[petsc-users] Solution "jumps" after setting timestep
Moritz.Huck at isea.rwth-aachen.de Moritz.Huck at isea.rwth-aachen.de
Wed Dec 12 04:09:27 CST 2018
sorry I missed the last response.
The system should be index 1 (being not a 100% certain I calculated
everything correct, it can be at most of index 2).
I cannot show the code easily, the code is quite complex (the system arises
from a FEM discretization).
As additional information the solution also jumps when the adaptive solver
reduces the timestep by a large amount.
Best Regards,
Moritz
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181212/19e5cb74/attachment.html>
Type: application/pkcs7-signature
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181212/19e5cb74/attachment.p7s>
