconditioned resid norm 8.712485801359e+00 true resid norm 8.712485801356e+00 ||r(i)||/||b|| 2.081619144705e-04
3298 KSP unpreconditioned resid norm 8.712485801342e+00 true resid norm 8.712485801348e+00 ||r(i)||/||b|| 2.081619144703e-04
3299 KSP unpreconditioned resid norm 8.712485801333e+00 true resid norm 8.712485801328e+00 ||r(i)||/||b|| 2.081619144698e-04
3300 KSP unpreconditioned resid norm 8.712485801334e+00 true resid norm 8.712485801334e+00 ||r(i)||/||b|| 2.081619144699e-04
3301 KSP unpreconditioned resid norm 8.712485801334e+00 true resid norm 8.712485801339e+00 ||r(i)||/||b|| 2.081619144701e-04
3302 KSP unpreconditioned resid norm 8.712485801334e+00 true resid norm 8.712485801336e+00 ||r(i)||/||b|| 2.081619144700e-04
3303 KSP unpreconditioned resid norm 8.712485801334e+00 true resid norm 8.712485801344e+00 ||r(i)||/||b|| 2.081619144702e-04
3304 KSP unpreconditioned resid norm 8.712485801334e+00 true resid norm 8.712485801344e+00 ||r(i)||/||b|| 2.081619144702e-04
3305 KSP unpreconditioned resid norm 8.712485801333e+00 true resid norm 8.712485801341e+00 ||r(i)||/||b|| 2.081619144701e-04
3306 KSP unpreconditioned resid norm 8.712485801333e+00 true resid norm 8.712485801343e+00 ||r(i)||/||b|| 2.081619144702e-04
3307 KSP unpreconditioned resid norm 8.712485801333e+00 true resid norm 8.712485801336e+00 ||r(i)||/||b|| 2.081619144700e-04
3308 KSP unpreconditioned resid norm 8.712485801333e+00 true resid norm 8.712485801340e+00 ||r(i)||/||b|| 2.081619144701e-04
3309 KSP unpreconditioned resid norm 8.712485801332e+00 true resid norm 8.712485801330e+00 ||r(i)||/||b|| 2.081619144699e-04
3310 KSP unpreconditioned resid norm 8.712485801332e+00 true resid norm 8.712485801332e+00 ||r(i)||/||b|| 2.081619144699e-04
3311 KSP unpreconditioned resid norm 8.712485801332e+00 true resid norm 8.712485801346e+00 ||r(i)||/||b|| 2.081619144702e-04
3312 KSP unpreconditioned resid norm 8.712485801332e+00 true resid norm 8.712485801328e+00 ||r(i)||/||b|| 2.081619144698e-04
3313 KSP unpreconditioned resid norm 8.712485801331e+00 true resid norm 8.712485801333e+00 ||r(i)||/||b|| 2.081619144699e-04
3314 KSP unpreconditioned resid norm 8.712485801331e+00 true resid norm 8.712485801332e+00 ||r(i)||/||b|| 2.081619144699e-04
3315 KSP unpreconditioned resid norm 8.712485801330e+00 true resid norm 8.712485801343e+00 ||r(i)||/||b|| 2.081619144702e-04
3316 KSP unpreconditioned resid norm 8.712485801329e+00 true resid norm 8.712485801333e+00 ||r(i)||/||b|| 2.081619144699e-04
3317 KSP unpreconditioned resid norm 8.712485801329e+00 true resid norm 8.712485801333e+00 ||r(i)||/||b|| 2.081619144699e-04
3318 KSP unpreconditioned resid norm 8.712485801328e+00 true resid norm 8.712485801333e+00 ||r(i)||/||b|| 2.081619144699e-04
3319 KSP unpreconditioned resid norm 8.712485801327e+00 true resid norm 8.712485801338e+00 ||r(i)||/||b|| 2.081619144700e-04
3320 KSP unpreconditioned resid norm 8.712485801327e+00 true resid norm 8.712485801325e+00 ||r(i)||/||b|| 2.081619144697e-04
3321 KSP unpreconditioned resid norm 8.712485801327e+00 true resid norm 8.712485801337e+00 ||r(i)||/||b|| 2.081619144700e-04
3322 KSP unpreconditioned resid norm 8.712485801327e+00 true resid norm 8.712485801334e+00 ||r(i)||/||b|| 2.081619144699e-04
3323 KSP unpreconditioned resid norm 8.712485801324e+00 true resid norm 8.712485801314e+00 ||r(i)||/||b|| 2.081619144695e-04
3324 KSP unpreconditioned resid norm 8.712485801320e+00 true resid norm 8.712485801323e+00 ||r(i)||/||b|| 2.081619144697e-04
3325 KSP unpreconditioned resid norm 8.712485801316e+00 true resid norm 8.712485801325e+00 ||r(i)||/||b|| 2.081619144697e-04
3326 KSP unpreconditioned resid norm 8.712485801313e+00 true resid norm 8.712485801321e+00 ||r(i)||/||b|| 2.081619144696e-04
3327 KSP unpreconditioned resid norm 8.712485801306e+00 true resid norm 8.712485801307e+00 ||r(i)||/||b|| 2.081619144693e-04
3328 KSP unpreconditioned resid norm 8.712485801292e+00 true resid norm 8.712485801289e+00 ||r(i)||/||b|| 2.081619144689e-04
3329 KSP unpreconditioned resid norm 8.712485801284e+00 true resid norm 8.712485801283e+00 ||r(i)||/||b|| 2.081619144687e-04
3330 KSP unpreconditioned resid norm 8.712485801285e+00 true resid norm 8.712485801285e+00 ||r(i)||/||b|| 2.081619144688e-04
3331 KSP unpreconditioned resid norm 8.712485801285e+00 true resid norm 8.712485801292e+00 ||r(i)||/||b|| 2.081619144689e-04
3332 KSP unpreconditioned resid norm 8.712485801285e+00 true resid norm 8.712485801293e+00 ||r(i)||/||b|| 2.081619144690e-04
3333 KSP unpreconditioned resid norm 8.712485801284e+00 true resid norm 8.712485801285e+00 ||r(i)||/||b|| 2.081619144688e-04
3334 KSP unpreconditioned resid norm 8.712485801284e+00 true resid norm 8.712485801297e+00 ||r(i)||/||b|| 2.081619144691e-04
3335 KSP unpreconditioned resid norm 8.712485801284e+00 true resid norm 8.712485801277e+00 ||r(i)||/||b|| 2.081619144686e-04
3336 KSP unpreconditioned resid norm 8.712485801284e+00 true resid norm 8.712485801288e+00 ||r(i)||/||b|| 2.081619144688e-04
3337 KSP unpreconditioned resid norm 8.712485801283e+00 true resid norm 8.712485801289e+00 ||r(i)||/||b|| 2.081619144689e-04
3338 KSP unpreconditioned resid norm 8.712485801283e+00 true resid norm 8.712485801284e+00 ||r(i)||/||b|| 2.081619144688e-04
3339 KSP unpreconditioned resid norm 8.712485801283e+00 true resid norm 8.712485801279e+00 ||r(i)||/||b|| 2.081619144686e-04
3340 KSP unpreconditioned resid norm 8.712485801283e+00 true resid norm 8.712485801282e+00 ||r(i)||/||b|| 2.081619144687e-04
3341 KSP unpreconditioned resid norm 8.712485801282e+00 true resid norm 8.712485801276e+00 ||r(i)||/||b|| 2.081619144685e-04
3342 KSP unpreconditioned resid norm 8.712485801282e+00 true resid norm 8.712485801283e+00 ||r(i)||/||b|| 2.081619144687e-04
3343 KSP unpreconditioned resid norm 8.712485801282e+00 true resid norm 8.712485801278e+00 ||r(i)||/||b|| 2.081619144686e-04
3344 KSP unpreconditioned resid norm 8.712485801281e+00 true resid norm 8.712485801283e+00 ||r(i)||/||b|| 2.081619144687e-04
3345 KSP unpreconditioned resid norm 8.712485801281e+00 true resid norm 8.712485801281e+00 ||r(i)||/||b|| 2.081619144687e-04
3346 KSP unpreconditioned resid norm 8.712485801280e+00 true resid norm 8.712485801277e+00 ||r(i)||/||b|| 2.081619144686e-04
3347 KSP unpreconditioned resid norm 8.712485801280e+00 true resid norm 8.712485801283e+00 ||r(i)||/||b|| 2.081619144687e-04
3348 KSP unpreconditioned resid norm 8.712485801279e+00 true resid norm 8.712485801274e+00 ||r(i)||/||b|| 2.081619144685e-04
3349 KSP unpreconditioned resid norm 8.712485801279e+00 true resid norm 8.712485801285e+00 ||r(i)||/||b|| 2.081619144688e-04
3350 KSP unpreconditioned resid norm 8.712485801279e+00 true resid norm 8.712485801279e+00 ||r(i)||/||b|| 2.081619144686e-04
3351 KSP unpreconditioned resid norm 8.712485801279e+00 true resid norm 8.712485801289e+00 ||r(i)||/||b|| 2.081619144689e-04
3352 KSP unpreconditioned resid norm 8.712485801278e+00 true resid norm 8.712485801275e+00 ||r(i)||/||b|| 2.081619144685e-04
3353 KSP unpreconditioned resid norm 8.712485801275e+00 true resid norm 8.712485801270e+00 ||r(i)||/||b|| 2.081619144684e-04
3354 KSP unpreconditioned resid norm 8.712485801272e+00 true resid norm 8.712485801281e+00 ||r(i)||/||b|| 2.081619144687e-04
3355 KSP unpreconditioned resid norm 8.712485801269e+00 true resid norm 8.712485801272e+00 ||r(i)||/||b|| 2.081619144685e-04
3356 KSP unpreconditioned resid norm 8.712485801265e+00 true resid norm 8.712485801261e+00 ||r(i)||/||b|| 2.081619144682e-04
3357 KSP unpreconditioned resid norm 8.712485801260e+00 true resid norm 8.712485801259e+00 ||r(i)||/||b|| 2.081619144682e-04
3358 KSP unpreconditioned resid norm 8.712485801247e+00 true resid norm 8.712485801250e+00 ||r(i)||/||b|| 2.081619144679e-04
3359 KSP unpreconditioned resid norm 8.712485801240e+00 true resid norm 8.712485801250e+00 ||r(i)||/||b|| 2.081619144679e-04
3360 KSP unpreconditioned resid norm 8.712485801241e+00 true resid norm 8.712485801241e+00 ||r(i)||/||b|| 2.081619144677e-04
3361 KSP unpreconditioned resid norm 8.712485801241e+00 true resid norm 8.712485801240e+00 ||r(i)||/||b|| 2.081619144677e-04
3362 KSP unpreconditioned resid norm 8.712485801241e+00 true resid norm 8.712485801235e+00 ||r(i)||/||b|| 2.081619144676e-04
3363 KSP unpreconditioned resid norm 8.712485801241e+00 true resid norm 8.712485801238e+00 ||r(i)||/||b|| 2.081619144676e-04
3364 KSP unpreconditioned resid norm 8.712485801241e+00 true resid norm 8.712485801240e+00 ||r(i)||/||b|| 2.081619144677e-04
3365 KSP unpreconditioned resid norm 8.712485801240e+00 true resid norm 8.712485801240e+00 ||r(i)||/||b|| 2.081619144677e-04
3366 KSP unpreconditioned resid norm 8.712485801240e+00 true resid norm 8.712485801245e+00 ||r(i)||/||b|| 2.081619144678e-04
3367 KSP unpreconditioned resid norm 8.712485801240e+00 true resid norm 8.712485801239e+00 ||r(i)||/||b|| 2.081619144677e-04
3368 KSP unpreconditioned resid norm 8.712485801240e+00 true resid norm 8.712485801242e+00 ||r(i)||/||b|| 2.081619144677e-04
3369 KSP unpreconditioned resid norm 8.712485801240e+00 true resid norm 8.712485801249e+00 ||r(i)||/||b|| 2.081619144679e-04
3370 KSP unpreconditioned resid norm 8.712485801239e+00 true resid norm 8.712485801239e+00 ||r(i)||/||b|| 2.081619144677e-04
3371 KSP unpreconditioned resid norm 8.712485801239e+00 true resid norm 8.712485801246e+00 ||r(i)||/||b|| 2.081619144678e-04
3372 KSP unpreconditioned resid norm 8.712485801239e+00 true resid norm 8.712485801236e+00 ||r(i)||/||b|| 2.081619144676e-04
3373 KSP unpreconditioned resid norm 8.712485801239e+00 true resid norm 8.712485801247e+00 ||r(i)||/||b|| 2.081619144679e-04
3374 KSP unpreconditioned resid norm 8.712485801239e+00 true resid norm 8.712485801241e+00 ||r(i)||/||b|| 2.081619144677e-04
3375 KSP unpreconditioned resid norm 8.712485801238e+00 true resid norm 8.712485801235e+00 ||r(i)||/||b|| 2.081619144676e-04
3376 KSP unpreconditioned resid norm 8.712485801237e+00 true resid norm 8.712485801235e+00 ||r(i)||/||b|| 2.081619144676e-04
3377 KSP unpreconditioned resid norm 8.712485801237e+00 true resid norm 8.712485801225e+00 ||r(i)||/||b|| 2.081619144673e-04
3378 KSP unpreconditioned resid norm 8.712485801236e+00 true resid norm 8.712485801230e+00 ||r(i)||/||b|| 2.081619144675e-04
3379 KSP unpreconditioned resid norm 8.712485801236e+00 true resid norm 8.712485801243e+00 ||r(i)||/||b|| 2.081619144678e-04
3380 KSP unpreconditioned resid norm 8.712485801236e+00 true resid norm 8.712485801232e+00 ||r(i)||/||b|| 2.081619144675e-04
3381 KSP unpreconditioned resid norm 8.712485801236e+00 true resid norm 8.712485801242e+00 ||r(i)||/||b|| 2.081619144677e-04
3382 KSP unpreconditioned resid norm 8.712485801236e+00 true resid norm 8.712485801240e+00 ||r(i)||/||b|| 2.081619144677e-04
3383 KSP unpreconditioned resid norm 8.712485801233e+00 true resid norm 8.712485801237e+00 ||r(i)||/||b|| 2.081619144676e-04
3384 KSP unpreconditioned resid norm 8.712485801230e+00 true resid norm 8.712485801236e+00 ||r(i)||/||b|| 2.081619144676e-04
3385 KSP unpreconditioned resid norm 8.712485801227e+00 true resid norm 8.712485801228e+00 ||r(i)||/||b|| 2.081619144674e-04
3386 KSP unpreconditioned resid norm 8.712485801224e+00 true resid norm 8.712485801222e+00 ||r(i)||/||b|| 2.081619144673e-04
3387 KSP unpreconditioned resid norm 8.712485801220e+00 true resid norm 8.712485801224e+00 ||r(i)||/||b|| 2.081619144673e-04
3388 KSP unpreconditioned resid norm 8.712485801208e+00 true resid norm 8.712485801205e+00 ||r(i)||/||b|| 2.081619144669e-04
3389 KSP unpreconditioned resid norm 8.712485801202e+00 true resid norm 8.712485801200e+00 ||r(i)||/||b|| 2.081619144667e-04
3390 KSP unpreconditioned resid norm 8.712485801202e+00 true resid norm 8.712485801202e+00 ||r(i)||/||b|| 2.081619144668e-04
3391 KSP unpreconditioned resid norm 8.712485801202e+00 true resid norm 8.712485801203e+00 ||r(i)||/||b|| 2.081619144668e-04
3392 KSP unpreconditioned resid norm 8.712485801202e+00 true resid norm 8.712485801213e+00 ||r(i)||/||b|| 2.081619144670e-04
3393 KSP unpreconditioned resid norm 8.712485801202e+00 true resid norm 8.712485801209e+00 ||r(i)||/||b|| 2.081619144669e-04
3394 KSP unpreconditioned resid norm 8.712485801201e+00 true resid norm 8.712485801209e+00 ||r(i)||/||b|| 2.081619144669e-04
3395 KSP unpreconditioned resid norm 8.712485801201e+00 true resid norm 8.712485801208e+00 ||r(i)||/||b|| 2.081619144669e-04
3396 KSP unpreconditioned resid norm 8.712485801201e+00 true resid norm 8.712485801217e+00 ||r(i)||/||b|| 2.081619144671e-04
3397 KSP unpreconditioned resid norm 8.712485801201e+00 true resid norm 8.712485801211e+00 ||r(i)||/||b|| 2.081619144670e-04
3398 KSP unpreconditioned resid norm 8.712485801201e+00 true resid norm 8.712485801202e+00 ||r(i)||/||b|| 2.081619144668e-04
3399 KSP unpreconditioned resid norm 8.712485801200e+00 true resid norm 8.712485801202e+00 ||r(i)||/||b|| 2.081619144668e-04
3400 KSP unpreconditioned resid norm 8.712485801200e+00 true resid norm 8.712485801207e+00 ||r(i)||/||b|| 2.081619144669e-04
3401 KSP unpreconditioned resid norm 8.712485801200e+00 true resid norm 8.712485801201e+00 ||r(i)||/||b|| 2.081619144668e-04
3402 KSP unpreconditioned resid norm 8.712485801200e+00 true resid norm 8.712485801206e+00 ||r(i)||/||b|| 2.081619144669e-04
3403 KSP unpreconditioned resid norm 8.712485801200e+00 true resid norm 8.712485801209e+00 ||r(i)||/||b|| 2.081619144669e-04
3404 KSP unpreconditioned resid norm 8.712485801199e+00 true resid norm 8.712485801199e+00 ||r(i)||/||b|| 2.081619144667e-04
3405 KSP unpreconditioned resid norm 8.712485801199e+00 true resid norm 8.712485801205e+00 ||r(i)||/||b|| 2.081619144668e-04
3406 KSP unpreconditioned resid norm 8.712485801198e+00 true resid norm 8.712485801194e+00 ||r(i)||/||b|| 2.081619144666e-04
3407 KSP unpreconditioned resid norm 8.712485801198e+00 true resid norm 8.712485801207e+00 ||r(i)||/||b|| 2.081619144669e-04
3408 KSP unpreconditioned resid norm 8.712485801197e+00 true resid norm 8.712485801204e+00 ||r(i)||/||b|| 2.081619144668e-04
3409 KSP unpreconditioned resid norm 8.712485801197e+00 true resid norm 8.712485801214e+00 ||r(i)||/||b|| 2.081619144671e-04
3410 KSP unpreconditioned resid norm 8.712485801197e+00 true resid norm 8.712485801194e+00 ||r(i)||/||b|| 2.081619144666e-04
3411 KSP unpreconditioned resid norm 8.712485801197e+00 true resid norm 8.712485801204e+00 ||r(i)||/||b|| 2.081619144668e-04
3412 KSP unpreconditioned resid norm 8.712485801197e+00 true resid norm 8.712485801203e+00 ||r(i)||/||b|| 2.081619144668e-04
3413 KSP unpreconditioned resid norm 8.712485801194e+00 true resid norm 8.712485801192e+00 ||r(i)||/||b|| 2.081619144665e-04
3414 KSP unpreconditioned resid norm 8.712485801192e+00 true resid norm 8.712485801195e+00 ||r(i)||/||b|| 2.081619144666e-04
3415 KSP unpreconditioned resid norm 8.712485801189e+00 true resid norm 8.712485801192e+00 ||r(i)||/||b|| 2.081619144665e-04
3416 KSP unpreconditioned resid norm 8.712485801187e+00 true resid norm 8.712485801190e+00 ||r(i)||/||b|| 2.081619144665e-04
3417 KSP unpreconditioned resid norm 8.712485801182e+00 true resid norm 8.712485801190e+00 ||r(i)||/||b|| 2.081619144665e-04
3418 KSP unpreconditioned resid norm 8.712485801172e+00 true resid norm 8.712485801172e+00 ||r(i)||/||b|| 2.081619144661e-04
3419 KSP unpreconditioned resid norm 8.712485801167e+00 true resid norm 8.712485801166e+00 ||r(i)||/||b|| 2.081619144659e-04
3420 KSP unpreconditioned resid norm 8.712485801176e+00 true resid norm 8.712485801176e+00 ||r(i)||/||b|| 2.081619144662e-04
3421 KSP unpreconditioned resid norm 8.712485801176e+00 true resid norm 8.712485801180e+00 ||r(i)||/||b|| 2.081619144663e-04
3422 KSP unpreconditioned resid norm 8.712485801176e+00 true resid norm 8.712485801184e+00 ||r(i)||/||b|| 2.081619144664e-04
3423 KSP unpreconditioned resid norm 8.712485801176e+00 true resid norm 8.712485801178e+00 ||r(i)||/||b|| 2.081619144662e-04
3424 KSP unpreconditioned resid norm 8.712485801175e+00 true resid norm 8.712485801180e+00 ||r(i)||/||b|| 2.081619144663e-04
3425 KSP unpreconditioned resid norm 8.712485801175e+00 true resid norm 8.712485801180e+00 ||r(i)||/||b|| 2.081619144663e-04
3426 KSP unpreconditioned resid norm 8.712485801175e+00 true resid norm 8.712485801168e+00 ||r(i)||/||b|| 2.081619144660e-04
3427 KSP unpreconditioned resid norm 8.712485801175e+00 true resid norm 8.712485801175e+00 ||r(i)||/||b|| 2.081619144661e-04
3428 KSP unpreconditioned resid norm 8.712485801175e+00 true resid norm 8.712485801175e+00 ||r(i)||/||b|| 2.081619144661e-04
3429 KSP unpreconditioned resid norm 8.712485801175e+00 true resid norm 8.712485801168e+00 ||r(i)||/||b|| 2.081619144660e-04
3430 KSP unpreconditioned resid norm 8.712485801174e+00 true resid norm 8.712485801178e+00 ||r(i)||/||b|| 2.081619144662e-04
3431 KSP unpreconditioned resid norm 8.712485801174e+00 true resid norm 8.712485801185e+00 ||r(i)||/||b|| 2.081619144664e-04
3432 KSP unpreconditioned resid norm 8.712485801174e+00 true resid norm 8.712485801185e+00 ||r(i)||/||b|| 2.081619144664e-04
3433 KSP unpreconditioned resid norm 8.712485801174e+00 true resid norm 8.712485801173e+00 ||r(i)||/||b|| 2.081619144661e-04
3434 KSP unpreconditioned resid norm 8.712485801174e+00 true resid norm 8.712485801178e+00 ||r(i)||/||b|| 2.081619144662e-04
3435 KSP unpreconditioned resid norm 8.712485801173e+00 true resid norm 8.712485801170e+00 ||r(i)||/||b|| 2.081619144660e-04
3436 KSP unpreconditioned resid norm 8.712485801173e+00 true resid norm 8.712485801171e+00 ||r(i)||/||b|| 2.081619144661e-04
3437 KSP unpreconditioned resid norm 8.712485801172e+00 true resid norm 8.712485801177e+00 ||r(i)||/||b|| 2.081619144662e-04
3438 KSP unpreconditioned resid norm 8.712485801172e+00 true resid norm 8.712485801172e+00 ||r(i)||/||b|| 2.081619144661e-04
3439 KSP unpreconditioned resid norm 8.712485801172e+00 true resid norm 8.712485801173e+00 ||r(i)||/||b|| 2.081619144661e-04
3440 KSP unpreconditioned resid norm 8.712485801172e+00 true resid norm 8.712485801183e+00 ||r(i)||/||b|| 2.081619144663e-04
3441 KSP unpreconditioned resid norm 8.712485801172e+00 true resid norm 8.712485801163e+00 ||r(i)||/||b|| 2.081619144659e-04
3442 KSP unpreconditioned resid norm 8.712485801171e+00 true resid norm 8.712485801176e+00 ||r(i)||/||b|| 2.081619144662e-04
3443 KSP unpreconditioned resid norm 8.712485801169e+00 true resid norm 8.712485801172e+00 ||r(i)||/||b|| 2.081619144661e-04
3444 KSP unpreconditioned resid norm 8.712485801167e+00 true resid norm 8.712485801176e+00 ||r(i)||/||b|| 2.081619144662e-04
3445 KSP unpreconditioned resid norm 8.712485801165e+00 true resid norm 8.712485801156e+00 ||r(i)||/||b|| 2.081619144657e-04
3446 KSP unpreconditioned resid norm 8.712485801163e+00 true resid norm 8.712485801158e+00 ||r(i)||/||b|| 2.081619144657e-04
3447 KSP unpreconditioned resid norm 8.712485801159e+00 true resid norm 8.712485801149e+00 ||r(i)||/||b|| 2.081619144655e-04
3448 KSP unpreconditioned resid norm 8.712485801150e+00 true resid norm 8.712485801149e+00 ||r(i)||/||b|| 2.081619144655e-04
3449 KSP unpreconditioned resid norm 8.712485801145e+00 true resid norm 8.712485801151e+00 ||r(i)||/||b|| 2.081619144656e-04
3450 KSP unpreconditioned resid norm 8.712485801155e+00 true resid norm 8.712485801155e+00 ||r(i)||/||b|| 2.081619144657e-04
3451 KSP unpreconditioned resid norm 8.712485801155e+00 true resid norm 8.712485801157e+00 ||r(i)||/||b|| 2.081619144657e-04
3452 KSP unpreconditioned resid norm 8.712485801155e+00 true resid norm 8.712485801145e+00 ||r(i)||/||b|| 2.081619144654e-04
3453 KSP unpreconditioned resid norm 8.712485801155e+00 true resid norm 8.712485801150e+00 ||r(i)||/||b|| 2.081619144656e-04
3454 KSP unpreconditioned resid norm 8.712485801155e+00 true resid norm 8.712485801152e+00 ||r(i)||/||b|| 2.081619144656e-04
3455 KSP unpreconditioned resid norm 8.712485801155e+00 true resid norm 8.712485801155e+00 ||r(i)||/||b|| 2.081619144657e-04
3456 KSP unpreconditioned resid norm 8.712485801155e+00 true resid norm 8.712485801148e+00 ||r(i)||/||b|| 2.081619144655e-04
3457 KSP unpreconditioned resid norm 8.712485801155e+00 true resid norm 8.712485801157e+00 ||r(i)||/||b|| 2.081619144657e-04
3458 KSP unpreconditioned resid norm 8.712485801154e+00 true resid norm 8.712485801147e+00 ||r(i)||/||b|| 2.081619144655e-04
3459 KSP unpreconditioned resid norm 8.712485801154e+00 true resid norm 8.712485801152e+00 ||r(i)||/||b|| 2.081619144656e-04
3460 KSP unpreconditioned resid norm 8.712485801154e+00 true resid norm 8.712485801145e+00 ||r(i)||/||b|| 2.081619144654e-04
3461 KSP unpreconditioned resid norm 8.712485801154e+00 true resid norm 8.712485801144e+00 ||r(i)||/||b|| 2.081619144654e-04
3462 KSP unpreconditioned resid norm 8.712485801154e+00 true resid norm 8.712485801151e+00 ||r(i)||/||b|| 2.081619144656e-04
3463 KSP unpreconditioned resid norm 8.712485801154e+00 true resid norm 8.712485801148e+00 ||r(i)||/||b|| 2.081619144655e-04
3464 KSP unpreconditioned resid norm 8.712485801153e+00 true resid norm 8.712485801144e+00 ||r(i)||/||b|| 2.081619144654e-04
3465 KSP unpreconditioned resid norm 8.712485801153e+00 true resid norm 8.712485801136e+00 ||r(i)||/||b|| 2.081619144652e-04
3466 KSP unpreconditioned resid norm 8.712485801152e+00 true resid norm 8.712485801147e+00 ||r(i)||/||b|| 2.081619144655e-04
3467 KSP unpreconditioned resid norm 8.712485801152e+00 true resid norm 8.712485801140e+00 ||r(i)||/||b|| 2.081619144653e-04
3468 KSP unpreconditioned resid norm 8.712485801152e+00 true resid norm 8.712485801151e+00 ||r(i)||/||b|| 2.081619144656e-04
3469 KSP unpreconditioned resid norm 8.712485801152e+00 true resid norm 8.712485801139e+00 ||r(i)||/||b|| 2.081619144653e-04
3470 KSP unpreconditioned resid norm 8.712485801152e+00 true resid norm 8.712485801145e+00 ||r(i)||/||b|| 2.081619144654e-04
3471 KSP unpreconditioned resid norm 8.712485801152e+00 true resid norm 8.712485801147e+00 ||r(i)||/||b|| 2.081619144655e-04
3472 KSP unpreconditioned resid norm 8.712485801151e+00 true resid norm 8.712485801153e+00 ||r(i)||/||b|| 2.081619144656e-04
3473 KSP unpreconditioned resid norm 8.712485801150e+00 true resid norm 8.712485801151e+00 ||r(i)||/||b|| 2.081619144656e-04
3474 KSP unpreconditioned resid norm 8.712485801147e+00 true resid norm 8.712485801145e+00 ||r(i)||/||b|| 2.081619144654e-04
3475 KSP unpreconditioned resid norm 8.712485801146e+00 true resid norm 8.712485801142e+00 ||r(i)||/||b|| 2.081619144654e-04
3476 KSP unpreconditioned resid norm 8.712485801144e+00 true resid norm 8.712485801146e+00 ||r(i)||/||b|| 2.081619144654e-04
3477 KSP unpreconditioned resid norm 8.712485801140e+00 true resid norm 8.712485801138e+00 ||r(i)||/||b|| 2.081619144653e-04
3478 KSP unpreconditioned resid norm 8.712485801132e+00 true resid norm 8.712485801136e+00 ||r(i)||/||b|| 2.081619144652e-04
3479 KSP unpreconditioned resid norm 8.712485801128e+00 true resid norm 8.712485801123e+00 ||r(i)||/||b|| 2.081619144649e-04
3480 KSP unpreconditioned resid norm 8.712485801127e+00 true resid norm 8.712485801127e+00 ||r(i)||/||b|| 2.081619144650e-04
3481 KSP unpreconditioned resid norm 8.712485801127e+00 true resid norm 8.712485801137e+00 ||r(i)||/||b|| 2.081619144652e-04
3482 KSP unpreconditioned resid norm 8.712485801127e+00 true resid norm 8.712485801126e+00 ||r(i)||/||b|| 2.081619144650e-04
3483 KSP unpreconditioned resid norm 8.712485801127e+00 true resid norm 8.712485801123e+00 ||r(i)||/||b|| 2.081619144649e-04
3484 KSP unpreconditioned resid norm 8.712485801127e+00 true resid norm 8.712485801135e+00 ||r(i)||/||b|| 2.081619144652e-04
3485 KSP unpreconditioned resid norm 8.712485801126e+00 true resid norm 8.712485801133e+00 ||r(i)||/||b|| 2.081619144651e-04
3486 KSP unpreconditioned resid norm 8.712485801126e+00 true resid norm 8.712485801124e+00 ||r(i)||/||b|| 2.081619144649e-04
3487 KSP unpreconditioned resid norm 8.712485801126e+00 true resid norm 8.712485801134e+00 ||r(i)||/||b|| 2.081619144652e-04
3488 KSP unpreconditioned resid norm 8.712485801126e+00 true resid norm 8.712485801129e+00 ||r(i)||/||b|| 2.081619144651e-04
3489 KSP unpreconditioned resid norm 8.712485801126e+00 true resid norm 8.712485801130e+00 ||r(i)||/||b|| 2.081619144651e-04
3490 KSP unpreconditioned resid norm 8.712485801126e+00 true resid norm 8.712485801121e+00 ||r(i)||/||b|| 2.081619144649e-04
3491 KSP unpreconditioned resid norm 8.712485801126e+00 true resid norm 8.712485801136e+00 ||r(i)||/||b|| 2.081619144652e-04
3492 KSP unpreconditioned resid norm 8.712485801126e+00 true resid norm 8.712485801126e+00 ||r(i)||/||b|| 2.081619144650e-04
3493 KSP unpreconditioned resid norm 8.712485801126e+00 true resid norm 8.712485801121e+00 ||r(i)||/||b|| 2.081619144649e-04
3494 KSP unpreconditioned resid norm 8.712485801125e+00 true resid norm 8.712485801135e+00 ||r(i)||/||b|| 2.081619144652e-04
3495 KSP unpreconditioned resid norm 8.712485801125e+00 true resid norm 8.712485801126e+00 ||r(i)||/||b|| 2.081619144650e-04
3496 KSP unpreconditioned resid norm 8.712485801125e+00 true resid norm 8.712485801126e+00 ||r(i)||/||b|| 2.081619144650e-04
3497 KSP unpreconditioned resid norm 8.712485801124e+00 true resid norm 8.712485801120e+00 ||r(i)||/||b|| 2.081619144648e-04
3498 KSP unpreconditioned resid norm 8.712485801124e+00 true resid norm 8.712485801126e+00 ||r(i)||/||b|| 2.081619144650e-04
3499 KSP unpreconditioned resid norm 8.712485801124e+00 true resid norm 8.712485801130e+00 ||r(i)||/||b|| 2.081619144651e-04
3500 KSP unpreconditioned resid norm 8.712485801124e+00 true resid norm 8.712485801120e+00 ||r(i)||/||b|| 2.081619144648e-04
3501 KSP unpreconditioned resid norm 8.712485801124e+00 true resid norm 8.712485801122e+00 ||r(i)||/||b|| 2.081619144649e-04
3502 KSP unpreconditioned resid norm 8.712485801123e+00 true resid norm 8.712485801121e+00 ||r(i)||/||b|| 2.081619144648e-04
3503 KSP unpreconditioned resid norm 8.712485801122e+00 true resid norm 8.712485801123e+00 ||r(i)||/||b|| 2.081619144649e-04
3504 KSP unpreconditioned resid norm 8.712485801120e+00 true resid norm 8.712485801120e+00 ||r(i)||/||b|| 2.081619144648e-04
3505 KSP unpreconditioned resid norm 8.712485801119e+00 true resid norm 8.712485801124e+00 ||r(i)||/||b|| 2.081619144649e-04
3506 KSP unpreconditioned resid norm 8.712485801117e+00 true resid norm 8.712485801111e+00 ||r(i)||/||b|| 2.081619144646e-04
3507 KSP unpreconditioned resid norm 8.712485801114e+00 true resid norm 8.712485801119e+00 ||r(i)||/||b|| 2.081619144648e-04
3508 KSP unpreconditioned resid norm 8.712485801107e+00 true resid norm 8.712485801121e+00 ||r(i)||/||b|| 2.081619144649e-04
3509 KSP unpreconditioned resid norm 8.712485801103e+00 true resid norm 8.712485801120e+00 ||r(i)||/||b|| 2.081619144648e-04
3510 KSP unpreconditioned resid norm 8.712485801105e+00 true resid norm 8.712485801105e+00 ||r(i)||/||b|| 2.081619144645e-04
3511 KSP unpreconditioned resid norm 8.712485801105e+00 true resid norm 8.712485801102e+00 ||r(i)||/||b|| 2.081619144644e-04
3512 KSP unpreconditioned resid norm 8.712485801105e+00 true resid norm 8.712485801105e+00 ||r(i)||/||b|| 2.081619144645e-04
3513 KSP unpreconditioned resid norm 8.712485801105e+00 true resid norm 8.712485801106e+00 ||r(i)||/||b|| 2.081619144645e-04
3514 KSP unpreconditioned resid norm 8.712485801105e+00 true resid norm 8.712485801110e+00 ||r(i)||/||b|| 2.081619144646e-04
3515 KSP unpreconditioned resid norm 8.712485801105e+00 true resid norm 8.712485801109e+00 ||r(i)||/||b|| 2.081619144646e-04
3516 KSP unpreconditioned resid norm 8.712485801105e+00 true resid norm 8.712485801111e+00 ||r(i)||/||b|| 2.081619144646e-04
3517 KSP unpreconditioned resid norm 8.712485801105e+00 true resid norm 8.712485801105e+00 ||r(i)||/||b|| 2.081619144645e-04
3518 KSP unpreconditioned resid norm 8.712485801104e+00 true resid norm 8.712485801095e+00 ||r(i)||/||b|| 2.081619144642e-04
3519 KSP unpreconditioned resid norm 8.712485801104e+00 true resid norm 8.712485801103e+00 ||r(i)||/||b|| 2.081619144644e-04
3520 KSP unpreconditioned resid norm 8.712485801104e+00 true resid norm 8.712485801099e+00 ||r(i)||/||b|| 2.081619144643e-04
3521 KSP unpreconditioned resid norm 8.712485801104e+00 true resid norm 8.712485801101e+00 ||r(i)||/||b|| 2.081619144644e-04
3522 KSP unpreconditioned resid norm 8.712485801104e+00 true resid norm 8.712485801105e+00 ||r(i)||/||b|| 2.081619144645e-04
3523 KSP unpreconditioned resid norm 8.712485801104e+00 true resid norm 8.712485801114e+00 ||r(i)||/||b|| 2.081619144647e-04
3524 KSP unpreconditioned resid norm 8.712485801104e+00 true resid norm 8.712485801107e+00 ||r(i)||/||b|| 2.081619144645e-04
3525 KSP unpreconditioned resid norm 8.712485801103e+00 true resid norm 8.712485801102e+00 ||r(i)||/||b|| 2.081619144644e-04
3526 KSP unpreconditioned resid norm 8.712485801103e+00 true resid norm 8.712485801112e+00 ||r(i)||/||b|| 2.081619144646e-04
3527 KSP unpreconditioned resid norm 8.712485801103e+00 true resid norm 8.712485801107e+00 ||r(i)||/||b|| 2.081619144645e-04
3528 KSP unpreconditioned resid norm 8.712485801102e+00 true resid norm 8.712485801105e+00 ||r(i)||/||b|| 2.081619144645e-04
3529 KSP unpreconditioned resid norm 8.712485801102e+00 true resid norm 8.712485801104e+00 ||r(i)||/||b|| 2.081619144644e-04
3530 KSP unpreconditioned resid norm 8.712485801102e+00 true resid norm 8.712485801105e+00 ||r(i)||/||b|| 2.081619144645e-04
3531 KSP unpreconditioned resid norm 8.712485801102e+00 true resid norm 8.712485801104e+00 ||r(i)||/||b|| 2.081619144644e-04
3532 KSP unpreconditioned resid norm 8.712485801102e+00 true resid norm 8.712485801108e+00 ||r(i)||/||b|| 2.081619144645e-04
3533 KSP unpreconditioned resid norm 8.712485801101e+00 true resid norm 8.712485801103e+00 ||r(i)||/||b|| 2.081619144644e-04
3534 KSP unpreconditioned resid norm 8.712485801099e+00 true resid norm 8.712485801097e+00 ||r(i)||/||b|| 2.081619144643e-04
3535 KSP unpreconditioned resid norm 8.712485801098e+00 true resid norm 8.712485801097e+00 ||r(i)||/||b|| 2.081619144643e-04
3536 KSP unpreconditioned resid norm 8.712485801096e+00 true resid norm 8.712485801101e+00 ||r(i)||/||b|| 2.081619144644e-04
3537 KSP unpreconditioned resid norm 8.712485801093e+00 true resid norm 8.712485801096e+00 ||r(i)||/||b|| 2.081619144642e-04
3538 KSP unpreconditioned resid norm 8.712485801087e+00 true resid norm 8.712485801089e+00 ||r(i)||/||b|| 2.081619144641e-04
3539 KSP unpreconditioned resid norm 8.712485801084e+00 true resid norm 8.712485801090e+00 ||r(i)||/||b|| 2.081619144641e-04
3540 KSP unpreconditioned resid norm 8.712485801086e+00 true resid norm 8.712485801086e+00 ||r(i)||/||b|| 2.081619144640e-04
3541 KSP unpreconditioned resid norm 8.712485801086e+00 true resid norm 8.712485801083e+00 ||r(i)||/||b|| 2.081619144639e-04
3542 KSP unpreconditioned resid norm 8.712485801086e+00 true resid norm 8.712485801093e+00 ||r(i)||/||b|| 2.081619144642e-04
3543 KSP unpreconditioned resid norm 8.712485801086e+00 true resid norm 8.712485801095e+00 ||r(i)||/||b|| 2.081619144642e-04
3544 KSP unpreconditioned resid norm 8.712485801086e+00 true resid norm 8.712485801090e+00 ||r(i)||/||b|| 2.081619144641e-04
3545 KSP unpreconditioned resid norm 8.712485801086e+00 true resid norm 8.712485801082e+00 ||r(i)||/||b|| 2.081619144639e-04
3546 KSP unpreconditioned resid norm 8.712485801085e+00 true resid norm 8.712485801093e+00 ||r(i)||/||b|| 2.081619144642e-04
3547 KSP unpreconditioned resid norm 8.712485801085e+00 true resid norm 8.712485801089e+00 ||r(i)||/||b|| 2.081619144641e-04
3548 KSP unpreconditioned resid norm 8.712485801085e+00 true resid norm 8.712485801083e+00 ||r(i)||/||b|| 2.081619144639e-04
3549 KSP unpreconditioned resid norm 8.712485801085e+00 true resid norm 8.712485801084e+00 ||r(i)||/||b|| 2.081619144640e-04
3550 KSP unpreconditioned resid norm 8.712485801085e+00 true resid norm 8.712485801095e+00 ||r(i)||/||b|| 2.081619144642e-04
3551 KSP unpreconditioned resid norm 8.712485801085e+00 true resid norm 8.712485801081e+00 ||r(i)||/||b|| 2.081619144639e-04
3552 KSP unpreconditioned resid norm 8.712485801085e+00 true resid norm 8.712485801082e+00 ||r(i)||/||b|| 2.081619144639e-04
3553 KSP unpreconditioned resid norm 8.712485801085e+00 true resid norm 8.712485801093e+00 ||r(i)||/||b|| 2.081619144642e-04
3554 KSP unpreconditioned resid norm 8.712485801085e+00 true resid norm 8.712485801087e+00 ||r(i)||/||b|| 2.081619144641e-04
3555 KSP unpreconditioned resid norm 8.712485801084e+00 true resid norm 8.712485801099e+00 ||r(i)||/||b|| 2.081619144643e-04
3556 KSP unpreconditioned resid norm 8.712485801084e+00 true resid norm 8.712485801076e+00 ||r(i)||/||b|| 2.081619144638e-04
3557 KSP unpreconditioned resid norm 8.712485801084e+00 true resid norm 8.712485801092e+00 ||r(i)||/||b|| 2.081619144642e-04
3558 KSP unpreconditioned resid norm 8.712485801084e+00 true resid norm 8.712485801078e+00 ||r(i)||/||b|| 2.081619144638e-04
3559 KSP unpreconditioned resid norm 8.712485801083e+00 true resid norm 8.712485801087e+00 ||r(i)||/||b|| 2.081619144640e-04
3560 KSP unpreconditioned resid norm 8.712485801083e+00 true resid norm 8.712485801082e+00 ||r(i)||/||b|| 2.081619144639e-04
3561 KSP unpreconditioned resid norm 8.712485801083e+00 true resid norm 8.712485801088e+00 ||r(i)||/||b|| 2.081619144641e-04
3562 KSP unpreconditioned resid norm 8.712485801083e+00 true resid norm 8.712485801087e+00 ||r(i)||/||b|| 2.081619144640e-04
3563 KSP unpreconditioned resid norm 8.712485801082e+00 true resid norm 8.712485801085e+00 ||r(i)||/||b|| 2.081619144640e-04
3564 KSP unpreconditioned resid norm 8.712485801080e+00 true resid norm 8.712485801078e+00 ||r(i)||/||b|| 2.081619144638e-04
3565 KSP unpreconditioned resid norm 8.712485801079e+00 true resid norm 8.712485801078e+00 ||r(i)||/||b|| 2.081619144638e-04
3566 KSP unpreconditioned resid norm 8.712485801078e+00 true resid norm 8.712485801085e+00 ||r(i)||/||b|| 2.081619144640e-04
3567 KSP unpreconditioned resid norm 8.712485801076e+00 true resid norm 8.712485801074e+00 ||r(i)||/||b|| 2.081619144637e-04
3568 KSP unpreconditioned resid norm 8.712485801070e+00 true resid norm 8.712485801080e+00 ||r(i)||/||b|| 2.081619144639e-04
3569 KSP unpreconditioned resid norm 8.712485801067e+00 true resid norm 8.712485801074e+00 ||r(i)||/||b|| 2.081619144637e-04
3570 KSP unpreconditioned resid norm 8.712485801066e+00 true resid norm 8.712485801066e+00 ||r(i)||/||b|| 2.081619144635e-04
3571 KSP unpreconditioned resid norm 8.712485801066e+00 true resid norm 8.712485801075e+00 ||r(i)||/||b|| 2.081619144638e-04
3572 KSP unpreconditioned resid norm 8.712485801066e+00 true resid norm 8.712485801070e+00 ||r(i)||/||b|| 2.081619144636e-04
3573 KSP unpreconditioned resid norm 8.712485801066e+00 true resid norm 8.712485801078e+00 ||r(i)||/||b|| 2.081619144638e-04
3574 KSP unpreconditioned resid norm 8.712485801066e+00 true resid norm 8.712485801063e+00 ||r(i)||/||b|| 2.081619144635e-04
3575 KSP unpreconditioned resid norm 8.712485801066e+00 true resid norm 8.712485801074e+00 ||r(i)||/||b|| 2.081619144637e-04
3576 KSP unpreconditioned resid norm 8.712485801066e+00 true resid norm 8.712485801068e+00 ||r(i)||/||b|| 2.081619144636e-04
3577 KSP unpreconditioned resid norm 8.712485801066e+00 true resid norm 8.712485801063e+00 ||r(i)||/||b|| 2.081619144635e-04
3578 KSP unpreconditioned resid norm 8.712485801066e+00 true resid norm 8.712485801074e+00 ||r(i)||/||b|| 2.081619144637e-04
3579 KSP unpreconditioned resid norm 8.712485801066e+00 true resid norm 8.712485801068e+00 ||r(i)||/||b|| 2.081619144636e-04
3580 KSP unpreconditioned resid norm 8.712485801065e+00 true resid norm 8.712485801064e+00 ||r(i)||/||b|| 2.081619144635e-04
3581 KSP unpreconditioned resid norm 8.712485801065e+00 true resid norm 8.712485801070e+00 ||r(i)||/||b|| 2.081619144636e-04
3582 KSP unpreconditioned resid norm 8.712485801065e+00 true resid norm 8.712485801076e+00 ||r(i)||/||b|| 2.081619144638e-04
3583 KSP unpreconditioned resid norm 8.712485801065e+00 true resid norm 8.712485801064e+00 ||r(i)||/||b|| 2.081619144635e-04
3584 KSP unpreconditioned resid norm 8.712485801065e+00 true resid norm 8.712485801074e+00 ||r(i)||/||b|| 2.081619144637e-04
3585 KSP unpreconditioned resid norm 8.712485801065e+00 true resid norm 8.712485801068e+00 ||r(i)||/||b|| 2.081619144636e-04
3586 KSP unpreconditioned resid norm 8.712485801064e+00 true resid norm 8.712485801064e+00 ||r(i)||/||b|| 2.081619144635e-04
3587 KSP unpreconditioned resid norm 8.712485801064e+00 true resid norm 8.712485801068e+00 ||r(i)||/||b|| 2.081619144636e-04
3588 KSP unpreconditioned resid norm 8.712485801064e+00 true resid norm 8.712485801062e+00 ||r(i)||/||b|| 2.081619144635e-04
3589 KSP unpreconditioned resid norm 8.712485801064e+00 true resid norm 8.712485801068e+00 ||r(i)||/||b|| 2.081619144636e-04
3590 KSP unpreconditioned resid norm 8.712485801064e+00 true resid norm 8.712485801058e+00 ||r(i)||/||b|| 2.081619144634e-04
3591 KSP unpreconditioned resid norm 8.712485801064e+00 true resid norm 8.712485801064e+00 ||r(i)||/||b|| 2.081619144635e-04
3592 KSP unpreconditioned resid norm 8.712485801064e+00 true resid norm 8.712485801063e+00 ||r(i)||/||b|| 2.081619144635e-04
3593 KSP unpreconditioned resid norm 8.712485801063e+00 true resid norm 8.712485801062e+00 ||r(i)||/||b|| 2.081619144634e-04
3594 KSP unpreconditioned resid norm 8.712485801061e+00 true resid norm 8.712485801064e+00 ||r(i)||/||b|| 2.081619144635e-04
3595 KSP unpreconditioned resid norm 8.712485801060e+00 true resid norm 8.712485801076e+00 ||r(i)||/||b|| 2.081619144638e-04
3596 KSP unpreconditioned resid norm 8.712485801059e+00 true resid norm 8.712485801064e+00 ||r(i)||/||b|| 2.081619144635e-04
3597 KSP unpreconditioned resid norm 8.712485801057e+00 true resid norm 8.712485801061e+00 ||r(i)||/||b|| 2.081619144634e-04
3598 KSP unpreconditioned resid norm 8.712485801052e+00 true resid norm 8.712485801044e+00 ||r(i)||/||b|| 2.081619144630e-04
3599 KSP unpreconditioned resid norm 8.712485801049e+00 true resid norm 8.712485801041e+00 ||r(i)||/||b|| 2.081619144629e-04
3600 KSP unpreconditioned resid norm 8.712485801048e+00 true resid norm 8.712485801048e+00 ||r(i)||/||b|| 2.081619144631e-04
3601 KSP unpreconditioned resid norm 8.712485801048e+00 true resid norm 8.712485801051e+00 ||r(i)||/||b|| 2.081619144632e-04
3602 KSP unpreconditioned resid norm 8.712485801048e+00 true resid norm 8.712485801051e+00 ||r(i)||/||b|| 2.081619144632e-04
3603 KSP unpreconditioned resid norm 8.712485801048e+00 true resid norm 8.712485801041e+00 ||r(i)||/||b|| 2.081619144629e-04
3604 KSP unpreconditioned resid norm 8.712485801048e+00 true resid norm 8.712485801055e+00 ||r(i)||/||b|| 2.081619144633e-04
3605 KSP unpreconditioned resid norm 8.712485801048e+00 true resid norm 8.712485801060e+00 ||r(i)||/||b|| 2.081619144634e-04
3606 KSP unpreconditioned resid norm 8.712485801048e+00 true resid norm 8.712485801042e+00 ||r(i)||/||b|| 2.081619144630e-04
3607 KSP unpreconditioned resid norm 8.712485801048e+00 true resid norm 8.712485801061e+00 ||r(i)||/||b|| 2.081619144634e-04
3608 KSP unpreconditioned resid norm 8.712485801048e+00 true resid norm 8.712485801057e+00 ||r(i)||/||b|| 2.081619144633e-04
3609 KSP unpreconditioned resid norm 8.712485801048e+00 true resid norm 8.712485801050e+00 ||r(i)||/||b|| 2.081619144631e-04
3610 KSP unpreconditioned resid norm 8.712485801048e+00 true resid norm 8.712485801053e+00 ||r(i)||/||b|| 2.081619144632e-04
3611 KSP unpreconditioned resid norm 8.712485801048e+00 true resid norm 8.712485801049e+00 ||r(i)||/||b|| 2.081619144631e-04
3612 KSP unpreconditioned resid norm 8.712485801048e+00 true resid norm 8.712485801060e+00 ||r(i)||/||b|| 2.081619144634e-04
3613 KSP unpreconditioned resid norm 8.712485801048e+00 true resid norm 8.712485801054e+00 ||r(i)||/||b|| 2.081619144632e-04
3614 KSP unpreconditioned resid norm 8.712485801047e+00 true resid norm 8.712485801058e+00 ||r(i)||/||b|| 2.081619144633e-04
3615 KSP unpreconditioned resid norm 8.712485801047e+00 true resid norm 8.712485801050e+00 ||r(i)||/||b|| 2.081619144631e-04
3616 KSP unpreconditioned resid norm 8.712485801047e+00 true resid norm 8.712485801057e+00 ||r(i)||/||b|| 2.081619144633e-04
3617 KSP unpreconditioned resid norm 8.712485801047e+00 true resid norm 8.712485801055e+00 ||r(i)||/||b|| 2.081619144633e-04
3618 KSP unpreconditioned resid norm 8.712485801047e+00 true resid norm 8.712485801057e+00 ||r(i)||/||b|| 2.081619144633e-04
3619 KSP unpreconditioned resid norm 8.712485801046e+00 true resid norm 8.712485801053e+00 ||r(i)||/||b|| 2.081619144632e-04
3620 KSP unpreconditioned resid norm 8.712485801046e+00 true resid norm 8.712485801053e+00 ||r(i)||/||b|| 2.081619144632e-04
3621 KSP unpreconditioned resid norm 8.712485801046e+00 true resid norm 8.712485801054e+00 ||r(i)||/||b|| 2.081619144632e-04
3622 KSP unpreconditioned resid norm 8.712485801046e+00 true resid norm 8.712485801049e+00 ||r(i)||/||b|| 2.081619144631e-04
3623 KSP unpreconditioned resid norm 8.712485801045e+00 true resid norm 8.712485801041e+00 ||r(i)||/||b|| 2.081619144629e-04
3624 KSP unpreconditioned resid norm 8.712485801044e+00 true resid norm 8.712485801047e+00 ||r(i)||/||b|| 2.081619144631e-04
3625 KSP unpreconditioned resid norm 8.712485801043e+00 true resid norm 8.712485801057e+00 ||r(i)||/||b|| 2.081619144633e-04
3626 KSP unpreconditioned resid norm 8.712485801042e+00 true resid norm 8.712485801036e+00 ||r(i)||/||b|| 2.081619144628e-04
3627 KSP unpreconditioned resid norm 8.712485801040e+00 true resid norm 8.712485801042e+00 ||r(i)||/||b|| 2.081619144630e-04
3628 KSP unpreconditioned resid norm 8.712485801036e+00 true resid norm 8.712485801039e+00 ||r(i)||/||b|| 2.081619144629e-04
3629 KSP unpreconditioned resid norm 8.712485801034e+00 true resid norm 8.712485801033e+00 ||r(i)||/||b|| 2.081619144627e-04
3630 KSP unpreconditioned resid norm 8.712485801036e+00 true resid norm 8.712485801036e+00 ||r(i)||/||b|| 2.081619144628e-04
3631 KSP unpreconditioned resid norm 8.712485801036e+00 true resid norm 8.712485801039e+00 ||r(i)||/||b|| 2.081619144629e-04
3632 KSP unpreconditioned resid norm 8.712485801036e+00 true resid norm 8.712485801038e+00 ||r(i)||/||b|| 2.081619144629e-04
3633 KSP unpreconditioned resid norm 8.712485801036e+00 true resid norm 8.712485801039e+00 ||r(i)||/||b|| 2.081619144629e-04
3634 KSP unpreconditioned resid norm 8.712485801036e+00 true resid norm 8.712485801031e+00 ||r(i)||/||b|| 2.081619144627e-04
3635 KSP unpreconditioned resid norm 8.712485801036e+00 true resid norm 8.712485801033e+00 ||r(i)||/||b|| 2.081619144628e-04
3636 KSP unpreconditioned resid norm 8.712485801036e+00 true resid norm 8.712485801034e+00 ||r(i)||/||b|| 2.081619144628e-04
3637 KSP unpreconditioned resid norm 8.712485801036e+00 true resid norm 8.712485801031e+00 ||r(i)||/||b|| 2.081619144627e-04
3638 KSP unpreconditioned resid norm 8.712485801036e+00 true resid norm 8.712485801033e+00 ||r(i)||/||b|| 2.081619144628e-04
3639 KSP unpreconditioned resid norm 8.712485801035e+00 true resid norm 8.712485801034e+00 ||r(i)||/||b|| 2.081619144628e-04
3640 KSP unpreconditioned resid norm 8.712485801035e+00 true resid norm 8.712485801039e+00 ||r(i)||/||b|| 2.081619144629e-04
3641 KSP unpreconditioned resid norm 8.712485801035e+00 true resid norm 8.712485801029e+00 ||r(i)||/||b|| 2.081619144626e-04
3642 KSP unpreconditioned resid norm 8.712485801035e+00 true resid norm 8.712485801031e+00 ||r(i)||/||b|| 2.081619144627e-04
3643 KSP unpreconditioned resid norm 8.712485801035e+00 true resid norm 8.712485801042e+00 ||r(i)||/||b|| 2.081619144630e-04
3644 KSP unpreconditioned resid norm 8.712485801035e+00 true resid norm 8.712485801036e+00 ||r(i)||/||b|| 2.081619144628e-04
3645 KSP unpreconditioned resid norm 8.712485801035e+00 true resid norm 8.712485801033e+00 ||r(i)||/||b|| 2.081619144627e-04
3646 KSP unpreconditioned resid norm 8.712485801035e+00 true resid norm 8.712485801029e+00 ||r(i)||/||b|| 2.081619144626e-04
3647 KSP unpreconditioned resid norm 8.712485801035e+00 true resid norm 8.712485801027e+00 ||r(i)||/||b|| 2.081619144626e-04
3648 KSP unpreconditioned resid norm 8.712485801034e+00 true resid norm 8.712485801034e+00 ||r(i)||/||b|| 2.081619144628e-04
3649 KSP unpreconditioned resid norm 8.712485801034e+00 true resid norm 8.712485801024e+00 ||r(i)||/||b|| 2.081619144625e-04
3650 KSP unpreconditioned resid norm 8.712485801034e+00 true resid norm 8.712485801032e+00 ||r(i)||/||b|| 2.081619144627e-04
3651 KSP unpreconditioned resid norm 8.712485801034e+00 true resid norm 8.712485801037e+00 ||r(i)||/||b|| 2.081619144629e-04
3652 KSP unpreconditioned resid norm 8.712485801034e+00 true resid norm 8.712485801041e+00 ||r(i)||/||b|| 2.081619144629e-04
3653 KSP unpreconditioned resid norm 8.712485801033e+00 true resid norm 8.712485801026e+00 ||r(i)||/||b|| 2.081619144626e-04
3654 KSP unpreconditioned resid norm 8.712485801032e+00 true resid norm 8.712485801038e+00 ||r(i)||/||b|| 2.081619144629e-04
3655 KSP unpreconditioned resid norm 8.712485801031e+00 true resid norm 8.712485801030e+00 ||r(i)||/||b|| 2.081619144627e-04
3656 KSP unpreconditioned resid norm 8.712485801030e+00 true resid norm 8.712485801032e+00 ||r(i)||/||b|| 2.081619144627e-04
3657 KSP unpreconditioned resid norm 8.712485801029e+00 true resid norm 8.712485801039e+00 ||r(i)||/||b|| 2.081619144629e-04
3658 KSP unpreconditioned resid norm 8.712485801025e+00 true resid norm 8.712485801029e+00 ||r(i)||/||b|| 2.081619144627e-04
3659 KSP unpreconditioned resid norm 8.712485801023e+00 true resid norm 8.712485801026e+00 ||r(i)||/||b|| 2.081619144626e-04
3660 KSP unpreconditioned resid norm 8.712485801025e+00 true resid norm 8.712485801025e+00 ||r(i)||/||b|| 2.081619144626e-04
3661 KSP unpreconditioned resid norm 8.712485801025e+00 true resid norm 8.712485801021e+00 ||r(i)||/||b|| 2.081619144625e-04
3662 KSP unpreconditioned resid norm 8.712485801025e+00 true resid norm 8.712485801024e+00 ||r(i)||/||b|| 2.081619144625e-04
3663 KSP unpreconditioned resid norm 8.712485801025e+00 true resid norm 8.712485801026e+00 ||r(i)||/||b|| 2.081619144626e-04
3664 KSP unpreconditioned resid norm 8.712485801025e+00 true resid norm 8.712485801026e+00 ||r(i)||/||b|| 2.081619144626e-04
3665 KSP unpreconditioned resid norm 8.712485801025e+00 true resid norm 8.712485801029e+00 ||r(i)||/||b|| 2.081619144627e-04
3666 KSP unpreconditioned resid norm 8.712485801025e+00 true resid norm 8.712485801016e+00 ||r(i)||/||b|| 2.081619144623e-04
3667 KSP unpreconditioned resid norm 8.712485801025e+00 true resid norm 8.712485801023e+00 ||r(i)||/||b|| 2.081619144625e-04
3668 KSP unpreconditioned resid norm 8.712485801025e+00 true resid norm 8.712485801026e+00 ||r(i)||/||b|| 2.081619144626e-04
3669 KSP unpreconditioned resid norm 8.712485801025e+00 true resid norm 8.712485801025e+00 ||r(i)||/||b|| 2.081619144626e-04
3670 KSP unpreconditioned resid norm 8.712485801024e+00 true resid norm 8.712485801036e+00 ||r(i)||/||b|| 2.081619144628e-04
3671 KSP unpreconditioned resid norm 8.712485801024e+00 true resid norm 8.712485801037e+00 ||r(i)||/||b|| 2.081619144629e-04
3672 KSP unpreconditioned resid norm 8.712485801024e+00 true resid norm 8.712485801028e+00 ||r(i)||/||b|| 2.081619144626e-04
3673 KSP unpreconditioned resid norm 8.712485801024e+00 true resid norm 8.712485801023e+00 ||r(i)||/||b|| 2.081619144625e-04
3674 KSP unpreconditioned resid norm 8.712485801024e+00 true resid norm 8.712485801025e+00 ||r(i)||/||b|| 2.081619144626e-04
3675 KSP unpreconditioned resid norm 8.712485801024e+00 true resid norm 8.712485801026e+00 ||r(i)||/||b|| 2.081619144626e-04
3676 KSP unpreconditioned resid norm 8.712485801024e+00 true resid norm 8.712485801020e+00 ||r(i)||/||b|| 2.081619144624e-04
3677 KSP unpreconditioned resid norm 8.712485801024e+00 true resid norm 8.712485801018e+00 ||r(i)||/||b|| 2.081619144624e-04
3678 KSP unpreconditioned resid norm 8.712485801024e+00 true resid norm 8.712485801015e+00 ||r(i)||/||b|| 2.081619144623e-04
3679 KSP unpreconditioned resid norm 8.712485801023e+00 true resid norm 8.712485801025e+00 ||r(i)||/||b|| 2.081619144626e-04
3680 KSP unpreconditioned resid norm 8.712485801023e+00 true resid norm 8.712485801020e+00 ||r(i)||/||b|| 2.081619144624e-04
3681 KSP unpreconditioned resid norm 8.712485801023e+00 true resid norm 8.712485801028e+00 ||r(i)||/||b|| 2.081619144626e-04
3682 KSP unpreconditioned resid norm 8.712485801023e+00 true resid norm 8.712485801023e+00 ||r(i)||/||b|| 2.081619144625e-04
3683 KSP unpreconditioned resid norm 8.712485801023e+00 true resid norm 8.712485801019e+00 ||r(i)||/||b|| 2.081619144624e-04
3684 KSP unpreconditioned resid norm 8.712485801022e+00 true resid norm 8.712485801013e+00 ||r(i)||/||b|| 2.081619144623e-04
3685 KSP unpreconditioned resid norm 8.712485801021e+00 true resid norm 8.712485801017e+00 ||r(i)||/||b|| 2.081619144624e-04
3686 KSP unpreconditioned resid norm 8.712485801020e+00 true resid norm 8.712485801022e+00 ||r(i)||/||b|| 2.081619144625e-04
3687 KSP unpreconditioned resid norm 8.712485801019e+00 true resid norm 8.712485801023e+00 ||r(i)||/||b|| 2.081619144625e-04
3688 KSP unpreconditioned resid norm 8.712485801015e+00 true resid norm 8.712485801008e+00 ||r(i)||/||b|| 2.081619144622e-04
3689 KSP unpreconditioned resid norm 8.712485801013e+00 true resid norm 8.712485801007e+00 ||r(i)||/||b|| 2.081619144621e-04
3690 KSP unpreconditioned resid norm 8.712485801012e+00 true resid norm 8.712485801012e+00 ||r(i)||/||b|| 2.081619144623e-04
3691 KSP unpreconditioned resid norm 8.712485801012e+00 true resid norm 8.712485801010e+00 ||r(i)||/||b|| 2.081619144622e-04
3692 KSP unpreconditioned resid norm 8.712485801012e+00 true resid norm 8.712485801000e+00 ||r(i)||/||b|| 2.081619144620e-04
3693 KSP unpreconditioned resid norm 8.712485801012e+00 true resid norm 8.712485801014e+00 ||r(i)||/||b|| 2.081619144623e-04
3694 KSP unpreconditioned resid norm 8.712485801012e+00 true resid norm 8.712485801001e+00 ||r(i)||/||b|| 2.081619144620e-04
3695 KSP unpreconditioned resid norm 8.712485801012e+00 true resid norm 8.712485801011e+00 ||r(i)||/||b|| 2.081619144622e-04
3696 KSP unpreconditioned resid norm 8.712485801012e+00 true resid norm 8.712485801019e+00 ||r(i)||/||b|| 2.081619144624e-04
3697 KSP unpreconditioned resid norm 8.712485801012e+00 true resid norm 8.712485801009e+00 ||r(i)||/||b|| 2.081619144622e-04
3698 KSP unpreconditioned resid norm 8.712485801012e+00 true resid norm 8.712485801018e+00 ||r(i)||/||b|| 2.081619144624e-04
3699 KSP unpreconditioned resid norm 8.712485801012e+00 true resid norm 8.712485801011e+00 ||r(i)||/||b|| 2.081619144622e-04
3700 KSP unpreconditioned resid norm 8.712485801012e+00 true resid norm 8.712485801015e+00 ||r(i)||/||b|| 2.081619144623e-04
3701 KSP unpreconditioned resid norm 8.712485801012e+00 true resid norm 8.712485801005e+00 ||r(i)||/||b|| 2.081619144621e-04
3702 KSP unpreconditioned resid norm 8.712485801012e+00 true resid norm 8.712485801016e+00 ||r(i)||/||b|| 2.081619144623e-04
3703 KSP unpreconditioned resid norm 8.712485801012e+00 true resid norm 8.712485801015e+00 ||r(i)||/||b|| 2.081619144623e-04
3704 KSP unpreconditioned resid norm 8.712485801011e+00 true resid norm 8.712485801015e+00 ||r(i)||/||b|| 2.081619144623e-04
3705 KSP unpreconditioned resid norm 8.712485801011e+00 true resid norm 8.712485801011e+00 ||r(i)||/||b|| 2.081619144622e-04
3706 KSP unpreconditioned resid norm 8.712485801011e+00 true resid norm 8.712485801011e+00 ||r(i)||/||b|| 2.081619144622e-04
3707 KSP unpreconditioned resid norm 8.712485801011e+00 true resid norm 8.712485801012e+00 ||r(i)||/||b|| 2.081619144623e-04
3708 KSP unpreconditioned resid norm 8.712485801011e+00 true resid norm 8.712485801011e+00 ||r(i)||/||b|| 2.081619144622e-04
3709 KSP unpreconditioned resid norm 8.712485801011e+00 true resid norm 8.712485801017e+00 ||r(i)||/||b|| 2.081619144624e-04
3710 KSP unpreconditioned resid norm 8.712485801011e+00 true resid norm 8.712485801019e+00 ||r(i)||/||b|| 2.081619144624e-04
3711 KSP unpreconditioned resid norm 8.712485801011e+00 true resid norm 8.712485801004e+00 ||r(i)||/||b|| 2.081619144620e-04
3712 KSP unpreconditioned resid norm 8.712485801011e+00 true resid norm 8.712485801004e+00 ||r(i)||/||b|| 2.081619144621e-04
3713 KSP unpreconditioned resid norm 8.712485801010e+00 true resid norm 8.712485801012e+00 ||r(i)||/||b|| 2.081619144622e-04
3714 KSP unpreconditioned resid norm 8.712485801009e+00 true resid norm 8.712485801010e+00 ||r(i)||/||b|| 2.081619144622e-04
3715 KSP unpreconditioned resid norm 8.712485801009e+00 true resid norm 8.712485801012e+00 ||r(i)||/||b|| 2.081619144622e-04
3716 KSP unpreconditioned resid norm 8.712485801008e+00 true resid norm 8.712485801008e+00 ||r(i)||/||b|| 2.081619144622e-04
3717 KSP unpreconditioned resid norm 8.712485801007e+00 true resid norm 8.712485800998e+00 ||r(i)||/||b|| 2.081619144619e-04
3718 KSP unpreconditioned resid norm 8.712485801004e+00 true resid norm 8.712485801004e+00 ||r(i)||/||b|| 2.081619144621e-04
3719 KSP unpreconditioned resid norm 8.712485801002e+00 true resid norm 8.712485801003e+00 ||r(i)||/||b|| 2.081619144620e-04
3720 KSP unpreconditioned resid norm 8.712485800990e+00 true resid norm 8.712485800990e+00 ||r(i)||/||b|| 2.081619144617e-04
3721 KSP unpreconditioned resid norm 8.712485800990e+00 true resid norm 8.712485801004e+00 ||r(i)||/||b|| 2.081619144621e-04
3722 KSP unpreconditioned resid norm 8.712485800990e+00 true resid norm 8.712485800996e+00 ||r(i)||/||b|| 2.081619144619e-04
3723 KSP unpreconditioned resid norm 8.712485800990e+00 true resid norm 8.712485800998e+00 ||r(i)||/||b|| 2.081619144619e-04
3724 KSP unpreconditioned resid norm 8.712485800990e+00 true resid norm 8.712485800997e+00 ||r(i)||/||b|| 2.081619144619e-04
3725 KSP unpreconditioned resid norm 8.712485800990e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
3726 KSP unpreconditioned resid norm 8.712485800990e+00 true resid norm 8.712485800990e+00 ||r(i)||/||b|| 2.081619144617e-04
3727 KSP unpreconditioned resid norm 8.712485800990e+00 true resid norm 8.712485801003e+00 ||r(i)||/||b|| 2.081619144620e-04
3728 KSP unpreconditioned resid norm 8.712485800990e+00 true resid norm 8.712485800994e+00 ||r(i)||/||b|| 2.081619144618e-04
3729 KSP unpreconditioned resid norm 8.712485800990e+00 true resid norm 8.712485800996e+00 ||r(i)||/||b|| 2.081619144619e-04
3730 KSP unpreconditioned resid norm 8.712485800990e+00 true resid norm 8.712485800994e+00 ||r(i)||/||b|| 2.081619144618e-04
3731 KSP unpreconditioned resid norm 8.712485800990e+00 true resid norm 8.712485800995e+00 ||r(i)||/||b|| 2.081619144618e-04
3732 KSP unpreconditioned resid norm 8.712485800990e+00 true resid norm 8.712485800984e+00 ||r(i)||/||b|| 2.081619144616e-04
3733 KSP unpreconditioned resid norm 8.712485800990e+00 true resid norm 8.712485800990e+00 ||r(i)||/||b|| 2.081619144617e-04
3734 KSP unpreconditioned resid norm 8.712485800990e+00 true resid norm 8.712485800999e+00 ||r(i)||/||b|| 2.081619144619e-04
3735 KSP unpreconditioned resid norm 8.712485800989e+00 true resid norm 8.712485800994e+00 ||r(i)||/||b|| 2.081619144618e-04
3736 KSP unpreconditioned resid norm 8.712485800989e+00 true resid norm 8.712485800998e+00 ||r(i)||/||b|| 2.081619144619e-04
3737 KSP unpreconditioned resid norm 8.712485800989e+00 true resid norm 8.712485800997e+00 ||r(i)||/||b|| 2.081619144619e-04
3738 KSP unpreconditioned resid norm 8.712485800989e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
3739 KSP unpreconditioned resid norm 8.712485800989e+00 true resid norm 8.712485800997e+00 ||r(i)||/||b|| 2.081619144619e-04
3740 KSP unpreconditioned resid norm 8.712485800989e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
3741 KSP unpreconditioned resid norm 8.712485800989e+00 true resid norm 8.712485800998e+00 ||r(i)||/||b|| 2.081619144619e-04
3742 KSP unpreconditioned resid norm 8.712485800989e+00 true resid norm 8.712485800995e+00 ||r(i)||/||b|| 2.081619144618e-04
3743 KSP unpreconditioned resid norm 8.712485800988e+00 true resid norm 8.712485800989e+00 ||r(i)||/||b|| 2.081619144617e-04
3744 KSP unpreconditioned resid norm 8.712485800988e+00 true resid norm 8.712485801000e+00 ||r(i)||/||b|| 2.081619144620e-04
3745 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800985e+00 ||r(i)||/||b|| 2.081619144616e-04
3746 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800994e+00 ||r(i)||/||b|| 2.081619144618e-04
3747 KSP unpreconditioned resid norm 8.712485800985e+00 true resid norm 8.712485801000e+00 ||r(i)||/||b|| 2.081619144620e-04
3748 KSP unpreconditioned resid norm 8.712485800983e+00 true resid norm 8.712485801004e+00 ||r(i)||/||b|| 2.081619144621e-04
3749 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800983e+00 ||r(i)||/||b|| 2.081619144616e-04
3750 KSP unpreconditioned resid norm 8.712485801000e+00 true resid norm 8.712485801000e+00 ||r(i)||/||b|| 2.081619144620e-04
3751 KSP unpreconditioned resid norm 8.712485801000e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
3752 KSP unpreconditioned resid norm 8.712485801000e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
3753 KSP unpreconditioned resid norm 8.712485801000e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
3754 KSP unpreconditioned resid norm 8.712485801000e+00 true resid norm 8.712485801002e+00 ||r(i)||/||b|| 2.081619144620e-04
3755 KSP unpreconditioned resid norm 8.712485801000e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
3756 KSP unpreconditioned resid norm 8.712485801000e+00 true resid norm 8.712485800985e+00 ||r(i)||/||b|| 2.081619144616e-04
3757 KSP unpreconditioned resid norm 8.712485801000e+00 true resid norm 8.712485800999e+00 ||r(i)||/||b|| 2.081619144619e-04
3758 KSP unpreconditioned resid norm 8.712485801000e+00 true resid norm 8.712485800985e+00 ||r(i)||/||b|| 2.081619144616e-04
3759 KSP unpreconditioned resid norm 8.712485801000e+00 true resid norm 8.712485800998e+00 ||r(i)||/||b|| 2.081619144619e-04
3760 KSP unpreconditioned resid norm 8.712485801000e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
3761 KSP unpreconditioned resid norm 8.712485801000e+00 true resid norm 8.712485801000e+00 ||r(i)||/||b|| 2.081619144620e-04
3762 KSP unpreconditioned resid norm 8.712485801000e+00 true resid norm 8.712485800994e+00 ||r(i)||/||b|| 2.081619144618e-04
3763 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485800995e+00 ||r(i)||/||b|| 2.081619144618e-04
3764 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
3765 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485800983e+00 ||r(i)||/||b|| 2.081619144616e-04
3766 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
3767 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485800998e+00 ||r(i)||/||b|| 2.081619144619e-04
3768 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
3769 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
3770 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485801005e+00 ||r(i)||/||b|| 2.081619144621e-04
3771 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
3772 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485800985e+00 ||r(i)||/||b|| 2.081619144616e-04
3773 KSP unpreconditioned resid norm 8.712485800998e+00 true resid norm 8.712485800988e+00 ||r(i)||/||b|| 2.081619144617e-04
3774 KSP unpreconditioned resid norm 8.712485800998e+00 true resid norm 8.712485800996e+00 ||r(i)||/||b|| 2.081619144619e-04
3775 KSP unpreconditioned resid norm 8.712485800997e+00 true resid norm 8.712485800990e+00 ||r(i)||/||b|| 2.081619144617e-04
3776 KSP unpreconditioned resid norm 8.712485800996e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
3777 KSP unpreconditioned resid norm 8.712485800995e+00 true resid norm 8.712485800979e+00 ||r(i)||/||b|| 2.081619144615e-04
3778 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800991e+00 ||r(i)||/||b|| 2.081619144617e-04
3779 KSP unpreconditioned resid norm 8.712485800992e+00 true resid norm 8.712485800984e+00 ||r(i)||/||b|| 2.081619144616e-04
3780 KSP unpreconditioned resid norm 8.712485800984e+00 true resid norm 8.712485800984e+00 ||r(i)||/||b|| 2.081619144616e-04
3781 KSP unpreconditioned resid norm 8.712485800984e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
3782 KSP unpreconditioned resid norm 8.712485800984e+00 true resid norm 8.712485800979e+00 ||r(i)||/||b|| 2.081619144615e-04
3783 KSP unpreconditioned resid norm 8.712485800984e+00 true resid norm 8.712485800983e+00 ||r(i)||/||b|| 2.081619144616e-04
3784 KSP unpreconditioned resid norm 8.712485800984e+00 true resid norm 8.712485800984e+00 ||r(i)||/||b|| 2.081619144616e-04
3785 KSP unpreconditioned resid norm 8.712485800984e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
3786 KSP unpreconditioned resid norm 8.712485800984e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
3787 KSP unpreconditioned resid norm 8.712485800984e+00 true resid norm 8.712485800983e+00 ||r(i)||/||b|| 2.081619144615e-04
3788 KSP unpreconditioned resid norm 8.712485800984e+00 true resid norm 8.712485800989e+00 ||r(i)||/||b|| 2.081619144617e-04
3789 KSP unpreconditioned resid norm 8.712485800984e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
3790 KSP unpreconditioned resid norm 8.712485800983e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
3791 KSP unpreconditioned resid norm 8.712485800983e+00 true resid norm 8.712485800995e+00 ||r(i)||/||b|| 2.081619144618e-04
3792 KSP unpreconditioned resid norm 8.712485800983e+00 true resid norm 8.712485800982e+00 ||r(i)||/||b|| 2.081619144615e-04
3793 KSP unpreconditioned resid norm 8.712485800983e+00 true resid norm 8.712485800979e+00 ||r(i)||/||b|| 2.081619144615e-04
3794 KSP unpreconditioned resid norm 8.712485800983e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
3795 KSP unpreconditioned resid norm 8.712485800983e+00 true resid norm 8.712485800985e+00 ||r(i)||/||b|| 2.081619144616e-04
3796 KSP unpreconditioned resid norm 8.712485800983e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
3797 KSP unpreconditioned resid norm 8.712485800983e+00 true resid norm 8.712485800982e+00 ||r(i)||/||b|| 2.081619144615e-04
3798 KSP unpreconditioned resid norm 8.712485800983e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
3799 KSP unpreconditioned resid norm 8.712485800983e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
3800 KSP unpreconditioned resid norm 8.712485800983e+00 true resid norm 8.712485800983e+00 ||r(i)||/||b|| 2.081619144615e-04
3801 KSP unpreconditioned resid norm 8.712485800983e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
3802 KSP unpreconditioned resid norm 8.712485800983e+00 true resid norm 8.712485800984e+00 ||r(i)||/||b|| 2.081619144616e-04
3803 KSP unpreconditioned resid norm 8.712485800982e+00 true resid norm 8.712485800990e+00 ||r(i)||/||b|| 2.081619144617e-04
3804 KSP unpreconditioned resid norm 8.712485800982e+00 true resid norm 8.712485800983e+00 ||r(i)||/||b|| 2.081619144615e-04
3805 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
3806 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
3807 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
3808 KSP unpreconditioned resid norm 8.712485800978e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
3809 KSP unpreconditioned resid norm 8.712485800977e+00 true resid norm 8.712485800990e+00 ||r(i)||/||b|| 2.081619144617e-04
3810 KSP unpreconditioned resid norm 8.712485800979e+00 true resid norm 8.712485800979e+00 ||r(i)||/||b|| 2.081619144615e-04
3811 KSP unpreconditioned resid norm 8.712485800979e+00 true resid norm 8.712485800989e+00 ||r(i)||/||b|| 2.081619144617e-04
3812 KSP unpreconditioned resid norm 8.712485800979e+00 true resid norm 8.712485800983e+00 ||r(i)||/||b|| 2.081619144616e-04
3813 KSP unpreconditioned resid norm 8.712485800979e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
3814 KSP unpreconditioned resid norm 8.712485800979e+00 true resid norm 8.712485800976e+00 ||r(i)||/||b|| 2.081619144614e-04
3815 KSP unpreconditioned resid norm 8.712485800979e+00 true resid norm 8.712485800985e+00 ||r(i)||/||b|| 2.081619144616e-04
3816 KSP unpreconditioned resid norm 8.712485800979e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
3817 KSP unpreconditioned resid norm 8.712485800979e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
3818 KSP unpreconditioned resid norm 8.712485800979e+00 true resid norm 8.712485800982e+00 ||r(i)||/||b|| 2.081619144615e-04
3819 KSP unpreconditioned resid norm 8.712485800979e+00 true resid norm 8.712485800982e+00 ||r(i)||/||b|| 2.081619144615e-04
3820 KSP unpreconditioned resid norm 8.712485800979e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
3821 KSP unpreconditioned resid norm 8.712485800979e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
3822 KSP unpreconditioned resid norm 8.712485800979e+00 true resid norm 8.712485800982e+00 ||r(i)||/||b|| 2.081619144615e-04
3823 KSP unpreconditioned resid norm 8.712485800979e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
3824 KSP unpreconditioned resid norm 8.712485800979e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
3825 KSP unpreconditioned resid norm 8.712485800979e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
3826 KSP unpreconditioned resid norm 8.712485800979e+00 true resid norm 8.712485800984e+00 ||r(i)||/||b|| 2.081619144616e-04
3827 KSP unpreconditioned resid norm 8.712485800979e+00 true resid norm 8.712485800982e+00 ||r(i)||/||b|| 2.081619144615e-04
3828 KSP unpreconditioned resid norm 8.712485800979e+00 true resid norm 8.712485800971e+00 ||r(i)||/||b|| 2.081619144613e-04
3829 KSP unpreconditioned resid norm 8.712485800979e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
3830 KSP unpreconditioned resid norm 8.712485800979e+00 true resid norm 8.712485800984e+00 ||r(i)||/||b|| 2.081619144616e-04
3831 KSP unpreconditioned resid norm 8.712485800978e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
3832 KSP unpreconditioned resid norm 8.712485800978e+00 true resid norm 8.712485800991e+00 ||r(i)||/||b|| 2.081619144617e-04
3833 KSP unpreconditioned resid norm 8.712485800978e+00 true resid norm 8.712485800991e+00 ||r(i)||/||b|| 2.081619144617e-04
3834 KSP unpreconditioned resid norm 8.712485800978e+00 true resid norm 8.712485800972e+00 ||r(i)||/||b|| 2.081619144613e-04
3835 KSP unpreconditioned resid norm 8.712485800977e+00 true resid norm 8.712485800982e+00 ||r(i)||/||b|| 2.081619144615e-04
3836 KSP unpreconditioned resid norm 8.712485800977e+00 true resid norm 8.712485800982e+00 ||r(i)||/||b|| 2.081619144615e-04
3837 KSP unpreconditioned resid norm 8.712485800976e+00 true resid norm 8.712485800978e+00 ||r(i)||/||b|| 2.081619144614e-04
3838 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800983e+00 ||r(i)||/||b|| 2.081619144615e-04
3839 KSP unpreconditioned resid norm 8.712485800973e+00 true resid norm 8.712485800966e+00 ||r(i)||/||b|| 2.081619144611e-04
3840 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
3841 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800989e+00 ||r(i)||/||b|| 2.081619144617e-04
3842 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800978e+00 ||r(i)||/||b|| 2.081619144614e-04
3843 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800985e+00 ||r(i)||/||b|| 2.081619144616e-04
3844 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
3845 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800979e+00 ||r(i)||/||b|| 2.081619144615e-04
3846 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
3847 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800972e+00 ||r(i)||/||b|| 2.081619144613e-04
3848 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800976e+00 ||r(i)||/||b|| 2.081619144614e-04
3849 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
3850 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800971e+00 ||r(i)||/||b|| 2.081619144613e-04
3851 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
3852 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800978e+00 ||r(i)||/||b|| 2.081619144614e-04
3853 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800978e+00 ||r(i)||/||b|| 2.081619144614e-04
3854 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800983e+00 ||r(i)||/||b|| 2.081619144616e-04
3855 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800984e+00 ||r(i)||/||b|| 2.081619144616e-04
3856 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
3857 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
3858 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
3859 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800988e+00 ||r(i)||/||b|| 2.081619144617e-04
3860 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800976e+00 ||r(i)||/||b|| 2.081619144614e-04
3861 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800977e+00 ||r(i)||/||b|| 2.081619144614e-04
3862 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
3863 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800978e+00 ||r(i)||/||b|| 2.081619144614e-04
3864 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800984e+00 ||r(i)||/||b|| 2.081619144616e-04
3865 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800979e+00 ||r(i)||/||b|| 2.081619144615e-04
3866 KSP unpreconditioned resid norm 8.712485800973e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
3867 KSP unpreconditioned resid norm 8.712485800972e+00 true resid norm 8.712485800976e+00 ||r(i)||/||b|| 2.081619144614e-04
3868 KSP unpreconditioned resid norm 8.712485800971e+00 true resid norm 8.712485800979e+00 ||r(i)||/||b|| 2.081619144615e-04
3869 KSP unpreconditioned resid norm 8.712485800970e+00 true resid norm 8.712485800983e+00 ||r(i)||/||b|| 2.081619144616e-04
3870 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
3871 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800979e+00 ||r(i)||/||b|| 2.081619144615e-04
3872 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800977e+00 ||r(i)||/||b|| 2.081619144614e-04
3873 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
3874 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
3875 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800966e+00 ||r(i)||/||b|| 2.081619144612e-04
3876 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
3877 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800978e+00 ||r(i)||/||b|| 2.081619144614e-04
3878 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800970e+00 ||r(i)||/||b|| 2.081619144613e-04
3879 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
3880 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800976e+00 ||r(i)||/||b|| 2.081619144614e-04
3881 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800970e+00 ||r(i)||/||b|| 2.081619144612e-04
3882 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800979e+00 ||r(i)||/||b|| 2.081619144615e-04
3883 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
3884 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
3885 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
3886 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
3887 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
3888 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800971e+00 ||r(i)||/||b|| 2.081619144613e-04
3889 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800970e+00 ||r(i)||/||b|| 2.081619144612e-04
3890 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800966e+00 ||r(i)||/||b|| 2.081619144612e-04
3891 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
3892 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800964e+00 ||r(i)||/||b|| 2.081619144611e-04
3893 KSP unpreconditioned resid norm 8.712485800967e+00 true resid norm 8.712485800976e+00 ||r(i)||/||b|| 2.081619144614e-04
3894 KSP unpreconditioned resid norm 8.712485800967e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
3895 KSP unpreconditioned resid norm 8.712485800967e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
3896 KSP unpreconditioned resid norm 8.712485800966e+00 true resid norm 8.712485800976e+00 ||r(i)||/||b|| 2.081619144614e-04
3897 KSP unpreconditioned resid norm 8.712485800966e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
3898 KSP unpreconditioned resid norm 8.712485800964e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
3899 KSP unpreconditioned resid norm 8.712485800964e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
3900 KSP unpreconditioned resid norm 8.712485800970e+00 true resid norm 8.712485800970e+00 ||r(i)||/||b|| 2.081619144612e-04
3901 KSP unpreconditioned resid norm 8.712485800970e+00 true resid norm 8.712485800971e+00 ||r(i)||/||b|| 2.081619144613e-04
3902 KSP unpreconditioned resid norm 8.712485800970e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
3903 KSP unpreconditioned resid norm 8.712485800970e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
3904 KSP unpreconditioned resid norm 8.712485800970e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
3905 KSP unpreconditioned resid norm 8.712485800970e+00 true resid norm 8.712485800976e+00 ||r(i)||/||b|| 2.081619144614e-04
3906 KSP unpreconditioned resid norm 8.712485800970e+00 true resid norm 8.712485800972e+00 ||r(i)||/||b|| 2.081619144613e-04
3907 KSP unpreconditioned resid norm 8.712485800970e+00 true resid norm 8.712485800971e+00 ||r(i)||/||b|| 2.081619144613e-04
3908 KSP unpreconditioned resid norm 8.712485800970e+00 true resid norm 8.712485800977e+00 ||r(i)||/||b|| 2.081619144614e-04
3909 KSP unpreconditioned resid norm 8.712485800970e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
3910 KSP unpreconditioned resid norm 8.712485800970e+00 true resid norm 8.712485800970e+00 ||r(i)||/||b|| 2.081619144612e-04
3911 KSP unpreconditioned resid norm 8.712485800970e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
3912 KSP unpreconditioned resid norm 8.712485800970e+00 true resid norm 8.712485800971e+00 ||r(i)||/||b|| 2.081619144613e-04
3913 KSP unpreconditioned resid norm 8.712485800970e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
3914 KSP unpreconditioned resid norm 8.712485800969e+00 true resid norm 8.712485800966e+00 ||r(i)||/||b|| 2.081619144611e-04
3915 KSP unpreconditioned resid norm 8.712485800969e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
3916 KSP unpreconditioned resid norm 8.712485800969e+00 true resid norm 8.712485800971e+00 ||r(i)||/||b|| 2.081619144613e-04
3917 KSP unpreconditioned resid norm 8.712485800969e+00 true resid norm 8.712485800976e+00 ||r(i)||/||b|| 2.081619144614e-04
3918 KSP unpreconditioned resid norm 8.712485800969e+00 true resid norm 8.712485800971e+00 ||r(i)||/||b|| 2.081619144613e-04
3919 KSP unpreconditioned resid norm 8.712485800969e+00 true resid norm 8.712485800970e+00 ||r(i)||/||b|| 2.081619144612e-04
3920 KSP unpreconditioned resid norm 8.712485800969e+00 true resid norm 8.712485800972e+00 ||r(i)||/||b|| 2.081619144613e-04
3921 KSP unpreconditioned resid norm 8.712485800969e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
3922 KSP unpreconditioned resid norm 8.712485800969e+00 true resid norm 8.712485800966e+00 ||r(i)||/||b|| 2.081619144611e-04
3923 KSP unpreconditioned resid norm 8.712485800969e+00 true resid norm 8.712485800972e+00 ||r(i)||/||b|| 2.081619144613e-04
3924 KSP unpreconditioned resid norm 8.712485800969e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
3925 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800972e+00 ||r(i)||/||b|| 2.081619144613e-04
3926 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800982e+00 ||r(i)||/||b|| 2.081619144615e-04
3927 KSP unpreconditioned resid norm 8.712485800967e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
3928 KSP unpreconditioned resid norm 8.712485800966e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
3929 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
3930 KSP unpreconditioned resid norm 8.712485800972e+00 true resid norm 8.712485800972e+00 ||r(i)||/||b|| 2.081619144613e-04
3931 KSP unpreconditioned resid norm 8.712485800972e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
3932 KSP unpreconditioned resid norm 8.712485800972e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
3933 KSP unpreconditioned resid norm 8.712485800972e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
3934 KSP unpreconditioned resid norm 8.712485800972e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
3935 KSP unpreconditioned resid norm 8.712485800972e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
3936 KSP unpreconditioned resid norm 8.712485800972e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
3937 KSP unpreconditioned resid norm 8.712485800972e+00 true resid norm 8.712485800966e+00 ||r(i)||/||b|| 2.081619144611e-04
3938 KSP unpreconditioned resid norm 8.712485800972e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
3939 KSP unpreconditioned resid norm 8.712485800972e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
3940 KSP unpreconditioned resid norm 8.712485800972e+00 true resid norm 8.712485800964e+00 ||r(i)||/||b|| 2.081619144611e-04
3941 KSP unpreconditioned resid norm 8.712485800972e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
3942 KSP unpreconditioned resid norm 8.712485800972e+00 true resid norm 8.712485800972e+00 ||r(i)||/||b|| 2.081619144613e-04
3943 KSP unpreconditioned resid norm 8.712485800972e+00 true resid norm 8.712485800972e+00 ||r(i)||/||b|| 2.081619144613e-04
3944 KSP unpreconditioned resid norm 8.712485800972e+00 true resid norm 8.712485800966e+00 ||r(i)||/||b|| 2.081619144612e-04
3945 KSP unpreconditioned resid norm 8.712485800971e+00 true resid norm 8.712485800966e+00 ||r(i)||/||b|| 2.081619144611e-04
3946 KSP unpreconditioned resid norm 8.712485800971e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
3947 KSP unpreconditioned resid norm 8.712485800971e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
3948 KSP unpreconditioned resid norm 8.712485800971e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
3949 KSP unpreconditioned resid norm 8.712485800971e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
3950 KSP unpreconditioned resid norm 8.712485800971e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
3951 KSP unpreconditioned resid norm 8.712485800971e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
3952 KSP unpreconditioned resid norm 8.712485800971e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
3953 KSP unpreconditioned resid norm 8.712485800971e+00 true resid norm 8.712485800951e+00 ||r(i)||/||b|| 2.081619144608e-04
3954 KSP unpreconditioned resid norm 8.712485800971e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
3955 KSP unpreconditioned resid norm 8.712485800970e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
3956 KSP unpreconditioned resid norm 8.712485800970e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
3957 KSP unpreconditioned resid norm 8.712485800970e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144614e-04
3958 KSP unpreconditioned resid norm 8.712485800969e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
3959 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
3960 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
3961 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
3962 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800966e+00 ||r(i)||/||b|| 2.081619144612e-04
3963 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800966e+00 ||r(i)||/||b|| 2.081619144611e-04
3964 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
3965 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
3966 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800971e+00 ||r(i)||/||b|| 2.081619144613e-04
3967 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
3968 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
3969 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
3970 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
3971 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800970e+00 ||r(i)||/||b|| 2.081619144613e-04
3972 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800966e+00 ||r(i)||/||b|| 2.081619144612e-04
3973 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
3974 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
3975 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800970e+00 ||r(i)||/||b|| 2.081619144612e-04
3976 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
3977 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
3978 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
3979 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800972e+00 ||r(i)||/||b|| 2.081619144613e-04
3980 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
3981 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
3982 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
3983 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
3984 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800964e+00 ||r(i)||/||b|| 2.081619144611e-04
3985 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
3986 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
3987 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
3988 KSP unpreconditioned resid norm 8.712485800959e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
3989 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
3990 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
3991 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800964e+00 ||r(i)||/||b|| 2.081619144611e-04
3992 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
3993 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
3994 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
3995 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800966e+00 ||r(i)||/||b|| 2.081619144611e-04
3996 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
3997 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
3998 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
3999 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
4000 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4001 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
4002 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4003 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
4004 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800970e+00 ||r(i)||/||b|| 2.081619144612e-04
4005 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800971e+00 ||r(i)||/||b|| 2.081619144613e-04
4006 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
4007 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
4008 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
4009 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800971e+00 ||r(i)||/||b|| 2.081619144613e-04
4010 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
4011 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4012 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
4013 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
4014 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800977e+00 ||r(i)||/||b|| 2.081619144614e-04
4015 KSP unpreconditioned resid norm 8.712485800964e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
4016 KSP unpreconditioned resid norm 8.712485800964e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4017 KSP unpreconditioned resid norm 8.712485800964e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
4018 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4019 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
4020 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4021 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
4022 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4023 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4024 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
4025 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4026 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800971e+00 ||r(i)||/||b|| 2.081619144613e-04
4027 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
4028 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4029 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
4030 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
4031 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
4032 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800964e+00 ||r(i)||/||b|| 2.081619144611e-04
4033 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
4034 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
4035 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4036 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800966e+00 ||r(i)||/||b|| 2.081619144611e-04
4037 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
4038 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
4039 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
4040 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800964e+00 ||r(i)||/||b|| 2.081619144611e-04
4041 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
4042 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
4043 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4044 KSP unpreconditioned resid norm 8.712485800959e+00 true resid norm 8.712485800966e+00 ||r(i)||/||b|| 2.081619144612e-04
4045 KSP unpreconditioned resid norm 8.712485800959e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
4046 KSP unpreconditioned resid norm 8.712485800959e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
4047 KSP unpreconditioned resid norm 8.712485800959e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
4048 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
4049 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
4050 KSP unpreconditioned resid norm 8.712485800967e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
4051 KSP unpreconditioned resid norm 8.712485800967e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
4052 KSP unpreconditioned resid norm 8.712485800967e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
4053 KSP unpreconditioned resid norm 8.712485800967e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
4054 KSP unpreconditioned resid norm 8.712485800967e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4055 KSP unpreconditioned resid norm 8.712485800966e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
4056 KSP unpreconditioned resid norm 8.712485800966e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4057 KSP unpreconditioned resid norm 8.712485800966e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4058 KSP unpreconditioned resid norm 8.712485800966e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
4059 KSP unpreconditioned resid norm 8.712485800966e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
4060 KSP unpreconditioned resid norm 8.712485800966e+00 true resid norm 8.712485800970e+00 ||r(i)||/||b|| 2.081619144612e-04
4061 KSP unpreconditioned resid norm 8.712485800966e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
4062 KSP unpreconditioned resid norm 8.712485800966e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4063 KSP unpreconditioned resid norm 8.712485800966e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
4064 KSP unpreconditioned resid norm 8.712485800966e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4065 KSP unpreconditioned resid norm 8.712485800966e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
4066 KSP unpreconditioned resid norm 8.712485800966e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
4067 KSP unpreconditioned resid norm 8.712485800966e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
4068 KSP unpreconditioned resid norm 8.712485800966e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
4069 KSP unpreconditioned resid norm 8.712485800966e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
4070 KSP unpreconditioned resid norm 8.712485800966e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
4071 KSP unpreconditioned resid norm 8.712485800966e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
4072 KSP unpreconditioned resid norm 8.712485800966e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4073 KSP unpreconditioned resid norm 8.712485800966e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
4074 KSP unpreconditioned resid norm 8.712485800966e+00 true resid norm 8.712485800964e+00 ||r(i)||/||b|| 2.081619144611e-04
4075 KSP unpreconditioned resid norm 8.712485800966e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
4076 KSP unpreconditioned resid norm 8.712485800966e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
4077 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
4078 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
4079 KSP unpreconditioned resid norm 8.712485800964e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
4080 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
4081 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
4082 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
4083 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
4084 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
4085 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
4086 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
4087 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800964e+00 ||r(i)||/||b|| 2.081619144611e-04
4088 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4089 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4090 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800970e+00 ||r(i)||/||b|| 2.081619144612e-04
4091 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4092 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
4093 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800971e+00 ||r(i)||/||b|| 2.081619144613e-04
4094 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144607e-04
4095 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
4096 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4097 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
4098 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800964e+00 ||r(i)||/||b|| 2.081619144611e-04
4099 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800947e+00 ||r(i)||/||b|| 2.081619144607e-04
4100 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4101 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144609e-04
4102 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4103 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800966e+00 ||r(i)||/||b|| 2.081619144612e-04
4104 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
4105 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800964e+00 ||r(i)||/||b|| 2.081619144611e-04
4106 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
4107 KSP unpreconditioned resid norm 8.712485800959e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
4108 KSP unpreconditioned resid norm 8.712485800959e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4109 KSP unpreconditioned resid norm 8.712485800959e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4110 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
4111 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
4112 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
4113 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
4114 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
4115 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
4116 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
4117 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4118 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4119 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800964e+00 ||r(i)||/||b|| 2.081619144611e-04
4120 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800964e+00 ||r(i)||/||b|| 2.081619144611e-04
4121 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4122 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4123 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
4124 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
4125 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
4126 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800966e+00 ||r(i)||/||b|| 2.081619144612e-04
4127 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
4128 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
4129 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
4130 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
4131 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800966e+00 ||r(i)||/||b|| 2.081619144611e-04
4132 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
4133 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800966e+00 ||r(i)||/||b|| 2.081619144611e-04
4134 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4135 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
4136 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
4137 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4138 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4139 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
4140 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
4141 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4142 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
4143 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
4144 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800966e+00 ||r(i)||/||b|| 2.081619144612e-04
4145 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4146 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800964e+00 ||r(i)||/||b|| 2.081619144611e-04
4147 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800964e+00 ||r(i)||/||b|| 2.081619144611e-04
4148 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4149 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800976e+00 ||r(i)||/||b|| 2.081619144614e-04
4150 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
4151 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4152 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
4153 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4154 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
4155 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800979e+00 ||r(i)||/||b|| 2.081619144615e-04
4156 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
4157 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
4158 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4159 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4160 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
4161 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
4162 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
4163 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4164 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800951e+00 ||r(i)||/||b|| 2.081619144608e-04
4165 KSP unpreconditioned resid norm 8.712485800967e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
4166 KSP unpreconditioned resid norm 8.712485800967e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4167 KSP unpreconditioned resid norm 8.712485800967e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4168 KSP unpreconditioned resid norm 8.712485800967e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
4169 KSP unpreconditioned resid norm 8.712485800966e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
4170 KSP unpreconditioned resid norm 8.712485800959e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
4171 KSP unpreconditioned resid norm 8.712485800959e+00 true resid norm 8.712485800970e+00 ||r(i)||/||b|| 2.081619144613e-04
4172 KSP unpreconditioned resid norm 8.712485800959e+00 true resid norm 8.712485800970e+00 ||r(i)||/||b|| 2.081619144612e-04
4173 KSP unpreconditioned resid norm 8.712485800959e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
4174 KSP unpreconditioned resid norm 8.712485800959e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4175 KSP unpreconditioned resid norm 8.712485800959e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
4176 KSP unpreconditioned resid norm 8.712485800959e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
4177 KSP unpreconditioned resid norm 8.712485800959e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
4178 KSP unpreconditioned resid norm 8.712485800959e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
4179 KSP unpreconditioned resid norm 8.712485800959e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
4180 KSP unpreconditioned resid norm 8.712485800959e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4181 KSP unpreconditioned resid norm 8.712485800959e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
4182 KSP unpreconditioned resid norm 8.712485800959e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
4183 KSP unpreconditioned resid norm 8.712485800959e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
4184 KSP unpreconditioned resid norm 8.712485800959e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
4185 KSP unpreconditioned resid norm 8.712485800959e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4186 KSP unpreconditioned resid norm 8.712485800959e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
4187 KSP unpreconditioned resid norm 8.712485800959e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
4188 KSP unpreconditioned resid norm 8.712485800959e+00 true resid norm 8.712485800971e+00 ||r(i)||/||b|| 2.081619144613e-04
4189 KSP unpreconditioned resid norm 8.712485800959e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
4190 KSP unpreconditioned resid norm 8.712485800959e+00 true resid norm 8.712485800964e+00 ||r(i)||/||b|| 2.081619144611e-04
4191 KSP unpreconditioned resid norm 8.712485800959e+00 true resid norm 8.712485800972e+00 ||r(i)||/||b|| 2.081619144613e-04
4192 KSP unpreconditioned resid norm 8.712485800959e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
4193 KSP unpreconditioned resid norm 8.712485800959e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
4194 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4195 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4196 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4197 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800951e+00 ||r(i)||/||b|| 2.081619144608e-04
4198 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800966e+00 ||r(i)||/||b|| 2.081619144611e-04
4199 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
4200 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
4201 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
4202 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800972e+00 ||r(i)||/||b|| 2.081619144613e-04
4203 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
4204 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
4205 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4206 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
4207 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4208 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4209 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
4210 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800972e+00 ||r(i)||/||b|| 2.081619144613e-04
4211 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4212 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800947e+00 ||r(i)||/||b|| 2.081619144607e-04
4213 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
4214 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
4215 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
4216 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800951e+00 ||r(i)||/||b|| 2.081619144608e-04
4217 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
4218 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144609e-04
4219 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144609e-04
4220 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
4221 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
4222 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4223 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
4224 KSP unpreconditioned resid norm 8.712485800964e+00 true resid norm 8.712485800964e+00 ||r(i)||/||b|| 2.081619144611e-04
4225 KSP unpreconditioned resid norm 8.712485800964e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4226 KSP unpreconditioned resid norm 8.712485800964e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144607e-04
4227 KSP unpreconditioned resid norm 8.712485800964e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4228 KSP unpreconditioned resid norm 8.712485800964e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144607e-04
4229 KSP unpreconditioned resid norm 8.712485800964e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
4230 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
4231 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
4232 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
4233 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
4234 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
4235 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800951e+00 ||r(i)||/||b|| 2.081619144608e-04
4236 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
4237 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
4238 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4239 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
4240 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800966e+00 ||r(i)||/||b|| 2.081619144611e-04
4241 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
4242 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
4243 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
4244 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800964e+00 ||r(i)||/||b|| 2.081619144611e-04
4245 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
4246 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800971e+00 ||r(i)||/||b|| 2.081619144613e-04
4247 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4248 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800964e+00 ||r(i)||/||b|| 2.081619144611e-04
4249 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
4250 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
4251 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4252 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4253 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4254 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4255 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4256 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4257 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
4258 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
4259 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4260 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
4261 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
4262 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4263 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800971e+00 ||r(i)||/||b|| 2.081619144613e-04
4264 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800964e+00 ||r(i)||/||b|| 2.081619144611e-04
4265 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
4266 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800972e+00 ||r(i)||/||b|| 2.081619144613e-04
4267 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
4268 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
4269 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
4270 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800966e+00 ||r(i)||/||b|| 2.081619144611e-04
4271 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4272 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
4273 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800964e+00 ||r(i)||/||b|| 2.081619144611e-04
4274 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
4275 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
4276 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800970e+00 ||r(i)||/||b|| 2.081619144613e-04
4277 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800951e+00 ||r(i)||/||b|| 2.081619144608e-04
4278 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
4279 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
4280 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
4281 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4282 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
4283 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
4284 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
4285 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
4286 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4287 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144608e-04
4288 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4289 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800951e+00 ||r(i)||/||b|| 2.081619144608e-04
4290 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
4291 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
4292 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
4293 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
4294 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4295 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800951e+00 ||r(i)||/||b|| 2.081619144608e-04
4296 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4297 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
4298 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800964e+00 ||r(i)||/||b|| 2.081619144611e-04
4299 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
4300 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4301 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
4302 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
4303 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4304 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800966e+00 ||r(i)||/||b|| 2.081619144611e-04
4305 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4306 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
4307 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4308 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
4309 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
4310 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
4311 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
4312 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4313 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4314 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800948e+00 ||r(i)||/||b|| 2.081619144607e-04
4315 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
4316 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
4317 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4318 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
4319 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4320 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4321 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4322 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800945e+00 ||r(i)||/||b|| 2.081619144606e-04
4323 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
4324 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4325 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800951e+00 ||r(i)||/||b|| 2.081619144608e-04
4326 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800947e+00 ||r(i)||/||b|| 2.081619144607e-04
4327 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800947e+00 ||r(i)||/||b|| 2.081619144607e-04
4328 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800946e+00 ||r(i)||/||b|| 2.081619144607e-04
4329 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
4330 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
4331 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
4332 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
4333 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
4334 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4335 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4336 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
4337 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
4338 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144607e-04
4339 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4340 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
4341 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800946e+00 ||r(i)||/||b|| 2.081619144607e-04
4342 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800948e+00 ||r(i)||/||b|| 2.081619144607e-04
4343 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4344 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
4345 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4346 KSP unpreconditioned resid norm 8.712485800959e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
4347 KSP unpreconditioned resid norm 8.712485800959e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4348 KSP unpreconditioned resid norm 8.712485800959e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
4349 KSP unpreconditioned resid norm 8.712485800959e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4350 KSP unpreconditioned resid norm 8.712485800954e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4351 KSP unpreconditioned resid norm 8.712485800954e+00 true resid norm 8.712485800966e+00 ||r(i)||/||b|| 2.081619144611e-04
4352 KSP unpreconditioned resid norm 8.712485800954e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
4353 KSP unpreconditioned resid norm 8.712485800954e+00 true resid norm 8.712485800947e+00 ||r(i)||/||b|| 2.081619144607e-04
4354 KSP unpreconditioned resid norm 8.712485800954e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
4355 KSP unpreconditioned resid norm 8.712485800954e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4356 KSP unpreconditioned resid norm 8.712485800954e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4357 KSP unpreconditioned resid norm 8.712485800954e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
4358 KSP unpreconditioned resid norm 8.712485800954e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144607e-04
4359 KSP unpreconditioned resid norm 8.712485800954e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144609e-04
4360 KSP unpreconditioned resid norm 8.712485800954e+00 true resid norm 8.712485800942e+00 ||r(i)||/||b|| 2.081619144606e-04
4361 KSP unpreconditioned resid norm 8.712485800954e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4362 KSP unpreconditioned resid norm 8.712485800954e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
4363 KSP unpreconditioned resid norm 8.712485800954e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4364 KSP unpreconditioned resid norm 8.712485800954e+00 true resid norm 8.712485800948e+00 ||r(i)||/||b|| 2.081619144607e-04
4365 KSP unpreconditioned resid norm 8.712485800954e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4366 KSP unpreconditioned resid norm 8.712485800954e+00 true resid norm 8.712485800948e+00 ||r(i)||/||b|| 2.081619144607e-04
4367 KSP unpreconditioned resid norm 8.712485800954e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
4368 KSP unpreconditioned resid norm 8.712485800954e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
4369 KSP unpreconditioned resid norm 8.712485800954e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
4370 KSP unpreconditioned resid norm 8.712485800954e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
4371 KSP unpreconditioned resid norm 8.712485800954e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4372 KSP unpreconditioned resid norm 8.712485800954e+00 true resid norm 8.712485800951e+00 ||r(i)||/||b|| 2.081619144608e-04
4373 KSP unpreconditioned resid norm 8.712485800954e+00 true resid norm 8.712485800948e+00 ||r(i)||/||b|| 2.081619144607e-04
4374 KSP unpreconditioned resid norm 8.712485800954e+00 true resid norm 8.712485800951e+00 ||r(i)||/||b|| 2.081619144608e-04
4375 KSP unpreconditioned resid norm 8.712485800954e+00 true resid norm 8.712485800946e+00 ||r(i)||/||b|| 2.081619144607e-04
4376 KSP unpreconditioned resid norm 8.712485800954e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
4377 KSP unpreconditioned resid norm 8.712485800954e+00 true resid norm 8.712485800951e+00 ||r(i)||/||b|| 2.081619144608e-04
4378 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
4379 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800951e+00 ||r(i)||/||b|| 2.081619144608e-04
4380 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
4381 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4382 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144607e-04
4383 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800947e+00 ||r(i)||/||b|| 2.081619144607e-04
4384 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800946e+00 ||r(i)||/||b|| 2.081619144607e-04
4385 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4386 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800946e+00 ||r(i)||/||b|| 2.081619144607e-04
4387 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4388 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800946e+00 ||r(i)||/||b|| 2.081619144607e-04
4389 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800945e+00 ||r(i)||/||b|| 2.081619144607e-04
4390 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800947e+00 ||r(i)||/||b|| 2.081619144607e-04
4391 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
4392 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800951e+00 ||r(i)||/||b|| 2.081619144608e-04
4393 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
4394 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
4395 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
4396 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
4397 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800946e+00 ||r(i)||/||b|| 2.081619144607e-04
4398 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4399 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800944e+00 ||r(i)||/||b|| 2.081619144606e-04
4400 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800948e+00 ||r(i)||/||b|| 2.081619144607e-04
4401 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800942e+00 ||r(i)||/||b|| 2.081619144606e-04
4402 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
4403 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144607e-04
4404 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
4405 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800951e+00 ||r(i)||/||b|| 2.081619144608e-04
4406 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800947e+00 ||r(i)||/||b|| 2.081619144607e-04
4407 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4408 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
4409 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
4410 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
4411 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4412 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
4413 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
4414 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
4415 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4416 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
4417 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800948e+00 ||r(i)||/||b|| 2.081619144607e-04
4418 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800951e+00 ||r(i)||/||b|| 2.081619144608e-04
4419 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144607e-04
4420 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800951e+00 ||r(i)||/||b|| 2.081619144608e-04
4421 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
4422 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4423 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
4424 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144607e-04
4425 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
4426 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4427 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800946e+00 ||r(i)||/||b|| 2.081619144607e-04
4428 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4429 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
4430 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
4431 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800951e+00 ||r(i)||/||b|| 2.081619144608e-04
4432 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800947e+00 ||r(i)||/||b|| 2.081619144607e-04
4433 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
4434 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4435 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144607e-04
4436 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4437 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
4438 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
4439 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800948e+00 ||r(i)||/||b|| 2.081619144607e-04
4440 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4441 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4442 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4443 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
4444 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
4445 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4446 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800951e+00 ||r(i)||/||b|| 2.081619144608e-04
4447 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800943e+00 ||r(i)||/||b|| 2.081619144606e-04
4448 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800947e+00 ||r(i)||/||b|| 2.081619144607e-04
4449 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
4450 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
4451 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4452 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144607e-04
4453 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4454 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
4455 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800964e+00 ||r(i)||/||b|| 2.081619144611e-04
4456 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4457 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4458 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144607e-04
4459 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800951e+00 ||r(i)||/||b|| 2.081619144608e-04
4460 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800947e+00 ||r(i)||/||b|| 2.081619144607e-04
4461 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
4462 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4463 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
4464 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4465 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4466 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
4467 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
4468 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4469 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
4470 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4471 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800970e+00 ||r(i)||/||b|| 2.081619144612e-04
4472 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800948e+00 ||r(i)||/||b|| 2.081619144607e-04
4473 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
4474 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
4475 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800947e+00 ||r(i)||/||b|| 2.081619144607e-04
4476 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
4477 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4478 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
4479 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4480 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4481 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
4482 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4483 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4484 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
4485 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
4486 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144607e-04
4487 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800943e+00 ||r(i)||/||b|| 2.081619144606e-04
4488 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4489 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
4490 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
4491 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
4492 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
4493 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4494 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144607e-04
4495 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
4496 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4497 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4498 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800948e+00 ||r(i)||/||b|| 2.081619144607e-04
4499 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800951e+00 ||r(i)||/||b|| 2.081619144608e-04
4500 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
4501 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4502 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
4503 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
4504 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800964e+00 ||r(i)||/||b|| 2.081619144611e-04
4505 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4506 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4507 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
4508 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4509 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
4510 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
4511 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
4512 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4513 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
4514 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
4515 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
4516 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
4517 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4518 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
4519 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
4520 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
4521 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
4522 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
4523 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
4524 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
4525 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
4526 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4527 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4528 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
4529 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
4530 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144609e-04
4531 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800945e+00 ||r(i)||/||b|| 2.081619144607e-04
4532 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4533 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
4534 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4535 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4536 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4537 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4538 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
4539 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800947e+00 ||r(i)||/||b|| 2.081619144607e-04
4540 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800966e+00 ||r(i)||/||b|| 2.081619144611e-04
4541 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4542 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4543 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4544 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
4545 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
4546 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
4547 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
4548 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
4549 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
4550 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
4551 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800971e+00 ||r(i)||/||b|| 2.081619144613e-04
4552 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
4553 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
4554 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4555 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
4556 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
4557 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
4558 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4559 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
4560 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4561 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
4562 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800964e+00 ||r(i)||/||b|| 2.081619144611e-04
4563 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
4564 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800964e+00 ||r(i)||/||b|| 2.081619144611e-04
4565 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4566 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
4567 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800964e+00 ||r(i)||/||b|| 2.081619144611e-04
4568 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4569 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800977e+00 ||r(i)||/||b|| 2.081619144614e-04
4570 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
4571 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
4572 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800976e+00 ||r(i)||/||b|| 2.081619144614e-04
4573 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
4574 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800966e+00 ||r(i)||/||b|| 2.081619144611e-04
4575 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800971e+00 ||r(i)||/||b|| 2.081619144613e-04
4576 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
4577 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4578 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
4579 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
4580 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800964e+00 ||r(i)||/||b|| 2.081619144611e-04
4581 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800977e+00 ||r(i)||/||b|| 2.081619144614e-04
4582 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800972e+00 ||r(i)||/||b|| 2.081619144613e-04
4583 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4584 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800971e+00 ||r(i)||/||b|| 2.081619144613e-04
4585 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
4586 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4587 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
4588 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
4589 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
4590 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
4591 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
4592 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
4593 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
4594 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800971e+00 ||r(i)||/||b|| 2.081619144613e-04
4595 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
4596 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
4597 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4598 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4599 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800972e+00 ||r(i)||/||b|| 2.081619144613e-04
4600 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4601 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
4602 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800966e+00 ||r(i)||/||b|| 2.081619144612e-04
4603 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4604 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800964e+00 ||r(i)||/||b|| 2.081619144611e-04
4605 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4606 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
4607 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
4608 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
4609 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800966e+00 ||r(i)||/||b|| 2.081619144611e-04
4610 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
4611 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4612 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
4613 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
4614 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
4615 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4616 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
4617 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
4618 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
4619 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
4620 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4621 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4622 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4623 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4624 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
4625 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
4626 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4627 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
4628 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
4629 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
4630 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
4631 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
4632 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
4633 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4634 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
4635 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800972e+00 ||r(i)||/||b|| 2.081619144613e-04
4636 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
4637 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
4638 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
4639 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
4640 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
4641 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
4642 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
4643 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4644 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
4645 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
4646 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4647 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800966e+00 ||r(i)||/||b|| 2.081619144611e-04
4648 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
4649 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800972e+00 ||r(i)||/||b|| 2.081619144613e-04
4650 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800951e+00 ||r(i)||/||b|| 2.081619144608e-04
4651 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800944e+00 ||r(i)||/||b|| 2.081619144606e-04
4652 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
4653 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800947e+00 ||r(i)||/||b|| 2.081619144607e-04
4654 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
4655 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800943e+00 ||r(i)||/||b|| 2.081619144606e-04
4656 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4657 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4658 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
4659 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144608e-04
4660 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4661 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4662 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4663 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4664 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4665 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4666 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4667 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
4668 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4669 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
4670 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800947e+00 ||r(i)||/||b|| 2.081619144607e-04
4671 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4672 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800948e+00 ||r(i)||/||b|| 2.081619144607e-04
4673 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
4674 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800964e+00 ||r(i)||/||b|| 2.081619144611e-04
4675 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
4676 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
4677 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4678 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800947e+00 ||r(i)||/||b|| 2.081619144607e-04
4679 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144609e-04
4680 KSP unpreconditioned resid norm 8.712485800947e+00 true resid norm 8.712485800947e+00 ||r(i)||/||b|| 2.081619144607e-04
4681 KSP unpreconditioned resid norm 8.712485800947e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4682 KSP unpreconditioned resid norm 8.712485800947e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
4683 KSP unpreconditioned resid norm 8.712485800947e+00 true resid norm 8.712485800939e+00 ||r(i)||/||b|| 2.081619144605e-04
4684 KSP unpreconditioned resid norm 8.712485800947e+00 true resid norm 8.712485800941e+00 ||r(i)||/||b|| 2.081619144605e-04
4685 KSP unpreconditioned resid norm 8.712485800947e+00 true resid norm 8.712485800948e+00 ||r(i)||/||b|| 2.081619144607e-04
4686 KSP unpreconditioned resid norm 8.712485800947e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
4687 KSP unpreconditioned resid norm 8.712485800947e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
4688 KSP unpreconditioned resid norm 8.712485800947e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
4689 KSP unpreconditioned resid norm 8.712485800947e+00 true resid norm 8.712485800948e+00 ||r(i)||/||b|| 2.081619144607e-04
4690 KSP unpreconditioned resid norm 8.712485800947e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
4691 KSP unpreconditioned resid norm 8.712485800947e+00 true resid norm 8.712485800948e+00 ||r(i)||/||b|| 2.081619144607e-04
4692 KSP unpreconditioned resid norm 8.712485800947e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
4693 KSP unpreconditioned resid norm 8.712485800947e+00 true resid norm 8.712485800951e+00 ||r(i)||/||b|| 2.081619144608e-04
4694 KSP unpreconditioned resid norm 8.712485800947e+00 true resid norm 8.712485800944e+00 ||r(i)||/||b|| 2.081619144606e-04
4695 KSP unpreconditioned resid norm 8.712485800947e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
4696 KSP unpreconditioned resid norm 8.712485800947e+00 true resid norm 8.712485800941e+00 ||r(i)||/||b|| 2.081619144606e-04
4697 KSP unpreconditioned resid norm 8.712485800947e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
4698 KSP unpreconditioned resid norm 8.712485800947e+00 true resid norm 8.712485800935e+00 ||r(i)||/||b|| 2.081619144604e-04
4699 KSP unpreconditioned resid norm 8.712485800947e+00 true resid norm 8.712485800940e+00 ||r(i)||/||b|| 2.081619144605e-04
4700 KSP unpreconditioned resid norm 8.712485800947e+00 true resid norm 8.712485800951e+00 ||r(i)||/||b|| 2.081619144608e-04
4701 KSP unpreconditioned resid norm 8.712485800947e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144608e-04
4702 KSP unpreconditioned resid norm 8.712485800947e+00 true resid norm 8.712485800945e+00 ||r(i)||/||b|| 2.081619144607e-04
4703 KSP unpreconditioned resid norm 8.712485800947e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
4704 KSP unpreconditioned resid norm 8.712485800947e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4705 KSP unpreconditioned resid norm 8.712485800947e+00 true resid norm 8.712485800939e+00 ||r(i)||/||b|| 2.081619144605e-04
4706 KSP unpreconditioned resid norm 8.712485800947e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
4707 KSP unpreconditioned resid norm 8.712485800947e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
4708 KSP unpreconditioned resid norm 8.712485800947e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144607e-04
4709 KSP unpreconditioned resid norm 8.712485800947e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
4710 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800951e+00 ||r(i)||/||b|| 2.081619144608e-04
4711 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800945e+00 ||r(i)||/||b|| 2.081619144606e-04
4712 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800946e+00 ||r(i)||/||b|| 2.081619144607e-04
4713 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
4714 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800945e+00 ||r(i)||/||b|| 2.081619144606e-04
4715 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4716 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4717 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800942e+00 ||r(i)||/||b|| 2.081619144606e-04
4718 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4719 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4720 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4721 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
4722 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800948e+00 ||r(i)||/||b|| 2.081619144607e-04
4723 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144609e-04
4724 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800948e+00 ||r(i)||/||b|| 2.081619144607e-04
4725 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
4726 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4727 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4728 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800951e+00 ||r(i)||/||b|| 2.081619144608e-04
4729 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800951e+00 ||r(i)||/||b|| 2.081619144608e-04
4730 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800946e+00 ||r(i)||/||b|| 2.081619144607e-04
4731 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144607e-04
4732 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800946e+00 ||r(i)||/||b|| 2.081619144607e-04
4733 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144607e-04
4734 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4735 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4736 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4737 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4738 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800945e+00 ||r(i)||/||b|| 2.081619144606e-04
4739 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
4740 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
4741 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4742 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800964e+00 ||r(i)||/||b|| 2.081619144611e-04
4743 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4744 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
4745 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800971e+00 ||r(i)||/||b|| 2.081619144613e-04
4746 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4747 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
4748 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
4749 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4750 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800972e+00 ||r(i)||/||b|| 2.081619144613e-04
4751 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
4752 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4753 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
4754 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
4755 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4756 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800946e+00 ||r(i)||/||b|| 2.081619144607e-04
4757 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
4758 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4759 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4760 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4761 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4762 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4763 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
4764 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
4765 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
4766 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4767 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4768 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
4769 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
4770 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
4771 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
4772 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4773 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800966e+00 ||r(i)||/||b|| 2.081619144611e-04
4774 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4775 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4776 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
4777 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4778 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
4779 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
4780 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
4781 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
4782 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
4783 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4784 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
4785 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
4786 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
4787 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
4788 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800945e+00 ||r(i)||/||b|| 2.081619144607e-04
4789 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4790 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
4791 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
4792 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4793 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4794 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800951e+00 ||r(i)||/||b|| 2.081619144608e-04
4795 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4796 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4797 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
4798 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
4799 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
4800 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
4801 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
4802 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
4803 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
4804 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
4805 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800964e+00 ||r(i)||/||b|| 2.081619144611e-04
4806 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
4807 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
4808 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4809 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
4810 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4811 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
4812 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800948e+00 ||r(i)||/||b|| 2.081619144607e-04
4813 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
4814 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4815 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
4816 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4817 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4818 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144609e-04
4819 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
4820 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
4821 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
4822 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
4823 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4824 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4825 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
4826 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
4827 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4828 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
4829 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
4830 KSP unpreconditioned resid norm 8.712485800945e+00 true resid norm 8.712485800945e+00 ||r(i)||/||b|| 2.081619144606e-04
4831 KSP unpreconditioned resid norm 8.712485800945e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4832 KSP unpreconditioned resid norm 8.712485800945e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
4833 KSP unpreconditioned resid norm 8.712485800945e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4834 KSP unpreconditioned resid norm 8.712485800945e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144608e-04
4835 KSP unpreconditioned resid norm 8.712485800945e+00 true resid norm 8.712485800951e+00 ||r(i)||/||b|| 2.081619144608e-04
4836 KSP unpreconditioned resid norm 8.712485800945e+00 true resid norm 8.712485800947e+00 ||r(i)||/||b|| 2.081619144607e-04
4837 KSP unpreconditioned resid norm 8.712485800945e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4838 KSP unpreconditioned resid norm 8.712485800945e+00 true resid norm 8.712485800945e+00 ||r(i)||/||b|| 2.081619144607e-04
4839 KSP unpreconditioned resid norm 8.712485800945e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
4840 KSP unpreconditioned resid norm 8.712485800945e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
4841 KSP unpreconditioned resid norm 8.712485800945e+00 true resid norm 8.712485800944e+00 ||r(i)||/||b|| 2.081619144606e-04
4842 KSP unpreconditioned resid norm 8.712485800945e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
4843 KSP unpreconditioned resid norm 8.712485800945e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4844 KSP unpreconditioned resid norm 8.712485800945e+00 true resid norm 8.712485800944e+00 ||r(i)||/||b|| 2.081619144606e-04
4845 KSP unpreconditioned resid norm 8.712485800945e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
4846 KSP unpreconditioned resid norm 8.712485800945e+00 true resid norm 8.712485800946e+00 ||r(i)||/||b|| 2.081619144607e-04
4847 KSP unpreconditioned resid norm 8.712485800945e+00 true resid norm 8.712485800951e+00 ||r(i)||/||b|| 2.081619144608e-04
4848 KSP unpreconditioned resid norm 8.712485800945e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
4849 KSP unpreconditioned resid norm 8.712485800945e+00 true resid norm 8.712485800937e+00 ||r(i)||/||b|| 2.081619144605e-04
4850 KSP unpreconditioned resid norm 8.712485800945e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
4851 KSP unpreconditioned resid norm 8.712485800945e+00 true resid norm 8.712485800951e+00 ||r(i)||/||b|| 2.081619144608e-04
4852 KSP unpreconditioned resid norm 8.712485800945e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
4853 KSP unpreconditioned resid norm 8.712485800944e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
4854 KSP unpreconditioned resid norm 8.712485800944e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4855 KSP unpreconditioned resid norm 8.712485800944e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4856 KSP unpreconditioned resid norm 8.712485800944e+00 true resid norm 8.712485800946e+00 ||r(i)||/||b|| 2.081619144607e-04
4857 KSP unpreconditioned resid norm 8.712485800944e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
4858 KSP unpreconditioned resid norm 8.712485800944e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144607e-04
4859 KSP unpreconditioned resid norm 8.712485800944e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
4860 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
4861 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
4862 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800951e+00 ||r(i)||/||b|| 2.081619144608e-04
4863 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144607e-04
4864 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800948e+00 ||r(i)||/||b|| 2.081619144607e-04
4865 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800951e+00 ||r(i)||/||b|| 2.081619144608e-04
4866 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800938e+00 ||r(i)||/||b|| 2.081619144605e-04
4867 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800948e+00 ||r(i)||/||b|| 2.081619144607e-04
4868 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800964e+00 ||r(i)||/||b|| 2.081619144611e-04
4869 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
4870 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4871 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
4872 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4873 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4874 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4875 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4876 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
4877 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800946e+00 ||r(i)||/||b|| 2.081619144607e-04
4878 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
4879 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
4880 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800951e+00 ||r(i)||/||b|| 2.081619144608e-04
4881 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
4882 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800942e+00 ||r(i)||/||b|| 2.081619144606e-04
4883 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
4884 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
4885 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
4886 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800945e+00 ||r(i)||/||b|| 2.081619144606e-04
4887 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
4888 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
4889 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4890 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4891 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4892 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800970e+00 ||r(i)||/||b|| 2.081619144612e-04
4893 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4894 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4895 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800964e+00 ||r(i)||/||b|| 2.081619144611e-04
4896 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
4897 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
4898 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800951e+00 ||r(i)||/||b|| 2.081619144608e-04
4899 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4900 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800972e+00 ||r(i)||/||b|| 2.081619144613e-04
4901 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
4902 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144607e-04
4903 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
4904 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4905 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4906 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
4907 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800951e+00 ||r(i)||/||b|| 2.081619144608e-04
4908 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4909 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
4910 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
4911 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
4912 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4913 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4914 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800964e+00 ||r(i)||/||b|| 2.081619144611e-04
4915 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4916 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
4917 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4918 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
4919 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800964e+00 ||r(i)||/||b|| 2.081619144611e-04
4920 KSP unpreconditioned resid norm 8.712485800964e+00 true resid norm 8.712485800964e+00 ||r(i)||/||b|| 2.081619144611e-04
4921 KSP unpreconditioned resid norm 8.712485800964e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
4922 KSP unpreconditioned resid norm 8.712485800964e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4923 KSP unpreconditioned resid norm 8.712485800964e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4924 KSP unpreconditioned resid norm 8.712485800964e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4925 KSP unpreconditioned resid norm 8.712485800964e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
4926 KSP unpreconditioned resid norm 8.712485800964e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
4927 KSP unpreconditioned resid norm 8.712485800964e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4928 KSP unpreconditioned resid norm 8.712485800964e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4929 KSP unpreconditioned resid norm 8.712485800964e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4930 KSP unpreconditioned resid norm 8.712485800964e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4931 KSP unpreconditioned resid norm 8.712485800964e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4932 KSP unpreconditioned resid norm 8.712485800964e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4933 KSP unpreconditioned resid norm 8.712485800964e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
4934 KSP unpreconditioned resid norm 8.712485800964e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4935 KSP unpreconditioned resid norm 8.712485800964e+00 true resid norm 8.712485800951e+00 ||r(i)||/||b|| 2.081619144608e-04
4936 KSP unpreconditioned resid norm 8.712485800964e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
4937 KSP unpreconditioned resid norm 8.712485800964e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4938 KSP unpreconditioned resid norm 8.712485800964e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4939 KSP unpreconditioned resid norm 8.712485800964e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4940 KSP unpreconditioned resid norm 8.712485800964e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4941 KSP unpreconditioned resid norm 8.712485800964e+00 true resid norm 8.712485800951e+00 ||r(i)||/||b|| 2.081619144608e-04
4942 KSP unpreconditioned resid norm 8.712485800964e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144607e-04
4943 KSP unpreconditioned resid norm 8.712485800964e+00 true resid norm 8.712485800964e+00 ||r(i)||/||b|| 2.081619144611e-04
4944 KSP unpreconditioned resid norm 8.712485800964e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
4945 KSP unpreconditioned resid norm 8.712485800964e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4946 KSP unpreconditioned resid norm 8.712485800964e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4947 KSP unpreconditioned resid norm 8.712485800964e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4948 KSP unpreconditioned resid norm 8.712485800964e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
4949 KSP unpreconditioned resid norm 8.712485800964e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
4950 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
4951 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4952 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4953 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4954 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800948e+00 ||r(i)||/||b|| 2.081619144607e-04
4955 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800970e+00 ||r(i)||/||b|| 2.081619144612e-04
4956 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4957 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
4958 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
4959 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
4960 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4961 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4962 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
4963 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
4964 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
4965 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
4966 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
4967 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4968 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800971e+00 ||r(i)||/||b|| 2.081619144613e-04
4969 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
4970 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800964e+00 ||r(i)||/||b|| 2.081619144611e-04
4971 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4972 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
4973 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4974 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
4975 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
4976 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
4977 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4978 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
4979 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
4980 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
4981 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800964e+00 ||r(i)||/||b|| 2.081619144611e-04
4982 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800951e+00 ||r(i)||/||b|| 2.081619144608e-04
4983 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800947e+00 ||r(i)||/||b|| 2.081619144607e-04
4984 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4985 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
4986 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
4987 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
4988 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
4989 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
4990 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
4991 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
4992 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800947e+00 ||r(i)||/||b|| 2.081619144607e-04
4993 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
4994 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4995 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4996 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800943e+00 ||r(i)||/||b|| 2.081619144606e-04
4997 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4998 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144607e-04
4999 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800948e+00 ||r(i)||/||b|| 2.081619144607e-04
5000 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
5001 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
5002 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
5003 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800939e+00 ||r(i)||/||b|| 2.081619144605e-04
5004 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800948e+00 ||r(i)||/||b|| 2.081619144607e-04
5005 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800964e+00 ||r(i)||/||b|| 2.081619144611e-04
5006 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
5007 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
5008 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
5009 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
5010 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
5011 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
5012 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
5013 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800948e+00 ||r(i)||/||b|| 2.081619144607e-04
5014 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
5015 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
5016 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800946e+00 ||r(i)||/||b|| 2.081619144607e-04
5017 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
5018 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
5019 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
5020 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
5021 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
5022 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
5023 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
5024 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800946e+00 ||r(i)||/||b|| 2.081619144607e-04
5025 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144607e-04
5026 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
5027 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800943e+00 ||r(i)||/||b|| 2.081619144606e-04
5028 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
5029 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800948e+00 ||r(i)||/||b|| 2.081619144607e-04
5030 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
5031 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800946e+00 ||r(i)||/||b|| 2.081619144607e-04
5032 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
5033 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800951e+00 ||r(i)||/||b|| 2.081619144608e-04
5034 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
5035 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800945e+00 ||r(i)||/||b|| 2.081619144606e-04
5036 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
5037 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
5038 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
5039 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
5040 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800951e+00 ||r(i)||/||b|| 2.081619144608e-04
5041 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800951e+00 ||r(i)||/||b|| 2.081619144608e-04
5042 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
5043 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
5044 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
5045 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800943e+00 ||r(i)||/||b|| 2.081619144606e-04
5046 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
5047 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800947e+00 ||r(i)||/||b|| 2.081619144607e-04
5048 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800947e+00 ||r(i)||/||b|| 2.081619144607e-04
5049 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800951e+00 ||r(i)||/||b|| 2.081619144608e-04
5050 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
5051 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
5052 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
5053 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
5054 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
5055 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800964e+00 ||r(i)||/||b|| 2.081619144611e-04
5056 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
5057 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
5058 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
5059 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800948e+00 ||r(i)||/||b|| 2.081619144607e-04
5060 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
5061 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
5062 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
5063 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
5064 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
5065 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
5066 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
5067 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
5068 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800945e+00 ||r(i)||/||b|| 2.081619144606e-04
5069 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800947e+00 ||r(i)||/||b|| 2.081619144607e-04
5070 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
5071 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
5072 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
5073 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
5074 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
5075 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
5076 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800964e+00 ||r(i)||/||b|| 2.081619144611e-04
5077 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
5078 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
5079 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
5080 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800947e+00 ||r(i)||/||b|| 2.081619144607e-04
5081 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
5082 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
5083 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800966e+00 ||r(i)||/||b|| 2.081619144612e-04
5084 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
5085 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
5086 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
5087 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
5088 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
5089 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800947e+00 ||r(i)||/||b|| 2.081619144607e-04
5090 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800951e+00 ||r(i)||/||b|| 2.081619144608e-04
5091 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
5092 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
5093 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
5094 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800945e+00 ||r(i)||/||b|| 2.081619144606e-04
5095 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
5096 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
5097 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
5098 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
5099 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
5100 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
5101 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
5102 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
5103 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
5104 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
5105 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
5106 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
5107 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
5108 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
5109 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
5110 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800966e+00 ||r(i)||/||b|| 2.081619144612e-04
5111 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
5112 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800964e+00 ||r(i)||/||b|| 2.081619144611e-04
5113 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
5114 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
5115 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
5116 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
5117 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800971e+00 ||r(i)||/||b|| 2.081619144613e-04
5118 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
5119 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
5120 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
5121 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
5122 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
5123 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
5124 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
5125 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
5126 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
5127 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
5128 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
5129 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
5130 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
5131 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
5132 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
5133 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800966e+00 ||r(i)||/||b|| 2.081619144612e-04
5134 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800971e+00 ||r(i)||/||b|| 2.081619144613e-04
5135 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
5136 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
5137 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
5138 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144609e-04
5139 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
5140 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800964e+00 ||r(i)||/||b|| 2.081619144611e-04
5141 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
5142 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
5143 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
5144 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
5145 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
5146 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
5147 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800966e+00 ||r(i)||/||b|| 2.081619144611e-04
5148 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800966e+00 ||r(i)||/||b|| 2.081619144611e-04
5149 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800971e+00 ||r(i)||/||b|| 2.081619144613e-04
5150 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
5151 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
5152 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
5153 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144609e-04
5154 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
5155 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
5156 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800970e+00 ||r(i)||/||b|| 2.081619144612e-04
5157 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
5158 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
5159 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
5160 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
5161 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
5162 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
5163 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
5164 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
5165 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800972e+00 ||r(i)||/||b|| 2.081619144613e-04
5166 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
5167 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
5168 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
5169 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
5170 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
5171 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
5172 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800976e+00 ||r(i)||/||b|| 2.081619144614e-04
5173 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800971e+00 ||r(i)||/||b|| 2.081619144613e-04
5174 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800972e+00 ||r(i)||/||b|| 2.081619144613e-04
5175 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800977e+00 ||r(i)||/||b|| 2.081619144614e-04
5176 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800971e+00 ||r(i)||/||b|| 2.081619144613e-04
5177 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
5178 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
5179 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
5180 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
5181 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800966e+00 ||r(i)||/||b|| 2.081619144612e-04
5182 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
5183 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800964e+00 ||r(i)||/||b|| 2.081619144611e-04
5184 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800970e+00 ||r(i)||/||b|| 2.081619144612e-04
5185 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
5186 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
5187 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
5188 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
5189 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
5190 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
5191 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
5192 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
5193 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
5194 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800964e+00 ||r(i)||/||b|| 2.081619144611e-04
5195 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800984e+00 ||r(i)||/||b|| 2.081619144616e-04
5196 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
5197 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
5198 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800977e+00 ||r(i)||/||b|| 2.081619144614e-04
5199 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800970e+00 ||r(i)||/||b|| 2.081619144612e-04
5200 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800964e+00 ||r(i)||/||b|| 2.081619144611e-04
5201 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
5202 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
5203 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
5204 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800977e+00 ||r(i)||/||b|| 2.081619144614e-04
5205 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
5206 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
5207 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
5208 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800972e+00 ||r(i)||/||b|| 2.081619144613e-04
5209 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800964e+00 ||r(i)||/||b|| 2.081619144611e-04
5210 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
5211 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
5212 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
5213 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800966e+00 ||r(i)||/||b|| 2.081619144612e-04
5214 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800966e+00 ||r(i)||/||b|| 2.081619144612e-04
5215 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
5216 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144614e-04
5217 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
5218 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800966e+00 ||r(i)||/||b|| 2.081619144612e-04
5219 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
5220 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5221 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
5222 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
5223 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800976e+00 ||r(i)||/||b|| 2.081619144614e-04
5224 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800966e+00 ||r(i)||/||b|| 2.081619144612e-04
5225 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800983e+00 ||r(i)||/||b|| 2.081619144616e-04
5226 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
5227 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800970e+00 ||r(i)||/||b|| 2.081619144612e-04
5228 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800983e+00 ||r(i)||/||b|| 2.081619144616e-04
5229 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
5230 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
5231 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
5232 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
5233 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800977e+00 ||r(i)||/||b|| 2.081619144614e-04
5234 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800978e+00 ||r(i)||/||b|| 2.081619144614e-04
5235 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800977e+00 ||r(i)||/||b|| 2.081619144614e-04
5236 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
5237 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800972e+00 ||r(i)||/||b|| 2.081619144613e-04
5238 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
5239 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800966e+00 ||r(i)||/||b|| 2.081619144612e-04
5240 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5241 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800971e+00 ||r(i)||/||b|| 2.081619144613e-04
5242 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800970e+00 ||r(i)||/||b|| 2.081619144612e-04
5243 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800976e+00 ||r(i)||/||b|| 2.081619144614e-04
5244 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800971e+00 ||r(i)||/||b|| 2.081619144613e-04
5245 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800964e+00 ||r(i)||/||b|| 2.081619144611e-04
5246 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
5247 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
5248 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800972e+00 ||r(i)||/||b|| 2.081619144613e-04
5249 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
5250 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
5251 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
5252 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
5253 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800972e+00 ||r(i)||/||b|| 2.081619144613e-04
5254 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800970e+00 ||r(i)||/||b|| 2.081619144612e-04
5255 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800978e+00 ||r(i)||/||b|| 2.081619144614e-04
5256 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
5257 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
5258 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800977e+00 ||r(i)||/||b|| 2.081619144614e-04
5259 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800982e+00 ||r(i)||/||b|| 2.081619144615e-04
5260 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800970e+00 ||r(i)||/||b|| 2.081619144612e-04
5261 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5262 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800985e+00 ||r(i)||/||b|| 2.081619144616e-04
5263 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800977e+00 ||r(i)||/||b|| 2.081619144614e-04
5264 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800983e+00 ||r(i)||/||b|| 2.081619144616e-04
5265 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800971e+00 ||r(i)||/||b|| 2.081619144613e-04
5266 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800972e+00 ||r(i)||/||b|| 2.081619144613e-04
5267 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800971e+00 ||r(i)||/||b|| 2.081619144613e-04
5268 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800978e+00 ||r(i)||/||b|| 2.081619144614e-04
5269 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800982e+00 ||r(i)||/||b|| 2.081619144615e-04
5270 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
5271 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800971e+00 ||r(i)||/||b|| 2.081619144613e-04
5272 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800978e+00 ||r(i)||/||b|| 2.081619144614e-04
5273 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800979e+00 ||r(i)||/||b|| 2.081619144615e-04
5274 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800977e+00 ||r(i)||/||b|| 2.081619144614e-04
5275 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800979e+00 ||r(i)||/||b|| 2.081619144615e-04
5276 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
5277 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
5278 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800982e+00 ||r(i)||/||b|| 2.081619144615e-04
5279 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
5280 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
5281 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
5282 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
5283 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800982e+00 ||r(i)||/||b|| 2.081619144615e-04
5284 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800978e+00 ||r(i)||/||b|| 2.081619144614e-04
5285 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800983e+00 ||r(i)||/||b|| 2.081619144616e-04
5286 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
5287 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
5288 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800984e+00 ||r(i)||/||b|| 2.081619144616e-04
5289 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800990e+00 ||r(i)||/||b|| 2.081619144617e-04
5290 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800985e+00 ||r(i)||/||b|| 2.081619144616e-04
5291 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5292 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
5293 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800984e+00 ||r(i)||/||b|| 2.081619144616e-04
5294 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800983e+00 ||r(i)||/||b|| 2.081619144616e-04
5295 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800978e+00 ||r(i)||/||b|| 2.081619144614e-04
5296 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800970e+00 ||r(i)||/||b|| 2.081619144613e-04
5297 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800990e+00 ||r(i)||/||b|| 2.081619144617e-04
5298 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800982e+00 ||r(i)||/||b|| 2.081619144615e-04
5299 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800984e+00 ||r(i)||/||b|| 2.081619144616e-04
5300 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5301 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800995e+00 ||r(i)||/||b|| 2.081619144618e-04
5302 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800976e+00 ||r(i)||/||b|| 2.081619144614e-04
5303 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
5304 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800984e+00 ||r(i)||/||b|| 2.081619144616e-04
5305 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
5306 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
5307 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800984e+00 ||r(i)||/||b|| 2.081619144616e-04
5308 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5309 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800985e+00 ||r(i)||/||b|| 2.081619144616e-04
5310 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
5311 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5312 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5313 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800985e+00 ||r(i)||/||b|| 2.081619144616e-04
5314 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800982e+00 ||r(i)||/||b|| 2.081619144615e-04
5315 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800984e+00 ||r(i)||/||b|| 2.081619144616e-04
5316 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
5317 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800985e+00 ||r(i)||/||b|| 2.081619144616e-04
5318 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800976e+00 ||r(i)||/||b|| 2.081619144614e-04
5319 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800982e+00 ||r(i)||/||b|| 2.081619144615e-04
5320 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800982e+00 ||r(i)||/||b|| 2.081619144615e-04
5321 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800985e+00 ||r(i)||/||b|| 2.081619144616e-04
5322 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
5323 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800982e+00 ||r(i)||/||b|| 2.081619144615e-04
5324 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800989e+00 ||r(i)||/||b|| 2.081619144617e-04
5325 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800971e+00 ||r(i)||/||b|| 2.081619144613e-04
5326 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800984e+00 ||r(i)||/||b|| 2.081619144616e-04
5327 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800970e+00 ||r(i)||/||b|| 2.081619144613e-04
5328 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800978e+00 ||r(i)||/||b|| 2.081619144614e-04
5329 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800982e+00 ||r(i)||/||b|| 2.081619144615e-04
5330 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
5331 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800984e+00 ||r(i)||/||b|| 2.081619144616e-04
5332 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800978e+00 ||r(i)||/||b|| 2.081619144614e-04
5333 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
5334 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800976e+00 ||r(i)||/||b|| 2.081619144614e-04
5335 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
5336 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800985e+00 ||r(i)||/||b|| 2.081619144616e-04
5337 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800983e+00 ||r(i)||/||b|| 2.081619144616e-04
5338 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5339 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
5340 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
5341 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
5342 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
5343 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
5344 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800985e+00 ||r(i)||/||b|| 2.081619144616e-04
5345 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800976e+00 ||r(i)||/||b|| 2.081619144614e-04
5346 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
5347 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
5348 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800984e+00 ||r(i)||/||b|| 2.081619144616e-04
5349 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800984e+00 ||r(i)||/||b|| 2.081619144616e-04
5350 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800985e+00 ||r(i)||/||b|| 2.081619144616e-04
5351 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
5352 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
5353 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800978e+00 ||r(i)||/||b|| 2.081619144614e-04
5354 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800977e+00 ||r(i)||/||b|| 2.081619144614e-04
5355 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800977e+00 ||r(i)||/||b|| 2.081619144614e-04
5356 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800982e+00 ||r(i)||/||b|| 2.081619144615e-04
5357 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800990e+00 ||r(i)||/||b|| 2.081619144617e-04
5358 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800988e+00 ||r(i)||/||b|| 2.081619144617e-04
5359 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800979e+00 ||r(i)||/||b|| 2.081619144615e-04
5360 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
5361 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800976e+00 ||r(i)||/||b|| 2.081619144614e-04
5362 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800989e+00 ||r(i)||/||b|| 2.081619144617e-04
5363 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5364 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800991e+00 ||r(i)||/||b|| 2.081619144617e-04
5365 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
5366 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800988e+00 ||r(i)||/||b|| 2.081619144617e-04
5367 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800970e+00 ||r(i)||/||b|| 2.081619144612e-04
5368 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800976e+00 ||r(i)||/||b|| 2.081619144614e-04
5369 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800979e+00 ||r(i)||/||b|| 2.081619144615e-04
5370 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5371 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5372 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5373 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
5374 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
5375 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800984e+00 ||r(i)||/||b|| 2.081619144616e-04
5376 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
5377 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800979e+00 ||r(i)||/||b|| 2.081619144615e-04
5378 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800976e+00 ||r(i)||/||b|| 2.081619144614e-04
5379 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800971e+00 ||r(i)||/||b|| 2.081619144613e-04
5380 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800982e+00 ||r(i)||/||b|| 2.081619144615e-04
5381 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
5382 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800979e+00 ||r(i)||/||b|| 2.081619144615e-04
5383 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800976e+00 ||r(i)||/||b|| 2.081619144614e-04
5384 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800972e+00 ||r(i)||/||b|| 2.081619144613e-04
5385 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800976e+00 ||r(i)||/||b|| 2.081619144614e-04
5386 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800972e+00 ||r(i)||/||b|| 2.081619144613e-04
5387 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800976e+00 ||r(i)||/||b|| 2.081619144614e-04
5388 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800978e+00 ||r(i)||/||b|| 2.081619144614e-04
5389 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
5390 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5391 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800984e+00 ||r(i)||/||b|| 2.081619144616e-04
5392 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800983e+00 ||r(i)||/||b|| 2.081619144616e-04
5393 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
5394 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
5395 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
5396 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800978e+00 ||r(i)||/||b|| 2.081619144614e-04
5397 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800979e+00 ||r(i)||/||b|| 2.081619144615e-04
5398 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800977e+00 ||r(i)||/||b|| 2.081619144614e-04
5399 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800982e+00 ||r(i)||/||b|| 2.081619144615e-04
5400 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5401 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
5402 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5403 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800982e+00 ||r(i)||/||b|| 2.081619144615e-04
5404 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800985e+00 ||r(i)||/||b|| 2.081619144616e-04
5405 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800977e+00 ||r(i)||/||b|| 2.081619144614e-04
5406 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5407 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
5408 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800985e+00 ||r(i)||/||b|| 2.081619144616e-04
5409 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800984e+00 ||r(i)||/||b|| 2.081619144616e-04
5410 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800979e+00 ||r(i)||/||b|| 2.081619144615e-04
5411 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
5412 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
5413 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
5414 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800989e+00 ||r(i)||/||b|| 2.081619144617e-04
5415 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800990e+00 ||r(i)||/||b|| 2.081619144617e-04
5416 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800982e+00 ||r(i)||/||b|| 2.081619144615e-04
5417 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800984e+00 ||r(i)||/||b|| 2.081619144616e-04
5418 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800994e+00 ||r(i)||/||b|| 2.081619144618e-04
5419 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800985e+00 ||r(i)||/||b|| 2.081619144616e-04
5420 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
5421 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800982e+00 ||r(i)||/||b|| 2.081619144615e-04
5422 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800983e+00 ||r(i)||/||b|| 2.081619144616e-04
5423 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800979e+00 ||r(i)||/||b|| 2.081619144615e-04
5424 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
5425 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
5426 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800976e+00 ||r(i)||/||b|| 2.081619144614e-04
5427 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
5428 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800978e+00 ||r(i)||/||b|| 2.081619144614e-04
5429 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800978e+00 ||r(i)||/||b|| 2.081619144614e-04
5430 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5431 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5432 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
5433 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800979e+00 ||r(i)||/||b|| 2.081619144615e-04
5434 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
5435 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800985e+00 ||r(i)||/||b|| 2.081619144616e-04
5436 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
5437 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800979e+00 ||r(i)||/||b|| 2.081619144615e-04
5438 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800994e+00 ||r(i)||/||b|| 2.081619144618e-04
5439 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800983e+00 ||r(i)||/||b|| 2.081619144616e-04
5440 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
5441 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
5442 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
5443 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800982e+00 ||r(i)||/||b|| 2.081619144615e-04
5444 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800978e+00 ||r(i)||/||b|| 2.081619144614e-04
5445 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800976e+00 ||r(i)||/||b|| 2.081619144614e-04
5446 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800978e+00 ||r(i)||/||b|| 2.081619144614e-04
5447 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800982e+00 ||r(i)||/||b|| 2.081619144615e-04
5448 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800979e+00 ||r(i)||/||b|| 2.081619144615e-04
5449 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
5450 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5451 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800978e+00 ||r(i)||/||b|| 2.081619144614e-04
5452 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800983e+00 ||r(i)||/||b|| 2.081619144616e-04
5453 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
5454 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5455 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
5456 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800978e+00 ||r(i)||/||b|| 2.081619144614e-04
5457 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
5458 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800988e+00 ||r(i)||/||b|| 2.081619144617e-04
5459 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800970e+00 ||r(i)||/||b|| 2.081619144613e-04
5460 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5461 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5462 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5463 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
5464 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800979e+00 ||r(i)||/||b|| 2.081619144615e-04
5465 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800982e+00 ||r(i)||/||b|| 2.081619144615e-04
5466 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
5467 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
5468 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800979e+00 ||r(i)||/||b|| 2.081619144615e-04
5469 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800983e+00 ||r(i)||/||b|| 2.081619144616e-04
5470 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
5471 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
5472 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
5473 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800979e+00 ||r(i)||/||b|| 2.081619144615e-04
5474 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800982e+00 ||r(i)||/||b|| 2.081619144615e-04
5475 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800985e+00 ||r(i)||/||b|| 2.081619144616e-04
5476 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
5477 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
5478 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800982e+00 ||r(i)||/||b|| 2.081619144615e-04
5479 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
5480 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5481 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800976e+00 ||r(i)||/||b|| 2.081619144614e-04
5482 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800977e+00 ||r(i)||/||b|| 2.081619144614e-04
5483 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800979e+00 ||r(i)||/||b|| 2.081619144615e-04
5484 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
5485 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800985e+00 ||r(i)||/||b|| 2.081619144616e-04
5486 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800989e+00 ||r(i)||/||b|| 2.081619144617e-04
5487 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
5488 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800985e+00 ||r(i)||/||b|| 2.081619144616e-04
5489 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800978e+00 ||r(i)||/||b|| 2.081619144614e-04
5490 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
5491 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
5492 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
5493 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
5494 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
5495 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
5496 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
5497 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
5498 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800970e+00 ||r(i)||/||b|| 2.081619144612e-04
5499 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800983e+00 ||r(i)||/||b|| 2.081619144616e-04
5500 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
5501 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
5502 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
5503 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800976e+00 ||r(i)||/||b|| 2.081619144614e-04
5504 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
5505 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800976e+00 ||r(i)||/||b|| 2.081619144614e-04
5506 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
5507 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800970e+00 ||r(i)||/||b|| 2.081619144612e-04
5508 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
5509 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
5510 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5511 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
5512 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800983e+00 ||r(i)||/||b|| 2.081619144616e-04
5513 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800970e+00 ||r(i)||/||b|| 2.081619144612e-04
5514 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
5515 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800976e+00 ||r(i)||/||b|| 2.081619144614e-04
5516 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800984e+00 ||r(i)||/||b|| 2.081619144616e-04
5517 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800982e+00 ||r(i)||/||b|| 2.081619144615e-04
5518 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
5519 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800971e+00 ||r(i)||/||b|| 2.081619144613e-04
5520 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5521 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
5522 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
5523 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
5524 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800985e+00 ||r(i)||/||b|| 2.081619144616e-04
5525 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800982e+00 ||r(i)||/||b|| 2.081619144615e-04
5526 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5527 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
5528 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800972e+00 ||r(i)||/||b|| 2.081619144613e-04
5529 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800983e+00 ||r(i)||/||b|| 2.081619144616e-04
5530 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
5531 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5532 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
5533 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
5534 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800970e+00 ||r(i)||/||b|| 2.081619144612e-04
5535 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800978e+00 ||r(i)||/||b|| 2.081619144614e-04
5536 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
5537 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800985e+00 ||r(i)||/||b|| 2.081619144616e-04
5538 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800982e+00 ||r(i)||/||b|| 2.081619144615e-04
5539 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
5540 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5541 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800976e+00 ||r(i)||/||b|| 2.081619144614e-04
5542 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800972e+00 ||r(i)||/||b|| 2.081619144613e-04
5543 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800972e+00 ||r(i)||/||b|| 2.081619144613e-04
5544 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
5545 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
5546 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800977e+00 ||r(i)||/||b|| 2.081619144614e-04
5547 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800978e+00 ||r(i)||/||b|| 2.081619144614e-04
5548 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
5549 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800978e+00 ||r(i)||/||b|| 2.081619144614e-04
5550 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
5551 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5552 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5553 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
5554 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
5555 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800985e+00 ||r(i)||/||b|| 2.081619144616e-04
5556 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5557 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
5558 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800970e+00 ||r(i)||/||b|| 2.081619144612e-04
5559 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800984e+00 ||r(i)||/||b|| 2.081619144616e-04
5560 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
5561 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
5562 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
5563 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
5564 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
5565 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800976e+00 ||r(i)||/||b|| 2.081619144614e-04
5566 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800979e+00 ||r(i)||/||b|| 2.081619144615e-04
5567 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800970e+00 ||r(i)||/||b|| 2.081619144612e-04
5568 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
5569 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
5570 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5571 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800979e+00 ||r(i)||/||b|| 2.081619144615e-04
5572 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800983e+00 ||r(i)||/||b|| 2.081619144616e-04
5573 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800983e+00 ||r(i)||/||b|| 2.081619144615e-04
5574 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800985e+00 ||r(i)||/||b|| 2.081619144616e-04
5575 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800971e+00 ||r(i)||/||b|| 2.081619144613e-04
5576 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800983e+00 ||r(i)||/||b|| 2.081619144616e-04
5577 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800977e+00 ||r(i)||/||b|| 2.081619144614e-04
5578 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800979e+00 ||r(i)||/||b|| 2.081619144615e-04
5579 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800971e+00 ||r(i)||/||b|| 2.081619144613e-04
5580 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
5581 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
5582 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5583 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
5584 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5585 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800976e+00 ||r(i)||/||b|| 2.081619144614e-04
5586 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5587 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
5588 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800979e+00 ||r(i)||/||b|| 2.081619144615e-04
5589 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800977e+00 ||r(i)||/||b|| 2.081619144614e-04
5590 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5591 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
5592 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
5593 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800985e+00 ||r(i)||/||b|| 2.081619144616e-04
5594 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800982e+00 ||r(i)||/||b|| 2.081619144615e-04
5595 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
5596 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800982e+00 ||r(i)||/||b|| 2.081619144615e-04
5597 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
5598 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
5599 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
5600 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144614e-04
5601 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800982e+00 ||r(i)||/||b|| 2.081619144615e-04
5602 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800984e+00 ||r(i)||/||b|| 2.081619144616e-04
5603 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800978e+00 ||r(i)||/||b|| 2.081619144614e-04
5604 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800988e+00 ||r(i)||/||b|| 2.081619144617e-04
5605 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800984e+00 ||r(i)||/||b|| 2.081619144616e-04
5606 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800983e+00 ||r(i)||/||b|| 2.081619144616e-04
5607 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800983e+00 ||r(i)||/||b|| 2.081619144616e-04
5608 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800976e+00 ||r(i)||/||b|| 2.081619144614e-04
5609 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800977e+00 ||r(i)||/||b|| 2.081619144614e-04
5610 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5611 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
5612 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
5613 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
5614 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
5615 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800985e+00 ||r(i)||/||b|| 2.081619144616e-04
5616 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
5617 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5618 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800976e+00 ||r(i)||/||b|| 2.081619144614e-04
5619 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800978e+00 ||r(i)||/||b|| 2.081619144614e-04
5620 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
5621 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5622 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
5623 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
5624 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
5625 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800988e+00 ||r(i)||/||b|| 2.081619144617e-04
5626 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
5627 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800976e+00 ||r(i)||/||b|| 2.081619144614e-04
5628 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
5629 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
5630 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
5631 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
5632 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800976e+00 ||r(i)||/||b|| 2.081619144614e-04
5633 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800977e+00 ||r(i)||/||b|| 2.081619144614e-04
5634 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800978e+00 ||r(i)||/||b|| 2.081619144614e-04
5635 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800983e+00 ||r(i)||/||b|| 2.081619144616e-04
5636 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800983e+00 ||r(i)||/||b|| 2.081619144615e-04
5637 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800984e+00 ||r(i)||/||b|| 2.081619144616e-04
5638 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800990e+00 ||r(i)||/||b|| 2.081619144617e-04
5639 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800984e+00 ||r(i)||/||b|| 2.081619144616e-04
5640 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
5641 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
5642 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
5643 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
5644 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800979e+00 ||r(i)||/||b|| 2.081619144615e-04
5645 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
5646 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5647 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
5648 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
5649 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800970e+00 ||r(i)||/||b|| 2.081619144613e-04
5650 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
5651 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
5652 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
5653 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
5654 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800970e+00 ||r(i)||/||b|| 2.081619144613e-04
5655 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
5656 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800976e+00 ||r(i)||/||b|| 2.081619144614e-04
5657 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
5658 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
5659 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
5660 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
5661 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800964e+00 ||r(i)||/||b|| 2.081619144611e-04
5662 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
5663 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800966e+00 ||r(i)||/||b|| 2.081619144611e-04
5664 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800970e+00 ||r(i)||/||b|| 2.081619144613e-04
5665 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800977e+00 ||r(i)||/||b|| 2.081619144614e-04
5666 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800966e+00 ||r(i)||/||b|| 2.081619144611e-04
5667 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800976e+00 ||r(i)||/||b|| 2.081619144614e-04
5668 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800972e+00 ||r(i)||/||b|| 2.081619144613e-04
5669 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800977e+00 ||r(i)||/||b|| 2.081619144614e-04
5670 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5671 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5672 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144614e-04
5673 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800979e+00 ||r(i)||/||b|| 2.081619144615e-04
5674 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
5675 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800979e+00 ||r(i)||/||b|| 2.081619144615e-04
5676 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
5677 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5678 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800982e+00 ||r(i)||/||b|| 2.081619144615e-04
5679 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800972e+00 ||r(i)||/||b|| 2.081619144613e-04
5680 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
5681 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
5682 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5683 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
5684 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800979e+00 ||r(i)||/||b|| 2.081619144615e-04
5685 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
5686 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
5687 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
5688 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800979e+00 ||r(i)||/||b|| 2.081619144615e-04
5689 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
5690 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5691 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
5692 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800976e+00 ||r(i)||/||b|| 2.081619144614e-04
5693 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800984e+00 ||r(i)||/||b|| 2.081619144616e-04
5694 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800984e+00 ||r(i)||/||b|| 2.081619144616e-04
5695 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800977e+00 ||r(i)||/||b|| 2.081619144614e-04
5696 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800977e+00 ||r(i)||/||b|| 2.081619144614e-04
5697 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800985e+00 ||r(i)||/||b|| 2.081619144616e-04
5698 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800976e+00 ||r(i)||/||b|| 2.081619144614e-04
5699 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800984e+00 ||r(i)||/||b|| 2.081619144616e-04
5700 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
5701 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5702 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5703 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
5704 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
5705 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
5706 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5707 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
5708 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800979e+00 ||r(i)||/||b|| 2.081619144615e-04
5709 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800976e+00 ||r(i)||/||b|| 2.081619144614e-04
5710 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5711 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
5712 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
5713 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
5714 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
5715 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800985e+00 ||r(i)||/||b|| 2.081619144616e-04
5716 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
5717 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
5718 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800982e+00 ||r(i)||/||b|| 2.081619144615e-04
5719 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
5720 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
5721 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
5722 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800979e+00 ||r(i)||/||b|| 2.081619144615e-04
5723 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800977e+00 ||r(i)||/||b|| 2.081619144614e-04
5724 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800977e+00 ||r(i)||/||b|| 2.081619144614e-04
5725 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800983e+00 ||r(i)||/||b|| 2.081619144616e-04
5726 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800978e+00 ||r(i)||/||b|| 2.081619144614e-04
5727 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
5728 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800979e+00 ||r(i)||/||b|| 2.081619144615e-04
5729 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800983e+00 ||r(i)||/||b|| 2.081619144616e-04
5730 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5731 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5732 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144614e-04
5733 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
5734 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
5735 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800979e+00 ||r(i)||/||b|| 2.081619144615e-04
5736 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
5737 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
5738 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
5739 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800985e+00 ||r(i)||/||b|| 2.081619144616e-04
5740 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
5741 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
5742 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
5743 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800982e+00 ||r(i)||/||b|| 2.081619144615e-04
5744 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800979e+00 ||r(i)||/||b|| 2.081619144615e-04
5745 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800976e+00 ||r(i)||/||b|| 2.081619144614e-04
5746 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
5747 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
5748 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800985e+00 ||r(i)||/||b|| 2.081619144616e-04
5749 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
5750 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
5751 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800979e+00 ||r(i)||/||b|| 2.081619144615e-04
5752 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800976e+00 ||r(i)||/||b|| 2.081619144614e-04
5753 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800972e+00 ||r(i)||/||b|| 2.081619144613e-04
5754 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800984e+00 ||r(i)||/||b|| 2.081619144616e-04
5755 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800984e+00 ||r(i)||/||b|| 2.081619144616e-04
5756 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800982e+00 ||r(i)||/||b|| 2.081619144615e-04
5757 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
5758 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800988e+00 ||r(i)||/||b|| 2.081619144617e-04
5759 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800972e+00 ||r(i)||/||b|| 2.081619144613e-04
5760 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
5761 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
5762 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
5763 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
5764 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
5765 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
5766 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5767 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
5768 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5769 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800982e+00 ||r(i)||/||b|| 2.081619144615e-04
5770 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
5771 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
5772 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
5773 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
5774 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
5775 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
5776 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
5777 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
5778 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
5779 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
5780 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
5781 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
5782 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800979e+00 ||r(i)||/||b|| 2.081619144615e-04
5783 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800977e+00 ||r(i)||/||b|| 2.081619144614e-04
5784 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800972e+00 ||r(i)||/||b|| 2.081619144613e-04
5785 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800977e+00 ||r(i)||/||b|| 2.081619144614e-04
5786 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
5787 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
5788 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5789 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800976e+00 ||r(i)||/||b|| 2.081619144614e-04
5790 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5791 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
5792 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144614e-04
5793 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
5794 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
5795 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
5796 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
5797 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5798 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800982e+00 ||r(i)||/||b|| 2.081619144615e-04
5799 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800979e+00 ||r(i)||/||b|| 2.081619144615e-04
5800 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
5801 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
5802 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5803 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
5804 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
5805 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800976e+00 ||r(i)||/||b|| 2.081619144614e-04
5806 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
5807 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
5808 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
5809 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
5810 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5811 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
5812 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800976e+00 ||r(i)||/||b|| 2.081619144614e-04
5813 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800972e+00 ||r(i)||/||b|| 2.081619144613e-04
5814 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800984e+00 ||r(i)||/||b|| 2.081619144616e-04
5815 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800978e+00 ||r(i)||/||b|| 2.081619144614e-04
5816 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800971e+00 ||r(i)||/||b|| 2.081619144613e-04
5817 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
5818 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
5819 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800985e+00 ||r(i)||/||b|| 2.081619144616e-04
5820 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
5821 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
5822 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
5823 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
5824 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5825 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
5826 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144614e-04
5827 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
5828 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5829 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800976e+00 ||r(i)||/||b|| 2.081619144614e-04
5830 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
5831 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
5832 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
5833 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
5834 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
5835 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5836 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800976e+00 ||r(i)||/||b|| 2.081619144614e-04
5837 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
5838 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
5839 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
5840 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
5841 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
5842 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800979e+00 ||r(i)||/||b|| 2.081619144615e-04
5843 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800977e+00 ||r(i)||/||b|| 2.081619144614e-04
5844 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800978e+00 ||r(i)||/||b|| 2.081619144614e-04
5845 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800983e+00 ||r(i)||/||b|| 2.081619144615e-04
5846 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800979e+00 ||r(i)||/||b|| 2.081619144615e-04
5847 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5848 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
5849 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800977e+00 ||r(i)||/||b|| 2.081619144614e-04
5850 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
5851 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
5852 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
5853 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5854 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
5855 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5856 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
5857 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5858 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800976e+00 ||r(i)||/||b|| 2.081619144614e-04
5859 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
5860 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
5861 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
5862 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
5863 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
5864 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800979e+00 ||r(i)||/||b|| 2.081619144615e-04
5865 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
5866 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
5867 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
5868 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5869 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
5870 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
5871 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
5872 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800976e+00 ||r(i)||/||b|| 2.081619144614e-04
5873 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800978e+00 ||r(i)||/||b|| 2.081619144614e-04
5874 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800977e+00 ||r(i)||/||b|| 2.081619144614e-04
5875 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800985e+00 ||r(i)||/||b|| 2.081619144616e-04
5876 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800982e+00 ||r(i)||/||b|| 2.081619144615e-04
5877 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800982e+00 ||r(i)||/||b|| 2.081619144615e-04
5878 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5879 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800979e+00 ||r(i)||/||b|| 2.081619144615e-04
5880 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
5881 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
5882 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
5883 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
5884 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
5885 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800982e+00 ||r(i)||/||b|| 2.081619144615e-04
5886 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
5887 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
5888 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
5889 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800982e+00 ||r(i)||/||b|| 2.081619144615e-04
5890 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5891 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
5892 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
5893 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5894 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800976e+00 ||r(i)||/||b|| 2.081619144614e-04
5895 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
5896 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
5897 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5898 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
5899 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5900 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
5901 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800988e+00 ||r(i)||/||b|| 2.081619144617e-04
5902 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
5903 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800989e+00 ||r(i)||/||b|| 2.081619144617e-04
5904 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800978e+00 ||r(i)||/||b|| 2.081619144614e-04
5905 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800977e+00 ||r(i)||/||b|| 2.081619144614e-04
5906 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800985e+00 ||r(i)||/||b|| 2.081619144616e-04
5907 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5908 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
5909 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800970e+00 ||r(i)||/||b|| 2.081619144613e-04
5910 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
5911 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
5912 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
5913 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
5914 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800988e+00 ||r(i)||/||b|| 2.081619144617e-04
5915 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
5916 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
5917 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
5918 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
5919 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
5920 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
5921 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
5922 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
5923 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800982e+00 ||r(i)||/||b|| 2.081619144615e-04
5924 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
5925 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800976e+00 ||r(i)||/||b|| 2.081619144614e-04
5926 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5927 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800976e+00 ||r(i)||/||b|| 2.081619144614e-04
5928 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5929 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
5930 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
5931 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
5932 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800982e+00 ||r(i)||/||b|| 2.081619144615e-04
5933 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800985e+00 ||r(i)||/||b|| 2.081619144616e-04
5934 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800977e+00 ||r(i)||/||b|| 2.081619144614e-04
5935 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800985e+00 ||r(i)||/||b|| 2.081619144616e-04
5936 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800982e+00 ||r(i)||/||b|| 2.081619144615e-04
5937 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800988e+00 ||r(i)||/||b|| 2.081619144617e-04
5938 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
5939 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800991e+00 ||r(i)||/||b|| 2.081619144618e-04
5940 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
5941 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
5942 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
5943 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
5944 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
5945 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
5946 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
5947 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
5948 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
5949 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800982e+00 ||r(i)||/||b|| 2.081619144615e-04
5950 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5951 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
5952 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
5953 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
5954 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
5955 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
5956 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
5957 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5958 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
5959 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
5960 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
5961 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800982e+00 ||r(i)||/||b|| 2.081619144615e-04
5962 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
5963 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800988e+00 ||r(i)||/||b|| 2.081619144617e-04
5964 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800997e+00 ||r(i)||/||b|| 2.081619144619e-04
5965 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800982e+00 ||r(i)||/||b|| 2.081619144615e-04
5966 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5967 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800985e+00 ||r(i)||/||b|| 2.081619144616e-04
5968 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800982e+00 ||r(i)||/||b|| 2.081619144615e-04
5969 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800982e+00 ||r(i)||/||b|| 2.081619144615e-04
5970 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
5971 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
5972 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
5973 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
5974 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
5975 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5976 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
5977 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5978 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
5979 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
5980 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
5981 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
5982 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5983 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
5984 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
5985 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
5986 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144614e-04
5987 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
5988 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5989 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
5990 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
5991 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5992 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800988e+00 ||r(i)||/||b|| 2.081619144617e-04
5993 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5994 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800989e+00 ||r(i)||/||b|| 2.081619144617e-04
5995 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
5996 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800982e+00 ||r(i)||/||b|| 2.081619144615e-04
5997 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800983e+00 ||r(i)||/||b|| 2.081619144615e-04
5998 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
5999 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800985e+00 ||r(i)||/||b|| 2.081619144616e-04
6000 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
6001 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
6002 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6003 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6004 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
6005 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485801000e+00 ||r(i)||/||b|| 2.081619144620e-04
6006 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6007 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
6008 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
6009 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800976e+00 ||r(i)||/||b|| 2.081619144614e-04
6010 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
6011 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
6012 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6013 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
6014 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6015 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
6016 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6017 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
6018 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6019 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6020 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6021 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6022 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
6023 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800982e+00 ||r(i)||/||b|| 2.081619144615e-04
6024 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800985e+00 ||r(i)||/||b|| 2.081619144616e-04
6025 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800982e+00 ||r(i)||/||b|| 2.081619144615e-04
6026 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
6027 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800979e+00 ||r(i)||/||b|| 2.081619144615e-04
6028 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800977e+00 ||r(i)||/||b|| 2.081619144614e-04
6029 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800994e+00 ||r(i)||/||b|| 2.081619144618e-04
6030 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6031 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6032 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6033 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6034 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6035 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
6036 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6037 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6038 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800994e+00 ||r(i)||/||b|| 2.081619144618e-04
6039 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
6040 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800988e+00 ||r(i)||/||b|| 2.081619144617e-04
6041 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6042 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6043 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6044 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
6045 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800988e+00 ||r(i)||/||b|| 2.081619144617e-04
6046 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6047 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6048 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6049 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800999e+00 ||r(i)||/||b|| 2.081619144619e-04
6050 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
6051 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
6052 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6053 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
6054 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800983e+00 ||r(i)||/||b|| 2.081619144615e-04
6055 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
6056 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800995e+00 ||r(i)||/||b|| 2.081619144618e-04
6057 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800983e+00 ||r(i)||/||b|| 2.081619144616e-04
6058 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800979e+00 ||r(i)||/||b|| 2.081619144615e-04
6059 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
6060 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6061 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6062 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6063 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6064 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
6065 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6066 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
6067 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6068 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
6069 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800988e+00 ||r(i)||/||b|| 2.081619144617e-04
6070 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6071 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6072 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6073 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
6074 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6075 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
6076 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6077 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
6078 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6079 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
6080 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6081 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800982e+00 ||r(i)||/||b|| 2.081619144615e-04
6082 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
6083 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800994e+00 ||r(i)||/||b|| 2.081619144618e-04
6084 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800985e+00 ||r(i)||/||b|| 2.081619144616e-04
6085 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800976e+00 ||r(i)||/||b|| 2.081619144614e-04
6086 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
6087 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800990e+00 ||r(i)||/||b|| 2.081619144617e-04
6088 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800983e+00 ||r(i)||/||b|| 2.081619144616e-04
6089 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800988e+00 ||r(i)||/||b|| 2.081619144617e-04
6090 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6091 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6092 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6093 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6094 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800988e+00 ||r(i)||/||b|| 2.081619144617e-04
6095 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
6096 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6097 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6098 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800994e+00 ||r(i)||/||b|| 2.081619144618e-04
6099 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
6100 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6101 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6102 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
6103 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6104 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
6105 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485801000e+00 ||r(i)||/||b|| 2.081619144620e-04
6106 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6107 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6108 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6109 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6110 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6111 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
6112 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800988e+00 ||r(i)||/||b|| 2.081619144617e-04
6113 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800998e+00 ||r(i)||/||b|| 2.081619144619e-04
6114 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800995e+00 ||r(i)||/||b|| 2.081619144618e-04
6115 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800998e+00 ||r(i)||/||b|| 2.081619144619e-04
6116 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800988e+00 ||r(i)||/||b|| 2.081619144617e-04
6117 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800990e+00 ||r(i)||/||b|| 2.081619144617e-04
6118 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800984e+00 ||r(i)||/||b|| 2.081619144616e-04
6119 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
6120 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6121 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6122 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800999e+00 ||r(i)||/||b|| 2.081619144619e-04
6123 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6124 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800999e+00 ||r(i)||/||b|| 2.081619144619e-04
6125 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800994e+00 ||r(i)||/||b|| 2.081619144618e-04
6126 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6127 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800999e+00 ||r(i)||/||b|| 2.081619144619e-04
6128 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
6129 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6130 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800999e+00 ||r(i)||/||b|| 2.081619144619e-04
6131 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6132 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6133 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
6134 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6135 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
6136 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6137 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
6138 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6139 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
6140 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6141 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6142 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
6143 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6144 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800991e+00 ||r(i)||/||b|| 2.081619144618e-04
6145 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800988e+00 ||r(i)||/||b|| 2.081619144617e-04
6146 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
6147 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800996e+00 ||r(i)||/||b|| 2.081619144619e-04
6148 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800990e+00 ||r(i)||/||b|| 2.081619144617e-04
6149 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800994e+00 ||r(i)||/||b|| 2.081619144618e-04
6150 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6151 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800999e+00 ||r(i)||/||b|| 2.081619144619e-04
6152 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485801005e+00 ||r(i)||/||b|| 2.081619144621e-04
6153 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800999e+00 ||r(i)||/||b|| 2.081619144619e-04
6154 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485801005e+00 ||r(i)||/||b|| 2.081619144621e-04
6155 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485801004e+00 ||r(i)||/||b|| 2.081619144621e-04
6156 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6157 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485801010e+00 ||r(i)||/||b|| 2.081619144622e-04
6158 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800999e+00 ||r(i)||/||b|| 2.081619144620e-04
6159 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800998e+00 ||r(i)||/||b|| 2.081619144619e-04
6160 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6161 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485801005e+00 ||r(i)||/||b|| 2.081619144621e-04
6162 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800998e+00 ||r(i)||/||b|| 2.081619144619e-04
6163 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6164 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800998e+00 ||r(i)||/||b|| 2.081619144619e-04
6165 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800999e+00 ||r(i)||/||b|| 2.081619144619e-04
6166 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800998e+00 ||r(i)||/||b|| 2.081619144619e-04
6167 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485801005e+00 ||r(i)||/||b|| 2.081619144621e-04
6168 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485801004e+00 ||r(i)||/||b|| 2.081619144621e-04
6169 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800999e+00 ||r(i)||/||b|| 2.081619144619e-04
6170 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485801005e+00 ||r(i)||/||b|| 2.081619144621e-04
6171 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800999e+00 ||r(i)||/||b|| 2.081619144619e-04
