[petsc-users] Solution "jumps" after setting timestep
    Emil Constantinescu
    emconsta at mcs.anl.gov
    Thu Dec 13 11:01:44 CST 2018
On 12/13/18 9:48 AM, Moritz.Huck--- via petsc-users wrote:
> If I set the next target time (in tssolve) to be tlast+1e-3 it looks
> like this:
How do you set the "next target time"? Are you using TSSetTimestep at
some discrete time points? If not then the adaptor will adjust it or
even ignore it (if the step is rejected).
Also did you set?
TSSetEquationType(ts,TS_EQ_DAE_IMPLICIT_INDEX1);
Emil
