[petsc-users] How to output VTK file with Vec associating with DMPLEX
Tsung-Hsing Chen
barrydog505 at gmail.com
Sun Dec 9 18:46:39 CST 2018
So I need to manually create a PetscSection by using DMPlexCreateSection().
Am I right?
Barry
Matthew Knepley <knepley at gmail.com> 於 2018年12月10日 週一 上午8:40寫道:
> On Sun, Dec 9, 2018 at 7:31 PM Tsung-Hsing Chen <barrydog505 at gmail.com>
> wrote:
>> Vertex-based is what I want.
>> Here I don't think I have created any PetscSection yet.
>> Do I need to create the PetscSection,
> Yes. There is a manual chapter with this in it.
>> if I already have a mesh file from gmsh?
> That is just topology and geometry. It says nothing about data layout.
>> or just I simply use DMPlexGetConeSection() to get vertex-based vector?
> That is a Section which describes the layout of topology data.
> Thanks,
> Matt
>> Thanks,
>> Barry
>> Matthew Knepley <knepley at gmail.com> 於 2018年12月10日 週一 上午7:27寫道:
>>> On Sun, Dec 9, 2018 at 5:47 PM Tsung-Hsing Chen via petsc-users <
>>> petsc-users at mcs.anl.gov> wrote:
>>>> Hi,
>>>> I want to output a VTK file containing Vec which associate with DMPLEX,
>>>> but I keep getting some errors.
>>> The really easy way is to put
>>> ierr = VecViewFromOptions(x, NULL, "-myvec_view");CHKERRQ(ierr);
>>> in your code and then give
>>> -myvec_view vtk:sol.vtk
>>> on the command line.
>>>> I use PetscViewerVTKOpen() to create the vtk file.
>>>> Then I saw many examples just use DMCreateGlobalVector() to create the
>>>> Vec associate with DM.
>>>> However, almost all of them aren't DMPLEX but are DMDA.
>>>> I don't know whether it will cause some problems.
>>>> These is what I write:
>>> 1) ALWAYS check return values. Your VecSetValue is failing.
>>> 2) VTK can only display two kinds of information, vertex-based and
>>> cell-based. DMDA only allows vertex based
>>> information in Vecs. Since DMPLEX allows any kind of distribution,
>>> when we output VTK we need to determine
>>> what kind of vector we have, vertex-based or cell-based. Here I
>>> cannot determine it, probably because your
>>> PetscSection is not setup correctly. How is data supposed to be laid
>>> out on the Plex?
>>> Thanks,
>>> Matt
>>>> PetscViewerCreate(PETSC_COMM_WORLD, &viewer);
>>>> PetscViewerVTKOpen(PETSC_COMM_WORLD, "vtk_output_test.vtk",
>>>> FILE_MODE_WRITE, &viewer);
>>>> DMCreateGlobalVector(dm, &x);
>>>> VecSetValue(); //Set value for x
>>>> VecView(x, viewer);
>>>> Here is the error output:
>>>> [0]PETSC ERROR: --------------------- Error Message
>>>> [0]PETSC ERROR: Argument out of range
>>>> [0]PETSC ERROR: Out of range index value 1 maximum 0
>>>> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
>>>> for trouble shooting.
>>>> [0]PETSC ERROR: Petsc Release Version 3.10.2, unknown
>>>> [0]PETSC ERROR: ./test3 on a arch-linux2-c-debug named barry-PhysioMech
>>>> by barry Mon Dec 10 05:52:19 2018
>>>> [0]PETSC ERROR: Configure options --with-cc=gcc --with-cxx=g++
>>>> --with-fc=gfortran --download-mpich --download-fblaslapack --download-mumps
>>>> --download-scalapack --download-ctetgen
>>>> [0]PETSC ERROR: #3 VecSetValues_Seq() line 726 in
>>>> /home/barry/petsc/src/vec/vec/impls/seq/bvec2.c
>>>> [0]PETSC ERROR: #4 VecSetValues() line 856 in
>>>> /home/barry/petsc/src/vec/vec/interface/rvector.c
>>>> [0]PETSC ERROR: Invalid argument
>>>> [0]PETSC ERROR: Could not classify input Vec for VTK
>>>> [0]PETSC ERROR: #17 DMPlexGetFieldType_Internal() line 134 in
>>>> /home/barry/petsc/src/dm/impls/plex/plex.c
>>>> [0]PETSC ERROR: #18 VecView_Plex_Local_VTK() line 294 in
>>>> [0]PETSC ERROR: #19 VecView_Plex_Local() line 335 in
>>>> [0]PETSC ERROR: #20 VecView_Plex() line 382 in
>>>> [0]PETSC ERROR: #21 VecView() line 590 in
>>>> /home/barry/petsc/src/vec/vec/interface/vector.c
>>>> I think the first part of the error comes from VecSetValue(), but I
>>>> don't know how to fix it.
>>>> And I totally don't know what its mean in the second part of the error.
>>>> Thank you,
>>>> Barry
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
>>> https://www.cse.buffalo.edu/~knepley/
>>> <http://www.cse.buffalo.edu/~knepley/>
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181210/129010df/attachment.html>