6172 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800999e+00 ||r(i)||/||b|| 2.081619144619e-04
6173 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800997e+00 ||r(i)||/||b|| 2.081619144619e-04
6174 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485801000e+00 ||r(i)||/||b|| 2.081619144620e-04
6175 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800997e+00 ||r(i)||/||b|| 2.081619144619e-04
6176 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800994e+00 ||r(i)||/||b|| 2.081619144618e-04
6177 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800997e+00 ||r(i)||/||b|| 2.081619144619e-04
6178 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800996e+00 ||r(i)||/||b|| 2.081619144619e-04
6179 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800998e+00 ||r(i)||/||b|| 2.081619144619e-04
6180 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485800999e+00 ||r(i)||/||b|| 2.081619144619e-04
6181 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485800999e+00 ||r(i)||/||b|| 2.081619144619e-04
6182 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485800999e+00 ||r(i)||/||b|| 2.081619144619e-04
6183 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6184 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485800998e+00 ||r(i)||/||b|| 2.081619144619e-04
6185 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485800999e+00 ||r(i)||/||b|| 2.081619144619e-04
6186 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485801005e+00 ||r(i)||/||b|| 2.081619144621e-04
6187 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485800999e+00 ||r(i)||/||b|| 2.081619144619e-04
6188 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485801004e+00 ||r(i)||/||b|| 2.081619144621e-04
6189 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485800999e+00 ||r(i)||/||b|| 2.081619144619e-04
6190 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485801004e+00 ||r(i)||/||b|| 2.081619144621e-04
6191 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485801005e+00 ||r(i)||/||b|| 2.081619144621e-04
6192 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485801005e+00 ||r(i)||/||b|| 2.081619144621e-04
6193 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485800998e+00 ||r(i)||/||b|| 2.081619144619e-04
6194 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6195 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485800998e+00 ||r(i)||/||b|| 2.081619144619e-04
6196 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6197 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485800998e+00 ||r(i)||/||b|| 2.081619144619e-04
6198 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485800999e+00 ||r(i)||/||b|| 2.081619144619e-04
6199 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485801005e+00 ||r(i)||/||b|| 2.081619144621e-04
6200 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485800999e+00 ||r(i)||/||b|| 2.081619144619e-04
6201 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485800999e+00 ||r(i)||/||b|| 2.081619144619e-04
6202 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485800998e+00 ||r(i)||/||b|| 2.081619144619e-04
6203 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485801006e+00 ||r(i)||/||b|| 2.081619144621e-04
6204 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485801003e+00 ||r(i)||/||b|| 2.081619144620e-04
6205 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485801000e+00 ||r(i)||/||b|| 2.081619144620e-04
6206 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485800998e+00 ||r(i)||/||b|| 2.081619144619e-04
6207 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485800995e+00 ||r(i)||/||b|| 2.081619144618e-04
6208 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485800990e+00 ||r(i)||/||b|| 2.081619144617e-04
6209 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485801005e+00 ||r(i)||/||b|| 2.081619144621e-04
6210 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485800999e+00 ||r(i)||/||b|| 2.081619144619e-04
6211 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485800999e+00 ||r(i)||/||b|| 2.081619144619e-04
6212 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6213 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485800999e+00 ||r(i)||/||b|| 2.081619144619e-04
6214 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6215 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485800998e+00 ||r(i)||/||b|| 2.081619144619e-04
6216 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6217 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485800999e+00 ||r(i)||/||b|| 2.081619144619e-04
6218 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485800999e+00 ||r(i)||/||b|| 2.081619144619e-04
6219 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485800998e+00 ||r(i)||/||b|| 2.081619144619e-04
6220 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485800999e+00 ||r(i)||/||b|| 2.081619144619e-04
6221 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485800999e+00 ||r(i)||/||b|| 2.081619144619e-04
6222 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485800999e+00 ||r(i)||/||b|| 2.081619144619e-04
6223 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485801005e+00 ||r(i)||/||b|| 2.081619144621e-04
6224 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485801004e+00 ||r(i)||/||b|| 2.081619144621e-04
6225 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6226 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485801005e+00 ||r(i)||/||b|| 2.081619144621e-04
6227 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6228 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485800999e+00 ||r(i)||/||b|| 2.081619144619e-04
6229 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6230 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6231 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485801010e+00 ||r(i)||/||b|| 2.081619144622e-04
6232 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485800999e+00 ||r(i)||/||b|| 2.081619144619e-04
6233 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
6234 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485800994e+00 ||r(i)||/||b|| 2.081619144618e-04
6235 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485801004e+00 ||r(i)||/||b|| 2.081619144621e-04
6236 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485800999e+00 ||r(i)||/||b|| 2.081619144620e-04
6237 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485800990e+00 ||r(i)||/||b|| 2.081619144617e-04
6238 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485800996e+00 ||r(i)||/||b|| 2.081619144619e-04
6239 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
6240 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6241 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6242 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6243 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6244 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
6245 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800999e+00 ||r(i)||/||b|| 2.081619144619e-04
6246 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6247 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6248 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
6249 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800994e+00 ||r(i)||/||b|| 2.081619144618e-04
6250 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6251 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800999e+00 ||r(i)||/||b|| 2.081619144619e-04
6252 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6253 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
6254 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6255 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800999e+00 ||r(i)||/||b|| 2.081619144619e-04
6256 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6257 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6258 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800999e+00 ||r(i)||/||b|| 2.081619144619e-04
6259 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800999e+00 ||r(i)||/||b|| 2.081619144619e-04
6260 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6261 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485801006e+00 ||r(i)||/||b|| 2.081619144621e-04
6262 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800998e+00 ||r(i)||/||b|| 2.081619144619e-04
6263 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800994e+00 ||r(i)||/||b|| 2.081619144618e-04
6264 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800998e+00 ||r(i)||/||b|| 2.081619144619e-04
6265 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800994e+00 ||r(i)||/||b|| 2.081619144618e-04
6266 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800998e+00 ||r(i)||/||b|| 2.081619144619e-04
6267 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485801001e+00 ||r(i)||/||b|| 2.081619144620e-04
6268 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485801002e+00 ||r(i)||/||b|| 2.081619144620e-04
6269 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800994e+00 ||r(i)||/||b|| 2.081619144618e-04
6270 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6271 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6272 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800999e+00 ||r(i)||/||b|| 2.081619144619e-04
6273 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6274 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800999e+00 ||r(i)||/||b|| 2.081619144619e-04
6275 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6276 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
6277 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6278 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6279 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800999e+00 ||r(i)||/||b|| 2.081619144619e-04
6280 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6281 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6282 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800999e+00 ||r(i)||/||b|| 2.081619144619e-04
6283 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6284 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
6285 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800999e+00 ||r(i)||/||b|| 2.081619144619e-04
6286 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6287 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6288 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800998e+00 ||r(i)||/||b|| 2.081619144619e-04
6289 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6290 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
6291 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485801004e+00 ||r(i)||/||b|| 2.081619144621e-04
6292 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485801000e+00 ||r(i)||/||b|| 2.081619144620e-04
6293 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800998e+00 ||r(i)||/||b|| 2.081619144619e-04
6294 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800988e+00 ||r(i)||/||b|| 2.081619144617e-04
6295 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800998e+00 ||r(i)||/||b|| 2.081619144619e-04
6296 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800988e+00 ||r(i)||/||b|| 2.081619144617e-04
6297 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800997e+00 ||r(i)||/||b|| 2.081619144619e-04
6298 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485801001e+00 ||r(i)||/||b|| 2.081619144620e-04
6299 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6300 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
6301 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
6302 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6303 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6304 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6305 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6306 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6307 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800999e+00 ||r(i)||/||b|| 2.081619144619e-04
6308 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
6309 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6310 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800999e+00 ||r(i)||/||b|| 2.081619144619e-04
6311 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6312 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800999e+00 ||r(i)||/||b|| 2.081619144619e-04
6313 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800999e+00 ||r(i)||/||b|| 2.081619144619e-04
6314 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6315 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
6316 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485801006e+00 ||r(i)||/||b|| 2.081619144621e-04
6317 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6318 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6319 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6320 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6321 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6322 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
6323 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800994e+00 ||r(i)||/||b|| 2.081619144618e-04
6324 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800998e+00 ||r(i)||/||b|| 2.081619144619e-04
6325 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800994e+00 ||r(i)||/||b|| 2.081619144618e-04
6326 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
6327 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800989e+00 ||r(i)||/||b|| 2.081619144617e-04
6328 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800985e+00 ||r(i)||/||b|| 2.081619144616e-04
6329 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800994e+00 ||r(i)||/||b|| 2.081619144618e-04
6330 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
6331 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
6332 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800999e+00 ||r(i)||/||b|| 2.081619144619e-04
6333 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
6334 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800999e+00 ||r(i)||/||b|| 2.081619144619e-04
6335 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6336 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6337 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6338 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800999e+00 ||r(i)||/||b|| 2.081619144619e-04
6339 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
6340 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6341 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
6342 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
6343 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6344 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
6345 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
6346 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
6347 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6348 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6349 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6350 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6351 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6352 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6353 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
6354 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800988e+00 ||r(i)||/||b|| 2.081619144617e-04
6355 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
6356 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6357 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800991e+00 ||r(i)||/||b|| 2.081619144617e-04
6358 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800989e+00 ||r(i)||/||b|| 2.081619144617e-04
6359 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
6360 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
6361 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6362 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6363 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6364 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6365 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800999e+00 ||r(i)||/||b|| 2.081619144619e-04
6366 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6367 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
6368 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
6369 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800994e+00 ||r(i)||/||b|| 2.081619144618e-04
6370 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
6371 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6372 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6373 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6374 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6375 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
6376 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6377 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
6378 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800999e+00 ||r(i)||/||b|| 2.081619144619e-04
6379 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
6380 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6381 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
6382 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
6383 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6384 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
6385 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6386 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
6387 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800988e+00 ||r(i)||/||b|| 2.081619144617e-04
6388 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800985e+00 ||r(i)||/||b|| 2.081619144616e-04
6389 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
6390 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6391 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
6392 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
6393 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800999e+00 ||r(i)||/||b|| 2.081619144619e-04
6394 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6395 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
6396 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6397 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6398 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6399 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
6400 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
6401 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6402 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6403 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6404 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
6405 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6406 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6407 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800999e+00 ||r(i)||/||b|| 2.081619144619e-04
6408 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6409 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6410 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6411 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6412 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6413 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
6414 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6415 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
6416 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6417 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800991e+00 ||r(i)||/||b|| 2.081619144618e-04
6418 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800988e+00 ||r(i)||/||b|| 2.081619144617e-04
6419 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
6420 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6421 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
6422 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
6423 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6424 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6425 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6426 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6427 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6428 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6429 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800982e+00 ||r(i)||/||b|| 2.081619144615e-04
6430 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
6431 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6432 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6433 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800999e+00 ||r(i)||/||b|| 2.081619144619e-04
6434 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6435 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800999e+00 ||r(i)||/||b|| 2.081619144619e-04
6436 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6437 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
6438 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6439 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6440 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
6441 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6442 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
6443 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800982e+00 ||r(i)||/||b|| 2.081619144615e-04
6444 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
6445 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800982e+00 ||r(i)||/||b|| 2.081619144615e-04
6446 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
6447 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800989e+00 ||r(i)||/||b|| 2.081619144617e-04
6448 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800991e+00 ||r(i)||/||b|| 2.081619144618e-04
6449 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800982e+00 ||r(i)||/||b|| 2.081619144615e-04
6450 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6451 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6452 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
6453 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
6454 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6455 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
6456 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6457 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6458 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
6459 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
6460 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6461 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6462 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6463 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
6464 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6465 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
6466 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6467 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6468 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6469 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6470 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6471 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6472 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800982e+00 ||r(i)||/||b|| 2.081619144615e-04
6473 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
6474 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800982e+00 ||r(i)||/||b|| 2.081619144615e-04
6475 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
6476 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6477 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
6478 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800995e+00 ||r(i)||/||b|| 2.081619144618e-04
6479 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
6480 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485800999e+00 ||r(i)||/||b|| 2.081619144619e-04
6481 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6482 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6483 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6484 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485800999e+00 ||r(i)||/||b|| 2.081619144619e-04
6485 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
6486 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
6487 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6488 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485800999e+00 ||r(i)||/||b|| 2.081619144619e-04
6489 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485800999e+00 ||r(i)||/||b|| 2.081619144619e-04
6490 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
6491 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6492 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6493 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6494 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6495 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485800999e+00 ||r(i)||/||b|| 2.081619144619e-04
6496 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6497 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
6498 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6499 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6500 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6501 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6502 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
6503 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6504 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485800998e+00 ||r(i)||/||b|| 2.081619144619e-04
6505 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6506 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485800999e+00 ||r(i)||/||b|| 2.081619144619e-04
6507 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485800988e+00 ||r(i)||/||b|| 2.081619144617e-04
6508 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485800997e+00 ||r(i)||/||b|| 2.081619144619e-04
6509 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485800999e+00 ||r(i)||/||b|| 2.081619144619e-04
6510 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6511 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
6512 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800999e+00 ||r(i)||/||b|| 2.081619144619e-04
6513 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6514 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
6515 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
6516 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6517 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6518 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6519 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800999e+00 ||r(i)||/||b|| 2.081619144619e-04
6520 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6521 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
6522 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
6523 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6524 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
6525 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6526 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6527 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800999e+00 ||r(i)||/||b|| 2.081619144619e-04
6528 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
6529 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6530 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
6531 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
6532 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6533 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
6534 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6535 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
6536 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800999e+00 ||r(i)||/||b|| 2.081619144619e-04
6537 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800985e+00 ||r(i)||/||b|| 2.081619144616e-04
6538 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800988e+00 ||r(i)||/||b|| 2.081619144617e-04
6539 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
6540 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
6541 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800999e+00 ||r(i)||/||b|| 2.081619144619e-04
6542 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
6543 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6544 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6545 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6546 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6547 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6548 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
6549 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
6550 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
6551 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6552 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6553 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6554 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6555 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
6556 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800999e+00 ||r(i)||/||b|| 2.081619144619e-04
6557 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
6558 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
6559 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
6560 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6561 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6562 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
6563 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6564 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800998e+00 ||r(i)||/||b|| 2.081619144619e-04
6565 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6566 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
6567 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800988e+00 ||r(i)||/||b|| 2.081619144617e-04
6568 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800985e+00 ||r(i)||/||b|| 2.081619144616e-04
6569 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6570 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
6571 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800999e+00 ||r(i)||/||b|| 2.081619144619e-04
6572 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6573 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800999e+00 ||r(i)||/||b|| 2.081619144619e-04
6574 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6575 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800999e+00 ||r(i)||/||b|| 2.081619144619e-04
6576 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
6577 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6578 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6579 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800999e+00 ||r(i)||/||b|| 2.081619144619e-04
6580 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6581 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6582 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800999e+00 ||r(i)||/||b|| 2.081619144619e-04
6583 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6584 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
6585 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6586 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800999e+00 ||r(i)||/||b|| 2.081619144619e-04
6587 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800999e+00 ||r(i)||/||b|| 2.081619144619e-04
6588 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
6589 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6590 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6591 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
6592 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6593 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
6594 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6595 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
6596 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6597 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
6598 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485801000e+00 ||r(i)||/||b|| 2.081619144620e-04
6599 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
6600 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6601 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6602 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
6603 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6604 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800999e+00 ||r(i)||/||b|| 2.081619144619e-04
6605 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6606 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
6607 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6608 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6609 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6610 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6611 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6612 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6613 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6614 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6615 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
6616 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6617 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800999e+00 ||r(i)||/||b|| 2.081619144619e-04
6618 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6619 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6620 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6621 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6622 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6623 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800988e+00 ||r(i)||/||b|| 2.081619144617e-04
6624 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
6625 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6626 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
6627 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485801000e+00 ||r(i)||/||b|| 2.081619144620e-04
6628 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800998e+00 ||r(i)||/||b|| 2.081619144619e-04
6629 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6630 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6631 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
6632 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6633 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6634 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6635 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6636 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
6637 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
6638 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6639 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
6640 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
6641 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
6642 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6643 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6644 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6645 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6646 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
6647 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6648 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
6649 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6650 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
6651 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6652 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6653 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6654 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800976e+00 ||r(i)||/||b|| 2.081619144614e-04
6655 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
6656 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800976e+00 ||r(i)||/||b|| 2.081619144614e-04
6657 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
6658 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800994e+00 ||r(i)||/||b|| 2.081619144618e-04
6659 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
6660 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6661 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6662 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6663 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6664 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6665 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6666 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6667 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6668 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
6669 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6670 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
6671 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6672 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
6673 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6674 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
6675 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6676 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6677 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
6678 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6679 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
6680 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6681 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6682 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6683 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
6684 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
6685 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
6686 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
6687 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800988e+00 ||r(i)||/||b|| 2.081619144617e-04
6688 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
6689 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800988e+00 ||r(i)||/||b|| 2.081619144617e-04
6690 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6691 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6692 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800999e+00 ||r(i)||/||b|| 2.081619144620e-04
6693 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6694 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6695 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6696 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6697 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6698 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6699 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800999e+00 ||r(i)||/||b|| 2.081619144619e-04
6700 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6701 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6702 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
6703 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6704 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800999e+00 ||r(i)||/||b|| 2.081619144619e-04
6705 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
6706 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6707 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6708 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6709 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6710 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6711 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
6712 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6713 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6714 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6715 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
6716 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6717 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
6718 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800988e+00 ||r(i)||/||b|| 2.081619144617e-04
6719 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6720 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6721 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6722 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6723 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
6724 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6725 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6726 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
6727 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6728 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6729 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6730 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6731 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6732 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6733 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6734 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6735 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6736 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6737 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6738 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800999e+00 ||r(i)||/||b|| 2.081619144619e-04
6739 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6740 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6741 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6742 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6743 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
6744 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6745 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6746 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
6747 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800988e+00 ||r(i)||/||b|| 2.081619144617e-04
6748 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
6749 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6750 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
6751 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
6752 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
6753 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6754 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6755 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6756 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
6757 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6758 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6759 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144614e-04
6760 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6761 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
6762 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6763 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6764 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
6765 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6766 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
6767 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6768 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
6769 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6770 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6771 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
6772 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
6773 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
6774 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6775 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
6776 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
6777 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
6778 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800970e+00 ||r(i)||/||b|| 2.081619144612e-04
6779 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144614e-04
6780 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6781 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6782 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6783 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
6784 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6785 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6786 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6787 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6788 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
6789 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6790 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6791 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
6792 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6793 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6794 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6795 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
6796 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6797 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
6798 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6799 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6800 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
6801 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
6802 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6803 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
6804 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
6805 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
6806 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
6807 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800982e+00 ||r(i)||/||b|| 2.081619144615e-04
6808 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
6809 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
6810 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6811 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
6812 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6813 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6814 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
6815 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6816 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
6817 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
6818 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
6819 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6820 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6821 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6822 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6823 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6824 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
6825 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6826 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
6827 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6828 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
6829 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6830 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
6831 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6832 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6833 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
6834 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6835 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
6836 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6837 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144614e-04
6838 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800982e+00 ||r(i)||/||b|| 2.081619144615e-04
6839 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
6840 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
6841 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6842 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6843 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6844 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
6845 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6846 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6847 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
6848 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6849 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6850 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
6851 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6852 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6853 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
6854 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6855 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
6856 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6857 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
6858 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
6859 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6860 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
6861 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
6862 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
6863 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800982e+00 ||r(i)||/||b|| 2.081619144615e-04
6864 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
6865 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6866 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6867 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800970e+00 ||r(i)||/||b|| 2.081619144612e-04
6868 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
6869 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6870 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6871 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
6872 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6873 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
6874 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6875 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
6876 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
6877 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
6878 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6879 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6880 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6881 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6882 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6883 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6884 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6885 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
6886 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6887 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6888 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6889 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
6890 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
6891 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6892 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
6893 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
6894 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800976e+00 ||r(i)||/||b|| 2.081619144614e-04
6895 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
6896 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
6897 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
6898 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800982e+00 ||r(i)||/||b|| 2.081619144615e-04
6899 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
6900 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6901 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
6902 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6903 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
6904 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6905 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
6906 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6907 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
6908 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
6909 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
6910 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
6911 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
6912 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
6913 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
6914 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6915 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6916 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6917 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6918 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
6919 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
6920 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6921 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
6922 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6923 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
6924 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
6925 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
6926 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
6927 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800982e+00 ||r(i)||/||b|| 2.081619144615e-04
6928 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
6929 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
6930 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6931 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6932 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6933 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
6934 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6935 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6936 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
6937 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6938 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6939 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6940 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6941 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6942 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6943 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
6944 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6945 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6946 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6947 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6948 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6949 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6950 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6951 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
6952 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6953 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
6954 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6955 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
6956 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6957 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
6958 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800994e+00 ||r(i)||/||b|| 2.081619144618e-04
6959 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6960 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6961 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6962 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
6963 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6964 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6965 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
6966 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6967 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6968 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6969 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
6970 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6971 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6972 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
6973 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6974 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6975 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6976 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6977 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6978 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6979 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
6980 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6981 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
6982 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6983 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6984 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
6985 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6986 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
6987 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6988 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
6989 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6990 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6991 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6992 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
6993 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
6994 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6995 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
6996 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6997 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
6998 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
6999 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
7000 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
7001 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
7002 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
7003 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7004 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
7005 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7006 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7007 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
7008 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
7009 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
7010 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
7011 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
7012 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800999e+00 ||r(i)||/||b|| 2.081619144619e-04
7013 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
7014 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
7015 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7016 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7017 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7018 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800982e+00 ||r(i)||/||b|| 2.081619144615e-04
7019 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7020 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
7021 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7022 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
7023 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
7024 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
7025 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7026 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7027 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7028 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7029 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7030 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7031 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
7032 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7033 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7034 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7035 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
7036 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
7037 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7038 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7039 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
7040 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7041 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7042 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
7043 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7044 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7045 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7046 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7047 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7048 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7049 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7050 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7051 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7052 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7053 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7054 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7055 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7056 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7057 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7058 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7059 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7060 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7061 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7062 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
7063 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7064 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
7065 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
7066 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7067 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
7068 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
7069 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
7070 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7071 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7072 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7073 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
7074 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7075 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7076 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
7077 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7078 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
7079 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
7080 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7081 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
7082 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7083 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7084 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144614e-04
7085 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7086 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7087 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7088 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7089 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7090 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7091 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7092 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7093 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7094 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
7095 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7096 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
7097 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
7098 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7099 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7100 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7101 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7102 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7103 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7104 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
7105 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7106 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7107 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7108 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7109 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7110 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7111 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7112 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7113 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
7114 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7115 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7116 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7117 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7118 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7119 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7120 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7121 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7122 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7123 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7124 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7125 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7126 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7127 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7128 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7129 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7130 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7131 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7132 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7133 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144614e-04
7134 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7135 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7136 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7137 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7138 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
7139 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7140 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7141 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
7142 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7143 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7144 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7145 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7146 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7147 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7148 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7149 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7150 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7151 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7152 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7153 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7154 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
7155 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7156 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7157 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7158 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7159 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7160 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7161 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
7162 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7163 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7164 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7165 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144614e-04
7166 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7167 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7168 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7169 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
7170 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7171 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7172 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7173 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7174 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7175 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7176 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7177 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7178 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
7179 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7180 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7181 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7182 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7183 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7184 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7185 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7186 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7187 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
7188 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7189 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
7190 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7191 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7192 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
7193 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7194 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7195 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7196 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7197 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7198 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7199 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
7200 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144614e-04
7201 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7202 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7203 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7204 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7205 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7206 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
7207 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7208 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7209 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
7210 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7211 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7212 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7213 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7214 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7215 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7216 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7217 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7218 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7219 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7220 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7221 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7222 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7223 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7224 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7225 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7226 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7227 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7228 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7229 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7230 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7231 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
7232 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7233 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
7234 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7235 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7236 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7237 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7238 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144614e-04
7239 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7240 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7241 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7242 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7243 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7244 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
7245 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7246 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
7247 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7248 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7249 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7250 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7251 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7252 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
7253 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7254 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7255 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7256 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7257 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
7258 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7259 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7260 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7261 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7262 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7263 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
7264 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7265 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7266 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7267 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7268 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144614e-04
7269 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7270 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
7271 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7272 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7273 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7274 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7275 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7276 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7277 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
7278 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
7279 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7280 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7281 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
7282 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7283 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7284 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7285 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7286 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7287 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7288 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144614e-04
7289 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7290 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7291 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144614e-04
7292 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7293 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7294 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7295 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7296 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7297 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7298 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7299 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
7300 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7301 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7302 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7303 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7304 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
7305 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7306 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
7307 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7308 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144614e-04
7309 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
7310 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7311 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144614e-04
7312 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7313 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7314 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
7315 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7316 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7317 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
7318 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7319 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7320 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7321 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7322 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7323 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7324 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
7325 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7326 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144614e-04
7327 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7328 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
7329 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7330 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7331 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7332 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7333 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7334 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7335 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7336 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7337 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7338 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7339 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7340 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7341 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7342 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7343 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
7344 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7345 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7346 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
7347 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7348 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7349 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
7350 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7351 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7352 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7353 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7354 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
7355 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7356 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144614e-04
7357 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
7358 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7359 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7360 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
7361 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7362 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
7363 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7364 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7365 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144614e-04
7366 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
7367 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7368 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7369 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7370 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
7371 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
7372 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7373 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7374 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7375 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7376 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7377 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
7378 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7379 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7380 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
7381 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7382 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7383 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7384 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7385 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7386 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7387 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7388 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144614e-04
7389 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7390 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7391 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7392 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7393 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7394 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7395 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
7396 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7397 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7398 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7399 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7400 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7401 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7402 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7403 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7404 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
7405 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7406 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
7407 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7408 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7409 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7410 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7411 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7412 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7413 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7414 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7415 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7416 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7417 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7418 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7419 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7420 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7421 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7422 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7423 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7424 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7425 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7426 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7427 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7428 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
7429 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7430 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7431 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7432 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7433 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7434 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7435 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7436 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7437 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7438 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
7439 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7440 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7441 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7442 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7443 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800998e+00 ||r(i)||/||b|| 2.081619144619e-04
7444 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144614e-04
7445 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7446 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7447 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7448 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7449 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7450 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144614e-04
7451 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7452 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7453 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7454 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7455 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7456 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7457 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7458 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7459 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7460 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144614e-04
7461 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7462 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7463 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7464 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
7465 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7466 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
7467 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7468 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7469 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7470 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7471 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7472 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
7473 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7474 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7475 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7476 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7477 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
7478 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7479 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144614e-04
7480 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7481 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7482 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7483 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7484 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7485 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
7486 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7487 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7488 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7489 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
7490 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7491 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7492 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7493 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7494 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7495 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7496 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7497 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7498 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7499 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7500 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7501 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7502 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
7503 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7504 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144614e-04
7505 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7506 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
7507 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
7508 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
7509 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7510 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
7511 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
7512 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7513 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144614e-04
7514 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
7515 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144614e-04
7516 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7517 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144614e-04
7518 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7519 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
7520 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
7521 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
7522 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144614e-04
7523 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7524 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7525 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7526 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
7527 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144614e-04
7528 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7529 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7530 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144614e-04
7531 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144614e-04
7532 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7533 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144614e-04
7534 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
7535 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7536 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7537 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7538 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7539 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
7540 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7541 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7542 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144614e-04
7543 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7544 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7545 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7546 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
7547 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7548 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7549 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7550 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
7551 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7552 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7553 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7554 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7555 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
7556 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7557 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
7558 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7559 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7560 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7561 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7562 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
7563 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7564 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144614e-04
7565 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
7566 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7567 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7568 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7569 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7570 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
7571 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7572 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
7573 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7574 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7575 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7576 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7577 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
7578 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7579 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
7580 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
7581 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7582 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144614e-04
7583 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7584 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7585 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
7586 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7587 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144614e-04
7588 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
7589 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7590 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7591 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7592 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7593 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7594 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7595 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
7596 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7597 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144614e-04
7598 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7599 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
7600 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7601 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7602 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7603 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7604 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144614e-04
7605 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7606 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7607 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7608 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7609 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7610 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7611 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144614e-04
7612 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7613 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7614 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7615 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7616 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7617 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7618 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7619 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7620 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7621 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
7622 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7623 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7624 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
7625 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7626 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7627 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7628 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
7629 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7630 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7631 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
7632 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7633 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
7634 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7635 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7636 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
7637 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7638 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7639 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7640 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
7641 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
7642 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7643 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
7644 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7645 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7646 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7647 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7648 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7649 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7650 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7651 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7652 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144614e-04
7653 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7654 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7655 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
7656 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7657 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7658 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7659 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7660 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7661 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7662 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
7663 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7664 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7665 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144614e-04
7666 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7667 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7668 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7669 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7670 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7671 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7672 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7673 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144614e-04
7674 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
7675 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7676 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7677 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7678 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7679 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7680 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7681 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7682 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7683 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7684 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7685 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
7686 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
7687 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7688 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7689 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
7690 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7691 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7692 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7693 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7694 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7695 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7696 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7697 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7698 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7699 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7700 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144614e-04
7701 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7702 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
7703 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7704 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
7705 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7706 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7707 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7708 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7709 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7710 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7711 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7712 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7713 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7714 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7715 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7716 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7717 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7718 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7719 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
7720 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7721 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7722 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
7723 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7724 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
7725 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7726 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7727 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7728 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7729 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7730 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144614e-04
7731 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
7732 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7733 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7734 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7735 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7736 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7737 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
7738 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7739 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7740 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7741 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144614e-04
7742 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7743 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7744 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7745 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144614e-04
7746 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7747 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7748 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7749 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7750 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7751 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7752 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7753 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7754 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7755 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
7756 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7757 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144614e-04
7758 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
7759 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
7760 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7761 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7762 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144614e-04
7763 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7764 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7765 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7766 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
7767 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
7768 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
7769 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7770 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7771 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
7772 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
7773 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7774 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7775 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7776 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7777 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
7778 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7779 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7780 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
7781 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7782 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7783 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7784 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7785 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
7786 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
7787 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7788 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7789 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7790 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7791 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
7792 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
7793 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7794 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
7795 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7796 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7797 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7798 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7799 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7800 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7801 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
7802 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7803 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7804 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7805 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7806 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7807 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7808 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7809 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7810 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7811 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7812 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7813 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7814 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7815 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7816 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7817 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
7818 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7819 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7820 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7821 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7822 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7823 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7824 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7825 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7826 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7827 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
7828 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7829 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7830 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7831 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
7832 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7833 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7834 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7835 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7836 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7837 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7838 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7839 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7840 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7841 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7842 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7843 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7844 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
7845 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7846 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
7847 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7848 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7849 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
7850 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7851 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7852 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
7853 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7854 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7855 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
7856 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7857 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7858 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7859 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7860 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7861 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7862 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7863 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7864 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7865 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7866 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7867 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7868 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
7869 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
7870 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7871 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7872 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
7873 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7874 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7875 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
7876 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144614e-04
7877 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7878 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7879 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7880 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7881 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7882 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7883 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7884 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7885 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7886 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7887 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
7888 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7889 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7890 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7891 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7892 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7893 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
7894 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7895 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7896 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7897 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7898 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
7899 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7900 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7901 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
7902 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7903 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7904 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7905 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
7906 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7907 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7908 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7909 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
7910 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
7911 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800998e+00 ||r(i)||/||b|| 2.081619144619e-04
7912 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
7913 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7914 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7915 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7916 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7917 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7918 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144614e-04
7919 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7920 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7921 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7922 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7923 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800998e+00 ||r(i)||/||b|| 2.081619144619e-04
7924 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7925 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7926 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7927 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7928 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7929 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7930 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7931 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
7932 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7933 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7934 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7935 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7936 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7937 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7938 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7939 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
7940 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7941 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
7942 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
7943 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7944 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
7945 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
7946 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
7947 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7948 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7949 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7950 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7951 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7952 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7953 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7954 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
7955 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7956 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7957 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7958 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7959 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7960 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7961 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7962 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7963 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7964 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7965 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7966 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144614e-04
7967 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7968 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7969 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
7970 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7971 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7972 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7973 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7974 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7975 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
7976 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7977 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7978 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7979 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7980 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7981 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7982 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
7983 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
7984 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7985 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7986 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7987 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7988 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7989 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
7990 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7991 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7992 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
7993 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7994 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7995 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7996 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7997 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
7998 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
7999 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8000 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
8001 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
8002 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
8003 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
8004 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8005 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
8006 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
8007 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
8008 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8009 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
8010 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8011 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8012 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
8013 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8014 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8015 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8016 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8017 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
8018 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8019 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
8020 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8021 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
8022 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8023 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8024 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8025 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
8026 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8027 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144614e-04
8028 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8029 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8030 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8031 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
8032 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8033 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
8034 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8035 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8036 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8037 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8038 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
8039 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8040 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144614e-04
8041 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8042 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8043 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
8044 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8045 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
8046 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8047 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8048 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8049 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8050 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8051 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8052 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8053 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8054 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
8055 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
8056 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8057 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8058 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8059 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144614e-04
8060 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8061 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8062 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8063 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8064 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
8065 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8066 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8067 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8068 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8069 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8070 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8071 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
8072 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8073 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
8074 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
8075 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
8076 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8077 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8078 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
8079 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
8080 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8081 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8082 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8083 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
8084 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8085 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8086 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8087 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
8088 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8089 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8090 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8091 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8092 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
8093 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
8094 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
8095 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
8096 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144614e-04
8097 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8098 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
8099 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8100 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
8101 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
8102 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8103 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
8104 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8105 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
8106 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
8107 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
8108 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
8109 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
8110 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
8111 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
8112 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
8113 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144614e-04
8114 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
8115 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8116 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
8117 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
8118 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
8119 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8120 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
8121 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
8122 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8123 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
8124 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
8125 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8126 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
8127 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
8128 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
8129 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
8130 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
8131 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
8132 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
8133 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8134 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8135 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
8136 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8137 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
8138 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8139 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8140 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8141 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
8142 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8143 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8144 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
8145 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8146 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
8147 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8148 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8149 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
8150 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8151 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
8152 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8153 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800998e+00 ||r(i)||/||b|| 2.081619144619e-04
8154 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8155 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8156 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8157 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
8158 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8159 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
8160 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8161 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8162 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8163 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
8164 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8165 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8166 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
8167 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
8168 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144614e-04
8169 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8170 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8171 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8172 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8173 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8174 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
8175 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
8176 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8177 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8178 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
8179 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8180 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8181 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
8182 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8183 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
8184 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
8185 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8186 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8187 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
8188 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
8189 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8190 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8191 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8192 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8193 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8194 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8195 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8196 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8197 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8198 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8199 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8200 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
8201 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8202 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8203 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
8204 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8205 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144614e-04
8206 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8207 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8208 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8209 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
8210 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8211 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8212 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
8213 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
8214 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8215 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8216 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8217 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
8218 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8219 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8220 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8221 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8222 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8223 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
8224 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8225 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
8226 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8227 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
8228 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8229 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
8230 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8231 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
8232 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
8233 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
8234 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8235 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8236 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8237 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8238 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
8239 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
8240 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8241 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
8242 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
8243 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
8244 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
8245 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
8246 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8247 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8248 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
8249 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8250 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
8251 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8252 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8253 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
8254 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
8255 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8256 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
8257 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
8258 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8259 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8260 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8261 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8262 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8263 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8264 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8265 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8266 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8267 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8268 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
8269 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
8270 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8271 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8272 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
8273 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8274 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8275 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8276 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8277 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8278 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8279 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8280 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
8281 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
8282 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8283 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8284 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
8285 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
8286 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8287 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
8288 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8289 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8290 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8291 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
8292 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
8293 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8294 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
8295 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8296 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8297 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
8298 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
8299 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
8300 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
8301 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8302 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8303 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8304 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8305 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
8306 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8307 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8308 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8309 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
8310 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8311 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
8312 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8313 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
8314 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
8315 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8316 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8317 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
8318 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
8319 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8320 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
8321 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8322 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
8323 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8324 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
8325 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8326 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8327 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8328 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
8329 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8330 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8331 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8332 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8333 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8334 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8335 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8336 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144614e-04
8337 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8338 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
8339 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8340 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8341 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
8342 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
8343 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8344 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8345 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8346 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144614e-04
8347 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8348 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
8349 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
8350 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8351 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8352 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
8353 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8354 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8355 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
8356 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8357 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8358 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
8359 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8360 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8361 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8362 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
8363 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144614e-04
8364 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
8365 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
8366 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
8367 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
8368 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144614e-04
8369 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
8370 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
8371 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8372 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144614e-04
8373 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
8374 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144614e-04
8375 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
8376 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
8377 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8378 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
8379 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
8380 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
8381 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
8382 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8383 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
8384 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
8385 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
8386 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
8387 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8388 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
8389 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
8390 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
8391 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8392 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
8393 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8394 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8395 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144614e-04
8396 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144614e-04
8397 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
8398 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8399 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8400 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8401 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144614e-04
8402 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
8403 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8404 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8405 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8406 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
8407 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8408 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8409 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8410 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8411 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8412 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8413 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144614e-04
8414 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8415 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8416 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8417 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8418 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144614e-04
8419 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8420 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8421 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8422 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8423 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
8424 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8425 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8426 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8427 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8428 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
8429 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144614e-04
8430 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
8431 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8432 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8433 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8434 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8435 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
8436 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
8437 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8438 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
8439 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
8440 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144614e-04
8441 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8442 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144614e-04
8443 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
8444 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8445 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8446 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8447 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
8448 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144614e-04
8449 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
8450 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
8451 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
8452 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
8453 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8454 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8455 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
8456 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
8457 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8458 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8459 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
8460 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
8461 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8462 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8463 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
8464 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
8465 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8466 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
8467 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
8468 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8469 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
8470 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
8471 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
8472 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
8473 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
8474 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8475 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
8476 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8477 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
8478 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
8479 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
8480 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
8481 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
8482 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
8483 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
8484 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
8485 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8486 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
8487 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
8488 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8489 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8490 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
8491 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
8492 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
8493 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8494 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
8495 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
8496 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
8497 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8498 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
8499 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
8500 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
8501 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
8502 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
8503 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
8504 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
8505 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8506 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
8507 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
8508 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
8509 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8510 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
8511 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
8512 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
8513 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8514 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8515 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8516 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8517 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
8518 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
8519 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8520 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
8521 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
8522 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
8523 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8524 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8525 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
8526 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8527 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8528 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
8529 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
8530 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8531 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8532 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8533 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
8534 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8535 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8536 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8537 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
8538 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
8539 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
8540 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
8541 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
8542 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
8543 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8544 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
8545 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8546 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8547 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
8548 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
8549 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8550 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
8551 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
8552 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
8553 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
8554 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8555 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
8556 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
8557 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
8558 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
8559 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8560 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
8561 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
8562 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8563 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
8564 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800944e+00 ||r(i)||/||b|| 2.081619144606e-04
8565 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
8566 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
8567 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8568 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
8569 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
8570 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
8571 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8572 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8573 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
8574 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
8575 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
8576 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8577 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
8578 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144608e-04
8579 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
8580 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8581 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8582 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
8583 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8584 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8585 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
8586 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
8587 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
8588 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
8589 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
8590 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8591 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
8592 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144608e-04
8593 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8594 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8595 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8596 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
8597 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
8598 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
8599 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
8600 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
8601 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
8602 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
8603 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
8604 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8605 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
8606 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8607 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8608 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
8609 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
8610 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
8611 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8612 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
8613 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
8614 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
8615 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
8616 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
8617 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
8618 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
8619 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
8620 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
8621 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
8622 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
8623 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8624 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
8625 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
8626 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8627 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144607e-04
8628 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
8629 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800943e+00 ||r(i)||/||b|| 2.081619144606e-04
8630 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
8631 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
8632 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
8633 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
8634 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8635 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
8636 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
8637 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
8638 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
8639 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8640 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
8641 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144608e-04
8642 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144608e-04
8643 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
8644 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
8645 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8646 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
8647 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
8648 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8649 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144608e-04
8650 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8651 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
8652 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8653 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144607e-04
8654 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
8655 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
8656 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
8657 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8658 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8659 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
8660 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8661 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
8662 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8663 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8664 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
8665 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
8666 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8667 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8668 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
8669 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
8670 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
8671 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
8672 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
8673 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8674 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8675 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
8676 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144607e-04
8677 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
8678 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
8679 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8680 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8681 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144608e-04
8682 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
8683 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
8684 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
8685 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800937e+00 ||r(i)||/||b|| 2.081619144605e-04
8686 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8687 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
8688 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8689 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8690 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
8691 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144608e-04
8692 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
8693 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8694 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
8695 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8696 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
8697 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800943e+00 ||r(i)||/||b|| 2.081619144606e-04
8698 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8699 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
8700 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
8701 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8702 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
8703 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8704 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800943e+00 ||r(i)||/||b|| 2.081619144606e-04
8705 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
8706 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
8707 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
8708 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8709 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
8710 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8711 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
8712 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
8713 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
8714 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
8715 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8716 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
8717 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
8718 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
8719 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144608e-04
8720 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
8721 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
8722 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
8723 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
8724 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
8725 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8726 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
8727 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
8728 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
8729 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
8730 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8731 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
8732 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
8733 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
8734 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
8735 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
8736 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
8737 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
8738 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
8739 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8740 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8741 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
8742 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8743 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8744 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
8745 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
8746 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
8747 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
8748 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8749 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8750 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
8751 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8752 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
8753 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8754 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
8755 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8756 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8757 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8758 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
8759 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
8760 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
8761 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8762 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
8763 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
8764 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
8765 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8766 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
8767 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
8768 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
8769 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
8770 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
8771 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
8772 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
8773 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
8774 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
8775 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144608e-04
8776 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
8777 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
8778 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800944e+00 ||r(i)||/||b|| 2.081619144606e-04
8779 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
8780 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
8781 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
8782 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
8783 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8784 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
8785 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
8786 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
8787 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8788 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8789 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8790 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
8791 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
8792 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
8793 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
8794 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
8795 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144607e-04
8796 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8797 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8798 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
8799 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
8800 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
8801 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
8802 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144608e-04
8803 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
8804 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800943e+00 ||r(i)||/||b|| 2.081619144606e-04
8805 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
8806 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
8807 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
8808 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
8809 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
8810 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8811 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
8812 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8813 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
8814 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
8815 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
8816 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
8817 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
8818 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8819 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
8820 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
8821 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
8822 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8823 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8824 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8825 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8826 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
8827 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
8828 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8829 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
8830 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8831 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8832 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8833 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8834 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8835 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144608e-04
8836 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8837 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8838 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
8839 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8840 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
8841 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
8842 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8843 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
8844 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8845 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
8846 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144608e-04
8847 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8848 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8849 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
8850 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
8851 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
8852 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
8853 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
8854 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144608e-04
8855 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144608e-04
8856 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
8857 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8858 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
8859 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
8860 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
8861 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
8862 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
8863 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
8864 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
8865 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8866 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8867 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8868 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8869 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8870 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
8871 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
8872 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
8873 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
8874 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8875 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
8876 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
8877 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
8878 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8879 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
8880 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
8881 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
8882 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144608e-04
8883 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
8884 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
8885 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144608e-04
8886 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
8887 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144607e-04
8888 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800943e+00 ||r(i)||/||b|| 2.081619144606e-04
8889 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144608e-04
8890 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800943e+00 ||r(i)||/||b|| 2.081619144606e-04
8891 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144608e-04
8892 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
8893 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800937e+00 ||r(i)||/||b|| 2.081619144605e-04
8894 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
8895 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144607e-04
8896 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8897 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
8898 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
8899 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
8900 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
8901 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800943e+00 ||r(i)||/||b|| 2.081619144606e-04
8902 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800943e+00 ||r(i)||/||b|| 2.081619144606e-04
8903 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800943e+00 ||r(i)||/||b|| 2.081619144606e-04
8904 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
8905 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800943e+00 ||r(i)||/||b|| 2.081619144606e-04
8906 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144608e-04
8907 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
8908 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800943e+00 ||r(i)||/||b|| 2.081619144606e-04
8909 KSP unpreconditioned resid norm 8.712485800955e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
8910 KSP unpreconditioned resid norm 8.712485800943e+00 true resid norm 8.712485800943e+00 ||r(i)||/||b|| 2.081619144606e-04
8911 KSP unpreconditioned resid norm 8.712485800943e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144608e-04
8912 KSP unpreconditioned resid norm 8.712485800943e+00 true resid norm 8.712485800943e+00 ||r(i)||/||b|| 2.081619144606e-04
8913 KSP unpreconditioned resid norm 8.712485800943e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
8914 KSP unpreconditioned resid norm 8.712485800943e+00 true resid norm 8.712485800943e+00 ||r(i)||/||b|| 2.081619144606e-04
8915 KSP unpreconditioned resid norm 8.712485800943e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144608e-04
8916 KSP unpreconditioned resid norm 8.712485800943e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144608e-04
8917 KSP unpreconditioned resid norm 8.712485800943e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8918 KSP unpreconditioned resid norm 8.712485800943e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144608e-04
8919 KSP unpreconditioned resid norm 8.712485800943e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144607e-04
8920 KSP unpreconditioned resid norm 8.712485800943e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144608e-04
8921 KSP unpreconditioned resid norm 8.712485800943e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144608e-04
8922 KSP unpreconditioned resid norm 8.712485800943e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144608e-04
8923 KSP unpreconditioned resid norm 8.712485800943e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144608e-04
8924 KSP unpreconditioned resid norm 8.712485800943e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144608e-04
8925 KSP unpreconditioned resid norm 8.712485800943e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144607e-04
8926 KSP unpreconditioned resid norm 8.712485800943e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
8927 KSP unpreconditioned resid norm 8.712485800943e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
8928 KSP unpreconditioned resid norm 8.712485800943e+00 true resid norm 8.712485800943e+00 ||r(i)||/||b|| 2.081619144606e-04
8929 KSP unpreconditioned resid norm 8.712485800943e+00 true resid norm 8.712485800943e+00 ||r(i)||/||b|| 2.081619144606e-04
8930 KSP unpreconditioned resid norm 8.712485800943e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
8931 KSP unpreconditioned resid norm 8.712485800943e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
8932 KSP unpreconditioned resid norm 8.712485800943e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144607e-04
8933 KSP unpreconditioned resid norm 8.712485800943e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8934 KSP unpreconditioned resid norm 8.712485800943e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144607e-04
8935 KSP unpreconditioned resid norm 8.712485800943e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144607e-04
8936 KSP unpreconditioned resid norm 8.712485800943e+00 true resid norm 8.712485800943e+00 ||r(i)||/||b|| 2.081619144606e-04
8937 KSP unpreconditioned resid norm 8.712485800943e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
8938 KSP unpreconditioned resid norm 8.712485800943e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
8939 KSP unpreconditioned resid norm 8.712485800943e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144608e-04
8940 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144607e-04
8941 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144608e-04
8942 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8943 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
8944 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144608e-04
8945 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
8946 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
8947 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144607e-04
8948 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800944e+00 ||r(i)||/||b|| 2.081619144606e-04
8949 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8950 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800943e+00 ||r(i)||/||b|| 2.081619144606e-04
8951 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800944e+00 ||r(i)||/||b|| 2.081619144606e-04
8952 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800944e+00 ||r(i)||/||b|| 2.081619144606e-04
8953 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
8954 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
8955 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
8956 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800943e+00 ||r(i)||/||b|| 2.081619144606e-04
8957 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144608e-04
8958 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
8959 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
8960 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800944e+00 ||r(i)||/||b|| 2.081619144606e-04
8961 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144607e-04
8962 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144608e-04
8963 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800944e+00 ||r(i)||/||b|| 2.081619144606e-04
8964 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144608e-04
8965 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144607e-04
8966 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144608e-04
8967 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800938e+00 ||r(i)||/||b|| 2.081619144605e-04
8968 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800944e+00 ||r(i)||/||b|| 2.081619144606e-04
8969 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144608e-04
8970 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144608e-04
8971 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144608e-04
8972 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
8973 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800944e+00 ||r(i)||/||b|| 2.081619144606e-04
8974 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800943e+00 ||r(i)||/||b|| 2.081619144606e-04
8975 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800943e+00 ||r(i)||/||b|| 2.081619144606e-04
8976 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800943e+00 ||r(i)||/||b|| 2.081619144606e-04
8977 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800944e+00 ||r(i)||/||b|| 2.081619144606e-04
8978 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800944e+00 ||r(i)||/||b|| 2.081619144606e-04
8979 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800937e+00 ||r(i)||/||b|| 2.081619144605e-04
8980 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
8981 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144608e-04
8982 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800943e+00 ||r(i)||/||b|| 2.081619144606e-04
8983 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144607e-04
8984 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800938e+00 ||r(i)||/||b|| 2.081619144605e-04
8985 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800944e+00 ||r(i)||/||b|| 2.081619144606e-04
8986 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800943e+00 ||r(i)||/||b|| 2.081619144606e-04
8987 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800943e+00 ||r(i)||/||b|| 2.081619144606e-04
8988 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800938e+00 ||r(i)||/||b|| 2.081619144605e-04
8989 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800943e+00 ||r(i)||/||b|| 2.081619144606e-04
8990 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800937e+00 ||r(i)||/||b|| 2.081619144605e-04
8991 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800944e+00 ||r(i)||/||b|| 2.081619144606e-04
8992 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144608e-04
8993 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800944e+00 ||r(i)||/||b|| 2.081619144606e-04
8994 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
8995 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
8996 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800944e+00 ||r(i)||/||b|| 2.081619144606e-04
8997 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
8998 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
8999 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800944e+00 ||r(i)||/||b|| 2.081619144606e-04
9000 KSP unpreconditioned resid norm 8.712485800938e+00 true resid norm 8.712485800938e+00 ||r(i)||/||b|| 2.081619144605e-04
9001 KSP unpreconditioned resid norm 8.712485800938e+00 true resid norm 8.712485800944e+00 ||r(i)||/||b|| 2.081619144606e-04
9002 KSP unpreconditioned resid norm 8.712485800938e+00 true resid norm 8.712485800937e+00 ||r(i)||/||b|| 2.081619144605e-04
9003 KSP unpreconditioned resid norm 8.712485800938e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144607e-04
9004 KSP unpreconditioned resid norm 8.712485800938e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144607e-04
9005 KSP unpreconditioned resid norm 8.712485800938e+00 true resid norm 8.712485800938e+00 ||r(i)||/||b|| 2.081619144605e-04
9006 KSP unpreconditioned resid norm 8.712485800938e+00 true resid norm 8.712485800943e+00 ||r(i)||/||b|| 2.081619144606e-04
9007 KSP unpreconditioned resid norm 8.712485800938e+00 true resid norm 8.712485800937e+00 ||r(i)||/||b|| 2.081619144605e-04
9008 KSP unpreconditioned resid norm 8.712485800938e+00 true resid norm 8.712485800938e+00 ||r(i)||/||b|| 2.081619144605e-04
9009 KSP unpreconditioned resid norm 8.712485800938e+00 true resid norm 8.712485800937e+00 ||r(i)||/||b|| 2.081619144605e-04
9010 KSP unpreconditioned resid norm 8.712485800938e+00 true resid norm 8.712485800943e+00 ||r(i)||/||b|| 2.081619144606e-04
9011 KSP unpreconditioned resid norm 8.712485800938e+00 true resid norm 8.712485800943e+00 ||r(i)||/||b|| 2.081619144606e-04
9012 KSP unpreconditioned resid norm 8.712485800938e+00 true resid norm 8.712485800943e+00 ||r(i)||/||b|| 2.081619144606e-04
9013 KSP unpreconditioned resid norm 8.712485800938e+00 true resid norm 8.712485800937e+00 ||r(i)||/||b|| 2.081619144605e-04
9014 KSP unpreconditioned resid norm 8.712485800938e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
9015 KSP unpreconditioned resid norm 8.712485800938e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
9016 KSP unpreconditioned resid norm 8.712485800938e+00 true resid norm 8.712485800938e+00 ||r(i)||/||b|| 2.081619144605e-04
9017 KSP unpreconditioned resid norm 8.712485800938e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144608e-04
9018 KSP unpreconditioned resid norm 8.712485800938e+00 true resid norm 8.712485800937e+00 ||r(i)||/||b|| 2.081619144605e-04
9019 KSP unpreconditioned resid norm 8.712485800938e+00 true resid norm 8.712485800944e+00 ||r(i)||/||b|| 2.081619144606e-04
9020 KSP unpreconditioned resid norm 8.712485800938e+00 true resid norm 8.712485800938e+00 ||r(i)||/||b|| 2.081619144605e-04
9021 KSP unpreconditioned resid norm 8.712485800938e+00 true resid norm 8.712485800943e+00 ||r(i)||/||b|| 2.081619144606e-04
9022 KSP unpreconditioned resid norm 8.712485800938e+00 true resid norm 8.712485800943e+00 ||r(i)||/||b|| 2.081619144606e-04
9023 KSP unpreconditioned resid norm 8.712485800938e+00 true resid norm 8.712485800931e+00 ||r(i)||/||b|| 2.081619144603e-04
9024 KSP unpreconditioned resid norm 8.712485800938e+00 true resid norm 8.712485800944e+00 ||r(i)||/||b|| 2.081619144606e-04
9025 KSP unpreconditioned resid norm 8.712485800938e+00 true resid norm 8.712485800943e+00 ||r(i)||/||b|| 2.081619144606e-04
9026 KSP unpreconditioned resid norm 8.712485800938e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144607e-04
9027 KSP unpreconditioned resid norm 8.712485800938e+00 true resid norm 8.712485800938e+00 ||r(i)||/||b|| 2.081619144605e-04
9028 KSP unpreconditioned resid norm 8.712485800938e+00 true resid norm 8.712485800938e+00 ||r(i)||/||b|| 2.081619144605e-04
9029 KSP unpreconditioned resid norm 8.712485800938e+00 true resid norm 8.712485800943e+00 ||r(i)||/||b|| 2.081619144606e-04
9030 KSP unpreconditioned resid norm 8.712485800944e+00 true resid norm 8.712485800944e+00 ||r(i)||/||b|| 2.081619144606e-04
9031 KSP unpreconditioned resid norm 8.712485800944e+00 true resid norm 8.712485800943e+00 ||r(i)||/||b|| 2.081619144606e-04
9032 KSP unpreconditioned resid norm 8.712485800944e+00 true resid norm 8.712485800943e+00 ||r(i)||/||b|| 2.081619144606e-04
9033 KSP unpreconditioned resid norm 8.712485800944e+00 true resid norm 8.712485800937e+00 ||r(i)||/||b|| 2.081619144605e-04
9034 KSP unpreconditioned resid norm 8.712485800944e+00 true resid norm 8.712485800944e+00 ||r(i)||/||b|| 2.081619144606e-04
9035 KSP unpreconditioned resid norm 8.712485800944e+00 true resid norm 8.712485800943e+00 ||r(i)||/||b|| 2.081619144606e-04
9036 KSP unpreconditioned resid norm 8.712485800944e+00 true resid norm 8.712485800943e+00 ||r(i)||/||b|| 2.081619144606e-04
9037 KSP unpreconditioned resid norm 8.712485800944e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144608e-04
9038 KSP unpreconditioned resid norm 8.712485800944e+00 true resid norm 8.712485800938e+00 ||r(i)||/||b|| 2.081619144605e-04
9039 KSP unpreconditioned resid norm 8.712485800944e+00 true resid norm 8.712485800943e+00 ||r(i)||/||b|| 2.081619144606e-04
9040 KSP unpreconditioned resid norm 8.712485800944e+00 true resid norm 8.712485800937e+00 ||r(i)||/||b|| 2.081619144605e-04
9041 KSP unpreconditioned resid norm 8.712485800944e+00 true resid norm 8.712485800944e+00 ||r(i)||/||b|| 2.081619144606e-04
9042 KSP unpreconditioned resid norm 8.712485800944e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144608e-04
9043 KSP unpreconditioned resid norm 8.712485800944e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144608e-04
9044 KSP unpreconditioned resid norm 8.712485800944e+00 true resid norm 8.712485800937e+00 ||r(i)||/||b|| 2.081619144605e-04
9045 KSP unpreconditioned resid norm 8.712485800944e+00 true resid norm 8.712485800937e+00 ||r(i)||/||b|| 2.081619144605e-04
9046 KSP unpreconditioned resid norm 8.712485800944e+00 true resid norm 8.712485800931e+00 ||r(i)||/||b|| 2.081619144603e-04
9047 KSP unpreconditioned resid norm 8.712485800944e+00 true resid norm 8.712485800937e+00 ||r(i)||/||b|| 2.081619144605e-04
9048 KSP unpreconditioned resid norm 8.712485800944e+00 true resid norm 8.712485800944e+00 ||r(i)||/||b|| 2.081619144606e-04
9049 KSP unpreconditioned resid norm 8.712485800944e+00 true resid norm 8.712485800944e+00 ||r(i)||/||b|| 2.081619144606e-04
9050 KSP unpreconditioned resid norm 8.712485800944e+00 true resid norm 8.712485800944e+00 ||r(i)||/||b|| 2.081619144606e-04
9051 KSP unpreconditioned resid norm 8.712485800944e+00 true resid norm 8.712485800943e+00 ||r(i)||/||b|| 2.081619144606e-04
9052 KSP unpreconditioned resid norm 8.712485800944e+00 true resid norm 8.712485800925e+00 ||r(i)||/||b|| 2.081619144602e-04
9053 KSP unpreconditioned resid norm 8.712485800944e+00 true resid norm 8.712485800943e+00 ||r(i)||/||b|| 2.081619144606e-04
9054 KSP unpreconditioned resid norm 8.712485800944e+00 true resid norm 8.712485800943e+00 ||r(i)||/||b|| 2.081619144606e-04
9055 KSP unpreconditioned resid norm 8.712485800944e+00 true resid norm 8.712485800943e+00 ||r(i)||/||b|| 2.081619144606e-04
9056 KSP unpreconditioned resid norm 8.712485800944e+00 true resid norm 8.712485800943e+00 ||r(i)||/||b|| 2.081619144606e-04
9057 KSP unpreconditioned resid norm 8.712485800944e+00 true resid norm 8.712485800943e+00 ||r(i)||/||b|| 2.081619144606e-04
9058 KSP unpreconditioned resid norm 8.712485800944e+00 true resid norm 8.712485800944e+00 ||r(i)||/||b|| 2.081619144606e-04
9059 KSP unpreconditioned resid norm 8.712485800944e+00 true resid norm 8.712485800943e+00 ||r(i)||/||b|| 2.081619144606e-04
9060 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
9061 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800938e+00 ||r(i)||/||b|| 2.081619144605e-04
9062 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
9063 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
9064 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144608e-04
9065 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800944e+00 ||r(i)||/||b|| 2.081619144606e-04
9066 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144608e-04
9067 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
9068 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
9069 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144608e-04
9070 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
9071 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800938e+00 ||r(i)||/||b|| 2.081619144605e-04
9072 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800944e+00 ||r(i)||/||b|| 2.081619144606e-04
9073 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800937e+00 ||r(i)||/||b|| 2.081619144605e-04
9074 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800943e+00 ||r(i)||/||b|| 2.081619144606e-04
9075 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
9076 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
9077 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
9078 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800944e+00 ||r(i)||/||b|| 2.081619144606e-04
9079 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
9080 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800944e+00 ||r(i)||/||b|| 2.081619144606e-04
9081 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800944e+00 ||r(i)||/||b|| 2.081619144606e-04
9082 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800943e+00 ||r(i)||/||b|| 2.081619144606e-04
9083 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800937e+00 ||r(i)||/||b|| 2.081619144605e-04
9084 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800943e+00 ||r(i)||/||b|| 2.081619144606e-04
9085 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
9086 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800937e+00 ||r(i)||/||b|| 2.081619144605e-04
9087 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9088 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
9089 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800944e+00 ||r(i)||/||b|| 2.081619144606e-04
9090 KSP unpreconditioned resid norm 8.712485800937e+00 true resid norm 8.712485800937e+00 ||r(i)||/||b|| 2.081619144605e-04
9091 KSP unpreconditioned resid norm 8.712485800937e+00 true resid norm 8.712485800932e+00 ||r(i)||/||b|| 2.081619144603e-04
9092 KSP unpreconditioned resid norm 8.712485800937e+00 true resid norm 8.712485800944e+00 ||r(i)||/||b|| 2.081619144606e-04
9093 KSP unpreconditioned resid norm 8.712485800937e+00 true resid norm 8.712485800944e+00 ||r(i)||/||b|| 2.081619144606e-04
9094 KSP unpreconditioned resid norm 8.712485800937e+00 true resid norm 8.712485800937e+00 ||r(i)||/||b|| 2.081619144605e-04
9095 KSP unpreconditioned resid norm 8.712485800937e+00 true resid norm 8.712485800938e+00 ||r(i)||/||b|| 2.081619144605e-04
9096 KSP unpreconditioned resid norm 8.712485800937e+00 true resid norm 8.712485800932e+00 ||r(i)||/||b|| 2.081619144603e-04
9097 KSP unpreconditioned resid norm 8.712485800937e+00 true resid norm 8.712485800937e+00 ||r(i)||/||b|| 2.081619144605e-04
9098 KSP unpreconditioned resid norm 8.712485800937e+00 true resid norm 8.712485800944e+00 ||r(i)||/||b|| 2.081619144606e-04
9099 KSP unpreconditioned resid norm 8.712485800937e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
9100 KSP unpreconditioned resid norm 8.712485800937e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9101 KSP unpreconditioned resid norm 8.712485800937e+00 true resid norm 8.712485800943e+00 ||r(i)||/||b|| 2.081619144606e-04
9102 KSP unpreconditioned resid norm 8.712485800937e+00 true resid norm 8.712485800943e+00 ||r(i)||/||b|| 2.081619144606e-04
9103 KSP unpreconditioned resid norm 8.712485800937e+00 true resid norm 8.712485800943e+00 ||r(i)||/||b|| 2.081619144606e-04
9104 KSP unpreconditioned resid norm 8.712485800937e+00 true resid norm 8.712485800938e+00 ||r(i)||/||b|| 2.081619144605e-04
9105 KSP unpreconditioned resid norm 8.712485800937e+00 true resid norm 8.712485800943e+00 ||r(i)||/||b|| 2.081619144606e-04
9106 KSP unpreconditioned resid norm 8.712485800937e+00 true resid norm 8.712485800931e+00 ||r(i)||/||b|| 2.081619144603e-04
9107 KSP unpreconditioned resid norm 8.712485800937e+00 true resid norm 8.712485800938e+00 ||r(i)||/||b|| 2.081619144605e-04
9108 KSP unpreconditioned resid norm 8.712485800937e+00 true resid norm 8.712485800944e+00 ||r(i)||/||b|| 2.081619144606e-04
9109 KSP unpreconditioned resid norm 8.712485800937e+00 true resid norm 8.712485800938e+00 ||r(i)||/||b|| 2.081619144605e-04
9110 KSP unpreconditioned resid norm 8.712485800937e+00 true resid norm 8.712485800931e+00 ||r(i)||/||b|| 2.081619144603e-04
9111 KSP unpreconditioned resid norm 8.712485800937e+00 true resid norm 8.712485800937e+00 ||r(i)||/||b|| 2.081619144605e-04
9112 KSP unpreconditioned resid norm 8.712485800937e+00 true resid norm 8.712485800943e+00 ||r(i)||/||b|| 2.081619144606e-04
9113 KSP unpreconditioned resid norm 8.712485800937e+00 true resid norm 8.712485800937e+00 ||r(i)||/||b|| 2.081619144605e-04
9114 KSP unpreconditioned resid norm 8.712485800937e+00 true resid norm 8.712485800944e+00 ||r(i)||/||b|| 2.081619144606e-04
9115 KSP unpreconditioned resid norm 8.712485800937e+00 true resid norm 8.712485800937e+00 ||r(i)||/||b|| 2.081619144605e-04
9116 KSP unpreconditioned resid norm 8.712485800937e+00 true resid norm 8.712485800944e+00 ||r(i)||/||b|| 2.081619144606e-04
9117 KSP unpreconditioned resid norm 8.712485800937e+00 true resid norm 8.712485800943e+00 ||r(i)||/||b|| 2.081619144606e-04
9118 KSP unpreconditioned resid norm 8.712485800937e+00 true resid norm 8.712485800938e+00 ||r(i)||/||b|| 2.081619144605e-04
9119 KSP unpreconditioned resid norm 8.712485800937e+00 true resid norm 8.712485800943e+00 ||r(i)||/||b|| 2.081619144606e-04
9120 KSP unpreconditioned resid norm 8.712485800937e+00 true resid norm 8.712485800937e+00 ||r(i)||/||b|| 2.081619144605e-04
9121 KSP unpreconditioned resid norm 8.712485800937e+00 true resid norm 8.712485800937e+00 ||r(i)||/||b|| 2.081619144605e-04
9122 KSP unpreconditioned resid norm 8.712485800937e+00 true resid norm 8.712485800944e+00 ||r(i)||/||b|| 2.081619144606e-04
9123 KSP unpreconditioned resid norm 8.712485800937e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
9124 KSP unpreconditioned resid norm 8.712485800937e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
9125 KSP unpreconditioned resid norm 8.712485800937e+00 true resid norm 8.712485800944e+00 ||r(i)||/||b|| 2.081619144606e-04
9126 KSP unpreconditioned resid norm 8.712485800937e+00 true resid norm 8.712485800937e+00 ||r(i)||/||b|| 2.081619144605e-04
9127 KSP unpreconditioned resid norm 8.712485800937e+00 true resid norm 8.712485800943e+00 ||r(i)||/||b|| 2.081619144606e-04
9128 KSP unpreconditioned resid norm 8.712485800937e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
9129 KSP unpreconditioned resid norm 8.712485800937e+00 true resid norm 8.712485800937e+00 ||r(i)||/||b|| 2.081619144605e-04
9130 KSP unpreconditioned resid norm 8.712485800937e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144607e-04
9131 KSP unpreconditioned resid norm 8.712485800937e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144608e-04
9132 KSP unpreconditioned resid norm 8.712485800937e+00 true resid norm 8.712485800943e+00 ||r(i)||/||b|| 2.081619144606e-04
9133 KSP unpreconditioned resid norm 8.712485800937e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144608e-04
9134 KSP unpreconditioned resid norm 8.712485800937e+00 true resid norm 8.712485800937e+00 ||r(i)||/||b|| 2.081619144605e-04
9135 KSP unpreconditioned resid norm 8.712485800937e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144608e-04
9136 KSP unpreconditioned resid norm 8.712485800937e+00 true resid norm 8.712485800943e+00 ||r(i)||/||b|| 2.081619144606e-04
9137 KSP unpreconditioned resid norm 8.712485800937e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144608e-04
9138 KSP unpreconditioned resid norm 8.712485800937e+00 true resid norm 8.712485800943e+00 ||r(i)||/||b|| 2.081619144606e-04
9139 KSP unpreconditioned resid norm 8.712485800937e+00 true resid norm 8.712485800937e+00 ||r(i)||/||b|| 2.081619144605e-04
9140 KSP unpreconditioned resid norm 8.712485800937e+00 true resid norm 8.712485800938e+00 ||r(i)||/||b|| 2.081619144605e-04
9141 KSP unpreconditioned resid norm 8.712485800937e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144608e-04
9142 KSP unpreconditioned resid norm 8.712485800937e+00 true resid norm 8.712485800943e+00 ||r(i)||/||b|| 2.081619144606e-04
9143 KSP unpreconditioned resid norm 8.712485800937e+00 true resid norm 8.712485800937e+00 ||r(i)||/||b|| 2.081619144605e-04
9144 KSP unpreconditioned resid norm 8.712485800937e+00 true resid norm 8.712485800943e+00 ||r(i)||/||b|| 2.081619144606e-04
9145 KSP unpreconditioned resid norm 8.712485800937e+00 true resid norm 8.712485800938e+00 ||r(i)||/||b|| 2.081619144605e-04
9146 KSP unpreconditioned resid norm 8.712485800937e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
9147 KSP unpreconditioned resid norm 8.712485800937e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9148 KSP unpreconditioned resid norm 8.712485800937e+00 true resid norm 8.712485800937e+00 ||r(i)||/||b|| 2.081619144605e-04
9149 KSP unpreconditioned resid norm 8.712485800937e+00 true resid norm 8.712485800944e+00 ||r(i)||/||b|| 2.081619144606e-04
9150 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144608e-04
9151 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144608e-04
9152 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
9153 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800943e+00 ||r(i)||/||b|| 2.081619144606e-04
9154 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800937e+00 ||r(i)||/||b|| 2.081619144605e-04
9155 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144608e-04
9156 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800943e+00 ||r(i)||/||b|| 2.081619144606e-04
9157 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
9158 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800943e+00 ||r(i)||/||b|| 2.081619144606e-04
9159 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800944e+00 ||r(i)||/||b|| 2.081619144606e-04
9160 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144608e-04
9161 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144608e-04
9162 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144608e-04
9163 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800943e+00 ||r(i)||/||b|| 2.081619144606e-04
9164 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
9165 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
9166 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
9167 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800943e+00 ||r(i)||/||b|| 2.081619144606e-04
9168 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
9169 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800937e+00 ||r(i)||/||b|| 2.081619144605e-04
9170 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
9171 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144608e-04
9172 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800943e+00 ||r(i)||/||b|| 2.081619144606e-04
9173 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144607e-04
9174 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800943e+00 ||r(i)||/||b|| 2.081619144606e-04
9175 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
9176 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
9177 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144608e-04
9178 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800943e+00 ||r(i)||/||b|| 2.081619144606e-04
9179 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
9180 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144608e-04
9181 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144607e-04
9182 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
9183 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
9184 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144607e-04
9185 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
9186 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800943e+00 ||r(i)||/||b|| 2.081619144606e-04
9187 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144608e-04
9188 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144607e-04
9189 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144608e-04
9190 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
9191 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9192 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800937e+00 ||r(i)||/||b|| 2.081619144605e-04
9193 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9194 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
9195 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9196 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
9197 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144607e-04
9198 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800943e+00 ||r(i)||/||b|| 2.081619144606e-04
9199 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
9200 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144608e-04
9201 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144608e-04
9202 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144608e-04
9203 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
9204 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144608e-04
9205 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144608e-04
9206 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800937e+00 ||r(i)||/||b|| 2.081619144605e-04
9207 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800938e+00 ||r(i)||/||b|| 2.081619144605e-04
9208 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800943e+00 ||r(i)||/||b|| 2.081619144606e-04
9209 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800944e+00 ||r(i)||/||b|| 2.081619144606e-04
9210 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144608e-04
9211 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9212 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
9213 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800944e+00 ||r(i)||/||b|| 2.081619144606e-04
9214 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
9215 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800944e+00 ||r(i)||/||b|| 2.081619144606e-04
9216 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800944e+00 ||r(i)||/||b|| 2.081619144606e-04
9217 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
9218 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
9219 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9220 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
9221 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9222 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144608e-04
9223 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144608e-04
9224 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
9225 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800944e+00 ||r(i)||/||b|| 2.081619144606e-04
9226 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
9227 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9228 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
9229 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800943e+00 ||r(i)||/||b|| 2.081619144606e-04
9230 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144608e-04
9231 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
9232 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800943e+00 ||r(i)||/||b|| 2.081619144606e-04
9233 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800944e+00 ||r(i)||/||b|| 2.081619144606e-04
9234 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
9235 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
9236 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
9237 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144608e-04
9238 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
9239 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
9240 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
9241 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9242 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
9243 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9244 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
9245 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9246 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
9247 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144608e-04
9248 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800944e+00 ||r(i)||/||b|| 2.081619144606e-04
9249 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9250 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
9251 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9252 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
9253 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9254 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9255 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800943e+00 ||r(i)||/||b|| 2.081619144606e-04
9256 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800944e+00 ||r(i)||/||b|| 2.081619144606e-04
9257 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9258 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9259 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
9260 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9261 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
9262 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
9263 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
9264 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9265 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9266 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9267 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
9268 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9269 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800944e+00 ||r(i)||/||b|| 2.081619144606e-04
9270 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9271 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
9272 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9273 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9274 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9275 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
9276 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9277 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
9278 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
9279 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9280 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
9281 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9282 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800944e+00 ||r(i)||/||b|| 2.081619144606e-04
9283 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
9284 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9285 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
9286 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9287 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9288 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9289 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
9290 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9291 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
9292 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9293 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9294 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144608e-04
9295 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
9296 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
9297 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
9298 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
9299 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
9300 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144607e-04
9301 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
9302 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
9303 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
9304 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800943e+00 ||r(i)||/||b|| 2.081619144606e-04
9305 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
9306 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
9307 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
9308 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144608e-04
9309 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800943e+00 ||r(i)||/||b|| 2.081619144606e-04
9310 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800943e+00 ||r(i)||/||b|| 2.081619144606e-04
9311 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144608e-04
9312 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144607e-04
9313 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9314 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9315 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
9316 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9317 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144607e-04
9318 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
9319 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144608e-04
9320 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9321 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
9322 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144608e-04
9323 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144608e-04
9324 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
9325 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800944e+00 ||r(i)||/||b|| 2.081619144606e-04
9326 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800943e+00 ||r(i)||/||b|| 2.081619144606e-04
9327 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9328 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9329 KSP unpreconditioned resid norm 8.712485800949e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
9330 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9331 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9332 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144608e-04
9333 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9334 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9335 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9336 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9337 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144608e-04
9338 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9339 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9340 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9341 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9342 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9343 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9344 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800944e+00 ||r(i)||/||b|| 2.081619144606e-04
9345 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9346 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9347 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
9348 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
9349 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
9350 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9351 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
9352 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9353 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
9354 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
9355 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9356 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9357 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
9358 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9359 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9360 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
9361 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800944e+00 ||r(i)||/||b|| 2.081619144606e-04
9362 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800944e+00 ||r(i)||/||b|| 2.081619144606e-04
9363 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800944e+00 ||r(i)||/||b|| 2.081619144606e-04
9364 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
9365 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
9366 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9367 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9368 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
9369 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
9370 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
9371 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9372 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
9373 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9374 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
9375 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144607e-04
9376 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144608e-04
9377 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
9378 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144608e-04
9379 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9380 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144608e-04
9381 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
9382 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9383 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
9384 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9385 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9386 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144608e-04
9387 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
9388 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144608e-04
9389 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144608e-04
9390 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9391 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9392 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
9393 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9394 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9395 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144608e-04
9396 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9397 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
9398 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
9399 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9400 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9401 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
9402 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9403 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
9404 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9405 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9406 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9407 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9408 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9409 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
9410 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
9411 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800943e+00 ||r(i)||/||b|| 2.081619144606e-04
9412 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9413 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9414 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9415 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
9416 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
9417 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
9418 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
9419 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9420 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
9421 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9422 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
9423 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
9424 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
9425 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9426 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9427 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
9428 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
9429 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
9430 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
9431 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
9432 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
9433 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
9434 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
9435 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
9436 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
9437 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9438 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
9439 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
9440 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
9441 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
9442 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
9443 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
9444 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
9445 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9446 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
9447 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144607e-04
9448 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9449 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
9450 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
9451 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9452 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
9453 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
9454 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9455 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
9456 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9457 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9458 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9459 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9460 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9461 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9462 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9463 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
9464 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9465 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
9466 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9467 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
9468 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
9469 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9470 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9471 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
9472 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9473 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
9474 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9475 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
9476 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
9477 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
9478 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
9479 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
9480 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
9481 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
9482 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
9483 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9484 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9485 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
9486 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9487 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9488 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9489 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9490 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9491 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
9492 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
9493 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9494 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
9495 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9496 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
9497 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
9498 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
9499 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9500 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9501 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9502 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9503 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9504 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9505 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9506 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
9507 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9508 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9509 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9510 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9511 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9512 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
9513 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9514 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9515 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
9516 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
9517 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
9518 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
9519 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
9520 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
9521 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
9522 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9523 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9524 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9525 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9526 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9527 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9528 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9529 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9530 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9531 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
9532 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9533 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9534 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9535 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9536 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
9537 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
9538 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
9539 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9540 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
9541 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9542 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9543 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9544 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
9545 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9546 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
9547 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9548 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
9549 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
9550 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9551 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
9552 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
9553 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
9554 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9555 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
9556 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
9557 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9558 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
9559 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9560 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9561 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
9562 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9563 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9564 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9565 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9566 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
9567 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9568 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9569 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
9570 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
9571 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9572 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
9573 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9574 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
9575 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
9576 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9577 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9578 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9579 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9580 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
9581 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
9582 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
9583 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
9584 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9585 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9586 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9587 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
9588 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9589 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9590 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9591 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
9592 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
9593 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9594 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9595 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
9596 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9597 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
9598 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9599 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
9600 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9601 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
9602 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
9603 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
9604 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9605 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
9606 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9607 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9608 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9609 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
9610 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
9611 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9612 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
9613 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9614 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
9615 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
9616 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
9617 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
9618 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
9619 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9620 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
9621 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
9622 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
9623 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9624 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
9625 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
9626 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
9627 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
9628 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
9629 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
9630 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9631 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
9632 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
9633 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
9634 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9635 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9636 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
9637 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
9638 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9639 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9640 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
9641 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9642 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9643 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
9644 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9645 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9646 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
9647 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9648 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
9649 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9650 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9651 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
9652 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9653 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9654 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9655 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9656 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
9657 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
9658 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9659 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
9660 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9661 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
9662 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9663 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
9664 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9665 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
9666 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
9667 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
9668 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9669 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
9670 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9671 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9672 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
9673 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9674 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9675 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
9676 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9677 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9678 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
9679 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
9680 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
9681 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9682 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9683 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9684 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9685 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
9686 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9687 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9688 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9689 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9690 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9691 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9692 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9693 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9694 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9695 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9696 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9697 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9698 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9699 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
9700 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
9701 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9702 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9703 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9704 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9705 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
9706 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9707 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9708 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9709 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
9710 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9711 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
9712 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9713 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9714 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9715 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
9716 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
9717 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
9718 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
9719 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
9720 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9721 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
9722 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9723 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9724 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9725 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
9726 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
9727 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9728 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9729 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9730 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9731 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9732 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9733 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9734 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9735 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9736 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
9737 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
9738 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9739 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
9740 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
9741 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9742 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
9743 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
9744 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9745 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9746 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9747 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9748 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
9749 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
9750 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
9751 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
9752 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
9753 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9754 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
9755 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
9756 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
9757 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
9758 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
9759 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
9760 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
9761 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
9762 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
9763 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
9764 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9765 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
9766 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9767 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
9768 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
9769 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9770 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9771 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9772 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
9773 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
9774 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9775 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
9776 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
9777 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9778 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
9779 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9780 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9781 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9782 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9783 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9784 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9785 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
9786 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
9787 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9788 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9789 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
9790 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
9791 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
9792 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
9793 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
9794 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
9795 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
9796 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
9797 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
9798 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
9799 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9800 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9801 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9802 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9803 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9804 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
9805 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9806 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
9807 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9808 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9809 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
9810 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
9811 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9812 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
9813 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9814 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9815 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9816 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9817 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
9818 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
9819 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9820 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9821 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
9822 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
9823 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9824 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
9825 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
9826 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
9827 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
9828 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9829 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
9830 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
9831 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
9832 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9833 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9834 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
9835 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
9836 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
9837 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
9838 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
9839 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9840 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9841 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
9842 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9843 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9844 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
9845 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
9846 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
9847 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
9848 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
9849 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
9850 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
9851 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
9852 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9853 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
9854 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
9855 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
9856 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
9857 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
9858 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
9859 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9860 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9861 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9862 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
9863 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
9864 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9865 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
9866 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9867 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
9868 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
9869 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9870 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9871 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
9872 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9873 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
9874 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
9875 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
9876 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9877 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9878 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9879 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9880 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
9881 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
9882 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
9883 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
9884 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9885 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9886 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
9887 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
9888 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9889 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
9890 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
9891 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
9892 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
9893 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9894 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9895 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
9896 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
9897 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9898 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
9899 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
9900 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9901 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
9902 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9903 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9904 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9905 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
9906 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9907 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
9908 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9909 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
9910 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
9911 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
9912 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9913 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9914 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
9915 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
9916 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
9917 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9918 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
9919 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
9920 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
9921 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9922 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9923 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
9924 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9925 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
9926 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
9927 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
9928 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9929 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
9930 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
9931 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
9932 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9933 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
9934 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9935 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9936 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
9937 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9938 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
9939 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
9940 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
9941 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9942 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9943 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9944 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9945 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
9946 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9947 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9948 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9949 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9950 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9951 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9952 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9953 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9954 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
9955 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9956 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9957 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
9958 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
9959 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9960 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9961 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9962 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9963 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
9964 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9965 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9966 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
9967 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
9968 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9969 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
9970 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
9971 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9972 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9973 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
9974 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9975 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9976 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
9977 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9978 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
9979 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9980 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9981 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9982 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9983 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9984 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
9985 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
9986 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9987 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9988 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
9989 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
9990 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
9991 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9992 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
9993 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
9994 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9995 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9996 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
9997 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
9998 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
9999 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
10000 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
Linear P_ solve did not converge due to DIVERGED_ITS iterations 10000
[ERROR] snesP diverged with reason -3
Checking 0
Time Step: 0
Residual norms for P_ solve.
