[petsc-users] How to output VTK file with Vec associating with DMPLEX
Sun Dec 9 19:30:54 CST 2018
On Sun, Dec 9, 2018 at 7:47 PM Tsung-Hsing Chen <barrydog505 at gmail.com>
wrote:
> So I need to manually create a PetscSection by using DMPlexCreateSection().
> Am I right?
No, you create it directly
DMPlexGetDepthStratum(dm, 0, &vStart, &vEnd);
PetscSectionCreate(PETSC_COMM_SELF, &s)
for (v = vStart; v < vEnd; ++v) {
  PetscSectionSetDof(s, v, 1);
DMSetSection(dm, s);
PetscSectionDestroy(&s);
   Matt
> Thanks,
> Barry
> Matthew Knepley <knepley at gmail.com> 於 2018年12月10日 週一 上午8:40寫道:
>> On Sun, Dec 9, 2018 at 7:31 PM Tsung-Hsing Chen <barrydog505 at gmail.com>
>> wrote:
>>> Vertex-based is what I want.
>>> Here I don't think I have created any PetscSection yet.
>>> Do I need to create the PetscSection,
>> Yes. There is a manual chapter with this in it.
>>> if I already have a mesh file from gmsh?
>> That is just topology and geometry. It says nothing about data layout.
>>> or just I simply use DMPlexGetConeSection() to get vertex-based vector?
>> That is a Section which describes the layout of topology data.
>>   Thanks,
>>      Matt
>>> Thanks,
>>> Barry
>>> Matthew Knepley <knepley at gmail.com> 於 2018年12月10日 週一 上午7:27寫道:
>>>> On Sun, Dec 9, 2018 at 5:47 PM Tsung-Hsing Chen via petsc-users <
>>>> petsc-users at mcs.anl.gov> wrote:
>>>>> Hi,
>>>>> I want to output a VTK file containing Vec which associate with
>>>>> DMPLEX, but I keep getting some errors.
>>>> The really easy way is to put
>>>>   ierr = VecViewFromOptions(x, NULL, "-myvec_view");CHKERRQ(ierr);
>>>> in your code and then give
>>>>   -myvec_view vtk:sol.vtk
>>>> on the command line.
>>>>> I use PetscViewerVTKOpen() to create the vtk file.
>>>>> Then I saw many examples just use DMCreateGlobalVector() to create the
>>>>> Vec associate with DM.
>>>>> However, almost all of them aren't DMPLEX but are DMDA.
>>>>> I don't know whether it will cause some problems.
>>>>> These is what I write:
>>>> 1) ALWAYS check return values. Your VecSetValue is failing.
>>>> 2) VTK can only display two kinds of information, vertex-based and
>>>> cell-based. DMDA only allows vertex based
>>>>     information in Vecs. Since DMPLEX allows any kind of distribution,
>>>> when we output VTK we need to determine
>>>>     what kind of vector we have, vertex-based or cell-based. Here I
>>>> cannot determine it, probably because your
>>>>     PetscSection is not setup correctly. How is data supposed to be
>>>> laid out on the Plex?
>>>>   Thanks,
>>>>      Matt
>>>>>   PetscViewerCreate(PETSC_COMM_WORLD, &viewer);
>>>>>   PetscViewerVTKOpen(PETSC_COMM_WORLD, "vtk_output_test.vtk",
>>>>> FILE_MODE_WRITE, &viewer);
>>>>>   DMCreateGlobalVector(dm, &x);
>>>>>   VecSetValue();   //Set value for x
>>>>>   VecView(x, viewer);
>>>>> Here is the error output:
>>>>> [0]PETSC ERROR: --------------------- Error Message
>>>>> [0]PETSC ERROR: Argument out of range
>>>>> [0]PETSC ERROR: Out of range index value 1 maximum 0
>>>>> [0]PETSC ERROR: See
>>>>> http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble
>>>>> shooting.
>>>>> [0]PETSC ERROR: Petsc Release Version 3.10.2, unknown
>>>>> [0]PETSC ERROR: ./test3 on a arch-linux2-c-debug named
>>>>> barry-PhysioMech by barry Mon Dec 10 05:52:19 2018
>>>>> [0]PETSC ERROR: Configure options --with-cc=gcc --with-cxx=g++
>>>>> --with-fc=gfortran --download-mpich --download-fblaslapack --download-mumps
>>>>> --download-scalapack --download-ctetgen
>>>>> [0]PETSC ERROR: #3 VecSetValues_Seq() line 726 in
>>>>> /home/barry/petsc/src/vec/vec/impls/seq/bvec2.c
>>>>> [0]PETSC ERROR: #4 VecSetValues() line 856 in
>>>>> /home/barry/petsc/src/vec/vec/interface/rvector.c
>>>>> [0]PETSC ERROR: Invalid argument
>>>>> [0]PETSC ERROR: Could not classify input Vec for VTK
>>>>> [0]PETSC ERROR: See
>>>>> shooting.
>>>>> [0]PETSC ERROR: #17 DMPlexGetFieldType_Internal() line 134 in
>>>>> /home/barry/petsc/src/dm/impls/plex/plex.c
>>>>> [0]PETSC ERROR: #18 VecView_Plex_Local_VTK() line 294 in
>>>>> [0]PETSC ERROR: #19 VecView_Plex_Local() line 335 in
>>>>> [0]PETSC ERROR: #20 VecView_Plex() line 382 in
>>>>> [0]PETSC ERROR: #21 VecView() line 590 in
>>>>> /home/barry/petsc/src/vec/vec/interface/vector.c
>>>>> I think the first part of the error comes from VecSetValue(), but I
>>>>> don't know how to fix it.
>>>>> And I totally don't know what its mean in the second part of the error.
>>>>> Thank you,
>>>>> Barry
>>>> What most experimenters take for granted before they begin their
>>>> experiments is infinitely more interesting than any results to which their
>>>> experiments lead.
>>>> -- Norbert Wiener
>>>> https://www.cse.buffalo.edu/~knepley/
>>>> <http://www.cse.buffalo.edu/~knepley/>
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181209/acfbd00b/attachment-0001.html>
