[petsc-users] Solution "jumps" after setting timestep
Constantinescu, Emil M. emconsta at anl.gov
Thu Dec 13 10:55:29 CST 2018
On 12/13/18 9:48 AM, Moritz.Huck--- via petsc-users wrote:
> If I set the next target time (in tssolve) to be tlast+1e-3 it looks
> like this:
How do you set the "next target time"? Are you using TSSetTimestep at
some discrete time points? If not then the adaptor will adjust it or
even ignore it (if the step is rejected).
Also did you set?
TSSetEquationType(ts,TS_EQ_DAE_IMPLICIT_INDEX1);
Emil