0 KSP unpreconditioned resid norm 4.185437006342e+04 true resid norm 4.185437006342e+04 ||r(i)||/||b|| 1.000000000000e+00
1 KSP unpreconditioned resid norm 4.184640887695e+04 true resid norm 4.184640887695e+04 ||r(i)||/||b|| 9.998097884056e-01
2 KSP unpreconditioned resid norm 4.171213485177e+04 true resid norm 4.171213485177e+04 ||r(i)||/||b|| 9.966016640215e-01
3 KSP unpreconditioned resid norm 4.093622417125e+04 true resid norm 4.093622417127e+04 ||r(i)||/||b|| 9.780633207295e-01
4 KSP unpreconditioned resid norm 3.840582270678e+04 true resid norm 3.840582270683e+04 ||r(i)||/||b|| 9.176060384768e-01
5 KSP unpreconditioned resid norm 3.322460159635e+04 true resid norm 3.322460159653e+04 ||r(i)||/||b|| 7.938143985010e-01
6 KSP unpreconditioned resid norm 2.634213498990e+04 true resid norm 2.634213499031e+04 ||r(i)||/||b|| 6.293759755648e-01
7 KSP unpreconditioned resid norm 1.980381737493e+04 true resid norm 1.980381737555e+04 ||r(i)||/||b|| 4.731600868809e-01
8 KSP unpreconditioned resid norm 1.467692800940e+04 true resid norm 1.467692800998e+04 ||r(i)||/||b|| 3.506665609288e-01
9 KSP unpreconditioned resid norm 1.096469054164e+04 true resid norm 1.096469054172e+04 ||r(i)||/||b|| 2.619724182949e-01
10 KSP unpreconditioned resid norm 8.328970656537e+03 true resid norm 8.328970656600e+03 ||r(i)||/||b|| 1.989988296080e-01
11 KSP unpreconditioned resid norm 6.445663747163e+03 true resid norm 6.445663747246e+03 ||r(i)||/||b|| 1.540021684111e-01
12 KSP unpreconditioned resid norm 5.078356973787e+03 true resid norm 5.078356973862e+03 ||r(i)||/||b|| 1.213339722033e-01
13 KSP unpreconditioned resid norm 4.154673390757e+03 true resid norm 4.154673390890e+03 ||r(i)||/||b|| 9.926498438741e-02
14 KSP unpreconditioned resid norm 3.356737749834e+03 true resid norm 3.356737749909e+03 ||r(i)||/||b|| 8.020041264085e-02
15 KSP unpreconditioned resid norm 2.681812457336e+03 true resid norm 2.681812457321e+03 ||r(i)||/||b|| 6.407484937074e-02
16 KSP unpreconditioned resid norm 2.149016260026e+03 true resid norm 2.149016260045e+03 ||r(i)||/||b|| 5.134508670873e-02
17 KSP unpreconditioned resid norm 1.748364269419e+03 true resid norm 1.748364269532e+03 ||r(i)||/||b|| 4.177256202598e-02
18 KSP unpreconditioned resid norm 1.459185573394e+03 true resid norm 1.459185573427e+03 ||r(i)||/||b|| 3.486339828352e-02
19 KSP unpreconditioned resid norm 1.225194416364e+03 true resid norm 1.225194416368e+03 ||r(i)||/||b|| 2.927279551722e-02
20 KSP unpreconditioned resid norm 1.031914188646e+03 true resid norm 1.031914188695e+03 ||r(i)||/||b|| 2.465487324577e-02
21 KSP unpreconditioned resid norm 8.735852793236e+02 true resid norm 8.735852793422e+02 ||r(i)||/||b|| 2.087202072373e-02
22 KSP unpreconditioned resid norm 7.443917521568e+02 true resid norm 7.443917521724e+02 ||r(i)||/||b|| 1.778528146630e-02
23 KSP unpreconditioned resid norm 6.387343091504e+02 true resid norm 6.387343091529e+02 ||r(i)||/||b|| 1.526087498594e-02
24 KSP unpreconditioned resid norm 5.501010666818e+02 true resid norm 5.501010666948e+02 ||r(i)||/||b|| 1.314321696543e-02
25 KSP unpreconditioned resid norm 4.783227223974e+02 true resid norm 4.783227223986e+02 ||r(i)||/||b|| 1.142826236959e-02
26 KSP unpreconditioned resid norm 4.219894039272e+02 true resid norm 4.219894039439e+02 ||r(i)||/||b|| 1.008232601051e-02
27 KSP unpreconditioned resid norm 3.772321733981e+02 true resid norm 3.772321733970e+02 ||r(i)||/||b|| 9.012969800417e-03
28 KSP unpreconditioned resid norm 3.408912515859e+02 true resid norm 3.408912515975e+02 ||r(i)||/||b|| 8.144699133711e-03
29 KSP unpreconditioned resid norm 3.104197243561e+02 true resid norm 3.104197243723e+02 ||r(i)||/||b|| 7.416662200434e-03
30 KSP unpreconditioned resid norm 2.844309566432e+02 true resid norm 2.844309566432e+02 ||r(i)||/||b|| 6.795729005412e-03
31 KSP unpreconditioned resid norm 2.725558244331e+02 true resid norm 2.725558244331e+02 ||r(i)||/||b|| 6.512003979994e-03
32 KSP unpreconditioned resid norm 2.606960762248e+02 true resid norm 2.606960762248e+02 ||r(i)||/||b|| 6.228646514804e-03
33 KSP unpreconditioned resid norm 2.488650158858e+02 true resid norm 2.488650158858e+02 ||r(i)||/||b|| 5.945974470735e-03
34 KSP unpreconditioned resid norm 2.368499267478e+02 true resid norm 2.368499267478e+02 ||r(i)||/||b|| 5.658905542932e-03
35 KSP unpreconditioned resid norm 2.247395208302e+02 true resid norm 2.247395208302e+02 ||r(i)||/||b|| 5.369559271582e-03
36 KSP unpreconditioned resid norm 2.125548513132e+02 true resid norm 2.125548513132e+02 ||r(i)||/||b|| 5.078438667005e-03
37 KSP unpreconditioned resid norm 2.018421848568e+02 true resid norm 2.018421848568e+02 ||r(i)||/||b|| 4.822487700830e-03
38 KSP unpreconditioned resid norm 1.929964456490e+02 true resid norm 1.929964456490e+02 ||r(i)||/||b|| 4.611142046973e-03
39 KSP unpreconditioned resid norm 1.854409542298e+02 true resid norm 1.854409542298e+02 ||r(i)||/||b|| 4.430623467724e-03
40 KSP unpreconditioned resid norm 1.781632871563e+02 true resid norm 1.781632871563e+02 ||r(i)||/||b|| 4.256742769902e-03
41 KSP unpreconditioned resid norm 1.705795476338e+02 true resid norm 1.705795476338e+02 ||r(i)||/||b|| 4.075549276583e-03
42 KSP unpreconditioned resid norm 1.630804077040e+02 true resid norm 1.630804077040e+02 ||r(i)||/||b|| 3.896377067841e-03
43 KSP unpreconditioned resid norm 1.553067395054e+02 true resid norm 1.553067395054e+02 ||r(i)||/||b|| 3.710645728752e-03
44 KSP unpreconditioned resid norm 1.463195822591e+02 true resid norm 1.463195822591e+02 ||r(i)||/||b|| 3.495921263117e-03
45 KSP unpreconditioned resid norm 1.363957299914e+02 true resid norm 1.363957299914e+02 ||r(i)||/||b|| 3.258816935597e-03
46 KSP unpreconditioned resid norm 1.260988883702e+02 true resid norm 1.260988883702e+02 ||r(i)||/||b|| 3.012801009289e-03
47 KSP unpreconditioned resid norm 1.158371057308e+02 true resid norm 1.158371057308e+02 ||r(i)||/||b|| 2.767622725065e-03
48 KSP unpreconditioned resid norm 1.053575736103e+02 true resid norm 1.053575736103e+02 ||r(i)||/||b|| 2.517241890169e-03
49 KSP unpreconditioned resid norm 9.533891433288e+01 true resid norm 9.533891433288e+01 ||r(i)||/||b|| 2.277872398711e-03
50 KSP unpreconditioned resid norm 8.705465269949e+01 true resid norm 8.705465269949e+01 ||r(i)||/||b|| 2.079941773526e-03
51 KSP unpreconditioned resid norm 8.068525173658e+01 true resid norm 8.068525173658e+01 ||r(i)||/||b|| 1.927761703601e-03
52 KSP unpreconditioned resid norm 7.566535127065e+01 true resid norm 7.566535127065e+01 ||r(i)||/||b|| 1.807824395780e-03
53 KSP unpreconditioned resid norm 7.099640454939e+01 true resid norm 7.099640454939e+01 ||r(i)||/||b|| 1.696272203878e-03
54 KSP unpreconditioned resid norm 6.668259985170e+01 true resid norm 6.668259985170e+01 ||r(i)||/||b|| 1.593205195793e-03
55 KSP unpreconditioned resid norm 6.260036654607e+01 true resid norm 6.260036654607e+01 ||r(i)||/||b|| 1.495670976560e-03
56 KSP unpreconditioned resid norm 5.883817898871e+01 true resid norm 5.883817898871e+01 ||r(i)||/||b|| 1.405783408030e-03
57 KSP unpreconditioned resid norm 5.562235607642e+01 true resid norm 5.562235607643e+01 ||r(i)||/||b|| 1.328949784506e-03
58 KSP unpreconditioned resid norm 5.297079658586e+01 true resid norm 5.297079658588e+01 ||r(i)||/||b|| 1.265597750142e-03
59 KSP unpreconditioned resid norm 5.079442717111e+01 true resid norm 5.079442717113e+01 ||r(i)||/||b|| 1.213599131803e-03
60 KSP unpreconditioned resid norm 4.907222818727e+01 true resid norm 4.907222818727e+01 ||r(i)||/||b|| 1.172451720404e-03
61 KSP unpreconditioned resid norm 4.855863018352e+01 true resid norm 4.855863018353e+01 ||r(i)||/||b|| 1.160180648041e-03
62 KSP unpreconditioned resid norm 4.818688995047e+01 true resid norm 4.818688995047e+01 ||r(i)||/||b|| 1.151298893699e-03
63 KSP unpreconditioned resid norm 4.777104756076e+01 true resid norm 4.777104756076e+01 ||r(i)||/||b|| 1.141363434413e-03
64 KSP unpreconditioned resid norm 4.732776721320e+01 true resid norm 4.732776721321e+01 ||r(i)||/||b|| 1.130772417349e-03
65 KSP unpreconditioned resid norm 4.680987352819e+01 true resid norm 4.680987352819e+01 ||r(i)||/||b|| 1.118398710989e-03
66 KSP unpreconditioned resid norm 4.609652595419e+01 true resid norm 4.609652595419e+01 ||r(i)||/||b|| 1.101355148443e-03
67 KSP unpreconditioned resid norm 4.510019040066e+01 true resid norm 4.510019040067e+01 ||r(i)||/||b|| 1.077550333032e-03
68 KSP unpreconditioned resid norm 4.377295459951e+01 true resid norm 4.377295459952e+01 ||r(i)||/||b|| 1.045839527227e-03
69 KSP unpreconditioned resid norm 4.208504090348e+01 true resid norm 4.208504090349e+01 ||r(i)||/||b|| 1.005511272532e-03
70 KSP unpreconditioned resid norm 3.980380090965e+01 true resid norm 3.980380090967e+01 ||r(i)||/||b|| 9.510070477555e-04
71 KSP unpreconditioned resid norm 3.708086284362e+01 true resid norm 3.708086284366e+01 ||r(i)||/||b|| 8.859496102194e-04
72 KSP unpreconditioned resid norm 3.459727873751e+01 true resid norm 3.459727873766e+01 ||r(i)||/||b|| 8.266109055097e-04
73 KSP unpreconditioned resid norm 3.180719255347e+01 true resid norm 3.180719255351e+01 ||r(i)||/||b|| 7.599491404438e-04
74 KSP unpreconditioned resid norm 2.918185526651e+01 true resid norm 2.918185526660e+01 ||r(i)||/||b|| 6.972236166111e-04
75 KSP unpreconditioned resid norm 2.678651110970e+01 true resid norm 2.678651110961e+01 ||r(i)||/||b|| 6.399931732105e-04
76 KSP unpreconditioned resid norm 2.484906333827e+01 true resid norm 2.484906333836e+01 ||r(i)||/||b|| 5.937029586328e-04
77 KSP unpreconditioned resid norm 2.330913573053e+01 true resid norm 2.330913573043e+01 ||r(i)||/||b|| 5.569104419710e-04
78 KSP unpreconditioned resid norm 2.216435682431e+01 true resid norm 2.216435682436e+01 ||r(i)||/||b|| 5.295589633956e-04
79 KSP unpreconditioned resid norm 2.123395613535e+01 true resid norm 2.123395613537e+01 ||r(i)||/||b|| 5.073294880127e-04
80 KSP unpreconditioned resid norm 2.043084268153e+01 true resid norm 2.043084268164e+01 ||r(i)||/||b|| 4.881412060600e-04
81 KSP unpreconditioned resid norm 1.965586415234e+01 true resid norm 1.965586415254e+01 ||r(i)||/||b|| 4.696251340723e-04
82 KSP unpreconditioned resid norm 1.881622901102e+01 true resid norm 1.881622901121e+01 ||r(i)||/||b|| 4.495642625298e-04
83 KSP unpreconditioned resid norm 1.789380993135e+01 true resid norm 1.789380993180e+01 ||r(i)||/||b|| 4.275254866981e-04
84 KSP unpreconditioned resid norm 1.688449457197e+01 true resid norm 1.688449457201e+01 ||r(i)||/||b|| 4.034105529823e-04
85 KSP unpreconditioned resid norm 1.593222827658e+01 true resid norm 1.593222827682e+01 ||r(i)||/||b|| 3.806586564960e-04
86 KSP unpreconditioned resid norm 1.515471799214e+01 true resid norm 1.515471799254e+01 ||r(i)||/||b|| 3.620820948823e-04
87 KSP unpreconditioned resid norm 1.446999386874e+01 true resid norm 1.446999386898e+01 ||r(i)||/||b|| 3.457224143393e-04
88 KSP unpreconditioned resid norm 1.383334025997e+01 true resid norm 1.383334026043e+01 ||r(i)||/||b|| 3.305112522174e-04
89 KSP unpreconditioned resid norm 1.317043989288e+01 true resid norm 1.317043989271e+01 ||r(i)||/||b|| 3.146729928739e-04
90 KSP unpreconditioned resid norm 1.239101125736e+01 true resid norm 1.239101125736e+01 ||r(i)||/||b|| 2.960505973112e-04
91 KSP unpreconditioned resid norm 1.186324262364e+01 true resid norm 1.186324262364e+01 ||r(i)||/||b|| 2.834409550464e-04
92 KSP unpreconditioned resid norm 1.150464677494e+01 true resid norm 1.150464677494e+01 ||r(i)||/||b|| 2.748732511685e-04
93 KSP unpreconditioned resid norm 1.113300288814e+01 true resid norm 1.113300288813e+01 ||r(i)||/||b|| 2.659937987662e-04
94 KSP unpreconditioned resid norm 1.070172922664e+01 true resid norm 1.070172922664e+01 ||r(i)||/||b|| 2.556896498604e-04
95 KSP unpreconditioned resid norm 1.031469163099e+01 true resid norm 1.031469163098e+01 ||r(i)||/||b|| 2.464424053055e-04
96 KSP unpreconditioned resid norm 9.961561506781e+00 true resid norm 9.961561506789e+00 ||r(i)||/||b|| 2.380052905275e-04
97 KSP unpreconditioned resid norm 9.727599193659e+00 true resid norm 9.727599193657e+00 ||r(i)||/||b|| 2.324153769109e-04
98 KSP unpreconditioned resid norm 9.599540307022e+00 true resid norm 9.599540307025e+00 ||r(i)||/||b|| 2.293557469024e-04
99 KSP unpreconditioned resid norm 9.509470398964e+00 true resid norm 9.509470398968e+00 ||r(i)||/||b|| 2.272037635391e-04
100 KSP unpreconditioned resid norm 9.466509947556e+00 true resid norm 9.466509947555e+00 ||r(i)||/||b|| 2.261773366368e-04
101 KSP unpreconditioned resid norm 9.455222327075e+00 true resid norm 9.455222327062e+00 ||r(i)||/||b|| 2.259076486574e-04
102 KSP unpreconditioned resid norm 9.453955291155e+00 true resid norm 9.453955291154e+00 ||r(i)||/||b|| 2.258773761696e-04
103 KSP unpreconditioned resid norm 9.453901238683e+00 true resid norm 9.453901238680e+00 ||r(i)||/||b|| 2.258760847280e-04
104 KSP unpreconditioned resid norm 9.453537983245e+00 true resid norm 9.453537983238e+00 ||r(i)||/||b|| 2.258674056954e-04
105 KSP unpreconditioned resid norm 9.453508666674e+00 true resid norm 9.453508666665e+00 ||r(i)||/||b|| 2.258667052530e-04
106 KSP unpreconditioned resid norm 9.453292702551e+00 true resid norm 9.453292702541e+00 ||r(i)||/||b|| 2.258615453588e-04
107 KSP unpreconditioned resid norm 9.453181837192e+00 true resid norm 9.453181837176e+00 ||r(i)||/||b|| 2.258588965227e-04
108 KSP unpreconditioned resid norm 9.452682673607e+00 true resid norm 9.452682673598e+00 ||r(i)||/||b|| 2.258469703230e-04
109 KSP unpreconditioned resid norm 9.447895229458e+00 true resid norm 9.447895229465e+00 ||r(i)||/||b|| 2.257325869473e-04
110 KSP unpreconditioned resid norm 9.447238405614e+00 true resid norm 9.447238405615e+00 ||r(i)||/||b|| 2.257168938704e-04
111 KSP unpreconditioned resid norm 9.446910264057e+00 true resid norm 9.446910264054e+00 ||r(i)||/||b|| 2.257090537915e-04
112 KSP unpreconditioned resid norm 9.446735687192e+00 true resid norm 9.446735687190e+00 ||r(i)||/||b|| 2.257048827369e-04
113 KSP unpreconditioned resid norm 9.439830631922e+00 true resid norm 9.439830631909e+00 ||r(i)||/||b|| 2.255399046170e-04
114 KSP unpreconditioned resid norm 9.417912808091e+00 true resid norm 9.417912808088e+00 ||r(i)||/||b|| 2.250162359108e-04
115 KSP unpreconditioned resid norm 9.387566046376e+00 true resid norm 9.387566046378e+00 ||r(i)||/||b|| 2.242911799211e-04
116 KSP unpreconditioned resid norm 9.358214264326e+00 true resid norm 9.358214264320e+00 ||r(i)||/||b|| 2.235898963511e-04
117 KSP unpreconditioned resid norm 9.329543016274e+00 true resid norm 9.329543016269e+00 ||r(i)||/||b|| 2.229048723498e-04
118 KSP unpreconditioned resid norm 9.283697902212e+00 true resid norm 9.283697902208e+00 ||r(i)||/||b|| 2.218095240268e-04
119 KSP unpreconditioned resid norm 9.230603560626e+00 true resid norm 9.230603560623e+00 ||r(i)||/||b|| 2.205409744941e-04
120 KSP unpreconditioned resid norm 9.176644987087e+00 true resid norm 9.176644987087e+00 ||r(i)||/||b|| 2.192517764139e-04
121 KSP unpreconditioned resid norm 9.143991177863e+00 true resid norm 9.143991177861e+00 ||r(i)||/||b|| 2.184715995966e-04
122 KSP unpreconditioned resid norm 9.129366561991e+00 true resid norm 9.129366561990e+00 ||r(i)||/||b|| 2.181221828965e-04
123 KSP unpreconditioned resid norm 9.117830710266e+00 true resid norm 9.117830710263e+00 ||r(i)||/||b|| 2.178465640851e-04
124 KSP unpreconditioned resid norm 9.114456287974e+00 true resid norm 9.114456287976e+00 ||r(i)||/||b|| 2.177659411470e-04
125 KSP unpreconditioned resid norm 9.114265447956e+00 true resid norm 9.114265447950e+00 ||r(i)||/||b|| 2.177613815270e-04
126 KSP unpreconditioned resid norm 9.113358612539e+00 true resid norm 9.113358612544e+00 ||r(i)||/||b|| 2.177397150820e-04
127 KSP unpreconditioned resid norm 9.109681304148e+00 true resid norm 9.109681304142e+00 ||r(i)||/||b|| 2.176518554775e-04
128 KSP unpreconditioned resid norm 9.108178258871e+00 true resid norm 9.108178258865e+00 ||r(i)||/||b|| 2.176159441670e-04
129 KSP unpreconditioned resid norm 9.108045214257e+00 true resid norm 9.108045214258e+00 ||r(i)||/||b|| 2.176127654163e-04
130 KSP unpreconditioned resid norm 9.107947148704e+00 true resid norm 9.107947148702e+00 ||r(i)||/||b|| 2.176104223980e-04
131 KSP unpreconditioned resid norm 9.107582780259e+00 true resid norm 9.107582780261e+00 ||r(i)||/||b|| 2.176017167732e-04
132 KSP unpreconditioned resid norm 9.102727327550e+00 true resid norm 9.102727327557e+00 ||r(i)||/||b|| 2.174857085118e-04
133 KSP unpreconditioned resid norm 9.100831330692e+00 true resid norm 9.100831330683e+00 ||r(i)||/||b|| 2.174404086573e-04
134 KSP unpreconditioned resid norm 9.099043254524e+00 true resid norm 9.099043254522e+00 ||r(i)||/||b|| 2.173976872842e-04
135 KSP unpreconditioned resid norm 9.098356626208e+00 true resid norm 9.098356626206e+00 ||r(i)||/||b|| 2.173812821079e-04
136 KSP unpreconditioned resid norm 9.097355464612e+00 true resid norm 9.097355464602e+00 ||r(i)||/||b|| 2.173573619868e-04
137 KSP unpreconditioned resid norm 9.089186105397e+00 true resid norm 9.089186105393e+00 ||r(i)||/||b|| 2.171621766526e-04
138 KSP unpreconditioned resid norm 9.072508753871e+00 true resid norm 9.072508753870e+00 ||r(i)||/||b|| 2.167637152375e-04
139 KSP unpreconditioned resid norm 9.045555446429e+00 true resid norm 9.045555446427e+00 ||r(i)||/||b|| 2.161197369049e-04
140 KSP unpreconditioned resid norm 8.998721136797e+00 true resid norm 8.998721136781e+00 ||r(i)||/||b|| 2.150007543572e-04
141 KSP unpreconditioned resid norm 8.957999948441e+00 true resid norm 8.957999948446e+00 ||r(i)||/||b|| 2.140278287518e-04
142 KSP unpreconditioned resid norm 8.914720920393e+00 true resid norm 8.914720920379e+00 ||r(i)||/||b|| 2.129937902989e-04
143 KSP unpreconditioned resid norm 8.861276524407e+00 true resid norm 8.861276524386e+00 ||r(i)||/||b|| 2.117168771375e-04
144 KSP unpreconditioned resid norm 8.828215689678e+00 true resid norm 8.828215689670e+00 ||r(i)||/||b|| 2.109269755176e-04
145 KSP unpreconditioned resid norm 8.814871762477e+00 true resid norm 8.814871762457e+00 ||r(i)||/||b|| 2.106081575019e-04
146 KSP unpreconditioned resid norm 8.812208435271e+00 true resid norm 8.812208435264e+00 ||r(i)||/||b|| 2.105445243092e-04
147 KSP unpreconditioned resid norm 8.811828184692e+00 true resid norm 8.811828184665e+00 ||r(i)||/||b|| 2.105354392221e-04
148 KSP unpreconditioned resid norm 8.810270839057e+00 true resid norm 8.810270839056e+00 ||r(i)||/||b|| 2.104982305481e-04
149 KSP unpreconditioned resid norm 8.809360836498e+00 true resid norm 8.809360836477e+00 ||r(i)||/||b|| 2.104764884319e-04
150 KSP unpreconditioned resid norm 8.809228450273e+00 true resid norm 8.809228450273e+00 ||r(i)||/||b|| 2.104733254120e-04
151 KSP unpreconditioned resid norm 8.809217648496e+00 true resid norm 8.809217648490e+00 ||r(i)||/||b|| 2.104730673319e-04
152 KSP unpreconditioned resid norm 8.809143040459e+00 true resid norm 8.809143040463e+00 ||r(i)||/||b|| 2.104712847694e-04
153 KSP unpreconditioned resid norm 8.809115621054e+00 true resid norm 8.809115621055e+00 ||r(i)||/||b|| 2.104706296549e-04
154 KSP unpreconditioned resid norm 8.808990540067e+00 true resid norm 8.808990540063e+00 ||r(i)||/||b|| 2.104676411738e-04
155 KSP unpreconditioned resid norm 8.808875174679e+00 true resid norm 8.808875174687e+00 ||r(i)||/||b|| 2.104648848218e-04
156 KSP unpreconditioned resid norm 8.808536626453e+00 true resid norm 8.808536626456e+00 ||r(i)||/||b|| 2.104567961030e-04
157 KSP unpreconditioned resid norm 8.808160785477e+00 true resid norm 8.808160785485e+00 ||r(i)||/||b|| 2.104478163723e-04
158 KSP unpreconditioned resid norm 8.808132992547e+00 true resid norm 8.808132992551e+00 ||r(i)||/||b|| 2.104471523333e-04
159 KSP unpreconditioned resid norm 8.808122181749e+00 true resid norm 8.808122181753e+00 ||r(i)||/||b|| 2.104468940378e-04
160 KSP unpreconditioned resid norm 8.807956020806e+00 true resid norm 8.807956020805e+00 ||r(i)||/||b|| 2.104429240593e-04
161 KSP unpreconditioned resid norm 8.806829391882e+00 true resid norm 8.806829391878e+00 ||r(i)||/||b|| 2.104160062267e-04
162 KSP unpreconditioned resid norm 8.806319018453e+00 true resid norm 8.806319018453e+00 ||r(i)||/||b|| 2.104038121972e-04
163 KSP unpreconditioned resid norm 8.806294482453e+00 true resid norm 8.806294482454e+00 ||r(i)||/||b|| 2.104032259740e-04
164 KSP unpreconditioned resid norm 8.806294365652e+00 true resid norm 8.806294365660e+00 ||r(i)||/||b|| 2.104032231836e-04
165 KSP unpreconditioned resid norm 8.806291697672e+00 true resid norm 8.806291697675e+00 ||r(i)||/||b|| 2.104031594391e-04
166 KSP unpreconditioned resid norm 8.805745258243e+00 true resid norm 8.805745258237e+00 ||r(i)||/||b|| 2.103901037071e-04
167 KSP unpreconditioned resid norm 8.805235547061e+00 true resid norm 8.805235547060e+00 ||r(i)||/||b|| 2.103779255002e-04
168 KSP unpreconditioned resid norm 8.805103805113e+00 true resid norm 8.805103805114e+00 ||r(i)||/||b|| 2.103747778732e-04
169 KSP unpreconditioned resid norm 8.805014161928e+00 true resid norm 8.805014161924e+00 ||r(i)||/||b|| 2.103726360852e-04
170 KSP unpreconditioned resid norm 8.804202103754e+00 true resid norm 8.804202103744e+00 ||r(i)||/||b|| 2.103532340925e-04
171 KSP unpreconditioned resid norm 8.797040981002e+00 true resid norm 8.797040981004e+00 ||r(i)||/||b|| 2.101821379148e-04
172 KSP unpreconditioned resid norm 8.792835377869e+00 true resid norm 8.792835377873e+00 ||r(i)||/||b|| 2.100816560983e-04
173 KSP unpreconditioned resid norm 8.792684168267e+00 true resid norm 8.792684168266e+00 ||r(i)||/||b|| 2.100780433428e-04
174 KSP unpreconditioned resid norm 8.792562059260e+00 true resid norm 8.792562059262e+00 ||r(i)||/||b|| 2.100751258695e-04
175 KSP unpreconditioned resid norm 8.791859939389e+00 true resid norm 8.791859939386e+00 ||r(i)||/||b|| 2.100583505633e-04
176 KSP unpreconditioned resid norm 8.789112601337e+00 true resid norm 8.789112601343e+00 ||r(i)||/||b|| 2.099927101525e-04
177 KSP unpreconditioned resid norm 8.784752787756e+00 true resid norm 8.784752787762e+00 ||r(i)||/||b|| 2.098885438833e-04
178 KSP unpreconditioned resid norm 8.781725079298e+00 true resid norm 8.781725079292e+00 ||r(i)||/||b|| 2.098162047592e-04
179 KSP unpreconditioned resid norm 8.781356495123e+00 true resid norm 8.781356495128e+00 ||r(i)||/||b|| 2.098073984108e-04
180 KSP unpreconditioned resid norm 8.780959440563e+00 true resid norm 8.780959440563e+00 ||r(i)||/||b|| 2.097979118371e-04
181 KSP unpreconditioned resid norm 8.780949304990e+00 true resid norm 8.780949304991e+00 ||r(i)||/||b|| 2.097976696743e-04
182 KSP unpreconditioned resid norm 8.780949101503e+00 true resid norm 8.780949101511e+00 ||r(i)||/||b|| 2.097976648127e-04
183 KSP unpreconditioned resid norm 8.780874815148e+00 true resid norm 8.780874815142e+00 ||r(i)||/||b|| 2.097958899354e-04
184 KSP unpreconditioned resid norm 8.780852129532e+00 true resid norm 8.780852129536e+00 ||r(i)||/||b|| 2.097953479226e-04
185 KSP unpreconditioned resid norm 8.780770254915e+00 true resid norm 8.780770254911e+00 ||r(i)||/||b|| 2.097933917440e-04
186 KSP unpreconditioned resid norm 8.780755189593e+00 true resid norm 8.780755189589e+00 ||r(i)||/||b|| 2.097930317977e-04
187 KSP unpreconditioned resid norm 8.780751549738e+00 true resid norm 8.780751549745e+00 ||r(i)||/||b|| 2.097929448333e-04
188 KSP unpreconditioned resid norm 8.780683751128e+00 true resid norm 8.780683751126e+00 ||r(i)||/||b|| 2.097913249637e-04
189 KSP unpreconditioned resid norm 8.780522987845e+00 true resid norm 8.780522987849e+00 ||r(i)||/||b|| 2.097874839484e-04
190 KSP unpreconditioned resid norm 8.780278742096e+00 true resid norm 8.780278742107e+00 ||r(i)||/||b|| 2.097816483393e-04
191 KSP unpreconditioned resid norm 8.780267035067e+00 true resid norm 8.780267035064e+00 ||r(i)||/||b|| 2.097813686303e-04
192 KSP unpreconditioned resid norm 8.780216625442e+00 true resid norm 8.780216625446e+00 ||r(i)||/||b|| 2.097801642252e-04
193 KSP unpreconditioned resid norm 8.779863419269e+00 true resid norm 8.779863419283e+00 ||r(i)||/||b|| 2.097717252937e-04
194 KSP unpreconditioned resid norm 8.778848410057e+00 true resid norm 8.778848410054e+00 ||r(i)||/||b|| 2.097474743200e-04
195 KSP unpreconditioned resid norm 8.777401446116e+00 true resid norm 8.777401446119e+00 ||r(i)||/||b|| 2.097129029256e-04
196 KSP unpreconditioned resid norm 8.776565851009e+00 true resid norm 8.776565851011e+00 ||r(i)||/||b|| 2.096929385800e-04
197 KSP unpreconditioned resid norm 8.776554097188e+00 true resid norm 8.776554097188e+00 ||r(i)||/||b|| 2.096926577533e-04
198 KSP unpreconditioned resid norm 8.776069995876e+00 true resid norm 8.776069995872e+00 ||r(i)||/||b|| 2.096810914267e-04
199 KSP unpreconditioned resid norm 8.775307222507e+00 true resid norm 8.775307222510e+00 ||r(i)||/||b|| 2.096628669650e-04
200 KSP unpreconditioned resid norm 8.774369998639e+00 true resid norm 8.774369998640e+00 ||r(i)||/||b|| 2.096404744677e-04
201 KSP unpreconditioned resid norm 8.772456346984e+00 true resid norm 8.772456346996e+00 ||r(i)||/||b|| 2.095947527989e-04
202 KSP unpreconditioned resid norm 8.771578449583e+00 true resid norm 8.771578449587e+00 ||r(i)||/||b|| 2.095737777512e-04
203 KSP unpreconditioned resid norm 8.771577600114e+00 true resid norm 8.771577600112e+00 ||r(i)||/||b|| 2.095737574552e-04
204 KSP unpreconditioned resid norm 8.769947395455e+00 true resid norm 8.769947395447e+00 ||r(i)||/||b|| 2.095348080059e-04
205 KSP unpreconditioned resid norm 8.765625569759e+00 true resid norm 8.765625569766e+00 ||r(i)||/||b|| 2.094315493576e-04
206 KSP unpreconditioned resid norm 8.762920016340e+00 true resid norm 8.762920016349e+00 ||r(i)||/||b|| 2.093669072805e-04
207 KSP unpreconditioned resid norm 8.762030877593e+00 true resid norm 8.762030877583e+00 ||r(i)||/||b|| 2.093456636501e-04
208 KSP unpreconditioned resid norm 8.762025443448e+00 true resid norm 8.762025443453e+00 ||r(i)||/||b|| 2.093455338159e-04
209 KSP unpreconditioned resid norm 8.759118158195e+00 true resid norm 8.759118158210e+00 ||r(i)||/||b|| 2.092760718878e-04
210 KSP unpreconditioned resid norm 8.757626170280e+00 true resid norm 8.757626170280e+00 ||r(i)||/||b|| 2.092404247636e-04
211 KSP unpreconditioned resid norm 8.757586002492e+00 true resid norm 8.757586002498e+00 ||r(i)||/||b|| 2.092394650601e-04
212 KSP unpreconditioned resid norm 8.757586002150e+00 true resid norm 8.757586002141e+00 ||r(i)||/||b|| 2.092394650516e-04
213 KSP unpreconditioned resid norm 8.757565964562e+00 true resid norm 8.757565964558e+00 ||r(i)||/||b|| 2.092389863063e-04
214 KSP unpreconditioned resid norm 8.757565930019e+00 true resid norm 8.757565930026e+00 ||r(i)||/||b|| 2.092389854812e-04
215 KSP unpreconditioned resid norm 8.757562287652e+00 true resid norm 8.757562287652e+00 ||r(i)||/||b|| 2.092388984563e-04
216 KSP unpreconditioned resid norm 8.757562261294e+00 true resid norm 8.757562261303e+00 ||r(i)||/||b|| 2.092388978268e-04
217 KSP unpreconditioned resid norm 8.757551783601e+00 true resid norm 8.757551783609e+00 ||r(i)||/||b|| 2.092386474899e-04
218 KSP unpreconditioned resid norm 8.757525988303e+00 true resid norm 8.757525988300e+00 ||r(i)||/||b|| 2.092380311789e-04
219 KSP unpreconditioned resid norm 8.757446263195e+00 true resid norm 8.757446263193e+00 ||r(i)||/||b|| 2.092361263573e-04
220 KSP unpreconditioned resid norm 8.757445081631e+00 true resid norm 8.757445081633e+00 ||r(i)||/||b|| 2.092360981270e-04
221 KSP unpreconditioned resid norm 8.757155678610e+00 true resid norm 8.757155678605e+00 ||r(i)||/||b|| 2.092291836034e-04
222 KSP unpreconditioned resid norm 8.757038866468e+00 true resid norm 8.757038866463e+00 ||r(i)||/||b|| 2.092263926848e-04
223 KSP unpreconditioned resid norm 8.756997899453e+00 true resid norm 8.756997899453e+00 ||r(i)||/||b|| 2.092254138859e-04
224 KSP unpreconditioned resid norm 8.756889734530e+00 true resid norm 8.756889734533e+00 ||r(i)||/||b|| 2.092228295699e-04
225 KSP unpreconditioned resid norm 8.756239703827e+00 true resid norm 8.756239703827e+00 ||r(i)||/||b|| 2.092072987972e-04
226 KSP unpreconditioned resid norm 8.755468069592e+00 true resid norm 8.755468069589e+00 ||r(i)||/||b|| 2.091888626283e-04
227 KSP unpreconditioned resid norm 8.755445934609e+00 true resid norm 8.755445934609e+00 ||r(i)||/||b|| 2.091883337712e-04
228 KSP unpreconditioned resid norm 8.754918105730e+00 true resid norm 8.754918105736e+00 ||r(i)||/||b|| 2.091757226897e-04
229 KSP unpreconditioned resid norm 8.754027449030e+00 true resid norm 8.754027449026e+00 ||r(i)||/||b|| 2.091544427921e-04
230 KSP unpreconditioned resid norm 8.753580266945e+00 true resid norm 8.753580266946e+00 ||r(i)||/||b|| 2.091437585534e-04
231 KSP unpreconditioned resid norm 8.753445273497e+00 true resid norm 8.753445273503e+00 ||r(i)||/||b|| 2.091405332404e-04
232 KSP unpreconditioned resid norm 8.753125264343e+00 true resid norm 8.753125264342e+00 ||r(i)||/||b|| 2.091328874638e-04
233 KSP unpreconditioned resid norm 8.753122592440e+00 true resid norm 8.753122592424e+00 ||r(i)||/||b|| 2.091328236254e-04
234 KSP unpreconditioned resid norm 8.751108125980e+00 true resid norm 8.751108125975e+00 ||r(i)||/||b|| 2.090846932522e-04
235 KSP unpreconditioned resid norm 8.747204043868e+00 true resid norm 8.747204043868e+00 ||r(i)||/||b|| 2.089914154870e-04
236 KSP unpreconditioned resid norm 8.739424804688e+00 true resid norm 8.739424804689e+00 ||r(i)||/||b|| 2.088055510440e-04
237 KSP unpreconditioned resid norm 8.735970046643e+00 true resid norm 8.735970046639e+00 ||r(i)||/||b|| 2.087230086943e-04
238 KSP unpreconditioned resid norm 8.735325320962e+00 true resid norm 8.735325320970e+00 ||r(i)||/||b|| 2.087076046715e-04
239 KSP unpreconditioned resid norm 8.731311370642e+00 true resid norm 8.731311370644e+00 ||r(i)||/||b|| 2.086117018943e-04
240 KSP unpreconditioned resid norm 8.726727857325e+00 true resid norm 8.726727857325e+00 ||r(i)||/||b|| 2.085021909087e-04
241 KSP unpreconditioned resid norm 8.726280522474e+00 true resid norm 8.726280522469e+00 ||r(i)||/||b|| 2.084915030198e-04
242 KSP unpreconditioned resid norm 8.726255525655e+00 true resid norm 8.726255525642e+00 ||r(i)||/||b|| 2.084909057864e-04
243 KSP unpreconditioned resid norm 8.726216348352e+00 true resid norm 8.726216348345e+00 ||r(i)||/||b|| 2.084899697481e-04
244 KSP unpreconditioned resid norm 8.725795928070e+00 true resid norm 8.725795928062e+00 ||r(i)||/||b|| 2.084799249120e-04
245 KSP unpreconditioned resid norm 8.725765353744e+00 true resid norm 8.725765353739e+00 ||r(i)||/||b|| 2.084791944191e-04
246 KSP unpreconditioned resid norm 8.725733691045e+00 true resid norm 8.725733691033e+00 ||r(i)||/||b|| 2.084784379221e-04
247 KSP unpreconditioned resid norm 8.725627225598e+00 true resid norm 8.725627225588e+00 ||r(i)||/||b|| 2.084758942105e-04
248 KSP unpreconditioned resid norm 8.724527925127e+00 true resid norm 8.724527925119e+00 ||r(i)||/||b|| 2.084496293195e-04
249 KSP unpreconditioned resid norm 8.723377732966e+00 true resid norm 8.723377732962e+00 ||r(i)||/||b|| 2.084221485055e-04
250 KSP unpreconditioned resid norm 8.723197023098e+00 true resid norm 8.723197023086e+00 ||r(i)||/||b|| 2.084178309187e-04
251 KSP unpreconditioned resid norm 8.722768328753e+00 true resid norm 8.722768328745e+00 ||r(i)||/||b|| 2.084075883959e-04
252 KSP unpreconditioned resid norm 8.721740187465e+00 true resid norm 8.721740187470e+00 ||r(i)||/||b|| 2.083830236665e-04
253 KSP unpreconditioned resid norm 8.721702728270e+00 true resid norm 8.721702728255e+00 ||r(i)||/||b|| 2.083821286771e-04
254 KSP unpreconditioned resid norm 8.721655068435e+00 true resid norm 8.721655068431e+00 ||r(i)||/||b|| 2.083809899711e-04
255 KSP unpreconditioned resid norm 8.721611187245e+00 true resid norm 8.721611187241e+00 ||r(i)||/||b|| 2.083799415456e-04
256 KSP unpreconditioned resid norm 8.721574655632e+00 true resid norm 8.721574655623e+00 ||r(i)||/||b|| 2.083790687187e-04
257 KSP unpreconditioned resid norm 8.721540381065e+00 true resid norm 8.721540381068e+00 ||r(i)||/||b|| 2.083782498184e-04
258 KSP unpreconditioned resid norm 8.721475929279e+00 true resid norm 8.721475929270e+00 ||r(i)||/||b|| 2.083767099124e-04
259 KSP unpreconditioned resid norm 8.721465096813e+00 true resid norm 8.721465096799e+00 ||r(i)||/||b|| 2.083764510990e-04
260 KSP unpreconditioned resid norm 8.721465019120e+00 true resid norm 8.721465019107e+00 ||r(i)||/||b|| 2.083764492428e-04
261 KSP unpreconditioned resid norm 8.721384031374e+00 true resid norm 8.721384031368e+00 ||r(i)||/||b|| 2.083745142539e-04
262 KSP unpreconditioned resid norm 8.721383529209e+00 true resid norm 8.721383529209e+00 ||r(i)||/||b|| 2.083745022561e-04
263 KSP unpreconditioned resid norm 8.721224081770e+00 true resid norm 8.721224081754e+00 ||r(i)||/||b|| 2.083706926789e-04
264 KSP unpreconditioned resid norm 8.720726769939e+00 true resid norm 8.720726769931e+00 ||r(i)||/||b|| 2.083588107220e-04
265 KSP unpreconditioned resid norm 8.720597987351e+00 true resid norm 8.720597987348e+00 ||r(i)||/||b|| 2.083557338012e-04
266 KSP unpreconditioned resid norm 8.719955804547e+00 true resid norm 8.719955804544e+00 ||r(i)||/||b|| 2.083403905335e-04
267 KSP unpreconditioned resid norm 8.718989506411e+00 true resid norm 8.718989506405e+00 ||r(i)||/||b|| 2.083173033830e-04
268 KSP unpreconditioned resid norm 8.718497997075e+00 true resid norm 8.718497997066e+00 ||r(i)||/||b|| 2.083055600611e-04
269 KSP unpreconditioned resid norm 8.717860759677e+00 true resid norm 8.717860759673e+00 ||r(i)||/||b|| 2.082903349510e-04
270 KSP unpreconditioned resid norm 8.717860526462e+00 true resid norm 8.717860526462e+00 ||r(i)||/||b|| 2.082903293791e-04
271 KSP unpreconditioned resid norm 8.717860524178e+00 true resid norm 8.717860524178e+00 ||r(i)||/||b|| 2.082903293245e-04
272 KSP unpreconditioned resid norm 8.717857081592e+00 true resid norm 8.717857081582e+00 ||r(i)||/||b|| 2.082902470727e-04
273 KSP unpreconditioned resid norm 8.717856493353e+00 true resid norm 8.717856493351e+00 ||r(i)||/||b|| 2.082902330185e-04
274 KSP unpreconditioned resid norm 8.717854425359e+00 true resid norm 8.717854425360e+00 ||r(i)||/||b|| 2.082901836093e-04
275 KSP unpreconditioned resid norm 8.717854130915e+00 true resid norm 8.717854130914e+00 ||r(i)||/||b|| 2.082901765743e-04
276 KSP unpreconditioned resid norm 8.717847329843e+00 true resid norm 8.717847329843e+00 ||r(i)||/||b|| 2.082900140806e-04
277 KSP unpreconditioned resid norm 8.717847300683e+00 true resid norm 8.717847300674e+00 ||r(i)||/||b|| 2.082900133837e-04
278 KSP unpreconditioned resid norm 8.717831899187e+00 true resid norm 8.717831899184e+00 ||r(i)||/||b|| 2.082896454056e-04
279 KSP unpreconditioned resid norm 8.717781277780e+00 true resid norm 8.717781277772e+00 ||r(i)||/||b|| 2.082884359402e-04
280 KSP unpreconditioned resid norm 8.717775160312e+00 true resid norm 8.717775160320e+00 ||r(i)||/||b|| 2.082882897798e-04
281 KSP unpreconditioned resid norm 8.717735983767e+00 true resid norm 8.717735983764e+00 ||r(i)||/||b|| 2.082873537591e-04
282 KSP unpreconditioned resid norm 8.717735948913e+00 true resid norm 8.717735948907e+00 ||r(i)||/||b|| 2.082873529263e-04
283 KSP unpreconditioned resid norm 8.717735939544e+00 true resid norm 8.717735939538e+00 ||r(i)||/||b|| 2.082873527025e-04
284 KSP unpreconditioned resid norm 8.717709924004e+00 true resid norm 8.717709923998e+00 ||r(i)||/||b|| 2.082867311296e-04
285 KSP unpreconditioned resid norm 8.717707763936e+00 true resid norm 8.717707763935e+00 ||r(i)||/||b|| 2.082866795206e-04
286 KSP unpreconditioned resid norm 8.717659689139e+00 true resid norm 8.717659689121e+00 ||r(i)||/||b|| 2.082855308995e-04
287 KSP unpreconditioned resid norm 8.717583508790e+00 true resid norm 8.717583508785e+00 ||r(i)||/||b|| 2.082837107709e-04
288 KSP unpreconditioned resid norm 8.717552811681e+00 true resid norm 8.717552811671e+00 ||r(i)||/||b|| 2.082829773441e-04
289 KSP unpreconditioned resid norm 8.717549445547e+00 true resid norm 8.717549445540e+00 ||r(i)||/||b|| 2.082828969193e-04
290 KSP unpreconditioned resid norm 8.717524666846e+00 true resid norm 8.717524666849e+00 ||r(i)||/||b|| 2.082823048977e-04
291 KSP unpreconditioned resid norm 8.717312269535e+00 true resid norm 8.717312269535e+00 ||r(i)||/||b|| 2.082772302230e-04
292 KSP unpreconditioned resid norm 8.717312122044e+00 true resid norm 8.717312122031e+00 ||r(i)||/||b|| 2.082772266987e-04
293 KSP unpreconditioned resid norm 8.717178077010e+00 true resid norm 8.717178077002e+00 ||r(i)||/||b|| 2.082740240456e-04
294 KSP unpreconditioned resid norm 8.716918901925e+00 true resid norm 8.716918901917e+00 ||r(i)||/||b|| 2.082678317392e-04
295 KSP unpreconditioned resid norm 8.716865809745e+00 true resid norm 8.716865809726e+00 ||r(i)||/||b|| 2.082665632410e-04
296 KSP unpreconditioned resid norm 8.716865464389e+00 true resid norm 8.716865464387e+00 ||r(i)||/||b|| 2.082665549901e-04
297 KSP unpreconditioned resid norm 8.716288976735e+00 true resid norm 8.716288976726e+00 ||r(i)||/||b|| 2.082527813349e-04
298 KSP unpreconditioned resid norm 8.715944271533e+00 true resid norm 8.715944271528e+00 ||r(i)||/||b|| 2.082445455115e-04
299 KSP unpreconditioned resid norm 8.715942917902e+00 true resid norm 8.715942917897e+00 ||r(i)||/||b|| 2.082445131701e-04
300 KSP unpreconditioned resid norm 8.715855687508e+00 true resid norm 8.715855687508e+00 ||r(i)||/||b|| 2.082424290296e-04
301 KSP unpreconditioned resid norm 8.715855679545e+00 true resid norm 8.715855679548e+00 ||r(i)||/||b|| 2.082424288394e-04
302 KSP unpreconditioned resid norm 8.715855562642e+00 true resid norm 8.715855562642e+00 ||r(i)||/||b|| 2.082424260462e-04
303 KSP unpreconditioned resid norm 8.715855196578e+00 true resid norm 8.715855196569e+00 ||r(i)||/||b|| 2.082424172999e-04
304 KSP unpreconditioned resid norm 8.715855171901e+00 true resid norm 8.715855171895e+00 ||r(i)||/||b|| 2.082424167103e-04
305 KSP unpreconditioned resid norm 8.715854660888e+00 true resid norm 8.715854660882e+00 ||r(i)||/||b|| 2.082424045010e-04
306 KSP unpreconditioned resid norm 8.715854351998e+00 true resid norm 8.715854352001e+00 ||r(i)||/||b|| 2.082423971211e-04
307 KSP unpreconditioned resid norm 8.715851775216e+00 true resid norm 8.715851775215e+00 ||r(i)||/||b|| 2.082423355556e-04
308 KSP unpreconditioned resid norm 8.715850858847e+00 true resid norm 8.715850858849e+00 ||r(i)||/||b|| 2.082423136615e-04
309 KSP unpreconditioned resid norm 8.715850704804e+00 true resid norm 8.715850704798e+00 ||r(i)||/||b|| 2.082423099808e-04
310 KSP unpreconditioned resid norm 8.715846850617e+00 true resid norm 8.715846850603e+00 ||r(i)||/||b|| 2.082422178950e-04
311 KSP unpreconditioned resid norm 8.715845332660e+00 true resid norm 8.715845332654e+00 ||r(i)||/||b|| 2.082421816276e-04
312 KSP unpreconditioned resid norm 8.715833913706e+00 true resid norm 8.715833913712e+00 ||r(i)||/||b|| 2.082419088020e-04
313 KSP unpreconditioned resid norm 8.715798925519e+00 true resid norm 8.715798925516e+00 ||r(i)||/||b|| 2.082410728512e-04
314 KSP unpreconditioned resid norm 8.715794362305e+00 true resid norm 8.715794362297e+00 ||r(i)||/||b|| 2.082409638251e-04
315 KSP unpreconditioned resid norm 8.715787838635e+00 true resid norm 8.715787838633e+00 ||r(i)||/||b|| 2.082408079593e-04
316 KSP unpreconditioned resid norm 8.715786233708e+00 true resid norm 8.715786233710e+00 ||r(i)||/||b|| 2.082407696139e-04
317 KSP unpreconditioned resid norm 8.715783459228e+00 true resid norm 8.715783459223e+00 ||r(i)||/||b|| 2.082407033248e-04
318 KSP unpreconditioned resid norm 8.715743962908e+00 true resid norm 8.715743962913e+00 ||r(i)||/||b|| 2.082397596645e-04
319 KSP unpreconditioned resid norm 8.715742474102e+00 true resid norm 8.715742474093e+00 ||r(i)||/||b|| 2.082397240930e-04
320 KSP unpreconditioned resid norm 8.715679403183e+00 true resid norm 8.715679403183e+00 ||r(i)||/||b|| 2.082382171796e-04
321 KSP unpreconditioned resid norm 8.715675934766e+00 true resid norm 8.715675934770e+00 ||r(i)||/||b|| 2.082381343111e-04
322 KSP unpreconditioned resid norm 8.715675589879e+00 true resid norm 8.715675589878e+00 ||r(i)||/||b|| 2.082381260708e-04
323 KSP unpreconditioned resid norm 8.715639208596e+00 true resid norm 8.715639208599e+00 ||r(i)||/||b|| 2.082372568359e-04
324 KSP unpreconditioned resid norm 8.715630416150e+00 true resid norm 8.715630416152e+00 ||r(i)||/||b|| 2.082370467635e-04
325 KSP unpreconditioned resid norm 8.715593228875e+00 true resid norm 8.715593228865e+00 ||r(i)||/||b|| 2.082361582712e-04
326 KSP unpreconditioned resid norm 8.715592540217e+00 true resid norm 8.715592540222e+00 ||r(i)||/||b|| 2.082361418178e-04
327 KSP unpreconditioned resid norm 8.715581797348e+00 true resid norm 8.715581797340e+00 ||r(i)||/||b|| 2.082358851450e-04
328 KSP unpreconditioned resid norm 8.715572447451e+00 true resid norm 8.715572447452e+00 ||r(i)||/||b|| 2.082356617540e-04
329 KSP unpreconditioned resid norm 8.715572431207e+00 true resid norm 8.715572431204e+00 ||r(i)||/||b|| 2.082356613658e-04
330 KSP unpreconditioned resid norm 8.715496797564e+00 true resid norm 8.715496797564e+00 ||r(i)||/||b|| 2.082338542991e-04
331 KSP unpreconditioned resid norm 8.715496769357e+00 true resid norm 8.715496769369e+00 ||r(i)||/||b|| 2.082338536254e-04
332 KSP unpreconditioned resid norm 8.715496589864e+00 true resid norm 8.715496589865e+00 ||r(i)||/||b|| 2.082338493366e-04
333 KSP unpreconditioned resid norm 8.715496072559e+00 true resid norm 8.715496072573e+00 ||r(i)||/||b|| 2.082338369773e-04
334 KSP unpreconditioned resid norm 8.715495964245e+00 true resid norm 8.715495964256e+00 ||r(i)||/||b|| 2.082338343893e-04
335 KSP unpreconditioned resid norm 8.715495580817e+00 true resid norm 8.715495580819e+00 ||r(i)||/||b|| 2.082338252281e-04
336 KSP unpreconditioned resid norm 8.715495522314e+00 true resid norm 8.715495522323e+00 ||r(i)||/||b|| 2.082338238305e-04
337 KSP unpreconditioned resid norm 8.715495335767e+00 true resid norm 8.715495335762e+00 ||r(i)||/||b|| 2.082338193731e-04
338 KSP unpreconditioned resid norm 8.715495317019e+00 true resid norm 8.715495317033e+00 ||r(i)||/||b|| 2.082338189257e-04
339 KSP unpreconditioned resid norm 8.715494238458e+00 true resid norm 8.715494238463e+00 ||r(i)||/||b|| 2.082337931561e-04
340 KSP unpreconditioned resid norm 8.715493847607e+00 true resid norm 8.715493847612e+00 ||r(i)||/||b|| 2.082337838177e-04
341 KSP unpreconditioned resid norm 8.715490918535e+00 true resid norm 8.715490918540e+00 ||r(i)||/||b|| 2.082337138353e-04
342 KSP unpreconditioned resid norm 8.715484900680e+00 true resid norm 8.715484900683e+00 ||r(i)||/||b|| 2.082335700544e-04
343 KSP unpreconditioned resid norm 8.715483403749e+00 true resid norm 8.715483403756e+00 ||r(i)||/||b|| 2.082335342893e-04
344 KSP unpreconditioned resid norm 8.715482678264e+00 true resid norm 8.715482678270e+00 ||r(i)||/||b|| 2.082335169557e-04
345 KSP unpreconditioned resid norm 8.715479172594e+00 true resid norm 8.715479172594e+00 ||r(i)||/||b|| 2.082334331968e-04
346 KSP unpreconditioned resid norm 8.715479083055e+00 true resid norm 8.715479083052e+00 ||r(i)||/||b|| 2.082334310574e-04
347 KSP unpreconditioned resid norm 8.715475638791e+00 true resid norm 8.715475638797e+00 ||r(i)||/||b|| 2.082333487660e-04
348 KSP unpreconditioned resid norm 8.715468928434e+00 true resid norm 8.715468928433e+00 ||r(i)||/||b|| 2.082331884395e-04
349 KSP unpreconditioned resid norm 8.715468571741e+00 true resid norm 8.715468571748e+00 ||r(i)||/||b|| 2.082331799175e-04
350 KSP unpreconditioned resid norm 8.715467609263e+00 true resid norm 8.715467609260e+00 ||r(i)||/||b|| 2.082331569214e-04
351 KSP unpreconditioned resid norm 8.715444037384e+00 true resid norm 8.715444037381e+00 ||r(i)||/||b|| 2.082325937334e-04
352 KSP unpreconditioned resid norm 8.715439910362e+00 true resid norm 8.715439910364e+00 ||r(i)||/||b|| 2.082324951292e-04
353 KSP unpreconditioned resid norm 8.715438567006e+00 true resid norm 8.715438567008e+00 ||r(i)||/||b|| 2.082324630332e-04
354 KSP unpreconditioned resid norm 8.715386508172e+00 true resid norm 8.715386508163e+00 ||r(i)||/||b|| 2.082312192241e-04
355 KSP unpreconditioned resid norm 8.715386039058e+00 true resid norm 8.715386039064e+00 ||r(i)||/||b|| 2.082312080162e-04
356 KSP unpreconditioned resid norm 8.715383056708e+00 true resid norm 8.715383056715e+00 ||r(i)||/||b|| 2.082311367609e-04
357 KSP unpreconditioned resid norm 8.715379362504e+00 true resid norm 8.715379362511e+00 ||r(i)||/||b|| 2.082310484976e-04
358 KSP unpreconditioned resid norm 8.715357301200e+00 true resid norm 8.715357301209e+00 ||r(i)||/||b|| 2.082305214008e-04
359 KSP unpreconditioned resid norm 8.715352121331e+00 true resid norm 8.715352121341e+00 ||r(i)||/||b|| 2.082303976415e-04
360 KSP unpreconditioned resid norm 8.715307128105e+00 true resid norm 8.715307128105e+00 ||r(i)||/||b|| 2.082293226466e-04
361 KSP unpreconditioned resid norm 8.715307119221e+00 true resid norm 8.715307119211e+00 ||r(i)||/||b|| 2.082293224341e-04
362 KSP unpreconditioned resid norm 8.715306968079e+00 true resid norm 8.715306968075e+00 ||r(i)||/||b|| 2.082293188231e-04
363 KSP unpreconditioned resid norm 8.715306020766e+00 true resid norm 8.715306020766e+00 ||r(i)||/||b|| 2.082292961896e-04
364 KSP unpreconditioned resid norm 8.715305347036e+00 true resid norm 8.715305347041e+00 ||r(i)||/||b|| 2.082292800928e-04
365 KSP unpreconditioned resid norm 8.715305297487e+00 true resid norm 8.715305297484e+00 ||r(i)||/||b|| 2.082292789087e-04
366 KSP unpreconditioned resid norm 8.715305268857e+00 true resid norm 8.715305268855e+00 ||r(i)||/||b|| 2.082292782247e-04
367 KSP unpreconditioned resid norm 8.715304760080e+00 true resid norm 8.715304760081e+00 ||r(i)||/||b|| 2.082292660689e-04
368 KSP unpreconditioned resid norm 8.715304577208e+00 true resid norm 8.715304577201e+00 ||r(i)||/||b|| 2.082292616995e-04
369 KSP unpreconditioned resid norm 8.715304551191e+00 true resid norm 8.715304551183e+00 ||r(i)||/||b|| 2.082292610778e-04
370 KSP unpreconditioned resid norm 8.715301827851e+00 true resid norm 8.715301827849e+00 ||r(i)||/||b|| 2.082291960109e-04
371 KSP unpreconditioned resid norm 8.715301721255e+00 true resid norm 8.715301721244e+00 ||r(i)||/||b|| 2.082291934639e-04
372 KSP unpreconditioned resid norm 8.715295756875e+00 true resid norm 8.715295756872e+00 ||r(i)||/||b|| 2.082290509609e-04
373 KSP unpreconditioned resid norm 8.715292049258e+00 true resid norm 8.715292049248e+00 ||r(i)||/||b|| 2.082289623770e-04
374 KSP unpreconditioned resid norm 8.715290821544e+00 true resid norm 8.715290821548e+00 ||r(i)||/||b|| 2.082289330443e-04
375 KSP unpreconditioned resid norm 8.715290664158e+00 true resid norm 8.715290664151e+00 ||r(i)||/||b|| 2.082289292838e-04
376 KSP unpreconditioned resid norm 8.715289995744e+00 true resid norm 8.715289995731e+00 ||r(i)||/||b|| 2.082289133136e-04
377 KSP unpreconditioned resid norm 8.715288560951e+00 true resid norm 8.715288560946e+00 ||r(i)||/||b|| 2.082288790332e-04
378 KSP unpreconditioned resid norm 8.715280213801e+00 true resid norm 8.715280213791e+00 ||r(i)||/||b|| 2.082286795999e-04
379 KSP unpreconditioned resid norm 8.715275517946e+00 true resid norm 8.715275517942e+00 ||r(i)||/||b|| 2.082285674050e-04
380 KSP unpreconditioned resid norm 8.715248139111e+00 true resid norm 8.715248139103e+00 ||r(i)||/||b|| 2.082279132597e-04
381 KSP unpreconditioned resid norm 8.715247766175e+00 true resid norm 8.715247766164e+00 ||r(i)||/||b|| 2.082279043493e-04
382 KSP unpreconditioned resid norm 8.715246414670e+00 true resid norm 8.715246414664e+00 ||r(i)||/||b|| 2.082278720588e-04
383 KSP unpreconditioned resid norm 8.715228242318e+00 true resid norm 8.715228242309e+00 ||r(i)||/||b|| 2.082274378782e-04
384 KSP unpreconditioned resid norm 8.715226313126e+00 true resid norm 8.715226313130e+00 ||r(i)||/||b|| 2.082273917855e-04
385 KSP unpreconditioned resid norm 8.715192789055e+00 true resid norm 8.715192789045e+00 ||r(i)||/||b|| 2.082265908157e-04
386 KSP unpreconditioned resid norm 8.715192785426e+00 true resid norm 8.715192785422e+00 ||r(i)||/||b|| 2.082265907292e-04
387 KSP unpreconditioned resid norm 8.715022319800e+00 true resid norm 8.715022319792e+00 ||r(i)||/||b|| 2.082225179016e-04
388 KSP unpreconditioned resid norm 8.715013024677e+00 true resid norm 8.715013024673e+00 ||r(i)||/||b|| 2.082222958193e-04
389 KSP unpreconditioned resid norm 8.715000295403e+00 true resid norm 8.715000295394e+00 ||r(i)||/||b|| 2.082219916866e-04
390 KSP unpreconditioned resid norm 8.714993298025e+00 true resid norm 8.714993298025e+00 ||r(i)||/||b|| 2.082218245029e-04
391 KSP unpreconditioned resid norm 8.714993256884e+00 true resid norm 8.714993256889e+00 ||r(i)||/||b|| 2.082218235201e-04
392 KSP unpreconditioned resid norm 8.714993208878e+00 true resid norm 8.714993208876e+00 ||r(i)||/||b|| 2.082218223730e-04
393 KSP unpreconditioned resid norm 8.714993203913e+00 true resid norm 8.714993203925e+00 ||r(i)||/||b|| 2.082218222547e-04
394 KSP unpreconditioned resid norm 8.714993107241e+00 true resid norm 8.714993107240e+00 ||r(i)||/||b|| 2.082218199446e-04
395 KSP unpreconditioned resid norm 8.714992513095e+00 true resid norm 8.714992513105e+00 ||r(i)||/||b|| 2.082218057493e-04
396 KSP unpreconditioned resid norm 8.714992076297e+00 true resid norm 8.714992076295e+00 ||r(i)||/||b|| 2.082217953129e-04
397 KSP unpreconditioned resid norm 8.714991904091e+00 true resid norm 8.714991904086e+00 ||r(i)||/||b|| 2.082217911984e-04
398 KSP unpreconditioned resid norm 8.714991526119e+00 true resid norm 8.714991526118e+00 ||r(i)||/||b|| 2.082217821679e-04
399 KSP unpreconditioned resid norm 8.714991333320e+00 true resid norm 8.714991333314e+00 ||r(i)||/||b|| 2.082217775613e-04
400 KSP unpreconditioned resid norm 8.714991057569e+00 true resid norm 8.714991057569e+00 ||r(i)||/||b|| 2.082217709731e-04
401 KSP unpreconditioned resid norm 8.714991027971e+00 true resid norm 8.714991027971e+00 ||r(i)||/||b|| 2.082217702660e-04
402 KSP unpreconditioned resid norm 8.714987121921e+00 true resid norm 8.714987121937e+00 ||r(i)||/||b|| 2.082216769416e-04
403 KSP unpreconditioned resid norm 8.714984075295e+00 true resid norm 8.714984075311e+00 ||r(i)||/||b|| 2.082216041504e-04
404 KSP unpreconditioned resid norm 8.714978100044e+00 true resid norm 8.714978100050e+00 ||r(i)||/||b|| 2.082214613873e-04
405 KSP unpreconditioned resid norm 8.714976277644e+00 true resid norm 8.714976277651e+00 ||r(i)||/||b|| 2.082214178459e-04
406 KSP unpreconditioned resid norm 8.714976178777e+00 true resid norm 8.714976178784e+00 ||r(i)||/||b|| 2.082214154837e-04
407 KSP unpreconditioned resid norm 8.714974190439e+00 true resid norm 8.714974190436e+00 ||r(i)||/||b|| 2.082213679774e-04
408 KSP unpreconditioned resid norm 8.714971493927e+00 true resid norm 8.714971493925e+00 ||r(i)||/||b|| 2.082213035514e-04
409 KSP unpreconditioned resid norm 8.714966686517e+00 true resid norm 8.714966686517e+00 ||r(i)||/||b|| 2.082211886910e-04
410 KSP unpreconditioned resid norm 8.714966673134e+00 true resid norm 8.714966673137e+00 ||r(i)||/||b|| 2.082211883713e-04
411 KSP unpreconditioned resid norm 8.714931601060e+00 true resid norm 8.714931601050e+00 ||r(i)||/||b|| 2.082203504161e-04
412 KSP unpreconditioned resid norm 8.714929853758e+00 true resid norm 8.714929853765e+00 ||r(i)||/||b|| 2.082203086693e-04
413 KSP unpreconditioned resid norm 8.714911505489e+00 true resid norm 8.714911505480e+00 ||r(i)||/||b|| 2.082198702854e-04
414 KSP unpreconditioned resid norm 8.714851686120e+00 true resid norm 8.714851686132e+00 ||r(i)||/||b|| 2.082184410595e-04
415 KSP unpreconditioned resid norm 8.714851670474e+00 true resid norm 8.714851670482e+00 ||r(i)||/||b|| 2.082184406856e-04
416 KSP unpreconditioned resid norm 8.714846601215e+00 true resid norm 8.714846601218e+00 ||r(i)||/||b|| 2.082183195689e-04
417 KSP unpreconditioned resid norm 8.714834014168e+00 true resid norm 8.714834014172e+00 ||r(i)||/||b|| 2.082180188345e-04
418 KSP unpreconditioned resid norm 8.714815093662e+00 true resid norm 8.714815093660e+00 ||r(i)||/||b|| 2.082175667787e-04
419 KSP unpreconditioned resid norm 8.714800460823e+00 true resid norm 8.714800460830e+00 ||r(i)||/||b|| 2.082172171658e-04
420 KSP unpreconditioned resid norm 8.714725005871e+00 true resid norm 8.714725005871e+00 ||r(i)||/||b|| 2.082154143681e-04
421 KSP unpreconditioned resid norm 8.714723986397e+00 true resid norm 8.714723986395e+00 ||r(i)||/||b|| 2.082153900104e-04
422 KSP unpreconditioned resid norm 8.714718946688e+00 true resid norm 8.714718946673e+00 ||r(i)||/||b|| 2.082152695995e-04
423 KSP unpreconditioned resid norm 8.714713071323e+00 true resid norm 8.714713071318e+00 ||r(i)||/||b|| 2.082151292234e-04
424 KSP unpreconditioned resid norm 8.714712053749e+00 true resid norm 8.714712053738e+00 ||r(i)||/||b|| 2.082151049110e-04
425 KSP unpreconditioned resid norm 8.714710421205e+00 true resid norm 8.714710421207e+00 ||r(i)||/||b|| 2.082150659060e-04
426 KSP unpreconditioned resid norm 8.714708686691e+00 true resid norm 8.714708686683e+00 ||r(i)||/||b|| 2.082150244641e-04
427 KSP unpreconditioned resid norm 8.714708099075e+00 true resid norm 8.714708099084e+00 ||r(i)||/||b|| 2.082150104250e-04
428 KSP unpreconditioned resid norm 8.714707078998e+00 true resid norm 8.714707079002e+00 ||r(i)||/||b|| 2.082149860528e-04
429 KSP unpreconditioned resid norm 8.714702226116e+00 true resid norm 8.714702226121e+00 ||r(i)||/||b|| 2.082148701060e-04
430 KSP unpreconditioned resid norm 8.714694253736e+00 true resid norm 8.714694253741e+00 ||r(i)||/||b|| 2.082146796269e-04
431 KSP unpreconditioned resid norm 8.714687649500e+00 true resid norm 8.714687649509e+00 ||r(i)||/||b|| 2.082145218362e-04
432 KSP unpreconditioned resid norm 8.714678601103e+00 true resid norm 8.714678601098e+00 ||r(i)||/||b|| 2.082143056482e-04
433 KSP unpreconditioned resid norm 8.714677059861e+00 true resid norm 8.714677059863e+00 ||r(i)||/||b|| 2.082142688245e-04
434 KSP unpreconditioned resid norm 8.714671700527e+00 true resid norm 8.714671700519e+00 ||r(i)||/||b|| 2.082141407771e-04
435 KSP unpreconditioned resid norm 8.714668710897e+00 true resid norm 8.714668710897e+00 ||r(i)||/||b|| 2.082140693479e-04
436 KSP unpreconditioned resid norm 8.714666474687e+00 true resid norm 8.714666474677e+00 ||r(i)||/||b|| 2.082140159193e-04
437 KSP unpreconditioned resid norm 8.714665998901e+00 true resid norm 8.714665998899e+00 ||r(i)||/||b|| 2.082140045519e-04
438 KSP unpreconditioned resid norm 8.714647091575e+00 true resid norm 8.714647091581e+00 ||r(i)||/||b|| 2.082135528112e-04
439 KSP unpreconditioned resid norm 8.714646452397e+00 true resid norm 8.714646452398e+00 ||r(i)||/||b|| 2.082135375397e-04
440 KSP unpreconditioned resid norm 8.714638240750e+00 true resid norm 8.714638240754e+00 ||r(i)||/||b|| 2.082133413440e-04
441 KSP unpreconditioned resid norm 8.714635480127e+00 true resid norm 8.714635480134e+00 ||r(i)||/||b|| 2.082132753863e-04
442 KSP unpreconditioned resid norm 8.714634630131e+00 true resid norm 8.714634630121e+00 ||r(i)||/||b|| 2.082132550775e-04
443 KSP unpreconditioned resid norm 8.714624324054e+00 true resid norm 8.714624324048e+00 ||r(i)||/||b|| 2.082130088410e-04
444 KSP unpreconditioned resid norm 8.714599358709e+00 true resid norm 8.714599358713e+00 ||r(i)||/||b|| 2.082124123600e-04
445 KSP unpreconditioned resid norm 8.714578314445e+00 true resid norm 8.714578314443e+00 ||r(i)||/||b|| 2.082119095626e-04
446 KSP unpreconditioned resid norm 8.714558492429e+00 true resid norm 8.714558492430e+00 ||r(i)||/||b|| 2.082114359678e-04
447 KSP unpreconditioned resid norm 8.714558085664e+00 true resid norm 8.714558085660e+00 ||r(i)||/||b|| 2.082114262491e-04
448 KSP unpreconditioned resid norm 8.714558011301e+00 true resid norm 8.714558011296e+00 ||r(i)||/||b|| 2.082114244723e-04
449 KSP unpreconditioned resid norm 8.714554079652e+00 true resid norm 8.714554079646e+00 ||r(i)||/||b|| 2.082113305359e-04
450 KSP unpreconditioned resid norm 8.714533931468e+00 true resid norm 8.714533931468e+00 ||r(i)||/||b|| 2.082108491482e-04
451 KSP unpreconditioned resid norm 8.714533768431e+00 true resid norm 8.714533768436e+00 ||r(i)||/||b|| 2.082108452530e-04
452 KSP unpreconditioned resid norm 8.714532877423e+00 true resid norm 8.714532877427e+00 ||r(i)||/||b|| 2.082108239647e-04
453 KSP unpreconditioned resid norm 8.714531400744e+00 true resid norm 8.714531400745e+00 ||r(i)||/||b|| 2.082107886833e-04
454 KSP unpreconditioned resid norm 8.714530886431e+00 true resid norm 8.714530886432e+00 ||r(i)||/||b|| 2.082107763951e-04
455 KSP unpreconditioned resid norm 8.714530746452e+00 true resid norm 8.714530746458e+00 ||r(i)||/||b|| 2.082107730508e-04
456 KSP unpreconditioned resid norm 8.714530644273e+00 true resid norm 8.714530644281e+00 ||r(i)||/||b|| 2.082107706095e-04
457 KSP unpreconditioned resid norm 8.714530502145e+00 true resid norm 8.714530502154e+00 ||r(i)||/||b|| 2.082107672138e-04
458 KSP unpreconditioned resid norm 8.714530132192e+00 true resid norm 8.714530132191e+00 ||r(i)||/||b|| 2.082107583745e-04
459 KSP unpreconditioned resid norm 8.714529822398e+00 true resid norm 8.714529822402e+00 ||r(i)||/||b|| 2.082107509729e-04
460 KSP unpreconditioned resid norm 8.714527883658e+00 true resid norm 8.714527883663e+00 ||r(i)||/||b|| 2.082107046519e-04
461 KSP unpreconditioned resid norm 8.714527639692e+00 true resid norm 8.714527639698e+00 ||r(i)||/||b|| 2.082106988230e-04
462 KSP unpreconditioned resid norm 8.714525996448e+00 true resid norm 8.714525996456e+00 ||r(i)||/||b|| 2.082106595620e-04
463 KSP unpreconditioned resid norm 8.714525927792e+00 true resid norm 8.714525927808e+00 ||r(i)||/||b|| 2.082106579218e-04
464 KSP unpreconditioned resid norm 8.714525542088e+00 true resid norm 8.714525542095e+00 ||r(i)||/||b|| 2.082106487062e-04
465 KSP unpreconditioned resid norm 8.714519167084e+00 true resid norm 8.714519167089e+00 ||r(i)||/||b|| 2.082104963923e-04
466 KSP unpreconditioned resid norm 8.714519166867e+00 true resid norm 8.714519166874e+00 ||r(i)||/||b|| 2.082104963871e-04
467 KSP unpreconditioned resid norm 8.714516326737e+00 true resid norm 8.714516326743e+00 ||r(i)||/||b|| 2.082104285297e-04
468 KSP unpreconditioned resid norm 8.714512766368e+00 true resid norm 8.714512766370e+00 ||r(i)||/||b|| 2.082103434639e-04
469 KSP unpreconditioned resid norm 8.714507313158e+00 true resid norm 8.714507313161e+00 ||r(i)||/||b|| 2.082102131738e-04
470 KSP unpreconditioned resid norm 8.714504721906e+00 true resid norm 8.714504721917e+00 ||r(i)||/||b|| 2.082101512629e-04
471 KSP unpreconditioned resid norm 8.714494108323e+00 true resid norm 8.714494108317e+00 ||r(i)||/||b|| 2.082098976789e-04
472 KSP unpreconditioned resid norm 8.714493327064e+00 true resid norm 8.714493327067e+00 ||r(i)||/||b|| 2.082098790129e-04
473 KSP unpreconditioned resid norm 8.714484449636e+00 true resid norm 8.714484449642e+00 ||r(i)||/||b|| 2.082096669103e-04
474 KSP unpreconditioned resid norm 8.714478729702e+00 true resid norm 8.714478729704e+00 ||r(i)||/||b|| 2.082095302474e-04
475 KSP unpreconditioned resid norm 8.714455769443e+00 true resid norm 8.714455769440e+00 ||r(i)||/||b|| 2.082089816723e-04
476 KSP unpreconditioned resid norm 8.714451897646e+00 true resid norm 8.714451897657e+00 ||r(i)||/||b|| 2.082088891663e-04
477 KSP unpreconditioned resid norm 8.714415532265e+00 true resid norm 8.714415532286e+00 ||r(i)||/||b|| 2.082080203114e-04
478 KSP unpreconditioned resid norm 8.714414702398e+00 true resid norm 8.714414702402e+00 ||r(i)||/||b|| 2.082080004835e-04
479 KSP unpreconditioned resid norm 8.714373893880e+00 true resid norm 8.714373893882e+00 ||r(i)||/||b|| 2.082070254714e-04
480 KSP unpreconditioned resid norm 8.714328889876e+00 true resid norm 8.714328889876e+00 ||r(i)||/||b|| 2.082059502191e-04
481 KSP unpreconditioned resid norm 8.714328518179e+00 true resid norm 8.714328518182e+00 ||r(i)||/||b|| 2.082059413385e-04
482 KSP unpreconditioned resid norm 8.714325140041e+00 true resid norm 8.714325140038e+00 ||r(i)||/||b|| 2.082058606266e-04
483 KSP unpreconditioned resid norm 8.714316876355e+00 true resid norm 8.714316876351e+00 ||r(i)||/||b|| 2.082056631876e-04
484 KSP unpreconditioned resid norm 8.714315353515e+00 true resid norm 8.714315353515e+00 ||r(i)||/||b|| 2.082056268034e-04
485 KSP unpreconditioned resid norm 8.714312054804e+00 true resid norm 8.714312054795e+00 ||r(i)||/||b|| 2.082055479892e-04
486 KSP unpreconditioned resid norm 8.714310656575e+00 true resid norm 8.714310656577e+00 ||r(i)||/||b|| 2.082055145824e-04
487 KSP unpreconditioned resid norm 8.714309076660e+00 true resid norm 8.714309076651e+00 ||r(i)||/||b|| 2.082054768343e-04
488 KSP unpreconditioned resid norm 8.714305995216e+00 true resid norm 8.714305995216e+00 ||r(i)||/||b|| 2.082054032115e-04
489 KSP unpreconditioned resid norm 8.714301832987e+00 true resid norm 8.714301832981e+00 ||r(i)||/||b|| 2.082053037658e-04
490 KSP unpreconditioned resid norm 8.714284818443e+00 true resid norm 8.714284818443e+00 ||r(i)||/||b|| 2.082048972482e-04
491 KSP unpreconditioned resid norm 8.714283308037e+00 true resid norm 8.714283308030e+00 ||r(i)||/||b|| 2.082048611609e-04
492 KSP unpreconditioned resid norm 8.714262434717e+00 true resid norm 8.714262434709e+00 ||r(i)||/||b|| 2.082043624478e-04
493 KSP unpreconditioned resid norm 8.714261564657e+00 true resid norm 8.714261564649e+00 ||r(i)||/||b|| 2.082043416600e-04
494 KSP unpreconditioned resid norm 8.714250839520e+00 true resid norm 8.714250839510e+00 ||r(i)||/||b|| 2.082040854111e-04
495 KSP unpreconditioned resid norm 8.714249406599e+00 true resid norm 8.714249406597e+00 ||r(i)||/||b|| 2.082040511754e-04
496 KSP unpreconditioned resid norm 8.714246249735e+00 true resid norm 8.714246249733e+00 ||r(i)||/||b|| 2.082039757504e-04
497 KSP unpreconditioned resid norm 8.714245768234e+00 true resid norm 8.714245768235e+00 ||r(i)||/||b|| 2.082039642463e-04
498 KSP unpreconditioned resid norm 8.714237614333e+00 true resid norm 8.714237614331e+00 ||r(i)||/||b|| 2.082037694302e-04
499 KSP unpreconditioned resid norm 8.714223832895e+00 true resid norm 8.714223832887e+00 ||r(i)||/||b|| 2.082034401589e-04
500 KSP unpreconditioned resid norm 8.714215373965e+00 true resid norm 8.714215373949e+00 ||r(i)||/||b|| 2.082032380549e-04
501 KSP unpreconditioned resid norm 8.714198979908e+00 true resid norm 8.714198979908e+00 ||r(i)||/||b|| 2.082028463624e-04
502 KSP unpreconditioned resid norm 8.714192880623e+00 true resid norm 8.714192880613e+00 ||r(i)||/||b|| 2.082027006358e-04
503 KSP unpreconditioned resid norm 8.714177003695e+00 true resid norm 8.714177003684e+00 ||r(i)||/||b|| 2.082023212984e-04
504 KSP unpreconditioned resid norm 8.714144020896e+00 true resid norm 8.714144020900e+00 ||r(i)||/||b|| 2.082015332616e-04
505 KSP unpreconditioned resid norm 8.714121931679e+00 true resid norm 8.714121931677e+00 ||r(i)||/||b|| 2.082010054977e-04
506 KSP unpreconditioned resid norm 8.714114483113e+00 true resid norm 8.714114483115e+00 ||r(i)||/||b|| 2.082008275339e-04
507 KSP unpreconditioned resid norm 8.714113967805e+00 true resid norm 8.714113967801e+00 ||r(i)||/||b|| 2.082008152219e-04
508 KSP unpreconditioned resid norm 8.714111639264e+00 true resid norm 8.714111639261e+00 ||r(i)||/||b|| 2.082007595875e-04
509 KSP unpreconditioned resid norm 8.714107997688e+00 true resid norm 8.714107997685e+00 ||r(i)||/||b|| 2.082006725817e-04
510 KSP unpreconditioned resid norm 8.714105654152e+00 true resid norm 8.714105654152e+00 ||r(i)||/||b|| 2.082006165891e-04
511 KSP unpreconditioned resid norm 8.714105635957e+00 true resid norm 8.714105635954e+00 ||r(i)||/||b|| 2.082006161543e-04
512 KSP unpreconditioned resid norm 8.714105461577e+00 true resid norm 8.714105461580e+00 ||r(i)||/||b|| 2.082006119881e-04
513 KSP unpreconditioned resid norm 8.714104934823e+00 true resid norm 8.714104934812e+00 ||r(i)||/||b|| 2.082005994024e-04
514 KSP unpreconditioned resid norm 8.714104613527e+00 true resid norm 8.714104613527e+00 ||r(i)||/||b|| 2.082005917261e-04
515 KSP unpreconditioned resid norm 8.714104603407e+00 true resid norm 8.714104603400e+00 ||r(i)||/||b|| 2.082005914842e-04
516 KSP unpreconditioned resid norm 8.714104583732e+00 true resid norm 8.714104583725e+00 ||r(i)||/||b|| 2.082005910141e-04
517 KSP unpreconditioned resid norm 8.714104001501e+00 true resid norm 8.714104001496e+00 ||r(i)||/||b|| 2.082005771033e-04
518 KSP unpreconditioned resid norm 8.714102384963e+00 true resid norm 8.714102384957e+00 ||r(i)||/||b|| 2.082005384803e-04
519 KSP unpreconditioned resid norm 8.714102354101e+00 true resid norm 8.714102354096e+00 ||r(i)||/||b|| 2.082005377430e-04
520 KSP unpreconditioned resid norm 8.714101450086e+00 true resid norm 8.714101450089e+00 ||r(i)||/||b|| 2.082005161441e-04
521 KSP unpreconditioned resid norm 8.714101392044e+00 true resid norm 8.714101392049e+00 ||r(i)||/||b|| 2.082005147574e-04
522 KSP unpreconditioned resid norm 8.714100912477e+00 true resid norm 8.714100912472e+00 ||r(i)||/||b|| 2.082005032992e-04
523 KSP unpreconditioned resid norm 8.714100871064e+00 true resid norm 8.714100871054e+00 ||r(i)||/||b|| 2.082005023096e-04
524 KSP unpreconditioned resid norm 8.714098225079e+00 true resid norm 8.714098225066e+00 ||r(i)||/||b|| 2.082004390907e-04
525 KSP unpreconditioned resid norm 8.714090740558e+00 true resid norm 8.714090740544e+00 ||r(i)||/||b|| 2.082002602677e-04
526 KSP unpreconditioned resid norm 8.714090691572e+00 true resid norm 8.714090691578e+00 ||r(i)||/||b|| 2.082002590978e-04
527 KSP unpreconditioned resid norm 8.714088532793e+00 true resid norm 8.714088532793e+00 ||r(i)||/||b|| 2.082002075193e-04
528 KSP unpreconditioned resid norm 8.714088312896e+00 true resid norm 8.714088312900e+00 ||r(i)||/||b|| 2.082002022656e-04
529 KSP unpreconditioned resid norm 8.714086319492e+00 true resid norm 8.714086319483e+00 ||r(i)||/||b|| 2.082001546381e-04
530 KSP unpreconditioned resid norm 8.714079009034e+00 true resid norm 8.714079009019e+00 ||r(i)||/||b|| 2.081999799738e-04
531 KSP unpreconditioned resid norm 8.714062546574e+00 true resid norm 8.714062546560e+00 ||r(i)||/||b|| 2.081995866467e-04
532 KSP unpreconditioned resid norm 8.714062466422e+00 true resid norm 8.714062466423e+00 ||r(i)||/||b|| 2.081995847320e-04
533 KSP unpreconditioned resid norm 8.714042504664e+00 true resid norm 8.714042504668e+00 ||r(i)||/||b|| 2.081991077984e-04
534 KSP unpreconditioned resid norm 8.714041234257e+00 true resid norm 8.714041234254e+00 ||r(i)||/||b|| 2.081990774452e-04
535 KSP unpreconditioned resid norm 8.714027851635e+00 true resid norm 8.714027851633e+00 ||r(i)||/||b|| 2.081987577027e-04
536 KSP unpreconditioned resid norm 8.714018782479e+00 true resid norm 8.714018782476e+00 ||r(i)||/||b|| 2.081985410191e-04
537 KSP unpreconditioned resid norm 8.713980165675e+00 true resid norm 8.713980165667e+00 ||r(i)||/||b|| 2.081976183721e-04
538 KSP unpreconditioned resid norm 8.713980109349e+00 true resid norm 8.713980109356e+00 ||r(i)||/||b|| 2.081976170267e-04
539 KSP unpreconditioned resid norm 8.713926586165e+00 true resid norm 8.713926586159e+00 ||r(i)||/||b|| 2.081963382308e-04
540 KSP unpreconditioned resid norm 8.713883118512e+00 true resid norm 8.713883118512e+00 ||r(i)||/||b|| 2.081952996858e-04
541 KSP unpreconditioned resid norm 8.713882712622e+00 true resid norm 8.713882712616e+00 ||r(i)||/||b|| 2.081952899880e-04
542 KSP unpreconditioned resid norm 8.713878343365e+00 true resid norm 8.713878343361e+00 ||r(i)||/||b|| 2.081951855961e-04
543 KSP unpreconditioned resid norm 8.713867453877e+00 true resid norm 8.713867453877e+00 ||r(i)||/||b|| 2.081949254206e-04
544 KSP unpreconditioned resid norm 8.713865726728e+00 true resid norm 8.713865726734e+00 ||r(i)||/||b|| 2.081948841550e-04
545 KSP unpreconditioned resid norm 8.713861777227e+00 true resid norm 8.713861777224e+00 ||r(i)||/||b|| 2.081947897919e-04
546 KSP unpreconditioned resid norm 8.713860164837e+00 true resid norm 8.713860164836e+00 ||r(i)||/||b|| 2.081947512681e-04
547 KSP unpreconditioned resid norm 8.713859225552e+00 true resid norm 8.713859225551e+00 ||r(i)||/||b|| 2.081947288264e-04
548 KSP unpreconditioned resid norm 8.713859033981e+00 true resid norm 8.713859033982e+00 ||r(i)||/||b|| 2.081947242493e-04
549 KSP unpreconditioned resid norm 8.713845977070e+00 true resid norm 8.713845977069e+00 ||r(i)||/||b|| 2.081944122888e-04
550 KSP unpreconditioned resid norm 8.713816253850e+00 true resid norm 8.713816253854e+00 ||r(i)||/||b|| 2.081937021308e-04
551 KSP unpreconditioned resid norm 8.713816229048e+00 true resid norm 8.713816229037e+00 ||r(i)||/||b|| 2.081937015378e-04
552 KSP unpreconditioned resid norm 8.713796904003e+00 true resid norm 8.713796904000e+00 ||r(i)||/||b|| 2.081932398169e-04
553 KSP unpreconditioned resid norm 8.713794974800e+00 true resid norm 8.713794974797e+00 ||r(i)||/||b|| 2.081931937237e-04
554 KSP unpreconditioned resid norm 8.713794955937e+00 true resid norm 8.713794955939e+00 ||r(i)||/||b|| 2.081931932732e-04
555 KSP unpreconditioned resid norm 8.713788163455e+00 true resid norm 8.713788163448e+00 ||r(i)||/||b|| 2.081930309845e-04
556 KSP unpreconditioned resid norm 8.713777273605e+00 true resid norm 8.713777273596e+00 ||r(i)||/||b|| 2.081927708001e-04
557 KSP unpreconditioned resid norm 8.713777272988e+00 true resid norm 8.713777272984e+00 ||r(i)||/||b|| 2.081927707855e-04
558 KSP unpreconditioned resid norm 8.713752892988e+00 true resid norm 8.713752892990e+00 ||r(i)||/||b|| 2.081921882897e-04
559 KSP unpreconditioned resid norm 8.713627218799e+00 true resid norm 8.713627218800e+00 ||r(i)||/||b|| 2.081891856358e-04
560 KSP unpreconditioned resid norm 8.713605454970e+00 true resid norm 8.713605454969e+00 ||r(i)||/||b|| 2.081886656463e-04
561 KSP unpreconditioned resid norm 8.713605284457e+00 true resid norm 8.713605284454e+00 ||r(i)||/||b|| 2.081886615723e-04
562 KSP unpreconditioned resid norm 8.713604428656e+00 true resid norm 8.713604428651e+00 ||r(i)||/||b|| 2.081886411251e-04
563 KSP unpreconditioned resid norm 8.713598699060e+00 true resid norm 8.713598699056e+00 ||r(i)||/||b|| 2.081885042315e-04
564 KSP unpreconditioned resid norm 8.713415240704e+00 true resid norm 8.713415240701e+00 ||r(i)||/||b|| 2.081841209771e-04
565 KSP unpreconditioned resid norm 8.713219643026e+00 true resid norm 8.713219643022e+00 ||r(i)||/||b|| 2.081794476854e-04
566 KSP unpreconditioned resid norm 8.713194229893e+00 true resid norm 8.713194229893e+00 ||r(i)||/||b|| 2.081788405056e-04
567 KSP unpreconditioned resid norm 8.713191300178e+00 true resid norm 8.713191300169e+00 ||r(i)||/||b|| 2.081787705075e-04
568 KSP unpreconditioned resid norm 8.713189738697e+00 true resid norm 8.713189738685e+00 ||r(i)||/||b|| 2.081787332000e-04
569 KSP unpreconditioned resid norm 8.713189032082e+00 true resid norm 8.713189032084e+00 ||r(i)||/||b|| 2.081787163176e-04
570 KSP unpreconditioned resid norm 8.713169109390e+00 true resid norm 8.713169109390e+00 ||r(i)||/||b|| 2.081782403173e-04
571 KSP unpreconditioned resid norm 8.713169033099e+00 true resid norm 8.713169033100e+00 ||r(i)||/||b|| 2.081782384945e-04
572 KSP unpreconditioned resid norm 8.713168654964e+00 true resid norm 8.713168654956e+00 ||r(i)||/||b|| 2.081782294598e-04
573 KSP unpreconditioned resid norm 8.713168376639e+00 true resid norm 8.713168376631e+00 ||r(i)||/||b|| 2.081782228099e-04
574 KSP unpreconditioned resid norm 8.713168278489e+00 true resid norm 8.713168278484e+00 ||r(i)||/||b|| 2.081782204650e-04
575 KSP unpreconditioned resid norm 8.713167058143e+00 true resid norm 8.713167058144e+00 ||r(i)||/||b|| 2.081781913082e-04
576 KSP unpreconditioned resid norm 8.713166342360e+00 true resid norm 8.713166342356e+00 ||r(i)||/||b|| 2.081781742063e-04
577 KSP unpreconditioned resid norm 8.713164013230e+00 true resid norm 8.713164013226e+00 ||r(i)||/||b|| 2.081781185578e-04
578 KSP unpreconditioned resid norm 8.713156397717e+00 true resid norm 8.713156397707e+00 ||r(i)||/||b|| 2.081779366051e-04
579 KSP unpreconditioned resid norm 8.713149141248e+00 true resid norm 8.713149141235e+00 ||r(i)||/||b|| 2.081777632308e-04
580 KSP unpreconditioned resid norm 8.713146901991e+00 true resid norm 8.713146901991e+00 ||r(i)||/||b|| 2.081777097299e-04
581 KSP unpreconditioned resid norm 8.713146737649e+00 true resid norm 8.713146737653e+00 ||r(i)||/||b|| 2.081777058035e-04
582 KSP unpreconditioned resid norm 8.713146617582e+00 true resid norm 8.713146617572e+00 ||r(i)||/||b|| 2.081777029345e-04
583 KSP unpreconditioned resid norm 8.713139085179e+00 true resid norm 8.713139085180e+00 ||r(i)||/||b|| 2.081775229678e-04
584 KSP unpreconditioned resid norm 8.713113087858e+00 true resid norm 8.713113087854e+00 ||r(i)||/||b|| 2.081769018301e-04
585 KSP unpreconditioned resid norm 8.713086776808e+00 true resid norm 8.713086776807e+00 ||r(i)||/||b|| 2.081762731969e-04
586 KSP unpreconditioned resid norm 8.713083311860e+00 true resid norm 8.713083311856e+00 ||r(i)||/||b|| 2.081761904111e-04
587 KSP unpreconditioned resid norm 8.713083302981e+00 true resid norm 8.713083302972e+00 ||r(i)||/||b|| 2.081761901988e-04
588 KSP unpreconditioned resid norm 8.713082785884e+00 true resid norm 8.713082785888e+00 ||r(i)||/||b|| 2.081761778444e-04
589 KSP unpreconditioned resid norm 8.713080098347e+00 true resid norm 8.713080098346e+00 ||r(i)||/||b|| 2.081761136327e-04
590 KSP unpreconditioned resid norm 8.713069258492e+00 true resid norm 8.713069258494e+00 ||r(i)||/||b|| 2.081758546429e-04
591 KSP unpreconditioned resid norm 8.713053389553e+00 true resid norm 8.713053389556e+00 ||r(i)||/||b|| 2.081754754965e-04
592 KSP unpreconditioned resid norm 8.713052789167e+00 true resid norm 8.713052789168e+00 ||r(i)||/||b|| 2.081754611518e-04
593 KSP unpreconditioned resid norm 8.713051817378e+00 true resid norm 8.713051817380e+00 ||r(i)||/||b|| 2.081754379334e-04
594 KSP unpreconditioned resid norm 8.713033024560e+00 true resid norm 8.713033024558e+00 ||r(i)||/||b|| 2.081749889284e-04
595 KSP unpreconditioned resid norm 8.713015636538e+00 true resid norm 8.713015636538e+00 ||r(i)||/||b|| 2.081745734875e-04
596 KSP unpreconditioned resid norm 8.713012180068e+00 true resid norm 8.713012180060e+00 ||r(i)||/||b|| 2.081744909040e-04
597 KSP unpreconditioned resid norm 8.713006786686e+00 true resid norm 8.713006786676e+00 ||r(i)||/||b|| 2.081743620433e-04
598 KSP unpreconditioned resid norm 8.713006727609e+00 true resid norm 8.713006727604e+00 ||r(i)||/||b|| 2.081743606319e-04
599 KSP unpreconditioned resid norm 8.712988569399e+00 true resid norm 8.712988569388e+00 ||r(i)||/||b|| 2.081739267892e-04
600 KSP unpreconditioned resid norm 8.712982123790e+00 true resid norm 8.712982123790e+00 ||r(i)||/||b|| 2.081737727886e-04
601 KSP unpreconditioned resid norm 8.712982083276e+00 true resid norm 8.712982083271e+00 ||r(i)||/||b|| 2.081737718205e-04
602 KSP unpreconditioned resid norm 8.712981662760e+00 true resid norm 8.712981662765e+00 ||r(i)||/||b|| 2.081737617736e-04
603 KSP unpreconditioned resid norm 8.712980892664e+00 true resid norm 8.712980892652e+00 ||r(i)||/||b|| 2.081737433738e-04
604 KSP unpreconditioned resid norm 8.712980882455e+00 true resid norm 8.712980882455e+00 ||r(i)||/||b|| 2.081737431301e-04
605 KSP unpreconditioned resid norm 8.712980311498e+00 true resid norm 8.712980311497e+00 ||r(i)||/||b|| 2.081737294886e-04
606 KSP unpreconditioned resid norm 8.712980310327e+00 true resid norm 8.712980310325e+00 ||r(i)||/||b|| 2.081737294606e-04
607 KSP unpreconditioned resid norm 8.712978420712e+00 true resid norm 8.712978420709e+00 ||r(i)||/||b|| 2.081736843132e-04
608 KSP unpreconditioned resid norm 8.712976777701e+00 true resid norm 8.712976777700e+00 ||r(i)||/||b|| 2.081736450578e-04
609 KSP unpreconditioned resid norm 8.712976663079e+00 true resid norm 8.712976663065e+00 ||r(i)||/||b|| 2.081736423189e-04
610 KSP unpreconditioned resid norm 8.712974689472e+00 true resid norm 8.712974689461e+00 ||r(i)||/||b|| 2.081735951648e-04
611 KSP unpreconditioned resid norm 8.712974392078e+00 true resid norm 8.712974392072e+00 ||r(i)||/||b|| 2.081735880595e-04
612 KSP unpreconditioned resid norm 8.712971415589e+00 true resid norm 8.712971415590e+00 ||r(i)||/||b|| 2.081735169443e-04
613 KSP unpreconditioned resid norm 8.712971360286e+00 true resid norm 8.712971360285e+00 ||r(i)||/||b|| 2.081735156229e-04
614 KSP unpreconditioned resid norm 8.712969392690e+00 true resid norm 8.712969392689e+00 ||r(i)||/||b|| 2.081734686124e-04
615 KSP unpreconditioned resid norm 8.712967281063e+00 true resid norm 8.712967281057e+00 ||r(i)||/||b|| 2.081734181605e-04
616 KSP unpreconditioned resid norm 8.712967204422e+00 true resid norm 8.712967204425e+00 ||r(i)||/||b|| 2.081734163296e-04
617 KSP unpreconditioned resid norm 8.712967202735e+00 true resid norm 8.712967202719e+00 ||r(i)||/||b|| 2.081734162889e-04
618 KSP unpreconditioned resid norm 8.712964460308e+00 true resid norm 8.712964460303e+00 ||r(i)||/||b|| 2.081733507660e-04
619 KSP unpreconditioned resid norm 8.712961490057e+00 true resid norm 8.712961490058e+00 ||r(i)||/||b|| 2.081732797999e-04
620 KSP unpreconditioned resid norm 8.712958224193e+00 true resid norm 8.712958224192e+00 ||r(i)||/||b|| 2.081732017706e-04
621 KSP unpreconditioned resid norm 8.712953065367e+00 true resid norm 8.712953065366e+00 ||r(i)||/||b|| 2.081730785140e-04
622 KSP unpreconditioned resid norm 8.712952626972e+00 true resid norm 8.712952626972e+00 ||r(i)||/||b|| 2.081730680397e-04
623 KSP unpreconditioned resid norm 8.712949768851e+00 true resid norm 8.712949768859e+00 ||r(i)||/||b|| 2.081729997527e-04
624 KSP unpreconditioned resid norm 8.712905570429e+00 true resid norm 8.712905570419e+00 ||r(i)||/||b|| 2.081719437473e-04
625 KSP unpreconditioned resid norm 8.712845083561e+00 true resid norm 8.712845083563e+00 ||r(i)||/||b|| 2.081704985731e-04
626 KSP unpreconditioned resid norm 8.712841173781e+00 true resid norm 8.712841173788e+00 ||r(i)||/||b|| 2.081704051593e-04
627 KSP unpreconditioned resid norm 8.712840373974e+00 true resid norm 8.712840373972e+00 ||r(i)||/||b|| 2.081703860498e-04
628 KSP unpreconditioned resid norm 8.712840072221e+00 true resid norm 8.712840072219e+00 ||r(i)||/||b|| 2.081703788402e-04
629 KSP unpreconditioned resid norm 8.712834817030e+00 true resid norm 8.712834817027e+00 ||r(i)||/||b|| 2.081702532812e-04
630 KSP unpreconditioned resid norm 8.712806333552e+00 true resid norm 8.712806333552e+00 ||r(i)||/||b|| 2.081695727436e-04
631 KSP unpreconditioned resid norm 8.712806236239e+00 true resid norm 8.712806236239e+00 ||r(i)||/||b|| 2.081695704185e-04
632 KSP unpreconditioned resid norm 8.712805743772e+00 true resid norm 8.712805743763e+00 ||r(i)||/||b|| 2.081695586521e-04
633 KSP unpreconditioned resid norm 8.712805342546e+00 true resid norm 8.712805342535e+00 ||r(i)||/||b|| 2.081695490658e-04
634 KSP unpreconditioned resid norm 8.712805338244e+00 true resid norm 8.712805338233e+00 ||r(i)||/||b|| 2.081695489630e-04
635 KSP unpreconditioned resid norm 8.712805068721e+00 true resid norm 8.712805068704e+00 ||r(i)||/||b|| 2.081695425234e-04
636 KSP unpreconditioned resid norm 8.712805068533e+00 true resid norm 8.712805068527e+00 ||r(i)||/||b|| 2.081695425191e-04
637 KSP unpreconditioned resid norm 8.712805019831e+00 true resid norm 8.712805019830e+00 ||r(i)||/||b|| 2.081695413556e-04
638 KSP unpreconditioned resid norm 8.712803440444e+00 true resid norm 8.712803440439e+00 ||r(i)||/||b|| 2.081695036202e-04
639 KSP unpreconditioned resid norm 8.712799561558e+00 true resid norm 8.712799561570e+00 ||r(i)||/||b|| 2.081694109449e-04
640 KSP unpreconditioned resid norm 8.712796734182e+00 true resid norm 8.712796734186e+00 ||r(i)||/||b|| 2.081693433920e-04
641 KSP unpreconditioned resid norm 8.712796167243e+00 true resid norm 8.712796167233e+00 ||r(i)||/||b|| 2.081693298461e-04
642 KSP unpreconditioned resid norm 8.712796055195e+00 true resid norm 8.712796055192e+00 ||r(i)||/||b|| 2.081693271692e-04
643 KSP unpreconditioned resid norm 8.712795658897e+00 true resid norm 8.712795658897e+00 ||r(i)||/||b|| 2.081693177008e-04
644 KSP unpreconditioned resid norm 8.712787091779e+00 true resid norm 8.712787091771e+00 ||r(i)||/||b|| 2.081691130118e-04
645 KSP unpreconditioned resid norm 8.712778429819e+00 true resid norm 8.712778429818e+00 ||r(i)||/||b|| 2.081689060573e-04
646 KSP unpreconditioned resid norm 8.712776305798e+00 true resid norm 8.712776305797e+00 ||r(i)||/||b|| 2.081688553094e-04
647 KSP unpreconditioned resid norm 8.712773988222e+00 true resid norm 8.712773988213e+00 ||r(i)||/||b|| 2.081687999368e-04
648 KSP unpreconditioned resid norm 8.712773916060e+00 true resid norm 8.712773916052e+00 ||r(i)||/||b|| 2.081687982127e-04
649 KSP unpreconditioned resid norm 8.712773710051e+00 true resid norm 8.712773710044e+00 ||r(i)||/||b|| 2.081687932907e-04
650 KSP unpreconditioned resid norm 8.712771861033e+00 true resid norm 8.712771861022e+00 ||r(i)||/||b|| 2.081687491132e-04
651 KSP unpreconditioned resid norm 8.712758684029e+00 true resid norm 8.712758684031e+00 ||r(i)||/||b|| 2.081684342837e-04
652 KSP unpreconditioned resid norm 8.712750664046e+00 true resid norm 8.712750664035e+00 ||r(i)||/||b|| 2.081682426670e-04
653 KSP unpreconditioned resid norm 8.712735633125e+00 true resid norm 8.712735633112e+00 ||r(i)||/||b|| 2.081678835427e-04
654 KSP unpreconditioned resid norm 8.712680868954e+00 true resid norm 8.712680868947e+00 ||r(i)||/||b|| 2.081665750971e-04
655 KSP unpreconditioned resid norm 8.712664583222e+00 true resid norm 8.712664583221e+00 ||r(i)||/||b|| 2.081661859925e-04
656 KSP unpreconditioned resid norm 8.712664510350e+00 true resid norm 8.712664510352e+00 ||r(i)||/||b|| 2.081661842515e-04
657 KSP unpreconditioned resid norm 8.712664496472e+00 true resid norm 8.712664496466e+00 ||r(i)||/||b|| 2.081661839197e-04
658 KSP unpreconditioned resid norm 8.712656312822e+00 true resid norm 8.712656312813e+00 ||r(i)||/||b|| 2.081659883929e-04
659 KSP unpreconditioned resid norm 8.712656115778e+00 true resid norm 8.712656115767e+00 ||r(i)||/||b|| 2.081659836850e-04
660 KSP unpreconditioned resid norm 8.712655364451e+00 true resid norm 8.712655364451e+00 ||r(i)||/||b|| 2.081659657343e-04
661 KSP unpreconditioned resid norm 8.712655360900e+00 true resid norm 8.712655360910e+00 ||r(i)||/||b|| 2.081659656497e-04
662 KSP unpreconditioned resid norm 8.712655353580e+00 true resid norm 8.712655353592e+00 ||r(i)||/||b|| 2.081659654748e-04
663 KSP unpreconditioned resid norm 8.712655338619e+00 true resid norm 8.712655338625e+00 ||r(i)||/||b|| 2.081659651172e-04
664 KSP unpreconditioned resid norm 8.712655161301e+00 true resid norm 8.712655161307e+00 ||r(i)||/||b|| 2.081659608807e-04
665 KSP unpreconditioned resid norm 8.712654969327e+00 true resid norm 8.712654969331e+00 ||r(i)||/||b|| 2.081659562939e-04
666 KSP unpreconditioned resid norm 8.712654951185e+00 true resid norm 8.712654951198e+00 ||r(i)||/||b|| 2.081659558607e-04
667 KSP unpreconditioned resid norm 8.712654218782e+00 true resid norm 8.712654218787e+00 ||r(i)||/||b|| 2.081659383617e-04
668 KSP unpreconditioned resid norm 8.712653254592e+00 true resid norm 8.712653254606e+00 ||r(i)||/||b|| 2.081659153251e-04
669 KSP unpreconditioned resid norm 8.712653083943e+00 true resid norm 8.712653083947e+00 ||r(i)||/||b|| 2.081659112476e-04
670 KSP unpreconditioned resid norm 8.712653076519e+00 true resid norm 8.712653076520e+00 ||r(i)||/||b|| 2.081659110702e-04
671 KSP unpreconditioned resid norm 8.712652841453e+00 true resid norm 8.712652841463e+00 ||r(i)||/||b|| 2.081659054541e-04
672 KSP unpreconditioned resid norm 8.712652771568e+00 true resid norm 8.712652771575e+00 ||r(i)||/||b|| 2.081659037843e-04
673 KSP unpreconditioned resid norm 8.712652265710e+00 true resid norm 8.712652265715e+00 ||r(i)||/||b|| 2.081658916981e-04
674 KSP unpreconditioned resid norm 8.712651257705e+00 true resid norm 8.712651257712e+00 ||r(i)||/||b|| 2.081658676146e-04
675 KSP unpreconditioned resid norm 8.712647351247e+00 true resid norm 8.712647351261e+00 ||r(i)||/||b|| 2.081657742802e-04
676 KSP unpreconditioned resid norm 8.712646407407e+00 true resid norm 8.712646407415e+00 ||r(i)||/||b|| 2.081657517295e-04
677 KSP unpreconditioned resid norm 8.712646273895e+00 true resid norm 8.712646273905e+00 ||r(i)||/||b|| 2.081657485396e-04
678 KSP unpreconditioned resid norm 8.712646085656e+00 true resid norm 8.712646085663e+00 ||r(i)||/||b|| 2.081657440421e-04
679 KSP unpreconditioned resid norm 8.712645399874e+00 true resid norm 8.712645399884e+00 ||r(i)||/||b|| 2.081657276572e-04
680 KSP unpreconditioned resid norm 8.712642084766e+00 true resid norm 8.712642084775e+00 ||r(i)||/||b|| 2.081656484514e-04
681 KSP unpreconditioned resid norm 8.712640636255e+00 true resid norm 8.712640636253e+00 ||r(i)||/||b|| 2.081656138428e-04
682 KSP unpreconditioned resid norm 8.712637627645e+00 true resid norm 8.712637627646e+00 ||r(i)||/||b|| 2.081655419600e-04
683 KSP unpreconditioned resid norm 8.712630096339e+00 true resid norm 8.712630096345e+00 ||r(i)||/||b|| 2.081653620194e-04
684 KSP unpreconditioned resid norm 8.712616915211e+00 true resid norm 8.712616915214e+00 ||r(i)||/||b|| 2.081650470910e-04
685 KSP unpreconditioned resid norm 8.712589842440e+00 true resid norm 8.712589842438e+00 ||r(i)||/||b|| 2.081644002583e-04
686 KSP unpreconditioned resid norm 8.712586622272e+00 true resid norm 8.712586622280e+00 ||r(i)||/||b|| 2.081643233211e-04
687 KSP unpreconditioned resid norm 8.712581730315e+00 true resid norm 8.712581730329e+00 ||r(i)||/||b|| 2.081642064408e-04
688 KSP unpreconditioned resid norm 8.712578181191e+00 true resid norm 8.712578181200e+00 ||r(i)||/||b|| 2.081641216437e-04
689 KSP unpreconditioned resid norm 8.712568644896e+00 true resid norm 8.712568644905e+00 ||r(i)||/||b|| 2.081638937990e-04
690 KSP unpreconditioned resid norm 8.712548921691e+00 true resid norm 8.712548921691e+00 ||r(i)||/||b|| 2.081634225647e-04
691 KSP unpreconditioned resid norm 8.712548855072e+00 true resid norm 8.712548855072e+00 ||r(i)||/||b|| 2.081634209730e-04
692 KSP unpreconditioned resid norm 8.712548556584e+00 true resid norm 8.712548556577e+00 ||r(i)||/||b|| 2.081634138413e-04
693 KSP unpreconditioned resid norm 8.712548298993e+00 true resid norm 8.712548298995e+00 ||r(i)||/||b|| 2.081634076870e-04
694 KSP unpreconditioned resid norm 8.712548255613e+00 true resid norm 8.712548255608e+00 ||r(i)||/||b|| 2.081634066504e-04
695 KSP unpreconditioned resid norm 8.712548255612e+00 true resid norm 8.712548255601e+00 ||r(i)||/||b|| 2.081634066503e-04
696 KSP unpreconditioned resid norm 8.712548233163e+00 true resid norm 8.712548233154e+00 ||r(i)||/||b|| 2.081634061139e-04
697 KSP unpreconditioned resid norm 8.712548206581e+00 true resid norm 8.712548206570e+00 ||r(i)||/||b|| 2.081634054788e-04
698 KSP unpreconditioned resid norm 8.712548195457e+00 true resid norm 8.712548195457e+00 ||r(i)||/||b|| 2.081634052133e-04
699 KSP unpreconditioned resid norm 8.712547507730e+00 true resid norm 8.712547507736e+00 ||r(i)||/||b|| 2.081633887820e-04
700 KSP unpreconditioned resid norm 8.712546690313e+00 true resid norm 8.712546690306e+00 ||r(i)||/||b|| 2.081633692516e-04
701 KSP unpreconditioned resid norm 8.712546587927e+00 true resid norm 8.712546587921e+00 ||r(i)||/||b|| 2.081633668054e-04
702 KSP unpreconditioned resid norm 8.712546325832e+00 true resid norm 8.712546325832e+00 ||r(i)||/||b|| 2.081633605435e-04
703 KSP unpreconditioned resid norm 8.712546168392e+00 true resid norm 8.712546168390e+00 ||r(i)||/||b|| 2.081633567818e-04
704 KSP unpreconditioned resid norm 8.712545473742e+00 true resid norm 8.712545473735e+00 ||r(i)||/||b|| 2.081633401849e-04
705 KSP unpreconditioned resid norm 8.712545388944e+00 true resid norm 8.712545388941e+00 ||r(i)||/||b|| 2.081633381590e-04
706 KSP unpreconditioned resid norm 8.712545236022e+00 true resid norm 8.712545236016e+00 ||r(i)||/||b|| 2.081633345052e-04
707 KSP unpreconditioned resid norm 8.712543578602e+00 true resid norm 8.712543578596e+00 ||r(i)||/||b|| 2.081632949055e-04
708 KSP unpreconditioned resid norm 8.712543555328e+00 true resid norm 8.712543555327e+00 ||r(i)||/||b|| 2.081632943496e-04
709 KSP unpreconditioned resid norm 8.712542192367e+00 true resid norm 8.712542192361e+00 ||r(i)||/||b|| 2.081632617851e-04
710 KSP unpreconditioned resid norm 8.712542188750e+00 true resid norm 8.712542188750e+00 ||r(i)||/||b|| 2.081632616988e-04
711 KSP unpreconditioned resid norm 8.712539094786e+00 true resid norm 8.712539094785e+00 ||r(i)||/||b|| 2.081631877767e-04
712 KSP unpreconditioned resid norm 8.712537689608e+00 true resid norm 8.712537689600e+00 ||r(i)||/||b|| 2.081631542035e-04
713 KSP unpreconditioned resid norm 8.712533191052e+00 true resid norm 8.712533191049e+00 ||r(i)||/||b|| 2.081630467224e-04
714 KSP unpreconditioned resid norm 8.712519693884e+00 true resid norm 8.712519693877e+00 ||r(i)||/||b|| 2.081627242430e-04
715 KSP unpreconditioned resid norm 8.712519057404e+00 true resid norm 8.712519057408e+00 ||r(i)||/||b|| 2.081627090363e-04
716 KSP unpreconditioned resid norm 8.712518959222e+00 true resid norm 8.712518959217e+00 ||r(i)||/||b|| 2.081627066903e-04
717 KSP unpreconditioned resid norm 8.712518884219e+00 true resid norm 8.712518884223e+00 ||r(i)||/||b|| 2.081627048985e-04
718 KSP unpreconditioned resid norm 8.712516786850e+00 true resid norm 8.712516786847e+00 ||r(i)||/||b|| 2.081626547872e-04
719 KSP unpreconditioned resid norm 8.712516685839e+00 true resid norm 8.712516685854e+00 ||r(i)||/||b|| 2.081626523743e-04
720 KSP unpreconditioned resid norm 8.712514084547e+00 true resid norm 8.712514084547e+00 ||r(i)||/||b|| 2.081625902229e-04
721 KSP unpreconditioned resid norm 8.712514077083e+00 true resid norm 8.712514077092e+00 ||r(i)||/||b|| 2.081625900447e-04
722 KSP unpreconditioned resid norm 8.712514056132e+00 true resid norm 8.712514056125e+00 ||r(i)||/||b|| 2.081625895438e-04
723 KSP unpreconditioned resid norm 8.712514055987e+00 true resid norm 8.712514055990e+00 ||r(i)||/||b|| 2.081625895406e-04
724 KSP unpreconditioned resid norm 8.712514027768e+00 true resid norm 8.712514027775e+00 ||r(i)||/||b|| 2.081625888665e-04
725 KSP unpreconditioned resid norm 8.712513997451e+00 true resid norm 8.712513997446e+00 ||r(i)||/||b|| 2.081625881418e-04
726 KSP unpreconditioned resid norm 8.712513974383e+00 true resid norm 8.712513974390e+00 ||r(i)||/||b|| 2.081625875909e-04
727 KSP unpreconditioned resid norm 8.712513712758e+00 true resid norm 8.712513712763e+00 ||r(i)||/||b|| 2.081625813401e-04
728 KSP unpreconditioned resid norm 8.712513534349e+00 true resid norm 8.712513534351e+00 ||r(i)||/||b|| 2.081625770774e-04
729 KSP unpreconditioned resid norm 8.712513515363e+00 true resid norm 8.712513515373e+00 ||r(i)||/||b|| 2.081625766240e-04
730 KSP unpreconditioned resid norm 8.712513392294e+00 true resid norm 8.712513392307e+00 ||r(i)||/||b|| 2.081625736836e-04
731 KSP unpreconditioned resid norm 8.712513353823e+00 true resid norm 8.712513353831e+00 ||r(i)||/||b|| 2.081625727643e-04
732 KSP unpreconditioned resid norm 8.712513308797e+00 true resid norm 8.712513308797e+00 ||r(i)||/||b|| 2.081625716884e-04
733 KSP unpreconditioned resid norm 8.712513270513e+00 true resid norm 8.712513270514e+00 ||r(i)||/||b|| 2.081625707737e-04
734 KSP unpreconditioned resid norm 8.712513131206e+00 true resid norm 8.712513131207e+00 ||r(i)||/||b|| 2.081625674453e-04
735 KSP unpreconditioned resid norm 8.712512953483e+00 true resid norm 8.712512953487e+00 ||r(i)||/||b|| 2.081625631992e-04
736 KSP unpreconditioned resid norm 8.712512877820e+00 true resid norm 8.712512877816e+00 ||r(i)||/||b|| 2.081625613912e-04
737 KSP unpreconditioned resid norm 8.712512877786e+00 true resid norm 8.712512877798e+00 ||r(i)||/||b|| 2.081625613908e-04
738 KSP unpreconditioned resid norm 8.712511745866e+00 true resid norm 8.712511745869e+00 ||r(i)||/||b|| 2.081625343463e-04
739 KSP unpreconditioned resid norm 8.712511648284e+00 true resid norm 8.712511648280e+00 ||r(i)||/||b|| 2.081625320147e-04
740 KSP unpreconditioned resid norm 8.712511467310e+00 true resid norm 8.712511467307e+00 ||r(i)||/||b|| 2.081625276908e-04
741 KSP unpreconditioned resid norm 8.712511466610e+00 true resid norm 8.712511466625e+00 ||r(i)||/||b|| 2.081625276745e-04
742 KSP unpreconditioned resid norm 8.712510803074e+00 true resid norm 8.712510803072e+00 ||r(i)||/||b|| 2.081625118207e-04
743 KSP unpreconditioned resid norm 8.712509576822e+00 true resid norm 8.712509576829e+00 ||r(i)||/||b|| 2.081624825228e-04
744 KSP unpreconditioned resid norm 8.712509188031e+00 true resid norm 8.712509188030e+00 ||r(i)||/||b|| 2.081624732335e-04
745 KSP unpreconditioned resid norm 8.712506436486e+00 true resid norm 8.712506436487e+00 ||r(i)||/||b|| 2.081624074926e-04
746 KSP unpreconditioned resid norm 8.712506346917e+00 true resid norm 8.712506346911e+00 ||r(i)||/||b|| 2.081624053524e-04
747 KSP unpreconditioned resid norm 8.712505531069e+00 true resid norm 8.712505531073e+00 ||r(i)||/||b|| 2.081623858601e-04
748 KSP unpreconditioned resid norm 8.712505156642e+00 true resid norm 8.712505156635e+00 ||r(i)||/||b|| 2.081623769139e-04
749 KSP unpreconditioned resid norm 8.712505120874e+00 true resid norm 8.712505120871e+00 ||r(i)||/||b|| 2.081623760594e-04
750 KSP unpreconditioned resid norm 8.712504873465e+00 true resid norm 8.712504873465e+00 ||r(i)||/||b|| 2.081623701483e-04
751 KSP unpreconditioned resid norm 8.712504872475e+00 true resid norm 8.712504872461e+00 ||r(i)||/||b|| 2.081623701243e-04
752 KSP unpreconditioned resid norm 8.712504869354e+00 true resid norm 8.712504869357e+00 ||r(i)||/||b|| 2.081623700502e-04
753 KSP unpreconditioned resid norm 8.712504865955e+00 true resid norm 8.712504865951e+00 ||r(i)||/||b|| 2.081623699688e-04
754 KSP unpreconditioned resid norm 8.712504865953e+00 true resid norm 8.712504865958e+00 ||r(i)||/||b|| 2.081623699690e-04
755 KSP unpreconditioned resid norm 8.712504863596e+00 true resid norm 8.712504863594e+00 ||r(i)||/||b|| 2.081623699125e-04
756 KSP unpreconditioned resid norm 8.712504850634e+00 true resid norm 8.712504850625e+00 ||r(i)||/||b|| 2.081623696026e-04
757 KSP unpreconditioned resid norm 8.712504804832e+00 true resid norm 8.712504804826e+00 ||r(i)||/||b|| 2.081623685084e-04
758 KSP unpreconditioned resid norm 8.712504743934e+00 true resid norm 8.712504743942e+00 ||r(i)||/||b|| 2.081623670537e-04
759 KSP unpreconditioned resid norm 8.712504738709e+00 true resid norm 8.712504738701e+00 ||r(i)||/||b|| 2.081623669285e-04
760 KSP unpreconditioned resid norm 8.712504738561e+00 true resid norm 8.712504738564e+00 ||r(i)||/||b|| 2.081623669252e-04
761 KSP unpreconditioned resid norm 8.712504738549e+00 true resid norm 8.712504738555e+00 ||r(i)||/||b|| 2.081623669250e-04
762 KSP unpreconditioned resid norm 8.712504719611e+00 true resid norm 8.712504719599e+00 ||r(i)||/||b|| 2.081623664721e-04
763 KSP unpreconditioned resid norm 8.712504717393e+00 true resid norm 8.712504717392e+00 ||r(i)||/||b|| 2.081623664193e-04
764 KSP unpreconditioned resid norm 8.712504667898e+00 true resid norm 8.712504667899e+00 ||r(i)||/||b|| 2.081623652369e-04
765 KSP unpreconditioned resid norm 8.712504622101e+00 true resid norm 8.712504622085e+00 ||r(i)||/||b|| 2.081623641422e-04
766 KSP unpreconditioned resid norm 8.712504614869e+00 true resid norm 8.712504614865e+00 ||r(i)||/||b|| 2.081623639698e-04
767 KSP unpreconditioned resid norm 8.712504485400e+00 true resid norm 8.712504485394e+00 ||r(i)||/||b|| 2.081623608764e-04
768 KSP unpreconditioned resid norm 8.712504472481e+00 true resid norm 8.712504472479e+00 ||r(i)||/||b|| 2.081623605678e-04
769 KSP unpreconditioned resid norm 8.712504426071e+00 true resid norm 8.712504426065e+00 ||r(i)||/||b|| 2.081623594589e-04
770 KSP unpreconditioned resid norm 8.712504403005e+00 true resid norm 8.712504403001e+00 ||r(i)||/||b|| 2.081623589078e-04
771 KSP unpreconditioned resid norm 8.712504162953e+00 true resid norm 8.712504162947e+00 ||r(i)||/||b|| 2.081623531724e-04
772 KSP unpreconditioned resid norm 8.712504145417e+00 true resid norm 8.712504145418e+00 ||r(i)||/||b|| 2.081623527535e-04
773 KSP unpreconditioned resid norm 8.712504075441e+00 true resid norm 8.712504075438e+00 ||r(i)||/||b|| 2.081623510816e-04
774 KSP unpreconditioned resid norm 8.712502686363e+00 true resid norm 8.712502686358e+00 ||r(i)||/||b|| 2.081623178932e-04
775 KSP unpreconditioned resid norm 8.712502682763e+00 true resid norm 8.712502682758e+00 ||r(i)||/||b|| 2.081623178071e-04
776 KSP unpreconditioned resid norm 8.712502640506e+00 true resid norm 8.712502640505e+00 ||r(i)||/||b|| 2.081623167976e-04
777 KSP unpreconditioned resid norm 8.712502233697e+00 true resid norm 8.712502233693e+00 ||r(i)||/||b|| 2.081623070779e-04
778 KSP unpreconditioned resid norm 8.712502233444e+00 true resid norm 8.712502233446e+00 ||r(i)||/||b|| 2.081623070720e-04
779 KSP unpreconditioned resid norm 8.712501744985e+00 true resid norm 8.712501744980e+00 ||r(i)||/||b|| 2.081622954014e-04
780 KSP unpreconditioned resid norm 8.712500817476e+00 true resid norm 8.712500817476e+00 ||r(i)||/||b|| 2.081622732411e-04
781 KSP unpreconditioned resid norm 8.712500813892e+00 true resid norm 8.712500813892e+00 ||r(i)||/||b|| 2.081622731555e-04
782 KSP unpreconditioned resid norm 8.712500799725e+00 true resid norm 8.712500799722e+00 ||r(i)||/||b|| 2.081622728169e-04
783 KSP unpreconditioned resid norm 8.712500792416e+00 true resid norm 8.712500792421e+00 ||r(i)||/||b|| 2.081622726425e-04
784 KSP unpreconditioned resid norm 8.712500792067e+00 true resid norm 8.712500792065e+00 ||r(i)||/||b|| 2.081622726340e-04
785 KSP unpreconditioned resid norm 8.712500791819e+00 true resid norm 8.712500791821e+00 ||r(i)||/||b|| 2.081622726282e-04
786 KSP unpreconditioned resid norm 8.712500779525e+00 true resid norm 8.712500779527e+00 ||r(i)||/||b|| 2.081622723344e-04
787 KSP unpreconditioned resid norm 8.712500713738e+00 true resid norm 8.712500713729e+00 ||r(i)||/||b|| 2.081622707624e-04
788 KSP unpreconditioned resid norm 8.712500656579e+00 true resid norm 8.712500656579e+00 ||r(i)||/||b|| 2.081622693969e-04
789 KSP unpreconditioned resid norm 8.712500656575e+00 true resid norm 8.712500656570e+00 ||r(i)||/||b|| 2.081622693967e-04
790 KSP unpreconditioned resid norm 8.712500650534e+00 true resid norm 8.712500650541e+00 ||r(i)||/||b|| 2.081622692526e-04
791 KSP unpreconditioned resid norm 8.712500635692e+00 true resid norm 8.712500635680e+00 ||r(i)||/||b|| 2.081622688976e-04
792 KSP unpreconditioned resid norm 8.712500635329e+00 true resid norm 8.712500635333e+00 ||r(i)||/||b|| 2.081622688893e-04
793 KSP unpreconditioned resid norm 8.712500623226e+00 true resid norm 8.712500623235e+00 ||r(i)||/||b|| 2.081622686002e-04
794 KSP unpreconditioned resid norm 8.712500623045e+00 true resid norm 8.712500623047e+00 ||r(i)||/||b|| 2.081622685958e-04
795 KSP unpreconditioned resid norm 8.712500519553e+00 true resid norm 8.712500519551e+00 ||r(i)||/||b|| 2.081622661230e-04
796 KSP unpreconditioned resid norm 8.712500482677e+00 true resid norm 8.712500482677e+00 ||r(i)||/||b|| 2.081622652420e-04
797 KSP unpreconditioned resid norm 8.712500482217e+00 true resid norm 8.712500482209e+00 ||r(i)||/||b|| 2.081622652308e-04
798 KSP unpreconditioned resid norm 8.712500281497e+00 true resid norm 8.712500281503e+00 ||r(i)||/||b|| 2.081622604355e-04
799 KSP unpreconditioned resid norm 8.712500277569e+00 true resid norm 8.712500277566e+00 ||r(i)||/||b|| 2.081622603414e-04
800 KSP unpreconditioned resid norm 8.712500260637e+00 true resid norm 8.712500260638e+00 ||r(i)||/||b|| 2.081622599369e-04
801 KSP unpreconditioned resid norm 8.712500245240e+00 true resid norm 8.712500245244e+00 ||r(i)||/||b|| 2.081622595692e-04
802 KSP unpreconditioned resid norm 8.712500143816e+00 true resid norm 8.712500143808e+00 ||r(i)||/||b|| 2.081622571456e-04
803 KSP unpreconditioned resid norm 8.712499926226e+00 true resid norm 8.712499926234e+00 ||r(i)||/||b|| 2.081622519472e-04
804 KSP unpreconditioned resid norm 8.712499888931e+00 true resid norm 8.712499888930e+00 ||r(i)||/||b|| 2.081622510560e-04
805 KSP unpreconditioned resid norm 8.712499222503e+00 true resid norm 8.712499222503e+00 ||r(i)||/||b|| 2.081622351334e-04
806 KSP unpreconditioned resid norm 8.712499117868e+00 true resid norm 8.712499117866e+00 ||r(i)||/||b|| 2.081622326334e-04
807 KSP unpreconditioned resid norm 8.712499117853e+00 true resid norm 8.712499117852e+00 ||r(i)||/||b|| 2.081622326331e-04
808 KSP unpreconditioned resid norm 8.712498556445e+00 true resid norm 8.712498556453e+00 ||r(i)||/||b|| 2.081622192199e-04
809 KSP unpreconditioned resid norm 8.712498437690e+00 true resid norm 8.712498437690e+00 ||r(i)||/||b|| 2.081622163824e-04
810 KSP unpreconditioned resid norm 8.712498324520e+00 true resid norm 8.712498324520e+00 ||r(i)||/||b|| 2.081622136785e-04
811 KSP unpreconditioned resid norm 8.712498324058e+00 true resid norm 8.712498324059e+00 ||r(i)||/||b|| 2.081622136675e-04
812 KSP unpreconditioned resid norm 8.712498321955e+00 true resid norm 8.712498321941e+00 ||r(i)||/||b|| 2.081622136169e-04
813 KSP unpreconditioned resid norm 8.712498317103e+00 true resid norm 8.712498317103e+00 ||r(i)||/||b|| 2.081622135013e-04
814 KSP unpreconditioned resid norm 8.712498311860e+00 true resid norm 8.712498311850e+00 ||r(i)||/||b|| 2.081622133758e-04
815 KSP unpreconditioned resid norm 8.712498308082e+00 true resid norm 8.712498308095e+00 ||r(i)||/||b|| 2.081622132861e-04
816 KSP unpreconditioned resid norm 8.712498299868e+00 true resid norm 8.712498299859e+00 ||r(i)||/||b|| 2.081622130893e-04
817 KSP unpreconditioned resid norm 8.712498289324e+00 true resid norm 8.712498289320e+00 ||r(i)||/||b|| 2.081622128375e-04
818 KSP unpreconditioned resid norm 8.712498274201e+00 true resid norm 8.712498274199e+00 ||r(i)||/||b|| 2.081622124762e-04
819 KSP unpreconditioned resid norm 8.712498269161e+00 true resid norm 8.712498269165e+00 ||r(i)||/||b|| 2.081622123559e-04
820 KSP unpreconditioned resid norm 8.712498265438e+00 true resid norm 8.712498265441e+00 ||r(i)||/||b|| 2.081622122670e-04
821 KSP unpreconditioned resid norm 8.712498264148e+00 true resid norm 8.712498264135e+00 ||r(i)||/||b|| 2.081622122358e-04
822 KSP unpreconditioned resid norm 8.712498262965e+00 true resid norm 8.712498262954e+00 ||r(i)||/||b|| 2.081622122076e-04
