[petsc-users] Periodic domains in DMPlex / petsc4py
    Artur Palha Da Silva Clérigo - LR
    A.PalhaDaSilvaClerigo at tudelft.nl
    Wed Dec 12 07:42:50 CST 2018
Dear All,
I having been trying to add periodic domain functionality to my code. I am able to generate a periodic mesh with gmsh and load it using dmplex. The problem is that I am unable to have a numbering of the degrees of freedom that reflects the periodicity (they are numbered as if there was no periodicity).
I read this thread: https://lists.mcs.anl.gov/mailman/htdig/petsc-users/2018-October/036539.html
There it is mentioned that DMLocalizeCoordinates is required after loading the mesh.
My questions are the following:
1. Is it correct that I need to run DMLocalizeCoordinates on my DM?
2. I am currently using petsc4py but I am unable to find DMLocalizeCoordinates. Is this functionality missing or is there an alternative to it?
Thank you for your time.
Kind regards,
-artur palha
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181212/1cff173f/attachment.html>