823 KSP unpreconditioned resid norm 8.712498259970e+00 true resid norm 8.712498259959e+00 ||r(i)||/||b|| 2.081622121360e-04
824 KSP unpreconditioned resid norm 8.712498229869e+00 true resid norm 8.712498229869e+00 ||r(i)||/||b|| 2.081622114171e-04
825 KSP unpreconditioned resid norm 8.712498197465e+00 true resid norm 8.712498197462e+00 ||r(i)||/||b|| 2.081622106428e-04
826 KSP unpreconditioned resid norm 8.712498189106e+00 true resid norm 8.712498189105e+00 ||r(i)||/||b|| 2.081622104431e-04
827 KSP unpreconditioned resid norm 8.712498149578e+00 true resid norm 8.712498149581e+00 ||r(i)||/||b|| 2.081622094988e-04
828 KSP unpreconditioned resid norm 8.712498142287e+00 true resid norm 8.712498142285e+00 ||r(i)||/||b|| 2.081622093245e-04
829 KSP unpreconditioned resid norm 8.712498129588e+00 true resid norm 8.712498129584e+00 ||r(i)||/||b|| 2.081622090210e-04
830 KSP unpreconditioned resid norm 8.712498111323e+00 true resid norm 8.712498111315e+00 ||r(i)||/||b|| 2.081622085845e-04
831 KSP unpreconditioned resid norm 8.712498074947e+00 true resid norm 8.712498074942e+00 ||r(i)||/||b|| 2.081622077155e-04
832 KSP unpreconditioned resid norm 8.712498065589e+00 true resid norm 8.712498065582e+00 ||r(i)||/||b|| 2.081622074919e-04
833 KSP unpreconditioned resid norm 8.712498027887e+00 true resid norm 8.712498027882e+00 ||r(i)||/||b|| 2.081622065911e-04
834 KSP unpreconditioned resid norm 8.712497635699e+00 true resid norm 8.712497635699e+00 ||r(i)||/||b|| 2.081621972209e-04
835 KSP unpreconditioned resid norm 8.712497624101e+00 true resid norm 8.712497624098e+00 ||r(i)||/||b|| 2.081621969438e-04
836 KSP unpreconditioned resid norm 8.712497537136e+00 true resid norm 8.712497537128e+00 ||r(i)||/||b|| 2.081621948658e-04
837 KSP unpreconditioned resid norm 8.712497226627e+00 true resid norm 8.712497226621e+00 ||r(i)||/||b|| 2.081621874471e-04
838 KSP unpreconditioned resid norm 8.712497114443e+00 true resid norm 8.712497114437e+00 ||r(i)||/||b|| 2.081621847668e-04
839 KSP unpreconditioned resid norm 8.712496800150e+00 true resid norm 8.712496800146e+00 ||r(i)||/||b|| 2.081621772576e-04
840 KSP unpreconditioned resid norm 8.712496570930e+00 true resid norm 8.712496570930e+00 ||r(i)||/||b|| 2.081621717811e-04
841 KSP unpreconditioned resid norm 8.712496569990e+00 true resid norm 8.712496569987e+00 ||r(i)||/||b|| 2.081621717585e-04
842 KSP unpreconditioned resid norm 8.712496565308e+00 true resid norm 8.712496565303e+00 ||r(i)||/||b|| 2.081621716466e-04
843 KSP unpreconditioned resid norm 8.712496560011e+00 true resid norm 8.712496560008e+00 ||r(i)||/||b|| 2.081621715201e-04
844 KSP unpreconditioned resid norm 8.712496555855e+00 true resid norm 8.712496555866e+00 ||r(i)||/||b|| 2.081621714212e-04
845 KSP unpreconditioned resid norm 8.712496550699e+00 true resid norm 8.712496550687e+00 ||r(i)||/||b|| 2.081621712974e-04
846 KSP unpreconditioned resid norm 8.712496544463e+00 true resid norm 8.712496544459e+00 ||r(i)||/||b|| 2.081621711486e-04
847 KSP unpreconditioned resid norm 8.712496527899e+00 true resid norm 8.712496527906e+00 ||r(i)||/||b|| 2.081621707531e-04
848 KSP unpreconditioned resid norm 8.712496510377e+00 true resid norm 8.712496510380e+00 ||r(i)||/||b|| 2.081621703344e-04
849 KSP unpreconditioned resid norm 8.712496507975e+00 true resid norm 8.712496507973e+00 ||r(i)||/||b|| 2.081621702769e-04
850 KSP unpreconditioned resid norm 8.712496507548e+00 true resid norm 8.712496507545e+00 ||r(i)||/||b|| 2.081621702667e-04
851 KSP unpreconditioned resid norm 8.712496500713e+00 true resid norm 8.712496500707e+00 ||r(i)||/||b|| 2.081621701033e-04
852 KSP unpreconditioned resid norm 8.712496500621e+00 true resid norm 8.712496500626e+00 ||r(i)||/||b|| 2.081621701014e-04
853 KSP unpreconditioned resid norm 8.712496487559e+00 true resid norm 8.712496487568e+00 ||r(i)||/||b|| 2.081621697894e-04
854 KSP unpreconditioned resid norm 8.712496483842e+00 true resid norm 8.712496483846e+00 ||r(i)||/||b|| 2.081621697004e-04
855 KSP unpreconditioned resid norm 8.712496436665e+00 true resid norm 8.712496436666e+00 ||r(i)||/||b|| 2.081621685732e-04
856 KSP unpreconditioned resid norm 8.712496414602e+00 true resid norm 8.712496414600e+00 ||r(i)||/||b|| 2.081621680460e-04
857 KSP unpreconditioned resid norm 8.712496412804e+00 true resid norm 8.712496412803e+00 ||r(i)||/||b|| 2.081621680031e-04
858 KSP unpreconditioned resid norm 8.712496350507e+00 true resid norm 8.712496350512e+00 ||r(i)||/||b|| 2.081621665148e-04
859 KSP unpreconditioned resid norm 8.712496346853e+00 true resid norm 8.712496346840e+00 ||r(i)||/||b|| 2.081621664271e-04
860 KSP unpreconditioned resid norm 8.712496345529e+00 true resid norm 8.712496345527e+00 ||r(i)||/||b|| 2.081621663957e-04
861 KSP unpreconditioned resid norm 8.712496340990e+00 true resid norm 8.712496340989e+00 ||r(i)||/||b|| 2.081621662873e-04
862 KSP unpreconditioned resid norm 8.712496300285e+00 true resid norm 8.712496300283e+00 ||r(i)||/||b|| 2.081621653147e-04
863 KSP unpreconditioned resid norm 8.712496181849e+00 true resid norm 8.712496181850e+00 ||r(i)||/||b|| 2.081621624850e-04
864 KSP unpreconditioned resid norm 8.712496139558e+00 true resid norm 8.712496139553e+00 ||r(i)||/||b|| 2.081621614745e-04
865 KSP unpreconditioned resid norm 8.712495885375e+00 true resid norm 8.712495885378e+00 ||r(i)||/||b|| 2.081621554016e-04
866 KSP unpreconditioned resid norm 8.712495790657e+00 true resid norm 8.712495790656e+00 ||r(i)||/||b|| 2.081621531385e-04
867 KSP unpreconditioned resid norm 8.712495745372e+00 true resid norm 8.712495745371e+00 ||r(i)||/||b|| 2.081621520565e-04
868 KSP unpreconditioned resid norm 8.712495334054e+00 true resid norm 8.712495334052e+00 ||r(i)||/||b|| 2.081621422291e-04
869 KSP unpreconditioned resid norm 8.712495220355e+00 true resid norm 8.712495220360e+00 ||r(i)||/||b|| 2.081621395128e-04
870 KSP unpreconditioned resid norm 8.712495183884e+00 true resid norm 8.712495183884e+00 ||r(i)||/||b|| 2.081621386413e-04
871 KSP unpreconditioned resid norm 8.712495183732e+00 true resid norm 8.712495183724e+00 ||r(i)||/||b|| 2.081621386375e-04
872 KSP unpreconditioned resid norm 8.712495182737e+00 true resid norm 8.712495182733e+00 ||r(i)||/||b|| 2.081621386138e-04
873 KSP unpreconditioned resid norm 8.712495179188e+00 true resid norm 8.712495179186e+00 ||r(i)||/||b|| 2.081621385290e-04
874 KSP unpreconditioned resid norm 8.712495172789e+00 true resid norm 8.712495172792e+00 ||r(i)||/||b|| 2.081621383763e-04
875 KSP unpreconditioned resid norm 8.712495166116e+00 true resid norm 8.712495166105e+00 ||r(i)||/||b|| 2.081621382165e-04
876 KSP unpreconditioned resid norm 8.712495161476e+00 true resid norm 8.712495161476e+00 ||r(i)||/||b|| 2.081621381059e-04
877 KSP unpreconditioned resid norm 8.712495157960e+00 true resid norm 8.712495157950e+00 ||r(i)||/||b|| 2.081621380216e-04
878 KSP unpreconditioned resid norm 8.712495151185e+00 true resid norm 8.712495151182e+00 ||r(i)||/||b|| 2.081621378599e-04
879 KSP unpreconditioned resid norm 8.712495144761e+00 true resid norm 8.712495144754e+00 ||r(i)||/||b|| 2.081621377064e-04
880 KSP unpreconditioned resid norm 8.712495138630e+00 true resid norm 8.712495138628e+00 ||r(i)||/||b|| 2.081621375600e-04
881 KSP unpreconditioned resid norm 8.712495137036e+00 true resid norm 8.712495137033e+00 ||r(i)||/||b|| 2.081621375219e-04
882 KSP unpreconditioned resid norm 8.712495137025e+00 true resid norm 8.712495137016e+00 ||r(i)||/||b|| 2.081621375215e-04
883 KSP unpreconditioned resid norm 8.712495131512e+00 true resid norm 8.712495131505e+00 ||r(i)||/||b|| 2.081621373898e-04
884 KSP unpreconditioned resid norm 8.712495112182e+00 true resid norm 8.712495112173e+00 ||r(i)||/||b|| 2.081621369279e-04
885 KSP unpreconditioned resid norm 8.712495090221e+00 true resid norm 8.712495090211e+00 ||r(i)||/||b|| 2.081621364032e-04
886 KSP unpreconditioned resid norm 8.712495081252e+00 true resid norm 8.712495081247e+00 ||r(i)||/||b|| 2.081621361890e-04
887 KSP unpreconditioned resid norm 8.712495060402e+00 true resid norm 8.712495060396e+00 ||r(i)||/||b|| 2.081621356909e-04
888 KSP unpreconditioned resid norm 8.712495053558e+00 true resid norm 8.712495053558e+00 ||r(i)||/||b|| 2.081621355275e-04
889 KSP unpreconditioned resid norm 8.712495044833e+00 true resid norm 8.712495044826e+00 ||r(i)||/||b|| 2.081621353189e-04
890 KSP unpreconditioned resid norm 8.712495037341e+00 true resid norm 8.712495037340e+00 ||r(i)||/||b|| 2.081621351400e-04
891 KSP unpreconditioned resid norm 8.712495027694e+00 true resid norm 8.712495027685e+00 ||r(i)||/||b|| 2.081621349093e-04
892 KSP unpreconditioned resid norm 8.712495018081e+00 true resid norm 8.712495018079e+00 ||r(i)||/||b|| 2.081621346798e-04
893 KSP unpreconditioned resid norm 8.712494974811e+00 true resid norm 8.712494974807e+00 ||r(i)||/||b|| 2.081621336459e-04
894 KSP unpreconditioned resid norm 8.712494800300e+00 true resid norm 8.712494800296e+00 ||r(i)||/||b|| 2.081621294765e-04
895 KSP unpreconditioned resid norm 8.712494777028e+00 true resid norm 8.712494777011e+00 ||r(i)||/||b|| 2.081621289201e-04
896 KSP unpreconditioned resid norm 8.712494698117e+00 true resid norm 8.712494698109e+00 ||r(i)||/||b|| 2.081621270350e-04
897 KSP unpreconditioned resid norm 8.712494500911e+00 true resid norm 8.712494500906e+00 ||r(i)||/||b|| 2.081621223233e-04
898 KSP unpreconditioned resid norm 8.712494325439e+00 true resid norm 8.712494325423e+00 ||r(i)||/||b|| 2.081621181306e-04
899 KSP unpreconditioned resid norm 8.712494118510e+00 true resid norm 8.712494118513e+00 ||r(i)||/||b|| 2.081621131870e-04
900 KSP unpreconditioned resid norm 8.712494046966e+00 true resid norm 8.712494046966e+00 ||r(i)||/||b|| 2.081621114776e-04
901 KSP unpreconditioned resid norm 8.712494046666e+00 true resid norm 8.712494046664e+00 ||r(i)||/||b|| 2.081621114704e-04
902 KSP unpreconditioned resid norm 8.712494044741e+00 true resid norm 8.712494044742e+00 ||r(i)||/||b|| 2.081621114245e-04
903 KSP unpreconditioned resid norm 8.712494040963e+00 true resid norm 8.712494040963e+00 ||r(i)||/||b|| 2.081621113342e-04
904 KSP unpreconditioned resid norm 8.712494035678e+00 true resid norm 8.712494035675e+00 ||r(i)||/||b|| 2.081621112078e-04
905 KSP unpreconditioned resid norm 8.712494029109e+00 true resid norm 8.712494029118e+00 ||r(i)||/||b|| 2.081621110512e-04
906 KSP unpreconditioned resid norm 8.712494025419e+00 true resid norm 8.712494025422e+00 ||r(i)||/||b|| 2.081621109629e-04
907 KSP unpreconditioned resid norm 8.712494019812e+00 true resid norm 8.712494019815e+00 ||r(i)||/||b|| 2.081621108289e-04
908 KSP unpreconditioned resid norm 8.712494011772e+00 true resid norm 8.712494011770e+00 ||r(i)||/||b|| 2.081621106367e-04
909 KSP unpreconditioned resid norm 8.712494007363e+00 true resid norm 8.712494007354e+00 ||r(i)||/||b|| 2.081621105312e-04
910 KSP unpreconditioned resid norm 8.712494004621e+00 true resid norm 8.712494004624e+00 ||r(i)||/||b|| 2.081621104660e-04
911 KSP unpreconditioned resid norm 8.712494001142e+00 true resid norm 8.712494001132e+00 ||r(i)||/||b|| 2.081621103825e-04
912 KSP unpreconditioned resid norm 8.712494000947e+00 true resid norm 8.712494000953e+00 ||r(i)||/||b|| 2.081621103782e-04
913 KSP unpreconditioned resid norm 8.712493991173e+00 true resid norm 8.712493991180e+00 ||r(i)||/||b|| 2.081621101448e-04
914 KSP unpreconditioned resid norm 8.712493984347e+00 true resid norm 8.712493984343e+00 ||r(i)||/||b|| 2.081621099814e-04
915 KSP unpreconditioned resid norm 8.712493957381e+00 true resid norm 8.712493957383e+00 ||r(i)||/||b|| 2.081621093373e-04
916 KSP unpreconditioned resid norm 8.712493942750e+00 true resid norm 8.712493942745e+00 ||r(i)||/||b|| 2.081621089875e-04
917 KSP unpreconditioned resid norm 8.712493938265e+00 true resid norm 8.712493938273e+00 ||r(i)||/||b|| 2.081621088807e-04
918 KSP unpreconditioned resid norm 8.712493912052e+00 true resid norm 8.712493912048e+00 ||r(i)||/||b|| 2.081621082541e-04
919 KSP unpreconditioned resid norm 8.712493907379e+00 true resid norm 8.712493907379e+00 ||r(i)||/||b|| 2.081621081426e-04
920 KSP unpreconditioned resid norm 8.712493907348e+00 true resid norm 8.712493907349e+00 ||r(i)||/||b|| 2.081621081418e-04
921 KSP unpreconditioned resid norm 8.712493906905e+00 true resid norm 8.712493906900e+00 ||r(i)||/||b|| 2.081621081311e-04
922 KSP unpreconditioned resid norm 8.712493885542e+00 true resid norm 8.712493885531e+00 ||r(i)||/||b|| 2.081621076206e-04
923 KSP unpreconditioned resid norm 8.712493807049e+00 true resid norm 8.712493807043e+00 ||r(i)||/||b|| 2.081621057453e-04
924 KSP unpreconditioned resid norm 8.712493758120e+00 true resid norm 8.712493758111e+00 ||r(i)||/||b|| 2.081621045762e-04
925 KSP unpreconditioned resid norm 8.712493633750e+00 true resid norm 8.712493633752e+00 ||r(i)||/||b|| 2.081621016050e-04
926 KSP unpreconditioned resid norm 8.712493557071e+00 true resid norm 8.712493557074e+00 ||r(i)||/||b|| 2.081620997729e-04
927 KSP unpreconditioned resid norm 8.712493487076e+00 true resid norm 8.712493487078e+00 ||r(i)||/||b|| 2.081620981006e-04
928 KSP unpreconditioned resid norm 8.712493187387e+00 true resid norm 8.712493187382e+00 ||r(i)||/||b|| 2.081620909401e-04
929 KSP unpreconditioned resid norm 8.712493082077e+00 true resid norm 8.712493082073e+00 ||r(i)||/||b|| 2.081620884240e-04
930 KSP unpreconditioned resid norm 8.712493066853e+00 true resid norm 8.712493066853e+00 ||r(i)||/||b|| 2.081620880604e-04
931 KSP unpreconditioned resid norm 8.712493066790e+00 true resid norm 8.712493066790e+00 ||r(i)||/||b|| 2.081620880589e-04
932 KSP unpreconditioned resid norm 8.712493066188e+00 true resid norm 8.712493066192e+00 ||r(i)||/||b|| 2.081620880446e-04
933 KSP unpreconditioned resid norm 8.712493063462e+00 true resid norm 8.712493063465e+00 ||r(i)||/||b|| 2.081620879795e-04
934 KSP unpreconditioned resid norm 8.712493057659e+00 true resid norm 8.712493057656e+00 ||r(i)||/||b|| 2.081620878407e-04
935 KSP unpreconditioned resid norm 8.712493050995e+00 true resid norm 8.712493050999e+00 ||r(i)||/||b|| 2.081620876816e-04
936 KSP unpreconditioned resid norm 8.712493048050e+00 true resid norm 8.712493048053e+00 ||r(i)||/||b|| 2.081620876112e-04
937 KSP unpreconditioned resid norm 8.712493046356e+00 true resid norm 8.712493046353e+00 ||r(i)||/||b|| 2.081620875706e-04
938 KSP unpreconditioned resid norm 8.712493042193e+00 true resid norm 8.712493042188e+00 ||r(i)||/||b|| 2.081620874711e-04
939 KSP unpreconditioned resid norm 8.712493035967e+00 true resid norm 8.712493035967e+00 ||r(i)||/||b|| 2.081620873225e-04
940 KSP unpreconditioned resid norm 8.712493030021e+00 true resid norm 8.712493030010e+00 ||r(i)||/||b|| 2.081620871801e-04
941 KSP unpreconditioned resid norm 8.712493028629e+00 true resid norm 8.712493028641e+00 ||r(i)||/||b|| 2.081620871474e-04
942 KSP unpreconditioned resid norm 8.712493028595e+00 true resid norm 8.712493028591e+00 ||r(i)||/||b|| 2.081620871462e-04
943 KSP unpreconditioned resid norm 8.712493023018e+00 true resid norm 8.712493023017e+00 ||r(i)||/||b|| 2.081620870130e-04
944 KSP unpreconditioned resid norm 8.712493009535e+00 true resid norm 8.712493009524e+00 ||r(i)||/||b|| 2.081620866907e-04
945 KSP unpreconditioned resid norm 8.712492993401e+00 true resid norm 8.712492993399e+00 ||r(i)||/||b|| 2.081620863054e-04
946 KSP unpreconditioned resid norm 8.712492985174e+00 true resid norm 8.712492985177e+00 ||r(i)||/||b|| 2.081620861090e-04
947 KSP unpreconditioned resid norm 8.712492972383e+00 true resid norm 8.712492972392e+00 ||r(i)||/||b|| 2.081620858035e-04
948 KSP unpreconditioned resid norm 8.712492966024e+00 true resid norm 8.712492966026e+00 ||r(i)||/||b|| 2.081620856514e-04
949 KSP unpreconditioned resid norm 8.712492958740e+00 true resid norm 8.712492958740e+00 ||r(i)||/||b|| 2.081620854773e-04
950 KSP unpreconditioned resid norm 8.712492955875e+00 true resid norm 8.712492955882e+00 ||r(i)||/||b|| 2.081620854090e-04
951 KSP unpreconditioned resid norm 8.712492952191e+00 true resid norm 8.712492952197e+00 ||r(i)||/||b|| 2.081620853210e-04
952 KSP unpreconditioned resid norm 8.712492943910e+00 true resid norm 8.712492943906e+00 ||r(i)||/||b|| 2.081620851229e-04
953 KSP unpreconditioned resid norm 8.712492903124e+00 true resid norm 8.712492903117e+00 ||r(i)||/||b|| 2.081620841483e-04
954 KSP unpreconditioned resid norm 8.712492804292e+00 true resid norm 8.712492804298e+00 ||r(i)||/||b|| 2.081620817873e-04
955 KSP unpreconditioned resid norm 8.712492775404e+00 true resid norm 8.712492775401e+00 ||r(i)||/||b|| 2.081620810969e-04
956 KSP unpreconditioned resid norm 8.712492712509e+00 true resid norm 8.712492712510e+00 ||r(i)||/||b|| 2.081620795943e-04
957 KSP unpreconditioned resid norm 8.712492581750e+00 true resid norm 8.712492581748e+00 ||r(i)||/||b|| 2.081620764701e-04
958 KSP unpreconditioned resid norm 8.712492399849e+00 true resid norm 8.712492399848e+00 ||r(i)||/||b|| 2.081620721241e-04
959 KSP unpreconditioned resid norm 8.712492251929e+00 true resid norm 8.712492251931e+00 ||r(i)||/||b|| 2.081620685900e-04
960 KSP unpreconditioned resid norm 8.712492222509e+00 true resid norm 8.712492222509e+00 ||r(i)||/||b|| 2.081620678870e-04
961 KSP unpreconditioned resid norm 8.712492222385e+00 true resid norm 8.712492222389e+00 ||r(i)||/||b|| 2.081620678842e-04
962 KSP unpreconditioned resid norm 8.712492221376e+00 true resid norm 8.712492221382e+00 ||r(i)||/||b|| 2.081620678601e-04
963 KSP unpreconditioned resid norm 8.712492218534e+00 true resid norm 8.712492218546e+00 ||r(i)||/||b|| 2.081620677923e-04
964 KSP unpreconditioned resid norm 8.712492213547e+00 true resid norm 8.712492213549e+00 ||r(i)||/||b|| 2.081620676729e-04
965 KSP unpreconditioned resid norm 8.712492207459e+00 true resid norm 8.712492207467e+00 ||r(i)||/||b|| 2.081620675276e-04
966 KSP unpreconditioned resid norm 8.712492204976e+00 true resid norm 8.712492204979e+00 ||r(i)||/||b|| 2.081620674682e-04
967 KSP unpreconditioned resid norm 8.712492202466e+00 true resid norm 8.712492202464e+00 ||r(i)||/||b|| 2.081620674081e-04
968 KSP unpreconditioned resid norm 8.712492197728e+00 true resid norm 8.712492197732e+00 ||r(i)||/||b|| 2.081620672950e-04
969 KSP unpreconditioned resid norm 8.712492193016e+00 true resid norm 8.712492193021e+00 ||r(i)||/||b|| 2.081620671825e-04
970 KSP unpreconditioned resid norm 8.712492189440e+00 true resid norm 8.712492189437e+00 ||r(i)||/||b|| 2.081620670969e-04
971 KSP unpreconditioned resid norm 8.712492187398e+00 true resid norm 8.712492187401e+00 ||r(i)||/||b|| 2.081620670482e-04
972 KSP unpreconditioned resid norm 8.712492187226e+00 true resid norm 8.712492187224e+00 ||r(i)||/||b|| 2.081620670440e-04
973 KSP unpreconditioned resid norm 8.712492180084e+00 true resid norm 8.712492180088e+00 ||r(i)||/||b|| 2.081620668735e-04
974 KSP unpreconditioned resid norm 8.712492172678e+00 true resid norm 8.712492172677e+00 ||r(i)||/||b|| 2.081620666964e-04
975 KSP unpreconditioned resid norm 8.712492154686e+00 true resid norm 8.712492154695e+00 ||r(i)||/||b|| 2.081620662668e-04
976 KSP unpreconditioned resid norm 8.712492144360e+00 true resid norm 8.712492144362e+00 ||r(i)||/||b|| 2.081620660199e-04
977 KSP unpreconditioned resid norm 8.712492139182e+00 true resid norm 8.712492139184e+00 ||r(i)||/||b|| 2.081620658962e-04
978 KSP unpreconditioned resid norm 8.712492125353e+00 true resid norm 8.712492125356e+00 ||r(i)||/||b|| 2.081620655658e-04
979 KSP unpreconditioned resid norm 8.712492120471e+00 true resid norm 8.712492120470e+00 ||r(i)||/||b|| 2.081620654491e-04
980 KSP unpreconditioned resid norm 8.712492120441e+00 true resid norm 8.712492120439e+00 ||r(i)||/||b|| 2.081620654483e-04
981 KSP unpreconditioned resid norm 8.712492120429e+00 true resid norm 8.712492120441e+00 ||r(i)||/||b|| 2.081620654484e-04
982 KSP unpreconditioned resid norm 8.712492107534e+00 true resid norm 8.712492107546e+00 ||r(i)||/||b|| 2.081620651403e-04
983 KSP unpreconditioned resid norm 8.712492052538e+00 true resid norm 8.712492052540e+00 ||r(i)||/||b|| 2.081620638261e-04
984 KSP unpreconditioned resid norm 8.712492004683e+00 true resid norm 8.712492004691e+00 ||r(i)||/||b|| 2.081620626828e-04
985 KSP unpreconditioned resid norm 8.712491931805e+00 true resid norm 8.712491931810e+00 ||r(i)||/||b|| 2.081620609415e-04
986 KSP unpreconditioned resid norm 8.712491871575e+00 true resid norm 8.712491871568e+00 ||r(i)||/||b|| 2.081620595022e-04
987 KSP unpreconditioned resid norm 8.712491801186e+00 true resid norm 8.712491801195e+00 ||r(i)||/||b|| 2.081620578208e-04
988 KSP unpreconditioned resid norm 8.712491577043e+00 true resid norm 8.712491577039e+00 ||r(i)||/||b|| 2.081620524652e-04
989 KSP unpreconditioned resid norm 8.712491484590e+00 true resid norm 8.712491484586e+00 ||r(i)||/||b|| 2.081620502563e-04
990 KSP unpreconditioned resid norm 8.712491476263e+00 true resid norm 8.712491476263e+00 ||r(i)||/||b|| 2.081620500574e-04
991 KSP unpreconditioned resid norm 8.712491476229e+00 true resid norm 8.712491476236e+00 ||r(i)||/||b|| 2.081620500568e-04
992 KSP unpreconditioned resid norm 8.712491475804e+00 true resid norm 8.712491475807e+00 ||r(i)||/||b|| 2.081620500465e-04
993 KSP unpreconditioned resid norm 8.712491473658e+00 true resid norm 8.712491473657e+00 ||r(i)||/||b|| 2.081620499952e-04
994 KSP unpreconditioned resid norm 8.712491468823e+00 true resid norm 8.712491468825e+00 ||r(i)||/||b|| 2.081620498797e-04
995 KSP unpreconditioned resid norm 8.712491463076e+00 true resid norm 8.712491463070e+00 ||r(i)||/||b|| 2.081620497422e-04
996 KSP unpreconditioned resid norm 8.712491461028e+00 true resid norm 8.712491461035e+00 ||r(i)||/||b|| 2.081620496936e-04
997 KSP unpreconditioned resid norm 8.712491459987e+00 true resid norm 8.712491459991e+00 ||r(i)||/||b|| 2.081620496687e-04
998 KSP unpreconditioned resid norm 8.712491457038e+00 true resid norm 8.712491457042e+00 ||r(i)||/||b|| 2.081620495982e-04
999 KSP unpreconditioned resid norm 8.712491451696e+00 true resid norm 8.712491451692e+00 ||r(i)||/||b|| 2.081620494704e-04
1000 KSP unpreconditioned resid norm 8.712491446715e+00 true resid norm 8.712491446706e+00 ||r(i)||/||b|| 2.081620493513e-04
1001 KSP unpreconditioned resid norm 8.712491445574e+00 true resid norm 8.712491445568e+00 ||r(i)||/||b|| 2.081620493241e-04
1002 KSP unpreconditioned resid norm 8.712491445507e+00 true resid norm 8.712491445511e+00 ||r(i)||/||b|| 2.081620493227e-04
1003 KSP unpreconditioned resid norm 8.712491440655e+00 true resid norm 8.712491440656e+00 ||r(i)||/||b|| 2.081620492067e-04
1004 KSP unpreconditioned resid norm 8.712491430753e+00 true resid norm 8.712491430741e+00 ||r(i)||/||b|| 2.081620489698e-04
1005 KSP unpreconditioned resid norm 8.712491418366e+00 true resid norm 8.712491418369e+00 ||r(i)||/||b|| 2.081620486742e-04
1006 KSP unpreconditioned resid norm 8.712491411400e+00 true resid norm 8.712491411406e+00 ||r(i)||/||b|| 2.081620485078e-04
1007 KSP unpreconditioned resid norm 8.712491402851e+00 true resid norm 8.712491402849e+00 ||r(i)||/||b|| 2.081620483034e-04
1008 KSP unpreconditioned resid norm 8.712491397262e+00 true resid norm 8.712491397250e+00 ||r(i)||/||b|| 2.081620481696e-04
1009 KSP unpreconditioned resid norm 8.712491391193e+00 true resid norm 8.712491391191e+00 ||r(i)||/||b|| 2.081620480249e-04
1010 KSP unpreconditioned resid norm 8.712491389994e+00 true resid norm 8.712491389999e+00 ||r(i)||/||b|| 2.081620479964e-04
1011 KSP unpreconditioned resid norm 8.712491388168e+00 true resid norm 8.712491388174e+00 ||r(i)||/||b|| 2.081620479528e-04
1012 KSP unpreconditioned resid norm 8.712491381447e+00 true resid norm 8.712491381454e+00 ||r(i)||/||b|| 2.081620477922e-04
1013 KSP unpreconditioned resid norm 8.712491346713e+00 true resid norm 8.712491346717e+00 ||r(i)||/||b|| 2.081620469623e-04
1014 KSP unpreconditioned resid norm 8.712491282127e+00 true resid norm 8.712491282130e+00 ||r(i)||/||b|| 2.081620454191e-04
1015 KSP unpreconditioned resid norm 8.712491253310e+00 true resid norm 8.712491253312e+00 ||r(i)||/||b|| 2.081620447306e-04
1016 KSP unpreconditioned resid norm 8.712491204315e+00 true resid norm 8.712491204323e+00 ||r(i)||/||b|| 2.081620435601e-04
1017 KSP unpreconditioned resid norm 8.712491112378e+00 true resid norm 8.712491112374e+00 ||r(i)||/||b|| 2.081620413633e-04
1018 KSP unpreconditioned resid norm 8.712490949380e+00 true resid norm 8.712490949378e+00 ||r(i)||/||b|| 2.081620374689e-04
1019 KSP unpreconditioned resid norm 8.712490838883e+00 true resid norm 8.712490838881e+00 ||r(i)||/||b|| 2.081620348289e-04
1020 KSP unpreconditioned resid norm 8.712490823669e+00 true resid norm 8.712490823669e+00 ||r(i)||/||b|| 2.081620344654e-04
1021 KSP unpreconditioned resid norm 8.712490823605e+00 true resid norm 8.712490823602e+00 ||r(i)||/||b|| 2.081620344638e-04
1022 KSP unpreconditioned resid norm 8.712490822980e+00 true resid norm 8.712490822978e+00 ||r(i)||/||b|| 2.081620344489e-04
1023 KSP unpreconditioned resid norm 8.712490820794e+00 true resid norm 8.712490820788e+00 ||r(i)||/||b|| 2.081620343966e-04
1024 KSP unpreconditioned resid norm 8.712490816546e+00 true resid norm 8.712490816540e+00 ||r(i)||/||b|| 2.081620342951e-04
1025 KSP unpreconditioned resid norm 8.712490811432e+00 true resid norm 8.712490811441e+00 ||r(i)||/||b|| 2.081620341733e-04
1026 KSP unpreconditioned resid norm 8.712490809639e+00 true resid norm 8.712490809633e+00 ||r(i)||/||b|| 2.081620341301e-04
1027 KSP unpreconditioned resid norm 8.712490808249e+00 true resid norm 8.712490808249e+00 ||r(i)||/||b|| 2.081620340970e-04
1028 KSP unpreconditioned resid norm 8.712490805055e+00 true resid norm 8.712490805054e+00 ||r(i)||/||b|| 2.081620340207e-04
1029 KSP unpreconditioned resid norm 8.712490800821e+00 true resid norm 8.712490800826e+00 ||r(i)||/||b|| 2.081620339196e-04
1030 KSP unpreconditioned resid norm 8.712490797390e+00 true resid norm 8.712490797403e+00 ||r(i)||/||b|| 2.081620338379e-04
1031 KSP unpreconditioned resid norm 8.712490796045e+00 true resid norm 8.712490796032e+00 ||r(i)||/||b|| 2.081620338051e-04
1032 KSP unpreconditioned resid norm 8.712490795914e+00 true resid norm 8.712490795904e+00 ||r(i)||/||b|| 2.081620338020e-04
1033 KSP unpreconditioned resid norm 8.712490790610e+00 true resid norm 8.712490790603e+00 ||r(i)||/||b|| 2.081620336754e-04
1034 KSP unpreconditioned resid norm 8.712490783855e+00 true resid norm 8.712490783850e+00 ||r(i)||/||b|| 2.081620335140e-04
1035 KSP unpreconditioned resid norm 8.712490770870e+00 true resid norm 8.712490770868e+00 ||r(i)||/||b|| 2.081620332039e-04
1036 KSP unpreconditioned resid norm 8.712490763287e+00 true resid norm 8.712490763279e+00 ||r(i)||/||b|| 2.081620330226e-04
1037 KSP unpreconditioned resid norm 8.712490758483e+00 true resid norm 8.712490758480e+00 ||r(i)||/||b|| 2.081620329079e-04
1038 KSP unpreconditioned resid norm 8.712490749938e+00 true resid norm 8.712490749935e+00 ||r(i)||/||b|| 2.081620327037e-04
1039 KSP unpreconditioned resid norm 8.712490745473e+00 true resid norm 8.712490745471e+00 ||r(i)||/||b|| 2.081620325971e-04
1040 KSP unpreconditioned resid norm 8.712490745385e+00 true resid norm 8.712490745376e+00 ||r(i)||/||b|| 2.081620325948e-04
1041 KSP unpreconditioned resid norm 8.712490745173e+00 true resid norm 8.712490745177e+00 ||r(i)||/||b|| 2.081620325901e-04
1042 KSP unpreconditioned resid norm 8.712490736579e+00 true resid norm 8.712490736572e+00 ||r(i)||/||b|| 2.081620323845e-04
1043 KSP unpreconditioned resid norm 8.712490696569e+00 true resid norm 8.712490696558e+00 ||r(i)||/||b|| 2.081620314284e-04
1044 KSP unpreconditioned resid norm 8.712490654327e+00 true resid norm 8.712490654324e+00 ||r(i)||/||b|| 2.081620304194e-04
1045 KSP unpreconditioned resid norm 8.712490606279e+00 true resid norm 8.712490606266e+00 ||r(i)||/||b|| 2.081620292711e-04
1046 KSP unpreconditioned resid norm 8.712490559352e+00 true resid norm 8.712490559356e+00 ||r(i)||/||b|| 2.081620281504e-04
1047 KSP unpreconditioned resid norm 8.712490497533e+00 true resid norm 8.712490497540e+00 ||r(i)||/||b|| 2.081620266734e-04
1048 KSP unpreconditioned resid norm 8.712490326551e+00 true resid norm 8.712490326545e+00 ||r(i)||/||b|| 2.081620225880e-04
1049 KSP unpreconditioned resid norm 8.712490248790e+00 true resid norm 8.712490248791e+00 ||r(i)||/||b|| 2.081620207302e-04
1050 KSP unpreconditioned resid norm 8.712490243279e+00 true resid norm 8.712490243279e+00 ||r(i)||/||b|| 2.081620205985e-04
1051 KSP unpreconditioned resid norm 8.712490243256e+00 true resid norm 8.712490243261e+00 ||r(i)||/||b|| 2.081620205981e-04
1052 KSP unpreconditioned resid norm 8.712490242933e+00 true resid norm 8.712490242926e+00 ||r(i)||/||b|| 2.081620205901e-04
1053 KSP unpreconditioned resid norm 8.712490241234e+00 true resid norm 8.712490241237e+00 ||r(i)||/||b|| 2.081620205497e-04
1054 KSP unpreconditioned resid norm 8.712490237337e+00 true resid norm 8.712490237340e+00 ||r(i)||/||b|| 2.081620204566e-04
1055 KSP unpreconditioned resid norm 8.712490232644e+00 true resid norm 8.712490232644e+00 ||r(i)||/||b|| 2.081620203444e-04
1056 KSP unpreconditioned resid norm 8.712490231140e+00 true resid norm 8.712490231134e+00 ||r(i)||/||b|| 2.081620203084e-04
1057 KSP unpreconditioned resid norm 8.712490230412e+00 true resid norm 8.712490230413e+00 ||r(i)||/||b|| 2.081620202911e-04
1058 KSP unpreconditioned resid norm 8.712490228192e+00 true resid norm 8.712490228192e+00 ||r(i)||/||b|| 2.081620202381e-04
1059 KSP unpreconditioned resid norm 8.712490223841e+00 true resid norm 8.712490223837e+00 ||r(i)||/||b|| 2.081620201340e-04
1060 KSP unpreconditioned resid norm 8.712490219863e+00 true resid norm 8.712490219860e+00 ||r(i)||/||b|| 2.081620200390e-04
1061 KSP unpreconditioned resid norm 8.712490218947e+00 true resid norm 8.712490218947e+00 ||r(i)||/||b|| 2.081620200172e-04
1062 KSP unpreconditioned resid norm 8.712490218876e+00 true resid norm 8.712490218884e+00 ||r(i)||/||b|| 2.081620200157e-04
1063 KSP unpreconditioned resid norm 8.712490214885e+00 true resid norm 8.712490214877e+00 ||r(i)||/||b|| 2.081620199199e-04
1064 KSP unpreconditioned resid norm 8.712490207411e+00 true resid norm 8.712490207407e+00 ||r(i)||/||b|| 2.081620197415e-04
1065 KSP unpreconditioned resid norm 8.712490197740e+00 true resid norm 8.712490197728e+00 ||r(i)||/||b|| 2.081620195102e-04
1066 KSP unpreconditioned resid norm 8.712490192065e+00 true resid norm 8.712490192058e+00 ||r(i)||/||b|| 2.081620193747e-04
1067 KSP unpreconditioned resid norm 8.712490185999e+00 true resid norm 8.712490185998e+00 ||r(i)||/||b|| 2.081620192300e-04
1068 KSP unpreconditioned resid norm 8.712490181291e+00 true resid norm 8.712490181293e+00 ||r(i)||/||b|| 2.081620191175e-04
1069 KSP unpreconditioned resid norm 8.712490176364e+00 true resid norm 8.712490176371e+00 ||r(i)||/||b|| 2.081620189999e-04
1070 KSP unpreconditioned resid norm 8.712490175783e+00 true resid norm 8.712490175782e+00 ||r(i)||/||b|| 2.081620189859e-04
1071 KSP unpreconditioned resid norm 8.712490174702e+00 true resid norm 8.712490174691e+00 ||r(i)||/||b|| 2.081620189598e-04
1072 KSP unpreconditioned resid norm 8.712490169338e+00 true resid norm 8.712490169334e+00 ||r(i)||/||b|| 2.081620188318e-04
1073 KSP unpreconditioned resid norm 8.712490141010e+00 true resid norm 8.712490141008e+00 ||r(i)||/||b|| 2.081620181550e-04
1074 KSP unpreconditioned resid norm 8.712490095212e+00 true resid norm 8.712490095218e+00 ||r(i)||/||b|| 2.081620170610e-04
1075 KSP unpreconditioned resid norm 8.712490069468e+00 true resid norm 8.712490069463e+00 ||r(i)||/||b|| 2.081620164456e-04
1076 KSP unpreconditioned resid norm 8.712490031325e+00 true resid norm 8.712490031319e+00 ||r(i)||/||b|| 2.081620155343e-04
1077 KSP unpreconditioned resid norm 8.712489963804e+00 true resid norm 8.712489963802e+00 ||r(i)||/||b|| 2.081620139212e-04
1078 KSP unpreconditioned resid norm 8.712489827012e+00 true resid norm 8.712489827007e+00 ||r(i)||/||b|| 2.081620106528e-04
1079 KSP unpreconditioned resid norm 8.712489742627e+00 true resid norm 8.712489742623e+00 ||r(i)||/||b|| 2.081620086367e-04
1080 KSP unpreconditioned resid norm 8.712489733341e+00 true resid norm 8.712489733341e+00 ||r(i)||/||b|| 2.081620084149e-04
1081 KSP unpreconditioned resid norm 8.712489733301e+00 true resid norm 8.712489733292e+00 ||r(i)||/||b|| 2.081620084137e-04
1082 KSP unpreconditioned resid norm 8.712489732873e+00 true resid norm 8.712489732872e+00 ||r(i)||/||b|| 2.081620084037e-04
1083 KSP unpreconditioned resid norm 8.712489731177e+00 true resid norm 8.712489731178e+00 ||r(i)||/||b|| 2.081620083632e-04
1084 KSP unpreconditioned resid norm 8.712489727714e+00 true resid norm 8.712489727716e+00 ||r(i)||/||b|| 2.081620082805e-04
1085 KSP unpreconditioned resid norm 8.712489723582e+00 true resid norm 8.712489723583e+00 ||r(i)||/||b|| 2.081620081818e-04
1086 KSP unpreconditioned resid norm 8.712489722238e+00 true resid norm 8.712489722232e+00 ||r(i)||/||b|| 2.081620081495e-04
1087 KSP unpreconditioned resid norm 8.712489721352e+00 true resid norm 8.712489721354e+00 ||r(i)||/||b|| 2.081620081285e-04
1088 KSP unpreconditioned resid norm 8.712489719044e+00 true resid norm 8.712489719036e+00 ||r(i)||/||b|| 2.081620080731e-04
1089 KSP unpreconditioned resid norm 8.712489715501e+00 true resid norm 8.712489715499e+00 ||r(i)||/||b|| 2.081620079886e-04
1090 KSP unpreconditioned resid norm 8.712489712548e+00 true resid norm 8.712489712542e+00 ||r(i)||/||b|| 2.081620079180e-04
1091 KSP unpreconditioned resid norm 8.712489711593e+00 true resid norm 8.712489711583e+00 ||r(i)||/||b|| 2.081620078951e-04
1092 KSP unpreconditioned resid norm 8.712489711495e+00 true resid norm 8.712489711502e+00 ||r(i)||/||b|| 2.081620078931e-04
1093 KSP unpreconditioned resid norm 8.712489707484e+00 true resid norm 8.712489707489e+00 ||r(i)||/||b|| 2.081620077972e-04
1094 KSP unpreconditioned resid norm 8.712489701776e+00 true resid norm 8.712489701777e+00 ||r(i)||/||b|| 2.081620076608e-04
1095 KSP unpreconditioned resid norm 8.712489692040e+00 true resid norm 8.712489692037e+00 ||r(i)||/||b|| 2.081620074280e-04
1096 KSP unpreconditioned resid norm 8.712489686330e+00 true resid norm 8.712489686329e+00 ||r(i)||/||b|| 2.081620072917e-04
1097 KSP unpreconditioned resid norm 8.712489682245e+00 true resid norm 8.712489682246e+00 ||r(i)||/||b|| 2.081620071941e-04
1098 KSP unpreconditioned resid norm 8.712489676406e+00 true resid norm 8.712489676401e+00 ||r(i)||/||b|| 2.081620070545e-04
1099 KSP unpreconditioned resid norm 8.712489672608e+00 true resid norm 8.712489672613e+00 ||r(i)||/||b|| 2.081620069640e-04
1100 KSP unpreconditioned resid norm 8.712489672498e+00 true resid norm 8.712489672500e+00 ||r(i)||/||b|| 2.081620069613e-04
1101 KSP unpreconditioned resid norm 8.712489672154e+00 true resid norm 8.712489672160e+00 ||r(i)||/||b|| 2.081620069531e-04
1102 KSP unpreconditioned resid norm 8.712489666039e+00 true resid norm 8.712489666028e+00 ||r(i)||/||b|| 2.081620068066e-04
1103 KSP unpreconditioned resid norm 8.712489636146e+00 true resid norm 8.712489636144e+00 ||r(i)||/||b|| 2.081620060926e-04
1104 KSP unpreconditioned resid norm 8.712489600917e+00 true resid norm 8.712489600916e+00 ||r(i)||/||b|| 2.081620052510e-04
1105 KSP unpreconditioned resid norm 8.712489566911e+00 true resid norm 8.712489566916e+00 ||r(i)||/||b|| 2.081620044386e-04
1106 KSP unpreconditioned resid norm 8.712489530407e+00 true resid norm 8.712489530399e+00 ||r(i)||/||b|| 2.081620035661e-04
1107 KSP unpreconditioned resid norm 8.712489479112e+00 true resid norm 8.712489479106e+00 ||r(i)||/||b|| 2.081620023406e-04
1108 KSP unpreconditioned resid norm 8.712489347084e+00 true resid norm 8.712489347087e+00 ||r(i)||/||b|| 2.081619991864e-04
1109 KSP unpreconditioned resid norm 8.712489283438e+00 true resid norm 8.712489283439e+00 ||r(i)||/||b|| 2.081619976657e-04
1110 KSP unpreconditioned resid norm 8.712489279381e+00 true resid norm 8.712489279381e+00 ||r(i)||/||b|| 2.081619975687e-04
1111 KSP unpreconditioned resid norm 8.712489279364e+00 true resid norm 8.712489279362e+00 ||r(i)||/||b|| 2.081619975683e-04
1112 KSP unpreconditioned resid norm 8.712489279110e+00 true resid norm 8.712489279103e+00 ||r(i)||/||b|| 2.081619975621e-04
1113 KSP unpreconditioned resid norm 8.712489277765e+00 true resid norm 8.712489277768e+00 ||r(i)||/||b|| 2.081619975302e-04
1114 KSP unpreconditioned resid norm 8.712489274670e+00 true resid norm 8.712489274661e+00 ||r(i)||/||b|| 2.081619974559e-04
1115 KSP unpreconditioned resid norm 8.712489270926e+00 true resid norm 8.712489270923e+00 ||r(i)||/||b|| 2.081619973666e-04
1116 KSP unpreconditioned resid norm 8.712489269788e+00 true resid norm 8.712489269785e+00 ||r(i)||/||b|| 2.081619973395e-04
1117 KSP unpreconditioned resid norm 8.712489269244e+00 true resid norm 8.712489269230e+00 ||r(i)||/||b|| 2.081619973262e-04
1118 KSP unpreconditioned resid norm 8.712489267530e+00 true resid norm 8.712489267518e+00 ||r(i)||/||b|| 2.081619972853e-04
1119 KSP unpreconditioned resid norm 8.712489264069e+00 true resid norm 8.712489264076e+00 ||r(i)||/||b|| 2.081619972031e-04
1120 KSP unpreconditioned resid norm 8.712489260945e+00 true resid norm 8.712489260934e+00 ||r(i)||/||b|| 2.081619971280e-04
1121 KSP unpreconditioned resid norm 8.712489260214e+00 true resid norm 8.712489260209e+00 ||r(i)||/||b|| 2.081619971107e-04
1122 KSP unpreconditioned resid norm 8.712489260152e+00 true resid norm 8.712489260143e+00 ||r(i)||/||b|| 2.081619971091e-04
1123 KSP unpreconditioned resid norm 8.712489256948e+00 true resid norm 8.712489256932e+00 ||r(i)||/||b|| 2.081619970324e-04
1124 KSP unpreconditioned resid norm 8.712489251224e+00 true resid norm 8.712489251226e+00 ||r(i)||/||b|| 2.081619968960e-04
1125 KSP unpreconditioned resid norm 8.712489243632e+00 true resid norm 8.712489243626e+00 ||r(i)||/||b|| 2.081619967144e-04
1126 KSP unpreconditioned resid norm 8.712489239095e+00 true resid norm 8.712489239085e+00 ||r(i)||/||b|| 2.081619966060e-04
1127 KSP unpreconditioned resid norm 8.712489234622e+00 true resid norm 8.712489234622e+00 ||r(i)||/||b|| 2.081619964993e-04
1128 KSP unpreconditioned resid norm 8.712489230764e+00 true resid norm 8.712489230757e+00 ||r(i)||/||b|| 2.081619964070e-04
1129 KSP unpreconditioned resid norm 8.712489226840e+00 true resid norm 8.712489226833e+00 ||r(i)||/||b|| 2.081619963132e-04
1130 KSP unpreconditioned resid norm 8.712489226512e+00 true resid norm 8.712489226517e+00 ||r(i)||/||b|| 2.081619963057e-04
1131 KSP unpreconditioned resid norm 8.712489225797e+00 true resid norm 8.712489225794e+00 ||r(i)||/||b|| 2.081619962884e-04
1132 KSP unpreconditioned resid norm 8.712489221540e+00 true resid norm 8.712489221535e+00 ||r(i)||/||b|| 2.081619961867e-04
1133 KSP unpreconditioned resid norm 8.712489198880e+00 true resid norm 8.712489198876e+00 ||r(i)||/||b|| 2.081619956453e-04
1134 KSP unpreconditioned resid norm 8.712489164903e+00 true resid norm 8.712489164893e+00 ||r(i)||/||b|| 2.081619948333e-04
1135 KSP unpreconditioned resid norm 8.712489143209e+00 true resid norm 8.712489143207e+00 ||r(i)||/||b|| 2.081619943152e-04
1136 KSP unpreconditioned resid norm 8.712489113424e+00 true resid norm 8.712489113409e+00 ||r(i)||/||b|| 2.081619936033e-04
1137 KSP unpreconditioned resid norm 8.712489062448e+00 true resid norm 8.712489062446e+00 ||r(i)||/||b|| 2.081619923856e-04
1138 KSP unpreconditioned resid norm 8.712488951318e+00 true resid norm 8.712488951300e+00 ||r(i)||/||b|| 2.081619897301e-04
1139 KSP unpreconditioned resid norm 8.712488886149e+00 true resid norm 8.712488886130e+00 ||r(i)||/||b|| 2.081619881730e-04
1140 KSP unpreconditioned resid norm 8.712488879862e+00 true resid norm 8.712488879862e+00 ||r(i)||/||b|| 2.081619880233e-04
1141 KSP unpreconditioned resid norm 8.712488879836e+00 true resid norm 8.712488879834e+00 ||r(i)||/||b|| 2.081619880226e-04
1142 KSP unpreconditioned resid norm 8.712488879525e+00 true resid norm 8.712488879520e+00 ||r(i)||/||b|| 2.081619880151e-04
1143 KSP unpreconditioned resid norm 8.712488878204e+00 true resid norm 8.712488878202e+00 ||r(i)||/||b|| 2.081619879836e-04
1144 KSP unpreconditioned resid norm 8.712488875439e+00 true resid norm 8.712488875438e+00 ||r(i)||/||b|| 2.081619879176e-04
1145 KSP unpreconditioned resid norm 8.712488872157e+00 true resid norm 8.712488872149e+00 ||r(i)||/||b|| 2.081619878390e-04
1146 KSP unpreconditioned resid norm 8.712488871130e+00 true resid norm 8.712488871130e+00 ||r(i)||/||b|| 2.081619878146e-04
1147 KSP unpreconditioned resid norm 8.712488870514e+00 true resid norm 8.712488870501e+00 ||r(i)||/||b|| 2.081619877996e-04
1148 KSP unpreconditioned resid norm 8.712488868785e+00 true resid norm 8.712488868778e+00 ||r(i)||/||b|| 2.081619877584e-04
1149 KSP unpreconditioned resid norm 8.712488865918e+00 true resid norm 8.712488865915e+00 ||r(i)||/||b|| 2.081619876900e-04
1150 KSP unpreconditioned resid norm 8.712488863492e+00 true resid norm 8.712488863478e+00 ||r(i)||/||b|| 2.081619876318e-04
1151 KSP unpreconditioned resid norm 8.712488862782e+00 true resid norm 8.712488862782e+00 ||r(i)||/||b|| 2.081619876152e-04
1152 KSP unpreconditioned resid norm 8.712488862709e+00 true resid norm 8.712488862700e+00 ||r(i)||/||b|| 2.081619876132e-04
1153 KSP unpreconditioned resid norm 8.712488859635e+00 true resid norm 8.712488859625e+00 ||r(i)||/||b|| 2.081619875398e-04
1154 KSP unpreconditioned resid norm 8.712488854989e+00 true resid norm 8.712488854988e+00 ||r(i)||/||b|| 2.081619874290e-04
1155 KSP unpreconditioned resid norm 8.712488847552e+00 true resid norm 8.712488847540e+00 ||r(i)||/||b|| 2.081619872510e-04
1156 KSP unpreconditioned resid norm 8.712488843186e+00 true resid norm 8.712488843176e+00 ||r(i)||/||b|| 2.081619871468e-04
1157 KSP unpreconditioned resid norm 8.712488839847e+00 true resid norm 8.712488839829e+00 ||r(i)||/||b|| 2.081619870668e-04
1158 KSP unpreconditioned resid norm 8.712488835614e+00 true resid norm 8.712488835609e+00 ||r(i)||/||b|| 2.081619869660e-04
1159 KSP unpreconditioned resid norm 8.712488832504e+00 true resid norm 8.712488832494e+00 ||r(i)||/||b|| 2.081619868915e-04
1160 KSP unpreconditioned resid norm 8.712488832396e+00 true resid norm 8.712488832394e+00 ||r(i)||/||b|| 2.081619868891e-04
1161 KSP unpreconditioned resid norm 8.712488832028e+00 true resid norm 8.712488832027e+00 ||r(i)||/||b|| 2.081619868804e-04
1162 KSP unpreconditioned resid norm 8.712488827502e+00 true resid norm 8.712488827485e+00 ||r(i)||/||b|| 2.081619867719e-04
1163 KSP unpreconditioned resid norm 8.712488804778e+00 true resid norm 8.712488804768e+00 ||r(i)||/||b|| 2.081619862291e-04
1164 KSP unpreconditioned resid norm 8.712488776297e+00 true resid norm 8.712488776296e+00 ||r(i)||/||b|| 2.081619855488e-04
1165 KSP unpreconditioned resid norm 8.712488751221e+00 true resid norm 8.712488751221e+00 ||r(i)||/||b|| 2.081619849497e-04
1166 KSP unpreconditioned resid norm 8.712488722819e+00 true resid norm 8.712488722820e+00 ||r(i)||/||b|| 2.081619842712e-04
1167 KSP unpreconditioned resid norm 8.712488681399e+00 true resid norm 8.712488681389e+00 ||r(i)||/||b|| 2.081619832813e-04
1168 KSP unpreconditioned resid norm 8.712488578739e+00 true resid norm 8.712488578734e+00 ||r(i)||/||b|| 2.081619808286e-04
1169 KSP unpreconditioned resid norm 8.712488527491e+00 true resid norm 8.712488527484e+00 ||r(i)||/||b|| 2.081619796041e-04
1170 KSP unpreconditioned resid norm 8.712488524324e+00 true resid norm 8.712488524324e+00 ||r(i)||/||b|| 2.081619795286e-04
1171 KSP unpreconditioned resid norm 8.712488524311e+00 true resid norm 8.712488524315e+00 ||r(i)||/||b|| 2.081619795284e-04
1172 KSP unpreconditioned resid norm 8.712488524110e+00 true resid norm 8.712488524109e+00 ||r(i)||/||b|| 2.081619795235e-04
1173 KSP unpreconditioned resid norm 8.712488523047e+00 true resid norm 8.712488523062e+00 ||r(i)||/||b|| 2.081619794985e-04
1174 KSP unpreconditioned resid norm 8.712488520605e+00 true resid norm 8.712488520612e+00 ||r(i)||/||b|| 2.081619794399e-04
1175 KSP unpreconditioned resid norm 8.712488517650e+00 true resid norm 8.712488517652e+00 ||r(i)||/||b|| 2.081619793692e-04
1176 KSP unpreconditioned resid norm 8.712488516775e+00 true resid norm 8.712488516767e+00 ||r(i)||/||b|| 2.081619793481e-04
1177 KSP unpreconditioned resid norm 8.712488516358e+00 true resid norm 8.712488516372e+00 ||r(i)||/||b|| 2.081619793386e-04
1178 KSP unpreconditioned resid norm 8.712488515020e+00 true resid norm 8.712488515027e+00 ||r(i)||/||b|| 2.081619793065e-04
1179 KSP unpreconditioned resid norm 8.712488512295e+00 true resid norm 8.712488512304e+00 ||r(i)||/||b|| 2.081619792414e-04
1180 KSP unpreconditioned resid norm 8.712488509855e+00 true resid norm 8.712488509859e+00 ||r(i)||/||b|| 2.081619791830e-04
1181 KSP unpreconditioned resid norm 8.712488509277e+00 true resid norm 8.712488509291e+00 ||r(i)||/||b|| 2.081619791695e-04
1182 KSP unpreconditioned resid norm 8.712488509226e+00 true resid norm 8.712488509225e+00 ||r(i)||/||b|| 2.081619791679e-04
1183 KSP unpreconditioned resid norm 8.712488506684e+00 true resid norm 8.712488506694e+00 ||r(i)||/||b|| 2.081619791074e-04
1184 KSP unpreconditioned resid norm 8.712488502263e+00 true resid norm 8.712488502255e+00 ||r(i)||/||b|| 2.081619790013e-04
1185 KSP unpreconditioned resid norm 8.712488496296e+00 true resid norm 8.712488496305e+00 ||r(i)||/||b|| 2.081619788592e-04
1186 KSP unpreconditioned resid norm 8.712488492704e+00 true resid norm 8.712488492709e+00 ||r(i)||/||b|| 2.081619787733e-04
1187 KSP unpreconditioned resid norm 8.712488489325e+00 true resid norm 8.712488489335e+00 ||r(i)||/||b|| 2.081619786926e-04
1188 KSP unpreconditioned resid norm 8.712488486218e+00 true resid norm 8.712488486234e+00 ||r(i)||/||b|| 2.081619786186e-04
1189 KSP unpreconditioned resid norm 8.712488483127e+00 true resid norm 8.712488483123e+00 ||r(i)||/||b|| 2.081619785442e-04
1190 KSP unpreconditioned resid norm 8.712488482919e+00 true resid norm 8.712488482922e+00 ||r(i)||/||b|| 2.081619785394e-04
1191 KSP unpreconditioned resid norm 8.712488482412e+00 true resid norm 8.712488482416e+00 ||r(i)||/||b|| 2.081619785273e-04
1192 KSP unpreconditioned resid norm 8.712488479044e+00 true resid norm 8.712488479048e+00 ||r(i)||/||b|| 2.081619784469e-04
1193 KSP unpreconditioned resid norm 8.712488461088e+00 true resid norm 8.712488461098e+00 ||r(i)||/||b|| 2.081619780180e-04
1194 KSP unpreconditioned resid norm 8.712488435250e+00 true resid norm 8.712488435244e+00 ||r(i)||/||b|| 2.081619774003e-04
1195 KSP unpreconditioned resid norm 8.712488417536e+00 true resid norm 8.712488417544e+00 ||r(i)||/||b|| 2.081619769774e-04
1196 KSP unpreconditioned resid norm 8.712488394223e+00 true resid norm 8.712488394233e+00 ||r(i)||/||b|| 2.081619764204e-04
1197 KSP unpreconditioned resid norm 8.712488355109e+00 true resid norm 8.712488355118e+00 ||r(i)||/||b|| 2.081619754859e-04
1198 KSP unpreconditioned resid norm 8.712488266342e+00 true resid norm 8.712488266347e+00 ||r(i)||/||b|| 2.081619733649e-04
1199 KSP unpreconditioned resid norm 8.712488215725e+00 true resid norm 8.712488215732e+00 ||r(i)||/||b|| 2.081619721556e-04
1200 KSP unpreconditioned resid norm 8.712488211219e+00 true resid norm 8.712488211219e+00 ||r(i)||/||b|| 2.081619720478e-04
1201 KSP unpreconditioned resid norm 8.712488211200e+00 true resid norm 8.712488211188e+00 ||r(i)||/||b|| 2.081619720471e-04
1202 KSP unpreconditioned resid norm 8.712488210966e+00 true resid norm 8.712488210957e+00 ||r(i)||/||b|| 2.081619720415e-04
1203 KSP unpreconditioned resid norm 8.712488209937e+00 true resid norm 8.712488209937e+00 ||r(i)||/||b|| 2.081619720172e-04
1204 KSP unpreconditioned resid norm 8.712488207752e+00 true resid norm 8.712488207737e+00 ||r(i)||/||b|| 2.081619719646e-04
1205 KSP unpreconditioned resid norm 8.712488205164e+00 true resid norm 8.712488205157e+00 ||r(i)||/||b|| 2.081619719030e-04
1206 KSP unpreconditioned resid norm 8.712488204372e+00 true resid norm 8.712488204370e+00 ||r(i)||/||b|| 2.081619718842e-04
1207 KSP unpreconditioned resid norm 8.712488203922e+00 true resid norm 8.712488203908e+00 ||r(i)||/||b|| 2.081619718731e-04
1208 KSP unpreconditioned resid norm 8.712488202603e+00 true resid norm 8.712488202594e+00 ||r(i)||/||b|| 2.081619718417e-04
1209 KSP unpreconditioned resid norm 8.712488200319e+00 true resid norm 8.712488200321e+00 ||r(i)||/||b|| 2.081619717874e-04
1210 KSP unpreconditioned resid norm 8.712488198369e+00 true resid norm 8.712488198356e+00 ||r(i)||/||b|| 2.081619717405e-04
1211 KSP unpreconditioned resid norm 8.712488197829e+00 true resid norm 8.712488197831e+00 ||r(i)||/||b|| 2.081619717279e-04
1212 KSP unpreconditioned resid norm 8.712488197774e+00 true resid norm 8.712488197770e+00 ||r(i)||/||b|| 2.081619717265e-04
1213 KSP unpreconditioned resid norm 8.712488195399e+00 true resid norm 8.712488195394e+00 ||r(i)||/||b|| 2.081619716697e-04
1214 KSP unpreconditioned resid norm 8.712488191688e+00 true resid norm 8.712488191670e+00 ||r(i)||/||b|| 2.081619715807e-04
1215 KSP unpreconditioned resid norm 8.712488185952e+00 true resid norm 8.712488185950e+00 ||r(i)||/||b|| 2.081619714441e-04
1216 KSP unpreconditioned resid norm 8.712488182584e+00 true resid norm 8.712488182573e+00 ||r(i)||/||b|| 2.081619713634e-04
1217 KSP unpreconditioned resid norm 8.712488179909e+00 true resid norm 8.712488179893e+00 ||r(i)||/||b|| 2.081619712993e-04
1218 KSP unpreconditioned resid norm 8.712488176735e+00 true resid norm 8.712488176724e+00 ||r(i)||/||b|| 2.081619712236e-04
1219 KSP unpreconditioned resid norm 8.712488174240e+00 true resid norm 8.712488174240e+00 ||r(i)||/||b|| 2.081619711643e-04
1220 KSP unpreconditioned resid norm 8.712488174145e+00 true resid norm 8.712488174134e+00 ||r(i)||/||b|| 2.081619711618e-04
1221 KSP unpreconditioned resid norm 8.712488173810e+00 true resid norm 8.712488173799e+00 ||r(i)||/||b|| 2.081619711538e-04
1222 KSP unpreconditioned resid norm 8.712488170383e+00 true resid norm 8.712488170379e+00 ||r(i)||/||b|| 2.081619710720e-04
1223 KSP unpreconditioned resid norm 8.712488152925e+00 true resid norm 8.712488152915e+00 ||r(i)||/||b|| 2.081619706548e-04
1224 KSP unpreconditioned resid norm 8.712488130282e+00 true resid norm 8.712488130271e+00 ||r(i)||/||b|| 2.081619701138e-04
1225 KSP unpreconditioned resid norm 8.712488111355e+00 true resid norm 8.712488111360e+00 ||r(i)||/||b|| 2.081619696619e-04
1226 KSP unpreconditioned resid norm 8.712488089244e+00 true resid norm 8.712488089238e+00 ||r(i)||/||b|| 2.081619691334e-04
1227 KSP unpreconditioned resid norm 8.712488056262e+00 true resid norm 8.712488056259e+00 ||r(i)||/||b|| 2.081619683454e-04
1228 KSP unpreconditioned resid norm 8.712487976139e+00 true resid norm 8.712487976131e+00 ||r(i)||/||b|| 2.081619664310e-04
1229 KSP unpreconditioned resid norm 8.712487935275e+00 true resid norm 8.712487935258e+00 ||r(i)||/||b|| 2.081619654544e-04
1230 KSP unpreconditioned resid norm 8.712487932760e+00 true resid norm 8.712487932760e+00 ||r(i)||/||b|| 2.081619653948e-04
1231 KSP unpreconditioned resid norm 8.712487932749e+00 true resid norm 8.712487932743e+00 ||r(i)||/||b|| 2.081619653944e-04
1232 KSP unpreconditioned resid norm 8.712487932589e+00 true resid norm 8.712487932595e+00 ||r(i)||/||b|| 2.081619653908e-04
1233 KSP unpreconditioned resid norm 8.712487931750e+00 true resid norm 8.712487931753e+00 ||r(i)||/||b|| 2.081619653707e-04
1234 KSP unpreconditioned resid norm 8.712487929831e+00 true resid norm 8.712487929831e+00 ||r(i)||/||b|| 2.081619653248e-04
1235 KSP unpreconditioned resid norm 8.712487927510e+00 true resid norm 8.712487927508e+00 ||r(i)||/||b|| 2.081619652693e-04
1236 KSP unpreconditioned resid norm 8.712487926832e+00 true resid norm 8.712487926829e+00 ||r(i)||/||b|| 2.081619652531e-04
1237 KSP unpreconditioned resid norm 8.712487926507e+00 true resid norm 8.712487926505e+00 ||r(i)||/||b|| 2.081619652453e-04
1238 KSP unpreconditioned resid norm 8.712487925459e+00 true resid norm 8.712487925456e+00 ||r(i)||/||b|| 2.081619652202e-04
1239 KSP unpreconditioned resid norm 8.712487923324e+00 true resid norm 8.712487923322e+00 ||r(i)||/||b|| 2.081619651693e-04
1240 KSP unpreconditioned resid norm 8.712487921422e+00 true resid norm 8.712487921418e+00 ||r(i)||/||b|| 2.081619651238e-04
1241 KSP unpreconditioned resid norm 8.712487920966e+00 true resid norm 8.712487920960e+00 ||r(i)||/||b|| 2.081619651128e-04
1242 KSP unpreconditioned resid norm 8.712487920924e+00 true resid norm 8.712487920925e+00 ||r(i)||/||b|| 2.081619651120e-04
1243 KSP unpreconditioned resid norm 8.712487918920e+00 true resid norm 8.712487918923e+00 ||r(i)||/||b|| 2.081619650642e-04
1244 KSP unpreconditioned resid norm 8.712487915489e+00 true resid norm 8.712487915484e+00 ||r(i)||/||b|| 2.081619649820e-04
1245 KSP unpreconditioned resid norm 8.712487910800e+00 true resid norm 8.712487910802e+00 ||r(i)||/||b|| 2.081619648701e-04
1246 KSP unpreconditioned resid norm 8.712487907971e+00 true resid norm 8.712487907969e+00 ||r(i)||/||b|| 2.081619648024e-04
1247 KSP unpreconditioned resid norm 8.712487905382e+00 true resid norm 8.712487905380e+00 ||r(i)||/||b|| 2.081619647406e-04
1248 KSP unpreconditioned resid norm 8.712487902907e+00 true resid norm 8.712487902906e+00 ||r(i)||/||b|| 2.081619646815e-04
1249 KSP unpreconditioned resid norm 8.712487900486e+00 true resid norm 8.712487900484e+00 ||r(i)||/||b|| 2.081619646236e-04
1250 KSP unpreconditioned resid norm 8.712487900343e+00 true resid norm 8.712487900353e+00 ||r(i)||/||b|| 2.081619646205e-04
1251 KSP unpreconditioned resid norm 8.712487899968e+00 true resid norm 8.712487899961e+00 ||r(i)||/||b|| 2.081619646111e-04
1252 KSP unpreconditioned resid norm 8.712487897310e+00 true resid norm 8.712487897308e+00 ||r(i)||/||b|| 2.081619645477e-04
1253 KSP unpreconditioned resid norm 8.712487883149e+00 true resid norm 8.712487883153e+00 ||r(i)||/||b|| 2.081619642095e-04
1254 KSP unpreconditioned resid norm 8.712487863234e+00 true resid norm 8.712487863240e+00 ||r(i)||/||b|| 2.081619637338e-04
1255 KSP unpreconditioned resid norm 8.712487849021e+00 true resid norm 8.712487849027e+00 ||r(i)||/||b|| 2.081619633942e-04
1256 KSP unpreconditioned resid norm 8.712487830747e+00 true resid norm 8.712487830732e+00 ||r(i)||/||b|| 2.081619629571e-04
1257 KSP unpreconditioned resid norm 8.712487800462e+00 true resid norm 8.712487800450e+00 ||r(i)||/||b|| 2.081619622335e-04
1258 KSP unpreconditioned resid norm 8.712487730199e+00 true resid norm 8.712487730199e+00 ||r(i)||/||b|| 2.081619605551e-04
1259 KSP unpreconditioned resid norm 8.712487690771e+00 true resid norm 8.712487690765e+00 ||r(i)||/||b|| 2.081619596129e-04
1260 KSP unpreconditioned resid norm 8.712487687400e+00 true resid norm 8.712487687400e+00 ||r(i)||/||b|| 2.081619595325e-04
1261 KSP unpreconditioned resid norm 8.712487687386e+00 true resid norm 8.712487687388e+00 ||r(i)||/||b|| 2.081619595322e-04
1262 KSP unpreconditioned resid norm 8.712487687208e+00 true resid norm 8.712487687210e+00 ||r(i)||/||b|| 2.081619595280e-04
1263 KSP unpreconditioned resid norm 8.712487686405e+00 true resid norm 8.712487686401e+00 ||r(i)||/||b|| 2.081619595086e-04
1264 KSP unpreconditioned resid norm 8.712487684687e+00 true resid norm 8.712487684686e+00 ||r(i)||/||b|| 2.081619594677e-04
1265 KSP unpreconditioned resid norm 8.712487682655e+00 true resid norm 8.712487682655e+00 ||r(i)||/||b|| 2.081619594191e-04
1266 KSP unpreconditioned resid norm 8.712487682041e+00 true resid norm 8.712487682049e+00 ||r(i)||/||b|| 2.081619594047e-04
1267 KSP unpreconditioned resid norm 8.712487681703e+00 true resid norm 8.712487681708e+00 ||r(i)||/||b|| 2.081619593965e-04
1268 KSP unpreconditioned resid norm 8.712487680687e+00 true resid norm 8.712487680681e+00 ||r(i)||/||b|| 2.081619593720e-04
1269 KSP unpreconditioned resid norm 8.712487678882e+00 true resid norm 8.712487678891e+00 ||r(i)||/||b|| 2.081619593292e-04
1270 KSP unpreconditioned resid norm 8.712487677333e+00 true resid norm 8.712487677338e+00 ||r(i)||/||b|| 2.081619592921e-04
1271 KSP unpreconditioned resid norm 8.712487676915e+00 true resid norm 8.712487676915e+00 ||r(i)||/||b|| 2.081619592820e-04
1272 KSP unpreconditioned resid norm 8.712487676873e+00 true resid norm 8.712487676874e+00 ||r(i)||/||b|| 2.081619592810e-04
1273 KSP unpreconditioned resid norm 8.712487675030e+00 true resid norm 8.712487675035e+00 ||r(i)||/||b|| 2.081619592371e-04
1274 KSP unpreconditioned resid norm 8.712487672095e+00 true resid norm 8.712487672105e+00 ||r(i)||/||b|| 2.081619591671e-04
1275 KSP unpreconditioned resid norm 8.712487667649e+00 true resid norm 8.712487667652e+00 ||r(i)||/||b|| 2.081619590607e-04
1276 KSP unpreconditioned resid norm 8.712487665036e+00 true resid norm 8.712487665049e+00 ||r(i)||/||b|| 2.081619589985e-04
1277 KSP unpreconditioned resid norm 8.712487662916e+00 true resid norm 8.712487662915e+00 ||r(i)||/||b|| 2.081619589475e-04
1278 KSP unpreconditioned resid norm 8.712487660492e+00 true resid norm 8.712487660508e+00 ||r(i)||/||b|| 2.081619588900e-04
1279 KSP unpreconditioned resid norm 8.712487658511e+00 true resid norm 8.712487658517e+00 ||r(i)||/||b|| 2.081619588424e-04
1280 KSP unpreconditioned resid norm 8.712487658431e+00 true resid norm 8.712487658435e+00 ||r(i)||/||b|| 2.081619588405e-04
1281 KSP unpreconditioned resid norm 8.712487658148e+00 true resid norm 8.712487658163e+00 ||r(i)||/||b|| 2.081619588340e-04
1282 KSP unpreconditioned resid norm 8.712487655520e+00 true resid norm 8.712487655517e+00 ||r(i)||/||b|| 2.081619587708e-04
1283 KSP unpreconditioned resid norm 8.712487642024e+00 true resid norm 8.712487642026e+00 ||r(i)||/||b|| 2.081619584484e-04
1284 KSP unpreconditioned resid norm 8.712487624184e+00 true resid norm 8.712487624191e+00 ||r(i)||/||b|| 2.081619580223e-04
1285 KSP unpreconditioned resid norm 8.712487609706e+00 true resid norm 8.712487609716e+00 ||r(i)||/||b|| 2.081619576765e-04
1286 KSP unpreconditioned resid norm 8.712487592482e+00 true resid norm 8.712487592484e+00 ||r(i)||/||b|| 2.081619572647e-04
1287 KSP unpreconditioned resid norm 8.712487566418e+00 true resid norm 8.712487566419e+00 ||r(i)||/||b|| 2.081619566420e-04
1288 KSP unpreconditioned resid norm 8.712487503765e+00 true resid norm 8.712487503769e+00 ||r(i)||/||b|| 2.081619551451e-04
1289 KSP unpreconditioned resid norm 8.712487471373e+00 true resid norm 8.712487471366e+00 ||r(i)||/||b|| 2.081619543709e-04
1290 KSP unpreconditioned resid norm 8.712487469365e+00 true resid norm 8.712487469365e+00 ||r(i)||/||b|| 2.081619543232e-04
1291 KSP unpreconditioned resid norm 8.712487469357e+00 true resid norm 8.712487469354e+00 ||r(i)||/||b|| 2.081619543229e-04
1292 KSP unpreconditioned resid norm 8.712487469229e+00 true resid norm 8.712487469222e+00 ||r(i)||/||b|| 2.081619543197e-04
1293 KSP unpreconditioned resid norm 8.712487468568e+00 true resid norm 8.712487468553e+00 ||r(i)||/||b|| 2.081619543037e-04
1294 KSP unpreconditioned resid norm 8.712487467062e+00 true resid norm 8.712487467058e+00 ||r(i)||/||b|| 2.081619542680e-04
1295 KSP unpreconditioned resid norm 8.712487465244e+00 true resid norm 8.712487465231e+00 ||r(i)||/||b|| 2.081619542244e-04
1296 KSP unpreconditioned resid norm 8.712487464716e+00 true resid norm 8.712487464713e+00 ||r(i)||/||b|| 2.081619542120e-04
1297 KSP unpreconditioned resid norm 8.712487464462e+00 true resid norm 8.712487464451e+00 ||r(i)||/||b|| 2.081619542058e-04
1298 KSP unpreconditioned resid norm 8.712487463639e+00 true resid norm 8.712487463630e+00 ||r(i)||/||b|| 2.081619541861e-04
1299 KSP unpreconditioned resid norm 8.712487461970e+00 true resid norm 8.712487461966e+00 ||r(i)||/||b|| 2.081619541464e-04
1300 KSP unpreconditioned resid norm 8.712487460488e+00 true resid norm 8.712487460486e+00 ||r(i)||/||b|| 2.081619541110e-04
1301 KSP unpreconditioned resid norm 8.712487460129e+00 true resid norm 8.712487460127e+00 ||r(i)||/||b|| 2.081619541024e-04
1302 KSP unpreconditioned resid norm 8.712487460096e+00 true resid norm 8.712487460096e+00 ||r(i)||/||b|| 2.081619541017e-04
1303 KSP unpreconditioned resid norm 8.712487458521e+00 true resid norm 8.712487458509e+00 ||r(i)||/||b|| 2.081619540638e-04
1304 KSP unpreconditioned resid norm 8.712487455850e+00 true resid norm 8.712487455846e+00 ||r(i)||/||b|| 2.081619540002e-04
1305 KSP unpreconditioned resid norm 8.712487452168e+00 true resid norm 8.712487452170e+00 ||r(i)||/||b|| 2.081619539123e-04
1306 KSP unpreconditioned resid norm 8.712487449946e+00 true resid norm 8.712487449940e+00 ||r(i)||/||b|| 2.081619538590e-04
1307 KSP unpreconditioned resid norm 8.712487447947e+00 true resid norm 8.712487447936e+00 ||r(i)||/||b|| 2.081619538112e-04
1308 KSP unpreconditioned resid norm 8.712487445986e+00 true resid norm 8.712487445982e+00 ||r(i)||/||b|| 2.081619537645e-04
1309 KSP unpreconditioned resid norm 8.712487444096e+00 true resid norm 8.712487444093e+00 ||r(i)||/||b|| 2.081619537193e-04
1310 KSP unpreconditioned resid norm 8.712487443992e+00 true resid norm 8.712487443997e+00 ||r(i)||/||b|| 2.081619537171e-04
1311 KSP unpreconditioned resid norm 8.712487443708e+00 true resid norm 8.712487443691e+00 ||r(i)||/||b|| 2.081619537097e-04
1312 KSP unpreconditioned resid norm 8.712487441613e+00 true resid norm 8.712487441606e+00 ||r(i)||/||b|| 2.081619536599e-04
1313 KSP unpreconditioned resid norm 8.712487430476e+00 true resid norm 8.712487430469e+00 ||r(i)||/||b|| 2.081619533938e-04
1314 KSP unpreconditioned resid norm 8.712487415014e+00 true resid norm 8.712487415004e+00 ||r(i)||/||b|| 2.081619530243e-04
1315 KSP unpreconditioned resid norm 8.712487403719e+00 true resid norm 8.712487403708e+00 ||r(i)||/||b|| 2.081619527545e-04
1316 KSP unpreconditioned resid norm 8.712487389387e+00 true resid norm 8.712487389382e+00 ||r(i)||/||b|| 2.081619524122e-04
1317 KSP unpreconditioned resid norm 8.712487365821e+00 true resid norm 8.712487365817e+00 ||r(i)||/||b|| 2.081619518492e-04
1318 KSP unpreconditioned resid norm 8.712487310484e+00 true resid norm 8.712487310479e+00 ||r(i)||/||b|| 2.081619505270e-04
1319 KSP unpreconditioned resid norm 8.712487279726e+00 true resid norm 8.712487279717e+00 ||r(i)||/||b|| 2.081619497920e-04
1320 KSP unpreconditioned resid norm 8.712487277171e+00 true resid norm 8.712487277171e+00 ||r(i)||/||b|| 2.081619497312e-04
1321 KSP unpreconditioned resid norm 8.712487277160e+00 true resid norm 8.712487277164e+00 ||r(i)||/||b|| 2.081619497310e-04
1322 KSP unpreconditioned resid norm 8.712487277024e+00 true resid norm 8.712487277021e+00 ||r(i)||/||b|| 2.081619497276e-04
1323 KSP unpreconditioned resid norm 8.712487276397e+00 true resid norm 8.712487276395e+00 ||r(i)||/||b|| 2.081619497126e-04
1324 KSP unpreconditioned resid norm 8.712487275050e+00 true resid norm 8.712487275057e+00 ||r(i)||/||b|| 2.081619496807e-04
1325 KSP unpreconditioned resid norm 8.712487273457e+00 true resid norm 8.712487273456e+00 ||r(i)||/||b|| 2.081619496424e-04
1326 KSP unpreconditioned resid norm 8.712487272979e+00 true resid norm 8.712487272966e+00 ||r(i)||/||b|| 2.081619496307e-04
1327 KSP unpreconditioned resid norm 8.712487272722e+00 true resid norm 8.712487272724e+00 ||r(i)||/||b|| 2.081619496249e-04
1328 KSP unpreconditioned resid norm 8.712487271935e+00 true resid norm 8.712487271933e+00 ||r(i)||/||b|| 2.081619496060e-04
1329 KSP unpreconditioned resid norm 8.712487270514e+00 true resid norm 8.712487270515e+00 ||r(i)||/||b|| 2.081619495721e-04
1330 KSP unpreconditioned resid norm 8.712487269291e+00 true resid norm 8.712487269283e+00 ||r(i)||/||b|| 2.081619495427e-04
1331 KSP unpreconditioned resid norm 8.712487268966e+00 true resid norm 8.712487268967e+00 ||r(i)||/||b|| 2.081619495352e-04
1332 KSP unpreconditioned resid norm 8.712487268934e+00 true resid norm 8.712487268938e+00 ||r(i)||/||b|| 2.081619495345e-04
1333 KSP unpreconditioned resid norm 8.712487267499e+00 true resid norm 8.712487267497e+00 ||r(i)||/||b|| 2.081619495000e-04
1334 KSP unpreconditioned resid norm 8.712487265190e+00 true resid norm 8.712487265187e+00 ||r(i)||/||b|| 2.081619494449e-04
1335 KSP unpreconditioned resid norm 8.712487261734e+00 true resid norm 8.712487261727e+00 ||r(i)||/||b|| 2.081619493622e-04
1336 KSP unpreconditioned resid norm 8.712487259702e+00 true resid norm 8.712487259690e+00 ||r(i)||/||b|| 2.081619493135e-04
1337 KSP unpreconditioned resid norm 8.712487258030e+00 true resid norm 8.712487258017e+00 ||r(i)||/||b|| 2.081619492735e-04
1338 KSP unpreconditioned resid norm 8.712487256160e+00 true resid norm 8.712487256153e+00 ||r(i)||/||b|| 2.081619492290e-04
1339 KSP unpreconditioned resid norm 8.712487254597e+00 true resid norm 8.712487254599e+00 ||r(i)||/||b|| 2.081619491919e-04
1340 KSP unpreconditioned resid norm 8.712487254531e+00 true resid norm 8.712487254530e+00 ||r(i)||/||b|| 2.081619491902e-04
1341 KSP unpreconditioned resid norm 8.712487254301e+00 true resid norm 8.712487254292e+00 ||r(i)||/||b|| 2.081619491845e-04
1342 KSP unpreconditioned resid norm 8.712487252271e+00 true resid norm 8.712487252267e+00 ||r(i)||/||b|| 2.081619491362e-04
1343 KSP unpreconditioned resid norm 8.712487241798e+00 true resid norm 8.712487241792e+00 ||r(i)||/||b|| 2.081619488859e-04
1344 KSP unpreconditioned resid norm 8.712487227808e+00 true resid norm 8.712487227802e+00 ||r(i)||/||b|| 2.081619485516e-04
1345 KSP unpreconditioned resid norm 8.712487216650e+00 true resid norm 8.712487216641e+00 ||r(i)||/||b|| 2.081619482850e-04
1346 KSP unpreconditioned resid norm 8.712487203226e+00 true resid norm 8.712487203225e+00 ||r(i)||/||b|| 2.081619479644e-04
1347 KSP unpreconditioned resid norm 8.712487182714e+00 true resid norm 8.712487182709e+00 ||r(i)||/||b|| 2.081619474743e-04
1348 KSP unpreconditioned resid norm 8.712487133680e+00 true resid norm 8.712487133683e+00 ||r(i)||/||b|| 2.081619463029e-04
1349 KSP unpreconditioned resid norm 8.712487108099e+00 true resid norm 8.712487108097e+00 ||r(i)||/||b|| 2.081619456916e-04
1350 KSP unpreconditioned resid norm 8.712487106485e+00 true resid norm 8.712487106485e+00 ||r(i)||/||b|| 2.081619456531e-04
1351 KSP unpreconditioned resid norm 8.712487106479e+00 true resid norm 8.712487106480e+00 ||r(i)||/||b|| 2.081619456530e-04
1352 KSP unpreconditioned resid norm 8.712487106377e+00 true resid norm 8.712487106383e+00 ||r(i)||/||b|| 2.081619456507e-04
1353 KSP unpreconditioned resid norm 8.712487105857e+00 true resid norm 8.712487105852e+00 ||r(i)||/||b|| 2.081619456380e-04
1354 KSP unpreconditioned resid norm 8.712487104677e+00 true resid norm 8.712487104678e+00 ||r(i)||/||b|| 2.081619456099e-04
1355 KSP unpreconditioned resid norm 8.712487103254e+00 true resid norm 8.712487103245e+00 ||r(i)||/||b|| 2.081619455757e-04
1356 KSP unpreconditioned resid norm 8.712487102842e+00 true resid norm 8.712487102845e+00 ||r(i)||/||b|| 2.081619455661e-04
1357 KSP unpreconditioned resid norm 8.712487102642e+00 true resid norm 8.712487102634e+00 ||r(i)||/||b|| 2.081619455611e-04
1358 KSP unpreconditioned resid norm 8.712487101996e+00 true resid norm 8.712487101991e+00 ||r(i)||/||b|| 2.081619455457e-04
1359 KSP unpreconditioned resid norm 8.712487100693e+00 true resid norm 8.712487100694e+00 ||r(i)||/||b|| 2.081619455147e-04
1360 KSP unpreconditioned resid norm 8.712487099538e+00 true resid norm 8.712487099525e+00 ||r(i)||/||b|| 2.081619454868e-04
1361 KSP unpreconditioned resid norm 8.712487099256e+00 true resid norm 8.712487099249e+00 ||r(i)||/||b|| 2.081619454802e-04
1362 KSP unpreconditioned resid norm 8.712487099230e+00 true resid norm 8.712487099226e+00 ||r(i)||/||b|| 2.081619454797e-04
1363 KSP unpreconditioned resid norm 8.712487097994e+00 true resid norm 8.712487097985e+00 ||r(i)||/||b|| 2.081619454500e-04
1364 KSP unpreconditioned resid norm 8.712487095912e+00 true resid norm 8.712487095911e+00 ||r(i)||/||b|| 2.081619454004e-04
1365 KSP unpreconditioned resid norm 8.712487093021e+00 true resid norm 8.712487093008e+00 ||r(i)||/||b|| 2.081619453311e-04
1366 KSP unpreconditioned resid norm 8.712487091278e+00 true resid norm 8.712487091288e+00 ||r(i)||/||b|| 2.081619452900e-04
1367 KSP unpreconditioned resid norm 8.712487089727e+00 true resid norm 8.712487089729e+00 ||r(i)||/||b|| 2.081619452528e-04
1368 KSP unpreconditioned resid norm 8.712487088181e+00 true resid norm 8.712487088180e+00 ||r(i)||/||b|| 2.081619452157e-04
1369 KSP unpreconditioned resid norm 8.712487086706e+00 true resid norm 8.712487086704e+00 ||r(i)||/||b|| 2.081619451805e-04
1370 KSP unpreconditioned resid norm 8.712487086629e+00 true resid norm 8.712487086627e+00 ||r(i)||/||b|| 2.081619451786e-04
1371 KSP unpreconditioned resid norm 8.712487086411e+00 true resid norm 8.712487086401e+00 ||r(i)||/||b|| 2.081619451732e-04
1372 KSP unpreconditioned resid norm 8.712487084763e+00 true resid norm 8.712487084761e+00 ||r(i)||/||b|| 2.081619451340e-04
1373 KSP unpreconditioned resid norm 8.712487076017e+00 true resid norm 8.712487076012e+00 ||r(i)||/||b|| 2.081619449250e-04
1374 KSP unpreconditioned resid norm 8.712487063965e+00 true resid norm 8.712487063965e+00 ||r(i)||/||b|| 2.081619446372e-04
1375 KSP unpreconditioned resid norm 8.712487055038e+00 true resid norm 8.712487055043e+00 ||r(i)||/||b|| 2.081619444240e-04
1376 KSP unpreconditioned resid norm 8.712487043796e+00 true resid norm 8.712487043799e+00 ||r(i)||/||b|| 2.081619441554e-04
1377 KSP unpreconditioned resid norm 8.712487025410e+00 true resid norm 8.712487025418e+00 ||r(i)||/||b|| 2.081619437162e-04
1378 KSP unpreconditioned resid norm 8.712486981951e+00 true resid norm 8.712486981949e+00 ||r(i)||/||b|| 2.081619426776e-04
1379 KSP unpreconditioned resid norm 8.712486957939e+00 true resid norm 8.712486957943e+00 ||r(i)||/||b|| 2.081619421041e-04
1380 KSP unpreconditioned resid norm 8.712486955984e+00 true resid norm 8.712486955984e+00 ||r(i)||/||b|| 2.081619420573e-04
1381 KSP unpreconditioned resid norm 8.712486955976e+00 true resid norm 8.712486955982e+00 ||r(i)||/||b|| 2.081619420572e-04
1382 KSP unpreconditioned resid norm 8.712486955870e+00 true resid norm 8.712486955864e+00 ||r(i)||/||b|| 2.081619420544e-04
1383 KSP unpreconditioned resid norm 8.712486955381e+00 true resid norm 8.712486955380e+00 ||r(i)||/||b|| 2.081619420428e-04
1384 KSP unpreconditioned resid norm 8.712486954326e+00 true resid norm 8.712486954319e+00 ||r(i)||/||b|| 2.081619420175e-04
1385 KSP unpreconditioned resid norm 8.712486953079e+00 true resid norm 8.712486953085e+00 ||r(i)||/||b|| 2.081619419880e-04
1386 KSP unpreconditioned resid norm 8.712486952707e+00 true resid norm 8.712486952711e+00 ||r(i)||/||b|| 2.081619419791e-04
1387 KSP unpreconditioned resid norm 8.712486952509e+00 true resid norm 8.712486952516e+00 ||r(i)||/||b|| 2.081619419744e-04
1388 KSP unpreconditioned resid norm 8.712486951897e+00 true resid norm 8.712486951891e+00 ||r(i)||/||b|| 2.081619419595e-04
1389 KSP unpreconditioned resid norm 8.712486950782e+00 true resid norm 8.712486950795e+00 ||r(i)||/||b|| 2.081619419333e-04
1390 KSP unpreconditioned resid norm 8.712486949819e+00 true resid norm 8.712486949822e+00 ||r(i)||/||b|| 2.081619419100e-04
1391 KSP unpreconditioned resid norm 8.712486949566e+00 true resid norm 8.712486949571e+00 ||r(i)||/||b|| 2.081619419040e-04
1392 KSP unpreconditioned resid norm 8.712486949541e+00 true resid norm 8.712486949545e+00 ||r(i)||/||b|| 2.081619419034e-04
1393 KSP unpreconditioned resid norm 8.712486948422e+00 true resid norm 8.712486948423e+00 ||r(i)||/||b|| 2.081619418766e-04
1394 KSP unpreconditioned resid norm 8.712486946610e+00 true resid norm 8.712486946609e+00 ||r(i)||/||b|| 2.081619418333e-04
1395 KSP unpreconditioned resid norm 8.712486943919e+00 true resid norm 8.712486943913e+00 ||r(i)||/||b|| 2.081619417689e-04
1396 KSP unpreconditioned resid norm 8.712486942336e+00 true resid norm 8.712486942340e+00 ||r(i)||/||b|| 2.081619417313e-04
1397 KSP unpreconditioned resid norm 8.712486941022e+00 true resid norm 8.712486941013e+00 ||r(i)||/||b|| 2.081619416996e-04
1398 KSP unpreconditioned resid norm 8.712486939572e+00 true resid norm 8.712486939577e+00 ||r(i)||/||b|| 2.081619416653e-04
1399 KSP unpreconditioned resid norm 8.712486938341e+00 true resid norm 8.712486938349e+00 ||r(i)||/||b|| 2.081619416359e-04
1400 KSP unpreconditioned resid norm 8.712486938288e+00 true resid norm 8.712486938282e+00 ||r(i)||/||b|| 2.081619416343e-04
1401 KSP unpreconditioned resid norm 8.712486938105e+00 true resid norm 8.712486938104e+00 ||r(i)||/||b|| 2.081619416301e-04
1402 KSP unpreconditioned resid norm 8.712486936530e+00 true resid norm 8.712486936532e+00 ||r(i)||/||b|| 2.081619415925e-04
1403 KSP unpreconditioned resid norm 8.712486928386e+00 true resid norm 8.712486928388e+00 ||r(i)||/||b|| 2.081619413979e-04
1404 KSP unpreconditioned resid norm 8.712486917441e+00 true resid norm 8.712486917432e+00 ||r(i)||/||b|| 2.081619411362e-04
1405 KSP unpreconditioned resid norm 8.712486908802e+00 true resid norm 8.712486908801e+00 ||r(i)||/||b|| 2.081619409300e-04
1406 KSP unpreconditioned resid norm 8.712486898336e+00 true resid norm 8.712486898350e+00 ||r(i)||/||b|| 2.081619406802e-04
1407 KSP unpreconditioned resid norm 8.712486882233e+00 true resid norm 8.712486882228e+00 ||r(i)||/||b|| 2.081619402951e-04
1408 KSP unpreconditioned resid norm 8.712486843844e+00 true resid norm 8.712486843853e+00 ||r(i)||/||b|| 2.081619393782e-04
1409 KSP unpreconditioned resid norm 8.712486823690e+00 true resid norm 8.712486823687e+00 ||r(i)||/||b|| 2.081619388964e-04
1410 KSP unpreconditioned resid norm 8.712486822389e+00 true resid norm 8.712486822389e+00 ||r(i)||/||b|| 2.081619388654e-04
1411 KSP unpreconditioned resid norm 8.712486822383e+00 true resid norm 8.712486822387e+00 ||r(i)||/||b|| 2.081619388653e-04
1412 KSP unpreconditioned resid norm 8.712486822303e+00 true resid norm 8.712486822305e+00 ||r(i)||/||b|| 2.081619388633e-04
1413 KSP unpreconditioned resid norm 8.712486821894e+00 true resid norm 8.712486821903e+00 ||r(i)||/||b|| 2.081619388538e-04
1414 KSP unpreconditioned resid norm 8.712486820969e+00 true resid norm 8.712486820969e+00 ||r(i)||/||b|| 2.081619388314e-04
1415 KSP unpreconditioned resid norm 8.712486819857e+00 true resid norm 8.712486819861e+00 ||r(i)||/||b|| 2.081619388050e-04
1416 KSP unpreconditioned resid norm 8.712486819535e+00 true resid norm 8.712486819537e+00 ||r(i)||/||b|| 2.081619387972e-04
1417 KSP unpreconditioned resid norm 8.712486819378e+00 true resid norm 8.712486819374e+00 ||r(i)||/||b|| 2.081619387933e-04
1418 KSP unpreconditioned resid norm 8.712486818871e+00 true resid norm 8.712486818887e+00 ||r(i)||/||b|| 2.081619387817e-04
1419 KSP unpreconditioned resid norm 8.712486817853e+00 true resid norm 8.712486817854e+00 ||r(i)||/||b|| 2.081619387570e-04
1420 KSP unpreconditioned resid norm 8.712486816953e+00 true resid norm 8.712486816957e+00 ||r(i)||/||b|| 2.081619387356e-04
1421 KSP unpreconditioned resid norm 8.712486816731e+00 true resid norm 8.712486816741e+00 ||r(i)||/||b|| 2.081619387304e-04
1422 KSP unpreconditioned resid norm 8.712486816711e+00 true resid norm 8.712486816728e+00 ||r(i)||/||b|| 2.081619387301e-04
1423 KSP unpreconditioned resid norm 8.712486815742e+00 true resid norm 8.712486815741e+00 ||r(i)||/||b|| 2.081619387065e-04
1424 KSP unpreconditioned resid norm 8.712486814118e+00 true resid norm 8.712486814124e+00 ||r(i)||/||b|| 2.081619386679e-04
1425 KSP unpreconditioned resid norm 8.712486811850e+00 true resid norm 8.712486811849e+00 ||r(i)||/||b|| 2.081619386135e-04
1426 KSP unpreconditioned resid norm 8.712486810484e+00 true resid norm 8.712486810493e+00 ||r(i)||/||b|| 2.081619385811e-04
1427 KSP unpreconditioned resid norm 8.712486809277e+00 true resid norm 8.712486809282e+00 ||r(i)||/||b|| 2.081619385522e-04
1428 KSP unpreconditioned resid norm 8.712486808061e+00 true resid norm 8.712486808069e+00 ||r(i)||/||b|| 2.081619385232e-04
1429 KSP unpreconditioned resid norm 8.712486806911e+00 true resid norm 8.712486806922e+00 ||r(i)||/||b|| 2.081619384958e-04
1430 KSP unpreconditioned resid norm 8.712486806852e+00 true resid norm 8.712486806862e+00 ||r(i)||/||b|| 2.081619384944e-04
1431 KSP unpreconditioned resid norm 8.712486806683e+00 true resid norm 8.712486806691e+00 ||r(i)||/||b|| 2.081619384903e-04
1432 KSP unpreconditioned resid norm 8.712486805388e+00 true resid norm 8.712486805398e+00 ||r(i)||/||b|| 2.081619384594e-04
1433 KSP unpreconditioned resid norm 8.712486798526e+00 true resid norm 8.712486798525e+00 ||r(i)||/||b|| 2.081619382952e-04
1434 KSP unpreconditioned resid norm 8.712486789112e+00 true resid norm 8.712486789121e+00 ||r(i)||/||b|| 2.081619380705e-04
1435 KSP unpreconditioned resid norm 8.712486782080e+00 true resid norm 8.712486782084e+00 ||r(i)||/||b|| 2.081619379024e-04
1436 KSP unpreconditioned resid norm 8.712486773262e+00 true resid norm 8.712486773264e+00 ||r(i)||/||b|| 2.081619376917e-04
1437 KSP unpreconditioned resid norm 8.712486758899e+00 true resid norm 8.712486758888e+00 ||r(i)||/||b|| 2.081619373482e-04
1438 KSP unpreconditioned resid norm 8.712486724823e+00 true resid norm 8.712486724826e+00 ||r(i)||/||b|| 2.081619365344e-04
1439 KSP unpreconditioned resid norm 8.712486706071e+00 true resid norm 8.712486706061e+00 ||r(i)||/||b|| 2.081619360860e-04
1440 KSP unpreconditioned resid norm 8.712486704580e+00 true resid norm 8.712486704580e+00 ||r(i)||/||b|| 2.081619360506e-04
1441 KSP unpreconditioned resid norm 8.712486704573e+00 true resid norm 8.712486704569e+00 ||r(i)||/||b|| 2.081619360504e-04
1442 KSP unpreconditioned resid norm 8.712486704491e+00 true resid norm 8.712486704478e+00 ||r(i)||/||b|| 2.081619360482e-04
1443 KSP unpreconditioned resid norm 8.712486704110e+00 true resid norm 8.712486704108e+00 ||r(i)||/||b|| 2.081619360394e-04
1444 KSP unpreconditioned resid norm 8.712486703284e+00 true resid norm 8.712486703280e+00 ||r(i)||/||b|| 2.081619360196e-04
1445 KSP unpreconditioned resid norm 8.712486702308e+00 true resid norm 8.712486702299e+00 ||r(i)||/||b|| 2.081619359961e-04
1446 KSP unpreconditioned resid norm 8.712486702018e+00 true resid norm 8.712486702009e+00 ||r(i)||/||b|| 2.081619359892e-04
1447 KSP unpreconditioned resid norm 8.712486701865e+00 true resid norm 8.712486701861e+00 ||r(i)||/||b|| 2.081619359857e-04
1448 KSP unpreconditioned resid norm 8.712486701389e+00 true resid norm 8.712486701379e+00 ||r(i)||/||b|| 2.081619359742e-04
1449 KSP unpreconditioned resid norm 8.712486700514e+00 true resid norm 8.712486700515e+00 ||r(i)||/||b|| 2.081619359535e-04
1450 KSP unpreconditioned resid norm 8.712486699757e+00 true resid norm 8.712486699750e+00 ||r(i)||/||b|| 2.081619359352e-04
1451 KSP unpreconditioned resid norm 8.712486699560e+00 true resid norm 8.712486699552e+00 ||r(i)||/||b|| 2.081619359305e-04
1452 KSP unpreconditioned resid norm 8.712486699540e+00 true resid norm 8.712486699538e+00 ||r(i)||/||b|| 2.081619359302e-04
1453 KSP unpreconditioned resid norm 8.712486698667e+00 true resid norm 8.712486698665e+00 ||r(i)||/||b|| 2.081619359093e-04
1454 KSP unpreconditioned resid norm 8.712486697248e+00 true resid norm 8.712486697238e+00 ||r(i)||/||b|| 2.081619358752e-04
1455 KSP unpreconditioned resid norm 8.712486695150e+00 true resid norm 8.712486695136e+00 ||r(i)||/||b|| 2.081619358250e-04
1456 KSP unpreconditioned resid norm 8.712486693915e+00 true resid norm 8.712486693910e+00 ||r(i)||/||b|| 2.081619357957e-04
1457 KSP unpreconditioned resid norm 8.712486692884e+00 true resid norm 8.712486692879e+00 ||r(i)||/||b|| 2.081619357711e-04
1458 KSP unpreconditioned resid norm 8.712486691756e+00 true resid norm 8.712486691752e+00 ||r(i)||/||b|| 2.081619357441e-04
1459 KSP unpreconditioned resid norm 8.712486690789e+00 true resid norm 8.712486690781e+00 ||r(i)||/||b|| 2.081619357209e-04
1460 KSP unpreconditioned resid norm 8.712486690747e+00 true resid norm 8.712486690739e+00 ||r(i)||/||b|| 2.081619357199e-04
1461 KSP unpreconditioned resid norm 8.712486690602e+00 true resid norm 8.712486690586e+00 ||r(i)||/||b|| 2.081619357163e-04
1462 KSP unpreconditioned resid norm 8.712486689378e+00 true resid norm 8.712486689375e+00 ||r(i)||/||b|| 2.081619356873e-04
1463 KSP unpreconditioned resid norm 8.712486683035e+00 true resid norm 8.712486683035e+00 ||r(i)||/||b|| 2.081619355359e-04
1464 KSP unpreconditioned resid norm 8.712486674483e+00 true resid norm 8.712486674479e+00 ||r(i)||/||b|| 2.081619353314e-04
1465 KSP unpreconditioned resid norm 8.712486667776e+00 true resid norm 8.712486667775e+00 ||r(i)||/||b|| 2.081619351713e-04
1466 KSP unpreconditioned resid norm 8.712486659614e+00 true resid norm 8.712486659599e+00 ||r(i)||/||b|| 2.081619349759e-04
1467 KSP unpreconditioned resid norm 8.712486646989e+00 true resid norm 8.712486646980e+00 ||r(i)||/||b|| 2.081619346744e-04
1468 KSP unpreconditioned resid norm 8.712486616933e+00 true resid norm 8.712486616931e+00 ||r(i)||/||b|| 2.081619339565e-04
1469 KSP unpreconditioned resid norm 8.712486601081e+00 true resid norm 8.712486601069e+00 ||r(i)||/||b|| 2.081619335775e-04
1470 KSP unpreconditioned resid norm 8.712486600032e+00 true resid norm 8.712486600032e+00 ||r(i)||/||b|| 2.081619335527e-04
1471 KSP unpreconditioned resid norm 8.712486600028e+00 true resid norm 8.712486600032e+00 ||r(i)||/||b|| 2.081619335527e-04
1472 KSP unpreconditioned resid norm 8.712486599965e+00 true resid norm 8.712486599972e+00 ||r(i)||/||b|| 2.081619335513e-04
1473 KSP unpreconditioned resid norm 8.712486599643e+00 true resid norm 8.712486599653e+00 ||r(i)||/||b|| 2.081619335437e-04
1474 KSP unpreconditioned resid norm 8.712486598919e+00 true resid norm 8.712486598923e+00 ||r(i)||/||b|| 2.081619335262e-04
1475 KSP unpreconditioned resid norm 8.712486598049e+00 true resid norm 8.712486598055e+00 ||r(i)||/||b|| 2.081619335055e-04
1476 KSP unpreconditioned resid norm 8.712486597797e+00 true resid norm 8.712486597794e+00 ||r(i)||/||b|| 2.081619334993e-04
1477 KSP unpreconditioned resid norm 8.712486597674e+00 true resid norm 8.712486597678e+00 ||r(i)||/||b|| 2.081619334965e-04
1478 KSP unpreconditioned resid norm 8.712486597276e+00 true resid norm 8.712486597285e+00 ||r(i)||/||b|| 2.081619334871e-04
1479 KSP unpreconditioned resid norm 8.712486596482e+00 true resid norm 8.712486596487e+00 ||r(i)||/||b|| 2.081619334680e-04
1480 KSP unpreconditioned resid norm 8.712486595780e+00 true resid norm 8.712486595789e+00 ||r(i)||/||b|| 2.081619334513e-04
1481 KSP unpreconditioned resid norm 8.712486595606e+00 true resid norm 8.712486595612e+00 ||r(i)||/||b|| 2.081619334471e-04
1482 KSP unpreconditioned resid norm 8.712486595590e+00 true resid norm 8.712486595600e+00 ||r(i)||/||b|| 2.081619334468e-04
1483 KSP unpreconditioned resid norm 8.712486594831e+00 true resid norm 8.712486594841e+00 ||r(i)||/||b|| 2.081619334287e-04
1484 KSP unpreconditioned resid norm 8.712486593563e+00 true resid norm 8.712486593565e+00 ||r(i)||/||b|| 2.081619333982e-04
1485 KSP unpreconditioned resid norm 8.712486591784e+00 true resid norm 8.712486591780e+00 ||r(i)||/||b|| 2.081619333556e-04
1486 KSP unpreconditioned resid norm 8.712486590714e+00 true resid norm 8.712486590716e+00 ||r(i)||/||b|| 2.081619333301e-04
1487 KSP unpreconditioned resid norm 8.712486589774e+00 true resid norm 8.712486589778e+00 ||r(i)||/||b|| 2.081619333077e-04
1488 KSP unpreconditioned resid norm 8.712486588818e+00 true resid norm 8.712486588807e+00 ||r(i)||/||b|| 2.081619332845e-04
1489 KSP unpreconditioned resid norm 8.712486587922e+00 true resid norm 8.712486587929e+00 ||r(i)||/||b|| 2.081619332636e-04
1490 KSP unpreconditioned resid norm 8.712486587876e+00 true resid norm 8.712486587884e+00 ||r(i)||/||b|| 2.081619332625e-04
1491 KSP unpreconditioned resid norm 8.712486587745e+00 true resid norm 8.712486587750e+00 ||r(i)||/||b|| 2.081619332593e-04
1492 KSP unpreconditioned resid norm 8.712486586728e+00 true resid norm 8.712486586732e+00 ||r(i)||/||b|| 2.081619332350e-04
1493 KSP unpreconditioned resid norm 8.712486581348e+00 true resid norm 8.712486581351e+00 ||r(i)||/||b|| 2.081619331064e-04
1494 KSP unpreconditioned resid norm 8.712486573987e+00 true resid norm 8.712486573985e+00 ||r(i)||/||b|| 2.081619329304e-04
1495 KSP unpreconditioned resid norm 8.712486568457e+00 true resid norm 8.712486568465e+00 ||r(i)||/||b|| 2.081619327985e-04
1496 KSP unpreconditioned resid norm 8.712486561543e+00 true resid norm 8.712486561539e+00 ||r(i)||/||b|| 2.081619326330e-04
1497 KSP unpreconditioned resid norm 8.712486550314e+00 true resid norm 8.712486550313e+00 ||r(i)||/||b|| 2.081619323648e-04
1498 KSP unpreconditioned resid norm 8.712486523621e+00 true resid norm 8.712486523621e+00 ||r(i)||/||b|| 2.081619317271e-04
1499 KSP unpreconditioned resid norm 8.712486508974e+00 true resid norm 8.712486508974e+00 ||r(i)||/||b|| 2.081619313771e-04
1500 KSP unpreconditioned resid norm 8.712486507813e+00 true resid norm 8.712486507813e+00 ||r(i)||/||b|| 2.081619313494e-04
1501 KSP unpreconditioned resid norm 8.712486507808e+00 true resid norm 8.712486507810e+00 ||r(i)||/||b|| 2.081619313493e-04
1502 KSP unpreconditioned resid norm 8.712486507744e+00 true resid norm 8.712486507740e+00 ||r(i)||/||b|| 2.081619313476e-04
1503 KSP unpreconditioned resid norm 8.712486507447e+00 true resid norm 8.712486507447e+00 ||r(i)||/||b|| 2.081619313406e-04
1504 KSP unpreconditioned resid norm 8.712486506800e+00 true resid norm 8.712486506811e+00 ||r(i)||/||b|| 2.081619313255e-04
1505 KSP unpreconditioned resid norm 8.712486506037e+00 true resid norm 8.712486506035e+00 ||r(i)||/||b|| 2.081619313069e-04
1506 KSP unpreconditioned resid norm 8.712486505810e+00 true resid norm 8.712486505804e+00 ||r(i)||/||b|| 2.081619313014e-04
1507 KSP unpreconditioned resid norm 8.712486505692e+00 true resid norm 8.712486505686e+00 ||r(i)||/||b|| 2.081619312986e-04
1508 KSP unpreconditioned resid norm 8.712486505321e+00 true resid norm 8.712486505327e+00 ||r(i)||/||b|| 2.081619312900e-04
1509 KSP unpreconditioned resid norm 8.712486504636e+00 true resid norm 8.712486504635e+00 ||r(i)||/||b|| 2.081619312735e-04
1510 KSP unpreconditioned resid norm 8.712486504042e+00 true resid norm 8.712486504046e+00 ||r(i)||/||b|| 2.081619312594e-04
1511 KSP unpreconditioned resid norm 8.712486503887e+00 true resid norm 8.712486503893e+00 ||r(i)||/||b|| 2.081619312557e-04
1512 KSP unpreconditioned resid norm 8.712486503872e+00 true resid norm 8.712486503878e+00 ||r(i)||/||b|| 2.081619312554e-04
1513 KSP unpreconditioned resid norm 8.712486503190e+00 true resid norm 8.712486503195e+00 ||r(i)||/||b|| 2.081619312391e-04
1514 KSP unpreconditioned resid norm 8.712486502079e+00 true resid norm 8.712486502082e+00 ||r(i)||/||b|| 2.081619312125e-04
1515 KSP unpreconditioned resid norm 8.712486500443e+00 true resid norm 8.712486500452e+00 ||r(i)||/||b|| 2.081619311735e-04
1516 KSP unpreconditioned resid norm 8.712486499479e+00 true resid norm 8.712486499480e+00 ||r(i)||/||b|| 2.081619311503e-04
1517 KSP unpreconditioned resid norm 8.712486498671e+00 true resid norm 8.712486498679e+00 ||r(i)||/||b|| 2.081619311312e-04
1518 KSP unpreconditioned resid norm 8.712486497792e+00 true resid norm 8.712486497795e+00 ||r(i)||/||b|| 2.081619311100e-04
1519 KSP unpreconditioned resid norm 8.712486497033e+00 true resid norm 8.712486497036e+00 ||r(i)||/||b|| 2.081619310919e-04
1520 KSP unpreconditioned resid norm 8.712486496999e+00 true resid norm 8.712486497007e+00 ||r(i)||/||b|| 2.081619310912e-04
1521 KSP unpreconditioned resid norm 8.712486496885e+00 true resid norm 8.712486496888e+00 ||r(i)||/||b|| 2.081619310884e-04
1522 KSP unpreconditioned resid norm 8.712486495932e+00 true resid norm 8.712486495937e+00 ||r(i)||/||b|| 2.081619310657e-04
1523 KSP unpreconditioned resid norm 8.712486490989e+00 true resid norm 8.712486490985e+00 ||r(i)||/||b|| 2.081619309473e-04
1524 KSP unpreconditioned resid norm 8.712486484309e+00 true resid norm 8.712486484303e+00 ||r(i)||/||b|| 2.081619307877e-04
1525 KSP unpreconditioned resid norm 8.712486479093e+00 true resid norm 8.712486479095e+00 ||r(i)||/||b|| 2.081619306632e-04
1526 KSP unpreconditioned resid norm 8.712486472726e+00 true resid norm 8.712486472725e+00 ||r(i)||/||b|| 2.081619305111e-04
1527 KSP unpreconditioned resid norm 8.712486462836e+00 true resid norm 8.712486462844e+00 ||r(i)||/||b|| 2.081619302750e-04
1528 KSP unpreconditioned resid norm 8.712486439306e+00 true resid norm 8.712486439302e+00 ||r(i)||/||b|| 2.081619297125e-04
1529 KSP unpreconditioned resid norm 8.712486426852e+00 true resid norm 8.712486426857e+00 ||r(i)||/||b|| 2.081619294152e-04
1530 KSP unpreconditioned resid norm 8.712486426034e+00 true resid norm 8.712486426034e+00 ||r(i)||/||b|| 2.081619293955e-04
1531 KSP unpreconditioned resid norm 8.712486426031e+00 true resid norm 8.712486426032e+00 ||r(i)||/||b|| 2.081619293955e-04
1532 KSP unpreconditioned resid norm 8.712486425981e+00 true resid norm 8.712486425986e+00 ||r(i)||/||b|| 2.081619293944e-04
1533 KSP unpreconditioned resid norm 8.712486425729e+00 true resid norm 8.712486425723e+00 ||r(i)||/||b|| 2.081619293881e-04
1534 KSP unpreconditioned resid norm 8.712486425162e+00 true resid norm 8.712486425168e+00 ||r(i)||/||b|| 2.081619293748e-04
1535 KSP unpreconditioned resid norm 8.712486424482e+00 true resid norm 8.712486424487e+00 ||r(i)||/||b|| 2.081619293585e-04
1536 KSP unpreconditioned resid norm 8.712486424285e+00 true resid norm 8.712486424274e+00 ||r(i)||/||b|| 2.081619293535e-04
1537 KSP unpreconditioned resid norm 8.712486424188e+00 true resid norm 8.712486424180e+00 ||r(i)||/||b|| 2.081619293512e-04
1538 KSP unpreconditioned resid norm 8.712486423876e+00 true resid norm 8.712486423875e+00 ||r(i)||/||b|| 2.081619293439e-04
1539 KSP unpreconditioned resid norm 8.712486423255e+00 true resid norm 8.712486423257e+00 ||r(i)||/||b|| 2.081619293291e-04
1540 KSP unpreconditioned resid norm 8.712486422708e+00 true resid norm 8.712486422703e+00 ||r(i)||/||b|| 2.081619293159e-04
1541 KSP unpreconditioned resid norm 8.712486422572e+00 true resid norm 8.712486422575e+00 ||r(i)||/||b|| 2.081619293129e-04
1542 KSP unpreconditioned resid norm 8.712486422559e+00 true resid norm 8.712486422556e+00 ||r(i)||/||b|| 2.081619293124e-04
1543 KSP unpreconditioned resid norm 8.712486421965e+00 true resid norm 8.712486421966e+00 ||r(i)||/||b|| 2.081619292983e-04
1544 KSP unpreconditioned resid norm 8.712486420974e+00 true resid norm 8.712486420978e+00 ||r(i)||/||b|| 2.081619292747e-04
1545 KSP unpreconditioned resid norm 8.712486419580e+00 true resid norm 8.712486419575e+00 ||r(i)||/||b|| 2.081619292412e-04
1546 KSP unpreconditioned resid norm 8.712486418742e+00 true resid norm 8.712486418738e+00 ||r(i)||/||b|| 2.081619292212e-04
1547 KSP unpreconditioned resid norm 8.712486418009e+00 true resid norm 8.712486418006e+00 ||r(i)||/||b|| 2.081619292037e-04
1548 KSP unpreconditioned resid norm 8.712486417259e+00 true resid norm 8.712486417265e+00 ||r(i)||/||b|| 2.081619291860e-04
1549 KSP unpreconditioned resid norm 8.712486416559e+00 true resid norm 8.712486416549e+00 ||r(i)||/||b|| 2.081619291689e-04
1550 KSP unpreconditioned resid norm 8.712486416524e+00 true resid norm 8.712486416521e+00 ||r(i)||/||b|| 2.081619291682e-04
1551 KSP unpreconditioned resid norm 8.712486416422e+00 true resid norm 8.712486416423e+00 ||r(i)||/||b|| 2.081619291659e-04
1552 KSP unpreconditioned resid norm 8.712486415624e+00 true resid norm 8.712486415625e+00 ||r(i)||/||b|| 2.081619291468e-04
1553 KSP unpreconditioned resid norm 8.712486411407e+00 true resid norm 8.712486411404e+00 ||r(i)||/||b|| 2.081619290460e-04
1554 KSP unpreconditioned resid norm 8.712486405648e+00 true resid norm 8.712486405639e+00 ||r(i)||/||b|| 2.081619289082e-04
1555 KSP unpreconditioned resid norm 8.712486401305e+00 true resid norm 8.712486401307e+00 ||r(i)||/||b|| 2.081619288047e-04
1556 KSP unpreconditioned resid norm 8.712486395884e+00 true resid norm 8.712486395885e+00 ||r(i)||/||b|| 2.081619286752e-04
1557 KSP unpreconditioned resid norm 8.712486387103e+00 true resid norm 8.712486387101e+00 ||r(i)||/||b|| 2.081619284653e-04
1558 KSP unpreconditioned resid norm 8.712486366206e+00 true resid norm 8.712486366202e+00 ||r(i)||/||b|| 2.081619279660e-04
1559 KSP unpreconditioned resid norm 8.712486354764e+00 true resid norm 8.712486354758e+00 ||r(i)||/||b|| 2.081619276926e-04
1560 KSP unpreconditioned resid norm 8.712486353863e+00 true resid norm 8.712486353863e+00 ||r(i)||/||b|| 2.081619276712e-04
1561 KSP unpreconditioned resid norm 8.712486353860e+00 true resid norm 8.712486353861e+00 ||r(i)||/||b|| 2.081619276711e-04
1562 KSP unpreconditioned resid norm 8.712486353810e+00 true resid norm 8.712486353808e+00 ||r(i)||/||b|| 2.081619276698e-04
1563 KSP unpreconditioned resid norm 8.712486353578e+00 true resid norm 8.712486353576e+00 ||r(i)||/||b|| 2.081619276643e-04
1564 KSP unpreconditioned resid norm 8.712486353072e+00 true resid norm 8.712486353069e+00 ||r(i)||/||b|| 2.081619276522e-04
1565 KSP unpreconditioned resid norm 8.712486352475e+00 true resid norm 8.712486352470e+00 ||r(i)||/||b|| 2.081619276379e-04
1566 KSP unpreconditioned resid norm 8.712486352298e+00 true resid norm 8.712486352305e+00 ||r(i)||/||b|| 2.081619276339e-04
1567 KSP unpreconditioned resid norm 8.712486352206e+00 true resid norm 8.712486352207e+00 ||r(i)||/||b|| 2.081619276316e-04
1568 KSP unpreconditioned resid norm 8.712486351917e+00 true resid norm 8.712486351911e+00 ||r(i)||/||b|| 2.081619276245e-04
1569 KSP unpreconditioned resid norm 8.712486351380e+00 true resid norm 8.712486351376e+00 ||r(i)||/||b|| 2.081619276117e-04
1570 KSP unpreconditioned resid norm 8.712486350914e+00 true resid norm 8.712486350912e+00 ||r(i)||/||b|| 2.081619276007e-04
1571 KSP unpreconditioned resid norm 8.712486350793e+00 true resid norm 8.712486350786e+00 ||r(i)||/||b|| 2.081619275977e-04
1572 KSP unpreconditioned resid norm 8.712486350781e+00 true resid norm 8.712486350778e+00 ||r(i)||/||b|| 2.081619275975e-04
1573 KSP unpreconditioned resid norm 8.712486350249e+00 true resid norm 8.712486350253e+00 ||r(i)||/||b|| 2.081619275849e-04
1574 KSP unpreconditioned resid norm 8.712486349379e+00 true resid norm 8.712486349370e+00 ||r(i)||/||b|| 2.081619275638e-04
1575 KSP unpreconditioned resid norm 8.712486348103e+00 true resid norm 8.712486348108e+00 ||r(i)||/||b|| 2.081619275337e-04
1576 KSP unpreconditioned resid norm 8.712486347350e+00 true resid norm 8.712486347347e+00 ||r(i)||/||b|| 2.081619275155e-04
1577 KSP unpreconditioned resid norm 8.712486346717e+00 true resid norm 8.712486346712e+00 ||r(i)||/||b|| 2.081619275003e-04
1578 KSP unpreconditioned resid norm 8.712486346031e+00 true resid norm 8.712486346027e+00 ||r(i)||/||b|| 2.081619274839e-04
1579 KSP unpreconditioned resid norm 8.712486345436e+00 true resid norm 8.712486345443e+00 ||r(i)||/||b|| 2.081619274700e-04
1580 KSP unpreconditioned resid norm 8.712486345410e+00 true resid norm 8.712486345405e+00 ||r(i)||/||b|| 2.081619274691e-04
1581 KSP unpreconditioned resid norm 8.712486345320e+00 true resid norm 8.712486345324e+00 ||r(i)||/||b|| 2.081619274672e-04
1582 KSP unpreconditioned resid norm 8.712486344578e+00 true resid norm 8.712486344576e+00 ||r(i)||/||b|| 2.081619274493e-04
1583 KSP unpreconditioned resid norm 8.712486340722e+00 true resid norm 8.712486340726e+00 ||r(i)||/||b|| 2.081619273573e-04
1584 KSP unpreconditioned resid norm 8.712486335506e+00 true resid norm 8.712486335501e+00 ||r(i)||/||b|| 2.081619272325e-04
1585 KSP unpreconditioned resid norm 8.712486331445e+00 true resid norm 8.712486331443e+00 ||r(i)||/||b|| 2.081619271355e-04
1586 KSP unpreconditioned resid norm 8.712486326476e+00 true resid norm 8.712486326472e+00 ||r(i)||/||b|| 2.081619270167e-04
1587 KSP unpreconditioned resid norm 8.712486318733e+00 true resid norm 8.712486318735e+00 ||r(i)||/||b|| 2.081619268319e-04
1588 KSP unpreconditioned resid norm 8.712486300314e+00 true resid norm 8.712486300312e+00 ||r(i)||/||b|| 2.081619263917e-04
1589 KSP unpreconditioned resid norm 8.712486290538e+00 true resid norm 8.712486290532e+00 ||r(i)||/||b|| 2.081619261581e-04
1590 KSP unpreconditioned resid norm 8.712486289883e+00 true resid norm 8.712486289883e+00 ||r(i)||/||b|| 2.081619261425e-04
1591 KSP unpreconditioned resid norm 8.712486289880e+00 true resid norm 8.712486289883e+00 ||r(i)||/||b|| 2.081619261425e-04
1592 KSP unpreconditioned resid norm 8.712486289840e+00 true resid norm 8.712486289845e+00 ||r(i)||/||b|| 2.081619261416e-04
1593 KSP unpreconditioned resid norm 8.712486289642e+00 true resid norm 8.712486289648e+00 ||r(i)||/||b|| 2.081619261369e-04
1594 KSP unpreconditioned resid norm 8.712486289199e+00 true resid norm 8.712486289203e+00 ||r(i)||/||b|| 2.081619261263e-04
1595 KSP unpreconditioned resid norm 8.712486288667e+00 true resid norm 8.712486288668e+00 ||r(i)||/||b|| 2.081619261135e-04
1596 KSP unpreconditioned resid norm 8.712486288513e+00 true resid norm 8.712486288509e+00 ||r(i)||/||b|| 2.081619261097e-04
1597 KSP unpreconditioned resid norm 8.712486288437e+00 true resid norm 8.712486288440e+00 ||r(i)||/||b|| 2.081619261081e-04
1598 KSP unpreconditioned resid norm 8.712486288192e+00 true resid norm 8.712486288197e+00 ||r(i)||/||b|| 2.081619261023e-04
1599 KSP unpreconditioned resid norm 8.712486287708e+00 true resid norm 8.712486287707e+00 ||r(i)||/||b|| 2.081619260905e-04
1600 KSP unpreconditioned resid norm 8.712486287281e+00 true resid norm 8.712486287283e+00 ||r(i)||/||b|| 2.081619260804e-04
1601 KSP unpreconditioned resid norm 8.712486287174e+00 true resid norm 8.712486287173e+00 ||r(i)||/||b|| 2.081619260778e-04
1602 KSP unpreconditioned resid norm 8.712486287164e+00 true resid norm 8.712486287162e+00 ||r(i)||/||b|| 2.081619260775e-04
1603 KSP unpreconditioned resid norm 8.712486286699e+00 true resid norm 8.712486286694e+00 ||r(i)||/||b|| 2.081619260663e-04
1604 KSP unpreconditioned resid norm 8.712486285925e+00 true resid norm 8.712486285924e+00 ||r(i)||/||b|| 2.081619260480e-04
1605 KSP unpreconditioned resid norm 8.712486284832e+00 true resid norm 8.712486284840e+00 ||r(i)||/||b|| 2.081619260221e-04
1606 KSP unpreconditioned resid norm 8.712486284176e+00 true resid norm 8.712486284176e+00 ||r(i)||/||b|| 2.081619260062e-04
1607 KSP unpreconditioned resid norm 8.712486283604e+00 true resid norm 8.712486283608e+00 ||r(i)||/||b|| 2.081619259926e-04
1608 KSP unpreconditioned resid norm 8.712486283016e+00 true resid norm 8.712486283005e+00 ||r(i)||/||b|| 2.081619259782e-04
1609 KSP unpreconditioned resid norm 8.712486282470e+00 true resid norm 8.712486282471e+00 ||r(i)||/||b|| 2.081619259655e-04
1610 KSP unpreconditioned resid norm 8.712486282443e+00 true resid norm 8.712486282430e+00 ||r(i)||/||b|| 2.081619259645e-04
1611 KSP unpreconditioned resid norm 8.712486282363e+00 true resid norm 8.712486282367e+00 ||r(i)||/||b|| 2.081619259630e-04
1612 KSP unpreconditioned resid norm 8.712486281737e+00 true resid norm 8.712486281739e+00 ||r(i)||/||b|| 2.081619259479e-04
1613 KSP unpreconditioned resid norm 8.712486278433e+00 true resid norm 8.712486278442e+00 ||r(i)||/||b|| 2.081619258692e-04
1614 KSP unpreconditioned resid norm 8.712486273926e+00 true resid norm 8.712486273925e+00 ||r(i)||/||b|| 2.081619257613e-04
1615 KSP unpreconditioned resid norm 8.712486270518e+00 true resid norm 8.712486270516e+00 ||r(i)||/||b|| 2.081619256798e-04
1616 KSP unpreconditioned resid norm 8.712486266270e+00 true resid norm 8.712486266277e+00 ||r(i)||/||b|| 2.081619255785e-04
1617 KSP unpreconditioned resid norm 8.712486259402e+00 true resid norm 8.712486259405e+00 ||r(i)||/||b|| 2.081619254143e-04
1618 KSP unpreconditioned resid norm 8.712486243048e+00 true resid norm 8.712486243047e+00 ||r(i)||/||b|| 2.081619250235e-04
1619 KSP unpreconditioned resid norm 8.712486234109e+00 true resid norm 8.712486234112e+00 ||r(i)||/||b|| 2.081619248100e-04
1620 KSP unpreconditioned resid norm 8.712486233418e+00 true resid norm 8.712486233418e+00 ||r(i)||/||b|| 2.081619247935e-04
1621 KSP unpreconditioned resid norm 8.712486233415e+00 true resid norm 8.712486233412e+00 ||r(i)||/||b|| 2.081619247933e-04
1622 KSP unpreconditioned resid norm 8.712486233377e+00 true resid norm 8.712486233378e+00 ||r(i)||/||b|| 2.081619247925e-04
1623 KSP unpreconditioned resid norm 8.712486233195e+00 true resid norm 8.712486233189e+00 ||r(i)||/||b|| 2.081619247880e-04
1624 KSP unpreconditioned resid norm 8.712486232800e+00 true resid norm 8.712486232806e+00 ||r(i)||/||b|| 2.081619247788e-04
1625 KSP unpreconditioned resid norm 8.712486232332e+00 true resid norm 8.712486232329e+00 ||r(i)||/||b|| 2.081619247674e-04
1626 KSP unpreconditioned resid norm 8.712486232194e+00 true resid norm 8.712486232192e+00 ||r(i)||/||b|| 2.081619247642e-04
1627 KSP unpreconditioned resid norm 8.712486232123e+00 true resid norm 8.712486232129e+00 ||r(i)||/||b|| 2.081619247626e-04
1628 KSP unpreconditioned resid norm 8.712486231897e+00 true resid norm 8.712486231898e+00 ||r(i)||/||b|| 2.081619247571e-04
1629 KSP unpreconditioned resid norm 8.712486231477e+00 true resid norm 8.712486231475e+00 ||r(i)||/||b|| 2.081619247470e-04
1630 KSP unpreconditioned resid norm 8.712486231112e+00 true resid norm 8.712486231108e+00 ||r(i)||/||b|| 2.081619247383e-04
1631 KSP unpreconditioned resid norm 8.712486231017e+00 true resid norm 8.712486231017e+00 ||r(i)||/||b|| 2.081619247361e-04
1632 KSP unpreconditioned resid norm 8.712486231008e+00 true resid norm 8.712486231002e+00 ||r(i)||/||b|| 2.081619247357e-04
1633 KSP unpreconditioned resid norm 8.712486230592e+00 true resid norm 8.712486230584e+00 ||r(i)||/||b|| 2.081619247257e-04
1634 KSP unpreconditioned resid norm 8.712486229911e+00 true resid norm 8.712486229907e+00 ||r(i)||/||b|| 2.081619247096e-04
1635 KSP unpreconditioned resid norm 8.712486228915e+00 true resid norm 8.712486228911e+00 ||r(i)||/||b|| 2.081619246858e-04
1636 KSP unpreconditioned resid norm 8.712486228327e+00 true resid norm 8.712486228318e+00 ||r(i)||/||b|| 2.081619246716e-04
1637 KSP unpreconditioned resid norm 8.712486227832e+00 true resid norm 8.712486227833e+00 ||r(i)||/||b|| 2.081619246600e-04
1638 KSP unpreconditioned resid norm 8.712486227296e+00 true resid norm 8.712486227305e+00 ||r(i)||/||b|| 2.081619246474e-04
1639 KSP unpreconditioned resid norm 8.712486226830e+00 true resid norm 8.712486226822e+00 ||r(i)||/||b|| 2.081619246359e-04
1640 KSP unpreconditioned resid norm 8.712486226809e+00 true resid norm 8.712486226811e+00 ||r(i)||/||b|| 2.081619246356e-04
1641 KSP unpreconditioned resid norm 8.712486226739e+00 true resid norm 8.712486226752e+00 ||r(i)||/||b|| 2.081619246342e-04
1642 KSP unpreconditioned resid norm 8.712486226160e+00 true resid norm 8.712486226156e+00 ||r(i)||/||b|| 2.081619246200e-04
1643 KSP unpreconditioned resid norm 8.712486223151e+00 true resid norm 8.712486223154e+00 ||r(i)||/||b|| 2.081619245482e-04
1644 KSP unpreconditioned resid norm 8.712486219078e+00 true resid norm 8.712486219081e+00 ||r(i)||/||b|| 2.081619244509e-04
1645 KSP unpreconditioned resid norm 8.712486215914e+00 true resid norm 8.712486215906e+00 ||r(i)||/||b|| 2.081619243750e-04
1646 KSP unpreconditioned resid norm 8.712486212036e+00 true resid norm 8.712486212033e+00 ||r(i)||/||b|| 2.081619242825e-04
1647 KSP unpreconditioned resid norm 8.712486205975e+00 true resid norm 8.712486205979e+00 ||r(i)||/||b|| 2.081619241379e-04
1648 KSP unpreconditioned resid norm 8.712486191559e+00 true resid norm 8.712486191555e+00 ||r(i)||/||b|| 2.081619237933e-04
1649 KSP unpreconditioned resid norm 8.712486183891e+00 true resid norm 8.712486183890e+00 ||r(i)||/||b|| 2.081619236101e-04
1650 KSP unpreconditioned resid norm 8.712486183382e+00 true resid norm 8.712486183382e+00 ||r(i)||/||b|| 2.081619235980e-04
1651 KSP unpreconditioned resid norm 8.712486183380e+00 true resid norm 8.712486183382e+00 ||r(i)||/||b|| 2.081619235980e-04
1652 KSP unpreconditioned resid norm 8.712486183349e+00 true resid norm 8.712486183359e+00 ||r(i)||/||b|| 2.081619235974e-04
1653 KSP unpreconditioned resid norm 8.712486183194e+00 true resid norm 8.712486183176e+00 ||r(i)||/||b|| 2.081619235931e-04
1654 KSP unpreconditioned resid norm 8.712486182846e+00 true resid norm 8.712486182837e+00 ||r(i)||/||b|| 2.081619235850e-04
1655 KSP unpreconditioned resid norm 8.712486182431e+00 true resid norm 8.712486182430e+00 ||r(i)||/||b|| 2.081619235752e-04
1656 KSP unpreconditioned resid norm 8.712486182310e+00 true resid norm 8.712486182307e+00 ||r(i)||/||b|| 2.081619235723e-04
1657 KSP unpreconditioned resid norm 8.712486182251e+00 true resid norm 8.712486182244e+00 ||r(i)||/||b|| 2.081619235708e-04
1658 KSP unpreconditioned resid norm 8.712486182059e+00 true resid norm 8.712486182045e+00 ||r(i)||/||b|| 2.081619235660e-04
1659 KSP unpreconditioned resid norm 8.712486181680e+00 true resid norm 8.712486181676e+00 ||r(i)||/||b|| 2.081619235572e-04
1660 KSP unpreconditioned resid norm 8.712486181347e+00 true resid norm 8.712486181334e+00 ||r(i)||/||b|| 2.081619235490e-04
1661 KSP unpreconditioned resid norm 8.712486181263e+00 true resid norm 8.712486181269e+00 ||r(i)||/||b|| 2.081619235475e-04
1662 KSP unpreconditioned resid norm 8.712486181255e+00 true resid norm 8.712486181249e+00 ||r(i)||/||b|| 2.081619235470e-04
1663 KSP unpreconditioned resid norm 8.712486180891e+00 true resid norm 8.712486180885e+00 ||r(i)||/||b|| 2.081619235383e-04
1664 KSP unpreconditioned resid norm 8.712486180286e+00 true resid norm 8.712486180286e+00 ||r(i)||/||b|| 2.081619235240e-04
1665 KSP unpreconditioned resid norm 8.712486179430e+00 true resid norm 8.712486179422e+00 ||r(i)||/||b|| 2.081619235034e-04
1666 KSP unpreconditioned resid norm 8.712486178917e+00 true resid norm 8.712486178913e+00 ||r(i)||/||b|| 2.081619234912e-04
1667 KSP unpreconditioned resid norm 8.712486178470e+00 true resid norm 8.712486178464e+00 ||r(i)||/||b|| 2.081619234805e-04
1668 KSP unpreconditioned resid norm 8.712486178009e+00 true resid norm 8.712486178009e+00 ||r(i)||/||b|| 2.081619234696e-04
1669 KSP unpreconditioned resid norm 8.712486177583e+00 true resid norm 8.712486177568e+00 ||r(i)||/||b|| 2.081619234591e-04
1670 KSP unpreconditioned resid norm 8.712486177562e+00 true resid norm 8.712486177562e+00 ||r(i)||/||b|| 2.081619234589e-04
1671 KSP unpreconditioned resid norm 8.712486177500e+00 true resid norm 8.712486177488e+00 ||r(i)||/||b|| 2.081619234571e-04
1672 KSP unpreconditioned resid norm 8.712486177009e+00 true resid norm 8.712486176997e+00 ||r(i)||/||b|| 2.081619234454e-04
1673 KSP unpreconditioned resid norm 8.712486174421e+00 true resid norm 8.712486174407e+00 ||r(i)||/||b|| 2.081619233835e-04
1674 KSP unpreconditioned resid norm 8.712486170893e+00 true resid norm 8.712486170883e+00 ||r(i)||/||b|| 2.081619232993e-04
1675 KSP unpreconditioned resid norm 8.712486168220e+00 true resid norm 8.712486168207e+00 ||r(i)||/||b|| 2.081619232354e-04
1676 KSP unpreconditioned resid norm 8.712486164892e+00 true resid norm 8.712486164880e+00 ||r(i)||/||b|| 2.081619231559e-04
1677 KSP unpreconditioned resid norm 8.712486159520e+00 true resid norm 8.712486159506e+00 ||r(i)||/||b|| 2.081619230275e-04
1678 KSP unpreconditioned resid norm 8.712486146724e+00 true resid norm 8.712486146716e+00 ||r(i)||/||b|| 2.081619227219e-04
1679 KSP unpreconditioned resid norm 8.712486139741e+00 true resid norm 8.712486139738e+00 ||r(i)||/||b|| 2.081619225552e-04
1680 KSP unpreconditioned resid norm 8.712486139195e+00 true resid norm 8.712486139195e+00 ||r(i)||/||b|| 2.081619225422e-04
1681 KSP unpreconditioned resid norm 8.712486139192e+00 true resid norm 8.712486139193e+00 ||r(i)||/||b|| 2.081619225422e-04
1682 KSP unpreconditioned resid norm 8.712486139162e+00 true resid norm 8.712486139160e+00 ||r(i)||/||b|| 2.081619225414e-04
1683 KSP unpreconditioned resid norm 8.712486139021e+00 true resid norm 8.712486139017e+00 ||r(i)||/||b|| 2.081619225380e-04
1684 KSP unpreconditioned resid norm 8.712486138712e+00 true resid norm 8.712486138713e+00 ||r(i)||/||b|| 2.081619225307e-04
1685 KSP unpreconditioned resid norm 8.712486138346e+00 true resid norm 8.712486138335e+00 ||r(i)||/||b|| 2.081619225217e-04
1686 KSP unpreconditioned resid norm 8.712486138238e+00 true resid norm 8.712486138234e+00 ||r(i)||/||b|| 2.081619225193e-04
1687 KSP unpreconditioned resid norm 8.712486138182e+00 true resid norm 8.712486138180e+00 ||r(i)||/||b|| 2.081619225180e-04
1688 KSP unpreconditioned resid norm 8.712486138006e+00 true resid norm 8.712486137996e+00 ||r(i)||/||b|| 2.081619225136e-04
1689 KSP unpreconditioned resid norm 8.712486137677e+00 true resid norm 8.712486137670e+00 ||r(i)||/||b|| 2.081619225058e-04
1690 KSP unpreconditioned resid norm 8.712486137391e+00 true resid norm 8.712486137392e+00 ||r(i)||/||b|| 2.081619224992e-04
1691 KSP unpreconditioned resid norm 8.712486137317e+00 true resid norm 8.712486137311e+00 ||r(i)||/||b|| 2.081619224972e-04
1692 KSP unpreconditioned resid norm 8.712486137310e+00 true resid norm 8.712486137312e+00 ||r(i)||/||b|| 2.081619224972e-04
1693 KSP unpreconditioned resid norm 8.712486136985e+00 true resid norm 8.712486136975e+00 ||r(i)||/||b|| 2.081619224892e-04
1694 KSP unpreconditioned resid norm 8.712486136453e+00 true resid norm 8.712486136458e+00 ||r(i)||/||b|| 2.081619224768e-04
1695 KSP unpreconditioned resid norm 8.712486135675e+00 true resid norm 8.712486135675e+00 ||r(i)||/||b|| 2.081619224582e-04
1696 KSP unpreconditioned resid norm 8.712486135216e+00 true resid norm 8.712486135217e+00 ||r(i)||/||b|| 2.081619224472e-04
1697 KSP unpreconditioned resid norm 8.712486134827e+00 true resid norm 8.712486134830e+00 ||r(i)||/||b|| 2.081619224380e-04
1698 KSP unpreconditioned resid norm 8.712486134409e+00 true resid norm 8.712486134402e+00 ||r(i)||/||b|| 2.081619224277e-04
1699 KSP unpreconditioned resid norm 8.712486134044e+00 true resid norm 8.712486134049e+00 ||r(i)||/||b|| 2.081619224193e-04
1700 KSP unpreconditioned resid norm 8.712486134027e+00 true resid norm 8.712486134021e+00 ||r(i)||/||b|| 2.081619224186e-04
1701 KSP unpreconditioned resid norm 8.712486133973e+00 true resid norm 8.712486133972e+00 ||r(i)||/||b|| 2.081619224175e-04
1702 KSP unpreconditioned resid norm 8.712486133521e+00 true resid norm 8.712486133518e+00 ||r(i)||/||b|| 2.081619224066e-04
1703 KSP unpreconditioned resid norm 8.712486131172e+00 true resid norm 8.712486131173e+00 ||r(i)||/||b|| 2.081619223506e-04
1704 KSP unpreconditioned resid norm 8.712486127992e+00 true resid norm 8.712486127986e+00 ||r(i)||/||b|| 2.081619222744e-04
1705 KSP unpreconditioned resid norm 8.712486125525e+00 true resid norm 8.712486125524e+00 ||r(i)||/||b|| 2.081619222156e-04
1706 KSP unpreconditioned resid norm 8.712486122497e+00 true resid norm 8.712486122498e+00 ||r(i)||/||b|| 2.081619221433e-04
1707 KSP unpreconditioned resid norm 8.712486117755e+00 true resid norm 8.712486117756e+00 ||r(i)||/||b|| 2.081619220300e-04
1708 KSP unpreconditioned resid norm 8.712486106473e+00 true resid norm 8.712486106475e+00 ||r(i)||/||b|| 2.081619217605e-04
1709 KSP unpreconditioned resid norm 8.712486100461e+00 true resid norm 8.712486100465e+00 ||r(i)||/||b|| 2.081619216169e-04
1710 KSP unpreconditioned resid norm 8.712486100055e+00 true resid norm 8.712486100055e+00 ||r(i)||/||b|| 2.081619216071e-04
1711 KSP unpreconditioned resid norm 8.712486100054e+00 true resid norm 8.712486100047e+00 ||r(i)||/||b|| 2.081619216069e-04
1712 KSP unpreconditioned resid norm 8.712486100029e+00 true resid norm 8.712486100020e+00 ||r(i)||/||b|| 2.081619216063e-04
1713 KSP unpreconditioned resid norm 8.712486099907e+00 true resid norm 8.712486099901e+00 ||r(i)||/||b|| 2.081619216034e-04
1714 KSP unpreconditioned resid norm 8.712486099636e+00 true resid norm 8.712486099631e+00 ||r(i)||/||b|| 2.081619215970e-04
1715 KSP unpreconditioned resid norm 8.712486099311e+00 true resid norm 8.712486099302e+00 ||r(i)||/||b|| 2.081619215891e-04
1716 KSP unpreconditioned resid norm 8.712486099216e+00 true resid norm 8.712486099204e+00 ||r(i)||/||b|| 2.081619215868e-04
1717 KSP unpreconditioned resid norm 8.712486099170e+00 true resid norm 8.712486099164e+00 ||r(i)||/||b|| 2.081619215858e-04
1718 KSP unpreconditioned resid norm 8.712486099019e+00 true resid norm 8.712486099021e+00 ||r(i)||/||b|| 2.081619215824e-04
1719 KSP unpreconditioned resid norm 8.712486098724e+00 true resid norm 8.712486098724e+00 ||r(i)||/||b|| 2.081619215753e-04
1720 KSP unpreconditioned resid norm 8.712486098463e+00 true resid norm 8.712486098468e+00 ||r(i)||/||b|| 2.081619215692e-04
1721 KSP unpreconditioned resid norm 8.712486098398e+00 true resid norm 8.712486098387e+00 ||r(i)||/||b|| 2.081619215672e-04
1722 KSP unpreconditioned resid norm 8.712486098392e+00 true resid norm 8.712486098386e+00 ||r(i)||/||b|| 2.081619215672e-04
1723 KSP unpreconditioned resid norm 8.712486098107e+00 true resid norm 8.712486098095e+00 ||r(i)||/||b|| 2.081619215603e-04
1724 KSP unpreconditioned resid norm 8.712486097634e+00 true resid norm 8.712486097629e+00 ||r(i)||/||b|| 2.081619215491e-04
1725 KSP unpreconditioned resid norm 8.712486096963e+00 true resid norm 8.712486096949e+00 ||r(i)||/||b|| 2.081619215329e-04
1726 KSP unpreconditioned resid norm 8.712486096562e+00 true resid norm 8.712486096552e+00 ||r(i)||/||b|| 2.081619215234e-04
1727 KSP unpreconditioned resid norm 8.712486096213e+00 true resid norm 8.712486096214e+00 ||r(i)||/||b|| 2.081619215153e-04
1728 KSP unpreconditioned resid norm 8.712486095852e+00 true resid norm 8.712486095847e+00 ||r(i)||/||b|| 2.081619215065e-04
1729 KSP unpreconditioned resid norm 8.712486095519e+00 true resid norm 8.712486095519e+00 ||r(i)||/||b|| 2.081619214987e-04
1730 KSP unpreconditioned resid norm 8.712486095503e+00 true resid norm 8.712486095494e+00 ||r(i)||/||b|| 2.081619214981e-04
1731 KSP unpreconditioned resid norm 8.712486095454e+00 true resid norm 8.712486095455e+00 ||r(i)||/||b|| 2.081619214972e-04
1732 KSP unpreconditioned resid norm 8.712486095069e+00 true resid norm 8.712486095063e+00 ||r(i)||/||b|| 2.081619214878e-04
1733 KSP unpreconditioned resid norm 8.712486093043e+00 true resid norm 8.712486093038e+00 ||r(i)||/||b|| 2.081619214394e-04
1734 KSP unpreconditioned resid norm 8.712486090282e+00 true resid norm 8.712486090283e+00 ||r(i)||/||b|| 2.081619213736e-04
1735 KSP unpreconditioned resid norm 8.712486088186e+00 true resid norm 8.712486088185e+00 ||r(i)||/||b|| 2.081619213235e-04
1736 KSP unpreconditioned resid norm 8.712486085578e+00 true resid norm 8.712486085572e+00 ||r(i)||/||b|| 2.081619212611e-04
1737 KSP unpreconditioned resid norm 8.712486081377e+00 true resid norm 8.712486081374e+00 ||r(i)||/||b|| 2.081619211608e-04
1738 KSP unpreconditioned resid norm 8.712486071367e+00 true resid norm 8.712486071359e+00 ||r(i)||/||b|| 2.081619209215e-04
1739 KSP unpreconditioned resid norm 8.712486065911e+00 true resid norm 8.712486065915e+00 ||r(i)||/||b|| 2.081619207914e-04
1740 KSP unpreconditioned resid norm 8.712486065485e+00 true resid norm 8.712486065485e+00 ||r(i)||/||b|| 2.081619207811e-04
1741 KSP unpreconditioned resid norm 8.712486065483e+00 true resid norm 8.712486065479e+00 ||r(i)||/||b|| 2.081619207810e-04
1742 KSP unpreconditioned resid norm 8.712486065459e+00 true resid norm 8.712486065465e+00 ||r(i)||/||b|| 2.081619207807e-04
1743 KSP unpreconditioned resid norm 8.712486065349e+00 true resid norm 8.712486065345e+00 ||r(i)||/||b|| 2.081619207778e-04
1744 KSP unpreconditioned resid norm 8.712486065107e+00 true resid norm 8.712486065112e+00 ||r(i)||/||b|| 2.081619207722e-04
1745 KSP unpreconditioned resid norm 8.712486064821e+00 true resid norm 8.712486064817e+00 ||r(i)||/||b|| 2.081619207652e-04
1746 KSP unpreconditioned resid norm 8.712486064737e+00 true resid norm 8.712486064731e+00 ||r(i)||/||b|| 2.081619207631e-04
1747 KSP unpreconditioned resid norm 8.712486064693e+00 true resid norm 8.712486064697e+00 ||r(i)||/||b|| 2.081619207623e-04
1748 KSP unpreconditioned resid norm 8.712486064556e+00 true resid norm 8.712486064549e+00 ||r(i)||/||b|| 2.081619207588e-04
1749 KSP unpreconditioned resid norm 8.712486064299e+00 true resid norm 8.712486064295e+00 ||r(i)||/||b|| 2.081619207527e-04
1750 KSP unpreconditioned resid norm 8.712486064074e+00 true resid norm 8.712486064067e+00 ||r(i)||/||b|| 2.081619207473e-04
1751 KSP unpreconditioned resid norm 8.712486064016e+00 true resid norm 8.712486064012e+00 ||r(i)||/||b|| 2.081619207459e-04
1752 KSP unpreconditioned resid norm 8.712486064011e+00 true resid norm 8.712486064003e+00 ||r(i)||/||b|| 2.081619207457e-04
1753 KSP unpreconditioned resid norm 8.712486063757e+00 true resid norm 8.712486063752e+00 ||r(i)||/||b|| 2.081619207397e-04
1754 KSP unpreconditioned resid norm 8.712486063340e+00 true resid norm 8.712486063339e+00 ||r(i)||/||b|| 2.081619207299e-04
1755 KSP unpreconditioned resid norm 8.712486062733e+00 true resid norm 8.712486062733e+00 ||r(i)||/||b|| 2.081619207154e-04
1756 KSP unpreconditioned resid norm 8.712486062374e+00 true resid norm 8.712486062379e+00 ||r(i)||/||b|| 2.081619207069e-04
1757 KSP unpreconditioned resid norm 8.712486062070e+00 true resid norm 8.712486062059e+00 ||r(i)||/||b|| 2.081619206993e-04
1758 KSP unpreconditioned resid norm 8.712486061744e+00 true resid norm 8.712486061743e+00 ||r(i)||/||b|| 2.081619206917e-04
1759 KSP unpreconditioned resid norm 8.712486061458e+00 true resid norm 8.712486061454e+00 ||r(i)||/||b|| 2.081619206848e-04
1760 KSP unpreconditioned resid norm 8.712486061445e+00 true resid norm 8.712486061446e+00 ||r(i)||/||b|| 2.081619206846e-04
1761 KSP unpreconditioned resid norm 8.712486061402e+00 true resid norm 8.712486061395e+00 ||r(i)||/||b|| 2.081619206834e-04
1762 KSP unpreconditioned resid norm 8.712486061049e+00 true resid norm 8.712486061047e+00 ||r(i)||/||b|| 2.081619206751e-04
1763 KSP unpreconditioned resid norm 8.712486059216e+00 true resid norm 8.712486059214e+00 ||r(i)||/||b|| 2.081619206313e-04
1764 KSP unpreconditioned resid norm 8.712486056731e+00 true resid norm 8.712486056725e+00 ||r(i)||/||b|| 2.081619205718e-04
1765 KSP unpreconditioned resid norm 8.712486054807e+00 true resid norm 8.712486054797e+00 ||r(i)||/||b|| 2.081619205258e-04
1766 KSP unpreconditioned resid norm 8.712486052443e+00 true resid norm 8.712486052437e+00 ||r(i)||/||b|| 2.081619204694e-04
1767 KSP unpreconditioned resid norm 8.712486048733e+00 true resid norm 8.712486048739e+00 ||r(i)||/||b|| 2.081619203810e-04
1768 KSP unpreconditioned resid norm 8.712486039905e+00 true resid norm 8.712486039893e+00 ||r(i)||/||b|| 2.081619201697e-04
1769 KSP unpreconditioned resid norm 8.712486035193e+00 true resid norm 8.712486035182e+00 ||r(i)||/||b|| 2.081619200571e-04
1770 KSP unpreconditioned resid norm 8.712486034860e+00 true resid norm 8.712486034860e+00 ||r(i)||/||b|| 2.081619200494e-04
1771 KSP unpreconditioned resid norm 8.712486034858e+00 true resid norm 8.712486034860e+00 ||r(i)||/||b|| 2.081619200494e-04
1772 KSP unpreconditioned resid norm 8.712486034839e+00 true resid norm 8.712486034846e+00 ||r(i)||/||b|| 2.081619200491e-04
1773 KSP unpreconditioned resid norm 8.712486034743e+00 true resid norm 8.712486034754e+00 ||r(i)||/||b|| 2.081619200469e-04
1774 KSP unpreconditioned resid norm 8.712486034531e+00 true resid norm 8.712486034539e+00 ||r(i)||/||b|| 2.081619200418e-04
1775 KSP unpreconditioned resid norm 8.712486034277e+00 true resid norm 8.712486034284e+00 ||r(i)||/||b|| 2.081619200357e-04
1776 KSP unpreconditioned resid norm 8.712486034203e+00 true resid norm 8.712486034213e+00 ||r(i)||/||b|| 2.081619200340e-04
1777 KSP unpreconditioned resid norm 8.712486034166e+00 true resid norm 8.712486034169e+00 ||r(i)||/||b|| 2.081619200329e-04
1778 KSP unpreconditioned resid norm 8.712486034049e+00 true resid norm 8.712486034055e+00 ||r(i)||/||b|| 2.081619200302e-04
1779 KSP unpreconditioned resid norm 8.712486033818e+00 true resid norm 8.712486033830e+00 ||r(i)||/||b|| 2.081619200248e-04
1780 KSP unpreconditioned resid norm 8.712486033614e+00 true resid norm 8.712486033616e+00 ||r(i)||/||b|| 2.081619200197e-04
1781 KSP unpreconditioned resid norm 8.712486033563e+00 true resid norm 8.712486033572e+00 ||r(i)||/||b|| 2.081619200186e-04
1782 KSP unpreconditioned resid norm 8.712486033558e+00 true resid norm 8.712486033555e+00 ||r(i)||/||b|| 2.081619200182e-04
1783 KSP unpreconditioned resid norm 8.712486033336e+00 true resid norm 8.712486033343e+00 ||r(i)||/||b|| 2.081619200132e-04
1784 KSP unpreconditioned resid norm 8.712486032966e+00 true resid norm 8.712486032968e+00 ||r(i)||/||b|| 2.081619200042e-04
1785 KSP unpreconditioned resid norm 8.712486032441e+00 true resid norm 8.712486032453e+00 ||r(i)||/||b|| 2.081619199919e-04
1786 KSP unpreconditioned resid norm 8.712486032126e+00 true resid norm 8.712486032130e+00 ||r(i)||/||b|| 2.081619199842e-04
1787 KSP unpreconditioned resid norm 8.712486031854e+00 true resid norm 8.712486031858e+00 ||r(i)||/||b|| 2.081619199777e-04
1788 KSP unpreconditioned resid norm 8.712486031571e+00 true resid norm 8.712486031575e+00 ||r(i)||/||b|| 2.081619199709e-04
1789 KSP unpreconditioned resid norm 8.712486031311e+00 true resid norm 8.712486031311e+00 ||r(i)||/||b|| 2.081619199646e-04
1790 KSP unpreconditioned resid norm 8.712486031299e+00 true resid norm 8.712486031306e+00 ||r(i)||/||b|| 2.081619199645e-04
1791 KSP unpreconditioned resid norm 8.712486031261e+00 true resid norm 8.712486031256e+00 ||r(i)||/||b|| 2.081619199633e-04
1792 KSP unpreconditioned resid norm 8.712486030959e+00 true resid norm 8.712486030969e+00 ||r(i)||/||b|| 2.081619199565e-04
1793 KSP unpreconditioned resid norm 8.712486029372e+00 true resid norm 8.712486029373e+00 ||r(i)||/||b|| 2.081619199183e-04
1794 KSP unpreconditioned resid norm 8.712486027211e+00 true resid norm 8.712486027216e+00 ||r(i)||/||b|| 2.081619198668e-04
1795 KSP unpreconditioned resid norm 8.712486025569e+00 true resid norm 8.712486025569e+00 ||r(i)||/||b|| 2.081619198275e-04
1796 KSP unpreconditioned resid norm 8.712486023526e+00 true resid norm 8.712486023528e+00 ||r(i)||/||b|| 2.081619197787e-04
1797 KSP unpreconditioned resid norm 8.712486020240e+00 true resid norm 8.712486020256e+00 ||r(i)||/||b|| 2.081619197005e-04
1798 KSP unpreconditioned resid norm 8.712486012411e+00 true resid norm 8.712486012418e+00 ||r(i)||/||b|| 2.081619195132e-04
1799 KSP unpreconditioned resid norm 8.712486008148e+00 true resid norm 8.712486008143e+00 ||r(i)||/||b|| 2.081619194111e-04
1800 KSP unpreconditioned resid norm 8.712486007828e+00 true resid norm 8.712486007828e+00 ||r(i)||/||b|| 2.081619194036e-04
1801 KSP unpreconditioned resid norm 8.712486007826e+00 true resid norm 8.712486007824e+00 ||r(i)||/||b|| 2.081619194035e-04
1802 KSP unpreconditioned resid norm 8.712486007808e+00 true resid norm 8.712486007810e+00 ||r(i)||/||b|| 2.081619194031e-04
1803 KSP unpreconditioned resid norm 8.712486007722e+00 true resid norm 8.712486007722e+00 ||r(i)||/||b|| 2.081619194010e-04
1804 KSP unpreconditioned resid norm 8.712486007533e+00 true resid norm 8.712486007523e+00 ||r(i)||/||b|| 2.081619193963e-04
1805 KSP unpreconditioned resid norm 8.712486007309e+00 true resid norm 8.712486007309e+00 ||r(i)||/||b|| 2.081619193912e-04
1806 KSP unpreconditioned resid norm 8.712486007243e+00 true resid norm 8.712486007242e+00 ||r(i)||/||b|| 2.081619193896e-04
1807 KSP unpreconditioned resid norm 8.712486007209e+00 true resid norm 8.712486007207e+00 ||r(i)||/||b|| 2.081619193887e-04
1808 KSP unpreconditioned resid norm 8.712486007102e+00 true resid norm 8.712486007099e+00 ||r(i)||/||b|| 2.081619193861e-04
1809 KSP unpreconditioned resid norm 8.712486006901e+00 true resid norm 8.712486006890e+00 ||r(i)||/||b|| 2.081619193812e-04
1810 KSP unpreconditioned resid norm 8.712486006725e+00 true resid norm 8.712486006713e+00 ||r(i)||/||b|| 2.081619193769e-04
1811 KSP unpreconditioned resid norm 8.712486006680e+00 true resid norm 8.712486006680e+00 ||r(i)||/||b|| 2.081619193761e-04
1812 KSP unpreconditioned resid norm 8.712486006675e+00 true resid norm 8.712486006662e+00 ||r(i)||/||b|| 2.081619193757e-04
1813 KSP unpreconditioned resid norm 8.712486006477e+00 true resid norm 8.712486006473e+00 ||r(i)||/||b|| 2.081619193712e-04
1814 KSP unpreconditioned resid norm 8.712486006151e+00 true resid norm 8.712486006138e+00 ||r(i)||/||b|| 2.081619193632e-04
1815 KSP unpreconditioned resid norm 8.712486005677e+00 true resid norm 8.712486005668e+00 ||r(i)||/||b|| 2.081619193520e-04
1816 KSP unpreconditioned resid norm 8.712486005396e+00 true resid norm 8.712486005392e+00 ||r(i)||/||b|| 2.081619193454e-04
1817 KSP unpreconditioned resid norm 8.712486005158e+00 true resid norm 8.712486005144e+00 ||r(i)||/||b|| 2.081619193394e-04
1818 KSP unpreconditioned resid norm 8.712486004903e+00 true resid norm 8.712486004896e+00 ||r(i)||/||b|| 2.081619193335e-04
1819 KSP unpreconditioned resid norm 8.712486004679e+00 true resid norm 8.712486004667e+00 ||r(i)||/||b|| 2.081619193280e-04
1820 KSP unpreconditioned resid norm 8.712486004669e+00 true resid norm 8.712486004660e+00 ||r(i)||/||b|| 2.081619193279e-04
1821 KSP unpreconditioned resid norm 8.712486004635e+00 true resid norm 8.712486004636e+00 ||r(i)||/||b|| 2.081619193273e-04
1822 KSP unpreconditioned resid norm 8.712486004360e+00 true resid norm 8.712486004361e+00 ||r(i)||/||b|| 2.081619193207e-04
1823 KSP unpreconditioned resid norm 8.712486002928e+00 true resid norm 8.712486002930e+00 ||r(i)||/||b|| 2.081619192865e-04
1824 KSP unpreconditioned resid norm 8.712486000988e+00 true resid norm 8.712486000983e+00 ||r(i)||/||b|| 2.081619192400e-04
1825 KSP unpreconditioned resid norm 8.712485999486e+00 true resid norm 8.712485999489e+00 ||r(i)||/||b|| 2.081619192043e-04
1826 KSP unpreconditioned resid norm 8.712485997640e+00 true resid norm 8.712485997635e+00 ||r(i)||/||b|| 2.081619191600e-04
1827 KSP unpreconditioned resid norm 8.712485994737e+00 true resid norm 8.712485994737e+00 ||r(i)||/||b|| 2.081619190908e-04
1828 KSP unpreconditioned resid norm 8.712485987831e+00 true resid norm 8.712485987828e+00 ||r(i)||/||b|| 2.081619189257e-04
1829 KSP unpreconditioned resid norm 8.712485984139e+00 true resid norm 8.712485984125e+00 ||r(i)||/||b|| 2.081619188372e-04
1830 KSP unpreconditioned resid norm 8.712485983876e+00 true resid norm 8.712485983876e+00 ||r(i)||/||b|| 2.081619188313e-04
1831 KSP unpreconditioned resid norm 8.712485983875e+00 true resid norm 8.712485983877e+00 ||r(i)||/||b|| 2.081619188313e-04
1832 KSP unpreconditioned resid norm 8.712485983859e+00 true resid norm 8.712485983854e+00 ||r(i)||/||b|| 2.081619188308e-04
1833 KSP unpreconditioned resid norm 8.712485983785e+00 true resid norm 8.712485983789e+00 ||r(i)||/||b|| 2.081619188292e-04
1834 KSP unpreconditioned resid norm 8.712485983618e+00 true resid norm 8.712485983623e+00 ||r(i)||/||b|| 2.081619188253e-04
1835 KSP unpreconditioned resid norm 8.712485983420e+00 true resid norm 8.712485983416e+00 ||r(i)||/||b|| 2.081619188203e-04
1836 KSP unpreconditioned resid norm 8.712485983362e+00 true resid norm 8.712485983359e+00 ||r(i)||/||b|| 2.081619188190e-04
1837 KSP unpreconditioned resid norm 8.712485983333e+00 true resid norm 8.712485983335e+00 ||r(i)||/||b|| 2.081619188184e-04
1838 KSP unpreconditioned resid norm 8.712485983241e+00 true resid norm 8.712485983251e+00 ||r(i)||/||b|| 2.081619188164e-04
1839 KSP unpreconditioned resid norm 8.712485983060e+00 true resid norm 8.712485983061e+00 ||r(i)||/||b|| 2.081619188118e-04
1840 KSP unpreconditioned resid norm 8.712485982902e+00 true resid norm 8.712485982887e+00 ||r(i)||/||b|| 2.081619188077e-04
1841 KSP unpreconditioned resid norm 8.712485982862e+00 true resid norm 8.712485982854e+00 ||r(i)||/||b|| 2.081619188069e-04
1842 KSP unpreconditioned resid norm 8.712485982858e+00 true resid norm 8.712485982858e+00 ||r(i)||/||b|| 2.081619188070e-04
1843 KSP unpreconditioned resid norm 8.712485982684e+00 true resid norm 8.712485982679e+00 ||r(i)||/||b|| 2.081619188027e-04
1844 KSP unpreconditioned resid norm 8.712485982395e+00 true resid norm 8.712485982391e+00 ||r(i)||/||b|| 2.081619187958e-04
1845 KSP unpreconditioned resid norm 8.712485981983e+00 true resid norm 8.712485981983e+00 ||r(i)||/||b|| 2.081619187861e-04
1846 KSP unpreconditioned resid norm 8.712485981737e+00 true resid norm 8.712485981746e+00 ||r(i)||/||b|| 2.081619187804e-04
1847 KSP unpreconditioned resid norm 8.712485981524e+00 true resid norm 8.712485981522e+00 ||r(i)||/||b|| 2.081619187751e-04
1848 KSP unpreconditioned resid norm 8.712485981303e+00 true resid norm 8.712485981296e+00 ||r(i)||/||b|| 2.081619187697e-04
1849 KSP unpreconditioned resid norm 8.712485981100e+00 true resid norm 8.712485981097e+00 ||r(i)||/||b|| 2.081619187649e-04
1850 KSP unpreconditioned resid norm 8.712485981090e+00 true resid norm 8.712485981096e+00 ||r(i)||/||b|| 2.081619187649e-04
1851 KSP unpreconditioned resid norm 8.712485981061e+00 true resid norm 8.712485981069e+00 ||r(i)||/||b|| 2.081619187642e-04
1852 KSP unpreconditioned resid norm 8.712485980824e+00 true resid norm 8.712485980814e+00 ||r(i)||/||b|| 2.081619187582e-04
1853 KSP unpreconditioned resid norm 8.712485979582e+00 true resid norm 8.712485979578e+00 ||r(i)||/||b|| 2.081619187286e-04
1854 KSP unpreconditioned resid norm 8.712485977891e+00 true resid norm 8.712485977887e+00 ||r(i)||/||b|| 2.081619186882e-04
1855 KSP unpreconditioned resid norm 8.712485976604e+00 true resid norm 8.712485976606e+00 ||r(i)||/||b|| 2.081619186576e-04
1856 KSP unpreconditioned resid norm 8.712485975004e+00 true resid norm 8.712485975005e+00 ||r(i)||/||b|| 2.081619186194e-04
1857 KSP unpreconditioned resid norm 8.712485972434e+00 true resid norm 8.712485972438e+00 ||r(i)||/||b|| 2.081619185580e-04
1858 KSP unpreconditioned resid norm 8.712485966310e+00 true resid norm 8.712485966317e+00 ||r(i)||/||b|| 2.081619184118e-04
1859 KSP unpreconditioned resid norm 8.712485962980e+00 true resid norm 8.712485962981e+00 ||r(i)||/||b|| 2.081619183321e-04
1860 KSP unpreconditioned resid norm 8.712485962713e+00 true resid norm 8.712485962713e+00 ||r(i)||/||b|| 2.081619183257e-04
1861 KSP unpreconditioned resid norm 8.712485962712e+00 true resid norm 8.712485962716e+00 ||r(i)||/||b|| 2.081619183257e-04
1862 KSP unpreconditioned resid norm 8.712485962698e+00 true resid norm 8.712485962717e+00 ||r(i)||/||b|| 2.081619183258e-04
1863 KSP unpreconditioned resid norm 8.712485962630e+00 true resid norm 8.712485962646e+00 ||r(i)||/||b|| 2.081619183241e-04
1864 KSP unpreconditioned resid norm 8.712485962483e+00 true resid norm 8.712485962496e+00 ||r(i)||/||b|| 2.081619183205e-04
1865 KSP unpreconditioned resid norm 8.712485962308e+00 true resid norm 8.712485962309e+00 ||r(i)||/||b|| 2.081619183160e-04
1866 KSP unpreconditioned resid norm 8.712485962256e+00 true resid norm 8.712485962267e+00 ||r(i)||/||b|| 2.081619183150e-04
1867 KSP unpreconditioned resid norm 8.712485962230e+00 true resid norm 8.712485962238e+00 ||r(i)||/||b|| 2.081619183143e-04
1868 KSP unpreconditioned resid norm 8.712485962146e+00 true resid norm 8.712485962152e+00 ||r(i)||/||b|| 2.081619183123e-04
1869 KSP unpreconditioned resid norm 8.712485961988e+00 true resid norm 8.712485962004e+00 ||r(i)||/||b|| 2.081619183087e-04
1870 KSP unpreconditioned resid norm 8.712485961851e+00 true resid norm 8.712485961874e+00 ||r(i)||/||b|| 2.081619183056e-04
1871 KSP unpreconditioned resid norm 8.712485961815e+00 true resid norm 8.712485961825e+00 ||r(i)||/||b|| 2.081619183045e-04
1872 KSP unpreconditioned resid norm 8.712485961812e+00 true resid norm 8.712485961828e+00 ||r(i)||/||b|| 2.081619183045e-04
1873 KSP unpreconditioned resid norm 8.712485961657e+00 true resid norm 8.712485961664e+00 ||r(i)||/||b|| 2.081619183006e-04
1874 KSP unpreconditioned resid norm 8.712485961402e+00 true resid norm 8.712485961416e+00 ||r(i)||/||b|| 2.081619182947e-04
1875 KSP unpreconditioned resid norm 8.712485961032e+00 true resid norm 8.712485961040e+00 ||r(i)||/||b|| 2.081619182857e-04
1876 KSP unpreconditioned resid norm 8.712485960812e+00 true resid norm 8.712485960822e+00 ||r(i)||/||b|| 2.081619182805e-04
1877 KSP unpreconditioned resid norm 8.712485960626e+00 true resid norm 8.712485960626e+00 ||r(i)||/||b|| 2.081619182758e-04
1878 KSP unpreconditioned resid norm 8.712485960427e+00 true resid norm 8.712485960437e+00 ||r(i)||/||b|| 2.081619182713e-04
1879 KSP unpreconditioned resid norm 8.712485960251e+00 true resid norm 8.712485960272e+00 ||r(i)||/||b|| 2.081619182673e-04
1880 KSP unpreconditioned resid norm 8.712485960243e+00 true resid norm 8.712485960251e+00 ||r(i)||/||b|| 2.081619182668e-04
1881 KSP unpreconditioned resid norm 8.712485960217e+00 true resid norm 8.712485960222e+00 ||r(i)||/||b|| 2.081619182662e-04
1882 KSP unpreconditioned resid norm 8.712485960002e+00 true resid norm 8.712485960014e+00 ||r(i)||/||b|| 2.081619182612e-04
1883 KSP unpreconditioned resid norm 8.712485958884e+00 true resid norm 8.712485958892e+00 ||r(i)||/||b|| 2.081619182344e-04
1884 KSP unpreconditioned resid norm 8.712485957368e+00 true resid norm 8.712485957375e+00 ||r(i)||/||b|| 2.081619181981e-04
1885 KSP unpreconditioned resid norm 8.712485956196e+00 true resid norm 8.712485956203e+00 ||r(i)||/||b|| 2.081619181701e-04
1886 KSP unpreconditioned resid norm 8.712485954754e+00 true resid norm 8.712485954765e+00 ||r(i)||/||b|| 2.081619181358e-04
1887 KSP unpreconditioned resid norm 8.712485952483e+00 true resid norm 8.712485952482e+00 ||r(i)||/||b|| 2.081619180812e-04
1888 KSP unpreconditioned resid norm 8.712485947080e+00 true resid norm 8.712485947092e+00 ||r(i)||/||b|| 2.081619179524e-04
1889 KSP unpreconditioned resid norm 8.712485944188e+00 true resid norm 8.712485944193e+00 ||r(i)||/||b|| 2.081619178832e-04
1890 KSP unpreconditioned resid norm 8.712485943997e+00 true resid norm 8.712485943997e+00 ||r(i)||/||b|| 2.081619178785e-04
1891 KSP unpreconditioned resid norm 8.712485943996e+00 true resid norm 8.712485943992e+00 ||r(i)||/||b|| 2.081619178784e-04
1892 KSP unpreconditioned resid norm 8.712485943984e+00 true resid norm 8.712485943975e+00 ||r(i)||/||b|| 2.081619178780e-04
1893 KSP unpreconditioned resid norm 8.712485943926e+00 true resid norm 8.712485943923e+00 ||r(i)||/||b|| 2.081619178767e-04
1894 KSP unpreconditioned resid norm 8.712485943796e+00 true resid norm 8.712485943795e+00 ||r(i)||/||b|| 2.081619178737e-04
1895 KSP unpreconditioned resid norm 8.712485943640e+00 true resid norm 8.712485943644e+00 ||r(i)||/||b|| 2.081619178701e-04
1896 KSP unpreconditioned resid norm 8.712485943595e+00 true resid norm 8.712485943591e+00 ||r(i)||/||b|| 2.081619178688e-04
1897 KSP unpreconditioned resid norm 8.712485943573e+00 true resid norm 8.712485943571e+00 ||r(i)||/||b|| 2.081619178683e-04
1898 KSP unpreconditioned resid norm 8.712485943500e+00 true resid norm 8.712485943497e+00 ||r(i)||/||b|| 2.081619178666e-04
1899 KSP unpreconditioned resid norm 8.712485943359e+00 true resid norm 8.712485943357e+00 ||r(i)||/||b|| 2.081619178632e-04
1900 KSP unpreconditioned resid norm 8.712485943235e+00 true resid norm 8.712485943229e+00 ||r(i)||/||b|| 2.081619178601e-04
1901 KSP unpreconditioned resid norm 8.712485943204e+00 true resid norm 8.712485943200e+00 ||r(i)||/||b|| 2.081619178595e-04
1902 KSP unpreconditioned resid norm 8.712485943201e+00 true resid norm 8.712485943192e+00 ||r(i)||/||b|| 2.081619178593e-04
1903 KSP unpreconditioned resid norm 8.712485943065e+00 true resid norm 8.712485943046e+00 ||r(i)||/||b|| 2.081619178558e-04
1904 KSP unpreconditioned resid norm 8.712485942839e+00 true resid norm 8.712485942830e+00 ||r(i)||/||b|| 2.081619178506e-04
1905 KSP unpreconditioned resid norm 8.712485942517e+00 true resid norm 8.712485942511e+00 ||r(i)||/||b|| 2.081619178430e-04
1906 KSP unpreconditioned resid norm 8.712485942324e+00 true resid norm 8.712485942325e+00 ||r(i)||/||b|| 2.081619178386e-04
1907 KSP unpreconditioned resid norm 8.712485942158e+00 true resid norm 8.712485942149e+00 ||r(i)||/||b|| 2.081619178343e-04
1908 KSP unpreconditioned resid norm 8.712485941984e+00 true resid norm 8.712485941971e+00 ||r(i)||/||b|| 2.081619178301e-04
1909 KSP unpreconditioned resid norm 8.712485941826e+00 true resid norm 8.712485941824e+00 ||r(i)||/||b|| 2.081619178266e-04
1910 KSP unpreconditioned resid norm 8.712485941819e+00 true resid norm 8.712485941820e+00 ||r(i)||/||b|| 2.081619178265e-04
1911 KSP unpreconditioned resid norm 8.712485941795e+00 true resid norm 8.712485941787e+00 ||r(i)||/||b|| 2.081619178257e-04
1912 KSP unpreconditioned resid norm 8.712485941610e+00 true resid norm 8.712485941609e+00 ||r(i)||/||b|| 2.081619178214e-04
1913 KSP unpreconditioned resid norm 8.712485940638e+00 true resid norm 8.712485940633e+00 ||r(i)||/||b|| 2.081619177981e-04
1914 KSP unpreconditioned resid norm 8.712485939314e+00 true resid norm 8.712485939313e+00 ||r(i)||/||b|| 2.081619177666e-04
1915 KSP unpreconditioned resid norm 8.712485938306e+00 true resid norm 8.712485938299e+00 ||r(i)||/||b|| 2.081619177424e-04
1916 KSP unpreconditioned resid norm 8.712485937054e+00 true resid norm 8.712485937045e+00 ||r(i)||/||b|| 2.081619177124e-04
1917 KSP unpreconditioned resid norm 8.712485935044e+00 true resid norm 8.712485935035e+00 ||r(i)||/||b|| 2.081619176644e-04
1918 KSP unpreconditioned resid norm 8.712485930254e+00 true resid norm 8.712485930244e+00 ||r(i)||/||b|| 2.081619175499e-04
1919 KSP unpreconditioned resid norm 8.712485927651e+00 true resid norm 8.712485927647e+00 ||r(i)||/||b|| 2.081619174879e-04
1920 KSP unpreconditioned resid norm 8.712485927438e+00 true resid norm 8.712485927438e+00 ||r(i)||/||b|| 2.081619174829e-04
1921 KSP unpreconditioned resid norm 8.712485927437e+00 true resid norm 8.712485927441e+00 ||r(i)||/||b|| 2.081619174829e-04
1922 KSP unpreconditioned resid norm 8.712485927426e+00 true resid norm 8.712485927431e+00 ||r(i)||/||b|| 2.081619174827e-04
1923 KSP unpreconditioned resid norm 8.712485927374e+00 true resid norm 8.712485927373e+00 ||r(i)||/||b|| 2.081619174813e-04
1924 KSP unpreconditioned resid norm 8.712485927258e+00 true resid norm 8.712485927256e+00 ||r(i)||/||b|| 2.081619174785e-04
1925 KSP unpreconditioned resid norm 8.712485927121e+00 true resid norm 8.712485927130e+00 ||r(i)||/||b|| 2.081619174755e-04
1926 KSP unpreconditioned resid norm 8.712485927081e+00 true resid norm 8.712485927085e+00 ||r(i)||/||b|| 2.081619174744e-04
1927 KSP unpreconditioned resid norm 8.712485927060e+00 true resid norm 8.712485927056e+00 ||r(i)||/||b|| 2.081619174737e-04
1928 KSP unpreconditioned resid norm 8.712485926995e+00 true resid norm 8.712485926999e+00 ||r(i)||/||b|| 2.081619174724e-04
1929 KSP unpreconditioned resid norm 8.712485926872e+00 true resid norm 8.712485926878e+00 ||r(i)||/||b|| 2.081619174695e-04
1930 KSP unpreconditioned resid norm 8.712485926764e+00 true resid norm 8.712485926762e+00 ||r(i)||/||b|| 2.081619174667e-04
1931 KSP unpreconditioned resid norm 8.712485926736e+00 true resid norm 8.712485926741e+00 ||r(i)||/||b|| 2.081619174662e-04
1932 KSP unpreconditioned resid norm 8.712485926734e+00 true resid norm 8.712485926747e+00 ||r(i)||/||b|| 2.081619174664e-04
1933 KSP unpreconditioned resid norm 8.712485926612e+00 true resid norm 8.712485926609e+00 ||r(i)||/||b|| 2.081619174631e-04
1934 KSP unpreconditioned resid norm 8.712485926413e+00 true resid norm 8.712485926417e+00 ||r(i)||/||b|| 2.081619174585e-04
1935 KSP unpreconditioned resid norm 8.712485926124e+00 true resid norm 8.712485926132e+00 ||r(i)||/||b|| 2.081619174517e-04
1936 KSP unpreconditioned resid norm 8.712485925952e+00 true resid norm 8.712485925949e+00 ||r(i)||/||b|| 2.081619174473e-04
1937 KSP unpreconditioned resid norm 8.712485925807e+00 true resid norm 8.712485925809e+00 ||r(i)||/||b|| 2.081619174439e-04
1938 KSP unpreconditioned resid norm 8.712485925651e+00 true resid norm 8.712485925655e+00 ||r(i)||/||b|| 2.081619174403e-04
1939 KSP unpreconditioned resid norm 8.712485925514e+00 true resid norm 8.712485925526e+00 ||r(i)||/||b|| 2.081619174372e-04
1940 KSP unpreconditioned resid norm 8.712485925507e+00 true resid norm 8.712485925514e+00 ||r(i)||/||b|| 2.081619174369e-04
1941 KSP unpreconditioned resid norm 8.712485925487e+00 true resid norm 8.712485925498e+00 ||r(i)||/||b|| 2.081619174365e-04
1942 KSP unpreconditioned resid norm 8.712485925319e+00 true resid norm 8.712485925335e+00 ||r(i)||/||b|| 2.081619174326e-04
1943 KSP unpreconditioned resid norm 8.712485924445e+00 true resid norm 8.712485924461e+00 ||r(i)||/||b|| 2.081619174117e-04
1944 KSP unpreconditioned resid norm 8.712485923260e+00 true resid norm 8.712485923263e+00 ||r(i)||/||b|| 2.081619173831e-04
1945 KSP unpreconditioned resid norm 8.712485922346e+00 true resid norm 8.712485922345e+00 ||r(i)||/||b|| 2.081619173612e-04
1946 KSP unpreconditioned resid norm 8.712485921219e+00 true resid norm 8.712485921220e+00 ||r(i)||/||b|| 2.081619173343e-04
1947 KSP unpreconditioned resid norm 8.712485919443e+00 true resid norm 8.712485919453e+00 ||r(i)||/||b|| 2.081619172921e-04
1948 KSP unpreconditioned resid norm 8.712485915216e+00 true resid norm 8.712485915219e+00 ||r(i)||/||b|| 2.081619171909e-04
1949 KSP unpreconditioned resid norm 8.712485912952e+00 true resid norm 8.712485912952e+00 ||r(i)||/||b|| 2.081619171368e-04
1950 KSP unpreconditioned resid norm 8.712485912801e+00 true resid norm 8.712485912801e+00 ||r(i)||/||b|| 2.081619171331e-04
1951 KSP unpreconditioned resid norm 8.712485912800e+00 true resid norm 8.712485912806e+00 ||r(i)||/||b|| 2.081619171333e-04
1952 KSP unpreconditioned resid norm 8.712485912791e+00 true resid norm 8.712485912797e+00 ||r(i)||/||b|| 2.081619171331e-04
1953 KSP unpreconditioned resid norm 8.712485912745e+00 true resid norm 8.712485912742e+00 ||r(i)||/||b|| 2.081619171317e-04
1954 KSP unpreconditioned resid norm 8.712485912643e+00 true resid norm 8.712485912642e+00 ||r(i)||/||b|| 2.081619171294e-04
1955 KSP unpreconditioned resid norm 8.712485912522e+00 true resid norm 8.712485912522e+00 ||r(i)||/||b|| 2.081619171265e-04
1956 KSP unpreconditioned resid norm 8.712485912486e+00 true resid norm 8.712485912476e+00 ||r(i)||/||b|| 2.081619171254e-04
1957 KSP unpreconditioned resid norm 8.712485912469e+00 true resid norm 8.712485912465e+00 ||r(i)||/||b|| 2.081619171251e-04
1958 KSP unpreconditioned resid norm 8.712485912412e+00 true resid norm 8.712485912409e+00 ||r(i)||/||b|| 2.081619171238e-04
1959 KSP unpreconditioned resid norm 8.712485912302e+00 true resid norm 8.712485912302e+00 ||r(i)||/||b|| 2.081619171212e-04
1960 KSP unpreconditioned resid norm 8.712485912205e+00 true resid norm 8.712485912198e+00 ||r(i)||/||b|| 2.081619171187e-04
1961 KSP unpreconditioned resid norm 8.712485912181e+00 true resid norm 8.712485912176e+00 ||r(i)||/||b|| 2.081619171182e-04
1962 KSP unpreconditioned resid norm 8.712485912178e+00 true resid norm 8.712485912177e+00 ||r(i)||/||b|| 2.081619171182e-04
1963 KSP unpreconditioned resid norm 8.712485912072e+00 true resid norm 8.712485912070e+00 ||r(i)||/||b|| 2.081619171157e-04
1964 KSP unpreconditioned resid norm 8.712485911895e+00 true resid norm 8.712485911880e+00 ||r(i)||/||b|| 2.081619171111e-04
1965 KSP unpreconditioned resid norm 8.712485911643e+00 true resid norm 8.712485911646e+00 ||r(i)||/||b|| 2.081619171056e-04
1966 KSP unpreconditioned resid norm 8.712485911492e+00 true resid norm 8.712485911492e+00 ||r(i)||/||b|| 2.081619171019e-04
1967 KSP unpreconditioned resid norm 8.712485911362e+00 true resid norm 8.712485911353e+00 ||r(i)||/||b|| 2.081619170986e-04
1968 KSP unpreconditioned resid norm 8.712485911227e+00 true resid norm 8.712485911225e+00 ||r(i)||/||b|| 2.081619170955e-04
1969 KSP unpreconditioned resid norm 8.712485911103e+00 true resid norm 8.712485911100e+00 ||r(i)||/||b|| 2.081619170925e-04
1970 KSP unpreconditioned resid norm 8.712485911097e+00 true resid norm 8.712485911098e+00 ||r(i)||/||b|| 2.081619170925e-04
1971 KSP unpreconditioned resid norm 8.712485911079e+00 true resid norm 8.712485911077e+00 ||r(i)||/||b|| 2.081619170920e-04
1972 KSP unpreconditioned resid norm 8.712485910934e+00 true resid norm 8.712485910931e+00 ||r(i)||/||b|| 2.081619170885e-04
1973 KSP unpreconditioned resid norm 8.712485910173e+00 true resid norm 8.712485910178e+00 ||r(i)||/||b|| 2.081619170705e-04
1974 KSP unpreconditioned resid norm 8.712485909137e+00 true resid norm 8.712485909137e+00 ||r(i)||/||b|| 2.081619170456e-04
1975 KSP unpreconditioned resid norm 8.712485908347e+00 true resid norm 8.712485908346e+00 ||r(i)||/||b|| 2.081619170267e-04
1976 KSP unpreconditioned resid norm 8.712485907367e+00 true resid norm 8.712485907351e+00 ||r(i)||/||b|| 2.081619170029e-04
1977 KSP unpreconditioned resid norm 8.712485905795e+00 true resid norm 8.712485905800e+00 ||r(i)||/||b|| 2.081619169659e-04
1978 KSP unpreconditioned resid norm 8.712485902049e+00 true resid norm 8.712485902041e+00 ||r(i)||/||b|| 2.081619168761e-04
1979 KSP unpreconditioned resid norm 8.712485900015e+00 true resid norm 8.712485900009e+00 ||r(i)||/||b|| 2.081619168275e-04
1980 KSP unpreconditioned resid norm 8.712485899862e+00 true resid norm 8.712485899862e+00 ||r(i)||/||b|| 2.081619168240e-04
1981 KSP unpreconditioned resid norm 8.712485899861e+00 true resid norm 8.712485899842e+00 ||r(i)||/||b|| 2.081619168235e-04
1982 KSP unpreconditioned resid norm 8.712485899852e+00 true resid norm 8.712485899846e+00 ||r(i)||/||b|| 2.081619168236e-04
1983 KSP unpreconditioned resid norm 8.712485899811e+00 true resid norm 8.712485899812e+00 ||r(i)||/||b|| 2.081619168228e-04
1984 KSP unpreconditioned resid norm 8.712485899721e+00 true resid norm 8.712485899723e+00 ||r(i)||/||b|| 2.081619168207e-04
1985 KSP unpreconditioned resid norm 8.712485899614e+00 true resid norm 8.712485899613e+00 ||r(i)||/||b|| 2.081619168181e-04
1986 KSP unpreconditioned resid norm 8.712485899582e+00 true resid norm 8.712485899571e+00 ||r(i)||/||b|| 2.081619168171e-04
1987 KSP unpreconditioned resid norm 8.712485899566e+00 true resid norm 8.712485899561e+00 ||r(i)||/||b|| 2.081619168168e-04
1988 KSP unpreconditioned resid norm 8.712485899515e+00 true resid norm 8.712485899512e+00 ||r(i)||/||b|| 2.081619168156e-04
1989 KSP unpreconditioned resid norm 8.712485899419e+00 true resid norm 8.712485899408e+00 ||r(i)||/||b|| 2.081619168132e-04
1990 KSP unpreconditioned resid norm 8.712485899334e+00 true resid norm 8.712485899328e+00 ||r(i)||/||b|| 2.081619168113e-04
1991 KSP unpreconditioned resid norm 8.712485899313e+00 true resid norm 8.712485899303e+00 ||r(i)||/||b|| 2.081619168107e-04
1992 KSP unpreconditioned resid norm 8.712485899311e+00 true resid norm 8.712485899310e+00 ||r(i)||/||b|| 2.081619168108e-04
1993 KSP unpreconditioned resid norm 8.712485899216e+00 true resid norm 8.712485899210e+00 ||r(i)||/||b|| 2.081619168084e-04
1994 KSP unpreconditioned resid norm 8.712485899060e+00 true resid norm 8.712485899052e+00 ||r(i)||/||b|| 2.081619168047e-04
1995 KSP unpreconditioned resid norm 8.712485898834e+00 true resid norm 8.712485898826e+00 ||r(i)||/||b|| 2.081619167993e-04
1996 KSP unpreconditioned resid norm 8.712485898700e+00 true resid norm 8.712485898693e+00 ||r(i)||/||b|| 2.081619167961e-04
1997 KSP unpreconditioned resid norm 8.712485898586e+00 true resid norm 8.712485898585e+00 ||r(i)||/||b|| 2.081619167935e-04
1998 KSP unpreconditioned resid norm 8.712485898464e+00 true resid norm 8.712485898467e+00 ||r(i)||/||b|| 2.081619167907e-04
1999 KSP unpreconditioned resid norm 8.712485898357e+00 true resid norm 8.712485898350e+00 ||r(i)||/||b|| 2.081619167879e-04
2000 KSP unpreconditioned resid norm 8.712485898352e+00 true resid norm 8.712485898344e+00 ||r(i)||/||b|| 2.081619167877e-04
2001 KSP unpreconditioned resid norm 8.712485898336e+00 true resid norm 8.712485898334e+00 ||r(i)||/||b|| 2.081619167875e-04
2002 KSP unpreconditioned resid norm 8.712485898205e+00 true resid norm 8.712485898192e+00 ||r(i)||/||b|| 2.081619167841e-04
2003 KSP unpreconditioned resid norm 8.712485897522e+00 true resid norm 8.712485897512e+00 ||r(i)||/||b|| 2.081619167679e-04
2004 KSP unpreconditioned resid norm 8.712485896596e+00 true resid norm 8.712485896592e+00 ||r(i)||/||b|| 2.081619167459e-04
2005 KSP unpreconditioned resid norm 8.712485895882e+00 true resid norm 8.712485895877e+00 ||r(i)||/||b|| 2.081619167288e-04
2006 KSP unpreconditioned resid norm 8.712485895002e+00 true resid norm 8.712485894995e+00 ||r(i)||/||b|| 2.081619167077e-04
2007 KSP unpreconditioned resid norm 8.712485893613e+00 true resid norm 8.712485893605e+00 ||r(i)||/||b|| 2.081619166745e-04
2008 KSP unpreconditioned resid norm 8.712485890306e+00 true resid norm 8.712485890301e+00 ||r(i)||/||b|| 2.081619165956e-04
2009 KSP unpreconditioned resid norm 8.712485888533e+00 true resid norm 8.712485888533e+00 ||r(i)||/||b|| 2.081619165533e-04
2010 KSP unpreconditioned resid norm 8.712485888401e+00 true resid norm 8.712485888401e+00 ||r(i)||/||b|| 2.081619165502e-04
2011 KSP unpreconditioned resid norm 8.712485888400e+00 true resid norm 8.712485888397e+00 ||r(i)||/||b|| 2.081619165501e-04
2012 KSP unpreconditioned resid norm 8.712485888393e+00 true resid norm 8.712485888391e+00 ||r(i)||/||b|| 2.081619165499e-04
2013 KSP unpreconditioned resid norm 8.712485888357e+00 true resid norm 8.712485888351e+00 ||r(i)||/||b|| 2.081619165490e-04
2014 KSP unpreconditioned resid norm 8.712485888278e+00 true resid norm 8.712485888278e+00 ||r(i)||/||b|| 2.081619165472e-04
2015 KSP unpreconditioned resid norm 8.712485888183e+00 true resid norm 8.712485888179e+00 ||r(i)||/||b|| 2.081619165449e-04
2016 KSP unpreconditioned resid norm 8.712485888155e+00 true resid norm 8.712485888152e+00 ||r(i)||/||b|| 2.081619165442e-04
2017 KSP unpreconditioned resid norm 8.712485888141e+00 true resid norm 8.712485888148e+00 ||r(i)||/||b|| 2.081619165441e-04
2018 KSP unpreconditioned resid norm 8.712485888097e+00 true resid norm 8.712485888101e+00 ||r(i)||/||b|| 2.081619165430e-04
2019 KSP unpreconditioned resid norm 8.712485888011e+00 true resid norm 8.712485888009e+00 ||r(i)||/||b|| 2.081619165408e-04
2020 KSP unpreconditioned resid norm 8.712485887935e+00 true resid norm 8.712485887933e+00 ||r(i)||/||b|| 2.081619165390e-04
2021 KSP unpreconditioned resid norm 8.712485887916e+00 true resid norm 8.712485887913e+00 ||r(i)||/||b|| 2.081619165385e-04
2022 KSP unpreconditioned resid norm 8.712485887914e+00 true resid norm 8.712485887922e+00 ||r(i)||/||b|| 2.081619165387e-04
2023 KSP unpreconditioned resid norm 8.712485887831e+00 true resid norm 8.712485887833e+00 ||r(i)||/||b|| 2.081619165366e-04
2024 KSP unpreconditioned resid norm 8.712485887692e+00 true resid norm 8.712485887695e+00 ||r(i)||/||b|| 2.081619165333e-04
2025 KSP unpreconditioned resid norm 8.712485887495e+00 true resid norm 8.712485887487e+00 ||r(i)||/||b|| 2.081619165283e-04
2026 KSP unpreconditioned resid norm 8.712485887377e+00 true resid norm 8.712485887385e+00 ||r(i)||/||b|| 2.081619165259e-04
2027 KSP unpreconditioned resid norm 8.712485887276e+00 true resid norm 8.712485887276e+00 ||r(i)||/||b|| 2.081619165233e-04
2028 KSP unpreconditioned resid norm 8.712485887169e+00 true resid norm 8.712485887173e+00 ||r(i)||/||b|| 2.081619165208e-04
2029 KSP unpreconditioned resid norm 8.712485887073e+00 true resid norm 8.712485887076e+00 ||r(i)||/||b|| 2.081619165185e-04
2030 KSP unpreconditioned resid norm 8.712485887068e+00 true resid norm 8.712485887069e+00 ||r(i)||/||b|| 2.081619165184e-04
2031 KSP unpreconditioned resid norm 8.712485887054e+00 true resid norm 8.712485887055e+00 ||r(i)||/||b|| 2.081619165180e-04
2032 KSP unpreconditioned resid norm 8.712485886940e+00 true resid norm 8.712485886943e+00 ||r(i)||/||b|| 2.081619165153e-04
2033 KSP unpreconditioned resid norm 8.712485886345e+00 true resid norm 8.712485886346e+00 ||r(i)||/||b|| 2.081619165011e-04
2034 KSP unpreconditioned resid norm 8.712485885534e+00 true resid norm 8.712485885533e+00 ||r(i)||/||b|| 2.081619164816e-04
2035 KSP unpreconditioned resid norm 8.712485884916e+00 true resid norm 8.712485884914e+00 ||r(i)||/||b|| 2.081619164669e-04
2036 KSP unpreconditioned resid norm 8.712485884149e+00 true resid norm 8.712485884155e+00 ||r(i)||/||b|| 2.081619164487e-04
2037 KSP unpreconditioned resid norm 8.712485882919e+00 true resid norm 8.712485882930e+00 ||r(i)||/||b|| 2.081619164195e-04
2038 KSP unpreconditioned resid norm 8.712485879990e+00 true resid norm 8.712485879990e+00 ||r(i)||/||b|| 2.081619163492e-04
2039 KSP unpreconditioned resid norm 8.712485878400e+00 true resid norm 8.712485878393e+00 ||r(i)||/||b|| 2.081619163111e-04
2040 KSP unpreconditioned resid norm 8.712485878278e+00 true resid norm 8.712485878278e+00 ||r(i)||/||b|| 2.081619163083e-04
2041 KSP unpreconditioned resid norm 8.712485878278e+00 true resid norm 8.712485878279e+00 ||r(i)||/||b|| 2.081619163084e-04
2042 KSP unpreconditioned resid norm 8.712485878271e+00 true resid norm 8.712485878265e+00 ||r(i)||/||b|| 2.081619163080e-04
2043 KSP unpreconditioned resid norm 8.712485878239e+00 true resid norm 8.712485878248e+00 ||r(i)||/||b|| 2.081619163076e-04
2044 KSP unpreconditioned resid norm 8.712485878168e+00 true resid norm 8.712485878168e+00 ||r(i)||/||b|| 2.081619163057e-04
2045 KSP unpreconditioned resid norm 8.712485878084e+00 true resid norm 8.712485878088e+00 ||r(i)||/||b|| 2.081619163038e-04
2046 KSP unpreconditioned resid norm 8.712485878060e+00 true resid norm 8.712485878080e+00 ||r(i)||/||b|| 2.081619163036e-04
2047 KSP unpreconditioned resid norm 8.712485878047e+00 true resid norm 8.712485878064e+00 ||r(i)||/||b|| 2.081619163032e-04
2048 KSP unpreconditioned resid norm 8.712485878007e+00 true resid norm 8.712485878007e+00 ||r(i)||/||b|| 2.081619163018e-04
2049 KSP unpreconditioned resid norm 8.712485877932e+00 true resid norm 8.712485877944e+00 ||r(i)||/||b|| 2.081619163003e-04
2050 KSP unpreconditioned resid norm 8.712485877866e+00 true resid norm 8.712485877869e+00 ||r(i)||/||b|| 2.081619162985e-04
2051 KSP unpreconditioned resid norm 8.712485877849e+00 true resid norm 8.712485877858e+00 ||r(i)||/||b|| 2.081619162983e-04
2052 KSP unpreconditioned resid norm 8.712485877847e+00 true resid norm 8.712485877854e+00 ||r(i)||/||b|| 2.081619162982e-04
2053 KSP unpreconditioned resid norm 8.712485877773e+00 true resid norm 8.712485877777e+00 ||r(i)||/||b|| 2.081619162964e-04
2054 KSP unpreconditioned resid norm 8.712485877651e+00 true resid norm 8.712485877664e+00 ||r(i)||/||b|| 2.081619162936e-04
2055 KSP unpreconditioned resid norm 8.712485877474e+00 true resid norm 8.712485877482e+00 ||r(i)||/||b|| 2.081619162893e-04
2056 KSP unpreconditioned resid norm 8.712485877370e+00 true resid norm 8.712485877375e+00 ||r(i)||/||b|| 2.081619162867e-04
2057 KSP unpreconditioned resid norm 8.712485877280e+00 true resid norm 8.712485877287e+00 ||r(i)||/||b|| 2.081619162846e-04
2058 KSP unpreconditioned resid norm 8.712485877185e+00 true resid norm 8.712485877193e+00 ||r(i)||/||b|| 2.081619162824e-04
2059 KSP unpreconditioned resid norm 8.712485877101e+00 true resid norm 8.712485877109e+00 ||r(i)||/||b|| 2.081619162804e-04
2060 KSP unpreconditioned resid norm 8.712485877097e+00 true resid norm 8.712485877097e+00 ||r(i)||/||b|| 2.081619162801e-04
2061 KSP unpreconditioned resid norm 8.712485877085e+00 true resid norm 8.712485877095e+00 ||r(i)||/||b|| 2.081619162801e-04
2062 KSP unpreconditioned resid norm 8.712485876982e+00 true resid norm 8.712485876981e+00 ||r(i)||/||b|| 2.081619162773e-04
2063 KSP unpreconditioned resid norm 8.712485876449e+00 true resid norm 8.712485876451e+00 ||r(i)||/||b|| 2.081619162647e-04
2064 KSP unpreconditioned resid norm 8.712485875725e+00 true resid norm 8.712485875738e+00 ||r(i)||/||b|| 2.081619162476e-04
2065 KSP unpreconditioned resid norm 8.712485875168e+00 true resid norm 8.712485875182e+00 ||r(i)||/||b|| 2.081619162343e-04
2066 KSP unpreconditioned resid norm 8.712485874480e+00 true resid norm 8.712485874482e+00 ||r(i)||/||b|| 2.081619162176e-04
2067 KSP unpreconditioned resid norm 8.712485873393e+00 true resid norm 8.712485873397e+00 ||r(i)||/||b|| 2.081619161917e-04
2068 KSP unpreconditioned resid norm 8.712485870807e+00 true resid norm 8.712485870815e+00 ||r(i)||/||b|| 2.081619161300e-04
2069 KSP unpreconditioned resid norm 8.712485869419e+00 true resid norm 8.712485869424e+00 ||r(i)||/||b|| 2.081619160968e-04
2070 KSP unpreconditioned resid norm 8.712485869321e+00 true resid norm 8.712485869321e+00 ||r(i)||/||b|| 2.081619160943e-04
2071 KSP unpreconditioned resid norm 8.712485869320e+00 true resid norm 8.712485869337e+00 ||r(i)||/||b|| 2.081619160947e-04
2072 KSP unpreconditioned resid norm 8.712485869315e+00 true resid norm 8.712485869323e+00 ||r(i)||/||b|| 2.081619160944e-04
2073 KSP unpreconditioned resid norm 8.712485869287e+00 true resid norm 8.712485869294e+00 ||r(i)||/||b|| 2.081619160937e-04
2074 KSP unpreconditioned resid norm 8.712485869224e+00 true resid norm 8.712485869227e+00 ||r(i)||/||b|| 2.081619160921e-04
2075 KSP unpreconditioned resid norm 8.712485869150e+00 true resid norm 8.712485869161e+00 ||r(i)||/||b|| 2.081619160905e-04
2076 KSP unpreconditioned resid norm 8.712485869128e+00 true resid norm 8.712485869138e+00 ||r(i)||/||b|| 2.081619160899e-04
2077 KSP unpreconditioned resid norm 8.712485869118e+00 true resid norm 8.712485869125e+00 ||r(i)||/||b|| 2.081619160896e-04
2078 KSP unpreconditioned resid norm 8.712485869083e+00 true resid norm 8.712485869092e+00 ||r(i)||/||b|| 2.081619160888e-04
2079 KSP unpreconditioned resid norm 8.712485869016e+00 true resid norm 8.712485869019e+00 ||r(i)||/||b|| 2.081619160871e-04
2080 KSP unpreconditioned resid norm 8.712485868956e+00 true resid norm 8.712485868970e+00 ||r(i)||/||b|| 2.081619160859e-04
2081 KSP unpreconditioned resid norm 8.712485868941e+00 true resid norm 8.712485868956e+00 ||r(i)||/||b|| 2.081619160856e-04
2082 KSP unpreconditioned resid norm 8.712485868940e+00 true resid norm 8.712485868943e+00 ||r(i)||/||b|| 2.081619160853e-04
2083 KSP unpreconditioned resid norm 8.712485868875e+00 true resid norm 8.712485868886e+00 ||r(i)||/||b|| 2.081619160839e-04
2084 KSP unpreconditioned resid norm 8.712485868767e+00 true resid norm 8.712485868771e+00 ||r(i)||/||b|| 2.081619160812e-04
2085 KSP unpreconditioned resid norm 8.712485868612e+00 true resid norm 8.712485868617e+00 ||r(i)||/||b|| 2.081619160775e-04
2086 KSP unpreconditioned resid norm 8.712485868520e+00 true resid norm 8.712485868529e+00 ||r(i)||/||b|| 2.081619160754e-04
2087 KSP unpreconditioned resid norm 8.712485868441e+00 true resid norm 8.712485868461e+00 ||r(i)||/||b|| 2.081619160738e-04
2088 KSP unpreconditioned resid norm 8.712485868358e+00 true resid norm 8.712485868368e+00 ||r(i)||/||b|| 2.081619160715e-04
2089 KSP unpreconditioned resid norm 8.712485868282e+00 true resid norm 8.712485868288e+00 ||r(i)||/||b|| 2.081619160696e-04
2090 KSP unpreconditioned resid norm 8.712485868279e+00 true resid norm 8.712485868287e+00 ||r(i)||/||b|| 2.081619160696e-04
2091 KSP unpreconditioned resid norm 8.712485868267e+00 true resid norm 8.712485868279e+00 ||r(i)||/||b|| 2.081619160694e-04
2092 KSP unpreconditioned resid norm 8.712485868179e+00 true resid norm 8.712485868183e+00 ||r(i)||/||b|| 2.081619160671e-04
2093 KSP unpreconditioned resid norm 8.712485867712e+00 true resid norm 8.712485867718e+00 ||r(i)||/||b|| 2.081619160560e-04
2094 KSP unpreconditioned resid norm 8.712485867078e+00 true resid norm 8.712485867089e+00 ||r(i)||/||b|| 2.081619160410e-04
2095 KSP unpreconditioned resid norm 8.712485866594e+00 true resid norm 8.712485866597e+00 ||r(i)||/||b|| 2.081619160292e-04
2096 KSP unpreconditioned resid norm 8.712485865994e+00 true resid norm 8.712485866000e+00 ||r(i)||/||b|| 2.081619160150e-04
2097 KSP unpreconditioned resid norm 8.712485865032e+00 true resid norm 8.712485865044e+00 ||r(i)||/||b|| 2.081619159921e-04
2098 KSP unpreconditioned resid norm 8.712485862741e+00 true resid norm 8.712485862746e+00 ||r(i)||/||b|| 2.081619159372e-04
2099 KSP unpreconditioned resid norm 8.712485861499e+00 true resid norm 8.712485861514e+00 ||r(i)||/||b|| 2.081619159078e-04
2100 KSP unpreconditioned resid norm 8.712485861404e+00 true resid norm 8.712485861404e+00 ||r(i)||/||b|| 2.081619159052e-04
2101 KSP unpreconditioned resid norm 8.712485861404e+00 true resid norm 8.712485861409e+00 ||r(i)||/||b|| 2.081619159053e-04
2102 KSP unpreconditioned resid norm 8.712485861398e+00 true resid norm 8.712485861412e+00 ||r(i)||/||b|| 2.081619159054e-04
2103 KSP unpreconditioned resid norm 8.712485861373e+00 true resid norm 8.712485861375e+00 ||r(i)||/||b|| 2.081619159045e-04
2104 KSP unpreconditioned resid norm 8.712485861318e+00 true resid norm 8.712485861318e+00 ||r(i)||/||b|| 2.081619159031e-04
2105 KSP unpreconditioned resid norm 8.712485861252e+00 true resid norm 8.712485861268e+00 ||r(i)||/||b|| 2.081619159019e-04
2106 KSP unpreconditioned resid norm 8.712485861233e+00 true resid norm 8.712485861244e+00 ||r(i)||/||b|| 2.081619159013e-04
2107 KSP unpreconditioned resid norm 8.712485861223e+00 true resid norm 8.712485861224e+00 ||r(i)||/||b|| 2.081619159009e-04
2108 KSP unpreconditioned resid norm 8.712485861192e+00 true resid norm 8.712485861200e+00 ||r(i)||/||b|| 2.081619159003e-04
2109 KSP unpreconditioned resid norm 8.712485861133e+00 true resid norm 8.712485861134e+00 ||r(i)||/||b|| 2.081619158987e-04
2110 KSP unpreconditioned resid norm 8.712485861081e+00 true resid norm 8.712485861091e+00 ||r(i)||/||b|| 2.081619158977e-04
2111 KSP unpreconditioned resid norm 8.712485861068e+00 true resid norm 8.712485861070e+00 ||r(i)||/||b|| 2.081619158972e-04
2112 KSP unpreconditioned resid norm 8.712485861067e+00 true resid norm 8.712485861079e+00 ||r(i)||/||b|| 2.081619158974e-04
2113 KSP unpreconditioned resid norm 8.712485861009e+00 true resid norm 8.712485861016e+00 ||r(i)||/||b|| 2.081619158959e-04
2114 KSP unpreconditioned resid norm 8.712485860914e+00 true resid norm 8.712485860912e+00 ||r(i)||/||b|| 2.081619158934e-04
2115 KSP unpreconditioned resid norm 8.712485860776e+00 true resid norm 8.712485860776e+00 ||r(i)||/||b|| 2.081619158902e-04
2116 KSP unpreconditioned resid norm 8.712485860694e+00 true resid norm 8.712485860714e+00 ||r(i)||/||b|| 2.081619158887e-04
2117 KSP unpreconditioned resid norm 8.712485860624e+00 true resid norm 8.712485860623e+00 ||r(i)||/||b|| 2.081619158865e-04
2118 KSP unpreconditioned resid norm 8.712485860550e+00 true resid norm 8.712485860554e+00 ||r(i)||/||b|| 2.081619158849e-04
2119 KSP unpreconditioned resid norm 8.712485860484e+00 true resid norm 8.712485860494e+00 ||r(i)||/||b|| 2.081619158834e-04
2120 KSP unpreconditioned resid norm 8.712485860481e+00 true resid norm 8.712485860489e+00 ||r(i)||/||b|| 2.081619158833e-04
2121 KSP unpreconditioned resid norm 8.712485860471e+00 true resid norm 8.712485860478e+00 ||r(i)||/||b|| 2.081619158830e-04
2122 KSP unpreconditioned resid norm 8.712485860391e+00 true resid norm 8.712485860394e+00 ||r(i)||/||b|| 2.081619158810e-04
2123 KSP unpreconditioned resid norm 8.712485859974e+00 true resid norm 8.712485859970e+00 ||r(i)||/||b|| 2.081619158709e-04
2124 KSP unpreconditioned resid norm 8.712485859409e+00 true resid norm 8.712485859409e+00 ||r(i)||/||b|| 2.081619158575e-04
2125 KSP unpreconditioned resid norm 8.712485858973e+00 true resid norm 8.712485858975e+00 ||r(i)||/||b|| 2.081619158471e-04
2126 KSP unpreconditioned resid norm 8.712485858435e+00 true resid norm 8.712485858437e+00 ||r(i)||/||b|| 2.081619158343e-04
2127 KSP unpreconditioned resid norm 8.712485857586e+00 true resid norm 8.712485857594e+00 ||r(i)||/||b|| 2.081619158141e-04
2128 KSP unpreconditioned resid norm 8.712485855563e+00 true resid norm 8.712485855572e+00 ||r(i)||/||b|| 2.081619157658e-04
2129 KSP unpreconditioned resid norm 8.712485854476e+00 true resid norm 8.712485854484e+00 ||r(i)||/||b|| 2.081619157398e-04
2130 KSP unpreconditioned resid norm 8.712485854407e+00 true resid norm 8.712485854407e+00 ||r(i)||/||b|| 2.081619157380e-04
2131 KSP unpreconditioned resid norm 8.712485854406e+00 true resid norm 8.712485854406e+00 ||r(i)||/||b|| 2.081619157380e-04
2132 KSP unpreconditioned resid norm 8.712485854402e+00 true resid norm 8.712485854406e+00 ||r(i)||/||b|| 2.081619157380e-04
2133 KSP unpreconditioned resid norm 8.712485854380e+00 true resid norm 8.712485854382e+00 ||r(i)||/||b|| 2.081619157374e-04
2134 KSP unpreconditioned resid norm 8.712485854331e+00 true resid norm 8.712485854332e+00 ||r(i)||/||b|| 2.081619157362e-04
2135 KSP unpreconditioned resid norm 8.712485854273e+00 true resid norm 8.712485854286e+00 ||r(i)||/||b|| 2.081619157351e-04
2136 KSP unpreconditioned resid norm 8.712485854256e+00 true resid norm 8.712485854271e+00 ||r(i)||/||b|| 2.081619157347e-04
2137 KSP unpreconditioned resid norm 8.712485854248e+00 true resid norm 8.712485854248e+00 ||r(i)||/||b|| 2.081619157342e-04
2138 KSP unpreconditioned resid norm 8.712485854221e+00 true resid norm 8.712485854228e+00 ||r(i)||/||b|| 2.081619157337e-04
2139 KSP unpreconditioned resid norm 8.712485854168e+00 true resid norm 8.712485854165e+00 ||r(i)||/||b|| 2.081619157322e-04
2140 KSP unpreconditioned resid norm 8.712485854122e+00 true resid norm 8.712485854126e+00 ||r(i)||/||b|| 2.081619157313e-04
2141 KSP unpreconditioned resid norm 8.712485854110e+00 true resid norm 8.712485854114e+00 ||r(i)||/||b|| 2.081619157310e-04
2142 KSP unpreconditioned resid norm 8.712485854109e+00 true resid norm 8.712485854109e+00 ||r(i)||/||b|| 2.081619157309e-04
2143 KSP unpreconditioned resid norm 8.712485854058e+00 true resid norm 8.712485854057e+00 ||r(i)||/||b|| 2.081619157296e-04
2144 KSP unpreconditioned resid norm 8.712485853973e+00 true resid norm 8.712485853976e+00 ||r(i)||/||b|| 2.081619157277e-04
2145 KSP unpreconditioned resid norm 8.712485853853e+00 true resid norm 8.712485853859e+00 ||r(i)||/||b|| 2.081619157249e-04
2146 KSP unpreconditioned resid norm 8.712485853781e+00 true resid norm 8.712485853789e+00 ||r(i)||/||b|| 2.081619157232e-04
2147 KSP unpreconditioned resid norm 8.712485853718e+00 true resid norm 8.712485853715e+00 ||r(i)||/||b|| 2.081619157215e-04
2148 KSP unpreconditioned resid norm 8.712485853653e+00 true resid norm 8.712485853655e+00 ||r(i)||/||b|| 2.081619157200e-04
2149 KSP unpreconditioned resid norm 8.712485853594e+00 true resid norm 8.712485853591e+00 ||r(i)||/||b|| 2.081619157185e-04
2150 KSP unpreconditioned resid norm 8.712485853592e+00 true resid norm 8.712485853597e+00 ||r(i)||/||b|| 2.081619157186e-04
2151 KSP unpreconditioned resid norm 8.712485853583e+00 true resid norm 8.712485853592e+00 ||r(i)||/||b|| 2.081619157185e-04
2152 KSP unpreconditioned resid norm 8.712485853513e+00 true resid norm 8.712485853514e+00 ||r(i)||/||b|| 2.081619157166e-04
2153 KSP unpreconditioned resid norm 8.712485853148e+00 true resid norm 8.712485853145e+00 ||r(i)||/||b|| 2.081619157078e-04
2154 KSP unpreconditioned resid norm 8.712485852652e+00 true resid norm 8.712485852659e+00 ||r(i)||/||b|| 2.081619156962e-04
2155 KSP unpreconditioned resid norm 8.712485852273e+00 true resid norm 8.712485852284e+00 ||r(i)||/||b|| 2.081619156873e-04
2156 KSP unpreconditioned resid norm 8.712485851803e+00 true resid norm 8.712485851810e+00 ||r(i)||/||b|| 2.081619156759e-04
2157 KSP unpreconditioned resid norm 8.712485851051e+00 true resid norm 8.712485851056e+00 ||r(i)||/||b|| 2.081619156579e-04
2158 KSP unpreconditioned resid norm 8.712485849260e+00 true resid norm 8.712485849269e+00 ||r(i)||/||b|| 2.081619156152e-04
2159 KSP unpreconditioned resid norm 8.712485848289e+00 true resid norm 8.712485848289e+00 ||r(i)||/||b|| 2.081619155918e-04
2160 KSP unpreconditioned resid norm 8.712485848225e+00 true resid norm 8.712485848225e+00 ||r(i)||/||b|| 2.081619155903e-04
2161 KSP unpreconditioned resid norm 8.712485848224e+00 true resid norm 8.712485848217e+00 ||r(i)||/||b|| 2.081619155901e-04
2162 KSP unpreconditioned resid norm 8.712485848220e+00 true resid norm 8.712485848212e+00 ||r(i)||/||b|| 2.081619155900e-04
2163 KSP unpreconditioned resid norm 8.712485848200e+00 true resid norm 8.712485848200e+00 ||r(i)||/||b|| 2.081619155897e-04
2164 KSP unpreconditioned resid norm 8.712485848157e+00 true resid norm 8.712485848156e+00 ||r(i)||/||b|| 2.081619155886e-04
2165 KSP unpreconditioned resid norm 8.712485848106e+00 true resid norm 8.712485848101e+00 ||r(i)||/||b|| 2.081619155873e-04
2166 KSP unpreconditioned resid norm 8.712485848091e+00 true resid norm 8.712485848088e+00 ||r(i)||/||b|| 2.081619155870e-04
2167 KSP unpreconditioned resid norm 8.712485848083e+00 true resid norm 8.712485848082e+00 ||r(i)||/||b|| 2.081619155869e-04
2168 KSP unpreconditioned resid norm 8.712485848059e+00 true resid norm 8.712485848063e+00 ||r(i)||/||b|| 2.081619155864e-04
2169 KSP unpreconditioned resid norm 8.712485848013e+00 true resid norm 8.712485848015e+00 ||r(i)||/||b|| 2.081619155853e-04
2170 KSP unpreconditioned resid norm 8.712485847972e+00 true resid norm 8.712485847965e+00 ||r(i)||/||b|| 2.081619155841e-04
2171 KSP unpreconditioned resid norm 8.712485847962e+00 true resid norm 8.712485847957e+00 ||r(i)||/||b|| 2.081619155839e-04
2172 KSP unpreconditioned resid norm 8.712485847961e+00 true resid norm 8.712485847961e+00 ||r(i)||/||b|| 2.081619155840e-04
2173 KSP unpreconditioned resid norm 8.712485847916e+00 true resid norm 8.712485847917e+00 ||r(i)||/||b|| 2.081619155829e-04
2174 KSP unpreconditioned resid norm 8.712485847841e+00 true resid norm 8.712485847833e+00 ||r(i)||/||b|| 2.081619155809e-04
2175 KSP unpreconditioned resid norm 8.712485847733e+00 true resid norm 8.712485847730e+00 ||r(i)||/||b|| 2.081619155785e-04
2176 KSP unpreconditioned resid norm 8.712485847669e+00 true resid norm 8.712485847675e+00 ||r(i)||/||b|| 2.081619155771e-04
2177 KSP unpreconditioned resid norm 8.712485847615e+00 true resid norm 8.712485847607e+00 ||r(i)||/||b|| 2.081619155755e-04
2178 KSP unpreconditioned resid norm 8.712485847557e+00 true resid norm 8.712485847554e+00 ||r(i)||/||b|| 2.081619155742e-04
2179 KSP unpreconditioned resid norm 8.712485847505e+00 true resid norm 8.712485847504e+00 ||r(i)||/||b|| 2.081619155731e-04
2180 KSP unpreconditioned resid norm 8.712485847503e+00 true resid norm 8.712485847500e+00 ||r(i)||/||b|| 2.081619155730e-04
2181 KSP unpreconditioned resid norm 8.712485847495e+00 true resid norm 8.712485847505e+00 ||r(i)||/||b|| 2.081619155731e-04
2182 KSP unpreconditioned resid norm 8.712485847432e+00 true resid norm 8.712485847433e+00 ||r(i)||/||b|| 2.081619155714e-04
2183 KSP unpreconditioned resid norm 8.712485847107e+00 true resid norm 8.712485847100e+00 ||r(i)||/||b|| 2.081619155634e-04
2184 KSP unpreconditioned resid norm 8.712485846665e+00 true resid norm 8.712485846654e+00 ||r(i)||/||b|| 2.081619155528e-04
2185 KSP unpreconditioned resid norm 8.712485846324e+00 true resid norm 8.712485846323e+00 ||r(i)||/||b|| 2.081619155448e-04
2186 KSP unpreconditioned resid norm 8.712485845904e+00 true resid norm 8.712485845908e+00 ||r(i)||/||b|| 2.081619155349e-04
2187 KSP unpreconditioned resid norm 8.712485845240e+00 true resid norm 8.712485845226e+00 ||r(i)||/||b|| 2.081619155186e-04
2188 KSP unpreconditioned resid norm 8.712485843657e+00 true resid norm 8.712485843652e+00 ||r(i)||/||b|| 2.081619154810e-04
2189 KSP unpreconditioned resid norm 8.712485842807e+00 true resid norm 8.712485842805e+00 ||r(i)||/||b|| 2.081619154608e-04
2190 KSP unpreconditioned resid norm 8.712485842738e+00 true resid norm 8.712485842738e+00 ||r(i)||/||b|| 2.081619154592e-04
2191 KSP unpreconditioned resid norm 8.712485842737e+00 true resid norm 8.712485842743e+00 ||r(i)||/||b|| 2.081619154593e-04
2192 KSP unpreconditioned resid norm 8.712485842734e+00 true resid norm 8.712485842745e+00 ||r(i)||/||b|| 2.081619154593e-04
2193 KSP unpreconditioned resid norm 8.712485842717e+00 true resid norm 8.712485842716e+00 ||r(i)||/||b|| 2.081619154587e-04
2194 KSP unpreconditioned resid norm 8.712485842679e+00 true resid norm 8.712485842696e+00 ||r(i)||/||b|| 2.081619154582e-04
2195 KSP unpreconditioned resid norm 8.712485842633e+00 true resid norm 8.712485842645e+00 ||r(i)||/||b|| 2.081619154570e-04
2196 KSP unpreconditioned resid norm 8.712485842620e+00 true resid norm 8.712485842630e+00 ||r(i)||/||b|| 2.081619154566e-04
2197 KSP unpreconditioned resid norm 8.712485842613e+00 true resid norm 8.712485842617e+00 ||r(i)||/||b|| 2.081619154563e-04
2198 KSP unpreconditioned resid norm 8.712485842592e+00 true resid norm 8.712485842601e+00 ||r(i)||/||b|| 2.081619154559e-04
2199 KSP unpreconditioned resid norm 8.712485842551e+00 true resid norm 8.712485842553e+00 ||r(i)||/||b|| 2.081619154548e-04
2200 KSP unpreconditioned resid norm 8.712485842515e+00 true resid norm 8.712485842522e+00 ||r(i)||/||b|| 2.081619154540e-04
2201 KSP unpreconditioned resid norm 8.712485842506e+00 true resid norm 8.712485842509e+00 ||r(i)||/||b|| 2.081619154537e-04
2202 KSP unpreconditioned resid norm 8.712485842505e+00 true resid norm 8.712485842507e+00 ||r(i)||/||b|| 2.081619154537e-04
2203 KSP unpreconditioned resid norm 8.712485842465e+00 true resid norm 8.712485842472e+00 ||r(i)||/||b|| 2.081619154528e-04
2204 KSP unpreconditioned resid norm 8.712485842399e+00 true resid norm 8.712485842415e+00 ||r(i)||/||b|| 2.081619154515e-04
2205 KSP unpreconditioned resid norm 8.712485842304e+00 true resid norm 8.712485842304e+00 ||r(i)||/||b|| 2.081619154488e-04
2206 KSP unpreconditioned resid norm 8.712485842248e+00 true resid norm 8.712485842255e+00 ||r(i)||/||b|| 2.081619154476e-04
2207 KSP unpreconditioned resid norm 8.712485842199e+00 true resid norm 8.712485842213e+00 ||r(i)||/||b|| 2.081619154466e-04
2208 KSP unpreconditioned resid norm 8.712485842148e+00 true resid norm 8.712485842149e+00 ||r(i)||/||b|| 2.081619154451e-04
2209 KSP unpreconditioned resid norm 8.712485842102e+00 true resid norm 8.712485842104e+00 ||r(i)||/||b|| 2.081619154440e-04
2210 KSP unpreconditioned resid norm 8.712485842100e+00 true resid norm 8.712485842106e+00 ||r(i)||/||b|| 2.081619154441e-04
2211 KSP unpreconditioned resid norm 8.712485842093e+00 true resid norm 8.712485842101e+00 ||r(i)||/||b|| 2.081619154440e-04
2212 KSP unpreconditioned resid norm 8.712485842039e+00 true resid norm 8.712485842051e+00 ||r(i)||/||b|| 2.081619154428e-04
2213 KSP unpreconditioned resid norm 8.712485841753e+00 true resid norm 8.712485841765e+00 ||r(i)||/||b|| 2.081619154359e-04
2214 KSP unpreconditioned resid norm 8.712485841365e+00 true resid norm 8.712485841371e+00 ||r(i)||/||b|| 2.081619154265e-04
2215 KSP unpreconditioned resid norm 8.712485841069e+00 true resid norm 8.712485841066e+00 ||r(i)||/||b|| 2.081619154192e-04
2216 KSP unpreconditioned resid norm 8.712485840701e+00 true resid norm 8.712485840714e+00 ||r(i)||/||b|| 2.081619154108e-04
2217 KSP unpreconditioned resid norm 8.712485840113e+00 true resid norm 8.712485840123e+00 ||r(i)||/||b|| 2.081619153967e-04
2218 KSP unpreconditioned resid norm 8.712485838712e+00 true resid norm 8.712485838719e+00 ||r(i)||/||b|| 2.081619153632e-04
2219 KSP unpreconditioned resid norm 8.712485837953e+00 true resid norm 8.712485837963e+00 ||r(i)||/||b|| 2.081619153451e-04
2220 KSP unpreconditioned resid norm 8.712485837904e+00 true resid norm 8.712485837904e+00 ||r(i)||/||b|| 2.081619153437e-04
2221 KSP unpreconditioned resid norm 8.712485837903e+00 true resid norm 8.712485837908e+00 ||r(i)||/||b|| 2.081619153438e-04
2222 KSP unpreconditioned resid norm 8.712485837900e+00 true resid norm 8.712485837902e+00 ||r(i)||/||b|| 2.081619153436e-04
2223 KSP unpreconditioned resid norm 8.712485837885e+00 true resid norm 8.712485837880e+00 ||r(i)||/||b|| 2.081619153431e-04
2224 KSP unpreconditioned resid norm 8.712485837851e+00 true resid norm 8.712485837849e+00 ||r(i)||/||b|| 2.081619153424e-04
2225 KSP unpreconditioned resid norm 8.712485837811e+00 true resid norm 8.712485837810e+00 ||r(i)||/||b|| 2.081619153414e-04
2226 KSP unpreconditioned resid norm 8.712485837799e+00 true resid norm 8.712485837803e+00 ||r(i)||/||b|| 2.081619153413e-04
2227 KSP unpreconditioned resid norm 8.712485837793e+00 true resid norm 8.712485837791e+00 ||r(i)||/||b|| 2.081619153410e-04
2228 KSP unpreconditioned resid norm 8.712485837774e+00 true resid norm 8.712485837779e+00 ||r(i)||/||b|| 2.081619153407e-04
2229 KSP unpreconditioned resid norm 8.712485837738e+00 true resid norm 8.712485837739e+00 ||r(i)||/||b|| 2.081619153397e-04
2230 KSP unpreconditioned resid norm 8.712485837706e+00 true resid norm 8.712485837701e+00 ||r(i)||/||b|| 2.081619153388e-04
2231 KSP unpreconditioned resid norm 8.712485837698e+00 true resid norm 8.712485837702e+00 ||r(i)||/||b|| 2.081619153389e-04
2232 KSP unpreconditioned resid norm 8.712485837697e+00 true resid norm 8.712485837699e+00 ||r(i)||/||b|| 2.081619153388e-04
2233 KSP unpreconditioned resid norm 8.712485837662e+00 true resid norm 8.712485837669e+00 ||r(i)||/||b|| 2.081619153381e-04
2234 KSP unpreconditioned resid norm 8.712485837604e+00 true resid norm 8.712485837608e+00 ||r(i)||/||b|| 2.081619153366e-04
2235 KSP unpreconditioned resid norm 8.712485837519e+00 true resid norm 8.712485837510e+00 ||r(i)||/||b|| 2.081619153343e-04
2236 KSP unpreconditioned resid norm 8.712485837469e+00 true resid norm 8.712485837470e+00 ||r(i)||/||b|| 2.081619153333e-04
2237 KSP unpreconditioned resid norm 8.712485837427e+00 true resid norm 8.712485837423e+00 ||r(i)||/||b|| 2.081619153322e-04
2238 KSP unpreconditioned resid norm 8.712485837381e+00 true resid norm 8.712485837370e+00 ||r(i)||/||b|| 2.081619153309e-04
2239 KSP unpreconditioned resid norm 8.712485837341e+00 true resid norm 8.712485837333e+00 ||r(i)||/||b|| 2.081619153301e-04
2240 KSP unpreconditioned resid norm 8.712485837339e+00 true resid norm 8.712485837345e+00 ||r(i)||/||b|| 2.081619153303e-04
2241 KSP unpreconditioned resid norm 8.712485837333e+00 true resid norm 8.712485837330e+00 ||r(i)||/||b|| 2.081619153300e-04
2242 KSP unpreconditioned resid norm 8.712485837284e+00 true resid norm 8.712485837273e+00 ||r(i)||/||b|| 2.081619153286e-04
2243 KSP unpreconditioned resid norm 8.712485837030e+00 true resid norm 8.712485837028e+00 ||r(i)||/||b|| 2.081619153228e-04
2244 KSP unpreconditioned resid norm 8.712485836684e+00 true resid norm 8.712485836687e+00 ||r(i)||/||b|| 2.081619153146e-04
2245 KSP unpreconditioned resid norm 8.712485836418e+00 true resid norm 8.712485836415e+00 ||r(i)||/||b|| 2.081619153081e-04
2246 KSP unpreconditioned resid norm 8.712485836090e+00 true resid norm 8.712485836082e+00 ||r(i)||/||b|| 2.081619153001e-04
2247 KSP unpreconditioned resid norm 8.712485835570e+00 true resid norm 8.712485835567e+00 ||r(i)||/||b|| 2.081619152878e-04
2248 KSP unpreconditioned resid norm 8.712485834333e+00 true resid norm 8.712485834336e+00 ||r(i)||/||b|| 2.081619152584e-04
2249 KSP unpreconditioned resid norm 8.712485833667e+00 true resid norm 8.712485833671e+00 ||r(i)||/||b|| 2.081619152425e-04
2250 KSP unpreconditioned resid norm 8.712485833619e+00 true resid norm 8.712485833619e+00 ||r(i)||/||b|| 2.081619152413e-04
2251 KSP unpreconditioned resid norm 8.712485833619e+00 true resid norm 8.712485833624e+00 ||r(i)||/||b|| 2.081619152414e-04
2252 KSP unpreconditioned resid norm 8.712485833616e+00 true resid norm 8.712485833609e+00 ||r(i)||/||b|| 2.081619152411e-04
2253 KSP unpreconditioned resid norm 8.712485833603e+00 true resid norm 8.712485833608e+00 ||r(i)||/||b|| 2.081619152410e-04
2254 KSP unpreconditioned resid norm 8.712485833573e+00 true resid norm 8.712485833569e+00 ||r(i)||/||b|| 2.081619152401e-04
2255 KSP unpreconditioned resid norm 8.712485833538e+00 true resid norm 8.712485833549e+00 ||r(i)||/||b|| 2.081619152396e-04
2256 KSP unpreconditioned resid norm 8.712485833527e+00 true resid norm 8.712485833529e+00 ||r(i)||/||b|| 2.081619152392e-04
2257 KSP unpreconditioned resid norm 8.712485833522e+00 true resid norm 8.712485833522e+00 ||r(i)||/||b|| 2.081619152390e-04
2258 KSP unpreconditioned resid norm 8.712485833505e+00 true resid norm 8.712485833514e+00 ||r(i)||/||b|| 2.081619152388e-04
2259 KSP unpreconditioned resid norm 8.712485833473e+00 true resid norm 8.712485833478e+00 ||r(i)||/||b|| 2.081619152379e-04
2260 KSP unpreconditioned resid norm 8.712485833445e+00 true resid norm 8.712485833446e+00 ||r(i)||/||b|| 2.081619152372e-04
2261 KSP unpreconditioned resid norm 8.712485833438e+00 true resid norm 8.712485833440e+00 ||r(i)||/||b|| 2.081619152370e-04
2262 KSP unpreconditioned resid norm 8.712485833437e+00 true resid norm 8.712485833441e+00 ||r(i)||/||b|| 2.081619152371e-04
2263 KSP unpreconditioned resid norm 8.712485833406e+00 true resid norm 8.712485833414e+00 ||r(i)||/||b|| 2.081619152364e-04
2264 KSP unpreconditioned resid norm 8.712485833354e+00 true resid norm 8.712485833362e+00 ||r(i)||/||b|| 2.081619152352e-04
2265 KSP unpreconditioned resid norm 8.712485833280e+00 true resid norm 8.712485833286e+00 ||r(i)||/||b|| 2.081619152334e-04
2266 KSP unpreconditioned resid norm 8.712485833236e+00 true resid norm 8.712485833232e+00 ||r(i)||/||b|| 2.081619152321e-04
2267 KSP unpreconditioned resid norm 8.712485833198e+00 true resid norm 8.712485833209e+00 ||r(i)||/||b|| 2.081619152315e-04
2268 KSP unpreconditioned resid norm 8.712485833158e+00 true resid norm 8.712485833147e+00 ||r(i)||/||b|| 2.081619152300e-04
2269 KSP unpreconditioned resid norm 8.712485833122e+00 true resid norm 8.712485833124e+00 ||r(i)||/||b|| 2.081619152295e-04
2270 KSP unpreconditioned resid norm 8.712485833121e+00 true resid norm 8.712485833127e+00 ||r(i)||/||b|| 2.081619152295e-04
2271 KSP unpreconditioned resid norm 8.712485833115e+00 true resid norm 8.712485833114e+00 ||r(i)||/||b|| 2.081619152292e-04
2272 KSP unpreconditioned resid norm 8.712485833073e+00 true resid norm 8.712485833077e+00 ||r(i)||/||b|| 2.081619152284e-04
2273 KSP unpreconditioned resid norm 8.712485832849e+00 true resid norm 8.712485832849e+00 ||r(i)||/||b|| 2.081619152229e-04
2274 KSP unpreconditioned resid norm 8.712485832546e+00 true resid norm 8.712485832550e+00 ||r(i)||/||b|| 2.081619152158e-04
2275 KSP unpreconditioned resid norm 8.712485832314e+00 true resid norm 8.712485832316e+00 ||r(i)||/||b|| 2.081619152102e-04
2276 KSP unpreconditioned resid norm 8.712485832026e+00 true resid norm 8.712485832038e+00 ||r(i)||/||b|| 2.081619152035e-04
2277 KSP unpreconditioned resid norm 8.712485831566e+00 true resid norm 8.712485831557e+00 ||r(i)||/||b|| 2.081619151921e-04
2278 KSP unpreconditioned resid norm 8.712485830470e+00 true resid norm 8.712485830479e+00 ||r(i)||/||b|| 2.081619151663e-04
2279 KSP unpreconditioned resid norm 8.712485829877e+00 true resid norm 8.712485829885e+00 ||r(i)||/||b|| 2.081619151521e-04
2280 KSP unpreconditioned resid norm 8.712485829834e+00 true resid norm 8.712485829834e+00 ||r(i)||/||b|| 2.081619151509e-04
2281 KSP unpreconditioned resid norm 8.712485829834e+00 true resid norm 8.712485829839e+00 ||r(i)||/||b|| 2.081619151510e-04
2282 KSP unpreconditioned resid norm 8.712485829832e+00 true resid norm 8.712485829821e+00 ||r(i)||/||b|| 2.081619151506e-04
2283 KSP unpreconditioned resid norm 8.712485829820e+00 true resid norm 8.712485829813e+00 ||r(i)||/||b|| 2.081619151504e-04
2284 KSP unpreconditioned resid norm 8.712485829793e+00 true resid norm 8.712485829788e+00 ||r(i)||/||b|| 2.081619151498e-04
2285 KSP unpreconditioned resid norm 8.712485829762e+00 true resid norm 8.712485829758e+00 ||r(i)||/||b|| 2.081619151491e-04
2286 KSP unpreconditioned resid norm 8.712485829753e+00 true resid norm 8.712485829751e+00 ||r(i)||/||b|| 2.081619151489e-04
2287 KSP unpreconditioned resid norm 8.712485829748e+00 true resid norm 8.712485829739e+00 ||r(i)||/||b|| 2.081619151486e-04
2288 KSP unpreconditioned resid norm 8.712485829733e+00 true resid norm 8.712485829735e+00 ||r(i)||/||b|| 2.081619151485e-04
2289 KSP unpreconditioned resid norm 8.712485829705e+00 true resid norm 8.712485829702e+00 ||r(i)||/||b|| 2.081619151477e-04
2290 KSP unpreconditioned resid norm 8.712485829680e+00 true resid norm 8.712485829675e+00 ||r(i)||/||b|| 2.081619151471e-04
2291 KSP unpreconditioned resid norm 8.712485829674e+00 true resid norm 8.712485829669e+00 ||r(i)||/||b|| 2.081619151469e-04
2292 KSP unpreconditioned resid norm 8.712485829673e+00 true resid norm 8.712485829670e+00 ||r(i)||/||b|| 2.081619151470e-04
2293 KSP unpreconditioned resid norm 8.712485829645e+00 true resid norm 8.712485829636e+00 ||r(i)||/||b|| 2.081619151461e-04
2294 KSP unpreconditioned resid norm 8.712485829600e+00 true resid norm 8.712485829594e+00 ||r(i)||/||b|| 2.081619151451e-04
2295 KSP unpreconditioned resid norm 8.712485829534e+00 true resid norm 8.712485829529e+00 ||r(i)||/||b|| 2.081619151436e-04
2296 KSP unpreconditioned resid norm 8.712485829495e+00 true resid norm 8.712485829487e+00 ||r(i)||/||b|| 2.081619151426e-04
2297 KSP unpreconditioned resid norm 8.712485829461e+00 true resid norm 8.712485829463e+00 ||r(i)||/||b|| 2.081619151420e-04
2298 KSP unpreconditioned resid norm 8.712485829426e+00 true resid norm 8.712485829426e+00 ||r(i)||/||b|| 2.081619151411e-04
2299 KSP unpreconditioned resid norm 8.712485829394e+00 true resid norm 8.712485829382e+00 ||r(i)||/||b|| 2.081619151401e-04
2300 KSP unpreconditioned resid norm 8.712485829393e+00 true resid norm 8.712485829397e+00 ||r(i)||/||b|| 2.081619151404e-04
2301 KSP unpreconditioned resid norm 8.712485829388e+00 true resid norm 8.712485829380e+00 ||r(i)||/||b|| 2.081619151400e-04
2302 KSP unpreconditioned resid norm 8.712485829350e+00 true resid norm 8.712485829342e+00 ||r(i)||/||b|| 2.081619151391e-04
2303 KSP unpreconditioned resid norm 8.712485829151e+00 true resid norm 8.712485829144e+00 ||r(i)||/||b|| 2.081619151344e-04
2304 KSP unpreconditioned resid norm 8.712485828881e+00 true resid norm 8.712485828882e+00 ||r(i)||/||b|| 2.081619151281e-04
2305 KSP unpreconditioned resid norm 8.712485828673e+00 true resid norm 8.712485828661e+00 ||r(i)||/||b|| 2.081619151228e-04
2306 KSP unpreconditioned resid norm 8.712485828416e+00 true resid norm 8.712485828412e+00 ||r(i)||/||b|| 2.081619151169e-04
2307 KSP unpreconditioned resid norm 8.712485828010e+00 true resid norm 8.712485828009e+00 ||r(i)||/||b|| 2.081619151073e-04
2308 KSP unpreconditioned resid norm 8.712485827042e+00 true resid norm 8.712485827042e+00 ||r(i)||/||b|| 2.081619150842e-04
2309 KSP unpreconditioned resid norm 8.712485826521e+00 true resid norm 8.712485826508e+00 ||r(i)||/||b|| 2.081619150714e-04
2310 KSP unpreconditioned resid norm 8.712485826481e+00 true resid norm 8.712485826481e+00 ||r(i)||/||b|| 2.081619150708e-04
2311 KSP unpreconditioned resid norm 8.712485826481e+00 true resid norm 8.712485826480e+00 ||r(i)||/||b|| 2.081619150707e-04
2312 KSP unpreconditioned resid norm 8.712485826479e+00 true resid norm 8.712485826480e+00 ||r(i)||/||b|| 2.081619150707e-04
2313 KSP unpreconditioned resid norm 8.712485826468e+00 true resid norm 8.712485826465e+00 ||r(i)||/||b|| 2.081619150704e-04
2314 KSP unpreconditioned resid norm 8.712485826445e+00 true resid norm 8.712485826440e+00 ||r(i)||/||b|| 2.081619150698e-04
2315 KSP unpreconditioned resid norm 8.712485826417e+00 true resid norm 8.712485826413e+00 ||r(i)||/||b|| 2.081619150691e-04
2316 KSP unpreconditioned resid norm 8.712485826409e+00 true resid norm 8.712485826405e+00 ||r(i)||/||b|| 2.081619150689e-04
2317 KSP unpreconditioned resid norm 8.712485826405e+00 true resid norm 8.712485826396e+00 ||r(i)||/||b|| 2.081619150687e-04
2318 KSP unpreconditioned resid norm 8.712485826392e+00 true resid norm 8.712485826398e+00 ||r(i)||/||b|| 2.081619150688e-04
2319 KSP unpreconditioned resid norm 8.712485826367e+00 true resid norm 8.712485826365e+00 ||r(i)||/||b|| 2.081619150680e-04
2320 KSP unpreconditioned resid norm 8.712485826345e+00 true resid norm 8.712485826347e+00 ||r(i)||/||b|| 2.081619150676e-04
2321 KSP unpreconditioned resid norm 8.712485826339e+00 true resid norm 8.712485826337e+00 ||r(i)||/||b|| 2.081619150673e-04
2322 KSP unpreconditioned resid norm 8.712485826339e+00 true resid norm 8.712485826339e+00 ||r(i)||/||b|| 2.081619150674e-04
2323 KSP unpreconditioned resid norm 8.712485826314e+00 true resid norm 8.712485826319e+00 ||r(i)||/||b|| 2.081619150669e-04
2324 KSP unpreconditioned resid norm 8.712485826274e+00 true resid norm 8.712485826277e+00 ||r(i)||/||b|| 2.081619150659e-04
2325 KSP unpreconditioned resid norm 8.712485826216e+00 true resid norm 8.712485826220e+00 ||r(i)||/||b|| 2.081619150645e-04
2326 KSP unpreconditioned resid norm 8.712485826182e+00 true resid norm 8.712485826176e+00 ||r(i)||/||b|| 2.081619150635e-04
2327 KSP unpreconditioned resid norm 8.712485826152e+00 true resid norm 8.712485826152e+00 ||r(i)||/||b|| 2.081619150629e-04
2328 KSP unpreconditioned resid norm 8.712485826121e+00 true resid norm 8.712485826127e+00 ||r(i)||/||b|| 2.081619150623e-04
2329 KSP unpreconditioned resid norm 8.712485826093e+00 true resid norm 8.712485826092e+00 ||r(i)||/||b|| 2.081619150615e-04
2330 KSP unpreconditioned resid norm 8.712485826091e+00 true resid norm 8.712485826090e+00 ||r(i)||/||b|| 2.081619150614e-04
2331 KSP unpreconditioned resid norm 8.712485826087e+00 true resid norm 8.712485826089e+00 ||r(i)||/||b|| 2.081619150614e-04
2332 KSP unpreconditioned resid norm 8.712485826054e+00 true resid norm 8.712485826063e+00 ||r(i)||/||b|| 2.081619150608e-04
2333 KSP unpreconditioned resid norm 8.712485825879e+00 true resid norm 8.712485825874e+00 ||r(i)||/||b|| 2.081619150563e-04
2334 KSP unpreconditioned resid norm 8.712485825641e+00 true resid norm 8.712485825649e+00 ||r(i)||/||b|| 2.081619150509e-04
2335 KSP unpreconditioned resid norm 8.712485825460e+00 true resid norm 8.712485825453e+00 ||r(i)||/||b|| 2.081619150462e-04
2336 KSP unpreconditioned resid norm 8.712485825235e+00 true resid norm 8.712485825240e+00 ||r(i)||/||b|| 2.081619150411e-04
2337 KSP unpreconditioned resid norm 8.712485824875e+00 true resid norm 8.712485824886e+00 ||r(i)||/||b|| 2.081619150327e-04
2338 KSP unpreconditioned resid norm 8.712485824018e+00 true resid norm 8.712485824018e+00 ||r(i)||/||b|| 2.081619150119e-04
2339 KSP unpreconditioned resid norm 8.712485823554e+00 true resid norm 8.712485823559e+00 ||r(i)||/||b|| 2.081619150010e-04
2340 KSP unpreconditioned resid norm 8.712485823510e+00 true resid norm 8.712485823510e+00 ||r(i)||/||b|| 2.081619149998e-04
2341 KSP unpreconditioned resid norm 8.712485823509e+00 true resid norm 8.712485823516e+00 ||r(i)||/||b|| 2.081619149999e-04
2342 KSP unpreconditioned resid norm 8.712485823507e+00 true resid norm 8.712485823511e+00 ||r(i)||/||b|| 2.081619149998e-04
2343 KSP unpreconditioned resid norm 8.712485823498e+00 true resid norm 8.712485823498e+00 ||r(i)||/||b|| 2.081619149995e-04
2344 KSP unpreconditioned resid norm 8.712485823477e+00 true resid norm 8.712485823478e+00 ||r(i)||/||b|| 2.081619149990e-04
2345 KSP unpreconditioned resid norm 8.712485823453e+00 true resid norm 8.712485823449e+00 ||r(i)||/||b|| 2.081619149983e-04
2346 KSP unpreconditioned resid norm 8.712485823446e+00 true resid norm 8.712485823442e+00 ||r(i)||/||b|| 2.081619149982e-04
2347 KSP unpreconditioned resid norm 8.712485823442e+00 true resid norm 8.712485823450e+00 ||r(i)||/||b|| 2.081619149984e-04
2348 KSP unpreconditioned resid norm 8.712485823430e+00 true resid norm 8.712485823439e+00 ||r(i)||/||b|| 2.081619149981e-04
2349 KSP unpreconditioned resid norm 8.712485823408e+00 true resid norm 8.712485823405e+00 ||r(i)||/||b|| 2.081619149973e-04
2350 KSP unpreconditioned resid norm 8.712485823389e+00 true resid norm 8.712485823402e+00 ||r(i)||/||b|| 2.081619149972e-04
2351 KSP unpreconditioned resid norm 8.712485823384e+00 true resid norm 8.712485823384e+00 ||r(i)||/||b|| 2.081619149968e-04
2352 KSP unpreconditioned resid norm 8.712485823384e+00 true resid norm 8.712485823381e+00 ||r(i)||/||b|| 2.081619149967e-04
2353 KSP unpreconditioned resid norm 8.712485823362e+00 true resid norm 8.712485823365e+00 ||r(i)||/||b|| 2.081619149963e-04
2354 KSP unpreconditioned resid norm 8.712485823326e+00 true resid norm 8.712485823322e+00 ||r(i)||/||b|| 2.081619149953e-04
2355 KSP unpreconditioned resid norm 8.712485823275e+00 true resid norm 8.712485823283e+00 ||r(i)||/||b|| 2.081619149943e-04
2356 KSP unpreconditioned resid norm 8.712485823244e+00 true resid norm 8.712485823252e+00 ||r(i)||/||b|| 2.081619149936e-04
2357 KSP unpreconditioned resid norm 8.712485823218e+00 true resid norm 8.712485823216e+00 ||r(i)||/||b|| 2.081619149928e-04
2358 KSP unpreconditioned resid norm 8.712485823190e+00 true resid norm 8.712485823198e+00 ||r(i)||/||b|| 2.081619149923e-04
2359 KSP unpreconditioned resid norm 8.712485823166e+00 true resid norm 8.712485823176e+00 ||r(i)||/||b|| 2.081619149918e-04
2360 KSP unpreconditioned resid norm 8.712485823164e+00 true resid norm 8.712485823163e+00 ||r(i)||/||b|| 2.081619149915e-04
2361 KSP unpreconditioned resid norm 8.712485823161e+00 true resid norm 8.712485823164e+00 ||r(i)||/||b|| 2.081619149915e-04
2362 KSP unpreconditioned resid norm 8.712485823131e+00 true resid norm 8.712485823138e+00 ||r(i)||/||b|| 2.081619149909e-04
2363 KSP unpreconditioned resid norm 8.712485822975e+00 true resid norm 8.712485822976e+00 ||r(i)||/||b|| 2.081619149870e-04
2364 KSP unpreconditioned resid norm 8.712485822764e+00 true resid norm 8.712485822767e+00 ||r(i)||/||b|| 2.081619149820e-04
2365 KSP unpreconditioned resid norm 8.712485822602e+00 true resid norm 8.712485822604e+00 ||r(i)||/||b|| 2.081619149781e-04
2366 KSP unpreconditioned resid norm 8.712485822401e+00 true resid norm 8.712485822403e+00 ||r(i)||/||b|| 2.081619149733e-04
2367 KSP unpreconditioned resid norm 8.712485822083e+00 true resid norm 8.712485822087e+00 ||r(i)||/||b|| 2.081619149658e-04
2368 KSP unpreconditioned resid norm 8.712485821326e+00 true resid norm 8.712485821329e+00 ||r(i)||/||b|| 2.081619149477e-04
2369 KSP unpreconditioned resid norm 8.712485820919e+00 true resid norm 8.712485820928e+00 ||r(i)||/||b|| 2.081619149381e-04
2370 KSP unpreconditioned resid norm 8.712485820892e+00 true resid norm 8.712485820892e+00 ||r(i)||/||b|| 2.081619149372e-04
2371 KSP unpreconditioned resid norm 8.712485820892e+00 true resid norm 8.712485820895e+00 ||r(i)||/||b|| 2.081619149373e-04
2372 KSP unpreconditioned resid norm 8.712485820890e+00 true resid norm 8.712485820885e+00 ||r(i)||/||b|| 2.081619149371e-04
2373 KSP unpreconditioned resid norm 8.712485820882e+00 true resid norm 8.712485820880e+00 ||r(i)||/||b|| 2.081619149369e-04
2374 KSP unpreconditioned resid norm 8.712485820864e+00 true resid norm 8.712485820864e+00 ||r(i)||/||b|| 2.081619149366e-04
2375 KSP unpreconditioned resid norm 8.712485820842e+00 true resid norm 8.712485820837e+00 ||r(i)||/||b|| 2.081619149359e-04
2376 KSP unpreconditioned resid norm 8.712485820836e+00 true resid norm 8.712485820837e+00 ||r(i)||/||b|| 2.081619149359e-04
2377 KSP unpreconditioned resid norm 8.712485820833e+00 true resid norm 8.712485820834e+00 ||r(i)||/||b|| 2.081619149358e-04
2378 KSP unpreconditioned resid norm 8.712485820822e+00 true resid norm 8.712485820826e+00 ||r(i)||/||b|| 2.081619149357e-04
2379 KSP unpreconditioned resid norm 8.712485820803e+00 true resid norm 8.712485820804e+00 ||r(i)||/||b|| 2.081619149351e-04
2380 KSP unpreconditioned resid norm 8.712485820785e+00 true resid norm 8.712485820788e+00 ||r(i)||/||b|| 2.081619149347e-04
2381 KSP unpreconditioned resid norm 8.712485820781e+00 true resid norm 8.712485820779e+00 ||r(i)||/||b|| 2.081619149345e-04
2382 KSP unpreconditioned resid norm 8.712485820781e+00 true resid norm 8.712485820790e+00 ||r(i)||/||b|| 2.081619149348e-04
2383 KSP unpreconditioned resid norm 8.712485820762e+00 true resid norm 8.712485820769e+00 ||r(i)||/||b|| 2.081619149343e-04
2384 KSP unpreconditioned resid norm 8.712485820730e+00 true resid norm 8.712485820735e+00 ||r(i)||/||b|| 2.081619149335e-04
2385 KSP unpreconditioned resid norm 8.712485820685e+00 true resid norm 8.712485820688e+00 ||r(i)||/||b|| 2.081619149324e-04
2386 KSP unpreconditioned resid norm 8.712485820658e+00 true resid norm 8.712485820663e+00 ||r(i)||/||b|| 2.081619149317e-04
2387 KSP unpreconditioned resid norm 8.712485820635e+00 true resid norm 8.712485820642e+00 ||r(i)||/||b|| 2.081619149313e-04
2388 KSP unpreconditioned resid norm 8.712485820610e+00 true resid norm 8.712485820608e+00 ||r(i)||/||b|| 2.081619149305e-04
2389 KSP unpreconditioned resid norm 8.712485820588e+00 true resid norm 8.712485820594e+00 ||r(i)||/||b|| 2.081619149301e-04
2390 KSP unpreconditioned resid norm 8.712485820587e+00 true resid norm 8.712485820587e+00 ||r(i)||/||b|| 2.081619149299e-04
2391 KSP unpreconditioned resid norm 8.712485820584e+00 true resid norm 8.712485820584e+00 ||r(i)||/||b|| 2.081619149299e-04
2392 KSP unpreconditioned resid norm 8.712485820558e+00 true resid norm 8.712485820557e+00 ||r(i)||/||b|| 2.081619149292e-04
2393 KSP unpreconditioned resid norm 8.712485820421e+00 true resid norm 8.712485820423e+00 ||r(i)||/||b|| 2.081619149260e-04
2394 KSP unpreconditioned resid norm 8.712485820235e+00 true resid norm 8.712485820235e+00 ||r(i)||/||b|| 2.081619149215e-04
2395 KSP unpreconditioned resid norm 8.712485820093e+00 true resid norm 8.712485820089e+00 ||r(i)||/||b|| 2.081619149180e-04
2396 KSP unpreconditioned resid norm 8.712485819917e+00 true resid norm 8.712485819922e+00 ||r(i)||/||b|| 2.081619149141e-04
2397 KSP unpreconditioned resid norm 8.712485819636e+00 true resid norm 8.712485819641e+00 ||r(i)||/||b|| 2.081619149073e-04
2398 KSP unpreconditioned resid norm 8.712485818966e+00 true resid norm 8.712485818968e+00 ||r(i)||/||b|| 2.081619148913e-04
2399 KSP unpreconditioned resid norm 8.712485818603e+00 true resid norm 8.712485818608e+00 ||r(i)||/||b|| 2.081619148827e-04
2400 KSP unpreconditioned resid norm 8.712485818571e+00 true resid norm 8.712485818571e+00 ||r(i)||/||b|| 2.081619148818e-04
2401 KSP unpreconditioned resid norm 8.712485818570e+00 true resid norm 8.712485818579e+00 ||r(i)||/||b|| 2.081619148820e-04
2402 KSP unpreconditioned resid norm 8.712485818569e+00 true resid norm 8.712485818578e+00 ||r(i)||/||b|| 2.081619148820e-04
2403 KSP unpreconditioned resid norm 8.712485818562e+00 true resid norm 8.712485818575e+00 ||r(i)||/||b|| 2.081619148819e-04
2404 KSP unpreconditioned resid norm 8.712485818545e+00 true resid norm 8.712485818560e+00 ||r(i)||/||b|| 2.081619148815e-04
2405 KSP unpreconditioned resid norm 8.712485818526e+00 true resid norm 8.712485818536e+00 ||r(i)||/||b|| 2.081619148809e-04
2406 KSP unpreconditioned resid norm 8.712485818521e+00 true resid norm 8.712485818522e+00 ||r(i)||/||b|| 2.081619148806e-04
2407 KSP unpreconditioned resid norm 8.712485818518e+00 true resid norm 8.712485818524e+00 ||r(i)||/||b|| 2.081619148807e-04
2408 KSP unpreconditioned resid norm 8.712485818509e+00 true resid norm 8.712485818524e+00 ||r(i)||/||b|| 2.081619148807e-04
2409 KSP unpreconditioned resid norm 8.712485818491e+00 true resid norm 8.712485818511e+00 ||r(i)||/||b|| 2.081619148803e-04
2410 KSP unpreconditioned resid norm 8.712485818476e+00 true resid norm 8.712485818484e+00 ||r(i)||/||b|| 2.081619148797e-04
2411 KSP unpreconditioned resid norm 8.712485818472e+00 true resid norm 8.712485818474e+00 ||r(i)||/||b|| 2.081619148795e-04
2412 KSP unpreconditioned resid norm 8.712485818472e+00 true resid norm 8.712485818487e+00 ||r(i)||/||b|| 2.081619148798e-04
2413 KSP unpreconditioned resid norm 8.712485818455e+00 true resid norm 8.712485818473e+00 ||r(i)||/||b|| 2.081619148794e-04
2414 KSP unpreconditioned resid norm 8.712485818427e+00 true resid norm 8.712485818431e+00 ||r(i)||/||b|| 2.081619148784e-04
2415 KSP unpreconditioned resid norm 8.712485818387e+00 true resid norm 8.712485818401e+00 ||r(i)||/||b|| 2.081619148777e-04
2416 KSP unpreconditioned resid norm 8.712485818363e+00 true resid norm 8.712485818363e+00 ||r(i)||/||b|| 2.081619148768e-04
2417 KSP unpreconditioned resid norm 8.712485818343e+00 true resid norm 8.712485818356e+00 ||r(i)||/||b|| 2.081619148766e-04
2418 KSP unpreconditioned resid norm 8.712485818321e+00 true resid norm 8.712485818324e+00 ||r(i)||/||b|| 2.081619148759e-04
2419 KSP unpreconditioned resid norm 8.712485818302e+00 true resid norm 8.712485818310e+00 ||r(i)||/||b|| 2.081619148755e-04
2420 KSP unpreconditioned resid norm 8.712485818301e+00 true resid norm 8.712485818313e+00 ||r(i)||/||b|| 2.081619148756e-04
2421 KSP unpreconditioned resid norm 8.712485818298e+00 true resid norm 8.712485818309e+00 ||r(i)||/||b|| 2.081619148755e-04
2422 KSP unpreconditioned resid norm 8.712485818274e+00 true resid norm 8.712485818277e+00 ||r(i)||/||b|| 2.081619148747e-04
2423 KSP unpreconditioned resid norm 8.712485818153e+00 true resid norm 8.712485818153e+00 ||r(i)||/||b|| 2.081619148718e-04
2424 KSP unpreconditioned resid norm 8.712485817988e+00 true resid norm 8.712485817999e+00 ||r(i)||/||b|| 2.081619148681e-04
2425 KSP unpreconditioned resid norm 8.712485817861e+00 true resid norm 8.712485817859e+00 ||r(i)||/||b|| 2.081619148648e-04
2426 KSP unpreconditioned resid norm 8.712485817704e+00 true resid norm 8.712485817714e+00 ||r(i)||/||b|| 2.081619148613e-04
2427 KSP unpreconditioned resid norm 8.712485817455e+00 true resid norm 8.712485817459e+00 ||r(i)||/||b|| 2.081619148552e-04
2428 KSP unpreconditioned resid norm 8.712485816863e+00 true resid norm 8.712485816878e+00 ||r(i)||/||b|| 2.081619148413e-04
2429 KSP unpreconditioned resid norm 8.712485816545e+00 true resid norm 8.712485816545e+00 ||r(i)||/||b|| 2.081619148334e-04
2430 KSP unpreconditioned resid norm 8.712485816538e+00 true resid norm 8.712485816538e+00 ||r(i)||/||b|| 2.081619148332e-04
2431 KSP unpreconditioned resid norm 8.712485816538e+00 true resid norm 8.712485816526e+00 ||r(i)||/||b|| 2.081619148329e-04
2432 KSP unpreconditioned resid norm 8.712485816537e+00 true resid norm 8.712485816528e+00 ||r(i)||/||b|| 2.081619148330e-04
2433 KSP unpreconditioned resid norm 8.712485816530e+00 true resid norm 8.712485816524e+00 ||r(i)||/||b|| 2.081619148329e-04
2434 KSP unpreconditioned resid norm 8.712485816516e+00 true resid norm 8.712485816509e+00 ||r(i)||/||b|| 2.081619148325e-04
2435 KSP unpreconditioned resid norm 8.712485816499e+00 true resid norm 8.712485816493e+00 ||r(i)||/||b|| 2.081619148321e-04
2436 KSP unpreconditioned resid norm 8.712485816494e+00 true resid norm 8.712485816488e+00 ||r(i)||/||b|| 2.081619148320e-04
2437 KSP unpreconditioned resid norm 8.712485816491e+00 true resid norm 8.712485816486e+00 ||r(i)||/||b|| 2.081619148320e-04
2438 KSP unpreconditioned resid norm 8.712485816484e+00 true resid norm 8.712485816476e+00 ||r(i)||/||b|| 2.081619148317e-04
2439 KSP unpreconditioned resid norm 8.712485816468e+00 true resid norm 8.712485816463e+00 ||r(i)||/||b|| 2.081619148314e-04
2440 KSP unpreconditioned resid norm 8.712485816455e+00 true resid norm 8.712485816443e+00 ||r(i)||/||b|| 2.081619148309e-04
2441 KSP unpreconditioned resid norm 8.712485816451e+00 true resid norm 8.712485816448e+00 ||r(i)||/||b|| 2.081619148310e-04
2442 KSP unpreconditioned resid norm 8.712485816451e+00 true resid norm 8.712485816440e+00 ||r(i)||/||b|| 2.081619148309e-04
2443 KSP unpreconditioned resid norm 8.712485816436e+00 true resid norm 8.712485816436e+00 ||r(i)||/||b|| 2.081619148308e-04
2444 KSP unpreconditioned resid norm 8.712485816411e+00 true resid norm 8.712485816408e+00 ||r(i)||/||b|| 2.081619148301e-04
2445 KSP unpreconditioned resid norm 8.712485816376e+00 true resid norm 8.712485816373e+00 ||r(i)||/||b|| 2.081619148293e-04
2446 KSP unpreconditioned resid norm 8.712485816355e+00 true resid norm 8.712485816346e+00 ||r(i)||/||b|| 2.081619148286e-04
2447 KSP unpreconditioned resid norm 8.712485816337e+00 true resid norm 8.712485816331e+00 ||r(i)||/||b|| 2.081619148283e-04
2448 KSP unpreconditioned resid norm 8.712485816318e+00 true resid norm 8.712485816315e+00 ||r(i)||/||b|| 2.081619148279e-04
2449 KSP unpreconditioned resid norm 8.712485816300e+00 true resid norm 8.712485816294e+00 ||r(i)||/||b|| 2.081619148274e-04
2450 KSP unpreconditioned resid norm 8.712485816299e+00 true resid norm 8.712485816293e+00 ||r(i)||/||b|| 2.081619148273e-04
2451 KSP unpreconditioned resid norm 8.712485816297e+00 true resid norm 8.712485816295e+00 ||r(i)||/||b|| 2.081619148274e-04
2452 KSP unpreconditioned resid norm 8.712485816277e+00 true resid norm 8.712485816271e+00 ||r(i)||/||b|| 2.081619148268e-04
2453 KSP unpreconditioned resid norm 8.712485816170e+00 true resid norm 8.712485816167e+00 ||r(i)||/||b|| 2.081619148243e-04
2454 KSP unpreconditioned resid norm 8.712485816024e+00 true resid norm 8.712485816013e+00 ||r(i)||/||b|| 2.081619148207e-04
2455 KSP unpreconditioned resid norm 8.712485815913e+00 true resid norm 8.712485815909e+00 ||r(i)||/||b|| 2.081619148182e-04
2456 KSP unpreconditioned resid norm 8.712485815775e+00 true resid norm 8.712485815764e+00 ||r(i)||/||b|| 2.081619148147e-04
2457 KSP unpreconditioned resid norm 8.712485815555e+00 true resid norm 8.712485815541e+00 ||r(i)||/||b|| 2.081619148094e-04
2458 KSP unpreconditioned resid norm 8.712485815031e+00 true resid norm 8.712485815020e+00 ||r(i)||/||b|| 2.081619147969e-04
2459 KSP unpreconditioned resid norm 8.712485814748e+00 true resid norm 8.712485814730e+00 ||r(i)||/||b|| 2.081619147900e-04
2460 KSP unpreconditioned resid norm 8.712485814719e+00 true resid norm 8.712485814719e+00 ||r(i)||/||b|| 2.081619147897e-04
2461 KSP unpreconditioned resid norm 8.712485814719e+00 true resid norm 8.712485814717e+00 ||r(i)||/||b|| 2.081619147897e-04
2462 KSP unpreconditioned resid norm 8.712485814717e+00 true resid norm 8.712485814711e+00 ||r(i)||/||b|| 2.081619147895e-04
2463 KSP unpreconditioned resid norm 8.712485814712e+00 true resid norm 8.712485814708e+00 ||r(i)||/||b|| 2.081619147895e-04
2464 KSP unpreconditioned resid norm 8.712485814699e+00 true resid norm 8.712485814691e+00 ||r(i)||/||b|| 2.081619147891e-04
2465 KSP unpreconditioned resid norm 8.712485814684e+00 true resid norm 8.712485814682e+00 ||r(i)||/||b|| 2.081619147889e-04
2466 KSP unpreconditioned resid norm 8.712485814680e+00 true resid norm 8.712485814679e+00 ||r(i)||/||b|| 2.081619147888e-04
2467 KSP unpreconditioned resid norm 8.712485814677e+00 true resid norm 8.712485814680e+00 ||r(i)||/||b|| 2.081619147888e-04
2468 KSP unpreconditioned resid norm 8.712485814670e+00 true resid norm 8.712485814665e+00 ||r(i)||/||b|| 2.081619147885e-04
2469 KSP unpreconditioned resid norm 8.712485814657e+00 true resid norm 8.712485814651e+00 ||r(i)||/||b|| 2.081619147881e-04
2470 KSP unpreconditioned resid norm 8.712485814645e+00 true resid norm 8.712485814650e+00 ||r(i)||/||b|| 2.081619147881e-04
2471 KSP unpreconditioned resid norm 8.712485814642e+00 true resid norm 8.712485814645e+00 ||r(i)||/||b|| 2.081619147880e-04
2472 KSP unpreconditioned resid norm 8.712485814642e+00 true resid norm 8.712485814630e+00 ||r(i)||/||b|| 2.081619147876e-04
2473 KSP unpreconditioned resid norm 8.712485814628e+00 true resid norm 8.712485814639e+00 ||r(i)||/||b|| 2.081619147878e-04
2474 KSP unpreconditioned resid norm 8.712485814607e+00 true resid norm 8.712485814613e+00 ||r(i)||/||b|| 2.081619147872e-04
2475 KSP unpreconditioned resid norm 8.712485814575e+00 true resid norm 8.712485814572e+00 ||r(i)||/||b|| 2.081619147862e-04
2476 KSP unpreconditioned resid norm 8.712485814556e+00 true resid norm 8.712485814552e+00 ||r(i)||/||b|| 2.081619147858e-04
2477 KSP unpreconditioned resid norm 8.712485814540e+00 true resid norm 8.712485814547e+00 ||r(i)||/||b|| 2.081619147856e-04
2478 KSP unpreconditioned resid norm 8.712485814523e+00 true resid norm 8.712485814525e+00 ||r(i)||/||b|| 2.081619147851e-04
2479 KSP unpreconditioned resid norm 8.712485814508e+00 true resid norm 8.712485814515e+00 ||r(i)||/||b|| 2.081619147849e-04
2480 KSP unpreconditioned resid norm 8.712485814508e+00 true resid norm 8.712485814508e+00 ||r(i)||/||b|| 2.081619147847e-04
2481 KSP unpreconditioned resid norm 8.712485814505e+00 true resid norm 8.712485814508e+00 ||r(i)||/||b|| 2.081619147847e-04
2482 KSP unpreconditioned resid norm 8.712485814487e+00 true resid norm 8.712485814479e+00 ||r(i)||/||b|| 2.081619147840e-04
2483 KSP unpreconditioned resid norm 8.712485814392e+00 true resid norm 8.712485814401e+00 ||r(i)||/||b|| 2.081619147821e-04
2484 KSP unpreconditioned resid norm 8.712485814263e+00 true resid norm 8.712485814271e+00 ||r(i)||/||b|| 2.081619147790e-04
2485 KSP unpreconditioned resid norm 8.712485814164e+00 true resid norm 8.712485814158e+00 ||r(i)||/||b|| 2.081619147763e-04
2486 KSP unpreconditioned resid norm 8.712485814041e+00 true resid norm 8.712485814034e+00 ||r(i)||/||b|| 2.081619147734e-04
2487 KSP unpreconditioned resid norm 8.712485813847e+00 true resid norm 8.712485813852e+00 ||r(i)||/||b|| 2.081619147690e-04
2488 KSP unpreconditioned resid norm 8.712485813384e+00 true resid norm 8.712485813379e+00 ||r(i)||/||b|| 2.081619147577e-04
2489 KSP unpreconditioned resid norm 8.712485813134e+00 true resid norm 8.712485813127e+00 ||r(i)||/||b|| 2.081619147517e-04
2490 KSP unpreconditioned resid norm 8.712485813119e+00 true resid norm 8.712485813119e+00 ||r(i)||/||b|| 2.081619147515e-04
2491 KSP unpreconditioned resid norm 8.712485813119e+00 true resid norm 8.712485813122e+00 ||r(i)||/||b|| 2.081619147516e-04
2492 KSP unpreconditioned resid norm 8.712485813117e+00 true resid norm 8.712485813108e+00 ||r(i)||/||b|| 2.081619147512e-04
2493 KSP unpreconditioned resid norm 8.712485813112e+00 true resid norm 8.712485813102e+00 ||r(i)||/||b|| 2.081619147511e-04
2494 KSP unpreconditioned resid norm 8.712485813101e+00 true resid norm 8.712485813091e+00 ||r(i)||/||b|| 2.081619147508e-04
2495 KSP unpreconditioned resid norm 8.712485813088e+00 true resid norm 8.712485813076e+00 ||r(i)||/||b|| 2.081619147505e-04
2496 KSP unpreconditioned resid norm 8.712485813084e+00 true resid norm 8.712485813070e+00 ||r(i)||/||b|| 2.081619147503e-04
2497 KSP unpreconditioned resid norm 8.712485813082e+00 true resid norm 8.712485813084e+00 ||r(i)||/||b|| 2.081619147507e-04
2498 KSP unpreconditioned resid norm 8.712485813076e+00 true resid norm 8.712485813073e+00 ||r(i)||/||b|| 2.081619147504e-04
2499 KSP unpreconditioned resid norm 8.712485813064e+00 true resid norm 8.712485813069e+00 ||r(i)||/||b|| 2.081619147503e-04
2500 KSP unpreconditioned resid norm 8.712485813053e+00 true resid norm 8.712485813051e+00 ||r(i)||/||b|| 2.081619147499e-04
2501 KSP unpreconditioned resid norm 8.712485813051e+00 true resid norm 8.712485813045e+00 ||r(i)||/||b|| 2.081619147497e-04
2502 KSP unpreconditioned resid norm 8.712485813050e+00 true resid norm 8.712485813041e+00 ||r(i)||/||b|| 2.081619147496e-04
2503 KSP unpreconditioned resid norm 8.712485813039e+00 true resid norm 8.712485813035e+00 ||r(i)||/||b|| 2.081619147495e-04
2504 KSP unpreconditioned resid norm 8.712485813019e+00 true resid norm 8.712485813007e+00 ||r(i)||/||b|| 2.081619147488e-04
2505 KSP unpreconditioned resid norm 8.712485812992e+00 true resid norm 8.712485812984e+00 ||r(i)||/||b|| 2.081619147483e-04
2506 KSP unpreconditioned resid norm 8.712485812975e+00 true resid norm 8.712485812963e+00 ||r(i)||/||b|| 2.081619147478e-04
2507 KSP unpreconditioned resid norm 8.712485812961e+00 true resid norm 8.712485812958e+00 ||r(i)||/||b|| 2.081619147477e-04
2508 KSP unpreconditioned resid norm 8.712485812946e+00 true resid norm 8.712485812940e+00 ||r(i)||/||b|| 2.081619147472e-04
2509 KSP unpreconditioned resid norm 8.712485812933e+00 true resid norm 8.712485812932e+00 ||r(i)||/||b|| 2.081619147471e-04
2510 KSP unpreconditioned resid norm 8.712485812932e+00 true resid norm 8.712485812933e+00 ||r(i)||/||b|| 2.081619147471e-04
2511 KSP unpreconditioned resid norm 8.712485812930e+00 true resid norm 8.712485812919e+00 ||r(i)||/||b|| 2.081619147467e-04
2512 KSP unpreconditioned resid norm 8.712485812914e+00 true resid norm 8.712485812907e+00 ||r(i)||/||b|| 2.081619147464e-04
2513 KSP unpreconditioned resid norm 8.712485812830e+00 true resid norm 8.712485812827e+00 ||r(i)||/||b|| 2.081619147445e-04
2514 KSP unpreconditioned resid norm 8.712485812717e+00 true resid norm 8.712485812709e+00 ||r(i)||/||b|| 2.081619147417e-04
2515 KSP unpreconditioned resid norm 8.712485812630e+00 true resid norm 8.712485812628e+00 ||r(i)||/||b|| 2.081619147398e-04
2516 KSP unpreconditioned resid norm 8.712485812522e+00 true resid norm 8.712485812518e+00 ||r(i)||/||b|| 2.081619147371e-04
2517 KSP unpreconditioned resid norm 8.712485812350e+00 true resid norm 8.712485812349e+00 ||r(i)||/||b|| 2.081619147331e-04
2518 KSP unpreconditioned resid norm 8.712485811940e+00 true resid norm 8.712485811935e+00 ||r(i)||/||b|| 2.081619147232e-04
2519 KSP unpreconditioned resid norm 8.712485811719e+00 true resid norm 8.712485811718e+00 ||r(i)||/||b|| 2.081619147180e-04
2520 KSP unpreconditioned resid norm 8.712485811714e+00 true resid norm 8.712485811714e+00 ||r(i)||/||b|| 2.081619147179e-04
2521 KSP unpreconditioned resid norm 8.712485811713e+00 true resid norm 8.712485811715e+00 ||r(i)||/||b|| 2.081619147180e-04
2522 KSP unpreconditioned resid norm 8.712485811713e+00 true resid norm 8.712485811712e+00 ||r(i)||/||b|| 2.081619147179e-04
2523 KSP unpreconditioned resid norm 8.712485811708e+00 true resid norm 8.712485811699e+00 ||r(i)||/||b|| 2.081619147176e-04
2524 KSP unpreconditioned resid norm 8.712485811698e+00 true resid norm 8.712485811690e+00 ||r(i)||/||b|| 2.081619147174e-04
2525 KSP unpreconditioned resid norm 8.712485811686e+00 true resid norm 8.712485811672e+00 ||r(i)||/||b|| 2.081619147169e-04
2526 KSP unpreconditioned resid norm 8.712485811683e+00 true resid norm 8.712485811671e+00 ||r(i)||/||b|| 2.081619147169e-04
2527 KSP unpreconditioned resid norm 8.712485811681e+00 true resid norm 8.712485811673e+00 ||r(i)||/||b|| 2.081619147170e-04
2528 KSP unpreconditioned resid norm 8.712485811676e+00 true resid norm 8.712485811667e+00 ||r(i)||/||b|| 2.081619147168e-04
2529 KSP unpreconditioned resid norm 8.712485811665e+00 true resid norm 8.712485811660e+00 ||r(i)||/||b|| 2.081619147167e-04
2530 KSP unpreconditioned resid norm 8.712485811656e+00 true resid norm 8.712485811642e+00 ||r(i)||/||b|| 2.081619147162e-04
2531 KSP unpreconditioned resid norm 8.712485811653e+00 true resid norm 8.712485811649e+00 ||r(i)||/||b|| 2.081619147164e-04
2532 KSP unpreconditioned resid norm 8.712485811653e+00 true resid norm 8.712485811644e+00 ||r(i)||/||b|| 2.081619147163e-04
2533 KSP unpreconditioned resid norm 8.712485811643e+00 true resid norm 8.712485811634e+00 ||r(i)||/||b|| 2.081619147160e-04
2534 KSP unpreconditioned resid norm 8.712485811626e+00 true resid norm 8.712485811613e+00 ||r(i)||/||b|| 2.081619147155e-04
2535 KSP unpreconditioned resid norm 8.712485811601e+00 true resid norm 8.712485811597e+00 ||r(i)||/||b|| 2.081619147151e-04
2536 KSP unpreconditioned resid norm 8.712485811587e+00 true resid norm 8.712485811580e+00 ||r(i)||/||b|| 2.081619147147e-04
2537 KSP unpreconditioned resid norm 8.712485811574e+00 true resid norm 8.712485811578e+00 ||r(i)||/||b|| 2.081619147147e-04
2538 KSP unpreconditioned resid norm 8.712485811561e+00 true resid norm 8.712485811553e+00 ||r(i)||/||b|| 2.081619147141e-04
2539 KSP unpreconditioned resid norm 8.712485811549e+00 true resid norm 8.712485811531e+00 ||r(i)||/||b|| 2.081619147136e-04
2540 KSP unpreconditioned resid norm 8.712485811548e+00 true resid norm 8.712485811539e+00 ||r(i)||/||b|| 2.081619147138e-04
2541 KSP unpreconditioned resid norm 8.712485811547e+00 true resid norm 8.712485811533e+00 ||r(i)||/||b|| 2.081619147136e-04
2542 KSP unpreconditioned resid norm 8.712485811532e+00 true resid norm 8.712485811524e+00 ||r(i)||/||b|| 2.081619147134e-04
2543 KSP unpreconditioned resid norm 8.712485811458e+00 true resid norm 8.712485811441e+00 ||r(i)||/||b|| 2.081619147114e-04
2544 KSP unpreconditioned resid norm 8.712485811357e+00 true resid norm 8.712485811345e+00 ||r(i)||/||b|| 2.081619147091e-04
2545 KSP unpreconditioned resid norm 8.712485811280e+00 true resid norm 8.712485811267e+00 ||r(i)||/||b|| 2.081619147073e-04
2546 KSP unpreconditioned resid norm 8.712485811184e+00 true resid norm 8.712485811168e+00 ||r(i)||/||b|| 2.081619147049e-04
2547 KSP unpreconditioned resid norm 8.712485811032e+00 true resid norm 8.712485811024e+00 ||r(i)||/||b|| 2.081619147015e-04
2548 KSP unpreconditioned resid norm 8.712485810670e+00 true resid norm 8.712485810656e+00 ||r(i)||/||b|| 2.081619146927e-04
2549 KSP unpreconditioned resid norm 8.712485810475e+00 true resid norm 8.712485810465e+00 ||r(i)||/||b|| 2.081619146881e-04
2550 KSP unpreconditioned resid norm 8.712485810458e+00 true resid norm 8.712485810458e+00 ||r(i)||/||b|| 2.081619146879e-04
2551 KSP unpreconditioned resid norm 8.712485810458e+00 true resid norm 8.712485810452e+00 ||r(i)||/||b|| 2.081619146878e-04
2552 KSP unpreconditioned resid norm 8.712485810457e+00 true resid norm 8.712485810454e+00 ||r(i)||/||b|| 2.081619146878e-04
2553 KSP unpreconditioned resid norm 8.712485810453e+00 true resid norm 8.712485810450e+00 ||r(i)||/||b|| 2.081619146878e-04
2554 KSP unpreconditioned resid norm 8.712485810444e+00 true resid norm 8.712485810445e+00 ||r(i)||/||b|| 2.081619146876e-04
2555 KSP unpreconditioned resid norm 8.712485810434e+00 true resid norm 8.712485810430e+00 ||r(i)||/||b|| 2.081619146873e-04
2556 KSP unpreconditioned resid norm 8.712485810431e+00 true resid norm 8.712485810425e+00 ||r(i)||/||b|| 2.081619146871e-04
2557 KSP unpreconditioned resid norm 8.712485810429e+00 true resid norm 8.712485810428e+00 ||r(i)||/||b|| 2.081619146872e-04
2558 KSP unpreconditioned resid norm 8.712485810424e+00 true resid norm 8.712485810414e+00 ||r(i)||/||b|| 2.081619146869e-04
2559 KSP unpreconditioned resid norm 8.712485810415e+00 true resid norm 8.712485810400e+00 ||r(i)||/||b|| 2.081619146866e-04
2560 KSP unpreconditioned resid norm 8.712485810407e+00 true resid norm 8.712485810407e+00 ||r(i)||/||b|| 2.081619146867e-04
2561 KSP unpreconditioned resid norm 8.712485810404e+00 true resid norm 8.712485810413e+00 ||r(i)||/||b|| 2.081619146869e-04
2562 KSP unpreconditioned resid norm 8.712485810404e+00 true resid norm 8.712485810409e+00 ||r(i)||/||b|| 2.081619146868e-04
2563 KSP unpreconditioned resid norm 8.712485810395e+00 true resid norm 8.712485810394e+00 ||r(i)||/||b|| 2.081619146864e-04
2564 KSP unpreconditioned resid norm 8.712485810380e+00 true resid norm 8.712485810376e+00 ||r(i)||/||b|| 2.081619146860e-04
2565 KSP unpreconditioned resid norm 8.712485810358e+00 true resid norm 8.712485810361e+00 ||r(i)||/||b|| 2.081619146856e-04
2566 KSP unpreconditioned resid norm 8.712485810345e+00 true resid norm 8.712485810344e+00 ||r(i)||/||b|| 2.081619146852e-04
2567 KSP unpreconditioned resid norm 8.712485810334e+00 true resid norm 8.712485810335e+00 ||r(i)||/||b|| 2.081619146850e-04
2568 KSP unpreconditioned resid norm 8.712485810323e+00 true resid norm 8.712485810321e+00 ||r(i)||/||b|| 2.081619146847e-04
2569 KSP unpreconditioned resid norm 8.712485810312e+00 true resid norm 8.712485810316e+00 ||r(i)||/||b|| 2.081619146845e-04
2570 KSP unpreconditioned resid norm 8.712485810312e+00 true resid norm 8.712485810305e+00 ||r(i)||/||b|| 2.081619146843e-04
2571 KSP unpreconditioned resid norm 8.712485810310e+00 true resid norm 8.712485810297e+00 ||r(i)||/||b|| 2.081619146841e-04
2572 KSP unpreconditioned resid norm 8.712485810298e+00 true resid norm 8.712485810302e+00 ||r(i)||/||b|| 2.081619146842e-04
2573 KSP unpreconditioned resid norm 8.712485810232e+00 true resid norm 8.712485810230e+00 ||r(i)||/||b|| 2.081619146825e-04
2574 KSP unpreconditioned resid norm 8.712485810143e+00 true resid norm 8.712485810147e+00 ||r(i)||/||b|| 2.081619146805e-04
2575 KSP unpreconditioned resid norm 8.712485810075e+00 true resid norm 8.712485810069e+00 ||r(i)||/||b|| 2.081619146786e-04
2576 KSP unpreconditioned resid norm 8.712485809991e+00 true resid norm 8.712485809990e+00 ||r(i)||/||b|| 2.081619146767e-04
2577 KSP unpreconditioned resid norm 8.712485809856e+00 true resid norm 8.712485809851e+00 ||r(i)||/||b|| 2.081619146734e-04
2578 KSP unpreconditioned resid norm 8.712485809536e+00 true resid norm 8.712485809533e+00 ||r(i)||/||b|| 2.081619146658e-04
2579 KSP unpreconditioned resid norm 8.712485809363e+00 true resid norm 8.712485809358e+00 ||r(i)||/||b|| 2.081619146616e-04
2580 KSP unpreconditioned resid norm 8.712485809348e+00 true resid norm 8.712485809348e+00 ||r(i)||/||b|| 2.081619146614e-04
2581 KSP unpreconditioned resid norm 8.712485809348e+00 true resid norm 8.712485809334e+00 ||r(i)||/||b|| 2.081619146611e-04
2582 KSP unpreconditioned resid norm 8.712485809347e+00 true resid norm 8.712485809339e+00 ||r(i)||/||b|| 2.081619146612e-04
2583 KSP unpreconditioned resid norm 8.712485809344e+00 true resid norm 8.712485809340e+00 ||r(i)||/||b|| 2.081619146612e-04
2584 KSP unpreconditioned resid norm 8.712485809336e+00 true resid norm 8.712485809336e+00 ||r(i)||/||b|| 2.081619146611e-04
2585 KSP unpreconditioned resid norm 8.712485809327e+00 true resid norm 8.712485809321e+00 ||r(i)||/||b|| 2.081619146608e-04
2586 KSP unpreconditioned resid norm 8.712485809324e+00 true resid norm 8.712485809320e+00 ||r(i)||/||b|| 2.081619146607e-04
2587 KSP unpreconditioned resid norm 8.712485809323e+00 true resid norm 8.712485809312e+00 ||r(i)||/||b|| 2.081619146606e-04
2588 KSP unpreconditioned resid norm 8.712485809319e+00 true resid norm 8.712485809305e+00 ||r(i)||/||b|| 2.081619146604e-04
2589 KSP unpreconditioned resid norm 8.712485809310e+00 true resid norm 8.712485809309e+00 ||r(i)||/||b|| 2.081619146605e-04
2590 KSP unpreconditioned resid norm 8.712485809303e+00 true resid norm 8.712485809311e+00 ||r(i)||/||b|| 2.081619146605e-04
2591 KSP unpreconditioned resid norm 8.712485809301e+00 true resid norm 8.712485809294e+00 ||r(i)||/||b|| 2.081619146601e-04
2592 KSP unpreconditioned resid norm 8.712485809301e+00 true resid norm 8.712485809301e+00 ||r(i)||/||b|| 2.081619146603e-04
2593 KSP unpreconditioned resid norm 8.712485809293e+00 true resid norm 8.712485809282e+00 ||r(i)||/||b|| 2.081619146598e-04
2594 KSP unpreconditioned resid norm 8.712485809280e+00 true resid norm 8.712485809275e+00 ||r(i)||/||b|| 2.081619146597e-04
2595 KSP unpreconditioned resid norm 8.712485809260e+00 true resid norm 8.712485809253e+00 ||r(i)||/||b|| 2.081619146591e-04
2596 KSP unpreconditioned resid norm 8.712485809249e+00 true resid norm 8.712485809247e+00 ||r(i)||/||b|| 2.081619146590e-04
2597 KSP unpreconditioned resid norm 8.712485809239e+00 true resid norm 8.712485809240e+00 ||r(i)||/||b|| 2.081619146588e-04
2598 KSP unpreconditioned resid norm 8.712485809229e+00 true resid norm 8.712485809225e+00 ||r(i)||/||b|| 2.081619146585e-04
2599 KSP unpreconditioned resid norm 8.712485809219e+00 true resid norm 8.712485809217e+00 ||r(i)||/||b|| 2.081619146583e-04
2600 KSP unpreconditioned resid norm 8.712485809219e+00 true resid norm 8.712485809216e+00 ||r(i)||/||b|| 2.081619146583e-04
2601 KSP unpreconditioned resid norm 8.712485809218e+00 true resid norm 8.712485809210e+00 ||r(i)||/||b|| 2.081619146581e-04
2602 KSP unpreconditioned resid norm 8.712485809206e+00 true resid norm 8.712485809203e+00 ||r(i)||/||b|| 2.081619146579e-04
2603 KSP unpreconditioned resid norm 8.712485809148e+00 true resid norm 8.712485809142e+00 ||r(i)||/||b|| 2.081619146565e-04
2604 KSP unpreconditioned resid norm 8.712485809069e+00 true resid norm 8.712485809070e+00 ||r(i)||/||b|| 2.081619146548e-04
2605 KSP unpreconditioned resid norm 8.712485809009e+00 true resid norm 8.712485809000e+00 ||r(i)||/||b|| 2.081619146531e-04
2606 KSP unpreconditioned resid norm 8.712485808934e+00 true resid norm 8.712485808921e+00 ||r(i)||/||b|| 2.081619146512e-04
2607 KSP unpreconditioned resid norm 8.712485808815e+00 true resid norm 8.712485808815e+00 ||r(i)||/||b|| 2.081619146487e-04
2608 KSP unpreconditioned resid norm 8.712485808532e+00 true resid norm 8.712485808525e+00 ||r(i)||/||b|| 2.081619146417e-04
2609 KSP unpreconditioned resid norm 8.712485808379e+00 true resid norm 8.712485808380e+00 ||r(i)||/||b|| 2.081619146383e-04
2610 KSP unpreconditioned resid norm 8.712485808363e+00 true resid norm 8.712485808363e+00 ||r(i)||/||b|| 2.081619146379e-04
2611 KSP unpreconditioned resid norm 8.712485808363e+00 true resid norm 8.712485808361e+00 ||r(i)||/||b|| 2.081619146378e-04
2612 KSP unpreconditioned resid norm 8.712485808363e+00 true resid norm 8.712485808363e+00 ||r(i)||/||b|| 2.081619146379e-04
2613 KSP unpreconditioned resid norm 8.712485808360e+00 true resid norm 8.712485808362e+00 ||r(i)||/||b|| 2.081619146379e-04
2614 KSP unpreconditioned resid norm 8.712485808353e+00 true resid norm 8.712485808354e+00 ||r(i)||/||b|| 2.081619146377e-04
2615 KSP unpreconditioned resid norm 8.712485808345e+00 true resid norm 8.712485808340e+00 ||r(i)||/||b|| 2.081619146373e-04
2616 KSP unpreconditioned resid norm 8.712485808342e+00 true resid norm 8.712485808336e+00 ||r(i)||/||b|| 2.081619146372e-04
2617 KSP unpreconditioned resid norm 8.712485808341e+00 true resid norm 8.712485808341e+00 ||r(i)||/||b|| 2.081619146373e-04
2618 KSP unpreconditioned resid norm 8.712485808337e+00 true resid norm 8.712485808325e+00 ||r(i)||/||b|| 2.081619146370e-04
2619 KSP unpreconditioned resid norm 8.712485808330e+00 true resid norm 8.712485808330e+00 ||r(i)||/||b|| 2.081619146371e-04
2620 KSP unpreconditioned resid norm 8.712485808323e+00 true resid norm 8.712485808329e+00 ||r(i)||/||b|| 2.081619146371e-04
2621 KSP unpreconditioned resid norm 8.712485808322e+00 true resid norm 8.712485808313e+00 ||r(i)||/||b|| 2.081619146367e-04
2622 KSP unpreconditioned resid norm 8.712485808322e+00 true resid norm 8.712485808326e+00 ||r(i)||/||b|| 2.081619146370e-04
2623 KSP unpreconditioned resid norm 8.712485808315e+00 true resid norm 8.712485808314e+00 ||r(i)||/||b|| 2.081619146367e-04
2624 KSP unpreconditioned resid norm 8.712485808303e+00 true resid norm 8.712485808302e+00 ||r(i)||/||b|| 2.081619146364e-04
2625 KSP unpreconditioned resid norm 8.712485808286e+00 true resid norm 8.712485808280e+00 ||r(i)||/||b|| 2.081619146359e-04
2626 KSP unpreconditioned resid norm 8.712485808276e+00 true resid norm 8.712485808271e+00 ||r(i)||/||b|| 2.081619146357e-04
2627 KSP unpreconditioned resid norm 8.712485808267e+00 true resid norm 8.712485808264e+00 ||r(i)||/||b|| 2.081619146355e-04
2628 KSP unpreconditioned resid norm 8.712485808258e+00 true resid norm 8.712485808254e+00 ||r(i)||/||b|| 2.081619146353e-04
2629 KSP unpreconditioned resid norm 8.712485808250e+00 true resid norm 8.712485808253e+00 ||r(i)||/||b|| 2.081619146353e-04
2630 KSP unpreconditioned resid norm 8.712485808249e+00 true resid norm 8.712485808249e+00 ||r(i)||/||b|| 2.081619146352e-04
2631 KSP unpreconditioned resid norm 8.712485808248e+00 true resid norm 8.712485808242e+00 ||r(i)||/||b|| 2.081619146350e-04
2632 KSP unpreconditioned resid norm 8.712485808238e+00 true resid norm 8.712485808234e+00 ||r(i)||/||b|| 2.081619146348e-04
2633 KSP unpreconditioned resid norm 8.712485808187e+00 true resid norm 8.712485808184e+00 ||r(i)||/||b|| 2.081619146336e-04
2634 KSP unpreconditioned resid norm 8.712485808118e+00 true resid norm 8.712485808120e+00 ||r(i)||/||b|| 2.081619146321e-04
2635 KSP unpreconditioned resid norm 8.712485808064e+00 true resid norm 8.712485808064e+00 ||r(i)||/||b|| 2.081619146307e-04
2636 KSP unpreconditioned resid norm 8.712485807998e+00 true resid norm 8.712485808004e+00 ||r(i)||/||b|| 2.081619146293e-04
2637 KSP unpreconditioned resid norm 8.712485807893e+00 true resid norm 8.712485807892e+00 ||r(i)||/||b|| 2.081619146266e-04
2638 KSP unpreconditioned resid norm 8.712485807643e+00 true resid norm 8.712485807639e+00 ||r(i)||/||b|| 2.081619146206e-04
2639 KSP unpreconditioned resid norm 8.712485807507e+00 true resid norm 8.712485807514e+00 ||r(i)||/||b|| 2.081619146176e-04
2640 KSP unpreconditioned resid norm 8.712485807503e+00 true resid norm 8.712485807503e+00 ||r(i)||/||b|| 2.081619146173e-04
2641 KSP unpreconditioned resid norm 8.712485807503e+00 true resid norm 8.712485807498e+00 ||r(i)||/||b|| 2.081619146172e-04
2642 KSP unpreconditioned resid norm 8.712485807502e+00 true resid norm 8.712485807495e+00 ||r(i)||/||b|| 2.081619146172e-04
2643 KSP unpreconditioned resid norm 8.712485807499e+00 true resid norm 8.712485807506e+00 ||r(i)||/||b|| 2.081619146174e-04
2644 KSP unpreconditioned resid norm 8.712485807493e+00 true resid norm 8.712485807489e+00 ||r(i)||/||b|| 2.081619146170e-04
2645 KSP unpreconditioned resid norm 8.712485807486e+00 true resid norm 8.712485807466e+00 ||r(i)||/||b|| 2.081619146164e-04
2646 KSP unpreconditioned resid norm 8.712485807484e+00 true resid norm 8.712485807466e+00 ||r(i)||/||b|| 2.081619146165e-04
2647 KSP unpreconditioned resid norm 8.712485807483e+00 true resid norm 8.712485807479e+00 ||r(i)||/||b|| 2.081619146168e-04
2648 KSP unpreconditioned resid norm 8.712485807479e+00 true resid norm 8.712485807476e+00 ||r(i)||/||b|| 2.081619146167e-04
2649 KSP unpreconditioned resid norm 8.712485807473e+00 true resid norm 8.712485807466e+00 ||r(i)||/||b|| 2.081619146164e-04
2650 KSP unpreconditioned resid norm 8.712485807467e+00 true resid norm 8.712485807462e+00 ||r(i)||/||b|| 2.081619146164e-04
2651 KSP unpreconditioned resid norm 8.712485807466e+00 true resid norm 8.712485807452e+00 ||r(i)||/||b|| 2.081619146161e-04
2652 KSP unpreconditioned resid norm 8.712485807466e+00 true resid norm 8.712485807462e+00 ||r(i)||/||b|| 2.081619146164e-04
2653 KSP unpreconditioned resid norm 8.712485807459e+00 true resid norm 8.712485807449e+00 ||r(i)||/||b|| 2.081619146161e-04
2654 KSP unpreconditioned resid norm 8.712485807449e+00 true resid norm 8.712485807440e+00 ||r(i)||/||b|| 2.081619146158e-04
2655 KSP unpreconditioned resid norm 8.712485807434e+00 true resid norm 8.712485807437e+00 ||r(i)||/||b|| 2.081619146158e-04
2656 KSP unpreconditioned resid norm 8.712485807425e+00 true resid norm 8.712485807413e+00 ||r(i)||/||b|| 2.081619146152e-04
2657 KSP unpreconditioned resid norm 8.712485807417e+00 true resid norm 8.712485807417e+00 ||r(i)||/||b|| 2.081619146153e-04
2658 KSP unpreconditioned resid norm 8.712485807409e+00 true resid norm 8.712485807399e+00 ||r(i)||/||b|| 2.081619146149e-04
2659 KSP unpreconditioned resid norm 8.712485807402e+00 true resid norm 8.712485807395e+00 ||r(i)||/||b|| 2.081619146147e-04
2660 KSP unpreconditioned resid norm 8.712485807402e+00 true resid norm 8.712485807391e+00 ||r(i)||/||b|| 2.081619146147e-04
2661 KSP unpreconditioned resid norm 8.712485807401e+00 true resid norm 8.712485807390e+00 ||r(i)||/||b|| 2.081619146146e-04
2662 KSP unpreconditioned resid norm 8.712485807392e+00 true resid norm 8.712485807384e+00 ||r(i)||/||b|| 2.081619146145e-04
2663 KSP unpreconditioned resid norm 8.712485807346e+00 true resid norm 8.712485807346e+00 ||r(i)||/||b|| 2.081619146136e-04
2664 KSP unpreconditioned resid norm 8.712485807285e+00 true resid norm 8.712485807290e+00 ||r(i)||/||b|| 2.081619146123e-04
2665 KSP unpreconditioned resid norm 8.712485807237e+00 true resid norm 8.712485807233e+00 ||r(i)||/||b|| 2.081619146109e-04
2666 KSP unpreconditioned resid norm 8.712485807179e+00 true resid norm 8.712485807173e+00 ||r(i)||/||b|| 2.081619146095e-04
2667 KSP unpreconditioned resid norm 8.712485807086e+00 true resid norm 8.712485807075e+00 ||r(i)||/||b|| 2.081619146071e-04
2668 KSP unpreconditioned resid norm 8.712485806864e+00 true resid norm 8.712485806852e+00 ||r(i)||/||b|| 2.081619146018e-04
2669 KSP unpreconditioned resid norm 8.712485806745e+00 true resid norm 8.712485806746e+00 ||r(i)||/||b|| 2.081619145992e-04
2670 KSP unpreconditioned resid norm 8.712485806739e+00 true resid norm 8.712485806739e+00 ||r(i)||/||b|| 2.081619145991e-04
2671 KSP unpreconditioned resid norm 8.712485806739e+00 true resid norm 8.712485806727e+00 ||r(i)||/||b|| 2.081619145988e-04
2672 KSP unpreconditioned resid norm 8.712485806739e+00 true resid norm 8.712485806738e+00 ||r(i)||/||b|| 2.081619145990e-04
2673 KSP unpreconditioned resid norm 8.712485806736e+00 true resid norm 8.712485806727e+00 ||r(i)||/||b|| 2.081619145988e-04
2674 KSP unpreconditioned resid norm 8.712485806731e+00 true resid norm 8.712485806710e+00 ||r(i)||/||b|| 2.081619145984e-04
2675 KSP unpreconditioned resid norm 8.712485806725e+00 true resid norm 8.712485806718e+00 ||r(i)||/||b|| 2.081619145986e-04
2676 KSP unpreconditioned resid norm 8.712485806723e+00 true resid norm 8.712485806715e+00 ||r(i)||/||b|| 2.081619145985e-04
2677 KSP unpreconditioned resid norm 8.712485806722e+00 true resid norm 8.712485806718e+00 ||r(i)||/||b|| 2.081619145986e-04
2678 KSP unpreconditioned resid norm 8.712485806719e+00 true resid norm 8.712485806714e+00 ||r(i)||/||b|| 2.081619145985e-04
2679 KSP unpreconditioned resid norm 8.712485806713e+00 true resid norm 8.712485806706e+00 ||r(i)||/||b|| 2.081619145983e-04
2680 KSP unpreconditioned resid norm 8.712485806708e+00 true resid norm 8.712485806707e+00 ||r(i)||/||b|| 2.081619145983e-04
2681 KSP unpreconditioned resid norm 8.712485806707e+00 true resid norm 8.712485806698e+00 ||r(i)||/||b|| 2.081619145981e-04
2682 KSP unpreconditioned resid norm 8.712485806707e+00 true resid norm 8.712485806696e+00 ||r(i)||/||b|| 2.081619145981e-04
2683 KSP unpreconditioned resid norm 8.712485806701e+00 true resid norm 8.712485806681e+00 ||r(i)||/||b|| 2.081619145977e-04
2684 KSP unpreconditioned resid norm 8.712485806692e+00 true resid norm 8.712485806686e+00 ||r(i)||/||b|| 2.081619145978e-04
2685 KSP unpreconditioned resid norm 8.712485806678e+00 true resid norm 8.712485806674e+00 ||r(i)||/||b|| 2.081619145975e-04
2686 KSP unpreconditioned resid norm 8.712485806671e+00 true resid norm 8.712485806669e+00 ||r(i)||/||b|| 2.081619145974e-04
2687 KSP unpreconditioned resid norm 8.712485806664e+00 true resid norm 8.712485806656e+00 ||r(i)||/||b|| 2.081619145971e-04
2688 KSP unpreconditioned resid norm 8.712485806657e+00 true resid norm 8.712485806637e+00 ||r(i)||/||b|| 2.081619145967e-04
2689 KSP unpreconditioned resid norm 8.712485806650e+00 true resid norm 8.712485806644e+00 ||r(i)||/||b|| 2.081619145968e-04
2690 KSP unpreconditioned resid norm 8.712485806650e+00 true resid norm 8.712485806640e+00 ||r(i)||/||b|| 2.081619145967e-04
2691 KSP unpreconditioned resid norm 8.712485806649e+00 true resid norm 8.712485806641e+00 ||r(i)||/||b|| 2.081619145967e-04
2692 KSP unpreconditioned resid norm 8.712485806641e+00 true resid norm 8.712485806632e+00 ||r(i)||/||b|| 2.081619145965e-04
2693 KSP unpreconditioned resid norm 8.712485806601e+00 true resid norm 8.712485806582e+00 ||r(i)||/||b|| 2.081619145953e-04
2694 KSP unpreconditioned resid norm 8.712485806547e+00 true resid norm 8.712485806549e+00 ||r(i)||/||b|| 2.081619145945e-04
2695 KSP unpreconditioned resid norm 8.712485806505e+00 true resid norm 8.712485806494e+00 ||r(i)||/||b|| 2.081619145932e-04
2696 KSP unpreconditioned resid norm 8.712485806454e+00 true resid norm 8.712485806439e+00 ||r(i)||/||b|| 2.081619145919e-04
2697 KSP unpreconditioned resid norm 8.712485806371e+00 true resid norm 8.712485806360e+00 ||r(i)||/||b|| 2.081619145900e-04
2698 KSP unpreconditioned resid norm 8.712485806175e+00 true resid norm 8.712485806167e+00 ||r(i)||/||b|| 2.081619145854e-04
2699 KSP unpreconditioned resid norm 8.712485806069e+00 true resid norm 8.712485806064e+00 ||r(i)||/||b|| 2.081619145830e-04
2700 KSP unpreconditioned resid norm 8.712485806054e+00 true resid norm 8.712485806054e+00 ||r(i)||/||b|| 2.081619145827e-04
2701 KSP unpreconditioned resid norm 8.712485806054e+00 true resid norm 8.712485806065e+00 ||r(i)||/||b|| 2.081619145830e-04
2702 KSP unpreconditioned resid norm 8.712485806053e+00 true resid norm 8.712485806059e+00 ||r(i)||/||b|| 2.081619145828e-04
2703 KSP unpreconditioned resid norm 8.712485806051e+00 true resid norm 8.712485806058e+00 ||r(i)||/||b|| 2.081619145828e-04
2704 KSP unpreconditioned resid norm 8.712485806046e+00 true resid norm 8.712485806048e+00 ||r(i)||/||b|| 2.081619145826e-04
2705 KSP unpreconditioned resid norm 8.712485806041e+00 true resid norm 8.712485806044e+00 ||r(i)||/||b|| 2.081619145825e-04
2706 KSP unpreconditioned resid norm 8.712485806039e+00 true resid norm 8.712485806046e+00 ||r(i)||/||b|| 2.081619145825e-04
2707 KSP unpreconditioned resid norm 8.712485806038e+00 true resid norm 8.712485806038e+00 ||r(i)||/||b|| 2.081619145823e-04
2708 KSP unpreconditioned resid norm 8.712485806036e+00 true resid norm 8.712485806044e+00 ||r(i)||/||b|| 2.081619145825e-04
2709 KSP unpreconditioned resid norm 8.712485806030e+00 true resid norm 8.712485806035e+00 ||r(i)||/||b|| 2.081619145823e-04
2710 KSP unpreconditioned resid norm 8.712485806026e+00 true resid norm 8.712485806030e+00 ||r(i)||/||b|| 2.081619145822e-04
2711 KSP unpreconditioned resid norm 8.712485806025e+00 true resid norm 8.712485806023e+00 ||r(i)||/||b|| 2.081619145820e-04
2712 KSP unpreconditioned resid norm 8.712485806025e+00 true resid norm 8.712485806038e+00 ||r(i)||/||b|| 2.081619145823e-04
2713 KSP unpreconditioned resid norm 8.712485806020e+00 true resid norm 8.712485806030e+00 ||r(i)||/||b|| 2.081619145822e-04
2714 KSP unpreconditioned resid norm 8.712485806012e+00 true resid norm 8.712485806013e+00 ||r(i)||/||b|| 2.081619145817e-04
2715 KSP unpreconditioned resid norm 8.712485806000e+00 true resid norm 8.712485806002e+00 ||r(i)||/||b|| 2.081619145815e-04
2716 KSP unpreconditioned resid norm 8.712485805993e+00 true resid norm 8.712485805993e+00 ||r(i)||/||b|| 2.081619145813e-04
2717 KSP unpreconditioned resid norm 8.712485805987e+00 true resid norm 8.712485805987e+00 ||r(i)||/||b|| 2.081619145811e-04
2718 KSP unpreconditioned resid norm 8.712485805981e+00 true resid norm 8.712485805994e+00 ||r(i)||/||b|| 2.081619145813e-04
2719 KSP unpreconditioned resid norm 8.712485805975e+00 true resid norm 8.712485805980e+00 ||r(i)||/||b|| 2.081619145809e-04
2720 KSP unpreconditioned resid norm 8.712485805975e+00 true resid norm 8.712485805978e+00 ||r(i)||/||b|| 2.081619145809e-04
2721 KSP unpreconditioned resid norm 8.712485805974e+00 true resid norm 8.712485805975e+00 ||r(i)||/||b|| 2.081619145808e-04
2722 KSP unpreconditioned resid norm 8.712485805967e+00 true resid norm 8.712485805964e+00 ||r(i)||/||b|| 2.081619145806e-04
2723 KSP unpreconditioned resid norm 8.712485805931e+00 true resid norm 8.712485805939e+00 ||r(i)||/||b|| 2.081619145800e-04
2724 KSP unpreconditioned resid norm 8.712485805883e+00 true resid norm 8.712485805895e+00 ||r(i)||/||b|| 2.081619145789e-04
2725 KSP unpreconditioned resid norm 8.712485805846e+00 true resid norm 8.712485805840e+00 ||r(i)||/||b|| 2.081619145776e-04
2726 KSP unpreconditioned resid norm 8.712485805800e+00 true resid norm 8.712485805806e+00 ||r(i)||/||b|| 2.081619145768e-04
2727 KSP unpreconditioned resid norm 8.712485805728e+00 true resid norm 8.712485805734e+00 ||r(i)||/||b|| 2.081619145751e-04
2728 KSP unpreconditioned resid norm 8.712485805554e+00 true resid norm 8.712485805558e+00 ||r(i)||/||b|| 2.081619145709e-04
2729 KSP unpreconditioned resid norm 8.712485805461e+00 true resid norm 8.712485805459e+00 ||r(i)||/||b|| 2.081619145685e-04
2730 KSP unpreconditioned resid norm 8.712485805462e+00 true resid norm 8.712485805462e+00 ||r(i)||/||b|| 2.081619145686e-04
2731 KSP unpreconditioned resid norm 8.712485805462e+00 true resid norm 8.712485805458e+00 ||r(i)||/||b|| 2.081619145685e-04
2732 KSP unpreconditioned resid norm 8.712485805462e+00 true resid norm 8.712485805468e+00 ||r(i)||/||b|| 2.081619145687e-04
2733 KSP unpreconditioned resid norm 8.712485805460e+00 true resid norm 8.712485805454e+00 ||r(i)||/||b|| 2.081619145684e-04
2734 KSP unpreconditioned resid norm 8.712485805456e+00 true resid norm 8.712485805455e+00 ||r(i)||/||b|| 2.081619145684e-04
2735 KSP unpreconditioned resid norm 8.712485805451e+00 true resid norm 8.712485805442e+00 ||r(i)||/||b|| 2.081619145681e-04
2736 KSP unpreconditioned resid norm 8.712485805450e+00 true resid norm 8.712485805442e+00 ||r(i)||/||b|| 2.081619145681e-04
2737 KSP unpreconditioned resid norm 8.712485805449e+00 true resid norm 8.712485805441e+00 ||r(i)||/||b|| 2.081619145681e-04
2738 KSP unpreconditioned resid norm 8.712485805447e+00 true resid norm 8.712485805440e+00 ||r(i)||/||b|| 2.081619145681e-04
2739 KSP unpreconditioned resid norm 8.712485805442e+00 true resid norm 8.712485805436e+00 ||r(i)||/||b|| 2.081619145679e-04
2740 KSP unpreconditioned resid norm 8.712485805438e+00 true resid norm 8.712485805431e+00 ||r(i)||/||b|| 2.081619145678e-04
2741 KSP unpreconditioned resid norm 8.712485805437e+00 true resid norm 8.712485805435e+00 ||r(i)||/||b|| 2.081619145679e-04
2742 KSP unpreconditioned resid norm 8.712485805437e+00 true resid norm 8.712485805427e+00 ||r(i)||/||b|| 2.081619145677e-04
2743 KSP unpreconditioned resid norm 8.712485805433e+00 true resid norm 8.712485805431e+00 ||r(i)||/||b|| 2.081619145678e-04
2744 KSP unpreconditioned resid norm 8.712485805425e+00 true resid norm 8.712485805429e+00 ||r(i)||/||b|| 2.081619145678e-04
2745 KSP unpreconditioned resid norm 8.712485805415e+00 true resid norm 8.712485805411e+00 ||r(i)||/||b|| 2.081619145674e-04
2746 KSP unpreconditioned resid norm 8.712485805409e+00 true resid norm 8.712485805403e+00 ||r(i)||/||b|| 2.081619145672e-04
2747 KSP unpreconditioned resid norm 8.712485805404e+00 true resid norm 8.712485805399e+00 ||r(i)||/||b|| 2.081619145671e-04
2748 KSP unpreconditioned resid norm 8.712485805398e+00 true resid norm 8.712485805394e+00 ||r(i)||/||b|| 2.081619145670e-04
2749 KSP unpreconditioned resid norm 8.712485805393e+00 true resid norm 8.712485805394e+00 ||r(i)||/||b|| 2.081619145670e-04
2750 KSP unpreconditioned resid norm 8.712485805393e+00 true resid norm 8.712485805382e+00 ||r(i)||/||b|| 2.081619145667e-04
2751 KSP unpreconditioned resid norm 8.712485805392e+00 true resid norm 8.712485805382e+00 ||r(i)||/||b|| 2.081619145667e-04
2752 KSP unpreconditioned resid norm 8.712485805386e+00 true resid norm 8.712485805385e+00 ||r(i)||/||b|| 2.081619145667e-04
2753 KSP unpreconditioned resid norm 8.712485805355e+00 true resid norm 8.712485805348e+00 ||r(i)||/||b|| 2.081619145658e-04
2754 KSP unpreconditioned resid norm 8.712485805312e+00 true resid norm 8.712485805311e+00 ||r(i)||/||b|| 2.081619145650e-04
2755 KSP unpreconditioned resid norm 8.712485805279e+00 true resid norm 8.712485805271e+00 ||r(i)||/||b|| 2.081619145640e-04
2756 KSP unpreconditioned resid norm 8.712485805239e+00 true resid norm 8.712485805234e+00 ||r(i)||/||b|| 2.081619145631e-04
2757 KSP unpreconditioned resid norm 8.712485805175e+00 true resid norm 8.712485805178e+00 ||r(i)||/||b|| 2.081619145618e-04
2758 KSP unpreconditioned resid norm 8.712485805022e+00 true resid norm 8.712485805021e+00 ||r(i)||/||b|| 2.081619145580e-04
2759 KSP unpreconditioned resid norm 8.712485804939e+00 true resid norm 8.712485804942e+00 ||r(i)||/||b|| 2.081619145562e-04
2760 KSP unpreconditioned resid norm 8.712485804931e+00 true resid norm 8.712485804931e+00 ||r(i)||/||b|| 2.081619145559e-04
2761 KSP unpreconditioned resid norm 8.712485804931e+00 true resid norm 8.712485804935e+00 ||r(i)||/||b|| 2.081619145560e-04
2762 KSP unpreconditioned resid norm 8.712485804931e+00 true resid norm 8.712485804936e+00 ||r(i)||/||b|| 2.081619145560e-04
2763 KSP unpreconditioned resid norm 8.712485804929e+00 true resid norm 8.712485804936e+00 ||r(i)||/||b|| 2.081619145560e-04
2764 KSP unpreconditioned resid norm 8.712485804925e+00 true resid norm 8.712485804930e+00 ||r(i)||/||b|| 2.081619145559e-04
2765 KSP unpreconditioned resid norm 8.712485804921e+00 true resid norm 8.712485804924e+00 ||r(i)||/||b|| 2.081619145557e-04
2766 KSP unpreconditioned resid norm 8.712485804920e+00 true resid norm 8.712485804931e+00 ||r(i)||/||b|| 2.081619145559e-04
2767 KSP unpreconditioned resid norm 8.712485804919e+00 true resid norm 8.712485804925e+00 ||r(i)||/||b|| 2.081619145557e-04
2768 KSP unpreconditioned resid norm 8.712485804917e+00 true resid norm 8.712485804911e+00 ||r(i)||/||b|| 2.081619145554e-04
2769 KSP unpreconditioned resid norm 8.712485804913e+00 true resid norm 8.712485804906e+00 ||r(i)||/||b|| 2.081619145553e-04
2770 KSP unpreconditioned resid norm 8.712485804909e+00 true resid norm 8.712485804913e+00 ||r(i)||/||b|| 2.081619145554e-04
2771 KSP unpreconditioned resid norm 8.712485804909e+00 true resid norm 8.712485804914e+00 ||r(i)||/||b|| 2.081619145555e-04
2772 KSP unpreconditioned resid norm 8.712485804909e+00 true resid norm 8.712485804910e+00 ||r(i)||/||b|| 2.081619145554e-04
2773 KSP unpreconditioned resid norm 8.712485804905e+00 true resid norm 8.712485804905e+00 ||r(i)||/||b|| 2.081619145553e-04
2774 KSP unpreconditioned resid norm 8.712485804898e+00 true resid norm 8.712485804907e+00 ||r(i)||/||b|| 2.081619145553e-04
2775 KSP unpreconditioned resid norm 8.712485804889e+00 true resid norm 8.712485804894e+00 ||r(i)||/||b|| 2.081619145550e-04
2776 KSP unpreconditioned resid norm 8.712485804884e+00 true resid norm 8.712485804903e+00 ||r(i)||/||b|| 2.081619145552e-04
2777 KSP unpreconditioned resid norm 8.712485804879e+00 true resid norm 8.712485804890e+00 ||r(i)||/||b|| 2.081619145549e-04
2778 KSP unpreconditioned resid norm 8.712485804874e+00 true resid norm 8.712485804875e+00 ||r(i)||/||b|| 2.081619145546e-04
2779 KSP unpreconditioned resid norm 8.712485804870e+00 true resid norm 8.712485804869e+00 ||r(i)||/||b|| 2.081619145544e-04
2780 KSP unpreconditioned resid norm 8.712485804869e+00 true resid norm 8.712485804874e+00 ||r(i)||/||b|| 2.081619145545e-04
2781 KSP unpreconditioned resid norm 8.712485804869e+00 true resid norm 8.712485804871e+00 ||r(i)||/||b|| 2.081619145545e-04
2782 KSP unpreconditioned resid norm 8.712485804863e+00 true resid norm 8.712485804872e+00 ||r(i)||/||b|| 2.081619145545e-04
2783 KSP unpreconditioned resid norm 8.712485804836e+00 true resid norm 8.712485804847e+00 ||r(i)||/||b|| 2.081619145539e-04
2784 KSP unpreconditioned resid norm 8.712485804798e+00 true resid norm 8.712485804802e+00 ||r(i)||/||b|| 2.081619145528e-04
2785 KSP unpreconditioned resid norm 8.712485804769e+00 true resid norm 8.712485804774e+00 ||r(i)||/||b|| 2.081619145521e-04
2786 KSP unpreconditioned resid norm 8.712485804733e+00 true resid norm 8.712485804740e+00 ||r(i)||/||b|| 2.081619145513e-04
2787 KSP unpreconditioned resid norm 8.712485804676e+00 true resid norm 8.712485804669e+00 ||r(i)||/||b|| 2.081619145496e-04
2788 KSP unpreconditioned resid norm 8.712485804541e+00 true resid norm 8.712485804534e+00 ||r(i)||/||b|| 2.081619145464e-04
2789 KSP unpreconditioned resid norm 8.712485804468e+00 true resid norm 8.712485804466e+00 ||r(i)||/||b|| 2.081619145448e-04
2790 KSP unpreconditioned resid norm 8.712485804468e+00 true resid norm 8.712485804468e+00 ||r(i)||/||b|| 2.081619145448e-04
2791 KSP unpreconditioned resid norm 8.712485804468e+00 true resid norm 8.712485804461e+00 ||r(i)||/||b|| 2.081619145446e-04
2792 KSP unpreconditioned resid norm 8.712485804468e+00 true resid norm 8.712485804469e+00 ||r(i)||/||b|| 2.081619145449e-04
2793 KSP unpreconditioned resid norm 8.712485804467e+00 true resid norm 8.712485804472e+00 ||r(i)||/||b|| 2.081619145449e-04
2794 KSP unpreconditioned resid norm 8.712485804463e+00 true resid norm 8.712485804458e+00 ||r(i)||/||b|| 2.081619145446e-04
2795 KSP unpreconditioned resid norm 8.712485804460e+00 true resid norm 8.712485804448e+00 ||r(i)||/||b|| 2.081619145444e-04
2796 KSP unpreconditioned resid norm 8.712485804458e+00 true resid norm 8.712485804449e+00 ||r(i)||/||b|| 2.081619145444e-04
2797 KSP unpreconditioned resid norm 8.712485804458e+00 true resid norm 8.712485804455e+00 ||r(i)||/||b|| 2.081619145445e-04
2798 KSP unpreconditioned resid norm 8.712485804456e+00 true resid norm 8.712485804444e+00 ||r(i)||/||b|| 2.081619145443e-04
2799 KSP unpreconditioned resid norm 8.712485804452e+00 true resid norm 8.712485804443e+00 ||r(i)||/||b|| 2.081619145442e-04
2800 KSP unpreconditioned resid norm 8.712485804449e+00 true resid norm 8.712485804446e+00 ||r(i)||/||b|| 2.081619145443e-04
2801 KSP unpreconditioned resid norm 8.712485804449e+00 true resid norm 8.712485804446e+00 ||r(i)||/||b|| 2.081619145443e-04
2802 KSP unpreconditioned resid norm 8.712485804449e+00 true resid norm 8.712485804443e+00 ||r(i)||/||b|| 2.081619145442e-04
2803 KSP unpreconditioned resid norm 8.712485804445e+00 true resid norm 8.712485804429e+00 ||r(i)||/||b|| 2.081619145439e-04
2804 KSP unpreconditioned resid norm 8.712485804439e+00 true resid norm 8.712485804422e+00 ||r(i)||/||b|| 2.081619145437e-04
2805 KSP unpreconditioned resid norm 8.712485804431e+00 true resid norm 8.712485804424e+00 ||r(i)||/||b|| 2.081619145438e-04
2806 KSP unpreconditioned resid norm 8.712485804427e+00 true resid norm 8.712485804425e+00 ||r(i)||/||b|| 2.081619145438e-04
2807 KSP unpreconditioned resid norm 8.712485804422e+00 true resid norm 8.712485804417e+00 ||r(i)||/||b|| 2.081619145436e-04
2808 KSP unpreconditioned resid norm 8.712485804418e+00 true resid norm 8.712485804412e+00 ||r(i)||/||b|| 2.081619145435e-04
2809 KSP unpreconditioned resid norm 8.712485804414e+00 true resid norm 8.712485804401e+00 ||r(i)||/||b|| 2.081619145432e-04
2810 KSP unpreconditioned resid norm 8.712485804414e+00 true resid norm 8.712485804410e+00 ||r(i)||/||b|| 2.081619145434e-04
2811 KSP unpreconditioned resid norm 8.712485804413e+00 true resid norm 8.712485804412e+00 ||r(i)||/||b|| 2.081619145435e-04
2812 KSP unpreconditioned resid norm 8.712485804409e+00 true resid norm 8.712485804397e+00 ||r(i)||/||b|| 2.081619145431e-04
2813 KSP unpreconditioned resid norm 8.712485804384e+00 true resid norm 8.712485804389e+00 ||r(i)||/||b|| 2.081619145429e-04
2814 KSP unpreconditioned resid norm 8.712485804351e+00 true resid norm 8.712485804346e+00 ||r(i)||/||b|| 2.081619145419e-04
2815 KSP unpreconditioned resid norm 8.712485804325e+00 true resid norm 8.712485804320e+00 ||r(i)||/||b|| 2.081619145413e-04
2816 KSP unpreconditioned resid norm 8.712485804294e+00 true resid norm 8.712485804277e+00 ||r(i)||/||b|| 2.081619145403e-04
2817 KSP unpreconditioned resid norm 8.712485804243e+00 true resid norm 8.712485804239e+00 ||r(i)||/||b|| 2.081619145393e-04
2818 KSP unpreconditioned resid norm 8.712485804124e+00 true resid norm 8.712485804116e+00 ||r(i)||/||b|| 2.081619145364e-04
2819 KSP unpreconditioned resid norm 8.712485804059e+00 true resid norm 8.712485804052e+00 ||r(i)||/||b|| 2.081619145349e-04
2820 KSP unpreconditioned resid norm 8.712485804043e+00 true resid norm 8.712485804043e+00 ||r(i)||/||b|| 2.081619145347e-04
2821 KSP unpreconditioned resid norm 8.712485804043e+00 true resid norm 8.712485804039e+00 ||r(i)||/||b|| 2.081619145346e-04
2822 KSP unpreconditioned resid norm 8.712485804043e+00 true resid norm 8.712485804034e+00 ||r(i)||/||b|| 2.081619145345e-04
2823 KSP unpreconditioned resid norm 8.712485804041e+00 true resid norm 8.712485804044e+00 ||r(i)||/||b|| 2.081619145347e-04
2824 KSP unpreconditioned resid norm 8.712485804039e+00 true resid norm 8.712485804039e+00 ||r(i)||/||b|| 2.081619145346e-04
2825 KSP unpreconditioned resid norm 8.712485804035e+00 true resid norm 8.712485804044e+00 ||r(i)||/||b|| 2.081619145347e-04
2826 KSP unpreconditioned resid norm 8.712485804034e+00 true resid norm 8.712485804036e+00 ||r(i)||/||b|| 2.081619145345e-04
2827 KSP unpreconditioned resid norm 8.712485804034e+00 true resid norm 8.712485804030e+00 ||r(i)||/||b|| 2.081619145344e-04
2828 KSP unpreconditioned resid norm 8.712485804032e+00 true resid norm 8.712485804022e+00 ||r(i)||/||b|| 2.081619145342e-04
2829 KSP unpreconditioned resid norm 8.712485804029e+00 true resid norm 8.712485804038e+00 ||r(i)||/||b|| 2.081619145345e-04
2830 KSP unpreconditioned resid norm 8.712485804026e+00 true resid norm 8.712485804047e+00 ||r(i)||/||b|| 2.081619145348e-04
2831 KSP unpreconditioned resid norm 8.712485804025e+00 true resid norm 8.712485804020e+00 ||r(i)||/||b|| 2.081619145341e-04
2832 KSP unpreconditioned resid norm 8.712485804025e+00 true resid norm 8.712485804030e+00 ||r(i)||/||b|| 2.081619145343e-04
2833 KSP unpreconditioned resid norm 8.712485804022e+00 true resid norm 8.712485804023e+00 ||r(i)||/||b|| 2.081619145342e-04
2834 KSP unpreconditioned resid norm 8.712485804017e+00 true resid norm 8.712485804021e+00 ||r(i)||/||b|| 2.081619145341e-04
2835 KSP unpreconditioned resid norm 8.712485804010e+00 true resid norm 8.712485804016e+00 ||r(i)||/||b|| 2.081619145340e-04
2836 KSP unpreconditioned resid norm 8.712485804006e+00 true resid norm 8.712485804013e+00 ||r(i)||/||b|| 2.081619145339e-04
2837 KSP unpreconditioned resid norm 8.712485804002e+00 true resid norm 8.712485804005e+00 ||r(i)||/||b|| 2.081619145338e-04
2838 KSP unpreconditioned resid norm 8.712485803998e+00 true resid norm 8.712485803998e+00 ||r(i)||/||b|| 2.081619145336e-04
2839 KSP unpreconditioned resid norm 8.712485803995e+00 true resid norm 8.712485803994e+00 ||r(i)||/||b|| 2.081619145335e-04
2840 KSP unpreconditioned resid norm 8.712485803995e+00 true resid norm 8.712485803993e+00 ||r(i)||/||b|| 2.081619145335e-04
2841 KSP unpreconditioned resid norm 8.712485803994e+00 true resid norm 8.712485803991e+00 ||r(i)||/||b|| 2.081619145334e-04
2842 KSP unpreconditioned resid norm 8.712485803990e+00 true resid norm 8.712485803999e+00 ||r(i)||/||b|| 2.081619145336e-04
2843 KSP unpreconditioned resid norm 8.712485803968e+00 true resid norm 8.712485803969e+00 ||r(i)||/||b|| 2.081619145329e-04
2844 KSP unpreconditioned resid norm 8.712485803939e+00 true resid norm 8.712485803954e+00 ||r(i)||/||b|| 2.081619145325e-04
2845 KSP unpreconditioned resid norm 8.712485803916e+00 true resid norm 8.712485803914e+00 ||r(i)||/||b|| 2.081619145316e-04
2846 KSP unpreconditioned resid norm 8.712485803888e+00 true resid norm 8.712485803900e+00 ||r(i)||/||b|| 2.081619145312e-04
2847 KSP unpreconditioned resid norm 8.712485803844e+00 true resid norm 8.712485803852e+00 ||r(i)||/||b|| 2.081619145301e-04
2848 KSP unpreconditioned resid norm 8.712485803738e+00 true resid norm 8.712485803744e+00 ||r(i)||/||b|| 2.081619145275e-04
2849 KSP unpreconditioned resid norm 8.712485803681e+00 true resid norm 8.712485803679e+00 ||r(i)||/||b|| 2.081619145260e-04
2850 KSP unpreconditioned resid norm 8.712485803673e+00 true resid norm 8.712485803673e+00 ||r(i)||/||b|| 2.081619145258e-04
2851 KSP unpreconditioned resid norm 8.712485803673e+00 true resid norm 8.712485803678e+00 ||r(i)||/||b|| 2.081619145259e-04
2852 KSP unpreconditioned resid norm 8.712485803673e+00 true resid norm 8.712485803664e+00 ||r(i)||/||b|| 2.081619145256e-04
2853 KSP unpreconditioned resid norm 8.712485803671e+00 true resid norm 8.712485803673e+00 ||r(i)||/||b|| 2.081619145258e-04
2854 KSP unpreconditioned resid norm 8.712485803669e+00 true resid norm 8.712485803663e+00 ||r(i)||/||b|| 2.081619145256e-04
2855 KSP unpreconditioned resid norm 8.712485803666e+00 true resid norm 8.712485803659e+00 ||r(i)||/||b|| 2.081619145255e-04
2856 KSP unpreconditioned resid norm 8.712485803665e+00 true resid norm 8.712485803667e+00 ||r(i)||/||b|| 2.081619145257e-04
2857 KSP unpreconditioned resid norm 8.712485803665e+00 true resid norm 8.712485803664e+00 ||r(i)||/||b|| 2.081619145256e-04
2858 KSP unpreconditioned resid norm 8.712485803663e+00 true resid norm 8.712485803670e+00 ||r(i)||/||b|| 2.081619145258e-04
2859 KSP unpreconditioned resid norm 8.712485803660e+00 true resid norm 8.712485803661e+00 ||r(i)||/||b|| 2.081619145255e-04
2860 KSP unpreconditioned resid norm 8.712485803658e+00 true resid norm 8.712485803668e+00 ||r(i)||/||b|| 2.081619145257e-04
2861 KSP unpreconditioned resid norm 8.712485803657e+00 true resid norm 8.712485803647e+00 ||r(i)||/||b|| 2.081619145252e-04
2862 KSP unpreconditioned resid norm 8.712485803657e+00 true resid norm 8.712485803660e+00 ||r(i)||/||b|| 2.081619145255e-04
2863 KSP unpreconditioned resid norm 8.712485803655e+00 true resid norm 8.712485803647e+00 ||r(i)||/||b|| 2.081619145252e-04
2864 KSP unpreconditioned resid norm 8.712485803650e+00 true resid norm 8.712485803652e+00 ||r(i)||/||b|| 2.081619145253e-04
2865 KSP unpreconditioned resid norm 8.712485803644e+00 true resid norm 8.712485803639e+00 ||r(i)||/||b|| 2.081619145250e-04
2866 KSP unpreconditioned resid norm 8.712485803640e+00 true resid norm 8.712485803637e+00 ||r(i)||/||b|| 2.081619145250e-04
2867 KSP unpreconditioned resid norm 8.712485803637e+00 true resid norm 8.712485803638e+00 ||r(i)||/||b|| 2.081619145250e-04
2868 KSP unpreconditioned resid norm 8.712485803633e+00 true resid norm 8.712485803645e+00 ||r(i)||/||b|| 2.081619145252e-04
2869 KSP unpreconditioned resid norm 8.712485803630e+00 true resid norm 8.712485803630e+00 ||r(i)||/||b|| 2.081619145248e-04
2870 KSP unpreconditioned resid norm 8.712485803630e+00 true resid norm 8.712485803633e+00 ||r(i)||/||b|| 2.081619145249e-04
2871 KSP unpreconditioned resid norm 8.712485803630e+00 true resid norm 8.712485803625e+00 ||r(i)||/||b|| 2.081619145247e-04
2872 KSP unpreconditioned resid norm 8.712485803626e+00 true resid norm 8.712485803632e+00 ||r(i)||/||b|| 2.081619145248e-04
2873 KSP unpreconditioned resid norm 8.712485803607e+00 true resid norm 8.712485803604e+00 ||r(i)||/||b|| 2.081619145242e-04
2874 KSP unpreconditioned resid norm 8.712485803581e+00 true resid norm 8.712485803593e+00 ||r(i)||/||b|| 2.081619145239e-04
2875 KSP unpreconditioned resid norm 8.712485803561e+00 true resid norm 8.712485803560e+00 ||r(i)||/||b|| 2.081619145231e-04
2876 KSP unpreconditioned resid norm 8.712485803536e+00 true resid norm 8.712485803539e+00 ||r(i)||/||b|| 2.081619145226e-04
2877 KSP unpreconditioned resid norm 8.712485803497e+00 true resid norm 8.712485803494e+00 ||r(i)||/||b|| 2.081619145216e-04
2878 KSP unpreconditioned resid norm 8.712485803403e+00 true resid norm 8.712485803399e+00 ||r(i)||/||b|| 2.081619145193e-04
2879 KSP unpreconditioned resid norm 8.712485803353e+00 true resid norm 8.712485803347e+00 ||r(i)||/||b|| 2.081619145180e-04
2880 KSP unpreconditioned resid norm 8.712485803354e+00 true resid norm 8.712485803354e+00 ||r(i)||/||b|| 2.081619145182e-04
2881 KSP unpreconditioned resid norm 8.712485803354e+00 true resid norm 8.712485803348e+00 ||r(i)||/||b|| 2.081619145181e-04
2882 KSP unpreconditioned resid norm 8.712485803354e+00 true resid norm 8.712485803348e+00 ||r(i)||/||b|| 2.081619145181e-04
2883 KSP unpreconditioned resid norm 8.712485803353e+00 true resid norm 8.712485803348e+00 ||r(i)||/||b|| 2.081619145181e-04
2884 KSP unpreconditioned resid norm 8.712485803351e+00 true resid norm 8.712485803337e+00 ||r(i)||/||b|| 2.081619145178e-04
2885 KSP unpreconditioned resid norm 8.712485803348e+00 true resid norm 8.712485803337e+00 ||r(i)||/||b|| 2.081619145178e-04
2886 KSP unpreconditioned resid norm 8.712485803347e+00 true resid norm 8.712485803348e+00 ||r(i)||/||b|| 2.081619145181e-04
2887 KSP unpreconditioned resid norm 8.712485803347e+00 true resid norm 8.712485803335e+00 ||r(i)||/||b|| 2.081619145177e-04
2888 KSP unpreconditioned resid norm 8.712485803346e+00 true resid norm 8.712485803344e+00 ||r(i)||/||b|| 2.081619145180e-04
2889 KSP unpreconditioned resid norm 8.712485803343e+00 true resid norm 8.712485803333e+00 ||r(i)||/||b|| 2.081619145177e-04
2890 KSP unpreconditioned resid norm 8.712485803341e+00 true resid norm 8.712485803334e+00 ||r(i)||/||b|| 2.081619145177e-04
2891 KSP unpreconditioned resid norm 8.712485803341e+00 true resid norm 8.712485803343e+00 ||r(i)||/||b|| 2.081619145179e-04
2892 KSP unpreconditioned resid norm 8.712485803341e+00 true resid norm 8.712485803331e+00 ||r(i)||/||b|| 2.081619145177e-04
2893 KSP unpreconditioned resid norm 8.712485803338e+00 true resid norm 8.712485803333e+00 ||r(i)||/||b|| 2.081619145177e-04
2894 KSP unpreconditioned resid norm 8.712485803334e+00 true resid norm 8.712485803321e+00 ||r(i)||/||b|| 2.081619145174e-04
2895 KSP unpreconditioned resid norm 8.712485803329e+00 true resid norm 8.712485803316e+00 ||r(i)||/||b|| 2.081619145173e-04
2896 KSP unpreconditioned resid norm 8.712485803325e+00 true resid norm 8.712485803317e+00 ||r(i)||/||b|| 2.081619145173e-04
2897 KSP unpreconditioned resid norm 8.712485803323e+00 true resid norm 8.712485803315e+00 ||r(i)||/||b|| 2.081619145173e-04
2898 KSP unpreconditioned resid norm 8.712485803320e+00 true resid norm 8.712485803304e+00 ||r(i)||/||b|| 2.081619145170e-04
2899 KSP unpreconditioned resid norm 8.712485803317e+00 true resid norm 8.712485803312e+00 ||r(i)||/||b|| 2.081619145172e-04
2900 KSP unpreconditioned resid norm 8.712485803317e+00 true resid norm 8.712485803319e+00 ||r(i)||/||b|| 2.081619145174e-04
2901 KSP unpreconditioned resid norm 8.712485803316e+00 true resid norm 8.712485803313e+00 ||r(i)||/||b|| 2.081619145172e-04
2902 KSP unpreconditioned resid norm 8.712485803313e+00 true resid norm 8.712485803311e+00 ||r(i)||/||b|| 2.081619145172e-04
2903 KSP unpreconditioned resid norm 8.712485803296e+00 true resid norm 8.712485803288e+00 ||r(i)||/||b|| 2.081619145166e-04
2904 KSP unpreconditioned resid norm 8.712485803273e+00 true resid norm 8.712485803273e+00 ||r(i)||/||b|| 2.081619145163e-04
2905 KSP unpreconditioned resid norm 8.712485803255e+00 true resid norm 8.712485803249e+00 ||r(i)||/||b|| 2.081619145157e-04
2906 KSP unpreconditioned resid norm 8.712485803233e+00 true resid norm 8.712485803224e+00 ||r(i)||/||b|| 2.081619145151e-04
2907 KSP unpreconditioned resid norm 8.712485803199e+00 true resid norm 8.712485803186e+00 ||r(i)||/||b|| 2.081619145142e-04
2908 KSP unpreconditioned resid norm 8.712485803116e+00 true resid norm 8.712485803114e+00 ||r(i)||/||b|| 2.081619145125e-04
2909 KSP unpreconditioned resid norm 8.712485803071e+00 true resid norm 8.712485803062e+00 ||r(i)||/||b|| 2.081619145112e-04
2910 KSP unpreconditioned resid norm 8.712485803076e+00 true resid norm 8.712485803076e+00 ||r(i)||/||b|| 2.081619145116e-04
2911 KSP unpreconditioned resid norm 8.712485803076e+00 true resid norm 8.712485803065e+00 ||r(i)||/||b|| 2.081619145113e-04
2912 KSP unpreconditioned resid norm 8.712485803076e+00 true resid norm 8.712485803065e+00 ||r(i)||/||b|| 2.081619145113e-04
2913 KSP unpreconditioned resid norm 8.712485803075e+00 true resid norm 8.712485803065e+00 ||r(i)||/||b|| 2.081619145113e-04
2914 KSP unpreconditioned resid norm 8.712485803073e+00 true resid norm 8.712485803059e+00 ||r(i)||/||b|| 2.081619145112e-04
2915 KSP unpreconditioned resid norm 8.712485803071e+00 true resid norm 8.712485803063e+00 ||r(i)||/||b|| 2.081619145112e-04
2916 KSP unpreconditioned resid norm 8.712485803070e+00 true resid norm 8.712485803061e+00 ||r(i)||/||b|| 2.081619145112e-04
2917 KSP unpreconditioned resid norm 8.712485803069e+00 true resid norm 8.712485803058e+00 ||r(i)||/||b|| 2.081619145111e-04
2918 KSP unpreconditioned resid norm 8.712485803068e+00 true resid norm 8.712485803065e+00 ||r(i)||/||b|| 2.081619145113e-04
2919 KSP unpreconditioned resid norm 8.712485803066e+00 true resid norm 8.712485803052e+00 ||r(i)||/||b|| 2.081619145110e-04
2920 KSP unpreconditioned resid norm 8.712485803064e+00 true resid norm 8.712485803057e+00 ||r(i)||/||b|| 2.081619145111e-04
2921 KSP unpreconditioned resid norm 8.712485803064e+00 true resid norm 8.712485803069e+00 ||r(i)||/||b|| 2.081619145114e-04
2922 KSP unpreconditioned resid norm 8.712485803064e+00 true resid norm 8.712485803062e+00 ||r(i)||/||b|| 2.081619145112e-04
2923 KSP unpreconditioned resid norm 8.712485803062e+00 true resid norm 8.712485803051e+00 ||r(i)||/||b|| 2.081619145110e-04
2924 KSP unpreconditioned resid norm 8.712485803058e+00 true resid norm 8.712485803051e+00 ||r(i)||/||b|| 2.081619145110e-04
2925 KSP unpreconditioned resid norm 8.712485803053e+00 true resid norm 8.712485803041e+00 ||r(i)||/||b|| 2.081619145107e-04
2926 KSP unpreconditioned resid norm 8.712485803050e+00 true resid norm 8.712485803060e+00 ||r(i)||/||b|| 2.081619145112e-04
2927 KSP unpreconditioned resid norm 8.712485803048e+00 true resid norm 8.712485803049e+00 ||r(i)||/||b|| 2.081619145109e-04
2928 KSP unpreconditioned resid norm 8.712485803045e+00 true resid norm 8.712485803046e+00 ||r(i)||/||b|| 2.081619145109e-04
2929 KSP unpreconditioned resid norm 8.712485803043e+00 true resid norm 8.712485803037e+00 ||r(i)||/||b|| 2.081619145106e-04
2930 KSP unpreconditioned resid norm 8.712485803043e+00 true resid norm 8.712485803036e+00 ||r(i)||/||b|| 2.081619145106e-04
2931 KSP unpreconditioned resid norm 8.712485803042e+00 true resid norm 8.712485803041e+00 ||r(i)||/||b|| 2.081619145107e-04
2932 KSP unpreconditioned resid norm 8.712485803039e+00 true resid norm 8.712485803030e+00 ||r(i)||/||b|| 2.081619145105e-04
2933 KSP unpreconditioned resid norm 8.712485803024e+00 true resid norm 8.712485803017e+00 ||r(i)||/||b|| 2.081619145102e-04
2934 KSP unpreconditioned resid norm 8.712485803004e+00 true resid norm 8.712485802993e+00 ||r(i)||/||b|| 2.081619145096e-04
2935 KSP unpreconditioned resid norm 8.712485802988e+00 true resid norm 8.712485802978e+00 ||r(i)||/||b|| 2.081619145092e-04
2936 KSP unpreconditioned resid norm 8.712485802969e+00 true resid norm 8.712485802957e+00 ||r(i)||/||b|| 2.081619145087e-04
2937 KSP unpreconditioned resid norm 8.712485802938e+00 true resid norm 8.712485802946e+00 ||r(i)||/||b|| 2.081619145084e-04
2938 KSP unpreconditioned resid norm 8.712485802865e+00 true resid norm 8.712485802864e+00 ||r(i)||/||b|| 2.081619145065e-04
2939 KSP unpreconditioned resid norm 8.712485802825e+00 true resid norm 8.712485802816e+00 ||r(i)||/||b|| 2.081619145054e-04
2940 KSP unpreconditioned resid norm 8.712485802811e+00 true resid norm 8.712485802811e+00 ||r(i)||/||b|| 2.081619145052e-04
2941 KSP unpreconditioned resid norm 8.712485802811e+00 true resid norm 8.712485802809e+00 ||r(i)||/||b|| 2.081619145052e-04
2942 KSP unpreconditioned resid norm 8.712485802810e+00 true resid norm 8.712485802812e+00 ||r(i)||/||b|| 2.081619145053e-04
2943 KSP unpreconditioned resid norm 8.712485802810e+00 true resid norm 8.712485802811e+00 ||r(i)||/||b|| 2.081619145052e-04
2944 KSP unpreconditioned resid norm 8.712485802808e+00 true resid norm 8.712485802806e+00 ||r(i)||/||b|| 2.081619145051e-04
2945 KSP unpreconditioned resid norm 8.712485802806e+00 true resid norm 8.712485802809e+00 ||r(i)||/||b|| 2.081619145052e-04
2946 KSP unpreconditioned resid norm 8.712485802805e+00 true resid norm 8.712485802809e+00 ||r(i)||/||b|| 2.081619145052e-04
2947 KSP unpreconditioned resid norm 8.712485802805e+00 true resid norm 8.712485802804e+00 ||r(i)||/||b|| 2.081619145051e-04
2948 KSP unpreconditioned resid norm 8.712485802804e+00 true resid norm 8.712485802804e+00 ||r(i)||/||b|| 2.081619145051e-04
2949 KSP unpreconditioned resid norm 8.712485802802e+00 true resid norm 8.712485802805e+00 ||r(i)||/||b|| 2.081619145051e-04
2950 KSP unpreconditioned resid norm 8.712485802800e+00 true resid norm 8.712485802803e+00 ||r(i)||/||b|| 2.081619145050e-04
2951 KSP unpreconditioned resid norm 8.712485802800e+00 true resid norm 8.712485802805e+00 ||r(i)||/||b|| 2.081619145051e-04
2952 KSP unpreconditioned resid norm 8.712485802800e+00 true resid norm 8.712485802802e+00 ||r(i)||/||b|| 2.081619145050e-04
2953 KSP unpreconditioned resid norm 8.712485802798e+00 true resid norm 8.712485802805e+00 ||r(i)||/||b|| 2.081619145051e-04
2954 KSP unpreconditioned resid norm 8.712485802795e+00 true resid norm 8.712485802788e+00 ||r(i)||/||b|| 2.081619145047e-04
2955 KSP unpreconditioned resid norm 8.712485802791e+00 true resid norm 8.712485802795e+00 ||r(i)||/||b|| 2.081619145048e-04
2956 KSP unpreconditioned resid norm 8.712485802788e+00 true resid norm 8.712485802787e+00 ||r(i)||/||b|| 2.081619145047e-04
2957 KSP unpreconditioned resid norm 8.712485802786e+00 true resid norm 8.712485802793e+00 ||r(i)||/||b|| 2.081619145048e-04
2958 KSP unpreconditioned resid norm 8.712485802783e+00 true resid norm 8.712485802798e+00 ||r(i)||/||b|| 2.081619145049e-04
2959 KSP unpreconditioned resid norm 8.712485802781e+00 true resid norm 8.712485802791e+00 ||r(i)||/||b|| 2.081619145048e-04
2960 KSP unpreconditioned resid norm 8.712485802781e+00 true resid norm 8.712485802792e+00 ||r(i)||/||b|| 2.081619145048e-04
2961 KSP unpreconditioned resid norm 8.712485802781e+00 true resid norm 8.712485802782e+00 ||r(i)||/||b|| 2.081619145045e-04
2962 KSP unpreconditioned resid norm 8.712485802778e+00 true resid norm 8.712485802782e+00 ||r(i)||/||b|| 2.081619145045e-04
2963 KSP unpreconditioned resid norm 8.712485802765e+00 true resid norm 8.712485802767e+00 ||r(i)||/||b|| 2.081619145042e-04
2964 KSP unpreconditioned resid norm 8.712485802747e+00 true resid norm 8.712485802744e+00 ||r(i)||/||b|| 2.081619145036e-04
2965 KSP unpreconditioned resid norm 8.712485802733e+00 true resid norm 8.712485802743e+00 ||r(i)||/||b|| 2.081619145036e-04
2966 KSP unpreconditioned resid norm 8.712485802716e+00 true resid norm 8.712485802722e+00 ||r(i)||/||b|| 2.081619145031e-04
2967 KSP unpreconditioned resid norm 8.712485802689e+00 true resid norm 8.712485802681e+00 ||r(i)||/||b|| 2.081619145021e-04
2968 KSP unpreconditioned resid norm 8.712485802624e+00 true resid norm 8.712485802624e+00 ||r(i)||/||b|| 2.081619145008e-04
2969 KSP unpreconditioned resid norm 8.712485802589e+00 true resid norm 8.712485802589e+00 ||r(i)||/||b|| 2.081619144999e-04
2970 KSP unpreconditioned resid norm 8.712485802593e+00 true resid norm 8.712485802593e+00 ||r(i)||/||b|| 2.081619145000e-04
2971 KSP unpreconditioned resid norm 8.712485802593e+00 true resid norm 8.712485802589e+00 ||r(i)||/||b|| 2.081619144999e-04
2972 KSP unpreconditioned resid norm 8.712485802592e+00 true resid norm 8.712485802593e+00 ||r(i)||/||b|| 2.081619145000e-04
2973 KSP unpreconditioned resid norm 8.712485802592e+00 true resid norm 8.712485802599e+00 ||r(i)||/||b|| 2.081619145002e-04
2974 KSP unpreconditioned resid norm 8.712485802590e+00 true resid norm 8.712485802590e+00 ||r(i)||/||b|| 2.081619145000e-04
2975 KSP unpreconditioned resid norm 8.712485802588e+00 true resid norm 8.712485802582e+00 ||r(i)||/||b|| 2.081619144998e-04
2976 KSP unpreconditioned resid norm 8.712485802588e+00 true resid norm 8.712485802601e+00 ||r(i)||/||b|| 2.081619145002e-04
2977 KSP unpreconditioned resid norm 8.712485802587e+00 true resid norm 8.712485802582e+00 ||r(i)||/||b|| 2.081619144998e-04
2978 KSP unpreconditioned resid norm 8.712485802587e+00 true resid norm 8.712485802590e+00 ||r(i)||/||b|| 2.081619145000e-04
2979 KSP unpreconditioned resid norm 8.712485802585e+00 true resid norm 8.712485802583e+00 ||r(i)||/||b|| 2.081619144998e-04
2980 KSP unpreconditioned resid norm 8.712485802583e+00 true resid norm 8.712485802581e+00 ||r(i)||/||b|| 2.081619144997e-04
2981 KSP unpreconditioned resid norm 8.712485802583e+00 true resid norm 8.712485802575e+00 ||r(i)||/||b|| 2.081619144996e-04
2982 KSP unpreconditioned resid norm 8.712485802583e+00 true resid norm 8.712485802587e+00 ||r(i)||/||b|| 2.081619144999e-04
2983 KSP unpreconditioned resid norm 8.712485802581e+00 true resid norm 8.712485802580e+00 ||r(i)||/||b|| 2.081619144997e-04
2984 KSP unpreconditioned resid norm 8.712485802579e+00 true resid norm 8.712485802574e+00 ||r(i)||/||b|| 2.081619144996e-04
2985 KSP unpreconditioned resid norm 8.712485802575e+00 true resid norm 8.712485802566e+00 ||r(i)||/||b|| 2.081619144994e-04
2986 KSP unpreconditioned resid norm 8.712485802573e+00 true resid norm 8.712485802575e+00 ||r(i)||/||b|| 2.081619144996e-04
2987 KSP unpreconditioned resid norm 8.712485802571e+00 true resid norm 8.712485802579e+00 ||r(i)||/||b|| 2.081619144997e-04
2988 KSP unpreconditioned resid norm 8.712485802568e+00 true resid norm 8.712485802580e+00 ||r(i)||/||b|| 2.081619144997e-04
2989 KSP unpreconditioned resid norm 8.712485802567e+00 true resid norm 8.712485802566e+00 ||r(i)||/||b|| 2.081619144994e-04
2990 KSP unpreconditioned resid norm 8.712485802566e+00 true resid norm 8.712485802576e+00 ||r(i)||/||b|| 2.081619144996e-04
2991 KSP unpreconditioned resid norm 8.712485802566e+00 true resid norm 8.712485802564e+00 ||r(i)||/||b|| 2.081619144993e-04
2992 KSP unpreconditioned resid norm 8.712485802564e+00 true resid norm 8.712485802560e+00 ||r(i)||/||b|| 2.081619144992e-04
2993 KSP unpreconditioned resid norm 8.712485802552e+00 true resid norm 8.712485802554e+00 ||r(i)||/||b|| 2.081619144991e-04
2994 KSP unpreconditioned resid norm 8.712485802536e+00 true resid norm 8.712485802543e+00 ||r(i)||/||b|| 2.081619144988e-04
2995 KSP unpreconditioned resid norm 8.712485802524e+00 true resid norm 8.712485802515e+00 ||r(i)||/||b|| 2.081619144982e-04
2996 KSP unpreconditioned resid norm 8.712485802509e+00 true resid norm 8.712485802505e+00 ||r(i)||/||b|| 2.081619144979e-04
2997 KSP unpreconditioned resid norm 8.712485802485e+00 true resid norm 8.712485802484e+00 ||r(i)||/||b|| 2.081619144974e-04
2998 KSP unpreconditioned resid norm 8.712485802428e+00 true resid norm 8.712485802425e+00 ||r(i)||/||b|| 2.081619144960e-04
2999 KSP unpreconditioned resid norm 8.712485802397e+00 true resid norm 8.712485802387e+00 ||r(i)||/||b|| 2.081619144951e-04
3000 KSP unpreconditioned resid norm 8.712485802396e+00 true resid norm 8.712485802396e+00 ||r(i)||/||b|| 2.081619144953e-04
3001 KSP unpreconditioned resid norm 8.712485802396e+00 true resid norm 8.712485802405e+00 ||r(i)||/||b|| 2.081619144955e-04
3002 KSP unpreconditioned resid norm 8.712485802396e+00 true resid norm 8.712485802387e+00 ||r(i)||/||b|| 2.081619144951e-04
3003 KSP unpreconditioned resid norm 8.712485802396e+00 true resid norm 8.712485802399e+00 ||r(i)||/||b|| 2.081619144954e-04
3004 KSP unpreconditioned resid norm 8.712485802394e+00 true resid norm 8.712485802395e+00 ||r(i)||/||b|| 2.081619144953e-04
3005 KSP unpreconditioned resid norm 8.712485802393e+00 true resid norm 8.712485802390e+00 ||r(i)||/||b|| 2.081619144952e-04
3006 KSP unpreconditioned resid norm 8.712485802392e+00 true resid norm 8.712485802397e+00 ||r(i)||/||b|| 2.081619144953e-04
3007 KSP unpreconditioned resid norm 8.712485802392e+00 true resid norm 8.712485802392e+00 ||r(i)||/||b|| 2.081619144952e-04
3008 KSP unpreconditioned resid norm 8.712485802391e+00 true resid norm 8.712485802388e+00 ||r(i)||/||b|| 2.081619144951e-04
3009 KSP unpreconditioned resid norm 8.712485802390e+00 true resid norm 8.712485802390e+00 ||r(i)||/||b|| 2.081619144952e-04
3010 KSP unpreconditioned resid norm 8.712485802388e+00 true resid norm 8.712485802379e+00 ||r(i)||/||b|| 2.081619144949e-04
3011 KSP unpreconditioned resid norm 8.712485802388e+00 true resid norm 8.712485802383e+00 ||r(i)||/||b|| 2.081619144950e-04
3012 KSP unpreconditioned resid norm 8.712485802388e+00 true resid norm 8.712485802398e+00 ||r(i)||/||b|| 2.081619144954e-04
3013 KSP unpreconditioned resid norm 8.712485802386e+00 true resid norm 8.712485802388e+00 ||r(i)||/||b|| 2.081619144951e-04
3014 KSP unpreconditioned resid norm 8.712485802384e+00 true resid norm 8.712485802382e+00 ||r(i)||/||b|| 2.081619144950e-04
3015 KSP unpreconditioned resid norm 8.712485802381e+00 true resid norm 8.712485802373e+00 ||r(i)||/||b|| 2.081619144948e-04
3016 KSP unpreconditioned resid norm 8.712485802379e+00 true resid norm 8.712485802376e+00 ||r(i)||/||b|| 2.081619144948e-04
3017 KSP unpreconditioned resid norm 8.712485802377e+00 true resid norm 8.712485802369e+00 ||r(i)||/||b|| 2.081619144947e-04
3018 KSP unpreconditioned resid norm 8.712485802375e+00 true resid norm 8.712485802376e+00 ||r(i)||/||b|| 2.081619144948e-04
3019 KSP unpreconditioned resid norm 8.712485802373e+00 true resid norm 8.712485802383e+00 ||r(i)||/||b|| 2.081619144950e-04
3020 KSP unpreconditioned resid norm 8.712485802373e+00 true resid norm 8.712485802368e+00 ||r(i)||/||b|| 2.081619144946e-04
3021 KSP unpreconditioned resid norm 8.712485802373e+00 true resid norm 8.712485802366e+00 ||r(i)||/||b|| 2.081619144946e-04
3022 KSP unpreconditioned resid norm 8.712485802371e+00 true resid norm 8.712485802373e+00 ||r(i)||/||b|| 2.081619144948e-04
3023 KSP unpreconditioned resid norm 8.712485802361e+00 true resid norm 8.712485802360e+00 ||r(i)||/||b|| 2.081619144945e-04
3024 KSP unpreconditioned resid norm 8.712485802347e+00 true resid norm 8.712485802338e+00 ||r(i)||/||b|| 2.081619144939e-04
3025 KSP unpreconditioned resid norm 8.712485802336e+00 true resid norm 8.712485802337e+00 ||r(i)||/||b|| 2.081619144939e-04
3026 KSP unpreconditioned resid norm 8.712485802322e+00 true resid norm 8.712485802316e+00 ||r(i)||/||b|| 2.081619144934e-04
3027 KSP unpreconditioned resid norm 8.712485802301e+00 true resid norm 8.712485802298e+00 ||r(i)||/||b|| 2.081619144930e-04
3028 KSP unpreconditioned resid norm 8.712485802250e+00 true resid norm 8.712485802248e+00 ||r(i)||/||b|| 2.081619144918e-04
3029 KSP unpreconditioned resid norm 8.712485802223e+00 true resid norm 8.712485802217e+00 ||r(i)||/||b|| 2.081619144910e-04
3030 KSP unpreconditioned resid norm 8.712485802225e+00 true resid norm 8.712485802225e+00 ||r(i)||/||b|| 2.081619144912e-04
3031 KSP unpreconditioned resid norm 8.712485802225e+00 true resid norm 8.712485802210e+00 ||r(i)||/||b|| 2.081619144909e-04
3032 KSP unpreconditioned resid norm 8.712485802225e+00 true resid norm 8.712485802214e+00 ||r(i)||/||b|| 2.081619144910e-04
3033 KSP unpreconditioned resid norm 8.712485802224e+00 true resid norm 8.712485802222e+00 ||r(i)||/||b|| 2.081619144911e-04
3034 KSP unpreconditioned resid norm 8.712485802223e+00 true resid norm 8.712485802210e+00 ||r(i)||/||b|| 2.081619144909e-04
3035 KSP unpreconditioned resid norm 8.712485802222e+00 true resid norm 8.712485802213e+00 ||r(i)||/||b|| 2.081619144910e-04
3036 KSP unpreconditioned resid norm 8.712485802221e+00 true resid norm 8.712485802210e+00 ||r(i)||/||b|| 2.081619144909e-04
3037 KSP unpreconditioned resid norm 8.712485802221e+00 true resid norm 8.712485802208e+00 ||r(i)||/||b|| 2.081619144908e-04
3038 KSP unpreconditioned resid norm 8.712485802220e+00 true resid norm 8.712485802218e+00 ||r(i)||/||b|| 2.081619144911e-04
3039 KSP unpreconditioned resid norm 8.712485802219e+00 true resid norm 8.712485802206e+00 ||r(i)||/||b|| 2.081619144908e-04
3040 KSP unpreconditioned resid norm 8.712485802218e+00 true resid norm 8.712485802209e+00 ||r(i)||/||b|| 2.081619144909e-04
3041 KSP unpreconditioned resid norm 8.712485802218e+00 true resid norm 8.712485802206e+00 ||r(i)||/||b|| 2.081619144908e-04
3042 KSP unpreconditioned resid norm 8.712485802218e+00 true resid norm 8.712485802207e+00 ||r(i)||/||b|| 2.081619144908e-04
3043 KSP unpreconditioned resid norm 8.712485802216e+00 true resid norm 8.712485802209e+00 ||r(i)||/||b|| 2.081619144909e-04
3044 KSP unpreconditioned resid norm 8.712485802214e+00 true resid norm 8.712485802214e+00 ||r(i)||/||b|| 2.081619144910e-04
3045 KSP unpreconditioned resid norm 8.712485802211e+00 true resid norm 8.712485802199e+00 ||r(i)||/||b|| 2.081619144906e-04
3046 KSP unpreconditioned resid norm 8.712485802209e+00 true resid norm 8.712485802205e+00 ||r(i)||/||b|| 2.081619144908e-04
3047 KSP unpreconditioned resid norm 8.712485802208e+00 true resid norm 8.712485802203e+00 ||r(i)||/||b|| 2.081619144907e-04
3048 KSP unpreconditioned resid norm 8.712485802206e+00 true resid norm 8.712485802187e+00 ||r(i)||/||b|| 2.081619144903e-04
3049 KSP unpreconditioned resid norm 8.712485802205e+00 true resid norm 8.712485802200e+00 ||r(i)||/||b|| 2.081619144906e-04
3050 KSP unpreconditioned resid norm 8.712485802205e+00 true resid norm 8.712485802194e+00 ||r(i)||/||b|| 2.081619144905e-04
3051 KSP unpreconditioned resid norm 8.712485802204e+00 true resid norm 8.712485802190e+00 ||r(i)||/||b|| 2.081619144904e-04
3052 KSP unpreconditioned resid norm 8.712485802203e+00 true resid norm 8.712485802198e+00 ||r(i)||/||b|| 2.081619144906e-04
3053 KSP unpreconditioned resid norm 8.712485802193e+00 true resid norm 8.712485802191e+00 ||r(i)||/||b|| 2.081619144904e-04
3054 KSP unpreconditioned resid norm 8.712485802181e+00 true resid norm 8.712485802177e+00 ||r(i)||/||b|| 2.081619144901e-04
3055 KSP unpreconditioned resid norm 8.712485802171e+00 true resid norm 8.712485802159e+00 ||r(i)||/||b|| 2.081619144897e-04
3056 KSP unpreconditioned resid norm 8.712485802160e+00 true resid norm 8.712485802136e+00 ||r(i)||/||b|| 2.081619144891e-04
3057 KSP unpreconditioned resid norm 8.712485802141e+00 true resid norm 8.712485802129e+00 ||r(i)||/||b|| 2.081619144889e-04
3058 KSP unpreconditioned resid norm 8.712485802096e+00 true resid norm 8.712485802093e+00 ||r(i)||/||b|| 2.081619144881e-04
3059 KSP unpreconditioned resid norm 8.712485802072e+00 true resid norm 8.712485802065e+00 ||r(i)||/||b|| 2.081619144874e-04
3060 KSP unpreconditioned resid norm 8.712485802051e+00 true resid norm 8.712485802051e+00 ||r(i)||/||b|| 2.081619144871e-04
3061 KSP unpreconditioned resid norm 8.712485802051e+00 true resid norm 8.712485802059e+00 ||r(i)||/||b|| 2.081619144873e-04
3062 KSP unpreconditioned resid norm 8.712485802050e+00 true resid norm 8.712485802071e+00 ||r(i)||/||b|| 2.081619144875e-04
3063 KSP unpreconditioned resid norm 8.712485802050e+00 true resid norm 8.712485802064e+00 ||r(i)||/||b|| 2.081619144874e-04
3064 KSP unpreconditioned resid norm 8.712485802049e+00 true resid norm 8.712485802055e+00 ||r(i)||/||b|| 2.081619144872e-04
3065 KSP unpreconditioned resid norm 8.712485802048e+00 true resid norm 8.712485802061e+00 ||r(i)||/||b|| 2.081619144873e-04
3066 KSP unpreconditioned resid norm 8.712485802047e+00 true resid norm 8.712485802052e+00 ||r(i)||/||b|| 2.081619144871e-04
3067 KSP unpreconditioned resid norm 8.712485802047e+00 true resid norm 8.712485802061e+00 ||r(i)||/||b|| 2.081619144873e-04
3068 KSP unpreconditioned resid norm 8.712485802046e+00 true resid norm 8.712485802048e+00 ||r(i)||/||b|| 2.081619144870e-04
3069 KSP unpreconditioned resid norm 8.712485802045e+00 true resid norm 8.712485802059e+00 ||r(i)||/||b|| 2.081619144873e-04
3070 KSP unpreconditioned resid norm 8.712485802044e+00 true resid norm 8.712485802051e+00 ||r(i)||/||b|| 2.081619144871e-04
3071 KSP unpreconditioned resid norm 8.712485802044e+00 true resid norm 8.712485802054e+00 ||r(i)||/||b|| 2.081619144871e-04
3072 KSP unpreconditioned resid norm 8.712485802044e+00 true resid norm 8.712485802050e+00 ||r(i)||/||b|| 2.081619144870e-04
3073 KSP unpreconditioned resid norm 8.712485802043e+00 true resid norm 8.712485802060e+00 ||r(i)||/||b|| 2.081619144873e-04
3074 KSP unpreconditioned resid norm 8.712485802041e+00 true resid norm 8.712485802061e+00 ||r(i)||/||b|| 2.081619144873e-04
3075 KSP unpreconditioned resid norm 8.712485802038e+00 true resid norm 8.712485802055e+00 ||r(i)||/||b|| 2.081619144872e-04
3076 KSP unpreconditioned resid norm 8.712485802037e+00 true resid norm 8.712485802035e+00 ||r(i)||/||b|| 2.081619144867e-04
3077 KSP unpreconditioned resid norm 8.712485802035e+00 true resid norm 8.712485802039e+00 ||r(i)||/||b|| 2.081619144868e-04
3078 KSP unpreconditioned resid norm 8.712485802034e+00 true resid norm 8.712485802048e+00 ||r(i)||/||b|| 2.081619144870e-04
3079 KSP unpreconditioned resid norm 8.712485802033e+00 true resid norm 8.712485802044e+00 ||r(i)||/||b|| 2.081619144869e-04
3080 KSP unpreconditioned resid norm 8.712485802032e+00 true resid norm 8.712485802040e+00 ||r(i)||/||b|| 2.081619144868e-04
3081 KSP unpreconditioned resid norm 8.712485802032e+00 true resid norm 8.712485802044e+00 ||r(i)||/||b|| 2.081619144869e-04
3082 KSP unpreconditioned resid norm 8.712485802031e+00 true resid norm 8.712485802042e+00 ||r(i)||/||b|| 2.081619144869e-04
3083 KSP unpreconditioned resid norm 8.712485802023e+00 true resid norm 8.712485802036e+00 ||r(i)||/||b|| 2.081619144867e-04
3084 KSP unpreconditioned resid norm 8.712485802012e+00 true resid norm 8.712485802012e+00 ||r(i)||/||b|| 2.081619144861e-04
3085 KSP unpreconditioned resid norm 8.712485802003e+00 true resid norm 8.712485802007e+00 ||r(i)||/||b|| 2.081619144860e-04
3086 KSP unpreconditioned resid norm 8.712485801993e+00 true resid norm 8.712485801995e+00 ||r(i)||/||b|| 2.081619144857e-04
3087 KSP unpreconditioned resid norm 8.712485801976e+00 true resid norm 8.712485801984e+00 ||r(i)||/||b|| 2.081619144855e-04
3088 KSP unpreconditioned resid norm 8.712485801936e+00 true resid norm 8.712485801943e+00 ||r(i)||/||b|| 2.081619144845e-04
3089 KSP unpreconditioned resid norm 8.712485801915e+00 true resid norm 8.712485801928e+00 ||r(i)||/||b|| 2.081619144841e-04
3090 KSP unpreconditioned resid norm 8.712485801932e+00 true resid norm 8.712485801932e+00 ||r(i)||/||b|| 2.081619144842e-04
3091 KSP unpreconditioned resid norm 8.712485801932e+00 true resid norm 8.712485801931e+00 ||r(i)||/||b|| 2.081619144842e-04
3092 KSP unpreconditioned resid norm 8.712485801932e+00 true resid norm 8.712485801927e+00 ||r(i)||/||b|| 2.081619144841e-04
3093 KSP unpreconditioned resid norm 8.712485801932e+00 true resid norm 8.712485801930e+00 ||r(i)||/||b|| 2.081619144842e-04
3094 KSP unpreconditioned resid norm 8.712485801931e+00 true resid norm 8.712485801920e+00 ||r(i)||/||b|| 2.081619144839e-04
3095 KSP unpreconditioned resid norm 8.712485801930e+00 true resid norm 8.712485801928e+00 ||r(i)||/||b|| 2.081619144841e-04
3096 KSP unpreconditioned resid norm 8.712485801930e+00 true resid norm 8.712485801931e+00 ||r(i)||/||b|| 2.081619144842e-04
3097 KSP unpreconditioned resid norm 8.712485801929e+00 true resid norm 8.712485801919e+00 ||r(i)||/||b|| 2.081619144839e-04
3098 KSP unpreconditioned resid norm 8.712485801929e+00 true resid norm 8.712485801923e+00 ||r(i)||/||b|| 2.081619144840e-04
3099 KSP unpreconditioned resid norm 8.712485801928e+00 true resid norm 8.712485801928e+00 ||r(i)||/||b|| 2.081619144841e-04
3100 KSP unpreconditioned resid norm 8.712485801927e+00 true resid norm 8.712485801922e+00 ||r(i)||/||b|| 2.081619144840e-04
3101 KSP unpreconditioned resid norm 8.712485801927e+00 true resid norm 8.712485801923e+00 ||r(i)||/||b|| 2.081619144840e-04
3102 KSP unpreconditioned resid norm 8.712485801927e+00 true resid norm 8.712485801925e+00 ||r(i)||/||b|| 2.081619144841e-04
3103 KSP unpreconditioned resid norm 8.712485801926e+00 true resid norm 8.712485801923e+00 ||r(i)||/||b|| 2.081619144840e-04
3104 KSP unpreconditioned resid norm 8.712485801924e+00 true resid norm 8.712485801918e+00 ||r(i)||/||b|| 2.081619144839e-04
3105 KSP unpreconditioned resid norm 8.712485801922e+00 true resid norm 8.712485801922e+00 ||r(i)||/||b|| 2.081619144840e-04
3106 KSP unpreconditioned resid norm 8.712485801920e+00 true resid norm 8.712485801925e+00 ||r(i)||/||b|| 2.081619144841e-04
3107 KSP unpreconditioned resid norm 8.712485801919e+00 true resid norm 8.712485801923e+00 ||r(i)||/||b|| 2.081619144840e-04
3108 KSP unpreconditioned resid norm 8.712485801918e+00 true resid norm 8.712485801914e+00 ||r(i)||/||b|| 2.081619144838e-04
3109 KSP unpreconditioned resid norm 8.712485801917e+00 true resid norm 8.712485801905e+00 ||r(i)||/||b|| 2.081619144836e-04
3110 KSP unpreconditioned resid norm 8.712485801917e+00 true resid norm 8.712485801906e+00 ||r(i)||/||b|| 2.081619144836e-04
3111 KSP unpreconditioned resid norm 8.712485801916e+00 true resid norm 8.712485801917e+00 ||r(i)||/||b|| 2.081619144839e-04
3112 KSP unpreconditioned resid norm 8.712485801915e+00 true resid norm 8.712485801916e+00 ||r(i)||/||b|| 2.081619144838e-04
3113 KSP unpreconditioned resid norm 8.712485801908e+00 true resid norm 8.712485801905e+00 ||r(i)||/||b|| 2.081619144836e-04
3114 KSP unpreconditioned resid norm 8.712485801898e+00 true resid norm 8.712485801890e+00 ||r(i)||/||b|| 2.081619144832e-04
3115 KSP unpreconditioned resid norm 8.712485801891e+00 true resid norm 8.712485801888e+00 ||r(i)||/||b|| 2.081619144832e-04
3116 KSP unpreconditioned resid norm 8.712485801881e+00 true resid norm 8.712485801877e+00 ||r(i)||/||b|| 2.081619144829e-04
3117 KSP unpreconditioned resid norm 8.712485801867e+00 true resid norm 8.712485801850e+00 ||r(i)||/||b|| 2.081619144823e-04
3118 KSP unpreconditioned resid norm 8.712485801832e+00 true resid norm 8.712485801815e+00 ||r(i)||/||b|| 2.081619144814e-04
3119 KSP unpreconditioned resid norm 8.712485801813e+00 true resid norm 8.712485801807e+00 ||r(i)||/||b|| 2.081619144812e-04
3120 KSP unpreconditioned resid norm 8.712485801813e+00 true resid norm 8.712485801813e+00 ||r(i)||/||b|| 2.081619144814e-04
3121 KSP unpreconditioned resid norm 8.712485801813e+00 true resid norm 8.712485801808e+00 ||r(i)||/||b|| 2.081619144813e-04
3122 KSP unpreconditioned resid norm 8.712485801813e+00 true resid norm 8.712485801820e+00 ||r(i)||/||b|| 2.081619144816e-04
3123 KSP unpreconditioned resid norm 8.712485801813e+00 true resid norm 8.712485801815e+00 ||r(i)||/||b|| 2.081619144814e-04
3124 KSP unpreconditioned resid norm 8.712485801812e+00 true resid norm 8.712485801815e+00 ||r(i)||/||b|| 2.081619144814e-04
3125 KSP unpreconditioned resid norm 8.712485801811e+00 true resid norm 8.712485801813e+00 ||r(i)||/||b|| 2.081619144814e-04
3126 KSP unpreconditioned resid norm 8.712485801811e+00 true resid norm 8.712485801814e+00 ||r(i)||/||b|| 2.081619144814e-04
3127 KSP unpreconditioned resid norm 8.712485801810e+00 true resid norm 8.712485801804e+00 ||r(i)||/||b|| 2.081619144812e-04
3128 KSP unpreconditioned resid norm 8.712485801810e+00 true resid norm 8.712485801805e+00 ||r(i)||/||b|| 2.081619144812e-04
3129 KSP unpreconditioned resid norm 8.712485801809e+00 true resid norm 8.712485801806e+00 ||r(i)||/||b|| 2.081619144812e-04
3130 KSP unpreconditioned resid norm 8.712485801808e+00 true resid norm 8.712485801816e+00 ||r(i)||/||b|| 2.081619144815e-04
3131 KSP unpreconditioned resid norm 8.712485801808e+00 true resid norm 8.712485801798e+00 ||r(i)||/||b|| 2.081619144810e-04
3132 KSP unpreconditioned resid norm 8.712485801808e+00 true resid norm 8.712485801811e+00 ||r(i)||/||b|| 2.081619144813e-04
3133 KSP unpreconditioned resid norm 8.712485801807e+00 true resid norm 8.712485801799e+00 ||r(i)||/||b|| 2.081619144811e-04
3134 KSP unpreconditioned resid norm 8.712485801806e+00 true resid norm 8.712485801809e+00 ||r(i)||/||b|| 2.081619144813e-04
3135 KSP unpreconditioned resid norm 8.712485801804e+00 true resid norm 8.712485801800e+00 ||r(i)||/||b|| 2.081619144811e-04
3136 KSP unpreconditioned resid norm 8.712485801802e+00 true resid norm 8.712485801799e+00 ||r(i)||/||b|| 2.081619144810e-04
3137 KSP unpreconditioned resid norm 8.712485801801e+00 true resid norm 8.712485801793e+00 ||r(i)||/||b|| 2.081619144809e-04
3138 KSP unpreconditioned resid norm 8.712485801800e+00 true resid norm 8.712485801799e+00 ||r(i)||/||b|| 2.081619144811e-04
3139 KSP unpreconditioned resid norm 8.712485801799e+00 true resid norm 8.712485801791e+00 ||r(i)||/||b|| 2.081619144809e-04
3140 KSP unpreconditioned resid norm 8.712485801799e+00 true resid norm 8.712485801795e+00 ||r(i)||/||b|| 2.081619144809e-04
3141 KSP unpreconditioned resid norm 8.712485801799e+00 true resid norm 8.712485801809e+00 ||r(i)||/||b|| 2.081619144813e-04
3142 KSP unpreconditioned resid norm 8.712485801798e+00 true resid norm 8.712485801782e+00 ||r(i)||/||b|| 2.081619144806e-04
3143 KSP unpreconditioned resid norm 8.712485801791e+00 true resid norm 8.712485801785e+00 ||r(i)||/||b|| 2.081619144807e-04
3144 KSP unpreconditioned resid norm 8.712485801783e+00 true resid norm 8.712485801781e+00 ||r(i)||/||b|| 2.081619144806e-04
3145 KSP unpreconditioned resid norm 8.712485801776e+00 true resid norm 8.712485801774e+00 ||r(i)||/||b|| 2.081619144805e-04
3146 KSP unpreconditioned resid norm 8.712485801768e+00 true resid norm 8.712485801771e+00 ||r(i)||/||b|| 2.081619144804e-04
3147 KSP unpreconditioned resid norm 8.712485801755e+00 true resid norm 8.712485801761e+00 ||r(i)||/||b|| 2.081619144801e-04
3148 KSP unpreconditioned resid norm 8.712485801724e+00 true resid norm 8.712485801719e+00 ||r(i)||/||b|| 2.081619144791e-04
3149 KSP unpreconditioned resid norm 8.712485801707e+00 true resid norm 8.712485801710e+00 ||r(i)||/||b|| 2.081619144789e-04
3150 KSP unpreconditioned resid norm 8.712485801708e+00 true resid norm 8.712485801708e+00 ||r(i)||/||b|| 2.081619144789e-04
3151 KSP unpreconditioned resid norm 8.712485801708e+00 true resid norm 8.712485801701e+00 ||r(i)||/||b|| 2.081619144787e-04
3152 KSP unpreconditioned resid norm 8.712485801708e+00 true resid norm 8.712485801710e+00 ||r(i)||/||b|| 2.081619144789e-04
3153 KSP unpreconditioned resid norm 8.712485801708e+00 true resid norm 8.712485801717e+00 ||r(i)||/||b|| 2.081619144791e-04
3154 KSP unpreconditioned resid norm 8.712485801707e+00 true resid norm 8.712485801700e+00 ||r(i)||/||b|| 2.081619144787e-04
3155 KSP unpreconditioned resid norm 8.712485801706e+00 true resid norm 8.712485801702e+00 ||r(i)||/||b|| 2.081619144787e-04
3156 KSP unpreconditioned resid norm 8.712485801706e+00 true resid norm 8.712485801698e+00 ||r(i)||/||b|| 2.081619144786e-04
3157 KSP unpreconditioned resid norm 8.712485801706e+00 true resid norm 8.712485801710e+00 ||r(i)||/||b|| 2.081619144789e-04
3158 KSP unpreconditioned resid norm 8.712485801705e+00 true resid norm 8.712485801696e+00 ||r(i)||/||b|| 2.081619144786e-04
3159 KSP unpreconditioned resid norm 8.712485801704e+00 true resid norm 8.712485801701e+00 ||r(i)||/||b|| 2.081619144787e-04
3160 KSP unpreconditioned resid norm 8.712485801704e+00 true resid norm 8.712485801705e+00 ||r(i)||/||b|| 2.081619144788e-04
3161 KSP unpreconditioned resid norm 8.712485801704e+00 true resid norm 8.712485801691e+00 ||r(i)||/||b|| 2.081619144785e-04
3162 KSP unpreconditioned resid norm 8.712485801704e+00 true resid norm 8.712485801697e+00 ||r(i)||/||b|| 2.081619144786e-04
3163 KSP unpreconditioned resid norm 8.712485801703e+00 true resid norm 8.712485801697e+00 ||r(i)||/||b|| 2.081619144786e-04
3164 KSP unpreconditioned resid norm 8.712485801701e+00 true resid norm 8.712485801693e+00 ||r(i)||/||b|| 2.081619144785e-04
3165 KSP unpreconditioned resid norm 8.712485801700e+00 true resid norm 8.712485801694e+00 ||r(i)||/||b|| 2.081619144785e-04
3166 KSP unpreconditioned resid norm 8.712485801699e+00 true resid norm 8.712485801692e+00 ||r(i)||/||b|| 2.081619144785e-04
3167 KSP unpreconditioned resid norm 8.712485801698e+00 true resid norm 8.712485801691e+00 ||r(i)||/||b|| 2.081619144785e-04
3168 KSP unpreconditioned resid norm 8.712485801697e+00 true resid norm 8.712485801694e+00 ||r(i)||/||b|| 2.081619144786e-04
3169 KSP unpreconditioned resid norm 8.712485801696e+00 true resid norm 8.712485801687e+00 ||r(i)||/||b|| 2.081619144784e-04
3170 KSP unpreconditioned resid norm 8.712485801696e+00 true resid norm 8.712485801691e+00 ||r(i)||/||b|| 2.081619144785e-04
3171 KSP unpreconditioned resid norm 8.712485801695e+00 true resid norm 8.712485801697e+00 ||r(i)||/||b|| 2.081619144786e-04
3172 KSP unpreconditioned resid norm 8.712485801694e+00 true resid norm 8.712485801695e+00 ||r(i)||/||b|| 2.081619144786e-04
3173 KSP unpreconditioned resid norm 8.712485801689e+00 true resid norm 8.712485801696e+00 ||r(i)||/||b|| 2.081619144786e-04
3174 KSP unpreconditioned resid norm 8.712485801681e+00 true resid norm 8.712485801669e+00 ||r(i)||/||b|| 2.081619144780e-04
3175 KSP unpreconditioned resid norm 8.712485801675e+00 true resid norm 8.712485801669e+00 ||r(i)||/||b|| 2.081619144779e-04
3176 KSP unpreconditioned resid norm 8.712485801668e+00 true resid norm 8.712485801667e+00 ||r(i)||/||b|| 2.081619144779e-04
3177 KSP unpreconditioned resid norm 8.712485801657e+00 true resid norm 8.712485801650e+00 ||r(i)||/||b|| 2.081619144775e-04
3178 KSP unpreconditioned resid norm 8.712485801629e+00 true resid norm 8.712485801631e+00 ||r(i)||/||b|| 2.081619144770e-04
3179 KSP unpreconditioned resid norm 8.712485801614e+00 true resid norm 8.712485801611e+00 ||r(i)||/||b|| 2.081619144765e-04
3180 KSP unpreconditioned resid norm 8.712485801608e+00 true resid norm 8.712485801608e+00 ||r(i)||/||b|| 2.081619144765e-04
3181 KSP unpreconditioned resid norm 8.712485801608e+00 true resid norm 8.712485801615e+00 ||r(i)||/||b|| 2.081619144767e-04
3182 KSP unpreconditioned resid norm 8.712485801608e+00 true resid norm 8.712485801614e+00 ||r(i)||/||b|| 2.081619144766e-04
3183 KSP unpreconditioned resid norm 8.712485801608e+00 true resid norm 8.712485801618e+00 ||r(i)||/||b|| 2.081619144767e-04
3184 KSP unpreconditioned resid norm 8.712485801607e+00 true resid norm 8.712485801611e+00 ||r(i)||/||b|| 2.081619144766e-04
3185 KSP unpreconditioned resid norm 8.712485801606e+00 true resid norm 8.712485801612e+00 ||r(i)||/||b|| 2.081619144766e-04
3186 KSP unpreconditioned resid norm 8.712485801606e+00 true resid norm 8.712485801619e+00 ||r(i)||/||b|| 2.081619144768e-04
3187 KSP unpreconditioned resid norm 8.712485801606e+00 true resid norm 8.712485801610e+00 ||r(i)||/||b|| 2.081619144765e-04
3188 KSP unpreconditioned resid norm 8.712485801606e+00 true resid norm 8.712485801616e+00 ||r(i)||/||b|| 2.081619144767e-04
3189 KSP unpreconditioned resid norm 8.712485801605e+00 true resid norm 8.712485801609e+00 ||r(i)||/||b|| 2.081619144765e-04
3190 KSP unpreconditioned resid norm 8.712485801604e+00 true resid norm 8.712485801606e+00 ||r(i)||/||b|| 2.081619144764e-04
3191 KSP unpreconditioned resid norm 8.712485801604e+00 true resid norm 8.712485801610e+00 ||r(i)||/||b|| 2.081619144765e-04
3192 KSP unpreconditioned resid norm 8.712485801604e+00 true resid norm 8.712485801625e+00 ||r(i)||/||b|| 2.081619144769e-04
3193 KSP unpreconditioned resid norm 8.712485801604e+00 true resid norm 8.712485801604e+00 ||r(i)||/||b|| 2.081619144764e-04
3194 KSP unpreconditioned resid norm 8.712485801602e+00 true resid norm 8.712485801604e+00 ||r(i)||/||b|| 2.081619144764e-04
3195 KSP unpreconditioned resid norm 8.712485801601e+00 true resid norm 8.712485801608e+00 ||r(i)||/||b|| 2.081619144765e-04
3196 KSP unpreconditioned resid norm 8.712485801600e+00 true resid norm 8.712485801603e+00 ||r(i)||/||b|| 2.081619144764e-04
3197 KSP unpreconditioned resid norm 8.712485801599e+00 true resid norm 8.712485801613e+00 ||r(i)||/||b|| 2.081619144766e-04
3198 KSP unpreconditioned resid norm 8.712485801598e+00 true resid norm 8.712485801615e+00 ||r(i)||/||b|| 2.081619144767e-04
3199 KSP unpreconditioned resid norm 8.712485801597e+00 true resid norm 8.712485801598e+00 ||r(i)||/||b|| 2.081619144762e-04
3200 KSP unpreconditioned resid norm 8.712485801597e+00 true resid norm 8.712485801616e+00 ||r(i)||/||b|| 2.081619144767e-04
3201 KSP unpreconditioned resid norm 8.712485801597e+00 true resid norm 8.712485801609e+00 ||r(i)||/||b|| 2.081619144765e-04
3202 KSP unpreconditioned resid norm 8.712485801596e+00 true resid norm 8.712485801608e+00 ||r(i)||/||b|| 2.081619144765e-04
3203 KSP unpreconditioned resid norm 8.712485801591e+00 true resid norm 8.712485801598e+00 ||r(i)||/||b|| 2.081619144762e-04
3204 KSP unpreconditioned resid norm 8.712485801584e+00 true resid norm 8.712485801593e+00 ||r(i)||/||b|| 2.081619144761e-04
3205 KSP unpreconditioned resid norm 8.712485801579e+00 true resid norm 8.712485801586e+00 ||r(i)||/||b|| 2.081619144760e-04
3206 KSP unpreconditioned resid norm 8.712485801573e+00 true resid norm 8.712485801582e+00 ||r(i)||/||b|| 2.081619144759e-04
3207 KSP unpreconditioned resid norm 8.712485801563e+00 true resid norm 8.712485801568e+00 ||r(i)||/||b|| 2.081619144755e-04
3208 KSP unpreconditioned resid norm 8.712485801538e+00 true resid norm 8.712485801553e+00 ||r(i)||/||b|| 2.081619144752e-04
3209 KSP unpreconditioned resid norm 8.712485801525e+00 true resid norm 8.712485801542e+00 ||r(i)||/||b|| 2.081619144749e-04
3210 KSP unpreconditioned resid norm 8.712485801533e+00 true resid norm 8.712485801533e+00 ||r(i)||/||b|| 2.081619144747e-04
3211 KSP unpreconditioned resid norm 8.712485801533e+00 true resid norm 8.712485801522e+00 ||r(i)||/||b|| 2.081619144744e-04
3212 KSP unpreconditioned resid norm 8.712485801533e+00 true resid norm 8.712485801531e+00 ||r(i)||/||b|| 2.081619144746e-04
3213 KSP unpreconditioned resid norm 8.712485801533e+00 true resid norm 8.712485801529e+00 ||r(i)||/||b|| 2.081619144746e-04
3214 KSP unpreconditioned resid norm 8.712485801532e+00 true resid norm 8.712485801532e+00 ||r(i)||/||b|| 2.081619144747e-04
3215 KSP unpreconditioned resid norm 8.712485801532e+00 true resid norm 8.712485801535e+00 ||r(i)||/||b|| 2.081619144747e-04
3216 KSP unpreconditioned resid norm 8.712485801532e+00 true resid norm 8.712485801527e+00 ||r(i)||/||b|| 2.081619144745e-04
3217 KSP unpreconditioned resid norm 8.712485801531e+00 true resid norm 8.712485801530e+00 ||r(i)||/||b|| 2.081619144746e-04
3218 KSP unpreconditioned resid norm 8.712485801531e+00 true resid norm 8.712485801526e+00 ||r(i)||/||b|| 2.081619144745e-04
3219 KSP unpreconditioned resid norm 8.712485801530e+00 true resid norm 8.712485801518e+00 ||r(i)||/||b|| 2.081619144743e-04
3220 KSP unpreconditioned resid norm 8.712485801530e+00 true resid norm 8.712485801527e+00 ||r(i)||/||b|| 2.081619144745e-04
3221 KSP unpreconditioned resid norm 8.712485801530e+00 true resid norm 8.712485801526e+00 ||r(i)||/||b|| 2.081619144745e-04
3222 KSP unpreconditioned resid norm 8.712485801530e+00 true resid norm 8.712485801525e+00 ||r(i)||/||b|| 2.081619144745e-04
3223 KSP unpreconditioned resid norm 8.712485801529e+00 true resid norm 8.712485801529e+00 ||r(i)||/||b|| 2.081619144746e-04
3224 KSP unpreconditioned resid norm 8.712485801528e+00 true resid norm 8.712485801526e+00 ||r(i)||/||b|| 2.081619144745e-04
3225 KSP unpreconditioned resid norm 8.712485801527e+00 true resid norm 8.712485801518e+00 ||r(i)||/||b|| 2.081619144743e-04
3226 KSP unpreconditioned resid norm 8.712485801526e+00 true resid norm 8.712485801531e+00 ||r(i)||/||b|| 2.081619144746e-04
3227 KSP unpreconditioned resid norm 8.712485801525e+00 true resid norm 8.712485801523e+00 ||r(i)||/||b|| 2.081619144745e-04
3228 KSP unpreconditioned resid norm 8.712485801524e+00 true resid norm 8.712485801527e+00 ||r(i)||/||b|| 2.081619144746e-04
3229 KSP unpreconditioned resid norm 8.712485801524e+00 true resid norm 8.712485801520e+00 ||r(i)||/||b|| 2.081619144744e-04
3230 KSP unpreconditioned resid norm 8.712485801524e+00 true resid norm 8.712485801526e+00 ||r(i)||/||b|| 2.081619144745e-04
3231 KSP unpreconditioned resid norm 8.712485801523e+00 true resid norm 8.712485801523e+00 ||r(i)||/||b|| 2.081619144744e-04
3232 KSP unpreconditioned resid norm 8.712485801523e+00 true resid norm 8.712485801522e+00 ||r(i)||/||b|| 2.081619144744e-04
3233 KSP unpreconditioned resid norm 8.712485801518e+00 true resid norm 8.712485801515e+00 ||r(i)||/||b|| 2.081619144743e-04
3234 KSP unpreconditioned resid norm 8.712485801512e+00 true resid norm 8.712485801513e+00 ||r(i)||/||b|| 2.081619144742e-04
3235 KSP unpreconditioned resid norm 8.712485801508e+00 true resid norm 8.712485801507e+00 ||r(i)||/||b|| 2.081619144741e-04
3236 KSP unpreconditioned resid norm 8.712485801502e+00 true resid norm 8.712485801493e+00 ||r(i)||/||b|| 2.081619144737e-04
3237 KSP unpreconditioned resid norm 8.712485801493e+00 true resid norm 8.712485801490e+00 ||r(i)||/||b|| 2.081619144737e-04
3238 KSP unpreconditioned resid norm 8.712485801472e+00 true resid norm 8.712485801465e+00 ||r(i)||/||b|| 2.081619144731e-04
3239 KSP unpreconditioned resid norm 8.712485801460e+00 true resid norm 8.712485801458e+00 ||r(i)||/||b|| 2.081619144729e-04
3240 KSP unpreconditioned resid norm 8.712485801454e+00 true resid norm 8.712485801454e+00 ||r(i)||/||b|| 2.081619144728e-04
3241 KSP unpreconditioned resid norm 8.712485801454e+00 true resid norm 8.712485801460e+00 ||r(i)||/||b|| 2.081619144729e-04
3242 KSP unpreconditioned resid norm 8.712485801454e+00 true resid norm 8.712485801464e+00 ||r(i)||/||b|| 2.081619144731e-04
3243 KSP unpreconditioned resid norm 8.712485801453e+00 true resid norm 8.712485801459e+00 ||r(i)||/||b|| 2.081619144729e-04
3244 KSP unpreconditioned resid norm 8.712485801453e+00 true resid norm 8.712485801467e+00 ||r(i)||/||b|| 2.081619144731e-04
3245 KSP unpreconditioned resid norm 8.712485801452e+00 true resid norm 8.712485801452e+00 ||r(i)||/||b|| 2.081619144728e-04
3246 KSP unpreconditioned resid norm 8.712485801452e+00 true resid norm 8.712485801467e+00 ||r(i)||/||b|| 2.081619144731e-04
3247 KSP unpreconditioned resid norm 8.712485801452e+00 true resid norm 8.712485801456e+00 ||r(i)||/||b|| 2.081619144728e-04
3248 KSP unpreconditioned resid norm 8.712485801452e+00 true resid norm 8.712485801456e+00 ||r(i)||/||b|| 2.081619144729e-04
3249 KSP unpreconditioned resid norm 8.712485801451e+00 true resid norm 8.712485801453e+00 ||r(i)||/||b|| 2.081619144728e-04
3250 KSP unpreconditioned resid norm 8.712485801451e+00 true resid norm 8.712485801455e+00 ||r(i)||/||b|| 2.081619144728e-04
3251 KSP unpreconditioned resid norm 8.712485801451e+00 true resid norm 8.712485801448e+00 ||r(i)||/||b|| 2.081619144727e-04
3252 KSP unpreconditioned resid norm 8.712485801451e+00 true resid norm 8.712485801459e+00 ||r(i)||/||b|| 2.081619144729e-04
3253 KSP unpreconditioned resid norm 8.712485801450e+00 true resid norm 8.712485801455e+00 ||r(i)||/||b|| 2.081619144728e-04
3254 KSP unpreconditioned resid norm 8.712485801449e+00 true resid norm 8.712485801453e+00 ||r(i)||/||b|| 2.081619144728e-04
3255 KSP unpreconditioned resid norm 8.712485801448e+00 true resid norm 8.712485801456e+00 ||r(i)||/||b|| 2.081619144729e-04
3256 KSP unpreconditioned resid norm 8.712485801447e+00 true resid norm 8.712485801453e+00 ||r(i)||/||b|| 2.081619144728e-04
3257 KSP unpreconditioned resid norm 8.712485801446e+00 true resid norm 8.712485801448e+00 ||r(i)||/||b|| 2.081619144727e-04
3258 KSP unpreconditioned resid norm 8.712485801446e+00 true resid norm 8.712485801448e+00 ||r(i)||/||b|| 2.081619144727e-04
3259 KSP unpreconditioned resid norm 8.712485801445e+00 true resid norm 8.712485801446e+00 ||r(i)||/||b|| 2.081619144726e-04
3260 KSP unpreconditioned resid norm 8.712485801445e+00 true resid norm 8.712485801457e+00 ||r(i)||/||b|| 2.081619144729e-04
3261 KSP unpreconditioned resid norm 8.712485801445e+00 true resid norm 8.712485801460e+00 ||r(i)||/||b|| 2.081619144730e-04
3262 KSP unpreconditioned resid norm 8.712485801444e+00 true resid norm 8.712485801444e+00 ||r(i)||/||b|| 2.081619144726e-04
3263 KSP unpreconditioned resid norm 8.712485801440e+00 true resid norm 8.712485801442e+00 ||r(i)||/||b|| 2.081619144725e-04
3264 KSP unpreconditioned resid norm 8.712485801435e+00 true resid norm 8.712485801440e+00 ||r(i)||/||b|| 2.081619144725e-04
3265 KSP unpreconditioned resid norm 8.712485801431e+00 true resid norm 8.712485801429e+00 ||r(i)||/||b|| 2.081619144722e-04
3266 KSP unpreconditioned resid norm 8.712485801426e+00 true resid norm 8.712485801429e+00 ||r(i)||/||b|| 2.081619144722e-04
3267 KSP unpreconditioned resid norm 8.712485801418e+00 true resid norm 8.712485801422e+00 ||r(i)||/||b|| 2.081619144721e-04
3268 KSP unpreconditioned resid norm 8.712485801399e+00 true resid norm 8.712485801394e+00 ||r(i)||/||b|| 2.081619144714e-04
3269 KSP unpreconditioned resid norm 8.712485801389e+00 true resid norm 8.712485801395e+00 ||r(i)||/||b|| 2.081619144714e-04
3270 KSP unpreconditioned resid norm 8.712485801391e+00 true resid norm 8.712485801391e+00 ||r(i)||/||b|| 2.081619144713e-04
3271 KSP unpreconditioned resid norm 8.712485801391e+00 true resid norm 8.712485801391e+00 ||r(i)||/||b|| 2.081619144713e-04
3272 KSP unpreconditioned resid norm 8.712485801391e+00 true resid norm 8.712485801397e+00 ||r(i)||/||b|| 2.081619144714e-04
3273 KSP unpreconditioned resid norm 8.712485801390e+00 true resid norm 8.712485801389e+00 ||r(i)||/||b|| 2.081619144713e-04
3274 KSP unpreconditioned resid norm 8.712485801390e+00 true resid norm 8.712485801393e+00 ||r(i)||/||b|| 2.081619144713e-04
3275 KSP unpreconditioned resid norm 8.712485801389e+00 true resid norm 8.712485801392e+00 ||r(i)||/||b|| 2.081619144713e-04
3276 KSP unpreconditioned resid norm 8.712485801389e+00 true resid norm 8.712485801389e+00 ||r(i)||/||b|| 2.081619144713e-04
3277 KSP unpreconditioned resid norm 8.712485801389e+00 true resid norm 8.712485801389e+00 ||r(i)||/||b|| 2.081619144713e-04
3278 KSP unpreconditioned resid norm 8.712485801389e+00 true resid norm 8.712485801392e+00 ||r(i)||/||b|| 2.081619144713e-04
3279 KSP unpreconditioned resid norm 8.712485801388e+00 true resid norm 8.712485801389e+00 ||r(i)||/||b|| 2.081619144713e-04
3280 KSP unpreconditioned resid norm 8.712485801388e+00 true resid norm 8.712485801389e+00 ||r(i)||/||b|| 2.081619144713e-04
3281 KSP unpreconditioned resid norm 8.712485801388e+00 true resid norm 8.712485801392e+00 ||r(i)||/||b|| 2.081619144713e-04
3282 KSP unpreconditioned resid norm 8.712485801388e+00 true resid norm 8.712485801395e+00 ||r(i)||/||b|| 2.081619144714e-04
3283 KSP unpreconditioned resid norm 8.712485801387e+00 true resid norm 8.712485801390e+00 ||r(i)||/||b|| 2.081619144713e-04
3284 KSP unpreconditioned resid norm 8.712485801387e+00 true resid norm 8.712485801387e+00 ||r(i)||/||b|| 2.081619144712e-04
3285 KSP unpreconditioned resid norm 8.712485801386e+00 true resid norm 8.712485801390e+00 ||r(i)||/||b|| 2.081619144713e-04
3286 KSP unpreconditioned resid norm 8.712485801385e+00 true resid norm 8.712485801392e+00 ||r(i)||/||b|| 2.081619144713e-04
3287 KSP unpreconditioned resid norm 8.712485801384e+00 true resid norm 8.712485801389e+00 ||r(i)||/||b|| 2.081619144713e-04
3288 KSP unpreconditioned resid norm 8.712485801384e+00 true resid norm 8.712485801378e+00 ||r(i)||/||b|| 2.081619144710e-04
3289 KSP unpreconditioned resid norm 8.712485801383e+00 true resid norm 8.712485801387e+00 ||r(i)||/||b|| 2.081619144712e-04
3290 KSP unpreconditioned resid norm 8.712485801383e+00 true resid norm 8.712485801387e+00 ||r(i)||/||b|| 2.081619144712e-04
3291 KSP unpreconditioned resid norm 8.712485801383e+00 true resid norm 8.712485801389e+00 ||r(i)||/||b|| 2.081619144713e-04
3292 KSP unpreconditioned resid norm 8.712485801382e+00 true resid norm 8.712485801379e+00 ||r(i)||/||b|| 2.081619144710e-04
3293 KSP unpreconditioned resid norm 8.712485801379e+00 true resid norm 8.712485801378e+00 ||r(i)||/||b|| 2.081619144710e-04
3294 KSP unpreconditioned resid norm 8.712485801374e+00 true resid norm 8.712485801372e+00 ||r(i)||/||b|| 2.081619144709e-04
3295 KSP unpreconditioned resid norm 8.712485801371e+00 true resid norm 8.712485801375e+00 ||r(i)||/||b|| 2.081619144709e-04
3296 KSP unpreconditioned resid norm 8.712485801366e+00 true resid norm 8.712485801372e+00 ||r(i)||/||b|| 2.081619144709e-04
3297 KSP unpreconditioned resid norm 8.712485801359e+00 true resid norm 8.712485801356e+00 ||r(i)||/||b|| 2.081619144705e-04
3298 KSP unpreconditioned resid norm 8.712485801342e+00 true resid norm 8.712485801348e+00 ||r(i)||/||b|| 2.081619144703e-04
3299 KSP unpreconditioned resid norm 8.712485801333e+00 true resid norm 8.712485801328e+00 ||r(i)||/||b|| 2.081619144698e-04
3300 KSP unpreconditioned resid norm 8.712485801334e+00 true resid norm 8.712485801334e+00 ||r(i)||/||b|| 2.081619144699e-04
3301 KSP unpreconditioned resid norm 8.712485801334e+00 true resid norm 8.712485801339e+00 ||r(i)||/||b|| 2.081619144701e-04
3302 KSP unpreconditioned resid norm 8.712485801334e+00 true resid norm 8.712485801336e+00 ||r(i)||/||b|| 2.081619144700e-04
3303 KSP unpreconditioned resid norm 8.712485801334e+00 true resid norm 8.712485801344e+00 ||r(i)||/||b|| 2.081619144702e-04
3304 KSP unpreconditioned resid norm 8.712485801334e+00 true resid norm 8.712485801344e+00 ||r(i)||/||b|| 2.081619144702e-04
3305 KSP unpreconditioned resid norm 8.712485801333e+00 true resid norm 8.712485801341e+00 ||r(i)||/||b|| 2.081619144701e-04
3306 KSP unpreconditioned resid norm 8.712485801333e+00 true resid norm 8.712485801343e+00 ||r(i)||/||b|| 2.081619144702e-04
3307 KSP unpreconditioned resid norm 8.712485801333e+00 true resid norm 8.712485801336e+00 ||r(i)||/||b|| 2.081619144700e-04
3308 KSP unpreconditioned resid norm 8.712485801333e+00 true resid norm 8.712485801340e+00 ||r(i)||/||b|| 2.081619144701e-04
3309 KSP unpreconditioned resid norm 8.712485801332e+00 true resid norm 8.712485801330e+00 ||r(i)||/||b|| 2.081619144699e-04
3310 KSP unpreconditioned resid norm 8.712485801332e+00 true resid norm 8.712485801332e+00 ||r(i)||/||b|| 2.081619144699e-04
3311 KSP unpreconditioned resid norm 8.712485801332e+00 true resid norm 8.712485801346e+00 ||r(i)||/||b|| 2.081619144702e-04
3312 KSP unpreconditioned resid norm 8.712485801332e+00 true resid norm 8.712485801328e+00 ||r(i)||/||b|| 2.081619144698e-04
3313 KSP unpreconditioned resid norm 8.712485801331e+00 true resid norm 8.712485801333e+00 ||r(i)||/||b|| 2.081619144699e-04
3314 KSP unpreconditioned resid norm 8.712485801331e+00 true resid norm 8.712485801332e+00 ||r(i)||/||b|| 2.081619144699e-04
3315 KSP unpreconditioned resid norm 8.712485801330e+00 true resid norm 8.712485801343e+00 ||r(i)||/||b|| 2.081619144702e-04
3316 KSP unpreconditioned resid norm 8.712485801329e+00 true resid norm 8.712485801333e+00 ||r(i)||/||b|| 2.081619144699e-04
3317 KSP unpreconditioned resid norm 8.712485801329e+00 true resid norm 8.712485801333e+00 ||r(i)||/||b|| 2.081619144699e-04
3318 KSP unpreconditioned resid norm 8.712485801328e+00 true resid norm 8.712485801333e+00 ||r(i)||/||b|| 2.081619144699e-04
3319 KSP unpreconditioned resid norm 8.712485801327e+00 true resid norm 8.712485801338e+00 ||r(i)||/||b|| 2.081619144700e-04
3320 KSP unpreconditioned resid norm 8.712485801327e+00 true resid norm 8.712485801325e+00 ||r(i)||/||b|| 2.081619144697e-04
3321 KSP unpreconditioned resid norm 8.712485801327e+00 true resid norm 8.712485801337e+00 ||r(i)||/||b|| 2.081619144700e-04
3322 KSP unpreconditioned resid norm 8.712485801327e+00 true resid norm 8.712485801334e+00 ||r(i)||/||b|| 2.081619144699e-04
3323 KSP unpreconditioned resid norm 8.712485801324e+00 true resid norm 8.712485801314e+00 ||r(i)||/||b|| 2.081619144695e-04
3324 KSP unpreconditioned resid norm 8.712485801320e+00 true resid norm 8.712485801323e+00 ||r(i)||/||b|| 2.081619144697e-04
3325 KSP unpreconditioned resid norm 8.712485801316e+00 true resid norm 8.712485801325e+00 ||r(i)||/||b|| 2.081619144697e-04
3326 KSP unpreconditioned resid norm 8.712485801313e+00 true resid norm 8.712485801321e+00 ||r(i)||/||b|| 2.081619144696e-04
3327 KSP unpreconditioned resid norm 8.712485801306e+00 true resid norm 8.712485801307e+00 ||r(i)||/||b|| 2.081619144693e-04
3328 KSP unpreconditioned resid norm 8.712485801292e+00 true resid norm 8.712485801289e+00 ||r(i)||/||b|| 2.081619144689e-04
3329 KSP unpreconditioned resid norm 8.712485801284e+00 true resid norm 8.712485801283e+00 ||r(i)||/||b|| 2.081619144687e-04
3330 KSP unpreconditioned resid norm 8.712485801285e+00 true resid norm 8.712485801285e+00 ||r(i)||/||b|| 2.081619144688e-04
3331 KSP unpreconditioned resid norm 8.712485801285e+00 true resid norm 8.712485801292e+00 ||r(i)||/||b|| 2.081619144689e-04
3332 KSP unpreconditioned resid norm 8.712485801285e+00 true resid norm 8.712485801293e+00 ||r(i)||/||b|| 2.081619144690e-04
3333 KSP unpreconditioned resid norm 8.712485801284e+00 true resid norm 8.712485801285e+00 ||r(i)||/||b|| 2.081619144688e-04
3334 KSP unpreconditioned resid norm 8.712485801284e+00 true resid norm 8.712485801297e+00 ||r(i)||/||b|| 2.081619144691e-04
3335 KSP unpreconditioned resid norm 8.712485801284e+00 true resid norm 8.712485801277e+00 ||r(i)||/||b|| 2.081619144686e-04
3336 KSP unpreconditioned resid norm 8.712485801284e+00 true resid norm 8.712485801288e+00 ||r(i)||/||b|| 2.081619144688e-04
3337 KSP unpreconditioned resid norm 8.712485801283e+00 true resid norm 8.712485801289e+00 ||r(i)||/||b|| 2.081619144689e-04
3338 KSP unpreconditioned resid norm 8.712485801283e+00 true resid norm 8.712485801284e+00 ||r(i)||/||b|| 2.081619144688e-04
3339 KSP unpreconditioned resid norm 8.712485801283e+00 true resid norm 8.712485801279e+00 ||r(i)||/||b|| 2.081619144686e-04
3340 KSP unpreconditioned resid norm 8.712485801283e+00 true resid norm 8.712485801282e+00 ||r(i)||/||b|| 2.081619144687e-04
3341 KSP unpreconditioned resid norm 8.712485801282e+00 true resid norm 8.712485801276e+00 ||r(i)||/||b|| 2.081619144685e-04
3342 KSP unpreconditioned resid norm 8.712485801282e+00 true resid norm 8.712485801283e+00 ||r(i)||/||b|| 2.081619144687e-04
3343 KSP unpreconditioned resid norm 8.712485801282e+00 true resid norm 8.712485801278e+00 ||r(i)||/||b|| 2.081619144686e-04
3344 KSP unpreconditioned resid norm 8.712485801281e+00 true resid norm 8.712485801283e+00 ||r(i)||/||b|| 2.081619144687e-04
3345 KSP unpreconditioned resid norm 8.712485801281e+00 true resid norm 8.712485801281e+00 ||r(i)||/||b|| 2.081619144687e-04
3346 KSP unpreconditioned resid norm 8.712485801280e+00 true resid norm 8.712485801277e+00 ||r(i)||/||b|| 2.081619144686e-04
3347 KSP unpreconditioned resid norm 8.712485801280e+00 true resid norm 8.712485801283e+00 ||r(i)||/||b|| 2.081619144687e-04
3348 KSP unpreconditioned resid norm 8.712485801279e+00 true resid norm 8.712485801274e+00 ||r(i)||/||b|| 2.081619144685e-04
3349 KSP unpreconditioned resid norm 8.712485801279e+00 true resid norm 8.712485801285e+00 ||r(i)||/||b|| 2.081619144688e-04
3350 KSP unpreconditioned resid norm 8.712485801279e+00 true resid norm 8.712485801279e+00 ||r(i)||/||b|| 2.081619144686e-04
3351 KSP unpreconditioned resid norm 8.712485801279e+00 true resid norm 8.712485801289e+00 ||r(i)||/||b|| 2.081619144689e-04
3352 KSP unpreconditioned resid norm 8.712485801278e+00 true resid norm 8.712485801275e+00 ||r(i)||/||b|| 2.081619144685e-04
3353 KSP unpreconditioned resid norm 8.712485801275e+00 true resid norm 8.712485801270e+00 ||r(i)||/||b|| 2.081619144684e-04
3354 KSP unpreconditioned resid norm 8.712485801272e+00 true resid norm 8.712485801281e+00 ||r(i)||/||b|| 2.081619144687e-04
3355 KSP unpreconditioned resid norm 8.712485801269e+00 true resid norm 8.712485801272e+00 ||r(i)||/||b|| 2.081619144685e-04
3356 KSP unpreconditioned resid norm 8.712485801265e+00 true resid norm 8.712485801261e+00 ||r(i)||/||b|| 2.081619144682e-04
3357 KSP unpreconditioned resid norm 8.712485801260e+00 true resid norm 8.712485801259e+00 ||r(i)||/||b|| 2.081619144682e-04
3358 KSP unpreconditioned resid norm 8.712485801247e+00 true resid norm 8.712485801250e+00 ||r(i)||/||b|| 2.081619144679e-04
3359 KSP unpreconditioned resid norm 8.712485801240e+00 true resid norm 8.712485801250e+00 ||r(i)||/||b|| 2.081619144679e-04
3360 KSP unpreconditioned resid norm 8.712485801241e+00 true resid norm 8.712485801241e+00 ||r(i)||/||b|| 2.081619144677e-04
3361 KSP unpreconditioned resid norm 8.712485801241e+00 true resid norm 8.712485801240e+00 ||r(i)||/||b|| 2.081619144677e-04
3362 KSP unpreconditioned resid norm 8.712485801241e+00 true resid norm 8.712485801235e+00 ||r(i)||/||b|| 2.081619144676e-04
3363 KSP unpreconditioned resid norm 8.712485801241e+00 true resid norm 8.712485801238e+00 ||r(i)||/||b|| 2.081619144676e-04
3364 KSP unpreconditioned resid norm 8.712485801241e+00 true resid norm 8.712485801240e+00 ||r(i)||/||b|| 2.081619144677e-04
3365 KSP unpreconditioned resid norm 8.712485801240e+00 true resid norm 8.712485801240e+00 ||r(i)||/||b|| 2.081619144677e-04
3366 KSP unpreconditioned resid norm 8.712485801240e+00 true resid norm 8.712485801245e+00 ||r(i)||/||b|| 2.081619144678e-04
3367 KSP unpreconditioned resid norm 8.712485801240e+00 true resid norm 8.712485801239e+00 ||r(i)||/||b|| 2.081619144677e-04
3368 KSP unpreconditioned resid norm 8.712485801240e+00 true resid norm 8.712485801242e+00 ||r(i)||/||b|| 2.081619144677e-04
3369 KSP unpreconditioned resid norm 8.712485801240e+00 true resid norm 8.712485801249e+00 ||r(i)||/||b|| 2.081619144679e-04
3370 KSP unpreconditioned resid norm 8.712485801239e+00 true resid norm 8.712485801239e+00 ||r(i)||/||b|| 2.081619144677e-04
3371 KSP unpreconditioned resid norm 8.712485801239e+00 true resid norm 8.712485801246e+00 ||r(i)||/||b|| 2.081619144678e-04
3372 KSP unpreconditioned resid norm 8.712485801239e+00 true resid norm 8.712485801236e+00 ||r(i)||/||b|| 2.081619144676e-04
3373 KSP unpreconditioned resid norm 8.712485801239e+00 true resid norm 8.712485801247e+00 ||r(i)||/||b|| 2.081619144679e-04
3374 KSP unpreconditioned resid norm 8.712485801239e+00 true resid norm 8.712485801241e+00 ||r(i)||/||b|| 2.081619144677e-04
3375 KSP unpreconditioned resid norm 8.712485801238e+00 true resid norm 8.712485801235e+00 ||r(i)||/||b|| 2.081619144676e-04
3376 KSP unpreconditioned resid norm 8.712485801237e+00 true resid norm 8.712485801235e+00 ||r(i)||/||b|| 2.081619144676e-04
3377 KSP unpreconditioned resid norm 8.712485801237e+00 true resid norm 8.712485801225e+00 ||r(i)||/||b|| 2.081619144673e-04
3378 KSP unpreconditioned resid norm 8.712485801236e+00 true resid norm 8.712485801230e+00 ||r(i)||/||b|| 2.081619144675e-04
3379 KSP unpreconditioned resid norm 8.712485801236e+00 true resid norm 8.712485801243e+00 ||r(i)||/||b|| 2.081619144678e-04
3380 KSP unpreconditioned resid norm 8.712485801236e+00 true resid norm 8.712485801232e+00 ||r(i)||/||b|| 2.081619144675e-04
3381 KSP unpreconditioned resid norm 8.712485801236e+00 true resid norm 8.712485801242e+00 ||r(i)||/||b|| 2.081619144677e-04
3382 KSP unpreconditioned resid norm 8.712485801236e+00 true resid norm 8.712485801240e+00 ||r(i)||/||b|| 2.081619144677e-04
3383 KSP unpreconditioned resid norm 8.712485801233e+00 true resid norm 8.712485801237e+00 ||r(i)||/||b|| 2.081619144676e-04
3384 KSP unpreconditioned resid norm 8.712485801230e+00 true resid norm 8.712485801236e+00 ||r(i)||/||b|| 2.081619144676e-04
3385 KSP unpreconditioned resid norm 8.712485801227e+00 true resid norm 8.712485801228e+00 ||r(i)||/||b|| 2.081619144674e-04
3386 KSP unpreconditioned resid norm 8.712485801224e+00 true resid norm 8.712485801222e+00 ||r(i)||/||b|| 2.081619144673e-04
3387 KSP unpreconditioned resid norm 8.712485801220e+00 true resid norm 8.712485801224e+00 ||r(i)||/||b|| 2.081619144673e-04
3388 KSP unpreconditioned resid norm 8.712485801208e+00 true resid norm 8.712485801205e+00 ||r(i)||/||b|| 2.081619144669e-04
3389 KSP unpreconditioned resid norm 8.712485801202e+00 true resid norm 8.712485801200e+00 ||r(i)||/||b|| 2.081619144667e-04
3390 KSP unpreconditioned resid norm 8.712485801202e+00 true resid norm 8.712485801202e+00 ||r(i)||/||b|| 2.081619144668e-04
3391 KSP unpreconditioned resid norm 8.712485801202e+00 true resid norm 8.712485801203e+00 ||r(i)||/||b|| 2.081619144668e-04
3392 KSP unpreconditioned resid norm 8.712485801202e+00 true resid norm 8.712485801213e+00 ||r(i)||/||b|| 2.081619144670e-04
3393 KSP unpreconditioned resid norm 8.712485801202e+00 true resid norm 8.712485801209e+00 ||r(i)||/||b|| 2.081619144669e-04
3394 KSP unpreconditioned resid norm 8.712485801201e+00 true resid norm 8.712485801209e+00 ||r(i)||/||b|| 2.081619144669e-04
3395 KSP unpreconditioned resid norm 8.712485801201e+00 true resid norm 8.712485801208e+00 ||r(i)||/||b|| 2.081619144669e-04
3396 KSP unpreconditioned resid norm 8.712485801201e+00 true resid norm 8.712485801217e+00 ||r(i)||/||b|| 2.081619144671e-04
3397 KSP unpreconditioned resid norm 8.712485801201e+00 true resid norm 8.712485801211e+00 ||r(i)||/||b|| 2.081619144670e-04
3398 KSP unpreconditioned resid norm 8.712485801201e+00 true resid norm 8.712485801202e+00 ||r(i)||/||b|| 2.081619144668e-04
3399 KSP unpreconditioned resid norm 8.712485801200e+00 true resid norm 8.712485801202e+00 ||r(i)||/||b|| 2.081619144668e-04
3400 KSP unpreconditioned resid norm 8.712485801200e+00 true resid norm 8.712485801207e+00 ||r(i)||/||b|| 2.081619144669e-04
3401 KSP unpreconditioned resid norm 8.712485801200e+00 true resid norm 8.712485801201e+00 ||r(i)||/||b|| 2.081619144668e-04
3402 KSP unpreconditioned resid norm 8.712485801200e+00 true resid norm 8.712485801206e+00 ||r(i)||/||b|| 2.081619144669e-04
3403 KSP unpreconditioned resid norm 8.712485801200e+00 true resid norm 8.712485801209e+00 ||r(i)||/||b|| 2.081619144669e-04
3404 KSP unpreconditioned resid norm 8.712485801199e+00 true resid norm 8.712485801199e+00 ||r(i)||/||b|| 2.081619144667e-04
3405 KSP unpreconditioned resid norm 8.712485801199e+00 true resid norm 8.712485801205e+00 ||r(i)||/||b|| 2.081619144668e-04
3406 KSP unpreconditioned resid norm 8.712485801198e+00 true resid norm 8.712485801194e+00 ||r(i)||/||b|| 2.081619144666e-04
3407 KSP unpreconditioned resid norm 8.712485801198e+00 true resid norm 8.712485801207e+00 ||r(i)||/||b|| 2.081619144669e-04
3408 KSP unpreconditioned resid norm 8.712485801197e+00 true resid norm 8.712485801204e+00 ||r(i)||/||b|| 2.081619144668e-04
3409 KSP unpreconditioned resid norm 8.712485801197e+00 true resid norm 8.712485801214e+00 ||r(i)||/||b|| 2.081619144671e-04
3410 KSP unpreconditioned resid norm 8.712485801197e+00 true resid norm 8.712485801194e+00 ||r(i)||/||b|| 2.081619144666e-04
3411 KSP unpreconditioned resid norm 8.712485801197e+00 true resid norm 8.712485801204e+00 ||r(i)||/||b|| 2.081619144668e-04
3412 KSP unpreconditioned resid norm 8.712485801197e+00 true resid norm 8.712485801203e+00 ||r(i)||/||b|| 2.081619144668e-04
3413 KSP unpreconditioned resid norm 8.712485801194e+00 true resid norm 8.712485801192e+00 ||r(i)||/||b|| 2.081619144665e-04
3414 KSP unpreconditioned resid norm 8.712485801192e+00 true resid norm 8.712485801195e+00 ||r(i)||/||b|| 2.081619144666e-04
3415 KSP unpreconditioned resid norm 8.712485801189e+00 true resid norm 8.712485801192e+00 ||r(i)||/||b|| 2.081619144665e-04
3416 KSP unpreconditioned resid norm 8.712485801187e+00 true resid norm 8.712485801190e+00 ||r(i)||/||b|| 2.081619144665e-04
3417 KSP unpreconditioned resid norm 8.712485801182e+00 true resid norm 8.712485801190e+00 ||r(i)||/||b|| 2.081619144665e-04
3418 KSP unpreconditioned resid norm 8.712485801172e+00 true resid norm 8.712485801172e+00 ||r(i)||/||b|| 2.081619144661e-04
3419 KSP unpreconditioned resid norm 8.712485801167e+00 true resid norm 8.712485801166e+00 ||r(i)||/||b|| 2.081619144659e-04
3420 KSP unpreconditioned resid norm 8.712485801176e+00 true resid norm 8.712485801176e+00 ||r(i)||/||b|| 2.081619144662e-04
3421 KSP unpreconditioned resid norm 8.712485801176e+00 true resid norm 8.712485801180e+00 ||r(i)||/||b|| 2.081619144663e-04
3422 KSP unpreconditioned resid norm 8.712485801176e+00 true resid norm 8.712485801184e+00 ||r(i)||/||b|| 2.081619144664e-04
3423 KSP unpreconditioned resid norm 8.712485801176e+00 true resid norm 8.712485801178e+00 ||r(i)||/||b|| 2.081619144662e-04
3424 KSP unpreconditioned resid norm 8.712485801175e+00 true resid norm 8.712485801180e+00 ||r(i)||/||b|| 2.081619144663e-04
3425 KSP unpreconditioned resid norm 8.712485801175e+00 true resid norm 8.712485801180e+00 ||r(i)||/||b|| 2.081619144663e-04
3426 KSP unpreconditioned resid norm 8.712485801175e+00 true resid norm 8.712485801168e+00 ||r(i)||/||b|| 2.081619144660e-04
3427 KSP unpreconditioned resid norm 8.712485801175e+00 true resid norm 8.712485801175e+00 ||r(i)||/||b|| 2.081619144661e-04
3428 KSP unpreconditioned resid norm 8.712485801175e+00 true resid norm 8.712485801175e+00 ||r(i)||/||b|| 2.081619144661e-04
3429 KSP unpreconditioned resid norm 8.712485801175e+00 true resid norm 8.712485801168e+00 ||r(i)||/||b|| 2.081619144660e-04
3430 KSP unpreconditioned resid norm 8.712485801174e+00 true resid norm 8.712485801178e+00 ||r(i)||/||b|| 2.081619144662e-04
3431 KSP unpreconditioned resid norm 8.712485801174e+00 true resid norm 8.712485801185e+00 ||r(i)||/||b|| 2.081619144664e-04
3432 KSP unpreconditioned resid norm 8.712485801174e+00 true resid norm 8.712485801185e+00 ||r(i)||/||b|| 2.081619144664e-04
3433 KSP unpreconditioned resid norm 8.712485801174e+00 true resid norm 8.712485801173e+00 ||r(i)||/||b|| 2.081619144661e-04
3434 KSP unpreconditioned resid norm 8.712485801174e+00 true resid norm 8.712485801178e+00 ||r(i)||/||b|| 2.081619144662e-04
3435 KSP unpreconditioned resid norm 8.712485801173e+00 true resid norm 8.712485801170e+00 ||r(i)||/||b|| 2.081619144660e-04
3436 KSP unpreconditioned resid norm 8.712485801173e+00 true resid norm 8.712485801171e+00 ||r(i)||/||b|| 2.081619144661e-04
3437 KSP unpreconditioned resid norm 8.712485801172e+00 true resid norm 8.712485801177e+00 ||r(i)||/||b|| 2.081619144662e-04
3438 KSP unpreconditioned resid norm 8.712485801172e+00 true resid norm 8.712485801172e+00 ||r(i)||/||b|| 2.081619144661e-04
3439 KSP unpreconditioned resid norm 8.712485801172e+00 true resid norm 8.712485801173e+00 ||r(i)||/||b|| 2.081619144661e-04
3440 KSP unpreconditioned resid norm 8.712485801172e+00 true resid norm 8.712485801183e+00 ||r(i)||/||b|| 2.081619144663e-04
3441 KSP unpreconditioned resid norm 8.712485801172e+00 true resid norm 8.712485801163e+00 ||r(i)||/||b|| 2.081619144659e-04
3442 KSP unpreconditioned resid norm 8.712485801171e+00 true resid norm 8.712485801176e+00 ||r(i)||/||b|| 2.081619144662e-04
3443 KSP unpreconditioned resid norm 8.712485801169e+00 true resid norm 8.712485801172e+00 ||r(i)||/||b|| 2.081619144661e-04
3444 KSP unpreconditioned resid norm 8.712485801167e+00 true resid norm 8.712485801176e+00 ||r(i)||/||b|| 2.081619144662e-04
3445 KSP unpreconditioned resid norm 8.712485801165e+00 true resid norm 8.712485801156e+00 ||r(i)||/||b|| 2.081619144657e-04
3446 KSP unpreconditioned resid norm 8.712485801163e+00 true resid norm 8.712485801158e+00 ||r(i)||/||b|| 2.081619144657e-04
3447 KSP unpreconditioned resid norm 8.712485801159e+00 true resid norm 8.712485801149e+00 ||r(i)||/||b|| 2.081619144655e-04
3448 KSP unpreconditioned resid norm 8.712485801150e+00 true resid norm 8.712485801149e+00 ||r(i)||/||b|| 2.081619144655e-04
3449 KSP unpreconditioned resid norm 8.712485801145e+00 true resid norm 8.712485801151e+00 ||r(i)||/||b|| 2.081619144656e-04
3450 KSP unpreconditioned resid norm 8.712485801155e+00 true resid norm 8.712485801155e+00 ||r(i)||/||b|| 2.081619144657e-04
3451 KSP unpreconditioned resid norm 8.712485801155e+00 true resid norm 8.712485801157e+00 ||r(i)||/||b|| 2.081619144657e-04
3452 KSP unpreconditioned resid norm 8.712485801155e+00 true resid norm 8.712485801145e+00 ||r(i)||/||b|| 2.081619144654e-04
3453 KSP unpreconditioned resid norm 8.712485801155e+00 true resid norm 8.712485801150e+00 ||r(i)||/||b|| 2.081619144656e-04
3454 KSP unpreconditioned resid norm 8.712485801155e+00 true resid norm 8.712485801152e+00 ||r(i)||/||b|| 2.081619144656e-04
3455 KSP unpreconditioned resid norm 8.712485801155e+00 true resid norm 8.712485801155e+00 ||r(i)||/||b|| 2.081619144657e-04
3456 KSP unpreconditioned resid norm 8.712485801155e+00 true resid norm 8.712485801148e+00 ||r(i)||/||b|| 2.081619144655e-04
3457 KSP unpreconditioned resid norm 8.712485801155e+00 true resid norm 8.712485801157e+00 ||r(i)||/||b|| 2.081619144657e-04
3458 KSP unpreconditioned resid norm 8.712485801154e+00 true resid norm 8.712485801147e+00 ||r(i)||/||b|| 2.081619144655e-04
3459 KSP unpreconditioned resid norm 8.712485801154e+00 true resid norm 8.712485801152e+00 ||r(i)||/||b|| 2.081619144656e-04
3460 KSP unpreconditioned resid norm 8.712485801154e+00 true resid norm 8.712485801145e+00 ||r(i)||/||b|| 2.081619144654e-04
3461 KSP unpreconditioned resid norm 8.712485801154e+00 true resid norm 8.712485801144e+00 ||r(i)||/||b|| 2.081619144654e-04
3462 KSP unpreconditioned resid norm 8.712485801154e+00 true resid norm 8.712485801151e+00 ||r(i)||/||b|| 2.081619144656e-04
3463 KSP unpreconditioned resid norm 8.712485801154e+00 true resid norm 8.712485801148e+00 ||r(i)||/||b|| 2.081619144655e-04
3464 KSP unpreconditioned resid norm 8.712485801153e+00 true resid norm 8.712485801144e+00 ||r(i)||/||b|| 2.081619144654e-04
3465 KSP unpreconditioned resid norm 8.712485801153e+00 true resid norm 8.712485801136e+00 ||r(i)||/||b|| 2.081619144652e-04
3466 KSP unpreconditioned resid norm 8.712485801152e+00 true resid norm 8.712485801147e+00 ||r(i)||/||b|| 2.081619144655e-04
3467 KSP unpreconditioned resid norm 8.712485801152e+00 true resid norm 8.712485801140e+00 ||r(i)||/||b|| 2.081619144653e-04
3468 KSP unpreconditioned resid norm 8.712485801152e+00 true resid norm 8.712485801151e+00 ||r(i)||/||b|| 2.081619144656e-04
3469 KSP unpreconditioned resid norm 8.712485801152e+00 true resid norm 8.712485801139e+00 ||r(i)||/||b|| 2.081619144653e-04
3470 KSP unpreconditioned resid norm 8.712485801152e+00 true resid norm 8.712485801145e+00 ||r(i)||/||b|| 2.081619144654e-04
3471 KSP unpreconditioned resid norm 8.712485801152e+00 true resid norm 8.712485801147e+00 ||r(i)||/||b|| 2.081619144655e-04
3472 KSP unpreconditioned resid norm 8.712485801151e+00 true resid norm 8.712485801153e+00 ||r(i)||/||b|| 2.081619144656e-04
3473 KSP unpreconditioned resid norm 8.712485801150e+00 true resid norm 8.712485801151e+00 ||r(i)||/||b|| 2.081619144656e-04
3474 KSP unpreconditioned resid norm 8.712485801147e+00 true resid norm 8.712485801145e+00 ||r(i)||/||b|| 2.081619144654e-04
3475 KSP unpreconditioned resid norm 8.712485801146e+00 true resid norm 8.712485801142e+00 ||r(i)||/||b|| 2.081619144654e-04
3476 KSP unpreconditioned resid norm 8.712485801144e+00 true resid norm 8.712485801146e+00 ||r(i)||/||b|| 2.081619144654e-04
3477 KSP unpreconditioned resid norm 8.712485801140e+00 true resid norm 8.712485801138e+00 ||r(i)||/||b|| 2.081619144653e-04
3478 KSP unpreconditioned resid norm 8.712485801132e+00 true resid norm 8.712485801136e+00 ||r(i)||/||b|| 2.081619144652e-04
3479 KSP unpreconditioned resid norm 8.712485801128e+00 true resid norm 8.712485801123e+00 ||r(i)||/||b|| 2.081619144649e-04
3480 KSP unpreconditioned resid norm 8.712485801127e+00 true resid norm 8.712485801127e+00 ||r(i)||/||b|| 2.081619144650e-04
3481 KSP unpreconditioned resid norm 8.712485801127e+00 true resid norm 8.712485801137e+00 ||r(i)||/||b|| 2.081619144652e-04
3482 KSP unpreconditioned resid norm 8.712485801127e+00 true resid norm 8.712485801126e+00 ||r(i)||/||b|| 2.081619144650e-04
3483 KSP unpreconditioned resid norm 8.712485801127e+00 true resid norm 8.712485801123e+00 ||r(i)||/||b|| 2.081619144649e-04
3484 KSP unpreconditioned resid norm 8.712485801127e+00 true resid norm 8.712485801135e+00 ||r(i)||/||b|| 2.081619144652e-04
3485 KSP unpreconditioned resid norm 8.712485801126e+00 true resid norm 8.712485801133e+00 ||r(i)||/||b|| 2.081619144651e-04
3486 KSP unpreconditioned resid norm 8.712485801126e+00 true resid norm 8.712485801124e+00 ||r(i)||/||b|| 2.081619144649e-04
3487 KSP unpreconditioned resid norm 8.712485801126e+00 true resid norm 8.712485801134e+00 ||r(i)||/||b|| 2.081619144652e-04
3488 KSP unpreconditioned resid norm 8.712485801126e+00 true resid norm 8.712485801129e+00 ||r(i)||/||b|| 2.081619144651e-04
3489 KSP unpreconditioned resid norm 8.712485801126e+00 true resid norm 8.712485801130e+00 ||r(i)||/||b|| 2.081619144651e-04
3490 KSP unpreconditioned resid norm 8.712485801126e+00 true resid norm 8.712485801121e+00 ||r(i)||/||b|| 2.081619144649e-04
3491 KSP unpreconditioned resid norm 8.712485801126e+00 true resid norm 8.712485801136e+00 ||r(i)||/||b|| 2.081619144652e-04
3492 KSP unpreconditioned resid norm 8.712485801126e+00 true resid norm 8.712485801126e+00 ||r(i)||/||b|| 2.081619144650e-04
3493 KSP unpreconditioned resid norm 8.712485801126e+00 true resid norm 8.712485801121e+00 ||r(i)||/||b|| 2.081619144649e-04
3494 KSP unpreconditioned resid norm 8.712485801125e+00 true resid norm 8.712485801135e+00 ||r(i)||/||b|| 2.081619144652e-04
3495 KSP unpreconditioned resid norm 8.712485801125e+00 true resid norm 8.712485801126e+00 ||r(i)||/||b|| 2.081619144650e-04
3496 KSP unpreconditioned resid norm 8.712485801125e+00 true resid norm 8.712485801126e+00 ||r(i)||/||b|| 2.081619144650e-04
3497 KSP unpreconditioned resid norm 8.712485801124e+00 true resid norm 8.712485801120e+00 ||r(i)||/||b|| 2.081619144648e-04
3498 KSP unpreconditioned resid norm 8.712485801124e+00 true resid norm 8.712485801126e+00 ||r(i)||/||b|| 2.081619144650e-04
3499 KSP unpreconditioned resid norm 8.712485801124e+00 true resid norm 8.712485801130e+00 ||r(i)||/||b|| 2.081619144651e-04
3500 KSP unpreconditioned resid norm 8.712485801124e+00 true resid norm 8.712485801120e+00 ||r(i)||/||b|| 2.081619144648e-04
3501 KSP unpreconditioned resid norm 8.712485801124e+00 true resid norm 8.712485801122e+00 ||r(i)||/||b|| 2.081619144649e-04
3502 KSP unpreconditioned resid norm 8.712485801123e+00 true resid norm 8.712485801121e+00 ||r(i)||/||b|| 2.081619144648e-04
3503 KSP unpreconditioned resid norm 8.712485801122e+00 true resid norm 8.712485801123e+00 ||r(i)||/||b|| 2.081619144649e-04
3504 KSP unpreconditioned resid norm 8.712485801120e+00 true resid norm 8.712485801120e+00 ||r(i)||/||b|| 2.081619144648e-04
3505 KSP unpreconditioned resid norm 8.712485801119e+00 true resid norm 8.712485801124e+00 ||r(i)||/||b|| 2.081619144649e-04
3506 KSP unpreconditioned resid norm 8.712485801117e+00 true resid norm 8.712485801111e+00 ||r(i)||/||b|| 2.081619144646e-04
3507 KSP unpreconditioned resid norm 8.712485801114e+00 true resid norm 8.712485801119e+00 ||r(i)||/||b|| 2.081619144648e-04
3508 KSP unpreconditioned resid norm 8.712485801107e+00 true resid norm 8.712485801121e+00 ||r(i)||/||b|| 2.081619144649e-04
3509 KSP unpreconditioned resid norm 8.712485801103e+00 true resid norm 8.712485801120e+00 ||r(i)||/||b|| 2.081619144648e-04
3510 KSP unpreconditioned resid norm 8.712485801105e+00 true resid norm 8.712485801105e+00 ||r(i)||/||b|| 2.081619144645e-04
3511 KSP unpreconditioned resid norm 8.712485801105e+00 true resid norm 8.712485801102e+00 ||r(i)||/||b|| 2.081619144644e-04
3512 KSP unpreconditioned resid norm 8.712485801105e+00 true resid norm 8.712485801105e+00 ||r(i)||/||b|| 2.081619144645e-04
3513 KSP unpreconditioned resid norm 8.712485801105e+00 true resid norm 8.712485801106e+00 ||r(i)||/||b|| 2.081619144645e-04
3514 KSP unpreconditioned resid norm 8.712485801105e+00 true resid norm 8.712485801110e+00 ||r(i)||/||b|| 2.081619144646e-04
3515 KSP unpreconditioned resid norm 8.712485801105e+00 true resid norm 8.712485801109e+00 ||r(i)||/||b|| 2.081619144646e-04
3516 KSP unpreconditioned resid norm 8.712485801105e+00 true resid norm 8.712485801111e+00 ||r(i)||/||b|| 2.081619144646e-04
3517 KSP unpreconditioned resid norm 8.712485801105e+00 true resid norm 8.712485801105e+00 ||r(i)||/||b|| 2.081619144645e-04
3518 KSP unpreconditioned resid norm 8.712485801104e+00 true resid norm 8.712485801095e+00 ||r(i)||/||b|| 2.081619144642e-04
3519 KSP unpreconditioned resid norm 8.712485801104e+00 true resid norm 8.712485801103e+00 ||r(i)||/||b|| 2.081619144644e-04
3520 KSP unpreconditioned resid norm 8.712485801104e+00 true resid norm 8.712485801099e+00 ||r(i)||/||b|| 2.081619144643e-04
3521 KSP unpreconditioned resid norm 8.712485801104e+00 true resid norm 8.712485801101e+00 ||r(i)||/||b|| 2.081619144644e-04
3522 KSP unpreconditioned resid norm 8.712485801104e+00 true resid norm 8.712485801105e+00 ||r(i)||/||b|| 2.081619144645e-04
3523 KSP unpreconditioned resid norm 8.712485801104e+00 true resid norm 8.712485801114e+00 ||r(i)||/||b|| 2.081619144647e-04
3524 KSP unpreconditioned resid norm 8.712485801104e+00 true resid norm 8.712485801107e+00 ||r(i)||/||b|| 2.081619144645e-04
3525 KSP unpreconditioned resid norm 8.712485801103e+00 true resid norm 8.712485801102e+00 ||r(i)||/||b|| 2.081619144644e-04
3526 KSP unpreconditioned resid norm 8.712485801103e+00 true resid norm 8.712485801112e+00 ||r(i)||/||b|| 2.081619144646e-04
3527 KSP unpreconditioned resid norm 8.712485801103e+00 true resid norm 8.712485801107e+00 ||r(i)||/||b|| 2.081619144645e-04
3528 KSP unpreconditioned resid norm 8.712485801102e+00 true resid norm 8.712485801105e+00 ||r(i)||/||b|| 2.081619144645e-04
3529 KSP unpreconditioned resid norm 8.712485801102e+00 true resid norm 8.712485801104e+00 ||r(i)||/||b|| 2.081619144644e-04
3530 KSP unpreconditioned resid norm 8.712485801102e+00 true resid norm 8.712485801105e+00 ||r(i)||/||b|| 2.081619144645e-04
3531 KSP unpreconditioned resid norm 8.712485801102e+00 true resid norm 8.712485801104e+00 ||r(i)||/||b|| 2.081619144644e-04
3532 KSP unpreconditioned resid norm 8.712485801102e+00 true resid norm 8.712485801108e+00 ||r(i)||/||b|| 2.081619144645e-04
3533 KSP unpreconditioned resid norm 8.712485801101e+00 true resid norm 8.712485801103e+00 ||r(i)||/||b|| 2.081619144644e-04
3534 KSP unpreconditioned resid norm 8.712485801099e+00 true resid norm 8.712485801097e+00 ||r(i)||/||b|| 2.081619144643e-04
3535 KSP unpreconditioned resid norm 8.712485801098e+00 true resid norm 8.712485801097e+00 ||r(i)||/||b|| 2.081619144643e-04
3536 KSP unpreconditioned resid norm 8.712485801096e+00 true resid norm 8.712485801101e+00 ||r(i)||/||b|| 2.081619144644e-04
3537 KSP unpreconditioned resid norm 8.712485801093e+00 true resid norm 8.712485801096e+00 ||r(i)||/||b|| 2.081619144642e-04
3538 KSP unpreconditioned resid norm 8.712485801087e+00 true resid norm 8.712485801089e+00 ||r(i)||/||b|| 2.081619144641e-04
3539 KSP unpreconditioned resid norm 8.712485801084e+00 true resid norm 8.712485801090e+00 ||r(i)||/||b|| 2.081619144641e-04
3540 KSP unpreconditioned resid norm 8.712485801086e+00 true resid norm 8.712485801086e+00 ||r(i)||/||b|| 2.081619144640e-04
3541 KSP unpreconditioned resid norm 8.712485801086e+00 true resid norm 8.712485801083e+00 ||r(i)||/||b|| 2.081619144639e-04
3542 KSP unpreconditioned resid norm 8.712485801086e+00 true resid norm 8.712485801093e+00 ||r(i)||/||b|| 2.081619144642e-04
3543 KSP unpreconditioned resid norm 8.712485801086e+00 true resid norm 8.712485801095e+00 ||r(i)||/||b|| 2.081619144642e-04
3544 KSP unpreconditioned resid norm 8.712485801086e+00 true resid norm 8.712485801090e+00 ||r(i)||/||b|| 2.081619144641e-04
3545 KSP unpreconditioned resid norm 8.712485801086e+00 true resid norm 8.712485801082e+00 ||r(i)||/||b|| 2.081619144639e-04
3546 KSP unpreconditioned resid norm 8.712485801085e+00 true resid norm 8.712485801093e+00 ||r(i)||/||b|| 2.081619144642e-04
3547 KSP unpreconditioned resid norm 8.712485801085e+00 true resid norm 8.712485801089e+00 ||r(i)||/||b|| 2.081619144641e-04
3548 KSP unpreconditioned resid norm 8.712485801085e+00 true resid norm 8.712485801083e+00 ||r(i)||/||b|| 2.081619144639e-04
3549 KSP unpreconditioned resid norm 8.712485801085e+00 true resid norm 8.712485801084e+00 ||r(i)||/||b|| 2.081619144640e-04
3550 KSP unpreconditioned resid norm 8.712485801085e+00 true resid norm 8.712485801095e+00 ||r(i)||/||b|| 2.081619144642e-04
3551 KSP unpreconditioned resid norm 8.712485801085e+00 true resid norm 8.712485801081e+00 ||r(i)||/||b|| 2.081619144639e-04
3552 KSP unpreconditioned resid norm 8.712485801085e+00 true resid norm 8.712485801082e+00 ||r(i)||/||b|| 2.081619144639e-04
3553 KSP unpreconditioned resid norm 8.712485801085e+00 true resid norm 8.712485801093e+00 ||r(i)||/||b|| 2.081619144642e-04
3554 KSP unpreconditioned resid norm 8.712485801085e+00 true resid norm 8.712485801087e+00 ||r(i)||/||b|| 2.081619144641e-04
3555 KSP unpreconditioned resid norm 8.712485801084e+00 true resid norm 8.712485801099e+00 ||r(i)||/||b|| 2.081619144643e-04
3556 KSP unpreconditioned resid norm 8.712485801084e+00 true resid norm 8.712485801076e+00 ||r(i)||/||b|| 2.081619144638e-04
3557 KSP unpreconditioned resid norm 8.712485801084e+00 true resid norm 8.712485801092e+00 ||r(i)||/||b|| 2.081619144642e-04
3558 KSP unpreconditioned resid norm 8.712485801084e+00 true resid norm 8.712485801078e+00 ||r(i)||/||b|| 2.081619144638e-04
3559 KSP unpreconditioned resid norm 8.712485801083e+00 true resid norm 8.712485801087e+00 ||r(i)||/||b|| 2.081619144640e-04
3560 KSP unpreconditioned resid norm 8.712485801083e+00 true resid norm 8.712485801082e+00 ||r(i)||/||b|| 2.081619144639e-04
3561 KSP unpreconditioned resid norm 8.712485801083e+00 true resid norm 8.712485801088e+00 ||r(i)||/||b|| 2.081619144641e-04
3562 KSP unpreconditioned resid norm 8.712485801083e+00 true resid norm 8.712485801087e+00 ||r(i)||/||b|| 2.081619144640e-04
3563 KSP unpreconditioned resid norm 8.712485801082e+00 true resid norm 8.712485801085e+00 ||r(i)||/||b|| 2.081619144640e-04
3564 KSP unpreconditioned resid norm 8.712485801080e+00 true resid norm 8.712485801078e+00 ||r(i)||/||b|| 2.081619144638e-04
3565 KSP unpreconditioned resid norm 8.712485801079e+00 true resid norm 8.712485801078e+00 ||r(i)||/||b|| 2.081619144638e-04
3566 KSP unpreconditioned resid norm 8.712485801078e+00 true resid norm 8.712485801085e+00 ||r(i)||/||b|| 2.081619144640e-04
3567 KSP unpreconditioned resid norm 8.712485801076e+00 true resid norm 8.712485801074e+00 ||r(i)||/||b|| 2.081619144637e-04
3568 KSP unpreconditioned resid norm 8.712485801070e+00 true resid norm 8.712485801080e+00 ||r(i)||/||b|| 2.081619144639e-04
3569 KSP unpreconditioned resid norm 8.712485801067e+00 true resid norm 8.712485801074e+00 ||r(i)||/||b|| 2.081619144637e-04
3570 KSP unpreconditioned resid norm 8.712485801066e+00 true resid norm 8.712485801066e+00 ||r(i)||/||b|| 2.081619144635e-04
3571 KSP unpreconditioned resid norm 8.712485801066e+00 true resid norm 8.712485801075e+00 ||r(i)||/||b|| 2.081619144638e-04
3572 KSP unpreconditioned resid norm 8.712485801066e+00 true resid norm 8.712485801070e+00 ||r(i)||/||b|| 2.081619144636e-04
3573 KSP unpreconditioned resid norm 8.712485801066e+00 true resid norm 8.712485801078e+00 ||r(i)||/||b|| 2.081619144638e-04
3574 KSP unpreconditioned resid norm 8.712485801066e+00 true resid norm 8.712485801063e+00 ||r(i)||/||b|| 2.081619144635e-04
3575 KSP unpreconditioned resid norm 8.712485801066e+00 true resid norm 8.712485801074e+00 ||r(i)||/||b|| 2.081619144637e-04
3576 KSP unpreconditioned resid norm 8.712485801066e+00 true resid norm 8.712485801068e+00 ||r(i)||/||b|| 2.081619144636e-04
3577 KSP unpreconditioned resid norm 8.712485801066e+00 true resid norm 8.712485801063e+00 ||r(i)||/||b|| 2.081619144635e-04
3578 KSP unpreconditioned resid norm 8.712485801066e+00 true resid norm 8.712485801074e+00 ||r(i)||/||b|| 2.081619144637e-04
3579 KSP unpreconditioned resid norm 8.712485801066e+00 true resid norm 8.712485801068e+00 ||r(i)||/||b|| 2.081619144636e-04
3580 KSP unpreconditioned resid norm 8.712485801065e+00 true resid norm 8.712485801064e+00 ||r(i)||/||b|| 2.081619144635e-04
3581 KSP unpreconditioned resid norm 8.712485801065e+00 true resid norm 8.712485801070e+00 ||r(i)||/||b|| 2.081619144636e-04
3582 KSP unpreconditioned resid norm 8.712485801065e+00 true resid norm 8.712485801076e+00 ||r(i)||/||b|| 2.081619144638e-04
3583 KSP unpreconditioned resid norm 8.712485801065e+00 true resid norm 8.712485801064e+00 ||r(i)||/||b|| 2.081619144635e-04
3584 KSP unpreconditioned resid norm 8.712485801065e+00 true resid norm 8.712485801074e+00 ||r(i)||/||b|| 2.081619144637e-04
3585 KSP unpreconditioned resid norm 8.712485801065e+00 true resid norm 8.712485801068e+00 ||r(i)||/||b|| 2.081619144636e-04
3586 KSP unpreconditioned resid norm 8.712485801064e+00 true resid norm 8.712485801064e+00 ||r(i)||/||b|| 2.081619144635e-04
3587 KSP unpreconditioned resid norm 8.712485801064e+00 true resid norm 8.712485801068e+00 ||r(i)||/||b|| 2.081619144636e-04
3588 KSP unpreconditioned resid norm 8.712485801064e+00 true resid norm 8.712485801062e+00 ||r(i)||/||b|| 2.081619144635e-04
3589 KSP unpreconditioned resid norm 8.712485801064e+00 true resid norm 8.712485801068e+00 ||r(i)||/||b|| 2.081619144636e-04
3590 KSP unpreconditioned resid norm 8.712485801064e+00 true resid norm 8.712485801058e+00 ||r(i)||/||b|| 2.081619144634e-04
3591 KSP unpreconditioned resid norm 8.712485801064e+00 true resid norm 8.712485801064e+00 ||r(i)||/||b|| 2.081619144635e-04
3592 KSP unpreconditioned resid norm 8.712485801064e+00 true resid norm 8.712485801063e+00 ||r(i)||/||b|| 2.081619144635e-04
3593 KSP unpreconditioned resid norm 8.712485801063e+00 true resid norm 8.712485801062e+00 ||r(i)||/||b|| 2.081619144634e-04
3594 KSP unpreconditioned resid norm 8.712485801061e+00 true resid norm 8.712485801064e+00 ||r(i)||/||b|| 2.081619144635e-04
3595 KSP unpreconditioned resid norm 8.712485801060e+00 true resid norm 8.712485801076e+00 ||r(i)||/||b|| 2.081619144638e-04
3596 KSP unpreconditioned resid norm 8.712485801059e+00 true resid norm 8.712485801064e+00 ||r(i)||/||b|| 2.081619144635e-04
3597 KSP unpreconditioned resid norm 8.712485801057e+00 true resid norm 8.712485801061e+00 ||r(i)||/||b|| 2.081619144634e-04
3598 KSP unpreconditioned resid norm 8.712485801052e+00 true resid norm 8.712485801044e+00 ||r(i)||/||b|| 2.081619144630e-04
3599 KSP unpreconditioned resid norm 8.712485801049e+00 true resid norm 8.712485801041e+00 ||r(i)||/||b|| 2.081619144629e-04
3600 KSP unpreconditioned resid norm 8.712485801048e+00 true resid norm 8.712485801048e+00 ||r(i)||/||b|| 2.081619144631e-04
3601 KSP unpreconditioned resid norm 8.712485801048e+00 true resid norm 8.712485801051e+00 ||r(i)||/||b|| 2.081619144632e-04
3602 KSP unpreconditioned resid norm 8.712485801048e+00 true resid norm 8.712485801051e+00 ||r(i)||/||b|| 2.081619144632e-04
3603 KSP unpreconditioned resid norm 8.712485801048e+00 true resid norm 8.712485801041e+00 ||r(i)||/||b|| 2.081619144629e-04
3604 KSP unpreconditioned resid norm 8.712485801048e+00 true resid norm 8.712485801055e+00 ||r(i)||/||b|| 2.081619144633e-04
3605 KSP unpreconditioned resid norm 8.712485801048e+00 true resid norm 8.712485801060e+00 ||r(i)||/||b|| 2.081619144634e-04
3606 KSP unpreconditioned resid norm 8.712485801048e+00 true resid norm 8.712485801042e+00 ||r(i)||/||b|| 2.081619144630e-04
3607 KSP unpreconditioned resid norm 8.712485801048e+00 true resid norm 8.712485801061e+00 ||r(i)||/||b|| 2.081619144634e-04
3608 KSP unpreconditioned resid norm 8.712485801048e+00 true resid norm 8.712485801057e+00 ||r(i)||/||b|| 2.081619144633e-04
3609 KSP unpreconditioned resid norm 8.712485801048e+00 true resid norm 8.712485801050e+00 ||r(i)||/||b|| 2.081619144631e-04
3610 KSP unpreconditioned resid norm 8.712485801048e+00 true resid norm 8.712485801053e+00 ||r(i)||/||b|| 2.081619144632e-04
3611 KSP unpreconditioned resid norm 8.712485801048e+00 true resid norm 8.712485801049e+00 ||r(i)||/||b|| 2.081619144631e-04
3612 KSP unpreconditioned resid norm 8.712485801048e+00 true resid norm 8.712485801060e+00 ||r(i)||/||b|| 2.081619144634e-04
3613 KSP unpreconditioned resid norm 8.712485801048e+00 true resid norm 8.712485801054e+00 ||r(i)||/||b|| 2.081619144632e-04
3614 KSP unpreconditioned resid norm 8.712485801047e+00 true resid norm 8.712485801058e+00 ||r(i)||/||b|| 2.081619144633e-04
3615 KSP unpreconditioned resid norm 8.712485801047e+00 true resid norm 8.712485801050e+00 ||r(i)||/||b|| 2.081619144631e-04
3616 KSP unpreconditioned resid norm 8.712485801047e+00 true resid norm 8.712485801057e+00 ||r(i)||/||b|| 2.081619144633e-04
3617 KSP unpreconditioned resid norm 8.712485801047e+00 true resid norm 8.712485801055e+00 ||r(i)||/||b|| 2.081619144633e-04
3618 KSP unpreconditioned resid norm 8.712485801047e+00 true resid norm 8.712485801057e+00 ||r(i)||/||b|| 2.081619144633e-04
3619 KSP unpreconditioned resid norm 8.712485801046e+00 true resid norm 8.712485801053e+00 ||r(i)||/||b|| 2.081619144632e-04
3620 KSP unpreconditioned resid norm 8.712485801046e+00 true resid norm 8.712485801053e+00 ||r(i)||/||b|| 2.081619144632e-04
3621 KSP unpreconditioned resid norm 8.712485801046e+00 true resid norm 8.712485801054e+00 ||r(i)||/||b|| 2.081619144632e-04
3622 KSP unpreconditioned resid norm 8.712485801046e+00 true resid norm 8.712485801049e+00 ||r(i)||/||b|| 2.081619144631e-04
3623 KSP unpreconditioned resid norm 8.712485801045e+00 true resid norm 8.712485801041e+00 ||r(i)||/||b|| 2.081619144629e-04
3624 KSP unpreconditioned resid norm 8.712485801044e+00 true resid norm 8.712485801047e+00 ||r(i)||/||b|| 2.081619144631e-04
3625 KSP unpreconditioned resid norm 8.712485801043e+00 true resid norm 8.712485801057e+00 ||r(i)||/||b|| 2.081619144633e-04
3626 KSP unpreconditioned resid norm 8.712485801042e+00 true resid norm 8.712485801036e+00 ||r(i)||/||b|| 2.081619144628e-04
3627 KSP unpreconditioned resid norm 8.712485801040e+00 true resid norm 8.712485801042e+00 ||r(i)||/||b|| 2.081619144630e-04
3628 KSP unpreconditioned resid norm 8.712485801036e+00 true resid norm 8.712485801039e+00 ||r(i)||/||b|| 2.081619144629e-04
3629 KSP unpreconditioned resid norm 8.712485801034e+00 true resid norm 8.712485801033e+00 ||r(i)||/||b|| 2.081619144627e-04
3630 KSP unpreconditioned resid norm 8.712485801036e+00 true resid norm 8.712485801036e+00 ||r(i)||/||b|| 2.081619144628e-04
3631 KSP unpreconditioned resid norm 8.712485801036e+00 true resid norm 8.712485801039e+00 ||r(i)||/||b|| 2.081619144629e-04
3632 KSP unpreconditioned resid norm 8.712485801036e+00 true resid norm 8.712485801038e+00 ||r(i)||/||b|| 2.081619144629e-04
3633 KSP unpreconditioned resid norm 8.712485801036e+00 true resid norm 8.712485801039e+00 ||r(i)||/||b|| 2.081619144629e-04
3634 KSP unpreconditioned resid norm 8.712485801036e+00 true resid norm 8.712485801031e+00 ||r(i)||/||b|| 2.081619144627e-04
3635 KSP unpreconditioned resid norm 8.712485801036e+00 true resid norm 8.712485801033e+00 ||r(i)||/||b|| 2.081619144628e-04
3636 KSP unpreconditioned resid norm 8.712485801036e+00 true resid norm 8.712485801034e+00 ||r(i)||/||b|| 2.081619144628e-04
3637 KSP unpreconditioned resid norm 8.712485801036e+00 true resid norm 8.712485801031e+00 ||r(i)||/||b|| 2.081619144627e-04
3638 KSP unpreconditioned resid norm 8.712485801036e+00 true resid norm 8.712485801033e+00 ||r(i)||/||b|| 2.081619144628e-04
3639 KSP unpreconditioned resid norm 8.712485801035e+00 true resid norm 8.712485801034e+00 ||r(i)||/||b|| 2.081619144628e-04
3640 KSP unpreconditioned resid norm 8.712485801035e+00 true resid norm 8.712485801039e+00 ||r(i)||/||b|| 2.081619144629e-04
3641 KSP unpreconditioned resid norm 8.712485801035e+00 true resid norm 8.712485801029e+00 ||r(i)||/||b|| 2.081619144626e-04
3642 KSP unpreconditioned resid norm 8.712485801035e+00 true resid norm 8.712485801031e+00 ||r(i)||/||b|| 2.081619144627e-04
3643 KSP unpreconditioned resid norm 8.712485801035e+00 true resid norm 8.712485801042e+00 ||r(i)||/||b|| 2.081619144630e-04
3644 KSP unpreconditioned resid norm 8.712485801035e+00 true resid norm 8.712485801036e+00 ||r(i)||/||b|| 2.081619144628e-04
3645 KSP unpreconditioned resid norm 8.712485801035e+00 true resid norm 8.712485801033e+00 ||r(i)||/||b|| 2.081619144627e-04
3646 KSP unpreconditioned resid norm 8.712485801035e+00 true resid norm 8.712485801029e+00 ||r(i)||/||b|| 2.081619144626e-04
3647 KSP unpreconditioned resid norm 8.712485801035e+00 true resid norm 8.712485801027e+00 ||r(i)||/||b|| 2.081619144626e-04
3648 KSP unpreconditioned resid norm 8.712485801034e+00 true resid norm 8.712485801034e+00 ||r(i)||/||b|| 2.081619144628e-04
3649 KSP unpreconditioned resid norm 8.712485801034e+00 true resid norm 8.712485801024e+00 ||r(i)||/||b|| 2.081619144625e-04
3650 KSP unpreconditioned resid norm 8.712485801034e+00 true resid norm 8.712485801032e+00 ||r(i)||/||b|| 2.081619144627e-04
3651 KSP unpreconditioned resid norm 8.712485801034e+00 true resid norm 8.712485801037e+00 ||r(i)||/||b|| 2.081619144629e-04
3652 KSP unpreconditioned resid norm 8.712485801034e+00 true resid norm 8.712485801041e+00 ||r(i)||/||b|| 2.081619144629e-04
3653 KSP unpreconditioned resid norm 8.712485801033e+00 true resid norm 8.712485801026e+00 ||r(i)||/||b|| 2.081619144626e-04
3654 KSP unpreconditioned resid norm 8.712485801032e+00 true resid norm 8.712485801038e+00 ||r(i)||/||b|| 2.081619144629e-04
3655 KSP unpreconditioned resid norm 8.712485801031e+00 true resid norm 8.712485801030e+00 ||r(i)||/||b|| 2.081619144627e-04
3656 KSP unpreconditioned resid norm 8.712485801030e+00 true resid norm 8.712485801032e+00 ||r(i)||/||b|| 2.081619144627e-04
3657 KSP unpreconditioned resid norm 8.712485801029e+00 true resid norm 8.712485801039e+00 ||r(i)||/||b|| 2.081619144629e-04
3658 KSP unpreconditioned resid norm 8.712485801025e+00 true resid norm 8.712485801029e+00 ||r(i)||/||b|| 2.081619144627e-04
3659 KSP unpreconditioned resid norm 8.712485801023e+00 true resid norm 8.712485801026e+00 ||r(i)||/||b|| 2.081619144626e-04
3660 KSP unpreconditioned resid norm 8.712485801025e+00 true resid norm 8.712485801025e+00 ||r(i)||/||b|| 2.081619144626e-04
3661 KSP unpreconditioned resid norm 8.712485801025e+00 true resid norm 8.712485801021e+00 ||r(i)||/||b|| 2.081619144625e-04
3662 KSP unpreconditioned resid norm 8.712485801025e+00 true resid norm 8.712485801024e+00 ||r(i)||/||b|| 2.081619144625e-04
3663 KSP unpreconditioned resid norm 8.712485801025e+00 true resid norm 8.712485801026e+00 ||r(i)||/||b|| 2.081619144626e-04
3664 KSP unpreconditioned resid norm 8.712485801025e+00 true resid norm 8.712485801026e+00 ||r(i)||/||b|| 2.081619144626e-04
3665 KSP unpreconditioned resid norm 8.712485801025e+00 true resid norm 8.712485801029e+00 ||r(i)||/||b|| 2.081619144627e-04
3666 KSP unpreconditioned resid norm 8.712485801025e+00 true resid norm 8.712485801016e+00 ||r(i)||/||b|| 2.081619144623e-04
3667 KSP unpreconditioned resid norm 8.712485801025e+00 true resid norm 8.712485801023e+00 ||r(i)||/||b|| 2.081619144625e-04
3668 KSP unpreconditioned resid norm 8.712485801025e+00 true resid norm 8.712485801026e+00 ||r(i)||/||b|| 2.081619144626e-04
3669 KSP unpreconditioned resid norm 8.712485801025e+00 true resid norm 8.712485801025e+00 ||r(i)||/||b|| 2.081619144626e-04
3670 KSP unpreconditioned resid norm 8.712485801024e+00 true resid norm 8.712485801036e+00 ||r(i)||/||b|| 2.081619144628e-04
3671 KSP unpreconditioned resid norm 8.712485801024e+00 true resid norm 8.712485801037e+00 ||r(i)||/||b|| 2.081619144629e-04
3672 KSP unpreconditioned resid norm 8.712485801024e+00 true resid norm 8.712485801028e+00 ||r(i)||/||b|| 2.081619144626e-04
3673 KSP unpreconditioned resid norm 8.712485801024e+00 true resid norm 8.712485801023e+00 ||r(i)||/||b|| 2.081619144625e-04
3674 KSP unpreconditioned resid norm 8.712485801024e+00 true resid norm 8.712485801025e+00 ||r(i)||/||b|| 2.081619144626e-04
3675 KSP unpreconditioned resid norm 8.712485801024e+00 true resid norm 8.712485801026e+00 ||r(i)||/||b|| 2.081619144626e-04
3676 KSP unpreconditioned resid norm 8.712485801024e+00 true resid norm 8.712485801020e+00 ||r(i)||/||b|| 2.081619144624e-04
3677 KSP unpreconditioned resid norm 8.712485801024e+00 true resid norm 8.712485801018e+00 ||r(i)||/||b|| 2.081619144624e-04
3678 KSP unpreconditioned resid norm 8.712485801024e+00 true resid norm 8.712485801015e+00 ||r(i)||/||b|| 2.081619144623e-04
3679 KSP unpreconditioned resid norm 8.712485801023e+00 true resid norm 8.712485801025e+00 ||r(i)||/||b|| 2.081619144626e-04
3680 KSP unpreconditioned resid norm 8.712485801023e+00 true resid norm 8.712485801020e+00 ||r(i)||/||b|| 2.081619144624e-04
3681 KSP unpreconditioned resid norm 8.712485801023e+00 true resid norm 8.712485801028e+00 ||r(i)||/||b|| 2.081619144626e-04
3682 KSP unpreconditioned resid norm 8.712485801023e+00 true resid norm 8.712485801023e+00 ||r(i)||/||b|| 2.081619144625e-04
3683 KSP unpreconditioned resid norm 8.712485801023e+00 true resid norm 8.712485801019e+00 ||r(i)||/||b|| 2.081619144624e-04
3684 KSP unpreconditioned resid norm 8.712485801022e+00 true resid norm 8.712485801013e+00 ||r(i)||/||b|| 2.081619144623e-04
3685 KSP unpreconditioned resid norm 8.712485801021e+00 true resid norm 8.712485801017e+00 ||r(i)||/||b|| 2.081619144624e-04
3686 KSP unpreconditioned resid norm 8.712485801020e+00 true resid norm 8.712485801022e+00 ||r(i)||/||b|| 2.081619144625e-04
3687 KSP unpreconditioned resid norm 8.712485801019e+00 true resid norm 8.712485801023e+00 ||r(i)||/||b|| 2.081619144625e-04
3688 KSP unpreconditioned resid norm 8.712485801015e+00 true resid norm 8.712485801008e+00 ||r(i)||/||b|| 2.081619144622e-04
3689 KSP unpreconditioned resid norm 8.712485801013e+00 true resid norm 8.712485801007e+00 ||r(i)||/||b|| 2.081619144621e-04
3690 KSP unpreconditioned resid norm 8.712485801012e+00 true resid norm 8.712485801012e+00 ||r(i)||/||b|| 2.081619144623e-04
3691 KSP unpreconditioned resid norm 8.712485801012e+00 true resid norm 8.712485801010e+00 ||r(i)||/||b|| 2.081619144622e-04
3692 KSP unpreconditioned resid norm 8.712485801012e+00 true resid norm 8.712485801000e+00 ||r(i)||/||b|| 2.081619144620e-04
3693 KSP unpreconditioned resid norm 8.712485801012e+00 true resid norm 8.712485801014e+00 ||r(i)||/||b|| 2.081619144623e-04
3694 KSP unpreconditioned resid norm 8.712485801012e+00 true resid norm 8.712485801001e+00 ||r(i)||/||b|| 2.081619144620e-04
3695 KSP unpreconditioned resid norm 8.712485801012e+00 true resid norm 8.712485801011e+00 ||r(i)||/||b|| 2.081619144622e-04
3696 KSP unpreconditioned resid norm 8.712485801012e+00 true resid norm 8.712485801019e+00 ||r(i)||/||b|| 2.081619144624e-04
3697 KSP unpreconditioned resid norm 8.712485801012e+00 true resid norm 8.712485801009e+00 ||r(i)||/||b|| 2.081619144622e-04
3698 KSP unpreconditioned resid norm 8.712485801012e+00 true resid norm 8.712485801018e+00 ||r(i)||/||b|| 2.081619144624e-04
3699 KSP unpreconditioned resid norm 8.712485801012e+00 true resid norm 8.712485801011e+00 ||r(i)||/||b|| 2.081619144622e-04
3700 KSP unpreconditioned resid norm 8.712485801012e+00 true resid norm 8.712485801015e+00 ||r(i)||/||b|| 2.081619144623e-04
3701 KSP unpreconditioned resid norm 8.712485801012e+00 true resid norm 8.712485801005e+00 ||r(i)||/||b|| 2.081619144621e-04
3702 KSP unpreconditioned resid norm 8.712485801012e+00 true resid norm 8.712485801016e+00 ||r(i)||/||b|| 2.081619144623e-04
3703 KSP unpreconditioned resid norm 8.712485801012e+00 true resid norm 8.712485801015e+00 ||r(i)||/||b|| 2.081619144623e-04
3704 KSP unpreconditioned resid norm 8.712485801011e+00 true resid norm 8.712485801015e+00 ||r(i)||/||b|| 2.081619144623e-04
3705 KSP unpreconditioned resid norm 8.712485801011e+00 true resid norm 8.712485801011e+00 ||r(i)||/||b|| 2.081619144622e-04
3706 KSP unpreconditioned resid norm 8.712485801011e+00 true resid norm 8.712485801011e+00 ||r(i)||/||b|| 2.081619144622e-04
3707 KSP unpreconditioned resid norm 8.712485801011e+00 true resid norm 8.712485801012e+00 ||r(i)||/||b|| 2.081619144623e-04
3708 KSP unpreconditioned resid norm 8.712485801011e+00 true resid norm 8.712485801011e+00 ||r(i)||/||b|| 2.081619144622e-04
3709 KSP unpreconditioned resid norm 8.712485801011e+00 true resid norm 8.712485801017e+00 ||r(i)||/||b|| 2.081619144624e-04
3710 KSP unpreconditioned resid norm 8.712485801011e+00 true resid norm 8.712485801019e+00 ||r(i)||/||b|| 2.081619144624e-04
3711 KSP unpreconditioned resid norm 8.712485801011e+00 true resid norm 8.712485801004e+00 ||r(i)||/||b|| 2.081619144620e-04
3712 KSP unpreconditioned resid norm 8.712485801011e+00 true resid norm 8.712485801004e+00 ||r(i)||/||b|| 2.081619144621e-04
3713 KSP unpreconditioned resid norm 8.712485801010e+00 true resid norm 8.712485801012e+00 ||r(i)||/||b|| 2.081619144622e-04
3714 KSP unpreconditioned resid norm 8.712485801009e+00 true resid norm 8.712485801010e+00 ||r(i)||/||b|| 2.081619144622e-04
3715 KSP unpreconditioned resid norm 8.712485801009e+00 true resid norm 8.712485801012e+00 ||r(i)||/||b|| 2.081619144622e-04
3716 KSP unpreconditioned resid norm 8.712485801008e+00 true resid norm 8.712485801008e+00 ||r(i)||/||b|| 2.081619144622e-04
3717 KSP unpreconditioned resid norm 8.712485801007e+00 true resid norm 8.712485800998e+00 ||r(i)||/||b|| 2.081619144619e-04
3718 KSP unpreconditioned resid norm 8.712485801004e+00 true resid norm 8.712485801004e+00 ||r(i)||/||b|| 2.081619144621e-04
3719 KSP unpreconditioned resid norm 8.712485801002e+00 true resid norm 8.712485801003e+00 ||r(i)||/||b|| 2.081619144620e-04
3720 KSP unpreconditioned resid norm 8.712485800990e+00 true resid norm 8.712485800990e+00 ||r(i)||/||b|| 2.081619144617e-04
3721 KSP unpreconditioned resid norm 8.712485800990e+00 true resid norm 8.712485801004e+00 ||r(i)||/||b|| 2.081619144621e-04
3722 KSP unpreconditioned resid norm 8.712485800990e+00 true resid norm 8.712485800996e+00 ||r(i)||/||b|| 2.081619144619e-04
3723 KSP unpreconditioned resid norm 8.712485800990e+00 true resid norm 8.712485800998e+00 ||r(i)||/||b|| 2.081619144619e-04
3724 KSP unpreconditioned resid norm 8.712485800990e+00 true resid norm 8.712485800997e+00 ||r(i)||/||b|| 2.081619144619e-04
3725 KSP unpreconditioned resid norm 8.712485800990e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
3726 KSP unpreconditioned resid norm 8.712485800990e+00 true resid norm 8.712485800990e+00 ||r(i)||/||b|| 2.081619144617e-04
3727 KSP unpreconditioned resid norm 8.712485800990e+00 true resid norm 8.712485801003e+00 ||r(i)||/||b|| 2.081619144620e-04
3728 KSP unpreconditioned resid norm 8.712485800990e+00 true resid norm 8.712485800994e+00 ||r(i)||/||b|| 2.081619144618e-04
3729 KSP unpreconditioned resid norm 8.712485800990e+00 true resid norm 8.712485800996e+00 ||r(i)||/||b|| 2.081619144619e-04
3730 KSP unpreconditioned resid norm 8.712485800990e+00 true resid norm 8.712485800994e+00 ||r(i)||/||b|| 2.081619144618e-04
3731 KSP unpreconditioned resid norm 8.712485800990e+00 true resid norm 8.712485800995e+00 ||r(i)||/||b|| 2.081619144618e-04
3732 KSP unpreconditioned resid norm 8.712485800990e+00 true resid norm 8.712485800984e+00 ||r(i)||/||b|| 2.081619144616e-04
3733 KSP unpreconditioned resid norm 8.712485800990e+00 true resid norm 8.712485800990e+00 ||r(i)||/||b|| 2.081619144617e-04
3734 KSP unpreconditioned resid norm 8.712485800990e+00 true resid norm 8.712485800999e+00 ||r(i)||/||b|| 2.081619144619e-04
3735 KSP unpreconditioned resid norm 8.712485800989e+00 true resid norm 8.712485800994e+00 ||r(i)||/||b|| 2.081619144618e-04
3736 KSP unpreconditioned resid norm 8.712485800989e+00 true resid norm 8.712485800998e+00 ||r(i)||/||b|| 2.081619144619e-04
3737 KSP unpreconditioned resid norm 8.712485800989e+00 true resid norm 8.712485800997e+00 ||r(i)||/||b|| 2.081619144619e-04
3738 KSP unpreconditioned resid norm 8.712485800989e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
3739 KSP unpreconditioned resid norm 8.712485800989e+00 true resid norm 8.712485800997e+00 ||r(i)||/||b|| 2.081619144619e-04
3740 KSP unpreconditioned resid norm 8.712485800989e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
3741 KSP unpreconditioned resid norm 8.712485800989e+00 true resid norm 8.712485800998e+00 ||r(i)||/||b|| 2.081619144619e-04
3742 KSP unpreconditioned resid norm 8.712485800989e+00 true resid norm 8.712485800995e+00 ||r(i)||/||b|| 2.081619144618e-04
3743 KSP unpreconditioned resid norm 8.712485800988e+00 true resid norm 8.712485800989e+00 ||r(i)||/||b|| 2.081619144617e-04
3744 KSP unpreconditioned resid norm 8.712485800988e+00 true resid norm 8.712485801000e+00 ||r(i)||/||b|| 2.081619144620e-04
3745 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800985e+00 ||r(i)||/||b|| 2.081619144616e-04
3746 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800994e+00 ||r(i)||/||b|| 2.081619144618e-04
3747 KSP unpreconditioned resid norm 8.712485800985e+00 true resid norm 8.712485801000e+00 ||r(i)||/||b|| 2.081619144620e-04
3748 KSP unpreconditioned resid norm 8.712485800983e+00 true resid norm 8.712485801004e+00 ||r(i)||/||b|| 2.081619144621e-04
3749 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800983e+00 ||r(i)||/||b|| 2.081619144616e-04
3750 KSP unpreconditioned resid norm 8.712485801000e+00 true resid norm 8.712485801000e+00 ||r(i)||/||b|| 2.081619144620e-04
3751 KSP unpreconditioned resid norm 8.712485801000e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
3752 KSP unpreconditioned resid norm 8.712485801000e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
3753 KSP unpreconditioned resid norm 8.712485801000e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
3754 KSP unpreconditioned resid norm 8.712485801000e+00 true resid norm 8.712485801002e+00 ||r(i)||/||b|| 2.081619144620e-04
3755 KSP unpreconditioned resid norm 8.712485801000e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
3756 KSP unpreconditioned resid norm 8.712485801000e+00 true resid norm 8.712485800985e+00 ||r(i)||/||b|| 2.081619144616e-04
3757 KSP unpreconditioned resid norm 8.712485801000e+00 true resid norm 8.712485800999e+00 ||r(i)||/||b|| 2.081619144619e-04
3758 KSP unpreconditioned resid norm 8.712485801000e+00 true resid norm 8.712485800985e+00 ||r(i)||/||b|| 2.081619144616e-04
3759 KSP unpreconditioned resid norm 8.712485801000e+00 true resid norm 8.712485800998e+00 ||r(i)||/||b|| 2.081619144619e-04
3760 KSP unpreconditioned resid norm 8.712485801000e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
3761 KSP unpreconditioned resid norm 8.712485801000e+00 true resid norm 8.712485801000e+00 ||r(i)||/||b|| 2.081619144620e-04
3762 KSP unpreconditioned resid norm 8.712485801000e+00 true resid norm 8.712485800994e+00 ||r(i)||/||b|| 2.081619144618e-04
3763 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485800995e+00 ||r(i)||/||b|| 2.081619144618e-04
3764 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
3765 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485800983e+00 ||r(i)||/||b|| 2.081619144616e-04
3766 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
3767 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485800998e+00 ||r(i)||/||b|| 2.081619144619e-04
3768 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
3769 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
3770 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485801005e+00 ||r(i)||/||b|| 2.081619144621e-04
3771 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
3772 KSP unpreconditioned resid norm 8.712485800999e+00 true resid norm 8.712485800985e+00 ||r(i)||/||b|| 2.081619144616e-04
3773 KSP unpreconditioned resid norm 8.712485800998e+00 true resid norm 8.712485800988e+00 ||r(i)||/||b|| 2.081619144617e-04
3774 KSP unpreconditioned resid norm 8.712485800998e+00 true resid norm 8.712485800996e+00 ||r(i)||/||b|| 2.081619144619e-04
3775 KSP unpreconditioned resid norm 8.712485800997e+00 true resid norm 8.712485800990e+00 ||r(i)||/||b|| 2.081619144617e-04
3776 KSP unpreconditioned resid norm 8.712485800996e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
3777 KSP unpreconditioned resid norm 8.712485800995e+00 true resid norm 8.712485800979e+00 ||r(i)||/||b|| 2.081619144615e-04
3778 KSP unpreconditioned resid norm 8.712485800993e+00 true resid norm 8.712485800991e+00 ||r(i)||/||b|| 2.081619144617e-04
3779 KSP unpreconditioned resid norm 8.712485800992e+00 true resid norm 8.712485800984e+00 ||r(i)||/||b|| 2.081619144616e-04
3780 KSP unpreconditioned resid norm 8.712485800984e+00 true resid norm 8.712485800984e+00 ||r(i)||/||b|| 2.081619144616e-04
3781 KSP unpreconditioned resid norm 8.712485800984e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
3782 KSP unpreconditioned resid norm 8.712485800984e+00 true resid norm 8.712485800979e+00 ||r(i)||/||b|| 2.081619144615e-04
3783 KSP unpreconditioned resid norm 8.712485800984e+00 true resid norm 8.712485800983e+00 ||r(i)||/||b|| 2.081619144616e-04
3784 KSP unpreconditioned resid norm 8.712485800984e+00 true resid norm 8.712485800984e+00 ||r(i)||/||b|| 2.081619144616e-04
3785 KSP unpreconditioned resid norm 8.712485800984e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
3786 KSP unpreconditioned resid norm 8.712485800984e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
3787 KSP unpreconditioned resid norm 8.712485800984e+00 true resid norm 8.712485800983e+00 ||r(i)||/||b|| 2.081619144615e-04
3788 KSP unpreconditioned resid norm 8.712485800984e+00 true resid norm 8.712485800989e+00 ||r(i)||/||b|| 2.081619144617e-04
3789 KSP unpreconditioned resid norm 8.712485800984e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
3790 KSP unpreconditioned resid norm 8.712485800983e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
3791 KSP unpreconditioned resid norm 8.712485800983e+00 true resid norm 8.712485800995e+00 ||r(i)||/||b|| 2.081619144618e-04
3792 KSP unpreconditioned resid norm 8.712485800983e+00 true resid norm 8.712485800982e+00 ||r(i)||/||b|| 2.081619144615e-04
3793 KSP unpreconditioned resid norm 8.712485800983e+00 true resid norm 8.712485800979e+00 ||r(i)||/||b|| 2.081619144615e-04
3794 KSP unpreconditioned resid norm 8.712485800983e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
3795 KSP unpreconditioned resid norm 8.712485800983e+00 true resid norm 8.712485800985e+00 ||r(i)||/||b|| 2.081619144616e-04
3796 KSP unpreconditioned resid norm 8.712485800983e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
3797 KSP unpreconditioned resid norm 8.712485800983e+00 true resid norm 8.712485800982e+00 ||r(i)||/||b|| 2.081619144615e-04
3798 KSP unpreconditioned resid norm 8.712485800983e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
3799 KSP unpreconditioned resid norm 8.712485800983e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
3800 KSP unpreconditioned resid norm 8.712485800983e+00 true resid norm 8.712485800983e+00 ||r(i)||/||b|| 2.081619144615e-04
3801 KSP unpreconditioned resid norm 8.712485800983e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
3802 KSP unpreconditioned resid norm 8.712485800983e+00 true resid norm 8.712485800984e+00 ||r(i)||/||b|| 2.081619144616e-04
3803 KSP unpreconditioned resid norm 8.712485800982e+00 true resid norm 8.712485800990e+00 ||r(i)||/||b|| 2.081619144617e-04
3804 KSP unpreconditioned resid norm 8.712485800982e+00 true resid norm 8.712485800983e+00 ||r(i)||/||b|| 2.081619144615e-04
3805 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
3806 KSP unpreconditioned resid norm 8.712485800981e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
3807 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
3808 KSP unpreconditioned resid norm 8.712485800978e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
3809 KSP unpreconditioned resid norm 8.712485800977e+00 true resid norm 8.712485800990e+00 ||r(i)||/||b|| 2.081619144617e-04
3810 KSP unpreconditioned resid norm 8.712485800979e+00 true resid norm 8.712485800979e+00 ||r(i)||/||b|| 2.081619144615e-04
3811 KSP unpreconditioned resid norm 8.712485800979e+00 true resid norm 8.712485800989e+00 ||r(i)||/||b|| 2.081619144617e-04
3812 KSP unpreconditioned resid norm 8.712485800979e+00 true resid norm 8.712485800983e+00 ||r(i)||/||b|| 2.081619144616e-04
3813 KSP unpreconditioned resid norm 8.712485800979e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
3814 KSP unpreconditioned resid norm 8.712485800979e+00 true resid norm 8.712485800976e+00 ||r(i)||/||b|| 2.081619144614e-04
3815 KSP unpreconditioned resid norm 8.712485800979e+00 true resid norm 8.712485800985e+00 ||r(i)||/||b|| 2.081619144616e-04
3816 KSP unpreconditioned resid norm 8.712485800979e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
3817 KSP unpreconditioned resid norm 8.712485800979e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
3818 KSP unpreconditioned resid norm 8.712485800979e+00 true resid norm 8.712485800982e+00 ||r(i)||/||b|| 2.081619144615e-04
3819 KSP unpreconditioned resid norm 8.712485800979e+00 true resid norm 8.712485800982e+00 ||r(i)||/||b|| 2.081619144615e-04
3820 KSP unpreconditioned resid norm 8.712485800979e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
3821 KSP unpreconditioned resid norm 8.712485800979e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
3822 KSP unpreconditioned resid norm 8.712485800979e+00 true resid norm 8.712485800982e+00 ||r(i)||/||b|| 2.081619144615e-04
3823 KSP unpreconditioned resid norm 8.712485800979e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
3824 KSP unpreconditioned resid norm 8.712485800979e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
3825 KSP unpreconditioned resid norm 8.712485800979e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
3826 KSP unpreconditioned resid norm 8.712485800979e+00 true resid norm 8.712485800984e+00 ||r(i)||/||b|| 2.081619144616e-04
3827 KSP unpreconditioned resid norm 8.712485800979e+00 true resid norm 8.712485800982e+00 ||r(i)||/||b|| 2.081619144615e-04
3828 KSP unpreconditioned resid norm 8.712485800979e+00 true resid norm 8.712485800971e+00 ||r(i)||/||b|| 2.081619144613e-04
3829 KSP unpreconditioned resid norm 8.712485800979e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
3830 KSP unpreconditioned resid norm 8.712485800979e+00 true resid norm 8.712485800984e+00 ||r(i)||/||b|| 2.081619144616e-04
3831 KSP unpreconditioned resid norm 8.712485800978e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
3832 KSP unpreconditioned resid norm 8.712485800978e+00 true resid norm 8.712485800991e+00 ||r(i)||/||b|| 2.081619144617e-04
3833 KSP unpreconditioned resid norm 8.712485800978e+00 true resid norm 8.712485800991e+00 ||r(i)||/||b|| 2.081619144617e-04
3834 KSP unpreconditioned resid norm 8.712485800978e+00 true resid norm 8.712485800972e+00 ||r(i)||/||b|| 2.081619144613e-04
3835 KSP unpreconditioned resid norm 8.712485800977e+00 true resid norm 8.712485800982e+00 ||r(i)||/||b|| 2.081619144615e-04
3836 KSP unpreconditioned resid norm 8.712485800977e+00 true resid norm 8.712485800982e+00 ||r(i)||/||b|| 2.081619144615e-04
3837 KSP unpreconditioned resid norm 8.712485800976e+00 true resid norm 8.712485800978e+00 ||r(i)||/||b|| 2.081619144614e-04
3838 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800983e+00 ||r(i)||/||b|| 2.081619144615e-04
3839 KSP unpreconditioned resid norm 8.712485800973e+00 true resid norm 8.712485800966e+00 ||r(i)||/||b|| 2.081619144611e-04
3840 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
3841 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800989e+00 ||r(i)||/||b|| 2.081619144617e-04
3842 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800978e+00 ||r(i)||/||b|| 2.081619144614e-04
3843 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800985e+00 ||r(i)||/||b|| 2.081619144616e-04
3844 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
3845 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800979e+00 ||r(i)||/||b|| 2.081619144615e-04
3846 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
3847 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800972e+00 ||r(i)||/||b|| 2.081619144613e-04
3848 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800976e+00 ||r(i)||/||b|| 2.081619144614e-04
3849 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
3850 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800971e+00 ||r(i)||/||b|| 2.081619144613e-04
3851 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
3852 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800978e+00 ||r(i)||/||b|| 2.081619144614e-04
3853 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800978e+00 ||r(i)||/||b|| 2.081619144614e-04
3854 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800983e+00 ||r(i)||/||b|| 2.081619144616e-04
3855 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800984e+00 ||r(i)||/||b|| 2.081619144616e-04
3856 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
3857 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
3858 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
3859 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800988e+00 ||r(i)||/||b|| 2.081619144617e-04
3860 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800976e+00 ||r(i)||/||b|| 2.081619144614e-04
3861 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800977e+00 ||r(i)||/||b|| 2.081619144614e-04
3862 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
3863 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800978e+00 ||r(i)||/||b|| 2.081619144614e-04
3864 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800984e+00 ||r(i)||/||b|| 2.081619144616e-04
3865 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800979e+00 ||r(i)||/||b|| 2.081619144615e-04
3866 KSP unpreconditioned resid norm 8.712485800973e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
3867 KSP unpreconditioned resid norm 8.712485800972e+00 true resid norm 8.712485800976e+00 ||r(i)||/||b|| 2.081619144614e-04
3868 KSP unpreconditioned resid norm 8.712485800971e+00 true resid norm 8.712485800979e+00 ||r(i)||/||b|| 2.081619144615e-04
3869 KSP unpreconditioned resid norm 8.712485800970e+00 true resid norm 8.712485800983e+00 ||r(i)||/||b|| 2.081619144616e-04
3870 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
3871 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800979e+00 ||r(i)||/||b|| 2.081619144615e-04
3872 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800977e+00 ||r(i)||/||b|| 2.081619144614e-04
3873 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
3874 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
3875 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800966e+00 ||r(i)||/||b|| 2.081619144612e-04
3876 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
3877 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800978e+00 ||r(i)||/||b|| 2.081619144614e-04
3878 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800970e+00 ||r(i)||/||b|| 2.081619144613e-04
3879 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
3880 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800976e+00 ||r(i)||/||b|| 2.081619144614e-04
3881 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800970e+00 ||r(i)||/||b|| 2.081619144612e-04
3882 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800979e+00 ||r(i)||/||b|| 2.081619144615e-04
3883 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
3884 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
3885 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
3886 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
3887 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
3888 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800971e+00 ||r(i)||/||b|| 2.081619144613e-04
3889 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800970e+00 ||r(i)||/||b|| 2.081619144612e-04
3890 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800966e+00 ||r(i)||/||b|| 2.081619144612e-04
3891 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
3892 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800964e+00 ||r(i)||/||b|| 2.081619144611e-04
3893 KSP unpreconditioned resid norm 8.712485800967e+00 true resid norm 8.712485800976e+00 ||r(i)||/||b|| 2.081619144614e-04
3894 KSP unpreconditioned resid norm 8.712485800967e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
3895 KSP unpreconditioned resid norm 8.712485800967e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
3896 KSP unpreconditioned resid norm 8.712485800966e+00 true resid norm 8.712485800976e+00 ||r(i)||/||b|| 2.081619144614e-04
3897 KSP unpreconditioned resid norm 8.712485800966e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
3898 KSP unpreconditioned resid norm 8.712485800964e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
3899 KSP unpreconditioned resid norm 8.712485800964e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
3900 KSP unpreconditioned resid norm 8.712485800970e+00 true resid norm 8.712485800970e+00 ||r(i)||/||b|| 2.081619144612e-04
3901 KSP unpreconditioned resid norm 8.712485800970e+00 true resid norm 8.712485800971e+00 ||r(i)||/||b|| 2.081619144613e-04
3902 KSP unpreconditioned resid norm 8.712485800970e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
3903 KSP unpreconditioned resid norm 8.712485800970e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
3904 KSP unpreconditioned resid norm 8.712485800970e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
3905 KSP unpreconditioned resid norm 8.712485800970e+00 true resid norm 8.712485800976e+00 ||r(i)||/||b|| 2.081619144614e-04
3906 KSP unpreconditioned resid norm 8.712485800970e+00 true resid norm 8.712485800972e+00 ||r(i)||/||b|| 2.081619144613e-04
3907 KSP unpreconditioned resid norm 8.712485800970e+00 true resid norm 8.712485800971e+00 ||r(i)||/||b|| 2.081619144613e-04
3908 KSP unpreconditioned resid norm 8.712485800970e+00 true resid norm 8.712485800977e+00 ||r(i)||/||b|| 2.081619144614e-04
3909 KSP unpreconditioned resid norm 8.712485800970e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
3910 KSP unpreconditioned resid norm 8.712485800970e+00 true resid norm 8.712485800970e+00 ||r(i)||/||b|| 2.081619144612e-04
3911 KSP unpreconditioned resid norm 8.712485800970e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
3912 KSP unpreconditioned resid norm 8.712485800970e+00 true resid norm 8.712485800971e+00 ||r(i)||/||b|| 2.081619144613e-04
3913 KSP unpreconditioned resid norm 8.712485800970e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
3914 KSP unpreconditioned resid norm 8.712485800969e+00 true resid norm 8.712485800966e+00 ||r(i)||/||b|| 2.081619144611e-04
3915 KSP unpreconditioned resid norm 8.712485800969e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
3916 KSP unpreconditioned resid norm 8.712485800969e+00 true resid norm 8.712485800971e+00 ||r(i)||/||b|| 2.081619144613e-04
3917 KSP unpreconditioned resid norm 8.712485800969e+00 true resid norm 8.712485800976e+00 ||r(i)||/||b|| 2.081619144614e-04
3918 KSP unpreconditioned resid norm 8.712485800969e+00 true resid norm 8.712485800971e+00 ||r(i)||/||b|| 2.081619144613e-04
3919 KSP unpreconditioned resid norm 8.712485800969e+00 true resid norm 8.712485800970e+00 ||r(i)||/||b|| 2.081619144612e-04
3920 KSP unpreconditioned resid norm 8.712485800969e+00 true resid norm 8.712485800972e+00 ||r(i)||/||b|| 2.081619144613e-04
3921 KSP unpreconditioned resid norm 8.712485800969e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
3922 KSP unpreconditioned resid norm 8.712485800969e+00 true resid norm 8.712485800966e+00 ||r(i)||/||b|| 2.081619144611e-04
3923 KSP unpreconditioned resid norm 8.712485800969e+00 true resid norm 8.712485800972e+00 ||r(i)||/||b|| 2.081619144613e-04
3924 KSP unpreconditioned resid norm 8.712485800969e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
3925 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800972e+00 ||r(i)||/||b|| 2.081619144613e-04
3926 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800982e+00 ||r(i)||/||b|| 2.081619144615e-04
3927 KSP unpreconditioned resid norm 8.712485800967e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
3928 KSP unpreconditioned resid norm 8.712485800966e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
3929 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
3930 KSP unpreconditioned resid norm 8.712485800972e+00 true resid norm 8.712485800972e+00 ||r(i)||/||b|| 2.081619144613e-04
3931 KSP unpreconditioned resid norm 8.712485800972e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
3932 KSP unpreconditioned resid norm 8.712485800972e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
3933 KSP unpreconditioned resid norm 8.712485800972e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
3934 KSP unpreconditioned resid norm 8.712485800972e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
3935 KSP unpreconditioned resid norm 8.712485800972e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
3936 KSP unpreconditioned resid norm 8.712485800972e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
3937 KSP unpreconditioned resid norm 8.712485800972e+00 true resid norm 8.712485800966e+00 ||r(i)||/||b|| 2.081619144611e-04
3938 KSP unpreconditioned resid norm 8.712485800972e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
3939 KSP unpreconditioned resid norm 8.712485800972e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
3940 KSP unpreconditioned resid norm 8.712485800972e+00 true resid norm 8.712485800964e+00 ||r(i)||/||b|| 2.081619144611e-04
3941 KSP unpreconditioned resid norm 8.712485800972e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
3942 KSP unpreconditioned resid norm 8.712485800972e+00 true resid norm 8.712485800972e+00 ||r(i)||/||b|| 2.081619144613e-04
3943 KSP unpreconditioned resid norm 8.712485800972e+00 true resid norm 8.712485800972e+00 ||r(i)||/||b|| 2.081619144613e-04
3944 KSP unpreconditioned resid norm 8.712485800972e+00 true resid norm 8.712485800966e+00 ||r(i)||/||b|| 2.081619144612e-04
3945 KSP unpreconditioned resid norm 8.712485800971e+00 true resid norm 8.712485800966e+00 ||r(i)||/||b|| 2.081619144611e-04
3946 KSP unpreconditioned resid norm 8.712485800971e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
3947 KSP unpreconditioned resid norm 8.712485800971e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
3948 KSP unpreconditioned resid norm 8.712485800971e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
3949 KSP unpreconditioned resid norm 8.712485800971e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
3950 KSP unpreconditioned resid norm 8.712485800971e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
3951 KSP unpreconditioned resid norm 8.712485800971e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
3952 KSP unpreconditioned resid norm 8.712485800971e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
3953 KSP unpreconditioned resid norm 8.712485800971e+00 true resid norm 8.712485800951e+00 ||r(i)||/||b|| 2.081619144608e-04
3954 KSP unpreconditioned resid norm 8.712485800971e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
3955 KSP unpreconditioned resid norm 8.712485800970e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
3956 KSP unpreconditioned resid norm 8.712485800970e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
3957 KSP unpreconditioned resid norm 8.712485800970e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144614e-04
3958 KSP unpreconditioned resid norm 8.712485800969e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
3959 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
3960 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
3961 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
3962 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800966e+00 ||r(i)||/||b|| 2.081619144612e-04
3963 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800966e+00 ||r(i)||/||b|| 2.081619144611e-04
3964 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
3965 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
3966 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800971e+00 ||r(i)||/||b|| 2.081619144613e-04
3967 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
3968 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
3969 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
3970 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
3971 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800970e+00 ||r(i)||/||b|| 2.081619144613e-04
3972 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800966e+00 ||r(i)||/||b|| 2.081619144612e-04
3973 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
3974 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
3975 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800970e+00 ||r(i)||/||b|| 2.081619144612e-04
3976 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
3977 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
3978 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
3979 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800972e+00 ||r(i)||/||b|| 2.081619144613e-04
3980 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
3981 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
3982 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
3983 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
3984 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800964e+00 ||r(i)||/||b|| 2.081619144611e-04
3985 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
3986 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
3987 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
3988 KSP unpreconditioned resid norm 8.712485800959e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
3989 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
3990 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
3991 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800964e+00 ||r(i)||/||b|| 2.081619144611e-04
3992 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
3993 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
3994 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
3995 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800966e+00 ||r(i)||/||b|| 2.081619144611e-04
3996 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
3997 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
3998 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
3999 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
4000 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4001 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
4002 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4003 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
4004 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800970e+00 ||r(i)||/||b|| 2.081619144612e-04
4005 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800971e+00 ||r(i)||/||b|| 2.081619144613e-04
4006 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
4007 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
4008 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
4009 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800971e+00 ||r(i)||/||b|| 2.081619144613e-04
4010 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
4011 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4012 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
4013 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
4014 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800977e+00 ||r(i)||/||b|| 2.081619144614e-04
4015 KSP unpreconditioned resid norm 8.712485800964e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
4016 KSP unpreconditioned resid norm 8.712485800964e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4017 KSP unpreconditioned resid norm 8.712485800964e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
4018 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4019 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
4020 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4021 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
4022 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4023 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4024 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
4025 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4026 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800971e+00 ||r(i)||/||b|| 2.081619144613e-04
4027 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
4028 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4029 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
4030 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
4031 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
4032 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800964e+00 ||r(i)||/||b|| 2.081619144611e-04
4033 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
4034 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
4035 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4036 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800966e+00 ||r(i)||/||b|| 2.081619144611e-04
4037 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
4038 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
4039 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
4040 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800964e+00 ||r(i)||/||b|| 2.081619144611e-04
4041 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
4042 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
4043 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4044 KSP unpreconditioned resid norm 8.712485800959e+00 true resid norm 8.712485800966e+00 ||r(i)||/||b|| 2.081619144612e-04
4045 KSP unpreconditioned resid norm 8.712485800959e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
4046 KSP unpreconditioned resid norm 8.712485800959e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
4047 KSP unpreconditioned resid norm 8.712485800959e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
4048 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
4049 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
4050 KSP unpreconditioned resid norm 8.712485800967e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
4051 KSP unpreconditioned resid norm 8.712485800967e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
4052 KSP unpreconditioned resid norm 8.712485800967e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
4053 KSP unpreconditioned resid norm 8.712485800967e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
4054 KSP unpreconditioned resid norm 8.712485800967e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4055 KSP unpreconditioned resid norm 8.712485800966e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
4056 KSP unpreconditioned resid norm 8.712485800966e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4057 KSP unpreconditioned resid norm 8.712485800966e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4058 KSP unpreconditioned resid norm 8.712485800966e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
4059 KSP unpreconditioned resid norm 8.712485800966e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
4060 KSP unpreconditioned resid norm 8.712485800966e+00 true resid norm 8.712485800970e+00 ||r(i)||/||b|| 2.081619144612e-04
4061 KSP unpreconditioned resid norm 8.712485800966e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
4062 KSP unpreconditioned resid norm 8.712485800966e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4063 KSP unpreconditioned resid norm 8.712485800966e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
4064 KSP unpreconditioned resid norm 8.712485800966e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4065 KSP unpreconditioned resid norm 8.712485800966e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
4066 KSP unpreconditioned resid norm 8.712485800966e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
4067 KSP unpreconditioned resid norm 8.712485800966e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
4068 KSP unpreconditioned resid norm 8.712485800966e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
4069 KSP unpreconditioned resid norm 8.712485800966e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
4070 KSP unpreconditioned resid norm 8.712485800966e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
4071 KSP unpreconditioned resid norm 8.712485800966e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
4072 KSP unpreconditioned resid norm 8.712485800966e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4073 KSP unpreconditioned resid norm 8.712485800966e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
4074 KSP unpreconditioned resid norm 8.712485800966e+00 true resid norm 8.712485800964e+00 ||r(i)||/||b|| 2.081619144611e-04
4075 KSP unpreconditioned resid norm 8.712485800966e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
4076 KSP unpreconditioned resid norm 8.712485800966e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
4077 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
4078 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
4079 KSP unpreconditioned resid norm 8.712485800964e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
4080 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
4081 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
4082 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
4083 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
4084 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
4085 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
4086 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
4087 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800964e+00 ||r(i)||/||b|| 2.081619144611e-04
4088 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4089 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4090 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800970e+00 ||r(i)||/||b|| 2.081619144612e-04
4091 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4092 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
4093 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800971e+00 ||r(i)||/||b|| 2.081619144613e-04
4094 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144607e-04
4095 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
4096 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4097 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
4098 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800964e+00 ||r(i)||/||b|| 2.081619144611e-04
4099 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800947e+00 ||r(i)||/||b|| 2.081619144607e-04
4100 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4101 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144609e-04
4102 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4103 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800966e+00 ||r(i)||/||b|| 2.081619144612e-04
4104 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
4105 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800964e+00 ||r(i)||/||b|| 2.081619144611e-04
4106 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
4107 KSP unpreconditioned resid norm 8.712485800959e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
4108 KSP unpreconditioned resid norm 8.712485800959e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4109 KSP unpreconditioned resid norm 8.712485800959e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4110 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
4111 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
4112 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
4113 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
4114 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
4115 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
4116 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
4117 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4118 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4119 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800964e+00 ||r(i)||/||b|| 2.081619144611e-04
4120 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800964e+00 ||r(i)||/||b|| 2.081619144611e-04
4121 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4122 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4123 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
4124 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
4125 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
4126 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800966e+00 ||r(i)||/||b|| 2.081619144612e-04
4127 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
4128 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
4129 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
4130 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
4131 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800966e+00 ||r(i)||/||b|| 2.081619144611e-04
4132 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
4133 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800966e+00 ||r(i)||/||b|| 2.081619144611e-04
4134 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4135 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
4136 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
4137 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4138 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4139 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
4140 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
4141 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4142 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
4143 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
4144 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800966e+00 ||r(i)||/||b|| 2.081619144612e-04
4145 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4146 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800964e+00 ||r(i)||/||b|| 2.081619144611e-04
4147 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800964e+00 ||r(i)||/||b|| 2.081619144611e-04
4148 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4149 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800976e+00 ||r(i)||/||b|| 2.081619144614e-04
4150 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
4151 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4152 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
4153 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4154 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
4155 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800979e+00 ||r(i)||/||b|| 2.081619144615e-04
4156 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
4157 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
4158 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4159 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4160 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
4161 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
4162 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
4163 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4164 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800951e+00 ||r(i)||/||b|| 2.081619144608e-04
4165 KSP unpreconditioned resid norm 8.712485800967e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
4166 KSP unpreconditioned resid norm 8.712485800967e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4167 KSP unpreconditioned resid norm 8.712485800967e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4168 KSP unpreconditioned resid norm 8.712485800967e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
4169 KSP unpreconditioned resid norm 8.712485800966e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
4170 KSP unpreconditioned resid norm 8.712485800959e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
4171 KSP unpreconditioned resid norm 8.712485800959e+00 true resid norm 8.712485800970e+00 ||r(i)||/||b|| 2.081619144613e-04
4172 KSP unpreconditioned resid norm 8.712485800959e+00 true resid norm 8.712485800970e+00 ||r(i)||/||b|| 2.081619144612e-04
4173 KSP unpreconditioned resid norm 8.712485800959e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
4174 KSP unpreconditioned resid norm 8.712485800959e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4175 KSP unpreconditioned resid norm 8.712485800959e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
4176 KSP unpreconditioned resid norm 8.712485800959e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
4177 KSP unpreconditioned resid norm 8.712485800959e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
4178 KSP unpreconditioned resid norm 8.712485800959e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
4179 KSP unpreconditioned resid norm 8.712485800959e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
4180 KSP unpreconditioned resid norm 8.712485800959e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4181 KSP unpreconditioned resid norm 8.712485800959e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
4182 KSP unpreconditioned resid norm 8.712485800959e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
4183 KSP unpreconditioned resid norm 8.712485800959e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
4184 KSP unpreconditioned resid norm 8.712485800959e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
4185 KSP unpreconditioned resid norm 8.712485800959e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4186 KSP unpreconditioned resid norm 8.712485800959e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
4187 KSP unpreconditioned resid norm 8.712485800959e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
4188 KSP unpreconditioned resid norm 8.712485800959e+00 true resid norm 8.712485800971e+00 ||r(i)||/||b|| 2.081619144613e-04
4189 KSP unpreconditioned resid norm 8.712485800959e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
4190 KSP unpreconditioned resid norm 8.712485800959e+00 true resid norm 8.712485800964e+00 ||r(i)||/||b|| 2.081619144611e-04
4191 KSP unpreconditioned resid norm 8.712485800959e+00 true resid norm 8.712485800972e+00 ||r(i)||/||b|| 2.081619144613e-04
4192 KSP unpreconditioned resid norm 8.712485800959e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
4193 KSP unpreconditioned resid norm 8.712485800959e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
4194 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4195 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4196 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4197 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800951e+00 ||r(i)||/||b|| 2.081619144608e-04
4198 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800966e+00 ||r(i)||/||b|| 2.081619144611e-04
4199 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
4200 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
4201 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
4202 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800972e+00 ||r(i)||/||b|| 2.081619144613e-04
4203 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
4204 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
4205 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4206 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
4207 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4208 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4209 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
4210 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800972e+00 ||r(i)||/||b|| 2.081619144613e-04
4211 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4212 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800947e+00 ||r(i)||/||b|| 2.081619144607e-04
4213 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
4214 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
4215 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
4216 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800951e+00 ||r(i)||/||b|| 2.081619144608e-04
4217 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
4218 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144609e-04
4219 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144609e-04
4220 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
4221 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
4222 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4223 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
4224 KSP unpreconditioned resid norm 8.712485800964e+00 true resid norm 8.712485800964e+00 ||r(i)||/||b|| 2.081619144611e-04
4225 KSP unpreconditioned resid norm 8.712485800964e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4226 KSP unpreconditioned resid norm 8.712485800964e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144607e-04
4227 KSP unpreconditioned resid norm 8.712485800964e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4228 KSP unpreconditioned resid norm 8.712485800964e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144607e-04
4229 KSP unpreconditioned resid norm 8.712485800964e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
4230 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
4231 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
4232 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
4233 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
4234 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
4235 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800951e+00 ||r(i)||/||b|| 2.081619144608e-04
4236 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
4237 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
4238 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4239 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
4240 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800966e+00 ||r(i)||/||b|| 2.081619144611e-04
4241 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
4242 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
4243 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
4244 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800964e+00 ||r(i)||/||b|| 2.081619144611e-04
4245 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
4246 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800971e+00 ||r(i)||/||b|| 2.081619144613e-04
4247 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4248 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800964e+00 ||r(i)||/||b|| 2.081619144611e-04
4249 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
4250 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
4251 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4252 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4253 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4254 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4255 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4256 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4257 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
4258 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
4259 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4260 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
4261 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
4262 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4263 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800971e+00 ||r(i)||/||b|| 2.081619144613e-04
4264 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800964e+00 ||r(i)||/||b|| 2.081619144611e-04
4265 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
4266 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800972e+00 ||r(i)||/||b|| 2.081619144613e-04
4267 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
4268 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
4269 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
4270 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800966e+00 ||r(i)||/||b|| 2.081619144611e-04
4271 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4272 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
4273 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800964e+00 ||r(i)||/||b|| 2.081619144611e-04
4274 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
4275 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
4276 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800970e+00 ||r(i)||/||b|| 2.081619144613e-04
4277 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800951e+00 ||r(i)||/||b|| 2.081619144608e-04
4278 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
4279 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
4280 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
4281 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4282 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
4283 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
4284 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
4285 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
4286 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4287 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144608e-04
4288 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4289 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800951e+00 ||r(i)||/||b|| 2.081619144608e-04
4290 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
4291 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
4292 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
4293 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
4294 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4295 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800951e+00 ||r(i)||/||b|| 2.081619144608e-04
4296 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4297 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
4298 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800964e+00 ||r(i)||/||b|| 2.081619144611e-04
4299 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
4300 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4301 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
4302 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
4303 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4304 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800966e+00 ||r(i)||/||b|| 2.081619144611e-04
4305 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4306 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
4307 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4308 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
4309 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
4310 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
4311 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
4312 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4313 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4314 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800948e+00 ||r(i)||/||b|| 2.081619144607e-04
4315 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
4316 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
4317 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4318 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
4319 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4320 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4321 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4322 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800945e+00 ||r(i)||/||b|| 2.081619144606e-04
4323 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
4324 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4325 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800951e+00 ||r(i)||/||b|| 2.081619144608e-04
4326 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800947e+00 ||r(i)||/||b|| 2.081619144607e-04
4327 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800947e+00 ||r(i)||/||b|| 2.081619144607e-04
4328 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800946e+00 ||r(i)||/||b|| 2.081619144607e-04
4329 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
4330 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
4331 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
4332 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
4333 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
4334 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4335 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4336 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
4337 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
4338 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144607e-04
4339 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4340 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
4341 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800946e+00 ||r(i)||/||b|| 2.081619144607e-04
4342 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800948e+00 ||r(i)||/||b|| 2.081619144607e-04
4343 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4344 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
4345 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4346 KSP unpreconditioned resid norm 8.712485800959e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
4347 KSP unpreconditioned resid norm 8.712485800959e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4348 KSP unpreconditioned resid norm 8.712485800959e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
4349 KSP unpreconditioned resid norm 8.712485800959e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4350 KSP unpreconditioned resid norm 8.712485800954e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4351 KSP unpreconditioned resid norm 8.712485800954e+00 true resid norm 8.712485800966e+00 ||r(i)||/||b|| 2.081619144611e-04
4352 KSP unpreconditioned resid norm 8.712485800954e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
4353 KSP unpreconditioned resid norm 8.712485800954e+00 true resid norm 8.712485800947e+00 ||r(i)||/||b|| 2.081619144607e-04
4354 KSP unpreconditioned resid norm 8.712485800954e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
4355 KSP unpreconditioned resid norm 8.712485800954e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4356 KSP unpreconditioned resid norm 8.712485800954e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4357 KSP unpreconditioned resid norm 8.712485800954e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
4358 KSP unpreconditioned resid norm 8.712485800954e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144607e-04
4359 KSP unpreconditioned resid norm 8.712485800954e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144609e-04
4360 KSP unpreconditioned resid norm 8.712485800954e+00 true resid norm 8.712485800942e+00 ||r(i)||/||b|| 2.081619144606e-04
4361 KSP unpreconditioned resid norm 8.712485800954e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4362 KSP unpreconditioned resid norm 8.712485800954e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
4363 KSP unpreconditioned resid norm 8.712485800954e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4364 KSP unpreconditioned resid norm 8.712485800954e+00 true resid norm 8.712485800948e+00 ||r(i)||/||b|| 2.081619144607e-04
4365 KSP unpreconditioned resid norm 8.712485800954e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4366 KSP unpreconditioned resid norm 8.712485800954e+00 true resid norm 8.712485800948e+00 ||r(i)||/||b|| 2.081619144607e-04
4367 KSP unpreconditioned resid norm 8.712485800954e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
4368 KSP unpreconditioned resid norm 8.712485800954e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
4369 KSP unpreconditioned resid norm 8.712485800954e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
4370 KSP unpreconditioned resid norm 8.712485800954e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
4371 KSP unpreconditioned resid norm 8.712485800954e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4372 KSP unpreconditioned resid norm 8.712485800954e+00 true resid norm 8.712485800951e+00 ||r(i)||/||b|| 2.081619144608e-04
4373 KSP unpreconditioned resid norm 8.712485800954e+00 true resid norm 8.712485800948e+00 ||r(i)||/||b|| 2.081619144607e-04
4374 KSP unpreconditioned resid norm 8.712485800954e+00 true resid norm 8.712485800951e+00 ||r(i)||/||b|| 2.081619144608e-04
4375 KSP unpreconditioned resid norm 8.712485800954e+00 true resid norm 8.712485800946e+00 ||r(i)||/||b|| 2.081619144607e-04
4376 KSP unpreconditioned resid norm 8.712485800954e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
4377 KSP unpreconditioned resid norm 8.712485800954e+00 true resid norm 8.712485800951e+00 ||r(i)||/||b|| 2.081619144608e-04
4378 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
4379 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800951e+00 ||r(i)||/||b|| 2.081619144608e-04
4380 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
4381 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4382 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144607e-04
4383 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800947e+00 ||r(i)||/||b|| 2.081619144607e-04
4384 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800946e+00 ||r(i)||/||b|| 2.081619144607e-04
4385 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4386 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800946e+00 ||r(i)||/||b|| 2.081619144607e-04
4387 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4388 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800946e+00 ||r(i)||/||b|| 2.081619144607e-04
4389 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800945e+00 ||r(i)||/||b|| 2.081619144607e-04
4390 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800947e+00 ||r(i)||/||b|| 2.081619144607e-04
4391 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
4392 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800951e+00 ||r(i)||/||b|| 2.081619144608e-04
4393 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
4394 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
4395 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
4396 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
4397 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800946e+00 ||r(i)||/||b|| 2.081619144607e-04
4398 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4399 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800944e+00 ||r(i)||/||b|| 2.081619144606e-04
4400 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800948e+00 ||r(i)||/||b|| 2.081619144607e-04
4401 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800942e+00 ||r(i)||/||b|| 2.081619144606e-04
4402 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
4403 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144607e-04
4404 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
4405 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800951e+00 ||r(i)||/||b|| 2.081619144608e-04
4406 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800947e+00 ||r(i)||/||b|| 2.081619144607e-04
4407 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4408 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
4409 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
4410 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
4411 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4412 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
4413 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
4414 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
4415 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4416 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
4417 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800948e+00 ||r(i)||/||b|| 2.081619144607e-04
4418 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800951e+00 ||r(i)||/||b|| 2.081619144608e-04
4419 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144607e-04
4420 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800951e+00 ||r(i)||/||b|| 2.081619144608e-04
4421 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
4422 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4423 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
4424 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144607e-04
4425 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
4426 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4427 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800946e+00 ||r(i)||/||b|| 2.081619144607e-04
4428 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4429 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
4430 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
4431 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800951e+00 ||r(i)||/||b|| 2.081619144608e-04
4432 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800947e+00 ||r(i)||/||b|| 2.081619144607e-04
4433 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
4434 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4435 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144607e-04
4436 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4437 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
4438 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
4439 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800948e+00 ||r(i)||/||b|| 2.081619144607e-04
4440 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4441 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4442 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4443 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
4444 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
4445 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4446 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800951e+00 ||r(i)||/||b|| 2.081619144608e-04
4447 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800943e+00 ||r(i)||/||b|| 2.081619144606e-04
4448 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800947e+00 ||r(i)||/||b|| 2.081619144607e-04
4449 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
4450 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
4451 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4452 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144607e-04
4453 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4454 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
4455 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800964e+00 ||r(i)||/||b|| 2.081619144611e-04
4456 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4457 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4458 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144607e-04
4459 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800951e+00 ||r(i)||/||b|| 2.081619144608e-04
4460 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800947e+00 ||r(i)||/||b|| 2.081619144607e-04
4461 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
4462 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4463 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
4464 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4465 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4466 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
4467 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
4468 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4469 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
4470 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4471 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800970e+00 ||r(i)||/||b|| 2.081619144612e-04
4472 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800948e+00 ||r(i)||/||b|| 2.081619144607e-04
4473 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
4474 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
4475 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800947e+00 ||r(i)||/||b|| 2.081619144607e-04
4476 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
4477 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4478 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
4479 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4480 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4481 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
4482 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4483 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4484 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
4485 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
4486 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144607e-04
4487 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800943e+00 ||r(i)||/||b|| 2.081619144606e-04
4488 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4489 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
4490 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
4491 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
4492 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
4493 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4494 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144607e-04
4495 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
4496 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4497 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4498 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800948e+00 ||r(i)||/||b|| 2.081619144607e-04
4499 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800951e+00 ||r(i)||/||b|| 2.081619144608e-04
4500 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
4501 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4502 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
4503 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
4504 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800964e+00 ||r(i)||/||b|| 2.081619144611e-04
4505 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4506 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4507 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
4508 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4509 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
4510 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
4511 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
4512 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4513 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
4514 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
4515 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
4516 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
4517 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4518 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
4519 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
4520 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
4521 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
4522 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
4523 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
4524 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
4525 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
4526 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4527 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4528 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
4529 KSP unpreconditioned resid norm 8.712485800961e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
4530 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144609e-04
4531 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800945e+00 ||r(i)||/||b|| 2.081619144607e-04
4532 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4533 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
4534 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4535 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4536 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4537 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4538 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
4539 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800947e+00 ||r(i)||/||b|| 2.081619144607e-04
4540 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800966e+00 ||r(i)||/||b|| 2.081619144611e-04
4541 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4542 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4543 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4544 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
4545 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
4546 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
4547 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
4548 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
4549 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
4550 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
4551 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800971e+00 ||r(i)||/||b|| 2.081619144613e-04
4552 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
4553 KSP unpreconditioned resid norm 8.712485800958e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
4554 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4555 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
4556 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
4557 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
4558 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4559 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
4560 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4561 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
4562 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800964e+00 ||r(i)||/||b|| 2.081619144611e-04
4563 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
4564 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800964e+00 ||r(i)||/||b|| 2.081619144611e-04
4565 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4566 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
4567 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800964e+00 ||r(i)||/||b|| 2.081619144611e-04
4568 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4569 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800977e+00 ||r(i)||/||b|| 2.081619144614e-04
4570 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
4571 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
4572 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800976e+00 ||r(i)||/||b|| 2.081619144614e-04
4573 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
4574 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800966e+00 ||r(i)||/||b|| 2.081619144611e-04
4575 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800971e+00 ||r(i)||/||b|| 2.081619144613e-04
4576 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
4577 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4578 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
4579 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
4580 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800964e+00 ||r(i)||/||b|| 2.081619144611e-04
4581 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800977e+00 ||r(i)||/||b|| 2.081619144614e-04
4582 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800972e+00 ||r(i)||/||b|| 2.081619144613e-04
4583 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4584 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800971e+00 ||r(i)||/||b|| 2.081619144613e-04
4585 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
4586 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4587 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
4588 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
4589 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
4590 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
4591 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
4592 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
4593 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
4594 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800971e+00 ||r(i)||/||b|| 2.081619144613e-04
4595 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
4596 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
4597 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4598 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4599 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800972e+00 ||r(i)||/||b|| 2.081619144613e-04
4600 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4601 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
4602 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800966e+00 ||r(i)||/||b|| 2.081619144612e-04
4603 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4604 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800964e+00 ||r(i)||/||b|| 2.081619144611e-04
4605 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4606 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
4607 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
4608 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
4609 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800966e+00 ||r(i)||/||b|| 2.081619144611e-04
4610 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
4611 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4612 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
4613 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
4614 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
4615 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4616 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
4617 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
4618 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
4619 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
4620 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4621 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4622 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4623 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4624 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
4625 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
4626 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4627 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
4628 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
4629 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
4630 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
4631 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
4632 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
4633 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4634 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
4635 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800972e+00 ||r(i)||/||b|| 2.081619144613e-04
4636 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
4637 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
4638 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
4639 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
4640 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
4641 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
4642 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
4643 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4644 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
4645 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
4646 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4647 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800966e+00 ||r(i)||/||b|| 2.081619144611e-04
4648 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
4649 KSP unpreconditioned resid norm 8.712485800960e+00 true resid norm 8.712485800972e+00 ||r(i)||/||b|| 2.081619144613e-04
4650 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800951e+00 ||r(i)||/||b|| 2.081619144608e-04
4651 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800944e+00 ||r(i)||/||b|| 2.081619144606e-04
4652 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
4653 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800947e+00 ||r(i)||/||b|| 2.081619144607e-04
4654 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
4655 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800943e+00 ||r(i)||/||b|| 2.081619144606e-04
4656 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4657 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4658 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
4659 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144608e-04
4660 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4661 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4662 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4663 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4664 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4665 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4666 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4667 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
4668 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4669 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
4670 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800947e+00 ||r(i)||/||b|| 2.081619144607e-04
4671 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4672 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800948e+00 ||r(i)||/||b|| 2.081619144607e-04
4673 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
4674 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800964e+00 ||r(i)||/||b|| 2.081619144611e-04
4675 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
4676 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
4677 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4678 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800947e+00 ||r(i)||/||b|| 2.081619144607e-04
4679 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144609e-04
4680 KSP unpreconditioned resid norm 8.712485800947e+00 true resid norm 8.712485800947e+00 ||r(i)||/||b|| 2.081619144607e-04
4681 KSP unpreconditioned resid norm 8.712485800947e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4682 KSP unpreconditioned resid norm 8.712485800947e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
4683 KSP unpreconditioned resid norm 8.712485800947e+00 true resid norm 8.712485800939e+00 ||r(i)||/||b|| 2.081619144605e-04
4684 KSP unpreconditioned resid norm 8.712485800947e+00 true resid norm 8.712485800941e+00 ||r(i)||/||b|| 2.081619144605e-04
4685 KSP unpreconditioned resid norm 8.712485800947e+00 true resid norm 8.712485800948e+00 ||r(i)||/||b|| 2.081619144607e-04
4686 KSP unpreconditioned resid norm 8.712485800947e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
4687 KSP unpreconditioned resid norm 8.712485800947e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
4688 KSP unpreconditioned resid norm 8.712485800947e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
4689 KSP unpreconditioned resid norm 8.712485800947e+00 true resid norm 8.712485800948e+00 ||r(i)||/||b|| 2.081619144607e-04
4690 KSP unpreconditioned resid norm 8.712485800947e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
4691 KSP unpreconditioned resid norm 8.712485800947e+00 true resid norm 8.712485800948e+00 ||r(i)||/||b|| 2.081619144607e-04
4692 KSP unpreconditioned resid norm 8.712485800947e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
4693 KSP unpreconditioned resid norm 8.712485800947e+00 true resid norm 8.712485800951e+00 ||r(i)||/||b|| 2.081619144608e-04
4694 KSP unpreconditioned resid norm 8.712485800947e+00 true resid norm 8.712485800944e+00 ||r(i)||/||b|| 2.081619144606e-04
4695 KSP unpreconditioned resid norm 8.712485800947e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
4696 KSP unpreconditioned resid norm 8.712485800947e+00 true resid norm 8.712485800941e+00 ||r(i)||/||b|| 2.081619144606e-04
4697 KSP unpreconditioned resid norm 8.712485800947e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
4698 KSP unpreconditioned resid norm 8.712485800947e+00 true resid norm 8.712485800935e+00 ||r(i)||/||b|| 2.081619144604e-04
4699 KSP unpreconditioned resid norm 8.712485800947e+00 true resid norm 8.712485800940e+00 ||r(i)||/||b|| 2.081619144605e-04
4700 KSP unpreconditioned resid norm 8.712485800947e+00 true resid norm 8.712485800951e+00 ||r(i)||/||b|| 2.081619144608e-04
4701 KSP unpreconditioned resid norm 8.712485800947e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144608e-04
4702 KSP unpreconditioned resid norm 8.712485800947e+00 true resid norm 8.712485800945e+00 ||r(i)||/||b|| 2.081619144607e-04
4703 KSP unpreconditioned resid norm 8.712485800947e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
4704 KSP unpreconditioned resid norm 8.712485800947e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4705 KSP unpreconditioned resid norm 8.712485800947e+00 true resid norm 8.712485800939e+00 ||r(i)||/||b|| 2.081619144605e-04
4706 KSP unpreconditioned resid norm 8.712485800947e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
4707 KSP unpreconditioned resid norm 8.712485800947e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
4708 KSP unpreconditioned resid norm 8.712485800947e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144607e-04
4709 KSP unpreconditioned resid norm 8.712485800947e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
4710 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800951e+00 ||r(i)||/||b|| 2.081619144608e-04
4711 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800945e+00 ||r(i)||/||b|| 2.081619144606e-04
4712 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800946e+00 ||r(i)||/||b|| 2.081619144607e-04
4713 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
4714 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800945e+00 ||r(i)||/||b|| 2.081619144606e-04
4715 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4716 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4717 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800942e+00 ||r(i)||/||b|| 2.081619144606e-04
4718 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4719 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4720 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4721 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
4722 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800948e+00 ||r(i)||/||b|| 2.081619144607e-04
4723 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144609e-04
4724 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800948e+00 ||r(i)||/||b|| 2.081619144607e-04
4725 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
4726 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4727 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4728 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800951e+00 ||r(i)||/||b|| 2.081619144608e-04
4729 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800951e+00 ||r(i)||/||b|| 2.081619144608e-04
4730 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800946e+00 ||r(i)||/||b|| 2.081619144607e-04
4731 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144607e-04
4732 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800946e+00 ||r(i)||/||b|| 2.081619144607e-04
4733 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144607e-04
4734 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4735 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4736 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4737 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4738 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800945e+00 ||r(i)||/||b|| 2.081619144606e-04
4739 KSP unpreconditioned resid norm 8.712485800950e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
4740 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
4741 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4742 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800964e+00 ||r(i)||/||b|| 2.081619144611e-04
4743 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4744 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
4745 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800971e+00 ||r(i)||/||b|| 2.081619144613e-04
4746 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4747 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
4748 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
4749 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4750 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800972e+00 ||r(i)||/||b|| 2.081619144613e-04
4751 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
4752 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4753 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
4754 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
4755 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4756 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800946e+00 ||r(i)||/||b|| 2.081619144607e-04
4757 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
4758 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4759 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4760 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4761 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4762 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4763 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
4764 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
4765 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
4766 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4767 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4768 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
4769 KSP unpreconditioned resid norm 8.712485800965e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
4770 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
4771 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
4772 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4773 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800966e+00 ||r(i)||/||b|| 2.081619144611e-04
4774 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4775 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4776 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
4777 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4778 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
4779 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
4780 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
4781 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
4782 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
4783 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4784 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
4785 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
4786 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
4787 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
4788 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800945e+00 ||r(i)||/||b|| 2.081619144607e-04
4789 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4790 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
4791 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
4792 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4793 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4794 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800951e+00 ||r(i)||/||b|| 2.081619144608e-04
4795 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4796 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4797 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
4798 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
4799 KSP unpreconditioned resid norm 8.712485800963e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
4800 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
4801 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
4802 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
4803 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
4804 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
4805 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800964e+00 ||r(i)||/||b|| 2.081619144611e-04
4806 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
4807 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
4808 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4809 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
4810 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4811 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
4812 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800948e+00 ||r(i)||/||b|| 2.081619144607e-04
4813 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
4814 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4815 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
4816 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4817 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4818 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144609e-04
4819 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
4820 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
4821 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
4822 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
4823 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4824 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4825 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
4826 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
4827 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4828 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
4829 KSP unpreconditioned resid norm 8.712485800953e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
4830 KSP unpreconditioned resid norm 8.712485800945e+00 true resid norm 8.712485800945e+00 ||r(i)||/||b|| 2.081619144606e-04
4831 KSP unpreconditioned resid norm 8.712485800945e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4832 KSP unpreconditioned resid norm 8.712485800945e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
4833 KSP unpreconditioned resid norm 8.712485800945e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4834 KSP unpreconditioned resid norm 8.712485800945e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144608e-04
4835 KSP unpreconditioned resid norm 8.712485800945e+00 true resid norm 8.712485800951e+00 ||r(i)||/||b|| 2.081619144608e-04
4836 KSP unpreconditioned resid norm 8.712485800945e+00 true resid norm 8.712485800947e+00 ||r(i)||/||b|| 2.081619144607e-04
4837 KSP unpreconditioned resid norm 8.712485800945e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4838 KSP unpreconditioned resid norm 8.712485800945e+00 true resid norm 8.712485800945e+00 ||r(i)||/||b|| 2.081619144607e-04
4839 KSP unpreconditioned resid norm 8.712485800945e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
4840 KSP unpreconditioned resid norm 8.712485800945e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
4841 KSP unpreconditioned resid norm 8.712485800945e+00 true resid norm 8.712485800944e+00 ||r(i)||/||b|| 2.081619144606e-04
4842 KSP unpreconditioned resid norm 8.712485800945e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
4843 KSP unpreconditioned resid norm 8.712485800945e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4844 KSP unpreconditioned resid norm 8.712485800945e+00 true resid norm 8.712485800944e+00 ||r(i)||/||b|| 2.081619144606e-04
4845 KSP unpreconditioned resid norm 8.712485800945e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
4846 KSP unpreconditioned resid norm 8.712485800945e+00 true resid norm 8.712485800946e+00 ||r(i)||/||b|| 2.081619144607e-04
4847 KSP unpreconditioned resid norm 8.712485800945e+00 true resid norm 8.712485800951e+00 ||r(i)||/||b|| 2.081619144608e-04
4848 KSP unpreconditioned resid norm 8.712485800945e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
4849 KSP unpreconditioned resid norm 8.712485800945e+00 true resid norm 8.712485800937e+00 ||r(i)||/||b|| 2.081619144605e-04
4850 KSP unpreconditioned resid norm 8.712485800945e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
4851 KSP unpreconditioned resid norm 8.712485800945e+00 true resid norm 8.712485800951e+00 ||r(i)||/||b|| 2.081619144608e-04
4852 KSP unpreconditioned resid norm 8.712485800945e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
4853 KSP unpreconditioned resid norm 8.712485800944e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
4854 KSP unpreconditioned resid norm 8.712485800944e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4855 KSP unpreconditioned resid norm 8.712485800944e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4856 KSP unpreconditioned resid norm 8.712485800944e+00 true resid norm 8.712485800946e+00 ||r(i)||/||b|| 2.081619144607e-04
4857 KSP unpreconditioned resid norm 8.712485800944e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
4858 KSP unpreconditioned resid norm 8.712485800944e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144607e-04
4859 KSP unpreconditioned resid norm 8.712485800944e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
4860 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
4861 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
4862 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800951e+00 ||r(i)||/||b|| 2.081619144608e-04
4863 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144607e-04
4864 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800948e+00 ||r(i)||/||b|| 2.081619144607e-04
4865 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800951e+00 ||r(i)||/||b|| 2.081619144608e-04
4866 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800938e+00 ||r(i)||/||b|| 2.081619144605e-04
4867 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800948e+00 ||r(i)||/||b|| 2.081619144607e-04
4868 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800964e+00 ||r(i)||/||b|| 2.081619144611e-04
4869 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
4870 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4871 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
4872 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4873 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4874 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4875 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4876 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
4877 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800946e+00 ||r(i)||/||b|| 2.081619144607e-04
4878 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
4879 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
4880 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800951e+00 ||r(i)||/||b|| 2.081619144608e-04
4881 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
4882 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800942e+00 ||r(i)||/||b|| 2.081619144606e-04
4883 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
4884 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
4885 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
4886 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800945e+00 ||r(i)||/||b|| 2.081619144606e-04
4887 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
4888 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
4889 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4890 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4891 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4892 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800970e+00 ||r(i)||/||b|| 2.081619144612e-04
4893 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4894 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4895 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800964e+00 ||r(i)||/||b|| 2.081619144611e-04
4896 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
4897 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
4898 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800951e+00 ||r(i)||/||b|| 2.081619144608e-04
4899 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4900 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800972e+00 ||r(i)||/||b|| 2.081619144613e-04
4901 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
4902 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144607e-04
4903 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
4904 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4905 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4906 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
4907 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800951e+00 ||r(i)||/||b|| 2.081619144608e-04
4908 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4909 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
4910 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
4911 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
4912 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4913 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4914 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800964e+00 ||r(i)||/||b|| 2.081619144611e-04
4915 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4916 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
4917 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4918 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
4919 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800964e+00 ||r(i)||/||b|| 2.081619144611e-04
4920 KSP unpreconditioned resid norm 8.712485800964e+00 true resid norm 8.712485800964e+00 ||r(i)||/||b|| 2.081619144611e-04
4921 KSP unpreconditioned resid norm 8.712485800964e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
4922 KSP unpreconditioned resid norm 8.712485800964e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4923 KSP unpreconditioned resid norm 8.712485800964e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4924 KSP unpreconditioned resid norm 8.712485800964e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4925 KSP unpreconditioned resid norm 8.712485800964e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
4926 KSP unpreconditioned resid norm 8.712485800964e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
4927 KSP unpreconditioned resid norm 8.712485800964e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4928 KSP unpreconditioned resid norm 8.712485800964e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4929 KSP unpreconditioned resid norm 8.712485800964e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4930 KSP unpreconditioned resid norm 8.712485800964e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4931 KSP unpreconditioned resid norm 8.712485800964e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4932 KSP unpreconditioned resid norm 8.712485800964e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4933 KSP unpreconditioned resid norm 8.712485800964e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
4934 KSP unpreconditioned resid norm 8.712485800964e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4935 KSP unpreconditioned resid norm 8.712485800964e+00 true resid norm 8.712485800951e+00 ||r(i)||/||b|| 2.081619144608e-04
4936 KSP unpreconditioned resid norm 8.712485800964e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
4937 KSP unpreconditioned resid norm 8.712485800964e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4938 KSP unpreconditioned resid norm 8.712485800964e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4939 KSP unpreconditioned resid norm 8.712485800964e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4940 KSP unpreconditioned resid norm 8.712485800964e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4941 KSP unpreconditioned resid norm 8.712485800964e+00 true resid norm 8.712485800951e+00 ||r(i)||/||b|| 2.081619144608e-04
4942 KSP unpreconditioned resid norm 8.712485800964e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144607e-04
4943 KSP unpreconditioned resid norm 8.712485800964e+00 true resid norm 8.712485800964e+00 ||r(i)||/||b|| 2.081619144611e-04
4944 KSP unpreconditioned resid norm 8.712485800964e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
4945 KSP unpreconditioned resid norm 8.712485800964e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4946 KSP unpreconditioned resid norm 8.712485800964e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4947 KSP unpreconditioned resid norm 8.712485800964e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4948 KSP unpreconditioned resid norm 8.712485800964e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
4949 KSP unpreconditioned resid norm 8.712485800964e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
4950 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
4951 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4952 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4953 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4954 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800948e+00 ||r(i)||/||b|| 2.081619144607e-04
4955 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800970e+00 ||r(i)||/||b|| 2.081619144612e-04
4956 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4957 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
4958 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
4959 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
4960 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
4961 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4962 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
4963 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
4964 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
4965 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
4966 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
4967 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4968 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800971e+00 ||r(i)||/||b|| 2.081619144613e-04
4969 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
4970 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800964e+00 ||r(i)||/||b|| 2.081619144611e-04
4971 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4972 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
4973 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4974 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
4975 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
4976 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
4977 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
4978 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
4979 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
4980 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
4981 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800964e+00 ||r(i)||/||b|| 2.081619144611e-04
4982 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800951e+00 ||r(i)||/||b|| 2.081619144608e-04
4983 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800947e+00 ||r(i)||/||b|| 2.081619144607e-04
4984 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
4985 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
4986 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
4987 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
4988 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
4989 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
4990 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
4991 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
4992 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800947e+00 ||r(i)||/||b|| 2.081619144607e-04
4993 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
4994 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
4995 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4996 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800943e+00 ||r(i)||/||b|| 2.081619144606e-04
4997 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
4998 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144607e-04
4999 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800948e+00 ||r(i)||/||b|| 2.081619144607e-04
5000 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
5001 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
5002 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
5003 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800939e+00 ||r(i)||/||b|| 2.081619144605e-04
5004 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800948e+00 ||r(i)||/||b|| 2.081619144607e-04
5005 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800964e+00 ||r(i)||/||b|| 2.081619144611e-04
5006 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
5007 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
5008 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
5009 KSP unpreconditioned resid norm 8.712485800952e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
5010 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
5011 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
5012 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
5013 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800948e+00 ||r(i)||/||b|| 2.081619144607e-04
5014 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
5015 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
5016 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800946e+00 ||r(i)||/||b|| 2.081619144607e-04
5017 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
5018 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
5019 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
5020 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
5021 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
5022 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
5023 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
5024 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800946e+00 ||r(i)||/||b|| 2.081619144607e-04
5025 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800949e+00 ||r(i)||/||b|| 2.081619144607e-04
5026 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
5027 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800943e+00 ||r(i)||/||b|| 2.081619144606e-04
5028 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
5029 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800948e+00 ||r(i)||/||b|| 2.081619144607e-04
5030 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
5031 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800946e+00 ||r(i)||/||b|| 2.081619144607e-04
5032 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
5033 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800951e+00 ||r(i)||/||b|| 2.081619144608e-04
5034 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
5035 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800945e+00 ||r(i)||/||b|| 2.081619144606e-04
5036 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
5037 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
5038 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
5039 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
5040 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800951e+00 ||r(i)||/||b|| 2.081619144608e-04
5041 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800951e+00 ||r(i)||/||b|| 2.081619144608e-04
5042 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
5043 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
5044 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
5045 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800943e+00 ||r(i)||/||b|| 2.081619144606e-04
5046 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
5047 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800947e+00 ||r(i)||/||b|| 2.081619144607e-04
5048 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800947e+00 ||r(i)||/||b|| 2.081619144607e-04
5049 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800951e+00 ||r(i)||/||b|| 2.081619144608e-04
5050 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
5051 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
5052 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
5053 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
5054 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
5055 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800964e+00 ||r(i)||/||b|| 2.081619144611e-04
5056 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
5057 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
5058 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
5059 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800948e+00 ||r(i)||/||b|| 2.081619144607e-04
5060 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
5061 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
5062 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
5063 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
5064 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
5065 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
5066 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
5067 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
5068 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800945e+00 ||r(i)||/||b|| 2.081619144606e-04
5069 KSP unpreconditioned resid norm 8.712485800951e+00 true resid norm 8.712485800947e+00 ||r(i)||/||b|| 2.081619144607e-04
5070 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
5071 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
5072 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
5073 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
5074 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
5075 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
5076 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800964e+00 ||r(i)||/||b|| 2.081619144611e-04
5077 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
5078 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
5079 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
5080 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800947e+00 ||r(i)||/||b|| 2.081619144607e-04
5081 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
5082 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
5083 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800966e+00 ||r(i)||/||b|| 2.081619144612e-04
5084 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
5085 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
5086 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
5087 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
5088 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
5089 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800947e+00 ||r(i)||/||b|| 2.081619144607e-04
5090 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800951e+00 ||r(i)||/||b|| 2.081619144608e-04
5091 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
5092 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
5093 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
5094 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800945e+00 ||r(i)||/||b|| 2.081619144606e-04
5095 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
5096 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
5097 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800950e+00 ||r(i)||/||b|| 2.081619144608e-04
5098 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
5099 KSP unpreconditioned resid norm 8.712485800956e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
5100 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
5101 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
5102 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800956e+00 ||r(i)||/||b|| 2.081619144609e-04
5103 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
5104 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
5105 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
5106 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
5107 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
5108 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
5109 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
5110 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800966e+00 ||r(i)||/||b|| 2.081619144612e-04
5111 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
5112 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800964e+00 ||r(i)||/||b|| 2.081619144611e-04
5113 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
5114 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
5115 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800952e+00 ||r(i)||/||b|| 2.081619144608e-04
5116 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
5117 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800971e+00 ||r(i)||/||b|| 2.081619144613e-04
5118 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144608e-04
5119 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
5120 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
5121 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
5122 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
5123 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
5124 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
5125 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
5126 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
5127 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
5128 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800954e+00 ||r(i)||/||b|| 2.081619144609e-04
5129 KSP unpreconditioned resid norm 8.712485800957e+00 true resid norm 8.712485800958e+00 ||r(i)||/||b|| 2.081619144610e-04
5130 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
5131 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
5132 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
5133 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800966e+00 ||r(i)||/||b|| 2.081619144612e-04
5134 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800971e+00 ||r(i)||/||b|| 2.081619144613e-04
5135 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
5136 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
5137 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800955e+00 ||r(i)||/||b|| 2.081619144609e-04
5138 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144609e-04
5139 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
5140 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800964e+00 ||r(i)||/||b|| 2.081619144611e-04
5141 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
5142 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
5143 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
5144 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
5145 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
5146 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
5147 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800966e+00 ||r(i)||/||b|| 2.081619144611e-04
5148 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800966e+00 ||r(i)||/||b|| 2.081619144611e-04
5149 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800971e+00 ||r(i)||/||b|| 2.081619144613e-04
5150 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
5151 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
5152 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
5153 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800953e+00 ||r(i)||/||b|| 2.081619144609e-04
5154 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
5155 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
5156 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800970e+00 ||r(i)||/||b|| 2.081619144612e-04
5157 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
5158 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800957e+00 ||r(i)||/||b|| 2.081619144609e-04
5159 KSP unpreconditioned resid norm 8.712485800962e+00 true resid norm 8.712485800961e+00 ||r(i)||/||b|| 2.081619144610e-04
5160 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
5161 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
5162 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
5163 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
5164 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
5165 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800972e+00 ||r(i)||/||b|| 2.081619144613e-04
5166 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
5167 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
5168 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
5169 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
5170 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
5171 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
5172 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800976e+00 ||r(i)||/||b|| 2.081619144614e-04
5173 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800971e+00 ||r(i)||/||b|| 2.081619144613e-04
5174 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800972e+00 ||r(i)||/||b|| 2.081619144613e-04
5175 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800977e+00 ||r(i)||/||b|| 2.081619144614e-04
5176 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800971e+00 ||r(i)||/||b|| 2.081619144613e-04
5177 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
5178 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
5179 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
5180 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
5181 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800966e+00 ||r(i)||/||b|| 2.081619144612e-04
5182 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
5183 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800964e+00 ||r(i)||/||b|| 2.081619144611e-04
5184 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800970e+00 ||r(i)||/||b|| 2.081619144612e-04
5185 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
5186 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
5187 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
5188 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
5189 KSP unpreconditioned resid norm 8.712485800975e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
5190 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
5191 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
5192 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144611e-04
5193 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
5194 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800964e+00 ||r(i)||/||b|| 2.081619144611e-04
5195 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800984e+00 ||r(i)||/||b|| 2.081619144616e-04
5196 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
5197 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
5198 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800977e+00 ||r(i)||/||b|| 2.081619144614e-04
5199 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800970e+00 ||r(i)||/||b|| 2.081619144612e-04
5200 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800964e+00 ||r(i)||/||b|| 2.081619144611e-04
5201 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800962e+00 ||r(i)||/||b|| 2.081619144610e-04
5202 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
5203 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
5204 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800977e+00 ||r(i)||/||b|| 2.081619144614e-04
5205 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
5206 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
5207 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
5208 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800972e+00 ||r(i)||/||b|| 2.081619144613e-04
5209 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800964e+00 ||r(i)||/||b|| 2.081619144611e-04
5210 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
5211 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800959e+00 ||r(i)||/||b|| 2.081619144610e-04
5212 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
5213 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800966e+00 ||r(i)||/||b|| 2.081619144612e-04
5214 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800966e+00 ||r(i)||/||b|| 2.081619144612e-04
5215 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800960e+00 ||r(i)||/||b|| 2.081619144610e-04
5216 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144614e-04
5217 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
5218 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800966e+00 ||r(i)||/||b|| 2.081619144612e-04
5219 KSP unpreconditioned resid norm 8.712485800968e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
5220 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5221 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
5222 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
5223 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800976e+00 ||r(i)||/||b|| 2.081619144614e-04
5224 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800966e+00 ||r(i)||/||b|| 2.081619144612e-04
5225 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800983e+00 ||r(i)||/||b|| 2.081619144616e-04
5226 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
5227 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800970e+00 ||r(i)||/||b|| 2.081619144612e-04
5228 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800983e+00 ||r(i)||/||b|| 2.081619144616e-04
5229 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
5230 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
5231 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800963e+00 ||r(i)||/||b|| 2.081619144611e-04
5232 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
5233 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800977e+00 ||r(i)||/||b|| 2.081619144614e-04
5234 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800978e+00 ||r(i)||/||b|| 2.081619144614e-04
5235 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800977e+00 ||r(i)||/||b|| 2.081619144614e-04
5236 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
5237 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800972e+00 ||r(i)||/||b|| 2.081619144613e-04
5238 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800965e+00 ||r(i)||/||b|| 2.081619144611e-04
5239 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800966e+00 ||r(i)||/||b|| 2.081619144612e-04
5240 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5241 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800971e+00 ||r(i)||/||b|| 2.081619144613e-04
5242 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800970e+00 ||r(i)||/||b|| 2.081619144612e-04
5243 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800976e+00 ||r(i)||/||b|| 2.081619144614e-04
5244 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800971e+00 ||r(i)||/||b|| 2.081619144613e-04
5245 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800964e+00 ||r(i)||/||b|| 2.081619144611e-04
5246 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
5247 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
5248 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800972e+00 ||r(i)||/||b|| 2.081619144613e-04
5249 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
5250 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
5251 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
5252 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
5253 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800972e+00 ||r(i)||/||b|| 2.081619144613e-04
5254 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800970e+00 ||r(i)||/||b|| 2.081619144612e-04
5255 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800978e+00 ||r(i)||/||b|| 2.081619144614e-04
5256 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
5257 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
5258 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800977e+00 ||r(i)||/||b|| 2.081619144614e-04
5259 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800982e+00 ||r(i)||/||b|| 2.081619144615e-04
5260 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800970e+00 ||r(i)||/||b|| 2.081619144612e-04
5261 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5262 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800985e+00 ||r(i)||/||b|| 2.081619144616e-04
5263 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800977e+00 ||r(i)||/||b|| 2.081619144614e-04
5264 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800983e+00 ||r(i)||/||b|| 2.081619144616e-04
5265 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800971e+00 ||r(i)||/||b|| 2.081619144613e-04
5266 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800972e+00 ||r(i)||/||b|| 2.081619144613e-04
5267 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800971e+00 ||r(i)||/||b|| 2.081619144613e-04
5268 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800978e+00 ||r(i)||/||b|| 2.081619144614e-04
5269 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800982e+00 ||r(i)||/||b|| 2.081619144615e-04
5270 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
5271 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800971e+00 ||r(i)||/||b|| 2.081619144613e-04
5272 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800978e+00 ||r(i)||/||b|| 2.081619144614e-04
5273 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800979e+00 ||r(i)||/||b|| 2.081619144615e-04
5274 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800977e+00 ||r(i)||/||b|| 2.081619144614e-04
5275 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800979e+00 ||r(i)||/||b|| 2.081619144615e-04
5276 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
5277 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
5278 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800982e+00 ||r(i)||/||b|| 2.081619144615e-04
5279 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
5280 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
5281 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
5282 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
5283 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800982e+00 ||r(i)||/||b|| 2.081619144615e-04
5284 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800978e+00 ||r(i)||/||b|| 2.081619144614e-04
5285 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800983e+00 ||r(i)||/||b|| 2.081619144616e-04
5286 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
5287 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
5288 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800984e+00 ||r(i)||/||b|| 2.081619144616e-04
5289 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800990e+00 ||r(i)||/||b|| 2.081619144617e-04
5290 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800985e+00 ||r(i)||/||b|| 2.081619144616e-04
5291 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5292 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
5293 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800984e+00 ||r(i)||/||b|| 2.081619144616e-04
5294 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800983e+00 ||r(i)||/||b|| 2.081619144616e-04
5295 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800978e+00 ||r(i)||/||b|| 2.081619144614e-04
5296 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800970e+00 ||r(i)||/||b|| 2.081619144613e-04
5297 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800990e+00 ||r(i)||/||b|| 2.081619144617e-04
5298 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800982e+00 ||r(i)||/||b|| 2.081619144615e-04
5299 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800984e+00 ||r(i)||/||b|| 2.081619144616e-04
5300 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5301 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800995e+00 ||r(i)||/||b|| 2.081619144618e-04
5302 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800976e+00 ||r(i)||/||b|| 2.081619144614e-04
5303 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
5304 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800984e+00 ||r(i)||/||b|| 2.081619144616e-04
5305 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
5306 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
5307 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800984e+00 ||r(i)||/||b|| 2.081619144616e-04
5308 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5309 KSP unpreconditioned resid norm 8.712485800987e+00 true resid norm 8.712485800985e+00 ||r(i)||/||b|| 2.081619144616e-04
5310 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
5311 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5312 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5313 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800985e+00 ||r(i)||/||b|| 2.081619144616e-04
5314 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800982e+00 ||r(i)||/||b|| 2.081619144615e-04
5315 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800984e+00 ||r(i)||/||b|| 2.081619144616e-04
5316 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
5317 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800985e+00 ||r(i)||/||b|| 2.081619144616e-04
5318 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800976e+00 ||r(i)||/||b|| 2.081619144614e-04
5319 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800982e+00 ||r(i)||/||b|| 2.081619144615e-04
5320 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800982e+00 ||r(i)||/||b|| 2.081619144615e-04
5321 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800985e+00 ||r(i)||/||b|| 2.081619144616e-04
5322 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
5323 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800982e+00 ||r(i)||/||b|| 2.081619144615e-04
5324 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800989e+00 ||r(i)||/||b|| 2.081619144617e-04
5325 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800971e+00 ||r(i)||/||b|| 2.081619144613e-04
5326 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800984e+00 ||r(i)||/||b|| 2.081619144616e-04
5327 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800970e+00 ||r(i)||/||b|| 2.081619144613e-04
5328 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800978e+00 ||r(i)||/||b|| 2.081619144614e-04
5329 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800982e+00 ||r(i)||/||b|| 2.081619144615e-04
5330 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
5331 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800984e+00 ||r(i)||/||b|| 2.081619144616e-04
5332 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800978e+00 ||r(i)||/||b|| 2.081619144614e-04
5333 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
5334 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800976e+00 ||r(i)||/||b|| 2.081619144614e-04
5335 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
5336 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800985e+00 ||r(i)||/||b|| 2.081619144616e-04
5337 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800983e+00 ||r(i)||/||b|| 2.081619144616e-04
5338 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5339 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
5340 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
5341 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
5342 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
5343 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
5344 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800985e+00 ||r(i)||/||b|| 2.081619144616e-04
5345 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800976e+00 ||r(i)||/||b|| 2.081619144614e-04
5346 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
5347 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
5348 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800984e+00 ||r(i)||/||b|| 2.081619144616e-04
5349 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800984e+00 ||r(i)||/||b|| 2.081619144616e-04
5350 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800985e+00 ||r(i)||/||b|| 2.081619144616e-04
5351 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
5352 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
5353 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800978e+00 ||r(i)||/||b|| 2.081619144614e-04
5354 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800977e+00 ||r(i)||/||b|| 2.081619144614e-04
5355 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800977e+00 ||r(i)||/||b|| 2.081619144614e-04
5356 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800982e+00 ||r(i)||/||b|| 2.081619144615e-04
5357 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800990e+00 ||r(i)||/||b|| 2.081619144617e-04
5358 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800988e+00 ||r(i)||/||b|| 2.081619144617e-04
5359 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800979e+00 ||r(i)||/||b|| 2.081619144615e-04
5360 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
5361 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800976e+00 ||r(i)||/||b|| 2.081619144614e-04
5362 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800989e+00 ||r(i)||/||b|| 2.081619144617e-04
5363 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5364 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800991e+00 ||r(i)||/||b|| 2.081619144617e-04
5365 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
5366 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800988e+00 ||r(i)||/||b|| 2.081619144617e-04
5367 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800970e+00 ||r(i)||/||b|| 2.081619144612e-04
5368 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800976e+00 ||r(i)||/||b|| 2.081619144614e-04
5369 KSP unpreconditioned resid norm 8.712485800986e+00 true resid norm 8.712485800979e+00 ||r(i)||/||b|| 2.081619144615e-04
5370 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5371 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5372 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5373 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800967e+00 ||r(i)||/||b|| 2.081619144612e-04
5374 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
5375 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800984e+00 ||r(i)||/||b|| 2.081619144616e-04
5376 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
5377 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800979e+00 ||r(i)||/||b|| 2.081619144615e-04
5378 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800976e+00 ||r(i)||/||b|| 2.081619144614e-04
5379 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800971e+00 ||r(i)||/||b|| 2.081619144613e-04
5380 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800982e+00 ||r(i)||/||b|| 2.081619144615e-04
5381 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
5382 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800979e+00 ||r(i)||/||b|| 2.081619144615e-04
5383 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800976e+00 ||r(i)||/||b|| 2.081619144614e-04
5384 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800972e+00 ||r(i)||/||b|| 2.081619144613e-04
5385 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800976e+00 ||r(i)||/||b|| 2.081619144614e-04
5386 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800972e+00 ||r(i)||/||b|| 2.081619144613e-04
5387 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800976e+00 ||r(i)||/||b|| 2.081619144614e-04
5388 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800978e+00 ||r(i)||/||b|| 2.081619144614e-04
5389 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
5390 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5391 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800984e+00 ||r(i)||/||b|| 2.081619144616e-04
5392 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800983e+00 ||r(i)||/||b|| 2.081619144616e-04
5393 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
5394 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
5395 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
5396 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800978e+00 ||r(i)||/||b|| 2.081619144614e-04
5397 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800979e+00 ||r(i)||/||b|| 2.081619144615e-04
5398 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800977e+00 ||r(i)||/||b|| 2.081619144614e-04
5399 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800982e+00 ||r(i)||/||b|| 2.081619144615e-04
5400 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5401 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
5402 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5403 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800982e+00 ||r(i)||/||b|| 2.081619144615e-04
5404 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800985e+00 ||r(i)||/||b|| 2.081619144616e-04
5405 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800977e+00 ||r(i)||/||b|| 2.081619144614e-04
5406 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5407 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
5408 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800985e+00 ||r(i)||/||b|| 2.081619144616e-04
5409 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800984e+00 ||r(i)||/||b|| 2.081619144616e-04
5410 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800979e+00 ||r(i)||/||b|| 2.081619144615e-04
5411 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
5412 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
5413 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
5414 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800989e+00 ||r(i)||/||b|| 2.081619144617e-04
5415 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800990e+00 ||r(i)||/||b|| 2.081619144617e-04
5416 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800982e+00 ||r(i)||/||b|| 2.081619144615e-04
5417 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800984e+00 ||r(i)||/||b|| 2.081619144616e-04
5418 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800994e+00 ||r(i)||/||b|| 2.081619144618e-04
5419 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800985e+00 ||r(i)||/||b|| 2.081619144616e-04
5420 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
5421 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800982e+00 ||r(i)||/||b|| 2.081619144615e-04
5422 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800983e+00 ||r(i)||/||b|| 2.081619144616e-04
5423 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800979e+00 ||r(i)||/||b|| 2.081619144615e-04
5424 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
5425 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800992e+00 ||r(i)||/||b|| 2.081619144618e-04
5426 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800976e+00 ||r(i)||/||b|| 2.081619144614e-04
5427 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
5428 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800978e+00 ||r(i)||/||b|| 2.081619144614e-04
5429 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800978e+00 ||r(i)||/||b|| 2.081619144614e-04
5430 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5431 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5432 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
5433 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800979e+00 ||r(i)||/||b|| 2.081619144615e-04
5434 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
5435 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800985e+00 ||r(i)||/||b|| 2.081619144616e-04
5436 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
5437 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800979e+00 ||r(i)||/||b|| 2.081619144615e-04
5438 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800994e+00 ||r(i)||/||b|| 2.081619144618e-04
5439 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800983e+00 ||r(i)||/||b|| 2.081619144616e-04
5440 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
5441 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
5442 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
5443 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800982e+00 ||r(i)||/||b|| 2.081619144615e-04
5444 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800978e+00 ||r(i)||/||b|| 2.081619144614e-04
5445 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800976e+00 ||r(i)||/||b|| 2.081619144614e-04
5446 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800978e+00 ||r(i)||/||b|| 2.081619144614e-04
5447 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800982e+00 ||r(i)||/||b|| 2.081619144615e-04
5448 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800979e+00 ||r(i)||/||b|| 2.081619144615e-04
5449 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800993e+00 ||r(i)||/||b|| 2.081619144618e-04
5450 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5451 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800978e+00 ||r(i)||/||b|| 2.081619144614e-04
5452 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800983e+00 ||r(i)||/||b|| 2.081619144616e-04
5453 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
5454 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5455 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
5456 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800978e+00 ||r(i)||/||b|| 2.081619144614e-04
5457 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
5458 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800988e+00 ||r(i)||/||b|| 2.081619144617e-04
5459 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800970e+00 ||r(i)||/||b|| 2.081619144613e-04
5460 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5461 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5462 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5463 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144617e-04
5464 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800979e+00 ||r(i)||/||b|| 2.081619144615e-04
5465 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800982e+00 ||r(i)||/||b|| 2.081619144615e-04
5466 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
5467 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
5468 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800979e+00 ||r(i)||/||b|| 2.081619144615e-04
5469 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800983e+00 ||r(i)||/||b|| 2.081619144616e-04
5470 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
5471 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800987e+00 ||r(i)||/||b|| 2.081619144616e-04
5472 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
5473 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800979e+00 ||r(i)||/||b|| 2.081619144615e-04
5474 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800982e+00 ||r(i)||/||b|| 2.081619144615e-04
5475 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800985e+00 ||r(i)||/||b|| 2.081619144616e-04
5476 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
5477 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
5478 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800982e+00 ||r(i)||/||b|| 2.081619144615e-04
5479 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
5480 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5481 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800976e+00 ||r(i)||/||b|| 2.081619144614e-04
5482 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800977e+00 ||r(i)||/||b|| 2.081619144614e-04
5483 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800979e+00 ||r(i)||/||b|| 2.081619144615e-04
5484 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
5485 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800985e+00 ||r(i)||/||b|| 2.081619144616e-04
5486 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800989e+00 ||r(i)||/||b|| 2.081619144617e-04
5487 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
5488 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800985e+00 ||r(i)||/||b|| 2.081619144616e-04
5489 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800978e+00 ||r(i)||/||b|| 2.081619144614e-04
5490 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
5491 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800968e+00 ||r(i)||/||b|| 2.081619144612e-04
5492 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
5493 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
5494 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
5495 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
5496 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
5497 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
5498 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800970e+00 ||r(i)||/||b|| 2.081619144612e-04
5499 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800983e+00 ||r(i)||/||b|| 2.081619144616e-04
5500 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800969e+00 ||r(i)||/||b|| 2.081619144612e-04
5501 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
5502 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800974e+00 ||r(i)||/||b|| 2.081619144613e-04
5503 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800976e+00 ||r(i)||/||b|| 2.081619144614e-04
5504 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
5505 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800976e+00 ||r(i)||/||b|| 2.081619144614e-04
5506 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
5507 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800970e+00 ||r(i)||/||b|| 2.081619144612e-04
5508 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
5509 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800981e+00 ||r(i)||/||b|| 2.081619144615e-04
5510 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5511 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
5512 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800983e+00 ||r(i)||/||b|| 2.081619144616e-04
5513 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800970e+00 ||r(i)||/||b|| 2.081619144612e-04
5514 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800973e+00 ||r(i)||/||b|| 2.081619144613e-04
5515 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800976e+00 ||r(i)||/||b|| 2.081619144614e-04
5516 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800984e+00 ||r(i)||/||b|| 2.081619144616e-04
5517 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800982e+00 ||r(i)||/||b|| 2.081619144615e-04
5518 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800986e+00 ||r(i)||/||b|| 2.081619144616e-04
5519 KSP unpreconditioned resid norm 8.712485800974e+00 true resid norm 8.712485800971e+00 ||r(i)||/||b|| 2.081619144613e-04
5520 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800980e+00 ||r(i)||/||b|| 2.081619144615e-04
5521 KSP unpreconditioned resid norm 8.712485800980e+00 true resid norm 8.712485800975e+00 ||r(i)||/||b|| 2.081619144614e-04
5522 KSP unpreconditioned resid norm 8.712485800980e+00 true resid nor
